[Swift-commit] r7342 - in trunk: bin etc/sites
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Nov 27 17:16:18 CST 2013
Author: davidk
Date: 2013-11-27 17:16:18 -0600 (Wed, 27 Nov 2013)
New Revision: 7342
Modified:
   trunk/bin/swift-service
   trunk/bin/swiftrun
   trunk/etc/sites/persistent-coasters
Log:
Use coaster-client to display information about the number of nodes and cores being used
Make sure jobspernode gets set correctly in the coaster service (workaround for bug #467)
Fix to kill local workers by pid
Various clean-up
Modified: trunk/bin/swift-service
--- trunk/bin/swift-service	2013-11-27 16:15:10 UTC (rev 7341)
+++ trunk/bin/swift-service	2013-11-27 23:16:18 UTC (rev 7342)
@@ -1,4 +1,4 @@
-#!/bin/bash
+#!/bin/bash
 # Allows a user to start, stop, name, and view the status of coaster services
@@ -7,9 +7,12 @@
 export SERVICE_DIR="$HOME/.swift/service"
 export COASTER_SERVICE="$SWIFT_BIN/coaster-service"
 export LOG="swift-service.log"
+export SPID=""
 export WORKER="$SWIFT_BIN/worker.pl"
 export WORKER_LOG="worker"
-export WORKER_LOG_DIR="."
+export WORKER_LOG_DIR="NOLOGGING"
+export WORKER_LOGGING_LEVEL="NONE"
 export IPADDR="127.0.0.1"
 mkdir -p "$SERVICE_DIR" || crash "Unable to create $SERVICE_DIR"
@@ -65,6 +68,23 @@
    done
+# Wait for a PID to stop running, up to a given amount of time ($2)
+wait_for_pid()
+   PID=$1
+   TIME=$2
+   count=0
+   while ps -p $PID &>/dev/null
+   do
+      sleep 1
+      (( count++ ))
+      if [ "$count" -ge "$TIME" ]; then
+         nicely_kill_all_children $PID
+      fi
+   done
 # Return current timestamp
 get_timestamp()
@@ -117,6 +137,7 @@
       (( count++ ))
       if [ "$count" -ge "$grace" ]; then
          run_command kill -9 $pid
+         break
       fi
    done
@@ -136,8 +157,8 @@
    fi
-   if [ -f "$SERVICE_DIR/$SERVICENAME/workers.pid" ]; then
-      PID=$( $SERVICE_DIR/$SERVICENAME/workers.pid )
+   if [ -f "$SERVICE_DIR/$SERVICENAME/worker.pid" ]; then
+      PID=$( cat $SERVICE_DIR/$SERVICENAME/worker.pid )
    fi
@@ -255,20 +276,15 @@
       rm $LOCAL_PORT_FILE
    fi
-   echo Service name: $SERVICE_NAME
-   echo Worker script: $WORKER
    # Generate sites.xml
-   export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
+   export SERVICEURL="http://$IPADDR:$SERVICE_PORT"
    export WORKERURL=$( java -jar $SWIFT_BIN/listcoasterurls.jar $LOCAL_PORT )
-   echo Execution URL: $EXECUTIONURL
-   echo Worker URL: $WORKERURL
-   echo $EXECUTIONURL >> $COASTER_DIR/execution.url
+   echo $SERVICEURL >> $COASTER_DIR/service.url
    echo $WORKERURL >> $COASTER_DIR/worker.url
    echo $WORKER >> $COASTER_DIR/worker.path
    echo $LOCAL_PORT >> $COASTER_DIR/worker.port
    echo $SERVICE_PORT >> $COASTER_DIR/service.port
    GENSITES_ARGS=""
    if [ -f "$CONFIG_FILE" ]; then
       GENSITES_ARGS=" -p $CONFIG_FILE "
@@ -281,17 +297,14 @@
    fi
    # Give defaults to gensites variables if needed
-   if [ -z "$JOBSPERNODE" ]; then
-      export JOBSPERNODE=1
-   fi
-   if [ -z "$JOBTHROTTLE" ]; then
-      export JOBTHROTTLE=0
-   fi
-   if [ -z "$WORK" ]; then
-      export WORK=/tmp
-   fi
+   export JOBSPERNODE=${JOBSPERNODE:-7}
+   export JOBTHROTTLE=${JOBTHROTTLE:-1}
+   export WORK=${WORK:-/tmp}
    gensites -n $SERVICE_NAME $GENSITES_ARGS > $COASTER_DIR/sites.xml
-   echo
+   # Workaround for bug #467
+   SPID=$( run_command_bg swift -site $SERVICE_NAME $SWIFT_BIN/../examples/swift/misc/hello.swift )
+   sleep 3
 # Display status of services
@@ -311,7 +324,11 @@
    for service in $services
    do
-      verify_files_exist $service/pid $service/service.port $service/execution.url $service/worker.port $service/worker.url $service/worker.path
+      verify_files_exist $service/pid $service/service.port $service/service.url $service/worker.port $service/worker.url $service/worker.path
+      ccoutput=$( mktemp $TMPDIR/XXXXXX )
+      $SWIFT_BIN/coaster-client $( cat $service/service.url ) list workers > $ccoutput 2>/dev/null
       echo -e "\nName:\t\t$(basename $service )"
       PID=$( cat $service/pid )
       echo -e "PID:\t\t$PID"
@@ -322,12 +339,23 @@
          echo -e "Status:\t\tFailed"
       fi
-      echo -e "Service URL:\t$( cat $service/execution.url )"
+      echo -e "Service URL:\t$( cat $service/service.url )"
       echo -e "Local URL:\t$( cat $service/worker.url )"
       echo -e "Worker script:\t$( cat $service/worker.path )"
+      nodes=0
+      cores=0
+      nodes=$( cat $ccoutput | sed '1d'|wc -l)
+      cores=$( cat $ccoutput | sed 1d | awk '{print $2}'|paste -sd+ | bc )
+      # active=$( cat $ccoutput | sed 1d | awk '{print $3}'|paste -sd+ | bc )
+      rm $ccoutput
+      echo -e "Nodes:\t\t$nodes"
+      echo -e "Cores:\t\t$cores"
+      # echo -e "Active jobs:\t$active"
       count=$((count+1))
    done
    if [ "$count" -gt 0 ]; then
       echo
    else
@@ -369,7 +397,6 @@
 # Start local workers
 start_workers_local()
-   echo Connecting local workers to service $SERVICE_NAME
    service="$SERVICE_DIR/$SERVICE_NAME"
    verify_files_exist $service/worker.path $service/worker.url
    LOG=$service/workers.log
@@ -410,7 +437,13 @@
       scheduler) start_workers_scheduler;;
       *) crash "Unknown WORKER_MODE";;
   esac
+  wait_for_pid $SPID 5
+  latest=$( ls -l1rtd run* | tail -1 )
+  if [ -d "$latest" ]; then
+     rm -rf $latest
+  fi
+  display_status
 elif [ "$STOP" == 1 ]; then
    stop_service
 elif [ "$STATUS" == 1 ]; then
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2013-11-27 16:15:10 UTC (rev 7341)
+++ trunk/bin/swiftrun	2013-11-27 23:16:18 UTC (rev 7342)
@@ -307,6 +307,7 @@
    foreach my $key (sort keys %properties) {
       print "\t$key=$properties{$key}\n";
+   print "\n";
    exit;
Modified: trunk/etc/sites/persistent-coasters
--- trunk/etc/sites/persistent-coasters	2013-11-27 16:15:10 UTC (rev 7341)
+++ trunk/etc/sites/persistent-coasters	2013-11-27 23:16:18 UTC (rev 7342)
@@ -1,7 +1,7 @@
 <?xml version="1.0" encoding="UTF-8"?>
 <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
   <pool handle="persistent-coasters">
-    <execution provider="coaster-persistent" url="_EXECUTIONURL_" jobmanager="local:local"/>
+    <execution provider="coaster-persistent" url="_SERVICEURL_" jobmanager="local:local"/>
     <profile namespace="globus" key="workerManager">passive</profile>
     <profile namespace="globus" key="jobsPerNode">_JOBSPERNODE_</profile>
     <profile key="jobThrottle" namespace="karajan">_JOBTHROTTLE_</profile>
