[Swift-commit] r7313 - trunk/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 22 22:47:22 CST 2013
Author: hategan
Date: 2013-11-22 22:47:22 -0600 (Fri, 22 Nov 2013)
New Revision: 7313
Removed:
   trunk/src/org/griphyn/vdl/mapping/MappingParam.java
Log:
removed unused file
Deleted: trunk/src/org/griphyn/vdl/mapping/MappingParam.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParam.java	2013-11-23 04:17:47 UTC (rev 7312)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParam.java	2013-11-23 04:47:22 UTC (rev 7313)
@@ -1,195 +0,0 @@
- * Copyright 2012 University of Chicago
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
-package org.griphyn.vdl.mapping;
-import org.griphyn.vdl.type.Types;
-/** The MappingParam class provides helper methods to deal with
-  * parameters to mappers. The basic usage pattern is to
-  * create a MappingParam class for each parameter of a particular
-  * Mapper parameter, and then use various getTypeValue methods to
-  * retrieve parameters in the mapper code.
-public class MappingParam {
-    public static final MappingParam SWIFT_LINE = new MappingParam("swift#line");
-    public static final MappingParam SWIFT_DBGNAME = new MappingParam("swift#dbgname");
-    public static final MappingParam SWIFT_RESTARTID = new MappingParam("swift#restartid");
-    public static final MappingParam SWIFT_BASEDIR = new MappingParam("swift#basedir");
-    public static final MappingParam SWIFT_DESCRIPTOR = new MappingParam("swift#descriptor");
-    public static final MappingParam SWIFT_INPUT = new MappingParam("swift#input");
-    public static final MappingParam SWIFT_HANDLE = new MappingParam("swift#handle");
-	private final String name;
-	private Object defValue;
-	private boolean defSet;
-	/** Creates a mapper parameter with a default value to be used
-	  * if none is specified in the SwiftScript program.
-	public MappingParam(String name, Object defaultValue) {
-		this.name = name;
-		this.defValue = defaultValue;
-		this.defSet = true;
-	/** Creates a mapper parameter with no default value. If no value
-	  * is specified in the SwiftScript program for this parameter,
-	  * then calls to the getValue methods will fail with an
-	  * InvalidMappingParameterException.
-	public MappingParam(String name) {
-		this.name = name;
-		this.defSet = false;
-	/** Returns the value of this parameter. If the value is a dataset,
-	  * then the value will be converted to a string. If no value is
-	  * specified in the SwiftScript program, then the default value
-	  * will be returned.
-	public Object getValue(Mapper mapper) throws HandleOpenException {
-		Object value = mapper.getParam(this);
-		if (value instanceof AbstractDataNode) {
-			AbstractDataNode handle = (AbstractDataNode) value;
-			handle.waitFor();
-			if (handle.getType().equals(Types.INT)) {
-			    return Integer.valueOf(((Number) handle.getValue()).intValue());
-			else {
-			    return handle.getValue().toString();
-		else if (value == null) {
-			if (!defSet) {
-				throw new InvalidMappingParameterException("Missing required mapping parameter: "
-						+ name);
-			else {
-				return defValue;
-		else {
-			return value;
-	public Object getValue(MappingParamSet params) throws HandleOpenException {
-        Object value = params.get(this);
-            handle.waitFor();
-            if (!defSet) {
-                        + name);
-            else {
-                return defValue;
-        else {
-            return value;
-	/** return the raw value of this parameter. Defaulting and type
-	  * conversion will not occur. */
-	public Object getRawValue(Mapper mapper) {
-		return mapper.getParam(this);
-	/** Returns the mapper parameter as a String. Other data types will be
-	    converted to a String as appropriate. */
-	public String getStringValue(Mapper mapper) throws HandleOpenException {
-		Object value = getValue(mapper);
-		if (value == null) {
-			return null;
-		return String.valueOf(value);
-	public String getStringValue(MappingParamSet params) throws HandleOpenException {
-        Object value = getValue(params);
-            return null;
-	public boolean isPresent(Mapper mapper) {
-		return mapper.getParam(this) != null;
-	public boolean isPresent(MappingParamSet map) {
-		return map.isPresent(this);
-	/** Returns the parameter value as a boolean. The native SwiftScript
-	  * types for this parameter can be boolean (in which case that
-	  * value is returned) or Strings "true" or "false". If none of these
-	  * match, then 'false' is returned (note an exception is not thrown,
-	  * unlike other getValue methods).
-	public boolean getBooleanValue(Mapper mapper) throws HandleOpenException {
-		if (value instanceof String) {
-			return Boolean.valueOf((String) value).booleanValue();
-		else if (value instanceof Boolean) {
-			return ((Boolean) value).booleanValue();
-		else {
-			return false;
-	/** Returns the parameter value as an int. If the SwiftScript value
-	  * is a string, then the string will be parsed to an int. If the
-	  * value is an int, then this will be passed through. Otherwise,
-	  * a NumberFormatException will be thrown. */
-	public int getIntValue(Mapper mapper) throws HandleOpenException {
-			return Integer.parseInt((String) value);
-		else if (value instanceof Integer) {
-			return ((Integer) value).intValue();
-		else {
-			throw new NumberFormatException(String.valueOf(value));
-	public void setValue(MappingParamSet map, Object value) {
-	    map.set(this, value);
-	public String toString() {
-		return "mapping parameter " + name;
-    public String getName() {
-        return name;
