[Swift-commit] r6370 - in branches/faster: libexec resources src/org/griphyn/vdl/engine src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Mar 11 14:58:59 CDT 2013
Author: hategan
Date: 2013-03-11 14:58:59 -0500 (Mon, 11 Mar 2013)
New Revision: 6370
Added:
   branches/faster/src/org/griphyn/vdl/karajan/lib/RefCount.java
   branches/faster/src/org/griphyn/vdl/karajan/lib/StaticRefCount.java
   branches/faster/src/org/griphyn/vdl/karajan/lib/While.java
Modified:
   branches/faster/libexec/swift-lib.k
   branches/faster/libexec/swift-operators.k
   branches/faster/resources/Karajan.stg
   branches/faster/src/org/griphyn/vdl/engine/Karajan.java
   branches/faster/src/org/griphyn/vdl/karajan/lib/Operators.java
   branches/faster/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
Log:
fixed iterate
Modified: branches/faster/libexec/swift-lib.k
--- branches/faster/libexec/swift-lib.k	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/libexec/swift-lib.k	2013-03-11 19:58:59 UTC (rev 6370)
@@ -119,6 +119,7 @@
 	export(tParallelFor, def("org.griphyn.vdl.karajan.lib.ThrottledParallelFor"))
 	export(throttled, def("org.griphyn.vdl.karajan.lib.Throttled"))
+	export(while, def("org.griphyn.vdl.karajan.lib.While"))
 	export(appStageins, def("org.griphyn.vdl.karajan.lib.AppStageins"))
 	export(appStageouts, def("org.griphyn.vdl.karajan.lib.AppStageouts"))
Modified: branches/faster/libexec/swift-operators.k
--- branches/faster/libexec/swift-operators.k	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/libexec/swift-operators.k	2013-03-11 19:58:59 UTC (rev 6370)
@@ -14,4 +14,6 @@
 	export(and, def("org.griphyn.vdl.karajan.lib.Operators$And"))
 	export(or, def("org.griphyn.vdl.karajan.lib.Operators$Or"))
 	export(not, def("org.griphyn.vdl.karajan.lib.Operators$Not"))
+	export(inc, def("org.griphyn.vdl.karajan.lib.Operators$Inc"))
\ No newline at end of file
Modified: branches/faster/resources/Karajan.stg
--- branches/faster/resources/Karajan.stg	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/resources/Karajan.stg	2013-03-11 19:58:59 UTC (rev 6370)
@@ -196,17 +196,17 @@
-iterate(declarations,statements,cond,var,cleanups,trace,line) ::= <<
-sys:while($var$, 0) {
+iterate(declarations, statements, cond, var, refs, cleanups, trace, line) ::= <<
+swift:while($var$$if(trace)$, _traceline="$line$"$endif$$if(refs)$, refs="$refs;separator=" "$"$endif$) {
 	if (swift:getFieldValue($cond$)) {
 		$sub_comp(declarations=declarations, statements=statements, cleanups=cleanups)$
-		next($var$ + 1)
+		next(swiftop:inc($var$))
 foreach(var, in, indexVar, indexVarType, declarations, statements, line, refs, selfClose, cleanups, trace) ::= <<
-swift:tParallelFor(\$, _traceline="$line$"$if(indexVar)$, _kvar="$indexVar$"$endif$, _vvar="$var$"$if(selfClose)$, selfClose=true$endif$$if(refs)$, refs="$refs;separator=" "$"$endif$,
+swift:tParallelFor(\$$if(trace)$, _traceline="$line$"$endif$$if(indexVar)$, _kvar="$indexVar$"$endif$, _vvar="$var$"$if(selfClose)$, selfClose=true$endif$$if(refs)$, refs="$refs;separator=" "$"$endif$,
 $! The iterator !$
 	getArrayIterator($in$)) {
 	(\$\$, $var$) := each(\$)
Modified: branches/faster/src/org/griphyn/vdl/engine/Karajan.java
--- branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/src/org/griphyn/vdl/engine/Karajan.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -916,7 +916,7 @@
     public void iterateStat(Iterate iterate, VariableScope scope) throws CompilationException {
-		VariableScope loopScope = new VariableScope(this, scope, EnclosureType.LOOP, iterate);
+		VariableScope loopScope = new VariableScope(this, scope, EnclosureType.ALL, iterate);
 		VariableScope innerScope = new VariableScope(this, loopScope, EnclosureType.LOOP, iterate);
 		loopScope.addVariable(iterate.getVar(), "int", "Iteration variable", iterate);
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/Operators.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/Operators.java	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/Operators.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -67,7 +67,7 @@
 			return ((Integer) v).intValue();
 		else {
-			throw new ExecutionException(n, "Internal error. Expected an int: " + h);
+			throw new ExecutionException(n, "Internal error. Expected an int: " + v + " (" + h + ")");
@@ -265,6 +265,14 @@
             return r;
+	public static class Inc extends SwiftUnaryOp {
+        @Override
+        protected DSHandle value(AbstractDataNode v) {
+            DSHandle r = new RootDataNode(Types.INT, getInt(this, v) + 1);
+            return r;
 	private static void logBinaryProvenance(String name, DSHandle v1, DSHandle v2, DSHandle result) throws ExecutionException {
 		if (PROVENANCE_ENABLED) {
Added: branches/faster/src/org/griphyn/vdl/karajan/lib/RefCount.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/RefCount.java	                        (rev 0)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/RefCount.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -0,0 +1,55 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Mar 11, 2013
+package org.griphyn.vdl.karajan.lib;
+import java.util.ArrayList;
+import java.util.List;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.griphyn.vdl.mapping.DSHandle;
+class RefCount {
+    public final DSHandle var;
+    public final int count;
+    public RefCount(DSHandle var, int count) {
+        this.var = var;
+        this.count = count;
+    public static List<RefCount> build(Stack stack, List<StaticRefCount> srefs) {
+        if (srefs == null) {
+            return null;
+        List<RefCount> l = new ArrayList<RefCount>(srefs.size());
+        for (StaticRefCount s : srefs) {
+            l.add(new RefCount((DSHandle) s.ref.getValue(stack), s.count));
+        return l;
+    public static void decRefs(List<RefCount> rcs) throws ExecutionException {
+            if (rcs != null) {
+                for (RefCount rc : rcs) {
+                    rc.var.updateWriteRefCount(-rc.count);
+    public static void incRefs(List<RefCount> rcs) throws ExecutionException {
+                rc.var.updateWriteRefCount(rc.count);
Added: branches/faster/src/org/griphyn/vdl/karajan/lib/StaticRefCount.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/StaticRefCount.java	                        (rev 0)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/StaticRefCount.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -0,0 +1,48 @@
+import java.util.StringTokenizer;
+import org.globus.cog.karajan.analyzer.Scope;
+import org.globus.cog.karajan.analyzer.VarRef;
+class StaticRefCount {
+    public final VarRef<?> ref;
+    public StaticRefCount(VarRef<?> ref, int count) {
+        this.ref = ref;
+     public static List<StaticRefCount> build(Scope scope, String refs) {
+        if (refs == null) {
+            return null;
+        List<StaticRefCount> l = new ArrayList<StaticRefCount>();
+        String name = null;
+        boolean flip = true;
+        StringTokenizer st = new StringTokenizer(refs);
+        while (st.hasMoreTokens()) {
+            if (flip) {
+                name = st.nextToken();
+            else {
+                int count = Integer.parseInt(st.nextToken());
+                l.add(new StaticRefCount(scope.getVarRef(name), count));
+            flip = !flip;
+        return l;
Modified: branches/faster/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2013-03-11 16:59:36 UTC (rev 6369)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -18,10 +18,8 @@
 import java.io.IOException;
-import java.util.ArrayList;
 import java.util.Iterator;
-import java.util.StringTokenizer;
 import k.rt.ConditionalYield;
@@ -40,13 +38,11 @@
 import org.globus.cog.karajan.analyzer.CompilerSettings;
 import org.globus.cog.karajan.analyzer.Signature;
-import org.globus.cog.karajan.analyzer.VarRef;
 import org.globus.cog.karajan.compiled.nodes.Node;
 import org.globus.cog.karajan.compiled.nodes.UParallelFor;
 import org.globus.cog.karajan.parser.WrapperNode;
 import org.globus.cog.karajan.util.TypeUtil;
 import org.griphyn.vdl.karajan.Pair;
-import org.griphyn.vdl.mapping.DSHandle;
 import org.griphyn.vdl.util.VDL2Config;
 public class ThrottledParallelFor extends UParallelFor {
@@ -79,38 +75,10 @@
 	private Tracer forTracer, iterationTracer;
     private List<StaticRefCount> srefs;
-    private static class StaticRefCount {
-        public final VarRef<?> ref;
-        public final int count;
-        public StaticRefCount(VarRef<?> ref, int count) {
-            this.ref = ref;
-            this.count = count;
-    private static class RefCount {
-        public final DSHandle var;
-        public RefCount(DSHandle var, int count) {
-            this.var = var;
-        public void inc() {
-        public void dec() {
     @Override
     protected Node compileBody(WrapperNode w, Scope argScope, Scope scope)
-        srefs = buildStaticRefs(scope);
+        srefs = StaticRefCount.build(scope, this.refs.getValue());
         if (_traceline.getValue() != null) {
             setLine(Integer.parseInt(_traceline.getValue()));
@@ -119,40 +87,7 @@
         sc = selfClose.getValue();
         return super.compileBody(w, argScope, scope);
-     private List<StaticRefCount> buildStaticRefs(Scope scope) {
-        String refs = this.refs.getValue();
-        if (refs == null) {
-            return null;
-        List<StaticRefCount> l = new ArrayList<StaticRefCount>();
-        String name = null;
-        boolean flip = true;
-        StringTokenizer st = new StringTokenizer(refs);
-        while (st.hasMoreTokens()) {
-            if (flip) {
-                name = st.nextToken();
-            else {
-                int count = Integer.parseInt(st.nextToken());
-                l.add(new StaticRefCount(scope.getVarRef(name), count));
-            flip = !flip;
-        return l;
-    private List<RefCount> buildRefs(Stack stack) {
-        if (srefs == null) {
-            return null;
-        List<RefCount> l = new ArrayList<RefCount>(srefs.size());
-        for (StaticRefCount s : srefs) {
-            l.add(new RefCount((DSHandle) s.ref.getValue(stack), s.count));
-        return l;
     @SuppressWarnings("unchecked")
     @Override
     protected void runBody(final LWThread thr) {
@@ -173,7 +108,7 @@
                         ts = new TPFThreadSet(it, getMaxThreads());
-                    drefs = buildRefs(stack);
+                    drefs = RefCount.build(stack, srefs);
                     ts.lock();
                     fc = stack.frameCount() + 1;
@@ -191,7 +126,7 @@
                     startRest(thr, ts, fc, drefs);
                     ts.unlock();
-                    decRefs(drefs);
+                    RefCount.decRefs(drefs);
                     i++;
                 case 2:
                     ts.waitFor();
@@ -242,7 +177,7 @@
     private boolean startOne(final LWThread thr, final ThreadSet ts, final Object value, final int fcf, List<RefCount> refs) {
-        incRefs(refs);
+        RefCount.incRefs(refs);
         LWThread ct = thr.fork(new KRunnable() {
             @Override
             public void run(LWThread thr2) {
@@ -281,23 +216,7 @@
         ct.start();
         return false;
-    private void decRefs(List<RefCount> rcs) throws ExecutionException {
-            if (rcs != null) {
-                for (RefCount rc : rcs) {
-                    rc.var.updateWriteRefCount(-rc.count);
-    private void incRefs(List<RefCount> rcs) throws ExecutionException {
-                rc.var.updateWriteRefCount(rc.count);
 	private int getMaxThreads() {
 	    if (maxThreadCount < 0) {
@@ -314,7 +233,7 @@
 	protected Object unwrap(Object value) {
         if (value instanceof Pair) {
-            Pair p = (Pair) value;
+            Pair<?> p = (Pair<?>) value;
             if (_kvar.getValue() != null) {
                 return _kvar.getValue() + "=" + p.get(0) + ", " + _vvar.getValue() + "=" + Tracer.unwrapHandle(p.get(1));
Added: branches/faster/src/org/griphyn/vdl/karajan/lib/While.java
--- branches/faster/src/org/griphyn/vdl/karajan/lib/While.java	                        (rev 0)
+++ branches/faster/src/org/griphyn/vdl/karajan/lib/While.java	2013-03-11 19:58:59 UTC (rev 6370)
@@ -0,0 +1,118 @@
+import java.util.LinkedList;
+import k.rt.SingleValueChannel;
+import k.rt.Stack;
+import k.thr.LWThread;
+import k.thr.Yield;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.CompilationException;
+import org.globus.cog.karajan.analyzer.DynamicScope;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.cog.karajan.analyzer.Var;
+import org.globus.cog.karajan.compiled.nodes.InternalFunction;
+import org.globus.cog.karajan.compiled.nodes.Node;
+import org.globus.cog.karajan.parser.WrapperNode;
+import org.griphyn.vdl.mapping.RootDataNode;
+import org.griphyn.vdl.type.Types;
+public class While extends InternalFunction {
+    private String name;
+    private Node body;
+    private ChannelRef.DynamicSingleValued<Object> c_next;
+    private VarRef<Object> var;
+    private ArgRef<String> _traceline;
+    private List<StaticRefCount> srefs;
+    private Tracer tracer;
+    private ArgRef<String> refs;
+    @Override
+    protected Signature getSignature() {
+        return new Signature(params(identifier("name"), optional("refs", null), optional("_traceline", null), block("body")));
+    protected Node compileBody(WrapperNode w, Scope argScope, Scope scope)
+            throws CompilationException {
+        if (_traceline.getValue() != null) {
+            setLine(Integer.parseInt(_traceline.getValue()));
+        tracer = Tracer.getTracer(this);
+        return super.compileBody(w, argScope, scope);
+    @Override
+    protected void compileBlocks(WrapperNode w, Signature sig, LinkedList<WrapperNode> blocks,
+            Scope scope) throws CompilationException {
+        Var v = scope.addVar(name);
+        var = scope.getVarRef(v);
+        Var.Channel next = scope.addChannel("next");
+        c_next = new ChannelRef.DynamicSingleValued<Object>("next", next.getIndex());
+        DynamicScope ds = new DynamicScope(w, scope);
+        super.compileBlocks(w, sig, blocks, ds);
+        ds.close();
+    @Override
+    @SuppressWarnings("unchecked")
+    public void runBody(LWThread thr) {
+        if (body == null) {
+            return;
+        int i = thr.checkSliceAndPopState();
+        SingleValueChannel<Object> next = (SingleValueChannel<Object>) thr.popState();
+        List<RefCount> drefs = (List<RefCount>) thr.popState();
+        Stack stack = thr.getStack();
+        try {
+            switch(i) {
+                case 0:
+                    var.setValue(stack, new RootDataNode(Types.INT, 0));
+                    c_next.create(stack);
+                    RefCount.incRefs(drefs);
+                    next = (SingleValueChannel<Object>) c_next.get(stack);
+                    if (tracer.isEnabled()) {
+                        tracer.trace(thr, unwrap(next));
+                    i++;
+                case 1:
+                    while (true) {
+                        body.run(thr);
+                        if (next.isEmpty()) {
+                            break;
+                        Object val = next.removeFirst();
+                        var.setValue(stack, val);
+        catch (Yield y) {
+            y.getState().push(drefs);
+            y.getState().push(next);
+            y.getState().push(i);
+            throw y;
