[Swift-commit] r7053 - in SwiftApps/tryswift: . scripts
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Sep 10 15:33:02 CDT 2013
Author: davidk
Date: 2013-09-10 15:33:02 -0500 (Tue, 10 Sep 2013)
New Revision: 7053
Added:
   SwiftApps/tryswift/index.php
   SwiftApps/tryswift/scripts/p1.swift
   SwiftApps/tryswift/scripts/p2.swift
   SwiftApps/tryswift/scripts/p3.swift
   SwiftApps/tryswift/scripts/p4.swift
   SwiftApps/tryswift/scripts/p5.swift
   SwiftApps/tryswift/scripts/p6.swift
Removed:
   SwiftApps/tryswift/index.html
   SwiftApps/tryswift/scripts/arrays.swift
   SwiftApps/tryswift/scripts/capitalise.swift
   SwiftApps/tryswift/scripts/capitalise_anonymous.swift
   SwiftApps/tryswift/scripts/default.swift
   SwiftApps/tryswift/scripts/fixed_array_mapper.swift
   SwiftApps/tryswift/scripts/foreach.swift
   SwiftApps/tryswift/scripts/hello.swift
   SwiftApps/tryswift/scripts/if.swift
   SwiftApps/tryswift/scripts/manyparam.swift
   SwiftApps/tryswift/scripts/my_first_mapper.swift
   SwiftApps/tryswift/scripts/parameter.swift
   SwiftApps/tryswift/scripts/regexp_mapper.swift
   SwiftApps/tryswift/scripts/restart.swift
   SwiftApps/tryswift/scripts/sequential_iteration.swift
   SwiftApps/tryswift/scripts/sleep.swift
   SwiftApps/tryswift/scripts/types.swift
Log:
Dynamic generation of available scripts based on contents of scripts/ directory
Use tutorial scripts from swift-cray-tutorial
Deleted: SwiftApps/tryswift/index.html
--- SwiftApps/tryswift/index.html	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/index.html	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,86 +0,0 @@
-<html>
-   <link rel="stylesheet" type="text/css" href="tryswift.css">
-   <head>
-      <title>Try Swift</title>
-   </head>
-   <body>
-      <div id="header">
-      <hr>
-      Try Swift
-      <hr>
-      </div>
-      <div id="wrap">
-      <div id="wrapHeader">
-         <br>
-         Enter your Swift code below
-      </div>
-      <form name="sourceForm" action="http://54.212.60.65:8080/tryswift.php" method="POST">
-         <div id="textAreaDiv">
-            <textarea id="source" name="source" spellcheck="false" wrap="physical"></textarea><br>
-         </div>
-         <div id="progsDiv">
-         <div id="progsDivText">
-            Example Programs<br><br>
-            <ul>
-            <li><input type="radio" name="existingApplications" value="scripts/hello.swift" onclick="addtext()">hello.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/manyparam.swift" onclick="addtext()">manyparam.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/capitalise.swift" onclick="addtext()">capitalise.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/default.swift" onclick="addtext()">default.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/if.swift" onclick="addtext()">if.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/parameter.swift" onclick="addtext()">parameter.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/sleep.swift" onclick="addtext()">sleep.swift</li>
-            <li><input type="radio" name="existingApplications" value="scripts/types.swift" onclick="addtext()">types.swift</li>
-            </ul>
-         </div>
-         </div>
-         <div id="submitButton">
-            <input type="submit" name="submit" value="Submit" />
-         </div>
-         <div id="appsDiv">
-         <div id="appsDivText">
-            Available Applications<br><br>
-            <ul>
-            <li>echo</li>
-            <li>cat</li>
-            <li>ls</li>
-            <li>grep</li>
-            <li>sort</li>
-            <li>paste</li>
-            <li>cp</li>
-            <li>touch</li>
-            <li>wc</li>
-            <li>sleep</li>
-            </ul>
-         </div>
-         </div>
-      </form>
-      </div>
-      <script type="text/javascript">
-         function addtext() {
-            var filePath = "http://swiftlang.org/tryswift/" + getRadioValue();
-            var xmlhttp = new XMLHttpRequest();
-            xmlhttp.open("GET", filePath, false);
-            xmlhttp.send(null);
-            var fileContent = xmlhttp.responseText;
-            document.getElementById('source').value = fileContent;
-         function getRadioValue() {
-            var l = sourceForm.existingApplications.length;
-            var radio_value;
-            for(var i=0; i<l; i++) {
-               if(sourceForm.existingApplications[i].checked)
-                  radio_value = sourceForm.existingApplications[i].value;
-            return radio_value;
-      </script>
-      </div>
-   </body>
-</html>
Added: SwiftApps/tryswift/index.php
--- SwiftApps/tryswift/index.php	                        (rev 0)
+++ SwiftApps/tryswift/index.php	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,94 @@
+<html>
+   <link rel="stylesheet" type="text/css" href="tryswift.css">
+   <head>
+      <title>Try Swift</title>
+   </head>
+   <body>
+      <div id="header">
+      <hr>
+      Try Swift
+      <hr>
+      </div>
+      <div id="wrap">
+      <div id="wrapHeader">
+         <br>
+         Enter your Swift code below
+      </div>
+      <form name="sourceForm" action="http://54.212.60.65:8080/tryswift.php" method="POST">
+         <div id="textAreaDiv">
+            <textarea id="source" name="source" spellcheck="false" wrap="physical"></textarea><br>
+         </div>
+         <div id="progsDiv">
+         <div id="progsDivText">
+            Example Programs<br><br>
+            <ul>
+            <?php
+               $scriptFiles = array();
+               $directory = opendir("scripts");
+               while($script = readdir($directory)) {
+                  if(substr($script, -6) == ".swift") {
+                     $scriptFiles[] = $script;
+               closedir($directory);
+               sort($scriptFiles);
+               foreach($scriptFiles as $script) {
+                  echo "<li><input type=\"radio\" name=\"existingApplications\" value=\"scripts/$script\" onclick=\"addtext()\">$script</li>\n";
+            </ul>
+         </div>
+         </div>
+         <div id="submitButton">
+            <input type="submit" name="submit" value="Submit" />
+         </div>
+         <div id="appsDiv">
+         <div id="appsDivText">
+            Available Applications<br><br>
+            <ul>
+            <li>echo</li>
+            <li>cat</li>
+            <li>ls</li>
+            <li>grep</li>
+            <li>sort</li>
+            <li>paste</li>
+            <li>cp</li>
+            <li>touch</li>
+            <li>wc</li>
+            <li>sleep</li>
+            </ul>
+         </div>
+         </div>
+      </form>
+      </div>
+      <script type="text/javascript">
+         function addtext() {
+            var filePath = "http://swiftlang.org/tryswift/" + getRadioValue();
+            var xmlhttp = new XMLHttpRequest();
+            xmlhttp.open("GET", filePath, false);
+            xmlhttp.send(null);
+            var fileContent = xmlhttp.responseText;
+            document.getElementById('source').value = fileContent;
+         function getRadioValue() {
+            var l = sourceForm.existingApplications.length;
+            var radio_value;
+            for(var i=0; i<l; i++) {
+               if(sourceForm.existingApplications[i].checked)
+                  radio_value = sourceForm.existingApplications[i].value;
+            return radio_value;
+      </script>
+      </div>
+   </body>
+</html>
Deleted: SwiftApps/tryswift/scripts/arrays.swift
--- SwiftApps/tryswift/scripts/arrays.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/arrays.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,12 +0,0 @@
-type messagefile;
-app (messagefile t) greeting (string s[]) {
-     echo s[0] s[1] s[2] stdout=@filename(t);
-messagefile outfile <"arrays.txt">;
-string words[] = ["how","are","you"];
-outfile = greeting(words);
Deleted: SwiftApps/tryswift/scripts/capitalise.swift
--- SwiftApps/tryswift/scripts/capitalise.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/capitalise.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,14 +0,0 @@
-type messagefile;
-app (messagefile t) greeting (string s) {
-    echo s stdout=@filename(t);
-app (messagefile o) capitalise(messagefile i) {
-    tr "[a-z]" "[A-Z]" stdin=@filename(i) stdout=@filename(o);
-messagefile hellofile <"capitalise.1.txt">;
-messagefile final <"capitalise.2.txt">;
-hellofile = greeting("hello from Swift");
-final = capitalise(hellofile);
Deleted: SwiftApps/tryswift/scripts/capitalise_anonymous.swift
--- SwiftApps/tryswift/scripts/capitalise_anonymous.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/capitalise_anonymous.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,14 +0,0 @@
-type messagefile;
-messagefile hellofile;
-messagefile final <"capitalise_anonymous.txt">;
Deleted: SwiftApps/tryswift/scripts/default.swift
--- SwiftApps/tryswift/scripts/default.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/default.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,15 +0,0 @@
-type file;
-// s has a default value
-app (file t) echo (string s="hello world") {
-file hw1<"default.1.txt">;
-file hw2<"default.2.txt">;
-// procedure call using the default value
-hw1 = echo();
-// using a different value
-hw2 = echo(s="hello again");
Deleted: SwiftApps/tryswift/scripts/fixed_array_mapper.swift
--- SwiftApps/tryswift/scripts/fixed_array_mapper.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/fixed_array_mapper.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,16 +0,0 @@
-type messagefile;
-type countfile;
-app (countfile t) countwords (messagefile f) {
-   wc "-w" @filename(f) stdout=@filename(t);
-string inputNames = "fixed_array_mapper.1.txt fixed_array_mapper.2.txt fixed_array_mapper.3.txt";
-string outputNames = "fixed_array_mapper.1.count fixed_array_mapper.2.count fixed_array_mapper.3.count";
-messagefile inputfiles[] <fixed_array_mapper;files=inputNames>;
-countfile outputfiles[] <fixed_array_mapper;files=outputNames>;
-outputfiles[0] = countwords(inputfiles[0]);
-outputfiles[1] = countwords(inputfiles[1]);
-outputfiles[2] = countwords(inputfiles[2]);
Deleted: SwiftApps/tryswift/scripts/foreach.swift
--- SwiftApps/tryswift/scripts/foreach.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/foreach.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,18 +0,0 @@
-type messagefile;
-type countfile;
-string inputNames = "foreach.1.txt foreach.2.txt foreach.3.txt";
-foreach f in inputfiles {
-  countfile c<regexp_mapper;
-	    source=@f,
-            match="(.*)txt",
-            transform="\\1count">;
-  c = countwords(f);
Deleted: SwiftApps/tryswift/scripts/hello.swift
--- SwiftApps/tryswift/scripts/hello.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/hello.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,10 +0,0 @@
-type messagefile;
-app (messagefile t) greeting() {
-    echo "Hello, world!" stdout=@filename(t);
-messagefile outfile <"hello.txt">;
-outfile = greeting();
Deleted: SwiftApps/tryswift/scripts/if.swift
--- SwiftApps/tryswift/scripts/if.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/if.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,16 +0,0 @@
-type messagefile;
-messagefile outfile <"if.txt">;
-boolean morning = true;
-if(morning) {
-  outfile = greeting("good morning");
-} else {
-  outfile = greeting("good afternoon");
Deleted: SwiftApps/tryswift/scripts/manyparam.swift
--- SwiftApps/tryswift/scripts/manyparam.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/manyparam.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,13 +0,0 @@
-type messagefile;
-messagefile english <"manyparam.english.txt">;
-messagefile french <"manyparam.french.txt">;
-messagefile japanese <"manyparam.japanese.txt">;
-english = greeting("hello");
-french = greeting("bonjour");
-japanese = greeting("konnichiwa");
Deleted: SwiftApps/tryswift/scripts/my_first_mapper.swift
--- SwiftApps/tryswift/scripts/my_first_mapper.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/my_first_mapper.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,9 +0,0 @@
-type messagefile;
-        echo "hello" stdout=@filename(t);
-messagefile outfile <my_first_mapper>;
Added: SwiftApps/tryswift/scripts/p1.swift
--- SwiftApps/tryswift/scripts/p1.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p1.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,9 @@
+type file;
+app (file o) simulation ()
+  simulate stdout=@filename(o);
+file f <"sim.out">;
+f = simulation();
Added: SwiftApps/tryswift/scripts/p2.swift
--- SwiftApps/tryswift/scripts/p2.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p2.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,11 @@
+type file;
+foreach i in [0:9] {
+  file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  f = simulation();
Added: SwiftApps/tryswift/scripts/p3.swift
--- SwiftApps/tryswift/scripts/p3.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p3.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,27 @@
+type file;
+app (file o) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@filename(o);
+app (file o) analyze (file s[])
+  stats @filenames(s) stdout=@filename(o);
+int nsim   = @toInt(@arg("nsim","10"));
+int steps  = @toInt(@arg("steps","1"));
+int range  = @toInt(@arg("range","100"));
+int values = @toInt(@arg("values","5"));
+file sims[];
+foreach i in [0:nsim-1] {
+  file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  simout = simulation(steps,range,values);
+  sims[i] = simout;
+file stats<"output/average.out">;
+stats = analyze(sims);
Added: SwiftApps/tryswift/scripts/p4.swift
--- SwiftApps/tryswift/scripts/p4.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p4.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,29 @@
+type file;
+app (file out, file log) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@out stderr=@log;
+app (file out, file log) analyze (file s[])
+  stats @filenames(s) stdout=@out stderr=@log;
+int nsim   = @toInt(@arg("nsim",   "10"));
+int steps  = @toInt(@arg("steps",  "1"));
+int range  = @toInt(@arg("range",  "100"));
+int values = @toInt(@arg("values", "5"));
+file sims[];
+  file simlog <single_file_mapper; file=@strcat("output/sim_",i,".log")>;
+  (simout,simlog) = simulation(steps,range,values);
+  sims[i] = simout;
+file stats_out<"output/average.out">;
+file stats_log<"output/average.log">;
+(stats_out, stats_log) = analyze(sims);
Added: SwiftApps/tryswift/scripts/p5.swift
--- SwiftApps/tryswift/scripts/p5.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p5.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,29 @@
+type file;
+file sims[];
+  sims[i] = simout;
Added: SwiftApps/tryswift/scripts/p6.swift
--- SwiftApps/tryswift/scripts/p6.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/p6.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -0,0 +1,57 @@
+type file;
+# app() functions for application programs to be called:
+app (file out) genseed (int nseeds)
+  genseed "-r" 2000000 "-n" nseeds stdout=@out;
+app (file out) genbias (int bias_range, int nvalues)
+  genbias "-r" bias_range "-n" nvalues stdout=@out;
+app (file out, file log) simulation (int timesteps, int sim_range,
+                                     file bias_file, int scale, int sim_count)
+  simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
+           "-n" sim_count stdout=@out stderr=@log;
+# Command line arguments
+int  nsim  = @toInt(@arg("nsim",   "10"));  # number of simulation programs to run
+int  steps = @toInt(@arg("steps",  "1"));   # number of timesteps (seconds) per simulation
+int  range = @toInt(@arg("range",  "100")); # range of the generated random numbers
+int  values = @toInt(@arg("values", "10"));  # number of values generated per simulation
+# Main script and data
+tracef("\n*** Script parameters: nsim=%i range=%i num values=%i\n\n", nsim, range, values);
+file seedfile<"output/seed.dat">;        # Dynamically generated bias for simulation ensemble
+seedfile = genseed(1);
+int seedval = readData(seedfile);
+tracef("Generated seed=%i\n", seedval);
+file sims[];                      # Array of files to hold each simulation output
+  file biasfile <single_file_mapper; file=@strcat("output/bias_",i,".dat")>;
+  biasfile = genbias(1000, 20);
+  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values);
+  sims[i] = simout;
+(stats_out,stats_log) = analyze(sims);
Deleted: SwiftApps/tryswift/scripts/parameter.swift
--- SwiftApps/tryswift/scripts/parameter.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/parameter.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,8 +0,0 @@
-type messagefile;
-messagefile outfile <"parameter.hello.txt">;
-outfile = greeting("hello world");
Deleted: SwiftApps/tryswift/scripts/regexp_mapper.swift
--- SwiftApps/tryswift/scripts/regexp_mapper.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/regexp_mapper.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,16 +0,0 @@
-type messagefile;
-type countfile;
-messagefile inputfile <"regexp_mapper.words.txt">;
-countfile c <regexp_mapper;
-	    source=@inputfile,
-            match="(.*)txt",
-c = countwords(inputfile);
Deleted: SwiftApps/tryswift/scripts/restart.swift
--- SwiftApps/tryswift/scripts/restart.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/restart.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,24 +0,0 @@
-type file;
-app (file f) touch() {
-    touch @f;
-app (file f) processL(file inp) {
-    echo "processL" stdout=@f;
-app (file f) processR(file inp) {
-    broken "process" stdout=@f;
-app (file f) join(file left, file right) {
-    echo "join" @left @right stdout=@f;
-file f = touch();
-file g = processL(f);
-file h = processR(f);
-file i = join(g,h);
Deleted: SwiftApps/tryswift/scripts/sequential_iteration.swift
--- SwiftApps/tryswift/scripts/sequential_iteration.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/sequential_iteration.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,18 +0,0 @@
-type counterfile;
-app (counterfile t) echo(string m) {
-    echo m stdout=@filename(t);
-app (counterfile t) countstep(counterfile i) {
-    wcl @filename(i) @filename(t);
-counterfile a[]  <simple_mapper;prefix="sequential_iteration.foldout">;
-a[0] = echo("793578934574893");
-iterate v {
-  a[v+1] = countstep(a[v]);
- trace("extract int value ", at extractint(a[v+1]));
-} until (@extractint(a[v+1]) <= 1);
Deleted: SwiftApps/tryswift/scripts/sleep.swift
--- SwiftApps/tryswift/scripts/sleep.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/sleep.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,9 +0,0 @@
-type file;
-app sleep (int s) {
-     sleep s;
-foreach f in [1:5] {
-   sleep(30);
Deleted: SwiftApps/tryswift/scripts/types.swift
--- SwiftApps/tryswift/scripts/types.swift	2013-09-10 19:41:45 UTC (rev 7052)
+++ SwiftApps/tryswift/scripts/types.swift	2013-09-10 20:33:02 UTC (rev 7053)
@@ -1,20 +0,0 @@
-type messagefile;
-type details {
-    string name;
-    int pies;
-app (messagefile t) greeting (details d) {
-    echo "Hello. Your name is" d.name "and you have eaten" d.pies "pies." stdout=@filename(t);
-details person;
-person.name = "John";
-person.pies = 3;
-messagefile outfile <"types.pies.txt">;
-outfile = greeting(person);
