[Swift-commit] r7262 - in trunk/src: . org/griphyn/vdl/engine org/griphyn/vdl/karajan/lib/swiftscript
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Nov 1 02:43:37 CDT 2013
Author: hategan
Date: 2013-11-01 02:43:35 -0500 (Fri, 01 Nov 2013)
New Revision: 7262
Modified:
   trunk/src/
   trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
Log:
changed format function to format(spec, ...), implementing exactly what java.lang.String.format implements; the previous version, I did not understand what it did or why
Property changes on: trunk/src
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/release-0.94/src:6283-6619,6999-7001
/trunk/src:6214,6255,6275-6618
   + /branches/release-0.94/src:6283-6619,6999-7001,7125
Modified: trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java
--- trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2013-11-01 00:15:48 UTC (rev 7261)
+++ trunk/src/org/griphyn/vdl/engine/ProcedureSignature.java	2013-11-01 07:43:35 UTC (rev 7262)
@@ -202,7 +202,7 @@
 		add(functionsMap, "toFloat", returns(FLOAT), args(ANY));
 		add(functionsMap, "toString", returns(STRING), args(ANY));
-		add(functionsMap, "format", returns(STRING), args(FLOAT, INT));
+		add(functionsMap, "format", returns(STRING), args(VARGS));
 		add(functionsMap, "pad", returns(STRING), args(INT, INT));
 		add(functionsMap, "java", returns(ANY), args(VARGS));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2013-11-01 00:15:48 UTC (rev 7261)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2013-11-01 07:43:35 UTC (rev 7262)
@@ -477,29 +477,30 @@
 	 * Takes in a float and formats to desired precision and returns a string
 	public static class Format extends AbstractSingleValuedFunction {
-        private ArgRef<AbstractDataNode> format;
-        private ArgRef<AbstractDataNode> value;
+	    private ChannelRef<AbstractDataNode> c_vargs;
         @Override
         protected Signature getSignature() {
-            return new Signature(params("format", "value"));
+            return new Signature(params("..."));
         @Override
         public Object function(Stack stack) {
-            AbstractDataNode hformat = this.format.getValue(stack);
-            String format = SwiftFunction.unwrap(this, hformat);
-            AbstractDataNode hvalue = this.value.getValue(stack);
-            Double value = SwiftFunction.unwrap(this, hvalue);
+            Channel<AbstractDataNode> vargs = c_vargs.get(stack);
+            Channel<Object> args = SwiftFunction.unwrapAll(this, vargs);
-            DSHandle handle = new RootDataNode(Types.STRING,
-            		String.format("%." + format + "f", value));
+            if (args.size() == 0) {
+                throw new ExecutionException(this, "Missing format specification");
+            String format = (String) args.get(0);
+            Object[] a = args.subChannel(1).toArray();
+            DSHandle handle = new RootDataNode(Types.STRING, String.format(format, a));
             if (PROVENANCE_ENABLED) {
                 int provid = SwiftFunction.nextProvenanceID();
                 SwiftFunction.logProvenanceResult(provid, handle, "format");
-                SwiftFunction.logProvenanceParameter(provid, hformat, "format");
-                SwiftFunction.logProvenanceParameter(provid, hvalue, "value");
             return handle;
