[Swift-commit] cog r3673
swift at ci.uchicago.edu swift at ci.uchicago.edu
Sat Jun 15 18:50:03 CDT 2013
r3673 | hategan | 2013-06-15 18:48:32 -0500 (Sat, 15 Jun 2013) | 1 line
prevent log configuration warnings when running along with something that replaces the file appender with an async appender (such as swift)
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java	(revision 3672)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/CoasterService.java	(working copy)
@@ -405,11 +405,8 @@
     public static void configureLogName() {
-        FileAppender fa = (FileAppender) getAppender(FileAppender.class);
-        if (fa == null) {
-            logger.warn("Failed to configure log file name");
-        else {
+        FileAppender fa = (FileAppender) getFileAppender();
+        if (fa != null) {
             fa.setFile(Bootstrap.LOG_DIR + File.separator + makeLogFileName());
             fa.activateOptions();
@@ -430,16 +427,23 @@
         root.addAppender(aa);
-    @SuppressWarnings({ "rawtypes", "unchecked" })
-    protected static Appender getAppender(Class cls) {
+    @SuppressWarnings("rawtypes")
+    protected static Appender getFileAppender() {
         Logger root = Logger.getRootLogger();
         Enumeration e = root.getAllAppenders();
         while (e.hasMoreElements()) {
             Appender a = (Appender) e.nextElement();
-            if (cls.isAssignableFrom(a.getClass())) {
+            if (a instanceof FileAppender) {
                 return a;
+            if (a instanceof AsyncAppender) {
+                // likely this is running in a JVM in which
+                // the file appender has been replaced with
+                // an async appender, so don't mess with things
+                return null;
+        logger.warn("Could not find a file appender to configure");
         return null;
