[Swift-commit] r6135 - in SwiftApps/SciColSim: . conf params
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sun Jan 6 22:24:07 CST 2013
Author: wilde
Date: 2013-01-06 22:24:06 -0600 (Sun, 06 Jan 2013)
New Revision: 6135
Added:
   SwiftApps/SciColSim/genrec.sh
Modified:
   SwiftApps/SciColSim/annealing.swift
   SwiftApps/SciColSim/conf/local.xml
   SwiftApps/SciColSim/params/MWtest02
   SwiftApps/SciColSim/sumloss.sh
   SwiftApps/SciColSim/swiftopt.sh
Log:
Add restart mechanism to annealing.swift and additional logging to sumloss (logs to runNNN/sumloss).
Modified: SwiftApps/SciColSim/annealing.swift
--- SwiftApps/SciColSim/annealing.swift	2013-01-06 07:54:35 UTC (rev 6134)
+++ SwiftApps/SciColSim/annealing.swift	2013-01-07 04:24:06 UTC (rev 6135)
@@ -15,6 +15,25 @@
     float tsdev;
+type Checkpoint
+  int i;
+  int j;
+  float dx0, dx1, dx2, dx3, dx4;
+  float rej0, rej1, rej2, rej3, rej4;
+  float target_innov;
+  float loss;
+  float alpha_i;
+  float alpha_m;
+  float beta;
+  float gamma;
+  float delta;
+  float sdev;
+global boolean restart = (@arg("restart","false") == "true");
+tracef("Restart flag is %b\n", restart);
 global int iterate_adjust = @toint(@arg("iterate_adjust","1")); // FIXME!!! : 1 for 0.93, 0 for 0.94
 global boolean FIX_VARIABLES = true;
@@ -40,9 +59,9 @@
   evolve @loss  args /*stdout=@outfile*/;  // FIXME: graph is passed implicitly
-app ( file x ) sumloss( file loss[] )
+app (file outfile, file logfile ) sumloss( file loss[] )
-  sumloss @filenames(loss) stdout=@x;
+  sumloss @filename(logfile) @filenames(loss) stdout=@filename(outfile);
@@ -57,7 +76,7 @@
        sumloss()
-(file bestfile, file maxfile) multi_annealing (string some_out_filename,
+(file bestfile, file maxfile) multi_annealing (string best_filename,
                                                float T_start,
                                                float T_end,
                                                float Target_rejection,
@@ -77,18 +96,29 @@
   Res mlres[][];
-  mlres[0][0] = multi_loss(T_start, T_end, annealing_cycles, Target_rejection,
-                          starting_jump, 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
-  tracef( "multi_annealing: AR: initial: %f +- %f\n", mlres[0][0].loss, mlres[0][0].sdev );
+  file ckptFile <single_file_mapper; file=@strcat("ckpt.",target_innov)>;
+  Checkpoint ckpt;
+  int restartIndex;
-  foreach j in [0:NEVOPARAMS-1] {
-    x[0][j]         = params0[j];
-    dx[0][j]        = starting_jump;
-    rejection[0][j] = 0.0;
-    curr_loss[j]    = mlres[0][0].loss;
-    curr_sdev[j]    = mlres[0][0].sdev;
+  if (restart) {
+    ckpt = readData(ckptFile);
+    restartIndex = ckpt.i;
+  else {
+    restartIndex = -1;
+    mlres[0][0] = multi_loss(T_start, T_end, annealing_cycles, Target_rejection,
+                            starting_jump, 0, 0, params0, target_innov, evolve_reruns ); // FIXME: serves for all evolve-params ???
+    tracef( "multi_annealing: AR: initial: %f +- %f\n", mlres[0][0].loss, mlres[0][0].sdev );
+    foreach j in [0:NEVOPARAMS-1] {
+      x[0][j]         = params0[j];
+      dx[0][j]        = starting_jump;
+      rejection[0][j] = 0.0;
+      curr_loss[j]    = mlres[0][0].loss;
+      curr_sdev[j]    = mlres[0][0].sdev;
   iterate iter_i {  // number of annealing cycles
     int i = iter_i + 1;  // i ranges [1:n] in the swift script so that [0] can be the initial condition
@@ -97,130 +127,147 @@
     tracef( @strcat( "multi_annealing: AR: i=%i ....T = ", color( 3, "%f" ),"\n" ), i, temperature );
-    // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
-    if (i %% cycle == 1 && i > 1) {
-      tracef( "multi_annealing: new cycle at i=%i\n", i );
-      tracef( color( Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n" ),
-                     i, dx[i-1][0], dx[i-1][1], dx[i-1][2], dx[i-1][3], dx[i-1][4] );
-      foreach k in [0:NEVOPARAMS-1] {
-        float newrejection = rejection[i-1][k] / @tofloat( cycle );
-        if (newrejection > 0.0) {
-          dx[i][k] = dx[i-1][k] / ( newrejection / Target_rejection );
-          // FIXME: re-enable: rejection[i][k]=0.0;
-          trejection[i][k]=0.0;
-        else {
-          dx[i][k] = dx[i-1][k] * 2.0;
-          // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
-                    trejection[i][k]=newrejection;
-                // FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
-      tracef( color( Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n" ),
-                             i, dx[i][0], dx[i][1], dx[i][2], dx[i][3], dx[i][4] );
+    if ( i <  restartIndex ) {
+      tracef( "skipping index %i - less than restart index %i\n", i, restartIndex );
-    else { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i][j] is set later.
-        dx[i][k] = dx[i-1][k];
+    else { if ( i == restartIndex ) { // reset variables from the restart file
+      dx[i] = [ckpt.dx0, ckpt.dx1, ckpt.dx2, ckpt.dx3, ckpt.dx4];
+      rejection[i] = [ckpt.rej0, ckpt.rej1, ckpt.rej2, ckpt.rej3, ckpt.rej4];
+      x[i][0] = ckpt.alpha_i;
+      x[i][1] = ckpt.alpha_m;
+      x[i][2] = ckpt.beta;
+      x[i][3] = ckpt.gamma;
+      x[i][4] = ckpt.delta;
+      curr_loss[((i+1)*NEVOPARAMS)-1] = ckpt.loss;
+      curr_sdev[((i+1)*NEVOPARAMS)-1] = ckpt.sdev;
-    iterate j {  // Try a new value for each non-fixed param; then write results and accept or reject
-      int curr = ( i * NEVOPARAMS ) + j;
-      int prev = curr-1;
+    else { // i > restartIndex: proceed as normal whether restarting or not
-      if ( /* (!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) {  // Adjustable vars
-           // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
-        float try_x[];
-        foreach k in [0:NEVOPARAMS-1] { // Select the evolve params to try
-          if (k < j) {
-            try_x[k] = x[i][k]; // already set x[i][k]
+      // On each new "major" cycle within the annealing_cycles (other than the first) set new rejection and dx values
+      if (i %% cycle == 1 && i > 1) {
+        tracef( "multi_annealing: new cycle at i=%i\n", i );
+        tracef( color( Pink, "multi_annealing: AR: New cycle at %i: prev dx[0-4]=[%f %f %f %f %f]\n" ),
+                       i, dx[i-1][0], dx[i-1][1], dx[i-1][2], dx[i-1][3], dx[i-1][4] );
+        foreach k in [0:NEVOPARAMS-1] {
+          float newrejection = rejection[i-1][k] / @tofloat( cycle );
+          if (newrejection > 0.0) {
+            dx[i][k] = dx[i-1][k] / ( newrejection / Target_rejection );
+            // FIXME: re-enable: rejection[i][k]=0.0;
+            trejection[i][k]=0.0;
           else {
-            if (k == j) {
-              try_x[k] = newx(x[i-1][j], dx[i-1][j]); // permute x[i-1][j]
-            else { // k > j
-              try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
+            dx[i][k] = dx[i-1][k] * 2.0;
+            // FIXME: re-enable: rejection[i][k]=rejection[i-1][k];
+                      trejection[i][k]=newrejection;
+                  // FIXME: HANGS? : tracef(color(Red,"Recomputed rejection: i=%d k=%d dx[i][k]=%f\n"), i, k, dx[i][k]);
-        tracef( @strcat( "multi_annealing: AR: ", color( 10,"%f" ), " ", color( 9,"%i" ),"\n" ), try_x[j], j );
-        mlres[i][j] = multi_loss( T_start, T_end, annealing_cycles, Target_rejection, starting_jump,
-                                  i, j, try_x, target_innov, evolve_reruns ); // do the N evolve()'s, N=evolve_rerusn
-        tracef( "multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev );
-        // Beyond this point, x[] and dx[] are being set for this i,j
-        float ALOT = 100000000000.0; // 100,000,000,000. = 10^11
-        if (mlres[i][j].loss < ALOT) {
-          fprintf( some_out_filename, "N, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
-                  mlres[i][j].tavg, i-1, j, dx[i][j], rejection[i][j], @toint(target_innov), mlres[i][j].loss,
-                  try_x[0], try_x[1], try_x[2], try_x[3], try_x[4], mlres[i][j].sdev );
-                  // Note i-1 field: print that way to match with C++ output
-                  // fprintf( "max_dist_swift.txt", color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) );
-                  // FIXME: max_dist is global set in evolve()
+        tracef( color( Blue, "multi_annealing: AR: New cycle at %i: dx[0-4]=[%f %f %f %f %f]\n" ),
+                               i, dx[i][0], dx[i][1], dx[i][2], dx[i][3], dx[i][4] );
+      else { // If not new cycle, set dx[i][*] from previous dx ([i-1]). rejection[i][j] is set later.
+          dx[i][k] = dx[i-1][k];
-        else { // does this ever occur? if so did we want to still do the ratio computation above???
-          fprintf( some_out_filename, "A, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
-          //tracef( "multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j );
-        float ratio = min( 1.0, exp( -( mlres[i][j].loss - curr_loss[prev] ) / temperature ) );
-        float r = (random()); //Java already returns a random float between [0.0-1.0]
-        tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
-        if (r > ratio) { // Reject new parameter
-          x[i][j] = x[i-1][j];
-            rejection[i][j] = trejection[i][j] + 1.0;    // FIXME: triple-check this!
+      iterate j {  // Try a new value for each non-fixed param; then write results and accept or reject
+        int curr = ( i * NEVOPARAMS ) + j;
+        int prev = curr-1;
+        if ( /* (!FIX_VARIABLES) || */ ( var_fixed[j] == 0 ) ) {  // Adjustable vars
+             // fixed=1,1,0,0,0: FIXME: FIX_VARIABLES flag has faulty logic but OK when TRUE
+          float try_x[];
+          foreach k in [0:NEVOPARAMS-1] { // Select the evolve params to try
+            if (k < j) {
+              try_x[k] = x[i][k]; // already set x[i][k]
+            else {
+              if (k == j) {
+                try_x[k] = newx(x[i-1][j], dx[i-1][j]); // permute x[i-1][j]
+              else { // k > j
+                try_x[k] = x[i-1][k]; // use x[i-1][k] (from prior cycle)
-          else {
-            rejection[i][j] = rejection[i-1][j] + 1.0;  // FIXME: AR: Is this correct? incr rejection?
+          tracef( @strcat( "multi_annealing: AR: ", color( 10,"%f" ), " ", color( 9,"%i" ),"\n" ), try_x[j], j );
+          mlres[i][j] = multi_loss( T_start, T_end, annealing_cycles, Target_rejection, starting_jump,
+                                    i, j, try_x, target_innov, evolve_reruns ); // do the N evolve()'s, N=evolve_rerusn
+          tracef( "multi_annealing: AR: %f +- %f\n", mlres[i][j].loss, mlres[i][j].sdev );
+          // Beyond this point, x[] and dx[] are being set for this i,j
+          float ALOT = 100000000000.0; // 100,000,000,000. = 10^11
+          if (mlres[i][j].loss < ALOT) {
+            fprintf( best_filename, "N, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
+                    mlres[i][j].tavg, i-1, j, dx[i][j], rejection[i][j], @toint(target_innov), mlres[i][j].loss,
+                    try_x[0], try_x[1], try_x[2], try_x[3], try_x[4], mlres[i][j].sdev );
+                    // Note i-1 field: print that way to match with C++ output
+                    // fprintf( "max_dist_swift.txt", color( Red,"multi_annealing: AF: max_dist.txt - tbd\n" ) );
+                    // FIXME: max_dist is global set in evolve()
-          curr_loss[curr] = curr_loss[prev];
-          curr_sdev[curr] = curr_sdev[prev];
-          // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
-          tracef( "multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j );
-          tracef( "multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4] );
-        else { // Accept new parameter
-          tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j );
-          x[i][j] = try_x[j];
-            rejection[i][j] = trejection[i][j];    // FIXME: triple-check this!
+          else { // does this ever occur? if so did we want to still do the ratio computation above???
+            fprintf( best_filename, "A, %fs, %i, %i, %f, %f, |, %i, %f, [, %f, %f, %f, %f, %f, ], %f\n",
+            //tracef( "multi_annealing: Loss %f > ALOT at [i][j] = [%d][%d]\n", mlres[i][j].loss, i ,j );
-          else {
-            rejection[i][j] = rejection[i-1][j];  // FIXME: AR: Is this correct? no incr of rejection?
+          float ratio = min( 1.0, exp( -( mlres[i][j].loss - curr_loss[prev] ) / temperature ) );
+          float r = (random()); //Java already returns a random float between [0.0-1.0]
+          tracef("multi_annealing: AR: %f vs %f\n", r, ratio);
+          if (r > ratio) { // Reject new parameter
+            x[i][j] = x[i-1][j];
+              rejection[i][j] = trejection[i][j] + 1.0;    // FIXME: triple-check this!
+            else {
+              rejection[i][j] = rejection[i-1][j] + 1.0;  // FIXME: AR: Is this correct? incr rejection?
+            curr_loss[curr] = curr_loss[prev];
+            curr_sdev[curr] = curr_sdev[prev];
+            // FIXME: AR: the following prints seem to replicate values in the .cpp version - please clarify.
+            tracef( "multi_annealing: AR: %i,%i %i Did not accept: %f (%i)\n", i, j, i, try_x[j], j );
+            tracef( "multi_annealing: AR: %f %f %f %f %f\n", try_x[0],try_x[1],try_x[2],try_x[3],try_x[4] );
-          curr_loss[curr] = mlres[i][j].loss;
-          curr_sdev[curr] = mlres[i][j].sdev;
-          tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n", i, j, try_x[j] );
-          float rj[];
-            if (k <= j) {
-              rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
+          else { // Accept new parameter
+            tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i\n",i,j );
+            x[i][j] = try_x[j];
+              rejection[i][j] = trejection[i][j];    // FIXME: triple-check this!
             else {
-              rj[k] = rejection[i-1][k]; // Not yet set, use previous
+              rejection[i][j] = rejection[i-1][j];  // FIXME: AR: Is this correct? no incr of rejection?
+            curr_loss[curr] = mlres[i][j].loss;
+            curr_sdev[curr] = mlres[i][j].sdev;
+            tracef( "multi_annealing: Accepting try_x[j], i=%i j=%i try_x[j]=%f\n", i, j, try_x[j] );
+            float rj[];
+              if (k <= j) {
+                rj[k] = rejection[i][k]; // Was either set from previous j or just set for this j
+              else {
+                rj[k] = rejection[i-1][k]; // Not yet set, use previous
+            tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
+                           color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
+                           i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
+            tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
+                           i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
-          tracef(@strcat("multi_annealing: AR: [%i][%i] ", color(8,"Rejection counts: "),
-                         color(1,"%f"), " ", color(7,"%f"), " ", color(5,"%f"), " ", color(9,"%f"), " ", color(6,"%f"), "\n\n"),
-                         i, j, rj[0], rj[1], rj[2], rj[3], rj[4]);
-          tracef(@strcat("multi_annealing: AR: %i ", color(8,"***** Did accept! "),
-                         i, try_x[0], try_x[1], try_x[2], try_x[3], try_x[4]);
+          else {// Fixed Vars
+            // dx[i][j] not set for fixed vars
-        else {// Fixed Vars
-          // dx[i][j] not set for fixed vars
-      } until( j == (NEVOPARAMS-iterate_adjust) );
+        } until( j == (NEVOPARAMS-iterate_adjust) );
+      }} // of if/else
     } until( iter_i == (annealing_cycles-iterate_adjust) );
@@ -260,7 +307,19 @@
     tracef("multi_loss: i=%i calling evolve, args=%q\n", i, args);
     // tracef("multi_loss: after evolve: i=%i %k %k\n", i, outfile, rfile[i]);
-  file sumfile = sumloss(rfile);
+  string anneal_cycle;
+  if(ci==0) {
+    anneal_cycle="init";
+  else {
+    anneal_cycle=@strcat(ci-1);
+  file sumfile<single_file_mapper; file=@strcat("sumloss/T",target_innov,".",anneal_cycle,".",cj,".sumloss")>;
+  file logfile<single_file_mapper; file=@strcat("sumloss/T",target_innov,".",anneal_cycle,".",cj,".sumlog")>;
+  (sumfile, logfile) = sumloss(rfile);
   r = readData(sumfile);
   tracef("multi_loss: returning: ci=%i cj=%i r.loss=%f r.sdev=%f\n",ci,cj,r.loss,r.sdev);
@@ -287,11 +346,11 @@
     int target_innov = minrange + (i*rangeinc);
     foreach rep in [1:nreps] {
-      string some_out_filename = @strcat( "best.T", @strcat(target_innov), ".R", @strcat(rep), ".txt" );
+      string best_filename = @strcat( "best.T", @strcat(target_innov), ".R", @strcat(rep), ".txt" );
       file outfile;  // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".out")>;
       file lossfile; // <single_file_mapper; file=@strcat("output/T",target_innov,".R",rep,".loss_data")>;
-      (outfile,lossfile) = multi_annealing(some_out_filename,
+      (outfile,lossfile) = multi_annealing(best_filename,
 		                           @tofloat(@arg("tstart", "2.0")),
                                            @tofloat(@arg("tend", "0.01")),
                                            @tofloat(@arg("trejection", "0.3")),
@@ -326,11 +385,11 @@
   foreach target_innov in [minrange:maxrange:rangeinc] {
Modified: SwiftApps/SciColSim/conf/local.xml
--- SwiftApps/SciColSim/conf/local.xml	2013-01-06 07:54:35 UTC (rev 6134)
+++ SwiftApps/SciColSim/conf/local.xml	2013-01-07 04:24:06 UTC (rev 6135)
@@ -1,7 +1,7 @@
 <config>
   <pool handle="local" >
     <execution provider="local" url="none" />
-    <profile namespace="karajan" key="jobThrottle">.03</profile>
+    <profile namespace="karajan" key="jobThrottle">.01</profile>
     <profile namespace="karajan" key="initialScore">10000</profile>
     <filesystem provider="local"/>
     <workdirectory>_WORK_/local</workdirectory>
Added: SwiftApps/SciColSim/genrec.sh
--- SwiftApps/SciColSim/genrec.sh	                        (rev 0)
+++ SwiftApps/SciColSim/genrec.sh	2013-01-07 04:24:06 UTC (rev 6135)
@@ -0,0 +1,28 @@
+#! /bin/sh
+for f in $1/best.T*.R1.txt; do
+  ti=$(echo $f | sed -e 's/^.*T//' -e 's/\..*//')
+    echo  "i j dx0 dx1 dx2 dx3 dx4 rej0 rej1 rej2 rej3 rej4 target_innov loss alpha_i alpha_m beta gamma delta sdev"
+    cycle=$(sed -e 's/\]//g' -e 's/[,|\[]//g' $f | awk '$4 == 4 {print $3}' | tail -1)
+    echo 1>&2 ti=$ti will restart at cycle $cycle
+    sed -e 's/\]//g' -e 's/[,|\[]//g' $f |
+      awk '
+        $3 == cycle { dx[$4] = $5; rej[$4] = $6 }
+        $3 == cycle && $4 == 4 {
+          print $3, $4,
+                dx[0], dx[1], dx[2], dx[3], dx[4],
+                rej[0], rej[1], rej[2], rej[3], rej[4],
+                $7, $8, $9, $10, $11, $12, $13, $14
+      ' cycle=$cycle |
+      tail -1
+  ) > ckpt.$ti
+  if [ $(wc -l <ckpt.$ti) != 2 ]; then
+    echo $0: WARNING: ckpt.$ti was not generated: input does not contain at least one complete annealing cycle.
+    rm -f ckpt.$ti
+  fi
+done
+# N AvgTime  i  j     dx      Rej    TgtInno    AvgLoss     alpha_i   alpha_m      beta     gamma     delta     LossSdev
Property changes on: SwiftApps/SciColSim/genrec.sh
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/SciColSim/params/MWtest02
--- SwiftApps/SciColSim/params/MWtest02	2013-01-06 07:54:35 UTC (rev 6134)
+++ SwiftApps/SciColSim/params/MWtest02	2013-01-07 04:24:06 UTC (rev 6135)
@@ -1,21 +1,21 @@
 #   Test with one target_innovation and few evolve_reruns to verify numeric behavior
-min_target_innovation         58     # starting target innovation value to try
-max_target_innovation         59    # stops before this target innovation value
-target_innovation_increment   50     # increment target innovation by this amount
+min_target_innovation         67     # starting target innovation value to try
+max_target_innovation         68     # stops before this target innovation value
+target_innovation_increment   135    # increment target innovation by this amount
 annealing_repeats             1      # times to repeate the entire optimization process for each target_innovation
-annealing_cycles              100    # times to perform the simulated annealing loop for all non-fixed parameters
+annealing_cycles              20     # times to perform the simulated annealing loop for all non-fixed parameters
-evolve_reruns                 20     # times to perform evolve_to_target_and_save() (objective function - is batched)
-nworkers                      2      # number of parallel threads (cores) to use per invocation of C++ optimizer
-reruns_per_opt_invocation     20      # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
+evolve_reruns                 4     # times to perform evolve_to_target_and_save() (objective function - is batched)
+nworkers                      1      # number of parallel threads (cores) to use per invocation of C++ optimizer
+reruns_per_opt_invocation     4     # reruns_per_opt_invocation mod nworkers must == 0 !!! <=== NOTE WELL !!!
 alpha_i                       0.0    # 5 evolve() parameters: must be decimal values !!!
 alpha_m                       0.0    # alpha_i and alpha_m are fixed for now
-beta                          4.0    # rest are varied by the optimization process
-gamma                         50.0
-delta                         -1.0
\ No newline at end of file
+beta                          0.0    # rest are varied by the optimization process
+gamma                         0.0
+delta                         0.0
+starting_jump                 0.3
Modified: SwiftApps/SciColSim/sumloss.sh
--- SwiftApps/SciColSim/sumloss.sh	2013-01-06 07:54:35 UTC (rev 6134)
+++ SwiftApps/SciColSim/sumloss.sh	2013-01-07 04:24:06 UTC (rev 6135)
@@ -9,6 +9,12 @@
 # tsdev = standard deviation of timing data
 # process each file individually and treat each number as a field
+logfile=$1; shift
+outfile=$(mktemp sumloss.outfile.XXXXXX)
 awk '
 BEGIN { RS = ""; FS="\n";  loss = 0; loss_sq = 0; tavg = 0; tavg_sq = 0; n = 0; tn = 0; }
@@ -47,4 +53,27 @@
   printf "loss sdev tavg tsdev\n" # header line must match Swift structure fields
   printf "%f %f %f %f\n", avg_loss, serr_loss, avg_time, serr_time
+  if ( sdev_loss >50000 ) {
+    printf("sumloss warning: high sdev_loss=%f\n", sdev_loss) > sdev_warning
+} ' $* 2>&1 | tee $outfile
+if [ _$logfile != _ -a _$logfile != "_none" ]; then
+( echo sumloss: $0 $*
+  if [ -f sdev_warning ]; then
+    cat sdve_warning
+  fi
+  echo
+  for f in $*; do
+    echo -e "\ninput file $f:\n"
+    cat $f
+  done
+  echo -e "\nsumloss output: \n"
+  cat $outfile
+) >$logfile
+fi
+rm -f $outfile
Modified: SwiftApps/SciColSim/swiftopt.sh
--- SwiftApps/SciColSim/swiftopt.sh	2013-01-06 07:54:35 UTC (rev 6134)
+++ SwiftApps/SciColSim/swiftopt.sh	2013-01-07 04:24:06 UTC (rev 6135)
@@ -32,14 +32,15 @@
    -nworkers=$nworkers                      \
    -rerunsperapp=$reruns_per_opt_invocation \
    -wget=$wget				    \
-   -longruns=$longruns
+   -longruns=$longruns                      \
+   -restart=$restart
 # Default settings
 execsite=local
 paramfile=Fast01
-ram=2048M
+ram=6000M
 dryrun=
 escapecode=$(printf '\033')
 variable_params=5     # Currently CONSTANT, will want to have this vary
@@ -49,11 +50,12 @@
 # Process command line arguments
 while [ $# -gt 0 ]; do
   case $1 in
-    -l) longruns=true; shift 1;;
+    -l) longruns=true; shift 1;; # FIXME
     -n) dryrun=true; shift 1;;
     -p) paramfile=$2; shift 2;;
     -s) execsite=$2; shift 2;;
-    -w) wget=true; shift 1;;
+    -w) wget=true; shift 1;;     # FIXME
+    -r) resdir=$2; shift 2;;
     *) echo $usage 1>&2
        exit 1;;
   esac
@@ -71,6 +73,18 @@
     mkdir $rundir
 fi
+if [ _$resdir != _ ]; then
+  if [ -d resdir ]; then
+    restart=true
+    cp $resdir/ckpt.* $rundir
+  else
+    echo $0: no restart directory $resdir found.
+    exit 1
+  fi
+else
+  restart=false
+fi
 # Get optimization parameters
 if [ ! -f params/$paramfile ];
 then
