[Swift-commit] r7038 - trunk/src/org/griphyn/vdl/util
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Sep 6 18:23:21 CDT 2013
Author: hategan
Date: 2013-09-06 18:23:21 -0500 (Fri, 06 Sep 2013)
New Revision: 7038
Added:
   trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
Modified:
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
Log:
validate entries in swift.properties when loading
Added: trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
--- trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2013-09-06 23:23:21 UTC (rev 7038)
@@ -0,0 +1,108 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Sep 6, 2013
+package org.griphyn.vdl.util;
+import java.io.File;
+import java.util.Collection;
+import java.util.Iterator;
+import java.util.SortedSet;
+import java.util.TreeSet;
+public abstract class ConfigPropertyType {
+    public static final ConfigPropertyType BOOLEAN = choices("true", "false");
+    public static final ConfigPropertyType ONOFF = choices("on", "off");
+    public static final ConfigPropertyType STRING = new CPTString();
+    public static final ConfigPropertyType INT = new Int();
+    public static final ConfigPropertyType FLOAT = new CPTFloat();
+    public static final ConfigPropertyType FILE = new CPTFile();
+    public static ConfigPropertyType choices(String... values) {
+        return new Choices(values);
+    public abstract void checkValue(String propName, String value);
+    private static String pp(Collection<String> c) {
+        StringBuilder sb = new StringBuilder();
+        Iterator<String> i = c.iterator();
+        while (i.hasNext()) {
+            sb.append('\'');
+            sb.append(i.next());
+            sb.append('\'');
+            if (i.hasNext()) {
+                sb.append(", ");
+        return sb.toString();
+    private static class Choices extends ConfigPropertyType {
+        private SortedSet<String> choices;
+        public Choices(String... values) {
+            choices = new TreeSet<String>();
+            for (String value : values) {
+                choices.add(value);
+        @Override
+        public void checkValue(String propName, String value) {
+            if (!choices.contains(value)) {
+                throw new IllegalArgumentException("Invalid value '" + value + "' for property '" +
+                    propName + "'. Valid values are: " + pp(choices));
+    private static class CPTString extends ConfigPropertyType {
+        @Override
+            // all values accepted
+    private static class Int extends ConfigPropertyType {
+        @Override
+            try {
+                Integer.parseInt(value);
+            catch (NumberFormatException e) {
+                    propName + "'. Must be an integer");
+    private static class CPTFloat extends ConfigPropertyType {
+        @Override
+            try {
+                Double.parseDouble(value);
+                    propName + "'. Must be a floating point number.");
+    private static class CPTFile extends ConfigPropertyType {
+        @Override
+            File f = new File(value);
+            if (!f.exists()) {
+                    propName + "'. File does not exist.");
Modified: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2013-09-06 23:22:27 UTC (rev 7037)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2013-09-06 23:23:21 UTC (rev 7038)
@@ -24,12 +24,13 @@
 import java.io.FileInputStream;
 import java.io.FileNotFoundException;
 import java.io.IOException;
+import java.util.HashMap;
 import java.util.LinkedList;
 import java.util.List;
+import java.util.Map;
 import java.util.Properties;
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.util.BoundContact;
 import org.globus.common.CoGProperties;
@@ -82,44 +83,47 @@
 	private List<String> files, tried;
+	private Map<Object, ConfigPropertyType> types;
 	private VDL2Config() {
 		files = new LinkedList<String>();
 		tried = new LinkedList<String>();
-		put(VDL2ConfigProperties.POOL_FILE, "${vds.home}/etc/sites.xml");
-		put(VDL2ConfigProperties.TC_FILE, "${vds.home}/var/tc.data");
-		put(VDL2ConfigProperties.LAZY_ERRORS, "false");
-		put(VDL2ConfigProperties.CACHING_ALGORITHM, "LRU");
-		put(VDL2ConfigProperties.PGRAPH, "false");
-		put(VDL2ConfigProperties.PGRAPH_GRAPH_OPTIONS, "splines=\"compound\", rankdir=\"TB\"");
-		put(VDL2ConfigProperties.PGRAPH_NODE_OPTIONS, "color=\"seagreen\", style=\"filled\"");
-		put(VDL2ConfigProperties.CLUSTERING_ENABLED, "false");
-		put(VDL2ConfigProperties.CLUSTERING_QUEUE_DELAY, "4");
-		put(VDL2ConfigProperties.CLUSTERING_MIN_TIME, "60");
-		put(VDL2ConfigProperties.KICKSTART_ENABLED, "maybe");
-		put(VDL2ConfigProperties.KICKSTART_ALWAYS_TRANSFER, "false");
-		put("throttle.submit", "4");
-		put("throttle.host.submit", "2");
-		put("throttle.transfers", "4");
-		put("throttle.file.operations", "8");
-		put("throttle.score.job.factor", "4");
-		put(VDL2ConfigProperties.SITEDIR_KEEP, "false");
-		put(VDL2ConfigProperties.PROVENANCE_LOG, "false");
+		types = new HashMap<Object, ConfigPropertyType>();
+		put(VDL2ConfigProperties.POOL_FILE, "${swift.home}/etc/sites.xml", ConfigPropertyType.FILE);
+		put(VDL2ConfigProperties.TC_FILE, "${swift.home}/etc/tc.data", ConfigPropertyType.FILE);
+		put(VDL2ConfigProperties.LAZY_ERRORS, "false", ConfigPropertyType.BOOLEAN);
+		put(VDL2ConfigProperties.CACHING_ALGORITHM, "LRU", ConfigPropertyType.STRING);
+		put(VDL2ConfigProperties.PGRAPH, "false", ConfigPropertyType.BOOLEAN);
+		put(VDL2ConfigProperties.PGRAPH_GRAPH_OPTIONS, "splines=\"compound\", rankdir=\"TB\"", ConfigPropertyType.STRING);
+		put(VDL2ConfigProperties.PGRAPH_NODE_OPTIONS, "color=\"seagreen\", style=\"filled\"", ConfigPropertyType.STRING);
+		put(VDL2ConfigProperties.CLUSTERING_ENABLED, "false", ConfigPropertyType.BOOLEAN);
+		put(VDL2ConfigProperties.CLUSTERING_QUEUE_DELAY, "4", ConfigPropertyType.INT);
+		put(VDL2ConfigProperties.CLUSTERING_MIN_TIME, "60", ConfigPropertyType.INT);
+		put(VDL2ConfigProperties.KICKSTART_ENABLED, "maybe", ConfigPropertyType.choices("true", "false", "maybe"));
+		put(VDL2ConfigProperties.KICKSTART_ALWAYS_TRANSFER, "false", ConfigPropertyType.BOOLEAN);
+		put("throttle.submit", "4", ConfigPropertyType.INT);
+		put("throttle.host.submit", "2", ConfigPropertyType.INT);
+		put("throttle.transfers", "4", ConfigPropertyType.INT);
+		put("throttle.file.operations", "8", ConfigPropertyType.INT);
+		put("throttle.score.job.factor", "4", ConfigPropertyType.FLOAT);
+		put(VDL2ConfigProperties.SITEDIR_KEEP, "false", ConfigPropertyType.BOOLEAN);
+		put(VDL2ConfigProperties.PROVENANCE_LOG, "false", ConfigPropertyType.BOOLEAN);
-		put("replication.enabled", "false");
-		put("replication.min.queue.time", "60");
-		put("replication.limit", "3");
-		put("status.mode", "files");
-		put("wrapper.parameter.mode", "args");
-		put("wrapper.invocation.mode", "absolute");
+		put("replication.enabled", "false", ConfigPropertyType.BOOLEAN);
+		put("replication.min.queue.time", "60", ConfigPropertyType.INT);
+		put("replication.limit", "3", ConfigPropertyType.INT);
+		put("status.mode", "files", ConfigPropertyType.choices("files", "provider"));
+		put("wrapper.parameter.mode", "args", ConfigPropertyType.choices("args", "files"));
+		put("wrapper.invocation.mode", "absolute", ConfigPropertyType.choices("absolute", "relative"));
+		// TODO what are the valid values here?
 		put("cdm.broadcast.mode", "file");
-		put("use.provider.staging", "false");
-		put("ticker.date.format", "");
-		put("ticker.prefix", "Progress:  time:");
+		put("use.provider.staging", "false", ConfigPropertyType.BOOLEAN);
+		put("ticker.date.format", "", ConfigPropertyType.STRING);
+		put("ticker.prefix", "Progress:  time:", ConfigPropertyType.STRING);
-		put(VDL2ConfigProperties.FILE_GC_ENABLED, "true");
-		put(VDL2ConfigProperties.DM_CHECKER, "on");
+		put(VDL2ConfigProperties.FILE_GC_ENABLED, "true", ConfigPropertyType.BOOLEAN);
+		put(VDL2ConfigProperties.DM_CHECKER, "on", ConfigPropertyType.ONOFF);
 	private VDL2Config(VDL2Config other) {
@@ -156,6 +160,11 @@
 			return this;
+	public synchronized Object put(Object key, Object value, ConfigPropertyType type) {
+	    types.put(key, type);
+	    return put(key, value);
 	 * Overridden to do variable expansion. Variables will be expanded if there
@@ -165,6 +174,7 @@
 	public synchronized Object put(Object key, Object value) {
 		String svalue = (String) value;
 		if (svalue.indexOf("${") == -1) {
+		    checkType(key, value);
 			return super.put(key, value);
 		else {
@@ -197,11 +207,20 @@
 			sb.append(svalue.substring(last));
-			return super.put(key, sb.toString());
+			value = sb.toString();
+			return super.put(key, value);
-	public String getPoolFile() {
+	private void checkType(Object key, Object value) {
+	    ConfigPropertyType type = types.get(key);
+	    if (type != null) {
+	        type.checkValue((String) key, (String) value);
+    public String getPoolFile() {
 		return getProperty(VDL2ConfigProperties.POOL_FILE);
