[Swift-commit] r7320 - in trunk/src/org/griphyn/vdl/mapping: . file
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Nov 25 00:08:56 CST 2013
Author: hategan
Date: 2013-11-25 00:08:56 -0600 (Mon, 25 Nov 2013)
New Revision: 7320
Modified:
   trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
   trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
   trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.params
   trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapperParams.java
Log:
fixed ArrayFileMapper.params (bug 1151)
Modified: trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java	2013-11-25 06:06:06 UTC (rev 7319)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java	2013-11-25 06:08:56 UTC (rev 7320)
@@ -61,6 +61,13 @@
     public Object unwrap(Object value) {
         if (value instanceof AbstractDataNode) {
             AbstractDataNode handle = (AbstractDataNode) value;
+             *  TODO The semantics here (and in the mapper initialization process)
+             *  are broken. If an array is passed, the code in RootHandle.innerInit
+             *  only waits for the array, but not for each of the elements in the
+             *  array, while at the same time mappers expect all elements of the
+             *  array to be closed (e.g. ArrayFileMapper.map(): assert(dn.isClosed()))
             if (!handle.isPrimitive()) {
                 throw new IllegalArgumentException("Cannot unwrap non-primitive data");
Modified: trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-11-25 06:06:06 UTC (rev 7319)
+++ trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-11-25 06:08:56 UTC (rev 7320)
@@ -36,7 +36,7 @@
 	public Collection<Path> existing() {
 	    ArrayFileMapperParams cp = getParams();
 		List<Path> l = new ArrayList<Path>();
-		DSHandle dn = (DSHandle) cp.getFiles();
+		DSHandle dn = cp.getFiles();
 		Map<?, DSHandle> m = dn.getArrayValue();
 		Set<?> s = m.keySet();
 		Iterator<?> i = s.iterator();
@@ -58,7 +58,7 @@
         // we could typecheck more elegantly here to make sure that
         // we really do have an array of strings as parameter.
         assert(dn.isClosed());
         logger.debug("dn: " + dn);
Modified: trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.params
--- trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.params	2013-11-25 06:06:06 UTC (rev 7319)
+++ trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.params	2013-11-25 06:08:56 UTC (rev 7320)
@@ -1 +1,2 @@
-Object files
\ No newline at end of file
+ at import org.griphyn.vdl.mapping.DSHandle
+DSHandle files
Modified: trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapperParams.java
--- trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapperParams.java	2013-11-25 06:06:06 UTC (rev 7319)
+++ trunk/src/org/griphyn/vdl/mapping/file/ArrayFileMapperParams.java	2013-11-25 06:08:56 UTC (rev 7320)
@@ -5,6 +5,7 @@
 import java.util.List;
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.MappingParamSet;
+import org.griphyn.vdl.mapping.DSHandle;
 public class ArrayFileMapperParams extends MappingParamSet {
@@ -18,12 +19,12 @@
 		return NAMES;
-	public void setFiles(Object files) {
+	public void setFiles(DSHandle files) {
 		this.files = files;
-	public Object getFiles() {
-		return files;
+	public DSHandle getFiles() {
+		return (DSHandle) files;
 	@Override
@@ -58,7 +59,6 @@
 		if (files == null) {
 			throw new IllegalArgumentException("Missing required argument 'files'");
-		files = unwrap(files);
 		super.unwrapPrimitives();
