[Swift-commit] r6612 - in branches/faster: . docs/cookbook docs/siteguide docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Mon Jul 8 00:54:14 CDT 2013
Author: hategan
Date: 2013-07-08 00:54:14 -0500 (Mon, 08 Jul 2013)
New Revision: 6612
Removed:
   branches/faster/docs/cookbook/cookbook-asciidoc.txt
Modified:
   branches/faster/
   branches/faster/docs/cookbook/cookbook.txt
   branches/faster/docs/cookbook/overview
   branches/faster/docs/siteguide/futuregrid
   branches/faster/docs/userguide/coasters
   branches/faster/docs/userguide/howto_tips
   branches/faster/docs/userguide/log-processing
Log:
merged 6215-6223 from trunk
Property changes on: branches/faster
___________________________________________________________________
Modified: svn:mergeinfo
   - /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208
   + /branches/release-0.93:4761-5122
/trunk:6172,6177,6182,6189-6190,6202-6203,6206-6208,6215-6223
Deleted: branches/faster/docs/cookbook/cookbook-asciidoc.txt
--- branches/faster/docs/cookbook/cookbook-asciidoc.txt	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/cookbook/cookbook-asciidoc.txt	2013-07-08 05:54:14 UTC (rev 6612)
@@ -1,20 +0,0 @@
-// To compile use: asciidoc -a toc -n cookbook-asciidoc.txt
-:numbered:
-Swift Cookbook
-Swift team <swift-user at ci.uchicago.edu>
-v0.92, March 2011
-include::overview[]
-include::swift_basics[]
-include::coasters[]
-include::diverse_infrastructures[]
-include::debugging_swift[]
-include::log_processing[]
Modified: branches/faster/docs/cookbook/cookbook.txt
--- branches/faster/docs/cookbook/cookbook.txt	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/cookbook/cookbook.txt	2013-07-08 05:54:14 UTC (rev 6612)
@@ -1,3 +1,7 @@
+// To compile use: asciidoc -a toc -n cookbook-asciidoc.txt
+:numbered:
 Swift Cookbook
Modified: branches/faster/docs/cookbook/overview
--- branches/faster/docs/cookbook/overview	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/cookbook/overview	2013-07-08 05:54:14 UTC (rev 6612)
@@ -5,7 +5,7 @@
 infrastructures. The Swift system comprises of SwiftScript language and the
 Swift runtime system. For
 introductory material, consult the Swift tutorial found
-link:http://www.ci.uchicago.edu/swift/guides/tutorial.php[here].
+link:http://www.ci.uchicago.edu/swift/guides/trunk/tutorial/tutorial.html[here].
-WARNING: Please be warned that the cookbook is under construction and most recipes are not tested rigorously. You are advised to use them at your own risk.
+WARNING: Please be warned that the cookbook is under construction and the recipes are not tested rigorously.
Modified: branches/faster/docs/siteguide/futuregrid
--- branches/faster/docs/siteguide/futuregrid	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/siteguide/futuregrid	2013-07-08 05:54:14 UTC (rev 6612)
@@ -1,10 +1,14 @@
-Futuregrid (x86 cloud)
+Futuregrid Cloud
+The NSF-funded FutureGrid cloud is administered by Indiana University. It
+offers a variety of resources via a multitude of interfaces. Currently, it
+offers cloud resources via three different interfaces: Eucalyptus,
+Nimbus (www.nimbusproject.org), and
+OpenStack (www.openstack.org). The total number of resources at
+FutureGrid is close to 5000 CPU cores and 220~TB of storage from more than six
+physical clusters. We use the resources offered by one such cluster via the
+Nebula middleware.
-FutureGrid is a distributed, high-performance test-bed that allows
-scientists to collaboratively develop and test innovative approaches
-to parallel, grid, and cloud computing.
 More information on futuregrid can be found at https://portal.futuregrid.org/.
 Requesting Futuregrid Access
Modified: branches/faster/docs/userguide/coasters
--- branches/faster/docs/userguide/coasters	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/userguide/coasters	2013-07-08 05:54:14 UTC (rev 6612)
@@ -1,30 +1,42 @@
 Coasters
+Introduction
 In many applications, Swift performance can be greatly enhanced by the
-use of CoG coasters. CoG coasters provide a low-overhead job submission
+use of coasters. Coasters provide a low-overhead job submission
 and file transfer mechanism suited for the execution of short jobs (on
 the order of a few seconds) and the transfer of small files (on the
 order of a few kilobytes) for which other grid protocols such as GRAM
 and GridFTP are poorly suited.
-The coaster mechanism submits a head job using some other execution
+Benefits
+The coaster mechanism submits a pilot job using some other execution
 mechanism such as GRAM, and for each worker node that will be used in a
 remote cluster, it submits a worker job, again using some other
 execution mechanism such as GRAM. Details on the design of the coaster
 mechanism can be found here. <http://wiki.cogkit.org/wiki/Coasters>
-The head job manages file transfers and the dispatch of execution jobs
+Mechanism
+The pilot job manages file transfers and the dispatch of execution jobs
 to workers. Much of the overhead associated with other grid protocols
 (such as authentication and authorization, and allocation of worker
 nodes by the site's local resource manager) is reduced, because that
-overhead is associated with the allocation of a coaster head or coaster
+overhead is associated with the allocation of a coaster pilot or coaster
 worker, rather than with every Swift-level procedure invocation;
 potentially hundreds or thousands of Swift-level procedure invocations
 can be run through a single worker.
-Coasters can be configured for use in two situations: job execution and
-file transfer.
+Coasters can be configured for two purposes: job execution and
+file staging.
+Coasters How-to
 To use for job execution, specify a sites.xml execution element like this:
@@ -46,6 +58,7 @@
 <filesystem provider="coaster" url="gt2://grid.myhost.org" />
 The url parameter should be a pseudo-URI formed with the URI scheme
 being the name of the provider to use to submit the coaster head job,
 and the hostname portion being the hostname to be used to execute the
Modified: branches/faster/docs/userguide/howto_tips
--- branches/faster/docs/userguide/howto_tips	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/userguide/howto_tips	2013-07-08 05:54:14 UTC (rev 6612)
@@ -39,8 +39,8 @@
 This use case allows the user to submit an MPI job to a remote queue.
-In SwiftScript, we make an invocation that does not look any different
-from any other invocation. In the below code, we do not have any input
+Swift makes an invocation that does not look any different
+from any other invocation. In the code below, we do not have any input
 files, and have two output files on stdout and stderr:
Modified: branches/faster/docs/userguide/log-processing
--- branches/faster/docs/userguide/log-processing	2013-07-08 05:44:24 UTC (rev 6611)
+++ branches/faster/docs/userguide/log-processing	2013-07-08 05:54:14 UTC (rev 6612)
@@ -5,7 +5,6 @@
 To properly generate log plots, you must enable VDL/Karajan logging.
 TODO:How?
 You should check the scripts that you intend to use to determine
 what log lines they require and ensure that you are generating
 those lines via log4j.properties
@@ -18,8 +17,55 @@
 TODO: Does it work for coasters-based runs only?
+Meaning and interpretation of Swift log messages
+A Swift log file is typically a text file with the name of the Swift run and
+its timestamp in the filename and an extension ".log". In addition, a ".rlog"
+file is Swift's resume log which is used by Swift when a run is resumed using
+the "-resume" option. The .rlog file is only for Swift's internal purpose and
+not to be interpreted by the user.
+Each line in the log file is typically made up of three parts. The first part
+is the timestamp, the second is the type of log message and the third is the
+message itself. The types of log messages follows the java log4j standard types
+of TRACE, DEBUG, INFO, WARN, ERROR and FATAL. This section lists the various
+Swift log messages and explains the meaning and likely interpretation of those
+messages. Please note that the list is not comprehensive at this time. Also
+note that we will ignore the timestamps here.
+. _DEBUG Loader arguments: [-sites.file, sites.xml, -config, cf, -tc.file, tc, postproc-gridftp.swift]_
+. _DEBUG Loader Max heap: 5592449024_
+. _DEBUG textfiles BEGIN_
+. _DEBUG Loader kmlversion is_
+. _DEBUG VDL2ExecutionContext Stack dump_
+. _INFO  SetFieldValue Set_
+. _INFO  get__site STARTCOMPOUND thread=0-8 name=get__site_
+. _INFO vdl:execute START thread=0-8-0 tr=_
+. _INFO  GlobalSubmitQueue No global submit throttle set. Using default (1024)_
+. _DEBUG vdl:execute2 THREAD_ASSOCIATION jobid=getsite-ymj72ook thread=0-8-0-1 host=localhost replicationGroup=xmj72ook_
+. _DEBUG vdl:execute2 JOB_START jobid=getsite-ymj72ook tr=getsite arguments=[644] tmpdir=postproc-gridftp-20120319-0942-adf1o1u2/jobs/y/getsite-ymj72ook host=localhost_
+. _INFO  GridExec TASK_DEFINITION_
+. _WARN  RemoteConfiguration Find: http://140.221.8.62:38260_
+. _INFO  AbstractStreamKarajanChannel$Multiplexer Multiplexer 0 started_
+. _INFO  AbstractStreamKarajanChannel$Multiplexer (0) Scheduling SC-null for addition_
+. _INFO  AbstractStreamKarajanChannel Channel configured_
+. _INFO  MetaChannel MetaChannel: 651528505[1478354072: {}] -> null.bind -> SC-null_
+. _INFO  ReadBuffer Will ask for 1 buffers for a size of 6070_
+. _INFO  ThrottleManager O maxBuffers=512, crtBuffers=0, allowedTransfers=256, active=0, suspended=0_
+. _INFO  ThrottleManager mem=113.54 MB, heap=482.88 MB, maxHeap=5.21 GB_
+. _INFO  ThrottleManager I maxBuffers=512, crtBuffers=0, allowedTransfers=256, active=0, suspended=0_
+. _INFO  PerformanceDiagnosticInputStream [MEM] Heap total: 482.88 MB, Heap used: 118.58 MB_
+. _INFO  vdl:execute END_SUCCESS thread=0-8-0 tr=getsite_
+. _INFO  WeightedHostScoreScheduler CONTACT_SELECTED host=localhost, score=99.854_
+. _
+Log plotting
 Normalize event times in the log to the run start time
 * Generate the log, assuming the log is titled +swift-run.log+
@@ -30,7 +76,7 @@
 Make a basic load plot from Coasters Cpu log lines
 . Normalize the log.
 . Build up a load data file:
@@ -47,7 +93,7 @@
 Make a basic job completion plot from Coasters Cpu log lines
@@ -64,7 +110,7 @@
 Make a basic Block allocation plot from Coasters Block log lines
@@ -81,7 +127,7 @@
 Make a job runtime distribution plot from Coasters Cpu log lines
