[Swift-commit] r6618 - in branches/faster: . docs docs/cookbook docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Jul 8 01:24:47 CDT 2013
Author: hategan
Date: 2013-07-08 01:24:47 -0500 (Mon, 08 Jul 2013)
New Revision: 6618
Added:
   branches/faster/docs/merged/
Removed:
   branches/faster/docs/cookbook/coasters
Modified:
   branches/faster/
   branches/faster/docs/cookbook/cookbook.txt
   branches/faster/docs/userguide/commands
Log:
merged 6274 from trunk
Property changes on: branches/faster
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208,6215-6223,6231-6241,6255-6258,6263,6272,6275
   + /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208,6215-6223,6231-6241,6255-6258,6263,6272,6274-6275
Deleted: branches/faster/docs/cookbook/coasters
--- branches/faster/docs/cookbook/coasters	2013-07-08 06:22:15 UTC (rev 6617)
+++ branches/faster/docs/cookbook/coasters	2013-07-08 06:24:47 UTC (rev 6618)
@@ -1,110 +0,0 @@
-Coasters
-Coasters were introduced in Swift v0.6 as an experimental feature. In many
-applications, Swift performance can be greatly enhanced by the use of
-coasters. Coasters provide a low-overhead job submission and file transfer
-mechanism suited for the execution of short jobs (on the order of a few
-seconds). A detailed information on coasters can be found at http://www.ci.uchicago.edu/swift/guides/userguide.php#coasters.
-//**Include neat diagrams.**
-Following is a coasters setup case-study for a PBS underlying provider where sites.xml coaster settings were:
-[xml]
-source~~~~
-<execution provider="coaster" jobmanager="local:pbs"/>
-<profile namespace="globus" key="project">CI-CCR000013</profile>
-<!-- Note that the following is going to be defunct in the new version (0.93+) and replaced by
-"ProviderAttributes" key and may not work in the future Swift versions-->
-<!--<profile namespace="globus" key="ppn">24:cray:pack</profile>-->
-<profile namespace="globus" key="providerAttributes">
-pbs.aprun
-pbs.mpp=true
-</profile>
-<profile namespace="globus" key="workersPerNode">24</profile>
-<profile namespace="globus" key="maxTime">100000</profile>
-<profile namespace="globus" key="lowOverallocation">100</profile>
-<profile namespace="globus" key="highOverallocation">100</profile>
-<profile namespace="globus" key="slots">20</profile>
-<profile namespace="globus" key="nodeGranularity">5</profile>
-<profile namespace="globus" key="maxNodes">5</profile>
-<profile namespace="karajan" key="jobThrottle">20.00</profile>
-<profile namespace="karajan" key="initialScore">10000</profile>
-source~~~~
-The following table briefly describes the elements on the coasters setup:
-[width="70%", cols="^3,10", options="header"]
-|profile key | brief description
-|slots |  How many maximum LRM jobs/worker blocks are allowed
-|workersPerNode | How many coaster workers to run per execution node
-|nodeGranularity | Each worker block uses a number of nodes that is a multiple of this number
-|lowOverallocation |  How many times larger than the job walltime should a block's walltime be if all jobs are 1s long
-|highOverallocation | How many times larger than the job walltime should a block's walltime be if all jobs are infinitely long
-|workersPerNode | How many coaster workers to run per execution node reserve How many seconds to reserve in a block's walltime for starting/shutdown operations
-|maxnodes |   The maximum number of nodes allowed in a block
-|maxtime | The maximum number of walltime allowed for a block coaster service
-|jobThrottle |the number of concurrent jobs allowed on a site
-//For Beginners
-//Coasters for beginners. Usage of existing, prebuilt templates.
-//For Intermediate Users
-//Coasters for intermediate users.
-//Using gensites
-//Usage of gensites to generate your own sites
-//configurations.
-For Advanced Users
-//Coasters for advanced users. Getting your hands dirty.
-One of the main reason that one would initially deviate from coaster
-defaults into more complex pool entries is to force jobs to fit into some
-site-imposed constraint. For instance a typical submission to the experimental
-queue requires a user to request upto 3 nodes for under 1 hour. This setup
-could be achieved with a careful tuning of coaters parameters.
-//How to run Swift under different Coasters configurations
-//Manual
-//Todo
-//Passive
-//Todo
-//Persistent
-//Todo
-//Summary of Differences Between different Coaster types
-//A tabular representations of highlights of different coaster setups
-//Data Management
-Coaster providers: local, ssh, pbs
-Settings and examples for different coaster providers mechanisms.
Modified: branches/faster/docs/cookbook/cookbook.txt
--- branches/faster/docs/cookbook/cookbook.txt	2013-07-08 06:22:15 UTC (rev 6617)
+++ branches/faster/docs/cookbook/cookbook.txt	2013-07-08 06:24:47 UTC (rev 6618)
@@ -11,8 +11,6 @@
 include::swift_basics[]
-include::coasters[]
 include::infrastructures[]
 include::debugging[]
Modified: branches/faster/docs/userguide/commands
--- branches/faster/docs/userguide/commands	2013-07-08 06:22:15 UTC (rev 6617)
+++ branches/faster/docs/userguide/commands	2013-07-08 06:24:47 UTC (rev 6618)
@@ -39,7 +39,7 @@
 -resume file
-    Resumes the execution using a log file
+    Resumes the execution using a resume-log file .rlog
 -config file
