[Swift-commit] r6649 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Jul 15 14:49:02 CDT 2013
Author: davidk
Date: 2013-07-15 14:49:02 -0500 (Mon, 15 Jul 2013)
New Revision: 6649
Modified:
   trunk/bin/nswift
   trunk/bin/swiftrun
Log:
Handle brackets for grouping in swift.properties
Modified: trunk/bin/nswift
--- trunk/bin/nswift	2013-07-14 22:02:38 UTC (rev 6648)
+++ trunk/bin/nswift	2013-07-15 19:49:02 UTC (rev 6649)
@@ -165,8 +165,8 @@
 	$BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH $return_code 1 > /dev/udp/$LISTENER/$PORT" > /dev/null 2>&1 &
 fi
-mv *.d/ $( ls -1rtd run*/ |tail -1 )
-rm *.swiftx *.kml
+mv *.d/ $( ls -1rtd run*/ |tail -1 ) > /dev/null 2>&1
+rm *.swiftx *.kml > /dev/null 2>&1
 exit $return_code
 # Local Variables:
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2013-07-14 22:02:38 UTC (rev 6648)
+++ trunk/bin/swiftrun	2013-07-15 19:49:02 UTC (rev 6649)
@@ -162,12 +162,31 @@
 # Set property values
 foreach my $property_file(@property_files) {
    open(PROPERTIES, $property_file) || die "Unable to open $property_file";
    while( <PROPERTIES> ) {
       chomp;
       next if /^\s*#/ || /^(\s)*$/; # Ignore blank lines and comments
-      my ($key, $value) = split('=', $_, 2);
-      $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
-      $properties{ $key } = $value;
+      $_ =~ s/^\s+//;               # Remove leading whitespace
+      # Handle brackets
+      if( /^site\./ && /{/ ) {
+         my $prefix = (split /\s+{/)[0];
+         while( <PROPERTIES> ) {
+            chomp;
+            next if /^\s*#/ || /^(\s)*$/;
+            $_ =~ s/^\s+//;
+            if( /^}/ ) { last; }
+            my ($key, $value) = split('=', ($prefix . ".$_"), 2);
+            $value =~ s/\$(\w+)/$ENV{$1}/g;
+            $properties{ $key } = $value;
+      else {
+         my ($key, $value) = split('=', $_, 2);
+         $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
