[Swift-commit] r6673 - in trunk/src/org/griphyn/vdl: karajan/lib karajan/lib/swiftscript mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Jul 28 23:35:49 CDT 2013
Author: hategan
Date: 2013-07-28 23:35:49 -0500 (Sun, 28 Jul 2013)
New Revision: 6673
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java
   trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
   trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java
   trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
   trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   trunk/src/org/griphyn/vdl/mapping/AbsFile.java
Log:
removed the use of java.net.(URI|URL) for parsing and use a custom based thing in cog since there are problems with URIs and spaces and URLs and path-only strings
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppStageins.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -79,8 +79,8 @@
             if (protocol.equals("file")) {
                 protocol = stagingMethod;
-            String path = file.getDir().equals("") ?
-                    file.getName() : file.getDir() + "/" + file.getName();
+            String path = file.getDirectory() == null ?
+                    file.getName() : file.getDirectory() + "/" + file.getName();
             String relpath = path.startsWith("/") ? path.substring(1) : path;
             if (logger.isDebugEnabled()) {
                 logger.debug("will stage in: " + relpath + " via: " + protocol);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppStageouts.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -73,7 +73,7 @@
-                String path = file.getDir().equals("") ? file.getName() : file.getDir()
+                String path = file.getDirectory() == null ? file.getName() : file.getDirectory()
                 cr_stageout.append(stack,
Modified: trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java
--- trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/FileCopier.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -50,9 +50,9 @@
         AbsFile fsrc = (AbsFile) src;
         AbsFile fdst = (AbsFile) dst;
         FileTransferSpecification fts = new FileTransferSpecificationImpl();
-        fts.setDestinationDirectory(fdst.getDir());
+        fts.setDestinationDirectory(fdst.getDirectory());
         fts.setDestinationFile(fdst.getName());
-        fts.setSourceDirectory(fsrc.getDir());
+        fts.setSourceDirectory(fsrc.getDirectory());
         fts.setSourceFile(fsrc.getName());
         fts.setThirdPartyIfPossible(true);
         task = new FileTransferTask();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/InFileDirs.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -50,14 +50,16 @@
         Channel<Object> ret = cr_vargs.get(stack);
         for (String path : files) {
         	AbsFile af = new AbsFile(path);
-        	String dir = af.getDir();
-        	if ("file".equals(af.getProtocol())) {
-                ret.add(PathUtils.remotePathName(dir));
+        	String dir = af.getDirectory();
+        	if (dir != null) {
+            	if ("file".equals(af.getProtocol())) {
+                    ret.add(PathUtils.remotePathName(dir));
+            	else {
+            	    // also prepend host name to the path
+            	    ret.add(af.getHost() + "/" + PathUtils.remotePathName(dir));
-        	else {
-        	    // also prepend host name to the path
-        	    ret.add(af.getHost() + "/" + PathUtils.remotePathName(dir));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java
--- trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/OutFileDirs.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -22,6 +22,7 @@
 import java.util.List;
+import k.rt.Channel;
 import k.rt.ExecutionException;
 import k.rt.Stack;
@@ -46,6 +47,7 @@
     @Override
     public Object function(Stack stack) {
         List<List<Object>> files = stageouts.getValue(stack);
+        Channel<Object> ret = cr_vargs.get(stack);
         try {
             for (List<Object> pv : files) {
                 Path p = parsePath(pv.get(0));
@@ -53,18 +55,15 @@
                 DSHandle leaf = handle.getField(p);
                 String fname = SwiftFunction.filename(leaf)[0];
                 AbsFile af = new AbsFile(fname);
-                    if (dir.startsWith("/") && dir.length() != 1) {
-                        cr_vargs.append(stack, dir.substring(1));
-                    else if (dir.length() != 0) {
-                        cr_vargs.append(stack, dir);
+                    else {
-                else {
-                	cr_vargs.append(stack, af.getHost() + "/" + af.getDir());
         catch (Exception e) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java
--- trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/PathUtils.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -40,7 +40,7 @@
         @Override
-            return new AbsFile(path.getValue(stack)).getDir();
+            return new AbsFile(path.getValue(stack)).getDirectory();
@@ -54,8 +54,13 @@
         @Override
-            String dir = new AbsFile(path.getValue(stack)).getDir();
-            return remotePathName(dir);
+            String dir = new AbsFile(path.getValue(stack)).getDirectory();
+                return remotePathName(dir);
+            else {
+                return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -584,8 +584,8 @@
             AbstractDataNode dn = file.getValue(stack);
             String name = SwiftFunction.filename(dn)[0];
-            String result = new AbsFile(name).getDir();
-            DSHandle handle = new RootDataNode(Types.BOOLEAN, result);
+            String result = new AbsFile(name).getDirectory();
+            DSHandle handle = new RootDataNode(Types.STRING, result);
             if (PROVENANCE_ENABLED) {
                 int provid = SwiftFunction.nextProvenanceID();
Modified: trunk/src/org/griphyn/vdl/mapping/AbsFile.java
--- trunk/src/org/griphyn/vdl/mapping/AbsFile.java	2013-07-27 18:18:11 UTC (rev 6672)
+++ trunk/src/org/griphyn/vdl/mapping/AbsFile.java	2013-07-29 04:35:49 UTC (rev 6673)
@@ -31,78 +31,43 @@
 import org.globus.cog.abstraction.impl.file.FileResourceCache;
 import org.globus.cog.abstraction.interfaces.FileResource;
 import org.globus.cog.abstraction.interfaces.GridFile;
+import org.globus.cog.abstraction.interfaces.RemoteFile;
 import org.globus.cog.abstraction.interfaces.Service;
-public class AbsFile implements GeneralizedFileFormat {
-	private final String protocol;
-	private final String host;
-	private final String path;
-	private String dir, name;
+public class AbsFile extends RemoteFile implements GeneralizedFileFormat {
 	public AbsFile(String url) {
-		int pi = url.indexOf("://");
-		if (pi == -1) {
-			protocol = "file";
-			host = "localhost";
-			path = normalize(url);
-		else {
-			protocol = url.substring(0, pi);
-			if (protocol.equals("file")) {
-				String rp = url.substring(pi + 3);
-				if (rp.startsWith("localhost/")) {
-					rp = rp.substring("localhost/".length());
-                path = normalize(rp);
-			else {
-				int si = url.indexOf('/', pi + 3);
-				if (si == -1) {
-					host = url.substring(pi + 3);
-					path = "";
-				else {
-					host = url.substring(pi + 3, si);
-					path = normalize(url.substring(si + 1));
-		initDirAndName();
+	    super(url);
-    private String normalize(String path) {
-        // there is a slight performance penalty here, but it makes things
-        // cleaner
-        return path.replace("/./", "/");
+	public AbsFile(String protocol, String host, String path) {
+	    super(protocol, host, path);
+	public AbsFile(String protocol, String host, int port, String dir, String name) {
+        super(protocol, host, port, dir, name);
-    private void initDirAndName() {
-    	int di = path.lastIndexOf('/');
-        if (di == 0) {
-            dir = "/";
+    public AbsFile(String protocol, String host, int port, String path) {
+        super(protocol, host, port, path);
+    @Override
+    protected void parse(String str) {
+        super.parse(str);
+        if (getProtocol() == null) {
+            setProtocol("file");
-        else if (di > 0) {
-            dir = path.substring(0, di);
+        if (getHost() == null) {
+            setHost("localhost");
-        else {
-            dir = "";
-        name = path.substring(di + 1);
-	public AbsFile(String protocol, String host, String path) {
-		this.protocol = protocol;
-		this.host = host;
-		this.path = path;
-		initDirAndName();
-	protected FileResource getFileResource() throws IOException {
+    protected FileResource getFileResource() throws IOException {
 		Service s = new ServiceImpl();
-		s.setProvider(protocol);
+		s.setProvider(getProtocol());
 		s.setType(Service.FILE_OPERATION);
-		s.setServiceContact(new ServiceContactImpl(host));
+		s.setServiceContact(new ServiceContactImpl(getHost(), getPort()));
 		try {
 			return FileResourceCache.getDefault().getResource(s);
@@ -119,7 +84,7 @@
 		try {
 			FileResource fr = getFileResource();
 			try {
-				return fr.exists(path);
+				return fr.exists(getPath());
 			finally {
 				releaseResource(fr);
@@ -137,10 +102,16 @@
 	    try {
             try {
+                String protocol = getProtocol();
+                String host = getHost();
+                int port = getPort();
+                String dir = getPath();
                 List<AbsFile> l = new ArrayList<AbsFile>();
-                for (GridFile gf : fr.list(path)) {
-                    AbsFile f = new AbsFile(protocol, host, gf.getAbsolutePathName());
-                    if (gf.isDirectory() && (filter == null || filter.accept(new File(f.getDir()), f.getName()))) {
+                for (GridFile gf : fr.list(dir)) {
+                    AbsFile f = new AbsFile(protocol, host, port, dir, gf.getName());
+                    // f.getDirectory() cannot be null since dir cannot be null since getPath() returns
+                    // a non-null string
+                    if (gf.isDirectory() && (filter == null || filter.accept(new File(f.getDirectory()), f.getName()))) {
                         l.add(f);
@@ -160,10 +131,14 @@
 		try {
 			try {
-					if (filter == null || filter.accept(new File(f.getDir()), f.getName())) {
+					if (filter == null || filter.accept(new File(f.getDirectory()), f.getName())) {
 						l.add(f);
@@ -179,64 +154,16 @@
-	public String getName() {
-		return name;
-	public String getDir() {
-		return dir;
-	public String getProtocol() {
-		return protocol;
-	public String getHost() {
-		return host;
-	public String getPath() {
-		return path;
-	public boolean isAbsolute() {
-	    return !path.isEmpty() && path.startsWith("/");
 	public String getType() {
 		return "file";
-	public String getURIAsString() {
-		return protocol + "://" + host + '/' + path;
-	public String toString() {
-		return getURIAsString();
     public void clean() {
         try {
-            getFileResource().deleteFile(path);
+            getFileResource().deleteFile(getPath());
             throw new RuntimeException(e);
-    @Override
-    public boolean equals(Object obj) {
-        if (obj instanceof AbsFile) {
-            AbsFile a = (AbsFile) obj;
-            return protocol.equals(a.protocol) && host.equals(a.host) && path.equals(a.path);
-        else {
-            return false;
-    @Override
-    public int hashCode() {
-        return protocol.hashCode() + host.hashCode() + path.hashCode();
