[Swift-commit] r6398 - in branches/faster/src/org/griphyn/vdl/karajan: . monitor monitor/items monitor/monitors monitor/monitors/ansi monitor/monitors/ansi/tui monitor/monitors/swing
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Mar 18 19:28:44 CDT 2013
Author: hategan
Date: 2013-03-18 19:28:44 -0500 (Mon, 18 Mar 2013)
New Revision: 6398
Modified:
   branches/faster/src/org/griphyn/vdl/karajan/Loader.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/StateUpdater.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemState.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemStateListener.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/items/AbstractStatefulItem.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/items/StatefulItem.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/items/TraceItem.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/Monitor.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/MonitorFactory.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/TextMonitor.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/ANSIMonitor.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/AbstractANSIDisplay.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensCellRenderer.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensModel.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SchedulerInfoPane.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/GanttChart.java
   branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/SwingMonitor.java
Log:
added ui command line argument to accept one of the (future) possible types of ui and cleaned up TUI a bit
Modified: branches/faster/src/org/griphyn/vdl/karajan/Loader.java
--- branches/faster/src/org/griphyn/vdl/karajan/Loader.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/Loader.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -83,7 +83,7 @@
     public static final String ARG_LOGFILE = "logfile";
     public static final String ARG_CDMFILE = "cdm.file";
     public static final String ARG_RUNID = "runid";
-    public static final String ARG_TUI = "tui";
+    public static final String ARG_UI = "ui";
     public static final String ARG_RECOMPILE = "recompile";
     public static final String ARG_REDUCED_LOGGING = "reduced.logging";
     public static final String ARG_MINIMAL_LOGGING = "minimal.logging";
@@ -233,7 +233,7 @@
         else {
             logger.info("Swift finished with no errors");
-        if (ap.isPresent(ARG_TUI)) {
+        if (ma != null) {
             ma.close();
         System.exit(runerror ? 2 : 0);
@@ -505,7 +505,16 @@
                 ARG_RUNID,
                 "Specifies the run identifier. This must be unique for every invocation of a workflow and is used in several places to keep files from different executions cleanly separated. By default, a datestamp and random number are used to generate a run identifier.",
                 "string", ArgumentParser.OPTIONAL);
-        ap.addFlag(ARG_TUI);
+        ap.addOption(
+            ARG_UI,
+            "Indicates how swift should display run-time information. The following are valid values:" +
+            "\n\t'summary' (default) - causesSswift to regularly print a count of jobs for each state that a job can be in" +
+            "\n\t'text' - regularly prints a more detailed table with Swift run-time information" +
+            "\n\t'TUI' - displays Swift run-time information using an interactive text user interface." +
+            " The terminal must standard ANSI/VT100 escape sequences. If a port is specified," +
+            " the interface will also be available via telnet at the specified port." +
+            "\n\t'http' - enables an http server allowing access to swift run-time information using a web browser",
+            "<summary|text|TUI[:port]|http[:[password@]port]>", ArgumentParser.OPTIONAL);
         ap.addFlag(ARG_REDUCED_LOGGING, "Makes logging more terse by disabling provenance " +
         		"information and low-level task messages");
         ap.addFlag(ARG_MINIMAL_LOGGING, "Makes logging much more terse: " +
@@ -566,8 +575,8 @@
             ca.activateOptions();
         Logger.getLogger(Log.class).setLevel(Level.INFO);
-            ma = new MonitorAppender(projectName);
+        if (ap.isPresent(ARG_UI) && !"summary".equals(ap.getStringValue(ARG_UI))) {
+            ma = new MonitorAppender(projectName, ap.getStringValue(ARG_UI));
             Logger.getRootLogger().addAppender(ma);
             Logger.getLogger(Log.class).setLevel(Level.DEBUG);
             Logger.getLogger(AbstractGridNode.class).setLevel(Level.DEBUG);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/StateUpdater.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/StateUpdater.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/StateUpdater.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -28,7 +28,6 @@
 import org.apache.log4j.Level;
 import org.apache.log4j.Logger;
-import org.apache.log4j.Priority;
 import org.griphyn.vdl.karajan.monitor.processors.LogMessageProcessor;
 public class StateUpdater {
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemState.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemState.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemState.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -30,8 +30,6 @@
 import org.griphyn.vdl.karajan.monitor.items.StatefulItem;
 import org.griphyn.vdl.karajan.monitor.items.StatefulItemClass;
-import com.sun.org.apache.xpath.internal.VariableStack;
 public class SystemState {
 	private Map<StatefulItemClass, StatefulItemClassSet<? extends StatefulItem>> classes;
     private Set<SystemStateListener> listeners;
@@ -50,7 +48,7 @@
 	public void addItem(StatefulItem item) {
 		getItemClassSet(item.getItemClass()).add(item);
-        notifyListeners(SystemStateListener.ITEM_ADDED, item);
+        notifyListeners(SystemStateListener.UpdateType.ITEM_ADDED, item);
 	@SuppressWarnings("unchecked")
@@ -68,7 +66,7 @@
 	public void removeItem(StatefulItem item) {
 		getItemClassSet(item.getItemClass()).remove(item);
-        notifyListeners(SystemStateListener.ITEM_REMOVED, item);
+        notifyListeners(SystemStateListener.UpdateType.ITEM_REMOVED, item);
 	public void setParent(StatefulItem item, StatefulItem parent) {
@@ -84,10 +82,10 @@
 	public void itemUpdated(StatefulItem item) {
-		notifyListeners(SystemStateListener.ITEM_UPDATED, item);
+		notifyListeners(SystemStateListener.UpdateType.ITEM_UPDATED, item);
-    protected void notifyListeners(int updateType, StatefulItem item) {
+    protected void notifyListeners(SystemStateListener.UpdateType updateType, StatefulItem item) {
         for (SystemStateListener l : listeners) {
             l.itemUpdated(updateType, item);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemStateListener.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemStateListener.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/SystemStateListener.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -23,9 +23,9 @@
 public interface SystemStateListener {
-	public static final int ITEM_ADDED = 0;
-	public static final int ITEM_REMOVED = 1;
-	public static final int ITEM_UPDATED = 2;
+	public enum UpdateType {
+		ITEM_ADDED, ITEM_REMOVED, ITEM_UPDATED;
-	void itemUpdated(int updateType, StatefulItem item);
+	void itemUpdated(UpdateType updateType, StatefulItem item);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/items/AbstractStatefulItem.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/items/AbstractStatefulItem.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/items/AbstractStatefulItem.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -26,7 +26,7 @@
 public abstract class AbstractStatefulItem implements StatefulItem {
 	private StatefulItem parent;
-	private Set children;
+	private Set<StatefulItem> children;
 	private final String id;
 	public AbstractStatefulItem(String id) {
@@ -39,7 +39,7 @@
 	public void addChild(StatefulItem child) {
 		synchronized (this) {
 			if (children == null) {
-				children = new HashSet();
+				children = new HashSet<StatefulItem>();
 		synchronized (children) {
@@ -47,7 +47,7 @@
-	public Collection getChildren() {
+	public Collection<StatefulItem> getChildren() {
 		return children;
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/items/StatefulItem.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/items/StatefulItem.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/items/StatefulItem.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -28,7 +28,7 @@
 	void addChild(StatefulItem child);
 	void removeChild(StatefulItem child);
-	Collection getChildren();
+	Collection<StatefulItem> getChildren();
 	StatefulItemClass getItemClass();
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/items/SummaryItem.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -24,8 +24,6 @@
 import java.util.HashMap;
 import java.util.Map;
-import org.griphyn.vdl.karajan.lib.RuntimeStats;
-import org.griphyn.vdl.karajan.lib.RuntimeStats.ProgressTicker;
 import org.griphyn.vdl.karajan.monitor.SystemState;
 public class SummaryItem extends AbstractStatefulItem {
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/items/TraceItem.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/items/TraceItem.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/items/TraceItem.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -55,4 +55,9 @@
     public void setEnded(int ended) {
         this.ended = ended;
+    @Override
+    public String toString() {
+        return this.getID() + ": " + ended + "/" + started;
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/Monitor.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/Monitor.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/Monitor.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -32,4 +32,6 @@
     void setOffline(boolean offline);
     TimelineController getTimelineController();
+    void setParams(String params);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/MonitorFactory.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/MonitorFactory.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/MonitorFactory.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -33,16 +33,27 @@
 		classes = new HashMap<String, Class<? extends Monitor>>();
 		classes.put("text", TextMonitor.class);
 		classes.put("ANSI", ANSIMonitor.class);
+		classes.put("TUI", ANSIMonitor.class);
 		classes.put("Swing", SwingMonitor.class);
 	public static Monitor newInstance(String type) throws InstantiationException,
 			IllegalAccessException {
+		String params = null;
+		if (type.contains(":")) {
+			int index = type.indexOf(':');
+			type = type.substring(0, index);
+			params = type.substring(index + 1, type.length());
 		Class<? extends Monitor> cls = classes.get(type);
 		if (cls == null) {
 			throw new IllegalArgumentException("Unsupported monitor type (" + type
 					+ "). The supported types are: " + classes.keySet());
-		return cls.newInstance();
+		Monitor m = cls.newInstance();
+		if (params != null) {
+			m.setParams(params);
+		return m;
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/TextMonitor.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/TextMonitor.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/TextMonitor.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -20,10 +20,21 @@
 package org.griphyn.vdl.karajan.monitor.monitors;
+import org.griphyn.vdl.karajan.monitor.SystemStateListener;
+import org.griphyn.vdl.karajan.monitor.items.StatefulItem;
 public class TextMonitor extends AbstractMonitor {
+    @Override
+    public void itemUpdated(SystemStateListener.UpdateType updateType, StatefulItem item) {
+        System.out.println(updateType + " -> " + item);
     public void shutdown() {
+    @Override
+    public void setParams(String params) {
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/ANSIMonitor.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/ANSIMonitor.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/ANSIMonitor.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -24,10 +24,10 @@
 import java.net.ServerSocket;
 import java.net.Socket;
 import java.util.HashSet;
-import java.util.Iterator;
 import java.util.Set;
 import org.griphyn.vdl.karajan.monitor.monitors.AbstractMonitor;
@@ -35,11 +35,12 @@
     public static final Logger logger = Logger.getLogger(ANSIMonitor.class);
 	private ServerSocket socket;
-	private Set connections;
+	private Set<RemoteANSIConnection> connections;
 	private AbstractANSIDisplay disp;
+	private int port;
 	public ANSIMonitor() {
-		connections = new HashSet();
+		connections = new HashSet<RemoteANSIConnection>();
 		new Thread(this).start();
@@ -47,14 +48,16 @@
 		try {
 			disp = new LocalANSIDisplay(this);
 			disp.start();
-			socket = new ServerSocket(11010);
-			while (true) {
-				Socket s = socket.accept();
-				RemoteANSIConnection c = new RemoteANSIConnection(this, s);
-				synchronized (connections) {
-					connections.add(c);
-				c.start();
+			if (port != 0) {
+    			socket = new ServerSocket(port);
+    			while (true) {
+    				Socket s = socket.accept();
+    				RemoteANSIConnection c = new RemoteANSIConnection(this, s);
+    				synchronized (connections) {
+    					connections.add(c);
+    				c.start();
 		catch (Exception e) {
@@ -62,15 +65,14 @@
-	public void itemUpdated(int updateType, StatefulItem item) {
 		if (disp != null) {
 			disp.itemUpdated(updateType, item);
-			Iterator i = connections.iterator();
-			while (i.hasNext()) {
-				((RemoteANSIConnection) i.next()).itemUpdated(updateType, item);
+		    for (RemoteANSIConnection c : connections) {
+		        c.itemUpdated(updateType, item);
@@ -100,4 +102,9 @@
             e.printStackTrace();
+    @Override
+        port = Integer.parseInt(params);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/AbstractANSIDisplay.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/AbstractANSIDisplay.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/AbstractANSIDisplay.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -28,6 +28,7 @@
 import org.griphyn.vdl.karajan.monitor.StatefulItemClassSet;
 import org.griphyn.vdl.karajan.monitor.items.ApplicationItem;
@@ -257,7 +258,7 @@
         return ben;
         StatefulItemClass cls = item.getItemClass();
         if (cls.equals(StatefulItemClass.APPLICATION)) {
             if (appsTable != null) {
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensCellRenderer.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensCellRenderer.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensCellRenderer.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -32,10 +32,10 @@
 public class BensCellRenderer extends DefaultTableCellRenderer implements
-    private Map lastUpdated;
+    private Map<String, Long> lastUpdated;
     public BensCellRenderer(SystemState state) {
-        lastUpdated = new HashMap();
+        lastUpdated = new HashMap<String, Long>();
         state.addListener(this);
@@ -50,7 +50,7 @@
             l.setJustification(Label.LEFT);
         long now = System.currentTimeMillis();
-        Long then = (Long) lastUpdated.get(String.valueOf(row + 1));
+        Long then = lastUpdated.get(String.valueOf(row + 1));
         if (then != null) {
             long t = then.longValue();
             if (now - t < 2000) {
@@ -69,7 +69,7 @@
         return l;
         if (item.getItemClass().equals(StatefulItemClass.TRACE)) {
             lastUpdated.put(item.getID(), new Long(System.currentTimeMillis()));
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensModel.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensModel.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/BensModel.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -100,7 +100,7 @@
     public void setValueAt(Object value, int rowIndex, int columnIndex) {
             fireTableDataChanged();
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SchedulerInfoPane.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SchedulerInfoPane.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SchedulerInfoPane.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -78,7 +78,7 @@
         hosts.dataChanged();
         if (item.getItemClass().equals(StatefulItemClass.HOST)) {
             update();
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/SummaryPane.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -18,8 +18,9 @@
 package org.griphyn.vdl.karajan.monitor.monitors.ansi;
 import java.io.IOException;
+import java.text.DecimalFormat;
+import java.text.NumberFormat;
-import java.util.TimerTask;
@@ -29,6 +30,7 @@
 import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.Container;
 import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.Dialog;
 import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.Label;
+import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.LevelBar;
 import org.griphyn.vdl.karajan.monitor.monitors.ansi.tui.LevelBars;
 public class SummaryPane extends Container {
@@ -38,19 +40,23 @@
             "Stage in", "Submitting", "Submitted", "Active", "Stage out",
             "Failed", "Replicating", "Finished successfully" };
-    private Label[] labels;
     private LevelBars bars;
+    private LevelBar memory;
+    private Label memlabel;
     public SummaryPane(SystemState state) {
         this.state = state;
         bars = new LevelBars(STATES.length);
-        bars.setLocation(34, 2);
+        bars.setLocation(26, 2);
         add(bars);
-        labels = new Label[STATES.length];
         for (int i = 0; i < STATES.length; i++) {
             addLabel(STATES[i] + ": ", 2, 2 + i, 24);
-            labels[i] = addLabel("0", 25, 2 + i, 8);
+        memlabel = addLabel("Heap: ", 2, 4 + STATES.length, 24);
+        memory = new LevelBar();
+        memory.setLocation(26, 4 + STATES.length);
+        add(memory);
         GlobalTimer.getTimer().schedule(new SafeTimerTask(getScreen()) {
             public void runTask() {
@@ -67,22 +73,57 @@
                     Integer v = counts.get(STATES[i]);
                     if (v != null) {
-                        labels[i].setText(v.toString());
                         bars.setValue(i, v);
+                        bars.setText(i, v.toString());
                     else {
-                        labels[i].setText("0");
                         bars.setValue(i, 0);
+                        bars.setText(i, "0");
+            // mem
+            Runtime r = Runtime.getRuntime();
+            long heapMax = r.maxMemory();
+            long heapCrt = r.totalMemory() - r.freeMemory();
+            double fraction = (double) heapCrt / heapMax;
+            memory.setValue((float) fraction);
+            memory.setText(formatMemory(heapCrt) + " / " + formatMemory(heapMax));
             redraw();
             Dialog.displaySimpleDialog(getScreen(), "Error", e.toString(), new String[] {"Close"});
+    private static final NumberFormat NF = new DecimalFormat("###.##");
+    private String formatMemory(long v) {
+        int l = 1;
+        while (v > 512 * 1024) {
+            v = v / 1024;
+            l++;
+        return NF.format(v / 1024.0) + unit(l);
+    private String unit(int l) {
+        switch(l) {
+            case 0:
+                return "b";
+            case 1:
+                return "Kb";
+            case 2:
+                return "Mb";
+            case 3:
+                return "Gb";
+            case 4:
+                return "Tb";
+            default:
+                return "?";
     private Label addLabel(String text, int x, int y, int w) {
         Label l = new Label(text);
         l.setLocation(x, y);
@@ -99,7 +140,8 @@
     protected void validate() {
-        bars.setSize(width - 35, STATES.length);
+        bars.setSize(width - 27, STATES.length);
+        memory.setSize(width - 27, 1);
         super.validate();
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/ANSIContext.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -193,7 +193,9 @@
             int[] sz = new int[2];
             sz[0] = ((Integer) nums.get(1)).intValue();
             sz[1] = ((Integer) nums.get(0)).intValue();
-            logger.info("Terminal size is " + sz[0] + "x" + sz[1]);
+            if (logger.isDebugEnabled()) {
+                logger.debug("Terminal size is " + sz[0] + "x" + sz[1]);
             return sz;
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBar.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -21,10 +21,13 @@
 public class LevelBar extends Component {
     private float value;
+    private String text;
+    private int textColor;
     public LevelBar() {
         bgColor = ANSI.BLACK;
         fgColor = ANSI.RED;
+        textColor = ANSI.WHITE;
     public float getValue() {
@@ -36,6 +39,15 @@
     protected void draw(ANSIContext context) throws IOException {
+        if (text == null) {
+            drawWithoutText(context);
+        else {
+            drawWithText(context);
+    private void drawWithoutText(ANSIContext context) throws IOException {
         context.moveTo(sx, sy);
         context.bgColor(fgColor);
         int c = (int) (value * width);
@@ -43,4 +55,43 @@
         context.bgColor(bgColor);
         context.spaces(width - c);
+    private void drawWithText(ANSIContext context) throws IOException {
+        int textPos = (width - text.length()) / 2;
+        StringBuilder sb = new StringBuilder();
+        spaces(sb, textPos);
+        sb.append(text);
+        spaces(sb, width - textPos - text.length());
+        String s = sb.toString();
+        context.moveTo(sx, sy);
+        context.bgColor(fgColor);
+        context.fgColor(textColor);
+        int c = (int) (value * width);
+        context.text(s.substring(0, c));
+        context.bgColor(bgColor);
+        context.text(s.substring(c));
+     private void spaces(StringBuilder sb, int count) {
+        for(int i = 0; i < count; i++) {
+            sb.append(' ');
+    public String getText() {
+        return text;
+    public void setText(String text) {
+        this.text = text;
+    public int getTextColor() {
+        return textColor;
+    public void setTextColor(int textColor) {
+        this.textColor = textColor;
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/ansi/tui/LevelBars.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -43,6 +43,10 @@
             getBar(i).setValue((float) values[i] / range);
+    public void setText(int index, String text) {
+        getBar(index).setText(text);
     private LevelBar getBar(int i) {
         return (LevelBar) getComponents().get(i);
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/GanttChart.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/GanttChart.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/GanttChart.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -63,8 +63,8 @@
 	private JTable table, header;
 	private HeaderModel hmodel;
 	private ChartModel cmodel;
-	private List jobs;
-	private Map jobmap;
+	private List<Job> jobs;
+	private Map<String, Job> jobmap;
 	private JScrollPane csp, hsp;
 	private JSpinner scalesp;
 	private long firstEvent;
@@ -74,8 +74,8 @@
 	public GanttChart() {
 		scale = 1.0 / SCALE;
-		jobs = new ArrayList();
-		jobmap = new HashMap();
+		jobs = new ArrayList<Job>();
+		jobmap = new HashMap<String, Job>();
 		header = new JTable() {
 			public Dimension getPreferredSize() {
@@ -127,38 +127,38 @@
 		repaint();
 		if (firstEvent == 0) {
 			firstEvent = System.currentTimeMillis();
 		if (item.getItemClass().equals(StatefulItemClass.APPLICATION)) {
 			ApplicationItem ai = (ApplicationItem) item;
-			if (updateType == ITEM_ADDED) {
+			if (updateType == SystemStateListener.UpdateType.ITEM_ADDED) {
 				addJob(ai);
-			else if (updateType == ITEM_REMOVED) {
-				Job j = (Job) jobmap.get(item.getID());
+			else if (updateType == SystemStateListener.UpdateType.ITEM_REMOVED) {
+				Job j = jobmap.get(item.getID());
 				j.end();
 		else if (item.getItemClass().equals(StatefulItemClass.TASK)) {
 			TaskItem ti = (TaskItem) item;
 			if (ti.getTask() != null && item.getParent() != null) {
-				Job job = (Job) jobmap.get(item.getParent().getID());
+				Job job = jobmap.get(item.getParent().getID());
 				if (job == null) {
 					return;
 				Task task = ti.getTask();
 				if (task.getType() == Task.FILE_OPERATION) {
 						job.addPretask();
 						job.removePretask();
 				else if (task.getType() == Task.JOB_SUBMISSION) {
-					if (updateType == ITEM_UPDATED) {
+					if (updateType == SystemStateListener.UpdateType.ITEM_UPDATED) {
 						job.setJobStatus(ti.getStatus());
 						hmodel.fireTableDataChanged();
@@ -190,7 +190,7 @@
-		public Class getColumnClass(int columnIndex) {
+		public Class<?> getColumnClass(int columnIndex) {
 			return Job.class;
@@ -214,7 +214,7 @@
 			return Job.class;
@@ -275,11 +275,11 @@
 	private class Job {
 		private ApplicationItem ai;
-		private List events;
+		private List<Event> events;
 		private int pretasks;
 		public Job(ApplicationItem ai) {
-			events = new ArrayList();
+			events = new ArrayList<Event>();
 			this.ai = ai;
@@ -411,18 +411,18 @@
 		public void paint(Graphics g) {
-			List events;
+			List<Event> events;
 			synchronized (job.events) {
-				events = new ArrayList(job.events);
+				events = new ArrayList<Event>(job.events);
 			if (events.size() == 0) {
 				return;
 			int ox = 0, ex = 0;
 			boolean endcap = false;
-			Iterator i = events.iterator();
+			Iterator<Event> i = events.iterator();
-				Event e = (Event) i.next();
+				Event e = i.next();
 				if (e.type == StartEvent.TYPE) {
 					ox = e.time;
@@ -452,7 +452,7 @@
 			int lx = ox;
 				int x = (int) (e.time * scale);
 				// System.err.println(crt+", "+lx+", "+x);
 				if (crt != null) {
Modified: branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/SwingMonitor.java
--- branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/SwingMonitor.java	2013-03-19 00:24:44 UTC (rev 6397)
+++ branches/faster/src/org/griphyn/vdl/karajan/monitor/monitors/swing/SwingMonitor.java	2013-03-19 00:28:44 UTC (rev 6398)
@@ -30,6 +30,7 @@
@@ -38,12 +39,12 @@
 public class SwingMonitor extends AbstractMonitor {
 	private JFrame frame;
 	private Timer timer;
-	private Map tablemap;
+	private Map<StatefulItemClass, ClassRenderer> tablemap;
 	private GanttChart gantt;
 	public SwingMonitor() {
 		createFrame();
-		tablemap = new HashMap();
+		tablemap = new HashMap<StatefulItemClass, ClassRenderer>();
 	private void createFrame() {
@@ -82,8 +83,8 @@
 		tabs.add("Gantt Chart", gantt);
-		ClassRenderer table = (ClassRenderer) tablemap.get(item.getItemClass());
+		ClassRenderer table = tablemap.get(item.getItemClass());
 		if (table != null) {
 			table.dataChanged();
@@ -92,4 +93,8 @@
+    @Override
