[Swift-commit] cog r3643
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Mar 18 03:15:08 CDT 2013
r3643 | hategan | 2013-03-18 03:14:23 -0500 (Mon, 18 Mar 2013) | 1 line
added method to determine if there are any tasks running
Index: modules/karajan/src/org/globus/cog/karajan/workflow/events/EventBus.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/events/EventBus.java	(revision 3642)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/events/EventBus.java	(working copy)
@@ -10,10 +10,9 @@
 package org.globus.cog.karajan.workflow.events;
-import java.util.concurrent.BlockingQueue;
-import java.util.concurrent.ExecutorService;
-import java.util.concurrent.Executors;
 import java.util.concurrent.LinkedBlockingQueue;
+import java.util.concurrent.ThreadPoolExecutor;
+import java.util.concurrent.TimeUnit;
 import org.apache.log4j.Logger;
 import org.globus.cog.karajan.stack.VariableStack;
@@ -48,10 +47,12 @@
 	private static final EventBus bus = new EventBus();
 	public volatile static long eventCount;
-	private final ExecutorService es;
+	private final ThreadPoolExecutor es;
 	public EventBus() {
-		es = Executors.newFixedThreadPool(DEFAULT_WORKER_COUNT);
+		es = new ThreadPoolExecutor(DEFAULT_WORKER_COUNT, DEFAULT_WORKER_COUNT,
+                                      0L, TimeUnit.MILLISECONDS,
+                                      new LinkedBlockingQueue<Runnable>());
 	private void _post(FlowElement target, VariableStack stack) {
@@ -72,6 +73,10 @@
 		bus._post(target, stack);
+	public boolean isAnythingRunning() {
+		return es.getActiveCount() != 0;
 	public static void post(Runnable r) {
 	    eventCount++;
 	    bus._post(r);
