[Swift-commit] cog r3551
swift at ci.uchicago.edu swift at ci.uchicago.edu
Fri Jan 11 18:25:05 CST 2013
r3551 | davidkelly999 | 2013-01-11 18:20:56 -0600 (Fri, 11 Jan 2013) | 2 lines
Use ibrun is available (TACC), otherwise use srun
Index: modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/slurm/SlurmExecutor.java
--- modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/slurm/SlurmExecutor.java	(revision 3550)
+++ modules/provider-localscheduler/src/org/globus/cog/abstraction/impl/scheduler/slurm/SlurmExecutor.java	(working copy)
@@ -165,8 +165,9 @@
 				logger.debug("Wrapper after variable substitution: " + wrapper);
-		wr.write(getProperties().getRunCommand() + " /bin/bash -c \'");
+                wr.write("RUNCOMMAND=$( command -v ibrun || command -v srun )\n");
+		wr.write("$RUNCOMMAND /bin/bash -c \'");
 		if (spec.getDirectory() != null) {
 			wr.write("cd " + quote(spec.getDirectory()) + " && ");
@@ -234,4 +235,4 @@
         return outArray[outArray.length-1].trim();
\ No newline at end of file
