[Swift-commit] cog r3561
swift at ci.uchicago.edu swift at ci.uchicago.edu
Wed Jan 23 22:30:04 CST 2013
r3561 | hategan | 2013-01-23 22:25:19 -0600 (Wed, 23 Jan 2013) | 1 line
synchronizing on the channel when updating the last used time prevents the channel configuration from completing, so use another lock
Index: modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java	(revision 3560)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java	(working copy)
@@ -48,6 +48,9 @@
 	private Service callbackService;
 	private final boolean client;
 	private long lastTime;
+	private final Object lastTimeLock = new Object();
+	private TimerTask timeoutCheckTask;
 	protected AbstractKarajanChannel(RequestManager requestManager, ChannelContext channelContext,
 			boolean client) {
@@ -114,7 +117,7 @@
 	public void configureTimeoutChecks() {
-		Timer.every(TIMEOUT_CHECK_INTERVAL * 1000, new TimerTask() {
+		Timer.every(TIMEOUT_CHECK_INTERVAL * 1000, timeoutCheckTask = new TimerTask() {
 			public void run() {
 			    checkTimeouts();
@@ -129,15 +132,20 @@
 		    TimeoutException e = new TimeoutException(this, "Channel timed out", lastTime);
 			context.notifyRegisteredCommandsAndHandlers(e);
 			handleChannelException(e);
+			timeoutCheckTask.cancel();
-	protected synchronized void updateLastTime() {
-		lastTime = System.currentTimeMillis();
+	protected void updateLastTime() {
+		synchronized(lastTimeLock) {
+			lastTime = System.currentTimeMillis();
-	protected synchronized long getLastTime() {
-	    return lastTime;
+	protected long getLastTime() {
+			return lastTime;
 	protected boolean clientControlsHeartbeats() {
