[Swift-commit] r7341 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Nov 27 10:15:11 CST 2013
Author: davidk
Date: 2013-11-27 10:15:10 -0600 (Wed, 27 Nov 2013)
New Revision: 7341
Modified:
   trunk/bin/swiftrun
Log:
Run on a service just like you would a normal site definition
Better error checking for funky swift.property values
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2013-11-27 14:38:37 UTC (rev 7340)
+++ trunk/bin/swiftrun	2013-11-27 16:15:10 UTC (rev 7341)
@@ -133,6 +133,7 @@
    push( @new_swift_args, "-config $run_directory/$property_filename" );
+# Check if a site is defined
 sub site_is_defined {
    my $site = $_[0];
    my $isDefined=0;
@@ -144,6 +145,53 @@
    return $isDefined;
+# Check if a service is defined
+sub service_is_defined {
+   my $site = $_[0];
+   my $isDefined=0;
+   while( my( $key, $value ) = each( %properties ) ) {
+      if( $key =~ m/^service\.$site/i ) {
+         $isDefined=1;
+   return $isDefined;
+# Verify a service is running
+sub service_is_running {
+   my $site = $_[0];
+   my $service_is_running = 0;
+   my $service_directory = "$ENV{HOME}/.swift/service/$site";
+   if( -d "$service_directory" ) {
+      if ( -f "$service_directory/pid" ) {
+         my $pid = `cat $service_directory/pid`;
+         $service_is_running = kill 0, $pid;
+   return $service_is_running;
+# Retrieve a service sites.xml
+sub retrieve_service_xml {
+   my $site = $_[0];
+   my $sitexmlfile = "$ENV{HOME}/.swift/service/$site/sites.xml";
+   my @xml;
+   open(SXML, $sitexmlfile) || die "Unable to open $sitexmlfile: $!\n";
+   while(<SXML>) {
+      if(m/^<\?xml|^<config|config>$/i){ next; }
+         push(@xml, $_);
+   close(SXML);
+   return @xml;
+sub swiftquit {
+   print STDERR $_[0] . "\n";
+   print " --SWIFTRUNQUIT ";
+   rmtree $run_directory || die "Failed to remove $run_directory: $!\n";
+   exit 1;
 # Write sites.xml to disk
 sub write_sites {
    my $filename = $_[0];
@@ -156,13 +204,23 @@
    foreach my $site(@sites) {
-      if( ! &site_is_defined($site) ) {
-         print STDERR "Site $site is not defined\n";
-         print " --SWIFTRUNQUIT ";
-         rmtree $run_directory || die "Failed to remove $run_directory: $!\n";
-         exit 1;
+      # XML from site definition
+      if ( &site_is_defined($site) ) {
+         print SITES &create_pool_entry($site);
-      print SITES &create_pool_entry($site);
+      # XML from service definition
+      elsif ( &service_is_defined($site)) {
+         if( ! &service_is_running($site) ) {
+            &swiftquit("Service process for $site is not running");
+         print SITES &retrieve_service_xml($site);
+      # Can't find definition
+      else {
+         &swiftquit("Site $site is not defined");
    print SITES "\n</config>\n";
@@ -214,7 +272,7 @@
       $_ =~ s/^\s+//;               # Remove leading whitespace
       # Handle brackets
-      if( /^site\./ && /{/ ) {
+      if( /^site\.|^service\./ && /{/ ) {
          my $prefix = (split /\s+{/)[0];
          while( <PROPERTIES> ) {
             chomp;
@@ -231,8 +289,10 @@
       else {
          my ($key, $value) = split('=', $_, 2);
          if($key eq "sites") { $key = "site"; }
-         $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
-         $properties{ $key } = $value;
+         if(defined($key) && defined($value) && length($key) && length($value)) {
+            $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
+            $properties{ $key } = $value;
