[Swift-commit] r6587 - branches/release-0.94/tests/language-behaviour/IO
yadunandb at ci.uchicago.edu yadunandb at ci.uchicago.edu
Tue Jun 18 13:35:40 CDT 2013
Author: yadunandb
Date: 2013-06-18 13:35:39 -0500 (Tue, 18 Jun 2013)
New Revision: 6587
Added:
   branches/release-0.94/tests/language-behaviour/IO/readData3.out.expected
   branches/release-0.94/tests/language-behaviour/IO/readData3.swift
   branches/release-0.94/tests/language-behaviour/IO/title.txt
Log:
Adding test to confirm Bug: 1028
Added: branches/release-0.94/tests/language-behaviour/IO/readData3.out.expected
--- branches/release-0.94/tests/language-behaviour/IO/readData3.out.expected	                        (rev 0)
+++ branches/release-0.94/tests/language-behaviour/IO/readData3.out.expected	2013-06-18 18:35:39 UTC (rev 6587)
@@ -0,0 +1 @@
+9
\ No newline at end of file
Added: branches/release-0.94/tests/language-behaviour/IO/readData3.swift
--- branches/release-0.94/tests/language-behaviour/IO/readData3.swift	                        (rev 0)
+++ branches/release-0.94/tests/language-behaviour/IO/readData3.swift	2013-06-18 18:35:39 UTC (rev 6587)
@@ -0,0 +1,23 @@
+type file;
+   Test case added to confirm Bug 1028 - readData in a foreach loop fails to compile.
+   https://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=1028
+   This test is expected to fail to compile till bug is resolved.
+app (file o) mysim (int i)
+  echo i stdout=@filename(o);
+int nums[];
+foreach i in [0:9] {
+  file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  f = mysim(i);
+  nums[i] = readData(f);
+file result <"readData3.out">;
+result = mysim(nums[i]);
Added: branches/release-0.94/tests/language-behaviour/IO/title.txt
--- branches/release-0.94/tests/language-behaviour/IO/title.txt	                        (rev 0)
+++ branches/release-0.94/tests/language-behaviour/IO/title.txt	2013-06-18 18:35:39 UTC (rev 6587)
@@ -0,0 +1 @@
+Language Behavior tests : Subgroup local IO
