[Swift-commit] cog r3546
swift at ci.uchicago.edu swift at ci.uchicago.edu
Thu Jan 10 18:40:05 CST 2013
r3546 | hategan | 2013-01-10 18:35:52 -0600 (Thu, 10 Jan 2013) | 1 line
added initial flag to distinguish between a valid request and a timed-out request sending spurious data
Index: modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/KarajanChannel.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/KarajanChannel.java	(revision 3545)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/KarajanChannel.java	(working copy)
@@ -26,6 +26,7 @@
 	public static final int ERROR_FLAG = 0x00000004;
 	public static final int COMPRESSED_FLAG = 0x00000008;
 	public static final int SIGNAL_FLAG = 0x00000010;
+	public static final int INITIAL_FLAG = 0x00000020;
 	void sendTaggedData(int i, boolean fin, byte[] bytes);
Index: modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java	(revision 3545)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/service/channels/AbstractKarajanChannel.java	(working copy)
@@ -479,9 +479,16 @@
 					return;
 				try {
-					handler = getRequestManager().handleInitialRequest(tag, data);
-					handler.setId(tag);
-					registerHandler(handler, tag);
+					if (flagIsSet(flags, INITIAL_FLAG)) {
+						handler = getRequestManager().handleInitialRequest(tag, data);
+						handler.setId(tag);
+						registerHandler(handler, tag);
+					else {
+						if (logger.isInfoEnabled()) {
+							logger.info("Received spurious request data, tag: " + tag + ", len: " + len);
 				catch (NoSuchHandlerException e) {
 					if (!getChannelContext().isIgnoredRequest(tag)) {
Index: modules/karajan/src/org/globus/cog/karajan/workflow/service/commands/Command.java
--- modules/karajan/src/org/globus/cog/karajan/workflow/service/commands/Command.java	(revision 3545)
+++ modules/karajan/src/org/globus/cog/karajan/workflow/service/commands/Command.java	(working copy)
@@ -110,8 +110,7 @@
 		if (channel == null) {
 			throw new ProtocolException("Unregistered command");
-		boolean fin = (outData == null) || (outData.size() == 0);
 		if (logger.isDebugEnabled()) {
 			logger.debug(ppOutData("CMD"));
@@ -123,7 +122,16 @@
 			if (id == NOID) {
 				logger.warn("Command has NOID: " + this, new Throwable());
-			channel.sendTaggedData(id, fin, getOutCmd().getBytes(), fin ? this : null);
+			int flags;
+			boolean fin = (outData == null) || (outData.size() == 0);
+			if (fin) {
+				flags = KarajanChannel.FINAL_FLAG + KarajanChannel.INITIAL_FLAG;;
+			else {
+				flags = KarajanChannel.INITIAL_FLAG;;
+			channel.sendTaggedData(id, flags, getOutCmd().getBytes(), fin ? this : null);
 			if (!fin) {
 				Iterator<byte[]> i = outData.iterator();
 				while (i.hasNext()) {
