[Swift-commit] r6572 - in SwiftTutorials/CMTS_2013-06-17/basic_swift: . swift10
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Jun 17 14:14:57 CDT 2013
Author: ketan
Date: 2013-06-17 14:14:57 -0500 (Mon, 17 Jun 2013)
New Revision: 6572
Added:
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/README
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/apps
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_5nm.coor
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_qvals.txt
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/p10.swift
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/particles.dat
   SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/sites.xml
Log:
TJ Lane's example
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/README
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/README	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/README	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,25 @@
+TOPIC: Example illustrating readData from a file with multiple fields
+To run:
+  $ swift p10.swift
+In this example, multiple fields from a file are read into a Swift struct
+variable. The file particles.dat contains eight fields corresponding to eight
+members in the struct type defined in p10.swift as follows:
+type shootargs{
+    string coords;
+    string qvals;
+    int numphi;
+    int numshots;
+    int nummolec;
+    float photons;
+    int parallel;
+    string output_filename;
+Note that the first row in the particles.dat corresponds to the member names in
+the shootargs type which is how Swift assigns values to structure member
+variables.
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/apps
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/apps	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/apps	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,3 @@
+cmtsworkshop random4  random4.sh
+cmtsworkshop echo  echo
+localhost    average  avg.sh
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_5nm.coor
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_5nm.coor	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_5nm.coor	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,3 @@
+Test.
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_qvals.txt
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_qvals.txt	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/gold_qvals.txt	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,3 @@
+Hello
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/p10.swift
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/p10.swift	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/p10.swift	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,30 @@
+type qvalfile;
+type coordfile;
+type shotfile;
+type shootargs{
+    string coords;
+    string qvals;
+    int numphi;
+    int numshots;
+    int nummolec;
+    float photons;
+    int parallel;
+app (shotfile outfile) shootsim (shootargs args, coordfile coords, qvalfile qvals) {
+     echo "polshoot" "-s" @coords "-f" @qvals "-x" args.numphi "-n" args.numshots
+                     "-m" args.nummolec "-g" args.photons "-p" args.parallel "-o" @outfile
+                     stdout=@outfile; # Note double use of outfile, just for testing/demo
+shootargs myargs[] = readData("particles.dat");
+foreach a in myargs {
+    shotfile  output <single_file_mapper; file=a.output_filename>;
+    coordfile coords <single_file_mapper; file=a.coords>;
+    qvalfile  qvals  <single_file_mapper; file=a.qvals>;
+    output = shootsim(a, coords, qvals);
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/particles.dat
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/particles.dat	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/particles.dat	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,6 @@
+coords        qvals          numphi numshots nummolec photons parallel output_filename
+gold_5nm.coor gold_qvals.txt 3600   10       1        0.25    12       out0.ring
+gold_5nm.coor gold_qvals.txt 3600   10       2        0.5     12       out1.ring
+gold_5nm.coor gold_qvals.txt 3600   10       4        1.0     12       out2.ring
+gold_5nm.coor gold_qvals.txt 3600   10       8        2.0     12       out3.ring
+gold_5nm.coor gold_qvals.txt 3600   10       16       4.0     12       out4.ring
Added: SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/sites.xml
--- SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/sites.xml	                        (rev 0)
+++ SwiftTutorials/CMTS_2013-06-17/basic_swift/swift10/sites.xml	2013-06-17 19:14:57 UTC (rev 6572)
@@ -0,0 +1,39 @@
+<config>
+  <pool handle="localhost">
+    <execution provider="local"/>
+    <filesystem provider="local"/>
+    <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
+  </pool>
+  <pool handle="cmtsworkshop">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <!-- Set partition and account here: -->
+    <profile namespace="globus" key="queue">cmtsworkshop</profile>
+    <profile namespace="globus" key="ppn">8</profile>
+    <profile namespace="globus" key="project">cmtsworkshop</profile>
+    <!-- Set number of jobs and nodes per job here: -->
+    <profile namespace="globus" key="slots">4</profile>
+    <profile namespace="globus" key="maxnodes">1</profile>
+    <profile namespace="globus" key="nodegranularity">1</profile>
+    <profile namespace="globus" key="jobsPerNode">8</profile> <!-- apps per node! -->
+    <profile namespace="karajan" key="jobThrottle">.31</profile> <!-- eg .31 -> 32 -->
+    <!-- Set estimated app time (maxwalltime) and requested job time (maxtime) here: -->
+    <profile namespace="globus" key="maxWalltime">00:15:00</profile>
+    <profile namespace="globus" key="maxtime">1800</profile>  <!-- in seconds! -->
+    <!-- Set data staging model and work dir here: -->
+    <!-- Typically leave these constant: -->
+    <profile namespace="globus" key="slurm.exclusive">false</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+  </pool>
+</config>
