[Swift-commit] r7768 - in trunk: resources src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Tue Apr 15 04:17:21 CDT 2014
Author: hategan
Date: 2014-04-15 04:17:17 -0500 (Tue, 15 Apr 2014)
New Revision: 7768
Modified:
   trunk/resources/swiftscript.g
   trunk/src/org/griphyn/vdl/engine/Karajan.java
Log:
fixed wrong procedure call prediction in parser and deal with the issue in the compiler (bug 1239)
Modified: trunk/resources/swiftscript.g
--- trunk/resources/swiftscript.g	2014-04-12 21:33:33 UTC (rev 7767)
+++ trunk/resources/swiftscript.g	2014-04-15 09:17:17 UTC (rev 7768)
@@ -653,36 +653,19 @@
     id=identifier
     ASSIGN
-      (predictProcedurecallAssign) => code=procedurecallCode
-        { StringTemplate o = template("returnParam");
-          o.setAttribute("name",id);
-          code.setAttribute("outputs",o);
-      code=variableAssign
-          code.setAttribute("lhs",id);
+    code=variableAssign {
+		code.setAttribute("lhs",id);
 appendStat returns [ StringTemplate code = null ]
 	{ StringTemplate id=null; }
     id=identifier
     APPEND
-    	(predictProcedurecallAssign) => code=procedurecallCode {
-    		StringTemplate o = template("returnParam");
-      	code=arrayAppend {
-			code.setAttribute("array", id);
+	code=arrayAppend {
+		code.setAttribute("array", id);
 arrayAppend returns [ StringTemplate code = null ]
@@ -705,9 +688,6 @@
-predictProcedurecallAssign
-    : ID LPAREN ;
 procedurecallCode returns [StringTemplate code=template("call")]
 {StringTemplate f=null;}
Modified: trunk/src/org/griphyn/vdl/engine/Karajan.java
--- trunk/src/org/griphyn/vdl/engine/Karajan.java	2014-04-12 21:33:33 UTC (rev 7767)
+++ trunk/src/org/griphyn/vdl/engine/Karajan.java	2014-04-15 09:17:17 UTC (rev 7768)
@@ -597,47 +597,67 @@
 	public void assign(Assign assign, VariableScope scope) throws CompilationException {
 		try {
-			StringTemplate assignST = template("assign");
-			StringTemplate varST = expressionToKarajan(assign.getAbstractExpressionArray(0), scope, true);
-			String lValueType = datatype(varST);
-			StringTemplate valueST = expressionToKarajan(assign.getAbstractExpressionArray(1), scope, false, lValueType);
-			String rValueType = datatype(valueST);
-			if (isAnyType(lValueType)) {
-			    if (isAnyType(rValueType)) {
-			        // any <- any
-			    else {
-			        // any <- someType, so infer lValueType as rValueType
-			        setDatatype(varST, rValueType);
-			else {
-			        // someType <- any
-			        // only expressions that are allowed to return 'any' are procedures
-			        // for example readData(ret, file). These are special procedures that
-			        // need to look at the return type at run-time.
-			    else if (!lValueType.equals(rValueType)){
-			        throw new CompilationException("You cannot assign value of type " + rValueType +
-                        " to a variable of type " + lValueType);
-			assignST.setAttribute("var", varST);
-			assignST.setAttribute("value", valueST);
-			assignST.setAttribute("line", getLine(assign));
-			String rootvar = abstractExpressionToRootVariable(assign.getAbstractExpressionArray(0));
-			scope.addWriter(rootvar, getRootVariableWriteType(assign.getAbstractExpressionArray(0)), assign, assignST);
-			scope.appendStatement(assignST);
+		    XmlObject value = assign.getAbstractExpressionArray(1);
+            if (isCall(value)) {
+                Call call = (Call) value;
+                ActualParameter out = call.addNewOutput();
+                XmlObject src = assign.getAbstractExpressionArray(0);
+                out.getDomNode().appendChild(src.getDomNode());
+                call(call, scope, false);
+            else {
+    			StringTemplate assignST = template("assign");
+    			StringTemplate varST = expressionToKarajan(assign.getAbstractExpressionArray(0), scope, true);
+    			String lValueType = datatype(varST);
+    			StringTemplate valueST = expressionToKarajan(assign.getAbstractExpressionArray(1), scope, false, lValueType);
+    			String rValueType = datatype(valueST);
+    			if (isAnyType(lValueType)) {
+    			    if (isAnyType(rValueType)) {
+    			        // any <- any
+    			    else {
+    			        // any <- someType, so infer lValueType as rValueType
+    			        setDatatype(varST, rValueType);
+    			else {
+    			        // someType <- any
+    			        // only expressions that are allowed to return 'any' are procedures
+    			        // for example readData(ret, file). These are special procedures that
+    			        // need to look at the return type at run-time.
+    			    else if (!lValueType.equals(rValueType)){
+    			        throw new CompilationException("You cannot assign value of type " + rValueType +
+                            " to a variable of type " + lValueType);
+    			assignST.setAttribute("var", varST);
+    			assignST.setAttribute("value", valueST);
+    			assignST.setAttribute("line", getLine(assign));
+    			String rootvar = abstractExpressionToRootVariable(assign.getAbstractExpressionArray(0));
+    			scope.addWriter(rootvar, getRootVariableWriteType(assign.getAbstractExpressionArray(0)), assign, assignST);
+    			scope.appendStatement(assignST);
 		} catch(CompilationException re) {
 			throw new CompilationException("Compile error in assignment at "+assign.getSrc()+": "+re.getMessage(),re);
+    private boolean isCall(XmlObject value) {
+        Node expressionDOM = value.getDomNode();
+        String namespaceURI = expressionDOM.getNamespaceURI();
+        String localName = expressionDOM.getLocalName();
+        QName expressionQName = new QName(namespaceURI, localName);
+        return expressionQName.equals(CALL_EXPR);
     private boolean isAnyType(String type) {
         return ProcedureSignature.ANY.equals(type);
