[Swift-commit] r7777 - in branches/release-0.94/src/org/griphyn/vdl: karajan mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Apr 17 20:29:19 CDT 2014
Author: hategan
Date: 2014-04-17 20:29:19 -0500 (Thu, 17 Apr 2014)
New Revision: 7777
Added:
   branches/release-0.94/src/org/griphyn/vdl/mapping/FutureArrayOpen.java
Modified:
   branches/release-0.94/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/ArrayDataNode.java
Log:
fix for busy loop when waiting for a full array for which some elements are available
Modified: branches/release-0.94/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java
--- branches/release-0.94/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2014-04-17 20:56:54 UTC (rev 7776)
+++ branches/release-0.94/src/org/griphyn/vdl/karajan/ArrayIndexFutureList.java	2014-04-18 01:29:19 UTC (rev 7777)
@@ -121,15 +121,19 @@
     public DSHandle getHandle() {
         return node;
+    public void addModificationAction(FutureListener target, VariableStack stack) {
+        addModificationAction(target, stack, true);
-    public void addModificationAction(FutureListener target, VariableStack stack) {
+    public void addModificationAction(FutureListener target, VariableStack stack, boolean partialUpdates) {
         synchronized(node) {
             if (listeners == null) {
                 listeners = new LinkedList<ListenerStackPair>();
             listeners.add(new ListenerStackPair(target, stack));
             WaitingThreadsMonitor.addThread(stack, node);
-            if (!node.isClosed() && keys.isEmpty()) {
+            if (!node.isClosed() && (keys.isEmpty() || !partialUpdates)) {
                 return;
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/ArrayDataNode.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2014-04-17 20:56:54 UTC (rev 7776)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/ArrayDataNode.java	2014-04-18 01:29:19 UTC (rev 7777)
@@ -38,7 +38,7 @@
 	public void getFringePaths(List<Path> list, Path parentPath) throws HandleOpenException {
 		checkMappingException();
 		if (!isClosed()) {
-		    throw new FutureNotYetAvailable(getFutureWrapper());
+		    throw new FutureArrayOpen((ArrayIndexFutureList) getFutureWrapper());
 		Map<Comparable<?>, DSHandle> handles = getHandles();
 		synchronized (this) {
@@ -55,7 +55,7 @@
-	/** Recursively closes arrays through a tree of arrays and complex
+    /** Recursively closes arrays through a tree of arrays and complex
         types. */
     public void closeDeep() {
         assert(this.getType().isArray());
@@ -121,6 +121,22 @@
         return (FutureList) getFutureWrapper();
+    @Override
+    public synchronized void waitFor() {
+        if (!isClosed()) {
+            if (logger.isDebugEnabled()) {
+                logger.debug("Waiting for " + this);
+        else {
+                logger.debug("Do not need to wait for " + this);
+            checkDataException();
     protected void getFields(List<DSHandle> fields, Path path) throws InvalidPathException {
         if (path.isEmpty()) {
             fields.add(this);
Added: branches/release-0.94/src/org/griphyn/vdl/mapping/FutureArrayOpen.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/FutureArrayOpen.java	                        (rev 0)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/FutureArrayOpen.java	2014-04-18 01:29:19 UTC (rev 7777)
@@ -0,0 +1,61 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Apr 17, 2014
+package org.griphyn.vdl.mapping;
+import org.globus.cog.karajan.stack.VariableStack;
+import org.globus.cog.karajan.workflow.futures.Future;
+import org.globus.cog.karajan.workflow.futures.FutureEvaluationException;
+import org.globus.cog.karajan.workflow.futures.FutureListener;
+import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
+import org.griphyn.vdl.karajan.ArrayIndexFutureList;
+public class FutureArrayOpen extends FutureNotYetAvailable {
+    public FutureArrayOpen(ArrayIndexFutureList f) {
+        super(new Wrapper(f));
+    @Override
+    public Future getFuture() {
+        return super.getFuture();
+    private static class Wrapper implements Future {
+        private final ArrayIndexFutureList f;
+        public Wrapper(ArrayIndexFutureList f) {
+            this.f = f;
+        @Override
+        public void close() {
+            f.close();
+        @Override
+        public boolean isClosed() {
+            return f.isClosed();
+        @Override
+        public Object getValue() {
+            return f.getValue();
+        @Override
+        public void fail(FutureEvaluationException e) {
+            f.fail(e);
+        @Override
+            f.addModificationAction(target, stack, false);
