[Swift-commit] r7316 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Nov 24 13:45:57 CST 2013
Author: hategan
Date: 2013-11-24 13:45:57 -0600 (Sun, 24 Nov 2013)
New Revision: 7316
Modified:
   trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
   trunk/src/org/griphyn/vdl/mapping/RootHandle.java
Log:
removed getMappingParams method from RootHandle interface. It was not used and it was causing a problem
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-11-24 19:42:13 UTC (rev 7315)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-11-24 19:45:57 UTC (rev 7316)
@@ -637,10 +637,6 @@
         return map(Path.EMPTY_PATH);
-    public MappingParamSet getMappingParams() {
-        return getRoot().getMappingParams();
     protected Map<Comparable<?>, DSHandle> getHandles() {
         return handles;
Modified: trunk/src/org/griphyn/vdl/mapping/RootDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2013-11-24 19:42:13 UTC (rev 7315)
+++ trunk/src/org/griphyn/vdl/mapping/RootDataNode.java	2013-11-24 19:45:57 UTC (rev 7316)
@@ -196,7 +196,6 @@
 	private static void addExisting(Mapper mapper, RootHandle root) {
 	    boolean any = false;
-	    MappingParamSet mps = root.getMappingParams();
 		for (Path p : mapper.existing()) {
             try {
                 DSHandle field = root.getField(p);
Modified: trunk/src/org/griphyn/vdl/mapping/RootHandle.java
--- trunk/src/org/griphyn/vdl/mapping/RootHandle.java	2013-11-24 19:42:13 UTC (rev 7315)
+++ trunk/src/org/griphyn/vdl/mapping/RootHandle.java	2013-11-24 19:45:57 UTC (rev 7316)
@@ -26,6 +26,4 @@
     Mapper getActualMapper();
     boolean isArray();
     void closeArraySizes();
-    MappingParamSet getMappingParams();
