[Swift-commit] r6385 - branches/release-0.94/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Mar 16 17:48:12 CDT 2013
Author: hategan
Date: 2013-03-16 17:48:10 -0500 (Sat, 16 Mar 2013)
New Revision: 6385
Added:
   branches/release-0.94/src/org/griphyn/vdl/mapping/MappingException.java
Modified:
   branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractDataNode.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/DataDependentException.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/DependentException.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/MappingDependentException.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
   branches/release-0.94/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
fixed mapping errors not being reported and causing a hang (bug 967)
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -29,7 +29,6 @@
 import java.util.Map;
 import org.apache.log4j.Logger;
-import org.globus.cog.karajan.workflow.ExecutionException;
 import org.globus.cog.karajan.workflow.futures.Future;
 import org.globus.cog.karajan.workflow.futures.FutureNotYetAvailable;
 import org.griphyn.vdl.karajan.DSHandleFutureWrapper;
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/DataDependentException.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/DataDependentException.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/DataDependentException.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -35,7 +35,7 @@
 	public String getMessage() {
-		return getVariableName() + " not derived due to errors in data dependencies";
+		return getVariableInfo() + " not derived due to errors in data dependencies";
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/DependentException.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/DependentException.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/DependentException.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -50,6 +50,16 @@
 	        return handle.toString();
+	public String getVariableInfo() {
+        if (handle instanceof AbstractDataNode) {
+            AbstractDataNode n = (AbstractDataNode) handle;
+            return n.getDisplayableName() + ", line " + n.getDeclarationLine();
+        else {
+            return handle.toString();
 	public String toString() {
 		return getMessage();
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/MappingDependentException.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/MappingDependentException.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/MappingDependentException.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -35,6 +35,6 @@
-		return getHandle() + " not mapped due to error in mapping dependencies";
+		return getVariableInfo() + " not mapped due to error in mapping dependencies";
Added: branches/release-0.94/src/org/griphyn/vdl/mapping/MappingException.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/MappingException.java	                        (rev 0)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/MappingException.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -0,0 +1,27 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 16, 2013
+package org.griphyn.vdl.mapping;
+public class MappingException extends DependentException {
+    public MappingException(DSHandle handle, Exception prev) {
+        super(handle, prev);
+    public MappingException(DSHandle handle) {
+        super(handle);
+    @Override
+    public String getMessage() {
+        return getVariableInfo() + " had mapping errors";
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/RootArrayDataNode.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/RootArrayDataNode.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -105,12 +105,16 @@
 		catch (DependentException e) {
 			setValue(new MappingDependentException(this, e));
-			closeShallow();
-	public void futureModified(Future f, VariableStack stack) {
-	    innerInit();
+	public void futureModified(Future f, VariableStack stack) {
+	    try {
+	        innerInit();
+	    catch (Exception e) {
+	        this.setValue(new MappingException(this, e));
 	public String getParam(MappingParam p) {
Modified: branches/release-0.94/src/org/griphyn/vdl/mapping/RootDataNode.java
--- branches/release-0.94/src/org/griphyn/vdl/mapping/RootDataNode.java	2013-03-15 21:53:56 UTC (rev 6384)
+++ branches/release-0.94/src/org/griphyn/vdl/mapping/RootDataNode.java	2013-03-16 22:48:10 UTC (rev 6385)
@@ -108,13 +108,16 @@
-			closeShallow();
-			return;
-		innerInit();
+		try {
+            innerInit();
