[Swift-commit] cog r3829
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Nov 4 17:10:16 CST 2013
r3829 | yadunand | 2013-11-04 17:06:30 -0600 (Mon, 04 Nov 2013) | 7 lines
Added a polling routine to poll instead of wait for job completion.
Tests added to confirm behavior.
I see two apps running in parallel under the same coaster-client from
the tcl tests.
Index: modules/provider-coaster-c-client/src/CoasterSWIG.h
--- modules/provider-coaster-c-client/src/CoasterSWIG.h	(revision 3828)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.h	(working copy)
@@ -28,6 +28,8 @@
 int CoasterSWIGWaitForJob(CoasterClient *client, Job* job);
+int CoasterSWIGGetJobStatus(CoasterClient *client, Job* job);
 int CoasterSWIGTest(CoasterLoop *loop, char *service_URL, CoasterClient *c);
 //int CoasterSWIGTest(CoasterLoop *loop, char *service_URL);
Index: modules/provider-coaster-c-client/src/CoasterSWIG.cpp
--- modules/provider-coaster-c-client/src/CoasterSWIG.cpp	(revision 3828)
+++ modules/provider-coaster-c-client/src/CoasterSWIG.cpp	(working copy)
@@ -129,12 +129,16 @@
     if ( strlen(args) != 0 ){
         std::vector<string> arg_vector = parse_string(string(args));
         for (std::vector<string>::iterator i = arg_vector.begin(); i != arg_vector.end(); i++ ){
             j->addArgument(*i);
             cout << "Attr ["<< *i <<"]" <<endl;
+        j->addArgument(args);
     // Untested code block ahead.
     if ( strlen(attr) != 0 ){
@@ -169,18 +173,25 @@
 int CoasterSWIGSubmitJob(CoasterClient *client, Job* job)
     client->submit(*job);
-    client->waitForJob(*job);
-    int status = job->getStatus()->getStatusCode();
-    cout << "SubmitJob returns code :" << status << endl;
     return 0;
 int CoasterSWIGWaitForJob(CoasterClient *client, Job *job)
-    return 0;
+    int status = job->getStatus()->getStatusCode();
+    cout << "SubmitJob returns code :" << status << endl;
+    return status;
+int CoasterSWIGGetJobStatus(CoasterClient *client, Job *job)
+    //    cerr << "Job status message     :" << job->getStatus()->getMessage() << endl;
+    return status;
  * This is a test function.
Index: modules/provider-coaster-c-client/README
--- modules/provider-coaster-c-client/README	(revision 3828)
+++ modules/provider-coaster-c-client/README	(working copy)
@@ -2,3 +2,6 @@
 To build with SWIG :
 ./configure --enable-swig --with-tcl-version=<Tcl_version> --with-tcl=<Path to tcl installation>
+./configure --enable-swig --with-tcl-version=8.5 --with-tcl=/home/wozniak/Public/tcl-8.5\
+.12-x86_64
\ No newline at end of file
Index: modules/provider-coaster-c-client/tests/tcl/wrapper.sh
--- modules/provider-coaster-c-client/tests/tcl/wrapper.sh	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/wrapper.sh	(revision 3829)
@@ -0,0 +1,13 @@
+#!/bin/bash
+if [[ $1 == "" ]]; then
+    sleep_time=5
+else
+    sleep_time=$1
+fi
+date
+sleep $sleep_time;
+echo "This is process $$"
+echo "Hostname : $(hostname -f)"
+date
Property changes on: modules/provider-coaster-c-client/tests/tcl/wrapper.sh
___________________________________________________________________
Added: svn:executable
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-0.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-0.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-0.tcl	(revision 3829)
@@ -0,0 +1,4 @@
+load ../../src/.libs/libcoasterclient.so
+set loop_ptr [CoasterSWIGLoopCreate]
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-8.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-8.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-8.tcl	(revision 3829)
@@ -0,0 +1,24 @@
+package require coaster 0.0
+set client_ptr [CoasterSWIGClientCreate $loop_ptr 140.221.8.81:58318]
+set x [CoasterSWIGClientSettings $client_ptr "SLOTS=1,MAX_NODES=1,JOBS_PER_NODE=2"]
+puts "Error code from CoasterSWIGClientSettings $x"
+# Job stuff
+set job1 [CoasterSWIGJobCreate "/bin/echo"]
+puts "Job set to /bin/hostname"
+set rcode [CoasterSWIGJobSettings $job1 "" "hello world how are you \$USERNAME \$RANDOM \$HOSTNAME" "" "" \
+                                  "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stdout" \
+                                  "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stderr" ]
+set rcode [CoasterSWIGSubmitJob $client_ptr $job1]
+puts "Job1 submitted"
+puts "Waiting for Job1"
+set rcode [CoasterSWIGWaitForJob $client_ptr $job1]
+puts "Job1 complete"
+set rcode [CoasterSWIGClientDestroy $client_ptr]
+set rcode [CoasterSWIGLoopDestroy $loop_ptr]
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-9.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-9.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-9.tcl	(revision 3829)
@@ -0,0 +1,24 @@
+# Job stuff
+set rcode [CoasterSWIGJobSettings $job1 "" "hello world how are you \\\$USERNAME \\\$RANDOM \\\$HOSTNAME" "" "" \
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-11.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-11.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-11.tcl	(revision 3829)
@@ -0,0 +1,44 @@
+set client_ptr [CoasterSWIGClientCreate $loop_ptr 140.221.8.81:45822]
+# Job stuff
+set job1 [CoasterSWIGJobCreate "/bin/bash"]
+puts "Job cmd set"
+set stdout_dst "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stdout"
+set stderr_dst "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stderr"
+set arg_script "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/wrapper.sh"
+set rcode [CoasterSWIGJobSettings $job1 "" $arg_script "" "" \
+               $stdout_dst $stderr_dst]
+# Anything less that 100ms seems to cause a segfault.
+# Maybe the buffers that are used aren't initialised till that wait time.?
+# Why ?
+after 100
+while 1 {
+    set rcode [CoasterSWIGGetJobStatus $client_ptr $job1]
+    if { $rcode == 5 } {
+        puts "Job1 failed"
+        break
+    } elseif { $rcode == 7 } {
+        puts "Job1 completed successfully"
+        break
+    } else {
+        puts "Rcode  : $rcode"
+        after 5000
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-12.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-12.tcl	(revision 0)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-12.tcl	(revision 3829)
@@ -0,0 +1,45 @@
+# Job stuff
+set job2 [CoasterSWIGJobCreate "/bin/bash"]
+puts "Job cmd set"
+set stdout_dst1 "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stdout1"
+set stderr_dst1 "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stderr1"
+set stdout_dst2 "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stdout2"
+set stderr_dst2 "/homes/yadunand/swift-trunk/cog/modules/provider-coaster-c-client/tests/tcl/stderr2"
+               $stdout_dst1 $stderr_dst1]
+set rcode [CoasterSWIGJobSettings $job2 "" $arg_script "" "" \
+               $stdout_dst2 $stderr_dst2]
+set rcode [CoasterSWIGSubmitJob $client_ptr $job2]
+# Why ?
+after 100
+while 1 {
+    set rcode1 [CoasterSWIGGetJobStatus $client_ptr $job1]
+    set rcode2 [CoasterSWIGGetJobStatus $client_ptr $job2]
+    if { $rcode1 == 7 && $rcode2 == 7 } {
+        puts "Job1 and Job2 completed"
+        break
+    } else {
+        puts "Job1 : $rcode1 , Job2 : $rcode2"
+        after 2000
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-4.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-4.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-4.tcl	(working copy)
@@ -1,4 +1,4 @@
-load ../../src/.libs/libcoasterclient.so
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-5.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-5.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-5.tcl	(working copy)
@@ -1,4 +1,4 @@
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-6.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-6.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-6.tcl	(working copy)
@@ -1,4 +1,4 @@
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-7.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-7.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-7.tcl	(working copy)
@@ -1,4 +1,4 @@
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-1.tcl	(working copy)
@@ -1,4 +1,6 @@
+#load ../../src/.libs/libcoasterclient.so
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-10.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-10.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-10.tcl	(working copy)
@@ -1,11 +1,27 @@
-set client_ptr [CoasterSWIGClientCreate $loop_ptr 140.221.8.81:40568]
+# Job stuff
-set result [CoasterSWIGTest $loop_ptr 140.221.8.81:40568 $client_ptr ]
-#set result [CoasterSWIGTest $client_ptr]
+set rcode [CoasterSWIGJobSettings $job1 "" "hello,world, how are you" "" "" \
-#set x [CoasterSWIGClientSettings $client_ptr "SLOTS=1,MAX_NODES=1"]
Index: modules/provider-coaster-c-client/tests/tcl/README
--- modules/provider-coaster-c-client/tests/tcl/README	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/README	(working copy)
@@ -1,5 +1,10 @@
-Run start-coaster-service in the coasters folder to start a coaster service.
+Here are few quick steps to do before running the Tcl tests:
+1. Run start-coaster-service in the coasters folder to start a coaster service.
 The configuration for coasters is in coaster-service.conf
-Use the url in the sites.xml generated in the tcl examples to connect to the
-coaster service
+2. Use the url in the sites.xml generated in the tcl examples to connect to the
+coaster service
+3. export the folder where the pkgIndex.tcl is present as TCLLIBPATH
+    export TCLLIBPATH="cog/modules/provider-coaster-c-client/tcl"
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-2.tcl	(working copy)
@@ -1,4 +1,4 @@
 set client_ptr [CoasterSWIGClientCreate $loop_ptr "140.221.8.81:40568"]
Index: modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl
--- modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl	(revision 3828)
+++ modules/provider-coaster-c-client/tests/tcl/coaster-test-3.tcl	(working copy)
@@ -1,4 +1,4 @@
Index: modules/provider-coaster-c-client/tests/coasters/sites.xml
--- modules/provider-coaster-c-client/tests/coasters/sites.xml	(revision 3828)
+++ modules/provider-coaster-c-client/tests/coasters/sites.xml	(working copy)
@@ -1,7 +1,7 @@
 <?xml version="1.0" encoding="UTF-8"?>
 <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
   <pool handle="persistent-coasters">
-    <execution provider="coaster-persistent" url="http://140.221.8.81:58318" jobmanager="local:local"/>
+    <execution provider="coaster-persistent" url="http://140.221.8.81:45822" jobmanager="local:local"/>
     <profile namespace="globus" key="workerManager">passive</profile>
     <profile namespace="globus" key="jobsPerNode">4</profile>
     <profile key="jobThrottle" namespace="karajan">100</profile>
Index: modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log
--- modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log	(revision 3828)
+++ modules/provider-coaster-c-client/tests/coasters/start-coaster-service.log	(working copy)
@@ -1,4803 +1,126625 @@
-Running /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/coaster-service -nosec -portfile /tmp/tmp.KmXG9rMorq -localportfile /tmp/tmp.D9N8ytVG6b -passive
-Switching log to: cps-2013-10-28_14-31-16.log
-2013-10-28 14:31:16,524-0500 WARN  CoasterPersistentService Switching log to: cps-2013-10-28_14-31-16.log
-Local contacts: [http://140.221.8.81:56573]
-2013-10-28 14:31:16,602-0500 INFO  Settings Local contacts: [http://140.221.8.81:56573]
-Starting... id=1028-3102160
-2013-10-28 14:31:16,615-0500 INFO  BlockQueueProcessor Starting... id=1028-3102160
-Started local service: http://140.221.8.81:56573
-2013-10-28 14:31:16,615-0500 INFO  CoasterService Started local service: http://140.221.8.81:56573
-Started coaster service: http://140.221.8.81:58318
-2013-10-28 14:31:16,615-0500 INFO  CoasterService Started coaster service: http://140.221.8.81:58318
-Worker connection URL: http://140.221.8.81:56573
+Running /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/coaster-service -nosec -portfile /tmp/tmp.A7AQ7iQhzq -localportfile /tmp/tmp.ebb56AbhlO -passive
+Switching log to: cps-2013-10-31_14-40-39.log
+2013-10-31 14:40:39,736-0500 WARN  CoasterPersistentService Switching log to: cps-2013-10-31_14-40-39.log
+Local contacts: [http://140.221.8.81:59510]
+2013-10-31 14:40:39,818-0500 INFO  Settings Local contacts: [http://140.221.8.81:59510]
+Starting... id=1031-4002390
+2013-10-31 14:40:39,831-0500 INFO  BlockQueueProcessor Starting... id=1031-4002390
+Started local service: http://140.221.8.81:59510
+2013-10-31 14:40:39,832-0500 INFO  CoasterService Started local service: http://140.221.8.81:59510
+Started coaster service: http://140.221.8.81:34959
+2013-10-31 14:40:39,832-0500 INFO  CoasterService Started coaster service: http://140.221.8.81:34959
+Worker connection URL: http://140.221.8.81:59510
 Running ssh yadunand at crush.mcs.anl.gov mkdir -p /homes/yadunand
 Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at crush.mcs.anl.gov:/homes/yadunand
-Running ssh yadunand at crush.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:56573 crush.mcs.anl.gov /homes/yadunand/logs
+Running ssh yadunand at crush.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:59510 crush.mcs.anl.gov /homes/yadunand/logs
 Running ssh yadunand at grind.mcs.anl.gov mkdir -p /homes/yadunand
+Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at grind.mcs.anl.gov:/homes/yadunand
 Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-10-28 14:31:18,748-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.62:34285]
-2013-10-28 14:31:18,753-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.62:34285]
+2013-10-31 14:40:42,247-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+Channel started: TCPChannel [type: server, contact: 140.221.8.62:34731]
+2013-10-31 14:40:42,252-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.62:34731]
 Received registration: blockid = crush.mcs.anl.gov, url = crush
-2013-10-28 14:31:18,758-0500 INFO  LocalTCPService Received registration: blockid = crush.mcs.anl.gov, url = crush
-MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:34285]
-2013-10-28 14:31:18,780-0500 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:34285]
-Running scp /homes/yadunand/swift-trunk/cog/modules/swift/dist/swift-svn/bin/worker.pl yadunand at grind.mcs.anl.gov:/homes/yadunand
-2013-10-28 14:31:18,784-0500 DEBUG Cpu worker started: block=crush.mcs.anl.gov host=crush id=0
-2013-10-28 14:31:18,784-0500 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
-Started CPU 0:1382988678s
-2013-10-28 14:31:18,786-0500 INFO  Block Started CPU 0:1382988678s
+2013-10-31 14:40:42,257-0500 INFO  LocalTCPService Received registration: blockid = crush.mcs.anl.gov, url = crush
+MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:34731]
+2013-10-31 14:40:42,278-0500 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.62:34731]
+2013-10-31 14:40:42,282-0500 DEBUG Cpu worker started: block=crush.mcs.anl.gov host=crush id=0
+2013-10-31 14:40:42,282-0500 DEBUG Cpu ready for work: block=crush.mcs.anl.gov id=0
+Started CPU 0:1383248442s
+2013-10-31 14:40:42,283-0500 INFO  Block Started CPU 0:1383248442s
+2013-10-31 14:40:42,283-0500 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
 Started worker crush.mcs.anl.gov:000000
-2013-10-28 14:31:18,786-0500 INFO  Block Started worker crush.mcs.anl.gov:000000
-2013-10-28 14:31:18,786-0500 DEBUG Cpu requesting work: block=crush.mcs.anl.gov id=0 Cpus sleeping: 1
+2013-10-31 14:40:42,283-0500 INFO  Block Started worker crush.mcs.anl.gov:000000
 Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-10-28 14:31:18,786-0500 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
-2013-10-28 14:31:18,787-0500 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
-Handler(tag: 9512, REGISTER) unregistering (send)
-2013-10-28 14:31:18,791-0500 INFO  RequestHandler Handler(tag: 9512, REGISTER) unregistering (send)
-Running ssh yadunand at grind.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:56573 grind.mcs.anl.gov /homes/yadunand/logs
+2013-10-31 14:40:42,284-0500 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: crush.mcs.anl.gov-000000]
+2013-10-31 14:40:42,284-0500 DEBUG Cpu crush.mcs.anl.gov:0 sleeping
+Handler(tag: 9449, REGISTER) unregistering (send)
+2013-10-31 14:40:42,288-0500 INFO  RequestHandler Handler(tag: 9449, REGISTER) unregistering (send)
+Running ssh yadunand at grind.mcs.anl.gov WORKER_LOGGING_LEVEL=DEBUG /homes/yadunand/worker.pl http://140.221.8.81:59510 grind.mcs.anl.gov /homes/yadunand/logs
 Adjusting buffer size to 8650752 for 2 sockets
-2013-10-28 14:31:19,639-0500 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
+2013-10-31 14:40:43,780-0500 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
-2013-10-28 14:31:19,639-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-Channel started: TCPChannel [type: server, contact: 140.221.8.74:39025]
-2013-10-28 14:31:19,639-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.74:39025]
+2013-10-31 14:40:43,780-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+Channel started: TCPChannel [type: server, contact: 140.221.8.74:44741]
+2013-10-31 14:40:43,780-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.74:44741]
 Received registration: blockid = grind.mcs.anl.gov, url = grind
-2013-10-28 14:31:19,639-0500 INFO  LocalTCPService Received registration: blockid = grind.mcs.anl.gov, url = grind
-MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:39025]
-2013-10-28 14:31:19,640-0500 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:39025]
-2013-10-28 14:31:19,640-0500 DEBUG Cpu worker started: block=grind.mcs.anl.gov host=grind id=0
-2013-10-28 14:31:19,640-0500 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
-Started CPU 0:1382988679s
-2013-10-28 14:31:19,640-0500 INFO  Block Started CPU 0:1382988679s
-2013-10-28 14:31:19,640-0500 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
+2013-10-31 14:40:43,781-0500 INFO  LocalTCPService Received registration: blockid = grind.mcs.anl.gov, url = grind
+MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:44741]
+2013-10-31 14:40:43,781-0500 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.74:44741]
+2013-10-31 14:40:43,781-0500 DEBUG Cpu worker started: block=grind.mcs.anl.gov host=grind id=0
+2013-10-31 14:40:43,781-0500 DEBUG Cpu ready for work: block=grind.mcs.anl.gov id=0
+Started CPU 0:1383248443s
+2013-10-31 14:40:43,782-0500 INFO  Block Started CPU 0:1383248443s
+2013-10-31 14:40:43,782-0500 DEBUG Cpu requesting work: block=grind.mcs.anl.gov id=0 Cpus sleeping: 2
 Started worker grind.mcs.anl.gov:000000
-2013-10-28 14:31:19,640-0500 INFO  Block Started worker grind.mcs.anl.gov:000000
-2013-10-28 14:31:19,640-0500 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
-Handler(tag: 932, REGISTER) unregistering (send)
-2013-10-28 14:31:19,640-0500 INFO  RequestHandler Handler(tag: 932, REGISTER) unregistering (send)
+2013-10-31 14:40:43,782-0500 INFO  Block Started worker grind.mcs.anl.gov:000000
+2013-10-31 14:40:43,782-0500 DEBUG Cpu grind.mcs.anl.gov:0 sleeping
+Handler(tag: 1316, REGISTER) unregistering (send)
+2013-10-31 14:40:43,782-0500 INFO  RequestHandler Handler(tag: 1316, REGISTER) unregistering (send)
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:41:16,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 14:41:20,139-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 14:41:50,215-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 14:41:56,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 14:42:10,910-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+Multiplexer 0 started
+2013-10-31 14:42:10,913-0500 INFO  Multiplexer Multiplexer 0 started
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38697] for addition
+2013-10-31 14:42:10,914-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38697] for addition
+Multiplexer 1 started
+2013-10-31 14:42:10,914-0500 INFO  Multiplexer Multiplexer 1 started
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:42:10,914-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38697]
+Channel id: channel-1-u56c1e1d7-14210098df7--8000
+2013-10-31 14:42:10,935-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--8000
+MetaChannel [context: cps-38697, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:42:10,936-0500 INFO  MetaChannel MetaChannel [context: cps-38697, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38697]
+Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:42:10,936-0500 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:38697]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 14:42:10,936-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 14:42:10,978-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 14:42:11,073-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 14:42:11,101-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/hostname -f
+2013-10-31 14:42:11,113-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 14:42:11,132-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38698] for addition
+2013-10-31 14:42:11,132-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38698] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:42:11,132-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38698]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fff
+2013-10-31 14:42:11,154-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fff
+MetaChannel [context: cps-38698, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:42:11,154-0500 INFO  MetaChannel MetaChannel [context: cps-38698, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38698]
+Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 14:42:11,154-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 14:42:11,195-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 14:42:11,276-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 14:42:11,276-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 14:42:11,276-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:42:20,289-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:42:20,928-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:42:30,942-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 14:42:36,029-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:42:40,956-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 14:42:41,066-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38699] for addition
+2013-10-31 14:42:41,066-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38699] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:42:41,066-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38699]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ffe
+2013-10-31 14:42:41,097-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ffe
+MetaChannel [context: cps-38699, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:42:41,097-0500 INFO  MetaChannel MetaChannel [context: cps-38699, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:42:41,098-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 14:42:41,138-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 14:42:41,138-0500 INFO  Sender Sender TCPChannel queue size: 0
+provider=local
+2013-10-31 14:42:41,219-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 14:42:41,219-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 14:42:41,219-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 14:42:41,261-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38700] for addition
+2013-10-31 14:42:41,261-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38700] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:42:41,261-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38700]
+Channel id: channel-2-u56c1e1d7-14210098df7--7ffd
+2013-10-31 14:42:41,300-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7ffd
+MetaChannel [context: cps-38700, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:42:41,300-0500 INFO  MetaChannel MetaChannel [context: cps-38700, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:42:41,300-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 14:42:41,321-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 14:42:41,401-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 14:42:41,402-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 14:42:41,402-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 14:42:50,364-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:42:50,976-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:43:00,990-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:43:11,004-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 14:43:15,699-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:43:20,439-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:43:21,016-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:43:31,029-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:43:41,039-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 14:43:50,515-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+Avg stream buf: 0
+2013-10-31 14:43:51,049-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 14:43:55,368-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:44:01,059-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:44:11,068-0500 INFO  Multiplexer Avg stream buf: 0
+Notifying commands and handlers about exception
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-144211.060, now=131031-144411.911, channel=TCPChannel [type: server, contact: 140.221.8.81:38697]
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 14:44:11,977-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, RLOG)
+2013-10-31 14:44:11,979-0500 INFO  ChannelContext => Command(tag: 1, RLOG)
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:11,979-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+Client could not properly process notification: null
+2013-10-31 14:44:11,979-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:11,980-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:11,980-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:11,980-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+=> Command(tag: 5, JOBSTATUS)
+2013-10-31 14:44:11,981-0500 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
+2013-10-31 14:44:11,981-0500 WARN  TaskNotifier Client could not properly process notification: null
+Channel config: null -> {keepalive=null}
+2013-10-31 14:44:11,981-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38697] handling channel exception
+2013-10-31 14:44:11,981-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38697] handling channel exception
+null: Channel shut down
+2013-10-31 14:44:11,982-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38697, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38697]] binding to NullChannel
+2013-10-31 14:44:11,982-0500 INFO  MetaChannel MetaChannel [context: cps-38697, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38697]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:44:11,983-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:44:11,983-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:11,983-0500 INFO  ChannelContext => Command(tag: 1, RLOG)
+2013-10-31 14:44:11,983-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:11,983-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:11,983-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:11,984-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:11,984-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:11,984-0500 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
+Channel exception handled
+2013-10-31 14:44:11,984-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 14:44:11,991-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 14:44:11,991-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 14:44:11,992-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 14:44:11,992-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38697] handling channel exception
+Channel already shut down
+2013-10-31 14:44:11,992-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38697]
+2013-10-31 14:44:11,992-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38697]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-144211.275, now=131031-144412.132, channel=TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:44:12,132-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:12,132-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:12,133-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:12,133-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:12,133-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:12,134-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:12,134-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:12,134-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38698] handling channel exception
+2013-10-31 14:44:12,134-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38698] handling channel exception
+2013-10-31 14:44:12,135-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38698, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38698]] binding to NullChannel
+2013-10-31 14:44:12,135-0500 INFO  MetaChannel MetaChannel [context: cps-38698, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38698]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:44:12,135-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:44:12,135-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:12,135-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:12,135-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:12,136-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:12,136-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:12,136-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:12,136-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:12,137-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 14:44:12,153-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 14:44:12,153-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 14:44:12,154-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 14:44:12,154-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38698] handling channel exception
+2013-10-31 14:44:12,154-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:44:12,154-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38698]
+2013-10-31 14:44:20,589-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:44:21,080-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 14:44:31,090-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 14:44:35,037-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 14:44:41,100-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-144241.219, now=131031-144442.066, channel=TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:44:42,066-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:42,067-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:42,067-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,067-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:42,067-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:42,068-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,068-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:42,068-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38699] handling channel exception
+2013-10-31 14:44:42,068-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38699] handling channel exception
+2013-10-31 14:44:42,068-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38699, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38699]] binding to NullChannel
+2013-10-31 14:44:42,068-0500 INFO  MetaChannel MetaChannel [context: cps-38699, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38699]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:44:42,069-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:44:42,069-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:42,069-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:42,069-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,069-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:42,069-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:42,070-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:42,070-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,070-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 14:44:42,082-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 14:44:42,083-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 14:44:42,083-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 14:44:42,083-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38699] handling channel exception
+2013-10-31 14:44:42,083-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38699]
+2013-10-31 14:44:42,083-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38699]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-144241.401, now=131031-144442.261, channel=TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:44:42,261-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:42,261-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:42,261-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,262-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:42,262-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,262-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:42,262-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:42,263-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38700] handling channel exception
+2013-10-31 14:44:42,263-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38700] handling channel exception
+2013-10-31 14:44:42,263-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38700, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38700]] binding to NullChannel
+2013-10-31 14:44:42,263-0500 INFO  MetaChannel MetaChannel [context: cps-38700, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38700]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:44:42,263-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:44:42,263-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 14:44:42,263-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 14:44:42,263-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,264-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 14:44:42,264-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 14:44:42,264-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,264-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 14:44:42,264-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 14:44:42,264-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 14:44:42,265-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 14:44:42,265-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 14:44:42,265-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 14:44:42,265-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38700] handling channel exception
+2013-10-31 14:44:42,265-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:44:42,265-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38700]
+2013-10-31 14:44:50,664-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:44:51,110-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:45:01,118-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:45:11,126-0500 INFO  Multiplexer No streams
+2013-10-31 14:45:14,706-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:45:20,739-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:45:21,135-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:45:31,143-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:45:41,151-0500 INFO  Multiplexer No streams
+2013-10-31 14:45:50,814-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:45:51,159-0500 INFO  Multiplexer No streams
+2013-10-31 14:45:54,375-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:46:01,167-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:46:11,175-0500 INFO  Multiplexer No streams
+2013-10-31 14:46:20,889-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:46:21,183-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:46:31,191-0500 INFO  Multiplexer No streams
+2013-10-31 14:46:34,044-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:46:41,199-0500 INFO  Multiplexer No streams
+2013-10-31 14:46:50,964-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:46:51,207-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:47:01,215-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:47:11,223-0500 INFO  Multiplexer No streams
+2013-10-31 14:47:13,713-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:47:21,039-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:47:21,231-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:47:31,238-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:47:41,246-0500 INFO  Multiplexer No streams
+2013-10-31 14:47:51,114-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:47:51,254-0500 INFO  Multiplexer No streams
+2013-10-31 14:47:53,382-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:48:01,262-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:48:11,270-0500 INFO  Multiplexer No streams
+2013-10-31 14:48:21,189-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:48:21,278-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:48:31,286-0500 INFO  Multiplexer No streams
+2013-10-31 14:48:33,051-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:48:41,293-0500 INFO  Multiplexer No streams
+2013-10-31 14:48:51,264-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:48:51,301-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:49:01,309-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:49:11,317-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 14:49:12,721-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 14:49:21,325-0500 INFO  Multiplexer No streams
+2013-10-31 14:49:21,340-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 14:49:31,333-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:49:41,340-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:49:51,348-0500 INFO  Multiplexer No streams
+2013-10-31 14:49:51,414-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 14:49:52,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:50:01,356-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:50:11,364-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:50:21,372-0500 INFO  Multiplexer No streams
+2013-10-31 14:50:21,488-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 14:50:31,379-0500 INFO  Multiplexer No streams
+2013-10-31 14:50:32,058-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:50:41,387-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:50:51,395-0500 INFO  Multiplexer No streams
+2013-10-31 14:50:51,563-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 14:51:01,402-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:51:11,410-0500 INFO  Multiplexer No streams
+2013-10-31 14:51:11,728-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 14:51:21,418-0500 INFO  Multiplexer No streams
+2013-10-31 14:51:21,638-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 14:51:31,426-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:51:41,434-0500 INFO  Multiplexer No streams
+2013-10-31 14:51:51,396-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:51:51,442-0500 INFO  Multiplexer No streams
+2013-10-31 14:51:51,713-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 14:52:01,450-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:52:11,457-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:52:21,468-0500 INFO  Multiplexer No streams
+2013-10-31 14:52:21,789-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:52:31,065-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:52:31,476-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:52:41,484-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:52:51,492-0500 INFO  Multiplexer No streams
+2013-10-31 14:52:51,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:53:01,500-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 14:53:10,734-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 14:53:11,508-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:53:21,516-0500 INFO  Multiplexer No streams
+2013-10-31 14:53:21,939-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:53:31,523-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:53:41,531-0500 INFO  Multiplexer No streams
+2013-10-31 14:53:50,404-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:53:51,539-0500 INFO  Multiplexer No streams
+2013-10-31 14:53:52,014-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:54:01,547-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:54:11,555-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:54:21,563-0500 INFO  Multiplexer No streams
+2013-10-31 14:54:22,089-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:54:30,073-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:54:31,571-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:54:41,579-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:54:51,587-0500 INFO  Multiplexer No streams
+2013-10-31 14:54:52,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:55:01,595-0500 INFO  Multiplexer No streams
+2013-10-31 14:55:09,742-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:55:11,603-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:55:21,611-0500 INFO  Multiplexer No streams
+2013-10-31 14:55:22,239-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:55:31,620-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:55:41,628-0500 INFO  Multiplexer No streams
+2013-10-31 14:55:49,411-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:55:51,636-0500 INFO  Multiplexer No streams
+2013-10-31 14:55:52,314-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:56:01,644-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:56:11,652-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:56:21,660-0500 INFO  Multiplexer No streams
+2013-10-31 14:56:22,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:56:29,080-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:56:31,668-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:56:41,676-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:56:51,684-0500 INFO  Multiplexer No streams
+2013-10-31 14:56:52,464-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:57:01,692-0500 INFO  Multiplexer No streams
+2013-10-31 14:57:08,749-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 14:57:11,700-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:57:21,708-0500 INFO  Multiplexer No streams
+2013-10-31 14:57:22,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:57:31,716-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:57:41,724-0500 INFO  Multiplexer No streams
+2013-10-31 14:57:48,419-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:57:51,732-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 14:57:52,614-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 14:58:01,740-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:58:11,748-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:58:21,756-0500 INFO  Multiplexer No streams
+2013-10-31 14:58:22,690-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 14:58:28,088-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:58:31,764-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:58:41,772-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:58:51,780-0500 INFO  Multiplexer No streams
+2013-10-31 14:58:52,765-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:59:01,788-0500 INFO  Multiplexer No streams
+2013-10-31 14:59:07,757-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:59:11,796-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:59:21,804-0500 INFO  Multiplexer No streams
+2013-10-31 14:59:22,840-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 14:59:31,812-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 14:59:41,820-0500 INFO  Multiplexer No streams
+2013-10-31 14:59:47,426-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 14:59:51,828-0500 INFO  Multiplexer No streams
+2013-10-31 14:59:52,914-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:00:01,831-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:00:11,839-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:00:21,847-0500 INFO  Multiplexer No streams
+2013-10-31 15:00:22,991-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:00:27,095-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:00:31,855-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:00:41,863-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:00:51,871-0500 INFO  Multiplexer No streams
+2013-10-31 15:00:53,065-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:01:01,879-0500 INFO  Multiplexer No streams
+2013-10-31 15:01:06,764-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:01:11,887-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:01:21,896-0500 INFO  Multiplexer No streams
+2013-10-31 15:01:23,140-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:01:31,904-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:01:41,912-0500 INFO  Multiplexer No streams
+2013-10-31 15:01:46,433-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:01:51,920-0500 INFO  Multiplexer No streams
+2013-10-31 15:01:53,215-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:02:01,928-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:02:11,936-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:02:21,944-0500 INFO  Multiplexer No streams
+2013-10-31 15:02:23,291-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:02:26,102-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:02:31,952-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:02:41,960-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:02:51,968-0500 INFO  Multiplexer No streams
+2013-10-31 15:02:53,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:03:01,976-0500 INFO  Multiplexer No streams
+2013-10-31 15:03:05,771-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:03:11,984-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:03:21,992-0500 INFO  Multiplexer No streams
+2013-10-31 15:03:23,441-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:03:32,000-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:03:42,008-0500 INFO  Multiplexer No streams
+2013-10-31 15:03:45,441-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:03:52,016-0500 INFO  Multiplexer No streams
+2013-10-31 15:03:53,516-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:04:02,024-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:04:12,032-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:04:22,040-0500 INFO  Multiplexer No streams
+2013-10-31 15:04:23,591-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:04:25,110-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:04:32,048-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:04:42,056-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:04:52,064-0500 INFO  Multiplexer No streams
+2013-10-31 15:04:53,666-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:05:02,072-0500 INFO  Multiplexer No streams
+2013-10-31 15:05:04,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:05:12,080-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:05:22,088-0500 INFO  Multiplexer No streams
+2013-10-31 15:05:23,741-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:05:32,096-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:05:42,104-0500 INFO  Multiplexer No streams
+2013-10-31 15:05:44,448-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:05:52,112-0500 INFO  Multiplexer No streams
+2013-10-31 15:05:53,816-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:06:02,120-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:06:12,128-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:06:22,136-0500 INFO  Multiplexer No streams
+2013-10-31 15:06:23,891-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:06:24,117-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:06:32,144-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:06:42,152-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:06:52,160-0500 INFO  Multiplexer No streams
+2013-10-31 15:06:53,966-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:07:02,168-0500 INFO  Multiplexer No streams
+2013-10-31 15:07:03,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:07:12,176-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:07:22,184-0500 INFO  Multiplexer No streams
+2013-10-31 15:07:24,041-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:07:32,192-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:07:42,200-0500 INFO  Multiplexer No streams
+2013-10-31 15:07:43,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:07:52,208-0500 INFO  Multiplexer No streams
+2013-10-31 15:07:54,116-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:08:02,216-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:08:12,224-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:08:22,232-0500 INFO  Multiplexer No streams
+2013-10-31 15:08:23,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:08:24,191-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:08:32,239-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:08:42,247-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:08:52,255-0500 INFO  Multiplexer No streams
+2013-10-31 15:08:54,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:09:02,263-0500 INFO  Multiplexer No streams
+2013-10-31 15:09:02,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:09:12,272-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:09:22,280-0500 INFO  Multiplexer No streams
+2013-10-31 15:09:24,341-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:09:32,288-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:09:42,296-0500 INFO  Multiplexer No streams
+2013-10-31 15:09:42,462-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:09:52,304-0500 INFO  Multiplexer No streams
+2013-10-31 15:09:54,416-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:10:02,312-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:10:12,320-0500 INFO  Multiplexer No streams
+2013-10-31 15:10:22,131-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:10:22,328-0500 INFO  Multiplexer No streams
+2013-10-31 15:10:24,491-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:10:32,336-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:10:42,344-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:10:52,352-0500 INFO  Multiplexer No streams
+2013-10-31 15:10:54,567-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:11:01,800-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:11:02,360-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:11:12,368-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:11:22,376-0500 INFO  Multiplexer No streams
+2013-10-31 15:11:24,642-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:11:32,384-0500 INFO  Multiplexer No streams
+2013-10-31 15:11:41,470-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:11:42,392-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:11:52,400-0500 INFO  Multiplexer No streams
+2013-10-31 15:11:54,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:12:02,408-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:12:12,416-0500 INFO  Multiplexer No streams
+2013-10-31 15:12:21,139-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:12:22,424-0500 INFO  Multiplexer No streams
+2013-10-31 15:12:24,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:12:32,432-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:12:42,440-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:12:52,448-0500 INFO  Multiplexer No streams
+2013-10-31 15:12:54,869-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 15:13:00,808-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:13:02,456-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:13:12,464-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:13:22,472-0500 INFO  Multiplexer No streams
+2013-10-31 15:13:24,944-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:13:32,480-0500 INFO  Multiplexer No streams
+2013-10-31 15:13:40,477-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:13:42,488-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:13:52,497-0500 INFO  Multiplexer No streams
+2013-10-31 15:13:55,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:14:02,505-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:14:12,513-0500 INFO  Multiplexer No streams
+2013-10-31 15:14:20,146-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:14:22,521-0500 INFO  Multiplexer No streams
+2013-10-31 15:14:25,094-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:14:32,529-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:14:42,537-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:14:52,545-0500 INFO  Multiplexer No streams
+2013-10-31 15:14:55,170-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 15:14:59,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:15:02,553-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:15:12,561-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:15:22,569-0500 INFO  Multiplexer No streams
+2013-10-31 15:15:25,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:15:32,577-0500 INFO  Multiplexer No streams
+2013-10-31 15:15:39,484-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:15:42,585-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:15:52,593-0500 INFO  Multiplexer No streams
+2013-10-31 15:15:55,319-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:16:02,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:16:12,609-0500 INFO  Multiplexer No streams
+2013-10-31 15:16:19,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:16:22,617-0500 INFO  Multiplexer No streams
+2013-10-31 15:16:25,395-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:16:32,624-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:16:42,632-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:16:52,640-0500 INFO  Multiplexer No streams
+2013-10-31 15:16:55,470-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:16:58,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:17:02,648-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:17:12,656-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:17:22,664-0500 INFO  Multiplexer No streams
+2013-10-31 15:17:25,545-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:17:32,672-0500 INFO  Multiplexer No streams
+2013-10-31 15:17:38,491-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:17:42,680-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:17:52,688-0500 INFO  Multiplexer No streams
+2013-10-31 15:17:55,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:18:02,696-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:18:12,704-0500 INFO  Multiplexer No streams
+2013-10-31 15:18:18,160-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:18:22,712-0500 INFO  Multiplexer No streams
+2013-10-31 15:18:25,695-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:18:32,720-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:18:42,728-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:18:52,736-0500 INFO  Multiplexer No streams
+2013-10-31 15:18:55,770-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:18:57,829-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:19:02,744-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:19:12,752-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:19:22,760-0500 INFO  Multiplexer No streams
+2013-10-31 15:19:25,845-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:19:32,768-0500 INFO  Multiplexer No streams
+2013-10-31 15:19:37,498-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:19:42,776-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:19:52,784-0500 INFO  Multiplexer No streams
+2013-10-31 15:19:55,920-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:20:02,792-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:20:12,800-0500 INFO  Multiplexer No streams
+2013-10-31 15:20:17,167-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:20:22,808-0500 INFO  Multiplexer No streams
+2013-10-31 15:20:25,994-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:20:32,816-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:20:42,824-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:20:52,831-0500 INFO  Multiplexer No streams
+2013-10-31 15:20:56,070-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:20:56,836-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:21:02,839-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:21:12,847-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:21:22,855-0500 INFO  Multiplexer No streams
+2013-10-31 15:21:26,145-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:21:32,863-0500 INFO  Multiplexer No streams
+2013-10-31 15:21:36,505-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:21:42,871-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:21:52,879-0500 INFO  Multiplexer No streams
+2013-10-31 15:21:56,220-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:22:02,887-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:22:12,895-0500 INFO  Multiplexer No streams
+2013-10-31 15:22:16,174-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:22:22,903-0500 INFO  Multiplexer No streams
+2013-10-31 15:22:26,295-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:22:32,910-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:22:42,918-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:22:52,926-0500 INFO  Multiplexer No streams
+2013-10-31 15:22:55,843-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:22:56,370-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:23:02,934-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:23:12,941-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:23:22,949-0500 INFO  Multiplexer No streams
+2013-10-31 15:23:26,445-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:23:32,957-0500 INFO  Multiplexer No streams
+2013-10-31 15:23:35,512-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:23:42,964-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:23:52,972-0500 INFO  Multiplexer No streams
+2013-10-31 15:23:56,520-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:24:02,980-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:24:12,988-0500 INFO  Multiplexer No streams
+2013-10-31 15:24:15,181-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:24:22,995-0500 INFO  Multiplexer No streams
+2013-10-31 15:24:26,595-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:24:33,003-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:24:43,011-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:24:53,030-0500 INFO  Multiplexer No streams
+2013-10-31 15:24:54,850-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 15:24:56,670-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:25:03,038-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:25:13,046-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:25:23,053-0500 INFO  Multiplexer No streams
+2013-10-31 15:25:26,745-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:25:33,061-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:25:34,519-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:25:43,069-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:25:53,076-0500 INFO  Multiplexer No streams
+2013-10-31 15:25:56,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:26:03,084-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:26:13,092-0500 INFO  Multiplexer No streams
+2013-10-31 15:26:14,188-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:26:23,100-0500 INFO  Multiplexer No streams
+2013-10-31 15:26:26,895-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:26:33,108-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:26:43,116-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:26:53,124-0500 INFO  Multiplexer No streams
+2013-10-31 15:26:53,857-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:26:56,970-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:27:03,132-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:27:13,140-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:27:23,149-0500 INFO  Multiplexer No streams
+2013-10-31 15:27:27,045-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:27:33,157-0500 INFO  Multiplexer No streams
+2013-10-31 15:27:33,527-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 15:27:43,165-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:27:53,173-0500 INFO  Multiplexer No streams
+2013-10-31 15:27:57,120-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:28:03,181-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:28:13,189-0500 INFO  Multiplexer No streams
+2013-10-31 15:28:13,195-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:28:23,197-0500 INFO  Multiplexer No streams
+2013-10-31 15:28:27,195-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:28:33,205-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:28:43,214-0500 INFO  Multiplexer No streams
+2013-10-31 15:28:52,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:28:53,224-0500 INFO  Multiplexer No streams
+2013-10-31 15:28:57,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:29:03,234-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:29:13,244-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:29:23,255-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 15:29:27,346-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 15:29:32,533-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:29:33,258-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:29:43,261-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:29:53,266-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:29:57,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:30:03,286-0500 INFO  Multiplexer No streams
+2013-10-31 15:30:12,202-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:30:13,296-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:30:23,304-0500 INFO  Multiplexer No streams
+2013-10-31 15:30:27,495-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:30:33,315-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:30:43,325-0500 INFO  Multiplexer No streams
+2013-10-31 15:30:51,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:30:53,338-0500 INFO  Multiplexer No streams
+2013-10-31 15:30:57,570-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:31:03,351-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:31:13,362-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:31:23,375-0500 INFO  Multiplexer No streams
 TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:31:58,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-10-28 14:31:58,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 15:31:27,645-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 15:31:31,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:31:33,385-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:31:43,398-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:31:53,408-0500 INFO  Multiplexer No streams
+2013-10-31 15:31:57,721-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:32:03,418-0500 INFO  Multiplexer No streams
+2013-10-31 15:32:11,210-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 15:32:13,427-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:32:23,437-0500 INFO  Multiplexer No streams
+2013-10-31 15:32:27,796-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:32:33,445-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:32:43,452-0500 INFO  Multiplexer No streams
+2013-10-31 15:32:50,878-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:32:53,460-0500 INFO  Multiplexer No streams
+2013-10-31 15:32:57,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:33:03,470-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:33:13,484-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:33:23,493-0500 INFO  Multiplexer No streams
+2013-10-31 15:33:27,946-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:33:30,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:33:33,503-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:33:43,513-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:33:53,520-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 15:33:58,022-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 15:34:03,528-0500 INFO  Multiplexer No streams
+2013-10-31 15:34:10,216-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:34:13,537-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:34:23,545-0500 INFO  Multiplexer No streams
+2013-10-31 15:34:28,096-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:34:33,553-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:34:43,564-0500 INFO  Multiplexer No streams
+2013-10-31 15:34:49,885-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:34:53,572-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 15:34:58,172-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:35:03,579-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:35:13,586-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:35:23,594-0500 INFO  Multiplexer No streams
+2013-10-31 15:35:28,247-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:35:29,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:35:33,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:35:43,611-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:35:53,619-0500 INFO  Multiplexer No streams
+2013-10-31 15:35:58,322-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:36:03,628-0500 INFO  Multiplexer No streams
+2013-10-31 15:36:09,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:36:13,639-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:36:23,648-0500 INFO  Multiplexer No streams
+2013-10-31 15:36:28,397-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:36:33,660-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:36:43,670-0500 INFO  Multiplexer No streams
+2013-10-31 15:36:48,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:36:53,680-0500 INFO  Multiplexer No streams
+2013-10-31 15:36:58,472-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:37:03,689-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:37:13,697-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:37:23,708-0500 INFO  Multiplexer No streams
+2013-10-31 15:37:28,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:37:28,561-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:37:33,719-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:37:43,729-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:37:53,738-0500 INFO  Multiplexer No streams
+2013-10-31 15:37:58,622-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:38:03,748-0500 INFO  Multiplexer No streams
+2013-10-31 15:38:08,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:38:13,759-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:38:23,769-0500 INFO  Multiplexer No streams
+2013-10-31 15:38:28,698-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:38:33,779-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:38:43,788-0500 INFO  Multiplexer No streams
+2013-10-31 15:38:47,900-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:38:53,799-0500 INFO  Multiplexer No streams
+2013-10-31 15:38:58,773-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:39:03,809-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:39:13,818-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:39:23,826-0500 INFO  Multiplexer No streams
+2013-10-31 15:39:27,570-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:39:28,848-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:39:33,835-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:39:43,846-0500 INFO  Multiplexer No streams
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 15:39:45,171-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38798] for addition
+2013-10-31 15:39:45,171-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38798] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38798]
+2013-10-31 15:39:45,171-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38798]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ffc
+2013-10-31 15:39:45,212-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ffc
+MetaChannel [context: cps-38798, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38798]
+2013-10-31 15:39:45,212-0500 INFO  MetaChannel MetaChannel [context: cps-38798, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38798]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:39:45,212-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 15:39:45,233-0500 INFO  Sender Sender TCPChannel queue size: 0
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:39:45,233-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 15:39:45,313-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/ech
+2013-10-31 15:39:45,314-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/ech
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 15:39:45,315-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+Avg stream buf: 0
+2013-10-31 15:39:53,866-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:39:58,923-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:40:03,879-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:40:07,239-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+Avg stream buf: 0
+2013-10-31 15:40:13,891-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:40:18,523-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38804] for addition
+2013-10-31 15:40:18,524-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38804] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:40:18,524-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38804]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ffb
+2013-10-31 15:40:18,546-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ffb
+MetaChannel [context: cps-38804, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:40:18,547-0500 INFO  MetaChannel MetaChannel [context: cps-38804, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:40:18,547-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:40:18,587-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:40:18,588-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 15:40:18,668-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 15:40:18,668-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/d
+2013-10-31 15:40:18,669-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/d
+Avg stream buf: 0
+2013-10-31 15:40:23,905-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:40:28,998-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:40:33,915-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:40:43,924-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:40:46,907-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:40:53,932-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:40:59,073-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:41:03,941-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:41:13,950-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:41:23,959-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:41:26,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:41:29,147-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 15:41:33,969-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:41:42,375-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38810] for addition
+2013-10-31 15:41:42,376-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38810] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:41:42,376-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38810]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ffa
+2013-10-31 15:41:42,414-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ffa
+MetaChannel [context: cps-38810, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:41:42,414-0500 INFO  MetaChannel MetaChannel [context: cps-38810, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:41:42,415-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:41:42,435-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:41:42,435-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 15:41:42,516-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 15:41:42,516-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/hostnam
+2013-10-31 15:41:42,516-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostnam
+2013-10-31 15:41:42,564-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38811] for addition
+2013-10-31 15:41:42,564-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38811] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:41:42,564-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38811]
+Channel id: channel-2-u56c1e1d7-14210098df7--7ff9
+2013-10-31 15:41:42,597-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7ff9
+MetaChannel [context: cps-38811, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:41:42,597-0500 INFO  MetaChannel MetaChannel [context: cps-38811, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38811]
+Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:41:42,597-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:41:42,637-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 15:41:42,718-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 15:41:42,718-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/hostnam -f
+2013-10-31 15:41:42,719-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostnam -f
+Avg stream buf: 0
+2013-10-31 15:41:43,982-0500 INFO  Multiplexer Avg stream buf: 0
+Notifying commands and handlers about exception
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-153945.313, now=131031-154146.171, channel=TCPChannel [type: server, contact: 140.221.8.81:38798]
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 15:41:46,171-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 15:41:46,172-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+Client could not properly process notification: null
+2013-10-31 15:41:46,172-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 15:41:46,172-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 15:41:46,172-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 15:41:46,173-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:41:46,173-0500 WARN  TaskNotifier Client could not properly process notification: null
+Channel config: null -> {keepalive=null}
+2013-10-31 15:41:46,173-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38798] handling channel exception
+2013-10-31 15:41:46,173-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38798] handling channel exception
+null: Channel shut down
+2013-10-31 15:41:46,173-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38798, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38798]] binding to NullChannel
+2013-10-31 15:41:46,174-0500 INFO  MetaChannel MetaChannel [context: cps-38798, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38798]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38798]
+2013-10-31 15:41:46,174-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38798]
+2013-10-31 15:41:46,174-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:41:46,174-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:41:46,174-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:41:46,174-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:41:46,174-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:41:46,175-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:41:46,175-0500 WARN  TaskNotifier Client could not properly process notification: null
+Channel exception handled
+2013-10-31 15:41:46,175-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 15:41:46,189-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 15:41:46,189-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:41:46,189-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:41:46,189-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38798] handling channel exception
+Channel already shut down
+2013-10-31 15:41:46,189-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38798]
+2013-10-31 15:41:46,190-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38798]
+Avg stream buf: 0
+2013-10-31 15:41:53,992-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:41:59,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:42:04,001-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:42:06,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:42:14,010-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154018.668, now=131031-154219.524, channel=TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:42:19,524-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:42:19,524-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:42:19,524-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:42:19,524-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:42:19,525-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:42:19,525-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:42:19,525-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:42:19,525-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38804] handling channel exception
+2013-10-31 15:42:19,525-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38804] handling channel exception
+2013-10-31 15:42:19,526-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38804, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38804]] binding to NullChannel
+2013-10-31 15:42:19,526-0500 INFO  MetaChannel MetaChannel [context: cps-38804, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38804]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:42:19,526-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:42:19,526-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:42:19,526-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:42:19,526-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:42:19,527-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:42:19,527-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:42:19,527-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:42:19,527-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:42:19,527-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:42:19,546-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:42:19,546-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:42:19,546-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:42:19,546-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38804] handling channel exception
+2013-10-31 15:42:19,546-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38804]
+2013-10-31 15:42:19,546-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38804]
+Avg stream buf: 0
+2013-10-31 15:42:24,019-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:42:29,298-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:42:34,028-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:42:44,036-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:42:45,914-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:42:54,045-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:42:58,930-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38818] for addition
+2013-10-31 15:42:58,930-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38818] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:42:58,930-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38818]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff8
+2013-10-31 15:42:58,960-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff8
+MetaChannel [context: cps-38818, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:42:58,961-0500 INFO  MetaChannel MetaChannel [context: cps-38818, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:42:58,961-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:42:59,001-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:42:59,001-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 15:42:59,082-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 15:42:59,082-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 15:42:59,082-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostnam -f
+2013-10-31 15:42:59,121-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38819] for addition
+2013-10-31 15:42:59,121-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38819] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:42:59,121-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38819]
+Channel id: channel-2-u56c1e1d7-14210098df7--7ff7
+2013-10-31 15:42:59,143-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7ff7
+MetaChannel [context: cps-38819, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:42:59,143-0500 INFO  MetaChannel MetaChannel [context: cps-38819, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:42:59,143-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:42:59,183-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 15:42:59,264-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 15:42:59,264-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 15:42:59,265-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
-2013-10-28 14:32:29,185-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:32:36,733-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 15:42:59,373-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:43:04,059-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:43:14,068-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:43:24,076-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 15:43:25,584-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 15:43:29,448-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:43:34,085-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154142.516, now=131031-154343.375, channel=TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:43:43,375-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:43:43,375-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:43:43,376-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,376-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:43:43,376-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:43:43,376-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:43:43,377-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38810] handling channel exception
+2013-10-31 15:43:43,377-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38810] handling channel exception
+2013-10-31 15:43:43,377-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38810, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38810]] binding to NullChannel
+2013-10-31 15:43:43,377-0500 INFO  MetaChannel MetaChannel [context: cps-38810, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38810]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:43:43,377-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:43:43,377-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:43:43,377-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:43:43,378-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,378-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:43:43,378-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:43:43,378-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:43:43,378-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:43:43,392-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:43:43,393-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:43:43,393-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:43:43,393-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38810] handling channel exception
+2013-10-31 15:43:43,393-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38810]
+2013-10-31 15:43:43,393-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38810]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154142.718, now=131031-154343.564, channel=TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:43:43,564-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:43:43,564-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:43:43,564-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,564-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:43:43,565-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:43:43,565-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,565-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:43:43,565-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38811] handling channel exception
+2013-10-31 15:43:43,565-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38811] handling channel exception
+2013-10-31 15:43:43,565-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38811, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38811]] binding to NullChannel
+2013-10-31 15:43:43,566-0500 INFO  MetaChannel MetaChannel [context: cps-38811, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38811]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:43:43,566-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:43:43,566-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:43:43,566-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:43:43,566-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,566-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:43:43,566-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:43:43,567-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:43:43,567-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:43:43,567-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:43:43,574-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:43:43,574-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:43:43,574-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:43:43,574-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38811] handling channel exception
+2013-10-31 15:43:43,574-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38811]
+2013-10-31 15:43:43,574-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38811]
+Avg stream buf: 0
+2013-10-31 15:43:44,096-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:43:54,104-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:43:59,523-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:44:02,743-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38820] for addition
+2013-10-31 15:44:02,744-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38820] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:44:02,744-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38820]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff6
+2013-10-31 15:44:02,770-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff6
+MetaChannel [context: cps-38820, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:44:02,770-0500 INFO  MetaChannel MetaChannel [context: cps-38820, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:44:02,771-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:44:02,811-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 15:44:02,811-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 15:44:02,895-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 15:44:02,895-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 15:44:02,896-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostnam -f
+2013-10-31 15:44:02,937-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38821] for addition
+2013-10-31 15:44:02,938-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38821] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:44:02,938-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38821]
+Channel id: channel-2-u56c1e1d7-14210098df7--7ff5
+2013-10-31 15:44:02,977-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7ff5
+MetaChannel [context: cps-38821, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:44:02,977-0500 INFO  MetaChannel MetaChannel [context: cps-38821, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:44:02,977-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 15:44:02,997-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 15:44:03,078-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 15:44:03,078-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 15:44:03,078-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+Avg stream buf: 0
+2013-10-31 15:44:04,124-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:44:05,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:44:14,133-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:44:24,142-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:44:29,598-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 15:44:34,152-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:44:44,161-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:44:44,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:44:54,170-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:44:59,674-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154259.082, now=131031-154459.930, channel=TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:44:59,931-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:44:59,931-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:44:59,931-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:44:59,931-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:44:59,932-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:44:59,932-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:44:59,932-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:44:59,932-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38818] handling channel exception
+2013-10-31 15:44:59,932-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38818] handling channel exception
+2013-10-31 15:44:59,933-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38818, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38818]] binding to NullChannel
+2013-10-31 15:44:59,933-0500 INFO  MetaChannel MetaChannel [context: cps-38818, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38818]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:44:59,933-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:44:59,933-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:44:59,933-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:44:59,933-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:44:59,933-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:44:59,933-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:44:59,934-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:44:59,934-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:44:59,934-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:44:59,947-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:44:59,947-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:44:59,947-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:44:59,947-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38818] handling channel exception
+2013-10-31 15:44:59,947-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38818]
+2013-10-31 15:44:59,947-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38818]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154259.264, now=131031-154500.121, channel=TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:45:00,121-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:45:00,121-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:45:00,122-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:45:00,122-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:45:00,122-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:45:00,122-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:45:00,123-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38819] handling channel exception
+2013-10-31 15:45:00,123-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38819] handling channel exception
+2013-10-31 15:45:00,123-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38819, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38819]] binding to NullChannel
+2013-10-31 15:45:00,123-0500 INFO  MetaChannel MetaChannel [context: cps-38819, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38819]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:45:00,123-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:45:00,123-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:45:00,124-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:45:00,124-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:45:00,124-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:45:00,124-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:45:00,124-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:45:00,125-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:45:00,128-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:45:00,128-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:45:00,128-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:45:00,128-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38819] handling channel exception
+2013-10-31 15:45:00,128-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38819]
+2013-10-31 15:45:00,128-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38819]
+Avg stream buf: 0
+2013-10-31 15:45:04,180-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:45:14,189-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:45:24,197-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 15:45:24,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 15:45:29,749-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 15:45:34,206-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:45:44,215-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 15:45:54,224-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 15:45:59,824-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154402.892, now=131031-154603.743, channel=TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:46:03,743-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:46:03,744-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:46:03,744-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,744-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:46:03,744-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:46:03,744-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:46:03,745-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38820] handling channel exception
+2013-10-31 15:46:03,745-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38820] handling channel exception
+2013-10-31 15:46:03,745-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38820, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38820]] binding to NullChannel
+2013-10-31 15:46:03,745-0500 INFO  MetaChannel MetaChannel [context: cps-38820, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38820]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:46:03,745-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:46:03,745-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:46:03,746-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:46:03,746-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,746-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:46:03,746-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:46:03,746-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:46:03,747-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:46:03,751-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:46:03,752-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:46:03,752-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:46:03,752-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38820] handling channel exception
+2013-10-31 15:46:03,752-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38820]
+2013-10-31 15:46:03,752-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38820]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-154403.078, now=131031-154603.938, channel=TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:46:03,938-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:46:03,938-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:46:03,938-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,938-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:46:03,939-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:46:03,939-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,939-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:46:03,939-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38821] handling channel exception
+2013-10-31 15:46:03,939-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38821] handling channel exception
+2013-10-31 15:46:03,940-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38821, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38821]] binding to NullChannel
+2013-10-31 15:46:03,940-0500 INFO  MetaChannel MetaChannel [context: cps-38821, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38821]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:46:03,940-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:46:03,940-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 15:46:03,940-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 15:46:03,940-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,940-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 15:46:03,941-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 15:46:03,941-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 15:46:03,941-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 15:46:03,941-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 15:46:03,953-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 15:46:03,953-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 15:46:03,953-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 15:46:03,953-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38821] handling channel exception
+2013-10-31 15:46:03,953-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38821]
+2013-10-31 15:46:03,954-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38821]
+No streams
+2013-10-31 15:46:04,234-0500 INFO  Multiplexer No streams
+2013-10-31 15:46:04,259-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:46:14,242-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:46:24,250-0500 INFO  Multiplexer No streams
-2013-10-28 14:33:00,143-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:33:14,927-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 15:46:29,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 15:46:34,258-0500 INFO  Multiplexer No streams
+2013-10-31 15:46:43,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:46:44,266-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:46:54,273-0500 INFO  Multiplexer No streams
+2013-10-31 15:46:59,974-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:47:04,281-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:47:14,288-0500 INFO  Multiplexer No streams
+2013-10-31 15:47:23,597-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:47:24,296-0500 INFO  Multiplexer No streams
+2013-10-31 15:47:30,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:47:34,304-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:47:44,311-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:47:54,319-0500 INFO  Multiplexer No streams
+2013-10-31 15:48:00,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:48:03,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:48:04,326-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:48:14,334-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:48:24,341-0500 INFO  Multiplexer No streams
-2013-10-28 14:33:31,101-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:33:53,121-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 15:48:30,199-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 15:48:34,349-0500 INFO  Multiplexer No streams
+2013-10-31 15:48:42,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:48:44,357-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:48:54,364-0500 INFO  Multiplexer No streams
+2013-10-31 15:49:00,274-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:49:04,372-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:49:14,379-0500 INFO  Multiplexer No streams
+2013-10-31 15:49:22,604-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:49:24,386-0500 INFO  Multiplexer No streams
+2013-10-31 15:49:30,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:49:34,393-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:49:44,404-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:49:54,411-0500 INFO  Multiplexer No streams
+2013-10-31 15:50:00,424-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 15:50:02,273-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:50:04,418-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:50:14,426-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:50:24,433-0500 INFO  Multiplexer No streams
+2013-10-31 15:50:30,500-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:50:34,440-0500 INFO  Multiplexer No streams
+2013-10-31 15:50:41,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:50:44,448-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:50:54,455-0500 INFO  Multiplexer No streams
+2013-10-31 15:51:00,575-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:51:04,461-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:51:14,469-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 15:51:21,611-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 15:51:24,477-0500 INFO  Multiplexer No streams
+2013-10-31 15:51:30,649-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:51:34,485-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:51:44,493-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:51:54,501-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:52:00,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:52:01,282-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:52:04,508-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:52:14,516-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:52:24,523-0500 INFO  Multiplexer No streams
+2013-10-31 15:52:30,800-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:52:34,531-0500 INFO  Multiplexer No streams
+2013-10-31 15:52:40,952-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 15:52:44,539-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:52:54,547-0500 INFO  Multiplexer No streams
+2013-10-31 15:53:00,874-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:53:04,554-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:53:14,562-0500 INFO  Multiplexer No streams
+2013-10-31 15:53:20,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:53:24,570-0500 INFO  Multiplexer No streams
-2013-10-28 14:34:02,059-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:34:31,315-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 15:53:30,950-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 15:53:34,577-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:53:44,585-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:53:54,593-0500 INFO  Multiplexer No streams
+2013-10-31 15:54:00,289-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 15:54:01,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:54:04,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:54:14,609-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:54:24,617-0500 INFO  Multiplexer No streams
+2013-10-31 15:54:31,099-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:54:34,625-0500 INFO  Multiplexer No streams
+2013-10-31 15:54:39,958-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:54:44,633-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:54:54,641-0500 INFO  Multiplexer No streams
+2013-10-31 15:55:01,175-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:55:04,649-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:55:14,657-0500 INFO  Multiplexer No streams
+2013-10-31 15:55:19,627-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:55:24,665-0500 INFO  Multiplexer No streams
+2013-10-31 15:55:31,250-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:55:34,673-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:55:44,681-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:55:54,689-0500 INFO  Multiplexer No streams
+2013-10-31 15:55:59,296-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 15:56:01,325-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:56:04,697-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:56:14,705-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:56:24,713-0500 INFO  Multiplexer No streams
+2013-10-31 15:56:31,399-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:56:34,721-0500 INFO  Multiplexer No streams
+2013-10-31 15:56:38,966-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 15:56:44,729-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:56:54,737-0500 INFO  Multiplexer No streams
+2013-10-31 15:57:01,475-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:57:04,745-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:57:14,753-0500 INFO  Multiplexer No streams
+2013-10-31 15:57:18,635-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:57:24,761-0500 INFO  Multiplexer No streams
+2013-10-31 15:57:31,550-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:57:34,770-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:57:44,778-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:57:54,786-0500 INFO  Multiplexer No streams
+2013-10-31 15:57:58,304-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 15:58:01,624-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:58:04,794-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:58:14,802-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:58:24,810-0500 INFO  Multiplexer No streams
+2013-10-31 15:58:31,700-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:58:34,818-0500 INFO  Multiplexer No streams
+2013-10-31 15:58:37,973-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:58:44,826-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:58:54,834-0500 INFO  Multiplexer No streams
+2013-10-31 15:59:01,775-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:59:04,842-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:59:14,850-0500 INFO  Multiplexer No streams
+2013-10-31 15:59:17,642-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 15:59:24,858-0500 INFO  Multiplexer No streams
+2013-10-31 15:59:31,849-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 15:59:34,867-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:59:44,875-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 15:59:54,883-0500 INFO  Multiplexer No streams
+2013-10-31 15:59:57,311-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:34:33,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:00:01,925-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:00:04,891-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:00:14,899-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:00:24,907-0500 INFO  Multiplexer No streams
+2013-10-31 16:00:32,000-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:00:34,915-0500 INFO  Multiplexer No streams
+2013-10-31 16:00:36,979-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 16:00:44,923-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:00:54,932-0500 INFO  Multiplexer No streams
+2013-10-31 16:01:02,074-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:01:04,940-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:01:14,948-0500 INFO  Multiplexer No streams
+2013-10-31 16:01:16,649-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:01:24,956-0500 INFO  Multiplexer No streams
+2013-10-31 16:01:32,150-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:01:34,964-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:01:44,972-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:01:54,980-0500 INFO  Multiplexer No streams
+2013-10-31 16:01:56,318-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:02:02,225-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:02:04,988-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:02:14,996-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:02:25,004-0500 INFO  Multiplexer No streams
+2013-10-31 16:02:32,300-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:02:35,012-0500 INFO  Multiplexer No streams
+2013-10-31 16:02:35,987-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:02:45,020-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:02:55,028-0500 INFO  Multiplexer No streams
+2013-10-31 16:03:02,376-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:03:05,037-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:03:15,045-0500 INFO  Multiplexer No streams
+2013-10-31 16:03:15,656-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:03:25,053-0500 INFO  Multiplexer No streams
+2013-10-31 16:03:32,451-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:03:35,060-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:03:45,068-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:03:55,075-0500 INFO  Multiplexer No streams
+2013-10-31 16:03:55,325-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:04:02,525-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:04:05,083-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:04:15,091-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:04:25,098-0500 INFO  Multiplexer No streams
+2013-10-31 16:04:32,601-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:04:34,994-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:04:35,106-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:04:45,114-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:04:55,121-0500 INFO  Multiplexer No streams
+2013-10-31 16:05:02,676-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:05:05,129-0500 INFO  Multiplexer No streams
+2013-10-31 16:05:14,663-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 16:05:15,137-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:05:25,144-0500 INFO  Multiplexer No streams
+2013-10-31 16:05:32,751-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:05:35,152-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:05:45,160-0500 INFO  Multiplexer No streams
+2013-10-31 16:05:54,333-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:05:55,167-0500 INFO  Multiplexer No streams
+2013-10-31 16:06:02,825-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:06:05,175-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:06:15,183-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:06:25,191-0500 INFO  Multiplexer No streams
+2013-10-31 16:06:32,901-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:06:34,002-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:06:35,198-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:06:45,206-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:06:55,214-0500 INFO  Multiplexer No streams
+2013-10-31 16:07:02,976-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:07:05,223-0500 INFO  Multiplexer No streams
+2013-10-31 16:07:13,671-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:07:15,231-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:07:25,239-0500 INFO  Multiplexer No streams
+2013-10-31 16:07:33,050-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:07:35,247-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:07:45,256-0500 INFO  Multiplexer No streams
+2013-10-31 16:07:53,341-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:07:55,266-0500 INFO  Multiplexer No streams
+2013-10-31 16:08:03,126-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:08:05,275-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:08:15,284-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:08:25,293-0500 INFO  Multiplexer No streams
+2013-10-31 16:08:33,011-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 16:08:33,201-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:08:35,304-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:08:45,316-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:08:55,328-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 16:09:03,277-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 16:09:05,342-0500 INFO  Multiplexer No streams
+2013-10-31 16:09:12,679-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:09:15,353-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:09:25,365-0500 INFO  Multiplexer No streams
+2013-10-31 16:09:33,351-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:09:35,377-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:09:45,387-0500 INFO  Multiplexer No streams
+2013-10-31 16:09:52,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 16:09:55,399-0500 INFO  Multiplexer No streams
-2013-10-28 14:35:03,976-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:35:09,509-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:10:03,426-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:10:05,410-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:10:15,427-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:10:25,442-0500 INFO  Multiplexer No streams
+2013-10-31 16:10:32,018-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:35:34,933-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:35:47,703-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:10:33,501-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:10:35,454-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:10:45,463-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:10:55,473-0500 INFO  Multiplexer No streams
+2013-10-31 16:11:03,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:11:05,483-0500 INFO  Multiplexer No streams
+2013-10-31 16:11:11,687-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:11:15,494-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:11:25,505-0500 INFO  Multiplexer No streams
+2013-10-31 16:11:33,652-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 16:11:35,522-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:11:45,536-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 16:11:51,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 16:11:55,548-0500 INFO  Multiplexer No streams
-2013-10-28 14:36:05,891-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:36:25,897-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:12:03,726-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:12:05,563-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:12:15,577-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:12:25,590-0500 INFO  Multiplexer No streams
+2013-10-31 16:12:31,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
-2013-10-28 14:36:36,849-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:37:04,091-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:12:33,801-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:12:35,603-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:12:45,619-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:12:55,634-0500 INFO  Multiplexer No streams
+2013-10-31 16:13:03,876-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:13:05,652-0500 INFO  Multiplexer No streams
+2013-10-31 16:13:10,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:13:15,665-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:13:25,679-0500 INFO  Multiplexer No streams
+2013-10-31 16:13:33,951-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:13:35,688-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:13:45,696-0500 INFO  Multiplexer No streams
+2013-10-31 16:13:50,362-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:13:55,704-0500 INFO  Multiplexer No streams
-2013-10-28 14:37:07,806-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:14:04,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:14:05,712-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:14:15,720-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:14:25,728-0500 INFO  Multiplexer No streams
+2013-10-31 16:14:30,031-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:14:34,101-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:14:35,735-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:14:45,743-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:14:55,751-0500 INFO  Multiplexer No streams
-2013-10-28 14:37:38,766-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:37:42,285-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:15:04,176-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:15:05,759-0500 INFO  Multiplexer No streams
+2013-10-31 16:15:09,700-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:15:15,767-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:15:25,775-0500 INFO  Multiplexer No streams
-2013-10-28 14:38:09,724-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:38:20,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:15:34,251-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:15:35,783-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:15:45,791-0500 INFO  Multiplexer No streams
+2013-10-31 16:15:49,369-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:15:55,799-0500 INFO  Multiplexer No streams
+2013-10-31 16:16:04,325-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:16:05,807-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:16:15,815-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:16:25,823-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:16:29,037-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:16:34,401-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:16:35,831-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:16:45,839-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:16:55,847-0500 INFO  Multiplexer No streams
+2013-10-31 16:17:04,476-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:17:05,855-0500 INFO  Multiplexer No streams
+2013-10-31 16:17:08,707-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:17:15,863-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:17:25,871-0500 INFO  Multiplexer No streams
+2013-10-31 16:17:34,550-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:17:35,879-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:17:45,887-0500 INFO  Multiplexer No streams
+2013-10-31 16:17:48,377-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:17:55,895-0500 INFO  Multiplexer No streams
+2013-10-31 16:18:04,626-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:18:05,903-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:18:15,911-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:18:25,919-0500 INFO  Multiplexer No streams
+2013-10-31 16:18:28,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:18:34,701-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:18:35,926-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:18:45,934-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:18:55,942-0500 INFO  Multiplexer No streams
+2013-10-31 16:19:04,776-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:19:05,949-0500 INFO  Multiplexer No streams
+2013-10-31 16:19:07,715-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:19:15,957-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:19:25,965-0500 INFO  Multiplexer No streams
+2013-10-31 16:19:34,851-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:19:35,972-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:19:45,980-0500 INFO  Multiplexer No streams
+2013-10-31 16:19:47,384-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:19:55,988-0500 INFO  Multiplexer No streams
+2013-10-31 16:20:04,926-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:20:05,996-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:20:16,003-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:20:26,011-0500 INFO  Multiplexer No streams
+2013-10-31 16:20:27,053-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:20:35,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:20:36,019-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:20:46,026-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:20:56,034-0500 INFO  Multiplexer No streams
+2013-10-31 16:21:05,077-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:21:06,042-0500 INFO  Multiplexer No streams
+2013-10-31 16:21:06,722-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:38:37,332-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:51564] for addition
-2013-10-28 14:38:37,336-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:51564] for addition
-Multiplexer 0 started
-2013-10-28 14:38:37,336-0500 INFO  Multiplexer Multiplexer 0 started
-Channel started: TCPChannel [type: server, contact: 140.221.8.81:51564]
-2013-10-28 14:38:37,336-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:51564]
-Multiplexer 1 started
-2013-10-28 14:38:37,336-0500 INFO  Multiplexer Multiplexer 1 started
-Channel id: channel-1-u-2f0d7f25-142009337ad--8000
-2013-10-28 14:38:37,358-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u-2f0d7f25-142009337ad--8000
-MetaChannel [context: cps-51564, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:51564]
-2013-10-28 14:38:37,358-0500 INFO  MetaChannel MetaChannel [context: cps-51564, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:51564]
-Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:51564]
-2013-10-28 14:38:37,358-0500 INFO  AbstractStreamCoasterChannel Using threaded sender for TCPChannel [type: server, contact: 140.221.8.81:51564]
-Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-10-28 14:38:37,359-0500 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-2013-10-28 14:38:37,401-0500 INFO  RequestHandler Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
-Handler(tag: 17769, SUBMITJOB) unregistering (send)
-2013-10-28 14:38:37,556-0500 INFO  RequestHandler Handler(tag: 17769, SUBMITJOB) unregistering (send)
+2013-10-31 16:21:11,823-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38863] for addition
+2013-10-31 16:21:11,823-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38863] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38863]
+2013-10-31 16:21:11,823-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38863]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff4
+2013-10-31 16:21:11,859-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff4
+MetaChannel [context: cps-38863, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38863]
+2013-10-31 16:21:11,859-0500 INFO  MetaChannel MetaChannel [context: cps-38863, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38863]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 16:21:11,859-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 16:21:11,899-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 16:21:11,899-0500 INFO  Sender Sender TCPChannel queue size: 0
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 16:21:11,980-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
 provider=local
-2013-10-28 14:38:37,581-0500 INFO  ExecutionTaskHandler provider=local
-Submit: in: null command: /bin/hostname
-2013-10-28 14:38:37,598-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 14:38:40,683-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 16:21:11,980-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /usr/bin/env X=x /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 16:21:11,981-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /usr/bin/env X=x /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
 Avg stream buf: 0
-2013-10-28 14:38:47,348-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:21:16,052-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:38:57,361-0500 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:38:58,673-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:21:26,060-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:21:35,152-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:39:07,375-0500 INFO  Multiplexer Avg stream buf: 0
-2013-10-28 14:39:11,641-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 16:21:36,068-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:39:17,388-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:21:46,075-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:21:46,391-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:39:27,402-0500 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-10-28 14:39:36,868-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 16:21:56,083-0500 INFO  Multiplexer Avg stream buf: 0
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 16:21:58,597-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38864] for addition
+2013-10-31 16:21:58,597-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38864] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:21:58,598-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38864]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff3
+2013-10-31 16:21:58,631-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff3
+MetaChannel [context: cps-38864, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:21:58,632-0500 INFO  MetaChannel MetaChannel [context: cps-38864, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:21:58,632-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 16:21:58,672-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 16:21:58,672-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 16:21:58,753-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 16:21:58,753-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 16:21:58,754-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /usr/bin/env X=x /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 16:22:05,227-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:39:37,414-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:22:06,094-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:22:16,102-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:22:26,059-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 16:22:26,110-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:22:35,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:22:36,118-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:22:46,126-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:22:56,135-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:23:05,377-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:23:05,729-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:23:06,143-0500 INFO  Multiplexer Avg stream buf: 0
+Notifying commands and handlers about exception
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-162111.980, now=131031-162312.823, channel=TCPChannel [type: server, contact: 140.221.8.81:38863]
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 16:23:12,823-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 16:23:12,823-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+Client could not properly process notification: null
+2013-10-31 16:23:12,823-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 16:23:12,824-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:23:12,824-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 16:23:12,824-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 16:23:12,824-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+Channel config: null -> {keepalive=null}
+2013-10-31 16:23:12,824-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38863] handling channel exception
+2013-10-31 16:23:12,825-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38863] handling channel exception
+null: Channel shut down
+2013-10-31 16:23:12,825-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38863, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38863]] binding to NullChannel
+2013-10-31 16:23:12,825-0500 INFO  MetaChannel MetaChannel [context: cps-38863, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38863]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38863]
+2013-10-31 16:23:12,825-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38863]
+2013-10-31 16:23:12,825-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:23:12,825-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:23:12,825-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:12,826-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:23:12,826-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:12,826-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:23:12,826-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+Channel exception handled
+2013-10-31 16:23:12,826-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 16:23:12,842-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 16:23:12,842-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 16:23:12,842-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 16:23:12,842-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38863] handling channel exception
+Channel already shut down
+2013-10-31 16:23:12,842-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38863]
+2013-10-31 16:23:12,842-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38863]
+Avg stream buf: 0
+2013-10-31 16:23:16,152-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:23:26,160-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:23:35,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:23:36,168-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:23:45,398-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:23:46,176-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:23:56,184-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-162158.753, now=131031-162359.597, channel=TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:23:59,598-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:23:59,598-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:23:59,598-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:59,598-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:23:59,599-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:23:59,599-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:59,599-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:23:59,599-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38864] handling channel exception
+2013-10-31 16:23:59,599-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38864] handling channel exception
+2013-10-31 16:23:59,600-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38864, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38864]] binding to NullChannel
+2013-10-31 16:23:59,600-0500 INFO  MetaChannel MetaChannel [context: cps-38864, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38864]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:23:59,600-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:23:59,600-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:23:59,600-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:23:59,600-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:59,600-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:23:59,601-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:23:59,601-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:23:59,601-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:23:59,601-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 16:23:59,614-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 16:23:59,614-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 16:23:59,614-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 16:23:59,614-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38864] handling channel exception
+2013-10-31 16:23:59,615-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:23:59,615-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38864]
+2013-10-31 16:24:05,527-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:24:06,193-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:24:16,201-0500 INFO  Multiplexer No streams
+2013-10-31 16:24:25,067-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:24:26,208-0500 INFO  Multiplexer No streams
+2013-10-31 16:24:35,602-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:24:36,216-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:24:46,224-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:24:56,231-0500 INFO  Multiplexer No streams
+2013-10-31 16:25:04,736-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:39:42,598-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:25:05,678-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:25:06,239-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:25:16,247-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:25:26,254-0500 INFO  Multiplexer No streams
+2013-10-31 16:25:35,753-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:25:36,262-0500 INFO  Multiplexer No streams
+2013-10-31 16:25:44,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:25:46,269-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:25:56,277-0500 INFO  Multiplexer No streams
+2013-10-31 16:26:05,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:26:06,284-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:26:16,292-0500 INFO  Multiplexer No streams
+2013-10-31 16:26:24,074-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:26:26,300-0500 INFO  Multiplexer No streams
+2013-10-31 16:26:35,903-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:26:36,307-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:26:46,315-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:26:56,322-0500 INFO  Multiplexer No streams
+2013-10-31 16:27:03,743-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:27:05,977-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:27:06,330-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:27:16,337-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:27:26,345-0500 INFO  Multiplexer No streams
+2013-10-31 16:27:36,053-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:27:36,353-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 16:27:43,413-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-10-31 16:27:46,361-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:27:56,369-0500 INFO  Multiplexer No streams
+2013-10-31 16:28:06,128-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:28:06,377-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:28:16,385-0500 INFO  Multiplexer No streams
+2013-10-31 16:28:23,081-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:28:26,393-0500 INFO  Multiplexer No streams
+2013-10-31 16:28:36,203-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:28:36,401-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:28:46,408-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:28:56,416-0500 INFO  Multiplexer No streams
+2013-10-31 16:29:02,750-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:29:06,278-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:29:06,424-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:29:16,432-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:29:26,440-0500 INFO  Multiplexer No streams
+2013-10-31 16:29:36,354-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:29:36,448-0500 INFO  Multiplexer No streams
+2013-10-31 16:29:42,419-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:29:46,456-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:29:56,463-0500 INFO  Multiplexer No streams
+2013-10-31 16:30:06,429-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:30:06,471-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:30:16,479-0500 INFO  Multiplexer No streams
+2013-10-31 16:30:22,088-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:30:26,487-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:30:36,495-0500 INFO  Multiplexer No streams
+2013-10-31 16:30:36,504-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:30:46,503-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:30:56,511-0500 INFO  Multiplexer No streams
+2013-10-31 16:31:01,757-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:31:06,518-0500 INFO  Multiplexer No streams
+2013-10-31 16:31:06,579-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:31:16,526-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:31:26,534-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:31:36,542-0500 INFO  Multiplexer No streams
+2013-10-31 16:31:36,653-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:31:41,426-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:31:46,550-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:31:56,558-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:32:06,565-0500 INFO  Multiplexer No streams
+2013-10-31 16:32:06,729-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:32:16,573-0500 INFO  Multiplexer No streams
+2013-10-31 16:32:21,095-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:32:26,581-0500 INFO  Multiplexer No streams
-2013-10-28 14:39:46,590-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:51565] for addition
-2013-10-28 14:39:46,591-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:51565] for addition
-Channel started: TCPChannel [type: server, contact: 140.221.8.81:51565]
-2013-10-28 14:39:46,591-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:51565]
-Channel id: channel-1-u-2f0d7f25-142009337ad--7fff
-2013-10-28 14:39:46,624-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u-2f0d7f25-142009337ad--7fff
-MetaChannel [context: cps-51565, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:51565]
-2013-10-28 14:39:46,624-0500 INFO  MetaChannel MetaChannel [context: cps-51565, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:51565]
-2013-10-28 14:39:46,624-0500 INFO  RequestHandler Handler(tag: 17767, CHANNELCONFIG) unregistering (send)
-2013-10-28 14:39:46,665-0500 INFO  RequestHandler Handler(tag: 17768, CONFIGSERVICE) unregistering (send)
+2013-10-31 16:32:31,431-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38874] for addition
+2013-10-31 16:32:31,431-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38874] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:32:31,431-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38874]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff2
+2013-10-31 16:32:31,455-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff2
+MetaChannel [context: cps-38874, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:32:31,456-0500 INFO  MetaChannel MetaChannel [context: cps-38874, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:32:31,456-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 16:32:31,496-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
-2013-10-28 14:39:46,665-0500 INFO  Sender Sender TCPChannel queue size: 0
-2013-10-28 14:39:46,745-0500 INFO  RequestHandler Handler(tag: 17769, SUBMITJOB) unregistering (send)
+2013-10-31 16:32:31,496-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 16:32:31,577-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
 provider=local
-2013-10-28 14:39:46,745-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 16:32:31,577-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 16:32:31,577-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /usr/bin/env X=x /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+Avg stream buf: 0
+2013-10-31 16:32:36,591-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:32:36,804-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:32:46,600-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:32:56,609-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:33:00,764-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:33:06,618-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:33:06,879-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:33:16,627-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:33:26,636-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:33:36,644-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:33:36,954-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:33:38,208-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38880] for addition
+2013-10-31 16:33:38,208-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38880] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:33:38,208-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38880]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff1
+2013-10-31 16:33:38,232-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff1
+MetaChannel [context: cps-38880, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:33:38,233-0500 INFO  MetaChannel MetaChannel [context: cps-38880, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:33:38,233-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 16:33:38,274-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 16:33:38,274-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 16:33:38,355-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 16:33:38,355-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/d
+2013-10-31 16:33:38,355-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/d
+2013-10-31 16:33:40,433-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:33:46,659-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:33:56,668-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:34:06,677-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:34:07,029-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:34:16,685-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:34:20,102-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:34:26,694-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-163231.577, now=131031-163432.431, channel=TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:34:32,431-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:34:32,432-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:34:32,432-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:34:32,432-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:34:32,432-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:34:32,433-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:34:32,433-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:34:32,433-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38874] handling channel exception
+2013-10-31 16:34:32,433-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38874] handling channel exception
+2013-10-31 16:34:32,433-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38874, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38874]] binding to NullChannel
+2013-10-31 16:34:32,434-0500 INFO  MetaChannel MetaChannel [context: cps-38874, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38874]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:34:32,434-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:34:32,434-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:34:32,434-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:34:32,434-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:34:32,434-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:34:32,434-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:34:32,435-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:34:32,435-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:34:32,435-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 16:34:32,451-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 16:34:32,451-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 16:34:32,451-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 16:34:32,451-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38874] handling channel exception
+2013-10-31 16:34:32,451-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38874]
+2013-10-31 16:34:32,451-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38874]
+Avg stream buf: 0
+2013-10-31 16:34:36,704-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:34:37,103-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 16:34:46,712-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:34:56,720-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:34:59,771-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:35:06,728-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:35:07,179-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:35:16,737-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:35:26,745-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:35:36,754-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:35:37,254-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-163338.355, now=131031-163539.208, channel=TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:35:39,208-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:35:39,209-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:35:39,209-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:35:39,209-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:35:39,209-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:35:39,209-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:35:39,210-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38880] handling channel exception
+2013-10-31 16:35:39,210-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38880] handling channel exception
+2013-10-31 16:35:39,210-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38880, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38880]] binding to NullChannel
+2013-10-31 16:35:39,210-0500 INFO  MetaChannel MetaChannel [context: cps-38880, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38880]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:35:39,210-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:35:39,210-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:35:39,211-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:35:39,211-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:35:39,211-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:35:39,211-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:35:39,211-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:35:39,212-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 16:35:39,221-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 16:35:39,221-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 16:35:39,222-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 16:35:39,222-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38880] handling channel exception
+2013-10-31 16:35:39,222-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:35:39,222-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38880]
+2013-10-31 16:35:39,440-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:35:44,715-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38881] for addition
+2013-10-31 16:35:44,715-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38881] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:35:44,716-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38881]
+Channel id: channel-1-u56c1e1d7-14210098df7--7ff0
+2013-10-31 16:35:44,738-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7ff0
+MetaChannel [context: cps-38881, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:35:44,738-0500 INFO  MetaChannel MetaChannel [context: cps-38881, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:35:44,739-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 16:35:44,779-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 16:35:44,779-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 16:35:44,860-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/date
+2013-10-31 16:35:44,861-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+2013-10-31 16:35:44,861-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+Avg stream buf: 0
+2013-10-31 16:35:46,767-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:35:56,776-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:36:06,784-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:36:07,329-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:36:16,793-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:36:19,109-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:36:26,802-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:36:36,810-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:36:37,404-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:36:46,819-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:36:56,828-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:36:58,778-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:37:06,836-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:37:07,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 16:37:16,845-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:37:26,854-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 16:37:36,862-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 16:37:37,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:37:38,447-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-163544.860, now=131031-163745.715, channel=TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:37:45,715-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:37:45,715-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:37:45,715-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:37:45,716-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:37:45,716-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:37:45,716-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:37:45,716-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:37:45,716-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38881] handling channel exception
+2013-10-31 16:37:45,717-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38881] handling channel exception
+2013-10-31 16:37:45,717-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38881, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38881]] binding to NullChannel
+2013-10-31 16:37:45,717-0500 INFO  MetaChannel MetaChannel [context: cps-38881, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38881]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:37:45,717-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:37:45,717-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 16:37:45,717-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 16:37:45,717-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:37:45,718-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 16:37:45,718-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 16:37:45,718-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 16:37:45,718-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 16:37:45,718-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 16:37:45,728-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 16:37:45,728-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 16:37:45,728-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 16:37:45,728-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38881] handling channel exception
+2013-10-31 16:37:45,728-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38881]
+2013-10-31 16:37:45,728-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38881]
+No streams
+2013-10-31 16:37:46,872-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:37:56,880-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:38:06,887-0500 INFO  Multiplexer No streams
+2013-10-31 16:38:07,629-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:38:16,895-0500 INFO  Multiplexer No streams
+2013-10-31 16:38:18,116-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:38:26,903-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:38:36,911-0500 INFO  Multiplexer No streams
+2013-10-31 16:38:37,704-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:38:46,919-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:38:56,927-0500 INFO  Multiplexer No streams
+2013-10-31 16:38:57,785-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:39:06,935-0500 INFO  Multiplexer No streams
+2013-10-31 16:39:07,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:39:16,943-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:39:26,950-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:39:36,958-0500 INFO  Multiplexer No streams
+2013-10-31 16:39:37,454-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:39:37,854-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:39:46,966-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:39:56,974-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:40:06,982-0500 INFO  Multiplexer No streams
+2013-10-31 16:40:07,929-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:40:16,989-0500 INFO  Multiplexer No streams
+2013-10-31 16:40:17,123-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:40:26,997-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:40:37,005-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:40:38,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:40:47,013-0500 INFO  Multiplexer No streams
+2013-10-31 16:40:56,792-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:40:57,020-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:41:07,028-0500 INFO  Multiplexer No streams
+2013-10-31 16:41:08,079-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:41:17,036-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:41:27,044-0500 INFO  Multiplexer No streams
+2013-10-31 16:41:36,461-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:41:37,051-0500 INFO  Multiplexer No streams
+2013-10-31 16:41:38,154-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:41:47,059-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:41:57,067-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:42:07,075-0500 INFO  Multiplexer No streams
+2013-10-31 16:42:08,229-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:42:16,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:42:17,082-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:42:27,090-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:42:37,098-0500 INFO  Multiplexer No streams
+2013-10-31 16:42:38,304-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:42:47,105-0500 INFO  Multiplexer No streams
+2013-10-31 16:42:55,799-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:42:57,113-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:43:07,121-0500 INFO  Multiplexer No streams
+2013-10-31 16:43:08,379-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:43:17,131-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:43:27,139-0500 INFO  Multiplexer No streams
+2013-10-31 16:43:35,468-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:43:37,147-0500 INFO  Multiplexer No streams
+2013-10-31 16:43:38,454-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:43:47,155-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:43:57,163-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:44:07,171-0500 INFO  Multiplexer No streams
+2013-10-31 16:44:08,529-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:44:15,137-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:44:17,179-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:44:27,187-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:44:37,195-0500 INFO  Multiplexer No streams
+2013-10-31 16:44:38,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:44:47,204-0500 INFO  Multiplexer No streams
+2013-10-31 16:44:54,806-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:44:57,212-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:45:07,220-0500 INFO  Multiplexer No streams
+2013-10-31 16:45:08,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:45:17,228-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:45:27,236-0500 INFO  Multiplexer No streams
+2013-10-31 16:45:34,475-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:45:37,244-0500 INFO  Multiplexer No streams
+2013-10-31 16:45:38,755-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:45:47,252-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:45:57,260-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:46:07,268-0500 INFO  Multiplexer No streams
+2013-10-31 16:46:08,829-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 16:46:14,144-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:46:17,276-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:46:27,284-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:46:37,292-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:46:38,905-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:46:47,295-0500 INFO  Multiplexer No streams
+2013-10-31 16:46:53,813-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:46:57,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:47:07,311-0500 INFO  Multiplexer No streams
+2013-10-31 16:47:08,980-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:47:17,319-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:47:27,327-0500 INFO  Multiplexer No streams
+2013-10-31 16:47:33,482-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:47:37,335-0500 INFO  Multiplexer No streams
+2013-10-31 16:47:39,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:47:47,343-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:47:57,351-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:48:07,359-0500 INFO  Multiplexer No streams
+2013-10-31 16:48:09,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:48:13,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:48:17,367-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:48:27,375-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:48:37,383-0500 INFO  Multiplexer No streams
+2013-10-31 16:48:39,205-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:48:47,391-0500 INFO  Multiplexer No streams
+2013-10-31 16:48:52,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:48:57,399-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:49:07,407-0500 INFO  Multiplexer No streams
+2013-10-31 16:49:09,280-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:49:17,415-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:49:27,424-0500 INFO  Multiplexer No streams
+2013-10-31 16:49:32,490-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:49:37,431-0500 INFO  Multiplexer No streams
+2013-10-31 16:49:39,355-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:49:47,439-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:49:57,446-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:50:07,454-0500 INFO  Multiplexer No streams
+2013-10-31 16:50:09,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:50:12,159-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:50:17,461-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:50:27,469-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:50:37,477-0500 INFO  Multiplexer No streams
+2013-10-31 16:50:39,505-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:50:47,484-0500 INFO  Multiplexer No streams
+2013-10-31 16:50:51,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:50:57,492-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:51:07,499-0500 INFO  Multiplexer No streams
+2013-10-31 16:51:09,580-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:51:17,507-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:51:27,515-0500 INFO  Multiplexer No streams
+2013-10-31 16:51:31,497-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:51:37,522-0500 INFO  Multiplexer No streams
+2013-10-31 16:51:39,655-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:51:47,530-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:51:57,537-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:52:07,545-0500 INFO  Multiplexer No streams
+2013-10-31 16:52:09,730-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 16:52:11,166-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:52:17,552-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:52:27,560-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:52:37,567-0500 INFO  Multiplexer No streams
+2013-10-31 16:52:39,805-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:52:47,575-0500 INFO  Multiplexer No streams
+2013-10-31 16:52:50,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:52:57,582-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:53:07,590-0500 INFO  Multiplexer No streams
+2013-10-31 16:53:09,879-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:53:17,598-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:53:27,605-0500 INFO  Multiplexer No streams
+2013-10-31 16:53:30,504-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:53:37,613-0500 INFO  Multiplexer No streams
+2013-10-31 16:53:39,955-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:53:47,620-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:53:57,628-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:54:07,636-0500 INFO  Multiplexer No streams
+2013-10-31 16:54:10,030-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:54:10,173-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:54:17,643-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:54:27,651-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:54:37,658-0500 INFO  Multiplexer No streams
+2013-10-31 16:54:40,105-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:54:47,666-0500 INFO  Multiplexer No streams
+2013-10-31 16:54:49,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:54:57,674-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:55:07,681-0500 INFO  Multiplexer No streams
+2013-10-31 16:55:10,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:55:17,689-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:55:27,696-0500 INFO  Multiplexer No streams
+2013-10-31 16:55:29,511-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:55:37,704-0500 INFO  Multiplexer No streams
+2013-10-31 16:55:40,255-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:55:47,712-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:55:57,719-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:56:07,727-0500 INFO  Multiplexer No streams
+2013-10-31 16:56:09,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:56:10,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 16:56:17,734-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:56:27,742-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:56:37,750-0500 INFO  Multiplexer No streams
+2013-10-31 16:56:40,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:56:47,757-0500 INFO  Multiplexer No streams
+2013-10-31 16:56:48,849-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:56:57,765-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:57:07,773-0500 INFO  Multiplexer No streams
+2013-10-31 16:57:10,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:57:17,780-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:57:27,788-0500 INFO  Multiplexer No streams
+2013-10-31 16:57:28,518-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:57:37,796-0500 INFO  Multiplexer No streams
+2013-10-31 16:57:40,555-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:57:47,803-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:57:57,811-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:58:07,818-0500 INFO  Multiplexer No streams
+2013-10-31 16:58:08,187-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 16:58:10,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:58:17,826-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:58:27,833-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:58:37,841-0500 INFO  Multiplexer No streams
+2013-10-31 16:58:40,705-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:58:47,848-0500 INFO  Multiplexer No streams
+2013-10-31 16:58:47,856-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:58:57,855-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:59:07,863-0500 INFO  Multiplexer No streams
+2013-10-31 16:59:10,780-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:59:17,871-0500 INFO  Multiplexer No streams
+2013-10-31 16:59:27,525-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 16:59:27,878-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:59:37,886-0500 INFO  Multiplexer No streams
+2013-10-31 16:59:40,854-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 16:59:47,893-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 16:59:57,901-0500 INFO  Multiplexer No streams
+2013-10-31 17:00:07,194-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:00:07,909-0500 INFO  Multiplexer No streams
+2013-10-31 17:00:10,930-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:00:17,916-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:00:27,924-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:00:37,932-0500 INFO  Multiplexer No streams
+2013-10-31 17:00:41,004-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 17:00:46,863-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 17:00:47,939-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:00:57,947-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:01:07,955-0500 INFO  Multiplexer No streams
+2013-10-31 17:01:11,080-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:01:17,962-0500 INFO  Multiplexer No streams
+2013-10-31 17:01:26,533-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:01:27,970-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:01:37,978-0500 INFO  Multiplexer No streams
+2013-10-31 17:01:41,155-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:01:47,985-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:01:57,993-0500 INFO  Multiplexer No streams
+2013-10-31 17:02:06,202-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:02:08,001-0500 INFO  Multiplexer No streams
+2013-10-31 17:02:11,229-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:02:18,008-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:02:28,016-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:02:38,024-0500 INFO  Multiplexer No streams
+2013-10-31 17:02:41,305-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:02:45,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:02:48,031-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:02:58,039-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:03:08,046-0500 INFO  Multiplexer No streams
+2013-10-31 17:03:11,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:03:18,054-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 17:03:25,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-10-31 17:03:28,062-0500 INFO  Multiplexer No streams
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 17:03:28,827-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38913] for addition
+2013-10-31 17:03:28,827-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38913] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38913]
+2013-10-31 17:03:28,827-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38913]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fef
+2013-10-31 17:03:28,865-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fef
+MetaChannel [context: cps-38913, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38913]
+2013-10-31 17:03:28,865-0500 INFO  MetaChannel MetaChannel [context: cps-38913, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38913]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:03:28,865-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:03:28,906-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 17:03:28,906-0500 INFO  Sender Sender TCPChannel queue size: 0
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:03:28,986-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:03:28,986-0500 INFO  ExecutionTaskHandler provider=local
 Submit: in: null command: /bin/hostname
-2013-10-28 14:39:46,746-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+2013-10-31 17:03:28,987-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+2013-10-31 17:03:29,050-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38914] for addition
+2013-10-31 17:03:29,050-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38914] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38914]
+2013-10-31 17:03:29,050-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38914]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fee
+2013-10-31 17:03:29,087-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fee
+MetaChannel [context: cps-38914, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38914]
+2013-10-31 17:03:29,087-0500 INFO  MetaChannel MetaChannel [context: cps-38914, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38914]
+Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:03:29,087-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:03:29,128-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 17:03:29,208-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:03:29,208-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/hostname -f
+2013-10-31 17:03:29,209-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
 Avg stream buf: 0
-2013-10-28 14:39:47,428-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:03:38,074-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:03:41,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:39:57,441-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:03:48,082-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:40:07,453-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:03:58,090-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:04:05,209-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:04:08,098-0500 INFO  Multiplexer Avg stream buf: 0
-2013-10-28 14:40:13,557-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:40:15,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:04:11,530-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:40:17,466-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:04:18,107-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:40:27,477-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:04:28,116-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:40:37,489-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:04:38,124-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:04:41,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:04:44,878-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:04:48,133-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:04:58,142-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:05:08,151-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:05:11,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:05:18,160-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:05:24,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:05:28,168-0500 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131028-143837.483, now=131028-144038.333, channel=TCPChannel [type: server, contact: 140.221.8.81:51564]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170328.986, now=131031-170529.827, channel=TCPChannel [type: server, contact: 140.221.8.81:38913]
 	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
 	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
 	at java.util.TimerThread.mainLoop(Timer.java:534)
 	at java.util.TimerThread.run(Timer.java:484)
-2013-10-28 14:40:38,336-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:05:29,827-0500 INFO  ChannelContext Notifying commands and handlers about exception
-=> Command(tag: 1, RLOG)
-2013-10-28 14:40:38,338-0500 INFO  ChannelContext => Command(tag: 1, RLOG)
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 17:05:29,828-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+Client could not properly process notification: null
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 17:05:29,828-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,338-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:05:29,828-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-10-28 14:40:38,338-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,339-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:05:29,828-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-10-28 14:40:38,339-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,339-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:29,829-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:29,829-0500 WARN  TaskNotifier Client could not properly process notification: null
-=> Command(tag: 5, JOBSTATUS)
-2013-10-28 14:40:38,340-0500 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
+Channel config: null -> {keepalive=null}
+2013-10-31 17:05:29,829-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38913] handling channel exception
+2013-10-31 17:05:29,829-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38913] handling channel exception
+null: Channel shut down
+2013-10-31 17:05:29,829-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38913, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38913]] binding to NullChannel
+2013-10-31 17:05:29,829-0500 INFO  MetaChannel MetaChannel [context: cps-38913, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38913]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38913]
+2013-10-31 17:05:29,829-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38913]
+Notifying commands and handlers about exception
+2013-10-31 17:05:29,829-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:05:29,830-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-10-28 14:40:38,340-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:05:29,830-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 17:05:29,830-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 17:05:29,830-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:29,830-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:29,831-0500 WARN  TaskNotifier Client could not properly process notification: null
+Channel exception handled
+2013-10-31 17:05:29,831-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 17:05:29,833-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 17:05:29,833-0500 INFO  Multiplexer Exception in channel step
-2013-10-28 14:40:38,340-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 140.221.8.81:51564] handling channel exception
+2013-10-31 17:05:29,833-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:05:29,834-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38913] handling channel exception
+Channel already shut down
+2013-10-31 17:05:29,834-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38913]
+2013-10-31 17:05:29,834-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38913]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170329.208, now=131031-170530.050, channel=TCPChannel [type: server, contact: 140.221.8.81:38914]
-2013-10-28 14:40:38,340-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:51564] handling channel exception
+2013-10-31 17:05:30,050-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:05:30,050-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:05:30,050-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:05:30,050-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:05:30,051-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:05:30,051-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:05:30,051-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:30,051-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38914] handling channel exception
+2013-10-31 17:05:30,051-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38914] handling channel exception
-2013-10-28 14:40:38,341-0500 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-51564, boundTo: TCPChannel [type: server, contact: 140.221.8.81:51564]] binding to NullChannel
-2013-10-28 14:40:38,342-0500 INFO  MetaChannel MetaChannel [context: cps-51564, boundTo: TCPChannel [type: server, contact: 140.221.8.81:51564]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:51564]
-2013-10-28 14:40:38,342-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:51564]
+2013-10-31 17:05:30,052-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38914, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38914]] binding to NullChannel
+2013-10-31 17:05:30,052-0500 INFO  MetaChannel MetaChannel [context: cps-38914, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38914]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38914]
+2013-10-31 17:05:30,052-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38914]
-2013-10-28 14:40:38,342-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:05:30,052-0500 INFO  ChannelContext Notifying commands and handlers about exception
-2013-10-28 14:40:38,343-0500 INFO  ChannelContext => Command(tag: 1, RLOG)
+2013-10-31 17:05:30,052-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:05:30,052-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,343-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:05:30,052-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-10-28 14:40:38,343-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,343-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:05:30,053-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:05:30,053-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:40:38,343-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:05:30,053-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-10-28 14:40:38,344-0500 INFO  ChannelContext => Command(tag: 5, JOBSTATUS)
+2013-10-31 17:05:30,053-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:05:30,054-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:05:30,055-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:05:30,055-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:05:30,055-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38914] handling channel exception
+2013-10-31 17:05:30,055-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38914]
+2013-10-31 17:05:30,055-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38914]
+No streams
+2013-10-31 17:05:38,178-0500 INFO  Multiplexer No streams
+2013-10-31 17:05:41,755-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:05:48,186-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:05:58,193-0500 INFO  Multiplexer No streams
+2013-10-31 17:05:59,951-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38920] for addition
+2013-10-31 17:05:59,952-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38920] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:05:59,952-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38920]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fed
+2013-10-31 17:05:59,979-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fed
+MetaChannel [context: cps-38920, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:05:59,979-0500 INFO  MetaChannel MetaChannel [context: cps-38920, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:05:59,980-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:06:00,020-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:06:00,020-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 17:06:00,101-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:06:00,101-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:06:00,102-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:06:00,141-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38921] for addition
+2013-10-31 17:06:00,141-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38921] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:06:00,141-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38921]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fec
+2013-10-31 17:06:00,182-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fec
+MetaChannel [context: cps-38921, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:06:00,182-0500 INFO  MetaChannel MetaChannel [context: cps-38921, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:06:00,182-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:06:00,222-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:06:00,303-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:06:00,303-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 17:06:00,304-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:06:04,216-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:06:08,206-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:06:11,830-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:06:18,214-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:06:28,223-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:06:38,232-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:06:41,905-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:06:43,885-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 17:06:48,240-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:06:58,249-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:07:08,257-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:07:11,980-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:07:18,273-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:07:23,555-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:07:28,282-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:07:38,291-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:07:42,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:07:48,299-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:07:58,308-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170600.100, now=131031-170800.952, channel=TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:08:00,952-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:08:00,952-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-10-28 14:40:38,344-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:00,952-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:00,953-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:08:00,953-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:00,953-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:08:00,953-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:08:00,954-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38920] handling channel exception
+2013-10-31 17:08:00,954-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38920] handling channel exception
+2013-10-31 17:08:00,954-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38920, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38920]] binding to NullChannel
+2013-10-31 17:08:00,954-0500 INFO  MetaChannel MetaChannel [context: cps-38920, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38920]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:08:00,954-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:08:00,954-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:08:00,954-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:08:00,955-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:00,955-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:08:00,955-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:08:00,955-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-10-28 14:40:38,344-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:08:00,955-0500 INFO  ChannelManager Channel exception handled
-2013-10-28 14:40:38,351-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:08:00,956-0500 INFO  Multiplexer Channel is closed. Removing.
-2013-10-28 14:40:38,352-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:08:00,956-0500 INFO  Multiplexer Exception in channel step
-2013-10-28 14:40:38,352-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:08:00,956-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-10-28 14:40:38,352-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:51564] handling channel exception
+2013-10-31 17:08:00,956-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38920] handling channel exception
-2013-10-28 14:40:38,352-0500 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:51564]
-2013-10-28 14:40:38,352-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:51564]
+2013-10-31 17:08:00,956-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38920]
+2013-10-31 17:08:00,956-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38920]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170600.303, now=131031-170801.141, channel=TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:08:01,141-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:08:01,141-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:08:01,141-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:01,141-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:08:01,141-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:08:01,142-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:08:01,142-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:01,142-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38921] handling channel exception
+2013-10-31 17:08:01,142-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38921] handling channel exception
+2013-10-31 17:08:01,142-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38921, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38921]] binding to NullChannel
+2013-10-31 17:08:01,142-0500 INFO  MetaChannel MetaChannel [context: cps-38921, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38921]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:08:01,142-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:08:01,143-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:08:01,143-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:08:01,143-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:01,143-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:08:01,143-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:08:01,143-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:08:01,144-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:08:01,144-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:08:01,157-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:08:01,157-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:08:01,157-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:08:01,157-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38921] handling channel exception
+2013-10-31 17:08:01,158-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:08:01,158-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38921]
+2013-10-31 17:08:03,224-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:08:08,318-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:08:12,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:08:18,326-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:08:28,334-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:08:38,341-0500 INFO  Multiplexer No streams
+2013-10-31 17:08:42,205-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:08:42,893-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:08:48,349-0500 INFO  Multiplexer No streams
+2013-10-31 17:08:56,891-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38932] for addition
+2013-10-31 17:08:56,891-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38932] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:08:56,891-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38932]
+Channel id: channel-1-u56c1e1d7-14210098df7--7feb
+2013-10-31 17:08:56,914-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7feb
+MetaChannel [context: cps-38932, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:08:56,914-0500 INFO  MetaChannel MetaChannel [context: cps-38932, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:08:56,914-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:08:56,955-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:08:56,955-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 17:08:57,036-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:08:57,036-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:08:57,036-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:08:57,077-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38933] for addition
+2013-10-31 17:08:57,078-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38933] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:08:57,078-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38933]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fea
+2013-10-31 17:08:57,117-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fea
+MetaChannel [context: cps-38933, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:08:57,117-0500 INFO  MetaChannel MetaChannel [context: cps-38933, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:08:57,117-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:08:57,137-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:08:57,218-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:08:57,218-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:08:57,218-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+Avg stream buf: 0
+2013-10-31 17:08:58,361-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:09:08,370-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:09:12,280-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:09:18,379-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:09:22,562-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:09:28,388-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:09:38,396-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:09:39,293-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38934] for addition
+2013-10-31 17:09:39,294-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38934] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:09:39,294-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38934]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe9
+2013-10-31 17:09:39,320-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe9
+MetaChannel [context: cps-38934, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:09:39,320-0500 INFO  MetaChannel MetaChannel [context: cps-38934, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:09:39,320-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:09:39,361-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 17:09:39,361-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:09:39,442-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/date
+2013-10-31 17:09:39,443-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+2013-10-31 17:09:39,443-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
-2013-10-28 14:40:44,514-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:09:42,355-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:40:47,501-0500 INFO  Multiplexer Avg stream buf: 0
-2013-10-28 14:40:53,255-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:09:48,416-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:40:57,511-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:09:58,425-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 17:10:02,232-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
 Avg stream buf: 0
-2013-10-28 14:41:07,521-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:10:08,434-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:10:12,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 17:10:18,442-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:10:28,452-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:10:38,460-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:10:41,900-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:10:42,506-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:10:48,469-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170857.035, now=131031-171057.891, channel=TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:10:57,891-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:10:57,891-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:10:57,891-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:57,892-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:10:57,892-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:57,892-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:10:57,892-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:10:57,893-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38932] handling channel exception
+2013-10-31 17:10:57,893-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38932] handling channel exception
+2013-10-31 17:10:57,893-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38932, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38932]] binding to NullChannel
+2013-10-31 17:10:57,893-0500 INFO  MetaChannel MetaChannel [context: cps-38932, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38932]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:10:57,893-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:10:57,893-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:10:57,893-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:10:57,893-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:57,894-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:10:57,894-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:57,894-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:10:57,894-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:10:57,894-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:10:57,897-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:10:57,897-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:10:57,897-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:10:57,897-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38932] handling channel exception
+2013-10-31 17:10:57,897-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38932]
+2013-10-31 17:10:57,897-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38932]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170857.218, now=131031-171058.078, channel=TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:10:58,078-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:10:58,078-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:10:58,078-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:58,078-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:10:58,078-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:10:58,079-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:58,079-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:10:58,079-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38933] handling channel exception
+2013-10-31 17:10:58,079-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38933] handling channel exception
+2013-10-31 17:10:58,079-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38933, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38933]] binding to NullChannel
+2013-10-31 17:10:58,080-0500 INFO  MetaChannel MetaChannel [context: cps-38933, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38933]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:10:58,080-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:10:58,080-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:10:58,080-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:10:58,080-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:58,080-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:10:58,080-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:10:58,081-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:10:58,081-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:10:58,081-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:10:58,098-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:10:58,098-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:10:58,098-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:10:58,098-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38933] handling channel exception
+2013-10-31 17:10:58,098-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38933]
+2013-10-31 17:10:58,098-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38933]
+Avg stream buf: 0
+2013-10-31 17:10:58,480-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:11:08,488-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:11:12,582-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:11:18,496-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:11:21,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:11:28,505-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:11:38,513-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-170939.442, now=131031-171140.293, channel=TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:11:40,293-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:11:40,293-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:11:40,293-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:11:40,293-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:11:40,294-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:11:40,294-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:11:40,294-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:11:40,294-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38934] handling channel exception
+2013-10-31 17:11:40,294-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38934] handling channel exception
+2013-10-31 17:11:40,295-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38934, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38934]] binding to NullChannel
+2013-10-31 17:11:40,295-0500 INFO  MetaChannel MetaChannel [context: cps-38934, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38934]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:11:40,295-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:11:40,295-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:11:40,295-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:11:40,295-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:11:40,295-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:11:40,296-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:11:40,296-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:11:40,296-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:11:40,296-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:11:40,298-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:11:40,299-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:11:40,299-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:11:40,299-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38934] handling channel exception
+2013-10-31 17:11:40,299-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38934]
+2013-10-31 17:11:40,299-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38934]
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:11:42,657-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:11:48,522-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:11:58,530-0500 INFO  Multiplexer No streams
+2013-10-31 17:12:01,238-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:12:08,538-0500 INFO  Multiplexer No streams
+2013-10-31 17:12:12,733-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:12:18,545-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:12:28,553-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:12:38,561-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 17:12:40,908-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 17:12:42,809-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:12:48,572-0500 INFO  Multiplexer No streams
+2013-10-31 17:12:58,400-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38953] for addition
+2013-10-31 17:12:58,400-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38953] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:12:58,400-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38953]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe8
+2013-10-31 17:12:58,421-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe8
+MetaChannel [context: cps-38953, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:12:58,422-0500 INFO  MetaChannel MetaChannel [context: cps-38953, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:12:58,422-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:12:58,462-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:12:58,462-0500 INFO  Sender Sender TCPChannel queue size: 0
+provider=local
+2013-10-31 17:12:58,543-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:12:58,543-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:12:58,543-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+Avg stream buf: 0
+2013-10-31 17:12:58,583-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:12:58,585-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38954] for addition
+2013-10-31 17:12:58,585-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38954] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:12:58,585-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38954]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fe7
+2013-10-31 17:12:58,624-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fe7
+MetaChannel [context: cps-38954, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:12:58,624-0500 INFO  MetaChannel MetaChannel [context: cps-38954, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:12:58,624-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:12:58,645-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:12:58,725-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:12:58,725-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:12:58,726-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:13:00,166-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38958] for addition
+2013-10-31 17:13:00,166-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38958] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:13:00,167-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38958]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe6
+2013-10-31 17:13:00,191-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe6
+MetaChannel [context: cps-38958, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:13:00,191-0500 INFO  MetaChannel MetaChannel [context: cps-38958, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:13:00,191-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:13:00,232-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:13:00,313-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:13:00,313-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:13:00,313-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:13:00,354-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38959] for addition
+2013-10-31 17:13:00,354-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38959] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:13:00,354-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38959]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fe5
+2013-10-31 17:13:00,393-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fe5
+MetaChannel [context: cps-38959, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:13:00,393-0500 INFO  MetaChannel MetaChannel [context: cps-38959, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:13:00,394-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:13:00,454-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:13:00,535-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:13:00,535-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 17:13:00,536-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 17:13:03,027-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38960] for addition
+2013-10-31 17:13:03,027-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38960] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:13:03,027-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38960]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe4
+2013-10-31 17:13:03,065-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe4
+MetaChannel [context: cps-38960, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:13:03,065-0500 INFO  MetaChannel MetaChannel [context: cps-38960, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:13:03,066-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:13:03,126-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:13:03,207-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:13:03,207-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/echo
+2013-10-31 17:13:03,208-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/echo
+2013-10-31 17:13:04,470-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38961] for addition
+2013-10-31 17:13:04,471-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38961] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:13:04,471-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38961]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe3
+2013-10-31 17:13:04,493-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe3
+MetaChannel [context: cps-38961, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:13:04,493-0500 INFO  MetaChannel MetaChannel [context: cps-38961, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:13:04,493-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:13:04,534-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:13:04,614-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:13:04,614-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:13:04,616-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+Avg stream buf: 0
+2013-10-31 17:13:08,592-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:13:12,884-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:13:18,611-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:13:20,577-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+Avg stream buf: 0
+2013-10-31 17:13:28,623-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:13:38,637-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:13:42,959-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:13:48,651-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:13:58,667-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:14:00,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:14:08,679-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:14:13,034-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:14:18,693-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:14:28,699-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:14:38,717-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:14:39,915-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-10-31 17:14:43,109-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:14:48,733-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:14:58,733-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171258.543, now=131031-171459.400, channel=TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:14:59,400-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:14:59,401-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:14:59,401-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,401-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:14:59,401-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:14:59,402-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:14:59,402-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,402-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38953] handling channel exception
+2013-10-31 17:14:59,402-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38953] handling channel exception
+2013-10-31 17:14:59,402-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38953, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38953]] binding to NullChannel
+2013-10-31 17:14:59,403-0500 INFO  MetaChannel MetaChannel [context: cps-38953, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38953]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:14:59,403-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:14:59,403-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:14:59,403-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:14:59,403-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,403-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:14:59,403-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:14:59,404-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:14:59,404-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,404-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:14:59,416-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:14:59,416-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:14:59,416-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:14:59,416-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38953] handling channel exception
+2013-10-31 17:14:59,417-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38953]
+2013-10-31 17:14:59,417-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38953]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171258.725, now=131031-171459.585, channel=TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:14:59,585-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:14:59,586-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:14:59,586-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,586-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:14:59,586-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:14:59,587-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,587-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:14:59,587-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38954] handling channel exception
+2013-10-31 17:14:59,587-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38954] handling channel exception
+2013-10-31 17:14:59,588-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38954, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38954]] binding to NullChannel
+2013-10-31 17:14:59,588-0500 INFO  MetaChannel MetaChannel [context: cps-38954, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38954]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:14:59,588-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:14:59,588-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:14:59,588-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:14:59,588-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,588-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:14:59,589-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:14:59,589-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:14:59,589-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:14:59,589-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:14:59,598-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:14:59,598-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:14:59,598-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:14:59,598-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38954] handling channel exception
+2013-10-31 17:14:59,598-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38954]
+2013-10-31 17:14:59,599-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38954]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171300.312, now=131031-171501.166, channel=TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:15:01,166-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:01,166-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:01,166-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:01,167-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:01,167-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:01,167-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:01,167-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:01,167-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38958] handling channel exception
+2013-10-31 17:15:01,168-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38958] handling channel exception
+2013-10-31 17:15:01,168-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38958, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38958]] binding to NullChannel
+2013-10-31 17:15:01,168-0500 INFO  MetaChannel MetaChannel [context: cps-38958, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38958]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:15:01,168-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:15:01,168-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:01,168-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:01,169-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:01,169-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+Client could not properly process notification: null
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 17:15:01,169-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:01,169-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:01,170-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:15:01,184-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:15:01,185-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:15:01,185-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:15:01,185-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38958] handling channel exception
+2013-10-31 17:15:01,185-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38958]
+2013-10-31 17:15:01,185-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38958]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171300.535, now=131031-171501.354, channel=TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:15:01,354-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:01,354-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:01,354-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:01,354-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:01,355-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:01,355-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:01,355-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+Channel config: null -> {keepalive=null}
+2013-10-31 17:15:01,355-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38959] handling channel exception
+2013-10-31 17:15:01,355-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38959] handling channel exception
+null: Channel shut down
+2013-10-31 17:15:01,355-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38959, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38959]] binding to NullChannel
+2013-10-31 17:15:01,356-0500 INFO  MetaChannel MetaChannel [context: cps-38959, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38959]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:15:01,356-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38959]
+Notifying commands and handlers about exception
+2013-10-31 17:15:01,356-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:01,356-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:01,356-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:01,356-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:01,356-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:01,357-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:01,357-0500 WARN  TaskNotifier Client could not properly process notification: null
+Channel exception handled
+2013-10-31 17:15:01,357-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 17:15:01,366-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 17:15:01,366-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:15:01,366-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:15:01,366-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38959] handling channel exception
+Channel already shut down
+2013-10-31 17:15:01,366-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38959]
+2013-10-31 17:15:01,367-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38959]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171303.207, now=131031-171504.027, channel=TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:15:04,027-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:04,027-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:04,027-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:04,028-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:04,028-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:04,028-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:04,028-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:04,028-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38960] handling channel exception
+2013-10-31 17:15:04,029-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38960] handling channel exception
+2013-10-31 17:15:04,029-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38960, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38960]] binding to NullChannel
+2013-10-31 17:15:04,029-0500 INFO  MetaChannel MetaChannel [context: cps-38960, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38960]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:15:04,029-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:15:04,029-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:04,029-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:04,030-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:04,030-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:04,030-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:04,030-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:04,030-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:15:04,037-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:15:04,037-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:15:04,037-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:15:04,037-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38960] handling channel exception
+2013-10-31 17:15:04,038-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38960]
+2013-10-31 17:15:04,038-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38960]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171304.614, now=131031-171505.470, channel=TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:15:05,470-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:05,471-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:05,471-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:05,471-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:05,471-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:05,471-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:05,472-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38961] handling channel exception
+2013-10-31 17:15:05,472-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38961] handling channel exception
+2013-10-31 17:15:05,472-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38961, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38961]] binding to NullChannel
+2013-10-31 17:15:05,473-0500 INFO  MetaChannel MetaChannel [context: cps-38961, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38961]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:15:05,473-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:15:05,473-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:15:05,473-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:15:05,473-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:05,473-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:15:05,473-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:15:05,474-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:15:05,474-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:15:05,474-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:15:05,483-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:15:05,483-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:15:05,483-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:15:05,483-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38961] handling channel exception
+2013-10-31 17:15:05,484-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38961]
+2013-10-31 17:15:05,484-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38961]
+No streams
+2013-10-31 17:15:08,753-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 17:15:13,185-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 17:15:18,764-0500 INFO  Multiplexer No streams
+2013-10-31 17:15:19,584-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 17:15:28,773-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:15:38,783-0500 INFO  Multiplexer No streams
-2013-10-28 14:41:15,472-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:15:43,259-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:15:48,792-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:15:58,802-0500 INFO  Multiplexer No streams
+2013-10-31 17:15:59,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:16:08,811-0500 INFO  Multiplexer No streams
+2013-10-31 17:16:13,334-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:16:18,821-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:16:28,830-0500 INFO  Multiplexer No streams
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 17:16:36,512-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38972] for addition
+2013-10-31 17:16:36,512-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38972] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:16:36,512-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38972]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe2
+2013-10-31 17:16:36,534-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe2
+MetaChannel [context: cps-38972, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:16:36,534-0500 INFO  MetaChannel MetaChannel [context: cps-38972, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38972]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:16:36,535-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:16:36,575-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 17:16:36,575-0500 INFO  Sender Sender TCPChannel queue size: 0
+provider=local
+2013-10-31 17:16:36,656-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/hostname
+2013-10-31 17:16:36,657-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:16:36,658-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:16:36,700-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38973] for addition
+2013-10-31 17:16:36,701-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38973] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:16:36,701-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38973]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fe1
+2013-10-31 17:16:36,739-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fe1
+MetaChannel [context: cps-38973, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:16:36,739-0500 INFO  MetaChannel MetaChannel [context: cps-38973, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38973]
+Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:16:36,739-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:16:36,760-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:16:36,841-0500 INFO  ExecutionTaskHandler provider=local
+Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 17:16:36,841-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+Submit: in: null command: /bin/hostname -f
+2013-10-31 17:16:36,842-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
 Avg stream buf: 0
-2013-10-28 14:41:17,530-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:16:38,848-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:16:38,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:16:43,410-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 Avg stream buf: 0
-2013-10-28 14:41:27,539-0500 INFO  Multiplexer Avg stream buf: 0
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:41:31,449-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:16:48,861-0500 INFO  Multiplexer Avg stream buf: 0
 Avg stream buf: 0
-2013-10-28 14:41:37,548-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:16:58,874-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:17:08,887-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:17:13,484-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:17:18,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:17:18,898-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:17:28,910-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:17:38,922-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:17:43,560-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+Avg stream buf: 0
+2013-10-31 17:17:48,931-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:17:58,259-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:17:58,939-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:18:08,948-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:18:13,635-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:18:18,957-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:18:28,966-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171636.656, now=131031-171837.512, channel=TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:18:37,512-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:18:37,513-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:18:37,513-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,513-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:18:37,514-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:18:37,514-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,514-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:18:37,514-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38972] handling channel exception
+2013-10-31 17:18:37,514-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38972] handling channel exception
+2013-10-31 17:18:37,515-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38972, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38972]] binding to NullChannel
+2013-10-31 17:18:37,515-0500 INFO  MetaChannel MetaChannel [context: cps-38972, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38972]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:18:37,515-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:18:37,515-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:18:37,515-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:18:37,515-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,515-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:18:37,516-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:18:37,516-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,516-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:18:37,516-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:18:37,531-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:18:37,531-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:18:37,531-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:18:37,531-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38972] handling channel exception
+2013-10-31 17:18:37,531-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38972]
+2013-10-31 17:18:37,531-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38972]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171636.840, now=131031-171837.701, channel=TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:18:37,701-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:18:37,701-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:18:37,702-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,702-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:18:37,702-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:18:37,702-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:18:37,703-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38973] handling channel exception
+2013-10-31 17:18:37,703-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38973] handling channel exception
+2013-10-31 17:18:37,703-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38973, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38973]] binding to NullChannel
+2013-10-31 17:18:37,703-0500 INFO  MetaChannel MetaChannel [context: cps-38973, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38973]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:18:37,703-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:18:37,703-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:18:37,704-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:18:37,704-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:18:37,704-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:18:37,704-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:18:37,704-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:18:37,705-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:18:37,712-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:18:37,712-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:18:37,712-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:18:37,712-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38973] handling channel exception
+2013-10-31 17:18:37,713-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:18:37,713-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38973]
+2013-10-31 17:18:37,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:18:38,976-0500 INFO  Multiplexer No streams
-2013-10-28 14:41:46,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:18:43,710-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:18:48,984-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:18:58,992-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:19:09,000-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:19:13,785-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:19:17,597-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:19:19,008-0500 INFO  Multiplexer No streams
+2013-10-31 17:19:24,833-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38980] for addition
+2013-10-31 17:19:24,833-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38980] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38980]
+2013-10-31 17:19:24,833-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38980]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fe0
+2013-10-31 17:19:24,866-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fe0
+MetaChannel [context: cps-38980, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38980]
+2013-10-31 17:19:24,866-0500 INFO  MetaChannel MetaChannel [context: cps-38980, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38980]
+2013-10-31 17:19:24,866-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:19:24,906-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:19:24,906-0500 INFO  Sender Sender TCPChannel queue size: 0
+provider=local
+2013-10-31 17:19:24,987-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:19:24,987-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:19:24,988-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:19:25,030-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38981] for addition
+2013-10-31 17:19:25,030-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38981] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:19:25,030-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38981]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fdf
+2013-10-31 17:19:25,069-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fdf
+MetaChannel [context: cps-38981, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:19:25,069-0500 INFO  MetaChannel MetaChannel [context: cps-38981, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:19:25,069-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:19:25,089-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:19:25,170-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:19:25,170-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
+2013-10-31 17:19:25,171-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/bash /homes/yadunand/bin/exm-trunk/sfw/turbine/trunk/code/tests/coasters/wrapper.sh
 Avg stream buf: 0
-2013-10-28 14:41:47,557-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:19:29,021-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:19:39,030-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:19:43,860-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:19:49,038-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:19:57,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:19:59,047-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:20:09,056-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:20:13,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:20:19,064-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:20:29,073-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:20:36,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:20:39,081-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:20:44,010-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:20:49,089-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:20:49,826-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38987] for addition
+2013-10-31 17:20:49,827-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38987] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:20:49,827-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38987]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fde
+2013-10-31 17:20:49,852-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fde
+MetaChannel [context: cps-38987, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:20:49,852-0500 INFO  MetaChannel MetaChannel [context: cps-38987, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:20:49,852-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:20:49,893-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:20:49,893-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 17:20:49,973-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:20:49,974-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:20:49,974-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+2013-10-31 17:20:50,014-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38988] for addition
+2013-10-31 17:20:50,014-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38988] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:20:50,014-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38988]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fdd
+2013-10-31 17:20:50,054-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fdd
+MetaChannel [context: cps-38988, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:20:50,055-0500 INFO  MetaChannel MetaChannel [context: cps-38988, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:20:50,055-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:20:50,075-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:20:50,156-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:20:50,156-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:20:50,156-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:20:51,507-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38989] for addition
+2013-10-31 17:20:51,507-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38989] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:20:51,507-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38989]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fdc
+2013-10-31 17:20:51,541-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fdc
+MetaChannel [context: cps-38989, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:20:51,541-0500 INFO  MetaChannel MetaChannel [context: cps-38989, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:20:51,541-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:20:51,582-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:20:51,663-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:20:51,663-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:20:51,663-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:20:51,704-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38990] for addition
+2013-10-31 17:20:51,705-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38990] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38990]
+2013-10-31 17:20:51,705-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38990]
+2013-10-31 17:20:53,838-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38991] for addition
+2013-10-31 17:20:53,839-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38991] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:20:53,839-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38991]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fdb
+2013-10-31 17:20:53,870-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fdb
+MetaChannel [context: cps-38991, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:20:53,871-0500 INFO  MetaChannel MetaChannel [context: cps-38991, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:20:53,871-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:20:53,911-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:20:53,992-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:20:53,992-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:20:53,992-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/echo
+2013-10-31 17:20:55,226-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38992] for addition
+2013-10-31 17:20:55,227-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38992] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:20:55,227-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38992]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fda
+2013-10-31 17:20:55,257-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fda
+MetaChannel [context: cps-38992, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:20:55,257-0500 INFO  MetaChannel MetaChannel [context: cps-38992, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:20:55,257-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:20:55,298-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:20:55,378-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:20:55,378-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/date
+2013-10-31 17:20:55,379-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+Avg stream buf: 0
+2013-10-31 17:20:59,090-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:21:09,100-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:21:14,085-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:21:16,604-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:21:19,110-0500 INFO  Multiplexer Avg stream buf: 0
-org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131028-143946.745, now=131028-144147.590, channel=TCPChannel [type: server, contact: 140.221.8.81:51565]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171924.987, now=131031-172125.833, channel=TCPChannel [type: server, contact: 140.221.8.81:38980]
-2013-10-28 14:41:47,590-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:21:25,833-0500 INFO  ChannelContext Notifying commands and handlers about exception
-2013-10-28 14:41:47,590-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:21:25,834-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-10-28 14:41:47,591-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:25,834-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:41:47,591-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:21:25,834-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-10-28 14:41:47,591-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:21:25,834-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-10-28 14:41:47,592-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:21:25,835-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-10-28 14:41:47,592-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:25,835-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:41:47,592-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-TCPChannel [type: server, contact: 140.221.8.81:51565] handling channel exception
+2013-10-31 17:21:25,835-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38980] handling channel exception
-2013-10-28 14:41:47,592-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:51565] handling channel exception
+2013-10-31 17:21:25,835-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38980] handling channel exception
-2013-10-28 14:41:47,593-0500 INFO  AbstractTCPChannel null: Channel shut down
-MetaChannel [context: cps-51565, boundTo: TCPChannel [type: server, contact: 140.221.8.81:51565]] binding to NullChannel
-2013-10-28 14:41:47,593-0500 INFO  MetaChannel MetaChannel [context: cps-51565, boundTo: TCPChannel [type: server, contact: 140.221.8.81:51565]] binding to NullChannel
-Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:51565]
-2013-10-28 14:41:47,593-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:51565]
+2013-10-31 17:21:25,835-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38980, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38980]] binding to NullChannel
+2013-10-31 17:21:25,836-0500 INFO  MetaChannel MetaChannel [context: cps-38980, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38980]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38980]
+2013-10-31 17:21:25,836-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38980]
-2013-10-28 14:41:47,593-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:21:25,836-0500 INFO  ChannelContext Notifying commands and handlers about exception
-2013-10-28 14:41:47,593-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:21:25,836-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
-2013-10-28 14:41:47,593-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:25,836-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:41:47,594-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:21:25,836-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
-2013-10-28 14:41:47,594-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:41:47,594-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:21:25,836-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
-2013-10-28 14:41:47,595-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:21:25,837-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
-2013-10-28 14:41:47,595-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:25,837-0500 WARN  TaskNotifier Client could not properly process notification: null
-2013-10-28 14:41:47,595-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:21:25,837-0500 INFO  ChannelManager Channel exception handled
-2013-10-28 14:41:47,597-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:21:25,850-0500 INFO  Multiplexer Channel is closed. Removing.
-2013-10-28 14:41:47,597-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:21:25,850-0500 INFO  Multiplexer Exception in channel step
-2013-10-28 14:41:47,597-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:21:25,850-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
-2013-10-28 14:41:47,597-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:51565] handling channel exception
+2013-10-31 17:21:25,850-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38980] handling channel exception
-2013-10-28 14:41:47,598-0500 INFO  ChannelManager Channel already shut down
-Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:51565]
-2013-10-28 14:41:47,598-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:51565]
+2013-10-31 17:21:25,851-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38980]
+2013-10-31 17:21:25,851-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38980]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-171925.170, now=131031-172126.030, channel=TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:21:26,030-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:21:26,030-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:21:26,031-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:26,031-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:21:26,031-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:21:26,031-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:21:26,032-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38981] handling channel exception
+2013-10-31 17:21:26,032-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38981] handling channel exception
+2013-10-31 17:21:26,032-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38981, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38981]] binding to NullChannel
+2013-10-31 17:21:26,032-0500 INFO  MetaChannel MetaChannel [context: cps-38981, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38981]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:21:26,032-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:21:26,032-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:21:26,033-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:21:26,033-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:21:26,033-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:21:26,033-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:21:26,033-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:21:26,034-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:21:26,051-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:21:26,051-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:21:26,052-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:21:26,052-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38981] handling channel exception
+2013-10-31 17:21:26,052-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:21:26,052-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38981]
+2013-10-31 17:21:27,327-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38993] for addition
+2013-10-31 17:21:27,327-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38993] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:21:27,327-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38993]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fd9
+2013-10-31 17:21:27,357-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fd9
+MetaChannel [context: cps-38993, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:21:27,357-0500 INFO  MetaChannel MetaChannel [context: cps-38993, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:21:27,357-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:21:27,398-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:21:27,398-0500 INFO  Sender Sender TCPChannel queue size: 0
+2013-10-31 17:21:27,479-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:21:27,479-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:21:27,479-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname
+2013-10-31 17:21:27,524-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38994] for addition
+2013-10-31 17:21:27,524-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38994] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:21:27,524-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38994]
+Channel id: channel-2-u56c1e1d7-14210098df7--7fd8
+2013-10-31 17:21:27,560-0500 INFO  ChannelConfigurationHandler Channel id: channel-2-u56c1e1d7-14210098df7--7fd8
+MetaChannel [context: cps-38994, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:21:27,560-0500 INFO  MetaChannel MetaChannel [context: cps-38994, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:21:27,560-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:21:27,601-0500 INFO  RequestHandler Handler(tag: 31104, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:21:27,681-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:21:27,682-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:21:27,683-0500 INFO  RequestHandler Handler(tag: 31105, SUBMITJOB) unregistering (send)
+2013-10-31 17:21:29,027-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38995] for addition
+2013-10-31 17:21:29,028-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38995] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:21:29,028-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38995]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fd7
+2013-10-31 17:21:29,068-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fd7
+MetaChannel [context: cps-38995, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:21:29,068-0500 INFO  MetaChannel MetaChannel [context: cps-38995, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:21:29,068-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:21:29,089-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+Avg stream buf: 2
+2013-10-31 17:21:29,129-0500 INFO  Multiplexer Avg stream buf: 2
+2013-10-31 17:21:29,169-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+provider=local
+2013-10-31 17:21:29,169-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:21:29,170-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/hostname -f
+2013-10-31 17:21:29,209-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38996] for addition
+2013-10-31 17:21:29,209-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38996] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38996]
+2013-10-31 17:21:29,209-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38996]
+2013-10-31 17:21:31,356-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38997] for addition
+2013-10-31 17:21:31,356-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38997] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:21:31,356-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38997]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fd6
+2013-10-31 17:21:31,379-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fd6
+MetaChannel [context: cps-38997, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:21:31,379-0500 INFO  MetaChannel MetaChannel [context: cps-38997, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:21:31,379-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:21:31,419-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:21:31,500-0500 INFO  ExecutionTaskHandler provider=local
+Submit: in: null command: /bin/echo
+2013-10-31 17:21:31,501-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/echo
+2013-10-31 17:21:31,501-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:21:32,747-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38998] for addition
+2013-10-31 17:21:32,747-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:38998] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:21:32,748-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:38998]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fd5
+2013-10-31 17:21:32,786-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fd5
+MetaChannel [context: cps-38998, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:21:32,786-0500 INFO  MetaChannel MetaChannel [context: cps-38998, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:21:32,786-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:21:32,847-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:21:32,928-0500 INFO  ExecutionTaskHandler provider=local
+2013-10-31 17:21:32,928-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+2013-10-31 17:21:32,928-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+Avg stream buf: 0
+2013-10-31 17:21:39,148-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:21:44,160-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:21:49,159-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:21:56,274-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:21:59,170-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:22:09,181-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:22:14,235-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:22:19,193-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:22:29,204-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:22:35,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:22:39,215-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:22:44,310-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:22:49,226-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172049.973, now=131031-172250.827, channel=TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:22:50,828-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:50,828-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:50,828-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:50,828-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:50,829-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:50,829-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:50,829-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:50,829-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38987] handling channel exception
+2013-10-31 17:22:50,829-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38987] handling channel exception
+2013-10-31 17:22:50,830-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38987, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38987]] binding to NullChannel
+2013-10-31 17:22:50,830-0500 INFO  MetaChannel MetaChannel [context: cps-38987, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38987]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:22:50,830-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:22:50,830-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:50,830-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:50,830-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:50,831-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:50,831-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:22:50,831-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:50,831-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:22:50,831-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:50,832-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:50,832-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:50,832-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:22:50,832-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:22:50,832-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38987] handling channel exception
+2013-10-31 17:22:50,832-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38987]
+2013-10-31 17:22:50,832-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38987]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172050.155, now=131031-172251.014, channel=TCPChannel [type: server, contact: 140.221.8.81:38988]
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:133)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:124)
+	at java.util.TimerThread.mainLoop(Timer.java:534)
+	at java.util.TimerThread.run(Timer.java:484)
+2013-10-31 17:22:51,014-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:51,014-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+Client could not properly process notification: null
+2013-10-31 17:22:51,014-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:51,015-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:51,015-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:51,015-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:51,015-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:51,016-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38988] handling channel exception
+2013-10-31 17:22:51,016-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38988] handling channel exception
+2013-10-31 17:22:51,016-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38988, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38988]] binding to NullChannel
+2013-10-31 17:22:51,016-0500 INFO  MetaChannel MetaChannel [context: cps-38988, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38988]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:22:51,016-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:22:51,016-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:51,016-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:51,016-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:51,017-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:51,017-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:51,017-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:51,017-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:51,017-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:22:51,033-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:22:51,033-0500 INFO  Multiplexer Exception in channel step
+Channel config: null -> {keepalive=null}
+2013-10-31 17:22:51,033-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:22:51,034-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38988] handling channel exception
+2013-10-31 17:22:51,034-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38988]
+2013-10-31 17:22:51,034-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38988]
+Notifying commands and handlers about exception
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172051.662, now=131031-172252.508, channel=TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:22:52,508-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:52,508-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:52,508-0500 WARN  TaskNotifier Client could not properly process notification: null
+=> Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:52,508-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+=> Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:52,508-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+=> Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:52,509-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:52,509-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:52,509-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38989] handling channel exception
+2013-10-31 17:22:52,509-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38989] handling channel exception
+null: Channel shut down
+2013-10-31 17:22:52,509-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38989, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38989]] binding to NullChannel
+2013-10-31 17:22:52,509-0500 INFO  MetaChannel MetaChannel [context: cps-38989, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38989]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:22:52,509-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:22:52,509-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:52,510-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:52,510-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:52,510-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:52,510-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:52,510-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+Channel exception handled
+2013-10-31 17:22:52,511-0500 INFO  ChannelManager Channel exception handled
+Channel is closed. Removing.
+2013-10-31 17:22:52,518-0500 INFO  Multiplexer Channel is closed. Removing.
+Exception in channel step
+java.io.IOException: Stream closed.
+	at java.net.AbstractPlainSocketImpl.available(AbstractPlainSocketImpl.java:435)
+	at java.net.SocketInputStream.available(SocketInputStream.java:234)
+	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.step(AbstractStreamCoasterChannel.java:105)
+	at org.globus.cog.coaster.channels.Multiplexer.run(Multiplexer.java:70)
+2013-10-31 17:22:52,519-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:22:52,519-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:22:52,519-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38989] handling channel exception
+Channel already shut down
+2013-10-31 17:22:52,519-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38989]
+2013-10-31 17:22:52,519-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38989]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172051.743, now=131031-172252.704, channel=TCPChannel [type: server, contact: 140.221.8.81:38990]
+2013-10-31 17:22:52,704-0500 INFO  ChannelContext Notifying commands and handlers about exception
+=> Handler(tag: 31103, CHANNELCONFIG)
+2013-10-31 17:22:52,704-0500 INFO  ChannelContext => Handler(tag: 31103, CHANNELCONFIG)
+2013-10-31 17:22:52,704-0500 INFO  RequestHandler
+Handler(tag: 31103, CHANNELCONFIG) unregister (errorReceived)
+2013-10-31 17:22:52,704-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregister (errorReceived)
+2013-10-31 17:22:52,704-0500 INFO  AbstractCoasterChannel Channel config: null
+TCPChannel [type: server, contact: 140.221.8.81:38990] handling channel exception
+2013-10-31 17:22:52,704-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38990] handling channel exception
+2013-10-31 17:22:52,705-0500 INFO  AbstractTCPChannel null: Channel shut down
+Failed to shut down channel
+org.globus.cog.coaster.channels.ChannelException: Invalid channel: null at id://null-nullS
+	at org.globus.cog.coaster.channels.ChannelManager.getMetaChannel(ChannelManager.java:452)
+	at org.globus.cog.coaster.channels.ChannelManager.getMetaChannel(ChannelManager.java:432)
+	at org.globus.cog.coaster.channels.ChannelManager.shutdownChannel(ChannelManager.java:421)
+	at org.globus.cog.coaster.channels.ChannelManager.handleChannelException(ChannelManager.java:284)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleChannelException(AbstractCoasterChannel.java:569)
+	at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:137)
+2013-10-31 17:22:52,705-0500 INFO  ChannelManager Failed to shut down channel
+2013-10-31 17:22:52,705-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:52,705-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:22:52,720-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:22:52,720-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:22:52,720-0500 INFO  AbstractCoasterChannel Channel config: null
+2013-10-31 17:22:52,720-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38990] handling channel exception
+2013-10-31 17:22:52,720-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38990]
+2013-10-31 17:22:52,720-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38990]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172053.992, now=131031-172254.839, channel=TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:22:54,839-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:54,839-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:54,839-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:54,839-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:54,840-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:54,840-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:54,840-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:54,840-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38991] handling channel exception
+2013-10-31 17:22:54,840-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38991] handling channel exception
+2013-10-31 17:22:54,841-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38991, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38991]] binding to NullChannel
+2013-10-31 17:22:54,841-0500 INFO  MetaChannel MetaChannel [context: cps-38991, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38991]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:22:54,841-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:22:54,841-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:54,841-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:54,841-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:54,841-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:54,841-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:54,842-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:54,842-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:54,842-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:22:54,847-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:22:54,847-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:22:54,847-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:22:54,847-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38991] handling channel exception
+2013-10-31 17:22:54,847-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38991]
+2013-10-31 17:22:54,847-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38991]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172055.378, now=131031-172256.227, channel=TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:22:56,227-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:56,227-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:56,227-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:56,227-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:56,227-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:56,228-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:56,228-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:56,228-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38992] handling channel exception
+2013-10-31 17:22:56,228-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38992] handling channel exception
+2013-10-31 17:22:56,228-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38992, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38992]] binding to NullChannel
+2013-10-31 17:22:56,228-0500 INFO  MetaChannel MetaChannel [context: cps-38992, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38992]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:22:56,229-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:22:56,229-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:22:56,229-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:22:56,229-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:56,229-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:22:56,229-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:22:56,230-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:22:56,230-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:22:56,230-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:22:56,231-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:22:56,232-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:22:56,232-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:22:56,232-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38992] handling channel exception
+2013-10-31 17:22:56,232-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38992]
+2013-10-31 17:22:56,232-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38992]
+Avg stream buf: 0
+2013-10-31 17:22:59,241-0500 INFO  Multiplexer Avg stream buf: 0
+Timeout check started for TCPChannel [type: server, contact: unknown]
+2013-10-31 17:23:08,979-0500 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
+(0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:39004] for addition
+2013-10-31 17:23:08,979-0500 INFO  Multiplexer (0) Scheduling TCPChannel [type: server, contact: 140.221.8.81:39004] for addition
+Channel started: TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:23:08,979-0500 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 140.221.8.81:39004]
+Channel id: channel-1-u56c1e1d7-14210098df7--7fd4
+2013-10-31 17:23:09,011-0500 INFO  ChannelConfigurationHandler Channel id: channel-1-u56c1e1d7-14210098df7--7fd4
+MetaChannel [context: cps-39004, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:23:09,011-0500 INFO  MetaChannel MetaChannel [context: cps-39004, boundTo: null] binding to TCPChannel [type: server, contact: 140.221.8.81:39004]
+Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+2013-10-31 17:23:09,011-0500 INFO  RequestHandler Handler(tag: 38906, CHANNELCONFIG) unregistering (send)
+Sender TCPChannel queue size: 0
+2013-10-31 17:23:09,052-0500 INFO  Sender Sender TCPChannel queue size: 0
+Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+2013-10-31 17:23:09,052-0500 INFO  RequestHandler Handler(tag: 38907, CONFIGSERVICE) unregistering (send)
+provider=local
+2013-10-31 17:23:09,133-0500 INFO  ExecutionTaskHandler provider=local
+Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:23:09,133-0500 INFO  RequestHandler Handler(tag: 38908, SUBMITJOB) unregistering (send)
+2013-10-31 17:23:09,135-0500 INFO  JobSubmissionTaskHandler Submit: in: null command: /bin/date
+Avg stream buf: 0
+2013-10-31 17:23:09,255-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:23:14,385-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:23:15,611-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:23:19,265-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172127.479, now=131031-172328.328, channel=TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:23:28,328-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:28,328-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:28,328-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,328-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:28,329-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:28,329-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,329-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:28,329-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38993] handling channel exception
+2013-10-31 17:23:28,329-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38993] handling channel exception
+2013-10-31 17:23:28,330-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38993, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38993]] binding to NullChannel
+2013-10-31 17:23:28,330-0500 INFO  MetaChannel MetaChannel [context: cps-38993, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38993]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:23:28,330-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:23:28,330-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:28,330-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:28,330-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,331-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:28,331-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,331-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:28,331-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:28,331-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:28,333-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:28,333-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:28,333-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:23:28,333-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38993] handling channel exception
+2013-10-31 17:23:28,333-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38993]
+2013-10-31 17:23:28,333-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38993]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172127.681, now=131031-172328.524, channel=TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:23:28,524-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:28,524-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:28,524-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,524-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:28,524-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:28,525-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:28,525-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,525-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38994] handling channel exception
+2013-10-31 17:23:28,525-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38994] handling channel exception
+2013-10-31 17:23:28,525-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38994, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38994]] binding to NullChannel
+2013-10-31 17:23:28,525-0500 INFO  MetaChannel MetaChannel [context: cps-38994, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38994]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:23:28,525-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:23:28,525-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:28,526-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:28,526-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:28,526-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:28,526-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:28,526-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:28,527-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:28,534-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:28,534-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:28,535-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:23:28,535-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38994] handling channel exception
+2013-10-31 17:23:28,535-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38994]
+2013-10-31 17:23:28,535-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38994]
+Avg stream buf: 0
+2013-10-31 17:23:29,277-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172129.169, now=131031-172330.027, channel=TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:23:30,027-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:30,028-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:30,028-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:30,028-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:30,028-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:30,028-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:30,029-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38995] handling channel exception
+2013-10-31 17:23:30,029-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38995] handling channel exception
+2013-10-31 17:23:30,029-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38995, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38995]] binding to NullChannel
+2013-10-31 17:23:30,029-0500 INFO  MetaChannel MetaChannel [context: cps-38995, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38995]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:23:30,029-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:23:30,029-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:30,029-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:30,029-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:30,029-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:30,030-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:30,030-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:30,030-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:30,030-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:30,039-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:30,039-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:30,040-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:23:30,040-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38995] handling channel exception
+2013-10-31 17:23:30,040-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38995]
+2013-10-31 17:23:30,040-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38995]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172129.230, now=131031-172330.209, channel=TCPChannel [type: server, contact: 140.221.8.81:38996]
+2013-10-31 17:23:30,209-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:30,210-0500 INFO  ChannelContext => Handler(tag: 31103, CHANNELCONFIG)
+2013-10-31 17:23:30,210-0500 INFO  RequestHandler
+2013-10-31 17:23:30,210-0500 INFO  RequestHandler Handler(tag: 31103, CHANNELCONFIG) unregister (errorReceived)
+2013-10-31 17:23:30,210-0500 INFO  AbstractCoasterChannel Channel config: null
+TCPChannel [type: server, contact: 140.221.8.81:38996] handling channel exception
+2013-10-31 17:23:30,210-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38996] handling channel exception
+2013-10-31 17:23:30,210-0500 INFO  AbstractTCPChannel null: Channel shut down
+2013-10-31 17:23:30,210-0500 INFO  ChannelManager Failed to shut down channel
+2013-10-31 17:23:30,211-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:30,211-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:30,221-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:30,221-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:30,221-0500 INFO  AbstractCoasterChannel Channel config: null
+2013-10-31 17:23:30,221-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38996] handling channel exception
+2013-10-31 17:23:30,221-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38996]
+2013-10-31 17:23:30,221-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38996]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172131.500, now=131031-172332.356, channel=TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:23:32,356-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:32,356-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:32,356-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:32,356-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:32,357-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:32,357-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:32,357-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:32,357-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38997] handling channel exception
+2013-10-31 17:23:32,357-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38997] handling channel exception
+2013-10-31 17:23:32,357-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38997, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38997]] binding to NullChannel
+2013-10-31 17:23:32,357-0500 INFO  MetaChannel MetaChannel [context: cps-38997, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38997]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:23:32,357-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:23:32,357-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:32,358-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:32,358-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:32,358-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:32,358-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:32,358-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:32,359-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:32,367-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:32,368-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:32,368-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:23:32,368-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38997] handling channel exception
+2013-10-31 17:23:32,368-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38997]
+2013-10-31 17:23:32,368-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38997]
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172132.927, now=131031-172333.747, channel=TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:23:33,747-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:33,747-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:33,747-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:33,747-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:33,748-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:33,748-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:33,748-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:33,748-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:38998] handling channel exception
+2013-10-31 17:23:33,748-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38998] handling channel exception
+2013-10-31 17:23:33,749-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-38998, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38998]] binding to NullChannel
+2013-10-31 17:23:33,749-0500 INFO  MetaChannel MetaChannel [context: cps-38998, boundTo: TCPChannel [type: server, contact: 140.221.8.81:38998]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:23:33,749-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:23:33,749-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:23:33,749-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:23:33,749-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:33,749-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:23:33,750-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:23:33,750-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:23:33,750-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:23:33,750-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:23:33,752-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:23:33,752-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:23:33,753-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:23:33,753-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:38998] handling channel exception
+2013-10-31 17:23:33,753-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38998]
+2013-10-31 17:23:33,753-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:38998]
+Avg stream buf: 0
+2013-10-31 17:23:39,288-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:23:44,460-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:23:49,296-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:23:55,281-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:23:59,304-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:24:09,312-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:24:14,535-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:24:19,321-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:24:29,328-0500 INFO  Multiplexer Avg stream buf: 0
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 17:24:34,951-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+Avg stream buf: 0
+2013-10-31 17:24:39,337-0500 INFO  Multiplexer Avg stream buf: 0
+2013-10-31 17:24:44,610-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+Avg stream buf: 0
+2013-10-31 17:24:49,345-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:24:59,353-0500 INFO  Multiplexer Avg stream buf: 0
+Avg stream buf: 0
+2013-10-31 17:25:09,361-0500 INFO  Multiplexer Avg stream buf: 0
+org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=131031-172309.133, now=131031-172509.979, channel=TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:25:09,980-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:25:09,980-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:25:09,980-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:25:09,980-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:25:09,980-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:25:09,981-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:25:09,981-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:25:09,981-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+TCPChannel [type: server, contact: 140.221.8.81:39004] handling channel exception
+2013-10-31 17:25:09,981-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:39004] handling channel exception
+2013-10-31 17:25:09,981-0500 INFO  AbstractTCPChannel null: Channel shut down
+MetaChannel [context: cps-39004, boundTo: TCPChannel [type: server, contact: 140.221.8.81:39004]] binding to NullChannel
+2013-10-31 17:25:09,981-0500 INFO  MetaChannel MetaChannel [context: cps-39004, boundTo: TCPChannel [type: server, contact: 140.221.8.81:39004]] binding to NullChannel
+Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:25:09,982-0500 INFO  Multiplexer Unregistering channel TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:25:09,982-0500 INFO  ChannelContext Notifying commands and handlers about exception
+2013-10-31 17:25:09,982-0500 INFO  ChannelContext => Command(tag: 1, JOBSTATUS)
+2013-10-31 17:25:09,982-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:25:09,982-0500 INFO  ChannelContext => Command(tag: 2, JOBSTATUS)
+2013-10-31 17:25:09,982-0500 INFO  ChannelContext => Command(tag: 3, JOBSTATUS)
+2013-10-31 17:25:09,983-0500 INFO  ChannelContext => Command(tag: 4, JOBSTATUS)
+2013-10-31 17:25:09,983-0500 WARN  TaskNotifier Client could not properly process notification: null
+2013-10-31 17:25:09,983-0500 INFO  ChannelManager Channel exception handled
+2013-10-31 17:25:09,983-0500 INFO  Multiplexer Channel is closed. Removing.
+2013-10-31 17:25:09,983-0500 INFO  Multiplexer Exception in channel step
+2013-10-31 17:25:09,983-0500 INFO  AbstractCoasterChannel Channel config: null -> {keepalive=null}
+2013-10-31 17:25:09,983-0500 INFO  ChannelManager TCPChannel [type: server, contact: 140.221.8.81:39004] handling channel exception
+2013-10-31 17:25:09,984-0500 INFO  ChannelManager Channel already shut down
+Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:39004]
+2013-10-31 17:25:09,984-0500 INFO  Multiplexer Removing faulty channel TCPChannel [type: server, contact: 140.221.8.81:39004]
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:25:14,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:25:14,684-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 14:41:57,566-0500 INFO  Multiplexer No streams
+2013-10-31 17:25:19,370-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:42:07,574-0500 INFO  Multiplexer No streams
+2013-10-31 17:25:29,377-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:25:39,385-0500 INFO  Multiplexer No streams
+2013-10-31 17:25:44,760-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:25:49,393-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:25:54,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:25:59,400-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:26:09,408-0500 INFO  Multiplexer No streams
+2013-10-31 17:26:14,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:26:19,415-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:26:29,422-0500 INFO  Multiplexer No streams
+2013-10-31 17:26:33,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:26:39,430-0500 INFO  Multiplexer No streams
+2013-10-31 17:26:44,910-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:26:49,437-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:26:59,444-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:27:09,451-0500 INFO  Multiplexer No streams
+2013-10-31 17:27:13,626-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:27:14,985-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:27:19,459-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:27:29,466-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:27:39,473-0500 INFO  Multiplexer No streams
+2013-10-31 17:27:45,060-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:27:49,481-0500 INFO  Multiplexer No streams
+2013-10-31 17:27:53,295-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:27:59,489-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:28:09,497-0500 INFO  Multiplexer No streams
+2013-10-31 17:28:15,135-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:28:19,505-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:28:29,513-0500 INFO  Multiplexer No streams
+2013-10-31 17:28:32,964-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:28:39,521-0500 INFO  Multiplexer No streams
+2013-10-31 17:28:45,211-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:28:49,528-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:28:59,536-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:29:09,544-0500 INFO  Multiplexer No streams
+2013-10-31 17:29:12,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:29:15,286-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:29:19,552-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:29:29,559-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:29:39,567-0500 INFO  Multiplexer No streams
+2013-10-31 17:29:45,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:29:49,575-0500 INFO  Multiplexer No streams
+2013-10-31 17:29:52,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:29:59,583-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:30:09,591-0500 INFO  Multiplexer No streams
+2013-10-31 17:30:15,436-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:30:19,599-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:30:29,607-0500 INFO  Multiplexer No streams
+2013-10-31 17:30:31,971-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:30:39,615-0500 INFO  Multiplexer No streams
+2013-10-31 17:30:45,510-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:30:49,623-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:30:59,630-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:31:09,638-0500 INFO  Multiplexer No streams
+2013-10-31 17:31:11,639-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:31:15,586-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:31:19,646-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:31:29,653-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:31:39,661-0500 INFO  Multiplexer No streams
+2013-10-31 17:31:45,661-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:31:49,669-0500 INFO  Multiplexer No streams
+2013-10-31 17:31:51,308-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:31:59,676-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:32:09,684-0500 INFO  Multiplexer No streams
+2013-10-31 17:32:15,736-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:32:19,692-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:32:29,699-0500 INFO  Multiplexer No streams
+2013-10-31 17:32:30,978-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:32:39,707-0500 INFO  Multiplexer No streams
+2013-10-31 17:32:45,811-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:32:49,715-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:32:59,722-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:33:09,730-0500 INFO  Multiplexer No streams
+2013-10-31 17:33:10,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:33:15,885-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:33:19,738-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:33:29,745-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:33:39,754-0500 INFO  Multiplexer No streams
+2013-10-31 17:33:45,961-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:33:49,761-0500 INFO  Multiplexer No streams
+2013-10-31 17:33:50,316-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:33:59,768-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:34:09,776-0500 INFO  Multiplexer No streams
+2013-10-31 17:34:16,036-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:34:19,784-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:34:29,791-0500 INFO  Multiplexer No streams
+2013-10-31 17:34:29,984-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:34:39,799-0500 INFO  Multiplexer No streams
+2013-10-31 17:34:46,110-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:34:49,807-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:34:59,814-0500 INFO  Multiplexer No streams
-2013-10-28 14:42:09,643-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:35:09,654-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:35:09,822-0500 INFO  Multiplexer No streams
+2013-10-31 17:35:16,186-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:35:19,830-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:35:29,837-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:35:39,845-0500 INFO  Multiplexer No streams
+2013-10-31 17:35:46,260-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:35:49,323-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:35:49,853-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:35:59,861-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:36:09,868-0500 INFO  Multiplexer No streams
-2013-10-28 14:42:17,388-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:36:16,336-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:42:17,582-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:19,876-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:28,992-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:42:27,590-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:29,884-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:42:37,598-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:39,891-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:46,411-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:42:47,607-0500 INFO  Multiplexer No streams
+2013-10-31 17:36:49,899-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:36:59,907-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
+2013-10-31 17:37:08,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 5ms
+No streams
+2013-10-31 17:37:09,915-0500 INFO  Multiplexer No streams
+2013-10-31 17:37:16,485-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:37:19,922-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:37:29,930-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:37:39,938-0500 INFO  Multiplexer No streams
+2013-10-31 17:37:46,561-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:37:48,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:37:49,946-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:37:59,954-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:38:09,961-0500 INFO  Multiplexer No streams
+2013-10-31 17:38:16,636-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:38:19,969-0500 INFO  Multiplexer No streams
-2013-10-28 14:42:47,837-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:38:27,999-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:38:29,977-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:38:39,985-0500 INFO  Multiplexer No streams
+2013-10-31 17:38:46,710-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:38:49,992-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:39:00,000-0500 INFO  Multiplexer No streams
+2013-10-31 17:39:07,668-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:39:10,008-0500 INFO  Multiplexer No streams
-2013-10-28 14:42:48,346-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:39:16,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:42:57,615-0500 INFO  Multiplexer No streams
+2013-10-31 17:39:20,016-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:43:07,623-0500 INFO  Multiplexer No streams
+2013-10-31 17:39:30,024-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:43:17,632-0500 INFO  Multiplexer No streams
+2013-10-31 17:39:40,031-0500 INFO  Multiplexer No streams
+2013-10-31 17:39:46,861-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:39:47,337-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:39:50,039-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:40:00,047-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:40:10,055-0500 INFO  Multiplexer No streams
+2013-10-31 17:40:16,936-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:40:20,063-0500 INFO  Multiplexer No streams
+2013-10-31 17:40:27,006-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:40:30,070-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:40:40,078-0500 INFO  Multiplexer No streams
+2013-10-31 17:40:47,012-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:40:50,086-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:41:00,094-0500 INFO  Multiplexer No streams
+2013-10-31 17:41:06,675-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:41:10,102-0500 INFO  Multiplexer No streams
+2013-10-31 17:41:17,087-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:41:20,110-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:41:30,117-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:41:40,125-0500 INFO  Multiplexer No streams
+2013-10-31 17:41:46,345-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:41:47,161-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:41:50,133-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:42:00,141-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:42:10,149-0500 INFO  Multiplexer No streams
+2013-10-31 17:42:17,237-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:42:20,157-0500 INFO  Multiplexer No streams
+2013-10-31 17:42:26,014-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:42:30,164-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:42:40,172-0500 INFO  Multiplexer No streams
+2013-10-31 17:42:47,312-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:42:50,180-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:43:00,188-0500 INFO  Multiplexer No streams
+2013-10-31 17:43:05,683-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:43:10,196-0500 INFO  Multiplexer No streams
+2013-10-31 17:43:17,386-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:43:20,204-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:43:30,212-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:43:40,219-0500 INFO  Multiplexer No streams
+2013-10-31 17:43:45,352-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:43:19,304-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:43:47,462-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:43:50,227-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:44:00,235-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:44:10,243-0500 INFO  Multiplexer No streams
+2013-10-31 17:44:17,537-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:44:20,251-0500 INFO  Multiplexer No streams
+2013-10-31 17:44:25,021-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:44:30,259-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:44:40,267-0500 INFO  Multiplexer No streams
+2013-10-31 17:44:47,612-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:44:50,274-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:45:00,282-0500 INFO  Multiplexer No streams
+2013-10-31 17:45:04,691-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 17:45:10,290-0500 INFO  Multiplexer No streams
+2013-10-31 17:45:17,687-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:45:20,298-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:45:30,306-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:45:40,314-0500 INFO  Multiplexer No streams
+2013-10-31 17:45:44,359-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:45:47,761-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:45:50,321-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:46:00,329-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:46:10,337-0500 INFO  Multiplexer No streams
+2013-10-31 17:46:17,837-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:46:20,345-0500 INFO  Multiplexer No streams
+2013-10-31 17:46:24,028-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:46:30,353-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:46:40,361-0500 INFO  Multiplexer No streams
+2013-10-31 17:46:47,912-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:46:50,369-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:47:00,376-0500 INFO  Multiplexer No streams
+2013-10-31 17:47:03,697-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:47:10,384-0500 INFO  Multiplexer No streams
+2013-10-31 17:47:17,986-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:47:20,392-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:47:30,400-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:47:40,408-0500 INFO  Multiplexer No streams
+2013-10-31 17:47:43,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:47:48,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:47:50,416-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:48:00,424-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:48:10,432-0500 INFO  Multiplexer No streams
+2013-10-31 17:48:18,137-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:48:20,440-0500 INFO  Multiplexer No streams
+2013-10-31 17:48:23,035-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:48:30,448-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:48:40,456-0500 INFO  Multiplexer No streams
+2013-10-31 17:48:48,212-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:48:50,463-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:49:00,472-0500 INFO  Multiplexer No streams
+2013-10-31 17:49:02,704-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:49:10,479-0500 INFO  Multiplexer No streams
+2013-10-31 17:49:18,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:49:20,487-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:49:30,495-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:49:40,503-0500 INFO  Multiplexer No streams
+2013-10-31 17:49:42,373-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:49:48,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:49:50,511-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:50:00,519-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:50:10,527-0500 INFO  Multiplexer No streams
+2013-10-31 17:50:18,437-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:50:20,534-0500 INFO  Multiplexer No streams
+2013-10-31 17:50:22,042-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:50:30,542-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:50:40,557-0500 INFO  Multiplexer No streams
+2013-10-31 17:50:48,512-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:50:50,565-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:51:00,573-0500 INFO  Multiplexer No streams
+2013-10-31 17:51:01,711-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:51:10,581-0500 INFO  Multiplexer No streams
+2013-10-31 17:51:18,587-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:51:20,589-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:51:30,597-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:51:40,605-0500 INFO  Multiplexer No streams
+2013-10-31 17:51:41,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 17:51:48,662-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:51:50,613-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:52:00,622-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:52:10,630-0500 INFO  Multiplexer No streams
+2013-10-31 17:52:18,736-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:52:20,638-0500 INFO  Multiplexer No streams
+2013-10-31 17:52:21,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:52:30,646-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:52:40,652-0500 INFO  Multiplexer No streams
+2013-10-31 17:52:48,813-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:52:50,660-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:53:00,668-0500 INFO  Multiplexer No streams
+2013-10-31 17:53:00,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:53:10,676-0500 INFO  Multiplexer No streams
+2013-10-31 17:53:18,887-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:53:20,684-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:53:30,692-0500 INFO  Multiplexer No streams
+2013-10-31 17:53:40,387-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:53:40,701-0500 INFO  Multiplexer No streams
+2013-10-31 17:53:48,962-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:53:50,709-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:54:00,717-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:54:10,725-0500 INFO  Multiplexer No streams
+2013-10-31 17:54:19,037-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:54:20,056-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:54:20,733-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:54:30,741-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:54:40,749-0500 INFO  Multiplexer No streams
+2013-10-31 17:54:49,112-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:54:50,757-0500 INFO  Multiplexer No streams
+2013-10-31 17:54:59,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:55:00,765-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:55:10,773-0500 INFO  Multiplexer No streams
+2013-10-31 17:55:19,187-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:55:20,792-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:55:30,800-0500 INFO  Multiplexer No streams
+2013-10-31 17:55:39,395-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:55:40,808-0500 INFO  Multiplexer No streams
+2013-10-31 17:55:49,262-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:55:50,816-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:56:00,823-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:56:10,831-0500 INFO  Multiplexer No streams
+2013-10-31 17:56:19,063-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 17:56:19,336-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 17:56:20,839-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:56:30,847-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:56:40,855-0500 INFO  Multiplexer No streams
+2013-10-31 17:56:49,412-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:56:50,864-0500 INFO  Multiplexer No streams
-2013-10-28 14:43:26,031-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:56:58,734-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:43:27,640-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:00,872-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:43:37,648-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:10,880-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:19,487-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:43:47,657-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:20,889-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:57:30,897-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:38,402-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:57:40,906-0500 INFO  Multiplexer No streams
+2013-10-31 17:57:49,562-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:57:50,914-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:58:00,922-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:58:10,930-0500 INFO  Multiplexer No streams
+2013-10-31 17:58:18,072-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 17:58:19,638-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:58:20,938-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:58:30,948-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:58:40,959-0500 INFO  Multiplexer No streams
-2013-10-28 14:43:50,262-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 17:58:49,714-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:43:57,665-0500 INFO  Multiplexer No streams
+2013-10-31 17:58:50,969-0500 INFO  Multiplexer No streams
+2013-10-31 17:58:57,740-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:59:00,980-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:59:10,991-0500 INFO  Multiplexer No streams
+2013-10-31 17:59:19,788-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:59:21,001-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 17:59:31,012-0500 INFO  Multiplexer No streams
+2013-10-31 17:59:37,409-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 17:59:41,023-0500 INFO  Multiplexer No streams
+2013-10-31 17:59:49,863-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 17:59:51,034-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:00:01,046-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:00:11,056-0500 INFO  Multiplexer No streams
+2013-10-31 18:00:17,079-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:00:19,938-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:00:21,072-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:00:31,084-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:00:41,098-0500 INFO  Multiplexer No streams
+2013-10-31 18:00:50,013-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:00:51,111-0500 INFO  Multiplexer No streams
+2013-10-31 18:00:56,748-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:01:01,122-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:01:11,124-0500 INFO  Multiplexer No streams
+2013-10-31 18:01:20,088-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:01:21,136-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:01:31,156-0500 INFO  Multiplexer No streams
+2013-10-31 18:01:36,417-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:01:41,175-0500 INFO  Multiplexer No streams
+2013-10-31 18:01:50,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:01:51,194-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:02:01,209-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:02:11,223-0500 INFO  Multiplexer No streams
+2013-10-31 18:02:16,087-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:02:20,239-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:02:21,233-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:02:31,242-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:02:41,251-0500 INFO  Multiplexer No streams
+2013-10-31 18:02:50,314-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:02:51,264-0500 INFO  Multiplexer No streams
-2013-10-28 14:44:04,225-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:02:55,756-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:44:07,673-0500 INFO  Multiplexer No streams
+2013-10-31 18:03:01,275-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:44:17,682-0500 INFO  Multiplexer No streams
+2013-10-31 18:03:11,284-0500 INFO  Multiplexer No streams
+2013-10-31 18:03:20,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:03:21,292-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:03:31,300-0500 INFO  Multiplexer No streams
+2013-10-31 18:03:35,424-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:03:41,308-0500 INFO  Multiplexer No streams
+2013-10-31 18:03:50,464-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:03:51,316-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:04:01,325-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:04:11,341-0500 INFO  Multiplexer No streams
+2013-10-31 18:04:15,094-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 14:44:21,220-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:04:20,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:44:27,690-0500 INFO  Multiplexer No streams
+2013-10-31 18:04:21,349-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:44:37,698-0500 INFO  Multiplexer No streams
+2013-10-31 18:04:31,357-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:04:41,365-0500 INFO  Multiplexer No streams
+2013-10-31 18:04:50,615-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:04:51,374-0500 INFO  Multiplexer No streams
-2013-10-28 14:44:42,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:04:54,763-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
 No streams
-2013-10-28 14:44:47,706-0500 INFO  Multiplexer No streams
+2013-10-31 18:05:01,383-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:05:11,392-0500 INFO  Multiplexer No streams
+2013-10-31 18:05:20,690-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:05:21,399-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:05:31,407-0500 INFO  Multiplexer No streams
+2013-10-31 18:05:34,431-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:05:41,416-0500 INFO  Multiplexer No streams
+2013-10-31 18:05:50,765-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:05:51,425-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:06:01,433-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:06:11,441-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:06:14,100-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 14:44:52,178-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:06:20,840-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:44:57,715-0500 INFO  Multiplexer No streams
+2013-10-31 18:06:21,451-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:45:07,723-0500 INFO  Multiplexer No streams
+2013-10-31 18:06:31,460-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:45:17,731-0500 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-10-28 14:45:20,614-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 18:06:41,471-0500 INFO  Multiplexer No streams
-2013-10-28 14:45:23,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:06:50,915-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:45:27,739-0500 INFO  Multiplexer No streams
+2013-10-31 18:06:51,479-0500 INFO  Multiplexer No streams
+2013-10-31 18:06:53,769-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:45:37,748-0500 INFO  Multiplexer No streams
+2013-10-31 18:07:01,489-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:45:47,756-0500 INFO  Multiplexer No streams
+2013-10-31 18:07:11,495-0500 INFO  Multiplexer No streams
+2013-10-31 18:07:20,990-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:07:21,500-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:07:31,502-0500 INFO  Multiplexer No streams
+2013-10-31 18:07:33,439-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:07:41,517-0500 INFO  Multiplexer No streams
-2013-10-28 14:45:54,094-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:07:51,066-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:45:57,764-0500 INFO  Multiplexer No streams
+2013-10-31 18:07:51,527-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:08:01,536-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:08:11,545-0500 INFO  Multiplexer No streams
+2013-10-31 18:08:13,108-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:08:21,140-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:08:21,554-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:08:31,563-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:08:41,571-0500 INFO  Multiplexer No streams
+2013-10-31 18:08:51,215-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:08:51,580-0500 INFO  Multiplexer No streams
-2013-10-28 14:45:58,807-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:08:52,777-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:46:07,772-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:01,589-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:46:17,780-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:11,598-0500 INFO  Multiplexer No streams
-2013-10-28 14:46:25,052-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:09:21,291-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:46:27,789-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:21,606-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:09:31,614-0500 INFO  Multiplexer No streams
-2013-10-28 14:46:37,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:09:32,446-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:46:37,797-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:41,623-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:51,365-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:46:47,805-0500 INFO  Multiplexer No streams
+2013-10-31 18:09:51,631-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:10:01,641-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:10:11,651-0500 INFO  Multiplexer No streams
+2013-10-31 18:10:12,115-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:10:21,440-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:10:21,660-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:10:31,669-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:10:41,679-0500 INFO  Multiplexer No streams
-2013-10-28 14:46:56,010-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:10:51,515-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:46:57,813-0500 INFO  Multiplexer No streams
+2013-10-31 18:10:51,688-0500 INFO  Multiplexer No streams
+2013-10-31 18:10:51,784-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:47:07,821-0500 INFO  Multiplexer No streams
+2013-10-31 18:11:01,697-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:11:11,706-0500 INFO  Multiplexer No streams
+2013-10-31 18:11:21,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:11:21,716-0500 INFO  Multiplexer No streams
+2013-10-31 18:11:31,454-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:11:31,725-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:11:41,736-0500 INFO  Multiplexer No streams
+2013-10-31 18:11:51,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:11:51,747-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:12:01,765-0500 INFO  Multiplexer No streams
+2013-10-31 18:12:11,123-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:12:11,777-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:12:21,741-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:12:21,793-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:12:31,806-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:12:41,825-0500 INFO  Multiplexer No streams
+2013-10-31 18:12:50,791-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:12:51,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:12:51,834-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:13:01,845-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:13:11,855-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:13:21,863-0500 INFO  Multiplexer No streams
+2013-10-31 18:13:21,891-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:13:30,461-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:13:31,879-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:13:41,894-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:13:51,913-0500 INFO  Multiplexer No streams
+2013-10-31 18:13:51,966-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:14:01,916-0500 INFO  Multiplexer No streams
+2013-10-31 18:14:10,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:14:11,934-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:14:21,945-0500 INFO  Multiplexer No streams
+2013-10-31 18:14:22,041-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:14:31,957-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:14:41,958-0500 INFO  Multiplexer No streams
-2013-10-28 14:47:15,195-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:14:49,799-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:47:17,829-0500 INFO  Multiplexer No streams
+2013-10-31 18:14:51,968-0500 INFO  Multiplexer No streams
+2013-10-31 18:14:52,115-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:15:01,989-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:15:11,999-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:15:22,013-0500 INFO  Multiplexer No streams
-2013-10-28 14:47:26,968-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:15:22,190-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:15:29,468-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
 No streams
-2013-10-28 14:47:27,838-0500 INFO  Multiplexer No streams
+2013-10-31 18:15:32,024-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:47:37,846-0500 INFO  Multiplexer No streams
+2013-10-31 18:15:42,035-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:47:47,854-0500 INFO  Multiplexer No streams
+2013-10-31 18:15:52,046-0500 INFO  Multiplexer No streams
+2013-10-31 18:15:52,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:16:02,061-0500 INFO  Multiplexer No streams
+2013-10-31 18:16:09,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:16:12,071-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:16:22,081-0500 INFO  Multiplexer No streams
+2013-10-31 18:16:22,341-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:16:32,092-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:16:42,103-0500 INFO  Multiplexer No streams
-2013-10-28 14:47:53,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:16:48,805-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:47:57,862-0500 INFO  Multiplexer No streams
+2013-10-31 18:16:52,113-0500 INFO  Multiplexer No streams
+2013-10-31 18:16:52,416-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:17:02,124-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:17:12,133-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:17:22,141-0500 INFO  Multiplexer No streams
-2013-10-28 14:47:57,926-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:17:22,491-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:17:28,474-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:48:07,870-0500 INFO  Multiplexer No streams
+2013-10-31 18:17:32,150-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:48:17,878-0500 INFO  Multiplexer No streams
+2013-10-31 18:17:42,161-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:48:27,887-0500 INFO  Multiplexer No streams
+2013-10-31 18:17:52,170-0500 INFO  Multiplexer No streams
+2013-10-31 18:17:52,567-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:18:02,177-0500 INFO  Multiplexer No streams
+2013-10-31 18:18:08,144-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:18:12,185-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:18:22,193-0500 INFO  Multiplexer No streams
-2013-10-28 14:48:28,884-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:18:22,642-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:18:32,200-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:18:42,208-0500 INFO  Multiplexer No streams
-2013-10-28 14:48:31,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:18:47,813-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:48:37,895-0500 INFO  Multiplexer No streams
+2013-10-31 18:18:52,215-0500 INFO  Multiplexer No streams
+2013-10-31 18:18:52,717-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:48:47,903-0500 INFO  Multiplexer No streams
+2013-10-31 18:19:02,223-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:48:57,911-0500 INFO  Multiplexer No streams
+2013-10-31 18:19:12,231-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:19:22,240-0500 INFO  Multiplexer No streams
-2013-10-28 14:48:59,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:19:22,792-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:19:27,482-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:49:07,919-0500 INFO  Multiplexer No streams
+2013-10-31 18:19:32,248-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:19:42,257-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:19:52,266-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:19:52,867-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:20:02,276-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:20:07,152-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:20:12,287-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:20:22,297-0500 INFO  Multiplexer No streams
+2013-10-31 18:20:22,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:20:32,307-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:20:42,315-0500 INFO  Multiplexer No streams
+2013-10-31 18:20:46,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:20:52,324-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:20:53,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:21:02,333-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:21:12,342-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:21:22,352-0500 INFO  Multiplexer No streams
+2013-10-31 18:21:23,093-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:21:26,490-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:21:32,362-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:21:42,370-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:21:52,379-0500 INFO  Multiplexer No streams
+2013-10-31 18:21:53,169-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:22:02,387-0500 INFO  Multiplexer No streams
+2013-10-31 18:22:06,158-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:22:12,396-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:22:22,405-0500 INFO  Multiplexer No streams
+2013-10-31 18:22:23,244-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:22:32,414-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:22:42,423-0500 INFO  Multiplexer No streams
-2013-10-28 14:49:09,777-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:22:45,827-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:49:17,927-0500 INFO  Multiplexer No streams
+2013-10-31 18:22:52,434-0500 INFO  Multiplexer No streams
+2013-10-31 18:22:53,318-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:49:27,935-0500 INFO  Multiplexer No streams
+2013-10-31 18:23:02,443-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:23:12,451-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:23:22,461-0500 INFO  Multiplexer No streams
+2013-10-31 18:23:23,393-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:23:25,496-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:23:32,471-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:23:42,480-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:23:52,491-0500 INFO  Multiplexer No streams
-2013-10-28 14:49:30,800-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:23:53,468-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:49:37,943-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:02,501-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:05,166-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:49:47,951-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:12,511-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:24:22,520-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:23,543-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:24:32,530-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:24:42,539-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:44,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:24:52,548-0500 INFO  Multiplexer No streams
+2013-10-31 18:24:53,618-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:25:02,558-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:25:12,568-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:25:22,578-0500 INFO  Multiplexer No streams
+2013-10-31 18:25:23,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:25:24,504-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:25:32,588-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:25:42,598-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:25:52,607-0500 INFO  Multiplexer No streams
+2013-10-31 18:25:53,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:26:02,618-0500 INFO  Multiplexer No streams
-2013-10-28 14:49:47,971-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:26:04,173-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:49:57,959-0500 INFO  Multiplexer No streams
+2013-10-31 18:26:12,627-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:26:22,637-0500 INFO  Multiplexer No streams
+2013-10-31 18:26:23,844-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:26:32,646-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:26:42,654-0500 INFO  Multiplexer No streams
+2013-10-31 18:26:43,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:26:52,662-0500 INFO  Multiplexer No streams
-2013-10-28 14:50:01,758-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:26:53,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:50:07,968-0500 INFO  Multiplexer No streams
+2013-10-31 18:27:02,671-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:50:17,976-0500 INFO  Multiplexer No streams
+2013-10-31 18:27:12,680-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:27:22,688-0500 INFO  Multiplexer No streams
+2013-10-31 18:27:23,512-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 18:27:23,993-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:27:32,698-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:27:42,706-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:27:52,714-0500 INFO  Multiplexer No streams
+2013-10-31 18:27:54,068-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:28:02,723-0500 INFO  Multiplexer No streams
-2013-10-28 14:50:26,165-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:28:03,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:50:27,984-0500 INFO  Multiplexer No streams
+2013-10-31 18:28:12,732-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:28:22,740-0500 INFO  Multiplexer No streams
-2013-10-28 14:50:32,716-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:28:24,143-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:50:37,992-0500 INFO  Multiplexer No streams
+2013-10-31 18:28:32,747-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:50:48,000-0500 INFO  Multiplexer No streams
+2013-10-31 18:28:42,755-0500 INFO  Multiplexer No streams
+2013-10-31 18:28:42,850-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
 No streams
-2013-10-28 14:50:58,008-0500 INFO  Multiplexer No streams
+2013-10-31 18:28:52,763-0500 INFO  Multiplexer No streams
-2013-10-28 14:51:03,674-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:28:54,218-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:29:02,771-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:29:12,779-0500 INFO  Multiplexer No streams
-2013-10-28 14:51:04,359-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:29:22,518-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:51:08,017-0500 INFO  Multiplexer No streams
+2013-10-31 18:29:22,786-0500 INFO  Multiplexer No streams
+2013-10-31 18:29:24,293-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:51:18,025-0500 INFO  Multiplexer No streams
+2013-10-31 18:29:32,794-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:51:28,033-0500 INFO  Multiplexer No streams
+2013-10-31 18:29:42,801-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:29:52,809-0500 INFO  Multiplexer No streams
+2013-10-31 18:29:54,368-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:30:02,187-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:30:02,816-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:30:12,824-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:30:22,831-0500 INFO  Multiplexer No streams
-2013-10-28 14:51:34,632-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:30:24,443-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:51:38,042-0500 INFO  Multiplexer No streams
+2013-10-31 18:30:32,838-0500 INFO  Multiplexer No streams
-2013-10-28 14:51:42,553-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:30:41,856-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:51:48,050-0500 INFO  Multiplexer No streams
+2013-10-31 18:30:42,846-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:51:58,059-0500 INFO  Multiplexer No streams
+2013-10-31 18:30:52,854-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 18:30:54,517-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:31:02,861-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:31:12,869-0500 INFO  Multiplexer No streams
+2013-10-31 18:31:21,525-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:31:22,877-0500 INFO  Multiplexer No streams
+2013-10-31 18:31:24,593-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:31:32,885-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:31:42,893-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:31:52,901-0500 INFO  Multiplexer No streams
+2013-10-31 18:31:54,669-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:32:01,194-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:32:02,908-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:32:12,916-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:32:22,924-0500 INFO  Multiplexer No streams
+2013-10-31 18:32:24,744-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:32:32,932-0500 INFO  Multiplexer No streams
+2013-10-31 18:32:40,863-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:32:42,940-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:32:52,947-0500 INFO  Multiplexer No streams
+2013-10-31 18:32:54,819-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:33:02,955-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:33:12,963-0500 INFO  Multiplexer No streams
+2013-10-31 18:33:20,532-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:33:22,971-0500 INFO  Multiplexer No streams
+2013-10-31 18:33:24,894-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:33:32,979-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:33:42,986-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:33:52,994-0500 INFO  Multiplexer No streams
+2013-10-31 18:33:54,969-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 18:34:00,201-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:34:03,002-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:34:13,010-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:34:23,018-0500 INFO  Multiplexer No streams
+2013-10-31 18:34:25,045-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:34:33,020-0500 INFO  Multiplexer No streams
+2013-10-31 18:34:39,870-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:34:43,028-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:34:53,036-0500 INFO  Multiplexer No streams
+2013-10-31 18:34:55,120-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:35:03,043-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:35:13,051-0500 INFO  Multiplexer No streams
+2013-10-31 18:35:19,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:35:23,059-0500 INFO  Multiplexer No streams
+2013-10-31 18:35:25,195-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:35:33,067-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:35:43,075-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:35:53,083-0500 INFO  Multiplexer No streams
-2013-10-28 14:52:05,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:35:55,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:35:59,208-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:52:08,067-0500 INFO  Multiplexer No streams
+2013-10-31 18:36:03,091-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:52:18,075-0500 INFO  Multiplexer No streams
+2013-10-31 18:36:13,099-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:36:23,107-0500 INFO  Multiplexer No streams
+2013-10-31 18:36:25,344-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:36:33,115-0500 INFO  Multiplexer No streams
-2013-10-28 14:52:20,747-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:36:38,877-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:52:28,084-0500 INFO  Multiplexer No streams
+2013-10-31 18:36:43,122-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:36:53,130-0500 INFO  Multiplexer No streams
-2013-10-28 14:52:36,548-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:36:55,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:52:38,092-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:03,138-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:52:48,100-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:13,146-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:18,546-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:52:58,109-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:23,154-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:25,495-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:37:33,162-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:37:43,170-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:37:53,178-0500 INFO  Multiplexer No streams
+2013-10-31 18:37:55,570-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:52:58,941-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:37:58,215-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:38:03,186-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:38:13,194-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:38:23,202-0500 INFO  Multiplexer No streams
+2013-10-31 18:38:25,645-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:38:33,210-0500 INFO  Multiplexer No streams
+2013-10-31 18:38:37,884-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:38:43,218-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:38:53,226-0500 INFO  Multiplexer No streams
+2013-10-31 18:38:55,720-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:39:03,234-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:39:13,242-0500 INFO  Multiplexer No streams
+2013-10-31 18:39:17,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:39:23,249-0500 INFO  Multiplexer No streams
+2013-10-31 18:39:25,794-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:39:33,257-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:39:43,265-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:39:53,273-0500 INFO  Multiplexer No streams
-2013-10-28 14:53:07,506-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:39:55,870-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:39:57,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:53:08,117-0500 INFO  Multiplexer No streams
+2013-10-31 18:40:03,281-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:53:18,125-0500 INFO  Multiplexer No streams
+2013-10-31 18:40:13,289-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:53:28,133-0500 INFO  Multiplexer No streams
+2013-10-31 18:40:23,297-0500 INFO  Multiplexer No streams
+2013-10-31 18:40:25,945-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:40:33,305-0500 INFO  Multiplexer No streams
-2013-10-28 14:53:37,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:40:36,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:53:38,142-0500 INFO  Multiplexer No streams
+2013-10-31 18:40:43,313-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:40:53,321-0500 INFO  Multiplexer No streams
-2013-10-28 14:53:38,464-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:40:56,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:53:48,150-0500 INFO  Multiplexer No streams
+2013-10-31 18:41:03,329-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:53:58,158-0500 INFO  Multiplexer No streams
+2013-10-31 18:41:13,337-0500 INFO  Multiplexer No streams
+2013-10-31 18:41:16,561-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:54:08,166-0500 INFO  Multiplexer No streams
+2013-10-31 18:41:23,345-0500 INFO  Multiplexer No streams
-2013-10-28 14:54:09,422-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:41:26,095-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:41:33,352-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:41:43,360-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:41:53,368-0500 INFO  Multiplexer No streams
+2013-10-31 18:41:56,169-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 18:41:56,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:42:03,376-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:42:13,384-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:42:23,392-0500 INFO  Multiplexer No streams
+2013-10-31 18:42:26,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:42:33,400-0500 INFO  Multiplexer No streams
+2013-10-31 18:42:35,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:42:43,408-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:42:53,416-0500 INFO  Multiplexer No streams
+2013-10-31 18:42:56,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:43:03,424-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:43:13,432-0500 INFO  Multiplexer No streams
+2013-10-31 18:43:15,568-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:43:23,440-0500 INFO  Multiplexer No streams
+2013-10-31 18:43:26,395-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:43:33,447-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:43:43,455-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:43:53,463-0500 INFO  Multiplexer No streams
+2013-10-31 18:43:55,237-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:43:56,470-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:44:03,471-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:44:13,479-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:44:23,487-0500 INFO  Multiplexer No streams
+2013-10-31 18:44:26,545-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:44:33,495-0500 INFO  Multiplexer No streams
-2013-10-28 14:54:15,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:44:34,906-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:54:18,175-0500 INFO  Multiplexer No streams
+2013-10-31 18:44:43,503-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:54:28,183-0500 INFO  Multiplexer No streams
+2013-10-31 18:44:53,511-0500 INFO  Multiplexer No streams
+2013-10-31 18:44:56,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:54:38,191-0500 INFO  Multiplexer No streams
+2013-10-31 18:45:03,519-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:45:13,527-0500 INFO  Multiplexer No streams
+2013-10-31 18:45:14,575-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:45:23,535-0500 INFO  Multiplexer No streams
+2013-10-31 18:45:26,694-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:45:33,543-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:45:43,551-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:45:53,559-0500 INFO  Multiplexer No streams
+2013-10-31 18:45:54,244-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:45:56,770-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:46:03,567-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:46:13,575-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:46:23,583-0500 INFO  Multiplexer No streams
-2013-10-28 14:54:40,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:46:26,846-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:54:48,200-0500 INFO  Multiplexer No streams
+2013-10-31 18:46:33,591-0500 INFO  Multiplexer No streams
-2013-10-28 14:54:53,524-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:46:33,913-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:54:58,208-0500 INFO  Multiplexer No streams
+2013-10-31 18:46:43,599-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:55:08,216-0500 INFO  Multiplexer No streams
+2013-10-31 18:46:53,607-0500 INFO  Multiplexer No streams
-2013-10-28 14:55:11,338-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:46:56,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:55:18,224-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:03,615-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:13,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:55:28,232-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:13,623-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:47:23,631-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:26,996-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:47:33,639-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:47:43,647-0500 INFO  Multiplexer No streams
-2013-10-28 14:55:31,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:47:53,251-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:55:38,241-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:53,655-0500 INFO  Multiplexer No streams
+2013-10-31 18:47:57,071-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:48:03,663-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:48:13,671-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:48:23,679-0500 INFO  Multiplexer No streams
+2013-10-31 18:48:27,145-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 18:48:32,920-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:48:33,687-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:48:43,695-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:48:53,703-0500 INFO  Multiplexer No streams
-2013-10-28 14:55:42,296-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:48:57,221-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:55:48,249-0500 INFO  Multiplexer No streams
+2013-10-31 18:49:03,711-0500 INFO  Multiplexer No streams
+2013-10-31 18:49:12,589-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:55:58,257-0500 INFO  Multiplexer No streams
+2013-10-31 18:49:13,719-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:56:08,265-0500 INFO  Multiplexer No streams
+2013-10-31 18:49:23,727-0500 INFO  Multiplexer No streams
+2013-10-31 18:49:27,296-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:49:33,735-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:49:43,743-0500 INFO  Multiplexer No streams
-2013-10-28 14:56:09,912-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:49:52,258-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:49:53,751-0500 INFO  Multiplexer No streams
-2013-10-28 14:56:13,254-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:49:57,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:56:18,273-0500 INFO  Multiplexer No streams
+2013-10-31 18:50:03,759-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:56:28,282-0500 INFO  Multiplexer No streams
+2013-10-31 18:50:13,767-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:56:38,290-0500 INFO  Multiplexer No streams
+2013-10-31 18:50:23,775-0500 INFO  Multiplexer No streams
+2013-10-31 18:50:27,446-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:50:31,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 18:50:33,783-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:50:43,791-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:50:53,799-0500 INFO  Multiplexer No streams
+2013-10-31 18:50:57,520-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:51:03,807-0500 INFO  Multiplexer No streams
+2013-10-31 18:51:11,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:51:13,815-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:51:23,822-0500 INFO  Multiplexer No streams
+2013-10-31 18:51:27,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:51:33,830-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:51:43,838-0500 INFO  Multiplexer No streams
+2013-10-31 18:51:51,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:51:53,846-0500 INFO  Multiplexer No streams
-2013-10-28 14:56:44,212-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:51:57,671-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:52:03,853-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:52:13,861-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:52:23,869-0500 INFO  Multiplexer No streams
+2013-10-31 18:52:27,746-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:52:30,934-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:52:33,876-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:52:43,884-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:52:53,892-0500 INFO  Multiplexer No streams
+2013-10-31 18:52:57,821-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:53:03,899-0500 INFO  Multiplexer No streams
+2013-10-31 18:53:10,603-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:53:13,907-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:53:23,915-0500 INFO  Multiplexer No streams
+2013-10-31 18:53:27,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:53:33,923-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:53:43,930-0500 INFO  Multiplexer No streams
+2013-10-31 18:53:50,272-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:53:53,938-0500 INFO  Multiplexer No streams
+2013-10-31 18:53:57,970-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:54:03,946-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:54:13,953-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:54:23,961-0500 INFO  Multiplexer No streams
+2013-10-31 18:54:28,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:54:29,941-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:54:33,969-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:54:43,976-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:54:53,984-0500 INFO  Multiplexer No streams
+2013-10-31 18:54:58,121-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:55:03,992-0500 INFO  Multiplexer No streams
+2013-10-31 18:55:09,610-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:55:14,000-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:55:24,008-0500 INFO  Multiplexer No streams
+2013-10-31 18:55:28,196-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:55:34,015-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:55:44,023-0500 INFO  Multiplexer No streams
-2013-10-28 14:56:48,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:55:49,279-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:56:48,298-0500 INFO  Multiplexer No streams
+2013-10-31 18:55:54,031-0500 INFO  Multiplexer No streams
+2013-10-31 18:55:58,271-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:56:58,306-0500 INFO  Multiplexer No streams
+2013-10-31 18:56:04,039-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:57:08,314-0500 INFO  Multiplexer No streams
+2013-10-31 18:56:14,046-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:56:24,054-0500 INFO  Multiplexer No streams
+2013-10-31 18:56:28,346-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 18:56:28,948-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:56:34,062-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:56:44,070-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:56:54,078-0500 INFO  Multiplexer No streams
+2013-10-31 18:56:58,421-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:57:04,086-0500 INFO  Multiplexer No streams
+2013-10-31 18:57:08,617-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:57:14,094-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:57:24,102-0500 INFO  Multiplexer No streams
+2013-10-31 18:57:28,495-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 18:57:34,109-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:57:44,117-0500 INFO  Multiplexer No streams
+2013-10-31 18:57:48,286-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:57:54,125-0500 INFO  Multiplexer No streams
-2013-10-28 14:57:15,170-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:57:58,571-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:57:18,322-0500 INFO  Multiplexer No streams
+2013-10-31 18:58:04,133-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:58:14,142-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:58:24,150-0500 INFO  Multiplexer No streams
-2013-10-28 14:57:26,300-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:58:27,955-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 18:58:28,646-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:57:28,330-0500 INFO  Multiplexer No streams
+2013-10-31 18:58:34,158-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:57:38,338-0500 INFO  Multiplexer No streams
+2013-10-31 18:58:44,166-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:58:54,174-0500 INFO  Multiplexer No streams
+2013-10-31 18:58:58,721-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:59:04,182-0500 INFO  Multiplexer No streams
+2013-10-31 18:59:07,624-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:59:14,190-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:59:24,198-0500 INFO  Multiplexer No streams
+2013-10-31 18:59:28,796-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 18:59:34,206-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 18:59:44,214-0500 INFO  Multiplexer No streams
+2013-10-31 18:59:47,293-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 18:59:54,222-0500 INFO  Multiplexer No streams
+2013-10-31 18:59:58,870-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:00:04,230-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:00:14,238-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:00:24,246-0500 INFO  Multiplexer No streams
+2013-10-31 19:00:26,962-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 14:57:46,128-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:00:28,946-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:57:48,346-0500 INFO  Multiplexer No streams
+2013-10-31 19:00:34,254-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:57:58,353-0500 INFO  Multiplexer No streams
+2013-10-31 19:00:44,262-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:00:54,271-0500 INFO  Multiplexer No streams
+2013-10-31 19:00:59,021-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:01:04,279-0500 INFO  Multiplexer No streams
-2013-10-28 14:58:04,494-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:01:06,631-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:58:08,361-0500 INFO  Multiplexer No streams
+2013-10-31 19:01:14,287-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:01:24,295-0500 INFO  Multiplexer No streams
+2013-10-31 19:01:29,096-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:01:34,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:01:44,311-0500 INFO  Multiplexer No streams
+2013-10-31 19:01:46,300-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:01:54,319-0500 INFO  Multiplexer No streams
+2013-10-31 19:01:59,171-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:02:04,327-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:02:14,335-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:02:24,343-0500 INFO  Multiplexer No streams
+2013-10-31 19:02:25,969-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:02:29,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:02:34,351-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:02:44,359-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:02:54,368-0500 INFO  Multiplexer No streams
-2013-10-28 14:58:17,086-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:02:59,321-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:58:18,369-0500 INFO  Multiplexer No streams
+2013-10-31 19:03:04,376-0500 INFO  Multiplexer No streams
+2013-10-31 19:03:05,638-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:58:28,377-0500 INFO  Multiplexer No streams
+2013-10-31 19:03:14,384-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:58:38,384-0500 INFO  Multiplexer No streams
+2013-10-31 19:03:24,392-0500 INFO  Multiplexer No streams
+2013-10-31 19:03:29,396-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:03:34,400-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:03:44,408-0500 INFO  Multiplexer No streams
-2013-10-28 14:58:42,688-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:03:45,307-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:03:54,416-0500 INFO  Multiplexer No streams
-2013-10-28 14:58:48,044-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:03:59,471-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:58:48,392-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:04,424-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:58:58,400-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:14,432-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:59:08,408-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:24,440-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:24,976-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:04:29,546-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:59:18,416-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:34,448-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:04:44,456-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:04:54,465-0500 INFO  Multiplexer No streams
+2013-10-31 19:04:59,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:05:04,473-0500 INFO  Multiplexer No streams
+2013-10-31 19:05:04,645-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:05:14,481-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:05:24,489-0500 INFO  Multiplexer No streams
+2013-10-31 19:05:29,696-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:05:34,497-0500 INFO  Multiplexer No streams
+2013-10-31 19:05:44,314-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:05:44,505-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:05:54,513-0500 INFO  Multiplexer No streams
-2013-10-28 14:59:19,002-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:05:59,771-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:06:04,521-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:06:14,529-0500 INFO  Multiplexer No streams
-2013-10-28 14:59:20,882-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:06:23,983-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:59:28,423-0500 INFO  Multiplexer No streams
+2013-10-31 19:06:24,537-0500 INFO  Multiplexer No streams
+2013-10-31 19:06:29,846-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 14:59:38,431-0500 INFO  Multiplexer No streams
+2013-10-31 19:06:34,545-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 14:59:48,439-0500 INFO  Multiplexer No streams
+2013-10-31 19:06:44,553-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:06:54,561-0500 INFO  Multiplexer No streams
+2013-10-31 19:06:59,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:07:03,652-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:07:04,569-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:07:14,577-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:07:24,585-0500 INFO  Multiplexer No streams
+2013-10-31 19:07:29,995-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:07:34,593-0500 INFO  Multiplexer No streams
+2013-10-31 19:07:43,321-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:07:44,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:07:54,609-0500 INFO  Multiplexer No streams
-2013-10-28 14:59:49,960-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:08:00,071-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 14:59:58,447-0500 INFO  Multiplexer No streams
+2013-10-31 19:08:04,617-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:08:14,625-0500 INFO  Multiplexer No streams
-2013-10-28 14:59:59,076-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:08:22,990-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:00:08,455-0500 INFO  Multiplexer No streams
+2013-10-31 19:08:24,633-0500 INFO  Multiplexer No streams
+2013-10-31 19:08:30,146-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:00:18,463-0500 INFO  Multiplexer No streams
+2013-10-31 19:08:34,641-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:08:44,649-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:08:54,657-0500 INFO  Multiplexer No streams
-2013-10-28 15:00:20,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:09:00,221-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:09:02,659-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:00:28,471-0500 INFO  Multiplexer No streams
+2013-10-31 19:09:04,665-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:09:14,673-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:09:24,681-0500 INFO  Multiplexer No streams
+2013-10-31 19:09:30,296-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:09:34,689-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:09:42,329-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:09:44,696-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:09:54,704-0500 INFO  Multiplexer No streams
+2013-10-31 19:10:00,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:10:04,712-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:10:14,719-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 19:10:21,998-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:10:24,727-0500 INFO  Multiplexer No streams
+2013-10-31 19:10:30,445-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:10:34,735-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:10:44,742-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:10:54,750-0500 INFO  Multiplexer No streams
+2013-10-31 19:11:00,521-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:11:01,666-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:11:04,758-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:11:14,765-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:11:24,773-0500 INFO  Multiplexer No streams
+2013-10-31 19:11:30,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:11:34,781-0500 INFO  Multiplexer No streams
+2013-10-31 19:11:41,335-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:11:44,789-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:11:54,796-0500 INFO  Multiplexer No streams
+2013-10-31 19:12:00,671-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:12:04,804-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:12:14,811-0500 INFO  Multiplexer No streams
+2013-10-31 19:12:21,004-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:12:24,819-0500 INFO  Multiplexer No streams
+2013-10-31 19:12:30,746-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:12:34,826-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:12:44,834-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:12:54,842-0500 INFO  Multiplexer No streams
+2013-10-31 19:13:00,675-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:13:00,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:13:04,849-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:13:14,857-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:13:24,864-0500 INFO  Multiplexer No streams
+2013-10-31 19:13:30,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:13:34,872-0500 INFO  Multiplexer No streams
+2013-10-31 19:13:40,344-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:13:44,879-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:13:54,887-0500 INFO  Multiplexer No streams
+2013-10-31 19:14:00,971-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:14:04,894-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:14:14,902-0500 INFO  Multiplexer No streams
+2013-10-31 19:14:20,013-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:14:24,909-0500 INFO  Multiplexer No streams
+2013-10-31 19:14:31,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:14:34,917-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:14:44,925-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:14:54,932-0500 INFO  Multiplexer No streams
+2013-10-31 19:14:59,682-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:15:01,121-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:15:04,940-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:15:14,947-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:15:24,955-0500 INFO  Multiplexer No streams
+2013-10-31 19:15:31,196-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:15:34,962-0500 INFO  Multiplexer No streams
+2013-10-31 19:15:39,351-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:15:44,970-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:15:54,978-0500 INFO  Multiplexer No streams
+2013-10-31 19:16:01,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:16:04,985-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:16:14,993-0500 INFO  Multiplexer No streams
+2013-10-31 19:16:19,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:16:25,001-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:16:31,346-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:16:35,009-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:16:45,017-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:16:55,025-0500 INFO  Multiplexer No streams
+2013-10-31 19:16:58,689-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:17:01,421-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:17:05,033-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:17:15,041-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:17:25,048-0500 INFO  Multiplexer No streams
+2013-10-31 19:17:31,496-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:17:35,056-0500 INFO  Multiplexer No streams
+2013-10-31 19:17:38,359-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:17:45,064-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:17:55,072-0500 INFO  Multiplexer No streams
+2013-10-31 19:18:01,571-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:18:05,080-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:18:15,088-0500 INFO  Multiplexer No streams
-2013-10-28 15:00:37,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:18:18,028-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:00:38,479-0500 INFO  Multiplexer No streams
+2013-10-31 19:18:25,096-0500 INFO  Multiplexer No streams
+2013-10-31 19:18:31,646-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:00:48,488-0500 INFO  Multiplexer No streams
+2013-10-31 19:18:35,104-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:18:45,112-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:18:55,119-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:18:57,697-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:19:01,721-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:19:05,127-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:19:15,135-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:19:25,143-0500 INFO  Multiplexer No streams
-2013-10-28 15:00:51,876-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:19:31,796-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:00:58,496-0500 INFO  Multiplexer No streams
+2013-10-31 19:19:35,151-0500 INFO  Multiplexer No streams
+2013-10-31 19:19:37,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:01:08,504-0500 INFO  Multiplexer No streams
+2013-10-31 19:19:45,158-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:19:55,166-0500 INFO  Multiplexer No streams
+2013-10-31 19:20:01,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:20:05,174-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:20:15,182-0500 INFO  Multiplexer No streams
+2013-10-31 19:20:17,035-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:20:25,190-0500 INFO  Multiplexer No streams
+2013-10-31 19:20:31,945-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:20:35,198-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:20:45,205-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:20:55,213-0500 INFO  Multiplexer No streams
+2013-10-31 19:20:56,704-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:21:02,021-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:21:05,221-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:21:15,229-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:21:25,237-0500 INFO  Multiplexer No streams
+2013-10-31 19:21:32,096-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:21:35,245-0500 INFO  Multiplexer No streams
-2013-10-28 15:01:15,464-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:21:36,373-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:01:18,512-0500 INFO  Multiplexer No streams
+2013-10-31 19:21:45,252-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:21:55,260-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:02,171-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:22:05,268-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:22:15,276-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:16,042-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:22:25,284-0500 INFO  Multiplexer No streams
-2013-10-28 15:01:22,834-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:22:32,247-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:01:28,520-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:35,292-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:01:38,528-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:45,299-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:01:48,537-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:55,307-0500 INFO  Multiplexer No streams
+2013-10-31 19:22:55,711-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:23:02,322-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:23:05,315-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:23:15,323-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:23:25,331-0500 INFO  Multiplexer No streams
+2013-10-31 19:23:32,397-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:23:35,339-0500 INFO  Multiplexer No streams
+2013-10-31 19:23:35,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:23:45,346-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:23:55,354-0500 INFO  Multiplexer No streams
+2013-10-31 19:24:02,472-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:24:05,362-0500 INFO  Multiplexer No streams
+2013-10-31 19:24:15,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:24:15,370-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:24:25,378-0500 INFO  Multiplexer No streams
+2013-10-31 19:24:32,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:24:35,386-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:24:45,394-0500 INFO  Multiplexer No streams
-2013-10-28 15:01:53,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:24:54,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:24:55,396-0500 INFO  Multiplexer No streams
+2013-10-31 19:25:02,622-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:25:05,404-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:25:15,412-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:25:25,420-0500 INFO  Multiplexer No streams
+2013-10-31 19:25:32,698-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:25:34,387-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:25:35,428-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:25:45,436-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:25:55,444-0500 INFO  Multiplexer No streams
+2013-10-31 19:26:02,773-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:26:05,451-0500 INFO  Multiplexer No streams
+2013-10-31 19:26:14,056-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:26:15,459-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:26:25,467-0500 INFO  Multiplexer No streams
+2013-10-31 19:26:32,847-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:26:35,475-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:26:45,483-0500 INFO  Multiplexer No streams
+2013-10-31 19:26:53,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:26:55,492-0500 INFO  Multiplexer No streams
-2013-10-28 15:01:53,792-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:27:02,923-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:01:58,545-0500 INFO  Multiplexer No streams
+2013-10-31 19:27:05,500-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:02:08,553-0500 INFO  Multiplexer No streams
+2013-10-31 19:27:15,508-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:02:18,561-0500 INFO  Multiplexer No streams
+2013-10-31 19:27:25,516-0500 INFO  Multiplexer No streams
+2013-10-31 19:27:32,998-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:27:33,394-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:27:35,524-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:27:45,532-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:27:55,540-0500 INFO  Multiplexer No streams
-2013-10-28 15:02:24,750-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:28:03,073-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:02:28,569-0500 INFO  Multiplexer No streams
+2013-10-31 19:28:05,548-0500 INFO  Multiplexer No streams
+2013-10-31 19:28:13,063-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:28:15,555-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:28:25,563-0500 INFO  Multiplexer No streams
+2013-10-31 19:28:33,148-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:28:35,571-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:28:45,578-0500 INFO  Multiplexer No streams
+2013-10-31 19:28:52,733-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:28:55,586-0500 INFO  Multiplexer No streams
+2013-10-31 19:29:03,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:29:05,593-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:29:15,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:29:25,608-0500 INFO  Multiplexer No streams
-2013-10-28 15:02:31,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:29:32,402-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 19:29:33,298-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:02:38,578-0500 INFO  Multiplexer No streams
+2013-10-31 19:29:35,616-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:02:48,586-0500 INFO  Multiplexer No streams
+2013-10-31 19:29:45,623-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:29:55,631-0500 INFO  Multiplexer No streams
+2013-10-31 19:30:03,374-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:30:05,638-0500 INFO  Multiplexer No streams
+2013-10-31 19:30:12,071-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:30:15,646-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:30:25,653-0500 INFO  Multiplexer No streams
+2013-10-31 19:30:33,448-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:30:35,661-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:30:45,668-0500 INFO  Multiplexer No streams
+2013-10-31 19:30:51,740-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:30:55,676-0500 INFO  Multiplexer No streams
-2013-10-28 15:02:55,708-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:31:03,524-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:02:58,594-0500 INFO  Multiplexer No streams
+2013-10-31 19:31:05,683-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:03:08,602-0500 INFO  Multiplexer No streams
+2013-10-31 19:31:15,691-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:31:25,698-0500 INFO  Multiplexer No streams
+2013-10-31 19:31:31,409-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 19:31:33,598-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:31:35,705-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:31:45,713-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:31:55,720-0500 INFO  Multiplexer No streams
+2013-10-31 19:32:03,674-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:32:05,728-0500 INFO  Multiplexer No streams
-2013-10-28 15:03:10,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:32:11,078-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:03:18,611-0500 INFO  Multiplexer No streams
+2013-10-31 19:32:15,735-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:32:25,743-0500 INFO  Multiplexer No streams
+2013-10-31 19:32:33,749-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:32:35,750-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:32:45,758-0500 INFO  Multiplexer No streams
+2013-10-31 19:32:50,747-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:32:55,765-0500 INFO  Multiplexer No streams
+2013-10-31 19:33:03,823-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:33:05,773-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:33:15,780-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:33:25,787-0500 INFO  Multiplexer No streams
+2013-10-31 19:33:30,416-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:03:26,666-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:33:33,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:03:28,619-0500 INFO  Multiplexer No streams
+2013-10-31 19:33:35,795-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:03:38,627-0500 INFO  Multiplexer No streams
+2013-10-31 19:33:45,802-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:33:55,810-0500 INFO  Multiplexer No streams
+2013-10-31 19:34:03,974-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:34:05,817-0500 INFO  Multiplexer No streams
+2013-10-31 19:34:10,084-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:34:15,825-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:34:25,832-0500 INFO  Multiplexer No streams
+2013-10-31 19:34:34,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:34:35,840-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:34:45,847-0500 INFO  Multiplexer No streams
-2013-10-28 15:03:48,240-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:34:49,754-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:03:48,635-0500 INFO  Multiplexer No streams
+2013-10-31 19:34:55,855-0500 INFO  Multiplexer No streams
-2013-10-28 15:03:57,624-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:35:04,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:03:58,643-0500 INFO  Multiplexer No streams
+2013-10-31 19:35:05,862-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:04:08,652-0500 INFO  Multiplexer No streams
+2013-10-31 19:35:15,869-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:04:18,660-0500 INFO  Multiplexer No streams
+2013-10-31 19:35:25,877-0500 INFO  Multiplexer No streams
-2013-10-28 15:04:26,434-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:35:29,423-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:35:34,198-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:35:35,884-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:35:45,892-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:35:55,899-0500 INFO  Multiplexer No streams
-2013-10-28 15:04:28,582-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:36:04,274-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:04:28,668-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:05,907-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:09,092-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:04:38,676-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:15,914-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:04:48,684-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:25,922-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:34,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:04:58,692-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:35,929-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:36:45,936-0500 INFO  Multiplexer No streams
+2013-10-31 19:36:48,761-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:36:55,944-0500 INFO  Multiplexer No streams
+2013-10-31 19:37:04,424-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:37:05,951-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:37:15,959-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:37:25,966-0500 INFO  Multiplexer No streams
+2013-10-31 19:37:28,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:04:59,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:37:34,500-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:37:35,974-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:37:45,981-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:37:55,988-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:04,575-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:38:05,996-0500 INFO  Multiplexer No streams
-2013-10-28 15:05:04,628-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:38:08,099-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:05:08,700-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:16,003-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:05:18,709-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:26,011-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:34,650-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:05:28,717-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:36,018-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:38:46,025-0500 INFO  Multiplexer No streams
+2013-10-31 19:38:47,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:38:56,033-0500 INFO  Multiplexer No streams
-2013-10-28 15:05:30,499-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:39:04,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:05:38,725-0500 INFO  Multiplexer No streams
+2013-10-31 19:39:06,040-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:39:16,048-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:39:26,055-0500 INFO  Multiplexer No streams
+2013-10-31 19:39:27,437-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:39:34,799-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:39:36,063-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:39:46,070-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:39:56,077-0500 INFO  Multiplexer No streams
+2013-10-31 19:40:04,875-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:40:06,085-0500 INFO  Multiplexer No streams
+2013-10-31 19:40:07,107-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:40:16,092-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:40:26,099-0500 INFO  Multiplexer No streams
+2013-10-31 19:40:34,950-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:40:36,107-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:40:46,114-0500 INFO  Multiplexer No streams
-2013-10-28 15:05:42,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:40:46,776-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:05:48,733-0500 INFO  Multiplexer No streams
+2013-10-31 19:40:56,121-0500 INFO  Multiplexer No streams
+2013-10-31 19:41:05,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:05:58,741-0500 INFO  Multiplexer No streams
+2013-10-31 19:41:06,129-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:41:16,136-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:41:26,143-0500 INFO  Multiplexer No streams
+2013-10-31 19:41:26,445-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:06:01,457-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:41:35,100-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:06:08,750-0500 INFO  Multiplexer No streams
+2013-10-31 19:41:36,151-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:06:18,758-0500 INFO  Multiplexer No streams
+2013-10-31 19:41:46,158-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:41:56,165-0500 INFO  Multiplexer No streams
+2013-10-31 19:42:05,174-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 19:42:06,114-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:42:06,173-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:42:16,180-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:42:26,187-0500 INFO  Multiplexer No streams
+2013-10-31 19:42:35,250-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:42:36,195-0500 INFO  Multiplexer No streams
+2013-10-31 19:42:45,783-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:42:46,202-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:42:56,210-0500 INFO  Multiplexer No streams
+2013-10-31 19:43:05,325-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:43:06,217-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:43:16,224-0500 INFO  Multiplexer No streams
-2013-10-28 15:06:21,016-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:43:25,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:06:28,766-0500 INFO  Multiplexer No streams
+2013-10-31 19:43:26,232-0500 INFO  Multiplexer No streams
+2013-10-31 19:43:35,400-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:43:36,239-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:43:46,246-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:43:56,254-0500 INFO  Multiplexer No streams
+2013-10-31 19:44:05,121-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:44:05,476-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:44:06,261-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:44:16,268-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:44:26,276-0500 INFO  Multiplexer No streams
+2013-10-31 19:44:35,550-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:44:36,283-0500 INFO  Multiplexer No streams
+2013-10-31 19:44:44,790-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:44:46,290-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:44:56,298-0500 INFO  Multiplexer No streams
-2013-10-28 15:06:32,415-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:45:05,626-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:06:38,774-0500 INFO  Multiplexer No streams
+2013-10-31 19:45:06,305-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:06:48,783-0500 INFO  Multiplexer No streams
+2013-10-31 19:45:16,312-0500 INFO  Multiplexer No streams
+2013-10-31 19:45:24,458-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:06:58,791-0500 INFO  Multiplexer No streams
+2013-10-31 19:45:26,320-0500 INFO  Multiplexer No streams
+2013-10-31 19:45:35,701-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:45:36,327-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:45:46,335-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:45:56,342-0500 INFO  Multiplexer No streams
-2013-10-28 15:06:59,210-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:46:04,128-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:46:05,775-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:46:06,349-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:46:16,357-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:46:26,364-0500 INFO  Multiplexer No streams
-2013-10-28 15:07:03,373-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:46:35,851-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:07:08,798-0500 INFO  Multiplexer No streams
+2013-10-31 19:46:36,371-0500 INFO  Multiplexer No streams
+2013-10-31 19:46:43,797-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:07:18,806-0500 INFO  Multiplexer No streams
+2013-10-31 19:46:46,378-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:07:28,813-0500 INFO  Multiplexer No streams
+2013-10-31 19:46:56,386-0500 INFO  Multiplexer No streams
+2013-10-31 19:47:05,926-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:47:06,393-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:47:16,400-0500 INFO  Multiplexer No streams
+2013-10-31 19:47:23,466-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:47:26,408-0500 INFO  Multiplexer No streams
-2013-10-28 15:07:34,331-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:47:36,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:47:36,415-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:47:46,422-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:47:56,430-0500 INFO  Multiplexer No streams
+2013-10-31 19:48:03,135-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:48:06,076-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:48:06,437-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:48:16,444-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:48:26,452-0500 INFO  Multiplexer No streams
+2013-10-31 19:48:36,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:48:36,459-0500 INFO  Multiplexer No streams
-2013-10-28 15:07:37,404-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:48:42,804-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:07:38,820-0500 INFO  Multiplexer No streams
+2013-10-31 19:48:46,466-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:07:48,827-0500 INFO  Multiplexer No streams
+2013-10-31 19:48:56,474-0500 INFO  Multiplexer No streams
+2013-10-31 19:49:06,227-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:07:58,834-0500 INFO  Multiplexer No streams
+2013-10-31 19:49:06,481-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:49:16,488-0500 INFO  Multiplexer No streams
+2013-10-31 19:49:22,473-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:49:26,496-0500 INFO  Multiplexer No streams
-2013-10-28 15:08:05,290-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:49:36,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:08:08,842-0500 INFO  Multiplexer No streams
+2013-10-31 19:49:36,503-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:49:46,510-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:49:56,517-0500 INFO  Multiplexer No streams
+2013-10-31 19:50:02,142-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:50:06,377-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:50:06,525-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:50:16,532-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:50:26,539-0500 INFO  Multiplexer No streams
+2013-10-31 19:50:36,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:50:36,547-0500 INFO  Multiplexer No streams
+2013-10-31 19:50:41,811-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:50:46,554-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:50:56,561-0500 INFO  Multiplexer No streams
+2013-10-31 19:51:06,527-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:51:06,569-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:51:16,576-0500 INFO  Multiplexer No streams
-2013-10-28 15:08:15,598-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:51:21,480-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:08:18,849-0500 INFO  Multiplexer No streams
+2013-10-31 19:51:26,583-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:08:28,856-0500 INFO  Multiplexer No streams
+2013-10-31 19:51:36,591-0500 INFO  Multiplexer No streams
+2013-10-31 19:51:36,602-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:51:46,598-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:51:56,605-0500 INFO  Multiplexer No streams
+2013-10-31 19:52:01,149-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:52:06,612-0500 INFO  Multiplexer No streams
+2013-10-31 19:52:06,676-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:52:16,620-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:52:26,627-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:52:36,634-0500 INFO  Multiplexer No streams
-2013-10-28 15:08:36,248-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:52:36,752-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:52:40,818-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:08:38,863-0500 INFO  Multiplexer No streams
+2013-10-31 19:52:46,642-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:08:48,871-0500 INFO  Multiplexer No streams
+2013-10-31 19:52:56,649-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:53:06,657-0500 INFO  Multiplexer No streams
+2013-10-31 19:53:06,827-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:53:16,664-0500 INFO  Multiplexer No streams
+2013-10-31 19:53:20,487-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:53:26,671-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:53:36,679-0500 INFO  Multiplexer No streams
+2013-10-31 19:53:36,902-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:53:46,686-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:53:56,693-0500 INFO  Multiplexer No streams
-2013-10-28 15:08:53,792-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:54:00,156-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:08:58,878-0500 INFO  Multiplexer No streams
+2013-10-31 19:54:06,701-0500 INFO  Multiplexer No streams
-2013-10-28 15:09:07,206-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:54:06,977-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:09:08,885-0500 INFO  Multiplexer No streams
+2013-10-31 19:54:16,708-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:09:18,893-0500 INFO  Multiplexer No streams
+2013-10-31 19:54:26,715-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:09:28,900-0500 INFO  Multiplexer No streams
+2013-10-31 19:54:36,723-0500 INFO  Multiplexer No streams
+2013-10-31 19:54:37,052-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:09:31,986-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:54:39,825-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:54:46,730-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:54:56,738-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:55:06,745-0500 INFO  Multiplexer No streams
+2013-10-31 19:55:07,128-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:55:16,752-0500 INFO  Multiplexer No streams
+2013-10-31 19:55:19,494-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:55:26,760-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:55:36,767-0500 INFO  Multiplexer No streams
-2013-10-28 15:09:38,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:55:37,203-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:09:38,907-0500 INFO  Multiplexer No streams
+2013-10-31 19:55:46,774-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:09:48,915-0500 INFO  Multiplexer No streams
+2013-10-31 19:55:56,782-0500 INFO  Multiplexer No streams
+2013-10-31 19:55:59,163-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:09:58,922-0500 INFO  Multiplexer No streams
+2013-10-31 19:56:06,789-0500 INFO  Multiplexer No streams
+2013-10-31 19:56:07,278-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:10:08,930-0500 INFO  Multiplexer No streams
+2013-10-31 19:56:16,796-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:56:26,803-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:56:36,811-0500 INFO  Multiplexer No streams
-2013-10-28 15:10:09,122-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
-2013-10-28 15:10:10,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-10-31 19:56:37,353-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 19:56:38,832-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:10:18,937-0500 INFO  Multiplexer No streams
+2013-10-31 19:56:46,818-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:10:28,945-0500 INFO  Multiplexer No streams
+2013-10-31 19:56:56,825-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:10:38,952-0500 INFO  Multiplexer No streams
+2013-10-31 19:57:06,833-0500 INFO  Multiplexer No streams
+2013-10-31 19:57:07,428-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:57:16,840-0500 INFO  Multiplexer No streams
+2013-10-31 19:57:18,501-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:57:26,847-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:57:36,854-0500 INFO  Multiplexer No streams
+2013-10-31 19:57:37,503-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:57:46,862-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:57:56,869-0500 INFO  Multiplexer No streams
+2013-10-31 19:57:58,170-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:58:06,876-0500 INFO  Multiplexer No streams
+2013-10-31 19:58:07,578-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:58:16,884-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:58:26,891-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:58:36,898-0500 INFO  Multiplexer No streams
+2013-10-31 19:58:37,653-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 19:58:37,839-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:58:46,905-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:58:56,913-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:59:06,920-0500 INFO  Multiplexer No streams
+2013-10-31 19:59:07,728-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 19:59:16,927-0500 INFO  Multiplexer No streams
+2013-10-31 19:59:17,507-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 19:59:26,935-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:59:36,942-0500 INFO  Multiplexer No streams
+2013-10-31 19:59:37,803-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 19:59:46,949-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 19:59:56,957-0500 INFO  Multiplexer No streams
+2013-10-31 19:59:57,177-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:00:06,964-0500 INFO  Multiplexer No streams
+2013-10-31 20:00:07,877-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:00:16,971-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:00:26,978-0500 INFO  Multiplexer No streams
+2013-10-31 20:00:36,846-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:00:36,986-0500 INFO  Multiplexer No streams
+2013-10-31 20:00:37,953-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:00:46,993-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:00:57,000-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:01:07,008-0500 INFO  Multiplexer No streams
+2013-10-31 20:01:08,028-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:01:16,515-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:01:17,015-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:01:27,022-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:01:37,030-0500 INFO  Multiplexer No streams
+2013-10-31 20:01:38,103-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:01:47,037-0500 INFO  Multiplexer No streams
+2013-10-31 20:01:56,185-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:01:57,044-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:02:07,051-0500 INFO  Multiplexer No streams
+2013-10-31 20:02:08,178-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:02:17,059-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:02:27,066-0500 INFO  Multiplexer No streams
+2013-10-31 20:02:35,853-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:02:37,073-0500 INFO  Multiplexer No streams
+2013-10-31 20:02:38,253-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:02:47,080-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:02:57,088-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:03:07,095-0500 INFO  Multiplexer No streams
+2013-10-31 20:03:08,328-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:03:15,522-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:03:17,102-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:03:27,109-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:03:37,117-0500 INFO  Multiplexer No streams
+2013-10-31 20:03:38,403-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:03:47,124-0500 INFO  Multiplexer No streams
+2013-10-31 20:03:55,191-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:03:57,131-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:04:07,139-0500 INFO  Multiplexer No streams
+2013-10-31 20:04:08,478-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:04:17,146-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:04:27,153-0500 INFO  Multiplexer No streams
+2013-10-31 20:04:34,860-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:04:37,161-0500 INFO  Multiplexer No streams
+2013-10-31 20:04:38,553-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:04:47,172-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:04:57,179-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:05:07,187-0500 INFO  Multiplexer No streams
+2013-10-31 20:05:08,628-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:05:14,530-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:05:17,194-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:05:27,201-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:05:37,208-0500 INFO  Multiplexer No streams
+2013-10-31 20:05:38,703-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:05:47,216-0500 INFO  Multiplexer No streams
+2013-10-31 20:05:54,200-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:05:57,223-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:06:07,230-0500 INFO  Multiplexer No streams
+2013-10-31 20:06:08,778-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:06:17,237-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:06:27,244-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:06:33,869-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:06:37,251-0500 INFO  Multiplexer No streams
+2013-10-31 20:06:38,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:06:47,258-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:06:57,265-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:07:07,272-0500 INFO  Multiplexer No streams
+2013-10-31 20:07:08,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:07:13,538-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:07:17,279-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:07:27,286-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:07:37,293-0500 INFO  Multiplexer No streams
+2013-10-31 20:07:39,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:07:47,299-0500 INFO  Multiplexer No streams
+2013-10-31 20:07:53,207-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:07:57,307-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:08:07,314-0500 INFO  Multiplexer No streams
+2013-10-31 20:08:09,078-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:08:17,321-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:08:27,329-0500 INFO  Multiplexer No streams
+2013-10-31 20:08:32,876-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:08:37,336-0500 INFO  Multiplexer No streams
+2013-10-31 20:08:39,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:08:47,343-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:08:57,350-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:09:07,358-0500 INFO  Multiplexer No streams
+2013-10-31 20:09:09,228-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:09:12,545-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:09:17,365-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:09:27,372-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:09:37,380-0500 INFO  Multiplexer No streams
+2013-10-31 20:09:39,303-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:09:47,387-0500 INFO  Multiplexer No streams
+2013-10-31 20:09:52,214-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:09:57,394-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:10:07,401-0500 INFO  Multiplexer No streams
+2013-10-31 20:10:09,378-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:10:17,409-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:10:27,416-0500 INFO  Multiplexer No streams
+2013-10-31 20:10:31,883-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:10:37,423-0500 INFO  Multiplexer No streams
+2013-10-31 20:10:39,453-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:10:47,431-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:10:57,438-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:11:07,445-0500 INFO  Multiplexer No streams
+2013-10-31 20:11:09,528-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:11:11,552-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:11:17,453-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:11:27,460-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:11:37,467-0500 INFO  Multiplexer No streams
+2013-10-31 20:11:39,603-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:11:47,474-0500 INFO  Multiplexer No streams
+2013-10-31 20:11:51,221-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:11:57,482-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:12:07,489-0500 INFO  Multiplexer No streams
+2013-10-31 20:12:09,679-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:12:17,496-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:12:27,503-0500 INFO  Multiplexer No streams
+2013-10-31 20:12:30,890-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:12:37,511-0500 INFO  Multiplexer No streams
+2013-10-31 20:12:39,754-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:12:47,517-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:12:57,525-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:13:07,532-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:13:09,829-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:13:10,559-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:13:17,539-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:13:27,547-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:13:37,554-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:13:39,904-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:13:47,561-0500 INFO  Multiplexer No streams
+2013-10-31 20:13:50,228-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:13:57,568-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:14:07,576-0500 INFO  Multiplexer No streams
+2013-10-31 20:14:09,979-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:14:17,583-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:14:27,590-0500 INFO  Multiplexer No streams
+2013-10-31 20:14:29,897-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:14:37,597-0500 INFO  Multiplexer No streams
+2013-10-31 20:14:40,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:14:47,605-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:14:57,612-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:15:07,619-0500 INFO  Multiplexer No streams
+2013-10-31 20:15:09,566-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:15:10,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:15:17,626-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:15:27,634-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:15:37,641-0500 INFO  Multiplexer No streams
+2013-10-31 20:15:40,205-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:15:47,648-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:15:49,235-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:15:57,655-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:16:07,663-0500 INFO  Multiplexer No streams
+2013-10-31 20:16:10,280-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:16:17,670-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:16:27,677-0500 INFO  Multiplexer No streams
+2013-10-31 20:16:28,904-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:16:37,685-0500 INFO  Multiplexer No streams
+2013-10-31 20:16:40,354-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:16:47,692-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:16:57,705-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:17:07,712-0500 INFO  Multiplexer No streams
+2013-10-31 20:17:08,573-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:17:10,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:17:17,719-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:17:27,726-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:17:37,738-0500 INFO  Multiplexer No streams
+2013-10-31 20:17:40,505-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:17:47,746-0500 INFO  Multiplexer No streams
+2013-10-31 20:17:48,242-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:17:57,753-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:18:07,761-0500 INFO  Multiplexer No streams
+2013-10-31 20:18:10,579-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:18:17,768-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:18:27,775-0500 INFO  Multiplexer No streams
+2013-10-31 20:18:27,911-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:18:37,783-0500 INFO  Multiplexer No streams
 TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 15:10:40,081-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 20:18:40,656-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 20:18:47,790-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:18:57,798-0500 INFO  Multiplexer No streams
-2013-10-28 15:10:48,375-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:19:07,580-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:10:48,959-0500 INFO  Multiplexer No streams
+2013-10-31 20:19:07,805-0500 INFO  Multiplexer No streams
+2013-10-31 20:19:10,730-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:10:58,967-0500 INFO  Multiplexer No streams
+2013-10-31 20:19:17,812-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:11:08,974-0500 INFO  Multiplexer No streams
+2013-10-31 20:19:27,820-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:19:37,827-0500 INFO  Multiplexer No streams
-2013-10-28 15:11:11,038-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:19:40,805-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:19:47,249-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:11:18,982-0500 INFO  Multiplexer No streams
+2013-10-31 20:19:47,835-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:19:57,843-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:20:07,851-0500 INFO  Multiplexer No streams
+2013-10-31 20:20:10,880-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:20:17,858-0500 INFO  Multiplexer No streams
+2013-10-31 20:20:26,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:20:27,866-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:20:37,873-0500 INFO  Multiplexer No streams
+2013-10-31 20:20:40,955-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:20:47,880-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:20:57,888-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 20:21:06,588-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 20:21:07,896-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 20:21:11,031-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 20:21:17,904-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:21:27,913-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:21:37,921-0500 INFO  Multiplexer No streams
+2013-10-31 20:21:41,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 15:11:26,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:21:46,256-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:11:28,989-0500 INFO  Multiplexer No streams
+2013-10-31 20:21:47,929-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:11:38,997-0500 INFO  Multiplexer No streams
+2013-10-31 20:21:57,938-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:22:07,946-0500 INFO  Multiplexer No streams
-2013-10-28 15:11:41,996-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:22:11,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:11:49,006-0500 INFO  Multiplexer No streams
+2013-10-31 20:22:17,954-0500 INFO  Multiplexer No streams
+2013-10-31 20:22:25,925-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:11:59,014-0500 INFO  Multiplexer No streams
+2013-10-31 20:22:27,962-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:22:37,970-0500 INFO  Multiplexer No streams
+2013-10-31 20:22:41,255-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:22:47,978-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:22:57,986-0500 INFO  Multiplexer No streams
+2013-10-31 20:23:05,594-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:23:07,994-0500 INFO  Multiplexer No streams
+2013-10-31 20:23:11,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:23:18,002-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:23:28,009-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:23:38,017-0500 INFO  Multiplexer No streams
+2013-10-31 20:23:41,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:12:04,763-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:23:45,263-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:12:09,021-0500 INFO  Multiplexer No streams
+2013-10-31 20:23:48,025-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:23:58,033-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:24:08,041-0500 INFO  Multiplexer No streams
+2013-10-31 20:24:11,481-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:24:18,049-0500 INFO  Multiplexer No streams
+2013-10-31 20:24:24,932-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:24:28,056-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:24:38,068-0500 INFO  Multiplexer No streams
+2013-10-31 20:24:41,555-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:24:48,076-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:24:58,084-0500 INFO  Multiplexer No streams
+2013-10-31 20:25:04,601-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:25:08,092-0500 INFO  Multiplexer No streams
-2013-10-28 15:12:12,954-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:25:11,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:12:19,029-0500 INFO  Multiplexer No streams
+2013-10-31 20:25:18,100-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:12:29,036-0500 INFO  Multiplexer No streams
+2013-10-31 20:25:28,108-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:12:39,044-0500 INFO  Multiplexer No streams
+2013-10-31 20:25:38,116-0500 INFO  Multiplexer No streams
+2013-10-31 20:25:41,705-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:12:42,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:25:44,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:25:48,124-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:25:58,132-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:26:08,141-0500 INFO  Multiplexer No streams
+2013-10-31 20:26:11,781-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:26:18,149-0500 INFO  Multiplexer No streams
+2013-10-31 20:26:23,939-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:26:28,157-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:26:38,165-0500 INFO  Multiplexer No streams
-2013-10-28 15:12:43,912-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:26:41,855-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:12:49,052-0500 INFO  Multiplexer No streams
+2013-10-31 20:26:48,173-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:12:59,059-0500 INFO  Multiplexer No streams
+2013-10-31 20:26:58,182-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:03,608-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:13:09,067-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:08,190-0500 INFO  Multiplexer No streams
-2013-10-28 15:13:14,870-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:27:11,930-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:13:19,074-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:18,199-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:27:28,207-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:27:38,215-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:42,005-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:13:21,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:27:43,277-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:13:29,082-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:48,223-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:13:39,089-0500 INFO  Multiplexer No streams
+2013-10-31 20:27:58,231-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:28:08,239-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 20:28:12,079-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:28:18,247-0500 INFO  Multiplexer No streams
+2013-10-31 20:28:22,946-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:28:28,255-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:28:38,263-0500 INFO  Multiplexer No streams
-2013-10-28 15:13:45,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:28:42,155-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:13:49,097-0500 INFO  Multiplexer No streams
+2013-10-31 20:28:48,271-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:13:59,104-0500 INFO  Multiplexer No streams
+2013-10-31 20:28:58,279-0500 INFO  Multiplexer No streams
+2013-10-31 20:29:02,615-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:29:08,287-0500 INFO  Multiplexer No streams
+2013-10-31 20:29:12,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:29:18,295-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:29:28,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:29:38,311-0500 INFO  Multiplexer No streams
+2013-10-31 20:29:42,284-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:29:42,304-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:29:48,319-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:29:58,327-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:30:08,335-0500 INFO  Multiplexer No streams
+2013-10-31 20:30:12,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:30:18,343-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 20:30:21,953-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:30:28,351-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:30:38,359-0500 INFO  Multiplexer No streams
+2013-10-31 20:30:42,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:30:48,367-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:30:58,375-0500 INFO  Multiplexer No streams
-2013-10-28 15:13:59,345-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:31:01,623-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:14:09,112-0500 INFO  Multiplexer No streams
+2013-10-31 20:31:08,383-0500 INFO  Multiplexer No streams
+2013-10-31 20:31:12,529-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:31:18,391-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:31:28,399-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:31:38,407-0500 INFO  Multiplexer No streams
+2013-10-31 20:31:41,292-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:14:16,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:31:42,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:14:19,119-0500 INFO  Multiplexer No streams
+2013-10-31 20:31:48,415-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:14:29,127-0500 INFO  Multiplexer No streams
+2013-10-31 20:31:58,423-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:32:08,430-0500 INFO  Multiplexer No streams
+2013-10-31 20:32:12,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:32:18,438-0500 INFO  Multiplexer No streams
+2013-10-31 20:32:20,961-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:32:28,446-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:32:38,454-0500 INFO  Multiplexer No streams
+2013-10-31 20:32:42,755-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:32:48,462-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:32:58,470-0500 INFO  Multiplexer No streams
+2013-10-31 20:33:00,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:33:08,478-0500 INFO  Multiplexer No streams
+2013-10-31 20:33:12,830-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:33:18,486-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:33:28,494-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:33:38,502-0500 INFO  Multiplexer No streams
+2013-10-31 20:33:40,299-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:33:42,905-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:33:48,510-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:33:58,517-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:34:08,525-0500 INFO  Multiplexer No streams
+2013-10-31 20:34:12,980-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:34:18,532-0500 INFO  Multiplexer No streams
+2013-10-31 20:34:19,967-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:34:28,540-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:34:38,548-0500 INFO  Multiplexer No streams
+2013-10-31 20:34:43,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:34:48,556-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:34:58,563-0500 INFO  Multiplexer No streams
-2013-10-28 15:14:37,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:34:59,637-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:14:39,134-0500 INFO  Multiplexer No streams
+2013-10-31 20:35:08,571-0500 INFO  Multiplexer No streams
-2013-10-28 15:14:47,744-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:35:13,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:14:49,142-0500 INFO  Multiplexer No streams
+2013-10-31 20:35:18,578-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:14:59,149-0500 INFO  Multiplexer No streams
+2013-10-31 20:35:28,586-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:15:09,157-0500 INFO  Multiplexer No streams
+2013-10-31 20:35:38,594-0500 INFO  Multiplexer No streams
-2013-10-28 15:15:15,733-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:35:39,306-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:35:43,205-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:35:48,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:35:58,609-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:36:08,616-0500 INFO  Multiplexer No streams
+2013-10-31 20:36:13,280-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:36:18,624-0500 INFO  Multiplexer No streams
+2013-10-31 20:36:18,975-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:36:28,631-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:36:38,639-0500 INFO  Multiplexer No streams
+2013-10-31 20:36:43,355-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:36:48,646-0500 INFO  Multiplexer No streams
+2013-10-31 20:36:58,644-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:36:58,654-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:37:08,662-0500 INFO  Multiplexer No streams
-2013-10-28 15:15:18,702-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:37:13,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:15:19,164-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:18,669-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:15:29,172-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:28,677-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:38,313-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:15:39,179-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:38,684-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:43,505-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:15:49,187-0500 INFO  Multiplexer No streams
+2013-10-31 20:37:48,692-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:37:58,699-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:38:08,707-0500 INFO  Multiplexer No streams
+2013-10-31 20:38:13,581-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:38:17,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:38:18,715-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:38:28,722-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:38:38,730-0500 INFO  Multiplexer No streams
+2013-10-31 20:38:43,656-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:38:48,737-0500 INFO  Multiplexer No streams
+2013-10-31 20:38:57,651-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:38:58,745-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:39:08,752-0500 INFO  Multiplexer No streams
+2013-10-31 20:39:13,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:39:18,760-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:39:28,768-0500 INFO  Multiplexer No streams
+2013-10-31 20:39:37,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:39:38,775-0500 INFO  Multiplexer No streams
+2013-10-31 20:39:43,806-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:39:48,783-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:39:58,790-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:40:08,798-0500 INFO  Multiplexer No streams
+2013-10-31 20:40:13,881-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:40:16,988-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:40:18,806-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:40:28,813-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:40:38,821-0500 INFO  Multiplexer No streams
-2013-10-28 15:15:49,660-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 20:40:43,955-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:40:48,829-0500 INFO  Multiplexer No streams
-2013-10-28 15:15:53,927-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:40:56,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:15:59,194-0500 INFO  Multiplexer No streams
+2013-10-31 20:40:58,836-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:16:09,202-0500 INFO  Multiplexer No streams
+2013-10-31 20:41:08,844-0500 INFO  Multiplexer No streams
+2013-10-31 20:41:14,031-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:16:19,209-0500 INFO  Multiplexer No streams
+2013-10-31 20:41:18,851-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:41:28,859-0500 INFO  Multiplexer No streams
+2013-10-31 20:41:36,327-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:41:38,867-0500 INFO  Multiplexer No streams
+2013-10-31 20:41:44,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:41:48,874-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:41:58,882-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:42:08,890-0500 INFO  Multiplexer No streams
-2013-10-28 15:16:20,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:42:14,181-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:42:15,996-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:16:29,217-0500 INFO  Multiplexer No streams
+2013-10-31 20:42:18,897-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:42:28,905-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:42:38,913-0500 INFO  Multiplexer No streams
+2013-10-31 20:42:44,256-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:42:48,920-0500 INFO  Multiplexer No streams
+2013-10-31 20:42:55,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:42:58,928-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:43:08,936-0500 INFO  Multiplexer No streams
+2013-10-31 20:43:14,331-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:43:18,943-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:43:28,951-0500 INFO  Multiplexer No streams
+2013-10-31 20:43:35,334-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:43:38,958-0500 INFO  Multiplexer No streams
+2013-10-31 20:43:44,406-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:43:48,966-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:43:58,974-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:44:08,981-0500 INFO  Multiplexer No streams
+2013-10-31 20:44:14,481-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:44:15,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:44:18,989-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:44:28,997-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:44:39,004-0500 INFO  Multiplexer No streams
+2013-10-31 20:44:44,556-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:44:49,012-0500 INFO  Multiplexer No streams
-2013-10-28 15:16:32,121-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:44:54,673-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:16:39,224-0500 INFO  Multiplexer No streams
+2013-10-31 20:44:59,020-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:16:49,232-0500 INFO  Multiplexer No streams
+2013-10-31 20:45:09,028-0500 INFO  Multiplexer No streams
+2013-10-31 20:45:14,631-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:45:19,036-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:45:29,044-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 4ms
+2013-10-31 20:45:34,345-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 4ms
+No streams
+2013-10-31 20:45:39,051-0500 INFO  Multiplexer No streams
+2013-10-31 20:45:44,705-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:45:49,059-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:45:59,067-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:46:09,075-0500 INFO  Multiplexer No streams
+2013-10-31 20:46:14,011-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:46:14,781-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:46:19,083-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:46:29,091-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:46:39,098-0500 INFO  Multiplexer No streams
-2013-10-28 15:16:51,578-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:46:44,856-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:16:59,239-0500 INFO  Multiplexer No streams
+2013-10-31 20:46:49,106-0500 INFO  Multiplexer No streams
+2013-10-31 20:46:53,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:17:09,247-0500 INFO  Multiplexer No streams
+2013-10-31 20:46:59,113-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:47:09,121-0500 INFO  Multiplexer No streams
+2013-10-31 20:47:14,930-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:47:19,129-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:47:29,136-0500 INFO  Multiplexer No streams
+2013-10-31 20:47:33,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:47:39,144-0500 INFO  Multiplexer No streams
+2013-10-31 20:47:45,006-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:47:49,152-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:47:59,160-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:48:09,167-0500 INFO  Multiplexer No streams
+2013-10-31 20:48:13,018-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:48:15,081-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:48:19,175-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:48:29,183-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:48:39,191-0500 INFO  Multiplexer No streams
+2013-10-31 20:48:45,155-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:48:49,199-0500 INFO  Multiplexer No streams
+2013-10-31 20:48:52,687-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:48:59,207-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:49:09,215-0500 INFO  Multiplexer No streams
+2013-10-31 20:49:15,232-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 20:49:19,223-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:49:29,231-0500 INFO  Multiplexer No streams
+2013-10-31 20:49:32,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:49:39,239-0500 INFO  Multiplexer No streams
+2013-10-31 20:49:45,306-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:49:49,247-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:49:59,255-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:50:09,263-0500 INFO  Multiplexer No streams
+2013-10-31 20:50:12,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:50:15,381-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:50:19,271-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:50:29,279-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:50:39,287-0500 INFO  Multiplexer No streams
+2013-10-31 20:50:45,456-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:50:49,295-0500 INFO  Multiplexer No streams
+2013-10-31 20:50:51,694-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:50:59,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:51:09,310-0500 INFO  Multiplexer No streams
+2013-10-31 20:51:15,531-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:51:19,318-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:51:29,326-0500 INFO  Multiplexer No streams
+2013-10-31 20:51:31,363-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:51:39,334-0500 INFO  Multiplexer No streams
+2013-10-31 20:51:45,606-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:51:49,342-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:51:59,350-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:52:09,358-0500 INFO  Multiplexer No streams
+2013-10-31 20:52:11,032-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:52:15,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 20:52:19,366-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:52:29,374-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:52:39,381-0500 INFO  Multiplexer No streams
+2013-10-31 20:52:45,756-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:52:49,389-0500 INFO  Multiplexer No streams
-2013-10-28 15:17:10,315-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:52:50,701-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:17:19,254-0500 INFO  Multiplexer No streams
+2013-10-31 20:52:59,397-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:53:09,406-0500 INFO  Multiplexer No streams
-2013-10-28 15:17:22,536-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:53:15,831-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:17:29,262-0500 INFO  Multiplexer No streams
+2013-10-31 20:53:19,414-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:17:39,269-0500 INFO  Multiplexer No streams
+2013-10-31 20:53:29,422-0500 INFO  Multiplexer No streams
-2013-10-28 15:17:48,509-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:53:30,370-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:17:49,277-0500 INFO  Multiplexer No streams
+2013-10-31 20:53:39,430-0500 INFO  Multiplexer No streams
-2013-10-28 15:17:53,494-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:53:45,906-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:17:59,284-0500 INFO  Multiplexer No streams
+2013-10-31 20:53:49,438-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:18:09,291-0500 INFO  Multiplexer No streams
+2013-10-31 20:53:59,446-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:18:19,299-0500 INFO  Multiplexer No streams
+2013-10-31 20:54:09,454-0500 INFO  Multiplexer No streams
+2013-10-31 20:54:10,039-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:18:24,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:54:15,981-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:54:19,462-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:54:29,469-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:54:39,477-0500 INFO  Multiplexer No streams
+2013-10-31 20:54:46,056-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:54:49,485-0500 INFO  Multiplexer No streams
-2013-10-28 15:18:26,703-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:54:49,708-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:18:29,306-0500 INFO  Multiplexer No streams
+2013-10-31 20:54:59,492-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:18:39,314-0500 INFO  Multiplexer No streams
+2013-10-31 20:55:09,500-0500 INFO  Multiplexer No streams
+2013-10-31 20:55:16,131-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:18:49,321-0500 INFO  Multiplexer No streams
+2013-10-31 20:55:19,507-0500 INFO  Multiplexer No streams
+2013-10-31 20:55:29,377-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:55:29,515-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:55:39,522-0500 INFO  Multiplexer No streams
-2013-10-28 15:18:55,410-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:55:46,206-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:18:59,329-0500 INFO  Multiplexer No streams
+2013-10-31 20:55:49,530-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:55:59,538-0500 INFO  Multiplexer No streams
-2013-10-28 15:19:04,897-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:56:09,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:19:09,336-0500 INFO  Multiplexer No streams
+2013-10-31 20:56:09,546-0500 INFO  Multiplexer No streams
+2013-10-31 20:56:16,281-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:19:19,344-0500 INFO  Multiplexer No streams
+2013-10-31 20:56:19,554-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:56:29,561-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:56:39,569-0500 INFO  Multiplexer No streams
+2013-10-31 20:56:46,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 20:56:48,715-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:56:49,577-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:56:59,585-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:57:09,593-0500 INFO  Multiplexer No streams
-2013-10-28 15:19:26,368-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:57:16,431-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:19:29,351-0500 INFO  Multiplexer No streams
+2013-10-31 20:57:19,601-0500 INFO  Multiplexer No streams
+2013-10-31 20:57:28,384-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:19:39,359-0500 INFO  Multiplexer No streams
+2013-10-31 20:57:29,608-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:57:39,616-0500 INFO  Multiplexer No streams
+2013-10-31 20:57:46,506-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:57:49,624-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:57:59,632-0500 INFO  Multiplexer No streams
+2013-10-31 20:58:08,053-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:58:09,640-0500 INFO  Multiplexer No streams
+2013-10-31 20:58:16,581-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:58:19,647-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:58:29,655-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:58:39,663-0500 INFO  Multiplexer No streams
+2013-10-31 20:58:46,656-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:58:47,722-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:58:49,671-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:58:59,678-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:59:09,686-0500 INFO  Multiplexer No streams
+2013-10-31 20:59:16,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 20:59:19,694-0500 INFO  Multiplexer No streams
-2013-10-28 15:19:43,091-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 20:59:27,391-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:19:49,366-0500 INFO  Multiplexer No streams
+2013-10-31 20:59:29,702-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:59:39,709-0500 INFO  Multiplexer No streams
+2013-10-31 20:59:46,806-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 20:59:49,717-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 20:59:59,725-0500 INFO  Multiplexer No streams
+2013-10-31 21:00:07,060-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:00:09,733-0500 INFO  Multiplexer No streams
+2013-10-31 21:00:16,881-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:00:19,740-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:00:29,748-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:00:39,756-0500 INFO  Multiplexer No streams
+2013-10-31 21:00:46,729-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:19:57,326-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:00:46,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:19:59,374-0500 INFO  Multiplexer No streams
+2013-10-31 21:00:49,764-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:20:09,381-0500 INFO  Multiplexer No streams
+2013-10-31 21:00:59,772-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:20:19,389-0500 INFO  Multiplexer No streams
+2013-10-31 21:01:09,779-0500 INFO  Multiplexer No streams
+2013-10-31 21:01:17,032-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:01:19,787-0500 INFO  Multiplexer No streams
+2013-10-31 21:01:26,398-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:01:29,795-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:01:39,803-0500 INFO  Multiplexer No streams
+2013-10-31 21:01:47,107-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:01:49,811-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:01:59,819-0500 INFO  Multiplexer No streams
+2013-10-31 21:02:06,067-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:02:09,827-0500 INFO  Multiplexer No streams
+2013-10-31 21:02:17,183-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:02:19,835-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:02:29,843-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:02:39,851-0500 INFO  Multiplexer No streams
+2013-10-31 21:02:45,736-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:02:47,258-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:02:49,859-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:02:59,867-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:03:09,874-0500 INFO  Multiplexer No streams
+2013-10-31 21:03:17,332-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:03:19,882-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:03:25,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:03:29,890-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:03:39,898-0500 INFO  Multiplexer No streams
+2013-10-31 21:03:47,408-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:03:49,906-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:03:59,914-0500 INFO  Multiplexer No streams
-2013-10-28 15:20:21,285-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:04:05,074-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:04:09,922-0500 INFO  Multiplexer No streams
+2013-10-31 21:04:17,483-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:04:19,930-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:04:29,938-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:04:39,946-0500 INFO  Multiplexer No streams
+2013-10-31 21:04:44,743-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:04:47,557-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:04:49,954-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:04:59,962-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:05:09,970-0500 INFO  Multiplexer No streams
-2013-10-28 15:20:28,284-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:05:17,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:20:29,397-0500 INFO  Multiplexer No streams
+2013-10-31 21:05:19,978-0500 INFO  Multiplexer No streams
+2013-10-31 21:05:24,412-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:20:39,404-0500 INFO  Multiplexer No streams
+2013-10-31 21:05:29,985-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:20:49,412-0500 INFO  Multiplexer No streams
+2013-10-31 21:05:39,993-0500 INFO  Multiplexer No streams
-2013-10-28 15:20:59,242-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:05:47,708-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:20:59,419-0500 INFO  Multiplexer No streams
+2013-10-31 21:05:50,001-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:06:00,009-0500 INFO  Multiplexer No streams
-2013-10-28 15:20:59,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:06:04,081-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:21:09,427-0500 INFO  Multiplexer No streams
+2013-10-31 21:06:10,016-0500 INFO  Multiplexer No streams
+2013-10-31 21:06:17,783-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:21:19,435-0500 INFO  Multiplexer No streams
+2013-10-31 21:06:20,024-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:21:29,447-0500 INFO  Multiplexer No streams
+2013-10-31 21:06:30,032-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:06:40,040-0500 INFO  Multiplexer No streams
+2013-10-31 21:06:43,750-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:06:47,857-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:06:50,047-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:07:00,055-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:07:10,063-0500 INFO  Multiplexer No streams
-2013-10-28 15:21:30,200-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 15:21:37,674-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 21:07:17,933-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:21:39,457-0500 INFO  Multiplexer No streams
+2013-10-31 21:07:20,071-0500 INFO  Multiplexer No streams
+2013-10-31 21:07:23,419-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:21:49,473-0500 INFO  Multiplexer No streams
+2013-10-31 21:07:30,078-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:21:59,485-0500 INFO  Multiplexer No streams
+2013-10-31 21:07:40,086-0500 INFO  Multiplexer No streams
-2013-10-28 15:22:01,158-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:07:48,008-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:22:09,499-0500 INFO  Multiplexer No streams
+2013-10-31 21:07:50,094-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:08:00,102-0500 INFO  Multiplexer No streams
+2013-10-31 21:08:03,088-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:08:10,109-0500 INFO  Multiplexer No streams
+2013-10-31 21:08:18,082-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:08:20,117-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:08:30,125-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:08:40,133-0500 INFO  Multiplexer No streams
+2013-10-31 21:08:42,757-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:08:48,158-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:08:50,140-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:09:00,148-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:09:10,156-0500 INFO  Multiplexer No streams
+2013-10-31 21:09:18,233-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:09:20,164-0500 INFO  Multiplexer No streams
+2013-10-31 21:09:22,426-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:09:30,171-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:09:40,179-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:09:48,308-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:09:50,187-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:10:00,195-0500 INFO  Multiplexer No streams
+2013-10-31 21:10:02,095-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:10:10,202-0500 INFO  Multiplexer No streams
+2013-10-31 21:10:18,382-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:10:20,210-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:10:30,218-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:10:40,226-0500 INFO  Multiplexer No streams
+2013-10-31 21:10:41,764-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 21:10:48,458-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:10:50,233-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:11:00,241-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:11:10,249-0500 INFO  Multiplexer No streams
+2013-10-31 21:11:18,534-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:11:20,257-0500 INFO  Multiplexer No streams
+2013-10-31 21:11:21,434-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:11:30,264-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:11:40,272-0500 INFO  Multiplexer No streams
+2013-10-31 21:11:48,609-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:11:50,280-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:12:00,287-0500 INFO  Multiplexer No streams
-2013-10-28 15:22:15,867-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:12:01,104-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:22:19,509-0500 INFO  Multiplexer No streams
+2013-10-31 21:12:10,295-0500 INFO  Multiplexer No streams
+2013-10-31 21:12:18,683-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:22:29,520-0500 INFO  Multiplexer No streams
+2013-10-31 21:12:20,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:12:30,311-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:12:40,319-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:12:40,773-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:22:32,116-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:12:48,759-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:22:39,529-0500 INFO  Multiplexer No streams
+2013-10-31 21:12:50,326-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:22:49,538-0500 INFO  Multiplexer No streams
+2013-10-31 21:13:00,334-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:13:10,342-0500 INFO  Multiplexer No streams
+2013-10-31 21:13:18,834-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:13:20,350-0500 INFO  Multiplexer No streams
-2013-10-28 15:22:54,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:13:20,442-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:22:59,548-0500 INFO  Multiplexer No streams
+2013-10-31 21:13:30,358-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:13:40,365-0500 INFO  Multiplexer No streams
+2013-10-31 21:13:48,908-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:13:50,373-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:00,111-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:14:00,381-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:14:10,389-0500 INFO  Multiplexer No streams
-2013-10-28 15:23:03,074-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:14:18,984-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:23:09,557-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:20,397-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:23:19,565-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:30,405-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:39,780-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:23:29,573-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:40,412-0500 INFO  Multiplexer No streams
+2013-10-31 21:14:49,059-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:14:50,420-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:15:00,428-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:15:10,436-0500 INFO  Multiplexer No streams
+2013-10-31 21:15:19,134-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:15:19,449-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:15:20,443-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:15:30,451-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:15:40,459-0500 INFO  Multiplexer No streams
+2013-10-31 21:15:49,209-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:15:50,467-0500 INFO  Multiplexer No streams
+2013-10-31 21:15:59,118-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:16:00,475-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:16:10,482-0500 INFO  Multiplexer No streams
+2013-10-31 21:16:19,284-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:16:20,490-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:16:30,498-0500 INFO  Multiplexer No streams
+2013-10-31 21:16:38,787-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:16:40,506-0500 INFO  Multiplexer No streams
+2013-10-31 21:16:49,359-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:16:50,513-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:17:00,521-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:17:10,529-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 21:17:18,457-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 21:17:19,434-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:17:20,537-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:17:30,544-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:17:40,552-0500 INFO  Multiplexer No streams
+2013-10-31 21:17:49,509-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:17:50,560-0500 INFO  Multiplexer No streams
-2013-10-28 15:23:32,256-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:17:58,125-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:18:00,568-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:18:10,576-0500 INFO  Multiplexer No streams
-2013-10-28 15:23:34,032-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:18:19,584-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:23:39,583-0500 INFO  Multiplexer No streams
+2013-10-31 21:18:20,583-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:23:49,592-0500 INFO  Multiplexer No streams
+2013-10-31 21:18:30,591-0500 INFO  Multiplexer No streams
+2013-10-31 21:18:37,794-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:23:59,604-0500 INFO  Multiplexer No streams
+2013-10-31 21:18:40,599-0500 INFO  Multiplexer No streams
+2013-10-31 21:18:49,659-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:18:50,607-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:19:00,615-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:19:10,623-0500 INFO  Multiplexer No streams
+2013-10-31 21:19:17,463-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:24:04,990-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:19:19,734-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:24:09,612-0500 INFO  Multiplexer No streams
+2013-10-31 21:19:20,631-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:19:30,638-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:19:40,646-0500 INFO  Multiplexer No streams
+2013-10-31 21:19:49,809-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:19:50,654-0500 INFO  Multiplexer No streams
-2013-10-28 15:24:10,449-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:19:57,132-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:24:19,620-0500 INFO  Multiplexer No streams
+2013-10-31 21:20:00,661-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:24:29,628-0500 INFO  Multiplexer No streams
+2013-10-31 21:20:10,669-0500 INFO  Multiplexer No streams
-2013-10-28 15:24:35,949-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:20:19,884-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:24:39,641-0500 INFO  Multiplexer No streams
+2013-10-31 21:20:20,677-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:20:30,685-0500 INFO  Multiplexer No streams
+2013-10-31 21:20:36,801-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:20:40,692-0500 INFO  Multiplexer No streams
+2013-10-31 21:20:49,959-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:20:50,700-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:21:00,708-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:21:10,716-0500 INFO  Multiplexer No streams
+2013-10-31 21:21:16,470-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:21:20,034-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:21:20,723-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:21:30,731-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:21:40,739-0500 INFO  Multiplexer No streams
+2013-10-31 21:21:50,109-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:21:50,747-0500 INFO  Multiplexer No streams
+2013-10-31 21:21:56,139-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:22:00,754-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:22:10,762-0500 INFO  Multiplexer No streams
+2013-10-31 21:22:20,184-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:22:20,770-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:22:30,778-0500 INFO  Multiplexer No streams
-2013-10-28 15:24:48,643-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:22:35,808-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:24:49,654-0500 INFO  Multiplexer No streams
+2013-10-31 21:22:40,785-0500 INFO  Multiplexer No streams
+2013-10-31 21:22:50,260-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:24:59,666-0500 INFO  Multiplexer No streams
+2013-10-31 21:22:50,793-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:23:00,801-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:23:10,809-0500 INFO  Multiplexer No streams
+2013-10-31 21:23:15,477-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:25:06,906-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:23:20,335-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:25:09,676-0500 INFO  Multiplexer No streams
+2013-10-31 21:23:20,816-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:25:19,686-0500 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-10-28 15:25:26,838-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:23:30,824-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:25:29,695-0500 INFO  Multiplexer No streams
+2013-10-31 21:23:40,832-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 21:23:50,409-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:23:50,840-0500 INFO  Multiplexer No streams
+2013-10-31 21:23:55,146-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:24:00,847-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:24:10,855-0500 INFO  Multiplexer No streams
-2013-10-28 15:25:37,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:24:20,485-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:25:39,706-0500 INFO  Multiplexer No streams
+2013-10-31 21:24:20,863-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:25:49,717-0500 INFO  Multiplexer No streams
+2013-10-31 21:24:30,871-0500 INFO  Multiplexer No streams
+2013-10-31 21:24:34,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:25:59,725-0500 INFO  Multiplexer No streams
+2013-10-31 21:24:40,878-0500 INFO  Multiplexer No streams
+2013-10-31 21:24:50,560-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:24:50,886-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:25:00,894-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:25:10,902-0500 INFO  Multiplexer No streams
+2013-10-31 21:25:14,484-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:25:20,635-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:25:20,910-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:25:30,918-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:25:40,926-0500 INFO  Multiplexer No streams
+2013-10-31 21:25:50,710-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:25:50,933-0500 INFO  Multiplexer No streams
+2013-10-31 21:25:54,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:26:00,941-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:26:10,949-0500 INFO  Multiplexer No streams
+2013-10-31 21:26:20,785-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:26:20,957-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:26:30,965-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 21:26:33,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:26:40,973-0500 INFO  Multiplexer No streams
+2013-10-31 21:26:50,859-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:26:50,981-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:27:00,989-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:27:10,997-0500 INFO  Multiplexer No streams
-2013-10-28 15:26:05,031-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:27:13,492-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:26:08,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:27:20,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:26:09,735-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:21,005-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:26:19,742-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:31,013-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:26:29,754-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:41,021-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:51,010-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:26:39,764-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:51,029-0500 INFO  Multiplexer No streams
+2013-10-31 21:27:53,161-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:28:01,037-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:28:11,045-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:28:21,053-0500 INFO  Multiplexer No streams
-2013-10-28 15:26:39,780-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:28:21,085-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:28:31,061-0500 INFO  Multiplexer No streams
+2013-10-31 21:28:32,830-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:28:41,069-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:28:51,077-0500 INFO  Multiplexer No streams
+2013-10-31 21:28:51,160-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:29:01,084-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:29:11,092-0500 INFO  Multiplexer No streams
+2013-10-31 21:29:12,499-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:29:21,100-0500 INFO  Multiplexer No streams
+2013-10-31 21:29:21,234-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:29:31,108-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:29:41,116-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:29:51,124-0500 INFO  Multiplexer No streams
+2013-10-31 21:29:51,310-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:29:52,168-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:30:01,132-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:30:11,140-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:30:21,148-0500 INFO  Multiplexer No streams
+2013-10-31 21:30:21,385-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:30:31,155-0500 INFO  Multiplexer No streams
-2013-10-28 15:26:43,225-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:30:31,838-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:26:49,772-0500 INFO  Multiplexer No streams
+2013-10-31 21:30:41,163-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:26:59,783-0500 INFO  Multiplexer No streams
+2013-10-31 21:30:51,171-0500 INFO  Multiplexer No streams
+2013-10-31 21:30:51,460-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:27:09,791-0500 INFO  Multiplexer No streams
+2013-10-31 21:31:01,179-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:31:11,186-0500 INFO  Multiplexer No streams
+2013-10-31 21:31:11,507-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:31:21,194-0500 INFO  Multiplexer No streams
+2013-10-31 21:31:21,535-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:31:31,202-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:31:41,209-0500 INFO  Multiplexer No streams
+2013-10-31 21:31:51,176-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:31:51,217-0500 INFO  Multiplexer No streams
-2013-10-28 15:27:10,738-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:31:51,610-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:27:19,799-0500 INFO  Multiplexer No streams
+2013-10-31 21:32:01,225-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:32:11,233-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:32:21,240-0500 INFO  Multiplexer No streams
+2013-10-31 21:32:21,685-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:27:21,419-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:32:30,845-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:27:29,807-0500 INFO  Multiplexer No streams
+2013-10-31 21:32:31,248-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:27:39,815-0500 INFO  Multiplexer No streams
+2013-10-31 21:32:41,256-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:32:51,263-0500 INFO  Multiplexer No streams
+2013-10-31 21:32:51,761-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:33:01,271-0500 INFO  Multiplexer No streams
+2013-10-31 21:33:10,514-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:33:11,279-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:33:21,286-0500 INFO  Multiplexer No streams
-2013-10-28 15:27:41,696-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:33:21,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:27:49,824-0500 INFO  Multiplexer No streams
+2013-10-31 21:33:31,294-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:33:41,302-0500 INFO  Multiplexer No streams
+2013-10-31 21:33:50,183-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:33:51,309-0500 INFO  Multiplexer No streams
+2013-10-31 21:33:51,910-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:34:01,317-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:34:11,325-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:34:21,333-0500 INFO  Multiplexer No streams
+2013-10-31 21:34:21,985-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 21:34:29,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:34:31,341-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:34:41,348-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:34:51,356-0500 INFO  Multiplexer No streams
+2013-10-31 21:34:52,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:35:01,364-0500 INFO  Multiplexer No streams
-2013-10-28 15:27:59,613-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:35:09,522-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:27:59,832-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:11,372-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:28:09,840-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:21,380-0500 INFO  Multiplexer No streams
-2013-10-28 15:28:12,654-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:35:22,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:28:19,849-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:31,387-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:28:29,857-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:41,395-0500 INFO  Multiplexer No streams
-2013-10-28 15:28:37,807-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:35:49,191-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:28:39,865-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:51,403-0500 INFO  Multiplexer No streams
+2013-10-31 21:35:52,211-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:36:01,410-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:36:11,418-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:36:21,426-0500 INFO  Multiplexer No streams
-2013-10-28 15:28:43,612-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:36:22,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:36:28,860-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:28:49,874-0500 INFO  Multiplexer No streams
+2013-10-31 21:36:31,434-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:28:59,882-0500 INFO  Multiplexer No streams
+2013-10-31 21:36:41,442-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:29:09,890-0500 INFO  Multiplexer No streams
+2013-10-31 21:36:51,449-0500 INFO  Multiplexer No streams
-2013-10-28 15:29:14,570-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:29:16,002-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:36:52,362-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:29:19,899-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:01,457-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:08,529-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:29:29,910-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:11,465-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:29:39,918-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:21,472-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:22,437-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:37:31,480-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:37:41,488-0500 INFO  Multiplexer No streams
+2013-10-31 21:37:48,198-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:37:51,496-0500 INFO  Multiplexer No streams
-2013-10-28 15:29:45,528-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:37:52,513-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:29:49,927-0500 INFO  Multiplexer No streams
+2013-10-31 21:38:01,504-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:38:11,511-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:38:21,519-0500 INFO  Multiplexer No streams
+2013-10-31 21:38:22,588-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:38:27,867-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:38:31,527-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:38:41,535-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:38:51,543-0500 INFO  Multiplexer No streams
+2013-10-31 21:38:52,663-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:39:01,550-0500 INFO  Multiplexer No streams
-2013-10-28 15:29:54,196-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:39:07,537-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:29:59,935-0500 INFO  Multiplexer No streams
+2013-10-31 21:39:11,558-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:30:09,946-0500 INFO  Multiplexer No streams
+2013-10-31 21:39:21,565-0500 INFO  Multiplexer No streams
-2013-10-28 15:30:16,486-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:39:22,738-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:30:19,956-0500 INFO  Multiplexer No streams
+2013-10-31 21:39:31,573-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:30:29,969-0500 INFO  Multiplexer No streams
-2013-10-28 15:30:32,391-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:39:41,580-0500 INFO  Multiplexer No streams
+2013-10-31 21:39:47,206-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:30:39,972-0500 INFO  Multiplexer No streams
+2013-10-31 21:39:51,587-0500 INFO  Multiplexer No streams
-2013-10-28 15:30:47,444-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:39:52,813-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:30:49,983-0500 INFO  Multiplexer No streams
+2013-10-31 21:40:01,594-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:30:59,989-0500 INFO  Multiplexer No streams
+2013-10-31 21:40:11,602-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:31:10,002-0500 INFO  Multiplexer No streams
+2013-10-31 21:40:21,609-0500 INFO  Multiplexer No streams
+2013-10-31 21:40:22,888-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-10-28 15:31:10,584-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:40:26,875-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:40:31,617-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:40:41,625-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:40:51,633-0500 INFO  Multiplexer No streams
-2013-10-28 15:31:18,402-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:40:52,964-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:31:20,012-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:01,640-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:06,544-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:31:30,025-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:11,648-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:31:40,035-0500 INFO  Multiplexer No streams
-2013-10-28 15:31:48,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:41:21,656-0500 INFO  Multiplexer No streams
-2013-10-28 15:31:49,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:41:23,039-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:31:50,045-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:31,664-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:32:00,054-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:41,672-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:46,213-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:32:10,064-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:51,679-0500 INFO  Multiplexer No streams
+2013-10-31 21:41:53,114-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:32:20,076-0500 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
-2013-10-28 15:32:20,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 21:42:01,687-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:42:11,695-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:42:21,703-0500 INFO  Multiplexer No streams
+2013-10-31 21:42:23,189-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:42:25,881-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:42:31,711-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:42:41,718-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:42:51,726-0500 INFO  Multiplexer No streams
+2013-10-31 21:42:53,264-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:43:01,734-0500 INFO  Multiplexer No streams
-2013-10-28 15:32:26,972-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:43:05,551-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:32:30,089-0500 INFO  Multiplexer No streams
+2013-10-31 21:43:11,742-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:32:40,100-0500 INFO  Multiplexer No streams
+2013-10-31 21:43:21,750-0500 INFO  Multiplexer No streams
+2013-10-31 21:43:23,339-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:32:50,113-0500 INFO  Multiplexer No streams
+2013-10-31 21:43:31,757-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:43:41,765-0500 INFO  Multiplexer No streams
+2013-10-31 21:43:45,220-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:43:51,773-0500 INFO  Multiplexer No streams
-2013-10-28 15:32:51,277-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:43:53,414-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:33:00,123-0500 INFO  Multiplexer No streams
-2013-10-28 15:33:05,167-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:44:01,781-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:33:10,132-0500 INFO  Multiplexer No streams
+2013-10-31 21:44:11,789-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:33:20,140-0500 INFO  Multiplexer No streams
+2013-10-31 21:44:21,797-0500 INFO  Multiplexer No streams
-2013-10-28 15:33:22,235-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:44:23,489-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:44:24,889-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:33:30,148-0500 INFO  Multiplexer No streams
+2013-10-31 21:44:31,805-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:33:40,156-0500 INFO  Multiplexer No streams
+2013-10-31 21:44:41,812-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:44:51,820-0500 INFO  Multiplexer No streams
+2013-10-31 21:44:53,564-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:45:01,828-0500 INFO  Multiplexer No streams
-2013-10-28 15:33:43,360-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:45:04,558-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:33:50,165-0500 INFO  Multiplexer No streams
+2013-10-31 21:45:11,836-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:45:21,844-0500 INFO  Multiplexer No streams
-2013-10-28 15:33:53,194-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:45:23,639-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:34:00,177-0500 INFO  Multiplexer No streams
+2013-10-31 21:45:31,851-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:34:10,191-0500 INFO  Multiplexer No streams
+2013-10-31 21:45:41,859-0500 INFO  Multiplexer No streams
+2013-10-31 21:45:44,227-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:34:20,206-0500 INFO  Multiplexer No streams
-2013-10-28 15:34:21,555-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:45:51,867-0500 INFO  Multiplexer No streams
-2013-10-28 15:34:24,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:45:53,714-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:34:30,215-0500 INFO  Multiplexer No streams
+2013-10-31 21:46:01,875-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:34:40,228-0500 INFO  Multiplexer No streams
+2013-10-31 21:46:11,883-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:34:50,236-0500 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
-2013-10-28 15:34:55,110-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 21:46:21,891-0500 INFO  Multiplexer No streams
+2013-10-31 21:46:23,788-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 21:46:23,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:46:31,899-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:46:41,908-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:46:51,915-0500 INFO  Multiplexer No streams
+2013-10-31 21:46:53,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:47:01,924-0500 INFO  Multiplexer No streams
+2013-10-31 21:47:03,564-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:47:11,932-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:47:21,940-0500 INFO  Multiplexer No streams
+2013-10-31 21:47:23,939-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:47:31,948-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:47:41,956-0500 INFO  Multiplexer No streams
-2013-10-28 15:34:59,748-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:47:43,235-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:35:00,243-0500 INFO  Multiplexer No streams
+2013-10-31 21:47:51,964-0500 INFO  Multiplexer No streams
+2013-10-31 21:47:54,014-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:35:10,252-0500 INFO  Multiplexer No streams
+2013-10-31 21:48:01,972-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:35:20,261-0500 INFO  Multiplexer No streams
+2013-10-31 21:48:11,980-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:48:21,987-0500 INFO  Multiplexer No streams
+2013-10-31 21:48:22,903-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:48:24,088-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:48:31,995-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:48:42,003-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:48:52,011-0500 INFO  Multiplexer No streams
-2013-10-28 15:35:26,067-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:48:54,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:35:30,268-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:02,019-0500 INFO  Multiplexer No streams
-2013-10-28 15:35:37,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:49:02,572-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:35:40,278-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:12,027-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:35:50,288-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:22,035-0500 INFO  Multiplexer No streams
-2013-10-28 15:35:57,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:49:24,239-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:36:00,296-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:32,042-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:36:10,304-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:42,050-0500 INFO  Multiplexer No streams
-2013-10-28 15:36:16,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:49:42,241-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:36:20,311-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:52,058-0500 INFO  Multiplexer No streams
+2013-10-31 21:49:54,314-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:50:02,066-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:50:12,074-0500 INFO  Multiplexer No streams
+2013-10-31 21:50:21,910-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:50:22,082-0500 INFO  Multiplexer No streams
+2013-10-31 21:50:24,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:50:32,090-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:50:42,098-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:50:52,106-0500 INFO  Multiplexer No streams
-2013-10-28 15:36:27,983-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:50:54,465-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:51:01,579-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:36:30,319-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:02,114-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:36:40,327-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:12,122-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:36:50,336-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:22,130-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:24,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:51:32,138-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:41,248-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:51:42,146-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:51:52,154-0500 INFO  Multiplexer No streams
+2013-10-31 21:51:54,615-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:52:02,162-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:52:12,170-0500 INFO  Multiplexer No streams
+2013-10-31 21:52:20,917-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:52:22,178-0500 INFO  Multiplexer No streams
+2013-10-31 21:52:24,691-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:52:32,186-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:52:42,193-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:52:52,201-0500 INFO  Multiplexer No streams
+2013-10-31 21:52:54,766-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:53:00,586-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:53:02,209-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:53:12,217-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:53:22,225-0500 INFO  Multiplexer No streams
+2013-10-31 21:53:24,841-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:53:32,233-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:53:40,255-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:53:42,241-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:53:52,249-0500 INFO  Multiplexer No streams
+2013-10-31 21:53:54,916-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:54:02,257-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:54:12,265-0500 INFO  Multiplexer No streams
-2013-10-28 15:36:54,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:54:19,924-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:54:22,273-0500 INFO  Multiplexer No streams
-2013-10-28 15:36:58,941-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:54:24,991-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:37:00,345-0500 INFO  Multiplexer No streams
+2013-10-31 21:54:32,281-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:37:10,355-0500 INFO  Multiplexer No streams
+2013-10-31 21:54:42,289-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:37:20,366-0500 INFO  Multiplexer No streams
+2013-10-31 21:54:52,297-0500 INFO  Multiplexer No streams
+2013-10-31 21:54:55,066-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:54:59,593-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:55:02,305-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:55:12,313-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:55:22,321-0500 INFO  Multiplexer No streams
+2013-10-31 21:55:25,142-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:55:32,329-0500 INFO  Multiplexer No streams
+2013-10-31 21:55:39,262-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:55:42,337-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:55:52,344-0500 INFO  Multiplexer No streams
-2013-10-28 15:37:29,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:55:55,217-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:37:30,380-0500 INFO  Multiplexer No streams
-2013-10-28 15:37:32,525-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 21:56:02,352-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:37:40,391-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:12,360-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:18,931-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:37:50,401-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:22,368-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:25,292-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:00,414-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:32,376-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:56:42,384-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:56:52,392-0500 INFO  Multiplexer No streams
+2013-10-31 21:56:55,367-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:56:58,600-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:57:02,400-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:57:12,408-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:57:22,416-0500 INFO  Multiplexer No streams
+2013-10-31 21:57:25,442-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 21:57:32,424-0500 INFO  Multiplexer No streams
+2013-10-31 21:57:38,269-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:57:42,432-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:57:52,440-0500 INFO  Multiplexer No streams
-2013-10-28 15:38:00,857-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:57:55,517-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:10,422-0500 INFO  Multiplexer No streams
+2013-10-31 21:58:02,448-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:58:12,456-0500 INFO  Multiplexer No streams
-2013-10-28 15:38:10,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:58:17,938-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:20,432-0500 INFO  Multiplexer No streams
+2013-10-31 21:58:22,464-0500 INFO  Multiplexer No streams
+2013-10-31 21:58:25,592-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:30,444-0500 INFO  Multiplexer No streams
+2013-10-31 21:58:32,472-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:58:42,479-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:58:52,487-0500 INFO  Multiplexer No streams
+2013-10-31 21:58:55,667-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 21:58:57,607-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 21:59:02,495-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:59:12,503-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:59:22,511-0500 INFO  Multiplexer No streams
-2013-10-28 15:38:31,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:59:25,742-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:40,454-0500 INFO  Multiplexer No streams
+2013-10-31 21:59:32,519-0500 INFO  Multiplexer No streams
+2013-10-31 21:59:37,276-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 21:59:42,527-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 21:59:52,535-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 21:59:55,817-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:00:02,543-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:00:12,551-0500 INFO  Multiplexer No streams
+2013-10-31 22:00:16,944-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:00:22,559-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 22:00:25,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:00:32,567-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:00:42,575-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:00:52,582-0500 INFO  Multiplexer No streams
+2013-10-31 22:00:55,967-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:38:48,912-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:00:56,614-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:38:50,464-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:02,590-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:39:00,473-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:12,598-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:01:22,606-0500 INFO  Multiplexer No streams
-2013-10-28 15:39:02,773-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:01:26,042-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:39:10,484-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:32,614-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:36,283-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:39:20,493-0500 INFO  Multiplexer No streams
-2013-10-28 15:39:27,107-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 22:01:42,622-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:39:30,503-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:52,629-0500 INFO  Multiplexer No streams
+2013-10-31 22:01:56,117-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:02:02,637-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:02:12,645-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:02:15,952-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:02:22,653-0500 INFO  Multiplexer No streams
-2013-10-28 15:39:33,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:02:26,192-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:39:40,512-0500 INFO  Multiplexer No streams
+2013-10-31 22:02:32,661-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:39:50,522-0500 INFO  Multiplexer No streams
+2013-10-31 22:02:42,669-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:40:00,531-0500 INFO  Multiplexer No streams
+2013-10-31 22:02:52,677-0500 INFO  Multiplexer No streams
+2013-10-31 22:02:55,621-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:40:04,689-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:02:56,267-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:03:02,685-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:03:12,693-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:03:22,700-0500 INFO  Multiplexer No streams
+2013-10-31 22:03:26,342-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:03:32,708-0500 INFO  Multiplexer No streams
-2013-10-28 15:40:05,300-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:03:35,290-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:40:10,541-0500 INFO  Multiplexer No streams
+2013-10-31 22:03:42,716-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:40:20,550-0500 INFO  Multiplexer No streams
+2013-10-31 22:03:52,724-0500 INFO  Multiplexer No streams
+2013-10-31 22:03:56,417-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:40:30,558-0500 INFO  Multiplexer No streams
+2013-10-31 22:04:02,732-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:04:12,740-0500 INFO  Multiplexer No streams
+2013-10-31 22:04:14,959-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:04:22,748-0500 INFO  Multiplexer No streams
-2013-10-28 15:40:35,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:04:26,492-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:40:40,568-0500 INFO  Multiplexer No streams
-2013-10-28 15:40:43,495-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 22:04:32,755-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:40:50,580-0500 INFO  Multiplexer No streams
+2013-10-31 22:04:42,763-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:41:00,591-0500 INFO  Multiplexer No streams
+2013-10-31 22:04:52,771-0500 INFO  Multiplexer No streams
+2013-10-31 22:04:54,628-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-10-28 15:41:06,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:04:56,567-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:41:10,601-0500 INFO  Multiplexer No streams
+2013-10-31 22:05:02,779-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:41:20,610-0500 INFO  Multiplexer No streams
-2013-10-28 15:41:21,689-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 22:05:12,787-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:41:30,620-0500 INFO  Multiplexer No streams
+2013-10-31 22:05:22,795-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 22:05:26,643-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 22:05:32,803-0500 INFO  Multiplexer No streams
+2013-10-31 22:05:34,298-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:05:42,811-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:05:52,819-0500 INFO  Multiplexer No streams
-2013-10-28 15:41:37,563-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:05:56,717-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:41:40,628-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:02,827-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:41:50,636-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:12,834-0500 INFO  Multiplexer No streams
-2013-10-28 15:41:59,882-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:06:13,968-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:42:00,644-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:22,842-0500 INFO  Multiplexer No streams
-2013-10-28 15:42:08,521-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:06:26,792-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:42:10,653-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:32,850-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:42:20,661-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:42,858-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:42:30,669-0500 INFO  Multiplexer No streams
+2013-10-31 22:06:52,866-0500 INFO  Multiplexer No streams
-2013-10-28 15:42:38,076-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:06:53,637-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:06:56,867-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:07:02,874-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:07:12,881-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:07:22,889-0500 INFO  Multiplexer No streams
-2013-10-28 15:42:39,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:07:26,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:42:40,677-0500 INFO  Multiplexer No streams
+2013-10-31 22:07:32,897-0500 INFO  Multiplexer No streams
+2013-10-31 22:07:33,306-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:42:50,686-0500 INFO  Multiplexer No streams
+2013-10-31 22:07:42,905-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:43:00,694-0500 INFO  Multiplexer No streams
+2013-10-31 22:07:52,913-0500 INFO  Multiplexer No streams
+2013-10-31 22:07:57,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:08:02,921-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:08:12,928-0500 INFO  Multiplexer No streams
+2013-10-31 22:08:12,975-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:08:22,936-0500 INFO  Multiplexer No streams
-2013-10-28 15:43:10,436-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:08:27,091-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:43:10,702-0500 INFO  Multiplexer No streams
-TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
-2013-10-28 15:43:16,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:08:32,944-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:43:20,710-0500 INFO  Multiplexer No streams
+2013-10-31 22:08:42,952-0500 INFO  Multiplexer No streams
+2013-10-31 22:08:52,644-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:43:30,718-0500 INFO  Multiplexer No streams
+2013-10-31 22:08:52,960-0500 INFO  Multiplexer No streams
+2013-10-31 22:08:57,167-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:43:40,726-0500 INFO  Multiplexer No streams
+2013-10-31 22:09:02,968-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:09:12,976-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:09:22,983-0500 INFO  Multiplexer No streams
+2013-10-31 22:09:27,242-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:09:32,313-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:09:32,991-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:09:42,999-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:09:53,007-0500 INFO  Multiplexer No streams
+2013-10-31 22:09:57,317-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:10:03,015-0500 INFO  Multiplexer No streams
+2013-10-31 22:10:11,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:10:13,022-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:10:23,030-0500 INFO  Multiplexer No streams
+2013-10-31 22:10:27,392-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:10:33,038-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:10:43,046-0500 INFO  Multiplexer No streams
+2013-10-31 22:10:51,651-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:10:53,054-0500 INFO  Multiplexer No streams
+2013-10-31 22:10:57,467-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:11:03,062-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:11:13,070-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:11:23,078-0500 INFO  Multiplexer No streams
-2013-10-28 15:43:41,394-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:11:27,541-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:11:31,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:43:50,734-0500 INFO  Multiplexer No streams
+2013-10-31 22:11:33,085-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:11:43,093-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:11:53,101-0500 INFO  Multiplexer No streams
+2013-10-31 22:11:57,617-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:12:03,109-0500 INFO  Multiplexer No streams
-2013-10-28 15:43:54,464-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:12:10,989-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:44:00,742-0500 INFO  Multiplexer No streams
+2013-10-31 22:12:13,117-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:44:10,749-0500 INFO  Multiplexer No streams
+2013-10-31 22:12:23,124-0500 INFO  Multiplexer No streams
+2013-10-31 22:12:27,692-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:12:33,132-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:12:43,140-0500 INFO  Multiplexer No streams
+2013-10-31 22:12:50,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:12:53,148-0500 INFO  Multiplexer No streams
+2013-10-31 22:12:57,767-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:13:03,156-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:13:13,164-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:13:23,172-0500 INFO  Multiplexer No streams
+2013-10-31 22:13:27,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:13:30,327-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:13:33,179-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:13:43,187-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:13:53,195-0500 INFO  Multiplexer No streams
+2013-10-31 22:13:57,917-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:14:03,203-0500 INFO  Multiplexer No streams
+2013-10-31 22:14:09,995-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:14:13,211-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:14:23,218-0500 INFO  Multiplexer No streams
+2013-10-31 22:14:27,992-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:14:33,226-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:14:43,234-0500 INFO  Multiplexer No streams
+2013-10-31 22:14:49,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:14:53,242-0500 INFO  Multiplexer No streams
+2013-10-31 22:14:58,067-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:15:03,250-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:15:13,258-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:15:23,265-0500 INFO  Multiplexer No streams
+2013-10-31 22:15:28,142-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:15:29,334-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:15:33,273-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:15:43,281-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:15:53,289-0500 INFO  Multiplexer No streams
+2013-10-31 22:15:58,217-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:16:03,297-0500 INFO  Multiplexer No streams
+2013-10-31 22:16:09,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:16:13,304-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:16:23,312-0500 INFO  Multiplexer No streams
+2013-10-31 22:16:28,292-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:16:33,320-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:16:43,328-0500 INFO  Multiplexer No streams
+2013-10-31 22:16:48,672-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:16:53,336-0500 INFO  Multiplexer No streams
+2013-10-31 22:16:58,367-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:17:03,344-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:17:13,352-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:17:23,359-0500 INFO  Multiplexer No streams
+2013-10-31 22:17:28,341-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:17:28,442-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:17:33,367-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:17:43,375-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:17:53,383-0500 INFO  Multiplexer No streams
+2013-10-31 22:17:58,517-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:18:03,390-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:18:08,009-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:18:13,398-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:18:23,406-0500 INFO  Multiplexer No streams
+2013-10-31 22:18:28,592-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:18:33,414-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:18:43,422-0500 INFO  Multiplexer No streams
+2013-10-31 22:18:47,679-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:18:53,430-0500 INFO  Multiplexer No streams
+2013-10-31 22:18:58,667-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:19:03,437-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:19:13,445-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:19:23,453-0500 INFO  Multiplexer No streams
+2013-10-31 22:19:27,348-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:19:28,742-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:19:33,461-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:19:43,469-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:19:53,476-0500 INFO  Multiplexer No streams
+2013-10-31 22:19:58,817-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:20:03,484-0500 INFO  Multiplexer No streams
+2013-10-31 22:20:07,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:20:13,492-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:20:23,500-0500 INFO  Multiplexer No streams
+2013-10-31 22:20:28,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:20:33,508-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:20:43,516-0500 INFO  Multiplexer No streams
+2013-10-31 22:20:46,686-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:20:53,523-0500 INFO  Multiplexer No streams
+2013-10-31 22:20:58,967-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:21:03,531-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:21:13,539-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:21:23,547-0500 INFO  Multiplexer No streams
+2013-10-31 22:21:26,355-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:21:29,042-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:21:33,555-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:21:43,562-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:21:53,570-0500 INFO  Multiplexer No streams
-2013-10-28 15:44:12,353-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:21:59,117-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:44:20,757-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:03,578-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:06,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:44:30,765-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:13,586-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:22:23,593-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:29,192-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:22:33,601-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:22:43,609-0500 INFO  Multiplexer No streams
-2013-10-28 15:44:32,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:22:45,694-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:44:40,772-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:53,617-0500 INFO  Multiplexer No streams
+2013-10-31 22:22:59,267-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:23:03,625-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:23:13,633-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:23:23,640-0500 INFO  Multiplexer No streams
+2013-10-31 22:23:25,363-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:23:29,342-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:23:33,648-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:23:43,656-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:23:53,664-0500 INFO  Multiplexer No streams
+2013-10-31 22:23:59,417-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:24:03,672-0500 INFO  Multiplexer No streams
+2013-10-31 22:24:05,032-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:24:13,679-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:24:23,687-0500 INFO  Multiplexer No streams
+2013-10-31 22:24:29,492-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:24:33,695-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:24:43,703-0500 INFO  Multiplexer No streams
+2013-10-31 22:24:44,701-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:24:53,710-0500 INFO  Multiplexer No streams
-2013-10-28 15:44:43,312-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:24:59,567-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:44:50,780-0500 INFO  Multiplexer No streams
+2013-10-31 22:25:03,718-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:45:00,787-0500 INFO  Multiplexer No streams
+2013-10-31 22:25:13,726-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:45:10,795-0500 INFO  Multiplexer No streams
+2013-10-31 22:25:23,734-0500 INFO  Multiplexer No streams
-2013-10-28 15:45:10,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:25:24,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:25:29,643-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:25:33,742-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:25:43,750-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:25:53,757-0500 INFO  Multiplexer No streams
+2013-10-31 22:25:59,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:26:03,765-0500 INFO  Multiplexer No streams
+2013-10-31 22:26:04,040-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:26:13,773-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:26:23,781-0500 INFO  Multiplexer No streams
+2013-10-31 22:26:29,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:26:33,789-0500 INFO  Multiplexer No streams
+2013-10-31 22:26:43,709-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:26:43,797-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:26:53,804-0500 INFO  Multiplexer No streams
+2013-10-31 22:26:59,868-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:27:03,812-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:27:13,820-0500 INFO  Multiplexer No streams
+2013-10-31 22:27:23,378-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:27:23,828-0500 INFO  Multiplexer No streams
+2013-10-31 22:27:29,943-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:27:33,836-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:27:43,844-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:27:53,852-0500 INFO  Multiplexer No streams
+2013-10-31 22:28:00,018-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:28:03,047-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:28:03,859-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:28:13,867-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:28:23,875-0500 INFO  Multiplexer No streams
+2013-10-31 22:28:30,093-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:28:33,883-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-10-31 22:28:42,715-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 22:28:43,891-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:28:53,899-0500 INFO  Multiplexer No streams
+2013-10-31 22:29:00,168-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:29:03,906-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:29:13,914-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:29:22,385-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:29:23,922-0500 INFO  Multiplexer No streams
+2013-10-31 22:29:30,243-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:29:33,930-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:29:43,938-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:29:53,946-0500 INFO  Multiplexer No streams
+2013-10-31 22:30:00,318-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:30:02,054-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:30:03,954-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:30:13,961-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:30:23,969-0500 INFO  Multiplexer No streams
+2013-10-31 22:30:30,393-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:30:33,977-0500 INFO  Multiplexer No streams
+2013-10-31 22:30:41,723-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:30:43,985-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:30:53,993-0500 INFO  Multiplexer No streams
+2013-10-31 22:31:00,468-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:31:04,001-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:31:14,009-0500 INFO  Multiplexer No streams
+2013-10-31 22:31:21,392-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:31:24,017-0500 INFO  Multiplexer No streams
+2013-10-31 22:31:30,543-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:31:34,025-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:31:44,032-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:31:54,040-0500 INFO  Multiplexer No streams
+2013-10-31 22:32:00,618-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 22:32:01,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:32:04,048-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:32:14,056-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:32:24,064-0500 INFO  Multiplexer No streams
+2013-10-31 22:32:30,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:32:34,072-0500 INFO  Multiplexer No streams
+2013-10-31 22:32:40,730-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:32:44,080-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:32:54,088-0500 INFO  Multiplexer No streams
+2013-10-31 22:33:00,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:33:04,096-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:33:14,104-0500 INFO  Multiplexer No streams
+2013-10-31 22:33:20,399-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:33:24,112-0500 INFO  Multiplexer No streams
+2013-10-31 22:33:30,843-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:33:34,120-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:33:44,128-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:33:54,136-0500 INFO  Multiplexer No streams
+2013-10-31 22:34:00,068-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:34:00,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:34:04,144-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:34:14,152-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:34:24,160-0500 INFO  Multiplexer No streams
+2013-10-31 22:34:30,993-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:34:34,168-0500 INFO  Multiplexer No streams
+2013-10-31 22:34:39,737-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:34:44,176-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:34:54,183-0500 INFO  Multiplexer No streams
+2013-10-31 22:35:01,068-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:35:04,191-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:35:14,199-0500 INFO  Multiplexer No streams
+2013-10-31 22:35:19,406-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:35:24,207-0500 INFO  Multiplexer No streams
+2013-10-31 22:35:31,143-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:35:34,215-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:35:44,223-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:35:54,231-0500 INFO  Multiplexer No streams
+2013-10-31 22:35:59,075-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:36:01,218-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:36:04,239-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:36:14,247-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:36:24,255-0500 INFO  Multiplexer No streams
+2013-10-31 22:36:31,293-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:36:34,263-0500 INFO  Multiplexer No streams
+2013-10-31 22:36:38,744-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:36:44,271-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:36:54,279-0500 INFO  Multiplexer No streams
+2013-10-31 22:37:01,368-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:37:04,287-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:37:14,295-0500 INFO  Multiplexer No streams
+2013-10-31 22:37:18,413-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:37:24,303-0500 INFO  Multiplexer No streams
+2013-10-31 22:37:31,443-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:37:34,311-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:37:44,319-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:37:54,327-0500 INFO  Multiplexer No streams
+2013-10-31 22:37:58,082-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:38:01,518-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:38:04,335-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:38:14,342-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:38:24,350-0500 INFO  Multiplexer No streams
+2013-10-31 22:38:31,593-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:38:34,358-0500 INFO  Multiplexer No streams
+2013-10-31 22:38:37,751-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:38:44,366-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:38:54,374-0500 INFO  Multiplexer No streams
+2013-10-31 22:39:01,668-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:39:04,382-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:39:14,390-0500 INFO  Multiplexer No streams
+2013-10-31 22:39:17,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:39:24,398-0500 INFO  Multiplexer No streams
+2013-10-31 22:39:31,743-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:39:34,406-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:39:44,414-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:39:54,422-0500 INFO  Multiplexer No streams
+2013-10-31 22:39:57,089-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:40:01,818-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:40:04,430-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:40:14,438-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:40:24,446-0500 INFO  Multiplexer No streams
+2013-10-31 22:40:31,893-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:40:34,454-0500 INFO  Multiplexer No streams
+2013-10-31 22:40:36,757-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 22:40:44,461-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:40:54,469-0500 INFO  Multiplexer No streams
+2013-10-31 22:41:01,968-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:41:04,477-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:41:14,485-0500 INFO  Multiplexer No streams
+2013-10-31 22:41:16,427-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:41:24,493-0500 INFO  Multiplexer No streams
+2013-10-31 22:41:32,043-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:41:34,501-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:41:44,509-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:41:54,517-0500 INFO  Multiplexer No streams
+2013-10-31 22:41:56,096-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:42:02,118-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:42:04,525-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:42:14,533-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:42:24,541-0500 INFO  Multiplexer No streams
-2013-10-28 15:45:14,271-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:42:32,192-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 15:45:20,802-0500 INFO  Multiplexer No streams
+2013-10-31 22:42:34,549-0500 INFO  Multiplexer No streams
+2013-10-31 22:42:35,765-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:45:30,810-0500 INFO  Multiplexer No streams
+2013-10-31 22:42:44,557-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:45:40,817-0500 INFO  Multiplexer No streams
+2013-10-31 22:42:54,565-0500 INFO  Multiplexer No streams
-2013-10-28 15:45:45,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:43:02,268-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:43:04,573-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:43:14,580-0500 INFO  Multiplexer No streams
-2013-10-28 15:45:49,046-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:43:15,434-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:45:50,825-0500 INFO  Multiplexer No streams
+2013-10-31 22:43:24,588-0500 INFO  Multiplexer No streams
+2013-10-31 22:43:32,343-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:46:00,832-0500 INFO  Multiplexer No streams
+2013-10-31 22:43:34,596-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:46:10,840-0500 INFO  Multiplexer No streams
+2013-10-31 22:43:44,604-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:43:54,612-0500 INFO  Multiplexer No streams
+2013-10-31 22:43:55,103-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:44:02,418-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:44:04,620-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:44:14,628-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:44:24,636-0500 INFO  Multiplexer No streams
-2013-10-28 15:46:16,188-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:44:32,493-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:46:20,847-0500 INFO  Multiplexer No streams
+2013-10-31 22:44:34,644-0500 INFO  Multiplexer No streams
+2013-10-31 22:44:34,771-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 22:44:44,652-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:44:54,660-0500 INFO  Multiplexer No streams
+2013-10-31 22:45:02,568-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:45:04,668-0500 INFO  Multiplexer No streams
-2013-10-28 15:46:27,240-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:45:14,441-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:46:30,855-0500 INFO  Multiplexer No streams
+2013-10-31 22:45:14,676-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:46:40,863-0500 INFO  Multiplexer No streams
+2013-10-31 22:45:24,684-0500 INFO  Multiplexer No streams
+2013-10-31 22:45:32,643-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:45:34,692-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:45:44,700-0500 INFO  Multiplexer No streams
+2013-10-31 22:45:54,110-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:45:54,708-0500 INFO  Multiplexer No streams
-2013-10-28 15:46:47,146-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:46:02,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:46:50,870-0500 INFO  Multiplexer No streams
+2013-10-31 22:46:04,716-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:47:00,877-0500 INFO  Multiplexer No streams
+2013-10-31 22:46:14,723-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:46:24,731-0500 INFO  Multiplexer No streams
+2013-10-31 22:46:32,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:46:33,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:46:34,739-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:46:44,747-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:46:54,755-0500 INFO  Multiplexer No streams
+2013-10-31 22:47:02,868-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:47:04,763-0500 INFO  Multiplexer No streams
+2013-10-31 22:47:13,448-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:47:14,771-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:47:24,779-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 22:47:32,943-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:47:34,787-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:47:44,795-0500 INFO  Multiplexer No streams
+2013-10-31 22:47:53,117-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:47:54,803-0500 INFO  Multiplexer No streams
+2013-10-31 22:48:03,018-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:48:04,811-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:48:14,819-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:48:24,827-0500 INFO  Multiplexer No streams
+2013-10-31 22:48:32,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:48:33,093-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:48:34,834-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:48:44,842-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:48:54,850-0500 INFO  Multiplexer No streams
+2013-10-31 22:49:03,169-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:49:04,858-0500 INFO  Multiplexer No streams
+2013-10-31 22:49:12,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:49:14,866-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:49:24,874-0500 INFO  Multiplexer No streams
+2013-10-31 22:49:33,244-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:49:34,882-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:49:44,889-0500 INFO  Multiplexer No streams
-2013-10-28 15:47:05,435-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-10-31 22:49:52,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
 No streams
-2013-10-28 15:47:10,885-0500 INFO  Multiplexer No streams
+2013-10-31 22:49:54,897-0500 INFO  Multiplexer No streams
+2013-10-31 22:50:03,319-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:50:04,905-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:50:14,913-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:50:24,921-0500 INFO  Multiplexer No streams
+2013-10-31 22:50:31,794-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:50:33,394-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:50:34,929-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:50:44,937-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:50:54,944-0500 INFO  Multiplexer No streams
-2013-10-28 15:47:18,104-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:51:03,469-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:47:20,892-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:04,952-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:11,463-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:47:30,900-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:14,960-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:47:40,907-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:24,968-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:33,544-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:51:34,976-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:51:44,984-0500 INFO  Multiplexer No streams
+2013-10-31 22:51:51,132-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:51:54,992-0500 INFO  Multiplexer No streams
+2013-10-31 22:52:03,619-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:52:04,999-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:52:15,007-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:52:25,015-0500 INFO  Multiplexer No streams
+2013-10-31 22:52:30,801-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:52:33,694-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:52:35,023-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:52:45,031-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:52:55,039-0500 INFO  Multiplexer No streams
+2013-10-31 22:53:03,769-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:53:05,047-0500 INFO  Multiplexer No streams
+2013-10-31 22:53:10,470-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:53:15,055-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:53:25,063-0500 INFO  Multiplexer No streams
+2013-10-31 22:53:33,844-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 22:53:35,070-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:53:45,078-0500 INFO  Multiplexer No streams
-2013-10-28 15:47:43,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:53:50,140-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:53:55,086-0500 INFO  Multiplexer No streams
-2013-10-28 15:47:49,062-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:54:03,920-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:47:50,915-0500 INFO  Multiplexer No streams
+2013-10-31 22:54:05,094-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:48:00,922-0500 INFO  Multiplexer No streams
+2013-10-31 22:54:15,102-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:48:10,930-0500 INFO  Multiplexer No streams
+2013-10-31 22:54:25,110-0500 INFO  Multiplexer No streams
+2013-10-31 22:54:29,808-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:54:33,995-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:54:35,118-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:54:45,125-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:54:55,133-0500 INFO  Multiplexer No streams
+2013-10-31 22:55:04,071-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 22:55:05,141-0500 INFO  Multiplexer No streams
+2013-10-31 22:55:09,477-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 22:55:15,149-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:55:25,157-0500 INFO  Multiplexer No streams
-2013-10-28 15:48:20,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:55:34,145-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:48:20,937-0500 INFO  Multiplexer No streams
+2013-10-31 22:55:35,165-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:55:45,173-0500 INFO  Multiplexer No streams
+2013-10-31 22:55:49,146-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:55:55,180-0500 INFO  Multiplexer No streams
+2013-10-31 22:56:04,220-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:56:05,188-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:56:15,196-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:56:25,204-0500 INFO  Multiplexer No streams
+2013-10-31 22:56:28,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:56:34,295-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:56:35,212-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:56:45,219-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:56:55,227-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:57:04,370-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:57:05,235-0500 INFO  Multiplexer No streams
+2013-10-31 22:57:08,484-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:57:15,243-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:57:25,250-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 22:57:34,445-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:57:35,258-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:57:45,266-0500 INFO  Multiplexer No streams
+2013-10-31 22:57:48,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 22:57:55,274-0500 INFO  Multiplexer No streams
+2013-10-31 22:58:04,520-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:58:05,282-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:58:15,289-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:58:25,297-0500 INFO  Multiplexer No streams
-2013-10-28 15:48:21,823-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:58:27,823-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 22:58:34,595-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:48:30,945-0500 INFO  Multiplexer No streams
+2013-10-31 22:58:35,305-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:48:40,952-0500 INFO  Multiplexer No streams
+2013-10-31 22:58:45,313-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:48:50,960-0500 INFO  Multiplexer No streams
+2013-10-31 22:58:55,320-0500 INFO  Multiplexer No streams
+2013-10-31 22:59:04,670-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:59:05,328-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 22:59:07,492-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:59:15,336-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:59:25,344-0500 INFO  Multiplexer No streams
+2013-10-31 22:59:34,746-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 22:59:35,351-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 22:59:45,359-0500 INFO  Multiplexer No streams
+2013-10-31 22:59:47,161-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 22:59:55,367-0500 INFO  Multiplexer No streams
-2013-10-28 15:48:50,978-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:00:04,821-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:00:05,375-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:00:15,382-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:00:25,390-0500 INFO  Multiplexer No streams
-2013-10-28 15:49:00,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:00:26,830-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:00:34,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:49:00,967-0500 INFO  Multiplexer No streams
+2013-10-31 23:00:35,398-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:49:10,975-0500 INFO  Multiplexer No streams
+2013-10-31 23:00:45,405-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:49:20,982-0500 INFO  Multiplexer No streams
+2013-10-31 23:00:55,413-0500 INFO  Multiplexer No streams
+2013-10-31 23:01:04,971-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 23:01:05,421-0500 INFO  Multiplexer No streams
+2013-10-31 23:01:06,499-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:01:15,429-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:01:25,436-0500 INFO  Multiplexer No streams
-2013-10-28 15:49:21,936-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:01:35,047-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:49:30,990-0500 INFO  Multiplexer No streams
+2013-10-31 23:01:35,444-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:01:45,452-0500 INFO  Multiplexer No streams
+2013-10-31 23:01:46,168-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:01:55,460-0500 INFO  Multiplexer No streams
+2013-10-31 23:02:05,122-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:02:05,467-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:02:15,475-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:02:25,483-0500 INFO  Multiplexer No streams
+2013-10-31 23:02:25,838-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 23:02:35,197-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:02:35,491-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:02:45,498-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:02:55,506-0500 INFO  Multiplexer No streams
+2013-10-31 23:03:05,272-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:03:05,507-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:03:05,514-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:03:15,522-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:03:25,529-0500 INFO  Multiplexer No streams
+2013-10-31 23:03:35,347-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:03:35,537-0500 INFO  Multiplexer No streams
-2013-10-28 15:49:38,211-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:03:45,176-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:49:40,997-0500 INFO  Multiplexer No streams
+2013-10-31 23:03:45,545-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:49:51,005-0500 INFO  Multiplexer No streams
+2013-10-31 23:03:55,553-0500 INFO  Multiplexer No streams
+2013-10-31 23:04:05,422-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:04:05,560-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:04:15,568-0500 INFO  Multiplexer No streams
+2013-10-31 23:04:24,845-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:04:25,576-0500 INFO  Multiplexer No streams
-2013-10-28 15:49:52,894-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:04:35,497-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:50:01,012-0500 INFO  Multiplexer No streams
+2013-10-31 23:04:35,584-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:50:11,020-0500 INFO  Multiplexer No streams
+2013-10-31 23:04:45,592-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:04:55,599-0500 INFO  Multiplexer No streams
-2013-10-28 15:50:16,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:05:04,514-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:05:05,572-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:50:21,027-0500 INFO  Multiplexer No streams
+2013-10-31 23:05:05,607-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:05:15,615-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:05:25,623-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:05:35,631-0500 INFO  Multiplexer No streams
+2013-10-31 23:05:35,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:05:44,183-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:05:45,638-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:05:55,646-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:06:05,654-0500 INFO  Multiplexer No streams
-2013-10-28 15:50:23,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:06:05,722-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:50:31,035-0500 INFO  Multiplexer No streams
+2013-10-31 23:06:15,662-0500 INFO  Multiplexer No streams
+2013-10-31 23:06:23,852-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:50:41,042-0500 INFO  Multiplexer No streams
+2013-10-31 23:06:25,670-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:50:51,050-0500 INFO  Multiplexer No streams
+2013-10-31 23:06:35,677-0500 INFO  Multiplexer No streams
+2013-10-31 23:06:35,797-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:06:45,685-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:06:55,693-0500 INFO  Multiplexer No streams
+2013-10-31 23:07:03,521-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:07:05,701-0500 INFO  Multiplexer No streams
+2013-10-31 23:07:05,872-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:07:15,709-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:07:25,716-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:07:35,724-0500 INFO  Multiplexer No streams
+2013-10-31 23:07:35,947-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-10-31 23:07:43,192-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-10-31 23:07:45,732-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:07:55,740-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:08:05,748-0500 INFO  Multiplexer No streams
+2013-10-31 23:08:06,023-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:08:15,756-0500 INFO  Multiplexer No streams
+2013-10-31 23:08:22,860-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:08:25,764-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:08:35,771-0500 INFO  Multiplexer No streams
+2013-10-31 23:08:36,098-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:08:45,779-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:08:55,787-0500 INFO  Multiplexer No streams
-2013-10-28 15:50:54,599-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:09:02,529-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:09:05,795-0500 INFO  Multiplexer No streams
+2013-10-31 23:09:06,173-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:09:15,803-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:09:25,811-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:09:35,818-0500 INFO  Multiplexer No streams
-2013-10-28 15:50:54,810-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:09:36,248-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:09:42,198-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:51:01,057-0500 INFO  Multiplexer No streams
+2013-10-31 23:09:45,826-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:51:11,065-0500 INFO  Multiplexer No streams
+2013-10-31 23:09:55,834-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:51:21,072-0500 INFO  Multiplexer No streams
+2013-10-31 23:10:05,842-0500 INFO  Multiplexer No streams
+2013-10-31 23:10:06,323-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:10:15,849-0500 INFO  Multiplexer No streams
+2013-10-31 23:10:21,867-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:10:25,857-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:10:35,865-0500 INFO  Multiplexer No streams
+2013-10-31 23:10:36,398-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:10:45,873-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:10:55,881-0500 INFO  Multiplexer No streams
+2013-10-31 23:11:01,536-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:11:05,889-0500 INFO  Multiplexer No streams
-2013-10-28 15:51:25,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:11:06,473-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:51:31,080-0500 INFO  Multiplexer No streams
+2013-10-31 23:11:15,897-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:11:25,905-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:11:35,912-0500 INFO  Multiplexer No streams
+2013-10-31 23:11:36,548-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:11:41,204-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:11:45,920-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:11:55,928-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:12:05,936-0500 INFO  Multiplexer No streams
+2013-10-31 23:12:06,623-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:12:15,944-0500 INFO  Multiplexer No streams
+2013-10-31 23:12:20,874-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:12:25,952-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:12:35,960-0500 INFO  Multiplexer No streams
+2013-10-31 23:12:36,698-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:12:45,968-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:12:55,976-0500 INFO  Multiplexer No streams
-2013-10-28 15:51:32,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:13:00,543-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:51:41,088-0500 INFO  Multiplexer No streams
+2013-10-31 23:13:05,983-0500 INFO  Multiplexer No streams
+2013-10-31 23:13:06,773-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:51:51,095-0500 INFO  Multiplexer No streams
+2013-10-31 23:13:15,991-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:13:25,999-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:13:36,007-0500 INFO  Multiplexer No streams
+2013-10-31 23:13:36,848-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:13:40,212-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:13:46,015-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:13:56,023-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:14:06,031-0500 INFO  Multiplexer No streams
-2013-10-28 15:51:56,726-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:14:06,923-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:52:01,103-0500 INFO  Multiplexer No streams
+2013-10-31 23:14:16,039-0500 INFO  Multiplexer No streams
-2013-10-28 15:52:10,987-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:14:19,881-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:52:11,110-0500 INFO  Multiplexer No streams
+2013-10-31 23:14:26,047-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:52:21,118-0500 INFO  Multiplexer No streams
+2013-10-31 23:14:36,056-0500 INFO  Multiplexer No streams
+2013-10-31 23:14:36,998-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:14:46,064-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:14:56,072-0500 INFO  Multiplexer No streams
+2013-10-31 23:14:59,550-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:15:06,080-0500 INFO  Multiplexer No streams
+2013-10-31 23:15:07,073-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:15:16,088-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:15:26,096-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:15:36,104-0500 INFO  Multiplexer No streams
-2013-10-28 15:52:27,684-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:15:37,148-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:15:39,219-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:52:31,125-0500 INFO  Multiplexer No streams
+2013-10-31 23:15:46,112-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:52:41,133-0500 INFO  Multiplexer No streams
+2013-10-31 23:15:56,120-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:16:06,128-0500 INFO  Multiplexer No streams
+2013-10-31 23:16:07,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:16:16,136-0500 INFO  Multiplexer No streams
+2013-10-31 23:16:18,888-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:16:26,144-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:16:36,152-0500 INFO  Multiplexer No streams
+2013-10-31 23:16:37,298-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:16:46,160-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:16:56,168-0500 INFO  Multiplexer No streams
-2013-10-28 15:52:49,182-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:16:58,558-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:52:51,140-0500 INFO  Multiplexer No streams
+2013-10-31 23:17:06,176-0500 INFO  Multiplexer No streams
+2013-10-31 23:17:07,374-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:17:16,184-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:17:26,193-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:17:36,201-0500 INFO  Multiplexer No streams
-2013-10-28 15:52:58,642-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:17:37,449-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:17:38,227-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
 No streams
-2013-10-28 15:53:01,148-0500 INFO  Multiplexer No streams
+2013-10-31 23:17:46,209-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:53:11,155-0500 INFO  Multiplexer No streams
+2013-10-31 23:17:56,217-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:53:21,163-0500 INFO  Multiplexer No streams
+2013-10-31 23:18:06,224-0500 INFO  Multiplexer No streams
+2013-10-31 23:18:07,524-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:18:16,232-0500 INFO  Multiplexer No streams
-2013-10-28 15:53:27,375-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:18:17,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:18:26,240-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:18:36,248-0500 INFO  Multiplexer No streams
+2013-10-31 23:18:37,599-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:18:46,256-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:18:56,263-0500 INFO  Multiplexer No streams
+2013-10-31 23:18:57,565-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:19:06,271-0500 INFO  Multiplexer No streams
-2013-10-28 15:53:29,600-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:19:07,674-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:53:31,170-0500 INFO  Multiplexer No streams
+2013-10-31 23:19:16,279-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:53:41,178-0500 INFO  Multiplexer No streams
+2013-10-31 23:19:26,287-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:53:51,185-0500 INFO  Multiplexer No streams
+2013-10-31 23:19:36,295-0500 INFO  Multiplexer No streams
+2013-10-31 23:19:37,234-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:19:37,749-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:19:46,303-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:19:56,311-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:20:06,318-0500 INFO  Multiplexer No streams
-2013-10-28 15:54:00,558-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:20:07,824-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:54:01,192-0500 INFO  Multiplexer No streams
+2013-10-31 23:20:16,326-0500 INFO  Multiplexer No streams
+2013-10-31 23:20:16,903-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:20:26,334-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:20:36,342-0500 INFO  Multiplexer No streams
+2013-10-31 23:20:37,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:20:46,350-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:20:56,358-0500 INFO  Multiplexer No streams
-2013-10-28 15:54:05,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:20:56,573-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:54:11,200-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:06,366-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:07,974-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:54:21,207-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:16,374-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:54:31,215-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:26,382-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:36,242-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:21:36,390-0500 INFO  Multiplexer No streams
-2013-10-28 15:54:31,516-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:21:38,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:54:41,222-0500 INFO  Multiplexer No streams
+2013-10-31 23:21:46,398-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:21:56,405-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:22:06,413-0500 INFO  Multiplexer No streams
+2013-10-31 23:22:08,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:54:43,763-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:22:15,911-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:54:51,230-0500 INFO  Multiplexer No streams
+2013-10-31 23:22:16,421-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:55:01,237-0500 INFO  Multiplexer No streams
+2013-10-31 23:22:26,429-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:22:36,437-0500 INFO  Multiplexer No streams
+2013-10-31 23:22:38,199-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:22:46,445-0500 INFO  Multiplexer No streams
+2013-10-31 23:22:55,580-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:22:56,452-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:23:06,460-0500 INFO  Multiplexer No streams
+2013-10-31 23:23:08,274-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:23:16,468-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:23:26,476-0500 INFO  Multiplexer No streams
+2013-10-31 23:23:35,249-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:23:36,483-0500 INFO  Multiplexer No streams
+2013-10-31 23:23:38,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:23:46,491-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:23:56,499-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:24:06,506-0500 INFO  Multiplexer No streams
-2013-10-28 15:55:02,474-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:24:08,424-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:24:14,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
 No streams
-2013-10-28 15:55:11,245-0500 INFO  Multiplexer No streams
+2013-10-31 23:24:16,514-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:55:21,252-0500 INFO  Multiplexer No streams
+2013-10-31 23:24:26,522-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:24:36,530-0500 INFO  Multiplexer No streams
+2013-10-31 23:24:38,499-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:24:46,537-0500 INFO  Multiplexer No streams
-2013-10-28 15:55:21,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:24:54,587-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:55:31,260-0500 INFO  Multiplexer No streams
+2013-10-31 23:24:56,545-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:25:06,553-0500 INFO  Multiplexer No streams
+2013-10-31 23:25:08,574-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:25:16,561-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:25:26,569-0500 INFO  Multiplexer No streams
+2013-10-31 23:25:34,256-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:25:36,578-0500 INFO  Multiplexer No streams
+2013-10-31 23:25:38,649-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 23:25:46,586-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:25:56,594-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:26:06,602-0500 INFO  Multiplexer No streams
+2013-10-31 23:26:08,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:26:13,925-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:26:16,610-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:26:26,618-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:26:36,626-0500 INFO  Multiplexer No streams
+2013-10-31 23:26:38,800-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:26:46,634-0500 INFO  Multiplexer No streams
+2013-10-31 23:26:53,594-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:26:56,641-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:27:06,649-0500 INFO  Multiplexer No streams
+2013-10-31 23:27:08,875-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:27:16,657-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:27:26,665-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-10-31 23:27:33,262-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:27:36,673-0500 INFO  Multiplexer No streams
-2013-10-28 15:55:33,432-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:27:38,950-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:55:41,267-0500 INFO  Multiplexer No streams
+2013-10-31 23:27:46,680-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:55:51,275-0500 INFO  Multiplexer No streams
+2013-10-31 23:27:56,688-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:28:06,696-0500 INFO  Multiplexer No streams
+2013-10-31 23:28:09,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:56:00,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-10-31 23:28:12,931-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
 No streams
-2013-10-28 15:56:01,282-0500 INFO  Multiplexer No streams
+2013-10-31 23:28:16,704-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:28:26,712-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:28:36,720-0500 INFO  Multiplexer No streams
+2013-10-31 23:28:39,100-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:28:46,727-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 23:28:52,601-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:28:56,735-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:29:06,743-0500 INFO  Multiplexer No streams
-2013-10-28 15:56:04,390-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:29:09,175-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:56:11,290-0500 INFO  Multiplexer No streams
+2013-10-31 23:29:16,751-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:56:21,298-0500 INFO  Multiplexer No streams
+2013-10-31 23:29:26,759-0500 INFO  Multiplexer No streams
+2013-10-31 23:29:32,270-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:56:31,305-0500 INFO  Multiplexer No streams
+2013-10-31 23:29:36,767-0500 INFO  Multiplexer No streams
+2013-10-31 23:29:39,250-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:29:46,774-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:29:56,782-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:30:06,790-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 23:30:09,326-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-10-31 23:30:11,939-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:30:16,797-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:30:26,805-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:30:36,812-0500 INFO  Multiplexer No streams
+2013-10-31 23:30:39,401-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-10-31 23:30:46,820-0500 INFO  Multiplexer No streams
+2013-10-31 23:30:51,608-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:30:56,828-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:31:06,836-0500 INFO  Multiplexer No streams
+2013-10-31 23:31:09,475-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:31:16,843-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:31:26,851-0500 INFO  Multiplexer No streams
+2013-10-31 23:31:31,277-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:31:36,859-0500 INFO  Multiplexer No streams
+2013-10-31 23:31:39,550-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:31:46,867-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:31:56,876-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:32:06,884-0500 INFO  Multiplexer No streams
+2013-10-31 23:32:09,625-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:32:10,946-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:32:16,892-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:32:26,899-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:32:36,907-0500 INFO  Multiplexer No streams
+2013-10-31 23:32:39,700-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:32:46,915-0500 INFO  Multiplexer No streams
+2013-10-31 23:32:50,615-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:32:56,924-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:33:06,932-0500 INFO  Multiplexer No streams
+2013-10-31 23:33:09,776-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:33:16,941-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:33:26,949-0500 INFO  Multiplexer No streams
+2013-10-31 23:33:30,285-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-10-31 23:33:36,957-0500 INFO  Multiplexer No streams
+2013-10-31 23:33:39,851-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:33:46,965-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:33:56,973-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:34:06,981-0500 INFO  Multiplexer No streams
+2013-10-31 23:34:09,926-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:34:09,953-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:34:16,989-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:34:26,997-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:34:37,005-0500 INFO  Multiplexer No streams
+2013-10-31 23:34:40,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:34:47,013-0500 INFO  Multiplexer No streams
+2013-10-31 23:34:49,622-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:34:57,021-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:35:07,029-0500 INFO  Multiplexer No streams
+2013-10-31 23:35:10,076-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:35:17,037-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:35:27,045-0500 INFO  Multiplexer No streams
+2013-10-31 23:35:29,292-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:35:37,053-0500 INFO  Multiplexer No streams
+2013-10-31 23:35:40,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:35:47,061-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:35:57,069-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:36:07,078-0500 INFO  Multiplexer No streams
+2013-10-31 23:36:08,961-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 23:36:10,226-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 23:36:17,086-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:36:27,094-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:36:37,102-0500 INFO  Multiplexer No streams
+2013-10-31 23:36:40,301-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:36:47,110-0500 INFO  Multiplexer No streams
+2013-10-31 23:36:48,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:36:57,118-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:37:07,127-0500 INFO  Multiplexer No streams
+2013-10-31 23:37:10,376-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:37:17,135-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:37:27,143-0500 INFO  Multiplexer No streams
+2013-10-31 23:37:28,299-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:37:37,151-0500 INFO  Multiplexer No streams
+2013-10-31 23:37:40,451-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:37:47,159-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:37:57,168-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:38:07,176-0500 INFO  Multiplexer No streams
+2013-10-31 23:38:07,968-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 23:38:10,526-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:38:17,183-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:38:27,192-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:38:37,200-0500 INFO  Multiplexer No streams
+2013-10-31 23:38:40,601-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:38:47,208-0500 INFO  Multiplexer No streams
+2013-10-31 23:38:47,637-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:38:57,216-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:39:07,225-0500 INFO  Multiplexer No streams
+2013-10-31 23:39:10,676-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:39:17,232-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:39:27,240-0500 INFO  Multiplexer No streams
+2013-10-31 23:39:27,306-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:39:37,249-0500 INFO  Multiplexer No streams
+2013-10-31 23:39:40,751-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:39:47,257-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:39:57,265-0500 INFO  Multiplexer No streams
+2013-10-31 23:40:06,975-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:40:07,273-0500 INFO  Multiplexer No streams
+2013-10-31 23:40:10,826-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:40:17,281-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:40:27,289-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:40:37,298-0500 INFO  Multiplexer No streams
+2013-10-31 23:40:40,901-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:40:46,644-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:40:47,306-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:40:57,313-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:41:07,321-0500 INFO  Multiplexer No streams
+2013-10-31 23:41:10,976-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:41:17,329-0500 INFO  Multiplexer No streams
+2013-10-31 23:41:26,313-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:41:27,337-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:41:37,345-0500 INFO  Multiplexer No streams
+2013-10-31 23:41:41,051-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:41:47,354-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:41:57,362-0500 INFO  Multiplexer No streams
+2013-10-31 23:42:05,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:42:07,370-0500 INFO  Multiplexer No streams
+2013-10-31 23:42:11,126-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:42:17,378-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:42:27,386-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:42:37,394-0500 INFO  Multiplexer No streams
+2013-10-31 23:42:41,201-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:42:45,651-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:42:47,402-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:42:57,410-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:43:07,418-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-10-31 23:43:11,276-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 23:43:17,426-0500 INFO  Multiplexer No streams
+2013-10-31 23:43:25,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:43:27,434-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:43:37,442-0500 INFO  Multiplexer No streams
+2013-10-31 23:43:41,352-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:43:47,450-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:43:57,459-0500 INFO  Multiplexer No streams
+2013-10-31 23:44:04,989-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:44:07,467-0500 INFO  Multiplexer No streams
+2013-10-31 23:44:11,427-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:44:17,475-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:44:27,484-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:44:37,492-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 23:44:41,503-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-10-31 23:44:44,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:44:47,500-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:44:57,508-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:45:07,516-0500 INFO  Multiplexer No streams
+2013-10-31 23:45:11,578-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:45:17,523-0500 INFO  Multiplexer No streams
+2013-10-31 23:45:24,327-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:45:27,532-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:45:37,540-0500 INFO  Multiplexer No streams
+2013-10-31 23:45:41,653-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:45:47,548-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:45:57,556-0500 INFO  Multiplexer No streams
+2013-10-31 23:46:03,996-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:46:07,564-0500 INFO  Multiplexer No streams
+2013-10-31 23:46:11,728-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:46:17,572-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:46:27,580-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:46:37,587-0500 INFO  Multiplexer No streams
+2013-10-31 23:46:41,803-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:46:43,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:46:47,595-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:46:57,602-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:47:07,610-0500 INFO  Multiplexer No streams
+2013-10-31 23:47:11,878-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:47:17,617-0500 INFO  Multiplexer No streams
+2013-10-31 23:47:23,334-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:47:27,625-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:47:37,633-0500 INFO  Multiplexer No streams
+2013-10-31 23:47:41,953-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:47:47,640-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:47:57,648-0500 INFO  Multiplexer No streams
+2013-10-31 23:48:03,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:48:07,655-0500 INFO  Multiplexer No streams
+2013-10-31 23:48:12,028-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:48:17,662-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:48:27,670-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:48:37,677-0500 INFO  Multiplexer No streams
+2013-10-31 23:48:42,103-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:48:42,672-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:48:47,684-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:48:57,691-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:49:07,699-0500 INFO  Multiplexer No streams
+2013-10-31 23:49:12,178-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:49:17,706-0500 INFO  Multiplexer No streams
+2013-10-31 23:49:22,341-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:49:27,713-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:49:37,721-0500 INFO  Multiplexer No streams
+2013-10-31 23:49:42,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 23:49:47,729-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:49:57,737-0500 INFO  Multiplexer No streams
+2013-10-31 23:50:02,010-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:50:07,744-0500 INFO  Multiplexer No streams
+2013-10-31 23:50:12,328-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:50:17,752-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:50:27,760-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:50:37,767-0500 INFO  Multiplexer No streams
+2013-10-31 23:50:41,679-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:50:42,403-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:50:47,775-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:50:57,782-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:51:07,790-0500 INFO  Multiplexer No streams
+2013-10-31 23:51:12,478-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:51:17,797-0500 INFO  Multiplexer No streams
+2013-10-31 23:51:21,348-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:51:27,805-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:51:37,812-0500 INFO  Multiplexer No streams
+2013-10-31 23:51:42,553-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:51:47,820-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:51:57,827-0500 INFO  Multiplexer No streams
+2013-10-31 23:52:01,017-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:52:07,835-0500 INFO  Multiplexer No streams
+2013-10-31 23:52:12,628-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:52:17,842-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:52:27,850-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:52:37,858-0500 INFO  Multiplexer No streams
+2013-10-31 23:52:40,687-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:52:42,703-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:52:47,865-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:52:57,873-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:53:07,881-0500 INFO  Multiplexer No streams
+2013-10-31 23:53:12,777-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-10-31 23:53:17,888-0500 INFO  Multiplexer No streams
+2013-10-31 23:53:20,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:53:27,896-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:53:37,904-0500 INFO  Multiplexer No streams
+2013-10-31 23:53:42,853-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:53:47,911-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:53:57,919-0500 INFO  Multiplexer No streams
+2013-10-31 23:54:00,026-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:54:07,926-0500 INFO  Multiplexer No streams
+2013-10-31 23:54:12,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:54:17,934-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:54:27,942-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:54:37,950-0500 INFO  Multiplexer No streams
+2013-10-31 23:54:39,695-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-10-31 23:54:43,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:54:47,958-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:54:57,966-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:55:07,974-0500 INFO  Multiplexer No streams
+2013-10-31 23:55:13,079-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:55:17,982-0500 INFO  Multiplexer No streams
+2013-10-31 23:55:19,364-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:55:27,990-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:55:37,998-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:55:43,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:55:48,006-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:55:58,014-0500 INFO  Multiplexer No streams
+2013-10-31 23:55:59,033-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:56:08,021-0500 INFO  Multiplexer No streams
+2013-10-31 23:56:13,228-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:56:18,029-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:56:28,036-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:56:38,044-0500 INFO  Multiplexer No streams
+2013-10-31 23:56:38,702-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-10-31 23:56:43,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-10-31 23:56:48,052-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:56:58,060-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:57:08,068-0500 INFO  Multiplexer No streams
+2013-10-31 23:57:13,378-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:57:18,076-0500 INFO  Multiplexer No streams
+2013-10-31 23:57:18,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:57:28,084-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:57:38,091-0500 INFO  Multiplexer No streams
+2013-10-31 23:57:43,453-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:57:48,099-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-10-31 23:57:58,040-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-10-31 23:57:58,107-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:58:08,114-0500 INFO  Multiplexer No streams
+2013-10-31 23:58:13,528-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:58:18,122-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:58:28,130-0500 INFO  Multiplexer No streams
+2013-10-31 23:58:37,709-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:58:38,138-0500 INFO  Multiplexer No streams
+2013-10-31 23:58:43,603-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:58:48,146-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:58:58,153-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:59:08,161-0500 INFO  Multiplexer No streams
+2013-10-31 23:59:13,678-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-10-31 23:59:17,378-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-10-31 23:59:18,170-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:59:28,177-0500 INFO  Multiplexer No streams
+No streams
+2013-10-31 23:59:38,185-0500 INFO  Multiplexer No streams
+2013-10-31 23:59:43,753-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-10-31 23:59:48,193-0500 INFO  Multiplexer No streams
+2013-10-31 23:59:57,048-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-10-31 23:59:58,201-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:00:08,209-0500 INFO  Multiplexer No streams
+2013-11-01 00:00:13,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 00:00:18,217-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:00:28,225-0500 INFO  Multiplexer No streams
+2013-11-01 00:00:36,717-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:00:38,233-0500 INFO  Multiplexer No streams
+2013-11-01 00:00:43,904-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:00:48,241-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:00:58,248-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:01:08,256-0500 INFO  Multiplexer No streams
+2013-11-01 00:01:13,979-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:01:16,386-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:01:18,264-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:01:28,272-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:01:38,279-0500 INFO  Multiplexer No streams
+2013-11-01 00:01:44,054-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 00:01:48,287-0500 INFO  Multiplexer No streams
+2013-11-01 00:01:56,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:01:58,295-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:02:08,303-0500 INFO  Multiplexer No streams
+2013-11-01 00:02:14,130-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:02:18,311-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:02:28,318-0500 INFO  Multiplexer No streams
+2013-11-01 00:02:35,724-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:02:38,326-0500 INFO  Multiplexer No streams
+2013-11-01 00:02:44,205-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:02:48,335-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:02:58,347-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:03:08,360-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 00:03:14,281-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 00:03:15,393-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:03:18,373-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:03:28,387-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:03:38,396-0500 INFO  Multiplexer No streams
+2013-11-01 00:03:44,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:03:48,408-0500 INFO  Multiplexer No streams
+2013-11-01 00:03:55,062-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:03:58,424-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:04:08,435-0500 INFO  Multiplexer No streams
+2013-11-01 00:04:14,431-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:04:18,447-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:04:28,459-0500 INFO  Multiplexer No streams
+2013-11-01 00:04:34,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:04:38,467-0500 INFO  Multiplexer No streams
+2013-11-01 00:04:44,505-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:04:48,479-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:04:58,499-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:05:08,513-0500 INFO  Multiplexer No streams
+2013-11-01 00:05:14,400-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:05:14,581-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:05:18,523-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:05:28,535-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:05:38,550-0500 INFO  Multiplexer No streams
+2013-11-01 00:05:44,656-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:05:48,561-0500 INFO  Multiplexer No streams
+2013-11-01 00:05:54,070-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:05:58,570-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:06:08,589-0500 INFO  Multiplexer No streams
+2013-11-01 00:06:14,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:06:18,601-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:06:28,612-0500 INFO  Multiplexer No streams
+2013-11-01 00:06:33,739-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:06:38,623-0500 INFO  Multiplexer No streams
+2013-11-01 00:06:44,805-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:06:48,635-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:06:58,647-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:07:08,659-0500 INFO  Multiplexer No streams
+2013-11-01 00:07:13,408-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-11-01 00:07:14,880-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:07:18,671-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:07:28,683-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:07:38,696-0500 INFO  Multiplexer No streams
+2013-11-01 00:07:44,956-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:07:48,710-0500 INFO  Multiplexer No streams
+2013-11-01 00:07:53,076-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:07:58,723-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:08:08,734-0500 INFO  Multiplexer No streams
+2013-11-01 00:08:15,030-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:08:18,745-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:08:28,755-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-11-01 00:08:32,746-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:08:38,765-0500 INFO  Multiplexer No streams
+2013-11-01 00:08:45,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:08:48,775-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:08:58,785-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:09:08,794-0500 INFO  Multiplexer No streams
+2013-11-01 00:09:12,414-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:09:15,182-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 00:09:18,805-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:09:28,816-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:09:38,825-0500 INFO  Multiplexer No streams
+2013-11-01 00:09:45,256-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:09:48,833-0500 INFO  Multiplexer No streams
+2013-11-01 00:09:52,083-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:09:58,841-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:10:08,850-0500 INFO  Multiplexer No streams
+2013-11-01 00:10:15,332-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:10:18,858-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:10:28,867-0500 INFO  Multiplexer No streams
+2013-11-01 00:10:31,752-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:10:38,874-0500 INFO  Multiplexer No streams
-2013-10-28 15:56:35,348-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:10:45,407-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:10:48,882-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:10:58,890-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:11:08,897-0500 INFO  Multiplexer No streams
-2013-10-28 15:56:38,346-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:11:11,422-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:11:15,482-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:56:41,313-0500 INFO  Multiplexer No streams
+2013-11-01 00:11:18,905-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:56:51,320-0500 INFO  Multiplexer No streams
+2013-11-01 00:11:28,913-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:57:01,328-0500 INFO  Multiplexer No streams
+2013-11-01 00:11:38,920-0500 INFO  Multiplexer No streams
+2013-11-01 00:11:45,557-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:11:48,928-0500 INFO  Multiplexer No streams
+2013-11-01 00:11:51,091-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:11:58,936-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:12:08,943-0500 INFO  Multiplexer No streams
+2013-11-01 00:12:15,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 00:12:18,951-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:12:28,959-0500 INFO  Multiplexer No streams
+2013-11-01 00:12:30,761-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:12:38,966-0500 INFO  Multiplexer No streams
+2013-11-01 00:12:45,707-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:12:48,974-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:12:58,982-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:13:08,989-0500 INFO  Multiplexer No streams
+2013-11-01 00:13:10,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 00:13:15,782-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:13:18,997-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:13:29,005-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:13:39,012-0500 INFO  Multiplexer No streams
+2013-11-01 00:13:45,857-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:13:49,020-0500 INFO  Multiplexer No streams
+2013-11-01 00:13:50,099-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:13:59,028-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:14:09,036-0500 INFO  Multiplexer No streams
-2013-10-28 15:57:06,306-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:14:15,932-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:57:11,335-0500 INFO  Multiplexer No streams
+2013-11-01 00:14:19,043-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:14:29,051-0500 INFO  Multiplexer No streams
-2013-10-28 15:57:16,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:14:29,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:57:21,343-0500 INFO  Multiplexer No streams
+2013-11-01 00:14:39,059-0500 INFO  Multiplexer No streams
+2013-11-01 00:14:46,007-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:57:31,350-0500 INFO  Multiplexer No streams
+2013-11-01 00:14:49,066-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:14:59,074-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:15:09,082-0500 INFO  Multiplexer No streams
+2013-11-01 00:15:09,437-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:15:16,082-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:15:19,090-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:15:29,098-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:15:39,106-0500 INFO  Multiplexer No streams
+2013-11-01 00:15:46,158-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 00:15:49,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:15:49,114-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:15:59,121-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:16:09,129-0500 INFO  Multiplexer No streams
+2013-11-01 00:16:16,232-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:16:19,137-0500 INFO  Multiplexer No streams
+2013-11-01 00:16:28,775-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:16:29,145-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:16:39,152-0500 INFO  Multiplexer No streams
+2013-11-01 00:16:46,307-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:16:49,160-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:16:59,168-0500 INFO  Multiplexer No streams
+2013-11-01 00:17:08,444-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:17:09,176-0500 INFO  Multiplexer No streams
+2013-11-01 00:17:16,382-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:17:19,183-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:17:29,191-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:17:39,199-0500 INFO  Multiplexer No streams
+2013-11-01 00:17:46,458-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 00:17:48,113-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:17:49,207-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:17:59,214-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:18:09,222-0500 INFO  Multiplexer No streams
+2013-11-01 00:18:16,532-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:18:19,230-0500 INFO  Multiplexer No streams
+2013-11-01 00:18:27,782-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:18:29,238-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:18:39,246-0500 INFO  Multiplexer No streams
+2013-11-01 00:18:46,607-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:18:49,254-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:18:59,263-0500 INFO  Multiplexer No streams
+2013-11-01 00:19:07,451-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:19:09,271-0500 INFO  Multiplexer No streams
+2013-11-01 00:19:16,682-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:19:19,281-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:19:29,290-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:19:39,298-0500 INFO  Multiplexer No streams
+2013-11-01 00:19:46,758-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 00:19:47,119-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:19:49,306-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:19:59,314-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:20:09,323-0500 INFO  Multiplexer No streams
+2013-11-01 00:20:16,832-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:20:19,331-0500 INFO  Multiplexer No streams
+2013-11-01 00:20:26,788-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:20:29,339-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:20:39,347-0500 INFO  Multiplexer No streams
+2013-11-01 00:20:46,907-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:20:49,356-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:20:59,364-0500 INFO  Multiplexer No streams
+2013-11-01 00:21:06,458-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:21:09,372-0500 INFO  Multiplexer No streams
+2013-11-01 00:21:16,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:21:19,380-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:21:29,388-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:21:39,396-0500 INFO  Multiplexer No streams
+2013-11-01 00:21:46,127-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:21:47,057-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:21:49,404-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:21:59,412-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:22:09,420-0500 INFO  Multiplexer No streams
+2013-11-01 00:22:17,132-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 00:22:19,429-0500 INFO  Multiplexer No streams
+2013-11-01 00:22:25,796-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:22:29,437-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:22:39,445-0500 INFO  Multiplexer No streams
+2013-11-01 00:22:47,208-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 00:22:49,453-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:22:59,461-0500 INFO  Multiplexer No streams
+2013-11-01 00:23:05,465-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:23:09,469-0500 INFO  Multiplexer No streams
+2013-11-01 00:23:17,282-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:23:19,477-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:23:29,485-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:23:39,493-0500 INFO  Multiplexer No streams
+2013-11-01 00:23:45,135-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:23:47,357-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:23:49,501-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:23:59,509-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:24:09,517-0500 INFO  Multiplexer No streams
+2013-11-01 00:24:17,433-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:24:19,524-0500 INFO  Multiplexer No streams
+2013-11-01 00:24:24,804-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:24:29,532-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:24:39,540-0500 INFO  Multiplexer No streams
+2013-11-01 00:24:47,508-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:24:49,548-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:24:59,556-0500 INFO  Multiplexer No streams
+2013-11-01 00:25:04,475-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:25:09,564-0500 INFO  Multiplexer No streams
+2013-11-01 00:25:17,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:25:19,572-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:25:29,581-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:25:39,589-0500 INFO  Multiplexer No streams
+2013-11-01 00:25:44,143-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 00:25:47,658-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:25:49,596-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:25:59,604-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:26:09,612-0500 INFO  Multiplexer No streams
+2013-11-01 00:26:17,733-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:26:19,620-0500 INFO  Multiplexer No streams
+2013-11-01 00:26:23,812-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:26:29,629-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:26:39,637-0500 INFO  Multiplexer No streams
+2013-11-01 00:26:47,807-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 00:26:49,645-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:26:59,652-0500 INFO  Multiplexer No streams
+2013-11-01 00:27:03,481-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:27:09,660-0500 INFO  Multiplexer No streams
-2013-10-28 15:57:37,264-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:27:17,883-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:57:41,358-0500 INFO  Multiplexer No streams
+2013-11-01 00:27:19,668-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:57:51,365-0500 INFO  Multiplexer No streams
+2013-11-01 00:27:29,676-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:27:39,683-0500 INFO  Multiplexer No streams
-2013-10-28 15:57:54,734-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:27:43,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:27:47,958-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:58:01,373-0500 INFO  Multiplexer No streams
+2013-11-01 00:27:49,691-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:27:59,699-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:28:09,707-0500 INFO  Multiplexer No streams
-2013-10-28 15:58:08,222-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:28:18,033-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:58:11,380-0500 INFO  Multiplexer No streams
+2013-11-01 00:28:19,715-0500 INFO  Multiplexer No streams
+2013-11-01 00:28:22,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:58:21,388-0500 INFO  Multiplexer No streams
+2013-11-01 00:28:29,722-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:58:31,395-0500 INFO  Multiplexer No streams
+2013-11-01 00:28:39,730-0500 INFO  Multiplexer No streams
+2013-11-01 00:28:48,108-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:28:49,738-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:28:59,745-0500 INFO  Multiplexer No streams
+2013-11-01 00:29:02,489-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:29:09,753-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:29:18,183-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:29:19,760-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:29:29,768-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:29:39,775-0500 INFO  Multiplexer No streams
+2013-11-01 00:29:42,159-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 00:29:48,258-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:29:49,783-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:29:59,791-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:30:09,798-0500 INFO  Multiplexer No streams
+2013-11-01 00:30:18,333-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:30:19,806-0500 INFO  Multiplexer No streams
+2013-11-01 00:30:21,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:30:29,813-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:30:39,821-0500 INFO  Multiplexer No streams
+2013-11-01 00:30:48,408-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:30:49,828-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:30:59,836-0500 INFO  Multiplexer No streams
+2013-11-01 00:31:01,498-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:31:09,844-0500 INFO  Multiplexer No streams
+2013-11-01 00:31:18,483-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:31:19,852-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:31:29,860-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:31:39,868-0500 INFO  Multiplexer No streams
-2013-10-28 15:58:32,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:31:41,166-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:58:39,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:31:48,558-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:58:41,403-0500 INFO  Multiplexer No streams
+2013-11-01 00:31:49,876-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:58:51,410-0500 INFO  Multiplexer No streams
+2013-11-01 00:31:59,884-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:59:01,418-0500 INFO  Multiplexer No streams
+2013-11-01 00:32:09,892-0500 INFO  Multiplexer No streams
-2013-10-28 15:59:10,138-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:32:18,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:32:19,899-0500 INFO  Multiplexer No streams
-2013-10-28 15:59:11,122-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:32:20,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:59:11,425-0500 INFO  Multiplexer No streams
+2013-11-01 00:32:29,907-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 15:59:21,433-0500 INFO  Multiplexer No streams
+2013-11-01 00:32:39,915-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 00:32:48,709-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
 No streams
-2013-10-28 15:59:31,440-0500 INFO  Multiplexer No streams
+2013-11-01 00:32:49,923-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:32:59,931-0500 INFO  Multiplexer No streams
+2013-11-01 00:33:00,504-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:33:09,939-0500 INFO  Multiplexer No streams
+2013-11-01 00:33:18,784-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:33:19,947-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:33:29,955-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:33:39,963-0500 INFO  Multiplexer No streams
+2013-11-01 00:33:40,173-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 15:59:41,096-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:33:48,858-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 15:59:41,448-0500 INFO  Multiplexer No streams
+2013-11-01 00:33:49,971-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:33:59,979-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:34:09,987-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:18,934-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 15:59:49,316-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:34:19,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 15:59:51,455-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:19,995-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:00:01,463-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:30,003-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:00:11,470-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:40,010-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:49,009-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:34:50,018-0500 INFO  Multiplexer No streams
+2013-11-01 00:34:59,511-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:35:00,026-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:35:10,034-0500 INFO  Multiplexer No streams
+2013-11-01 00:35:19,084-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:35:20,042-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:35:30,050-0500 INFO  Multiplexer No streams
+2013-11-01 00:35:39,181-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:35:40,058-0500 INFO  Multiplexer No streams
+2013-11-01 00:35:49,159-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:35:50,066-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:36:00,074-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:36:10,082-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 00:36:18,850-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 00:36:19,235-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:36:20,090-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:36:30,098-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:36:40,106-0500 INFO  Multiplexer No streams
+2013-11-01 00:36:49,310-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:36:50,114-0500 INFO  Multiplexer No streams
+2013-11-01 00:36:58,520-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:37:00,122-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:37:10,130-0500 INFO  Multiplexer No streams
+2013-11-01 00:37:19,385-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:37:20,138-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:37:30,145-0500 INFO  Multiplexer No streams
+2013-11-01 00:37:38,188-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 00:37:40,153-0500 INFO  Multiplexer No streams
+2013-11-01 00:37:49,460-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:37:50,161-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:38:00,169-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:38:10,176-0500 INFO  Multiplexer No streams
+2013-11-01 00:38:17,857-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:38:19,536-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:38:20,184-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:38:30,192-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:38:40,200-0500 INFO  Multiplexer No streams
+2013-11-01 00:38:49,611-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:38:50,208-0500 INFO  Multiplexer No streams
+2013-11-01 00:38:57,526-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:39:00,216-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:39:10,223-0500 INFO  Multiplexer No streams
+2013-11-01 00:39:19,686-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:39:20,231-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:39:30,239-0500 INFO  Multiplexer No streams
+2013-11-01 00:39:37,195-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:39:40,247-0500 INFO  Multiplexer No streams
+2013-11-01 00:39:49,760-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 00:39:50,255-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:40:00,262-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:40:10,270-0500 INFO  Multiplexer No streams
+2013-11-01 00:40:16,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:40:19,836-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:40:20,278-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:40:30,286-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:40:40,294-0500 INFO  Multiplexer No streams
+2013-11-01 00:40:49,911-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:40:50,301-0500 INFO  Multiplexer No streams
+2013-11-01 00:40:56,533-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:41:00,309-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:41:10,317-0500 INFO  Multiplexer No streams
+2013-11-01 00:41:19,985-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 00:41:20,325-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:41:30,333-0500 INFO  Multiplexer No streams
+2013-11-01 00:41:36,202-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:41:40,341-0500 INFO  Multiplexer No streams
+2013-11-01 00:41:50,061-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:41:50,348-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:42:00,356-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:42:10,364-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 00:42:15,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 00:42:20,136-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:42:20,372-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:42:30,380-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:42:40,388-0500 INFO  Multiplexer No streams
+2013-11-01 00:42:50,211-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:42:50,396-0500 INFO  Multiplexer No streams
+2013-11-01 00:42:55,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:43:00,403-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:43:10,411-0500 INFO  Multiplexer No streams
+2013-11-01 00:43:20,285-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 00:43:20,419-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:43:30,427-0500 INFO  Multiplexer No streams
+2013-11-01 00:43:35,210-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:43:40,435-0500 INFO  Multiplexer No streams
+2013-11-01 00:43:50,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:43:50,443-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:44:00,451-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:44:10,459-0500 INFO  Multiplexer No streams
+2013-11-01 00:44:14,879-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 00:44:20,436-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:44:20,466-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:44:30,474-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:44:40,482-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:44:50,490-0500 INFO  Multiplexer No streams
+2013-11-01 00:44:50,510-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-11-01 00:44:54,548-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:45:00,498-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:45:10,506-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:45:20,514-0500 INFO  Multiplexer No streams
+2013-11-01 00:45:20,587-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:45:30,522-0500 INFO  Multiplexer No streams
+2013-11-01 00:45:34,217-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:45:40,530-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:45:50,538-0500 INFO  Multiplexer No streams
+2013-11-01 00:45:50,661-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:46:00,545-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:46:10,553-0500 INFO  Multiplexer No streams
+2013-11-01 00:46:13,886-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:46:20,561-0500 INFO  Multiplexer No streams
+2013-11-01 00:46:20,736-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:46:30,569-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:46:40,577-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:46:50,585-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 00:46:50,812-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 00:46:53,555-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:47:00,593-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:47:10,601-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:47:20,608-0500 INFO  Multiplexer No streams
+2013-11-01 00:47:20,887-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:47:30,616-0500 INFO  Multiplexer No streams
+2013-11-01 00:47:33,224-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:47:40,624-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:47:50,632-0500 INFO  Multiplexer No streams
+2013-11-01 00:47:50,962-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:48:00,640-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:48:10,648-0500 INFO  Multiplexer No streams
+2013-11-01 00:48:12,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 00:48:20,656-0500 INFO  Multiplexer No streams
+2013-11-01 00:48:21,037-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:48:30,664-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:48:40,672-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:48:50,679-0500 INFO  Multiplexer No streams
+2013-11-01 00:48:51,112-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:48:52,562-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:49:00,687-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:49:10,695-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:49:20,703-0500 INFO  Multiplexer No streams
+2013-11-01 00:49:21,187-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:49:30,711-0500 INFO  Multiplexer No streams
+2013-11-01 00:49:32,231-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:49:40,719-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:49:50,727-0500 INFO  Multiplexer No streams
+2013-11-01 00:49:51,262-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:50:00,734-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:50:10,742-0500 INFO  Multiplexer No streams
+2013-11-01 00:50:11,900-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:50:20,750-0500 INFO  Multiplexer No streams
+2013-11-01 00:50:21,338-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 00:50:30,758-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:50:40,765-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:50:50,773-0500 INFO  Multiplexer No streams
+2013-11-01 00:50:51,413-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:50:51,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:51:00,781-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:51:10,789-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:51:20,797-0500 INFO  Multiplexer No streams
+2013-11-01 00:51:21,488-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:51:30,805-0500 INFO  Multiplexer No streams
+2013-11-01 00:51:31,238-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:51:40,813-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:51:50,821-0500 INFO  Multiplexer No streams
+2013-11-01 00:51:51,563-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 00:52:00,829-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:52:10,836-0500 INFO  Multiplexer No streams
+2013-11-01 00:52:10,907-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:52:20,844-0500 INFO  Multiplexer No streams
+2013-11-01 00:52:21,638-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:52:30,852-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:52:40,859-0500 INFO  Multiplexer No streams
+2013-11-01 00:52:50,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:52:50,867-0500 INFO  Multiplexer No streams
+2013-11-01 00:52:51,713-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:53:00,875-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:53:10,882-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:53:20,890-0500 INFO  Multiplexer No streams
+2013-11-01 00:53:21,788-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 00:53:30,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:53:30,897-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:53:40,905-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:53:50,913-0500 INFO  Multiplexer No streams
+2013-11-01 00:53:51,864-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 00:54:00,920-0500 INFO  Multiplexer No streams
+2013-11-01 00:54:09,914-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:54:10,928-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:54:20,936-0500 INFO  Multiplexer No streams
+2013-11-01 00:54:21,939-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:54:30,944-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:54:40,952-0500 INFO  Multiplexer No streams
+2013-11-01 00:54:49,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:54:50,961-0500 INFO  Multiplexer No streams
+2013-11-01 00:54:52,014-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:55:00,968-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:55:10,977-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:55:20,985-0500 INFO  Multiplexer No streams
+2013-11-01 00:55:22,089-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 00:55:29,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:55:30,993-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:55:41,001-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:55:51,009-0500 INFO  Multiplexer No streams
+2013-11-01 00:55:52,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:56:01,017-0500 INFO  Multiplexer No streams
+2013-11-01 00:56:08,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:56:11,025-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:56:21,033-0500 INFO  Multiplexer No streams
+2013-11-01 00:56:22,239-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:56:31,041-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:56:41,049-0500 INFO  Multiplexer No streams
+2013-11-01 00:56:48,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:56:51,057-0500 INFO  Multiplexer No streams
+2013-11-01 00:56:52,314-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:57:01,066-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:57:11,074-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:57:21,082-0500 INFO  Multiplexer No streams
+2013-11-01 00:57:22,390-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 00:57:28,260-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 00:57:31,091-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:57:41,100-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:57:51,108-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 00:57:52,465-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:58:01,116-0500 INFO  Multiplexer No streams
+2013-11-01 00:58:07,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:58:11,125-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:58:21,133-0500 INFO  Multiplexer No streams
+2013-11-01 00:58:22,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 00:58:31,142-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:58:41,150-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 00:58:47,598-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 00:58:51,159-0500 INFO  Multiplexer No streams
+2013-11-01 00:58:52,615-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 00:59:01,171-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:59:11,181-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:59:21,192-0500 INFO  Multiplexer No streams
+2013-11-01 00:59:22,690-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 00:59:27,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 00:59:31,202-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:59:41,213-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 00:59:51,224-0500 INFO  Multiplexer No streams
+2013-11-01 00:59:52,765-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:00:01,234-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:00:06,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:00:11,245-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:00:21,255-0500 INFO  Multiplexer No streams
+2013-11-01 01:00:22,840-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:00:31,266-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:00:41,279-0500 INFO  Multiplexer No streams
+2013-11-01 01:00:46,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:00:51,285-0500 INFO  Multiplexer No streams
+2013-11-01 01:00:52,916-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:01:01,302-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:01:11,308-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:01:21,311-0500 INFO  Multiplexer No streams
+2013-11-01 01:01:22,990-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:01:26,275-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 01:01:31,321-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:01:41,328-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:01:51,330-0500 INFO  Multiplexer No streams
+2013-11-01 01:01:53,066-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:02:01,342-0500 INFO  Multiplexer No streams
+2013-11-01 01:02:05,943-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:02:11,351-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:02:21,363-0500 INFO  Multiplexer No streams
+2013-11-01 01:02:23,141-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:02:31,374-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:02:41,383-0500 INFO  Multiplexer No streams
+2013-11-01 01:02:45,613-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:02:51,393-0500 INFO  Multiplexer No streams
+2013-11-01 01:02:53,215-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:03:01,402-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:03:11,411-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:03:21,422-0500 INFO  Multiplexer No streams
+2013-11-01 01:03:23,290-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:03:25,282-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:03:31,431-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:03:41,440-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:03:51,450-0500 INFO  Multiplexer No streams
+2013-11-01 01:03:53,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:04:01,459-0500 INFO  Multiplexer No streams
+2013-11-01 01:04:04,952-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:04:11,467-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:04:21,477-0500 INFO  Multiplexer No streams
+2013-11-01 01:04:23,440-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:04:31,488-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:04:41,499-0500 INFO  Multiplexer No streams
+2013-11-01 01:04:44,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:04:51,507-0500 INFO  Multiplexer No streams
+2013-11-01 01:04:53,515-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:05:01,515-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:05:11,524-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:05:21,531-0500 INFO  Multiplexer No streams
+2013-11-01 01:05:23,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 01:05:24,289-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:05:31,539-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:05:41,547-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:05:51,556-0500 INFO  Multiplexer No streams
+2013-11-01 01:05:53,665-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:06:01,565-0500 INFO  Multiplexer No streams
+2013-11-01 01:06:03,959-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 01:06:11,573-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:06:21,582-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 01:06:23,741-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:06:31,592-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:06:41,603-0500 INFO  Multiplexer No streams
+2013-11-01 01:06:43,628-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:06:51,613-0500 INFO  Multiplexer No streams
+2013-11-01 01:06:53,815-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:07:01,623-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:07:11,635-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:07:21,646-0500 INFO  Multiplexer No streams
+2013-11-01 01:07:23,298-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-11-01 01:07:23,890-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:07:31,656-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:07:41,664-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:07:51,672-0500 INFO  Multiplexer No streams
+2013-11-01 01:07:53,966-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:08:01,680-0500 INFO  Multiplexer No streams
+2013-11-01 01:08:02,966-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:08:11,688-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:08:21,696-0500 INFO  Multiplexer No streams
+2013-11-01 01:08:24,040-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:08:31,704-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:08:41,712-0500 INFO  Multiplexer No streams
+2013-11-01 01:08:42,636-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:08:51,720-0500 INFO  Multiplexer No streams
+2013-11-01 01:08:54,115-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:09:01,728-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:09:11,737-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:09:21,745-0500 INFO  Multiplexer No streams
+2013-11-01 01:09:22,304-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:09:24,191-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:09:31,755-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:09:41,763-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:09:51,773-0500 INFO  Multiplexer No streams
+2013-11-01 01:09:54,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:10:01,785-0500 INFO  Multiplexer No streams
+2013-11-01 01:10:01,973-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:10:11,796-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:10:21,805-0500 INFO  Multiplexer No streams
+2013-11-01 01:10:24,340-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:10:31,815-0500 INFO  Multiplexer No streams
+2013-11-01 01:10:41,642-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:10:41,825-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:10:51,836-0500 INFO  Multiplexer No streams
+2013-11-01 01:10:54,416-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:11:01,845-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:11:11,856-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-11-01 01:11:21,312-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:11:21,866-0500 INFO  Multiplexer No streams
+2013-11-01 01:11:24,490-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:11:31,875-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:11:41,885-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:11:51,894-0500 INFO  Multiplexer No streams
+2013-11-01 01:11:54,565-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:12:00,981-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:12:01,903-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:12:11,913-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:12:21,923-0500 INFO  Multiplexer No streams
+2013-11-01 01:12:24,641-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:12:31,933-0500 INFO  Multiplexer No streams
+2013-11-01 01:12:40,649-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:12:41,944-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:12:51,954-0500 INFO  Multiplexer No streams
+2013-11-01 01:12:54,716-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:13:01,963-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:13:11,972-0500 INFO  Multiplexer No streams
+2013-11-01 01:13:20,318-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:13:21,981-0500 INFO  Multiplexer No streams
+2013-11-01 01:13:24,790-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:13:31,990-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:13:41,998-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:13:52,007-0500 INFO  Multiplexer No streams
+2013-11-01 01:13:54,865-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:13:59,987-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:14:02,016-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:14:12,025-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:14:22,034-0500 INFO  Multiplexer No streams
+2013-11-01 01:14:24,940-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:14:32,043-0500 INFO  Multiplexer No streams
+2013-11-01 01:14:39,657-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:14:42,051-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:14:52,059-0500 INFO  Multiplexer No streams
+2013-11-01 01:14:55,016-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:15:02,067-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:15:12,076-0500 INFO  Multiplexer No streams
+2013-11-01 01:15:19,325-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:15:22,085-0500 INFO  Multiplexer No streams
+2013-11-01 01:15:25,090-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:15:32,094-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:15:42,102-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:15:52,110-0500 INFO  Multiplexer No streams
+2013-11-01 01:15:55,165-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:15:58,994-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:16:02,118-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:16:12,127-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:16:22,137-0500 INFO  Multiplexer No streams
+2013-11-01 01:16:25,240-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:16:32,148-0500 INFO  Multiplexer No streams
+2013-11-01 01:16:38,663-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:16:42,158-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:16:52,167-0500 INFO  Multiplexer No streams
+2013-11-01 01:16:55,316-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:17:02,176-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:17:12,186-0500 INFO  Multiplexer No streams
+2013-11-01 01:17:18,333-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:17:22,196-0500 INFO  Multiplexer No streams
+2013-11-01 01:17:25,392-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:17:32,205-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:17:42,214-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:17:52,224-0500 INFO  Multiplexer No streams
+2013-11-01 01:17:55,468-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:17:58,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:18:02,233-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:18:12,242-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:18:22,253-0500 INFO  Multiplexer No streams
+2013-11-01 01:18:25,542-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:18:32,263-0500 INFO  Multiplexer No streams
+2013-11-01 01:18:37,670-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:18:42,272-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:18:52,285-0500 INFO  Multiplexer No streams
+2013-11-01 01:18:55,618-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:19:02,294-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:19:12,302-0500 INFO  Multiplexer No streams
+2013-11-01 01:19:17,340-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:19:22,311-0500 INFO  Multiplexer No streams
+2013-11-01 01:19:25,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:19:32,319-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:19:42,327-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:19:52,335-0500 INFO  Multiplexer No streams
+2013-11-01 01:19:55,769-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 01:19:57,008-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:20:02,343-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:20:12,350-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:20:22,358-0500 INFO  Multiplexer No streams
+2013-11-01 01:20:25,843-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:20:32,366-0500 INFO  Multiplexer No streams
+2013-11-01 01:20:36,677-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:20:42,373-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:20:52,381-0500 INFO  Multiplexer No streams
+2013-11-01 01:20:55,918-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:21:02,388-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:21:12,396-0500 INFO  Multiplexer No streams
+2013-11-01 01:21:16,347-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:21:22,404-0500 INFO  Multiplexer No streams
+2013-11-01 01:21:25,993-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:21:32,412-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:21:42,420-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:21:52,430-0500 INFO  Multiplexer No streams
+2013-11-01 01:21:56,015-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 01:21:56,068-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:22:02,439-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:22:12,453-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:22:22,454-0500 INFO  Multiplexer No streams
+2013-11-01 01:22:26,143-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:22:32,455-0500 INFO  Multiplexer No streams
+2013-11-01 01:22:35,684-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:22:42,457-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:22:52,476-0500 INFO  Multiplexer No streams
+2013-11-01 01:22:56,219-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:23:02,485-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:23:12,497-0500 INFO  Multiplexer No streams
+2013-11-01 01:23:15,353-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:23:22,507-0500 INFO  Multiplexer No streams
+2013-11-01 01:23:26,293-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:23:32,518-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:23:42,529-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:23:52,539-0500 INFO  Multiplexer No streams
+2013-11-01 01:23:55,023-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 01:23:56,369-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 01:24:02,550-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:24:12,561-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:24:22,572-0500 INFO  Multiplexer No streams
+2013-11-01 01:24:26,444-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:24:32,583-0500 INFO  Multiplexer No streams
+2013-11-01 01:24:34,691-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:24:42,602-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:24:52,616-0500 INFO  Multiplexer No streams
+2013-11-01 01:24:56,519-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:25:02,623-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:25:12,637-0500 INFO  Multiplexer No streams
+2013-11-01 01:25:14,361-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:25:22,647-0500 INFO  Multiplexer No streams
+2013-11-01 01:25:26,594-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:25:32,655-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:25:42,664-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:25:52,673-0500 INFO  Multiplexer No streams
+2013-11-01 01:25:54,030-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:25:56,670-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:26:02,683-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:26:12,691-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:26:22,699-0500 INFO  Multiplexer No streams
+2013-11-01 01:26:26,744-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:26:32,714-0500 INFO  Multiplexer No streams
+2013-11-01 01:26:33,699-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:26:42,724-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:26:52,736-0500 INFO  Multiplexer No streams
+2013-11-01 01:26:56,820-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:27:02,747-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:27:12,758-0500 INFO  Multiplexer No streams
+2013-11-01 01:27:13,368-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:27:22,772-0500 INFO  Multiplexer No streams
+2013-11-01 01:27:26,894-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:27:32,789-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:27:42,803-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:27:52,812-0500 INFO  Multiplexer No streams
+2013-11-01 01:27:53,037-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 01:27:56,969-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:28:02,820-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:28:12,834-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:28:22,844-0500 INFO  Multiplexer No streams
+2013-11-01 01:28:27,045-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 01:28:32,706-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:28:32,854-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:28:42,864-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:28:52,873-0500 INFO  Multiplexer No streams
+2013-11-01 01:28:57,119-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:29:02,884-0500 INFO  Multiplexer No streams
+2013-11-01 01:29:12,376-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:29:12,893-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:29:22,902-0500 INFO  Multiplexer No streams
+2013-11-01 01:29:27,194-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:29:32,912-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:29:42,922-0500 INFO  Multiplexer No streams
+2013-11-01 01:29:52,044-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:29:52,931-0500 INFO  Multiplexer No streams
+2013-11-01 01:29:57,269-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:30:02,942-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:30:12,953-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:30:22,971-0500 INFO  Multiplexer No streams
+2013-11-01 01:30:27,345-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 01:30:31,714-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:30:32,991-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:30:43,008-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:30:53,017-0500 INFO  Multiplexer No streams
+2013-11-01 01:30:57,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:31:03,037-0500 INFO  Multiplexer No streams
+2013-11-01 01:31:11,383-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:31:13,054-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:31:23,072-0500 INFO  Multiplexer No streams
+2013-11-01 01:31:27,496-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:31:33,091-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:31:43,099-0500 INFO  Multiplexer No streams
+2013-11-01 01:31:51,051-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:31:53,107-0500 INFO  Multiplexer No streams
+2013-11-01 01:31:57,570-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:32:03,116-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:32:13,126-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:32:23,134-0500 INFO  Multiplexer No streams
+2013-11-01 01:32:27,645-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:32:30,720-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:32:33,142-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:32:43,150-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:32:53,158-0500 INFO  Multiplexer No streams
+2013-11-01 01:32:57,721-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:33:03,166-0500 INFO  Multiplexer No streams
+2013-11-01 01:33:10,389-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:33:13,173-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:33:23,182-0500 INFO  Multiplexer No streams
+2013-11-01 01:33:27,795-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:33:33,183-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:33:43,193-0500 INFO  Multiplexer No streams
+2013-11-01 01:33:50,058-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:33:53,202-0500 INFO  Multiplexer No streams
+2013-11-01 01:33:57,871-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:34:03,211-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:34:13,221-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:34:23,230-0500 INFO  Multiplexer No streams
+2013-11-01 01:34:27,945-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:34:29,728-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:34:33,243-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:34:43,253-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:34:53,264-0500 INFO  Multiplexer No streams
+2013-11-01 01:34:58,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:35:03,274-0500 INFO  Multiplexer No streams
+2013-11-01 01:35:09,397-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:35:13,285-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:35:23,293-0500 INFO  Multiplexer No streams
+2013-11-01 01:35:28,095-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:35:33,305-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:35:43,316-0500 INFO  Multiplexer No streams
+2013-11-01 01:35:49,066-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:35:53,327-0500 INFO  Multiplexer No streams
+2013-11-01 01:35:58,170-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:36:03,337-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:36:13,346-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:36:23,355-0500 INFO  Multiplexer No streams
+2013-11-01 01:36:28,246-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 01:36:28,735-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:36:33,365-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:36:43,373-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:36:53,383-0500 INFO  Multiplexer No streams
+2013-11-01 01:36:58,320-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:37:03,392-0500 INFO  Multiplexer No streams
+2013-11-01 01:37:08,405-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:37:13,403-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:37:23,413-0500 INFO  Multiplexer No streams
+2013-11-01 01:37:28,395-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:37:33,422-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:37:43,432-0500 INFO  Multiplexer No streams
+2013-11-01 01:37:48,075-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:37:53,442-0500 INFO  Multiplexer No streams
+2013-11-01 01:37:58,471-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:38:03,451-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:38:13,460-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:38:23,469-0500 INFO  Multiplexer No streams
+2013-11-01 01:38:27,744-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:38:28,545-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:38:33,478-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:38:43,488-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:38:53,498-0500 INFO  Multiplexer No streams
+2013-11-01 01:38:58,620-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:39:03,509-0500 INFO  Multiplexer No streams
+2013-11-01 01:39:07,413-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:39:13,518-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:39:23,527-0500 INFO  Multiplexer No streams
+2013-11-01 01:39:28,696-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 01:39:33,543-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:39:43,558-0500 INFO  Multiplexer No streams
+2013-11-01 01:39:47,082-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:39:53,569-0500 INFO  Multiplexer No streams
+2013-11-01 01:39:58,770-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:40:03,580-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:40:13,594-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:40:23,606-0500 INFO  Multiplexer No streams
+2013-11-01 01:40:26,752-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+2013-11-01 01:40:28,845-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:40:33,626-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:40:43,638-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:40:53,651-0500 INFO  Multiplexer No streams
+2013-11-01 01:40:58,920-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:41:03,665-0500 INFO  Multiplexer No streams
+2013-11-01 01:41:06,420-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:41:13,676-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:41:23,687-0500 INFO  Multiplexer No streams
+2013-11-01 01:41:28,995-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:41:33,695-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:41:43,703-0500 INFO  Multiplexer No streams
+2013-11-01 01:41:46,090-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:41:53,711-0500 INFO  Multiplexer No streams
+2013-11-01 01:41:59,070-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:42:03,719-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:42:13,727-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:42:23,735-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 01:42:25,758-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 01:42:29,145-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:42:33,743-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:42:43,751-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:42:53,759-0500 INFO  Multiplexer No streams
+2013-11-01 01:42:59,220-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:43:03,767-0500 INFO  Multiplexer No streams
+2013-11-01 01:43:05,427-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:43:13,775-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:43:23,783-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-11-01 01:43:29,295-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 01:43:33,791-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:43:43,799-0500 INFO  Multiplexer No streams
+2013-11-01 01:43:45,097-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:43:53,807-0500 INFO  Multiplexer No streams
+2013-11-01 01:43:59,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:44:03,815-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:44:13,823-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:44:23,831-0500 INFO  Multiplexer No streams
+2013-11-01 01:44:24,765-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+2013-11-01 01:44:29,446-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:44:33,839-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:44:43,847-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:44:53,855-0500 INFO  Multiplexer No streams
+2013-11-01 01:44:59,521-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:45:03,863-0500 INFO  Multiplexer No streams
+2013-11-01 01:45:04,435-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 2ms
+No streams
+2013-11-01 01:45:13,871-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:45:23,878-0500 INFO  Multiplexer No streams
+2013-11-01 01:45:29,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 01:45:33,886-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:45:43,894-0500 INFO  Multiplexer No streams
+2013-11-01 01:45:44,103-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:45:53,902-0500 INFO  Multiplexer No streams
+2013-11-01 01:45:59,672-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:46:03,910-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:46:13,918-0500 INFO  Multiplexer No streams
+2013-11-01 01:46:23,772-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:46:23,926-0500 INFO  Multiplexer No streams
+2013-11-01 01:46:29,747-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:46:33,934-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:46:43,942-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:46:53,950-0500 INFO  Multiplexer No streams
+2013-11-01 01:46:59,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:47:03,441-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:47:03,958-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:47:13,965-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:47:23,973-0500 INFO  Multiplexer No streams
 TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-10-28 16:00:12,053-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 01:47:29,896-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:00:21,478-0500 INFO  Multiplexer No streams
+2013-11-01 01:47:33,981-0500 INFO  Multiplexer No streams
+2013-11-01 01:47:43,111-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:47:43,989-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:47:53,997-0500 INFO  Multiplexer No streams
+2013-11-01 01:47:59,972-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:48:04,005-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:48:14,013-0500 INFO  Multiplexer No streams
-2013-10-28 16:00:27,511-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:48:22,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:00:31,485-0500 INFO  Multiplexer No streams
+2013-11-01 01:48:24,021-0500 INFO  Multiplexer No streams
+2013-11-01 01:48:30,047-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 16:00:41,493-0500 INFO  Multiplexer No streams
+2013-11-01 01:48:34,029-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:48:44,036-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:48:54,044-0500 INFO  Multiplexer No streams
+2013-11-01 01:49:00,122-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:49:02,448-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: -1ms, rtt: 1ms
+No streams
+2013-11-01 01:49:04,052-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:49:14,060-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:49:24,068-0500 INFO  Multiplexer No streams
+2013-11-01 01:49:30,197-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:49:34,076-0500 INFO  Multiplexer No streams
+2013-11-01 01:49:42,117-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:49:44,083-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:49:54,091-0500 INFO  Multiplexer No streams
+2013-11-01 01:50:00,272-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 01:50:04,099-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:50:14,107-0500 INFO  Multiplexer No streams
+2013-11-01 01:50:21,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:50:24,115-0500 INFO  Multiplexer No streams
+2013-11-01 01:50:30,347-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:50:34,122-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:50:44,130-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:50:54,138-0500 INFO  Multiplexer No streams
+2013-11-01 01:51:00,422-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 01:51:01,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:51:04,146-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:51:14,154-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:51:24,160-0500 INFO  Multiplexer No streams
+2013-11-01 01:51:30,497-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:51:34,168-0500 INFO  Multiplexer No streams
+2013-11-01 01:51:41,124-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:51:44,176-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:51:54,184-0500 INFO  Multiplexer No streams
+2013-11-01 01:52:00,572-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:52:04,192-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:52:14,200-0500 INFO  Multiplexer No streams
+2013-11-01 01:52:20,793-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:52:24,208-0500 INFO  Multiplexer No streams
+2013-11-01 01:52:30,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:52:34,216-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:52:44,224-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:52:54,232-0500 INFO  Multiplexer No streams
+2013-11-01 01:53:00,462-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:53:00,722-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:53:04,240-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:53:14,248-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:53:24,255-0500 INFO  Multiplexer No streams
+2013-11-01 01:53:30,797-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:53:34,263-0500 INFO  Multiplexer No streams
+2013-11-01 01:53:40,131-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:53:44,271-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:53:54,279-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 01:54:00,873-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 01:54:04,288-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:54:14,296-0500 INFO  Multiplexer No streams
+2013-11-01 01:54:19,800-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:54:24,304-0500 INFO  Multiplexer No streams
+2013-11-01 01:54:30,947-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:54:34,312-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:54:44,319-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:54:54,327-0500 INFO  Multiplexer No streams
+2013-11-01 01:54:59,469-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:55:01,022-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:55:04,335-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:55:14,343-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:55:24,351-0500 INFO  Multiplexer No streams
+2013-11-01 01:55:31,097-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:55:34,360-0500 INFO  Multiplexer No streams
+2013-11-01 01:55:39,138-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:55:44,367-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:55:54,375-0500 INFO  Multiplexer No streams
+2013-11-01 01:56:01,172-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:56:04,383-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:56:14,391-0500 INFO  Multiplexer No streams
+2013-11-01 01:56:18,807-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:56:24,400-0500 INFO  Multiplexer No streams
+2013-11-01 01:56:31,247-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:56:34,408-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:56:44,415-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:56:54,423-0500 INFO  Multiplexer No streams
+2013-11-01 01:56:58,476-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:57:01,322-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:57:04,431-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:57:14,439-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:57:24,447-0500 INFO  Multiplexer No streams
+2013-11-01 01:57:31,397-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:57:34,455-0500 INFO  Multiplexer No streams
+2013-11-01 01:57:38,145-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:57:44,463-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:57:54,471-0500 INFO  Multiplexer No streams
+2013-11-01 01:58:01,472-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:58:04,479-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:58:14,487-0500 INFO  Multiplexer No streams
+2013-11-01 01:58:17,814-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:58:24,495-0500 INFO  Multiplexer No streams
+2013-11-01 01:58:31,546-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 01:58:34,502-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:58:44,510-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:58:54,519-0500 INFO  Multiplexer No streams
+2013-11-01 01:58:57,483-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 01:59:01,622-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:59:04,526-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:59:14,534-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:59:24,543-0500 INFO  Multiplexer No streams
+2013-11-01 01:59:31,697-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 01:59:34,550-0500 INFO  Multiplexer No streams
+2013-11-01 01:59:37,152-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 01:59:44,558-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 01:59:54,566-0500 INFO  Multiplexer No streams
+2013-11-01 02:00:01,772-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:00:04,574-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:00:14,582-0500 INFO  Multiplexer No streams
+2013-11-01 02:00:16,821-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:00:24,589-0500 INFO  Multiplexer No streams
+2013-11-01 02:00:31,847-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:00:34,598-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:00:44,606-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:00:54,614-0500 INFO  Multiplexer No streams
+2013-11-01 02:00:56,490-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:01:01,922-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:01:04,622-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:01:14,630-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:01:24,638-0500 INFO  Multiplexer No streams
+2013-11-01 02:01:31,997-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:01:34,646-0500 INFO  Multiplexer No streams
+2013-11-01 02:01:36,159-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:01:44,654-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:01:54,662-0500 INFO  Multiplexer No streams
+2013-11-01 02:02:02,072-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:02:04,669-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:02:14,677-0500 INFO  Multiplexer No streams
+2013-11-01 02:02:15,828-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:02:24,685-0500 INFO  Multiplexer No streams
+2013-11-01 02:02:32,147-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:02:34,693-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:02:44,701-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:02:54,709-0500 INFO  Multiplexer No streams
+2013-11-01 02:02:55,497-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:03:02,222-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:03:04,720-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:03:14,728-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:03:24,736-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:03:32,297-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:03:34,744-0500 INFO  Multiplexer No streams
+2013-11-01 02:03:35,166-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:03:44,752-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:03:54,761-0500 INFO  Multiplexer No streams
+2013-11-01 02:04:02,372-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:04:04,768-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:04:14,776-0500 INFO  Multiplexer No streams
+2013-11-01 02:04:14,835-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:04:24,785-0500 INFO  Multiplexer No streams
+2013-11-01 02:04:32,447-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:04:34,792-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:04:44,800-0500 INFO  Multiplexer No streams
+2013-11-01 02:04:54,504-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:04:54,808-0500 INFO  Multiplexer No streams
+2013-11-01 02:05:02,522-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:05:04,816-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:05:14,823-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:05:24,831-0500 INFO  Multiplexer No streams
+2013-11-01 02:05:32,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:05:34,173-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:05:34,841-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:05:44,848-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:05:54,856-0500 INFO  Multiplexer No streams
+2013-11-01 02:06:02,672-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:06:04,865-0500 INFO  Multiplexer No streams
+2013-11-01 02:06:13,842-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:06:14,872-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:06:24,881-0500 INFO  Multiplexer No streams
+2013-11-01 02:06:32,747-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:06:34,889-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:06:44,896-0500 INFO  Multiplexer No streams
+2013-11-01 02:06:53,511-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:06:54,905-0500 INFO  Multiplexer No streams
+2013-11-01 02:07:02,822-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:07:04,912-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:07:14,920-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:07:24,928-0500 INFO  Multiplexer No streams
+2013-11-01 02:07:32,897-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:07:33,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:07:34,936-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:07:44,944-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:07:54,951-0500 INFO  Multiplexer No streams
+2013-11-01 02:08:02,972-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:08:04,960-0500 INFO  Multiplexer No streams
+2013-11-01 02:08:12,849-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:08:14,968-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:08:24,976-0500 INFO  Multiplexer No streams
+2013-11-01 02:08:33,047-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:08:34,983-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:08:44,991-0500 INFO  Multiplexer No streams
+2013-11-01 02:08:52,518-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:08:55,000-0500 INFO  Multiplexer No streams
+2013-11-01 02:09:03,122-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:09:05,007-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:09:15,015-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:09:25,022-0500 INFO  Multiplexer No streams
+2013-11-01 02:09:32,187-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:09:33,197-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:09:35,030-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:09:45,038-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:09:55,045-0500 INFO  Multiplexer No streams
+2013-11-01 02:10:03,272-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:10:05,053-0500 INFO  Multiplexer No streams
+2013-11-01 02:10:11,856-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:10:15,061-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:10:25,068-0500 INFO  Multiplexer No streams
+2013-11-01 02:10:33,347-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:10:35,077-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:10:45,085-0500 INFO  Multiplexer No streams
+2013-11-01 02:10:51,525-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:10:55,093-0500 INFO  Multiplexer No streams
+2013-11-01 02:11:03,421-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:11:05,100-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:11:15,108-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:11:25,116-0500 INFO  Multiplexer No streams
+2013-11-01 02:11:31,194-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:11:33,497-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:11:35,124-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:11:45,132-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:11:55,140-0500 INFO  Multiplexer No streams
+2013-11-01 02:12:03,572-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:12:05,149-0500 INFO  Multiplexer No streams
+2013-11-01 02:12:10,863-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:12:15,156-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:12:25,164-0500 INFO  Multiplexer No streams
+2013-11-01 02:12:33,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:12:35,172-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:12:45,180-0500 INFO  Multiplexer No streams
+2013-11-01 02:12:50,532-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:12:55,188-0500 INFO  Multiplexer No streams
+2013-11-01 02:13:03,722-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:13:05,196-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:13:15,204-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:13:25,212-0500 INFO  Multiplexer No streams
+2013-11-01 02:13:30,201-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:13:33,798-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:13:35,220-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:13:45,227-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:13:55,236-0500 INFO  Multiplexer No streams
+2013-11-01 02:14:03,873-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:14:05,245-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:14:09,870-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:14:15,252-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:14:25,260-0500 INFO  Multiplexer No streams
+2013-11-01 02:14:33,948-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:14:35,268-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:14:45,276-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 02:14:49,539-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:14:55,285-0500 INFO  Multiplexer No streams
+2013-11-01 02:15:04,023-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:15:05,293-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:15:15,301-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:15:25,308-0500 INFO  Multiplexer No streams
+2013-11-01 02:15:29,209-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:15:34,098-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:15:35,317-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:15:45,325-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:15:55,333-0500 INFO  Multiplexer No streams
+2013-11-01 02:16:04,172-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:16:05,341-0500 INFO  Multiplexer No streams
+2013-11-01 02:16:08,878-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:16:15,349-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:16:25,357-0500 INFO  Multiplexer No streams
+2013-11-01 02:16:34,248-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:16:35,365-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:16:45,373-0500 INFO  Multiplexer No streams
+2013-11-01 02:16:48,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:16:55,381-0500 INFO  Multiplexer No streams
+2013-11-01 02:17:04,323-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:17:05,389-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:17:15,397-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:17:25,405-0500 INFO  Multiplexer No streams
+2013-11-01 02:17:28,216-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:17:34,398-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:17:35,413-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:17:45,421-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:17:55,429-0500 INFO  Multiplexer No streams
+2013-11-01 02:18:04,473-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:18:05,438-0500 INFO  Multiplexer No streams
+2013-11-01 02:18:07,885-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:18:15,446-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:18:25,454-0500 INFO  Multiplexer No streams
+2013-11-01 02:18:34,548-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:18:35,462-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:18:45,469-0500 INFO  Multiplexer No streams
+2013-11-01 02:18:47,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:18:55,479-0500 INFO  Multiplexer No streams
+2013-11-01 02:19:04,623-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:19:05,487-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:19:15,495-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:19:25,503-0500 INFO  Multiplexer No streams
+2013-11-01 02:19:27,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 02:19:34,698-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:19:35,511-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:19:45,519-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:19:55,527-0500 INFO  Multiplexer No streams
+2013-11-01 02:20:04,774-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:20:05,535-0500 INFO  Multiplexer No streams
+2013-11-01 02:20:06,893-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:20:15,543-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:20:25,551-0500 INFO  Multiplexer No streams
+2013-11-01 02:20:34,849-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:20:35,560-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:20:45,568-0500 INFO  Multiplexer No streams
+2013-11-01 02:20:46,562-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:20:55,576-0500 INFO  Multiplexer No streams
+2013-11-01 02:21:04,924-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:21:05,583-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:21:15,591-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:21:25,599-0500 INFO  Multiplexer No streams
+2013-11-01 02:21:26,231-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:21:35,000-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:21:35,607-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:21:45,615-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:21:55,623-0500 INFO  Multiplexer No streams
+2013-11-01 02:22:05,075-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:22:05,631-0500 INFO  Multiplexer No streams
+2013-11-01 02:22:05,900-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:22:15,639-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:22:25,647-0500 INFO  Multiplexer No streams
+2013-11-01 02:22:35,151-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:22:35,655-0500 INFO  Multiplexer No streams
+2013-11-01 02:22:45,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:22:45,663-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:22:55,671-0500 INFO  Multiplexer No streams
+2013-11-01 02:23:05,226-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:23:05,678-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:23:15,686-0500 INFO  Multiplexer No streams
+2013-11-01 02:23:25,238-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:23:25,694-0500 INFO  Multiplexer No streams
+2013-11-01 02:23:35,301-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:23:35,702-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:23:45,710-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:23:55,718-0500 INFO  Multiplexer No streams
+2013-11-01 02:24:04,907-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:24:05,376-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:24:05,726-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:24:15,734-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:24:25,742-0500 INFO  Multiplexer No streams
+2013-11-01 02:24:35,451-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:24:35,750-0500 INFO  Multiplexer No streams
+2013-11-01 02:24:44,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:24:45,758-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:24:55,766-0500 INFO  Multiplexer No streams
+2013-11-01 02:25:05,526-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:25:05,774-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:25:15,781-0500 INFO  Multiplexer No streams
+2013-11-01 02:25:24,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:25:25,790-0500 INFO  Multiplexer No streams
+2013-11-01 02:25:35,601-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:25:35,797-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:25:45,805-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:25:55,813-0500 INFO  Multiplexer No streams
+2013-11-01 02:26:03,914-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:26:05,676-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:26:05,821-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:26:15,829-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:26:25,837-0500 INFO  Multiplexer No streams
+2013-11-01 02:26:35,751-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:26:35,845-0500 INFO  Multiplexer No streams
+2013-11-01 02:26:43,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:26:45,853-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:26:55,861-0500 INFO  Multiplexer No streams
+2013-11-01 02:27:05,826-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:27:05,869-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:27:15,877-0500 INFO  Multiplexer No streams
+2013-11-01 02:27:23,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:27:25,885-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:27:35,892-0500 INFO  Multiplexer No streams
+2013-11-01 02:27:35,901-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:27:45,900-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:27:55,908-0500 INFO  Multiplexer No streams
+2013-11-01 02:28:02,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:28:05,917-0500 INFO  Multiplexer No streams
+2013-11-01 02:28:05,976-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:28:15,925-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:28:25,933-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:28:35,941-0500 INFO  Multiplexer No streams
+2013-11-01 02:28:36,051-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:28:42,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:28:45,949-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:28:55,957-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:29:05,965-0500 INFO  Multiplexer No streams
+2013-11-01 02:29:06,126-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:29:15,973-0500 INFO  Multiplexer No streams
+2013-11-01 02:29:22,259-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:29:25,981-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:29:35,989-0500 INFO  Multiplexer No streams
+2013-11-01 02:29:36,201-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:29:45,998-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:29:56,005-0500 INFO  Multiplexer No streams
+2013-11-01 02:30:01,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:30:06,014-0500 INFO  Multiplexer No streams
+2013-11-01 02:30:06,276-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:30:16,022-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:30:26,029-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:30:36,037-0500 INFO  Multiplexer No streams
+2013-11-01 02:30:36,351-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:30:41,596-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:30:46,046-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:30:56,054-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:31:06,062-0500 INFO  Multiplexer No streams
+2013-11-01 02:31:06,425-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:31:16,070-0500 INFO  Multiplexer No streams
+2013-11-01 02:31:21,266-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:31:26,078-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:31:36,086-0500 INFO  Multiplexer No streams
+2013-11-01 02:31:36,501-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:31:46,094-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:31:56,102-0500 INFO  Multiplexer No streams
+2013-11-01 02:32:00,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:32:06,110-0500 INFO  Multiplexer No streams
+2013-11-01 02:32:06,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:32:16,118-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:32:26,126-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:32:36,134-0500 INFO  Multiplexer No streams
+2013-11-01 02:32:36,651-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:32:40,604-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:32:46,142-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:32:56,150-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:33:06,158-0500 INFO  Multiplexer No streams
+2013-11-01 02:33:06,726-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:33:16,166-0500 INFO  Multiplexer No streams
+2013-11-01 02:33:20,273-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:33:26,174-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:33:36,182-0500 INFO  Multiplexer No streams
+2013-11-01 02:33:36,801-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:33:46,190-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:33:56,199-0500 INFO  Multiplexer No streams
+2013-11-01 02:33:59,942-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:34:06,207-0500 INFO  Multiplexer No streams
+2013-11-01 02:34:06,876-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:34:16,215-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:34:26,223-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:34:36,231-0500 INFO  Multiplexer No streams
+2013-11-01 02:34:36,951-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 02:34:39,611-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:34:46,240-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:34:56,248-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:35:06,255-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 02:35:07,027-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+No streams
+2013-11-01 02:35:16,264-0500 INFO  Multiplexer No streams
+2013-11-01 02:35:19,280-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:35:26,272-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:35:36,280-0500 INFO  Multiplexer No streams
+2013-11-01 02:35:37,101-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:35:46,288-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:35:56,296-0500 INFO  Multiplexer No streams
+2013-11-01 02:35:58,949-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:36:06,304-0500 INFO  Multiplexer No streams
+2013-11-01 02:36:07,176-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:36:16,312-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:36:26,320-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:36:36,328-0500 INFO  Multiplexer No streams
+2013-11-01 02:36:37,251-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:36:38,618-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:36:46,336-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:36:56,344-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:37:06,352-0500 INFO  Multiplexer No streams
+2013-11-01 02:37:07,326-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:37:16,361-0500 INFO  Multiplexer No streams
+2013-11-01 02:37:18,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:37:26,369-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:37:36,377-0500 INFO  Multiplexer No streams
+2013-11-01 02:37:37,401-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:37:46,385-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:37:56,393-0500 INFO  Multiplexer No streams
+2013-11-01 02:37:57,956-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:38:06,402-0500 INFO  Multiplexer No streams
+2013-11-01 02:38:07,476-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:38:16,410-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:38:26,418-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:38:36,426-0500 INFO  Multiplexer No streams
+2013-11-01 02:38:37,551-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:38:37,625-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:38:46,434-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:38:56,443-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:39:06,451-0500 INFO  Multiplexer No streams
+2013-11-01 02:39:07,626-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:39:16,459-0500 INFO  Multiplexer No streams
+2013-11-01 02:39:17,294-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:39:26,467-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:39:36,475-0500 INFO  Multiplexer No streams
+2013-11-01 02:39:37,701-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:39:46,483-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:39:56,492-0500 INFO  Multiplexer No streams
+2013-11-01 02:39:56,963-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:40:06,500-0500 INFO  Multiplexer No streams
+2013-11-01 02:40:07,776-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:40:16,508-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:40:26,516-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:40:36,524-0500 INFO  Multiplexer No streams
+2013-11-01 02:40:36,632-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:40:37,851-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:40:46,532-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:40:56,540-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:41:06,548-0500 INFO  Multiplexer No streams
+2013-11-01 02:41:07,926-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 02:41:16,301-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:41:16,556-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:41:26,564-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:41:36,572-0500 INFO  Multiplexer No streams
+2013-11-01 02:41:38,001-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:41:46,580-0500 INFO  Multiplexer No streams
+2013-11-01 02:41:55,970-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:41:56,588-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:42:06,596-0500 INFO  Multiplexer No streams
+2013-11-01 02:42:08,077-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:42:16,605-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:42:26,613-0500 INFO  Multiplexer No streams
+2013-11-01 02:42:35,640-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:42:36,621-0500 INFO  Multiplexer No streams
+2013-11-01 02:42:38,152-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:42:46,629-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:42:56,637-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:43:06,645-0500 INFO  Multiplexer No streams
+2013-11-01 02:43:08,227-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 02:43:15,309-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:43:16,653-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:43:26,661-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:43:36,669-0500 INFO  Multiplexer No streams
+2013-11-01 02:43:38,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:43:46,677-0500 INFO  Multiplexer No streams
+2013-11-01 02:43:54,979-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:43:56,686-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:44:06,694-0500 INFO  Multiplexer No streams
+2013-11-01 02:44:08,377-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:44:16,702-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:44:26,710-0500 INFO  Multiplexer No streams
+2013-11-01 02:44:34,647-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:44:36,718-0500 INFO  Multiplexer No streams
+2013-11-01 02:44:38,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:44:46,726-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:44:56,734-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:45:06,742-0500 INFO  Multiplexer No streams
+2013-11-01 02:45:08,527-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 02:45:14,316-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:45:16,751-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:45:26,758-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:45:36,767-0500 INFO  Multiplexer No streams
+2013-11-01 02:45:38,602-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:45:46,775-0500 INFO  Multiplexer No streams
+2013-11-01 02:45:53,985-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:45:56,783-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:46:06,791-0500 INFO  Multiplexer No streams
+2013-11-01 02:46:08,677-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:46:16,799-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:46:26,806-0500 INFO  Multiplexer No streams
+2013-11-01 02:46:33,654-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:46:36,814-0500 INFO  Multiplexer No streams
+2013-11-01 02:46:38,751-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:46:46,822-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:46:56,830-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:47:06,837-0500 INFO  Multiplexer No streams
+2013-11-01 02:47:08,827-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:47:13,323-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:47:16,846-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:47:26,854-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:47:36,862-0500 INFO  Multiplexer No streams
+2013-11-01 02:47:38,902-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:47:46,870-0500 INFO  Multiplexer No streams
+2013-11-01 02:47:52,992-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:47:56,878-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:48:06,886-0500 INFO  Multiplexer No streams
+2013-11-01 02:48:08,977-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:48:16,894-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:48:26,902-0500 INFO  Multiplexer No streams
+2013-11-01 02:48:32,661-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:48:36,910-0500 INFO  Multiplexer No streams
+2013-11-01 02:48:39,052-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:48:46,918-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:48:56,926-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:49:06,934-0500 INFO  Multiplexer No streams
+2013-11-01 02:49:09,127-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:49:12,330-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:49:16,942-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:49:26,950-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:49:36,958-0500 INFO  Multiplexer No streams
+2013-11-01 02:49:39,202-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:49:46,966-0500 INFO  Multiplexer No streams
+2013-11-01 02:49:51,999-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:49:56,975-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:50:06,983-0500 INFO  Multiplexer No streams
+2013-11-01 02:50:09,277-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:50:16,991-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:50:26,999-0500 INFO  Multiplexer No streams
+2013-11-01 02:50:31,668-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:50:37,007-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+2013-11-01 02:50:39,351-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:50:47,015-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:50:57,023-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:51:07,031-0500 INFO  Multiplexer No streams
+2013-11-01 02:51:09,427-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:51:11,336-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:51:17,039-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:51:27,047-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:51:37,055-0500 INFO  Multiplexer No streams
+2013-11-01 02:51:39,502-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:51:47,063-0500 INFO  Multiplexer No streams
+2013-11-01 02:51:51,006-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:51:57,071-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:52:07,080-0500 INFO  Multiplexer No streams
+2013-11-01 02:52:09,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:52:17,088-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:52:27,095-0500 INFO  Multiplexer No streams
+2013-11-01 02:52:30,675-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:52:37,103-0500 INFO  Multiplexer No streams
+2013-11-01 02:52:39,653-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:52:47,112-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:52:57,120-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:53:07,128-0500 INFO  Multiplexer No streams
+2013-11-01 02:53:09,728-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:53:10,344-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:53:17,136-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:53:27,144-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:53:37,152-0500 INFO  Multiplexer No streams
+2013-11-01 02:53:39,803-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:53:47,160-0500 INFO  Multiplexer No streams
+2013-11-01 02:53:50,013-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:53:57,168-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:54:07,176-0500 INFO  Multiplexer No streams
+2013-11-01 02:54:09,877-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:54:17,184-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:54:27,192-0500 INFO  Multiplexer No streams
+2013-11-01 02:54:29,682-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:54:37,200-0500 INFO  Multiplexer No streams
+2013-11-01 02:54:39,953-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:54:47,208-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:54:57,216-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:55:07,224-0500 INFO  Multiplexer No streams
+2013-11-01 02:55:09,351-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:55:10,028-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:55:17,232-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:55:27,240-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:55:37,248-0500 INFO  Multiplexer No streams
+2013-11-01 02:55:40,102-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:55:47,256-0500 INFO  Multiplexer No streams
+2013-11-01 02:55:49,020-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:55:57,263-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:56:07,271-0500 INFO  Multiplexer No streams
+2013-11-01 02:56:10,178-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:56:17,279-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:56:27,287-0500 INFO  Multiplexer No streams
+2013-11-01 02:56:28,688-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:56:37,295-0500 INFO  Multiplexer No streams
+2013-11-01 02:56:40,253-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:56:47,303-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:56:57,316-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:57:07,324-0500 INFO  Multiplexer No streams
+2013-11-01 02:57:08,358-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 02:57:10,328-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 02:57:17,332-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:57:27,340-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:57:37,348-0500 INFO  Multiplexer No streams
+2013-11-01 02:57:40,403-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:57:47,356-0500 INFO  Multiplexer No streams
+2013-11-01 02:57:48,027-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 02:57:57,364-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:58:07,372-0500 INFO  Multiplexer No streams
+2013-11-01 02:58:10,478-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:58:17,381-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:58:27,388-0500 INFO  Multiplexer No streams
+2013-11-01 02:58:27,697-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 02:58:37,397-0500 INFO  Multiplexer No streams
+2013-11-01 02:58:40,553-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:58:47,405-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:58:57,413-0500 INFO  Multiplexer No streams
+2013-11-01 02:59:07,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:59:07,421-0500 INFO  Multiplexer No streams
+2013-11-01 02:59:10,627-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 02:59:17,429-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:59:27,437-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:59:37,445-0500 INFO  Multiplexer No streams
+2013-11-01 02:59:40,703-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 02:59:47,035-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 02:59:47,453-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 02:59:57,461-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:00:07,469-0500 INFO  Multiplexer No streams
+2013-11-01 03:00:10,778-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:00:17,477-0500 INFO  Multiplexer No streams
+2013-11-01 03:00:26,704-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:00:27,485-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:00:37,493-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+2013-11-01 03:00:40,853-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 2ms, rtt: 1ms
+No streams
+2013-11-01 03:00:47,501-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:00:57,508-0500 INFO  Multiplexer No streams
+2013-11-01 03:01:06,373-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:01:07,516-0500 INFO  Multiplexer No streams
+2013-11-01 03:01:10,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:01:17,524-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:01:27,533-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:01:37,540-0500 INFO  Multiplexer No streams
+2013-11-01 03:01:41,003-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:01:46,042-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:01:47,549-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:01:57,556-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:02:07,565-0500 INFO  Multiplexer No streams
+2013-11-01 03:02:11,077-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 03:02:17,572-0500 INFO  Multiplexer No streams
+2013-11-01 03:02:25,711-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:02:27,580-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:02:37,588-0500 INFO  Multiplexer No streams
+2013-11-01 03:02:41,153-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:02:47,596-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:02:57,604-0500 INFO  Multiplexer No streams
+2013-11-01 03:03:05,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:03:07,612-0500 INFO  Multiplexer No streams
+2013-11-01 03:03:11,228-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:03:17,620-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:03:27,628-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:03:37,636-0500 INFO  Multiplexer No streams
+2013-11-01 03:03:41,303-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:03:45,049-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:03:47,644-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:03:57,652-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:04:07,661-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 4ms
+2013-11-01 03:04:11,381-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 4ms
+No streams
+2013-11-01 03:04:17,669-0500 INFO  Multiplexer No streams
+2013-11-01 03:04:24,718-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:04:27,677-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:04:37,685-0500 INFO  Multiplexer No streams
+2013-11-01 03:04:41,453-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:04:47,694-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:04:57,702-0500 INFO  Multiplexer No streams
+2013-11-01 03:05:04,387-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:05:07,710-0500 INFO  Multiplexer No streams
+2013-11-01 03:05:11,528-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:05:17,718-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:05:27,726-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:05:37,735-0500 INFO  Multiplexer No streams
+2013-11-01 03:05:41,603-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:05:44,056-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:05:47,743-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:05:57,750-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:06:07,759-0500 INFO  Multiplexer No streams
+2013-11-01 03:06:11,678-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:06:17,767-0500 INFO  Multiplexer No streams
+2013-11-01 03:06:23,725-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:06:27,775-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:06:37,783-0500 INFO  Multiplexer No streams
+2013-11-01 03:06:41,753-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:06:47,792-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:06:57,800-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 03:07:03,395-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:07:07,808-0500 INFO  Multiplexer No streams
+2013-11-01 03:07:11,827-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 03:07:17,816-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:07:27,824-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:07:37,832-0500 INFO  Multiplexer No streams
+2013-11-01 03:07:41,903-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:07:43,063-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:07:47,841-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:07:57,849-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:08:07,857-0500 INFO  Multiplexer No streams
+2013-11-01 03:08:11,978-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:08:17,865-0500 INFO  Multiplexer No streams
+2013-11-01 03:08:22,732-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:08:27,873-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:08:37,881-0500 INFO  Multiplexer No streams
+2013-11-01 03:08:42,052-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 03:08:47,889-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:08:57,897-0500 INFO  Multiplexer No streams
+2013-11-01 03:09:02,401-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:09:07,905-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:09:12,128-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:09:17,913-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:09:27,921-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:09:37,930-0500 INFO  Multiplexer No streams
+2013-11-01 03:09:42,070-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:09:42,203-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:09:47,938-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:09:57,946-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:10:07,954-0500 INFO  Multiplexer No streams
+2013-11-01 03:10:12,278-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:10:17,962-0500 INFO  Multiplexer No streams
+2013-11-01 03:10:21,739-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:10:27,970-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:10:37,978-0500 INFO  Multiplexer No streams
+2013-11-01 03:10:42,353-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:10:47,987-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:10:57,994-0500 INFO  Multiplexer No streams
+2013-11-01 03:11:01,408-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:11:08,003-0500 INFO  Multiplexer No streams
+2013-11-01 03:11:12,428-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:11:18,011-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:11:28,019-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:11:38,027-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:11:41,077-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
-2013-10-28 16:00:43,011-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:11:42,502-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:00:51,500-0500 INFO  Multiplexer No streams
+2013-11-01 03:11:48,035-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:01:01,508-0500 INFO  Multiplexer No streams
+2013-11-01 03:11:58,044-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:12:08,052-0500 INFO  Multiplexer No streams
+2013-11-01 03:12:12,578-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:12:18,060-0500 INFO  Multiplexer No streams
-2013-10-28 16:01:05,705-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:12:20,746-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:01:11,515-0500 INFO  Multiplexer No streams
+2013-11-01 03:12:28,068-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:12:38,076-0500 INFO  Multiplexer No streams
+2013-11-01 03:12:42,653-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:12:48,084-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:12:58,092-0500 INFO  Multiplexer No streams
+2013-11-01 03:13:00,415-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:13:08,100-0500 INFO  Multiplexer No streams
-2013-10-28 16:01:13,970-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:13:12,727-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:01:21,523-0500 INFO  Multiplexer No streams
+2013-11-01 03:13:18,108-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:01:31,530-0500 INFO  Multiplexer No streams
+2013-11-01 03:13:28,116-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:01:41,537-0500 INFO  Multiplexer No streams
+2013-11-01 03:13:38,124-0500 INFO  Multiplexer No streams
+2013-11-01 03:13:40,084-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:13:42,803-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 0ms
+No streams
+2013-11-01 03:13:48,132-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:13:58,140-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:14:08,149-0500 INFO  Multiplexer No streams
+2013-11-01 03:14:12,879-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:14:18,157-0500 INFO  Multiplexer No streams
+2013-11-01 03:14:19,753-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:14:28,165-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:14:38,173-0500 INFO  Multiplexer No streams
+2013-11-01 03:14:42,954-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:14:48,181-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:14:58,189-0500 INFO  Multiplexer No streams
+2013-11-01 03:14:59,422-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:15:08,197-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:15:13,029-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:15:18,205-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:15:28,213-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:15:38,221-0500 INFO  Multiplexer No streams
+2013-11-01 03:15:39,091-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:15:43,104-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:15:48,229-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:15:58,237-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:16:08,245-0500 INFO  Multiplexer No streams
+2013-11-01 03:16:13,179-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:16:18,253-0500 INFO  Multiplexer No streams
+2013-11-01 03:16:18,760-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:16:28,261-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:16:38,269-0500 INFO  Multiplexer No streams
+2013-11-01 03:16:43,253-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:16:48,277-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:16:58,286-0500 INFO  Multiplexer No streams
+2013-11-01 03:16:58,430-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:17:08,293-0500 INFO  Multiplexer No streams
+2013-11-01 03:17:13,329-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:17:18,302-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:17:28,310-0500 INFO  Multiplexer No streams
+2013-11-01 03:17:38,100-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:17:38,318-0500 INFO  Multiplexer No streams
+2013-11-01 03:17:43,404-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:17:48,325-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:17:58,333-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:18:08,341-0500 INFO  Multiplexer No streams
+2013-11-01 03:18:13,479-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 16:01:43,899-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:18:17,768-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:18:18,350-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:18:28,358-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:18:38,366-0500 INFO  Multiplexer No streams
-2013-10-28 16:01:44,929-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:18:43,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:01:51,545-0500 INFO  Multiplexer No streams
+2013-11-01 03:18:48,374-0500 INFO  Multiplexer No streams
+2013-11-01 03:18:57,437-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:02:01,552-0500 INFO  Multiplexer No streams
+2013-11-01 03:18:58,382-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:02:11,560-0500 INFO  Multiplexer No streams
+2013-11-01 03:19:08,390-0500 INFO  Multiplexer No streams
+2013-11-01 03:19:13,630-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:19:18,399-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:19:28,407-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:19:37,106-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:19:38,415-0500 INFO  Multiplexer No streams
+2013-11-01 03:19:43,705-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:19:48,422-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:19:58,431-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:20:08,439-0500 INFO  Multiplexer No streams
+2013-11-01 03:20:13,779-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:20:16,775-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:20:18,447-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:20:28,455-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:20:38,463-0500 INFO  Multiplexer No streams
+2013-11-01 03:20:43,855-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:20:48,471-0500 INFO  Multiplexer No streams
+2013-11-01 03:20:56,444-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:20:58,479-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:21:08,487-0500 INFO  Multiplexer No streams
+2013-11-01 03:21:13,930-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:21:18,495-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:21:28,503-0500 INFO  Multiplexer No streams
+2013-11-01 03:21:36,113-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:21:38,511-0500 INFO  Multiplexer No streams
+2013-11-01 03:21:44,005-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:21:48,519-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:21:58,527-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:22:08,535-0500 INFO  Multiplexer No streams
+2013-11-01 03:22:14,080-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:22:15,782-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:22:18,543-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:22:28,551-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:22:38,560-0500 INFO  Multiplexer No streams
+2013-11-01 03:22:44,155-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:22:48,568-0500 INFO  Multiplexer No streams
+2013-11-01 03:22:55,451-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:22:58,575-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:23:08,583-0500 INFO  Multiplexer No streams
+2013-11-01 03:23:14,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:23:18,592-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:23:28,600-0500 INFO  Multiplexer No streams
+2013-11-01 03:23:35,120-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:23:38,608-0500 INFO  Multiplexer No streams
+2013-11-01 03:23:44,305-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:23:48,616-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:23:58,624-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:24:08,632-0500 INFO  Multiplexer No streams
 TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 16:02:15,888-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:24:14,380-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:24:14,788-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:02:21,567-0500 INFO  Multiplexer No streams
+2013-11-01 03:24:18,640-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:24:28,648-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:24:38,656-0500 INFO  Multiplexer No streams
+2013-11-01 03:24:44,455-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:24:48,664-0500 INFO  Multiplexer No streams
-2013-10-28 16:02:22,093-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:24:54,458-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:02:31,575-0500 INFO  Multiplexer No streams
+2013-11-01 03:24:58,672-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:02:41,582-0500 INFO  Multiplexer No streams
+2013-11-01 03:25:08,680-0500 INFO  Multiplexer No streams
+2013-11-01 03:25:14,530-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:25:18,689-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:25:28,696-0500 INFO  Multiplexer No streams
+2013-11-01 03:25:34,127-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:25:38,705-0500 INFO  Multiplexer No streams
+2013-11-01 03:25:44,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:25:48,713-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:25:58,720-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:26:08,729-0500 INFO  Multiplexer No streams
+2013-11-01 03:26:13,796-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:26:14,681-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:26:18,737-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:26:28,745-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:26:38,753-0500 INFO  Multiplexer No streams
+2013-11-01 03:26:44,756-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:26:48,761-0500 INFO  Multiplexer No streams
+2013-11-01 03:26:53,466-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:26:58,770-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:27:08,779-0500 INFO  Multiplexer No streams
-2013-10-28 16:02:46,846-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:27:14,831-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:02:51,590-0500 INFO  Multiplexer No streams
+2013-11-01 03:27:18,787-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:27:28,795-0500 INFO  Multiplexer No streams
+2013-11-01 03:27:33,134-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:27:38,803-0500 INFO  Multiplexer No streams
+2013-11-01 03:27:44,906-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:27:48,812-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:27:58,820-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:28:08,829-0500 INFO  Multiplexer No streams
+2013-11-01 03:28:12,803-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:28:14,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:28:18,838-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:28:28,846-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:28:38,856-0500 INFO  Multiplexer No streams
+2013-11-01 03:28:45,056-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:28:48,868-0500 INFO  Multiplexer No streams
+2013-11-01 03:28:52,473-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:28:58,880-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:29:08,892-0500 INFO  Multiplexer No streams
+2013-11-01 03:29:15,131-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:29:18,901-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:29:28,912-0500 INFO  Multiplexer No streams
+2013-11-01 03:29:32,141-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:29:38,921-0500 INFO  Multiplexer No streams
+2013-11-01 03:29:45,206-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:29:48,934-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:29:58,937-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:30:08,943-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 03:30:11,811-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 2ms, rtt: 2ms
+2013-11-01 03:30:15,281-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:30:18,947-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:30:28,961-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:30:38,971-0500 INFO  Multiplexer No streams
+2013-11-01 03:30:45,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:30:48,982-0500 INFO  Multiplexer No streams
+2013-11-01 03:30:51,480-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:30:58,992-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:31:09,002-0500 INFO  Multiplexer No streams
+2013-11-01 03:31:15,432-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:31:19,013-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:31:29,023-0500 INFO  Multiplexer No streams
-2013-10-28 16:03:00,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:31:31,148-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:03:01,597-0500 INFO  Multiplexer No streams
+2013-11-01 03:31:39,034-0500 INFO  Multiplexer No streams
+2013-11-01 03:31:45,506-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 16:03:11,605-0500 INFO  Multiplexer No streams
+2013-11-01 03:31:49,046-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:31:59,057-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:32:09,069-0500 INFO  Multiplexer No streams
+2013-11-01 03:32:10,817-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 16:03:17,804-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:32:15,581-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:03:21,612-0500 INFO  Multiplexer No streams
+2013-11-01 03:32:19,079-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:03:31,619-0500 INFO  Multiplexer No streams
+2013-11-01 03:32:29,088-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:32:39,097-0500 INFO  Multiplexer No streams
+2013-11-01 03:32:45,657-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:32:49,106-0500 INFO  Multiplexer No streams
-2013-10-28 16:03:38,481-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:32:50,486-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:03:41,627-0500 INFO  Multiplexer No streams
+2013-11-01 03:32:59,114-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:33:09,123-0500 INFO  Multiplexer No streams
+2013-11-01 03:33:15,732-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:33:19,133-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:33:29,143-0500 INFO  Multiplexer No streams
+2013-11-01 03:33:30,155-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:33:39,153-0500 INFO  Multiplexer No streams
-2013-10-28 16:03:48,762-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:33:45,807-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:03:51,634-0500 INFO  Multiplexer No streams
+2013-11-01 03:33:49,164-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:04:01,642-0500 INFO  Multiplexer No streams
+2013-11-01 03:33:59,176-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:04:11,649-0500 INFO  Multiplexer No streams
+2013-11-01 03:34:09,185-0500 INFO  Multiplexer No streams
+2013-11-01 03:34:09,825-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 03:34:15,883-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:34:19,193-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:34:29,202-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:34:39,212-0500 INFO  Multiplexer No streams
+2013-11-01 03:34:45,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:34:49,223-0500 INFO  Multiplexer No streams
+2013-11-01 03:34:49,494-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:34:59,232-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:35:09,242-0500 INFO  Multiplexer No streams
+2013-11-01 03:35:16,032-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:35:19,250-0500 INFO  Multiplexer No streams
+2013-11-01 03:35:29,164-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:35:29,258-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:35:39,266-0500 INFO  Multiplexer No streams
+2013-11-01 03:35:46,107-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:35:49,275-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:35:59,283-0500 INFO  Multiplexer No streams
+2013-11-01 03:36:08,833-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:36:09,292-0500 INFO  Multiplexer No streams
+2013-11-01 03:36:16,182-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:36:19,301-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:36:29,310-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:36:39,321-0500 INFO  Multiplexer No streams
+2013-11-01 03:36:46,257-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
-2013-10-28 16:04:16,675-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:36:48,502-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:36:49,332-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:36:59,343-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:37:09,354-0500 INFO  Multiplexer No streams
+2013-11-01 03:37:16,332-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:37:19,364-0500 INFO  Multiplexer No streams
+2013-11-01 03:37:28,172-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:37:29,372-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:37:39,383-0500 INFO  Multiplexer No streams
+2013-11-01 03:37:46,407-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:37:49,392-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:37:59,403-0500 INFO  Multiplexer No streams
+2013-11-01 03:38:07,841-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:38:09,412-0500 INFO  Multiplexer No streams
-2013-10-28 16:04:19,720-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:38:16,482-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:04:21,657-0500 INFO  Multiplexer No streams
+2013-11-01 03:38:19,422-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:04:31,664-0500 INFO  Multiplexer No streams
+2013-11-01 03:38:29,432-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:04:41,671-0500 INFO  Multiplexer No streams
+2013-11-01 03:38:39,442-0500 INFO  Multiplexer No streams
-2013-10-28 16:04:50,678-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:38:46,557-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:38:47,510-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
 No streams
-2013-10-28 16:04:51,679-0500 INFO  Multiplexer No streams
+2013-11-01 03:38:49,452-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:38:59,461-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:39:09,472-0500 INFO  Multiplexer No streams
+2013-11-01 03:39:16,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:39:19,483-0500 INFO  Multiplexer No streams
+2013-11-01 03:39:27,180-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 03:39:29,493-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:39:39,502-0500 INFO  Multiplexer No streams
+2013-11-01 03:39:46,707-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:39:49,510-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:39:59,519-0500 INFO  Multiplexer No streams
+2013-11-01 03:40:06,848-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:40:09,531-0500 INFO  Multiplexer No streams
+2013-11-01 03:40:16,783-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:40:19,544-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:40:29,554-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:40:39,565-0500 INFO  Multiplexer No streams
+2013-11-01 03:40:46,518-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:40:46,858-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:40:49,575-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:40:59,582-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:41:09,591-0500 INFO  Multiplexer No streams
+2013-11-01 03:41:16,933-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:41:19,599-0500 INFO  Multiplexer No streams
+2013-11-01 03:41:26,186-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:41:29,607-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:41:39,615-0500 INFO  Multiplexer No streams
+2013-11-01 03:41:47,009-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:41:49,623-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:41:59,631-0500 INFO  Multiplexer No streams
+2013-11-01 03:42:05,855-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:42:09,640-0500 INFO  Multiplexer No streams
+2013-11-01 03:42:17,084-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:42:19,647-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:42:29,656-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:42:39,664-0500 INFO  Multiplexer No streams
+2013-11-01 03:42:45,524-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:42:47,159-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:42:49,673-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:42:59,680-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:43:09,689-0500 INFO  Multiplexer No streams
+2013-11-01 03:43:17,233-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:43:19,697-0500 INFO  Multiplexer No streams
+2013-11-01 03:43:25,193-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:43:29,705-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:43:39,713-0500 INFO  Multiplexer No streams
+2013-11-01 03:43:47,309-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:43:49,721-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:43:59,729-0500 INFO  Multiplexer No streams
+2013-11-01 03:44:04,863-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:44:09,737-0500 INFO  Multiplexer No streams
+2013-11-01 03:44:17,384-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:44:19,745-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:44:29,753-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:44:39,762-0500 INFO  Multiplexer No streams
+2013-11-01 03:44:44,533-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 03:44:47,459-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:44:49,770-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:44:59,778-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:45:09,787-0500 INFO  Multiplexer No streams
+2013-11-01 03:45:17,534-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:45:19,795-0500 INFO  Multiplexer No streams
-2013-10-28 16:04:54,869-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:45:24,202-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:05:01,686-0500 INFO  Multiplexer No streams
+2013-11-01 03:45:29,802-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:05:11,694-0500 INFO  Multiplexer No streams
+2013-11-01 03:45:39,810-0500 INFO  Multiplexer No streams
-2013-10-28 16:05:21,636-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:45:47,609-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:05:21,701-0500 INFO  Multiplexer No streams
+2013-11-01 03:45:49,818-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:05:31,709-0500 INFO  Multiplexer No streams
+2013-11-01 03:45:59,825-0500 INFO  Multiplexer No streams
-2013-10-28 16:05:33,063-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:46:03,872-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:05:41,716-0500 INFO  Multiplexer No streams
+2013-11-01 03:46:09,833-0500 INFO  Multiplexer No streams
+2013-11-01 03:46:17,684-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:05:51,724-0500 INFO  Multiplexer No streams
+2013-11-01 03:46:19,841-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:46:29,848-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:46:39,856-0500 INFO  Multiplexer No streams
+2013-11-01 03:46:43,540-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
-2013-10-28 16:05:52,594-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:46:47,759-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:06:01,731-0500 INFO  Multiplexer No streams
+2013-11-01 03:46:49,863-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:46:59,870-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:47:09,878-0500 INFO  Multiplexer No streams
+2013-11-01 03:47:17,834-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:47:19,885-0500 INFO  Multiplexer No streams
+2013-11-01 03:47:23,209-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:47:29,893-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:47:39,900-0500 INFO  Multiplexer No streams
+2013-11-01 03:47:47,910-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:47:49,908-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:47:59,915-0500 INFO  Multiplexer No streams
+2013-11-01 03:48:02,878-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:48:09,923-0500 INFO  Multiplexer No streams
+2013-11-01 03:48:17,985-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:48:19,931-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:48:29,939-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:48:39,946-0500 INFO  Multiplexer No streams
+2013-11-01 03:48:42,547-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:48:48,060-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:48:49,954-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:48:59,962-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:49:09,970-0500 INFO  Multiplexer No streams
+2013-11-01 03:49:18,135-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:49:19,978-0500 INFO  Multiplexer No streams
+2013-11-01 03:49:22,216-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:49:29,985-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:49:39,993-0500 INFO  Multiplexer No streams
+2013-11-01 03:49:48,210-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:49:50,001-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:50:00,009-0500 INFO  Multiplexer No streams
+2013-11-01 03:50:01,885-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:50:10,017-0500 INFO  Multiplexer No streams
+2013-11-01 03:50:18,285-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:50:20,024-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:50:30,032-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:50:40,040-0500 INFO  Multiplexer No streams
+2013-11-01 03:50:41,554-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:50:48,359-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:50:50,048-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:51:00,055-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:51:10,063-0500 INFO  Multiplexer No streams
+2013-11-01 03:51:18,435-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:51:20,071-0500 INFO  Multiplexer No streams
+2013-11-01 03:51:21,223-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:51:30,079-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:51:40,086-0500 INFO  Multiplexer No streams
+2013-11-01 03:51:48,510-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:51:50,094-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:52:00,102-0500 INFO  Multiplexer No streams
+2013-11-01 03:52:00,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:52:10,110-0500 INFO  Multiplexer No streams
+2013-11-01 03:52:18,585-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:52:20,117-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:52:30,125-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:52:40,132-0500 INFO  Multiplexer No streams
+2013-11-01 03:52:40,561-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:52:48,660-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:52:50,140-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:53:00,148-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:53:10,155-0500 INFO  Multiplexer No streams
+2013-11-01 03:53:18,735-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:53:20,163-0500 INFO  Multiplexer No streams
-2013-10-28 16:06:11,257-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 03:53:20,230-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
 No streams
-2013-10-28 16:06:11,738-0500 INFO  Multiplexer No streams
+2013-11-01 03:53:30,170-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:06:21,746-0500 INFO  Multiplexer No streams
+2013-11-01 03:53:40,178-0500 INFO  Multiplexer No streams
-2013-10-28 16:06:23,552-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:53:48,810-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:06:31,753-0500 INFO  Multiplexer No streams
+2013-11-01 03:53:50,186-0500 INFO  Multiplexer No streams
+2013-11-01 03:53:59,900-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:06:41,761-0500 INFO  Multiplexer No streams
+2013-11-01 03:54:00,194-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:54:10,201-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 03:54:18,884-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 03:54:20,209-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:54:30,217-0500 INFO  Multiplexer No streams
-2013-10-28 16:06:49,452-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:54:39,569-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:06:51,768-0500 INFO  Multiplexer No streams
+2013-11-01 03:54:40,225-0500 INFO  Multiplexer No streams
+2013-11-01 03:54:48,959-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:54:50,233-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:55:00,240-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:55:10,248-0500 INFO  Multiplexer No streams
-2013-10-28 16:06:54,510-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:55:19,035-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 03:55:19,238-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
 No streams
-2013-10-28 16:07:01,775-0500 INFO  Multiplexer No streams
+2013-11-01 03:55:20,256-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:07:11,783-0500 INFO  Multiplexer No streams
+2013-11-01 03:55:30,264-0500 INFO  Multiplexer No streams
 No streams
-2013-10-28 16:07:21,790-0500 INFO  Multiplexer No streams
+2013-11-01 03:55:40,272-0500 INFO  Multiplexer No streams
+2013-11-01 03:55:49,110-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:55:50,279-0500 INFO  Multiplexer No streams
+2013-11-01 03:55:58,907-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:56:00,287-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:56:10,295-0500 INFO  Multiplexer No streams
+2013-11-01 03:56:19,184-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:56:20,303-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:56:30,311-0500 INFO  Multiplexer No streams
+2013-11-01 03:56:38,576-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:56:40,320-0500 INFO  Multiplexer No streams
+2013-11-01 03:56:49,260-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 03:56:50,327-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:57:00,335-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:57:10,344-0500 INFO  Multiplexer No streams
+2013-11-01 03:57:18,245-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:57:19,336-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:57:20,352-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:57:30,360-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:57:40,368-0500 INFO  Multiplexer No streams
+2013-11-01 03:57:49,411-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:57:50,376-0500 INFO  Multiplexer No streams
+2013-11-01 03:57:57,914-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:58:00,384-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:58:10,391-0500 INFO  Multiplexer No streams
+2013-11-01 03:58:19,485-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 03:58:20,402-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:58:30,410-0500 INFO  Multiplexer No streams
+2013-11-01 03:58:37,583-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 03:58:40,418-0500 INFO  Multiplexer No streams
+2013-11-01 03:58:49,561-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:58:50,426-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:59:00,434-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:59:10,442-0500 INFO  Multiplexer No streams
+2013-11-01 03:59:17,252-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 03:59:19,636-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:59:20,450-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:59:30,458-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 03:59:40,466-0500 INFO  Multiplexer No streams
+2013-11-01 03:59:49,711-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 03:59:50,474-0500 INFO  Multiplexer No streams
+2013-11-01 03:59:56,921-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:00:00,482-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:00:10,489-0500 INFO  Multiplexer No streams
+2013-11-01 04:00:19,786-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:00:20,497-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:00:30,505-0500 INFO  Multiplexer No streams
+2013-11-01 04:00:36,590-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:00:40,513-0500 INFO  Multiplexer No streams
+2013-11-01 04:00:49,861-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:00:50,521-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:01:00,529-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:01:10,537-0500 INFO  Multiplexer No streams
+2013-11-01 04:01:16,259-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 04:01:19,937-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:01:20,545-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:01:30,553-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:01:40,561-0500 INFO  Multiplexer No streams
+2013-11-01 04:01:50,012-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:01:50,569-0500 INFO  Multiplexer No streams
+2013-11-01 04:01:55,928-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:02:00,577-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:02:10,585-0500 INFO  Multiplexer No streams
+2013-11-01 04:02:20,086-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:02:20,593-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:02:30,600-0500 INFO  Multiplexer No streams
+2013-11-01 04:02:35,597-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:02:40,609-0500 INFO  Multiplexer No streams
+2013-11-01 04:02:50,162-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:02:50,617-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:03:00,625-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:03:10,633-0500 INFO  Multiplexer No streams
+2013-11-01 04:03:15,267-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:03:20,237-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:03:20,642-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:03:30,649-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:03:40,657-0500 INFO  Multiplexer No streams
+2013-11-01 04:03:50,312-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:03:50,665-0500 INFO  Multiplexer No streams
+2013-11-01 04:03:54,935-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:04:00,673-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:04:10,681-0500 INFO  Multiplexer No streams
+2013-11-01 04:04:20,386-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:04:20,689-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:04:30,697-0500 INFO  Multiplexer No streams
+2013-11-01 04:04:34,605-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:04:40,705-0500 INFO  Multiplexer No streams
+2013-11-01 04:04:50,462-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:04:50,713-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:05:00,721-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:05:10,729-0500 INFO  Multiplexer No streams
+2013-11-01 04:05:14,274-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:05:20,537-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:05:20,738-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:05:30,745-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:05:40,753-0500 INFO  Multiplexer No streams
+2013-11-01 04:05:50,612-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:05:50,761-0500 INFO  Multiplexer No streams
+2013-11-01 04:05:53,943-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:06:00,769-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:06:10,777-0500 INFO  Multiplexer No streams
+2013-11-01 04:06:20,686-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:06:20,785-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:06:30,793-0500 INFO  Multiplexer No streams
+2013-11-01 04:06:33,612-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:06:40,801-0500 INFO  Multiplexer No streams
+2013-11-01 04:06:50,762-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:06:50,808-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:07:00,816-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:07:10,824-0500 INFO  Multiplexer No streams
+2013-11-01 04:07:13,281-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:07:20,832-0500 INFO  Multiplexer No streams
+2013-11-01 04:07:20,837-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:07:30,840-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:07:40,847-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:07:50,855-0500 INFO  Multiplexer No streams
+2013-11-01 04:07:50,912-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:07:52,950-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:08:00,863-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:08:10,871-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:08:20,879-0500 INFO  Multiplexer No streams
+2013-11-01 04:08:20,987-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:08:30,887-0500 INFO  Multiplexer No streams
+2013-11-01 04:08:32,619-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:08:40,895-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:08:50,903-0500 INFO  Multiplexer No streams
+2013-11-01 04:08:51,062-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:09:00,911-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:09:10,920-0500 INFO  Multiplexer No streams
+2013-11-01 04:09:12,288-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:09:20,928-0500 INFO  Multiplexer No streams
+2013-11-01 04:09:21,137-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:09:30,936-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:09:40,944-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:09:50,952-0500 INFO  Multiplexer No streams
+2013-11-01 04:09:51,212-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:09:51,957-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:10:00,960-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:10:10,968-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:10:20,976-0500 INFO  Multiplexer No streams
+2013-11-01 04:10:21,287-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:10:30,985-0500 INFO  Multiplexer No streams
+2013-11-01 04:10:31,626-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:10:40,993-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:10:51,001-0500 INFO  Multiplexer No streams
+2013-11-01 04:10:51,363-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:11:01,009-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:11:11,017-0500 INFO  Multiplexer No streams
+2013-11-01 04:11:11,295-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:11:21,025-0500 INFO  Multiplexer No streams
+2013-11-01 04:11:21,438-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:11:31,033-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:11:41,041-0500 INFO  Multiplexer No streams
+2013-11-01 04:11:50,964-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:11:51,049-0500 INFO  Multiplexer No streams
+2013-11-01 04:11:51,513-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:12:01,057-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:12:11,065-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:12:21,073-0500 INFO  Multiplexer No streams
+2013-11-01 04:12:21,588-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 04:12:30,633-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:12:31,081-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:12:41,089-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:12:51,097-0500 INFO  Multiplexer No streams
+2013-11-01 04:12:51,664-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:13:01,105-0500 INFO  Multiplexer No streams
+2013-11-01 04:13:10,302-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:13:11,113-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:13:21,121-0500 INFO  Multiplexer No streams
+2013-11-01 04:13:21,739-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:13:31,129-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:13:41,136-0500 INFO  Multiplexer No streams
+2013-11-01 04:13:49,972-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:13:51,144-0500 INFO  Multiplexer No streams
+2013-11-01 04:13:51,814-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:14:01,151-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:14:11,159-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:14:21,167-0500 INFO  Multiplexer No streams
+2013-11-01 04:14:21,889-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:14:29,641-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:14:31,175-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:14:41,182-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:14:51,191-0500 INFO  Multiplexer No streams
+2013-11-01 04:14:51,964-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:15:01,198-0500 INFO  Multiplexer No streams
+2013-11-01 04:15:09,312-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:15:11,207-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:15:21,214-0500 INFO  Multiplexer No streams
+2013-11-01 04:15:22,039-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:15:31,222-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:15:41,230-0500 INFO  Multiplexer No streams
+2013-11-01 04:15:48,982-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:15:51,238-0500 INFO  Multiplexer No streams
+2013-11-01 04:15:52,114-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:16:01,247-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:16:11,255-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:16:21,262-0500 INFO  Multiplexer No streams
+2013-11-01 04:16:22,188-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 04:16:28,651-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:16:31,271-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:16:41,278-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:16:51,287-0500 INFO  Multiplexer No streams
+2013-11-01 04:16:52,264-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:17:01,295-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+2013-11-01 04:17:08,322-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 2ms
+No streams
+2013-11-01 04:17:11,302-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:17:21,310-0500 INFO  Multiplexer No streams
+2013-11-01 04:17:22,339-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:17:31,318-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:17:41,325-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:17:47,990-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:17:51,333-0500 INFO  Multiplexer No streams
+2013-11-01 04:17:52,414-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:18:01,341-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:18:11,349-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:18:21,356-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:18:22,489-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:18:27,659-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:18:31,364-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:18:41,372-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:18:51,380-0500 INFO  Multiplexer No streams
+2013-11-01 04:18:52,565-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:19:01,388-0500 INFO  Multiplexer No streams
+2013-11-01 04:19:07,328-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:19:11,396-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:19:21,404-0500 INFO  Multiplexer No streams
+2013-11-01 04:19:22,640-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:19:31,412-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:19:41,420-0500 INFO  Multiplexer No streams
+2013-11-01 04:19:46,997-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:19:51,428-0500 INFO  Multiplexer No streams
+2013-11-01 04:19:52,714-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:20:01,436-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:20:11,444-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:20:21,452-0500 INFO  Multiplexer No streams
+2013-11-01 04:20:22,790-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+2013-11-01 04:20:26,666-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:20:31,460-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:20:41,468-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:20:51,476-0500 INFO  Multiplexer No streams
+2013-11-01 04:20:52,865-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:21:01,484-0500 INFO  Multiplexer No streams
+2013-11-01 04:21:06,335-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:21:11,493-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:21:21,501-0500 INFO  Multiplexer No streams
+2013-11-01 04:21:22,940-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:21:31,508-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:21:41,517-0500 INFO  Multiplexer No streams
+2013-11-01 04:21:46,004-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:21:51,525-0500 INFO  Multiplexer No streams
+2013-11-01 04:21:53,015-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:22:01,533-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:22:11,541-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:22:21,549-0500 INFO  Multiplexer No streams
+2013-11-01 04:22:23,090-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 04:22:25,673-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:22:31,557-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:22:41,565-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:22:51,573-0500 INFO  Multiplexer No streams
+2013-11-01 04:22:53,166-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:23:01,581-0500 INFO  Multiplexer No streams
+2013-11-01 04:23:05,342-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:23:11,590-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:23:21,599-0500 INFO  Multiplexer No streams
+2013-11-01 04:23:23,241-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:23:31,607-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:23:41,615-0500 INFO  Multiplexer No streams
+2013-11-01 04:23:45,011-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:23:51,623-0500 INFO  Multiplexer No streams
+2013-11-01 04:23:53,316-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:24:01,631-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:24:11,639-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:24:21,647-0500 INFO  Multiplexer No streams
+2013-11-01 04:24:23,390-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+2013-11-01 04:24:24,680-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:24:31,655-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:24:41,664-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:24:51,671-0500 INFO  Multiplexer No streams
+2013-11-01 04:24:53,466-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:25:01,679-0500 INFO  Multiplexer No streams
+2013-11-01 04:25:04,349-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:25:11,687-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:25:21,696-0500 INFO  Multiplexer No streams
+2013-11-01 04:25:23,541-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:25:31,703-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:25:41,711-0500 INFO  Multiplexer No streams
+2013-11-01 04:25:44,018-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:25:51,720-0500 INFO  Multiplexer No streams
+2013-11-01 04:25:53,616-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:26:01,728-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:26:11,736-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:26:21,744-0500 INFO  Multiplexer No streams
+2013-11-01 04:26:23,687-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:26:23,690-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:26:31,752-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:26:41,760-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:26:51,768-0500 INFO  Multiplexer No streams
+2013-11-01 04:26:53,766-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:27:01,776-0500 INFO  Multiplexer No streams
+2013-11-01 04:27:03,356-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:27:11,784-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:27:21,792-0500 INFO  Multiplexer No streams
+2013-11-01 04:27:23,841-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:27:31,800-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:27:41,808-0500 INFO  Multiplexer No streams
+2013-11-01 04:27:43,025-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:27:51,816-0500 INFO  Multiplexer No streams
+2013-11-01 04:27:53,916-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:28:01,824-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:28:11,832-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:28:21,840-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:28:22,693-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:28:23,991-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:28:31,848-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:28:41,856-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:28:51,864-0500 INFO  Multiplexer No streams
+2013-11-01 04:28:54,066-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: -1ms, rtt: 0ms
+No streams
+2013-11-01 04:29:01,872-0500 INFO  Multiplexer No streams
+2013-11-01 04:29:02,363-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:29:11,880-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:29:21,888-0500 INFO  Multiplexer No streams
+2013-11-01 04:29:24,142-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:29:31,896-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:29:41,904-0500 INFO  Multiplexer No streams
+2013-11-01 04:29:42,033-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:29:51,912-0500 INFO  Multiplexer No streams
+TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+2013-11-01 04:29:54,217-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:30:01,920-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:30:11,928-0500 INFO  Multiplexer No streams
+2013-11-01 04:30:21,702-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:30:21,936-0500 INFO  Multiplexer No streams
+2013-11-01 04:30:24,292-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:30:31,944-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:30:41,952-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:30:51,960-0500 INFO  Multiplexer No streams
+2013-11-01 04:30:54,366-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:31:01,371-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+No streams
+2013-11-01 04:31:01,968-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:31:11,976-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:31:21,984-0500 INFO  Multiplexer No streams
+2013-11-01 04:31:24,442-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:31:31,992-0500 INFO  Multiplexer No streams
+2013-11-01 04:31:41,041-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:31:42,000-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:31:52,008-0500 INFO  Multiplexer No streams
+2013-11-01 04:31:54,517-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:32:02,016-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:32:12,024-0500 INFO  Multiplexer No streams
+2013-11-01 04:32:20,710-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:32:22,032-0500 INFO  Multiplexer No streams
+2013-11-01 04:32:24,592-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:32:32,040-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:32:42,048-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:32:52,056-0500 INFO  Multiplexer No streams
+2013-11-01 04:32:54,667-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:33:00,379-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:33:02,064-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:33:12,072-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:33:22,081-0500 INFO  Multiplexer No streams
+2013-11-01 04:33:24,742-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:33:32,089-0500 INFO  Multiplexer No streams
+2013-11-01 04:33:40,048-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:33:42,096-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:33:52,104-0500 INFO  Multiplexer No streams
+2013-11-01 04:33:54,817-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:34:02,113-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:34:12,121-0500 INFO  Multiplexer No streams
+2013-11-01 04:34:19,717-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:34:22,129-0500 INFO  Multiplexer No streams
+2013-11-01 04:34:24,892-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:34:32,137-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:34:42,145-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:34:52,153-0500 INFO  Multiplexer No streams
+2013-11-01 04:34:54,967-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:34:59,386-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:35:02,161-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:35:12,169-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:35:22,177-0500 INFO  Multiplexer No streams
+2013-11-01 04:35:25,043-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:35:32,185-0500 INFO  Multiplexer No streams
+2013-11-01 04:35:39,055-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:35:42,193-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:35:52,201-0500 INFO  Multiplexer No streams
+2013-11-01 04:35:55,118-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:36:02,210-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:36:12,217-0500 INFO  Multiplexer No streams
+2013-11-01 04:36:18,724-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:36:22,226-0500 INFO  Multiplexer No streams
+2013-11-01 04:36:25,193-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:36:32,233-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:36:42,241-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:36:52,249-0500 INFO  Multiplexer No streams
+2013-11-01 04:36:55,267-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 0ms
+2013-11-01 04:36:58,393-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:37:02,258-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:37:12,266-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:37:22,274-0500 INFO  Multiplexer No streams
+2013-11-01 04:37:25,343-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:37:32,282-0500 INFO  Multiplexer No streams
+2013-11-01 04:37:38,062-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:37:42,290-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:37:52,298-0500 INFO  Multiplexer No streams
+2013-11-01 04:37:55,418-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:38:02,306-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:38:12,314-0500 INFO  Multiplexer No streams
+2013-11-01 04:38:17,731-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: grind.mcs.anl.gov-000000] up latency: 1ms, rtt: 1ms
+No streams
+2013-11-01 04:38:22,322-0500 INFO  Multiplexer No streams
+2013-11-01 04:38:25,493-0500 INFO  HeartBeatCommand TCPChannel [type: server, contact: crush.mcs.anl.gov-000000] up latency: 0ms, rtt: 1ms
+No streams
+2013-11-01 04:38:32,330-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:38:42,338-0500 INFO  Multiplexer No streams
+No streams
+2013-11-01 04:38:52,346-0500 INFO  Multiplexer No streams
+2013-11-01
