[Swift-commit] r6515 - in branches/faster: resources src/org/griphyn/vdl/engine
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri May 24 17:51:14 CDT 2013
Author: hategan
Date: 2013-05-24 17:51:14 -0500 (Fri, 24 May 2013)
New Revision: 6515
Modified:
   branches/faster/resources/swiftscript.g
   branches/faster/resources/swiftscript.xsd
   branches/faster/src/org/griphyn/vdl/engine/Karajan.java
Log:
removed requirement that the '@' syntax be used for function invocation and deprecated that syntax with the exception of '@var' which remains a shortcut for 'filename(var)'
Modified: branches/faster/resources/swiftscript.g
--- branches/faster/resources/swiftscript.g	2013-05-22 21:49:01 UTC (rev 6514)
+++ branches/faster/resources/swiftscript.g	2013-05-24 22:51:14 UTC (rev 6515)
@@ -907,7 +907,16 @@
     (e=identifier | (LPAREN e=identifier RPAREN) )
-      code.setAttribute("name", "filename");
+       * This is matched on expressions like @varname,
+       * which are a shortcut for filename(varname).
+       * The interpretation of what a function invocation
+       * with an empty file name means was moved to the swiftx -> ?
+       * compiler and allows that layer to distinguish between
+       * '@filename(x)' and '@(x)', the former of which
+       * has been deprecated.
+      code.setAttribute("name", "");
       code.setAttribute("args", e);
Modified: branches/faster/resources/swiftscript.xsd
--- branches/faster/resources/swiftscript.xsd	2013-05-22 21:49:01 UTC (rev 6514)
+++ branches/faster/resources/swiftscript.xsd	2013-05-24 22:51:14 UTC (rev 6515)
@@ -229,7 +229,7 @@
       <xs:element minOccurs="0" maxOccurs="unbounded" ref="abstractExpression" />
     </xs:sequence>
-    <xs:attribute name="name" type="xs:NMTOKEN">
+    <xs:attribute name="name" type="xs:string">
       <xs:annotation>
         <xs:documentation>name of the mapping function</xs:documentation>
       </xs:annotation>
Modified: branches/faster/src/org/griphyn/vdl/engine/Karajan.java
--- branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-05-22 21:49:01 UTC (rev 6514)
+++ branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-05-24 22:51:14 UTC (rev 6515)
@@ -61,6 +61,7 @@
 import org.globus.swift.language.TypesDocument.Types.Type;
 import org.globus.swift.language.Variable.Mapping;
 import org.globus.swift.language.Variable.Mapping.Param;
+import org.globus.swift.language.impl.FunctionImpl;
 import org.griphyn.vdl.engine.VariableScope.EnclosureType;
 import org.griphyn.vdl.engine.VariableScope.WriteType;
 import org.griphyn.vdl.karajan.CompilationException;
@@ -1232,15 +1233,15 @@
 	  * that happens.
-	public StringTemplate function(Function func, VariableScope scope) throws CompilationException {
+	public StringTemplate function(XmlObject func, String name, XmlObject[] arguments, VariableScope scope)
+	        throws CompilationException {
 		StringTemplate funcST = template("function");
-		funcST.setAttribute("name", func.getName());
+		funcST.setAttribute("name", name);
 		funcST.setAttribute("line", getLine(func));
-		ProcedureSignature funcSignature =  functionsMap.get(func.getName());
-		if(funcSignature == null) {
-			throw new CompilationException("Unknown function: @"+func.getName());
+		ProcedureSignature funcSignature = functionsMap.get(name);
+		if (funcSignature == null) {
+			throw new CompilationException("Unknown function: @" + name);
-		XmlObject[] arguments = func.getAbstractExpressionArray();
 		int noOfOptInArgs = 0;
 		for (int i = 0; i < funcSignature.sizeOfInputArray(); i++) {
 			if (funcSignature.getInputArray(i).isOptional())
@@ -1586,47 +1587,22 @@
 			return st;
 		} else if (expressionQName.equals(FUNCTION_EXPR)) {
 			Function f = (Function) expression;
-			StringTemplate st = function(f, scope);
-			/* Set function output type */
-			String name = f.getName();
-			ProcedureSignature funcSignature = functionsMap.get(name);
-			if (funcSignature != null) {
-				/* Functions have only one output parameter */
-				st.setAttribute("datatype", funcSignature.getOutputArray(0).getType());
-				if (funcSignature.isDeprecated()) {
-				    Warnings.warn(f, "Function " + name + " is deprecated");
-			} else
-				throw new CompilationException("Function " + name + " is not defined.");
-			return st;
+			return functionExpr(f, scope);
 		} else if (expressionQName.equals(CALL_EXPR)) {
 		    Call c = (Call) expression;
-		    c.addNewOutput();
-		    VariableScope subscope = new VariableScope(this, scope, c);
-		    VariableReferenceDocument ref = VariableReferenceDocument.Factory.newInstance();
-		    ref.setVariableReference("swift#callintermediate");
-		    c.getOutputArray(0).set(ref);
 		    String name = c.getProc().getLocalPart();
-		    ProcedureSignature funcSignature = proceduresMap.get(name);
-		    if (funcSignature == null) {
-                throw new CompilationException("Procedure " + name + " is not defined.");
-		    if (funcSignature.sizeOfOutputArray() != 1) {
-		        throw new CompilationException("Procedure " + name + " must have exactly one " +
-		        		"return value to be used in an expression.");
+		    if (proceduresMap.containsKey(name)) {
+		        return callExpr(c, scope);
-		    StringTemplate call = template("callexpr");
-		    String type = funcSignature.getOutputArray(0).getType();
-		    subscope.addInternalVariable("swift#callintermediate", type, null);
-		    call.setAttribute("datatype", type);
-		    call.setAttribute("call", call(c, subscope, true));
-		    call.setAttribute("prefix", UUIDGenerator.getInstance().generateRandomBasedUUID().toString());
-		    return call;
+		    else {
+		        if (functionsMap.containsKey(name)) {
+		            return functionExpr(c, scope);
+		        else {
+		            throw new CompilationException("No function or procedure '" + name + "' found.");
 		} else {
 			throw new CompilationException("unknown expression implemented by class "+expression.getClass()+" with node name "+expressionQName +" and with content "+expression);
@@ -1634,6 +1610,78 @@
 		// which shows Compiler Exception and line number of error
+    private StringTemplate callExpr(Call c, VariableScope scope) throws CompilationException {
+        c.addNewOutput();
+        VariableScope subscope = new VariableScope(this, scope, c);
+        VariableReferenceDocument ref = VariableReferenceDocument.Factory.newInstance();
+        ref.setVariableReference("swift#callintermediate");
+        c.getOutputArray(0).set(ref);
+        String name = c.getProc().getLocalPart();
+        ProcedureSignature funcSignature = proceduresMap.get(name);
+        if (funcSignature.sizeOfOutputArray() != 1) {
+            throw new CompilationException("Procedure " + name + " must have exactly one " +
+                    "return value to be used in an expression.");
+        StringTemplate call = template("callexpr");
+        String type = funcSignature.getOutputArray(0).getType();
+        subscope.addInternalVariable("swift#callintermediate", type, null);
+        call.setAttribute("datatype", type);
+        call.setAttribute("call", call(c, subscope, true));
+        call.setAttribute("prefix", UUIDGenerator.getInstance().generateRandomBasedUUID().toString());
+        return call;
+    private StringTemplate functionExpr(Call c, VariableScope scope) throws CompilationException {
+            throw new CompilationException("Function " + name + " is not defined.");
+        XmlObject[] params = new XmlObject[c.getInputArray().length];
+        for (int i = 0; i < params.length; i++) {
+            params[i] = c.getInputArray(i).getAbstractExpression();
+        StringTemplate st = function(c, name, params, scope);
+        /* Set function output type */
+        /* Functions have only one output parameter */
+        st.setAttribute("datatype", funcSignature.getOutputArray(0).getType());
+        if (funcSignature.isDeprecated()) {
+            Warnings.warn(c, "Function " + name + " is deprecated");
+        return st;
+    private StringTemplate functionExpr(Function f, VariableScope scope) throws CompilationException {
+        String name = f.getName();
+        if (name.equals("")) {
+            name = "filename";
+        else {
+            // the @var shortcut for filename(var) is not deprecated
+            Warnings.warn("The @ syntax for function invocation is deprecated");
+        StringTemplate st = function(f, name, f.getAbstractExpressionArray(), scope);
+            Warnings.warn(f, "Function " + name + " is deprecated");
+        return st;
     void checkTypesInCondExpr(String op, String left, String right, StringTemplate st)
 		if (left.equals(right))
