[Swift-commit] r7770 - in SwiftApps/tryswift: . css
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Apr 16 16:07:52 CDT 2014
Author: davidk
Date: 2014-04-16 16:07:51 -0500 (Wed, 16 Apr 2014)
New Revision: 7770
Modified:
   SwiftApps/tryswift/css/tryswift.css
   SwiftApps/tryswift/getfiles.php
   SwiftApps/tryswift/index.php
   SwiftApps/tryswift/tryswift.php
Log:
Various updates to tryswift - remove twitter bootstrap, layout changes
Modified: SwiftApps/tryswift/css/tryswift.css
--- SwiftApps/tryswift/css/tryswift.css	2014-04-16 17:51:49 UTC (rev 7769)
+++ SwiftApps/tryswift/css/tryswift.css	2014-04-16 21:07:51 UTC (rev 7770)
@@ -1,79 +1,44 @@
-#header {
-   text-align: center;
+#body,html {
+   height: 100%;
-#infoFrame {
-   width: 100%;
-   background: white;
-   overflow-y: scroll;
+a {
+   text-decoration: none
-#editor {
-   width: 100%;
-   height: 50%;
 #scriptNav {
-   position: relative;
-   left: 25%;
-   right: 25%;
    width: 100%;
-#scriptDropdown {
-   top: 5px;
-.b0b0 {
-   background: #b0b0b0;
    border: 1px solid black;
+   float: left;
+   line-height: 2em;
-#editorContainer {
+#editor {
+   width: 100%;
+   height: 30%;
-   border-bottom: 0px;
-#executeButton {
-   left: 47px;
-   width: 100px;
-   font-size: 1.2em;
-#resetButton {
-   left: 44px;
-   width: 100px;
-   font-size: 1.2em;
 #editorButtons {
-   background: #fbf1d3;
+   width: 100%;
+   border: 1px solid black;
-#pre {
-   background: #fff;
-   margin: 0;
-   padding: 0;
+#swiftOutputDiv {
+   width: 100%;
-#fileOutput {
-   width: 100%;
-   overflow-x: hidden;
-   background: #fff;
+#example {
+   float: left;
-#swiftOutput {
-   border: 1px solid black;
-   background: #fff;
+#explanation {
+   float: left;
+   padding-left: 20px;
+   top:50%
-#.ace_editor {
-  line-height: normal;
+#outputs {
+   visibility: hidden;
Modified: SwiftApps/tryswift/getfiles.php
--- SwiftApps/tryswift/getfiles.php	2014-04-16 17:51:49 UTC (rev 7769)
+++ SwiftApps/tryswift/getfiles.php	2014-04-16 21:07:51 UTC (rev 7770)
@@ -1,5 +1,4 @@
 <?PHP
 $dir = $_POST['dir'];
 $web_directory = "/home/tryswift/tryswift";
 chdir("$web_directory/$dir");
@@ -31,7 +30,8 @@
            $size = filesize($file);
            #$type = shell_exec("file -b $file");
-           print "<div class=\"span2\"><a href=\"$dir/$file\" target=\"_blank\">$file</a> [$size bytes]</div>\n";
+           # print "<div class=\"span2\"><a href=\"$dir/$file\" target=\"_blank\">$file</a> [$size bytes]</div>\n";
+           print "<option value=\"$dir/$file\">$file</option>\n";
Modified: SwiftApps/tryswift/index.php
--- SwiftApps/tryswift/index.php	2014-04-16 17:51:49 UTC (rev 7769)
+++ SwiftApps/tryswift/index.php	2014-04-16 21:07:51 UTC (rev 7770)
@@ -2,58 +2,48 @@
 <html lang="en">
    <head>
       <title>Try Swift</title>
-      <link href="css/tryswift.css" rel="stylesheet" media="screen">
-      <link href="css/bootstrap.min.css" rel="stylesheet" media="screen">
+      <link rel="stylesheet" type="text/css" href="css/tryswift.css">
    </head>
    <body>
-      <div class="container-fluid">
+      <div id="scriptNav">
+         <div id="example">
+            Example:
+            <select id="scriptDropdown">
+            </select>
+         </div>
+         <div id="explain">
+         </div>
+      </div> <!-- scriptNav -->
+      <!-- Swift code editor -->
+      <div id="editor">
+         <script src="js/ace/ace.js" type="text/javascript" charset="utf-8"></script>
+         <script>
+            var editor = ace.edit("editor");
+            editor.setFontSize('13px');
+            editor.setTheme("ace/theme/solarized_light");
+            editor.getSession().setMode("ace/mode/text");
+            editor.setShowPrintMargin(false);
+            editor.setHighlightActiveLine(false);
+            editor.setDisplayIndentGuides(false);
+         </script>
+      </div> <!-- editor -->
-         <!-- Script navigation -->
-         <div class="row-fluid">
-            <div id="infoContainer" class="span4 b0b0">
-               <div id="scriptNav">
-                  <select id="scriptDropdown">
-                  </select>
-               </div> <!-- scriptNav -->
-               <iframe id="infoFrame"></iframe>
-            </div> <!-- infoContainer -->
-            <!-- Code editor -->
-            <div id="editorContainer" class="span8">
-               <div id="editor">
-                  <script src="js/ace/ace.js" type="text/javascript" charset="utf-8"></script>
-                  <script>
-                     var editor = ace.edit("editor");
-                     editor.setFontSize('13px');
-                     editor.setTheme("ace/theme/solarized_light");
-                     editor.getSession().setMode("ace/mode/text");
-                     editor.setShowPrintMargin(false);
-                     editor.setHighlightActiveLine(false);
-                     editor.setDisplayIndentGuides(false);
-                  </script>
-               </div> <!-- editor -->
-               <div id="editorButtons">
-                  <button id="executeButton">Execute</button>
-                  <button id="resetButton">Reset</button>
-               </div> <!-- editorButtons -->
-            </div> <!-- editorContainer -->
-         </div> <!-- row -->
+     <!-- Execute and reset buttons -->
+     <div id="editorButtons">
+        <button id="executeButton">Execute</button>
+        <button id="resetButton">Reset</button>
+        <select id="outputs">
+           <option>File outputs</option>
+        </select>
+     </div> <!-- editorButtons -->
+     <!-- Textual swift output and ticker -->
+     <div id="swiftOutputDiv">
+        <pre id="swiftOutput"></pre>
+     </div> <!-- swiftOutputDiv -->
-            <div class="span12">
-               <pre id="swiftOutput">Swift output</pre>
-            </div> <!-- span12 -->
-               <div id="fileOutput"> Output files</div>
-         </div> <!-- row-fluid -->
-      </div> <!-- container -->
       <script>
          var scriptCounter=0;
          var scripts=[
@@ -78,29 +68,44 @@
       <script src="http://code.jquery.com/jquery-1.10.1.min.js"></script>
       <script src="js/logtail.js"></script>
       <script type="text/javascript">
+      // Popup a new browser window in center of screen
+      function popupwindow(url, name, w, h) {
+         var left = (screen.width/2)-(w/2);
+         var top = (screen.height/2)-(h/2);
+         return window.open(url, name, 'width='+w+', height='+h+', top='+top+', left='+left);
+      // Fill editor with script selected from dropdown
       function updateScript(index) {
          $.get(scripts[index][0], null, function (data) {
             editor.setValue(data);
             editor.gotoLine(1);
          }, "text");
-         $('#infoFrame').attr('src', scripts[index][2]);
+         $('#explain').html("<button id=\"explainButton\" value=\"" + scripts[index][2] + "\">Explain</button>");
       function resize() {
-         $('#editor').height( $(document).height() / 2 );
-         $('#infoContainer').height( $('#editorContainer').height() );
-         $('#infoFrame').height( $('#infoContainer').height() - $('#scriptDropdown').height()-5 );
-         $('#swiftOutput').height( $(document).height() * .20 );
-         $('#fileOutput').height( $(document).height() * .19 );
-         $('#fileOutput').width( $(document).width() );
+         $('#editor').height( $(document).height() * .55 );
+         $('#swiftOutputDiv').height( $(document).height() * .35 );
+      function hideOutputs() {
+         $('#outputs').css('visibility', 'hidden');
+      function showOutputs() {
+         $('#outputs').css('visibility', 'visible');
       $(document).ready(function() {
          resize();
          updateScript(0);
          $(window).resize(function() { resize(); });
-         $('#resetButton').click(function() { updateScript(); })
+         $('#resetButton').click(function() {
+            updateScript($('#scriptDropdown').find('option:selected').index());
+            hideOutputs();
          $.each(scripts, function(key, value) {
@@ -111,21 +116,33 @@
          $('#scriptDropdown').change(function() {
             updateScript($(this).find('option:selected').index());
+            hideOutputs();
+         $(document).on("change", "#outputs", function(){
+            popupwindow($('#outputs').val(), '', 800, 600);
+            // $('#swiftOutput').load($("#outputs").val());
+         $(document).on("click", "#explainButton", function(){
+            popupwindow($(this).attr("value"), $(this).text(), 800, 600);
+            return false;
          $('#executeButton').click(function() {
            sourceCode=editor.getSession().getValue();
            if(!sourceCode) {
               alert("Source text is empty!");
               return false;
+           $('#outputs').html('<option>File outputs</option>');
            $.post("tryswift.php", {source: sourceCode}).done(function(data) {
-              $('#fileOutput').html("");
               var urlArray = data.split("\n");
               tailf(urlArray[0], "#swiftOutput");
               $.post("getfiles.php", {dir: urlArray[1]}).done(function(filedata) {
-                 $('#fileOutput').html(filedata);
+                 $('#outputs').append(filedata);
+                 showOutputs();
Modified: SwiftApps/tryswift/tryswift.php
--- SwiftApps/tryswift/tryswift.php	2014-04-16 17:51:49 UTC (rev 7769)
+++ SwiftApps/tryswift/tryswift.php	2014-04-16 21:07:51 UTC (rev 7770)
@@ -27,7 +27,7 @@
    # Run Swift
-   system("echo Executing.. > $dirname/swift.out");
+   system("echo Swift run starting at $( date +%T ) > $dirname/swift.out");
    system("$swift_cmd >> $dirname/swift.out 2>&1 &");
    print "runs/$unique/swift.out\n";
