[Swift-commit] r7347 - provenancedb
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Fri Nov 29 07:26:07 CST 2013
Author: lgadelha
Date: 2013-11-29 07:26:05 -0600 (Fri, 29 Nov 2013)
New Revision: 7347
Removed:
   provenancedb/ProvSQL.g
Modified:
   provenancedb/prov-init.sql
Log:
Minor changes, added view to display annotations of any entity type and data type
Deleted: provenancedb/ProvSQL.g
--- provenancedb/ProvSQL.g	2013-11-29 08:52:22 UTC (rev 7346)
+++ provenancedb/ProvSQL.g	2013-11-29 13:26:05 UTC (rev 7347)
@@ -1,760 +0,0 @@
-grammar ProvSQL;
- at header {
-	import java.util.HashSet;
-	import java.util.HashMap;
-	import java.util.Iterator;
-	import org.jgrapht.*;
-	import org.jgrapht.alg.DijkstraShortestPath;
-	import org.jgrapht.graph.*;
- at members {
-	String selectClause = new String();
-	String fromClause = new String();
-	String whereClauseJoinExpressions = new String();
-	String whereClause = new String();
-	boolean hasWhereJoinExpression;
-	boolean hasWhereExpression = false;
-	static boolean hasCompareRunCall = false;
-	HashSet<String> relations = new HashSet<String>();
-	UndirectedGraph<String,DefaultEdge> schemaGraph;
-	HashSet<DefaultEdge> joinEdges;
-	static HashSet<String> compareRunParams = new HashSet<String>();;
-	// Ideally it could receive a DB schema in SQL and build the graph automatically
-	public static UndirectedGraph<String,DefaultEdge> buildGraph() {
-		UndirectedGraph<String,DefaultEdge> schemaGraph = new Multigraph<String,DefaultEdge>(DefaultEdge.class);
-		schemaGraph.addVertex("a_run_t");
-		schemaGraph.addVertex("a_run_n");
-		schemaGraph.addVertex("run");
-		schemaGraph.addVertex("proc");
-		schemaGraph.addVertex("a_proc_n");
-		schemaGraph.addVertex("a_proc_t");
-		schemaGraph.addVertex("app_inv");
-		schemaGraph.addVertex("app_exec");
-		schemaGraph.addVertex("rt_info");
-		schemaGraph.addVertex("ds_in");
-		schemaGraph.addVertex("ds_out");
-		schemaGraph.addVertex("ds");
-		schemaGraph.addVertex("file");
-		schemaGraph.addVertex("in_mem");
-		schemaGraph.addVertex("a_ds_t");
-		schemaGraph.addVertex("a_ds_n");
-		schemaGraph.addVertex("ds_cont");
-		schemaGraph.addVertex("compare_run");
-		schemaGraph.addEdge("a_run_t", "run");
-		schemaGraph.addEdge("a_run_n", "run");
-		schemaGraph.addEdge("run","proc");
-		schemaGraph.addEdge("proc", "a_proc_t");
-		schemaGraph.addEdge("proc", "a_proc_n");
-		schemaGraph.addEdge("proc", "ds_out");
-		schemaGraph.addEdge("proc", "ds_in");
-		schemaGraph.addEdge("proc", "app_inv");
-		schemaGraph.addEdge("app_inv", "app_exec");
-		schemaGraph.addEdge("app_exec", "rt_info");
-		schemaGraph.addEdge("ds", "ds_in");
-		schemaGraph.addEdge("ds", "ds_out");
-		schemaGraph.addEdge("ds", "a_ds_t");
-		schemaGraph.addEdge("ds", "a_ds_n");
-		schemaGraph.addEdge("ds", "file");
-		schemaGraph.addEdge("ds", "in_mem");
-		schemaGraph.addEdge("ds", "ds_cont");
-		return schemaGraph;
-	private static HashSet<DefaultEdge> computeJoinEdges(
-			UndirectedGraph<String, DefaultEdge> schemaGraph,
-			HashSet<String> relations) {
-		HashSet<DefaultEdge> jEdges = new HashSet<DefaultEdge>();
-		Iterator<String> i = relations.iterator();
-		String first = new String();
-		if(i.hasNext())
-			first += i.next();
-		while(i.hasNext()) {
-			DijkstraShortestPath<String, DefaultEdge> sP = new DijkstraShortestPath<String, DefaultEdge>(schemaGraph, first, i.next());
-			Iterator<DefaultEdge> j = (sP.getPathEdgeList()).iterator();
-			while(j.hasNext())
-				jEdges.add(j.next());
-		return jEdges;
-	public static String computeFrom(UndirectedGraph<String,DefaultEdge> schemaGraph, HashSet<DefaultEdge> joinEdges, HashSet<String> qrels) {
-		HashSet<String> fromRels = new HashSet<String>();
-		String fromq = " FROM ";
-		Iterator<DefaultEdge> i = joinEdges.iterator();
-		Iterator<String> k = qrels.iterator();
-		if(qrels.size() == 1)
-			fromRels.add(k.next());
-		else
-				DefaultEdge aux = i.next();
-				// If ds_in or ds_out were not in the original select clause's relations and they are on the the joinEdges
-				// then one has to make sure that both consumed and produced datasets are considered in the join so there
-				// is no loss of information. One alternative, implemented here, is to replace these occurrences by the ds
-				// view, which is an union of ds_in and ds_out.
-				if(qrels.contains("ds_in") || qrels.contains("ds_out")) {
-					fromRels.add(schemaGraph.getEdgeSource(aux));
-					fromRels.add(schemaGraph.getEdgeTarget(aux));
-				else {
-					if(aux.equals(schemaGraph.getEdge("ds_in","proc")) ||
-							aux.equals(schemaGraph.getEdge("ds_in","ds")) ||
-							aux.equals(schemaGraph.getEdge("ds_out","proc")) ||
-							aux.equals(schemaGraph.getEdge("ds_out","ds"))) {
-						fromRels.add("ds");
-						fromRels.add("ds_use");
-						fromRels.add("proc");
-					else {
-		Iterator<String> j = fromRels.iterator();
-		if(j.hasNext())
-			fromq += j.next();
-			fromq += "," + j.next();
-		if(hasCompareRunCall) {
-			if(fromRels.size() > 0)
-				fromq += ",";
-			fromq += "(" + computeCompareRunQuery(compareRunParams) + ") AS compare_run";
-		return fromq;
-	public static String computeJoinExpressions(UndirectedGraph<String,DefaultEdge> schemaGraph, HashSet<DefaultEdge> jEdges, HashSet<String> qrels) {
-		HashMap<DefaultEdge,String> joinExpressions = new HashMap<DefaultEdge, String>();
-		String joinExpressionsString = new String();
-		joinExpressions.put(schemaGraph.getEdge("a_run_t", "run"), "a_run_t.run_id=run.id");
-		joinExpressions.put(schemaGraph.getEdge("a_run_n", "run"), "a_run_n.run_id=run.id");
-		joinExpressions.put(schemaGraph.getEdge("run", "proc"), "run.id=proc.run_id");
-		joinExpressions.put(schemaGraph.getEdge("proc", "a_proc_t"), "proc.id=a_proc_t.proc_id");
-		joinExpressions.put(schemaGraph.getEdge("proc", "a_proc_n"), "proc.id=a_proc_n.proc_id");
-		joinExpressions.put(schemaGraph.getEdge("proc", "ds_out"), "proc.id=ds_out.proc_id");
-		joinExpressions.put(schemaGraph.getEdge("proc", "ds_in"), "proc.id=ds_in.proc_id");
-		joinExpressions.put(schemaGraph.getEdge("proc", "app_inv"), "proc.id=app_inv.id");
-		joinExpressions.put(schemaGraph.getEdge("app_inv", "app_exec"), "app_inv.id=app_exec.app_inv_id");
-		joinExpressions.put(schemaGraph.getEdge("app_exec", "rt_info"), "app_exec.id=rt_info.app_exec_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "ds_in"), "ds.id=ds_in.ds_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "ds_out"), "ds.id=ds_out.ds_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "a_ds_t"), "ds.id=a_ds_t.ds_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "a_ds_n"), "ds.id=a_ds_n.ds_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "file"), "ds.id=file.id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "in_mem"), "ds.id=in_mem.id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "ds_cont"), "ds.id=ds_cont.in_id");
-		joinExpressions.put(schemaGraph.getEdge("ds", "ds_cont"), "ds.id=ds_cont.out_id");
-		Iterator<DefaultEdge> i = jEdges.iterator();
-		if(i.hasNext()) {
-				joinExpressionsString = joinExpressions.get(aux);
-			else {
-				if(aux.equals(schemaGraph.getEdge("ds_in","proc")) || aux.equals(schemaGraph.getEdge("ds_out","proc")))
-					joinExpressionsString = "ds_use.proc_id=proc.id";
-				else if(aux.equals(schemaGraph.getEdge("ds_in","ds")) || aux.equals(schemaGraph.getEdge("ds_out","ds")))
-					joinExpressionsString = "ds_use.ds_id=ds.id";
-				else {
-				joinExpressionsString += " AND " + joinExpressions.get(aux);
-			else {
-					joinExpressionsString += " AND " + "ds_use.proc_id=proc.id";
-					joinExpressionsString += " AND " + "ds_use.ds_id=ds.id";
-				else {
-		return joinExpressionsString;
-	public static String computeCompareRunQuery(HashSet<String> atoms) {
-		String compareRunSelectClause = "SELECT run_id";
-		String compareRunFromClause = "FROM";
-		Iterator<String> i = atoms.iterator();
-		int nId = 0;
-		for(String arg: atoms) {
-			String[] argTokens = arg.split("=");
-			if(argTokens[0].equals("key_numeric") ||
-			   argTokens[0].equals("key_text")    ||
-			   argTokens[0].equals("parameter"))
-				String key = argTokens[1].split("'")[1];
-				nId++;
-				String sId = "j" + nId;
-				compareRunSelectClause+=", " + sId + ".value as " + key;
-				if(nId>1)
-					compareRunFromClause += " INNER JOIN";
-				compareRunFromClause += " compare_run_by_" + argTokens[0] + "(\'" + key + "\') as " + sId;
-				if(nId>1)
-					compareRunFromClause += " USING (run_id)";
-		String compareRunQuery = compareRunSelectClause + " " + compareRunFromClause;
-		return compareRunQuery;
-query	:	squery (
-		UNION { System.out.println(" UNION "); }
-		INTERSECT { System.out.println(" INTERSECT "); }
-		EXCEPT { System.out.println(" EXCEPT "); }
-		ALL { System.out.println(" ALL "); }
-		squery
-		SEMICOLON
-			System.out.print(";");
-squery	:	SELECT
-			System.out.print("SELECT ");
-		DISTINCT
-			System.out.print("DISTINCT ");
-		selectExpression
-			System.out.print(selectClause);
-		(WHERE whereExpression
-						hasWhereExpression=true;
-			schemaGraph = buildGraph();
-			joinEdges = computeJoinEdges(schemaGraph, relations);
-			hasWhereJoinExpression=false;
-			fromClause += computeFrom(schemaGraph, joinEdges, relations);
-			System.out.print(fromClause);
-			whereClauseJoinExpressions += computeJoinExpressions(schemaGraph, joinEdges, relations);
-			if(!whereClauseJoinExpressions.isEmpty()) {
-				hasWhereJoinExpression=true;
-				System.out.print(" WHERE " + whereClauseJoinExpressions);
-			if(hasWhereExpression) {
-				if(hasWhereJoinExpression)
-					System.out.print(" AND ");
-				else
-					System.out.print(" WHERE ");
-				System.out.print(whereClause);
- 		GROUP BY
- 			System.out.print(" GROUP BY ");
- 		a=entityAndAttribute
- 			System.out.print($a.text);
- 		COLON
- 		b=entityAndAttribute
- 			System.out.print(",");
- 			System.out.print($b.text);
- 		HAVING { System.out.print(" HAVING "); }
- 		havingExpression
- 		ORDER BY
- 			System.out.print(" ORDER BY ");
- 		c=entityAndAttribute
- 			System.out.print($c.text);
- 		COUNT { System.out.print(" COUNT "); }
- 		e=AGGRFUN { System.out.print(" " + $e.text + " "); }
- 		COLON { System.out.print(","); }
- 		d=entityAndAttribute
- 			System.out.print($d.text);
- 		f=AGGRFUN { System.out.print(" " + $f.text + " "); }
- 			DESC { System.out.print(" DESC "); }
- 			ASC  { System.out.print(" ASC "); }
-		'(' { System.out.print("("); }
-		squery
-		')' { System.out.print(")"); }
-selectAtom
-	:	a=entityAttribute
-			selectClause += $a.text;
-			relations.add($a.text.split("\\.")[0]);
-			if($a.text.split("\\.").length == 1)
-				selectClause +=  ".*";
-		b=AGGRFUN
-			selectClause+=$b.text;
-		'(' 	{ selectClause+="("; }
-			selectClause += $c.text;
-			relations.add($c.text.split("\\.")[0]);
-			if($c.text.split("\\.").length == 1)
-		')' 	{ selectClause+=")"; }
-		d=COUNT
-			selectClause+=$d.text;
-		e=entityAttribute
-			selectClause += $e.text;
-			relations.add($e.text.split("\\.")[0]);
-			if($e.text.split("\\.").length == 1)
-		'*' { selectClause+="*"; }
-		builtInProcedureAttribute
-selectExpression
-			selectAtom
-		(COLON { selectClause+=","; }
-			selectAtom
-whereExpression
-	:	whereAtom
-			(AND
-				whereClause += " AND ";
-			| OR
-				whereClause += " OR ";
-			) whereAtom
-whereAtom
-	:	(a=entityAndAttribute
-			whereClause += $a.text;
-		j=COMPARERUN { whereClause+="comapare_run"; }
-		DOT
-		k=ID { whereClause+="."+$k.text; }
-		NOT
-			whereClause += " NOT ";
-	b=OP
-		whereClause += $b.text;
-	c=STRING
-		whereClause += $c.text;
-	d=INT
-		whereClause += $d.text;
-	e=FLOAT
-		whereClause += $e.text;
-	BETWEEN
-		whereClause += " BETWEEN ";
-	f=STRING
-		whereClause += $f.text;
-	AND
-	g=STRING
-		whereClause += $g.text;
-	LIKE
-		whereClause += " LIKE ";
-	h=STRING
-		whereClause += $h.text;
-	IN
-		whereClause += " IN ";
-		i=OP
-		whereClause += $i.text;
-		ALL
-			whereClause += " ALL ";
-		ANY
-			whereClause += " ANY ";
-		squery
-havingExpression
-	:	havingAtom
-			(AND
-			| OR
-				System.out.print(" OR ");
-			) havingAtom
-havingAtom
-	:	a=entityAndAttribute
-		NOT
-			System.out.print(" NOT ");
-	b=OP
-	c=STRING
-	d=INT
-	e=FLOAT
-		System.out.print($e.text);
-	BETWEEN
-		System.out.print(" BETWEEN ");
-	f=STRING
-		System.out.print($f.text);
-	AND
-	g=STRING
-		System.out.print($g.text);
-	LIKE
-	h=STRING
-		System.out.print($h.text);
-	IN
-		System.out.print(" IN ");
-		i=OP
-		System.out.print($i.text);
-		ALL
-			System.out.print(" ALL ");
-		ANY
-			System.out.print(" ANY ");
-		squery
-entityAttribute	:	ID (DOT ID)?;
-entityAndAttribute
-	:	ID DOT ID;
-builtInProcedureAttribute
-	:	COMPARERUN {
-			boolean hasAttribute = false;
-			hasCompareRunCall=true;
-		a=builtInAtom
-			compareRunParams.add($a.text);
-			if(relations.size() > 0)
-				relations.add("run");
-	 	(COLON
-	 	b=builtInAtom
-			compareRunParams.add($b.text);
-	 	DOT
-	 		hasAttribute = true;
-	 	c=ID
-	 		selectClause += "compare_run." + $c.text;
-	 	d=ID
-	 		selectClause += "compare_run." + $d.text;
-	 	(COLON
-	 	e=ID
-	 		selectClause += ", compare_run." + $e.text;
-	 		if(!hasAttribute)
-	 			selectClause += "compare_run.*";
-builtInAtom
-	:	('parameter' | 'key_numeric' | 'key_text') OP STRING;
-OP	:	'=' | '>' | '>=' | '<' | '<=';
-GROUP	:	'group';
-ORDER	:	'order';
-COMPARERUN
-	:	'compare_run';
-ANCESTOR:	'ancestor';
-BY	:	'by';
-AGGRFUN	:	'avg' | 'max' | 'min' | 'sum';
-COUNT	:	'count';
-SELECT 	:	'select';
-DESC	:	'desc';
-ASC	:	'asc';
-DISTINCT
-	:	'distinct';
-WHERE	:	'where';
-AND	:	'and';
-OR	:	'or';
-NOT	:	'not';
-IN	:	'in';
-ANY	:	'any';
-UNION	:	'union';
-INTERSECT
-	:	'intersect';
-EXCEPT	:	'except';
-ALL	:	'all';
-DOT	:	'.';
-COLON	:	',';
-BETWEEN	:	'between';
-HAVING	:	'having';
-LIKE 	:	'like';
-SEMICOLON	:	';';
-ID  :	('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'0'..'9'|'_'|'-')*
-INT :	'0'..'9'+
-FLOAT
-    :   ('0'..'9')+ '.' ('0'..'9')*
-    |   '.' ('0'..'9')+
-    |   ('0'..'9')+
-STRING
-    :  '\'' ( 'a'..'z' | 'A'..'Z' | '_' | '-' | '0'..'9' | '.' | '%')* '\''
-NEWLINE	:	'\r' ?	'\n';
-WS	:	(' ' |'\t' |'\n' |'\r' )+
-		skip();
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql	2013-11-29 08:52:22 UTC (rev 7346)
+++ provenancedb/prov-init.sql	2013-11-29 13:26:05 UTC (rev 7347)
@@ -329,4 +329,29 @@
 create view script_run_summary as
        select id,swift_version,cog_version,final_state,
        	      start_time,duration,script_filename
-       from script_run;
\ No newline at end of file
+       from script_run;
+create view annotation_text as
+       select dataset_id as entity_id, name, value as text_value, 'dataset' as entity_type from annot_dataset_text
+       union all
+       select function_call_id as entity_id, value as text_value, 'function_call' as entity_type from annot_function_call_text
+       union all
+       select app_exec_id as entity_id, value as text_value, 'app_exec' as entity_type from annot_app_exec_text
+       union all
+       select script_run_id as entity_id, value as text_value, 'script_run' as entity from annot_script_run_text;
+create view annotation_numeric as
+       select dataset_id as entity_id, name, value as numeric_value, 'dataset' as entity_type from annot_dataset_num
+       union all
+       select function_call_id as entity_id, value as numeric_value, 'function_call' as entity_type from annot_function_call_num
+       union all
+       select app_exec_id as entity_id, value as numeric_value, 'app_exec' as entity_type from annot_app_exec_num
+       union all
+       select script_run_id as entity_id, value as numeric_value, 'script_run' as entity from annot_script_run_num;
+create view annotation as
+       select entity_id, entity_type, NULL as numeric_value, text_value from annotation_text
+       union all
+       select entity_id, entity_type, numeric_value, NULL as text_value from annotation_numeric;
