[Swift-commit] cog r3746
swift at ci.uchicago.edu swift at ci.uchicago.edu
Mon Jul 22 15:10:03 CDT 2013
r3746 | hategan | 2013-07-22 15:07:55 -0500 (Mon, 22 Jul 2013) | 1 line
made block shutdown delay configurable
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BlockQueueProcessor.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BlockQueueProcessor.java	(revision 3745)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/BlockQueueProcessor.java	(working copy)
@@ -442,7 +442,7 @@
         for (Block b : sorted.values()) {
             if (sum >= needed
                     && !b.isSuspended()
-                    && (System.currentTimeMillis() - b.getLastUsed()) > Block.SUSPEND_SHUTDOWN_DELAY) {
+                    && (System.currentTimeMillis() - b.getLastUsed()) > (1000 * settings.getMaxBlockIdleTime())) {
                 b.suspend();
             sum += b.sizeLeft();
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java	(revision 3745)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Settings.java	(working copy)
@@ -50,6 +50,7 @@
                        "workerLoggingDirectory",
                        "ldLibraryPath", "workerCopies",
                        "directory", "useHashBang",
+                       "maxBlockIdleTime",
                        "parallelism",
                        "coresPerNode"};
@@ -107,6 +108,8 @@
     private int maxNodes = Integer.MAX_VALUE / 1024;
     private int maxtime = Integer.MAX_VALUE;
+    private int maxBlockIdleTime = 30; //s
     private final Set<URI> callbackURIs;
@@ -289,6 +292,14 @@
         this.maxtime = maxtime;
+    public int getMaxBlockIdleTime() {
+        return maxBlockIdleTime;
+    public void setMaxBlockIdleTime(int maxBlockIdleTime) {
+        this.maxBlockIdleTime = maxBlockIdleTime;
     public String getWorkerManager() {
         return workerManager;
Index: modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java
--- modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java	(revision 3745)
+++ modules/provider-coaster/src/org/globus/cog/abstraction/coaster/service/job/manager/Block.java	(working copy)
@@ -32,9 +32,6 @@
     /** milliseconds */
     public static final long SHUTDOWN_WATCHDOG_DELAY = 2 * 60 * 1000;
-    /** milliseconds */
-    public static final long SUSPEND_SHUTDOWN_DELAY = 30 * 1000;
     private static BlockTaskSubmitter submitter;
     private synchronized static BlockTaskSubmitter getSubmitter() {
