[Swift-commit] r6390 - in branches/faster/src/org/griphyn/vdl: engine mapping mapping/file
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Mar 17 23:49:05 CDT 2013
Author: hategan
Date: 2013-03-17 23:49:05 -0500 (Sun, 17 Mar 2013)
New Revision: 6390
Added:
   branches/faster/src/org/griphyn/vdl/mapping/file/DirectoryScanner.java
Modified:
   branches/faster/src/org/griphyn/vdl/engine/Karajan.java
   branches/faster/src/org/griphyn/vdl/mapping/AbsFile.java
   branches/faster/src/org/griphyn/vdl/mapping/AbstractMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/Mapper.java
   branches/faster/src/org/griphyn/vdl/mapping/MapperFactory.java
   branches/faster/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/CSVMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
   branches/faster/src/org/griphyn/vdl/mapping/file/TestMapper.java
Log:
merged mapper parameter checking from 0.94 and added deep globbing (including /**/ for arbitrary depth subdirs)
Modified: branches/faster/src/org/griphyn/vdl/engine/Karajan.java
--- branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -65,6 +65,7 @@
 import org.griphyn.vdl.engine.VariableScope.WriteType;
 import org.griphyn.vdl.karajan.CompilationException;
 import org.griphyn.vdl.karajan.Loader;
+import org.griphyn.vdl.mapping.MapperFactory;
 import org.griphyn.vdl.toolkit.VDLt2VDLx;
 import org.griphyn.vdl.type.NoSuchTypeException;
 import org.safehaus.uuid.UUIDGenerator;
@@ -473,7 +474,9 @@
 			if (mapping != null) {
 				StringTemplate mappingST = new StringTemplate("mapping");
-				mappingST.setAttribute("descriptor", mapping.getDescriptor());
+				String mapperType = mapping.getDescriptor();
+				mappingST.setAttribute("descriptor", mapperType);
+				checkMapperParams(mapperType, mapping);
 				for (int i = 0; i < mapping.sizeOfParamArray(); i++) {
 					Param param = mapping.getParamArray(i);
 					mappingST.setAttribute("params", mappingParameter(param, scope));
@@ -499,6 +502,27 @@
 		scope.bodyTemplate.setAttribute("declarations", variableST);
+    private void checkMapperParams(String mapperType, Mapping mapping) throws CompilationException {
+        if (!MapperFactory.isValidMapperType(mapperType)) {
+            throw new CompilationException("Unknown mapper type: '" + mapperType + "'");
+        Set<String> validParams = MapperFactory.getValidParams(mapperType);
+        if (validParams == null && mapping.sizeOfParamArray() > 0) {
+            throw new CompilationException(mapperType + " does not support any parameters");
+        if (validParams.contains("*")) {
+            // mapper accepts any parameter (e.g. external_mapper)
+            return;
+        for (int i = 0; i < mapping.sizeOfParamArray(); i++) {
+            Param param = mapping.getParamArray(i);
+            if (!validParams.contains(param.getName())) {
+                throw new CompilationException(mapperType + " does not support a '" + param.getName() + "' parameter");
     private StringTemplate mappingParameter(Param param, VariableScope scope) throws CompilationException {
         StringTemplate paramST = template("swift_parameter");
         paramST.setAttribute("name", param.getName());
Modified: branches/faster/src/org/griphyn/vdl/mapping/AbsFile.java
--- branches/faster/src/org/griphyn/vdl/mapping/AbsFile.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/AbsFile.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -44,7 +44,7 @@
 		if (pi == -1) {
 			protocol = "file";
 			host = "localhost";
-			path = url;
+			path = normalize(url);
 		else {
 			protocol = url.substring(0, pi);
@@ -54,7 +54,7 @@
 				if (rp.startsWith("localhost/")) {
 					rp = rp.substring("localhost/".length());
-                path = rp;
+                path = normalize(rp);
 			else {
 				int si = url.indexOf('/', pi + 3);
@@ -64,13 +64,19 @@
 				else {
 					host = url.substring(pi + 3, si);
-					path = url.substring(si + 1);
+					path = normalize(url.substring(si + 1));
 		initDirAndName();
+    private String normalize(String path) {
+        // there is a slight performance penalty here, but it makes things
+        // cleaner
+        return path.replace("/./", "/");
     private void initDirAndName() {
     	int di = path.lastIndexOf('/');
         if (di == 0) {
@@ -126,8 +132,31 @@
 	private static final AbsFile[] FILE_ARRAY = new AbsFile[0];
+	public List<AbsFile> listDirectories(FilenameFilter filter) {
+	    try {
+            FileResource fr = getFileResource();
+            try {
+                List<AbsFile> l = new ArrayList<AbsFile>();
+                for (GridFile gf : fr.list(path)) {
+                    AbsFile f = new AbsFile(protocol, host, gf.getAbsolutePathName());
+                    if (gf.isDirectory() && (filter == null || filter.accept(new File(f.getDir()), f.getName()))) {
+                        l.add(f);
+                return l;
+            finally {
+                releaseResource(fr);
+        catch (Exception e) {
+            // TODO this should be a proper exception
+            throw new RuntimeException(e);
-	public AbsFile[] listFiles(FilenameFilter filter) {
+	public List<AbsFile> listFiles(FilenameFilter filter) {
 		try {
 			try {
@@ -138,7 +167,7 @@
 						l.add(f);
-				return l.toArray(FILE_ARRAY);
+				return l;
 			finally {
@@ -149,7 +178,7 @@
 	public String getName() {
 		return name;
Modified: branches/faster/src/org/griphyn/vdl/mapping/AbstractMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/AbstractMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/AbstractMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -17,6 +17,9 @@
 package org.griphyn.vdl.mapping;
+import java.util.HashSet;
+import java.util.Set;
 import org.apache.log4j.Logger;
 import org.griphyn.vdl.mapping.file.FileGarbageCollector;
@@ -30,8 +33,26 @@
 	public static final Logger logger = Logger.getLogger(AbstractMapper.class);
 	public static final MappingParam PARAM_INPUT = new MappingParam("input", Boolean.FALSE);
-	protected MappingParamSet params;
+	protected void getValidMappingParams(Set<String> s) {
+	    addParams(s, PARAM_INPUT);
+	protected void addParams(Set<String> s, MappingParam... params) {
+	    for (MappingParam p : params) {
+	        s.add(p.getName());
+    @Override
+    public final Set<String> getSupportedParamNames() {
+        Set<String> s = new HashSet<String>();
+        getValidMappingParams(s);
+        return s;
+    protected MappingParamSet params;
 	public synchronized void setParam(MappingParam param, Object value) {
 		if (params == null) {
 			params = new MappingParamSet();
Modified: branches/faster/src/org/griphyn/vdl/mapping/Mapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/Mapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/Mapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -18,6 +18,7 @@
 import java.util.Collection;
 /** This interface must be implemented by a Java class that represents
     a Swift mapper between SwiftScript variables and external data
@@ -78,4 +79,6 @@
     boolean isPersistent(Path path);
+    Set<String> getSupportedParamNames();
Modified: branches/faster/src/org/griphyn/vdl/mapping/MapperFactory.java
--- branches/faster/src/org/griphyn/vdl/mapping/MapperFactory.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/MapperFactory.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -22,6 +22,7 @@
 import java.util.HashMap;
 import java.util.Map;
 import org.griphyn.vdl.mapping.file.AirsnMapper;
 import org.griphyn.vdl.mapping.file.ArrayFileMapper;
@@ -38,11 +39,14 @@
 import org.griphyn.vdl.mapping.file.TestMapper;
 public class MapperFactory {
-	private static Map<String,Class<Mapper>> mappers =
-	    new HashMap<String,Class<Mapper>>();
+	private static Map<String, Class<? extends Mapper>> mappers;
+	private static Map<String, Set<String>> validParams;
 	static {
+	    mappers = new HashMap<String, Class<? extends Mapper>>();
+	    validParams = new HashMap<String, Set<String>>();
 		// the following are general purpose file mappers
 		registerMapper("simple_mapper", SimpleFileMapper.class);
 		registerMapper("single_file_mapper", SingleFileMapper.class);
@@ -62,11 +66,10 @@
 		registerMapper("test_mapper", TestMapper.class);
-	public synchronized static Mapper getMapper(String type, MappingParamSet params)
-	throws InvalidMapperException {
-		Class<Mapper> cls = mappers.get(type);
+	public synchronized static Mapper getMapper(String type, MappingParamSet params) throws InvalidMapperException {
+		Class<? extends Mapper> cls = mappers.get(type);
 		if (cls == null) {
-			throw new InvalidMapperException("no such mapper: "+type);
+			throw new InvalidMapperException("No such mapper: "+type);
 		try {
 			Mapper mapper = cls.newInstance();
@@ -77,15 +80,29 @@
 			throw new InvalidMapperException(type + ": " + e.getMessage(), e);
+	public synchronized static boolean isValidMapperType(String type) {
+	    return mappers.containsKey(type);
+    @SuppressWarnings("unchecked")
+    public static void registerMapper(String type, String cls) throws ClassNotFoundException {
+	    registerMapper(type, (Class<? extends Mapper>) MapperFactory.class.getClassLoader().loadClass(cls));
-    public static void registerMapper(String type, String cls)
-	throws ClassNotFoundException {
-	    registerMapper(type, MapperFactory.class.getClassLoader().loadClass(cls));
+    public synchronized static void registerMapper(String type, Class<? extends Mapper> cls) {
+		mappers.put(type, cls);
+		try {
+		    Mapper m = cls.newInstance();
+		    validParams.put(type, m.getSupportedParamNames());
+		    throw new RuntimeException("Cannot instantiate a '" + type + "'", e);
-	@SuppressWarnings("unchecked")
-    public synchronized static void registerMapper(String type,
-	                                               Class<?> cls) {
-		mappers.put(type, (Class<Mapper>) cls);
+    public static Set<String> getValidParams(String type) {
+        return validParams.get(type);
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/AbstractFileMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -23,8 +23,11 @@
 import java.security.NoSuchAlgorithmException;
 import java.util.ArrayList;
+import java.util.Collections;
 import java.util.Iterator;
 import java.util.List;
+import java.util.StringTokenizer;
 import org.globus.cog.util.Base64;
@@ -32,7 +35,6 @@
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.AbstractMapper;
 import org.griphyn.vdl.mapping.HandleOpenException;
-import org.griphyn.vdl.mapping.InvalidMappingParameterException;
 import org.griphyn.vdl.mapping.MappingParam;
 import org.griphyn.vdl.mapping.MappingParamSet;
 import org.griphyn.vdl.mapping.Path;
@@ -51,15 +53,12 @@
   * <ul>
   *   <li>location - if specified, then all generated filenames
   *                  will be prefixed with this directory, and all lookups
-  *                  for files will happen in this directory</li>
-  *   <li>prefix - if specified, then all filenames will be prefixed
+  *                  for files will happen in this directory. If not specified,
+  *                  the current directory will be used.</li>
+  *   <li>prefix - if specified, then all file names will be prefixed
   *                  with this string</li>
   *   <li>suffix - if specified, then all filenames will be suffixed with
-  *                  this string. If suffix does not begin with a '.'
-  *                  character, then a '.' will be added automatically to
-  *                  separate the rest of the filename from the suffix</li>
-  *   <li>noauto - if specified as "true", then the suffix auto addition of a'.'
-  *                  will be disabled.  Default value is "false".</li>
+  *                  this string.</li>
   *   <li>pattern - if specified, then filenames will be selected from
   *                 the location directory when they match the unix glob
   *                 pattern supplied in this parameter.</li>
@@ -71,9 +70,15 @@
 	public static final MappingParam PARAM_SUFFIX = new MappingParam("suffix", null);
 	public static final MappingParam PARAM_PATTERN = new MappingParam("pattern", null);
 	public static final MappingParam PARAM_LOCATION = new MappingParam("location", null);
-	public static final MappingParam PARAM_NOAUTO = new MappingParam("noauto", "false");
 	private String location, prefix, suffix, pattern;
+	@Override
+	    addParams(s, PARAM_PREFIX, PARAM_SUFFIX, PARAM_PATTERN, PARAM_LOCATION);
+        super.getValidMappingParams(s);
 	public static final Logger logger = Logger.getLogger(AbstractFileMapper.class);
@@ -106,25 +111,29 @@
 	public void setParams(MappingParamSet params) throws HandleOpenException {
 		super.setParams(params);
+		StringBuilder pattern = new StringBuilder();
+		boolean wildcard = false;
+		if (PARAM_PREFIX.isPresent(this)) {
+		    prefix = PARAM_PREFIX.getStringValue(this);
+		    pattern.append(prefix);
+		    pattern.append('*');
+		    wildcard = true;
+		if (PARAM_PATTERN.isPresent(this)) {
+            pattern.append(PARAM_PATTERN.getStringValue(this));
+            wildcard = false;
 		if (PARAM_SUFFIX.isPresent(this)) {
-			String suffix = PARAM_SUFFIX.getStringValue(this);
-			String noauto = PARAM_NOAUTO.getStringValue(this);
-			if (!noauto.equals("true") && !noauto.equals("false")) {
-				throw new InvalidMappingParameterException("noauto parameter value should be 'true' or 'false'" +
-						". Value set was '" + noauto + "'");
+			suffix = PARAM_SUFFIX.getStringValue(this);
+			if (!wildcard) {
-			if (!suffix.startsWith(".") && noauto.equals("false")) {
-			    params.set(PARAM_SUFFIX, "." + suffix);
+			pattern.append(suffix);
-		if (PARAM_PATTERN.isPresent(this)) {
-			String pattern = PARAM_PATTERN.getStringValue(this);
-			params.set(PARAM_PATTERN, replaceWildcards(pattern));
 		location = PARAM_LOCATION.getStringValue(this);
-        pattern = PARAM_PATTERN.getStringValue(this);
+        this.pattern = pattern.toString();
 	public PhysicalFormat map(Path path) {
@@ -219,9 +228,9 @@
     public Collection<Path> existing() {
-		if(logger.isDebugEnabled())
-			logger.debug("list existing paths for mapper id="+this.hashCode());
+		if (logger.isDebugEnabled()) {
+			logger.debug("list existing paths for mapper id=" + this.hashCode());
 		List<Path> result = new ArrayList<Path>();
 		final AbsFile f;
 		if (location == null) {
@@ -229,41 +238,112 @@
 		else {
 			f = new AbsFile(location);
+			if (!f.exists()) {
+			    throw new IllegalArgumentException("Directory not found: " + location);
 		logger.debug("Processing file list.");
-		AbsFile[] files = f.listFiles(new FilenameFilter() {
-			public boolean accept(File dir, String name) {
-				boolean accept = (prefix == null || name.startsWith(prefix))
-						&& (suffix == null || name.endsWith(suffix))
-						&& (pattern == null || name.matches(pattern));
-				logger.debug("file "+name+"? "+accept);
-				return accept;
+		List<AbsFile> files = glob(f, pattern);
 		if (files != null) {
-			for (int i = 0; i < files.length; i++) {
-				if(logger.isDebugEnabled()) logger.debug("Processing existing file "+files[i].getName());
-				Path p = rmap(files[i].getName());
+			for (AbsFile file : files) {
+				    logger.debug("Processing existing file " + file.getName());
+				Path p = rmap(file.getName());
 				if (p != null) {
-					if(logger.isDebugEnabled()) logger.debug("reverse-mapped to path "+p);
+					    logger.debug("reverse-mapped to path " + p);
 					result.add(p);
-				} else {
+				else {
 					logger.debug("reverse-mapped to nothing");
 		else {
-			logger.debug("list existing paths failed for mapper id="+this.hashCode());
-			throw new IllegalArgumentException("Directory not found: " + location);
+			logger.debug("No files found id=" + this.hashCode());
-		if(logger.isDebugEnabled()) {
-			logger.debug("Finish list existing paths for mapper "+this.hashCode()+" list="+result);
+			logger.debug("Finish list existing paths for mapper " + this.hashCode() + " list=" + result);
-		// System.out.println(getVarName() + " (input): found " + result.size() + " files");
 		return result;
+    protected List<AbsFile> glob(AbsFile f, String pattern) {
+        if (pattern.length() == 0) {
+            pattern = "*";
+        List<String> tokens;
+        StringTokenizer st = new StringTokenizer(pattern, File.separator);
+        // avoid creating an array list if only one token exists
+        String firstToken;
+        if (st.hasMoreTokens()) {
+            firstToken = st.nextToken();
+        else {
+            return Collections.emptyList();
+            tokens = new ArrayList<String>();
+            tokens.add(firstToken);
+            while (st.hasMoreTokens()) {
+                tokens.add(st.nextToken());
+        else {
+            tokens = Collections.singletonList(firstToken);
+        globRecursive(f, l, tokens, 0);
+        return l;
+    private void globRecursive(AbsFile f, List<AbsFile> l, List<String> tokens, int pos) {
+        String token = tokens.get(pos);
+        if (pos == tokens.size() - 1) {
+            if (token.equals("**")) {
+                throw new IllegalArgumentException("** cannot be the last path element in a path pattern");
+            // at the file level
+            globFiles(f, l, token);
+        else if (token.equals("**")) {
+            // recursively go through all sub-directories and match the remaining pattern tokens
+            DirectoryScanner ds = new DirectoryScanner(f);
+            while (ds.hasNext()) {
+                AbsFile dir = ds.next();
+                globRecursive(dir, l, tokens, pos + 1);
+        else {
+            // not the last path element, so a directory
+            final String regex = replaceWildcards(token);
+            List<AbsFile> dirs = f.listDirectories(new FilenameFilter() {
+                @Override
+                public boolean accept(File dir, String name) {
+                    return name.matches(regex);
+            for (AbsFile dir : dirs) {
-	private String getVarName() {
+    private void globFiles(AbsFile f, List<AbsFile> l, String token) {
+        List<AbsFile> files = f.listFiles(new FilenameFilter() {
+            @Override
+        l.addAll(files);
+    private String getVarName() {
         AbstractDataNode var = (AbstractDataNode) getParam(MappingParam.SWIFT_HANDLE);
         return var == null ? "" : var.getDisplayableName();
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/ArrayFileMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -37,6 +37,12 @@
     static Logger logger = Logger.getLogger(ArrayFileMapper.class);
 	public static final MappingParam PARAM_FILES = new MappingParam("files");
+	@Override
+	    addParams(s, PARAM_FILES);
 		List<Path> l = new ArrayList<Path>();
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/CSVMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/CSVMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -27,6 +27,7 @@
 import org.griphyn.vdl.mapping.AbsFile;
@@ -56,7 +57,14 @@
 	public static final MappingParam PARAM_HDELIMITER = new MappingParam("hdelim");
 	/** delimiters between content fields. default is space, tab, comma */
-	public static final MappingParam PARAM_DELIMITER = new MappingParam("delim", " \t,");
+	public static final MappingParam PARAM_DELIMITER = new MappingParam("delim", " \t,");
+	@Override
+	    addParams(s, PARAM_FILE, PARAM_HEADER, PARAM_SKIP, PARAM_HDELIMITER, PARAM_DELIMITER);
 	/** list of column names */
 	private List cols = new ArrayList();
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/ConcurrentMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -36,6 +36,13 @@
 public class ConcurrentMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_THREAD_PREFIX = new MappingParam("thread_prefix", "");
+	@Override
+	    addParams(s, PARAM_THREAD_PREFIX);
 	private Map<Path, PhysicalFormat> remappedPaths;
 	public ConcurrentMapper() {
Added: branches/faster/src/org/griphyn/vdl/mapping/file/DirectoryScanner.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/DirectoryScanner.java	                        (rev 0)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/DirectoryScanner.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -0,0 +1,62 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 17, 2013
+package org.griphyn.vdl.mapping.file;
+import java.util.Iterator;
+import java.util.List;
+import java.util.Stack;
+import org.griphyn.vdl.mapping.AbsFile;
+public class DirectoryScanner implements Iterator<AbsFile> {
+    private Stack<Iterator<AbsFile>> paths;
+    public DirectoryScanner(AbsFile root) {
+        paths = new Stack<Iterator<AbsFile>>();
+        paths.push(Collections.singletonList(root).iterator());
+    @Override
+    public boolean hasNext() {
+        while (!paths.isEmpty() && !paths.peek().hasNext()) {
+            paths.pop();
+        if (paths.isEmpty()) {
+            return false;
+        else {
+            return true;
+    @Override
+    public AbsFile next() {
+        AbsFile nextdir = paths.peek().next();
+        List<AbsFile> subdirs = nextdir.listDirectories(null);
+        if (subdirs != null) {
+            paths.push(subdirs.iterator());
+        return nextdir;
+    @Override
+    public void remove() {
+        throw new UnsupportedOperationException();
+    public static void main(String[] args) {
+        AbsFile f = new AbsFile(".");
+        DirectoryScanner s = new DirectoryScanner(f);
+        while (s.hasNext()) {
+            System.out.println(s.next());
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/ExternalMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/ExternalMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -27,6 +27,7 @@
@@ -43,7 +44,15 @@
 	private Map<Path, AbsFile> map;
 	private Map<String, Path> rmap;
-	public static final MappingParam PARAM_EXEC = new MappingParam("exec");
+	public static final MappingParam PARAM_EXEC = new MappingParam("exec");
+	@Override
+	    addParams(s, PARAM_EXEC);
+	    s.add("*");
 	private static final String[] STRING_ARRAY = new String[0];
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/FixedArrayFileMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -20,6 +20,7 @@
@@ -36,7 +37,14 @@
     an array. */
 public class FixedArrayFileMapper extends AbstractMapper {
+	@Override
 	private String[] files;
 	public FixedArrayFileMapper() {
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -22,6 +22,7 @@
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -40,6 +41,13 @@
 	public static final MappingParam PARAM_TRANSFORM = new MappingParam("transform");
 	private String match, source, transform;
+	@Override
+	    addParams(s, PARAM_SOURCE, PARAM_MATCH, PARAM_TRANSFORM);
 	public RegularExpressionMapper() {
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/SimpleFileMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -21,11 +21,19 @@
 public class SimpleFileMapper extends AbstractFileMapper {
 	public static final MappingParam PARAM_PADDING = new MappingParam("padding", new Integer(4));
+	@Override
+	    addParams(s, PARAM_PADDING);
 	public SimpleFileMapper() {
 		super();
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/SingleFileMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -20,6 +20,7 @@
 import java.util.Arrays;
@@ -33,11 +34,16 @@
 public class SingleFileMapper extends AbstractMapper {
-	public static final MappingParam PARAM_FILE = new MappingParam("file");
+	public static final MappingParam PARAM_FILE = new MappingParam("file");
+	private AbsFile file;
-	private AbsFile file;
+	@Override
+	    addParams(s, PARAM_FILE);
-	public SingleFileMapper() {
+    public SingleFileMapper() {
 		super();
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/StructuredRegularExpressionMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -21,6 +21,7 @@
@@ -44,6 +45,12 @@
 	private String match, transform;
+	@Override
 	public StructuredRegularExpressionMapper() {
Modified: branches/faster/src/org/griphyn/vdl/mapping/file/TestMapper.java
--- branches/faster/src/org/griphyn/vdl/mapping/file/TestMapper.java	2013-03-17 14:29:44 UTC (rev 6389)
+++ branches/faster/src/org/griphyn/vdl/mapping/file/TestMapper.java	2013-03-18 04:49:05 UTC (rev 6390)
@@ -19,6 +19,7 @@
@@ -36,6 +37,12 @@
     public static final MappingParam PARAM_REMAPPABLE = new MappingParam("remappable", false);
     public static final MappingParam PARAM_STATIC = new MappingParam("static", true);
+    @Override
+        addParams(s, PARAM_FILE, PARAM_TEMP, PARAM_REMAPPABLE, PARAM_STATIC);
     private PhysicalFormat remap, map;
     private boolean remappable, temp, _static;
