[Swift-commit] r6637 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Jul 10 20:36:09 CDT 2013
Author: hategan
Date: 2013-07-10 20:36:08 -0500 (Wed, 10 Jul 2013)
New Revision: 6637
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
Log:
fixed potential NPE
Modified: trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2013-07-11 01:35:43 UTC (rev 6636)
+++ trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2013-07-11 01:36:08 UTC (rev 6637)
@@ -178,13 +178,15 @@
 	private void addEnvironment(Stack stack, BoundContact bc) {
 		Map<String,Object> props = bc.getProperties();
-		for (Map.Entry<String,Object> e : props.entrySet()) {
-			String name = e.getKey();
-			FQN fqn = new FQN(name);
-			String value = (String) e.getValue();
-			if (Profile.ENV.equalsIgnoreCase(fqn.getNamespace())) {
-			    cr_environment.append(stack, new Entry(fqn.getName(), value));
+		if (props != null) {
+    		for (Map.Entry<String,Object> e : props.entrySet()) {
+    			String name = e.getKey();
+    			FQN fqn = new FQN(name);
+    			String value = (String) e.getValue();
+    			if (Profile.ENV.equalsIgnoreCase(fqn.getNamespace())) {
+    			    cr_environment.append(stack, new Entry(fqn.getName(), value));
