[Swift-commit] r6542 - SwiftTutorials/OHBM_2013-06-16
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Thu Jun 13 10:13:05 CDT 2013
Author: wilde
Date: 2013-06-13 10:13:05 -0500 (Thu, 13 Jun 2013)
New Revision: 6542
Added:
   SwiftTutorials/OHBM_2013-06-16/TODO
   SwiftTutorials/OHBM_2013-06-16/apps.beagle
   SwiftTutorials/OHBM_2013-06-16/makedata.sh
Modified:
   SwiftTutorials/OHBM_2013-06-16/README
   SwiftTutorials/OHBM_2013-06-16/align.sh
   SwiftTutorials/OHBM_2013-06-16/genatlas.swift
   SwiftTutorials/OHBM_2013-06-16/sites.xml
   SwiftTutorials/OHBM_2013-06-16/swift.properties
Log:
Misc changes; updated README; add beagle and midway site defs; adjust properties.
Modified: SwiftTutorials/OHBM_2013-06-16/README
--- SwiftTutorials/OHBM_2013-06-16/README	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/README	2013-06-13 15:13:05 UTC (rev 6542)
@@ -18,16 +18,30 @@
   module load swift
+To generate test data directories:
+  ./makedata data_100 100 # create 100 anatomical image volumes in directory data_100
 To run:
  # On localhost:
- swift genatlas.swift
+ swift genatlas.swift             # processes data/ directory by default
+ swift genatlas.swift -d=data_100 # process data_100/ directory
  # With most parallel work on midway westmere parition:
  swift -tc.file apps.midway genatlas.swift
+ # Choices for -tc.file are:
+ apps         # default, runs on localhost
+ apps.beagle  # on beagle, 8 nodes
+ apps.midway  # on midway westmere, 1 node
+ apps.amazon  # on Amazon EC2 - needs start-coaster-service, see below
+ apps.UC3     # submits to UC3, needs apps to be sent.
 The output files of the workflow are placed under output/,
 intermediate files under work/.
Added: SwiftTutorials/OHBM_2013-06-16/TODO
--- SwiftTutorials/OHBM_2013-06-16/TODO	                        (rev 0)
+++ SwiftTutorials/OHBM_2013-06-16/TODO	2013-06-13 15:13:05 UTC (rev 6542)
@@ -0,0 +1,5 @@
+timeseries:
+/scratch/midway/wilde/ds107/ds107/sub001/model/model001
Modified: SwiftTutorials/OHBM_2013-06-16/align.sh
--- SwiftTutorials/OHBM_2013-06-16/align.sh	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/align.sh	2013-06-13 15:13:05 UTC (rev 6542)
@@ -1,7 +1,6 @@
 #!/bin/sh
-AIR5=/home/wilde/software/AIR5.3.0
-fsl=/project/wilde/software/fsl-5.0.4/fsl
+#AIR5=/home/wilde/software/AIR5.3.0
 # Arguments: referenceImage (in) anatomicalImage (in) reslicedImage (out)
@@ -23,6 +22,8 @@
+fsl=/project/wilde/software/fsl-5.0.4/fsl
 clean=y
 if [ $clean = y ]; then
Modified: SwiftTutorials/OHBM_2013-06-16/apps
--- SwiftTutorials/OHBM_2013-06-16/apps	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/apps	2013-06-13 15:13:05 UTC (rev 6542)
@@ -1,4 +1,5 @@
-localhost sh       /bin/sh
+localhost sh       /bin/sh null null env::AIR5=/home/wilde/software/AIR5.3.0
+#localhost sh       /bin/sh
 localhost softmean /home/wilde/software/AIR5.3.0/bin/softmean
 localhost slicer   /project/wilde/software/fsl-5.0.4/fsl/bin/slicer null null env::FSLOUTPUTTYPE=NIFTI
 localhost convert  convert
Added: SwiftTutorials/OHBM_2013-06-16/apps.beagle
--- SwiftTutorials/OHBM_2013-06-16/apps.beagle	                        (rev 0)
+++ SwiftTutorials/OHBM_2013-06-16/apps.beagle	2013-06-13 15:13:05 UTC (rev 6542)
@@ -0,0 +1,4 @@
+beagle    sh       /bin/sh null null env::AIR5=/lustre/beagle/wilde/software/AIR5.3.0
+localhost softmean /home/wilde/software/AIR5.3.0/bin/softmean
+localhost slicer   /project/wilde/software/fsl-5.0.4/fsl/bin/slicer null null env::FSLOUTPUTTYPE=NIFTI
+localhost convert  convert
Modified: SwiftTutorials/OHBM_2013-06-16/genatlas.swift
--- SwiftTutorials/OHBM_2013-06-16/genatlas.swift	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/genatlas.swift	2013-06-13 15:13:05 UTC (rev 6542)
@@ -5,18 +5,13 @@
   file image;
-app (Volume alignedVol) align (file alignScript, Volume reference, Volume input)
+app (Volume alignedVol) align (file script, Volume reference, Volume input)
-  sh @alignScript @filename(reference.image) @filename(input.image) @filename(alignedVol.image);
+  sh @script @filename(reference.image) @filename(input.image) @filename(alignedVol.image);
 app (Volume atlas) softmean (Volume v[])
-  softmean @filename(atlas.header) "y" "null" imageNames(v);
-app (Volume atlas) softmeanORIG (Volume v[])
   softmean @filename(atlas.header) "y" "null" @filenames(v);
@@ -30,12 +25,13 @@
   convert @i @o;
+string dataDir = @arg("d","data");
+file   alignScript<"align.sh">;
 Volume referenceVolume<ext; exec="volmapper",name="data/reference">;
-Volume inputVolumes []<ext; exec="volmapper",prefix="data/anatomy">;
+Volume inputVolumes []<ext; exec="volmapper",prefix=@strcat(dataDir,"/anatomy")>;
 Volume outputVolumes[];
-file alignScript<"align.sh">;
 foreach v, i in inputVolumes {
   Volume aligned<ext; exec="volmapper",name=@strcat("work/aligned",i)>;
   aligned = align(alignScript,referenceVolume, v);
@@ -54,16 +50,19 @@
 zSlice = convert(slicer(atlasVolume,"z"));
+/******* The following code to be removed
 string testNames[] = imageNames(outputVolumes);
 foreach n, i in testNames {
   tracef("testNames[%i] = %s\n", i, n);
+app (Volume atlas) softmeanALT (Volume v[]) # A better version
+  softmean @filename(atlas.header) "y" "null" imageNames(v); # puts only the .img on command line
 (string onames[]) imageNames (Volume v[])
   string names[] = @filenames(v);
@@ -75,3 +74,4 @@
\ No newline at end of file
Added: SwiftTutorials/OHBM_2013-06-16/makedata.sh
--- SwiftTutorials/OHBM_2013-06-16/makedata.sh	                        (rev 0)
+++ SwiftTutorials/OHBM_2013-06-16/makedata.sh	2013-06-13 15:13:05 UTC (rev 6542)
@@ -0,0 +1,24 @@
+#! /bin/sh
+datadir=${1:-data_10}
+nfiles=${2:-10}
+rm -rf $datadir
+mkdir $datadir
+cp data/anatomy1.{hdr,img} $datadir
+n=0
+( cd  $datadir
+  mv anatomy1.hdr s.hdr
+  mv anatomy1.img s.img
+  for id in $(seq -w 000 999); do
+      n=$((n+1))
+      if [ $n -gt $nfiles ]; then
+        break;
+      else
+        ln s.img anatomy$id.img
+        ln s.hdr anatomy$id.hdr
+      fi
+  done
+  rm s.{img,hdr}
Property changes on: SwiftTutorials/OHBM_2013-06-16/makedata.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftTutorials/OHBM_2013-06-16/sites.xml
--- SwiftTutorials/OHBM_2013-06-16/sites.xml	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/sites.xml	2013-06-13 15:13:05 UTC (rev 6542)
@@ -5,6 +5,7 @@
     <profile namespace="karajan" key="initialScore">10000</profile>
     <filesystem provider="local"/>
     <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
+    <profile namespace="swift" key="stagingMethod">file</profile>
     <profile namespace="karajan" key="jobThrottle">.03</profile> <!-- eg .11 -> 12 -->
   </pool>
@@ -38,4 +39,24 @@
   </pool>
+  <pool handle="beagle">
+    <execution provider="coaster" jobmanager="ssh-cl:pbs" url="login.beagle.ci.uchicago.edu"/>
+    <profile namespace="globus" key="jobsPerNode">24</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24</profile>
+    <!-- to use a beage reservation, eg:
+         <profile namespace="globus" key="providerAttributes">pbs.aprun;pbs.mpp;depth=24;pbs.resource_list=advres=wilde.1768</profile>
+    <profile namespace="globus" key="maxtime">3600</profile>
+    <profile namespace="globus" key="maxWalltime">00:05:00</profile>
+    <profile namespace="globus" key="userHomeOverride">/lustre/beagle/{env.USER}/swiftwork</profile>
+    <profile namespace="globus" key="slots">20</profile>
+    <profile namespace="globus" key="maxnodes">1</profile>
+    <profile namespace="globus" key="nodeGranularity">1</profile>
+    <profile namespace="karajan" key="jobThrottle">4.80</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <workdirectory>/tmp/{env.USER}/swiftwork</workdirectory>
+  </pool>
 </config>
Modified: SwiftTutorials/OHBM_2013-06-16/swift.properties
--- SwiftTutorials/OHBM_2013-06-16/swift.properties	2013-06-13 13:43:03 UTC (rev 6541)
+++ SwiftTutorials/OHBM_2013-06-16/swift.properties	2013-06-13 15:13:05 UTC (rev 6542)
@@ -3,12 +3,12 @@
 tc.file=apps
 status.mode=provider
-use.provider.staging=false
+use.provider.staging=true
 use.wrapper.staging=false
 wrapperlog.always.transfer=true
 execution.retries=0
 lazy.errors=false
-provider.staging.pin.swiftfiles=false
+provider.staging.pin.swiftfiles=true
 sitedir.keep=true
 file.gc.enabled=false
 #tcp.port.range=50000,51000
