[Swift-commit] r6376 - trunk/docs/merged/refmanual
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Wed Mar 13 11:07:19 CDT 2013
Author: ketan
Date: 2013-03-13 11:07:19 -0500 (Wed, 13 Mar 2013)
New Revision: 6376
Modified:
   trunk/docs/merged/refmanual/swiftlang
Log:
app and composite functions
Modified: trunk/docs/merged/refmanual/swiftlang
--- trunk/docs/merged/refmanual/swiftlang	2013-03-12 20:32:37 UTC (rev 6375)
+++ trunk/docs/merged/refmanual/swiftlang	2013-03-13 16:07:19 UTC (rev 6376)
@@ -95,19 +95,51 @@
 run time error. Unassigned variables that are inputs to functions
 will lead to a stall in progress.
-== App functions
+== Composite functions
 Swift code is written in composite functions.
-Composite functions have the form:
+[(<output list>)] function_name [(<input list>)]
+  statement;
+  statement;
+An example of a Swift composite function is shown below:
+(Station _stat) get_site(int _run_id) {
+    StationFile file<"/tmp/site_tmp">;
+    file = getsite_file(_run_id);
+    _stat = readData(file);
+== App functions
+Swift app functions are used to integrate external apps into Swift and made
+callable as Swift functions.  App functions have the form:
 [(<output list>)] app function_name [(<input list>)]
   statement;
+An example of an app function definition is as follows:
+(RuptureFile _rup) app getrupture_file(int _run_id) {
+    getrupture _run_id stdout=@filename(_rup);
+Note that an app function may have only one commandline statement while a
+composite function may have multiple statements.
 An empty input or output list may be omitted or written as +()+.
 The output list may have more than one entry.  Thus, assignments
@@ -118,6 +150,7 @@
 (x1, x2) = f(i1, i2);
 == Types
 Swift provides a similar range of primitive types to many other
@@ -370,6 +403,8 @@
 String concatenation is also performed with +++ (plus).
 +==+ and +!=+ may also be used on strings.
+== Standard Library
 === Output
 +trace(anything, anything, ...)+:: Report the value of any variable
@@ -414,13 +449,12 @@
 * +\x+: character +x+
 * +{a,b,c,...}+ any of +a+, +b+, +c+, etc.
-== Defining Leaf functions
+== Defining Apps
 In typical Swift applications, the computationally intensive parts of the
 application are not written in the Swift language.  Rather,
-the work is done by _leaf functions_ that are _composed_ together with
-Swift code.  Leaf functions may be extension or app functions.
-The builtin functions mentioned above are implemented as extension
+the work is done by _app functions_ that are _composed_ together with
+Swift code. The builtin functions mentioned above are implemented as extension
 functions in Tcl.
 === App functions
