[Swift-commit] cog r3770
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Sep 2 03:40:04 CDT 2013
r3770 | hategan | 2013-09-02 03:36:43 -0500 (Mon, 02 Sep 2013) | 1 line
only use auto CA if no standard proxy is present (expired or not) (port from 0.94)
Index: modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java	(revision 3769)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/impl/execution/coaster/ServiceManager.java	(working copy)
@@ -55,6 +55,7 @@
 import org.globus.cog.coaster.commands.Command;
 import org.globus.cog.coaster.commands.Command.Callback;
 import org.globus.common.CoGProperties;
+import org.globus.common.CoGProperties;
 import org.ietf.jgss.GSSCredential;
 public class ServiceManager implements StatusListener {
@@ -224,11 +225,27 @@
     private void setupGSIProxy() throws IOException, GeneralSecurityException {
-        AutoCA.Info result = AutoCA.getInstance().createProxy();
-        System.setProperty("X509_USER_PROXY", result.proxyPath);
-        System.setProperty("X509_CERT_DIR", result.caCertPath);
+        if (!checkStandardProxy()) {
+             *  only do the automatic CA if a standard proxy file does not exist
+             *  to allow using things like GridFTP from the coaster service through
+             *  delegation (which won't work with the auto-generated proxy).
+            logger.info("No standard proxy found. Using AutoCA.");
+            AutoCA.Info result = AutoCA.getInstance().createProxy();
+            System.setProperty("X509_USER_PROXY", result.proxyPath);
+            System.setProperty("X509_CERT_DIR", result.caCertPath);
+        else {
+            logger.info("Standard proxy file found. Disabling AutoCA.");
+    private boolean checkStandardProxy() {
+        File proxy = new File(CoGProperties.getDefault().getProxyFile());
+        return proxy.exists();
     private void setSecurityContext(Task t, SecurityContext sc, String provider)
             throws InvalidProviderException, ProviderMethodException {
         t.getService(0).setSecurityContext(AbstractionFactory.getSecurityContext(provider, t.getService(0).getServiceContact()));
