[Swift-commit] r7414 - SwiftApps/tryswift/scripts
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Dec 11 16:22:45 CST 2013
Author: davidk
Date: 2013-12-11 16:22:44 -0600 (Wed, 11 Dec 2013)
New Revision: 7414
Added:
   SwiftApps/tryswift/scripts/004-multipleapps.html
   SwiftApps/tryswift/scripts/004-multipleapps.swift
   SwiftApps/tryswift/scripts/004-multipleapps.txt
   SwiftApps/tryswift/scripts/005-multistage.html
   SwiftApps/tryswift/scripts/005-multistage.png
   SwiftApps/tryswift/scripts/005-multistage.swift
   SwiftApps/tryswift/scripts/005-multistage.txt
Removed:
   SwiftApps/tryswift/scripts/004-analysis.html
   SwiftApps/tryswift/scripts/004-analysis.swift
   SwiftApps/tryswift/scripts/004-analysis.txt
   SwiftApps/tryswift/scripts/activeplot.png
   SwiftApps/tryswift/scripts/cumulativeplot.png
   SwiftApps/tryswift/scripts/p4.html
   SwiftApps/tryswift/scripts/p4.swift
   SwiftApps/tryswift/scripts/p4.txt
   SwiftApps/tryswift/scripts/p5.html
   SwiftApps/tryswift/scripts/p5.swift
   SwiftApps/tryswift/scripts/p5.txt
   SwiftApps/tryswift/scripts/p6.html
   SwiftApps/tryswift/scripts/p6.swift
   SwiftApps/tryswift/scripts/p6.txt
   SwiftApps/tryswift/scripts/part04.png
   SwiftApps/tryswift/scripts/part05.png
   SwiftApps/tryswift/scripts/part06.png
   SwiftApps/tryswift/scripts/part4.txt
   SwiftApps/tryswift/scripts/part5.txt
   SwiftApps/tryswift/scripts/part6.txt
Modified:
   SwiftApps/tryswift/scripts/002-helloworld.swift
   SwiftApps/tryswift/scripts/003-foreach.html
   SwiftApps/tryswift/scripts/003-foreach.swift
Log:
Remove unused script
New 005-multistage example based on tutorial scripts
Some doc improvements and script improvements based on feedback
Modified: SwiftApps/tryswift/scripts/002-helloworld.swift
--- SwiftApps/tryswift/scripts/002-helloworld.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/002-helloworld.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,9 +1,9 @@
 type file;
-app (file out) echo (string s)
+app (file out) echo_app (string s)
    echo s stdout=filename(out);
 file out <"out.txt">;
-out = echo("Hello world!");
+out = echo_app("Hello world!");
Modified: SwiftApps/tryswift/scripts/003-foreach.html
--- SwiftApps/tryswift/scripts/003-foreach.html	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/003-foreach.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -9,8 +9,8 @@
 In this example, we first change our application. Instead of using "echo",
 we use an app called simulate. The simulate application serves as a trivial
-proxy for any more complex scientific simulation application. It generates
-and prints a set of one or more random integers
+proxy for any more complex scientific simulation application. In this
+example, simulate will print a single number in the range of 1-100.
 <pre>
 app (file o) simulate ()
Modified: SwiftApps/tryswift/scripts/003-foreach.swift
--- SwiftApps/tryswift/scripts/003-foreach.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/003-foreach.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,6 +1,6 @@
 type file;
-app (file o) simulate ()
+app (file o) simulate_app ()
   simulate stdout=filename(o);
@@ -8,5 +8,5 @@
 foreach i in [1:10] {
   string fname=strcat("output/sim_", i, ".out");
   file f <single_file_mapper; file=fname>;
-  f = simulate();
+  f = simulate_app();
Deleted: SwiftApps/tryswift/scripts/004-analysis.html
--- SwiftApps/tryswift/scripts/004-analysis.html	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/004-analysis.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,69 +0,0 @@
-<html>
-<head>
-<link href="formatting.css" rel="stylesheet" media="screen">
-</head>
-<body>
-<h2>Multiple apps</h2>
-<p>After all the parallel simulations in an ensemble run have completed,
-it is typically necessary to gather and analyze their results with some
-kind of post-processing analysis program or script. This script shows
-an example of this.</p>
-<p>The first change in this script is to the simulate script:</p>
-<pre>
-app (file o) simulate (int time)
-  simulate "-t" time stdout=filename(o);
-</pre>
-<p>Simulate now takes an argument, time. The command "simulate -t 10" will sleep
-for 10 seconds before printing a value. This is an example of how to pass command
-line arguments to an app in Swift.</p>
-<p>We introduce a new app call called stats:</p>
-<pre>
-app (file o) stats (file s[])
-  stats filenames(s) stdout=filename(o);
-</pre>
-<p>The stats app function takes an array of files as input (file s[]). The stats app takes a list of
-files, reads the numbers contained inside, and prints the average value. The filenames() function simply
-prints a list of all filenames contained within a file array.</p>
-<p>Within the foreach loop:
-<pre>
-  simout = simulate(time);
-  sims[i] = simout;
-</pre>
-<p>We now add each simout file to the sims array before finally passing all the files to stats</p>
-<pre>
-foreach i in [1:nsims] {
-  string fname = strcat("output/sim_",i,".out");
-  file simout <single_file_mapper; file=fname>;
-  sims[i] = simout;
-file average<"output/average.out">;
-average = stats(sims);
-</pre>
-Execute the script and view output/average.out to verify it succeeded.
-<h3>Exercises</h3>
-<ul>
-<li>Simulate takes another command line option, -r. The -r option sets the range of random numbers it generates. Call simulate with the added options -r 1000.</li>
-<li>Modify the simulate app so that it takes a second int representing range (hint: multiple inputs are separated by commas).</li>
-</ul>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/004-analysis.swift
--- SwiftApps/tryswift/scripts/004-analysis.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/004-analysis.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,25 +0,0 @@
-type file;
-file sims[];
-int time = 5;
-int nsims = 10;
-  sims[i] = simout;
Deleted: SwiftApps/tryswift/scripts/004-analysis.txt
--- SwiftApps/tryswift/scripts/004-analysis.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/004-analysis.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1 +0,0 @@
-Multiple apps
Copied: SwiftApps/tryswift/scripts/004-multipleapps.html (from rev 7151, SwiftApps/tryswift/scripts/004-analysis.html)
--- SwiftApps/tryswift/scripts/004-multipleapps.html	                        (rev 0)
+++ SwiftApps/tryswift/scripts/004-multipleapps.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1,72 @@
+<html>
+<head>
+<link href="formatting.css" rel="stylesheet" media="screen">
+</head>
+<body>
+<h2>Multiple apps</h2>
+<p>After all the parallel simulations in an ensemble run have completed,
+it is typically necessary to gather and analyze their results with some
+kind of post-processing analysis program or script. This script shows
+an example of this.</p>
+<p>The first change in this script is to the simulate script:</p>
+<pre>
+app (file o) simulate (int time)
+  simulate "-t" time stdout=filename(o);
+</pre>
+<p>Simulate now takes an argument, time. The command "simulate -t 10" will sleep
+for 10 seconds before printing a value. This is an example of how to pass command
+line arguments to an app in Swift.</p>
+<p>We introduce a new app call called stats:</p>
+<pre>
+app (file o) stats (file s[])
+  stats filenames(s) stdout=filename(o);
+</pre>
+<p>The stats app function takes an array of files as input (file s[]). The stats app takes a list of
+files, reads the numbers contained inside, and prints the average value. The filenames() function simply
+prints a list of all filenames contained within a file array.</p>
+<p>Within the foreach loop:
+<pre>
+  simout = simulate(time);
+  sims[i] = simout;
+</pre>
+<p>We now add each simout file to the sims array before finally passing all the files to stats</p>
+<pre>
+foreach i in [1:nsims] {
+  string fname = strcat("output/sim_",i,".out");
+  file simout <single_file_mapper; file=fname>;
+  sims[i] = simout;
+file average<"output/average.out">;
+average = stats(sims);
+</pre>
+Execute the script and view output/average.out to verify it succeeded.
+<h3>Exercises</h3>
+<ul>
+<li>Modify the simulate_app function so that it accepts a second int that will
+    representing range (hint: multiple inputs are separated by commas).</li>
+<li>Modify the simulate command line arguments. The current arguments are "-t time".
+    Simulate takes another command line option, -r. The -r option sets the range of
+    random numbers it generates. Call simulate with the added options -r 1000.</li>
+</ul>
+</body>
+</html>
Copied: SwiftApps/tryswift/scripts/004-multipleapps.swift (from rev 7151, SwiftApps/tryswift/scripts/004-analysis.swift)
--- SwiftApps/tryswift/scripts/004-multipleapps.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/004-multipleapps.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1,25 @@
+type file;
+app (file o) simulate_app (int time)
+app (file o) stats_app (file s[])
+file sims[];
+int time = 5;
+int nsims = 10;
+  simout = simulate_app(time);
+  sims[i] = simout;
+file average <"output/average.out">;
+average = stats_app(sims);
Copied: SwiftApps/tryswift/scripts/004-multipleapps.txt (from rev 7151, SwiftApps/tryswift/scripts/004-analysis.txt)
--- SwiftApps/tryswift/scripts/004-multipleapps.txt	                        (rev 0)
+++ SwiftApps/tryswift/scripts/004-multipleapps.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1 @@
+Multiple apps
Added: SwiftApps/tryswift/scripts/005-multistage.html
--- SwiftApps/tryswift/scripts/005-multistage.html	                        (rev 0)
+++ SwiftApps/tryswift/scripts/005-multistage.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1,42 @@
+<html>
+<head>
+</head>
+<body>
+<h2>Multi-stage workflows</h2>
+<p>This example expands the workflow pattern of the previous example by adding additional stages to the workflow.
+Here, we generate a dynamic seed value that will be used by all of the simulations, and for each simulation,
+we run an pre-processing application to generate a unique "bias file". This pattern is shown below, followed
+by the Swift script.</p>
+<img src="005-multistage.png"/>
+<p>Note that the workflow is based on data flow dependencies: each simulation depends on the seed value, calculated
+in these two dependent statements:</p>
+<pre>
+seedfile = genseed_app(1);
+int seedval = readData(seedfile);
+</pre>
+The workflow also depends on the bias file, computed and then consumed in these two dependent statements:
+<pre>
+biasfile = genbias_app(1000, 20);
+(simout,simlog) = simulation_app(steps, range, biasfile, 1000000, values);
+</pre>
+We produce 20 values in each bias file. Simulations of less than 20 values
+ignore the unneeded numbers, while simualtions of more than 20 will use the
+last bias number for all values past 20.
+<h3>Exercises</h3>
+<ul>
+<li>Adjust the code to produce the same number of bias values as is needed for each simulation.</li>
+<li>Modify the script to generate a unique seed value for each simulation</li>
+</ul>
+</body>
+</html>
Added: SwiftApps/tryswift/scripts/005-multistage.png
(Binary files differ)
Property changes on: SwiftApps/tryswift/scripts/005-multistage.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/tryswift/scripts/005-multistage.swift
--- SwiftApps/tryswift/scripts/005-multistage.swift	                        (rev 0)
+++ SwiftApps/tryswift/scripts/005-multistage.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1,54 @@
+type file;
+app (file out) genseed_app (int nseeds)
+  genseed "-r" 2000000 "-n" nseeds stdout=@out;
+app (file out) genbias_app (int bias_range, int nvalues)
+  genbias "-r" bias_range "-n" nvalues stdout=@out;
+app (file out, file log) simulation_app (int timesteps, int sim_range,
+                                         file bias_file, int scale, int sim_count)
+  simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
+           "-n" sim_count stdout=@out stderr=@log;
+app (file out, file log) analyze_app (file s[])
+  stats filenames(s) stdout=@out stderr=@log;
+# Values that shape the run
+int nsim = 10;   # number of simulation programs to run
+int steps = 1;   # number of timesteps (seconds) per simulation
+int range = 100; # range of the generated random numbers
+int values = 10; # number of values generated per simulation
+# Main script and data
+tracef("\n*** Script parameters: nsim=%i range=%i num values=%i\n\n", nsim, range, values);
+# Dynamically generated bias for simulation ensemble
+file seedfile<"output/seed.dat">;
+tracef("Generated seed=%i\n", seedval);
+file sims[]; # Array of files to hold each simulation output
+foreach i in [0:nsim-1] {
+  file biasfile <single_file_mapper; file=strcat("output/bias_",i,".dat")>;
+  file simout   <single_file_mapper; file=strcat("output/sim_",i,".out")>;
+  file simlog   <single_file_mapper; file=strcat("output/sim_",i,".log")>;
+  biasfile = genbias_app(1000, 20);
+  (simout,simlog) = simulation_app(steps, range, biasfile, 1000000, values);
+  sims[i] = simout;
+file stats_out<"output/average.out">;
+file stats_log<"output/average.log">;
+(stats_out,stats_log) = analyze_app(sims);
Added: SwiftApps/tryswift/scripts/005-multistage.txt
--- SwiftApps/tryswift/scripts/005-multistage.txt	                        (rev 0)
+++ SwiftApps/tryswift/scripts/005-multistage.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -0,0 +1 @@
+Multi-stage workflows
Deleted: SwiftApps/tryswift/scripts/activeplot.png
Deleted: SwiftApps/tryswift/scripts/cumulativeplot.png
Deleted: SwiftApps/tryswift/scripts/p4.html
--- SwiftApps/tryswift/scripts/p4.html	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p4.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,816 +0,0 @@
-<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.1//EN"
-    "http://www.w3.org/TR/xhtml11/DTD/xhtml11.dtd">
-<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en">
-<head>
-<meta http-equiv="Content-Type" content="application/xhtml+xml; charset=UTF-8" />
-<meta name="generator" content="AsciiDoc 8.6.4" />
-<title>Part 4: Running a parallel ensemble on Cray compute nodes</title>
-<style type="text/css">
-/* Sans-serif font. */
-h1, h2, h3, h4, h5, h6,
-div.title, caption.title,
-thead, p.table.header,
-div#toctitle,
-span#author, span#revnumber, span#revdate, span#revremark,
-div#footer {
-  font-family: Arial,Helvetica,sans-serif;
-/* Serif font. */
-div.sectionbody {
-  font-family: Georgia,"Times New Roman",Times,serif;
-/* Monospace font. */
-tt {
-  font-size: inherit;
-body {
-  margin: 1em 5% 1em 5%;
-a {
-  color: blue;
-  text-decoration: underline;
-a:visited {
-  color: fuchsia;
-em {
-  font-style: italic;
-  color: navy;
-strong {
-  font-weight: bold;
-  color: #083194;
-tt {
-  color: navy;
-h1, h2, h3, h4, h5, h6 {
-  color: #527bbd;
-  margin-top: 1.2em;
-  margin-bottom: 0.5em;
-  line-height: 1.3;
-h1, h2, h3 {
-  border-bottom: 2px solid silver;
-h2 {
-  padding-top: 0.5em;
-h3 {
-  float: left;
-h3 + * {
-  clear: left;
-div.sectionbody {
-  margin-left: 0;
-hr {
-  border: 1px solid silver;
-p {
-  margin-top: 0.5em;
-ul, ol, li > p {
-  margin-top: 0;
-ul > li     { color: #aaa; }
-ul > li > * { color: black; }
-pre {
-  padding: 0;
-  margin: 0;
-span#author {
-  color: #527bbd;
-  font-size: 1.1em;
-span#email {
-span#revnumber, span#revdate, span#revremark {
-div#footer {
-  font-size: small;
-  border-top: 2px solid silver;
-  margin-top: 4.0em;
-div#footer-text {
-  float: left;
-  padding-bottom: 0.5em;
-div#footer-badges {
-  float: right;
-div#preamble {
-  margin-top: 1.5em;
-  margin-bottom: 1.5em;
-div.tableblock, div.imageblock, div.exampleblock, div.verseblock,
-div.quoteblock, div.literalblock, div.listingblock, div.sidebarblock,
-div.admonitionblock {
-  margin-top: 1.0em;
-  margin-top: 2.0em;
-  margin-bottom: 2.0em;
-  margin-right: 10%;
-  color: #606060;
-div.content { /* Block element content. */
-  padding: 0;
-/* Block element titles. */
-div.title, caption.title {
-  color: #527bbd;
-  text-align: left;
-div.title + * {
-  margin-top: 0;
-td div.title:first-child {
-  margin-top: 0.0em;
-div.content div.title:first-child {
-div.content + div.title {
-div.sidebarblock > div.content {
-  background: #ffffee;
-  border: 1px solid #dddddd;
-  border-left: 4px solid #f0f0f0;
-  padding: 0.5em;
-div.listingblock > div.content {
-  border-left: 5px solid #f0f0f0;
-  background: #f8f8f8;
-  padding: 0.5em;
-div.quoteblock, div.verseblock {
-  padding-left: 1.0em;
-  margin-left: 1.0em;
-  color: #777777;
-div.quoteblock > div.attribution {
-  text-align: right;
-div.verseblock > pre.content {
-  font-family: inherit;
-div.verseblock > div.attribution {
-  padding-top: 0.75em;
-  text-align: left;
-/* DEPRECATED: Pre version 8.2.7 verse style literal block. */
-div.verseblock + div.attribution {
-  text-align: left;
-div.admonitionblock .icon {
-  vertical-align: top;
-  font-size: 1.1em;
-  color: #527bbd;
-  padding-right: 0.5em;
-div.admonitionblock td.content {
-  padding-left: 0.5em;
-  border-left: 3px solid #dddddd;
-div.exampleblock > div.content {
-div.imageblock div.content { padding-left: 0; }
-span.image img { border-style: none; }
-a.image:visited { color: white; }
-dl {
-  margin-top: 0.8em;
-  margin-bottom: 0.8em;
-dt {
-  margin-bottom: 0;
-  font-style: normal;
-  color: navy;
-dd > *:first-child {
-  margin-top: 0.1em;
-ul, ol {
-    list-style-position: outside;
-ol.arabic {
-  list-style-type: decimal;
-ol.loweralpha {
-  list-style-type: lower-alpha;
-ol.upperalpha {
-  list-style-type: upper-alpha;
-ol.lowerroman {
-  list-style-type: lower-roman;
-ol.upperroman {
-  list-style-type: upper-roman;
-div.compact ul, div.compact ol,
-div.compact p, div.compact p,
-div.compact div, div.compact div {
-  margin-bottom: 0.1em;
-div.tableblock > table {
-  border: 3px solid #527bbd;
-thead, p.table.header {
-  color: #527bbd;
-tfoot {
-td > div.verse {
-  white-space: pre;
-p.table {
-  margin-top: 0;
-/* Because the table frame attribute is overriden by CSS in most browsers. */
-div.tableblock > table[frame="void"] {
-  border-style: none;
-div.tableblock > table[frame="hsides"] {
-  border-left-style: none;
-  border-right-style: none;
-div.tableblock > table[frame="vsides"] {
-  border-top-style: none;
-  border-bottom-style: none;
-div.hdlist {
-div.hdlist tr {
-  padding-bottom: 15px;
-dt.hdlist1.strong, td.hdlist1.strong {
-td.hdlist1 {
-  padding-right: 0.8em;
-  color: navy;
-td.hdlist2 {
-div.hdlist.compact tr {
-  margin: 0;
-  padding-bottom: 0;
-.comment {
-  background: yellow;
-.footnote, .footnoteref {
-  font-size: 0.8em;
-span.footnote, span.footnoteref {
-  vertical-align: super;
-#footnotes {
-  margin: 20px 0 20px 0;
-  padding: 7px 0 0 0;
-#footnotes div.footnote {
-  margin: 0 0 5px 0;
-#footnotes hr {
-  border: none;
-  border-top: 1px solid silver;
-  height: 1px;
-  text-align: left;
-  margin-left: 0;
-  width: 20%;
-  min-width: 100px;
-div.colist td {
-  padding-bottom: 0.3em;
-div.colist td img {
-  margin-top: 0.3em;
- at media print {
-  div#footer-badges { display: none; }
-div#toc {
-  margin-bottom: 2.5em;
-div#toctitle {
-  color: #527bbd;
-  font-size: 1.1em;
-div.toclevel1, div.toclevel2, div.toclevel3, div.toclevel4 {
-  margin-top: 0;
-  margin-bottom: 0;
-div.toclevel2 {
-  margin-left: 2em;
-  font-size: 0.9em;
-div.toclevel3 {
-  margin-left: 4em;
-  font-size: 0.9em;
-div.toclevel4 {
-  margin-left: 6em;
-  font-size: 0.9em;
-span.aqua { color: aqua; }
-span.black { color: black; }
-span.blue { color: blue; }
-span.fuchsia { color: fuchsia; }
-span.gray { color: gray; }
-span.green { color: green; }
-span.lime { color: lime; }
-span.maroon { color: maroon; }
-span.navy { color: navy; }
-span.olive { color: olive; }
-span.purple { color: purple; }
-span.red { color: red; }
-span.silver { color: silver; }
-span.teal { color: teal; }
-span.white { color: white; }
-span.yellow { color: yellow; }
-span.aqua-background { background: aqua; }
-span.black-background { background: black; }
-span.blue-background { background: blue; }
-span.fuchsia-background { background: fuchsia; }
-span.gray-background { background: gray; }
-span.green-background { background: green; }
-span.lime-background { background: lime; }
-span.maroon-background { background: maroon; }
-span.navy-background { background: navy; }
-span.olive-background { background: olive; }
-span.purple-background { background: purple; }
-span.red-background { background: red; }
-span.silver-background { background: silver; }
-span.teal-background { background: teal; }
-span.white-background { background: white; }
-span.yellow-background { background: yellow; }
-span.big { font-size: 2em; }
-span.small { font-size: 0.6em; }
-a:link { color:navy; }
-a:visited { color:navy; }
-.monospaced, code, pre {
-  font-family: "Courier New", Courier, monospace;
-  font-size: medium; /* inherit; */
-  color: black;
-  padding: 0;
-  margin: 0;
-  padding: 0.5em;
-  background: none;
-  border: none;
-  border-left: none;
-  margin-right: none;
-</style>
-<script type="text/javascript">
-/*<![CDATA[*/
-window.onload = function(){asciidoc.footnotes();}
-var asciidoc = {  // Namespace.
-// Table Of Contents generator
-/* Author: Mihai Bazon, September 2002
- * http://students.infoiasi.ro/~mishoo
- * Table Of Content generator
- * Version: 0.4
- * Feel free to use this script under the terms of the GNU General Public
- * License, as long as you do not remove or alter this notice.
- /* modified by Troy D. Hanson, September 2006. License: GPL */
- /* modified by Stuart Rackham, 2006, 2009. License: GPL */
-// toclevels = 1..4.
-toc: function (toclevels) {
-  function getText(el) {
-    var text = "";
-    for (var i = el.firstChild; i != null; i = i.nextSibling) {
-      if (i.nodeType == 3 /* Node.TEXT_NODE */) // IE doesn't speak constants.
-        text += i.data;
-      else if (i.firstChild != null)
-        text += getText(i);
-    return text;
-  function TocEntry(el, text, toclevel) {
-    this.element = el;
-    this.text = text;
-    this.toclevel = toclevel;
-  function tocEntries(el, toclevels) {
-    var result = new Array;
-    var re = new RegExp('[hH]([2-'+(toclevels+1)+'])');
-    // Function that scans the DOM tree for header elements (the DOM2
-    // nodeIterator API would be a better technique but not supported by all
-    // browsers).
-    var iterate = function (el) {
-        if (i.nodeType == 1 /* Node.ELEMENT_NODE */) {
-          var mo = re.exec(i.tagName);
-          if (mo && (i.getAttribute("class") || i.getAttribute("className")) != "float") {
-            result[result.length] = new TocEntry(i, getText(i), mo[1]-1);
-          iterate(i);
-    iterate(el);
-    return result;
-  var toc = document.getElementById("toc");
-  var entries = tocEntries(document.getElementById("content"), toclevels);
-  for (var i = 0; i < entries.length; ++i) {
-    var entry = entries[i];
-    if (entry.element.id == "")
-      entry.element.id = "_toc_" + i;
-    var a = document.createElement("a");
-    a.href = "#" + entry.element.id;
-    a.appendChild(document.createTextNode(entry.text));
-    var div = document.createElement("div");
-    div.appendChild(a);
-    div.className = "toclevel" + entry.toclevel;
-    toc.appendChild(div);
-  if (entries.length == 0)
-    toc.parentNode.removeChild(toc);
-// Footnotes generator
-/* Based on footnote generation code from:
- * http://www.brandspankingnew.net/archive/2005/07/format_footnote.html
-footnotes: function () {
-  var cont = document.getElementById("content");
-  var noteholder = document.getElementById("footnotes");
-  var spans = cont.getElementsByTagName("span");
-  var refs = {};
-  var n = 0;
-  for (i=0; i<spans.length; i++) {
-    if (spans[i].className == "footnote") {
-      n++;
-      // Use [\s\S] in place of . so multi-line matches work.
-      // Because JavaScript has no s (dotall) regex flag.
-      note = spans[i].innerHTML.match(/\s*\[([\s\S]*)]\s*/)[1];
-      noteholder.innerHTML +=
-        "<div class='footnote' id='_footnote_" + n + "'>" +
-        "<a href='#_footnoteref_" + n + "' title='Return to text'>" +
-        n + "</a>. " + note + "</div>";
-      spans[i].innerHTML =
-        "[<a id='_footnoteref_" + n + "' href='#_footnote_" + n +
-        "' title='View footnote' class='footnote'>" + n + "</a>]";
-      var id =spans[i].getAttribute("id");
-      if (id != null) refs["#"+id] = n;
-  if (n == 0)
-    noteholder.parentNode.removeChild(noteholder);
-  else {
-    // Process footnoterefs.
-      if (spans[i].className == "footnoteref") {
-        var href = spans[i].getElementsByTagName("a")[0].getAttribute("href");
-        href = href.match(/#.*/)[0];  // Because IE return full URL.
-        n = refs[href];
-          "[<a href='#_footnote_" + n +
-</script>
-</head>
-<body class="article" style="max-width:800px">
-<div id="header">
-<h1>Part 4: Running a parallel ensemble on Cray compute nodes</h1>
-</div>
-<div id="content">
-<div id="preamble">
-<div class="sectionbody">
-<div class="paragraph"><p><tt>p4.swift</tt> will run our mock "simulation"
-applications on Cray compute nodes.  The script is similar to as
-<tt>p3.swift</tt>, but specifies that each simulation app invocation should
-additionally return the log file which the application writes to
-<tt>stderr</tt>.</p></div>
-<div class="paragraph"><p>Now when you run <tt>swift p4.swift</tt> you’ll see that two types output
-files will placed in the <tt>output/</tt> directory: <tt>sim_N.out</tt> and
-<tt>sim_N.log</tt>.  The log files provide data on the runtime environment of
-each app invocation. For example:</p></div>
-<div class="listingblock">
-<div class="content">
-<pre><tt>$ cat output/sim_0.log
-Called as: /home/users/p01532/swift-cray-tutorial/app/simulate.sh: --timesteps 1 --range 100 --nvalues 5
-Start time: Tue Aug 27 12:17:43 CDT 2013
-Running on node: nid00018
-Running as user: uid=61532(p01532) gid=61532 groups=61532
-Simulation parameters:
-bias=0
-biasfile=none
-initseed=none
-log=yes
-paramfile=none
-range=100
-scale=1
-seedfile=none
-timesteps=1
-output width=8
-Environment:
-ALPS_APP_DEPTH=32
-ASSEMBLER_X86_64=/opt/cray/cce/8.2.0.173/cray-binutils/x86_64-unknown-linux-gnu/bin/as
-ASYNCPE_DIR=/opt/cray/xt-asyncpe/5.23.02
-ASYNCPE_VERSION=5.23.02
-...</tt></pre>
-</div></div>
-<div class="paragraph"><p>To tell Swift to run the apps on compute nodes, we specify in the
-<tt>apps</tt> file that the apps should be executed on the <tt>raven</tt> site
-(instead of the <tt>localhost</tt> site).  We can specify the location of
-each app in the third field of the <tt>apps</tt> file, with either an
-absolute pathname or the name of an executable to be located in
-<tt>PATH</tt>). Here we use the latter form:</p></div>
-<pre><tt>$ cat apps
-raven simulate simulate.sh
-raven stats    stats.sh</tt></pre>
-</div></div>
-<div class="paragraph"><p>You can experiment, for example, with an alternate version of stats.sh by specfying that app’s location explicitly:</p></div>
-raven stats    /home/users/p01532/bin/my-alt-stats.sh</tt></pre>
-</div></div>
-<div class="paragraph"><p>We can see that when we run many apps requesting a larger set of nodes (6), we are indeed running on the compute nodes:</p></div>
-<pre><tt>$ swift p4.swift -nsim=1000 -steps=1
-Swift 0.94.1 RC2 swift-r6895 cog-r3765
-RunID: 20130827-1638-t23ax37a
-Progress:  time: Tue, 27 Aug 2013 16:38:11 -0500
-Progress:  time: Tue, 27 Aug 2013 16:38:12 -0500  Initializing:966
-Progress:  time: Tue, 27 Aug 2013 16:38:13 -0500  Selecting site:499  Submitting:500  Submitted:1
-Progress:  time: Tue, 27 Aug 2013 16:38:14 -0500  Selecting site:499  Stage in:1  Submitted:500
-Progress:  time: Tue, 27 Aug 2013 16:38:16 -0500  Selecting site:499  Submitted:405  Active:95  Stage out:1
-Progress:  time: Tue, 27 Aug 2013 16:38:17 -0500  Selecting site:430  Submitted:434  Active:66  Stage out:1  Finished successfully:69
-Progress:  time: Tue, 27 Aug 2013 16:38:18 -0500  Selecting site:388  Submitted:405  Active:95  Stage out:1  Finished successfully:111
-Progress:  time: Tue, 27 Aug 2013 16:38:30 -0500  Stage in:1  Submitted:93  Active:94  Finished successfully:812
-Progress:  time: Tue, 27 Aug 2013 16:38:31 -0500  Submitted:55  Active:95  Stage out:1  Finished successfully:849
-Progress:  time: Tue, 27 Aug 2013 16:38:32 -0500  Active:78  Stage out:1  Finished successfully:921
-Progress:  time: Tue, 27 Aug 2013 16:38:34 -0500  Active:70  Stage out:1  Finished successfully:929
-Progress:  time: Tue, 27 Aug 2013 16:38:37 -0500  Stage in:1  Finished successfully:1000
-Progress:  time: Tue, 27 Aug 2013 16:38:38 -0500  Stage out:1  Finished successfully:1000
-Final status: Tue, 27 Aug 2013 16:38:38 -0500  Finished successfully:1001
-$ grep "on node:" output/*log | head
-output/sim_0.log:Running on node: nid00063
-output/sim_100.log:Running on node: nid00060
-output/sim_101.log:Running on node: nid00061
-output/sim_102.log:Running on node: nid00032
-output/sim_103.log:Running on node: nid00060
-output/sim_104.log:Running on node: nid00061
-output/sim_105.log:Running on node: nid00032
-output/sim_106.log:Running on node: nid00060
-output/sim_107.log:Running on node: nid00061
-output/sim_108.log:Running on node: nid00062
-$ grep "on node:" output/*log | awk '{print $4}' | sort | uniq -c
-    158 nid00032
-    156 nid00033
-    171 nid00060
-    178 nid00061
-    166 nid00062
-    171 nid00063
-$ hostname
-raven
-$ hostname -f
-nid00008</tt></pre>
-</div></div>
-<div class="paragraph"><p>Swift’s <tt>sites.xml</tt> configuration file allows many parameters to
-specify how jobs should be run on a given cluster. Consider for
-example that Raven has several queues, each with limitiations on the
-size of jobs that can be run in them.  All Raven queues will only run
-2 jobs per user at one. The Raven queue "small" will only allow up to
-4 nodes per job and 1 hours of walltime per job.  The following
-site.xml parameters will allow us to match this:</p></div>
-<pre><tt>  <profile namespace="globus" key="queue">small</profile>
-  <profile namespace="globus" key="slots">2</profile>
-  <profile namespace="globus" key="maxNodes">4</profile>
-  <profile namespace="globus" key="nodeGranularity">4</profile></tt></pre>
-</div></div>
-<div class="paragraph"><p>To run large jobs, we can specify:</p></div>
-<pre><tt>  <profile namespace="globus" key="slots">2</profile>
-  <profile namespace="globus" key="maxNodes">8</profile>
-  <profile namespace="globus" key="nodeGranularity">8</profile>
-  <profile namespace="karajan" key="jobThrottle">50.0</profile>
-  <profile namespace="globus" key="maxTime">21600</profile>
-  <profile namespace="globus" key="lowOverAllocation">10000</profile>
-  <profile namespace="globus" key="highOverAllocation">10000</profile></tt></pre>
-</div></div>
-<div class="paragraph"><p>This will enable 512 Swift apps (2 x 8 x 32) to run concurrently
-within 2 8-node jobs on Raven’s 32-core nodes.  It results in the
-following two PBS jobs submitted by Swift to "provision" compute nodes
-to run thousands of apps, 512 at a time:</p></div>
-<pre><tt>$ qstat -u $USER
-Job ID          Username Queue    Jobname    SessID NDS TSK Memory Time  S Time
-288637.sdb      p01532   medium   B0827-2703    --    8 256    --  05:59 Q   --
-288638.sdb      p01532   medium   B0827-2703    --    8 256    --  05:59 Q   --</tt></pre>
-</div></div>
-<div class="paragraph"><p>The following section is a summary of the important <tt>sites.xml</tt>
-attributes for running apps on Cray systems. Many of these attributes
-can be set the same for all Swift users of a given system; only a few
-of the attributes need be overridden by users. We explain these
-attributes in detail here to show the degree of control afforded by
-Swift over application execution.  Most users will use templates for a
-given Cray system, only changing a few parameters to meet any unique
-needs of their application workflows.</p></div>
-<div class="paragraph"><p>The additional attributes in the <tt>sites.xml</tt> file (described here
-without their XML formatting) specify that Swift should run
-applications on Raven in the following manner:</p></div>
-<div class="paragraph"><p><tt>execution provider coaster, jobmanager local:pbs</tt> specifies that
-Swift should run apps using its "coaster" provider, which submits
-"pilot jobs" using qsub. These pilot jobs hold on to compute nodes and
-allow Swift to run many app invocations within a single job. This
-mechanism is described in
-<a href="http://www.swift-lang.org/papers/UCC-coasters.pdf">this paper from UCC-2011</a>.</p></div>
-<div class="paragraph"><p><tt>profile</tt> tags specify additional attributes for the execution
-provider. (A "provider" is like a driver which knows how to handle
-site-specific aspects of app execution). The attributes are grouped
-into various "namespaces", but we can ignore this for now).</p></div>
-<div class="paragraph"><p>The <tt>env</tt> key <tt>PATHPREFIX</tt> specifies that our tutorial <tt>app</tt> directory
-(<tt>../app</tt>) will be placed at the front of PATH to locate the app on
-the compute node.</p></div>
-<div class="paragraph"><p><tt>queue small</tt> specifies that pilot (coaster) jobs to run apps will be
-submitted to Raven’s <tt>small</tt> queue.</p></div>
-<div class="paragraph"><p><tt>providerAttributes pbs.aprun;pbs.mpp;depth=32</tt> specifies some
-Cray-specific attributes: that jobs should use Cray-specific PBS "mpp"
-resource attributes (eg <tt>mppwidth</tt> and <tt>mppnppn</tt>) and an mppdepth of
-32 (because we will be running one coaster process per node, and
-Raven’s XE6 dual IL-16 nodes have a depth of 32 processing elements
-(PEs).</p></div>
-<div class="paragraph"><p><tt>jobsPerNode 32</tt> tells Swift that each coaster should run up to 32
-concurrent apps. This can be reduced to place fewer apps per node, eg
-if each app needs more memory (or, rarely, greater than 32, e.g. if the apps are
-IO-bound or for benchmark experiments, etc).</p></div>
-<div class="paragraph"><p><tt>slots 2</tt> specifies that Swift will run up to 2 concurrent PBS jobs,
-and <tt>maxNodes 1</tt> specifies that each of these jobs will request only 1
-compute node.</p></div>
-<div class="paragraph"><p><tt>maxWallTime 00:01:00</tt> specifies that Swift should allow each app to
-run for up to one minute of walltime within the larger pilot job. In
-this example Swift will dynamically determine the total PBS walltime
-needed for the pilot job, but this can be specified manually using
-attributes <tt>maxtime</tt> along with <tt>highOverAllocation</tt> and
-<tt>lowOverAllocation</tt>.</p></div>
-<div class="paragraph"><p><tt>jobThrottle 3.20</tt> specifies that Swift should allow up to 320 apps to
-run on the <tt>raven</tt> site at once.  This is typically set to a number
-greater than or equal to the number of slots x compute nodes x apps
-per node (<tt>jobsPerNode</tt> attribute).</p></div>
-<div class="paragraph"><p><tt>initialscore 10000</tt> is specified to override Swift’s automatic
-throttling, and forces an actual throttle value of approximately
-(specifically 1 over) <tt>jobThrottle</tt> * 100 to be used.</p></div>
-<div class="paragraph"><p>The last two attributes specify where and how Swift should perform
-data management.  <tt>workdirectory /lus/scratch/{env.USER}/swiftwork</tt>
-specifies where the Swift "application execution sanbox directory"
-used for each app will be located. In some situations this can be a
-directory local to the compute node (eg, for Cray systems, <tt>/dev/shm</tt>
-or <tt>/tmp</tt>, if those are writable by user jobs and the nodes have
-sufficient space in these RAM-based filesystems).</p></div>
-<div class="paragraph"><p>Finally, <tt>stagingMethod sfs</tt> specifies that Swift will copy data to
-and from the shared file system to the application sandbox
-directories.</p></div>
-</div>
-</div>
-</div>
-<div id="footnotes"><hr /></div>
-<div id="footer">
-<div id="footer-text">
-Last updated 2013-09-11 13:13:14 CDT
-</div>
-</div>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/p4.swift
--- SwiftApps/tryswift/scripts/p4.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p4.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,29 +0,0 @@
-type file;
-app (file out, file log) simulation (int sim_steps, int sim_range, int sim_values)
-  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@out stderr=@log;
-app (file out, file log) analyze (file s[])
-  stats filenames(s) stdout=@out stderr=@log;
-int nsim   = toInt(arg("nsim",   "10"));
-int steps  = toInt(arg("steps",  "1"));
-int range  = toInt(arg("range",  "100"));
-int values = toInt(arg("values", "5"));
-file sims[];
-foreach i in [0:nsim-1] {
-  file simout <single_file_mapper; file=strcat("output/sim_",i,".out")>;
-  file simlog <single_file_mapper; file=strcat("output/sim_",i,".log")>;
-  (simout,simlog) = simulation(steps,range,values);
-  sims[i] = simout;
-file stats_out<"output/average.out">;
-file stats_log<"output/average.log">;
-(stats_out, stats_log) = analyze(sims);
Deleted: SwiftApps/tryswift/scripts/p4.txt
--- SwiftApps/tryswift/scripts/p4.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p4.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1 +0,0 @@
-p4
Deleted: SwiftApps/tryswift/scripts/p5.html
--- SwiftApps/tryswift/scripts/p5.html	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p5.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,716 +0,0 @@
-<head>
-<title>Part 5: Controlling the compute-node pools where applications run</title>
-div#toctitle,
-div#footer {
-/* Serif font. */
-div.sectionbody {
-tt {
-body {
-a {
-  color: blue;
-a:visited {
-  color: fuchsia;
-em {
-  color: navy;
-strong {
-  color: #083194;
-tt {
-  color: navy;
-  color: #527bbd;
-  line-height: 1.3;
-h1, h2, h3 {
-h2 {
-h3 {
-  float: left;
-h3 + * {
-  clear: left;
-div.sectionbody {
-  margin-left: 0;
-hr {
-p {
-ul, ol, li > p {
-  margin-top: 0;
-pre {
-  padding: 0;
-  margin: 0;
-span#author {
-  color: #527bbd;
-  font-size: 1.1em;
-span#email {
-div#footer {
-  font-size: small;
-div#footer-text {
-  float: left;
-  float: right;
-div#preamble {
-  color: #606060;
-  padding: 0;
-  color: #527bbd;
-  text-align: left;
-div.title + * {
-  margin-top: 0;
-  padding: 0.5em;
-  padding: 0.5em;
-  color: #777777;
-  text-align: left;
-  text-align: left;
-  font-size: 1.1em;
-  color: #527bbd;
-dl {
-dt {
-  margin-bottom: 0;
-  color: navy;
-ul, ol {
-ol.arabic {
-ol.loweralpha {
-ol.upperalpha {
-ol.lowerroman {
-ol.upperroman {
-  color: #527bbd;
-tfoot {
-td > div.verse {
-  white-space: pre;
-p.table {
-  margin-top: 0;
-div.hdlist {
-div.hdlist tr {
-td.hdlist1 {
-  color: navy;
-td.hdlist2 {
-  margin: 0;
-.comment {
-  font-size: 0.8em;
-#footnotes {
-#footnotes hr {
-  border: none;
-  height: 1px;
-  text-align: left;
-  margin-left: 0;
-  width: 20%;
-  min-width: 100px;
-div.colist td {
- at media print {
-div#toc {
-div#toctitle {
-  color: #527bbd;
-  font-size: 1.1em;
-  margin-top: 0;
-  margin-bottom: 0;
-div.toclevel2 {
-  margin-left: 2em;
-  font-size: 0.9em;
-div.toclevel3 {
-  margin-left: 4em;
-  font-size: 0.9em;
-div.toclevel4 {
-  margin-left: 6em;
-  font-size: 0.9em;
-  color: black;
-  padding: 0;
-  margin: 0;
-  padding: 0.5em;
-  background: none;
-  border: none;
-</style>
-/*<![CDATA[*/
- * Version: 0.4
-    var text = "";
-        text += i.data;
-    return text;
-    this.text = text;
-    // browsers).
-          iterate(i);
-    iterate(el);
-    return result;
-  var refs = {};
-  var n = 0;
-      n++;
-  if (n == 0)
-  else {
-        n = refs[href];
-</script>
-</head>
-<div id="header">
-<h1>Part 5: Controlling the compute-node pools where applications run</h1>
-</div>
-<div id="content">
-<div class="paragraph"><p>In this section we’ll use the script <tt>p5.swift</tt>, very similar to
-<tt>p4.swift</tt> of the prior section, to show how we can route apps to
-specific sites, and also how we can make multiple pools of resources
-(on the same or on different computer systems) available to run a
-single Swift script.</p></div>
-<div class="paragraph"><p>First, lets specify that the analysis app <tt>stats.sh</tt> should be run on
-the local login node instead of on the cluster. This is done simply by
-change the site name field of the analyze app in the apps file:</p></div>
-localhost stats     stats.sh</tt></pre>
-</div></div>
-<div class="paragraph"><p>Running this with <tt>swift p5.swift</tt> we see:</p></div>
-<pre><tt>$ grep "on node:" output/*.log
-output/average.log:Running on node: raven
-output/sim_0.log:Running on node: nid00029
-output/sim_1.log:Running on node: nid00029
-output/sim_2.log:Running on node: nid00029
-output/sim_3.log:Running on node: nid00029
-output/sim_4.log:Running on node: nid00029
-output/sim_5.log:Running on node: nid00029
-output/sim_6.log:Running on node: nid00029
-output/sim_7.log:Running on node: nid00029
-output/sim_8.log:Running on node: nid00029
-output/sim_9.log:Running on node: nid00029</tt></pre>
-</div></div>
-<div class="paragraph"><p>Now lets make further use of Swift’s ability to route specific apps to
-specific pools of resources. The Cray Raven system has two node types,
-XE6 32-core 2 x IL-16, and XK7 16-core 1 x IL-16 plus one GPU.  Each
-"pool" of nodes has different queue characteristics. We can define
-these differences to Swift as two separate pools, and then spread the
-load of executing a large ensemble of simulations across all the
-pools. (And we’ll continue to run the analysis script on a third pool,
-comprising the single login host.)</p></div>
-<div class="paragraph"><p>We use the following <tt>apps</tt> file:</p></div>
-<pre><tt>$ cat multipools
-ravenGPU  simulate simulate.sh
-</div></div>
-<div class="paragraph"><p>and we adjust the sites file to specify 4-node jobs in the Raven pool:</p></div>
-<pre><tt>    <profile namespace="globus" key="maxNodes">4</profile>
-</div></div>
-<div class="paragraph"><p>This results in these PBS jobs:</p></div>
-<pre><tt>p01532 at raven:~> qstat -u $USER
-288687.sdb      p01532   small    B0827-3406   9919   4 128    --  00:59 R 00:00
-288688.sdb      p01532   gpu_node B0827-3406   9931   6  96    --  00:59 R 00:00</tt></pre>
-</div></div>
-<div class="olist lowerroman"><ol class="lowerroman">
-<li>
-<p>
-and achieves the following parallelism (of about 224 concurrent app tasks):
-</p>
-</li>
-</ol></div>
-<pre><tt>$ swift -tc.file multipools p5.swift -nsim=1000 -steps=3
-RunID: 20130827-1829-o3h6mht5
-Progress:  time: Tue, 27 Aug 2013 18:29:31 -0500
-Progress:  time: Tue, 27 Aug 2013 18:29:32 -0500  Initializing:997
-Progress:  time: Tue, 27 Aug 2013 18:29:34 -0500  Selecting site:774  Submitting:225  Submitted:1
-Progress:  time: Tue, 27 Aug 2013 18:29:35 -0500  Selecting site:774  Stage in:1  Submitted:225
-Progress:  time: Tue, 27 Aug 2013 18:29:36 -0500  Selecting site:774  Stage in:1  Submitted:37  Active:188
-Progress:  time: Tue, 27 Aug 2013 18:29:39 -0500  Selecting site:774  Submitted:2  Active:223  Stage out:1
-Progress:  time: Tue, 27 Aug 2013 18:29:40 -0500  Selecting site:750  Submitted:17  Active:208  Stage out:1  Finished successfully:24
-Progress:  time: Tue, 27 Aug 2013 18:29:41 -0500  Selecting site:640  Stage in:1  Submitted:51  Active:174  Finished successfully:134
-Progress:  time: Tue, 27 Aug 2013 18:29:42 -0500  Selecting site:551  Submitted:11  Active:214  Stage out:1  Finished successfully:223
-Progress:  time: Tue, 27 Aug 2013 18:29:43 -0500  Selecting site:542  Submitted:2  Active:223  Stage out:1  Finished successfully:232
-Progress:  time: Tue, 27 Aug 2013 18:29:44 -0500  Selecting site:511  Submitting:1  Submitted:19  Active:206  Finished successfully:263
-Progress:  time: Tue, 27 Aug 2013 18:29:45 -0500  Selecting site:463  Stage in:1  Submitted:43  Active:182  Finished successfully:311
-Progress:  time: Tue, 27 Aug 2013 18:29:46 -0500  Selecting site:367  Submitting:1  Submitted:38  Active:186  Stage out:1  Finished successfully:407
-Progress:  time: Tue, 27 Aug 2013 18:29:47 -0500  Selecting site:309  Submitted:2  Active:223  Stage out:1  Finished successfully:465
-Progress:  time: Tue, 27 Aug 2013 18:29:48 -0500  Selecting site:300  Submitted:2  Active:223  Stage out:1  Finished successfully:474
-Progress:  time: Tue, 27 Aug 2013 18:29:50 -0500  Selecting site:259  Submitted:11  Active:214  Stage out:1  Finished successfully:515
-Progress:  time: Tue, 27 Aug 2013 18:29:51 -0500  Selecting site:201  Stage in:1  Submitted:39  Active:186  Finished successfully:573
-Progress:  time: Tue, 27 Aug 2013 18:29:52 -0500  Selecting site:80  Submitted:42  Active:184  Finished successfully:694
-Progress:  time: Tue, 27 Aug 2013 18:29:53 -0500  Selecting site:54  Submitted:2  Active:223  Stage out:1  Finished successfully:720
-Progress:  time: Tue, 27 Aug 2013 18:29:54 -0500  Selecting site:32  Submitted:4  Active:220  Stage out:1  Finished successfully:743
-Progress:  time: Tue, 27 Aug 2013 18:29:55 -0500  Submitted:3  Active:216  Stage out:1  Finished successfully:780
-Progress:  time: Tue, 27 Aug 2013 18:29:56 -0500  Stage in:1  Active:143  Finished successfully:856
-Progress:  time: Tue, 27 Aug 2013 18:29:57 -0500  Active:38  Stage out:1  Finished successfully:961
-Progress:  time: Tue, 27 Aug 2013 18:29:58 -0500  Active:8  Stage out:1  Finished successfully:991
-Progress:  time: Tue, 27 Aug 2013 18:29:59 -0500  Stage out:1  Finished successfully:999
-Progress:  time: Tue, 27 Aug 2013 18:30:01 -0500  Stage in:1  Finished successfully:1000
-Progress:  time: Tue, 27 Aug 2013 18:30:02 -0500  Active:1  Finished successfully:1000
-Progress:  time: Tue, 27 Aug 2013 18:30:06 -0500  Stage out:1  Finished successfully:1000
-Final status: Tue, 27 Aug 2013 18:30:07 -0500  Finished successfully:1001</tt></pre>
-</div></div>
-</div>
-</div>
-</div>
-<div id="footer">
-Last updated 2013-09-11 13:13:27 CDT
-</div>
-</div>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/p5.swift
--- SwiftApps/tryswift/scripts/p5.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p5.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,29 +0,0 @@
-type file;
-file sims[];
-  sims[i] = simout;
Deleted: SwiftApps/tryswift/scripts/p5.txt
--- SwiftApps/tryswift/scripts/p5.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p5.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1 +0,0 @@
-p5
Deleted: SwiftApps/tryswift/scripts/p6.html
--- SwiftApps/tryswift/scripts/p6.html	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p6.html	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,797 +0,0 @@
-<head>
-<title></title>
-div#toctitle,
-div#footer {
-/* Serif font. */
-div.sectionbody {
-tt {
-body {
-a {
-  color: blue;
-a:visited {
-  color: fuchsia;
-em {
-  color: navy;
-strong {
-  color: #083194;
-tt {
-  color: navy;
-  color: #527bbd;
-  line-height: 1.3;
-h1, h2, h3 {
-h2 {
-h3 {
-  float: left;
-h3 + * {
-  clear: left;
-div.sectionbody {
-  margin-left: 0;
-hr {
-p {
-ul, ol, li > p {
-  margin-top: 0;
-pre {
-  padding: 0;
-  margin: 0;
-span#author {
-  color: #527bbd;
-  font-size: 1.1em;
-span#email {
-div#footer {
-  font-size: small;
-div#footer-text {
-  float: left;
-  float: right;
-div#preamble {
-  color: #606060;
-  padding: 0;
-  color: #527bbd;
-  text-align: left;
-div.title + * {
-  margin-top: 0;
-  padding: 0.5em;
-  padding: 0.5em;
-  color: #777777;
-  text-align: left;
-  text-align: left;
-  font-size: 1.1em;
-  color: #527bbd;
-dl {
-dt {
-  margin-bottom: 0;
-  color: navy;
-ul, ol {
-ol.arabic {
-ol.loweralpha {
-ol.upperalpha {
-ol.lowerroman {
-ol.upperroman {
-  color: #527bbd;
-tfoot {
-td > div.verse {
-  white-space: pre;
-p.table {
-  margin-top: 0;
-div.hdlist {
-div.hdlist tr {
-td.hdlist1 {
-  color: navy;
-td.hdlist2 {
-  margin: 0;
-.comment {
-  font-size: 0.8em;
-#footnotes {
-#footnotes hr {
-  border: none;
-  height: 1px;
-  text-align: left;
-  margin-left: 0;
-  width: 20%;
-  min-width: 100px;
-div.colist td {
- at media print {
-div#toc {
-div#toctitle {
-  color: #527bbd;
-  font-size: 1.1em;
-  margin-top: 0;
-  margin-bottom: 0;
-div.toclevel2 {
-  margin-left: 2em;
-  font-size: 0.9em;
-div.toclevel3 {
-  margin-left: 4em;
-  font-size: 0.9em;
-div.toclevel4 {
-  margin-left: 6em;
-  font-size: 0.9em;
-  color: black;
-  padding: 0;
-  margin: 0;
-  padding: 0.5em;
-  background: none;
-  border: none;
-</style>
-/*<![CDATA[*/
- * Version: 0.4
-    var text = "";
-        text += i.data;
-    return text;
-    this.text = text;
-    // browsers).
-          iterate(i);
-    iterate(el);
-    return result;
-  var refs = {};
-  var n = 0;
-      n++;
-  if (n == 0)
-  else {
-        n = refs[href];
-</script>
-</head>
-<div id="header">
-</div>
-<div id="content">
-<div class="sect2">
-<h3 id="_part_6_specifying_more_complex_workflow_patterns">Part 6: Specifying more complex workflow patterns</h3>
-<div class="paragraph"><p>p6.swift expands the workflow pattern of p4.swift to add additional
-stages to the workflow. Here, we generate a dynamic seed value that
-will be used by all of the simulations, and for each simulation, we
-run an pre-processing application to generate a unique "bias
-file". This pattern is shown below, followed by the Swift script.</p></div>
-<div class="imageblock" style="text-align:center;">
-<img src="part06.png" alt="part06.png" />
-</div>
-</div>
-<div class="title">p6.swift</div>
-<pre><tt>type file;
-# app() functions for application programs to be called:
-app (file out) genseed (int nseeds)
-  genseed "-r" 2000000 "-n" nseeds stdout=@out;
-app (file out) genbias (int bias_range, int nvalues)
-  genbias "-r" bias_range "-n" nvalues stdout=@out;
-app (file out, file log) simulation (int timesteps, int sim_range,
-                                     file bias_file, int scale, int sim_count)
-  simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
-           "-n" sim_count stdout=@out stderr=@log;
-  stats @filenames(s) stdout=@out stderr=@log;
-# Command line arguments
-int  nsim  = @toInt(@arg("nsim",   "10"));  # number of simulation programs to run
-int  steps = @toInt(@arg("steps",  "1"));   # number of timesteps (seconds) per simulation
-int  range = @toInt(@arg("range",  "100")); # range of the generated random numbers
-int  values = @toInt(@arg("values", "10"));  # number of values generated per simulation
-# Main script and data
-tracef("\n*** Script parameters: nsim=%i range=%i num values=%i\n\n", nsim, range, values);
-file seedfile<"output/seed.dat">;        # Dynamically generated bias for simulation ensemble
-seedfile = genseed(1);
-int seedval = readData(seedfile);
-tracef("Generated seed=%i\n", seedval);
-file sims[];                      # Array of files to hold each simulation output
-  file biasfile <single_file_mapper; file=@strcat("output/bias_",i,".dat")>;
-  file simout   <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
-  file simlog   <single_file_mapper; file=@strcat("output/sim_",i,".log")>;
-  biasfile = genbias(1000, 20);
-  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values);
-  sims[i] = simout;
-(stats_out,stats_log) = analyze(sims);</tt></pre>
-</div></div>
-<div class="paragraph"><p>Note that the workflow is based on data flow dependencies: each simulation depends on the seed value, calculated in these two dependent statements:</p></div>
-<pre><tt>seedfile = genseed(1);
-int seedval = readData(seedfile);</tt></pre>
-</div></div>
-<div class="paragraph"><p>and on the bias file, computed and then consumed in these two dependent statements:</p></div>
-<pre><tt>  biasfile = genbias(1000, 20);
-  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values);</tt></pre>
-</div></div>
-<div class="paragraph"><p>To run:</p></div>
-<pre><tt>$ cd ../part06
-$ swift p6.swift</tt></pre>
-</div></div>
-<div class="paragraph"><p>The default parameters result in the following execution log:</p></div>
-<pre><tt>$ swift p6.swift
-RunID: 20130827-1917-jvs4gqm5
-Progress:  time: Tue, 27 Aug 2013 19:17:56 -0500
-*** Script parameters: nsim=10 range=100 num values=10
-Progress:  time: Tue, 27 Aug 2013 19:17:57 -0500  Stage in:1  Submitted:10
-Generated seed=382537
-Progress:  time: Tue, 27 Aug 2013 19:17:59 -0500  Active:9  Stage out:1  Finished successfully:11
-Final status: Tue, 27 Aug 2013 19:18:00 -0500  Finished successfully:22</tt></pre>
-</div></div>
-<div class="paragraph"><p>which produces the following output:</p></div>
-<pre><tt>$ ls -lrt output
-total 264
--rw-r--r-- 1 p01532 61532     9 Aug 27 19:17 seed.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_9.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_8.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_7.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_6.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_5.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_4.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_3.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_2.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_1.dat
--rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_0.dat
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_9.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_9.log
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_8.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_7.out
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_6.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_6.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_5.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_5.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_4.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_4.log
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_1.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_8.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_7.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_3.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_3.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_2.out
--rw-r--r-- 1 p01532 61532 14898 Aug 27 19:18 sim_2.log
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_1.out
--rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_0.out
--rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_0.log
--rw-r--r-- 1 p01532 61532     9 Aug 27 19:18 average.out
--rw-r--r-- 1 p01532 61532 14675 Aug 27 19:18 average.log</tt></pre>
-</div></div>
-<div class="paragraph"><p>Each sim_N.out file is the sum of its bias file plus newly "simulated" random output scaled by 1,000,000:</p></div>
-<pre><tt>$ cat output/bias_0.dat
-     302
-     489
-      81
-     582
-     664
-     290
-     839
-     258
-     506
-     310
-     293
-     508
-      88
-     261
-     453
-     187
-      26
-     198
-     402
-     555
-$ cat output/sim_0.out
-64000302
-38000489
-32000081
-12000582
-46000664
-36000290
-35000839
-22000258
-49000506
-75000310</tt></pre>
-</div></div>
-<div class="paragraph"><p>We produce 20 values in each bias file. Simulations of less than that
-number of values ignore the unneeded number, while simualtions of more
-than 20 will use the last bias number for all remoaining values past
-20.  As an exercise, adjust the code to produce the same number of
-bias values as is needed for each simulation.  As a further exercise,
-modify the script to generate a unique seed value for each simulation,
-which is a common practice in ensemble computations.</p></div>
-</div>
-</div>
-<div id="footer">
-Last updated 2013-09-11 13:10:53 CDT
-</div>
-</div>
-</body>
-</html>
Deleted: SwiftApps/tryswift/scripts/p6.swift
--- SwiftApps/tryswift/scripts/p6.swift	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p6.swift	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,57 +0,0 @@
-type file;
-int  nsim  = toInt(arg("nsim",   "10"));  # number of simulation programs to run
-int  steps = toInt(arg("steps",  "1"));   # number of timesteps (seconds) per simulation
-int  range = toInt(arg("range",  "100")); # range of the generated random numbers
-int  values = toInt(arg("values", "10"));  # number of values generated per simulation
-  file biasfile <single_file_mapper; file=strcat("output/bias_",i,".dat")>;
-  sims[i] = simout;
Deleted: SwiftApps/tryswift/scripts/p6.txt
--- SwiftApps/tryswift/scripts/p6.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/p6.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1 +0,0 @@
-p6
Deleted: SwiftApps/tryswift/scripts/part04.png
Deleted: SwiftApps/tryswift/scripts/part05.png
Deleted: SwiftApps/tryswift/scripts/part06.png
Deleted: SwiftApps/tryswift/scripts/part4.txt
--- SwiftApps/tryswift/scripts/part4.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/part4.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,249 +0,0 @@
-Part 4: Running a parallel ensemble on Cray compute nodes
-`p4.swift` will run our mock "simulation"
-`p3.swift`, but specifies that each simulation app invocation should
-`stderr`.
-FIXME: need to revise this figure: drop prog:
-, making the parallel portion of the script behave like this:
-image::part04.png[align="center"]
-.p4.swift
-sys::[cat ../part04/p4.swift]
-Now when you run `swift p4.swift` you'll see that two types output
-files will placed in the `output/` directory: `sim_N.out` and
-`sim_N.log`.  The log files provide data on the runtime environment of
-$ cat output/sim_0.log
-bias=0
-biasfile=none
-initseed=none
-log=yes
-paramfile=none
-range=100
-scale=1
-seedfile=none
-timesteps=1
-output width=8
-Environment:
-ALPS_APP_DEPTH=32
-To tell Swift to run the apps on compute nodes, we specify in the
-`apps` file that the apps should be executed on the `raven` site
-(instead of the `localhost` site).  We can specify the location of
-each app in the third field of the `apps` file, with either an
-`PATH`). Here we use the latter form:
-$ cat apps
-You can experiment, for example, with an alternate version of stats.sh by specfying that app's location explicitly:
-$ cat apps
-We can see that when we run many apps requesting a larger set of nodes (6), we are indeed running on the compute nodes:
-$ swift p4.swift -nsim=1000 -steps=1
-    158 nid00032
-    156 nid00033
-    171 nid00060
-    178 nid00061
-    166 nid00062
-    171 nid00063
-$ hostname
-raven
-$ hostname -f
-nid00008
-Swift's `sites.xml` configuration file allows many parameters to
-  <profile namespace="globus" key="queue">small</profile>
-To run large jobs, we can specify:
-This will enable 512 Swift apps (2 x 8 x 32) to run concurrently
-within 2 8-node jobs on Raven's 32-core nodes.  It results in the
-$ qstat -u $USER
-The following section is a summary of the important `sites.xml`
-.sites.xml
-sys::[egrep -v '<.xml|<config|</config' ../part04/sites.xml | cat -n ]
-The additional attributes in the `sites.xml` file (described here
-`execution provider coaster, jobmanager local:pbs` specifies that
-http://www.swift-lang.org/papers/UCC-coasters.pdf[this paper from UCC-2011].
-`profile` tags specify additional attributes for the execution
-The `env` key `PATHPREFIX` specifies that our tutorial `app` directory
-(`../app`) will be placed at the front of PATH to locate the app on
-the compute node.
-`queue small` specifies that pilot (coaster) jobs to run apps will be
-submitted to Raven's `small` queue.
-`providerAttributes pbs.aprun;pbs.mpp;depth=32` specifies some
-resource attributes (eg `mppwidth` and `mppnppn`) and an mppdepth of
-Raven's XE6 dual IL-16 nodes have a depth of 32 processing elements
-(PEs).
-`jobsPerNode 32` tells Swift that each coaster should run up to 32
-`slots 2` specifies that Swift will run up to 2 concurrent PBS jobs,
-and `maxNodes 1` specifies that each of these jobs will request only 1
-compute node.
-`maxWallTime 00:01:00` specifies that Swift should allow each app to
-attributes `maxtime` along with `highOverAllocation` and
-`lowOverAllocation`.
-`jobThrottle 3.20` specifies that Swift should allow up to 320 apps to
-run on the `raven` site at once.  This is typically set to a number
-per node (`jobsPerNode` attribute).
-`initialscore 10000` is specified to override Swift's automatic
-(specifically 1 over) `jobThrottle` * 100 to be used.
-The last two attributes specify where and how Swift should perform
-data management.  `workdirectory /lus/scratch/{env.USER}/swiftwork`
-directory local to the compute node (eg, for Cray systems, `/dev/shm`
-or `/tmp`, if those are writable by user jobs and the nodes have
-Finally, `stagingMethod sfs` specifies that Swift will copy data to
-directories.
Deleted: SwiftApps/tryswift/scripts/part5.txt
--- SwiftApps/tryswift/scripts/part5.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/part5.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,112 +0,0 @@
-Part 5: Controlling the compute-node pools where applications run
-In this section we'll use the script `p5.swift`, very similar to
-`p4.swift` of the prior section, to show how we can route apps to
-image::part05.png[align="center"]
-.p5.swift
-sys::[cat ../part05/p5.swift]
-First, lets specify that the analysis app `stats.sh` should be run on
-$ cat apps
-Running this with `swift p5.swift` we see:
-$ grep "on node:" output/*.log
-Now lets make further use of Swift's ability to route specific apps to
-pools. (And we'll continue to run the analysis script on a third pool,
-We use the following `apps` file:
-$ cat multipools
-and we adjust the sites file to specify 4-node jobs in the Raven pool:
-This results in these PBS jobs:
-p01532 at raven:~> qstat -u $USER
-... and achieves the following parallelism (of about 224 concurrent app tasks):
-$ swift -tc.file multipools p5.swift -nsim=1000 -steps=3
Deleted: SwiftApps/tryswift/scripts/part6.txt
--- SwiftApps/tryswift/scripts/part6.txt	2013-12-11 19:31:24 UTC (rev 7413)
+++ SwiftApps/tryswift/scripts/part6.txt	2013-12-11 22:22:44 UTC (rev 7414)
@@ -1,134 +0,0 @@
-Part 6: Specifying more complex workflow patterns
-p6.swift expands the workflow pattern of p4.swift to add additional
-image::part06.png[align="center"]
-.p6.swift
-sys::[cat ../part06/p6.swift]
-Note that the workflow is based on data flow dependencies: each simulation depends on the seed value, calculated in these two dependent statements:
-and on the bias file, computed and then consumed in these two dependent statements:
-To run:
-$ cd ../part06
-$ swift p6.swift
-The default parameters result in the following execution log:
-$ swift p6.swift
-which produces the following output:
-$ ls -lrt output
-total 264
-Each sim_N.out file is the sum of its bias file plus newly "simulated" random output scaled by 1,000,000:
-$ cat output/bias_0.dat
-     302
-     489
-      81
-     582
-     664
-     290
-     839
-     258
-     506
-     310
-     293
-     508
-      88
-     261
-     453
-     187
-      26
-     198
-     402
-     555
-64000302
-38000489
-32000081
-12000582
-46000664
-36000290
-35000839
-22000258
-49000506
-75000310
-We produce 20 values in each bias file. Simulations of less than that
