[Swift-commit] r6410 - trunk/docs/userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Mar 28 11:10:02 CDT 2013
Author: ketan
Date: 2013-03-28 11:10:02 -0500 (Thu, 28 Mar 2013)
New Revision: 6410
Modified:
   trunk/docs/userguide/build_options
Log:
remove obsolete build options
Modified: trunk/docs/userguide/build_options
--- trunk/docs/userguide/build_options	2013-03-28 15:25:39 UTC (rev 6409)
+++ trunk/docs/userguide/build_options	2013-03-28 16:10:02 UTC (rev 6410)
@@ -1,50 +1,24 @@
 Build options
-See the Swift download page
-<http://www.ci.uchicago.edu/swift/downloads/> for instructions on
-downloading and building Swift from source. When building, various build
-options can be supplied on the ant commandline. These are summarised here:
+See the Swift download page <http://www.ci.uchicago.edu/swift/downloads/> for
+instructions on downloading and building Swift from source. When building,
+various build options can be supplied on the ant commandline. These are
+summarised here:
 with-provider-condor - build with CoG condor provider
-with-provider-coaster - build with CoG coaster provider (see the
-section on coasters). Since 0.8, coasters are always built,
-and this option has no effect.
-with-provider-deef - build with Falkon provider deef. In order for
-this option to work, it is necessary to check out the provider-deef code
-in the cog/modules directory alongside swift:
-$ cd cog/modules
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/provider-deef
-$ cd ../swift
-$ ant -Dwith-provider-deef=true redist
+with-provider-coaster - build with CoG coaster provider (see the section on
+coasters). Since 0.8, coasters are always built, and this option has no effect.
-with-provider-wonky - build with provider-wonky, an execution provider
-that provides delays and unreliability for the purposes of testing
-Swift's fault tolerance mechanisms. In order for this option to work, it
-is necessary to check out the provider-wonky code in the |cog/modules|
-directory alongside swift:
+no-supporting - produces a distribution without supporting commands such as
+grid-proxy-init. This is intended for when the Swift distribution will be used
+in an environment where those commands are already provided by other packages,
+where the Swift package should be providing only Swift commands, and where the
+presence of commands such as grid-proxy-init from the Swift distribution in the
+path will mask the presence of those commands from their true distribution
+package such as a Globus Toolkit package.
-$ cd cog/modules
-$ svn co https://svn.ci.uchicago.edu/svn/vdl2/provider-wonky
-$ cd ../swift
-$ ant -Dwith-provider-wonky=true redist
-no-supporting - produces a distribution without supporting commands
-such as grid-proxy-init. This is intended for when the Swift
-distribution will be used in an environment where those commands are
-already provided by other packages, where the Swift package should be
-providing only Swift commands, and where the presence of commands such
-as grid-proxy-init from the Swift distribution in the path will mask the
-presence of those commands from their true distribution package such as
-a Globus Toolkit package.
 $ ant -Dno-supporting=true redist
