[Swift-commit] r7337 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Nov 26 16:08:37 CST 2013
Author: davidk
Date: 2013-11-26 16:08:36 -0600 (Tue, 26 Nov 2013)
New Revision: 7337
Added:
   trunk/bin/prop2scs.pl
Removed:
   trunk/bin/swift-workers
Modified:
   trunk/bin/swift-service
Log:
Add utility to export shell variables from swift.property service properties
Merge swift-workers
Added: trunk/bin/prop2scs.pl
--- trunk/bin/prop2scs.pl	                        (rev 0)
+++ trunk/bin/prop2scs.pl	2013-11-26 22:08:36 UTC (rev 7337)
@@ -0,0 +1,82 @@
+#!/usr/bin/perl -w
+use strict;
+use warnings;
+use File::Basename;
+my %properties = ();		# Hash storing all swift properties
+my @property_files = ();	# List of swift property files to be read
+my $service = $ARGV[0];
+if (!defined($service) || $service eq "-help") {
+   print STDERR "Usage: $0 service\n";
+   exit 1;
+# How to convert SCS options to environment variables
+my %conversionTable = (
+                   'ip'          => 'IPADDR',
+                   'localport'   => 'LOCAL_PORT',
+                   'mode'        => 'WORKER_MODE',
+                   'serviceport' => 'SERVICE_PORT',
+                   'workers'     => 'WORKER_HOSTS',
+# Verify a property file exists and add it to the search path
+sub add_property_file {
+   my $property_file = $_[0];
+   if( -e "$property_file" ) {
+      push( @property_files, $property_file );
+# Verify Swift is found in PATH
+my $swift_etc_directory = dirname(dirname(`which swift`)) . "/etc";
+if( ! -d $swift_etc_directory ) { die "Unable to find a valid Swift installation"; }
+# Set the search order for properties
+&add_property_file("$swift_etc_directory/swift.properties");
+&add_property_file("$ENV{SWIFT_SITE_CONF}/swift.properties") if defined($ENV{SWIFT_SITE_CONF});
+&add_property_file("$ENV{HOME}/.swift/swift.properties");
+&add_property_file("swift.properties");
+# Set property values
+foreach my $property_file(@property_files) {
+   open(PROPERTIES, $property_file) || die "Unable to open $property_file";
+   while( <PROPERTIES> ) {
+      chomp;
+      next if /^\s*#/ || /^(\s)*$/; # Ignore blank lines and comments
+      $_ =~ s/^\s+//;               # Remove leading whitespace
+      # Handle brackets
+      if( /^site\.|^service\./ && /{/ ) {
+         my $prefix = (split /\s+{/)[0];
+            chomp;
+            $_ =~ s/^\s+//;
+            if( /^}/ ) { last; }
+            my ($key, $value) = split('=', ($prefix . ".$_"), 2);
+            if($key eq "sites") { $key = "site"; }
+            $value =~ s/\$(\w+)/$ENV{$1}/g;
+            $properties{ $key } = $value;
+      else {
+         my ($key, $value) = split('=', $_, 2);
+         $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
+foreach my $key (sort keys %properties) {
+   if($key =~ m/service\.$service/ ) {
+      my $val = (split /\./, $key)[-1];
+      if ( defined( $conversionTable{ lc( $val )})) {
+         print "export $conversionTable{lc($val)}=$properties{$key}\n";
Property changes on: trunk/bin/prop2scs.pl
___________________________________________________________________
Added: svn:executable
Modified: trunk/bin/swift-service
--- trunk/bin/swift-service	2013-11-26 17:29:13 UTC (rev 7336)
+++ trunk/bin/swift-service	2013-11-26 22:08:36 UTC (rev 7337)
@@ -3,14 +3,11 @@
 # Allows a user to start, stop, name, and view the status of coaster services
-# :set debug
 export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
-export WORKER="$SWIFT_BIN/worker.pl"
+export SERVICE_DIR="$HOME/.swift/service"
 export COASTER_SERVICE="$SWIFT_BIN/coaster-service"
 export LOG="swift-service.log"
-export SERVICE_DIR="$HOME/.swift/service"
-export IPADDR=127.0.0.1
+export WORKER="$SWIFT_BIN/worker.pl"
 mkdir -p "$SERVICE_DIR" || crash "Unable to create $SERVICE_DIR"
@@ -22,12 +19,24 @@
    exit 1
+# Verify an argument is not null
+verify_not_null()
+   argname=$1; shift
+   if [ _$1 != _ ]; then
+      return 0;
+   else
+      usage
+   fi
 # Print usage
 usage()
-   crash "$( basename $0 ) [ -start | -stop | -status | -xml | -debug ] [ -name servicename ] [ -serviceport port ] [ -workerport port ]"
+   crash "$( basename $0 ) [ -start service | -stop service | -status | -xml | -debug ]"
+# Verify list of files exist, or crash
 verify_files_exist()
    for file in "$@"
@@ -172,8 +181,17 @@
       crash "Service named $SERVICE_NAME already exists!"
    fi
+   mkdir $COASTER_DIR || crash "Unable to create $COASTER_DIR"
+   # Generate environment variables from swift.properties
+   $SWIFT_BIN/prop2scs.pl $SERVICE_NAME > $COASTER_DIR/swift-service.conf 2>/dev/null
+   if [ ! -s "$COASTER_DIR/swift-service.conf" ]; then
+      rm -rf $COASTER_DIR
+      crash "Service $SERVICE_NAME not defined! Please add service definition to swift.properties"
+   fi
+   source $COASTER_DIR/swift-service.conf
    echo -e "Starting Swift service..\n"
-   mkdir $COASTER_DIR || crash "Unable to create $COASTER_DIR"
    LOG="$COASTER_DIR/swift-service.log"
    # Verify we can find coaster service
@@ -242,7 +260,6 @@
    # Generate sites.xml
    export EXECUTIONURL="http://$IPADDR:$SERVICE_PORT"
    export WORKERURL=$( java -jar $SWIFT_BIN/listcoasterurls.jar $LOCAL_PORT )
    echo Execution URL: $EXECUTIONURL
    echo Worker URL: $WORKERURL
    echo $EXECUTIONURL >> $COASTER_DIR/execution.url
@@ -329,62 +346,68 @@
    fi
-# Generate XML
-generate_xml()
+# Display debug info
+display_debug()
-   count=0
-   echo "<?xml version=\"1.0\" encoding=\"UTF-8\"?>"
-   echo -e "<config xmlns=\"http://www.ci.uchicago.edu/swift/SwiftSites\">\n"
-   services=""
-   if [ -n "$SERVICE_NAME" ]; then
-      NAME=$( echo $SERVICE_NAME |  sed s/,/' '/g )
-      for n in $SERVICE_NAME
-      do
-         services="$services $SERVICE_DIR/$n "
-      done
-   else
-      services=$( get_services )
-   fi
-   for service in $services
+   SERVICES=$( get_services )
+   for service in $SERVICES
    do
-      if [ ! -d "$service" ]; then
-         crash "Service $( basename $service ) does not exist"
-      fi
-      verify_files_exist $service/sites.xml
-      cat $service/sites.xml | grep -v "<?xml" | grep -v "<config" | grep -v "</config>"
+      echo -e "Displaying debug info for service $( basename $service ) ($service/swift-service.log)\n"
+      cat $service/swift-service.log
       echo
    done
-   echo "</config>"
+# Start SSH workers
+start-workers-ssh()
+   for MACHINE in $WORKER_HOSTS
+   do
+      # Enable ssh tunneling if needed
+      if [ "$SSH_TUNNELING" != "no" ]; then
+         run_command_bg ssh -N -T -R *:$LOCAL_PORT:localhost:$LOCAL_PORT "$WORKER_USERNAME@$MACHINE"
+      fi
+      # Connect directly
+      run_command ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION
+      run_command scp $WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION
+      echo Starting worker on $MACHINE
+      run_command_bg ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/worker.pl $WORKERURL $MACHINE $WORKER_LOG_DIR"
+   done
+   return 0
-# Display debug info
-display_debug()
+# Start local workers
+start-workers-local()
-   SERVICES=$( get_services )
-   for service in $SERVICES
    do
-      echo -e "Displaying debug info for service $( basename $service ) ($service/swift-service.log)\n"
-      cat $service/swift-service.log
-      echo
+      echo Connecting local workers to service $service
+      service="$SERVICE_DIR/$service"
+      verify_files_exist $service/worker.path $service/worker.url
+      LOG=$service/workers.log
+      WORKER=$( cat $service/worker.path )
+      WORKERURL=$( cat $service/worker.url )
+      WORKERPID=$( run_command_bg $WORKER $WORKERURL $WORKER_LOG $WORKER_LOG_DIR )
+      echo $WORKERPID >> $service/worker.pid
    done
+# Start condor workers
+start-workers-scheduler()
+   echo Starting workers
+   run_command $SCHEDULER_COMMAND
 # Parse command line arguments
 START=0; STOP=0; STATUS=0; XML=0; DEBUG=0
 while [ $# -gt 0 ]; do
    case $1 in
       -debug) DEBUG=1; shift;;
-      -localport|-workerport) LOCAL_PORT=$2; shift 2;;
-      -name) SERVICE_NAME=$2; shift 2;;
-      -serviceport) SERVICE_PORT=$2; shift 2;;
-      -start) START=1; shift;;
+      -start) START=1; SERVICE_NAME=$2; verify_not_null service_name $SERVICE_NAME; shift 2;;
       -status) STATUS=1; shift;;
       -stop) STOP=1; shift;;
-      -xml) XML=1; shift;;
       *) echo "Do not recognize command line option: $1" 1>&2; usage;;
    esac
 done
@@ -399,8 +422,6 @@
    stop_service
 elif [ "$STATUS" == 1 ]; then
    display_status
-elif [ "$XML" == 1 ]; then
-   generate_xml
 elif [ "$DEBUG" == 1 ]; then
    display_debug
 fi
Deleted: trunk/bin/swift-workers
--- trunk/bin/swift-workers	2013-11-26 17:29:13 UTC (rev 7336)
+++ trunk/bin/swift-workers	2013-11-26 22:08:36 UTC (rev 7337)
@@ -1,188 +0,0 @@
-#!/bin/bash
-export SWIFT_BIN="$( cd "$( dirname "$0" )" && pwd )"
-# Report a problem and exit
-crash()
-   MSG=$1
-   echo ${MSG} >&2
-   exit 1
-# Print usage
-usage()
-   crash "$( basename $0 ) [ -start | -stop ] [ -service servicename ]"
-# Return current timestamp
-get_timestamp()
-   date +"%b %d %H:%M:%S "
-# Write command to log, run command, wait for completion
-run_command()
-   command="$@"
-   echo "$( get_timestamp ) Running command $command" >> $LOG
-   $command 2>&1 | tee -a $LOG
-# Write command to log, run in background, return PID
-run_command_bg()
-   command="$@"
-   echo "$( get_timestamp ) Running background command $command" >> $LOG
-   $command >> $LOG 2>&1 &
-   echo $!
-verify_files_exist()
-   for file in "$@"
-   do
-      if [ ! -f "$file" ]; then
-         crash "File $file does not exist. Service is in a corrupt state, please stop and restart"
-      fi
-   done
-# Kill all children processes
-nicely_kill_all_children()
-   PID=$1
-   ps -u $USER -o "pid,ppid"|sed 1d | while read PROC
-   do
-      PROC_PID=$( echo $PROC | awk '{print $1}' )
-      PROC_PPID=$( echo $PROC | awk '{print $2}' )
-      if [ $PROC_PPID == $PID ]; then
-         nice_kill $PROC_PID 5
-      fi
-   done
-   nice_kill $PID 5
-# Try to nicely kill a process before giving it a SIGKILL
-nice_kill()
-   pid=$1
-   grace=$2
-   run_command kill $pid &>/dev/null
-   count=0
-   while ps -p $pid &>/dev/null
-   do
-      sleep 1
-      (( count++ ))
-      if [ "$count" -ge "$grace" ]; then
-         run_command kill -9 $pid
-      fi
-   done
-# Start SSH workers
-start-workers-ssh()
-   for MACHINE in $WORKER_HOSTS
-   do
-      # Enable ssh tunneling if needed
-      if [ "$SSH_TUNNELING" != "no" ]; then
-         run_command_bg ssh -N -T -R *:$LOCAL_PORT:localhost:$LOCAL_PORT "$WORKER_USERNAME@$MACHINE"
-      fi
-      # Connect directly
-      run_command ssh $WORKER_USERNAME@$MACHINE mkdir -p $WORKER_LOCATION
-      run_command scp $WORKER $WORKER_USERNAME@$MACHINE:$WORKER_LOCATION
-      echo Starting worker on $MACHINE
-      run_command_bg ssh $WORKER_USERNAME@$MACHINE "WORKER_LOGGING_LEVEL=$WORKER_LOGGING_LEVEL $WORKER_LOCATION/worker.pl $WORKERURL $MACHINE $WORKER_LOG_DIR"
-   done
-   return 0
-# Start local workers
-start-workers-local()
-   do
-      echo Connecting local workers to service $service
-      service="$SERVICE_DIR/$service"
-      verify_files_exist $service/worker.path $service/worker.url
-      LOG=$service/workers.log
-      WORKER=$( cat $service/worker.path )
-      WORKERURL=$( cat $service/worker.url )
-      WORKERPID=$( run_command_bg $WORKER $WORKERURL $WORKER_LOG $WORKER_LOG_DIR )
-      echo $WORKERPID >> $service/worker.pid
-   done
-# Start condor workers
-start-workers-scheduler()
-   echo Starting workers
-   run_command $SCHEDULER_COMMAND
-# Print a list of services
-get_services()
-   find $SERVICE_DIR -mindepth 1 -maxdepth 1 -type d 2>/dev/null | sort -n
-# Stop worker processes
-stop_workers()
-   if [ ! -d "$SERVICE_DIR/$SERVICE" ]; then
-      crash "Service $SERVICE does not work"
-   fi
-   echo Stopping service $SERVICE
-   verify_files_exist "$SERVICE_DIR/$SERVICE/worker.pid"
-   nicely_kill_all_children $( cat $SERVICE_DIR/$SERVICE/worker.pid )
-   rm $SERVICE_DIR/$SERVICE/worker.pid
-# Parse command line arguments
-START=0;STOP=0
-while [ $# -gt 0 ]; do
-   case $1 in
-      -conf) CMDLN_CONF=$2; shift 2;;
-      -stop) STOP=1; shift;;
-      -service) SERVICE=$2; shift 2;;
-      *) echo "Do not recognize command line option: $1" 1>&2; exit 1;;
-   esac
-done
-if [ -z "$SERVICE" ] || [ $(($START+$STOP)) != 1 ]; then
-   usage
-fi
-# Defaults for worker logging
-WORKER_LOG="worker.log"
-WORKER_LOG_DIR="NOLOGGING"
-WORKER_LOGGING_LEVEL="OFF"
-# Import settings
-if [ -f "$CMDLN_CONF" ]; then
-   CONFIG_FILE=$CMDLN_CONF
-elif [ -f "coaster-service.conf" ]; then
-   CONFIG_FILE="coaster-service.conf"
-fi
-if [ -f "$CONFIG_FILE" ]; then
-   echo "Configuration: $CONFIG_FILE"
-   source $CONFIG_FILE
-fi
-if [ "$START" -eq 1 ]; then
-   case $WORKER_MODE in
-      ssh) start-workers-ssh;;
-      local) start-workers-local;;
-      scheduler) start-workers-scheduler;;
-      *) crash "Unknown WORKER_MODE";;
-  esac
-elif [ "$STOP" -eq 1 ]; then
-   stop_workers
-fi
