[Swift-commit] r6639 - in trunk: . bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Fri Jul 12 10:34:52 CDT 2013
Author: davidk
Date: 2013-07-12 10:34:52 -0500 (Fri, 12 Jul 2013)
New Revision: 6639
Added:
   trunk/bin/nswift
Removed:
   trunk/bin/chxml
Modified:
   trunk/bin/swiftrun
   trunk/build.xml
Log:
Swiftrun and nswift scripts
Deleted: trunk/bin/chxml
--- trunk/bin/chxml	2013-07-11 02:30:21 UTC (rev 6638)
+++ trunk/bin/chxml	2013-07-12 15:34:52 UTC (rev 6639)
@@ -1,99 +0,0 @@
-#!/usr/bin/env python
-# This does not run under python3.2
-# ensures that that there is a sites file specified and that it contains
-# well-formed xml as well as essential attributes for the specified provider
-import xml.parsers.expat,sys,os,commands,pprint
-from glob import glob
-class siteProps:
-    def __init__(self,argstr):
-        self.sites_file = ""
-        self.startTags= []
-        self.endTags=[]
-        self.globusParams = 0
-        self.execProvider = ""
-        if len(argstr)<2:
-            print "please specify a sites file"
-            sys.exit(1)
-        i = 0
-        for o in argstr:
-            if o == "'-sites.file'":
-                self.sites_file = argstr[i+1].split("'")[1]
-            elif o == "'-config'":
-                try:
-                    config_filename = argstr[i+1].split("'")[1]
-                    config_file = open(config_filename,"r")
-                except IOError, (errno, strerror):
-                    print strerror
-                    sys.exit("Could not read: " + config_filename)
-                for line in config_file.readlines():
-                    if line.strip().startswith('#'):
-                        continue
-                    if line.find("sites.file")>-1:
-                        self.sites_file = line.split("=")[1].strip()
-            i = i+1
-        if (self.sites_file == ""):
-            swift_loc = commands.getoutput("which swift")
-            swift_home = swift_loc.split("bin")[0]
-            self.sites_file = swift_home+"etc/sites.xml"
-            print "no sites file specified, setting to default: "+self.sites_file
-    def parsefile(self):
-        parser = xml.parsers.expat.ParserCreate()
-        parser.ParseFile(open(self.sites_file, "r"))
-    def start_element(self, name, attrs):
-        self.startTags.append(name)
-        for x, y in attrs.iteritems():
-            if (name=="execution" and x=="provider"):
-                self.execProvider = y
-            if (y=="globus"):
-                self.globusParams = 1
-	    if (mysite.globusParams == 1 and mysite.execProvider == "local"):
-    		pp = pprint.PrettyPrinter()
-    		print "Warning: "+mysite.sites_file+" contains globus parameters that do not apply to the local execution provider ("+name+" "+pp.pformat(attrs)+")"
-		sys.exit()
-    def end_element(self, name):
-        self.endTags.append(name)
-#------------------------main----------------------------------
-mysite = siteProps(sys.argv)
-try:
-    mysite.parsefile()
-except Exception, e:
-    print "Error: XML parsing error in "+mysite.sites_file
-    print "%s is %s" % (mysite.sites_file, e)
-    sys.exit()
-p = xml.parsers.expat.ParserCreate()
-p.StartElementHandler = mysite.start_element
-p.EndElementHandler = mysite.end_element
-p.ParseFile(open(mysite.sites_file,"r"))
-config = 0
-pool = 0
-for tag in mysite.startTags:
-    if tag=="config":
-        config = 1
-    else:
-        if tag=="pool":
-            pool= 1
-if (pool<1):
-    print "Warning: Your sites file, "+mysite.sites_file+" is missing a pool entry"
-    sys.exit()
-if (config<1):
-    print "Warning: Your site file, "+mysite.sites_file+" is missing a config entry"
-    sys.exit()
Added: trunk/bin/nswift
--- trunk/bin/nswift	                        (rev 0)
+++ trunk/bin/nswift	2013-07-12 15:34:52 UTC (rev 6639)
@@ -0,0 +1,175 @@
+#!/bin/bash
+# Referenced environment variables (default values):
+# SWIFT_ASSERTS
+# SWIFT_HEAP_MAX (1024M)
+# SWIFT_USAGE_STATS
+EXEC=org.griphyn.vdl.karajan.Loader
+OPTIONS="-XX:+HeapDumpOnOutOfMemoryError"
+CYGWIN=
+CPDELIM=":"
+HEAPMAX=1024M
+if echo `uname` | grep -i "cygwin"; then
+	CYGWIN="yes"
+    CPDELIM=";"
+fi
+updateOptions() {
+    if [ "X$1" != "X" ] ; then
+		OPTIONS="$OPTIONS -D$2=$1"
+    fi
+####### MAIN BODY ##########
+if [ ! -d "$SWIFT_HOME" ] ; then
+    SWIFT_HOME=`dirname $0`"/.."
+    if [ ! -f "$SWIFT_HOME/lib/cog-swift-svn.jar" ] && [ ! -f "$SWIFT_HOME/lib/cog.jar" ] ; then
+		MY_PATH=`which $0`
+		SWIFT_HOME=`dirname $MY_PATH`"/.."
+	    	echo "Error: SWIFT_HOME is not set, and all attempts at guessing it failed"
+	    	exit 1
+		fi
+    fi
+fi
+OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
+LOCALCLASSPATH=$SWIFT_HOME/etc$CPDELIM$SWIFT_HOME/libexec
+for JAR in $SWIFT_HOME/lib/*.jar; do
+	LOCALCLASSPATH="$LOCALCLASSPATH$CPDELIM$JAR"
+done
+LOCALCLASSPATH=$LOCALCLASSPATH$CPDELIM$CLASSPATH
+CMDLINE="$@"
+### SETUP OTHER ENV VARIABLES ####
+USERID=`id | awk '{printf("%s\n", substr($1, 5, index($1, "(")-5 ) ) }'`
+if [ "X$GLOBUS_HOSTNAME" = "X" ] && [ "X$HOSTNAME" != "X" ]; then
+	GLOBUS_HOSTNAME=$HOSTNAME
+fi
+updateOptions "$USERID" "UID"
+updateOptions "$GLOBUS_INSTALL_PATH" "GLOBUS_INSTALL_PATH"
+updateOptions "$GLOBUS_DEPLOY_PATH" "GLOBUS_DEPLOY_PATH"
+updateOptions "$GLOBUS_TCP_PORT_RANGE" "GLOBUS_TCP_PORT_RANGE"
+updateOptions "$GLOBUS_TCP_SOURCE_PORT_RANGE" "GLOBUS_TCP_SOURCE_PORT_RANGE"
+updateOptions "$GLOBUS_UDP_SOURCE_PORT_RANGE" "GLOBUS_UDP_SOURCE_PORT_RANGE"
+updateOptions "$GLOBUS_HOSTNAME" "GLOBUS_HOSTNAME"
+updateOptions "$X509_USER_CERT" "X509_USER_CERT"
+updateOptions "$X509_USER_KEY" "X509_USER_KEY"
+updateOptions "$X509_CERT_DIR" "X509_CERT_DIR"
+updateOptions "$X509_USER_PROXY" "X509_USER_PROXY"
+updateOptions "$SWIFT_HOME" "COG_INSTALL_PATH"
+updateOptions "$SWIFT_HOME" "swift.home"
+updateOptions "$SWIFT_USERHOME" "user.home"
+#Use /dev/urandom instead of /dev/random for seeding RNGs
+#This will lower the randomness of the seed, but avoid
+#large delays if /dev/random does not have enough entropy collected
+updateOptions "file:///dev/urandom" "java.security.egd"
+if [ "X$SWIFT_HEAP_MAX" != "X" ]; then
+	HEAPMAX=$SWIFT_HEAP_MAX
+fi
+if [ "X$HEAPMAX" != "X" ]; then
+	OPTIONS="-Xmx$HEAPMAX $OPTIONS"
+fi
+if [ "X$SWIFT_ASSERTS" != "X" ]; then
+	OPTIONS="-ea $OPTIONS"
+fi
+# Anonymous usage statistics
+LISTENER="128.135.125.18"
+PORT="9999"
+if [ -z "$SWIFT_USAGE_STATS" ]; then
+    SWIFT_USAGE_STATS=1
+fi
+# To disable usage statistics, uncomment the line below
+#SWIFT_USAGE_STATS=0
+PATH=$PATH:/sbin
+IFCONFIG=`which ifconfig 2>&1`
+if [ -x "$IFCONFIG" ]; then
+    MAC=`$IFCONFIG 2>/dev/null |grep HWaddr`
+fi
+# Check if we are running on a mac, if so look for md5 and not md5sum
+if [ "`uname`" = "Darwin" ]; then
+	MD5SUM=`which md5 2>&1`
+	if [ ! -x "$MD5SUM" ]; then
+		echo "warning: unable to find md5"
+		SWIFT_USAGE_STATS=0
+	fi
+else
+	MD5SUM=`which md5sum 2>&1`
+		echo "warning: unable to find md5sum"
+	fi
+fi
+BASH="/bin/bash"
+if [ ! -x "$BASH" ]; then
+    BASH=`which bash 2>&1`
+    if [ ! -x "$BASH" ]; then
+        echo "warning: unable to find bash"
+    fi
+fi
+if [ "$SWIFT_USAGE_STATS" = 1 ]; then
+    for var in "$@"
+    do
+        SCRIPT=`echo $var|grep -i .swift`
+        if [ -e "$SCRIPT" ]; then
+            SCRIPT=$var
+            SCRIPTID=`$MD5SUM $SCRIPT|cut -d ' ' -f1`
+            SCRIPTLENGTH=`wc -l $SCRIPT|cut -d ' ' -f1`
+        fi
+    done
+    HOSTNAME=`hostname`
+    USERID=`echo $USERID $HOSTNAME $MAC | $MD5SUM |cut -d ' ' -f1`
+    DATE=`date`
+    KEY=`echo $USERID $DATE $$ | $MD5SUM | cut -d ' ' -f1`
+    $BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH -1 0 > /dev/udp/$LISTENER/$PORT" > /dev/null 2>&1 &
+fi
+# Swiftrun
+CMDLINE="$( swiftrun $CMDLINE )"
+### EXECUTE ############
+# Note: killing Swift may be briefly delayed due to Coasters shutdown
+if test -n "$CYGWIN"; then
+    set CLASSPATHSAVE=$CLASSPATH
+    export CLASSPATH="$LOCALCLASSPATH"
+    eval java ${OPTIONS} ${COG_OPTS} ${EXEC} ${CMDLINE}
+    export CLASSPATH=$CLASSPATHSAVE
+else
+    eval java ${OPTIONS} ${COG_OPTS} -classpath ${LOCALCLASSPATH} ${EXEC} ${CMDLINE}
+fi
+return_code=$?
+	$BASH -c "echo $KEY $USERID $SCRIPTID $SCRIPTLENGTH $return_code 1 > /dev/udp/$LISTENER/$PORT" > /dev/null 2>&1 &
+fi
+mv *.d/ $( ls -1rtd run*/ |tail -1 )
+rm *.swiftx *.kml
+exit $return_code
+# Local Variables:
+# tab-width: 4
+# indent-tabs-mode: t
+# End:
Property changes on: trunk/bin/nswift
___________________________________________________________________
Added: svn:executable
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2013-07-11 02:30:21 UTC (rev 6638)
+++ trunk/bin/swiftrun	2013-07-12 15:34:52 UTC (rev 6639)
@@ -1,116 +1,214 @@
-#!/bin/bash
+#!/usr/bin/perl -w
-# Verify an argument is not null
-verify_not_null()
-   argname=$1; shift
-   if [ _$1 != _ ]; then
-      return 0;
-   else
-      echo $0: value for $argname can not be null
-      exit 1
-   fi
+use strict;
+use warnings;
+use File::Basename;
+use Getopt::Long qw(GetOptionsFromArray);
+use Switch;
+use Cwd;
+Getopt::Long::Configure("pass_through");
+my %properties = ();		# Hash storing all swift properties
+my @property_files = ();	# List of swift property files to be read
+my $option_tcfile;		# Value of -tc.file option
+my $option_sitesfile;		# Value of -sites.file option
+my $option_siteslist;		# Value of -sites option, comma separated
+my $option_config;		# Value of -config option
+my @sites;			# List of sites from -sites in array
+my $run_directory;		# Run directory to be created, run.NNNN
+my @new_swift_args;		# New command line arguments
+my @original_swift_args;	# Original arguments
+# List of xml shortcuts. Keep in lower case.
+my %xml_aliases = (
+                   'provider'     => 'provider.coaster',
+                   'jobspernode'  => 'globus.jobspernode',
+                   'maxwalltime'  => 'globus.maxwalltime',
+                   'queue'        => 'globus.queue',
+                   'initialscore' => 'karajan.initialscore',
+# Verify a property file exists and add it to the search path
+sub add_property_file {
+   my $property_file = $_[0];
+   if( -e "$property_file" ) {
+      push( @property_files, $property_file );
-# crash: Report a problem and exit
-crash()
-    MSG=$1
-    echo ${MSG}  >&2
-    exit 1
+# Create a string with a single pool entry
+sub create_pool_entry {
+   my $site = $_[0];
+   my $pool = "\n<pool handle=\"" . $site . "\">\n";
+   while( my( $key, $value ) = each( %properties ) ) {
+      if( $key =~ /^\s*site.$site/ ) {
+         $pool .= &property_to_xml( $key, $value );
+   $pool .= "</pool>\n";
+   return $pool;
-# Create .swift structure
-create_dotswift()
-   if [ ! -d "$HOME/.swift" ]; then
-      mkdir $HOME/.swift || crash "Unable to mkdir $HOME/.swift"
-   fi
+# Given a string in format site.beagle.globus.jobsPerNode=12, convert to xml
+sub property_to_xml {
+   my $key = $_[0];
+   my $value = $_[1];
+   my ( $site, $sitename, $namespace, $property ) = split(/\./, $key);
-   if [ ! -d "$HOME/.swift/runs" ]; then
-      mkdir $HOME/.swift/runs || crash "Unable to mkdir $HOME/.swift/runs"
-   fi
+   # In the case of a shortened definition, check for aliases
+   if ( !defined( $property ) ) {
+      if ( defined( $xml_aliases{ lc( $namespace )})) {
+         ( $namespace, $property ) = split(/\./, $xml_aliases{ lc($namespace) });
+   # Make sure to handle special cases that are not in the namespace=x, key=y, format
+   switch($namespace) {
+      case "provider"	   { return "<execution provider=\"" . $property . "\" jobmanager=\"" . $value . "\"/>\n"; }
+      case "workdirectory" { return "<workdirectory>$value</workdirectory>\n"; }
+      case "filesystem"    { return "<filesystem provider=\"" . $value . "\"/>\n"; }
+      else                 { return "<profile namespace=\"" . $namespace . "\" key=\"" . $property . "\">" . $value . "</profile>\n"; }
-   if [ ! -d "$HOME/.swift/runs/current" ]; then
-      mkdir $HOME/.swift/runs/current || crash "Unable to mkdir $HOME/.swift/runs/current"
-   fi
+# Write apps to file in tc.data format
+sub write_apps {
+   my $app_filename = $_[0];
+   open( APP_FILE, ">$run_directory/$app_filename" ) || die "Unable to open $run_directory/$app_filename\n";
-  if [ ! -d "$HOME/.swift/runs/completed" ]; then
-     mkdir $HOME/.swift/runs/completed || crash "Unable to mkdir $HOME/.swift/runs/completed"
-  fi
+   # Find app definitions
+      if( $key =~ /^\s*app./ ) {
+         my ( $app, $site, $command ) = split(/\./, $key);
+         # Handle wildcards for site names
+         if ( $site eq "*" ) {
+            foreach my $nsite( @sites ) {
+               print APP_FILE "$nsite $command $value\n";
+         # Handle apps for defined sites
+         elsif ( grep( /^$site$/, @sites ) ) {
+            print APP_FILE "$site $command $value\n";
+   # Update command line args
+   push( @new_swift_args, "-tc.file $run_directory/$app_filename" );
-# Parse command line arguments
-args=""
-script=""
-while [ $# -gt 0 ]
-do
-   case "$1" in
-      -site|-sites|-s) SITES=$2; verify_not_null sites $SITES; shift ;;
-      -config|-c) CONFIG=$2; verify_not_null config $CONFIG; shift ;;
-      *) if [ -z "$script" ] && [[ $1 == *.swift ]]; then script="$1"
-         else args+="$1 "
-         fi ;;
-   esac
-   shift
-done
+# Write properties to file
+sub write_properties {
+   my $property_filename = $_[0];
+   open( PROPERTY_FILE, ">$run_directory/$property_filename" ) || die "Unable to open $run_directory/$property_filename\n";
+      # Ignore properties that start with app. or site.
+      next if $key =~ /^\s*app./;
+      next if $key =~ /^\s*site./;
+      print PROPERTY_FILE "$key=$value\n";
+   push( @new_swift_args, "-config $run_directory/$property_filename" );
-# Create run directory
-create_dotswift
-rundir=$( echo run??? | sed -e 's/^.*run//' | awk '{ printf("run%03d\n", $1+1)}' )
-mkdir $rundir
+# Write sites.xml to disk
+sub write_sites {
+   my $filename = $_[0];
+   open(SITES, ">$run_directory/$filename") || die "Unable to open $run_directory/$filename\n";
+   print SITES "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
+   print SITES "<config xmlns=\"http://www.ci.uchicago.edu/swift/SwiftSites\">\n";
-# Link input_files
-if [ -d "input_files" ]; then
-   for input_file in input_files/*
-   do
-      ln -s $PWD/$input_file $rundir
-   done
-fi
+   foreach my $site(@sites) {
+      print SITES &create_pool_entry($site);
-# Swift script
-if [ -f "$script" ]; then
-   cp $script $rundir
-fi
+   print SITES "\n</config>\n";
+   close(SITES);
+   push(@new_swift_args, "-sites.file $run_directory/$filename");
-# Copy config file if specified
-if [ -f "$CONFIG" ]; then
-   cp $CONFIG $rundir
-   CONFIG=$( basename $CONFIG )
-fi
+# Getopt::Long can't accept dots in arguments, work around to make things easy
+foreach my $arg(@ARGV) {
+   $arg =~ s/sites.file/sitesfile/g;
+   $arg =~ s/tc.file/tcfile/g;
-# Create sites.xml
-IFS=","
-echo "<config>" > $rundir/sites.xml
-for site in $SITES
-do
-   # If config is not defined, but there is a config in conf/ that matches, use that
-   if [ -z "$CONFIG" ] && [ -f "conf/$site.cf" ]; then
-      cp conf/$site.cf $rundir
-      config=$site.cf
-   fi
+# Command line arguments we care about
+ at original_swift_args = @ARGV;
+GetOptionsFromArray(
+           \@original_swift_args,
+           'sitesfile=s'     => \$option_sitesfile,
+           'tcfile=s'        => \$option_tcfile,
+           'config=s'        => \$option_config,
+           'site|sites=s'    => \$option_siteslist,
-   if [ -f "conf/$config" ]; then
-      gensites -p conf/$config $site >> $rundir/sites.xml
-   else
-      gensites $site >> $rundir/sites.xml
-   fi
+# Set @sites array from comma separated list of sites
+if(defined($option_siteslist)) {
+   @sites = split(',', $option_siteslist);
-done
-echo "</config>" >> $rundir/sites.xml
-mv tc.data $rundir
-cd $rundir
+# Verify Swift is found in PATH
+my $swift_etc_directory = dirname(dirname(`which swift`)) . "/etc";
+if( ! -d $swift_etc_directory ) { die "Unable to find a valid Swift installation"; }
-if [ -z "$CONFIG" ]; then
-   CONFIG=$config
-fi
+# Set the search order for properties
+&add_property_file("$swift_etc_directory/swift.properties");
+&add_property_file("$ENV{SWIFT_CONFIG}/swift.properties") if defined($ENV{SWIFT_CONFIG});
+&add_property_file("$ENV{HOME}/.swift/swift.properties");
+&add_property_file("swift.properties");
-# Run
-timestamp=$( date +%s )
-ln -s $PWD $HOME/.swift/runs/current/$rundir.$timestamp
-if [ -n "$CONFIG" ]; then
-   eval time swift -sites.file sites.xml -tc.file tc.data -config $CONFIG $( basename $script ) $args 2>&1 | tee swift.out
-else
-   eval time swift -sites.file sites.xml -tc.file tc.data $( basename $script ) $args 2>&1 | tee swift.out
-fi
-mv $HOME/.swift/runs/current/$rundir.$timestamp $HOME/.swift/runs/completed
+# Set property values
+foreach my $property_file(@property_files) {
+   open(PROPERTIES, $property_file) || die "Unable to open $property_file";
+   while( <PROPERTIES> ) {
+      chomp;
+      next if /^\s*#/ || /^(\s)*$/; # Ignore blank lines and comments
+      my ($key, $value) = split('=', $_, 2);
+      $value =~ s/\$(\w+)/$ENV{$1}/g; # Substitute environment variables
+      $properties{ $key } = $value;
+# Create/increment run directory
+my $run_number = 0;
+my @run_directories = <run????>;
+if(@run_directories) {
+   $run_number = $run_directories[-1];
+   $run_number =~ s/run//g;
+   $run_number++;
+$run_directory = getcwd() . "/" . sprintf "run%04s", $run_number;
+mkdir($run_directory) || die "Unable to create run directory $run_directory\n";
+# Write swift configuration files
+&write_sites("sites.xml") if defined( $option_siteslist );
+&write_apps("tc.data")    if ( !defined( $option_tcfile ) && defined( $option_siteslist ));
+&write_properties("cf")   if !defined( $option_config );
+# Repair args with dots
+   $arg =~ s/sitesfile/sites.file/g;
+   $arg =~ s/tcfile/tc.file/g;
+# Make sure -sites isn't in the arguments we send back to swift
+while( @ARGV ) {
+   my $option = shift;
+   switch( $option ) {
+      case "-site" { shift; }
+      case "-sites" { shift; }
+      else { push( @new_swift_args, $option ); }
+push( @new_swift_args, sprintf( "-logfile $run_directory/run%04s.log", $run_number ));
+foreach my $arg( @new_swift_args ) {
+   print "$arg ";
+print "\n";
Modified: trunk/build.xml
--- trunk/build.xml	2013-07-11 02:30:21 UTC (rev 6638)
+++ trunk/build.xml	2013-07-12 15:34:52 UTC (rev 6639)
@@ -88,6 +88,7 @@
 				<include name="swift-plot-log"/>
 				<include name="swiftconfig"/>
 				<include name="swiftrun"/>
+                                <include name="nswift"/>
 				<include name="gensites"/>
 				<include name="chxml"/>
 				<include name="start-coaster-service"/>
