[Swift-commit] r6616 - in branches/faster: . docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Jul 8 01:19:24 CDT 2013
Author: hategan
Date: 2013-07-08 01:19:24 -0500 (Mon, 08 Jul 2013)
New Revision: 6616
Modified:
   branches/faster/
   branches/faster/docs/userguide/app_procedures
Log:
merged 6263 from trunk
Property changes on: branches/faster
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208,6215-6223,6231-6241,6255-6258
   + /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208,6215-6223,6231-6241,6255-6258,6263
Modified: branches/faster/docs/userguide/app_procedures
--- branches/faster/docs/userguide/app_procedures	2013-07-08 06:17:51 UTC (rev 6615)
+++ branches/faster/docs/userguide/app_procedures	2013-07-08 06:19:24 UTC (rev 6616)
@@ -91,9 +91,10 @@
       procedure call must exist. Files will be mapped in the same way as
       for input files.
-      (? Is it defined that output subdirectories will be precreated
-      before execution or should app executables expect to make them?
-      That's probably determined by the present behaviour of wrapper.sh)
+    * The output subdirectories will be precreated
+      before execution by Swift if defined within a Swift script such as the
+      location attribute of a mapper. App executables expect to make them if
+      they are referred to in the wrapper scripts.
     * Output produced by running the application executable on some
       inputs should be the same no matter how many times, when or where
@@ -104,19 +105,19 @@
 Things to not assume:
-    * anything about the path of the application workspace directory
+    * Anything about the path of the application workspace directory
-    * that either the application workspace directory will be deleted or
+    * That either the application workspace directory will be deleted or
       will continue to exist or will remain unmodified after execution
       has finished
-    * that files can be passed(?def) between application procedure
+    * That files can be passed between application procedure
       invocations through any mechanism except through files known to
       Swift through the mapping mechanism (there is some exception here
       for external datasets - there are a separate set of assertions
       that hold for external datasets)
-    * that application executables will run on any particular site of
+    * That application executables will run on any particular site of
       those available, or than any combination of applications will run
       on the same or different sites.
