[Swift-commit] r6404 - in trunk/docs: merged/refmanual userguide
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun Mar 24 21:16:58 CDT 2013
Author: ketan
Date: 2013-03-24 21:16:58 -0500 (Sun, 24 Mar 2013)
New Revision: 6404
Modified:
   trunk/docs/merged/refmanual/grammar
   trunk/docs/merged/refmanual/swiftlang
   trunk/docs/userguide/coasters
Log:
formatting, and updates
Modified: trunk/docs/merged/refmanual/grammar
--- trunk/docs/merged/refmanual/grammar	2013-03-22 22:00:32 UTC (rev 6403)
+++ trunk/docs/merged/refmanual/grammar	2013-03-25 02:16:58 UTC (rev 6404)
@@ -457,10 +457,8 @@
-TODO in here, why do we have an | between LBRACKBRACK and ASSIGN?
-does this mean that we don't have array initialisation in formal
-params? this wouldn't surprise me given the previous treatment
-of arrays. investigate this and fix...
+App Formal parameter
 formalParameter returns [StringTemplate code=template("parameter")]
@@ -563,7 +561,7 @@
-These are the statements that we can predict with ll(1) grammer
+These are the statements that can be predicted with ll(1) grammer
 i.e. with one token of lookahead
@@ -1227,12 +1225,6 @@
 Identifier
-// TODO - redo identifier parsing to fit in with the XML style
-// that this patch introduces
-// specifically, need the base ID to be distinct from all the
-// other IDs
 identifier returns [StringTemplate code=null]
@@ -1270,11 +1262,11 @@
+Array Member
-memberName returns [StringTemplate code=null]
-    d:DOT (member:ID | s:STAR)
+memberName returns [StringTemplate code=null] :
+    d:DOT (member:ID | s:STAR) {
       code=template("memberAccess");
       if(member != null) code.setAttribute("name",member.getText());
       if(s != null) code.setAttribute("name","*");
@@ -1315,8 +1307,6 @@
-// TODO ^^^^^^ array literal -- rename and rearrange the methods
 Literal Symbols
@@ -1381,7 +1371,6 @@
 whitespace  :   (   ' '
         |   '\t'
         |   '\r'
@@ -1390,18 +1379,21 @@
         { $setType(Token.SKIP); }
+//Single line comment C/C++ style
 singleline_ccomment:
         (~('\n'|'\r'))* ('\n'|'\r'('\n')?)
         {$setType(Token.SKIP); newline();}
+//Single line comment shell style
 singleline_scomment:
+//Multiline comment C style
 multiline_comment :
Modified: trunk/docs/merged/refmanual/swiftlang
--- trunk/docs/merged/refmanual/swiftlang	2013-03-22 22:00:32 UTC (rev 6403)
+++ trunk/docs/merged/refmanual/swiftlang	2013-03-25 02:16:58 UTC (rev 6404)
@@ -142,9 +142,11 @@
 Following is a list of Swift keywords:
-    app type float int boolean string global
-    foreach if else iterate switch case default
-    file while import
+    app type float int boolean string
+    global foreach if else iterate
+    switch case default file while import
 == Types
Modified: trunk/docs/userguide/coasters
--- trunk/docs/userguide/coasters	2013-03-22 22:00:32 UTC (rev 6403)
+++ trunk/docs/userguide/coasters	2013-03-25 02:16:58 UTC (rev 6404)
@@ -100,3 +100,12 @@
 <profile namespace="globus" key="queue">normal</profile>
+Jobs and Coasters Parameters Equation
+The parameters provided in the coasters specification affect jobs submitted by Swift to the scheduling system.
+Jobs Submitted = slots X node_granularity X jobs_per_node
