[Swift-commit] r7401 - in SwiftApps/Blast: . v1 v2
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Tue Dec 10 22:50:43 CST 2013
Author: wilde
Date: 2013-12-10 22:50:42 -0600 (Tue, 10 Dec 2013)
New Revision: 7401
Added:
   SwiftApps/Blast/v1/
   SwiftApps/Blast/v1/Tblast.swift
   SwiftApps/Blast/v1/apps
   SwiftApps/Blast/v1/blast.c++.swift
   SwiftApps/Blast/v1/blast.swift
   SwiftApps/Blast/v1/cf
   SwiftApps/Blast/v1/cleanup
   SwiftApps/Blast/v1/formatdbmapper.sh
   SwiftApps/Blast/v1/outputmapper.sh
   SwiftApps/Blast/v1/run.sh
   SwiftApps/Blast/v1/sequence.seq
   SwiftApps/Blast/v1/sites.local.xml
   SwiftApps/Blast/v1/sites.midway.xml
   SwiftApps/Blast/v1/splitmapper.sh
   SwiftApps/Blast/v1/tc.data
   SwiftApps/Blast/v2/
   SwiftApps/Blast/v2/apps
   SwiftApps/Blast/v2/blast2.swift
   SwiftApps/Blast/v2/cf
   SwiftApps/Blast/v2/fblastall.sh
   SwiftApps/Blast/v2/nr.sub1
   SwiftApps/Blast/v2/run2.sh
   SwiftApps/Blast/v2/sequence.seq
   SwiftApps/Blast/v2/sites.local.xml
Log:
Initial snapshot of Ketan's BLAST workflow from EC2 VM.
Added: SwiftApps/Blast/v1/Tblast.swift
--- SwiftApps/Blast/v1/Tblast.swift	                        (rev 0)
+++ SwiftApps/Blast/v1/Tblast.swift	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,53 @@
+import files;
+import io;
+import string;
+import sys;
+app (file out) formatdb (file i) {
+  "/root/bin/formatdb.sh" i out;
+app (file o) blastapp (file i, file d, string p, string e, string f, file db) {
+ "/root/bin/blastall.sh" i d p e f db o;
+app (file o) blastmerge (file o_frags[]) {
+  "/root/parallelblast_2.0.9/blastmerge" o o_frags;
+(file o[]) split_database(file d, int n) "turbine" "0.1"
+set f [ swift_filename &<<d>> ];
+exec -ignorestderr /root/parallelblast_2.0.9/fastasplitn $f <<n>>;
+set L [ glob frag* ];
+turbine::swift_array_build <<o>> $L file;
+main{
+ string prog_name="blastp";
+ string expectation_value="0.1";
+ string filter_query_sequence="F";
+ int np=toint(argv("np"));
+ file out[];
+ nr="/root/blast/nr.trm";
+ seq="/root/blast/sequence.seq";
+ file formatdbout[];
+ //file outfile <"output.html">;
+ file dbin=input_file(nr);
+ file query_file=input_file(seq);
+ file partition[];
+ partition=split_database(dbin, np);
+ foreach i in [0:np-1] {
+  file t<sprintf("frag%i.tgz", i)> = formatdb(partition[i]);
+  formatdbout[i] = t;
+  file q<sprintf("blastout%i.html", i)> = blastapp(query_file, partition[i], prog_name, expectation_value, filter_query_sequence, formatdbout[i]);
+  out[i] = q;
+ file blast_output_file<"output.html"> = blastmerge(out);
Added: SwiftApps/Blast/v1/apps
--- SwiftApps/Blast/v1/apps	                        (rev 0)
+++ SwiftApps/Blast/v1/apps	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,16 @@
+midway bash /bin/bash
+midway mid_bash /bin/bash
+midway loc_bash /bin/bash
+beagle bgl_bash /bin/bash
+local  loc_bash /bin/bash
+local  cat /bin/cat
+midway blastmerge /root/parallelblast_2.0.9/blastmerge
+midway blastall /root/blast-2.2.26/bin/blastall
+localhost fastasplitn /root/parallelblast_2.0.9/fastasplitn
+localhost formatdb /root/blast-2.2.26/bin/formatdb
+localhost blastall /root/blast-2.2.26/bin/blastall
+localhost blastmerge /root/parallelblast_2.0.9/blastmerge
+persistent-coasters fastasplitn /root/parallelblast_2.0.9/fastasplitn
+persistent-coasters formatdb /root/blast-2.2.26/bin/formatdb
+persistent-coasters blastall /root/blast-2.2.26/bin/blastall
+persistent-coasters blastmerge /root/parallelblast_2.0.9/blastmerge
Added: SwiftApps/Blast/v1/blast.c++.swift
--- SwiftApps/Blast/v1/blast.c++.swift	                        (rev 0)
+++ SwiftApps/Blast/v1/blast.c++.swift	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,59 @@
+type fastaseq;
+type headerfile;
+type indexfile;
+type seqfile;
+type query;
+type output;
+type database {
+  headerfile phr;
+  indexfile pin;
+  seqfile psq;
+string num_partitions = arg("n", "50");
+string program_name = arg("p", "blastp");
+fastaseq dbin <single_file_mapper;file = arg("d", "nr")>;
+query query_file <single_file_mapper;file = arg("i", "sequence.seq")>;
+string expectation_value = arg("e", "0.1");
+output blast_output_file <single_file_mapper;file = arg("o", "output.html")>;
+string filter_query_sequence = arg("F", "F");
+fastaseq partition[] <ext;exec = "splitmapper.sh", n = num_partitions>;
+database formatdbout[] <ext; exec = "formatdbmapper.sh", n = num_partitions>;
+output out[] <ext; exec = "outputmapper.sh", n = num_partitions>;
+app (fastaseq out[]) split_database (fastaseq d, string n){
+  fastasplitn filename(d) n;
+app (database out) formatdb (fastaseq i){
+  formatdb "-dbtype" "prot" "-in" @filename(i);
+app (output o) blastapp(query i, fastaseq d, string e, string f, database db){
+  blastp "-query" @filename(i) "-out" @filename(o) "-db" @filename(d) "-evalue" e "-html" "-outfmt" "1";
+app (output o) blastmerge(output o_frags[]){
+  blastmerge filename(o) filenames(o_frags);
+partition=split_database(dbin, num_partitions);
+foreach part,i in partition {
+  formatdbout[i] = formatdb(part);
+  out[i] = blastapp(query_file, part, expectation_value, filter_query_sequence, formatdbout[i]);
+blast_output_file = blastmerge(out);
Added: SwiftApps/Blast/v1/blast.swift
--- SwiftApps/Blast/v1/blast.swift	                        (rev 0)
+++ SwiftApps/Blast/v1/blast.swift	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,51 @@
+type fastaseq;
+type headerfile;
+type indexfile;
+type seqfile;
+type database
+  headerfile phr;
+  indexfile pin;
+  seqfile psq;
+type query;
+type output;
+string num_partitions=@arg("n", "10");
+string program_name=@arg("p", "blastp");
+fastaseq dbin <single_file_mapper;file=@arg("d", "nr.trm")>;
+query query_file <single_file_mapper;file=@arg("i", "sequence.seq")>;
+string expectation_value=@arg("e", "0.1");
+output blast_output_file <single_file_mapper;file=@arg("o", "output.html")>;
+string filter_query_sequence=@arg("F", "F");
+fastaseq partition[] <ext;exec="splitmapper.sh",n=num_partitions>;
+  fastasplitn @filename(d) n;
+  formatdb "-i" @filename(i);
+app (output o) blastapp(query i, fastaseq d, string p, string e, string f, database db){
+  blastall "-p" p "-i" @filename(i) "-d" @filename(d) "-o" @filename(o) "-e" e "-T" "-F" f;
+  blastmerge @filename(o) @filenames(o_frags);
+database formatdbout[] <ext; exec="formatdbmapper.sh",n=num_partitions>;
+output out[] <ext; exec="outputmapper.sh",n=num_partitions>;
+  out[i]=blastapp(query_file, part, program_name, expectation_value, filter_query_sequence, formatdbout[i]);
+blast_output_file=blastmerge(out);
Added: SwiftApps/Blast/v1/cf
--- SwiftApps/Blast/v1/cf	                        (rev 0)
+++ SwiftApps/Blast/v1/cf	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,9 @@
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+#tcp.port.range=50000,51000
+Dtcp.channel.log.io.performance=true
\ No newline at end of file
Added: SwiftApps/Blast/v1/cleanup
--- SwiftApps/Blast/v1/cleanup	                        (rev 0)
+++ SwiftApps/Blast/v1/cleanup	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,2 @@
+rm -rf *.log frag??? frag*.tgz *.rlog *.d blast-*-*-* *.kml *.swiftx *.out output *.html *.phr *.pin *.psq outdir logs .swift/tmp
Property changes on: SwiftApps/Blast/v1/cleanup
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Blast/v1/formatdbmapper.sh
--- SwiftApps/Blast/v1/formatdbmapper.sh	                        (rev 0)
+++ SwiftApps/Blast/v1/formatdbmapper.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,18 @@
+#!/bin/bash
+while [ $# -gt 0 ]; do
+    case $1 in
+	-n)          n=$2;;
+	*) echo "$0: bad mapper args" 1>&2
+	    exit 1;;
+    esac
+    shift 2
+done
+for i in $(seq 1 $n)
+do
+    printf "[%d].phr frag%03d.phr\n" $i $i;
+    printf "[%d].pin frag%03d.pin\n" $i $i;
+    printf "[%d].psq frag%03d.psq\n" $i $i;
+done
Property changes on: SwiftApps/Blast/v1/formatdbmapper.sh
Added: SwiftApps/Blast/v1/outputmapper.sh
--- SwiftApps/Blast/v1/outputmapper.sh	                        (rev 0)
+++ SwiftApps/Blast/v1/outputmapper.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,16 @@
+#!/bin/bash
+    case $1 in
+	-n)          n=$2;;
+	    exit 1;;
+    esac
+    shift 2
+done
+do
+    printf "[%d] frag%03d.html\n" $i $i;
+done
Property changes on: SwiftApps/Blast/v1/outputmapper.sh
Added: SwiftApps/Blast/v1/run.sh
--- SwiftApps/Blast/v1/run.sh	                        (rev 0)
+++ SwiftApps/Blast/v1/run.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1 @@
+swift -sites.file sites.xml -config cf -tc.file apps blast.swift
Property changes on: SwiftApps/Blast/v1/run.sh
Added: SwiftApps/Blast/v1/sequence.seq
--- SwiftApps/Blast/v1/sequence.seq	                        (rev 0)
+++ SwiftApps/Blast/v1/sequence.seq	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,106 @@
+>gnl|md5|e0785fc0b8720a5c4d78be370ef19af0
+MEVLESGEQGVLQWDRKLSELSEPGDGEALMYHTHFSELLDEFSQNVLGQLLNDPFLSEK
+SVSMEVEPSPTSPAPLIQAEHSYSLCEEPRAQSPFTHITSDSFNDDEVESEKWYLSTDFP
+STSIKTEPITDEPPPGLVPSVTLTITAISTPLEKEEPPLEMNTGVDSSCQTIIPKIKLEP
+HEVDQFLNFSPKEAPVDHLHLPPTPPSSHGSDSEGSLSPNPRLHPFSLPQTHSPSRAAPR
+APSALSSSPLLTAPHKLQGSGPLVLTEEEKRTLIAEGYPIPTKLPLSKSEEKALKKIRRK
+IKNKISAQESRRKKKEYMDSLEKKVESCSTENLELRKKVEVLENTNRTLLQQLQKLQTLV
+MGKVSRTCKLAGTQTGTCLMVVVLCFAVAFGSFFQGYGPYPSATKMALPSQHSLQEPYTA
+SVVRSRNLLIYEEHSPPEESSSPGSAGELGGWDRGSSLLRVSGLESRPDVDLPHFIISNE
+TSLEKSVLLELQQHLVSAKLEGNETLKVVELDRRVNTTF
+>gnl|md5|f67549f249c59ecd0b48ff02ca209442
+MAEETRQSKLAIAKEKLKEYWQRNSLGVPAGVKRNRKTSGSSPETATSGGCHSPEDSATG
+IHGEGPTSSATLKDLESPCQELAVVLDSRSIKISQLNNTIKSLVIMANILVFVFPKCIVI
+DLNRNVDTEISKMSMG
+>gnl|md5|cd0de5548a14c880425dc87f8486310c
+MNSGAMRIHSKGHFQGGIQVKNEKNRPSLKSLKTDNRPEKSKCKPLWGKVFYLDLPSVTI
+SEKLQKDIKDLGGRVEEFLSKDISYLISNKKEAKFAQTLGRISPVPSPESAYTAETTSPH
+PSHDGSSFKSPDTVCLSRGKLLVEKAIKDHDFIPSNSILSNALSWGVKILHIDDIRYYIE
+QKKKELYLLKKSSTSVRDGGKRVGSGAQKTRTGRLKKPFVKVEDMSQLYRPFYLQLTNMP
+FINYSIQKPCSPFDVDKPSSMQKQTQVKLRIQTDGDKYGGTSIQLQLKEKKKKGYCECCL
+QKYEDLETHLLSEQHRNFAQSNQYQVVDDIVSKLVFDFVEYEKDTPKKKRIKYSVGSLSP
+VSASVLKKTEQKEKVELQHISQKDCQEDDTTVKEQNFLYKETQETEKKLLFISEPIPHPS
+NELRGLNEKMSNKCSMLSTAEDDIRQNFTQLPLHKNKQECILDISEHTLSENDLEELRVD
+HYKCNIQASVHVSDFSTDNSGSQPKQKSDTVLFPAKDLKEKDLHSIFTHDSGLITINSSQ
+EHLTVQAKAPFHTPPEEPNECDFKNMDSLPSGKIHRKVKILLGQNRKENLEPNAEFDKRT
+EFITQEENRICSSPVQSLPDLFQTSEEKSEFLGFTSYTEKSGICNVLDIWEEENSDNLLT
+AFFSSPSTSTFTGF
+>gnl|md5|c243d77c83c27dff598d70af18d8ed42
+MGAEQIRLEDRAQCAARQVLGGAGDGEGGVVHQRVDAPQGQRGFGAARHAVLAAQFQVQR
+VEALGAAGLDILGLAAGGDDAPAARPHVPRRVQPDARGTAGDQNGLHARLLAAGVLRQGR
+ALRKPRISGWTGAACGPIHRNMSDDPNVPDPTPPDPSQDQTTSEPLSRAIGERYLTYALS
+TIMNRALPDARDGLKPVHRRILFAMRELRLSPTGAFRKSAKISGDVMGNYHPHGDAAIYD
+AMARLAQPFAMRYPLVDGQGNFGNIDGDNPAASRYTEARLTAAAEALMEGLAENAVDFRP
+NYDGTLEEPIVLPAAFPNLLCNGASGIAVGMATNVPPHNLHEVIDACLHLIKAPDARDDT
+LVSIVPGPDFPTGGVLVESRETIAEAYRTGRGSLRLRARWSVEDLGRGQWQIVVTEIPYQ
+VQKSKLIERLAEVIQLKKVPILADVRDESAEDIRIVLEPRTRAVDAEQLMAALFRVSDLE
+VRFGLNMNVLIDGRVPKVCSLKEVLRAFLDHRREVLVRRSNHRLDKIAARLEVLEGYMIA
+FLNLDRVIEIIRHEDDPKAVMIAEFKLSDVQVEAILNMRLRALRRLEEIELRAEHENLTR
+EREGLAAMLADEGAQWARIAEELRETRAKFGKSASGGQRRTEIGEAGEVAEIDMDAMIER
+EPITVILSKMGWIRAMKGHQPLDAEVKFKDGDGPFMALHAETTDKLMVFAANGRFYTLPA
+NNLPGGRGMGEPLRLMIDLPNDAAVIDMFPWRDGERYLVASKAGDGFVVAGADILAQTRA
+GKQVLNGEAALCRRVTGDHVAVVGQNRKLLVFPLSELPEMARGKGVRLQKYKDGGLSDAV
+CITLAEGLRWQETGGRTRSEPDLTEWLGKRAGAGYMAPRGFPRDNRFN
+>gnl|md5|ccc28dbc1a3ca81c8dd929af669b1173
+MDRAERIGFWVSGFAHAGLLGAALVGGALFRPQPLEAVRMAEVATMSEAEFQSLAAAAAG
+RGPVSDVAATTPAQPRPPADENRLGEVEAVSPPAPDAQAAELSTPSDRPEARPDLSDFQT
+PNRPVAVATDAPRPAEPENTVELAAL
+>gnl|md5|9d3da0729b348bbcaba8c65c444b6fee
+MAGPAHGRAHRGAALMLEVAFRHRFPGLSLEVAFQAPGGVTALFGPSGCGKSTAINAIAG
+LLRPDQGRIALDGRVLFDGATNLSPQARRIGCVFQDARLFPHMTVAANLRYPSRWRRGAA
+RDFDRITEMLALGPLLHRRPGTLSGGERQRVAIGRALLSDPALLVMDEPLAALDEARKAE
+IMPWLERLRDQIRLPILYVSHSVPEVLRLATTVVLMRQGRVTHSGALADILADPELAPQL
+GAREAGALIRATVEAREADGLTRVATAGGPMLLPELDLAPGRVLRLRILAHEVILAREAP
+RGLSALNALPVAVTRIEGGLVQLALGHGAQHERMLAQVTPRSVKALELQPGTACHAIVKS
+VSVLPS
+>gnl|md5|4276fd81078276b607fce4cf16581984
+MPRRRSSCCPRSLAGRPVPRNTRQPSRGSTLPGSPRRWKSPRPHGRSISEGLARPGKGRT
+FIGRPSPSLNIWPGIAGIMPPLAVGSWVAAVEQTYAADAGMRRDEAIRSATPGAAFPIFA
+AQAHGLASCPMVGFDAERLAREFALAADEIPVLLVAVGHAAEGNRPQKPRLPVAQILTTL
+QQPEVDMPKPSDILLTALAPAVWGSTYIVATELLPGAPPLSVAAIRALPTGLILLLLVRQ
+LPKGDWLWRSFVLGALNFTVFWALLFVAAYRLPGGIAATVGAVQPLIVVFAASAVLGTRI
+RVLSVLAAVMGMAGVALLVLQDGAVPDMPGIAAALGGAFSMAFGTVLTRKWRPPVSALVL
+TAWQLTAGGLLLLPLALLLDPPMPPLDAANAAGMGYLVLFTALTYILWFRGVARLEPAAV
+SSLGFLSPLTAILLGWAILGQALSASQMIGAAVVVASIWLSQRATPSRQVHAR
+>gnl|md5|6803c5e1ab1272ec69688700d3c02e0e
+MKVYLANQPVDFRKGPDSQLSLVRDAGSDPFSFELEILAAHVLGEILKGPRVFADETGLP
+TLAPGTGTVNKAWLWAYARDDSTFGGSGPPMVPYRFEDSRSGECVHRHLGGYGGILQVDG
+YAAYNQLVRKDGGNAGPSLAECWAHSRRRFYELHTAGTVRSPPPRSSGWPISGSSNPRFV
+AKTPTFAPPRGRPSPPPPSPDCSPSGNRPCRASRANRSWPRPSAMPSPGATSSSDS
+>gnl|md5|c63587eb43399c568f1164527fc27358
+PFWATPFALAACTPEAPPPPEPETVSVDPCGAARYSHLIGQTSPTISVPEGQMYRIARED
+RPMTMEMIQDRLTFIVDSRGKLLSVSCS
+>gnl|md5|3f0af0be21624a9da7db4d62141deca1
+MSRHRGAKRCRRYGLLGIISLLSPAYLLSVERWPFHSGPPDHYGRLSSLLDLSVLQSGWL
+LPLHSTSDFRPL
+>gnl|md5|bfd0bd685d4ee94a015cd061816ab82d
+RHIRRDALEASVLNGLKKHLMEPELFREFCAEFTREVNRLRMERGADLEVARRELDKIGR
+QISQIIEAITDGMYHPSMKEKMTKLEARKAEATEKLANADEPPPLLHPNMAALYAQRITE
+LSENLQHEDSRAQAAEILRSLVDQVTLLPEEGELAIVLRGDLGAILRFAAGKKDPDFLSE
+AEALDNLLGQMAVSRKPGRTKAKTSALNATEVSQLSLVAGVGFEPTTFRL
+>gnl|md5|458f535dc6b3a85dbf0b50bf0ffae312
+MMMPTARSMTLPRAMNSLNSLNMGLPFPACCACSGRGCHITLTPCNMRQDMTGNDMTALS
+EFPITRRWPPRRPDVIQLYTLNTPNGIKTSVMLEECGLDYDAHRISIGDPEDQFTPEFLS
+LNPNNKIPAMIDPNGPDGKPMGLFETGAMLVYLGDKTGKFLPASGAARYHTIQWLMWQMG
+GVGPMFGQVGYFHRYKGSEIEDARPRTRYYNEARRLLGVLDRQLEGRDWITGEYSIADMA
+VGPWLRTVRVNYEAEKETGMDGFANVQAYLDRFLARPAVQRGIEVGAE
+>gnl|md5|f53520edd5c9ba7e5bed2fd08cb44ad7
+MPSWRRNWAAATRIRPAVRFWPRSGWTDAAGPMRPDPRPAACAAAPAGAEPRHRCTEEPA
+LTESRKINPWLKAALEFGPLILFFLVFMRFRDQTVSLAGRDYSGFILATLAFVPVLALST
+LALWRLTGRLSPMQVATLVLVVVFGGLSVWLNDPKFFKMKPTIIYLIFAALLGTSLALRR
+NWLELVMSEALPMNAEGWRILTLRMALLFLGLAAANEAVWRLMSETAWVNFKTFGLPAIM
+VAFFIANSRLFERHAQPRDGE
+>gnl|md5|68631421ddc36a3fd81617d12227b1dd
+MILHRPDDDSTARRLEIELRNGPALEAKLVDKIGGAWVELNARHERLVRQEVGARLDAER
+DRKAEVILDLLYEEAAEGRLYTSTQFASNFENRAGLGSQHTIQDRLNVLATKGFIKYQRN
+GALYGLPLVRSRFGYMCVEGMRFGRVEQVDPETGEITGQGLAVLPSHYRCASSGAALEVE
+NPSVWVWPEVVDV
+>gnl|md5|04b3fad17b0d40e02b489a48c451ecc3
+MPVACCRPCGAADGGADLGRSGGEGWLHLFPVLLGAGQARTHEALRRQGRIARRTAGTPR
+PWFIVIITAGLLARRSLPLPAFPMPCGTSGVIRRRLAAYSCGGSAGLAPKGAPASLFAFG
+SDRPERTVMPTYRDDEAISVKMLYWPATLCPREEVSPLTTTGAEDLKQADTVLYMQFFRL
+R
+>gnl|md5|0fab0da718e659ed5fb9c7a5f6a3d18e
+MAEHLPFLAHCSPAPRGLARAWGFGRRPGSNDRGNDTLTHNVLRFASGLWRGQPGRVILY
+TIHYKAFTMTASTTMTIRVSPETKQKLERIAGETRRSKSFLAAEAVSAYVERELEIIDGI
+RRGMADAAAGRVVSHEDAMAEIHAVIDAAEATRAGKA
Added: SwiftApps/Blast/v1/sites.local.xml
--- SwiftApps/Blast/v1/sites.local.xml	                        (rev 0)
+++ SwiftApps/Blast/v1/sites.local.xml	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+   <pool handle="localhost">
+      <execution provider="local" />
+      <profile namespace="karajan" key="jobThrottle">0.01</profile>
+      <profile namespace="karajan" key="initialScore">10000</profile>
+      <filesystem provider="local"/>
+      <workdirectory>swift.work</workdirectory>
+      <profile namespace="swift" key="stagingMethod">local</profile>
+   </pool>
+</config>
Added: SwiftApps/Blast/v1/sites.midway.xml
--- SwiftApps/Blast/v1/sites.midway.xml	                        (rev 0)
+++ SwiftApps/Blast/v1/sites.midway.xml	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,28 @@
+<?xml version="1.0" encoding="utf-8"?>
+  <pool handle="midway">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <profile namespace="globus" key="queue">westmere</profile>
+    <!-- <profile namespace="globus" key="queue">sandyb</profile> -->
+    <!-- <profile namespace="globus" key="queue">amd</profile> -->
+    <profile namespace="globus" key="jobsPerNode">12</profile>
+    <profile namespace="globus" key="maxtime">2400</profile>
+    <profile namespace="globus" key="maxWalltime">00:20:00</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="globus" key="slots">1</profile>
+    <profile namespace="globus" key="maxNodes">8</profile>
+    <profile namespace="globus" key="nodeGranularity">8</profile>
+    <profile namespace="karajan" key="jobThrottle">3.99</profile>
+    <workdirectory>/tmp/maheshwari/swift.work</workdirectory>
+  </pool>
+     <profile namespace="karajan" key="jobThrottle">0.07</profile>
+     <workdirectory>/tmp/swift.work</workdirectory>
+   </pool>
+</config>
Added: SwiftApps/Blast/v1/splitmapper.sh
--- SwiftApps/Blast/v1/splitmapper.sh	                        (rev 0)
+++ SwiftApps/Blast/v1/splitmapper.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,14 @@
+#!/bin/bash
+    case $1 in
+	-n)          n=$2;;
+	    exit 1;;
+    esac
+    shift 2
+done
+do
+    printf "[%d] frag%03d\n" $i $i;
+done
Property changes on: SwiftApps/Blast/v1/splitmapper.sh
Added: SwiftApps/Blast/v1/tc.data
--- SwiftApps/Blast/v1/tc.data	                        (rev 0)
+++ SwiftApps/Blast/v1/tc.data	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,11 @@
+local  cat /bin/cat
+midway blastmerge /home/maheshwari/parallelblast_2.0.9/blastmerge
+midway blastall /home/maheshwari/blast-2.2.26/bin/blastall
+localhost fastasplitn /home/maheshwari/parallelblast_2.0.9/fastasplitn
+localhost formatdb /home/maheshwari/blast-2.2.26/bin/formatdb
Added: SwiftApps/Blast/v2/apps
--- SwiftApps/Blast/v2/apps	                        (rev 0)
+++ SwiftApps/Blast/v2/apps	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,18 @@
+local  cat /bin/cat
+localhost bash bash
+localhost fblastall /root/blast.mw/fblastall.sh
Added: SwiftApps/Blast/v2/blast2.swift
--- SwiftApps/Blast/v2/blast2.swift	                        (rev 0)
+++ SwiftApps/Blast/v2/blast2.swift	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,37 @@
+type file;
+type fasta;
+type query;
+string num_partitions        = arg("n", "10");
+fasta  dbin       <single_file_mapper;file=arg("d", "nr.sub1")>;
+query  query_file <single_file_mapper;file=arg("i", "sequence.seq")>;
+app (file dblist) split_database (fasta d, string n){
+  bash "-c" strcat("/root/parallelblast_2.0.9/fastasplitn ", at d, " ", n, " 2>&1 | grep Opening | sed -e 's/^.* //'") stdout=@dblist;
+app (file o) fblast(fasta d, query i, string p, string e, string f){
+  fblastall @d "-p" p "-i" @i "-d" "fmtdb" "-o" @o "-e" e "-m" "0" "-F" f;
+app (file o) blastmerge(file o_frags[]){
+  blastmerge "-t" @o filenames(o_frags);
+file dbparts<"dbparts">;
+dbparts=split_database(dbin, num_partitions);
+string db[] = readData(dbparts);
+file out[];
+foreach partname,i in db {
+  fasta dbpart<single_file_mapper; file=partname>;
+  out[i]=fblast(dbpart, query_file, program_name, expectation_value, filter_query_sequence);
+file merged <single_file_mapper;file=arg("o", "merged.txt")>;
+merged = blastmerge(out);
Added: SwiftApps/Blast/v2/cf
--- SwiftApps/Blast/v2/cf	                        (rev 0)
+++ SwiftApps/Blast/v2/cf	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,9 @@
+lazy.errors=false
+sitedir.keep=true
Added: SwiftApps/Blast/v2/fblastall.sh
--- SwiftApps/Blast/v2/fblastall.sh	                        (rev 0)
+++ SwiftApps/Blast/v2/fblastall.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,12 @@
+#! /bin/bash
+BLASTALL=/root/blast-2.2.26/bin/blastall
+FORMAT=/root/blast-2.2.26/bin/formatdb
+$FORMAT -i $1 -n $7
+shift
+$BLASTALL $*
+#  fblastall "-p" p "-i" @filename(i) "-d" @filename(d) "-o" @filename(o) "-e" e "-m" "0" "-F" f;
Property changes on: SwiftApps/Blast/v2/fblastall.sh
Added: SwiftApps/Blast/v2/nr.sub1
--- SwiftApps/Blast/v2/nr.sub1	                        (rev 0)
+++ SwiftApps/Blast/v2/nr.sub1	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,9997 @@
+>gnl|md5|68b627edd50f66d146c66d4896b8842b
+MIFCGTLSLVRNSTRLGLAALASYGAAIALIAVMAPSANLLLWIMGAAIPLEAWFVMRSQ
+KALVLSGGIAAAVLAVLLGVSVWMGGNVTLTAFSLLAALAYGATLLVRSAGALVARGQEA
+RRDDRVADLESAVDGVVIGLGRDGMITALSCKAQEHFGVARSLLIGTALVDRVHVSDRVH
+FLAFLSDLRSGTAATAAEIKLRCVAPGDAAKPAHTVRFATYRLSGVPQSRDNGFVIVATD
+ISGVVADRFALDAARTQVETAEVTKGRFLASVSHELRTPLNSIIGFSDVLLQEIVASCPM
+RASANMSSWCISPARTCSPLSMPSSTYXKIEAGTYPIMAEPFAFKDAVTMVHDMMAHQAS
+QKNVTLCDRVSRNIGIVVADQRAIQQVLINLVSNAVKFTESGGVVTIDAGLHGDMLAFSV
+SDTGIGIAEADLLTLGQPFRQVQNDYTRRHEGTGLGLATVKGLIGLHGGQMDIRSRPSEG
+TVGECPHSTRRSADRARSGRTGQYRRIPGPTATVRRFACAKPAIGLTAESAAPPSAATWP
+VSPSGQXG
+>gnl|md5|5bb6f58a792bc43ae33e6258b0a10f17
+MDMDVLRLKREFKNLDIEFIIRVLAVYKSYNLAQNVLKYYKDLENQDDLCNKVLGPLPNG
+LCFTHFQNNIVSSANIDTIIPFHNLYYLKSKISKDSETYNRLFSDIDFDSYILGREGEQE
+GEGEREGEREREEGEGEGGEGDEYEEGEGEEKKEKVRHMENTKLRKSTLGNESTGGQTIS
+PTLTFPPNAIPPNSNPTSLNKSIAKSISKSFSKSSMKSFQNGLKRNLEKKLLKKTGITTS
+GKSSSKKRLTKENINNSNYVYKNVIGQIIPINSQEKLFCLISNNRIVNKTGIPLEICFIN
+ENNIPIQLFDISNISIEKELTNLILNQEVPNHHSKYKNIYDQKHFKESKKLKFNSEYITD
+NQLNYNETNSIPLWLNNTDIINTILNSMSQIYNGENDIQDILFESXPNFTNNNNNNNNNT
+IQRIKQKRFYYSYFLPNNHMMSVPQIALLNDHCKVIFRPCIIGLLEIYNIHCQYNNDNDI
+DQMLFDQEIFLKYSKLMNNYYDEDILNEEFHQITYELLKIFKTSNGEFIMDLYYSFWNHL
+ISRFTNTNNQIMDLSYLQSRGWTHSPIITNKNLNTSQTHFCNLYPDFKNYKKSESHYKEN
+AIYFQSYIQTYQSLFPGNTCIKNILLYPSFSLLNLSPAIMDIKFKSLNQNLLHKCSNVLF
+RFKPMHHYNIYQLSSEMKLQYKVRIMLETNSLSEFQFNSESRKTDQLLYTQWSSPMDLNL
+SDTETPFTLYCNNNSIIDLKCTIIDKTNQNLPGKNKFGSLFGKMQNNIIALSLSTWFINK
+TNHNVVPIFENSPFPYINTKSGAFFLNNSSFQDDGDYNDRDRDRDHDRDHDRDHDHDHDH
+YQGNNKKGKDSEKRILSKRKNKLGDEEKIFLLNNRHNYLKIYFNSYENLKEKYGNIGQRI
+NDEIYLKEEKEILEVINSSEASIYSSGSGNYDNNNNNNNSNIGLLEIPPLNGTYSFPIVN
+EGKVYFFTVKSSPLFYYNDFSCSSKVITISPHIIIQNTTDDQFIWSSFMFPSGNDDLDKI
+NAISRIDPNHLLLPNSDNTETRRYLGPIEKDFITSIKIDNPINSILSNNNNNNIHNNHHL
+QNLRSKSGSNMITVPSSSISGSGIESNNSNNSENNKSMIKDQSILLYLSRYVEYKTNNNP
+KWSQPILISSESNGIFYMHIPKMYENQIQDGIIVNPKTYCIEIIASNGLFILKIIKDFSI
+GNKWDGVIFTNYCDYLSKIYIETYHFEHNFEEIKKKRKLSLLSSGFLSIGNNKVTNNNNN
+NNNNNFLSEMNDDITIRYIISSGQKKPIKISWSSPFVYNSRNCRLYIIPNQETSEFIDQN
+NINNIGCYNNNSGILAFDMNFRYNQNNPYQSKRYILSLPESDIIKLCTMYPYLNPRYFLN
+KNAKKGNGMNNYPIATISITARNNGLYIDILPPRNHSSLLLNLLGNNINDNNSNNNSNNN
+KIINNDDEITKNSFQKEKVYIEDLYQKRIHEINKLVNNDVWSLIYTYYRKITLDISQIGI
+SIISENRQAEIVYVELSTIQFKKQEKNRNGIIESYKFVIGNLQIDNQYISSNSKFYINNS
+SKFYGSPELDNTDLEDGNNSELDNSIIIGSNGVAPYVLLANRSNNEKSIDNMNPFITLKW
+SCSNAKSQWETIIYNFDCELSDLELNFDFNVYRILNEFMEECRKNSNKQYILDIKSILSK
+DQILEGVEPNMTFSIEKIKIGALNLYVWCSIPLSELNYIPEWFRIGLRILTVSNALELRG
+APIKLESHNLENSIGTIQNIVNAFYEYYMAELLWRIGTVLGHSSFVNIPLVPLQVGKNTL
+NMAFSTISMVNSNITSLLSNLTLDTEYINSRQRELLYNNSTISCPNSFGNAPKLLHGTNS
+QQASSLRQGFVQAGHNLTQGILSLGNVITKPIEGAQKSGFTGFCTGLIKGVTSSVVRPID
+HIGQALNNVIDGIQAEVNKPLGGYKERIYRRRIPRMLYSQYSKISDYEIQDALLRDIIGP
+KFARHLNQYFIIPTDHYSMPLILLLFPKNIVLIKLMSSFSISDLNNNCQISLRNNIIGGN
+SVVGVSGGSNGSSIGGNNGMNSNFGISSSNSIGVNGKVSSGGGFSSGFTSTSSFSSSGRN
+NFYKSQIIWLVNINNIREVKASSHGILIELSNEKRDTLQIPICKFPLIKKIIVALDNSQN
+NASPHLIFKK
+>gnl|md5|645b2cbed6feedbff0d1da42734caf07
+MIGRADIEGSKSNVAMNAWLPQASYPCGNFSDTSSCNFHRSKGSIGHAFTVCIRTENQNQ
+VSFSPFGLHEISVLIELTLGHLRYLLTDVPPQPNSPSDYVFREDQQ
+>gnl|md5|6677ceb13e09402422e6bdbd71e92c6f
+MIMKSSFTFLLIILLVLSCAYANQFSNFGSLEKRIQRLEKEHLMHDLKRENLRNTYPIVG
+KLLLMAIEQEKNTIEYPLLGTFQSEGKCVKTKLFFYDLSSKKFVVAKYKCSNQTVNIEGK
+NGEYLLRTKDSKEIKKLRDEKVKFIVKKFSFNYRIRSLNKISNCPSILKSFDSRIIPENF
+DVETDQKYEKGHDLVHRGFYLVKCRKNVKEDSEKDLTYALFKSATLSYAVPIQSGCRCIL
+EGTKLLVCTCDDFNYHFDVEQGILTVGETKLLTANIRGLKVLTSKTNTELLALIDITQEC
+ENEQNGNEIETKL
+>gnl|md5|1a3b0c01d43fa5ff7f4b2c86412b4b49
+MEENSVKFGNIDEEVSEKFVYNYFITGIIIGICKWIIIIAHFFCLNRNGASLLPIVEQSG
+FSFGTLLAHSLNVAIPLYMSLLGSQNYYLTILEKKSYKVRKNSFTYMVIPGIIYFFLSIL
+LNFIGIPKHVSGSQLGMSPSKIFSIFKPGFLSFFLLAYLTMLFFSPFVAISIPSSSSIME
+FKRFMSSTSNSDSNLEKGILIQKHAIPFNNSDMVKLSNIGAYSIIKCVVSSIFVAYLFYF
+LHVSDSCIFKFFMFVSVIILTLSVGSFAFKEYLLETYVLLIIVSIIWSFICLHGNSFFKS
+EIPDLICSTLSVYLTMYTAGHFFSCIGMEVVKSPSYYFLFIPVVALVYYNVNSYYVTISP
+ILYPFYHCHFSFQKSLIISWLSIIPIISLCLNLCVYVKNKTVIWFISSLPDDIIIYILSL
+TPIFELFIGFYIHPIIL
+>gnl|md5|61a174a1e04bc41b803f3debb77e9f8a
+MCSNIYRENNKKNESLKDFLESQLTIQIGISLWIIFFFHCSHIIMYNGVIFPVAIDVNAT
+FSYYTVDLLNIAIPLYLYSHGWELVKIRVMNFQYYLNHHLKYLLPGFVYWLLIFVIKNFD
+KFELSTQSNFSLPNEDWSWSVPYRFGLISIFIYHFLVAMVMYPIICLIKKCYNCYESCEY
+EYGIISNSDLITNVDKGFSENEISKSFVASQNVYINYGSSNSNLPYIISNIIIYFLIINI
+FFYFSYSANLYILYTLFYSSIFLIYSLKFIQKEISISGICIFMNITYISLYKYLTSGIPN
+SAFNNGAVFFNTFFLFLVYYFTGFTMAFTDFLLKIQKYYLDLLFLLPIIYNFLSIPNRTL
+MYSPLIFPISFQEGDQTRVIISTWIGIIFTISIVLRFCRKRSIEYTKLIIKKIPYILIIL
+VTMISFIYERARQIANGL
+>gnl|md5|21d9071f8a341bc0426313891d8b4d31
+MENFNSIPTINYRGNYPGQQNAGEIHFDEEYDSSESEFSFPVVGSTNSANIKTSGKNKAF
+IGRDKEKAKRYYIQSTLEVNIDNQYPVDNIEIYRQKIFPFQLSPNISLVAPEEKNVNKSR
+ISKIWKALSNSEPSIIGILRGKGFVYTLPETIDLLLYVTFCFGFMMAILFFNSSGSVKHS
+IHNMLNQQTFNFQSSLASECLGMPDENGVSSYEQLYSKKFIKYVIEPNKDTFFNSMSGDV
+VFPCGRGTIKDVATIADYLRWIALVLFPSFIYIRNTMNSALTSHIKISTQFNNGTESELT
+YVFDKGLLKGNNIYIYPYDTESALEILDLIVEKNYFNNTEVSSINTRFFTYNPFVGIKTS
+VMITLGNSKITGYYDSSLDVKSLLIHTNSYSYIFMALAIISGFFGFLRFFTHKDVIVSPI
+MTIKSSMNRVFALLSSILIIISVVTYMCIFIPINWLWTEDSSLEYSTLLSLHEDKMEENF
+TEQSSHFEYLATFDIIFRTSGSASLIFTLWEFFWFLSVKISRKHATSITVVVKKVTFPIL
+FGALLVLFFFSSYGIIGLILLGDYTPMYSSAKSILFHMLLFIIGKTDEIWILLNETGIYT
+GIFFVPIICIFGIILPSYVYALFCHIYNSTIDTVEWCWDNCTRENGTNIQSSPWYIEENS
+IYERNIREDNTLSTQKTDESKGINNNESQELNLNVRQNSQMNDLLFVRDRYSNFMAQTTT
+FERLFDIFFSRKKYLTLKQKKEIEMGKFDSYEQTRKIASLHGSNVNNLNNSLPSLTHNNA
+NENSEIIKQQSQNESLEGSEYVTLVTKSIHEYYWSIFNSGKTIFSNPGTVSNYGNNISST
+SQQLMFRMVGTMEASVDMTQFLISKNRDSDYSDSIGLNDQNGLPLLVGNVMAASPCPNME
+NLLTFTEKINRVGESIWFTVLLCFILILLITSSIFEFRKQIYNDLINSISWNQFHTNINV
+NAMKPISAKEELDIKKSTDPSKFILNPVTLNLLTSETSNEVAYWISLASSRLIFNSSSEY
+QYKVLFPDFENDVTYPKILFDQNLLYNDQGEAGVTLRAIAVTENRSVDQYIDGTSSADEL
+FKFIGVTERFFSTFDDDDKKLSEDLNMKFINKAINGYPFFYTKNIVPSEHSSFIESLYSN
+IYELLHYPKIVYLEILLPSLLIEDQMFNFVRIIITRDISGGLNKGPLNILLSTINSEFDS
+YFKISLEVAIILLMIAYIVVFFLECKKFTKIYRNSPESTGRRARSTVFCFFNYIFTDLSR
+AHDIVIIMMIIIRLGVYSSIFYYKMVLFKSKIDTDEFDMVYGLSIQLSYINIAIIWIFIL
+RLFGQFSSISSNFRFLTFSYRRSFLPLFLVFIFLALQFIGLSIMIFINFSSCNDNYSSVF
+GVISSTINLFVGNFDFYEAYKCSSNLTISVLLPLLIAIYYIIMPVHTIIILRSLWLSKKE
+STDIDRIFKIVAESRNKKNSEEYKKYIKHITGMNTQISEREIWDHAGIDYDEDDPIDRKM
+YEQKYEKSVPKVEIPPPKIAELTDEQWDASPDFIKEWAEYEAESFIDRFRCLESEFKMNT
+SSTGYYSQFVSKWESSVYKELQLLEVTTNEAEQLLKRLQRAIKGTASRVRINQALQTNNL
+EAAIREKEEERESKRALLKARKNRNIYDNN
+>gnl|md5|5873cd7539c5d17004c366ab655b21e8
+MNDTIIGAFCVAGIYFFFIFYGIVQERIHTLGDKKVGDNFNYSLFLVFCFCLVNTVVSFG
+VIQLENWRIGPGKEGNSKKNKNSSNAEKIFFNLSFECIFQIMLTSATYLTSMVLTNLALG
+NVNYPTQVLVKSAKCVPIIVIGTLYFKTKYPWYDYLAVIVITISLSCFNLMQIKTNKVGT
+VQTLSGVSLLGLSLLCDGLTGPRQDKLIKKYNVTSNVLMFYTNLFAMILCGILSLFLEGK
+EPYLFISRFPSTPYYILALSLTGTCGQFFIFQSLIRFGSLYLAIITTTRKFFTVLVSVII
+FGHKLSLGQWLCVSAIFVVLGIQTVFSRKNKDKLKTK
+>gnl|md5|a7edab283b7b02d2ff020a6e8e6207ae
+MSINNGKEVSVEDCPESKFLVEENVDLTKSCLWSILERYYKTVSIDAWRKNQVPSFITSN
+NRLASGYARLIHSFIMDQNPIGTPFKKIYIVEIGGGHGRFTFLLLRALERYSPVWEDLGY
+SGVPFKYIFTDATDASFSFLTRESSALISYIQKGWLEFACFNGNNSEPSDIKFGLNKEET
+IPPESSIVLVCNYVLDSLLTDAIAISKDKVISKATVSVYSSQVEEDLTHPSIADRMTLSW
+SWKEMIDEDFLPITTHSENKVCNTNNETKKTQESEYLTEKEQLLLRYSQFDYSLCEVIKS
+YLELDREMSFVLPLGAIQMLRRFYQYSTGNICVLIGDKGYPDDTEFISIKPPHIAVHGCM
+SFMVNLDAIKKYFCNLGCSYLATRYKDTFQIICILGGKKSSFPRVVASFIDSQEDLVPDN
+LLSIQRGFEQLSSNSGSFTNGLKPYLGVLRYSLHDPFILWVLRNGILANIGDLNIRQRED
+IIFDLHSVYRNIYPLEINIDVFDLLAQICLKGGFVNDAIFYYNESLRCCPEMIHPSTYVN
+LAKCYQSQRNWKKAFHFCNEALKLDPDYPPALEFNSEYLNSSKRINYIIIGCYSSWIFTD
+VIPTIQFDAMYNCIGVVPSKKTIENAKKAFDHLQAIFSCNQENEVFSSSPPKFFLEEISE
+NSSFANAIADIFYSNPQIEAIVLDVPPDLFKPCMDVIWEFNKHVMTRSPTARDVVNASEI
+LSRKPPRSLWFDYAPFKFETALLQVFNIIKQHGRLYAINCKYDLPSETPINSEGYKNDEL
+IARLIHSLSAIYIAIDGTLDWVFCPSTDKDHDKKTLFCGWSSPLWSQADSGKRNKIPSEK
+ASIKPTSTKSDEIHCTISTEFVTWDKTFIQFDFHCDNCTLSLRKEGPIWILLIRTSKGRY
+ESKIQCVGLQTANERFRKLCKDYNPDQYNIKDSIGFSAWWDAIEKSKQSPIHFSYQ
+>gnl|md5|0cc9a8c2b9a2dd5780b08ff3968f5e05
+MIQKLIWDSINFTLGDGEKDNSSIGDYEYLEIIGEGTYGVVYKCKCKQSGELFAVKTFRS
+ATSEFSTTTLREISILREINHPNIVSVQDVILSSKGVNIVFEFFPYDLKRYLSMFPDKVP
+PVKFIKHIIFEMLKGIFHLHMHRIIHRDLKPQNILISCDRNLPDVKIADFGLSRILSTPF
+KTLTREVVTLWYRAPELLLGNKNYSSSIDIWSVGCIFIELLIGRPIFSGDSEVSTLFKIF
+KTLGTPNSKVYSNINSLPNYSPDWPKWDIDENWVDNQICMYSPTKQYLLETDAKNLIKM
+>gnl|md5|d7670580a72ac20165d9e1c7fa5a6db4
+MIDNAEVPLQRQIQNQKRIKISVKPHLILKRLFGTQANACNPENLVAPFKGLDGASLIAS
+RFNRASGGIELLQRCDGSQYNEALVELESESYGDVICVPDPPRPSWLCSGLSVYCKPY
+>gnl|md5|8010d4fd2e0dee5c0ac2f12a8740f7cb
+MLINKFFILFSAVLIINIVEYMLCFEKLRITPNVIEDLQNGKITLTEALDRYIVPNDIIV
+AYVKALSEESQKRINVDLNGVTAEVFFVGDTYYIGGIPPKPENELTIYERLRDLSDPGNP
+GRRWCWKFVKHAQVSYFAFNFLEAFIF
+>gnl|md5|83f7264331da821610c6e8dfa773cfde
+MLRKTKTYDYDQFLLNDCLDVGVCEMENNLVLRKKQRINFDNYNESERNKDYMENSGIFS
+VYDFVYPLSKQVCCDSISSNAASLIVQTVEFKLRQIIEEAIKLAFHRGSCSSGDLQENAE
+LPFISLGDINSAMRYICGSKNLIWSLEKPLRSYFISRSQNGNDQLIVEKNAEVFYNLPER
+SIKYIPCFCFPDRNYKIASLKTFKKDTSDDKEIFHDIIKDLDGKKIKKPSIHLHWLAVEG
+KFVFNSENDTTYIKNIYNNMEANSKFVKRKNFDVISNENVDNFKIVINKAIEGFLSEEQR
+EFLSYMNRIFLRGMEELYSSCNLPFNLLDSNIERRALIINNYVNTYGLSDKDTGTISSVF
+SVFEGLNSSNLPHSAYNQYDNCIEKNKFHSKESQQKFELFQKLDYIFHIIETNTDFEPLL
+PYLVYYFNYNTRIICIQFEKTGVFPKIGTLRLLIRICRSIIRNPHCSKTTYYIHKIIESL
+IRIMVSCPVKEALSNINFKVSELFLADNLNARLDASILLENILEQCSNHLPIGTAKILEY
+LSSEFKKILDIRINNLTNGNCLQIASLYGIVCGIRSLGDFSVSSVLFPRLLTLFFHYPED
+QNSKISFIRLHLEISSLINKYMALFQVKFKLPNHCNSTDLIFLYLEKLIENLENILGDGA
+IPILLTSSINPIWNVNQINQAICILDQCIRTHYIDSNIKCQGSKEFLYITDKKCLSNQYL
+NKFVNSYNKDELCSKHDFCIESFDSDFYPLNSILNIFI
+>gnl|md5|62b5dd2317950861b94762aa3e04471a
+MNPKTIILTCEDFLRNFSTHELKVSQANSKYFEQFRNLSSLWDSKNVSDRDSLELSEVWN
+SILHCYKVVLDKTSTEIRVNSEKISKRENIRSNSSEKLLLKFDGQFQSLFSTELTLIKQF
+LMDLLEVIKELTLVCENMKSYLESNVGLTSSSSTNSLSIVLILVKIICHKIETKNRDLLE
+KMCGSTLYCLNILFRIYKLEFTENWDLILFPEKFDISSIEINYLLYNEISIFLSIDSDIP
+FLSYFLLSSNAKMRVNSILCIQSIFTSPIFRFKSMTSLLCKPLSQQIIDTSASSLSKNAV
+ILTLSLLKFGETFFRSENYDSDTVITFIKTISKIVSTTPSLFWTNNFINANTSFIQILSN
+NLLYGLKDLNLFIPSLQLFSNILNLIKNCETSKNILFDDLNPCFEQVLIN
+>gnl|md5|706cf8662fab3b156e7b5cef3ffe92de
+MLKLSFFLALLIIYFCINYSFGASNQSKSDEDHLKNSVLLQATALKNLWALLSLIVNLTE
+CSNIYGIDRMLFCSPSVGYYLEMTQKSLIEKSKQLSDKEREIIVRAKYSPDLKELFDEVN
+AIIDDCLKKRLKTEAAVALKDQLLGLITKIYRQMVYFDFSILLPNHTNEDAFHLFQEFSS
+ASGFTVTKLVLATTSKTLNENNNTPKEDHHRKSRRNRQSSAPKLLNQQELNEANKAADLN
+AHLMLGCCTDGTCGALEGKAKSKVKSKKKGGGRKKLKEVALDTPDLEEKSDEIDHKNLDQ
+DLAQSIEIVNQIVHFLGLIAEIEEKLISRENDFQTIVTKIFEIDSATINRGLKERLAKLP
+VNMKIQSSSIKNLLALKSEYNENIKKMAEPLINRNGENLTVNLPCNKKPKGKCVHCSHCS
+STKLSEDDEIHSVD
+>gnl|md5|1930c2cf95b2d0805978b8ea285d52e7
+MKSQVLYLTVACFVFFFYSKETSAAELPNSSNKPQVVTKLDLQNVEITLLKETYSIFCQL
+MCLIKLLNLFNSLNNLSMARQSQELLLILSKEKNVTEKQSEIREELLKRNIDLLSSIDVD
+AIKKCSDLTRKLSRNICSNSSRFAEFLLELIELIQSIIYLITGYNLETSISEDFSSENVR
+DLLLSLNDYFLGLVLDATQQNENQEQGVNKESNSMDDLLLSLPNQDLYNDESHALSSQLG
+QEQDLYLECSENSNINKERKAPTSDNKLGNNDHVENGASKKSKRKKNRKDKDGNVNSKEN
+ICQTPPCNIQANRQDEDGRFEGASPSNTSGVKTRANITKLEASNADEGSARGKDSTHKKR
+TSKKKHLQSSPHGPQPQVTFVQPAELIALDPRGGAKQKVKTKTDTSKNDNRRNSRRRSRS
+PSPKPCTSSGAQTGSSSRSSSPRPCTSSGVQTGSSFRSHSPRPRVSSRSQAGSSLRSHLQ
+SKGKSRSRRSRSRSRDASPTAPRTGSVTEGDQSKDGELEASEALFLIQEAEETLTEILKL
+EDELLNLSFKLHEKLGEMDQLLFKIIGRGDKFAAIIAQMEIIKVALEDWRKKIDFSSNGK
+YVLMNAKDVLAAIPPSVAARARTCIKSMWF
+>gnl|md5|2ced690af9934a18a2513a3f1225cb34
+MINFSFEVVLFVIENFFFFKNGIAKQSLSKHFEVYDKIQQEMFARSTELLLTEDKAYEIK
+VKVRQFLGFDSLLQTDNSVFSFDGPLNKRIIIKKFFKLIERLKILLLYLKQEIIGKSSSS
+YIYFLLYNTIIYLEETILDLESAIVLFESYDIDYLLAFINKNSKEFLASARKSMVESSTS
+KGLHTSKKMKPGRFKNIESVCATSSVPINENDQEVDLTSKATGSSKTKKSKSMRKQLKME
+LLLSQEEASEKKSAISETIKEQKMDNQKKSKRDKIRNRAEKWQRKREKEEDERRKEREEE
+ARKKKEKEEKVELNRLIRVVTKIEQNFEAVNLEIQMRESLQSLFLNVFNLLSHLTESENT
+RNDREKSSNQIFEGGNLASASLEKNKPSQPPVATQSTTSFVGRSRVNKRRADETHKEPLA
+ASTLDLIMKSRTTNEESDVRSQSFGIDSVETKSLETTQAKSGDKLRSKSKEHSKTHTRSR
+SRNRSTRSRTGSRGRSKSRSKSRRGRSRSGSSGRKGKHNFDYESGYSFERPLTKAEDTEG
+TKNIESKLLKLFSSFESNTSEDFTQTEKSKEQFLFSFFDIKRFDYSKFTLETSTSELETA
+ISEINSELERIHKDVIPLLTGEDYEIVKNFEKFMIKELIKLLIMLNNISEKYK
+>gnl|md5|24f14ba41d82d2e4b419c9c4227b46d1
+MEKKIQLEQEKLDYKKRLEKLKEKSKSKQKKSYPEVKYEIKKVQECDTIILETQKIIRPT
+VRNKAERRRKLMEEINRFNEKSIKKELIREAVNILKLTRKSKKNLSSSERRSKLHSMETN
+NARTKDRNTHNIDMGSDVSSLIFL
+>gnl|md5|238b97092cf84bcc75abd3ad0fe9312f
+MISKLMQLEEKMSYSVDDSSEHKSKFIPMFSKSKVTEEVQSVDIFSFFNIVNLDFLEITE
+ASTIEEIEAAIEFCSEEITRIHTEILPLLTGYDLLQMKNFQKDLISRLIRLLIMFNNKKN
+E
+>gnl|md5|98083bcb4e35a34491e49828be10c0cc
+MVILLEKLSSLEVDSNLRCTAKFLIGVSNDCLRMFSKCILKYYKMTTSQFNSLFASKIEQ
+ISKSTLSVELNDDFGYLVNMGSNFEKIVRSIEAYNKFLETGDPTLSNGEIENAKSIIVNF
+FENGNLDETGIFKKEETALISFEFLGLAAMNLSSLDKTKFLSFKNEVEEACKSATLMINS
+RGTEIRLSQTVVVTIREEIRTLMRYQEFLRLDFTVMNLNNSLLKSQILYFMNFVYELLLR
+AFEIVRKEQSGESGGKYISTIYCKLNPLFEKALDHYKNTILNFEQTQTKSKKTSRGTISR
+DGKKIMRRILSKDRLKPSIYLTKIKSDSAKKTRKIKIRKKNNLDRLKQNVDKQGIEGVNN
+DQPKKKSERQLKAQTLSETSQLLRVARMMKNQQGYLNKNNIADISIAIGTVLEISGEILS
+FDGLISHEEQREIISSANDFSNLVSNLRSIGDMTNTEFSLFADNSNEASDPDNKSIGKKT
+KILEQYSDQNSLMTLEERRPKLEDVVSLGSRKLINSNKKKRKADDTVRPLSQIGPTADLF
+GKDATFATKKESRHTFGKSSKTRQKHTRARTNSSNENLNNSFSLADNKRTLKGASKKIYD
+KSYINHSRRAAKRILSKNQSCFIINKKLIDERTLVMVPPTLFGQEIVQNMISTYNIKILN
+FSHVSVGSSYSFIKQAILFCCDEIGHLFFEIFPFLSGIENMILKQIIMQMIILFKNLVSV
+LI
+>gnl|md5|917fc352004f9b6c8b692016a4d181d5
+MNTHNRSSTTDYSCYYDFSNAHEYYQKFDNTMFMNQNNSQYSGSIYNKGLSAQGPNFLHS
+NKINLSTVKLDVNNNAPALMNTLIEKNKEIKNMEKELKIVNESNIFLNNKIEMLKILAAN
+FGATQEDIEATMSTNDIFCIPKPSINVNYPQTDSSYENLHEKIDDELDDLIVSDKNIINL
+NIDDPVKPFNDEQSNESKNISKSTRIKQQNEDQSEKKVDLSPKNLLKRSSTLLKATKSLT
+NSIQAQKCTNNKYLTGTRFGPSIRQKTMMQANANKRLLLSKAKNI
+>gnl|md5|10877c7edbcb5d332575d3b1c2bbcb1d
+MHYSYNTNGMMQPQMHVMQNHQQFSGMHHQMGGGVCSQQFYHENGIGNNRGYSDNQSYQQ
+GSFQAQQHMPQYSMMQSQQQQHQHHQPMGDRNLGRARAQTRGPFSRTAASRSTTPTPMNR
+TTNLKSREFFQNDEIGMLRRSSEYSEVNKNPSLSQIENSNFNGEYNNYSSHQDIPQTPTI
+GGGRSEHGSKLNIMNPDHIIVQKLNAPLEPTPTHVARMNKMRLMGLLNNNNTPMTQMTPT
+SSGNNNFGMRDFHAISRQSSFPPHYQEKYPPKSTSNSNNTAAAFKDSSPKVLGSYVSRQL
+EEEVTRLRYLVDSQTKRISALEMRNKELENELISARNYQQMYQNLLEKTNLENHDEDENE
+LENNEGQVNNEDYNERDHDEVEDNVVQKQKTMASEIKYVRQSSEKGASMFSNIHQFSAES
+ALRKAGVPPGKPSYVYRPPNNPEMIDLKLAEFHNSRSSLIRWSKVSSTIYLFGTTQVQLR
+ISRGNLLAKPESSEWGNGNFWPIEKFVSVFEPIERAKMPNN
+>gnl|md5|badc89acb963ee7f55bc6f967f7a425a
+MFSTAVKLANLDDYLESSQDCIVSLLSDKDDTKPKIAVMRPAKAQDNKDDKKSGTSDKAT
+VNVADCLACSGCVTSAEAKLLEDQNVSEFMNILKQKRLTVVSISNQSCSSFACHLNCDLI
+TIQRKLSGLFKHIGARFVMNSTISEYISLLETKYEFISRYKAKSDLPMIISHCPGWICYS
+EKSLNSSVLPLLSKVRSAQQLQGILIKTLTLEIYNQLLFLYKFRLSNSYGTNMNIKTTFT
+QNDDFVEQSDIFHVAIMPCHDKKLESTRSSLSLKSSDKNSSCPEVDIVLATSEVGEIIKL
+AGFNSLLDVPEAPLDNLWLNQNFQITKKHNLSLLITENYVSNQILNQFPWLIPSYFNSNS
+GGFCEYIIRSAIKELAGDNIDNKVQLPFNKLKNDILEAKYIKNNVELNYCLVYGFRAIQS
+ISRKLNLQKNASQHTQYKQNVVNHVNYHLIEAMACPTGCVSGGGQILSQNDQNDDNSDLN
+KLRKNIKFIDEVQEALYKGINLNKNQEIILPDEIPIVNILYEYLIHIDKQIDRSSGLKLP
+FLRNDFVSINEVPTASSLKW
+>gnl|md5|8886f9967e75873ced75ac80cf2b432c
+MTLLQVIRKTKMKDKEMRILVLGLDNAGKTTVVRKFAGEDISTIQPTLGFNIKTLLHGKY
+RLNTWDIGGQKTIRSYWRNYFESTDGIIWVVDSTNIERMDSCSEELHRLLSEERLSGASL
+LVFANKQDLSNALKPEEVAHVSFFDKIKLIK
+>gnl|md5|3105541feac9d723f60db29757fe05bd
+MYGFIKFFVGFCIPAYHSILALKTQNHHLIKIWLVYFFTVVFYELILSFILDPVFKVIDP
+RLLHFKTLFVVLYIFPETGFQESYFSFFSNYLSKLFIQVFEY
+>gnl|md5|9bcc6c457f06f203196fda602fec823c
+MKIFLAFTILLFYSLEILFQRFPTRNKTFEHSFLQLKSQNNWAVIVSTSRYWYNYRHNTN
+ALSFYNYLRQNGFRDDRIILMLAENIPCNTRNSIPGGVYSEDFDFFYNLNNHTQTMECAD
+VDYREDEVTVSNFIKVLTNKHDDSVPNKKRLLSDEDSNIFIFLTGHGGDGFLKFQDFEEM
+TSFELANAIKEMKAHKRFKKIFIISETCQASTLHNHLDFEDVYAIGCSSLGESSYSKHYK
+VEIGVASIDRFTHFSLADFKNLNRNKLMPIASLIGKYSVFQLKSTPQLKYKSGKTDIKNV
+YVNEFFFPNIEKLFSLNIGNLILNHKNIKEPIKRVLNEGVSKYLNCSFLYHTLKRYNDLD
+LIDPLSNCHFKNTLKKAIIFSQKRYVFNSKFSSKKMIDNKSLKLIKAIFGLTFILILVFI
+LSYYSL
+>gnl|md5|d048f51ca432939c652e57df5160b508
+MEPIKRVAVTHLECGIGGAEQLMVLASLALQSYKSSNEKIELTLFTSYHDKSHSFSATND
+GRIKVKVYGNWIPRTFFGYGTTLFSYIRIIYTSLIMFFFVIMTSFSLEKTSRYYDVILND
+QVSVINPILKLMTRRLIFYCHFPDQLLVRKRDGSLRKMYRYVMDFLEEFGMRYCDYVFVN
+SIFTRKVYIETFKGLISNANKYPLTLSYPEVLYPPVNLEDIPSEEECENYFSNSKIPQQL
+NRAPNVPFFLSLNRYERKKNIELAIKSFAILRDQYKPGEKLCLVISGGYDKRVSENIEYF
+EELLRLANSYAFNVYIGNECIESTDSCFSVVFLRSISDSLRWSLLRKSIGLLYTPENEHF
+GMVPCEAMSVGTCVIACNSGGPTETIVHGKTGFLCEPNPENFAIRMNELIKISKDSIESS
+VWSSSCKERVTALFSQSIFQKRLCEVAYSNETKSKVFKKIKHL
+>gnl|md5|59370bb4eb497791d552f92839405f6f
+MSTAILGLIEDVYANRSNGTIDNKRKMCLEFSKELLDLDGTDFLKIVTSLISDEEKSNKF
+IFTLAQALILCKGDKCDKRLLLIDRLLTGNRRVIEDVLSPIIAILTWIYLTRAFCTLSSI
+PKCHFDTKDSDHKALRPNYDGIEHILLRICSRNIDLLRSSSCNLCLHEDDLNSSVILGTN
+KLKLFKQTKVEKKHRFVDFIEKFDGDSYSNFPTSHKDQTTLVQICISLIHQLNFNGTITF
+IWIMLGLCSSLSNQELIPIDLSSINFETRDISPNNSKIRINIEDDTLITICKVVGKCLFS
+LSSTKFNSNIKKFIYKKIRITLNKVQRRSICEVMPNSSSFISSYIVLIEKILNS
+>gnl|md5|0149408b98c47f7ae1f5071f66e0ca5b
+MEFLNLGLHKWVQDTCDSLKIQTPTAIQSKSIPYILKGRNVVGNAPTGSGKTLCYCLPML
+QILAEDPFSVFGLVLVPSRELSYQVLDQFQVFGNKVNANCQVLTGGFDESEQIHILNQKR
+PHILIGTPGRLSSIISYPGSNISDLLRNLRFLVLDEADRLLSESLEDDMLPILSILPKSC
+TGRQTLLFSATLTNAIKEIVNNYSTAPKDMKGKKPQELPMIIVNENPDDSPVEKIRQMYL
+FLNHRVRLVYLHYILSNVHFFNIDSVDKAKFEKNSTFFEDSQEDVDENVTFGTKNKKKFI
+KKQEQVIDQNKIIKQGIIFTATKQQCQMLTSCLEIMGYSVTGLHSLMNQRRRLASLGKFR
+SKTSKLLVATGVAARGLDIPDVEFVINYDFPRSFEDYIHRIGRVGRANKTGISLTFVTEQ
+DVPYVYEFESKMKKEMELLKLDEDEVLKNMNRVTVAQQKALLLLEEIGFNEKNQEARERK
+LKVLMSKNKIPSDNKKTIK
+>gnl|md5|39614cd7b6fa34e764d46265725c63db
+MSLLFLTFVLIILKTHCLNSSGNLNEIEFPPSWHFFENHNSLESYKYGFFMETLLHLKKK
+SEKNGEIFSNIMNYNIESKPCEIDEDVFNLFNNPVILVDNRTTFQKDDNTKNVLFCQEKT
+NIGSGKKKRKTIIRTLKLKLENGNVLRLMLNFSKIGLWIWDNNLLLKNHSNIINRCFAVG
+KKDKIKILQKSLHSKIKVSELLIEVPFFKSKLFSQNMYKFIVENKIDGIIGLNDNSIQGV
+GIFETASKAMEPSKGRYIMSFQCSGLGDKNRVNQNEDSLIFAIYNGNGESSKDEKFLSNG
+ESDPIVKVMIDREVKSKFNVKFSINLNIYGAIIPEIRLLQLYTILNKYAVQKGFSCETQE
+TILGKTILCDCNFLNNKLSIKLYNNANSYSIDLSNFVINNGNDQKSCGIEIYGRKRNGIK
+FEENWVFGQILCSASNISRFSKTNSSSWSIGNPKFFINQA
+>gnl|md5|74bde4523e2ab0728b8b7a0feb14365b
+MGRKKRKVAEIKPFCYYCNREFGDEKVLKQHQKVRHLKCLHCSRKLSTVSGLIVHMLQVS
+WNFKSSKIYS
+>gnl|md5|f768ebda20a4849abfe9ee1173ab5865
+MYGGPEFIFGAMLPFPNQKPIPGVMVQRENENLGKTSKNYELIMVLEDSDTSPEELYASK
+LFSYRIIRKHAPINISLIKK
+>gnl|md5|656cb382b773c1f67acfd4c147a1072d
+MRRALRTILNVYGFILSAFIALPVLVWGMFVTLISKYSDFNLGCLSDDISPEYFKDKVVW
+ITGASSGIGKALALRLAKLSKESNITLSLILTSRDSKRLNQVKNDLVEEFKFPENDILVL
+EFDLGDLDAIDSKVDEARNWKGKIDILYNNAGIGQRAIIGSFESDEKVMMINSLGSMKIS
+KQVLSKCFIPQKSGHLINTLSIQSYVVLPGRCAYGASKRACLSFFQALRKELNYINWDEY
+LEYNYSSDKEENISPAIHLGNPNVVITNIYPGHIQTEFDSRNVLHDGSLNVGAHKLKGMA
+SEKCSDLMVKATSNLLNEAWIAQGHELLFFYLTYYSPSVAEAIQSFLDKGFTDKIWELQK
+SHLKKSS
+>gnl|md5|a18ed2420f1bd848d3aee8118b287252
+MEQIKVTVKWNLKTFEDVDLVLSSPLSEFRERLSNLTGVPASKQKLMSQRGVLRDGMDLN
+KLGLKPGSKIVLVGTAEGGELKAPSEKTIFFEDLTSDERAKILHEKEIVPLPVGLENLGN
+TCYLNSIIHMLRSIPSFLQILRNSNLSSSERTSSSSGNSIKFLNSFKQLMDKMDGSIERV
+VPGECVDLFRRQFPQYSTTTGGAFAMYQQQDAEEVLGSLLTLFRNELDGKDGDDQTIGDL
+FRFRMKTKFKNTALETDEEVKMEENYKLMCHMGTQLNPVDFLTQGIKLSLDEKVEKKSSE
+TGIDSIYQKTSEIDSLPPYLLVQLVRFEWKKSSEIARTEATRAKVCRKIEFSQNLDLYEF
+CSEDLKKILNIGRDISEKKKSKAIEKPDQEEQKMETELYTDCPTGVYELECVVTHQGRTA
+DSGHYVAWRYCPNDREYIIKFDDDKVSRIKAKDADLSGGRSDYHIAVMLLYKKTVIKASE
+EEMATLLS
+>gnl|md5|d6d63871b7a08a7102a3653e14e405c8
+MPNSPKKSLKKVIKEEKGEKNQSRNLKQAKLEVFSSNIKTELKVRDDVCHTYEGHKELAE
+KYRKFVGAHVSASGGVDKSVNNSMNIAGMAFSMFLKPSRGWNAPPLKQQTIDLFKKNCET
+NKIEYCKFCIPHGSYLINLGNPDEEKRSKMYVAFEDELKRCDALGIRLYNFHPGSTVGQC
+SKEESIQFISDCINKAHEQTKSVITVLENCAESKCVGYRFKELSEIIERVKDKSRVGVCL
+DTCHLFAAGYDVRTAESFNKVMVEFEAVIGLKYLKAMHLNDSKGQFNSGLDRHENLGKGN
+IGMECFKFIMNDSRFNDIPLILETPDPNNDDKVYKKEIAILYDMLVENK
+>gnl|md5|4831512f0c59a1ea3dd03b629ddafea7
+MNRIRRKISRYVHRKPKGFRTEEILERNTDITQEIDVNKHISLLENIEIETNTGERRSKS
+LSSSNLLEEVHIVSNEAETTTVIEEVDNLISSSSIIESSNSNTLIKKNKVMKTNSEESFV
+SIKESEDDLSVERLNTTKTCVENEDIEKEETYNITRRRNLPVPKTSAKFSLLSMMRQVFG
+KDLSRISMPICLNEPLSFIQRLSEDLEYHDLLKKASNSKSIDERVAYITVFASSAISSTF
+LRLSKPFNPLLGETFELTHRGFKFIAEQVMHHPPVAAYHAESDDGSWVYWGTVWSTMSFG
+PNSLSILPQGTVHLKIRTADGEEEYSWERPNCIIHNIIFGSTWLEWLGDVNVTSKNHGYR
+GKTSFFSDSNNSYSWNKYNSSLENSKRGKRRNIVTGSVYNEDNQRLFCIEGQSDQEIQIS
+STKSQNDSFHPYSKSNVVWRCNPHPNNGDNSHNFFLTYMALELNEISDDYNPEKGANIPI
+TDSRFRPDQRLYESGDVDGAQIIKGLLEEKQRKREKSGNSAVPRWFTKGKRLSSSVLNAK
+NSSVSKDVVEYEWDFTHEYWNYKDSQDFSNLNDIIDIFNIDK
+>gnl|md5|3abd5ea41064981eb92f1305e005d4c0
+MNVDGENQVPKSEEVQMTNGDSSANNTSLTQIEKKRAPNRLLVDDAINDDNSVVCLSPAK
+MEELKLFRGDTILLKGKKRRDTICIVLVDPDLEEGKIRMNKVVRKNLRVKLGDTVSVLEC
+GDVPYGKRIHVLPFDDCLEGITGNLFETYLKPYFLEAYRPVKKGDAFLVRGGFRPIEFKV
+VGVDPEEYCIVAPDTVIHCEGDPIKREDEEKMDDIGYDDIGGCRKQMAQIREMIELPLRH
+PGLFKALGVKPPRGVLLYGPPGSGKTLIAKAVANETGAFFFLINGPEVMSKMAGEAEGNL
+RRAFEEAEKNSPAIIFIDEIDSIAPKREKTNGEVERRVVSQLLTLMDGLKGRGQVVVIAA
+TNRPNSIDPALRRFGRFDREIDIGVPDDNGRLEIIRIHTRNMKLAKDVKIDDIAANTHGF
+VGADLAQLCTEAALCCIREKMDVIDMEDETIDAVILDSMAVSQDHFNSALGVCNPSSLRE
+TVVEVPNIKWDDIGGLEEVKRNLQEMILYPIEHPEKFERFGMSPSRGVLFYGPPGCGKTL
+LAKAVASECSANFISVKGPELLTLWFGESEANVREVFDKARAAAPCVLFFDELDSIGTQR
+GSSMGDAGGAGDRVMNQLLTEIDGVGVKKNLFFIGATNRPEILDEALLRPGRLDQLIYIP
+LPDLPARVSVLQAILRKSPLSKNVPISFIAQKTEGFSGADLAELCQRAAKAAIRDAIAAE
+ELKKASGDDSAMKIEDEVDSHIYEIGRKHFEEAFAGARRSVSITDLAKYDQFRMKFDPVY
+VTQSGGEGFTIDWPDSTHAQYSAPIDDDADDLYS
+>gnl|md5|bde8cfb2bfadc64edb9d25f35297983f
+MSTKENVIVYWEKQGNDRMCALHCLNSILQGPYFDEAFLSKIAYEIDDMERRLLEKSNST
+FKTISDNNSQNASYDGFFSIMVLQECLQRHGYSCIPAANPRVQDYILYPSSCCGYIINSS
+EHWTSIRCVKGKWFNLDSLKAAPIHIDYFEVSKYLQEIMFSGKSVFVVQKIQNETDSHSI
+PLPDPDPFLRPIKNNGKQRFYLTASEIENLVLEKQKEENRVSQMGDETPNKNFMYSKKPV
+EYSWPTSGGNVLQSTLNNVDQSNEMTSEEKELQKVLRESAIEFAKSIPLPDEPPADHVNS
+IQIRVRSKVGSSFVRRFDKTNSCKHLFSWIEYEMALLGNSIHGSPYSFVSQFPYLKVSKF
+DENSIKISRSDISEMILNSPTFNDIGINENTLLLLNL
+>gnl|md5|4ab0dbb18a01aa27b9f9c1b4331f6bd8
+MDNLWSNPNVNNKHCQLLFIECELWRLHPAEKYQVPIVNGNVGSNQQSLCFEPSFLDASS
+LFNISNVSHFEDSKYLVEVTLLSVNSSDDLENSTGYTALISSEFLSPQTLSYSRDCIDVK
+GFSERIEKQGILDMERIHRLMSYFLSCCQNKDCNCNLNNLNNKSCIITWDPVKTKLLLNL
+DLFNNNLASSNSTISVNHSCPNNIWNKLNSIIGLGGLIKSFLPEFWPAYEPSSSLELFSI
+LKNIAFSFNISIEDLFVSPFNSDNITSIRDLSLICKCMARIYLILLKKGIINAHQERVNV
+SEYKDSPHLENSLVRPVVRLRGLPWKAAVLDIIA
+>gnl|md5|e0ca3f40f8e0acfe755c7b61f84a2f24
+MKKQRKPSDIISFLTIIFLIFIYKVFGYVERPERKLQYSREQISTIPDDYLELGIPDMDY
+GVENQDLRRILYSLNRGSLRSFPTLNEAMIILDNLASQFGPNFMRKHKIGTSFEGRPIDA
+YRVGFFSKMDGSYSEDSYFYINQGKKPAFLLTSMHHSREPAGLTTGIYFITKLMEDAIYK
+QDPASNFLLSNIDIWYVPFVNPDGYAAIERTRNYGIRKNQRKTCNSGRSDEDGVDINRNY
+DFNFKNSLVSKCDPQEYSGEYPFSEPETRAIRDLVNNVKSFVTAVNLHTFGDLWTIPWNC
+CKNKDLNENIASIYNELKYEILISSPSCIIRTLMHMKGPFFVNSAKKGFDSTFFTKSRNE
+FENASNYCFSSAARNPTMDYEASGEADDYLLAVHNIISLSPEIGSEYFGFYPPQSEIFPI
+AKKYYPQILAVASKSTIELSISASLHLQMHSEVNHGKLEFSMFNSGLSSICSNITYETHK
+NDSKGTSECHTIFTWELLSSNCKQDSKFDPGKTKFGEYSAGFRYRTSNFKELNSTVS
+>gnl|md5|8ef882386458bcc2151252d13a2a214e
+MNKFTNLLIKRTASSLKGGDFRELFRKNYIPITQFEKVLLSVTSCVEGLKNPTDSNSVAC
+ITELTSNRALRKLQILMNSTPDGRRIIKNRPLIDSSKYSIKDLMAFPDDSLGRRYGEFLT
+TYNLEIDRAPVRYVNSEDLAYVLTRFRQVSLNDYK
+>gnl|md5|c9503f92696364f7dbe5b13359ac4a36
+MYKTKNNMNSGYADPRSLVLTLQELSTDYHKEIAEMNNILFQAKERYQLTLNENNEKIQR
+AQDKMSDENVQIQKEFEELRKMYEKNLPSLNEEKIMIQSQYYKEKSKFDCDFQTKVNEAT
+NKLSEINVKLMTTSKEAVQEIEDLKAQLEREIAELNSEYRSNLSNIDVSYKKELNAVNQH
+IQDLTNYVNETTIKLNQRREQSSKDYHLSVERLTQDNNAAGEEYNATCISISQNIRMRTQ
+NYENSASGIRNAIEGAINNQKRQVVHSPFA
+>gnl|md5|ff11d3abdadf2f82a0b920c5d6fe2048
+MFWYNTRFYGVFLLTIFNILLILKASENGKVCEPREEKSKVELSRQNSFSNQGNQKNNQL
+NEEFNVISKDNDAYLLLFKMMDHDKQKMLLLFSKDNNSGDLLSNKNKDNESGIIIKKYSL
+KTWSKLDINKLKELSVLGKNKQNNQGIWKRKLGNIQNKRLRELEYKTLNIDNNILRIDYT
+NRLLLEGVPFLNLLPNVENEYATSNELTLYKEKSLIKMSDGVLGLNFDNDLNKLHSSYPD
+DKIKGLIRYFKFNKGSYGEVWRGLAFTEYLSEPFGNCGTEKPVENDHLYWRRGELLNHEL
+NSLILDALDILKKDFNKAKMAPSAPRNSSNQEKDGDVLDIVMKKMSHNLEESTIIYSVVR
+EVFFGIILYCLPNVSRFLHIFEENIEDHETFKDSNAKSNIWLVYRYEGVSLGNLLFDIDD
+NGSLIPSEFWWKKVKGVKGKSKEKNIFKEILYQIFQGLNSAHSLGIIHRDIKPSNIFISQ
+VKDEFGQESIYVRVGDWGSAMVSGDEDMRQEIFSVNSYKDIQEALYGKIGPTSGDETEGF
+QPPEVQFKSFGSENEENPRKLSYDVWSVGIVMLQMIWGNLQVFSVLDEDSEFQHILKRVI
+FHVKQLINEDRNTNINQDELVADSVYRLSLMRLCLLDISEGKLGYSNKLDRFISIIIEKA
+IQKSMKNSQQDVIGITRKCSDEYFSNLIRKYDPSEVGLDSPEALDLIKKLLKPKYKERIS
+IKEVVTHPYFS
+>gnl|md5|6795f44d76720cca82fb34905cea3e2a
+MCFEQEMWHPNVYPDGNVCISILHPPGHDRYNEQESPDERWRPIFGVESILVSVISMLGE
+PNLDSPANIDAALEFKNNINEYKKKVRAIVRQSVE
+>gnl|md5|62cc64e95635e8846840944ed8817897
+MHTFPSGYTLGCHISCSKHIFGGLFGKSSGNVNNALNIPPSYKVSGGPSKHTRHLRKFES
+SSKPTEKPEVSSLISSEYTKNYGNLIIFINY
+>gnl|md5|a1978538e5f7556ab2827ae96acafa5f
+MQFGEYIKCNLNLYRLRNGVQLSTTATANFTRNELAELLRSDPHNVNILIGGYTKEEGAK
+LYWMDELASLGNVNNAAHGYGKF
+>gnl|md5|165a15ac6ef87294695e9d468ea9922a
+MNKRGSKGRSERNEVKSINKLLNNLEIQSSKSSESSFSRHSNSTIVSNSPSLYDQDLNSL
+NKTINNLKNSRKQVSFEMDLKKLEKKRSSKISKRFSNLLGKRPSKTYSDVQFSKKLSEPK
+INYPNNNNKADDYNNNAKNDIILLEDGIFTINQDEVKQVQEFNIPITLLKSESSETLNSN
+FSLDQRVARTYDMQIITYDQTPIPIPNLPRGRRLQSLENLENCYLVISPNISNMLSLCYC
+K
+>gnl|md5|1baba2bef08ff36df10b783c0bdb704d
+MIEEKELEKRMSSGSYSEFEPSSNEGFFQDETESNKSKMIWSEIGHIVHSNRKPQYSLSS
+ILRRTNLFDEQELNQYEEPLMDNENNVDITLREIGEPGKLDDYYMARKSKTLELLQVTDI
+IKNVHKEEVKIYLDEIAVLRSQILQMSKNKMNEIAEHDIMEEKESLREVEERINIKEEEV
+KFEEKGINTNTNIELNLQVLDSIQILLSKTNNELVGSLVHKIELFPEVLPDTTMQSADYE
+QLLIEKNNYIQRLEDLNIEIQRQLDLRNEQFSSVSLELVKQKSLFAKESENLKKSQQTVI
+EMENQMKQLLEKVSENENYHLEQQELFNTNNSILNEVVQKLEFEKKSLNDFLQDLLNFIG
+YHIESESILESNFSDLLENYSKDSLIWESYPNLIEFIIIIDKVFQPLKELLWNKKNTFLM
+DSETQTNPQNKTKPKLNVERISNIFIQSISNLQNQNYYEDIPITSNYILENVHKKDFLNK
+TNNERNIDFVSSVSATRLRNEINILKNQLDASKQKLKLKDLENKKLSEEISYLKNKIIRN
+KTYNTSLSNQNFDHSYNENYKLINNLKLNKLSRSKNYYSTLNHNNYSDE
+>gnl|md5|b0f83fcccf761fd4ccc90d5bbf218bda
+MRYLFLAIFYLFTLYTSLIYPVSYGSNYYQTISEVSLVKLKTLPRNSQDPKNKTGEGGNS
+KSATARVGSRPSTVGSSTTSGSGTKPKATIPRPSGQSTSSSSRIVSGAVQGPSKRNTQPK
+QNESGTTEAPSTGSPTPKEEQSEVQSPCGGSSQEGIPSPRLTSNSEAGVPESKSPTSSPN
+PTTKSPPNPTTKSPPNPTTKSPPKPAPKPTTKPAPKPTLPGVTTKPSSTARPSKPLGPAA
+GVRPLGSGVAPKPSGPSRSSKPLGPGAGVKPLGSGVTSKPSGPSRSSKPLGPGAGVKPLG
+SGVTPKPPASSRLSRPLGAGAAIGSPTKGATTASRVSATGLTKPTPSGLSRAFLSGSSKP
+SAGGGLTKRSGSGTTKSSTGLGAGPKSSPLTRASQPKTKSGATRARSKSRSRSRSRDRFS
+GGRRSLESTEPGCSGETGDKGGSGEGRSSGGSSGGASGGASGGTSGGASGGGEGGSGESG
+AYGGSGSGSGDDKGDKGNQPGRGRYGMSIDSSGSDSDSDSDSDSDSNSDGEIRDAVSSAA
+IPSVTLFCRDLINSVTNPGKTTLSFEQNKASSLRYIEGYINNWVKILKMLEKRLEVLLKR
+FVALGCENPEARKNPKLNKLCQKLEEKIRDVETSIYLAKRKIHKLKKCLKKIARIEEEEE
+EAHTSKKHRRARRSQSDLETGHKDSQQEAGSSSDEDSSQREKCPKRRSKRGRSRTGVTSL
+DESTLGAVGGQSLDSSTLESKSSGSTSSLDSTSSSLLGNSESSARPDPDKVPVYNGKVIT
+PTPTLISEEIDSSRRHCKGILSSIGIVPEEELIQILEQFGVTVSALKSLLSSNLEKLSQT
+QERLLELSQKTGDGTNSGREVKRFEVRASSLKLKSEIYEGKLSVLEECLLEILERIIELN
+LEYALPQVKLMACRLHPELEQTDEETNQGDGDDGEDDDEDDEDNGDDDGTQYDSELLKEL
+TDGGDS
+>gnl|md5|b52aebb1feb128e8ce77438142050d29
+MFNLIIKFQIITNKNTNFSLIIKYLPTRIDHNQIILFELFKQVYEDILCLISCIPNNIVK
+ETEINKLSELNFKIMIQKNIEKDSKILKVFNYSSISYDPKSSICQSTRYSPYQYKDIIFK
+MNSLTLSSSSHETISLFMENQLTCVKIVSLKLKQKYHTLTSVSLF
+>gnl|md5|100ccb9c3955f99d6351dfe65f6de463
+MSEFVLVGSSLFEEKLMEFFNEGVRCKKINKMNALIMKIQKHEFDLSGKFQESDSNGKEL
+LVPKCEIEQKIEIPLDQILVTERNSFGVVSTGELFENICQFLRSDDKIRDYKDDFRIILI
+NGAYFSKYLR
+>gnl|md5|213d2ddfb41a6f7e704dba61d30b3654
+MSISSFRIKRRKKSEDDDDEKKDSSSYEELLEVIAPINKFKSKPALGVTTFSRQMWCEKS
+LEICLENNIKITSKAIEEGIKHHEELELEDHQVLSVMVENEYEKMSIEILSIVNLLDGLI
+ERGYIRELPIIGFYKGIMLRGIIDSLQLKPKLNGIGETNNVKYSSNNINKFIILISDTKT
+RRNTTLPSNVQQKTTVLQLGLYRKILGEMVNFGKIWKSCHPNLIDSNAIKKYLNSSSTID
+LSNCCSGCSFLNSIFEFHGLDPLISFSIFQELEDAKRKQSCKEKNDICDTNQDQIQTETH
+SETESVVDTDGKSVLKEFENAVEIGFNMLLSFSKLPDIQSEMKVEYDCQGKTFATKWYKS
+SEQTIELELDYLLGWWLGAREAEFVRMSEAWKCKFCNVIEYCQVCPLSKEEKEKCIEKIR
+QDELESLLIKDLEESSNEHILTLNCS
+>gnl|md5|403734af008381e72a2b8471c34ca759
+MPSSSALSTKCCKIIDEYETKLNKELGNACREGAVGAPELKKYNNLRKGSLLGTNLVNSV
+IASESPFRRDSSLLWLSYDPSNERQNEINKMIKNEDGIAIPDMCDKYVLVDTYTSILASN
+RQQACYISLLSPLPQDTVVGIKFGDHLCQGRINDTMIEYISPSLPVGRQYARLYLNSVKM
+GVKFGNGNTMSEARSYLPFDVIVQEPKSRRLNIKKHKTSIPVGVMGPAPLPEVDIEDEVE
+ELLIMHKPRGNASIISRRHALDKYFKGTHSKVVNAPRRETGDLNNLDPSFKAAVNRDFLR
+RLSNITLEPDCRRTINLLNEFISKLDPGATNNLIPFNVKLEYWKRVLSDGCQEIVDNYHS
+YITQESSNEKSVYIFTKTSPDSLEPYNVFMFSCIMDEENNNCLPLLRRFTCSPENCGDVR
+LWICIGDCYLAKNEVANNYRKIDLPCPIPPIMKSKKSAHIWSRAKNKSYTNSTFSSRKFG
+IGNFVSTRGVGGGLLGAAGVGAGGIGAGIGADEDLNAENENSSEKERCIQISNDVFLFFE
+MWPSKLLPNAGNTTESYSFVLCIKNHQYHSITGISKPVLNFILEKWLTKVPINS
+>gnl|md5|fee4d1d06555a4e79dd146ba4cec57ed
+MITCDPNSLFFGFLGIAGCLIFANLGAAYGIAKSGVGISSMAVMRPDLIMRSIIPAVMAG
+ILGIYGLIGSLVIFFQMGEPNLYSAYTAYAQMSAGLVIGLSSLAAGLAIGIVGDAGVRAA
+AQQPRLLTGMILILVFGEALAIYGVIIGIIMGTTKPTGQLCASYI
+>gnl|md5|a4ead6c3439348870f4e554f4a7d0a15
+MAPPFCTPTATLFGMLGSTLATALSNFGAAYGTAKAGLAIASCGVMRPDLVMRSIIPAVM
+AGILGVYGLIVGVIICSQIRTDYSLYQGYCHLAAGLISGFSCAASGFTIGVAGDAGIRGT
+AQQSKLFVASMLILIFGEALAIYGIIVSLVLISSPSANNLCVLIK
+>gnl|md5|a02ea1700f1a0f5ea559a803722f1f2d
+MIKNCPNFKSKFQKSNCEVFSKEFKNIIISRNTLIISIITSDLTSLYLVPYINLQSEREM
+SENSSVCIQLPKIEFYLKKYNNSHVENQEINNFLSQIELSSLFLKEGILIWILSKEIFAP
+VSNRELQCRLSSILNSKNQKYSLKSTLVSISKLNINTQRNTYNNFNIKLDLDGLDKKSII
+ERCFGNDFNNGDNTQNMVIPLTLNLDSEKLIQLSTILESFLDESNFDSISIYYCEDCNKF
+KPTKSESLLRSQKVLNLDQKSLSHEKNNNQPELNFKLKISLNHINLRYEIFSLIINHVLL
+DLRYFNSKIGNLKLGIKETQLIAEYFPYKLSQFSKSSQSFKILRGSSIQISSNFSVITKM
+LEIARIGSIFFDINNNDSILLVLRAPQFSLSTLTIIYLEVLIKIINILKSKSKRVSFTNE
+KSSLSPIP
+>gnl|md5|ea036c710567bf55861ca591247f998d
+MIQEYRRICLYTESNISIPLEYGQIIDYMILGEFGYGIKSDHISLSRSFKQIITRIPRVD
+CSIGIHDRNKKFEFVLKIFPVSIDVFLSNRLIWDLFGECTLENLFDINKEDHPSISPEIS
+NYYCCRSEESFQWDDHNCQAHPHSQNDFSRIISDIPHVTKSNENFEAVTENFLSSSLSSS
+PPLALIEEFQSDRKRSLYDSTQEILKTTPIFVSIRIHTEKPSTQLKMYSKLLSVSIDSSR
+VQSINEILNSFELRNINTNKNNQSYQVSNNISNHPSTLTSSNNTTINNHPMSVLSNTMNS
+VAGGNLPPPIYYSHNLNPTNSIVSSGDQAQNLSSHILQQGYNFNAYPIAKTPSVLSFSNY
+FYDQKQEKGQRTNLMNLLNLNNKTKNANPKSNSLDLNTNRLLLNCDLNDKNVMNMLKFEI
+DKFLADNPLFYTVVDNIQCQAGGDNNHLNQYKLQIECIVDQLNVDIFINNKRFSNFQSKD
+INFVMFSNNNPSNSTIIEFDTSFIHLSANKDFVQSNGNSSVIPGTSGVGSGVVSGNNSNY
+NNQINCNISNSNLNPNPNNIFNANGNSIGNGNVNSNIIGEGGTGLNHNNSGLNVSSVSTI
+ENSINATSQEEISIIHPMYIDGHTSQGHGHVLSIRINMRQVRLLEVYNIRILESVVIRVH
+PIRVNITQYLTSCYYDIFFPPPITNQPSMSSIQIGSNTQNFLQMSNVDSEAVSSKIKEDN
+AIYAENSYIINSNTNSDITIPTIEQENFSLTFNNQQPQNNNTSVDTQNCSSKNILYFNYL
+RISSILVEVTYRGSVSLNNVLLELSSFTQRRKHRTVKEMVDKYISFLRRQAARPVISYTF
+KQLRHSLLPKHFKSHKRNSTYNSHYDIIQANIQNSHHNNGNERSLKIDSSYQDLLSETTN
+NGNHSNYNNNINSILSKNDDELPNTYRKIQNTNCSKNDSEYNKFRLIFGNQLLI
+>gnl|md5|a1c858c0363a46c0304618d277bb5616
+MIFRGNIRSICRNKQIRDHVRTNNMALFALNCRNYPVKVYNFDGELITTVYMKNQFEEID
+EIYSLEFIYSEESSIILGGGKNCVHVYDYNSGKTLEYIVSLISILIFLIKIKLNIRRISI
+PKNVK
+>gnl|md5|6a22e1b568dbfce8040e24b28ef6f245
+MDYHLISGHRNSDYLYIWDVRKPNNILFKLDRENFGSNQRYNINFKYFEDELILTYGDSR
+GNLNIQKLKFNYDYNKFLQNVRQRQKIKLKSQSIPCIERFFDQKLLVTLSGERFTSCEKD
+QGCTFKVWKINTNTLS
+>gnl|md5|8a9eb0ad1b2f514554a7e0d72e7f6d4a
+MWLQILFFIVSCFLLGIIVYYSFKDVEILNSQDEALCDAFISSGRLTFPKKDLKHYFQLR
+DEVAPQNVGLEEFRLRLRASSPELVSEMKKALLRAAMAVQDNYSRISSEYMGNMQLYKKL
+LLSEKQWLYVENSMEELKETVEYIRDEANLIQDSWGDYIFLDARKLNAIRKQQEEMRLQK
+ERLAKEKELEEKKAKEKEKTESNLANKIAQELLEQEESLSNNDSKNNSGIKKRR
+>gnl|md5|a495e3366392152885e8a861e1c1762d
+MRLVHIPSKNGIDEAYVVFEKDKNKKFTDFEKVREEIDRLTDEVAGKNKGIVDDPIILTI
+YGTQCPDLTLIDLPGITRVPLKGSDQCDNIEQLTRDMAIRYARDPRTIILAVIPANADMS
+TSDALQLSRRVDPKGLRTIGVVTKIDLMDRGTDASKMLHGDEVPLRLGYTGVKNRSSADL
+KAGKSIKDALEDEATFFSTHPVYRNLSPELVGTKNLVSKLTKVLFKHIRTFLPDIRREIN
+ARIRTLSSRLDEFGQSVPLESSDRTQLMWAMITDYCEMIKNTIRGKYDKRLQTYFDHGSD
+GGMSSGAQIRVIFNELLDEYTENDVTSELTDYDIDAAIRMHEGDSMPGFPSPDMFEYLIL
+PHLRKIQAPVMECLDKVTSALENVSQKVAHKVFSRFPKLSDQILDRSQEILLQEKENTKT
+ILEQLVEAETGYLFTNDSKYLTEHGSVINNNSQGNPNDPNAAGARAGQMGANGMQDPNMM
+QVGPDGQPIQKEQTKTSQIFSQVQQTVGSMTNSLSANLWSQDPFSQNKDNNKRKTRYSQV
+FLKEIRKRLDSYFSIVVRNIRDSVPKIIGHFLVRQIMDKLQFQLYNEFNKAERLSDLLNE
+PNHIVEERKALVNQLNTLKKASTILQRDPNIAALTNNDFDEQYDSDLQQMQNNFNQKMQL
+SGGGQPGAGNMRQQQMQHSQSQNNFRNNQQSMPNQQLLSSGSGSGGAGGNIGGGSSQMQN
+PNMNNPSSAKAALFSSVPGQKQAQRDPLFANF
+>gnl|md5|cf705657ec6c8045cb1ca5b2e7da9fb4
+MGRLLLTSTAVTLFLFSSLCTGIGLKSPSTSSGSNEPLTTVFDTKRNVEIVHSGNVKYNI
+EMGYNGSILGGGELVVGNNLLIGLAEPEAHNLRDGSKTDLRILESNRDEVQVGLFLGSPC
+IYENGNSGILGPGSTHMTITNILACTKLFKNQSIKHDDIRFLFWKMRDYSLQNPEMNLID
+LDDIVIDSNTYLSIMFRGLLHVSALFKYSKKYKNSSSTLLSSLDTFLRSGYVAEIKPVYS
+DSELKLELNLNVGASLTGSVGTLVKENVPFAIASITKEGKTHMENIVSPCDGSIVWLSER
+WLQYGKSSGLNTSQTNSGYYGNKDYMEEIMVVIKCNSTPSYLVPRPGLNKRHPNDILVSD
+RFGQVSDWLLKEHIKNSLNLIKVNSKNIPSNLRSEMIFEIKATKTLDELRNTLIGHMRSF
+GLELDLLPNLSLPKPNEGEDKERPKEVVLREENDLLERLNDSKLLLRSNMAPKTKMSNFE
+RRVRSGSVPGNTYIYNMEKQHLENYEENQIPVPKWEGLAIAGWNNMKSDEKRIKLKAASY
+TGKAIQIFGPRPWNMDFLSMDVVRMVSMYRYGNIRYLLSREFLYLFGKFGELEDYNIYTS
+SLMKYSVEMFVIAGMFVSGEEGAETLLGTVTIEFTAELKHRDPIKINIFSMHTGIVKQVI
+ATPKVACSLDPLVIISSVENEIHNAEKYFEINSDKLDGSYIFSKVPGQRDYLTYPLSQNQ
+KLLDGGNVQAKTDAMLDALNRHTYLFPSQSPTDIPSHSGPIPNLFNIESESIESIQTSRQ
+ILHTKLKKLNSEKLREIQKLQEMFVAPTSDNTRPIFSSSVLRLGILKNWRKSKSKSISNK
+ILGAMKTKSDRVDESFLASFGTKLELSLITNVPNLKTVSKKRSARVVRKLALLEKLKLKR
+KPKTERELKIKSALIARRVKMLKKMSSQKYPSLDLHSGYGQSKVQSSTGTFPIKSKARRR
+LLSAKIHSAPSAFSLAAMKIPFYLRQELIQSSNITPKRKTKPVSLSKPKKKKPAQDKPTE
+LQSEENLIKSTVGPTFPFTSNFFLQEEFELEKSSSIGERSTQIMVDSDERFGYINEESDY
+TAIIHLLKLEGSRIKNLRSECMSYQSSLDKMLDLKEGLLSDIANTNLINDAKGILSDVVR
+LTAQYQECLKKLTGSILVTKGLEIEAKIIRKNFKKKLERINKVRKNIHNKYKKCKTELSK
+AKKSFYSFLKGEISKQKSKNKMSSQSYEDLLRKIQQEFKNYRRLEKKCQGIMVNLRKEDM
+NLSETKMNRYVMASSYESLLKRNLELFNQTLLYYRVNQTYFLMILSLEKLILSSHEVLLE
+SEYSTLNTAVQQEQKLESLTAYYKSQVNLDRLRFEEEVAYQDNTIRAGVHCLTLSNELLV
+KTKLLLEVFETNIDGLEAGIKSLLAILSFTQVGSNSQLNLEIIKKCQVMARRQAKIITKL
+SEYIGTTERINSDMYLLSRTRELLNSGLNSLSVAVTEETEESSSRMRERARTSAYNTRIR
+KLERKISAKMKLLELTTSRFSYMKKKFEEQKEQFSEVLNTMKTIIPGLNLDSFTTDTSDI
+QTSDASVDSEIGSFGFTSDSNSSGNEQAPSDSLMITRISNAIMIVEREIATGPSTNNKEL
+ESVRAKMIELRTELNDKLEQFRRLSGQRKSKSTSSARTKLREEISVHIKEAIKLKKYYNQ
+RMEESIKLLKRKLLFSWPRTRLRRSLLDSNRRKKMEENRMRRINKEKSRVGRLETWDYSQ
+GSTGESEEKLLEELGGEGDDIKGIDTSASSLDLTKEKEKATKKEKTKKGIKISRKPKESK
+KGSKKGSKKGSKKGIKKGSKGSEDELLRKFGGEGDDIKGIETSLSSLDLTEEKEKAIKEE
+KDKEKKGKIPKGEVTVRVEGSEKSARESEEKLLEELGGEGDDIKGIDTSASSLDLTKEKE
+KAIKEEMDRKKGDDTITKGEEIGKENVELEDDKKGSSESIIDLVANSVINEMKIEKFRSK
+WSKSRELKKRKVLDKLRSRIQKTENKEYSSSELSSDAEQGKGVASRKHGKKGADRKKSRS
+DKKQKPKTNGKKKRLGLGKKLGGSLVKESKPNLEVPETQIPSSVPGSPTASETPIATGSP
+MTPESLTAPGTPVAAGSPMVTAPSLVSGVASPAEVSSIAGTPIPTPPSFSPPPPPIPPPP
+SFSPPPPPIPPPPSSPPPPPPVPEYPPLSSAIPPPPSFSPPPPPIPPPPPPIPSPPSPIP
+SSPSPIPSPPSSPPPPPPKPEYPPPSSPIPSPPSSPPPPPPKPEYPPPSSPIPTLPPSSP
+PTPPMPAFPPSPPPTTPGVPSPTFPSQLSPIPEAPEGAEDKLLEELGGEGDDIKGILTDS
+SSIDLNEAHEKALEKEKEMRHSGATTSSGLKPASPIQQGASVISGPAGTPPTPTFPPAPT
+LPSTSKLPTPTISTPTIPIPTVPPTPIPTPKAPTLSPLPPLPPTSKVPTLPTLPLLPPLP
+PTPKAPTLPTPTISTPTIPTPTIPTPTIPAPTIPPTPTPTISTPTIPTPTIPTPTIPAPT
+IPAPTIPPTPTPTPTISTPTLPPQTLPPALPPALPPTITPTPTPPTLPQTPGQTITSGYP
+SNLSQQHSTNTDMTTDEEEQQSDSDEFLQRNFGQREKKTTEDKILNKEIQQQIENINKEA
+EEASVE
+>gnl|md5|3103bc31a57583c42e9c3a6ef5d955f8
+MQLQNFEGYSKPTPFSLARDIINKNGILGLYKGLDAGLIRQLTYSTARLGIFRLLCDYYK
+NQMVYQGHKVCNLSLGVKALIGLTSGGISSFICNPVDLALIRLQTNSLLPLSKQKYYKNV
+LQAMKYIIKEEGFFSMWKGSIPSIIRAMSINMGMLATFDHFIEVCYRWTGPDKNQVFVKV
+LSSILSGAVASVVSLPFDTIKTQIQKQTVDGEDSESLITKREDHNLNSYSKVITHIYKSQ
+GLSGFFKGYLTYYFRIAPHAMITLLCMDWLNKKF
+>gnl|md5|1822de798b49b8e98a9729979b97f09d
+MSSLKHSIHRRVHLERATPVNRLRFGILERKKDYKIRAKRYHEKENLLKSLSEKARTRNP
+DEFDFGMVNSRLENGRYKKIGSDLSNGGLTSAEERKLAESQNLTYVHFRKSIDNKVSCFT
+KSFPVCFFCLYSIRKLKEWKKS
+>gnl|md5|4a709ccaa4cf30e3da4254ed8d71284c
+MEKELTLFGQNMQRSHIFFDDEHEQLESGSQRNKSNTKKLKDLDSLSNLETIPKEVVKNI
+TKSYKIFNDTIARSQKLEKVSKHLELQRDLKSKGKKKKVVTKNGNTEYVWYPKRKK
+>gnl|md5|6b9c3c7ecac34b7a9e381b485fc360cf
+MAYLSRRLKAQTITLFFFLIAFISLNEFFSEASSTQQKKEPKSVRFVQSGQPPYVLSSRP
+GQYFRHLQTTVEQDSSSSPDESSSKEQSRTRSLGPKYRFVHAPVGYEKSKNAYLAEIQSL
+KEANEKLNEEVKTQAQKIKALMAENKELREKIEGELKKTNSSNSKVKSLEEDLKKKERQN
+NSFSSILSQKEKIISEQRAEIKSLLQKIQDKETSLESKEKALSELEKQINNKIEYIQVKE
+REQEKIKEEKELEALRFMEKIENLSANVRENASKQELLVSEKNQLEAKIKELMAERDNAN
+KALNECLESLNAKEVKNEAENVPKETQPEEKRRALYNLVLKQMASQPMKERWVKAPPFKR
+PEGINVESGLVPEIVKVFNSLKKKKENEFKAFVTENGLENEDSAKQRQLYEKHKEKNIVA
+SPAGIQQFTRFKKESVSD
+>gnl|md5|8d32ae2bf3f8eefd63eb2e7ee3c01472
+MVMKLELKLPGTDVGMRIAFGHLDENSTGSRTKASSSSSSSTSSPTLPSKQNSGAKIKVI
+KNDLEESECECDDCSGKAKTKEKAISHKDDDQYSVDMVTKVFASLMQCTASNINNSQFNQ
+NNKLNQKSKGLKQVNSSKSNNKYASDSEDDPLARGILGKGCSSDFSVSQSLYPDDILVSY
+EPRRKKSPKSNKSPAKTKSAPLSSQVQQNTKDLKDVRIIPINKSTNAKILPNRKFKESKY
+DISCISVPTFCNKAKLISCCNARLIPQIPRCDLTKHEDENLMISVPSAIYPDNIILTLKN
+PKPKKNKKK
+>gnl|md5|abe5a1ddefdcbc8b73c27dd25663ef7e
+MAGKITAHLARSAQLLKRYEEKRNEYIRSQKKLLDELNKSKSVLRTKALLENVNKVSSAL
+KGSDTGIDVSKYVSEPDNKKFGSFFENRDELKNVVENEHENNLQELQRIGKECHDNFREL
+EDACDDLIRDSSLINVEISSLEDEITSKVLESLDKRQRIGVQILDDLDKLEKLNDYLLQN
+AHEVGNVDITRIELDDFEKNPEISKTLDSETFGIFSGDRKASDFKKLIDTNYVSTRYYIE
+EPKNGDFVDSDEGDDEEETKGGKKKSGKGSDKSKKASKYSTDFKGKVKLVFEEALTIIED
+HVRDLYIAVADRKERMSELLKLEAFLIREVSRHRKSLSVVLNRVALPEDEIIDENENDEL
+KMRILLKIHEEKTKLMYVREVLDKLYFYPHFRGVKPSSSLKLKELEERGILSRFGYTYLP
+KFKLGEDEQPIGIYGFKKLDYYDMKLDFYNRLISGFEYDLSSYRFDLEMMSLLDSLKYPE
+LNKLIYSDDYIESSIFTKRTKLMKLLKKLILKEKNKDLRRSLKRAYFEIREWFDNAVRFE
+REYYGSSALETIFSESKSSDDGSSRSESAIVLSDKKGSSPSPSNKQQRRMRRKN
+>gnl|md5|350c08f2f7e1301c685f2d9d6aa42202
+MFINYYSNSIVRMHMQLLTSQFFYLFYFTLLTPMPRPKYSKSQSPLLAMHKPPNVGGKHG
+TESTNIKNCQVKGKFSNKERKRK
+>gnl|md5|eeea995aa43cb791776930d28e697fd7
+MRQHWDGNLNDTANKLIHLSKQRTISQEKSEIEPIFEDELIRNRERAKEMGIFKGEKSRS
+NGELSKSSKGISEMYNIGSETEDSKAGDSSKKSELDEKSIIGKKKKKNKKRKSQQKKNNR
+GKEKRSGILNKAKELLESFKKEPEVHASEESKAKSSENDISSSESTLDDVEKSSDSPFNL
+LNFGSPIKDEQENSEFSERFGIDTLFEKSFEDLNEPKKLGGEPSFPSLEKSKLEEKLNNS
+EKNNEFEPEKSEIPTSLKEEVKEKEKMDLSEQSPKKEPSADVSPETTVMVNLFEDIPLAD
+ESFNSEDSFKLKGNEDIIKKNDQISQDISEKSVKKVDNGLGSQYETTSLPENEDLENYSV
+PSYREENIFHYEPTGETSKTEPSNSSKYLPKEDDDLSEEETKEDSEEGDTRVSDKEKPIK
+KKFSKIFENKLSTLFANTKKFFGFDKKSSKEDLASSDQIKGNQDQYLNVEEEYKNLTKII
+IYFIQSYAALRYKFADKAVIENSFDEINEIVKSSIHFHQGTTEFDNIDMEKAIKKIASML
+GGGSFTALKSIGLTTKDITANLKRYLIKLFPTEITQEHYKKDKKLNTTNFWLKQHFTQDV
+TKDGMIPEQLERPFIIETSQDLIAKSNDPGSIETKAENLCKRIPSILEKFFDKSITKKIN
+HKDFDCLAVVAANELYGLSLSNSLYLFLFDYKTNYWRFLTPDLSISISQILENE
+>gnl|md5|60d51457b1bfbb9b6b7aa77054a64bbd
+MKLLAILFLFELIFRATAQDVILESEEGHQNKDDNGIADSDSNTEVTKVPNFILLCALIP
+QIPGCPCDPLLETRPTFYDFLPSDCSCYDSQQSGFSSPPCFCSKPDSDECKCLSGLSSLD
+EEHDRMCIVSPLTYVTPYANCTSFLNPLGEEGLCSGDSELSEHCVTLKSCRRLTPISIEE
+SSIQDKCVTDPESEGCPCSADQQITDEDALICSCYKNNKNPGCPCDVQPDSSICQKFIDL
+LTKPTSSSSTTTTSEPIEIMNSKETEPDTKNIEDKTKSSVKETEDDKAKEIDDIVPHDET
+IMKDAGNDSGKNDSSFAFKVSTNLYISVIFVLLSTLIF
+>gnl|md5|9f4a442c647d3859959118bbfa7e96f2
+MIDLVYDIESLIILEPIRGKFTREVLKFDNIQEIDDLLGLLKLLTTIRNSLELGYRDVKK
+RVNLENPSAATSISIIAVLVYSICYGIAVEHFSKFHLNICNLPRPAFSRPVLRRNQQDWM
+KFAITNVLTNLNIKLSFPIARSFERKLEASIYVSNPKSTLFNSLFQPYFSGIPYKPFKSR
+VESNQNFTENDNKSNVFNPFKSDKDHREIFKKNLIMLNDDLLEYLINSLSSLDYMPFFVR
+QCISVTTAFVRFQIQKTEEEKDNGAPKPSNNELASIVCQNIQDYLQKKVPKFFKL
+>gnl|md5|3c5eeb750c68f02bb889594dbeb92735
+MSELRREELVISDIPALLKEEMIEDDKSLSLELILDSEIRKTEVLDNWSFGSNEEFNLLS
+IFKDDNANIKNNEQLDGQKDWEKDLKKDQEKKADEKQKDQKEGEKEVEKNAKKNQKKESE
+NKDQDNDNKKREKEEADKAKTKEDVKKEVKKKDQKEGQKKEANIKDQEKDSKKETKIKDQ
+EKDPKKDQKKDPKKETKIKDQEKDQKKDQEKDPKKDQKKDPKKETKIKDQEKDPKKDQKK
+DLKKETKRDQKEDPKKDEKKDLKNKSDQAKTKDKKDTKKDSGKEVQKKDSSSQNKAKYKE
+NIEEDNITDSESDHKEKKNSKTKKNSSSSSKSINIKIPYRETSHIPSCLFEQDNTNNLDF
+NRIKNYNEYIHETSRVFSVDSACRYVFIKRISKLE
+>gnl|md5|a48d27a0675357cb69aec91e6699088a
+MNEEKSFKDLETLVSRYIKLNMSEERGEGEEEEEQEEGGTRRRKGRDGEEEEEKIFIDSF
+ELCKGTKSIRNKRRKIEDSNSSYTNSENLNHRKLTGTIAQYLLSRVPLPTSRVDIQKKFI
+KPEGSKKIDLDSILNTINDKFKSCMGLGIFGLDKSTTNQNIIQP
+>gnl|md5|b4bbd5d53615e44314960faf61dc938c
+MNDSELNENGIYSSKNFSKLNKQYIDIDTVNFESLGKYPKYHSFFKRGFLNTILFKWLSP
+IINSAEKGIIVNDSDINLADDDVDIQTEYIYFIRNWNEEFSKPEAVNSIQFSTFKVIFKT
+FYLRIINILLFKLIYDIIQMCRPWQIHGVLYWIGDPNGSKTSGILKFFSIVICELISGSI
+LQQYFRRSFSLSVMLKGVMNYSLTNKLIKLPKNVAIENVSKCISLLSSESTYLLGTGNTL
+LAVPSMVLQNLLLLFSLYQFIGISAFIGYIIIVLSLFVNGLLINLTQSVRFKYISSLDKR
+ISISTELVNSFKQIKCYAWEKYYIKNINEIRKEEIRHLGIWRFLNQFGLVLATLCVSLSP
+VISFGSF
+>gnl|md5|db1da942833948369ecc2cb0e974b189
+MIPQNLIDFTYCFTRVTIYIGYFIYLDYRFIIVFIPISYFFNKFRIRAMFANRQLKRIFH
+SRTSPILTSVSYTVDGLSILRCSKNGLKNFSKNVQYLIDYECAPWRCYCLIQRWLGIHID
+ILGACVISSLGIFCISAKGFVSVGAIAIAFQCSVSFTQLVLWMIRNISETENNFLSYDRI
+SELIGILPQETNIGDDDDDNDLNKSCNIKEIDENAQDSDSLLINIDHPNKPLSLDWPTNG
+NIVFKNVVFRYNPDEPPILNNLSFSIQGGKKIGICGRTGSGKSTLLSAILRLYSIQEGSI
+LIDNVDVSQISLKKLRSFITIIPQEPNILTGTLRYNLDPFNEYTSEEIDQALVNSNSKSF
+VDSLPDGINTQMTNVSNNISLGQKQLICLARAILRKSKIILLDEATSSMDIATDNIIQNI
+IKTHFSSCTILSIAHRIHTIIDYDLIVVLDKGKIVEYDSPQNLLSNTSSVFYSIANEVNK
+L
+>gnl|md5|a654a2dfb6a37ee03ecd927f10817d6c
+MSERSDLNYKMERMRMDEVLGYLKHILDKYQEYPKGLNKVGLNQASKSSNFEFEVLVQNN
+HLVNDCLKIVCDLVSESLLKSNRIDQLKDIILNTDGNQKINHHFDHQYKDENQCYCNNND
+LFGSVYGKIVCNDEKKHLKEKVQHLSHEKLLLQRGIEFLKKKLYTLKNQQLIVSSENYES
+NLDLMASIDKPLGETEIDSQEIIQVSDLWDISNYLKEDGINDLTIMSEFLVVMNRWKKLA
+KYTIENDDDISELKSHSELRKKYSDHFSKGGISIQGFNNKSIYYKFK
+>gnl|md5|5f1b7b0f2d5fe603b595edc11b28c31f
+MPEGRKLIQIGKKELLAWGSSLLGEELNWKSFSDGTVLLKFCFIVWPSLNNTKTEIDALS
+DSWRKIETIFRTLSIDYSKLIDEEGIKNDKLCSAYNSVIIFFFLYHCAFKNESSFEFIPP
+PSKHIAEFLMGDSSIKTLIVGGSLQLSPKTQIRLFENDSKVPNKLSEVPTEGVRYFKGDE
+GVYYDRIQRFNEVMDMDERTVKLVQSIDNFFEGLNDKLSEINKINLPDEIENFTTKVRHS
+LEYCVRQLVRTKEEQAIERANYENRIKTIEEDCEKKIEQLKLTYEEKIREIENEGKQKII
+QEKKASQMMLRTMQNNQTLNLQMSGSIYKDYHNGDLSLEELSTKIKGETIEQLKYLQEIV
+NEENXKRDEIEKTLNDEISFYPERNRD
+>gnl|md5|d9359d582e0ca03d4d8b86b03251db63
+MFLLGLFLFSCLIIKWNFSLSQDSLHSVQLPNIYSVKILQEFPHYHIPENHIFSENDSSY
+KYNKNPFTQGLMFLNSTILIESAGLFEGSFIKLIEFPSMKNLQHKILPRRNWGEGIATLN
+GHIYQLTWTSRVMFGYSLDLSVVKRYSLPLTGWGLTSDNESRIWATSGSDQLFELNVPDF
+DSSDNKVTIKKVIMLGCLGKPMNFVNEMEYIPETKTIWGNIFQSQMIVEFSPETGECISI
+ANLKSIYDPSKSTLLEHFDILNDVLNGIAYHPSYQEKKISNLNGPVLFVTGKRWPRIYKI
+ELTKIPIRARKNEKINESGDFDKYFEFYSSSIENPSSISNEKFEM
+>gnl|md5|a01e1512ecc48d61b2250d84ba081330
+MNQNQLLKYIFRSLKYLSCQSLELVQAYKHKLLTFLLAWKFGTQYFHLNSLKYLTLACYS
+KRIRISKTQIKDFKFKV
+>gnl|md5|4abf176bc132ab8542820a078fa98d3d
+MTENSVKIESHSKKETISHLNESASRSNPRKKSRKNTGKDNKVDNFDSPVFSVRYKDPSI
+ELSEDRLTAVGYKGWSTVLLTHGASSGVWYFEITVLEPRVISKFLGHSKFLNLKQDPSIR
+>gnl|md5|c6203d82ac97a336ba217410907d8fc7
+MMNEMIIKHFPNLSIEKDLYRPLLFTNIVTSICREIPRSIVSEYLQDRLTSYYEEQGTSR
+LVFFDEFLDNINRVDRVLRQPFGHLLLIGPPGCGKTLLADMVSWLNGLNVFTIKPGRKYD
+IFAFEADLRSVMKRAAIKGEKLTFIFEESHALGPAFIERMNALLASGEVPGLFEGDEYNQ
+LLNECRTAFSNSSSVSISDDGNELFARFT
+>gnl|md5|56bcff5c50c2be847fa9c0a24e00dff6
+MISTEPEVILDTLGTGIWDDQELLDSIFNNDDNNNQMNSEEFNEKREILKNFKKGVLKCL
+LLKIIRPDRIVTLFNKLISDTLGSEFSNISEFSKDLLKEIVLKQITEITPILFVTSPGFD
+ASLVVSQLANEQNSNLLSIAIGSAESLEKAESSIKTAMRKGTWVMLKNVHLSSGNLDYLE
+QLLQNRQNRPNKGFRLFLATELPKKILNPSHKDSVIGASFNTSDSSSGSLSPLGISFNLI
+RISMTIVLESPVGLKAALQRASEITIKTVDDSQSSSTIRIKLYFLLAFLHSVILERKRYT
+PLGWTKFYDFSEADLQCCINIVNQWTITNISGDPEQIPWEAVRKLVSQVAYGGRLDNIVD
+KQILYILIDEILSSKSFEDGSELISCTSEWNKLYRNDQIKPNILLAPDTSKKVQNYLDWV
+EKLSSTNWPTWLGLSPLAENVISAQKGQKMSLNWSVLIIRSRNETPDLIPKDKGNMITNI
+EENEELMGDGGLSGGGNNKIEQEEVLKSDTTGIPSWLLKISGKLTKMENSLRIFSEYIIK
+NSRNIIEYSENNSLDPILRYYVSEISKFYKGFKNIWENIHELLNILGGESKLTNNLRSIG
+LSIQSDLVPDLWLKLLPILLYSLDIWLSDLIRKLSQNCLLISSICKKLDIKVIEGGEDSS
+KMDIFLSNVLISSPGIKKIGLKTIWVGGVCDPGAFFTASKQYAAKKFGCSYNDIVPRIIS
+IGEMVENENEDGDEARFVLGGLTAVALEWKQESKLFELSTEKAVSEVPPILVEWIKGDSD
+MITNHNISDNNYELNIIPQNSLDNSIAIPIFKDSNRSQILMWINVPAKANENIKQWRLAS
+TSLILWKG
+>gnl|md5|7171dc45ba491738cce6b6261018ffe1
+MIIHIINVSGDVCKNVFQDKLEYRTYYVLDTPQESIEGVLYDSIEWIDGKFKESNENRIY
+VHCQEGVSRSSSIVIGYLMWKYNKSFNDASEYVRERRSTSSPNIGFTYQLLLFQKALSLV
+KFGIPTRDEKEEGGGEKAELPSINHLGKKHWITSSKIYYISKHGIPVSLIHWKGDGSNKF
+SLNSNKIYLLRQSLLEEADSIRREKIWIWIGSQVNEGVRESILAVLRFCRQILKIEIGYD
+SSLELENLEIRADLIIGALADDRNSASECITNILSSTIILEYFHEFSESGEFMQILAPAD
+LHLCNSYDVIQRSFSSPSIKSISKNAIPLDYENDVEDEAEDIGVDNNEGNYNQIDRLSSD
+SKSSSELSSLISLDESLPYFSSFPSSNGSPIPSRNSPDNFKSSDTESTKEMGRINQHHFS
+LDSRKIIYSKDNLLEKESREVESCPLTFGKVVIPKLNFAFKGGDKSLEDRSQSQDSEMKD
+LKVHSFSTKEDSAPVKKQHSIHFFQEEVFCFNSSSYSKRSSISQENLSMNEDCHSTLDSG
+RMKVLLFRFPDYFGSESLRFFDSEDLLPTSVCPLIIIGEITSDEQKNKEKEEQKKKQEEQ
+RKDKEKDKEQADLSLSPLEKNPIKNIMVYLWIGSKTTYFNQAKQILSEHFQGNDSHNHAD
+VSSLILSTVENHSLKDSEKTNLNEQINNHHFELDITQLLILLIRNNSKLSIKEVSSVYFE
+FEGEESNSFWNYFYQ
+>gnl|md5|a441557400d36164b8d98da580d80c25
+MAQDDPVTASLNFNTSAALYKELAINFNKEYLLPCSTSFNNLSVASFYSSKLPNSVSILE
+NQIYNQNNFFFNSQQLFATNFKNLKTLYQFSSDKDKLINELKKISKSSLRYSIIK
+>gnl|md5|d08b7a55afae61d7c4e31ffaecbb3636
+MSTQALEKITNKSEKEKIKKELYDEYEIFKVSNIYNEMDLNKAISNVISSIITLSGLEEQ
+IQIYHRKNILMLIATVFGIFGAVVFKFPKDQWFILICVVGFFLSMFGTFLIDAKSPFSGF
+TNSYIVPKKLQEKGGFSLKNIWNYDKDACYITPKLNRASNNIEFLLQNQDHQVSKTIYVG
+KLFTLDGYINTDEIFEVISKLIVELYEKSNEKKKK
+>gnl|md5|7079e977cea735fb77b79e0966dc0f55
+MKNDLKKNKELKSVRQDRNYTTKSIGMESSLKLGMKAFSYSSGAEWNPMNPSLIWRKNKE
+NDDASTISSSFSNQKALMNNPGIIRELENELGPVKGSIMLAATGEKLRDINIGNSLIAKE
+VWKDEPLSHITKLTQQEREKQQVGYNYQESIYDNFGVKPTELVKMNDFGNIKLPVRSVLS
+MSQEASKEVEKKILDKEGNLEMKLLNAVDPFKQKFHHNDMTENRMVCDRKSSKIGRFYKN
+PNNLKDQILFENEISKDSEKEHENDLMKLRAFNTNFEKHLGFKLTGKVSLDNIGERVISL
+GTDNTSKQIGKEFKELRRQLGWEKNTEKNFKNEEKEFNMYGNLLDQKNISNEALIDRLIE
+NTTLYPCFDEVLFENTFRIHPDKNRNHVSLITDYLDATSVLSSSDVLLNIHKKQYTPPLA
+ENFPKGLPSIVQDPRVIWQKEFLNIPYEVTADLIRKIQRGFWDEISNDIAKSSYGSISIS
+SVESITNIKKFILNELSYNSIYNVDEPFDVSPPKLPPIEREQQGRILGSSSKFQQQNNKL
+VITPKLKFGLGGTNLISGSISKIGNKMFKGPISSHNSNESSKPETFRNDVTVIKYIPDCE
+LYETALWGRYEFPNDDSNKGIIRKVKNTEINEGEPLYRENVISMSNEWREDMEKQISERK
+KGVEMLVNSQENRSSLQNFTLNLNKIIDSKIQNMDKKELSKLKEILKDRESLEELSKTQI
+SGKGTTLGDNNKIHKNSRQLNITGFKNIGLSSIGINKESTYNHLDSPDISRVGIQQNNIF
+KKIKNSQKTVKNKIGMANINDDYDDDESSVRDDESEEFEDLSSENEEDYRQICETIHIAP
+WEPTNLMMTKNLFKSTNNLFSTLSILITKDSKIKSRVELHELGEHGIIVWMSRDPIGIKE
+KILNCCTDIKTKLRVKGGIYFTPDSDISPIEPCTEIPGNFTFSVTGVNLSHLILSKNSIK
+QLEYVKKYVKNYENSFNELSNNGSINNFNGNDPMYQKSLNTGIKYDENNLVNDSPILEQT
+QFGINADTDIEIITRYDKKNINNIDVMNLIPALNNNQISGQNTILVVSENPFIKGILPLT
+LSDFPKTTMKFSLRRNRLLLWRSIKCQIWKTQYIEYCFKSSVVPAKKVITFISNAFLKSN
+TSNSFDMGGLIFNETLFSHCINVALSKKDPKEMIFRGCYMGDDGFHAIFPLLTQVKSLGK
+LDLGMNNLTARSLPLILEVVKGCNCKKLLLDFNNLGPNKTKREFSVFFKHILFSTSIEHL
+NLSRNKINGRCIDSLDTILDNLGMKNKTLETLSWCSNGNTQPEIETLLLALQPCCVNLSK
+VFLGGNPIERIDAFKRRFSPIRIIMEDISSHYVNKAGVNQGEGSYFSDSKEKKSRGLSRK
+SLTSNSNLSYTNSGLFSQ
+>gnl|md5|acdbda2afbc8e54ea2dbbaaa7ea70252
+MNYIIFLHTAYLILAGISSSFGEELRLSNSNNFGKSNDINNGNNSLYVSNSTNNNSSNNS
+FTTTTTTTVSTLMTANTIINKSNEIDAGFQITTPGPKFVQNLLNAGGVPNSESLVKQLGL
+EDLSEFTKIDSVVLFYVPWCVYCRGIMPEFEKAANIFKGKKISFGKIDCNEHRKAVLLEQ
+VIRFPTIKIYSEGQSQYYSGLPNSVSIVNFVNSEFNRDISISSLSVLEVFLNTDNSSIKV
+VAIIDHENSDESDPMSLVSSSYSKLSHKYHNIFFAHALTNNTEVLNFIKNYSTKDKNKSR
+SVMNHSNLIKENTLAIFTPWDDNSDKQYDFNKNDGNKHGLILIDKVDFSNFENLEKQILK
+YQYPLITEFDPLIAQKLFLGEKTISFLFVNNDVPNLKLIMEKYREIASQFRGEILFVKSG
+TNLAHERRIAQVLIPEECKLPCISIIKFPSVDEGKMIAPTLPNMPPMKRPQAPLIYRCRF
+SGPDLLKNSNLEHFIQDFASGRLSPYFKSEEPPSEEDNDGPVRIVVSKTFKKEVIEINLD
+VLIVFYAPWCGHCRKLEPDYNVLAQRLRGISDKLKIAKIDGSQNEVENIQILGYPSILLF
+KSGMKTEPILYNGDRSGANM
+>gnl|md5|74f616f2c6ae593e535de4d2413f779b
+MVSILNNLENIYFLLQVSPIVQVHTLRANVRYRIGPEDGITDVDISYPDPPPCITTSFDL
+WIKNEDREFRLTRKGDNNQAESCKYFYKDCVTGSYLPIPLFPDIIVVSSGTKLRVMTSQP
+NECNIAFVLKTQDVSDLIGSKIMFNTEIQAYKINSKENSHKMLIDEISNSKTKYKDTTEK
+KLQEDMGKSYLVFTEASLGKGGNGEVFLGLNRETFEFVAVKSEMSGSLSREADYLEKCKS
+DYVVRKLDWFQNRTDNREYLIMELFHGGTIRQLLRFKYKNGLPINSVRNLMYTLLVGISQ
+MHSKGVVHRDLKTANLMLTDVVRDINTCNSQMKICDLGNSGMSIGGRLKGHCCTCFATAP
+EVYLNNDYDEKVDMWSIGTILYELITGQRLIECNHQIHCNANEKILRFDFSNIEKKINEH
+ISTHYTFGDVNWVEDLIDLLRRLLEKSPSKRISAQESLSHHFFTNYQPITIDNSWKCTTK
+LQLIKILDENIPVQHESEEANTYLPNCKCCSNQMNINHHFNYNIAPTSRISSSCFPSL
+>gnl|md5|c5d47ff96b45ec297f48e5dc075f6933
+MELSKRSNCYEAEYTANELAIAAQRRDKNTLHNIIQQLIETGNTGILNESNALHWSVYYR
+WDDVSIHLLSLGCDPFMGDINGDTTVHYCIKSGNFSMLKYLYEKHGNKIFYVKNRNQFGL
+MLTAASEVAEGRVQDLLRVMEWLYLQGYSLEEQDILGQTPIFWATKRGNYGIIQWLISHG
+ANIGHRDHKGNTLLHAACSGDVDDETVSFLCDLGLIHLISYSNYENPAVGNTAFQICWTR
+KNYWLALMLNFWYYHNKLFGRISLLRNPYAVYYWFISILNLLVVFIMVSTLKSYREYLDG
+IYLGYFYTWIILFAAAQLFWVLSNIGNDNYVKHPIYQKIIPKLPRDKLLLLESHGLYLPL
+LTPQANKLGKNSSIYHLMLKENEQIQLNNQLIDMNKLLFNGDHFNISKYREKYNNHISRQ
+IELSNEIIGLMPFVAKERQSNNSKIYIDIVEGKPINSTAPVLPKICVTCRTERPFRGHHC
+SDCGYCIQRFDHHCVWIDSCVGYGNQRAFFFFLKFLTISFFLYYYLFQQYCSFRFKFSAS
+LKKISSTDSNNNWFTMQTGDLFLGVGDTEGIYFHEKAYYFMTSDPWFALIMFNSIMNIPW
+MIFVLYLFIRHVKSIMSNVTFYEYYKKPEAIKKRFAGRNTEGFCYDMQGRTFSTCIRSAF
+AYFTKNNSWDNLDFFTHIREPEKILGSTTMPIHIESNAPYQSLSQVPPSNDITFINENGD
+PIPNIFSSHVSTSHPYYHSQFNFPSNSSSAFYQVNPYAGNHMYN
+>gnl|md5|32abef08e71d56feca57604f634eb6c6
+MTKKRQASQSNNEAKLVEIDTDLGSIYSISNFDSILLAWDFFKDIKEEVFGVERPDIVNS
+FDISGETCQVRDNPTRFATSKEYLDYFFPLFLLECQQSIQRAKQIEMSDFDTFSLKDIRA
+NNSNKLEESNFLTLVFERRRADELIYFSPQDLVLIIFDPEFKSEEFDDNLKHVIGVVQGS
+NSNGRVTITVLNPNYYVDDKTMKRKIASFTSQDRLVSRMKSFSDSLGNKEFGQDTSNALS
+QSSSQSWYLSRITSFSTNYRELSGLFSLPDLLLKDELLCRGLKCEHTMKIPTLLQEKLKE
+KYNPSQMSALNECLKYSGISLIQGPPGTGKTTTIIGIISALLSSTFEVKNVSEDSSNEEN
+IETKKRKSNEENIPEMYAPILRAKPWCYDPDYVPWYDSEMKNLRIFRNNKVEIKKVTLDT
+SSRKMGPRKLLVCAPSNAAIDAIVRKLVRNPITGEGGILDNTGEYYSPTLVRAGPNFHPD
+LHDLSLEYKLQQRLQRNGFDAKNCKQEIRQQTQWKILQESQIVCATLSVCGSKELISILS
+QNGRMQAAGSGDRTALSFDTVIIDEASQGVELSTLIPLKLGCKRLILVGDPKQLPATVLS
+RRAIERKYDISLFQRLQMSGQQVVMLSVQYRMHPQISAFPSKHFYDGELHDYKDILETRA
+PVVAWQDIPIFKPFTFFSVNSEEEQGKSISNPLEADFVCQILELLGLILYEHQKKLTENT
+DLGEPSKRWYERIAVISPYNEQVKIIRKKIKEKFGLSPETICPIDVSTVDGFQGQEKDFI
+IFSVVRSQYIEEDSLNNADDRKTNAGFIADRRRINVALTRAKYNLWIVGNSRYLLGNPEW
+RSLWDYSCKNNSQFSVDFKRIGSTENYLKLWLYGFLQRKESCRNALRQEVPEFVQNLTLD
+CSVLEKNKDTLNSVTEIKAKVDSSFFVDLKEDSQGYESKNKRGSKVFQTESKPIEIEENG
+VIRKFRNLDLDLFCDINDYESSKNKDLESENAAE
+>gnl|md5|68ee1efe5bc753499533965afffa1b09
+MIQDSKETDSPEHQLREKKSQELDQILKEQKELVIRLDNINIIIKDNPKILNENLSSANQ
+ELSIWEDNVCSLRQWIKKKMPGISEKEINNNFGLPDDD
+>gnl|md5|8f13237721dce8c6e597281f95d33c00
+MTLYETAAPRVIKTAKDVPAGILIEKFAQQLKKGGKMTMPEWIDHVKTASSKELPPQNSD
+WLYIRAASILRHLYVRPNVGVGALSKFYGRKQRNGTARNHSAVASRGIIRYCLIQLQSLG
+LVEFNPNTGTRRLSPQGQRELDSIARQCKA
+>gnl|md5|f8071bf826e1c6de061542f9f64b17bf
+MRFIFAFISLLLGLIVSVFAEKGVRPSTVTPSVVVELTVSIDKEESKLRIGLFGVEVPKT
+ANNFYSLCVGGMKDKDGKEMSYIGSIFHRVIPGFMAQGGDFTNGNGTGGKSIYGDSFEDE
+NFKFIHESHVISMANRGPNTNGSQFFITFTPTPHLDGRHVVFGKLVDDESKLTLTKIEQL
+GSYSGRTSKRIEVTACSHYSGTPPSAKLEL
+>gnl|md5|72e88511b9fb577dad9f1aa191a29447
+MTNSEQNPPSEENVQVASTGEIESNYDEIVECFEALNLEGDLLRGIFAYGFEKPSAIQQR
+GIKPILDGYDTIGQAQSGTGKTATFVIAALQKIDYSLNACQVLLLAPTRELAQQIQKVAL
+ALGDYCELRCHACVGGTSVRDDMNKLKSGVHMVVGTPGRVFDMLDKGYLRVDNLKLFILD
+EADEMLSRGFKVQIHDIFKKLPQDVQVALFSATMPNEILHLTTQFMRDPKRILVKQEELT
+LEGIRQFYVGVEKDEWKMDTLIDLYETLTIVQAIIYCNTRRRVDQLTKQMRERDFTCSSM
+HGDMDQKDREVIMRQFRSGSSRVLITTDLLARGIDVQQVSLVINYDLPVSPETYIHRIGR
+SGRFGKKGVSINFVTDDDIVCLRDIERHYNTQIEEMPMGITDILQ
+>gnl|md5|a3729ed257a8799ca1dbd7eae3fa16bd
+MKGRKRIWQVSYRDAGTKGMLVKWGLVVLIFQLFFSLLINAGDLDLPSRNSESSRISLPE
+IYFVLTVDGTLWSIGENGKILWKRKILEEGTFYPSRVFYDRGNDESSIKSTRLYCSFQGK
+IFFGTSSESTQGFYNTQNTYENIFSEKSVLPGGVIPIEGISIGDLVERCPFHSSLFPGLY
+LTGSRTSDVLAIDLFTGRILSNSASSQQCEAYDQEASLNPKIQVSIAIGVTTWKILALNI
+PTNKLEWDIRYSDVNGINYNKYSQSLQNVHLLESGQADREIPIFFGSSRNSLYLKNISLG
+FNSIISKVFILKEGLSIPYFPSNFYYIEQVHVSRLRNYSNSAVGPLIGTNNNILLDDFAH
+SKSEPVNSEISHLIGSKLKGLTPMVINSNRPVPRPMLPFPGNKTETSEEEVTLQNLHNQT
+EAVGLGTNSESPKLPELESENGSNSILFSLSILYHRNHLAMTTGIILFIVNVILLFVLLS
+KRKHTSSANNQQQSGNLRNSFLGSSYATTFNSEETETDFPPSRSSGDKYMRLSKSYSMVD
+MRTNFIGISKNAFFKALNNKNDAISKSPNYNNHFDNLGARTSFEDDSKLTIDLPNSSITA
+QLGASTTRGQTNLNASNANTPTNLQESQNAFTPKSAASGPKSSSLYNIPPRCELARCIDN
+GRFSKNFEIVKLIGSGGFGQVYQVEHKLERGTYYAIKFLRLGIGANDDITRIRYFREITA
+NRTTLSKHVVRYYTWWCEEPEALQNYVDGIDSLGCSKSASHSSIQPKVLETRKPTKKHKN
+RKSDSSGLKGRKKNSKKELADNSETLDQGLNKIKARFIIDELSQEDEDLLMETSSNDSIG
+RFSLEPTQKNRKGRHNAEFGFYNDEHSQFSNSDSCFSRAPFDLDGEDNYQGIEESAFNGD
+SHINGNRYADGSEGFGLHSDDKLSIGYSARFGNLSLASDSSFQDGFENDSHNLNFIAFEN
+ESHVLEKSELEDSSPEHIEEIPNIYIDDVHNQPNDNGLLYRTKTISTKNNHELFVLSSGN
+LPQVSSISSVTDNSKSLNNNNHNHHHRSLVYLSPANRKDNDPIYEVIMMIQMELCIGVTL
+RSWLGDASRSTEYGGTDVELNMFKQIIKGIRDIHEKGIVHRDLKPENIFVNPDSLQIKIG
+DFGLARLMFDGDSKTNNGNSNVISGDTQLVSQPPSSFTPSYKLEKNGAAVNNDLNRFMDE
+RRRQSQMEAQMNNPLSRLDSQMSVRGQVIGTPGYTAPEGGALCNEKADIYSAALILLELL
+CPRFTTAMERIHVLDSFRSKGVVPVSIMKNHDAWIPLLRSMTYQDPEFRPSAENTYRIVK
+DLIKKKKVI
+>gnl|md5|b513dc67c4d61d32674a71caa0413eba
+MDSNTPPVSSSPAHSPSLCLNNCGFYGNPTTNNLCSKCYKDSISGNSVSNQSSVSHPQSS
+DSVGPSKDSECGFLETSKEFKQESSSPTLIEQEITPIETTKEKESQDLTTEPASSSASLS
+SPTEKPSIPGRCYHCNKKVGIYGFNCRCGFNFCSTHRYADAHDCTFDYKTFEREQLRKTN
+QAVIADKIQRI
+>gnl|md5|9e2cbe0ca21978c0069212d9032e1d9c
+MSSFSGDQAANGEQCIVIDCGSAYMKAGTDSDKSPTCIFPSMVGQYRSRYVPEDEDNNPI
+FVGEEAIAQRKKLSLTFPIDHGHIDDWTKFEELLNYLFYRGLDIDPIDSSVIITKPPLCS
+NRHEEKITELMFEMFQTQSLNIALQGLMALYSAGRTTGVACDIGEGVTQVVPVYDGYCDS
+SSLKRADIGGQEITMYLQKLLSDKGYIATTRDDLEHVRIIKETLCYIAKDPAAENERPEE
+EINEVYTLPDGLTLHDEHTNKIEIDKERFYAPEVIFDPKLIMRDVQPVHELIMESIMSSP
+MEVRKTLMGSILLSGGTSLTTGIEERLEEELMYICPSQAKSNIRVTPADDRNYAIWKGAQ
+LFSALRDYQENLWISRDEYLEEGVNICIKKQPFFSSIPK
+>gnl|md5|c651ada9a30b0641bb65efb5ff08351d
+MEASIRNRLRKQDLVLPDEEVPNSQDSNINSIDYSEVKELVLDGVKLRELTQQDSEFLGR
+FSELQYLSLNATGLQRLDNFPLLENLKVLEIQDNHISGGLDILQNYKNLRCLLLGGNKIK
+DFSELIVLKELPKLETLSLLLNPIAEKNSESYRSIVFETLPNLQILDEMNKEGKEVEDYG
+YDDEEVEIIDDDTEGGDEEETSVHADSHGLPDDDDDDDFDDDDDEDAGQVDLKQFYENDL
+EDDDDEDEFEPGDVDIDEAEDFEEEEEEEDDEEDEEDEIQASSSKKQRIEQDDDEDE
+>gnl|md5|49f2e57eab7aab4886ce8daf0d7be067
+MDNDRSISMSYIDLGSDSPTSKESCPSNLEYIIELVIYSQLVISLFLCIGRTDYNFMLYL
+LGYGVFCVEMPPLDVNGLIRKITGIRRFLMLIILATAIEAIWLSFAVSAWLCPNNQNPDV
+CFVEDFQMNWEYKLHQYIIWGSSINFILKLVLGTLCWMWIDKERTKLEAISLKPLIFFW
+>gnl|md5|bc78f169d2b626772f499eed94e668d9
+MASIKIFKSLPFNFLLLFTLLVFSIGVVSVKSNDNSEKLPVFALVDIFHVPPESRQKCST
+ILGWLATKYPNNYVLMSVRNIIYQLALPHSMLQENAEKELIAAMDSLQGTMSNVSGLEPG
+TYISILTCSVDNKGRTILQKMVEHGLVQALSHTLSQKFWVGAKLNKLLDTEGNNLAHLAA
+MSENDELVHYVLGIMFKSNIVAEMLESLNSNGQKPIDIAIFHRDQQTVDTMKNFFRVTTL
+AEREGFVDGVEVIEDSVALAEKEAENKKFKEFIEKEEDAASKITNAEITRDIEYAKQDNY
+KESINDDISDSQSQSFESSAAEDSMNSSQLTQSLEDEFSIKPKLKDQDILQNENNQQEQT
+FSDENIYDEQVEDSIINGNQRFSAINKIENTEKGDEPREAELNFSSLRGAVENNMDQETQ
+HHHYQDDQEEIKKVNKEPQSKWNATAKAIVGASILVGTSILAATVVFIVCKGYGNKEENS
+F
+>gnl|md5|f71a535674a3d7c4ef585d0d31544f97
+MNLQGHKRGLSSQNKINSYHYLNGKKNTIANILSNTTTTNNNYCLVNNVVNQDDNRFKPL
+NNNSSKSMGISPSTTTKMKYHMEENENNKSSLGLFQQVSSTNLSRSQNVSLTKQNEGLNG
+SGVNNSSAGNSLSNNPSISNELKDKPQLSGLNNCNSGIQSNNNNDSKKKRSRVIYCHVCC
+QYKPRSTRARFQVCQHIACYDCVRLALMIQQRYNVKAHCPFCQIELDWNRVKPFIVLFKP
+KSEANIEEDTNKTLADSKQETNLGIGFNNNNNSIGIATNSNGANNAVVNNNSTQNESNDY
+NANSQMISNDLIAQAFESNGISKEKILKGFFSCYLQKQTHLRNNGCILQNNNNNNNGCVS
+QNILYDSKELQNTHTNYSNTLESYKMTGSICYGGVNNKQYIPLKNFADQNILVLPNLQNS
+SESCGEFLPDVGLAPVGETLPLTNCMHQIVGTKEFNPYMYGGNFSSTISNNGAGNSTIAQ
+NTNISTFISDNNQINYSSSGCNVDLNNNNSNIISSNNSNSSNSSISSSSSSSSINSNNSI
+CGNISYSSSTTTTMRNSCIGMRNNNVAGTRVVHGSNCNCTSCLKQVGRMGITSSMGLGMT
+PPGSILSTIYDENNPRGFVCGLFNPSIPTDGVALVHQGKSNKSQHIHFELQKQFMSDSLN
+NYSIGQNDGASTSRISNGINTNNNTANNHFIQQQNNHCTSQSRNHCQIPYSLSTYGNSCG
+VSSIGNGTFNNINIGNTLLNCDENIPNSLKTSYGLYNDQNIRLSTGVSEIFGFFETSEDK
+QMPNWMITTPYLNMKDILSDWRNSTLLKSHSDMVICSI
+>gnl|md5|4b2bc62fa861819735c33ed071144a73
+MPPKKSTKSGGGDENESRLRIAIVEADRCKPKNCRQECKSFCPVVRTGKLCVEVDSSSKI
+ASISEPLCIGCGICVKKCPYSAITIINLPKNMSKDTTHRYGKNSFKLHRLPVPRPGQVLG
+LVGTNGIGKSTALQILSGKLRPNLGDYTKELEWKEVIAYFRGSELQTYFNKMQNGELKTV
+IKPQYVDHIPKRVKGRVGDIINAKDEKSIAETLIDQLELRHLLDRQVGELSGGELQRFAL
+CVSTSVASMVYMYDEPSSYLDIKQRINAAKVIRNVLNHENYVIVVEHDLSVLDYLSDLVC
+CLWGSPGVYGVVTTPFSVREGINIFLDGFVPTENMRFREEGLNFKIVDQDEIAMQRSNFV
+KYPGFTKTMGSFKLSAEAGDFGNSEIIVMLGQNGCGKTTFIKILAGVSKPDDSDVIDKDH
+YQMPEFNVSYKPQTISPKFEGSVRDLFLMKIRDSFMDVQFTSEVVKPFNIERISDQQVKL
+LSGGELQRVALILALGKKADIYLIDEPSAYLDSEQRITASKIIKRFILHSQKTAFVVEHD
+FIMATYLADRVILFTGTPGVDCLAHRPENLVTGMNKFLKILEISFRRDPMNFRPRINKLD
+SVKDKEQKMSGNYFLLEE
+>gnl|md5|b753a02856604c283d0fe109c0cedc17
+MPVIISMLNSYSGWSTAITGFLLDNSLLIISGALIGSSGAILSYIMCKGMNRDFISVLLG
+GFDQEETEKVVGDTKCYTTSSKETAEILAESSKILIVPGYGMAVSKCQDIISDIIKELES
+RSTIVEIGIHPVAGRMPGHMNVLLAESGVPSRIVKEMDAVNNCMQEYDLVLVVGANDIVN
+PAALDSQSKISGMPVINVWKAKQVVVSKRSLAYGYACIENELFTCERTRMLLGDSRETLQ
+QVYKILKGCAGFVPRQYIDSRVTEEIEEVEDTDEVTTALLSSKQRKSSKTSGNVSSRNKK
+AGGAETEIEKVSISVNKGSKKIALLPIVSEQDKTLLFPIPPSKVYKFREKGYEVAISRDV
+LTSPFQSKYFSEEIYMRSGALVYKNIEELIKECDVVIKMARPSEKEAKCMKQRQILICNM
+HISQYQDKENSQDQLLASLTKNGVTVIALDEVPRTSRAQTMDIRTTTSTISGYRAVVEAF
+NYLPRISKSISSAAGNVEESTVLVIGAGVAGLQAIATAKSMGTKVFAMDSRSTSKEEAES
+CGARFIQVPSEGESLRKEEILKKQRDLIEKYLCISDIVITSACKPGEECPILITKEAVRK
+MKSGSVIVDLCSEFGGNCELTQKDRTFSDVQSGTTIIGKCNYVFSMPLQSSELFSGNLLS
+LISELGPTSDRFKCDLNNEIISKMCVAHENKMLWRPFTEQNQEKHENQEMLEKKSLLENI
+SKQSTLISIKDEDTTASKTSVFCSKTEIDGYLQKVMKEFKNFDKQLNGGVNFYAGVMLAT
+LFFTVLGLTMTTIQIQNIFSFIISTMLGYYCVWDVDPKLHTPLMSVTNALSGVIIIGSMM
+QYGNQTVTYTTLMSMFSTFLASINTFGGFYVTNKMLTLFTS
+>gnl|md5|06b0feaa7dbc581a1cd4f0affad63aa5
+MLDYDQEKNLFDEESISQLQTNRDQGNIPQEKDEEELDNAIEVLVSEKKVWEAAFHAAKL
+EIEEKNLEIESLKKLLIERNQLEMQKEYNRNCNLLKGPFESKIDSNKAVVNSDSTSKISK
+PPEDYIFEEFINIALEETQILDDGDEFVSKLESSGDIEDAYRLIFRSFVELSLNNISQEQ
+RIESLNEELNATQEAVQNLHKTIQDSQNSSKLVSVAYTSQIKSLQEDLLNACKDIDFWKQ
+QCENLNKTDIASIQNEEVFSETNFQGFDPTEWCNLGSGINTMVQVETSPDSYWWFISF
+>gnl|md5|bcc20fa5be377282c3c89ec37537babc
+MNDLDDSTFRFYTSPEDRNELVNYRSSLSKFDHDEFMLQSTARQSGYVVNSYIHGRAASE
+YSCSSGSFRDLNSSAEQTTFERSLSPVNRTLETTTSEVSTIPSARSIAECNRRGRSPSLS
+YTVTTLQAQRGANQAFKGLRNTNNNIGWNSNQLISSNDRNPLCTLTMKSIDLNPPCLSED
+NLSTTRVINNGMLTGSVKNKNYTDKTARSSLCTFFDFCNCFGPRVKDIHNL
+>gnl|md5|c3fef1784564deafb82d2b896a3a4bf0
+MEYKNKKFVVFPDTNTGLERNLTIITLPHPSVCTL
+>gnl|md5|78865fba1ccd80948f72cf32c207adac
+MLFACIPKSLTNVRERLKRRFGEYKTTNDSGNTDKNNISLNKNPKNQYVGVKRSINKRAP
+PIITKKTPSKRAPPHKSLKLNVNNDVSNGNILEFLKKKKNSINM
+>gnl|md5|354fa80b88ea8876214886ca7679447f
+MEDNNLKDDEMEQKSTPSFQPEINENSRQIAENLRKRSILELYDLIANGSEVYDLMNFQP
+TSIENQKKMTKHQILAIQYFVPYVIKHSYKLEDDEIPDNIEKTEYLVKMKYNTTPIMVDF
+DEEMHLFVTRDSFLESMQSYLKLPNGKKFPIPIRFDKKGIPKDCKGEDKNDNLDKKNKER
+NKLIKLTKSQVGPQMEKAINEYLKRRQLINERSNNGGGGDGIYTTEIDPECTFQPNLRKT
+LFEKYRNELGINSITKNDECMQMIKKYLLLDNNDKDEKVESYFKSLQECTFQPNIEKFIK
+KGVPKEYYSKIKKESKEEVNEIESTNKSEMVFFGRDEAENNLDNERIQKERTKAINRIFK
+EVWNDSMNIVFNFDSSKVYSNLIP
+>gnl|md5|af42dd3f91da2c811c74314d605ddf81
+MDFGQHYFSDQVSQVSNGILNYDLFRSSVEQLISNDDSSTIEKNSNIINNPNIKTEIRLL
+SIILTIWGGLLDENSGICLGFNFQKLKNLITVAIGEGIINPSLASISLACILTCIQSPVC
+LDISLNMSRYQIFLDLFELILEILEGMKARESVSEDSVPEDSKESEMNDREHQSGELSNN
+GLKKCVLALIYIFKSGSQTCSYRQVDEKIQKFMEDSTVEIFLRLGSV
+>gnl|md5|7e01f154d2fde3f66552746d89e8d44e
+MTKITREERERREKVNREITRLAQQEKWLESFRPKREEKNRVKVQIKKKAIKIVKEKVSK
+KKKKLNSKLLQELNNEIQRMMTLYENKAK
+>gnl|md5|724c46727a15f76781a610867c489434
+MNIEKEDKSILDSHSKKRFRKAAGQVWVDNTLDEWPENDFRLFCGDLGNDVTEEILANAF
+KKYASFEKCKVIRNKHTGKSRGYGFVSFTNPNDMLSAMKEMNRKYVGSRPITLKRSKWKD
+REIDSDKNKRFDEMTRRNESANALVQDYQKEYKKRKYSDKFQR
+>gnl|md5|154c5eeea88527cb623f2bb7122d309c
+MYSWMYDDVDIIISISARFDLANSIITRFISDEQYEKLKNNELESVEIIPRDNIPRKITL
+ECINKRNLVDYNMLKDSKEYKVFPTNTWHKGRYCPSTSKFYLRLNFK
+>gnl|md5|a9fea371146ebc259d26d09eaeadefe0
+MGNDDIKYICIRLISGLKFLEFDDIETGKPSLKTSQGFKGCKLFLSNIEIVNEILEIEAS
+DRIYRSSFTNNYKALFPYPKKRFYRVDVLEASIEGYTSIWVNGERFEFNSNVIQTGKDLH
+ESWICLVTLIFQMKDLIEERIKKEKELKIFDFENELWKANVINVLKRFDQSWVEFEREYI
+TELIAIENIARRFIINLHKYMLENEILSNNMIGAKMCVNINNIDNIFVHEMHKKEESENN
+GSDGSRLKSEIKCNSLDLVFFELIKSLFRVLNLNNKHSITENINLSTWEQIVQINELAAN
+SPHSSFSVVGAFGMHCVSEMTILLEKVTEICEIPEKIDPHICNNLSLQQQILKVDETWGI
+AKKQFNKLVSMEKEDVDKLSLVQLVKLLQKVFSIQFQIRRRIKELEIGELITEIGSVNNF
+EEICLWENIFVEKLEECDVIALLALPKICCILFLVNPGVCSDMISQFLNNDTTMEYHWVQ
+QETENIEDKLIKSQIFRSIQLNNALSNNKKIESKNCSVKNSFLNMVTLWNSFTEAVLCCE
+DYMNFSTNLLALETGKKAFNKEEILFVYIFSLLTGTCLCGENQISDCKICNKETKIIQEN
+EFIKKSEKLLNSLLISIEEVSILLQRVSVSEWNEFIQTAVICITKSPIILEEIINVDTDQ
+KEIEIEQNNFLLKFEDNTTSTQTTSSNSAYIVSQAKNTDSSFVINNTKIQSFLSNIGSII
+YENVKSYGKFTTTSRNSATPKPSESSTMIVYSNSNSNFDNATHIL
+>gnl|md5|2b93ec9c0ce97975d830ce9f2cae7852
+MNTDEIFEYYYAQHIIPKSLPTSIMDSCFLGCIIFILTYVASRALRANLKEIKRNKLNNY
+QIKKARSTYGKKMMICGVAGRVFGISCLLIILVGLTQYVAHESLNTKGLLVPDIWFSLAK
+DKYKYDDYKGFTSLLAHIILYWTGLSVDFFGFITALRMVFAYVHLFDGVILGIYLCMVVG
+IGLPLMQEGLLGPKNSCNANDHHWYKFDTHEITFFRDESGKIRTGDFRGPTSTNYPPLFY
+SEYITMDDGVKIAVDVYLPRIRFGYKTLPTVVDITRYNRRMDVHWPFTLFSLWGEPKSVS
+MNIWSWQITQTFIPNFYAVVVVDTRGTGASTGHRIVDFSENEVDDFRQIIGWIKNQPWSN
+GKVGVGGISYDGMAAIKTAALSGNNESESSSEGFRSDNNLVDAVFALSSPMNVIKELIEP
+GGLICKPLVEDYYSITYSFEQYGSPLLHFLKTVAYYPFKLVVAFLLVIGNVSPVQGYSSI
+KKQALEMHQKNWDMSKTIKKYKYLDEQVELDDGTLIYAERLGNTEDVATILGNKGVNVYL
+TSGYCDSANSRGVIQFYDALVESASKAYEQYLLEAGNMASKEKPIYKLVLGPWTHSGRAS
+CSPFGKSISCFEPALYYDLVRFMDCALKGICWENQDKNIHFFQVGEEKWYTTDKFPPPDT
+KYLQFSFEKHGENEKSSIQEFSSILGTRFVPLVFQSKKKETRTHLNQSQNNPSGSSSSYI
+QLKVGDNYFSEYRSRWMIAMHPFRVTVSYNEKGKQLWHAGERLHQKRKSRQHIRFATAPF
+KADIRLVGSVWLHFSVQLLDGYDAPIYVYLEDISPENEIMYITEGLAQIGHRHVNMTKSA
+LENIPHGSARKVIRPLTRSYYQPLRRIGDESPMQITLEPITWTFFKDHKLAISITGADTK
+NFKLHHISQNIKIAKTINIKLDNSFMVKLPVNREDYNTWIELNPEV
+>gnl|md5|1c4d69b8be8bc0d5d7830c32f3b9aaee
+MSVLRNKYIPRMEEHNFSKSTGYMGFWASILLSIPVIILWVFSELFSRGLLFESLRISSN
+MRVACGVMAVVAITMVMSIHFLPSGTFRWPCYAFWKIMMGMNILYFMLLTFLLFEDTEHI
+RNTLVYIDPKLIEKVPEVNYAGNSCSIIGSNGWFSNILPKIDMFVIAHFLGWMVKTLILR
+NNFLVWFNSILFEWLEITLRHILPNFYECWWDHIILDIFGCNMIGIFLGNYIIKRFNMTR
+FNWHTCRNGLGGQEYDHKAGDSISNSKRSIKASKEVGSSSVNKKNQKSTSKPRLLKVKNF
+MSSFFKWPKILTTLRGLGSFLILTAIVQLIDLNYFFFKAEFNMPVSHWIFGLRTALLAIS
+GASAVRELYETIARDSSIHFGKVSFQCWLIVVVIFTESLLCWRFSGNLRVDSFIPSNFII
+YIWTFIFFILVVLYLFLTLKSFFQNFGPSDKKNK
+>gnl|md5|2e57068b064b22d9875e55654c13163b
+MLDRGLLQSIFGSDSASAPSGYQLNEVTNLSYIQEGSCNYLEDYLIKKLKRNDPKVKFKA
+LRLIKHLCENGNPTFKMLVQRHANQIRVCQSYKGTFDPVYGDTLSELVREEAIQCLKSIF
+SSNNRSDESIKVGNQSKGSGLKANGSANNSYKDRIHGFGNPNFTDKIEPDNDSMDISQIG
+NSIVYNAKIGQYNQVVDDLSELVLKVLPNKLINGISNYYGNSRNGVKPANFSYQSNPEPR
+RDFRDGFFNSEISRRVTNIQNYQIPTYKQKNFPECKIEENKLQYSKPTITISNQNISSGN
+TLETHFVENYCSSTGLIMNPSNEILQNSIKEIQKLDIPIVIKLLHNKLIDLSDTDTNFGK
+KDNETHNNGNDEKTDSYYIDNNEQHKSPYTSNQTLKSESNFKVIYKILCLILSMLETNQN
+TKKSLIEYSNNDFIHLLNTISTSNIHCRRKVKQIIEALGASTSTSHAVPHAPQCPPDVEL
+TNNLIDLSTESTDFKADKKLNSVTDLTDSLLILSNQTQENSYKKNNLFKNLSIKNHSNKT
+GAINSRGQQQDKQTKGFGSKENVGKSLVDLGIL
+>gnl|md5|4efe478f2d91cd6d6de0f272f886af14
+MIENQLSCSSAGKMKEIIKIQEQLRDEVLECIQSRKSKMAELQGETEELGNQMIQEVTMK
+VLHRIELIMNTLESILCRCEKVEAKFISYKRDLNSKSQQVGELAERFESVKHELKNYFVI
+IERIAGIFSETNHLNNQMIKTINDKLSRLSCNNSHIPIQEQIQKFHENFENNSKLNVFNP
+NNQFSNFVLQEFKSIQNAINSTSKLRQEADDSIANAMKEFTDTLQNGLKIAVSHSKY
+>gnl|md5|bc4b9a9e8fe35b030e32f18c7e65a061
+MTDILSTNKKFASAADYCANNVSSFSNEELLDLYGFYKQATVGDAPEKSGSFFSAFSMKD
+QAKSKSWASRKGMNPEDAANEYIKLIEKKNPQWEETIGKNSSISLSNSTSRPLLESNLDE
+EKLEVELKGVLDQVLLDPNFSEKNCSLSVFDAFCSQVNKNEVEFLKKILERYPFLSNSRS
+SEGSYALHLACDKGYSEIALLLLKNGANPNVKDNFGDSPLHVSVISEQESCVKVLLNYGA
+DLKLTNDDGLTPIQLSENDQLKRILESS
+>gnl|md5|7df12f7bd962310c7d5328e21948ecdd
+MCNNNFFCFESYPTNNRRCSCCCFDLRRGCSQQLMCANRRPIVQRYICRICIPRVNRMPA
+LQNRNTCFECSACGQKAGTAPIQSQKPEVLDKCEHNQSCSYSQGSIQKNPTGGYRCGECC
+IVFCGR
+>gnl|md5|327be46953e976bc2eebbd10d10a4f2f
+MRIIFLAFLVVIFFFIVKTSKGEENEKLIKISRRFLVEICKSFQISKNPEDLVNCYESSI
+YFCEYLWVIAYIIEEKKSFKTQMILPKGVIDNKNCMEINFQQCITIANFLINESSISVEY
+NAINSMVSPVIEECNFENTNLLLSLNALWLRNSNKISDLTQGVIIGRGYQELVQFTNPFL
+DLSTIICQDVKMYLFTEKYKMKLKAVMKDLIQYKNLPLTIPDPVYVRLPLKYDEELDLNW
+LYCQDLPKYLNKLDEISDQIKLDLRGKSLIINKDIITKCTLKNNNKVMKIITWKIVN
+>gnl|md5|5d19d271eaa5e0542d40eee254930a71
+MSGDWCTIESDPGVFTELVERYGVKGIQFAEIYDYSESGMEFIANEYGNIYGIIFLFKFT
+EKFKGNHFSQPIEAPPGMFYANQVINNACATQAILSIILNRLDIDIGSHLEEFKKFSSSF
+DPMTKGLVIGNSEVLRTAHNSFRPISSLEVSDPDSNDSKGDAFHYICYIPFGKNVYELDG
+LTTGVVDLGSPKVNDSENFSLDNEISALYDKPNLWVSRVMEEVKRRIELQNEDSSHGEIR
+FSLLAVVPDKISVTEKKVKYLKISRQAHIAKLLSLGGDLSTDLESLSEEEIESDEFDSML
+SSIPNDIALIQKEITKITHEISENLSIIQNEKYNREIWIIENERRRHDFLPFVLTLLRHA
+SKKGLLMKKLSQLQ
+>gnl|md5|ad2482e65cbf3cf8b2a28e83ef7f2ccd
+MIRINSNKSEGGLDDTGKNAVRQTEIALIRSPIMSMLSVESGKPVMFQSFRSPMSGHVPG
+VSLESRKMTLGVRIPRDSTYCNSIKQPGFKLPPKADDGSPKGEPEPQVNINPLILWISSE
+DGEKRVIEVDSMLTKWLREHQRQGVTFIFECLMGLRDFDGNGCILADDMGLGKTLQSITI
+LWTLLNQGFDGKPSVRKAVVVCPASLVKNWASEIEKWLQGKCKCTPVAERDREKVVSAFA
+GFKYDTMSRILIASYETFRMHVEQLDGVPIDLVICDEAHRLKNDKTKTAMAINNLPAKKR
+LLLSGTPIQNDLVEFYSLVSLANPQVLGDVSQFKKIYANPILEGREPDASEYQQELATQR
+LQELSNITNHFILRRANTLLAKVLPPKIILNIFCNLTPIQNYLYRRFLRSSACKKLLDSD
+STGNPTGLTGQVLSSIQSLMKLCNHPTLIRPKTSGGYGKGFEGSEKYLEMIHGRSASGES
+GGEYKKRVTVGSSIRNSNRTGFSSKPNLSGKLYLLSRLLFHIRSNTKDRVVLVSNYTQTL
+DVFECLCRDLQVPCVRLDGSTSITRRHNLVKTFNDPNSNSFAFLLSSKAGGCGINLIGAN
+RLVMFDPDWNPANDKQALARVWRDGQKKNCYIYRLFSTGTIEEKIYQRQLCKDGLSAMLV
+TSGGNNELKDSISADLVRDLFTLKEDTISDTHDMIQCNRCHDSSGQPLDMVPQTTGLEDD
+LNTWGHYHSFSEIPDEILSLTLNECSNETNKMSVDMESEKPHPLELPSDFQPVSFVMACR
+IELQDQEDEQSKESNGEKPMEVDKENYNKDNTTCNMDDTRTDNSISFVNPVINIFGGHVS
+PDAKRIKDSNDSEDDYASEFDMDEEMEYYSSSDSGME
+>gnl|md5|5853c3d376eba52a1aada4bcca050c48
+MKGEVSLIEKKHITGGNDEYVSAVEVKKTAQQQSEAAKDIMSCSNLNIYYPIQTTQRKSN
+ETDSEGFCFEKNQYPSSTRVLSELDDCIEESFESLSGVGKTCNKTISRKESLECIEWSGE
+ERVFSPETKFPLSKIEFYSNWKNIINHQDAPRTPQFRATYILPTSPHFSDSDEFYSDSSS
+NSSESLLYIQKETPIMRKNNNAFKANSRRVNGISWNQYEGANEVNYNCISPSLPIPSSIQ
+GRNRLDILLSQWVSYFSGRQSIDINDIDCATQYFTGLDGATLAAVTSSLIYIGHCARYTQ
+IRKYNQE
+>gnl|md5|c9dc9b596005bd2ec99b65877ea70aee
+MSKSRKNKSSESSSHPKSRNESRVEYLPDPHRMLAKCEFREFHSSLGSFGKFSETDHCQR
+SILSFALSLMEGLFQSILCSGTILESLHELDHDIYSYQEGKRQGSLNLSFKVISTEKKGF
+TLLPLDYKGFNKSNFKDPKSKNDDENNFSENDPLVPPKEYLDIIGYKEPITKATVFQFPF
+NTSPEDLITEKCIIDVIRRRIEDKEWLSRLEIICGWLGELARVIRHLVKHFPVTYKRFLE
+ETDGRIYTSLRCPLFYMALMKLLFDEYPMITETDEELNSKYPGDARRLINRIRRNKLPGM
+RLVEIMSRITISFGSVLESMGGSPAWRCNPEFAQYYLHMAFVFDDSSLFTHIAAKSQMFD
+YEIFEWKYTLNSLAQHIPLLNSFLKPLATSIMANRVQTRLACYLKDLNRKAHAEDGANSE
+KSIKLPKPVVGNSLEARFLTNEVIKRSKAFFGNFEGERLISSVKLEFENWQYKPIRPVEE
+IQKLASRKVDLDKTLKEYSRTVLVPEKKSRHAKTVINNVLPPLTHLSEKKKNILIKMAPG
+QKYAQSFYNNKVSIPVGMMVYP
+>gnl|md5|d4894ae0dc25645ddbdb90323da31009
+MVLDWSLCSSSRSGNDSKKIRSKVNNLSNNKEFSNSLNKREISSRFNSSSSLTQSTRTES
+KQKPSLLKKSTSNNETSKNLSDINLKQNSREKPGDVSSLSNKSKSPEPEEKYCASCKKKI
+LNKEVDEDSVEYHRNIFSLRQNVTLDDFHTISVIGQGGYSIVRLVFDIHTGNVYALKQAK
+KCQIMNNQSQHDNLENLIKIDINSSKKQVEEKQTLNTGIMLNTEISLMYNSDSPWINKLY
+YYWEDNHFYYMLMEYMPGGDLMRHLIDLHTFDEETAKFYIAELLLALDYLNNIQGHIHRD
+IKPDNILLDVDGHIKLIDFGLSKQIIQSKQRPFVSNASVNSSFQKNVTARIDPHEVLIHD
+QNFHAGTPDYMAPEIHRGEPYSLCVDLWSVGIILFEMLFGGPPLSDPGQNSLITRNKVMN
+WDKHFYLPSEHHKYSPEAMDLICSLVCEPSQRIKSAKEALKHPFFKGMDFTKIRLQKPPI
+VPKVKHKLDHSNFDKFPDDLLVSFYNSAKASTSVPISNLSEELNFNSCNTNKIQGESFVS
+EFFPNSMVPGASHKLGNSQSVIEHCSIPTVGNSKIPICTPKRSYLPLITHISSPLSNPST
+ASSWKQINNSPIFQTPRKPSPASNNISSQSISLNSHILPQSHSFSQIIGKTNSNFSNPIG
+ASSCIPQPFSNLTPIDKISSNLPKSTIQTSNSNILNRNSGTPNNHKFLTFKERKSSENVY
+SRQSQKPNTHLFPQRSTSTSITRNNQEIVNILRKKNII
+>gnl|md5|003700286e0f55d5aacb5ca802c1f70c
+MNIIWGFKISCLILVALLQYATSDQKVEQKDPYRSTMRVEDLNNIDRKRSKADSYVFSDN
+MLQLSAQFPVISPFESLSLVWLSIYDKIQIRHRNEGALIILFLLSPIYRVINDENFDGDE
+LFNEMESFDEQLSQVIYCLIQTNHGINCESAIEDFTTFINDQILYEIQKHKNSDYDINMT
+ARIDQITDVLNTIKNKQLYIIDKENQIKMYNTLNPEAFIFHIFNIGNLLEHYMDFNSGIS
+FIAILGPLRTFLDLMNKNWGIGENEDASRWFRNKISPLKSVCDDIILGVNKIREEIDHYF
+QSKSYEKLIILTEIKLYTDSLKQFCTDYNEFLNLPDEDPKKTKEISENLKAVNLIFVDRK
+NVILGMQTSKLYEYSRKAADTNSQLCMVESDKKVLSSQGLSEYEMDQDISITLLDLIGQF
+FLNNKIDTKFNAWLVNTCPTTKNLVLNSKFASIGRSFGSIGNQVKNLSTILSARRTNLAS
+KICSRLNSELDDANYNNRRFIIINRLLIPLVVNSSLPSIIPGNAQIYKNKDSTDNKMNLE
+QVFVDTDRSCLINYFDTMNYYIRETTNICEKIKDHSTLFGSAFNKIANQKAITQMNQNLQ
+KVSQSQLLHEFRELGRDLKGSKYGHFVSEVGNNCFSSLMHWYHFSKKRRKLKGARRLLRK
+AFYTYTSTFRYVNVEL
+>gnl|md5|47b95033f681d8ffd394fcbea65db364
+MADQDSGEVLGPCLSKEEERISEIIDAFKDTSILEKSHSESESVSFTSALEESDMELVEE
+LDPVSSRAFLDRKMNSLPQLQETVGNLEITKSTSMTNSGNAKPIQRNIGGVEIYSALNPF
+STTLSCLLIEPSESDIIEDEIRYIYLNQILSENEQLYLAKLRKYAKNHGYKFPHSIWIQA
+LRFLASSRFHVQTALEMMVSNHEFRIKELPISEKDVMNDLKVGAIYWHGKDIKCRPILIV
+KLAKLDTFVGEIERIQKLLCFCLEFFLKYLQVAGRVENWNVIIDLAGKGITDLPIQVLKS
+VLSLVNTRYRMRLYRMFIVNCPKFINVVSNALVAAIPGSSVRKVRFIDESYSDEITSLVP
+LEQLEESYGGKCPNLTENFYPFRFYPMNELDQKFPNIHAIIPPEYISGISIEIPPRFDLT
+KLPWLNQIPNANFTKKTAEQLSQILGTEIKPKITTEDITNP
+>gnl|md5|1889c8874c9e3689151a4785ad9425f8
+MSRTKKSWKRNNSGFQLYIKLIPAILLWIFFISGKVSSSNTYENLRSSRTANYSPLRYEE
+VSNNFQEDNKQHHSFEKIRNSTPDGSLSTRKSSLGSAPDETQKKDPLLTQQNHSSAFLPE
+IFMSQLDMEYGNRNQGSGRITDKSSDERPESGLNLQISSLSTSPETTLESDLQKLSSEPN
+SSINTPLSSSPPPAPPPPPPLPNQSPTNSPSFQMLDPLFDPINKKKQDEFIKDLTKIKLV
+SDVLPIPFKKSEQKYEFNYSRNRNQSLNNYKMKNLAISREEFKENQKKLEEKDPEEQGKA
+IDTPEKAEEDKIEMLPLPLGPPIPGTEPGIEGLSHIIPLDKAPIRPQKRQDEWECITSQV
+ERDKTTWKIEKGKMRFNYIPKFSEINQSVFPLSGDPKSLYYNCISALKALEAKLIITPPS
+SDEIEAEFLRTTFCISAAVFCYVETAMGDPELQLFWNREVRMITDALVARDPNLDLLQVV
+GESLATKIDTHVGSTGIASPDRLPDFMPQRMPNQSFSFASTKLETCPTRNQRTDQGDYEY
+EGGLAVALSTNINGVIVDDPEIWTMWKAIITQKDRDLNMNLKRFKIFSKDFPVKFSSDTK
+PKKMREMRNLCVELIREGIKENPPRYELLPLAKPNEEQVLNEFCNYAADYYFGNRQWSYI
+YDFSLNSKYINGVPIYRPYAPFRYFAAETFNEMRNNCCSVIYDLFLSKVFPHLSTNHYRD
+KGASMDKSKLERFCHEAAGKYFKKDTSEFDSRLKNVGYFDFASYKSRVTNYKKANYQSLV
+LEGMHDLEDTPGHFSIGSIDGNLSYTPRFPNLKPTRVCFSQWKAILDQNKEDLKNNIETP
+THLPDVIPSEWNMPQFSRATFKITCFRILRKLYREGSVSLRSSVLRSSSVEQNMEKIFSD
+FCTEASKRYFDGLNTDYSMESLLQVQADTESQWNSVVEAIMRLQESKKSTTIYWVYPIPP
+ESYALSLFRYNVNPSSEDEEEEEKIKKSFWKSKEGEVGYETRCIESLKFYKAKSDEEIMK
+MEVDTKDMALIEMAMRKVCEEAADSFFGAIEWIWMYKLSNIDNINKYATWVPAVTGLPKR
+RPISSLLKYKGTGSIVQFRNYCFAFVWTLWKSGNEPDLRISGKLYSPGEGSLVDQKAQLE
+RWCTHVANEAYNSGYKLSLEKKKQEGIVDLMPRADPQTSLSAVEHENKSEQESAQVIEGE
+TVVFSFGNAFSQWKMILSQVEVDRRRNIKRIAWLPEYSEIKEYFPGPVERRQFVPACMQI
+LQKLGERGLLVWGTVSPEYQGVVIREFCSDAFMNGYEWRNDDSNPISAPYGEKEANRELL
+IEFLKFMHTNRMNIRKWILFYLNENLNLDYAITWAINEDNWGYLNDYFHQSQLHEPENFD
+QLFEEVRERVRQMGGFVDASGDDYFSNSPTARENLWKAIYNQMHIDLLLGRQQRVSNLPL
+NPPEIWLGSKSPEEFVADCKRVITMLQGQTNPDLPSSKELTLKEILTAVRVFASGDKDDS
+EILNSYCDDVLLHVSDKRGSSIFKGSGFSYPGAILEFERNRQWGVIANLESKYSKLEQRD
+VDGKIGSISRISKIPGFVRHTIFQGSYDMEEFQSQCEIALQTLATDINIPSHLRVVFPDM
+HAGEKIEDIIKEYCRTASEYAFQEKVDHALSEDATEEAAILNDLDSVSRKFKLRNPLGLD
+YSKRWNSIIDLAKKRIEEEKYLRMNRVLEIDSAWLKNTYPEISGKDLKNAFDSKGNNHLA
+SFVLVSYELFSAILLGKEGNNGANKDKFKFISRKTLLQFCRDVCYKYFTDEARGDVNYSS
+RDKAATENALILDMIATRPRIGPDPRDPLYELYPEQGEEVPELNSFNMDQYITSRWEIYK
+KDFESDSYKENLRKNIMDSLTSAEINLLNPGSGKPSPIGNNIVWAPTAPYPWKHHTASKI
+ALQGNAHASSGGTVLAGKTLEHMKSIFGGNIADVAKVAVIPAIPDPNSRKQNGKPDNQSG
+SGSSTDFGTSNRILPLGDFGETAKVKRLKIGTKGGRPIKGREVNPIEDKFDQIDREYKEL
+VSNSFISKGTVGENEEKNIISGIKPRNRSNPDRISQEPKKKIRSNRSKGSRSSDASVAEG
+EPPKGSLEEKTLTKEELASSRLADREWTVISQLGKILPANEGSNLVVGIPIERPKDFYKK
+PMGNVRGMTEACFSVISNAKFRAISGTRISGKTKEERRQNANFYCRKAAEAYYESIDGEF
+IPPKGFENLPGFYGLYSSIGKSKAVRGRGNRVFLGESSANPMGKEVGLKPLHKESARIRR
+SFGPTVGSFGLNVHMQNQSNSLANTYSKISAADSTVISGFGISGKASRIKRSVFTDSKNN
+VRERLELSPGDDLLTDPDYYNDMKPVTTPNSYVEMRPSKGLGSGAPRPGRSPKKDKFGNP
+EVYYVHPRPDLVEEAKIKSQLARRINQFSTINKPENKNRPNSS
+>gnl|md5|a13bff6475a866bc5c6f505f259c4450
+MASDESEPVDPFDNKDFLINSVSSLTSNAIRFGVYHYVNKRDSKMTGVESSENLETSEKS
+DKKSEKKSEKKSEHKSESKSDNKSEKNKSNLRPEKESNESQKEKSGSRMKYWWSKYIRRQ
+KKKKEESKEKQTNTHRNQIDSYEYLFFGSDPGNKSNSTFGNPQATRELFIQDMTSNEDIM
+NSNYNGNKMRPETYVPLEIKTSIFAAYFAAEPVVIHFSKTISRNRRVKYGQEIAVAEAFP
+RTINNSLSSIILARCDGTISIINQTKGLPIQSTRMFLVITCNDTV
+>gnl|md5|12f58ed997e9717487db0ec4b1e47c9d
+MSDIGEKVELHIYDLSNGMASQLSPMLLGRTIEAIYHTGVFVYGYEYFYGGGIVCVRPEE
+ITRLYGLKPIRTLTLGTTKKSQKELNSHLESISNEFNSDNYDLLNHNCNHFSDNIVKFLI
+GEGIPSYILDLPNEVMRTPFGSMILPMLQKAQKSQAIRSVANVWNTNGINPSNVINKTAE
+EFSYLSSGSSSTGSSRTSHHSRSSGSSDSISEFSKKLSTVSNKYGWQCQRVLETLETILF
+NIISNPGDLRYRSIKSTSNTLKSVLMSIDEGLELLFLVGFREKQAEDQLRYEIQLSQPLS
+REEREQLETQINLVRRTLSSLGMASEQETQESACPESKASNGSKSESTIDYVKLLAEVKE
+MGFEDNKKILQALHKTNGDISRTVSILLDEQSQ
+>gnl|md5|88ba8acae81d321d2ebe111b93398e2f
+MLNILKVGDNQTIAQIESADASFIVGTGGRTRRKLAAVSGTSITIIQDDSKTARVEINGD
+AACREKAYLYLKYLVQQKHGPVTIDVTPDSRDDLTIVNVPALCVGYITGKKGQGLRAIEE
+DSGTLMFFSRPEEECPTDSTPPSNGVPMNNGNSQSQYILAIFGVARNRRAAELRVMCYIE
+QKINGHFTKDLKAESHDHIEDLATDIVHIETEDLSYAVGKEGNTRRRLCASSGAIIEYVG
+NFAFIHGDLSERKRAKEYLAWLIAQRTSTVSVDTRAREDVTVVSIPQNVIGYVTGAKGSF
+LRRVEDETGTFIFIDENKGNVLERVLIFSRSAFGRQKARDFIERRMYEKLCGYADNKNYP
+PNGNGFNSRNMNGIRKTNGITLNNSHFDHPMKGNFAAIPNAFLSQPGISGLGAPNMGIGR
+RSRTRGGAPEHHISDKSSGKPAGLYGGNLVPFGLSGGALF
+>gnl|md5|303c943043c6011c9dca4b76da1b27f1
+MGSSKIRTAAAVAGGLAVVGALLYYLFRSDSSENKDESNTLVEASVAKDVPENTVKGSLD
+TFTKEDMLLLLDEILESQNSLKKIMRSLTNDFVADPPKSLQDCYNKVKDASPQDPLDKRK
+ISLVDFDRLVERFYNDEGISSAIEKIMGIHGPSSITERAGSISSDQLVKVNEFMLKELRE
+FVDQYIFIANKDQFDVKTLTIAAQVWVGSKVEKQFNLSSDDIETAMLLHSQTLRNDPDFG
+RISFQMQATMEQLLGSPAPTNLPFSI
+>gnl|md5|409d2e0218b253a19826d5e9b5756b45
+MLKDGGVTNKIPEICQEMTIFCFCNNSELDGIINFKEWVVNGAEEHLLNNDHINIVGTIL
+IELLNNIESFQQICINLRIYSCSKCLSRLLDIQKFEESDMEDLVYFIGMIFSKILLQIFN
+IKLVNFDRIISLIIDLIQNCIRYKMTNIESVNDNENSIKNTERIHELIMQVLSFGIIQIS
+LKNYDDACLALNYIANKYQDIDRLVSCLKETVLILFKSNKLEFLENNSHQYFLSCFLFYP
+NIIHCMVRIILSLNGIDLSQPPLANIRINDSKNLEVYSRCKNLLQECFESNKNCINCEIG
+YSLSRLCFEIDDNIDKSIGIMEKLIKKNPFNDDFRSYFGKLLYNKAVEARKKNAGFSLVK
+SILKKVILYIPQSSEAYTDLGIIYYELGKEEKAIWCFKLSIHFNPMNVNAYDSFGIILRK
+LGFIDQAILCYERISRINPNCITTLNVIAALYGNIGKIDESYEYFKRCIEVNQGVPDVYN
+NLGVLYRDCGNFLMAKNCFLVALELDPNHTLAFQNLLYILNYFIPLDNPKLIGNIRNNSI
+ESIINNLKDSEKSLCLDISSTPESYACESQIWINNSDYYINTKICMNYLWNGGINSSRFI
+KKSRTRLDDLIPIAEIPDIESTSDKQLINIGFVGAEYFXSCSCILHFSSYKIFN
+>gnl|md5|2fcfbd24c6c63f47b87ed5bec1470444
+MNSAGPVLSMRIVHDKDTGLSRGFSFCEYRDIETCIMAIKSLNGYELRGRSIRVDWASQD
+MRSRYNHLVVNNTSGAAPVTATTQGGIGMGQQGTEGLHHPISLTAPSHVQQIQEDGTSMP
+SIPNNNANFDNISSEIIQLVQGMTVSQLYYLIGHMQKLVVQNPETARSILLDNPQFCYAL
+LHSQFILGMVNEPFVPLNQEQLNKANEIRTKVLALRNENSNINIKNLGEDVSVLIEEIAN
+NPNPALLQALGSIQPNSVAQWTEEEKSKILAIQQALKNRGLIN
+>gnl|md5|d330cd9acc05c5fec7a3298085c16e86
+MGNRISIDDSIFELKLQKKELERQYNKRDRDSKSERKKAKDAIISGKADLSK
+>gnl|md5|10c0c26f5c5ab97ccf383f4986e39242
+MQEECKELLIMISKLDRLCARLEKASSKEKISTQLLDIMPKLKKQLSEEGVMGYSNMGKI
+KEIGQLLNTIEDSQPETVGENVGKEKCMHAEDSVERLLDELLNEHAMEIDLAISSKTEIN
+ELLEEKLE
+>gnl|md5|b97b05f3d07885cf93a1f49c2e03d979
+MKQDLTVVKRIKIEEKCKKVDNLDIKYESETDIENKAGYMNSEKYTSLFDGSDRDDEDLN
+RGFKRLVRRKRSARNLSDSSSVSSSSIESIGKSDFTDLENSSQDDQTLEEKEAKRLRELM
+QREEDALSFCLDISSKMKEGIVDFFVGNNADNETKKQIIDNIKNGHCNISKLTEELKKSE
+IFEYINSFGDTRLKEYQIVGVSWLLALHQNSYNGILADEMGLGKTAQTCVWLQYLFDSGK
+LVKPVIISCPASLLDNWTKEVSIWAPRIRAVKYHGSQKERRQIADQLFEEYEESRVDVII
+TTFQMLSNKMDINMAFKHFEFSYMIVDEAHNIKNSASQRYKSMSRKIQSERKLLLTGTPI
+SNSISELSNMLIFLMPEVFNSDLLEDAYNSYKRKISNREKLDEANSEVLFLQQIIAPFVL
+RRSKQDVLSCLPKKHTFIEFCELTKIQKKQYDNEIGRIYMEKDSVNDSKDSNMLDKDSNQ
+ESSDEKKLINLIERKIQDKVNSHFGDSASAENEKESEDDNLNSNDLKTGLQDYDQDQEQI
+EQVKSREGGKHHYDPKYVNSIIFRMRRICNHTLLHQGHYTSKQIEELVDYLSDNVDEFKG
+YSRIKVEQYITQLCDYEIHQLVSRLLIVKNSPLLERFRIDDELIINGSCKLRKMNEIIQS
+TVIENKEKCLIFCHHTMLLDIIEEYIKIKYNMSDFYLRLDGTTPILERQNMIEKFQTTQV
+PLFLLSTKAAGQGLNLTVASSVIMMDLDYNPQIEKQAEDRVHRIGQSKQVKIFKLVCKDT
+IEENIFNCCQSKLTLDNAFGGRNQRQL
+>gnl|md5|322777d132ab5e342804c8906b93949c
+MITDILEALETEYNTLLLNLIKAYGTKNEDENIQINKNSHVFNTMTTLTQVIISLIAFNI
+KNPDFEISNSFIQSIKLLDEKLKTQLNKDSCSLISDVISVLLFRFGALKNTNILNQINKR
+FKTHYYSSFVLNKQTHACILHAILNCAGNRGIYSKEDLSFKDKIDHEIFVPKEQDILMKS
+EDECVNCIYLTEKMLNDRKNLIKIIKKKQEEINVLVKAYMESQEALRNISTNKDESESNM
+GRSERKDVAIDKPVDTSDYFALLEMVGILYRRFPNIKEFIENHLMLSNQVKSEISSILLD
+EDIQNFEYEYLTDSGEILLEERDQQNVENSTTIMFDDNTEDKLLPSELERS
+>gnl|md5|1e595dede14ce8f6d44cb871c22e4d44
+MWAFTQKASNLKILKPHPFVLNRSTKYGILYLGVFATSIRGKKAFFPSESNLAQGNCMHA
+MTISTFKNEDLAKENKLVNILKKSRFIQEKDSKNIEILTKYLWPKNREYRKRIIFSLLSL
+GVAKLATIQVPLLLSRLIDNVGAISSSNLSLSLTNKLNVFFLISSYGIARISSSGFNELR
+NALFSEVSQSACKDLSLKAFHHFHNVSNLSFIQSHRSGELLTIITRGFKSVSKLLNIMIF
+QIIPTTAEFLMVLGILLHKVGSEVALITLATMVAYMDFTRRITHKRTIYRKNMNTSEQKS
+NGLLSDSLINAETLKYLNGEKYIYDLYSKYQEIYKNSNVKVQTSLAFLNFGQNFIFTGGL
+LSAMLITTNKVLAGTLPIGSIVLVTSLLFQLAIPLNFIGMIYRESKLTLIDLSKLNEYLT
+IKPKNSSNSQDRTIQLNPKTKVLDFYKEMNLNGTESSSEKNSIKLENVSFGFPSTFGNEH
+TYIETSNSSDDLVVNDLSLEIPLGKRMGFVGSSGSGKTTLAKLIYRIFEPNSGKIRIFGK
+EIEDYEINEYRNCFAVLPQEVLLLNMSIIDNLKIANNNVTLDEIKSACKLAGVHENILKM
+KNGYETIVGERGCSLSGGEKQRLGFARMLIKKSPIWILDEPTSALDLINHNFMVKMLSFL
+HEYSLSTSNSVNISDKYDLGSKYKDIFTLIPYVKDKKEIQSIKKLIDDIVKLPLTIIVIA
+HRLSSVRNFDLIAYLEEGNVKEVGDHDQLIENKMQYYQLWNKQHIDSILK
+>gnl|md5|ec6c3e404eab2ab65441a4261cb48820
+MKKQFEVLYTRQKTQKTKTWHDGVVVIDNIKGINRISLYKTDENGYKGDIVESFSFHVQK
+INISKISFPGHLIELVNEEKIEEVELEADEDLDANTSSVLKGTPNKTPPKSPENNDDNKN
+SLVKKNLIRPFKAPLVKVNMDICKSAQIKAPKKISKNIPLSKISSKQGFIKALERIYN
+>gnl|md5|da1636b42e9085e8946711e1b4e5c299
+MFRNESSGISEQEKLELVHAASFTRRDIIRIYSRFKALDTNQNGELDPHELFEMPEIADN
+PLVKRVISIFDTNKDGKVSFVEFIIGLARLAVGSNPEEKMKFAFDIYDVNSDGWISNGEL
+FKVMKMMVGDNLEDLQVSFGIMPLLLSEYFNLNFTKTN
+>gnl|md5|3dcdb37ab07b3aa7521350361547a6f2
+MIKSTNMAGTDDILLDHSNGYDKFRRKVLTALPVIFVVVIIMCLYLIYTFYHIIPLIKEN
+SEAGITQVVIFNIFVLMTLVCFVLSILTKPGEIPDTPEWSIKTTGGLQSDLKSKELKSNG
+ERRYCKWCAKYKPDRTHHCRVCRTCVLKMDHHCPWISNCVGWGNHKHLLLLILYSAISCS
+FITITLGPTLNKSLNMTTIQFGDIVALLLAEILSAFLVVVLFSFFFFHLWLVFNSMTTIE
+FCEKSRSTSYTNMWFKGYMHSFKQVFGSNPFLWIFPVGNQVGDGINFEYSQKPDRDIQNN
+EHTNGSNNVSNTNTDVVVDCQPKTTEESSLLLSSKQESGKIRDDSL
+>gnl|md5|48d850f0274029856893acc8892f1a0a
+MLNKETSNSLKIPEYCFRRRNFKGEGELENSKLHAFTDECWDSPRITPNFGDENDNLLPN
+RTLSRVPRIYSLAEGDFEDFENKPEALKPLFDAVRESSSIDSEITIHAEEYIEPANDGYD
+YDDDDYDDDDEALTPLASSAARYRLYDIDWDEKLRLKKDEQISNIHEIQDDIKLKDADFC
+LLDSTGIKGPKEFETKQGKVIISEDGDFSFEFSDRRKLFTVKGGGCFVLVSDVIDKKRRF
+SGDSSFESADATNQEYNESKYHVSELPQQHLKRYIYGTHLCETIKSFIPKVKLKVPQEGT
+YFLMSNHLTFADFRAEFISNLSDQVLSAHLTNYQSTVIFTSKSGKRVELDKLILDKMGVF
+EEVDQAFEEIKYNDYLIKKSHEVSECGIKWSTIIKIWRLILDRLVDCKNLELKGLKAYSE
+SLISSDVDLTLCESFSIGENCMMDWHIKKSVFENIFPIQVEKF
+>gnl|md5|0d2af62666fa6f1ebcd25d84d1d31bde
+MFIIILEYMASIESKLNFSEKKVQKHLKSFNQSNLTNFYKNIHLNDNSHNVASERCKNIP
+YHDILALIRFGMVNNGLNKHSFKYNDIASSLKSLKGFTSK
+>gnl|md5|b469349756ccd204a36c21ceacc09af3
+MPAKEDFKPFEINNFLAEFRSQVSKRKKRFQEQPSSKHLDIFADGRAKLMVKKTSDNNYQ
+SDIKRLIEFAIDRSSVQGENSPLSPFNTDLLFFNEDTTSSSVYFEWSCTDCPLYMPKMCN
+CGTKGGENLYSMVCSNESCEGLLKLPYSLIHIPLNRKINSVQSFVSENMGIPSSILIYYG
+KLKNSLLLVLFDKEQERNLVRALYNASESIGCIALYDIFPDNNKSRSSRRPYTTKLKYTG
+QIRNLYK
+>gnl|md5|404b30c94c39912b5ae335d097f4857a
+MYKVMNIIREYCMGNKQIKFRALNLQDSSNVNGYNWEVGDANVSIPFFGIHGNHDDPGEE
+GLLSPLDILESARFINYIGKNNNVDNIEVFPVLLEKGSTRLAIYGIGNIRDERLHRSFEK
+NKVKFLIPENTNADSEWFSILLFHQNRKKGNFGGTLSKDSIPESFLPDFLDLIIWGHEHE
+CIVNPVEVANKNFFVLQPGSSIATSLIASESLQKHVTLLEIKNNTFKTTPIPLLSPRVFI
+HDHIVLDKDLVQVEQHLIEKVHQLIEQAKIVQLEKNKLNLPQNPEIQEILKNKSMDLPII
+RLRVEYECDSQLINSKRFGFQFVSKTANPHEILMFSRRNRNNVNKYNDQEDPIGLNSRIN
+PISFSSDDSNMIESLTIHYTEKLNGLEVININDLNKAIDLFVNKFDNHSIENCILNAISK
+SNSFYKNNKNLEISDVLQKIKENNRICKDEFGISQIDSIMSEGFSDSFSEGEISDSSDHI
+KQNKRSRENKNITNQRKSVKNEKMGEISDSEWN
+>gnl|md5|cdce8671eec86cfccd5a00824f603060
+MLINRWVIFAYLFQLLWRYIISEGIQINAATKENDVDRYDIIADDLLNMDFPPYKFRDLK
+RKSRVIIEANNRMLHVLEDLLIISDEILEDFSDPSKEPYFLEEYKSISLVSLILNVI
+>gnl|md5|e698a196b02565be12734cec0d571d7a
+MLESLPSSKPISYFLYNDATEVYRKAHIELLKDYRVVTIRVACRLLIISILLSSLENLAN
+KEHSKSLNISYPFLDDIIIRPKSTARSNLTKVLNRILNSIRNYGRRIKIGIKKKVGMSDE
+FEIVSADSPELNEKEFLSAIYNHRQSSARSIFGKDEAIFENKQEVFQVINNFIGKQERDS
+GILLQILETVIRKELGIESSQELQWNSKAKRKLTNVCRDSHVLEILPNRIKFKTCRQLFN
+KAGEILTGSHYKNSKKESHMAGRANVLKKIRRVSSIKFIQVSIKLN
+>gnl|md5|3d4490e8a158310e7201869d85a6b148
+MNSWVILFIFLLLSIIIVSEAQIKLWNLKKTKNNDRYQQLLDFFVEKSKFTSNVELINLN
+SKLENTVATQKRIFSKEESIKLVCENSLLRLLKENIVDSKTFSSEMSVFRDSIHIWTKNF
+NILQESDQVCTLKEFIYFLDYINTKKFEIDFCIRLLKNFQNQQENMFNKDSFIRKKDLCV
+GLQQDIEHFISTKLSSHSLGVLKQHNKDIGDIFQVTAKSIYNDLRQAINRVNKYSKVFNL
+ILLLDEHKNNLSRSKELEPYLTLSGFIDQDTMKSIEQNIIGSIIELQEYLPENTIFVSSP
+LSKIVLMELNRANKQLKQLKNCFKYKHILVPLEKKLIYMMKSVSNVLVSYEKSFEILRET
+LAHVSYIDITYDKNLVDLCSYNFEKNKKELESLSQLDNILNDSDFDKNSLSKAKLNPTKL
+LPYQFSKTKSSQGVLLENRNAKGLPFFPDYKEIDILQEKFSDKLSSKEIQKLIQHINLLA
+NELDHVYMYINNSTSIMLNSLEKLKFTNKVYSEIILSSAKNESVPNSLYSYSYLLSLDIT
+MSLKKNLSKLKKEGSDKENQTNSILKSIDVSSDLRNELVESSEEAINKVISTIASLRQTV
+YERTQGSGLKNIKARLPTTKRKLRKEVLFPLINIEDYLNNIKQSSVHANNKMINIEKQIE
+LIKKNNAPQVNSSKTTAKLEKFIKPLNLIMKCSVVKETSEQFESCKEVISQAPYLLKRIH
+SLIKENNEVVLSQEKIFNKSNAKLEALVKEWNRHLNWVRDIPKLCNDQLSTMNKLDSSTR
+MILG
+>gnl|md5|18ca65dad9f9d49a37a8969c7958f3fe
+MYDRPHLNGAFRRGSSLDSLMDSNKRNQVRRFSQGGIASTTREERPIISSIEREAKTQER
+LRRLSMSIKSGGKSIKRNNELPQNKIQIEQILLYINTGAKYNSDIYEKKEDYERMVYEIF
+SVGGYCCDLMVSSFKNIVNNPKVNGVNMTRMDRLLNFLSFVQDLFKNYCSPEIVSMAPKQ
+RIQSWKVLNPSQDYRSKSLSNMYNTDSNNLNESERFLKIERKLLESVSKKAVQNNNLKKD
+LLEKYKIEKDNKNLISSKNSQSPYDLIRRRYLGELKKTLVSDSQILNREFSRPKSSEGGV
+KKIFESLRYSRKKVGEDENRARSLSNIPISRDFTSEIKIIRSRSENSLKLEETKLNIKKL
+EDQRIQGLQRLIDKLKEVKLGSSSRESKAIESPENNSISLHDSKKLTRKISEVSSTSISS
+SLIYKKLIQAQIEHSNTLNKNIGPEECLSEEASDENNSKESTHKIKRRWELDTPFIHYRN
+IGFNKDLKQDHIKEIYDKPVAGYESNEVERPFIPGIPPVRYEYSEIKEPNSAANQHTTTK
+SILELNSQIDQEPIEKQIKLEDSVDEIVQFDHLVTPEAVASDSKEVIEPEIVSESDLNNL
+DLQIKIMDPTLVHELENDYIDEAQKTPSNKDVRNSPSEDGTERLSVVIIDPQKTLDNKIA
+LNVVSIEDEQTSERKHGLEDSPLEPIKILKDSEVAVEEISKITDKLEDITMVNESLIKRI
+EDLPIENIDLSNENGLSILNSCASNSEGNSPENKKDINMDRLQNIEYFTSGDEELRSKIE
+EYNYWFENASSGNYYELNLDGLNLEEFYYKNIESIPRCYDELIDMSESSIINLCNIIFNR
+LPELILEQMERSTENNMGESKASIGIEALAYYELSEEDLLFFIHEKVMKDPSYLGFKSSI
+RGEIYPPDDNFILLIIDLIRELVQEWKDDTSNSWKTPIADELIARKVTDIICNSYEPYLS
+EVGSEEWVLKKVFHAPHYPNILESEKEFLNIEHLFKYHSCEDSITNEYINMDRQKWLQTS
+GLYIPLLNEVIEQILHESIDRAILELKPHN
+>gnl|md5|0fe9fcccd36fb9ae7d0bf85fe736ae20
+MEFSSSEFLEKIIPCSEKLEALLGEYVSECILWNEVKQVFELNGQKIKKFSEEISKIEIS
+KTDIIHSIMLVLIKREEPSDDSKIVMMKDRQILILSTSTLFLVNSGYFDIVFWLDIILDI
+SNLFKVHGLVAFTKWICGCFEEFNWAISNPSIPFDKRGLAQEGVEQSTSGCDLSPSVAAQ
+RQLAQAKFVGLLKVISRRLIGYRCFIEAGMLRSFVFSILPSNQAGICRKAFTPRPYSSVN
+VDEQMESIIEAATLIDDFEALSDNDTDKEEGEMSKEKEDYNSGIIKSDFQHILDPSKSAK
+SVFEAYKRVDNFFQTSTDFLNSMIDNSETLSSSKKKQIDDICKDVEIVVSYFEDYNYMDI
+QDPVSHFQGLVSTLEGIPSSLESLYFRINFAYRFSFIVCCQLNQVIDGCKHACEYMHNKM
+VPLLKRCLGSVDKFKNKNISSATLFINLMIKYEFLWKSWKNNNCVDISIPPEKLKPLLEM
+TKSSTEERNDSKKRRIEESKCVTKFIDDETFNKYMSFIQNFSNSDSNKDSDSITIRNINL
+PNFTTERELLYLDPIDLDSYSSKSVNSKIISKFNDYKEKILIDLDPDNGIDESEKSIKDP
+IIRWRCDRLYKRIHLDRLNELSDIQLSISNVEHLIQNCDTEKNNNLPNTDKFEFLNIYSP
+LEDNQ
+>gnl|md5|ee905fca157b65367b23d8b43574cd96
+MFTYSVLGFSYRAEETPFTKKLKYALAFILVLQLIVLLMRVVTLTDVISTFFEGWMIYLG
+YVVYTEKSPCAFFLFITISFVRGILLSLIAFEWIKRNTLVFSEIKLVDKLKFAITIATPV
+LSILACIISYNIFKNIHFVEETDELLNQFINPWNGANTGALANENTASGANEAGNPSTTN
+INISNTSAPSPVMYTPFTGKSYKLSDISSSSNSAAGQAGNYPIYKGT
+>gnl|md5|c5f59d76427d205b21b8d9ac6ec46ebe
+MQKQAMHKNHFIQEDYEEIEEIGRGCFGTVHKIRRKSDGRLFVWKKICYENMTQQEKIQI
+VNEVNVLRKLNHRNIIKYIDRIIDKQNQQIYIIMEYCDEGDLGNILKKKKKLGLSIDEET
+VISIFIQLLDALNYCHTRSNRVLHRDIKPQNIFMIASSSPELKNKIQEGSRINKDLDKPE
+QKTMIVKLGDFGLARYLTGRNQLATTHVGTPYYMSPEVLGKGEYDEKSDIWSLGCCIYEI
+LAGRPPFYARSYDELRKYVKDGLVPDLPKFYSSELNSVLKLMFERDPHKRPSAEEIFNLD
+FIKYKTIKLSPKLDLYFLMYEYQKILSYNRYLESLLKGDQIFGKKIIPEESALDESIDSS
+ASTGIACSNNENISQNTVNSVGQEYKRVSNQGVSQKIEYTGISTGKESEKISYITPKRKT
+PVYNFGSQDNVPGSADVFCKSNSKVCAYSPVTAPTRLNGHKEKCYLKKQPIPDFKDQSFC
+YVRKQLIIGNEANVEDSIRTPVYSGISSNSSNSSINESNIKSTTTFRKGDDIIFESEQRL
+SRWIQRFHSRNKSSI
+>gnl|md5|935b138edc7fb0bfa958b616e82633bf
+MEGGENKNHVGMNCSLDDLIRKEAPKRPNVSKSIKKNMSRGKPVMKNKKLVRSERTFISK
+RNNGSAQVSSGRNNASGLYRGTYKKEGKSQSLYTKRKKDFQMRTELNKNDNIPDKYCELS
+NLDERERIIKMIRLEHKDEDFTLQVLLDSNPIIIVNKITGVIKLNSFNCRTSSMLDVWNL
+LLKPLGLSLQVVNMGGDCTNWSITDGSCYMENFKDGMIVRGSGSRDTARNARFSILEQHI
+RQLII
+>gnl|md5|2c7570bd56faeb557af547138417fcd9
+MHANMVAFIIIGEPKCRSLKIRKRILHLKMKLSFSVVLTLLIYTIGKPHGCEAGLLDTIA
+KAVGTYFKVFYPEVTTPRKDYSPDFELQDQLVVQSQEIMKGLVHIKNNITQIEDNWAGIK
+EFAELRRNPKNIFAENSLGIVDNLSDVISKMSLSSAFKNMEAPIVFLEPPSVAIKQEEQA
+GTPCITCVGRLSLSQSEFKIFKSEINRLKRIHAKTLQEANQELLEAEALAKETLQQRSKI
+IENIQKLSNVISLNEGVYGADNVELKFLQSDLAIAEQKHAALQQKQKALAKKIQELSSKK
+KSFWRK
+>gnl|md5|bff3e918eb45535d77756f7a19c4ab7f
+MKYKMTSITSQLGYRITEDYKKIKLDNEKVYRMNPLFYQPSIVPGPGMSECLLLAFNTKS
+NNSGLLITPPIELQKKVINKNRNTKNSMNKDEQKKKGNGLLNGNFDEKNDEISEISECYX
+DGQ
+>gnl|md5|03d109d88a87abe71c50a082de24683a
+MAISNSMINQSESESNNNNNNDSGSNNVKTNKINDILENFSNINKNNKEEVCQINVKNNG
+IITIHRGPTNENICIDPTQIFILEKKSGYSTEGGSVILERAVRLSKNWSCEVWFYVPFEI
+TFHPYCLISNSDGIGFVVIGLNGELGSIQRKITNMYENNGVISKKNNKYDSKGYEKNNNR
+LQFLSWDVNLRDHVDVGWYHMVVTFNTTQNNTITTYINSQCIGKKMNAFELPHHQSPWID
+CIGNLKSFKGNYIAPFGLFGHLKIYDFALSTIEVGLLYKSWMCHKNLKKEILNRHIKQEK
+SAITKNYTLYKNLMNKNNNLKEEKRSEDKDADDKGLDVNTDSDSEA
+>gnl|md5|c36f218d2b4aed0f42bf5c843b45e386
+MQDQNTREQLNETVNPISELESLVKDPKCTQDLSAETDSLITKLENAGINEMSFQNAVEE
+LLVLEKKCRQVSDSNSSCKIIYKIILWLLKYSKNIDEPLSVIQKICKKRSQLKKVISYII
+QLFLNLVIDSIVALSPNFAKYNSSRKPIETITNLEESYRSISYEIKNMVECNKIITILSE
+ITQGKIYLELERARLMLILSNIKQEDNDLKEASKLLEDITVETIGNMDLREKTQYVLEQM
+RLSLLCKDFVRLQIFAKKINPKIIEKFIDLKVIYYQYLIILWHYEQNPKEISICFLNLLN
+SIANFENDTENNYEKLIGEIPEYMKSPISQYNFSEKMPTTASCIEGYVIYLILGPYSTNI
+RDELIKFNKDYQKHIERNVQCISDLLNDYINNELMFLESTKNFNYTVPKYFNQLSNCFFF
+SNNDYEMNNDVYYTEYKRCKINLCNKKDRFTLFMQRIQERNISIISCYYKTISFQRVQDL
+LNLDRQELQLVVNHLVERGIFSAKINQPAGIITFTSNNNNGQFNKFHNNVGEILNKLDLL
+KDLISNDMMIHQFNSKINNK
+>gnl|md5|3e267db7511358422d5ca75f9dec7d39
+MENKTNRIQDLIREHQSTLKSQRKLLDDYSKNFCDQSKGFEEDVDKIVNSILSEGGLSDS
+LFTGNEEQFNGLNLAAMGDIGPESLEDNLRGPGSALKKLIGEVDLNILETTKDTFDKGIQ
+ADLIQSSQLGVAPDRYTGLKNHTTGGSNKHLSISIPLSPADLHQNETVSESSKPLVMRID
+TNEEKYSPSGGQISVENNNEILKSSEFMDFFSRASRLIERALGEGAVFNPFFNINSEVAE
+STLSSENDGSAKNPGNISFSSSNGLLKNSMIFQHETSSNRPVMNIKSHPTFPEYFIVAYG
+TKFSQNSSFEGMKQNMGSGTMFDYGGCVQLWSISTPKNPENTFIASSPVLTISFDPYCQY
+KYIGTSYNGEILIWDSRSGKIPCQKSNSINISDSEGNNIGGHSFPIYCMELLGSKGSQSI
+ITIDTDGKLCNWNLTNLSEPVESFQLRKTNSKDVSIQCMTLSKLINPNAIICGSEDGSLY
+QTMIKTNKPGVISNTFQNAHNGYITSLDYHPINDCFLSSGADWTIKLWMPNPLASSFTLL
+YTFESSENYVIGVAWHPVHPGIFAAIDADSKLIIYDLTNSNCQTPLCKINTSCSTTTNSI
+PNTSDIPTCISWSMDGTRLFIGYMNGNVIMCNSDSKLYQPNRNVWDLFNQQMETFKSNNS
+VDFNSSLESKDEENLEQ
+>gnl|md5|6800cfc5fcde6d21c3483f32e18fa503
+MTASERLKQILENNLESNFENSEDLEETFNEWSVNGNYDVKNIQESNLNILHALSQREII
+HIMDRVLGGDSFENVLEEIAKEYLGDAWSASTTNAGEKNLKIEAKSKFESGHNEMADAVQ
+DFDKELCNSEEFVTLSQNVPLRIDHNERQLLKLVEGTLEVSKYTDRVDIGSASRSKMIVN
+EIRQVCAILSGLAVSFDYELGQRLIKDRSFSENEKFFQTVFEIARRYKMLNPETMRDSYG
+KLVFLLMDAQKESIRELLQFRCYKPVLTVYEFLKSKNCLDILSDPLLPIATRNVEQVDDV
+NILNSKLTKKRLAIKELLRRYASKDYSEQCNKKSTSRGFYNLFMLGRSNQTQETEISNQS
+GIVTSTGSLENLEKTQETKDITVEELEMCIYSLNDHDVFLYYNKRPIDKMIEYLTTFFNP
+HKEQSRDLSLSLVSDPNSTARA
+>gnl|md5|e9d3a0471d2e8978381866202f9e2ddf
+MQHSQQGELGTLQDGSYIQQYDYSPINSPNFEENILLYNDNPVNNAGMLYRSDSIFSESS
+CVSGYTMMKSSSLTNIPSRNLISDVPPIQSGPARASRNSSNIRRSSTSPPPHINYPYSPN
+SYHQSSPYYSNSPSSSPRSLSPSLTSRQSPQLGSEQSRAESGLLLLTEKVIEYAKQSPKY
+EIDLQSVENKLGVPRRRLYDITNVLEAVGLFTKPRHNIYKLNMDMSSGLLQDEENDENII
+FYTKSQLELEQAISKIKDSIQELIQVGQEQGLLYADRETLSKLCPVNTNTIVSISMPIDS
+SITLNPNQHSYQLLNSILRTKNSHTESGMISVQSQILDSHWSILLKHQSSQFNVDVINGH
+ANILEEIRQTMSPMKQPMQSPNISNPTSIVDNFLH
+>gnl|md5|ff3856ae881743e6bfe2d446d07d79bc
+MSSSRSNSPYDTDRHRGNYEWEDNDRRRVADNEGRRDRDFDSERGRRREHYGGRDRKRDF
+RRRSVENSRGGRHRDDENMDKGKNDDQNNFQWEREREKERDRDRERDRERDRERDRERDR
+ERDRERGRERDRERDRERDRDRERDRDRCKERIKDRGYMEKKRSKGYRSKRRSSSVSSDD
+SDLPPRRYREFRSRNRRRRRSVSSSRSSSEVSSSSEYERRDRNYERGRGRDRDRYKRSRR
+NYSSDESSPERAYRHRENKYSKKHKNYYSESGSSSDSEIDRSGHKRRHEPDNYDWKDRSK
+DFHVDIQEESHSSKKWQPASSSSIEKEGSGYSSKNNVDTSRNNTIIELNNYNSSYEEGIP
+ENSTCVTLCERLMDIRNMSEPQRCNKSIAKLLDLILDNSDEFLAEDTAGRELTKQQFITW
+FVINQQNGPSIADSEVTSSKMENRRQRFTRVNKRLFTEISSSESYSLDFEELRDKESDET
+INTQIVLYGCKKGKLIRVYVIKDKDDLTMKDNISLNKLKSHKIFAVFLRYLQKKGIKYPR
+NNYGNDEDQNPHFDGVFHYYDFVNNQNIIE
+>gnl|md5|8233d909924c26e923117d4a3526564a
+MDTDSANDTFLWSLTEIENDCSLCLRQIGISNNIPGVVLQCCQQVVCEDCYKDELINKNN
+GSCPFCFFKGNNKGQKSSISINNPGISMNGVINSVNPAAIVSATAIPNGSSSNTNCLSSV
+GGGLPLDLSCWLPQNLTAICNPGFQSSSSSTCATSPYYKSNSTSAGEGFNQDSFIYMRGN
+SIPGVVCGMNSINVGVGTPNVNIPNSQPSPFGGVLNDGFWNHSHNSVALQNNTVNHNTTG
+SSTNGSFISDPWMSTSGGYSPSNGFLHDFNSYDNNINSNNLNPNMNCSNTESISDTNTNI
+NHMKQCNNGANGILNNGQNSKIVNGAMNNLSETRNSIIETDKKVCDLINEGNKDNLYQPG
+INVSSFNTTAPNLISISNNASDIYQNNSIYTWTVQNPMACNSMNSFNQANNQNGIIPSTT
+SVDVDFQRFCLGLGFDINSQNQVICDSQNKNNMLISEHINNVNINERNNRSNNGGVTLSS
+HQNMKPLDNSDNNACAGEGDGISVESGVNEAYINGSNLTENKLENRDLQIGSNMDNHLIA
+INEDSGSNNINSSINDTNTNTQLFNSSAFPPLTSALIKQIPSSKDSTKISSVTSSTNNNN
+GLNTGNSQQNECLNSSNSPKLSSISTSGSNQNINNNNPSAGSNPKLISMMGVRNEGSIRN
+NLNIGSALSANNSKQNTINSGKPGVVGNLSISTGNVSYIDAVLHKNDSNSGGVTTTSSST
+GRSENQASVNSDMSNISNDSSNNLLSVNTDEDSSTALGAHGEPYNYKRALCRHWMRGYCW
+LEADCKFAHGEAELRTRDGKLRHPTLSTGNSEVANQNQGQSQSQSQTQSQSQYQSATQLP
+TVNNVTIPSGNLTATSTSTFTSSTSGGSSVSSSIQSKGLKQQSGNSKNGSNASYAATAAG
+SLTNNVLNNDSNISYSVMVVSGASNLDSKR
+>gnl|md5|71aa10a1924d269ce5ff04f12756ef2f
+MLSISPIRENKKGVLRMPNSEVKERSKPKCSVAFCETVEFRTVYVTKQERLGQFYDLTHW
+DFINEDNQEHTQNLIADFAATCIPLKDSDESTGNRKIKRLFWNYNDENCCNNFTISWLNS
+CSNEESSFSTEMDQDSIFHHFEDSYSNEIEYDQQDVTFQEFDADFNCEEFEDSVDDDYFI
+ESEEISISISYK
+>gnl|md5|e8900ffbca6fcd3031ba7bb70f738052
+MVDSEVTIFDRIVSGEIPCRKIYEDDLCISFHDIDPVAPVHALLIPKKRSGLTRLSKATE
+THKEILGHLMTKVPVVAKLLDLDDFRIVINDGESSCQTVFHLHIHILGGRNFTWPPG
+>gnl|md5|4674834ab75de2a505f6bbf4a361e441
+MIMEHDSNYGCSGENGRIYASVGYESCNGGITEGNLQVSHSNQHINIDDIRNISPQKIIC
+ENSSCFNNNDNNNLYEPVNLTNSFMDHRESGSLPTIRRNSMRGRRRYRRTLLRNYEQPLG
+QNSHGNQTYIEQCDDFESNNQRRVYLRNPNIGGANGGMNYSSFKFNSNFDNYSKVSKPSW
+DGGRLVKLLQGHGLNIENYEKENESLLNKSWGSKQINTQNSQLSSISNNKDFSTSAVLNG
+QSYVQLSHIYHGVNLKVCDVVDHQKISNTKNIRNFPSYANDQKDSFGLCHKETLIHEGNP
+LNQINHLEKKVFLQDNLTEGDSISNESLETQKTDRFALVSSLENQHLLKSNQNIEDSSNI
+IGIAHKNSLFNLYESSKESYFNSERKYSITSLIPSMEKQVVNIDNQLSFNMEEHESEHAS
+NSTYCDLNHSLYNISQEELFITLGDTPTSKSNYNISTIFVPNQDS
+>gnl|md5|4046656b1a32ec55dd14766252033ae4
+MYQIPWVVKESCVVTNEVAYHLIGKCIRSIGKLGKSKFEENPSSMQETVREMEKLSTEQL
+QNIRESFINKGEYDNECFELLRVKGTVQLLPNSIGNIEDSIKKYLCCFLFHYIAEFQGVW
+VCFHKISTVNTYGYVPDCEPNGSFLVNIEFKALVFKPKIGELLICRISHVSPSHVSGITY
+GILNIVIPMKSFKGDEYEFQKADSLAYETNTLVNKINKEKNLKVGSIIFVRIKKYNFSDN
+GDFISSISGQFESLID
+>gnl|md5|7abca0f3453db8b1cc1213ed771e9dce
+MNSKIIGIGRISMMKREIRWADIEEDDHVFLNENNLPNKTSVEQQLEQLNELENDHFLEI
+ESSNIFLPLIKGKCSRAARRQQKLDVLDDDIDEILKEFGLGDSLREMKEVEEIVNNGCDN
+SIGCRSYQNKVSKEFIAESTARALGEIKSRNKKQKKKSSANNYYY
+>gnl|md5|eee3c8438ddc4f63d41cdaf31cd99b9e
+METDFNYLSGEKILEYMSKNVSESQRFPSYAEKLILTRDEDLNVTSISPVKYKTDLNRIK
+LFKDEVCWSINKSQDSMSTQNKNLLDETKISGKAINDKSFVDSSPISYAKLWEKTINQHL
+FISIIDNWRKSVGFIFNDSYKNLKYTLNEGIELLQEGIALNNKIRLPELETLVNAVEESL
+AFEEKIKKLLSIDDPTVNLGVLKSPCKIPITELYELLKEGESCSFRSNYLDFLKCQLEKL
+KSWRSNVQSAIIEKNLDKCKDLMKDKDEILIEVPGINDLTEQIAASNWIEKVERSLSRPM
+KFNFAENLLNEPASKFLDEKNVAAKQQLINRVQKAQEWLNVVQSPPFIYSLVSACKTTAP
+NDISETTQKIIDQAKITMEESKNWKLPKPTEYEKVWLESSTLKIIIPLMKYMEPVYLRWR
+KWNKKYKRLMDGLCIFMEAQLILEEAEYTLCDYLDMSEYLPELRKKIKESGDWLNTSKEF
+LNTISDFHTKQDINNVSSSIWNTVAGIKKGNEFSRLEIQQALDFMNSQFHERLSYEKLKQ
+LIEIGNELTIYEMTILQELTSCQDSCEKWLKKGKEYLKCSKISGINIAMAISLLLERSCI
+LVSKETEDSLFAELHFIIWKMDINEIQAPIDDYELSSLIERFNEVKLYFDFDHSNLAKTQ
+NENQIQPNKLIALSLPNIKKENEESGPQNNEESLAHHSSVCENNTTQSEASYDPKSPEIS
+IEEIDIQQINISHWNQIKELEAAAFITKLQNILIYWTNLIHEYETEKKEVEVWRSILEDL
+KHLPISFNKLELKINKIISDYDRIISILKCGDEESNHLPDLKHPFSLLYSYKRLNELNIE
+VSNLPVKISEWDKWQKHLDELNQCDDYTLSTFSYLKETEIIVSNCESTSIEQIERKKVMD
+YLNSINERLASNSVWGITDFKRILIDLKFTGKLIQDLSICECWIKSVKGDSSNDPMGIEH
+WNSLLQRGRTIRIIDHEIFNKFEAQVKQSIEWNEIYFTVLHSDAFCKVIKYKRNSKPSNK
+ILYKIAELLVGVDYGIGERLVTFRELRQSVNSFVELRNQGIKYLNICINERRDKVFSRLL
+NKYLNQSQVSTEQNSEVIDQINSIKQFTSDLKNLLESCNKHTISMDLISYIQDEILLREI
+NQKMFNSLINQENPYFTTNLYGHSAASNDSKIPTFDEANDIVNFIRINDLNIMPENYSNT
+NETNGSQTQLSFEIHEKSQLTIKELKEIILNSESVLMKGLDSTGMLIEKKYIDVDLFKKF
+RKAVYISSEWLKVFKINHFNIIDNIKAESFYNREVPKRLLSVRVESSIDYLL
+>gnl|md5|43bb86f62a21fec7a681da8a1274cf55
+MPSIELSLFLINFGKKFVKFELKEFSNLCKMVEFSLLWMALVINKFPNFIKVSLGDDISE
+ISGIETIKKQNSQLIFEDWEKNVCFDFFSTNNICLGTINTGEIANSQCRRLHNTLELKEF
+VSLIETCDQLPIQIPIKSRLVNILVDALKWTISAREAILLLPRNTILCPWVHIEGIVEEI
+TLCSKNSQIMKTIGLDKNIYNIKDEEIMNIISNLNANEYETCSNFEKNCEVEIQVKKFPR
+PRGRPKREQVCVEKNESQFEDIFNNICMDYKEIDRLPNCVFPKSFYSWLLNENNNKYFSV
+QDLISITSKDEDNKSSKLNNSQNCNSNIGWENGYFYWNKSSSSASNESIVEDDYGSDYKL
+QYIGLIDPQNYPKKEVYKNKLLLDFILCIEVYNNIQNNPAELCSICSNFRRRKHTNNISP
+LNCNSSWIICEECSRWYHQDCVGYSSKSNNFPEKLSNGSNSANELSSWTCPSCSLRFSTS
+IGRSNSIINLLKNSNNLELFHSNNAYILSDIHCKSIDRAEKNKTYDKSLKREVPTLENLK
+QIMKSSFSDKISFIRLHERNVIANTFYLFNVWVNDFYRILKWDPFEFSEFNSSVFFDPAE
+IQERIMNKQILKEKSEPLDKAEEDENLLKEKHIEHEQAVAMSDITQTSRKGRLLKNKLSA
+KEMLNPKLNSIKPKKGRKRRLLFPSTVTKKQIKRSFPCMIDNSAGTLQINFETVFKDISP
+GCKYNIDPDYIGKNKIIEPGLSKPLEIDEIMNLYIIGALIGLDGAVEFEWLYCILKYLAF
+FNSKFGFYNENLALLNSFQLSEELSFINTLKNQKRLSWEEFKYILVHFSPNFPIKLNSCK
+IFYLNLPKLRSIRLKCKSILDYIKNSSQENLTKPQSIDQNNRNLFTDHEQHKLNGKNFKT
+ELESLLIGIVKSGIMIPEEKIVSHLLFTYYLESILLLYGKQISSVYCNQLNPKPLHSTLV
+NINQHILFWKESDANLSKIYGTRFIPPEYNGFVLEGEGSCFQNQENKPLLRIQRFIKYCE
+TIQESINQCNEWNERYKFLMETPNEFEIYVKFLKQGLNLPCIYPTVYSFGNILASIESYE
+DFVNQVFESPGNPSSLKKASNPPGSFKPSFAQTVGAIVGSSQPSLNPKFENIQILKNVRE
+FLKGLPIQKSDLILKIDQMEENTQRFIEGIKQKMPQLKQLSSTEALISQLQLIKEEAIHK
+VPIIVNNVPELRELLNNIPDFGSPHHNLLLRTQFLMSLQCPIAKLRKPLNPFPNIPEASS
+SLSNVVGQSQNNELHQSETKGELMDSQGNNSNKPILHAPGGANNKINTSCQLPNSMSFIW
+QNLVQQGSNPMSHYYYK
+>gnl|md5|4744c08a97d9b133f53d2853c6bc2008
+MENLIIMWSLMKSCCYSIGGSSCTDPVNFNADWCSLIHTNDEESKNFQYKLNSSKKDESS
+ENQKKISMSSTDINDLVNYFIKCALNGVSVDIYDQASQSFVSGKYFINRNLNIITFKSPV
+HTIIIPFKAVSLYRSKLSNSYKILDKYTPKQF
+>gnl|md5|0084aca235dffb376d6048fae87a5b29
+MTSSISTGTVVGLNTGFIVTKRPQRPRPSSRKGKLSARNALVRQVIREVAGFAPYEKRMM
+ELLKVGSASTAKRAMRFARARLGTERRAKKKRDELVDIIQQQRKRAA
+>gnl|md5|2174005c6ce268614b1971f3fe1129ba
+MPKFKKSKNKPSRNRNPLHVDIESASCPYSKPRKSKPIDSSHDSLYDNLPNEEQFSSEVP
+KNIGKKILDEANRQLNDFYDDEIQEHIIDKETNEPKEEFNLPIDSSGFIYIDESGIGTAD
+DMGLDDSYWNDLLKNYEHENHSTQGIRNQTGFIDTIVSKLREKSSDRKPLEISESCQNSN
+IPEKVTQVYTLIGEWLTKYKSGKLPKAFSIIPKLENWEEVVFLTNPHNWSPNAMNEAVRI
+FSSNLSPKGLTKILFKNFISYYSNEYISKLWQTELSLLPST
+>gnl|md5|84cd434d6bce19668913cf63fa0193a0
+MLIIKSLQTNGEYTEWEYRSFINRMFVEIENQNQNQNPSKNRHKFISFILEYTQTILGSS
+SNEGYNKCELFNSWAYKLLHRQSIIAYLQGNISKNKSLYLIEKFVLNSKILSLNDKYSMK
+KKIHKLTRPIDIALINPVVEDINNTVLAFYQFGVPSFEEKLHLMALQPIIQEYIYDNLRT
+NKQLGYIIFANIIPISSTRLLVVGVEGDNNNSVEKIESIIRNTLYEFSTRKLGNMESHMF
+EDIKNSLIQEAKSIGNSFNQKLNHYWDEIRYVGDLSESFNLQRAIDYINNKMTIEHLYNT
+FNKLINSEERTRSHSTIKAIYYSKTSPEFKKQEFIDKYMNSALSIARMSLKEDDFY
+>gnl|md5|f571f81ca9a12e9bcb604d28383dc1d9
+MNMCVNCGYIYHLTCQSQANKITKNDWFCDYCKTHGNKLKPGSKFQIGELVWVNYKCTFW
+PAQIIEFSKEQFEVFIFHIEKRIEKSSNEILPWSKGIISIDGLASKGTFVRESTSSIMHW
+QSVYKAIKYYLNSLRSKQRRLPQIKKKNSSNEFKIDKKKKKIDIMVSNNSNSETRVFHPI
+PSEINDGLEQHSNEISLLDVLSN
+>gnl|md5|bcdfc8b5e12f7f8965edb8311c847d73
+MKSQIETNRNMNGGSIAIPLIENIIQSKDEKLVKRSNILTNLTSCDILSDDQSLIGTRTL
+SGDSQCLENYPFLNMLGQQPLNNVISGDRILIDSVRNVSGDGNSEGDMIFGYKNTKYFDT
+EIQSMKNMDSKLKQTNERRAGRPPLDRSDYFCQICSATKTPQWRYISVCSVESKLRVCNA
+CWMKQRKKRDGKCLPLQIGMNNNLNCSNIGLLKTQKIGMNKENYDSQRQSYSRGMGGVGY
+KISGIVSKNLVANGRNVSIMNNGVNKDRKAISHDLTENLNAYLPNDNLKNDPASCNLNAA
+INNVQCIKPISFRSSPYSASSNLACSNSTFDCQTCGNNQRCYCSSIIGFQGISLTNTITN
+DIPEGSGKLVSGSSEVGLHCGYSNISIDKPSVDVCSQANTTGMNYKNSSSKSSLLEINNH
+CAQNIFIDGNKLTETHVDERHSFAENFSISEQLSFDVNCGLNTGENNIMVGIEESYGGNC
+LKLNVVSNAEESPINSIQQSPTQSSSIDSYPSRIGGKLSNSVLSRKCSDSRNSMVSGNKF
+SVSTPVHHQASTTVSPNTNYCNISSYTSSPCQSFSTYDGPFLEDPNKTMYISSGTYFYSN
+AETSRWSEETTVQSSVGLSSCVGNSNSRENEEKAETLSSFPLDQDTHNTLSQNNEQIEHD
+QVNYTIFNKHLVATESWNCDYLNIDMFCIPTTDKNPISSEASTSAPHYSVGSKFFNSSVS
+CTLPAVYSAEVQQEDESSSQNDCNSWDFDSSSISCIDTWQNPLWYDSYSNGFCKLS
+>gnl|md5|77bdc4aa6dc95743032e5f5d28384efb
+MNFSFLFNKKTLASSKLYRFAKISTSSIILSGVVTIYSFVNFGYYLKDSINWNPNWDGNY
+KHENKRNGKIVSDNARKWHQNILVRHAQYITSAAKDEEKVLTDLGKEQAEETGKYLSQQY
+GEKVNAIYHSNLTRAKETATIISKYFPGVKLIEDPNLAEGVPIAPSPSISGFKPTIGEIV
+KDKERIDNAFNTYFSKDGKSFGDNVDIIVCHGNVIRYMFCKGLQYPTSGWLRLNHLNCGV
+TRMSISTDSLVICSGLGDGGHLRPSIHTYN
+>gnl|md5|a96926276528e61d45e2aeb1f9eb6ad4
+MVYAMHKYRHLCNVKSFICILDCYENFSIHLLKTNWDKFEKLLFDLQNLEKEWWIDCLIE
+IGLNHENLNVRKFVAFNTINLAIKNHKNLPNWIKRNTFFNEYLRYIVSSLNNKISLQIEE
+LFLKFIYCVLRVKIEWINEYLKYIACNIKAFTPIRVLIYPLTIGTRNNLYLSNDSTNILE
+GTNVTKIESLFHNFNSCNIKTNVSKDITNKYSFQEHKDFEESIIIPKELFTEVLDISIPI
+IKFVPILLRREVYSKWLEVILNYFVCNEFSTDELIKNLILFLGIIPEYLFSTNEIYTVIY
+NNIIKHKLVINSCFDPEILTLSKTWFNIFQLGVGFGRLKQIFGSFSDSSLIIKSHVIFVS
+SYYNCEEMHNLNSSMNDKIIEISEKMKILFENSDGNNFIDIDLLWLDIHLLSILKGDSYN
+FYLEKLWNWCILVISDIDTLLNRIKSNINSQISFAMILKCLIYLQKVGKYSSIQNILDIV
+NNLLLISNKMLSNLLMNNQNLIIWDKARRTNFLYDIIDIHSISNDKYCIIQSSFLTLGFP
+ENYSSKYNNIIKGNRLVQLFPSNYRDFFNLISQLEFQLVNIIISKNADEAFRLVENDIYY
+YSTSLKVSGDNFSYAKGSLSNWFQTSQKYCFMRLNTGALIVLYWVLGDNYLAWIMEDIKC
+GEHSFPLLRKIEL
+>gnl|md5|778c72901214f56e43d623e042bf2af8
+MIQIDSESLSNIIIFANILVELIIFEEQGLIDGSKVRFQEFSIENNVGISEMIDIYRRCK
+IYEDSGSFVRHVTIIYLSNIIEDSNSKKHDSLIKFISMTIILLTKKLEGAIPASVQDKLA
+LTNIQVNKTDLNISNYFLINEAENSFKNAKKFPPLPNSNHHKFLINIWQSICCLMNILNS
+SEDKFINYLIGFYFKHLQYLYNPDVRQYIDMFGCNIVVYFPKKCIEYIIEGLSNNINNHT
+QVIYSYLCISSYLIHFLKDVSPLPFNDNSETEVISDIFAFEGDLWIKINIEFLDKYVSFF
+NLFTSYSISNSSLLRNVVLYTLYDAYNNNYVFEILQRSFESCYSSDTENIHSLAIDFKNA
+FKIEETKAKIEIIRNSRYYASNKLDTSKRMFLLNLFILEESKYMRTLVNSIFNNNDILKM
+LKNLSIVWTIWKPIKYCAVENIIPRDNLVEFSDQKESQNFFNCSSCLDSILSKLDGNTDI
+YETNFEKELLAMQDKCETYILNSHLIFGDLRPSWSLYYLLKKIICKEMSGYYVQEKEEKE
+EPNAIEIQRSHNYQLKFEPPHYDSLISGEPRSRRSDNQLLNRSGLIVIGSLVDKVPNIAG
+ITRTCEVFRANELLLSSKKVMNDPIFRQISVTAEKWLPINELEPTKIKEYVQKKRMEGYK
+IFGLEQTSSSISIKECAFPEKSVLILGKEKEGIPSEIVSIVDQCIEIPQYGIIRSLNVHV
+SASIFIYEYTTQFMQSLSTN
+>gnl|md5|af21d7108daf12b239fb56f709b7067e
+MIKRTLVSTIVFAFALIKDARSQDVILENNNGNITELDKNSTLETLSNFTYLNTSEIPLV
+LPFEVLDLNMSVHRSLRAKKEQKKYNCSFNCIISDLDGSLAGVGSSYIAESNSMIFGDIL
+SSNINFFLATGKSYTSSLKFITKNLKNSVFTGFPGVYYNGALVFGPGGIKDVLYETRINS
+EDALEIVNYIKKFAVSNEKSLRFESNINGNSKYAKISNNEEKDDESADSLRLLNIAIENS
+NGLFVDGFEGENMKEYISQEIDSMVHKGVNLSKFLEPREGEKIKGIFKIVIVENPDVLLH
+LREHLETFVRMFGCKIYRSVPNVLEIVPQNASKLNGARLILKKLKLKFHQVAYLGDGEND
+LEIMSKVGFPIAVMGSIPAVSYVSRAVQTFSPETSFSSLIAEYCEVECSKKKPN
+>gnl|md5|3de9fdcf247104c5b6c901fb0401aa5c
+MAEHLLKEIIFSLSKKDYVWITCSFLSFLLVNYYITKWIWGSNLTSSQNEGSTRGHEIET
+AINIIDNQKLNNSLKKKIRIEELASKQLINAKQARKQRREAYEAKQRLKAVKYELHENRI
+NKKVLEKLSERKKALICEQKEYEKWRLKININETGNEFEFGDENLNSEYEDLSKFINAIT
+REKITNINDLSVEFNISIEDVISRINQLEEQKIIDGVITDKGQYIFISEQEWEGINFCIN
+KNGKISKSKDLTLICNDVIAM
+>gnl|md5|781c8958abcbec6c35ea8f290974e896
+MILKNMHLSKNIISRKSAKLQFYRFSKLWHSEVIFKTVIVALLIVINIILLIYTLIKIDG
+NKCDDFLGLFGWMLLLLYCGVLIDIESSRSLKICLSILVLINLVCIEKNILMVGITIDFL
+NLGVLWPIFKYGEIHLDSEENYEDEYILPLIDSSKKLLNVYYELWRRNSYGGIKSYNGLL
+VTRCVIMSCIFLCILLFNTVDKYTNFGKNKLTELENIIYLRSTRIISKTESIDKISKIGG
+NGIFIAQIMIITLAVLLKPVLSKLVNLIIAFKNKCILTLKNNEMSDGKVKQIVKFNDYEF
+NHQNLDIESNKQNAFINQNKLLNSCVFFFSVFLFGIITCENREFDIISRMFLIEQDKSIV
+LCILLPLIGLLTEISMFRDWCWYFIFSWVIYYFNIWSDNSMVKSITSLLSGVLFNISAIL
+FVINQTKNSSNNNKVREYILTSYIFHKMCYFLGCSMSKKVFSIHESSIIKNIYLIITNII
+IIFNLYFLLYFSSSQEIASKQDDNEIEWDVVY
+>gnl|md5|2b1e0ae2cc28c549f54c7756c4f6751e
+MNSNYYRHELSNLVWIQRLRKGEKKVDEILESFVQQDMKIWNPGKYLFSPKIAIILFLIG
+GVFHAVFAAFFFFNYRSNSYVEYISEPIQNNVSSLIFNIENDITGAVNINIYIDNFYQNF
+RSYIQSRPSDIFPGFTCGTAKTITYLRQVRGNTLDNYINKIQVEKNDEETGEEVPLIPCG
+LSSITFYNDKFEIYMLKEDGKKELINVEIDQLSLKNDFSMFAVPYNKMMWIKTTDIHYRI
+WMHGAWLPSFKMVWGQISHGLKRGKYEIKMIDNMWPAENFNSKKRLGIERVSFLGSKNIK
+ASYFFFIWSVWLFTISFLFIFMLSCSCNTLKIILRSFLESI
+>gnl|md5|74c23bbcb64a151be6241bff12a838aa
+MCGFDLVGIILTVKWPYQEPEIIFYHPPSSFSILNEKNVIQTKECFGHECSKLAPLILPS
+DSALWNKMSDLVIESKDFQHRFVFFPSSTIHTKSLNQTLFNNIQKKININNRNLKLDKFI
+ESFSVTLVFIASTLINYEFIEEKLFRIASTLLSCEIANNFISVEILRSNETSFEYLKNLY
+KSCQNNKGGASIGSEHINLSGSERSNLQEHIFSIVEKNNRLSKKLIKYFTRLKIDCNDFT
+VTPSKPHQFFSSIDNNCLQNPVESSYDELTFYIDKSKLSNIYKENELINEISNIADPHLS
+IRDISVELLEQPSNILKVCQKLITKKVAKVLEIIRYDKVYVICPDSIKTQVNRFNLKYRD
+IIDWKGCNPLILISSFFCNGKKLCDVRSELVEFFQKFTREKRASERLIYYPYESSDKIYS
+SNRDEALKIVKSIISWLYVNGCIEVKYSTNAPNDNIDLFK
+>gnl|md5|a8d5ea2eea20acdde7f9b4764d44e244
+MENNNSRPEPSIFHASIIDRINNLDLSILNFSAERSSRNLFFTFFVFFVIIILSFENKFQ
+GNGSITSSTITSSAFYFGEFQMNTYLDNYHGNPHDKNGLFAGSKSIPAIYGNSKWHLEWT
+KSSISSKSALVSLIIQLDKNGKAYNWNFEKIITEDELNMVFTSKVNETPTNQIQNSDSNY
+CLLEIDISNDTNLVNQIFPQKENEKYKFRGSNINEKGEGKSQIEFIIKSLDCNFNVLLKG
+EPFSMSLFRLNIIHFSFIYNLKVLMEIRGSVIQLVHSNSPVIGASFVSNTSISCLFMQII
+LDILECVFILYCSFALPSLLFSSFSLMILFKWIHIFYIEIKYLFWIWKSNYLQNAPSSEI
+TIITTQFYRRLYVFLFGIVLFFILLFGICNSSILFSTFAKSLSKRNIIIIQSVPYCIYVS
+LFLFLIPQILNDLLANTIHLNSTLPLHPYFILTSLIGKAFVPIYVWGYSNSIFNAPVFQY
+LNLMPISTKNSPLLSIFIFLITSIQMIIYFVQLKFGPKCLIPKIFRPRPYNYFRLTSKDI
+YNGASNEEDTREVNIPIDGELNSESLNRSKVNFAQENISNTEPSGLDEIELTNFNDRTHT
+NKLCVICMVNVSIFKDFDHELCAVCTPCDHIFHQKCLKQWMSVKLECPTCRRQIPPFDTK
+>gnl|md5|34c76dd8ad8aa13b9c6ef44f34af4107
+MFEKDDSANINQLLQKSSAPDVDDAIFNHYDLNKVTLNEQINSFSCSSTAFDLNFNFQNK
+STSSKKVDKRTKFDQKKEVYFENLSQDVGEKKLKPSPKKSKYNYIGPWRKDQKEKVITEN
+IIFQTEEDFGGVNNLESEFNDETQESDTDDSLTDEKYAESTFLGKERTDYQNRSWIISPN
+ETKERLPNEQCYAPKKLIKVIRAHSLGVQAIRFIPKTGHLLLSAGLDSQIKIWSSDSKCI
+YIYHGHKNAVRDIQFSNRQRDCKSFYSCGYDKQILFWDAEYGKTKWKILNDKTPYCVSVH
+PKNEQSIIVGFSNKKAIQYDTRSNEVVQVYNEHQGAVNTVTFCEDGKKFVTTSDDKKMFV
+WDVGIPIVVKHIADPLMQSMPYVALHSDGQHLVCQSMDNKILVYDTHANYRCIKKRFTGL
+KNSGYAIQCDVSPDGQYIISGDINGKVHFWDWKTTKNFRSFNAHEGVSIGCQWHPVFPSR
+IASCGWDGTIKIWE
+>gnl|md5|089f5beea25507a3b6affc621e4e82e6
+MENEKMKDQENEIQAEEKESLDSSIRSFENKPIYSDKSRELQDHEKNDNCSGESCKVNSK
+QIAQNCNIINEKTNSFDMDNRNSQNITDLYLDNKTIITEKSEKNGNAEFDLTNNQSYFKD
+LDNLIEKDDDKTQKSAQKLEKISQTEEMFSNNKNKIKMEYKVNLKDRKGEIKELLDNINK
+LKSKASQNETCIVAKLMNSRGVYCGMHTELSLYEELLKYLFSKRDLNEETFESIDIEDNV
+SLVDQSESNTNNLFHLEIENT
+>gnl|md5|24995cda3abccfbcfc976f4238a2e13e
+MSMGGNLHITYIGYPRFNNSTSNIGYYMPLEEGLNNIEPKELLSSTTEINL
+>gnl|md5|d5d6b0d6e939aaa97cf6396d347aa51f
+MTNNWRMLNSNKNPESLSVFSGLSIDFEAYCKEIDNKLINISWIKPASESLGCRPCYLMF
+GAVFILVLIVSMGYAGALICNLVGFIYPAYMSFKALETPGKLDDKQWLTYWVVYAIFNIL
+EVFIDIILFWMPFYYLFKLCFLFWLFLPQTTGAVTLYSNIFRPLLIRFEKKIDNTIENVL
+DVSNSARLVAQRYSKKLLEGSEKIE
+>gnl|md5|541f307b8d081e3ad1520db33f365bde
+MIEESYSNFSKRGDIENPIEILDNGTFQDRENLSVTSNTHIGKDSHKVIPFEYGNGYGYL
+YTRLKWILDNNETSGQFKNEMYSLLETIGELRVLGVYNEPYKKYRKAFDIFSMKFDSYSE
+YNENIIGDLRYQCYQSSSSGRKELKIIDKGIKEWSKRDRENKLLHSYRDAMSEWLNKSEL
+GINKMEPKAINSENIFKEIINYSKDTNNPLQQSQILSFLSISYISEKLFPFMSGQLANTS
+SGVFPCGVLSDAIRSETQNPNGSISSIELVNENAVEDAAISIEEKQNPLRTDFPLEVIQK
+SGENSLNSLRIHKNGSVMNWIKSNSIRRQDANSQKPELIYDKIRKERKKQLSSDREKILS
+QRLTRSSYDINKDMSNSLNKDFILKEYFTDYFSIYKLFISTRENLYSQREYYKSIPIVGS
+IRYKKQKIDLEEVRTRQFQSIYNDGIHSELVSKIRRVLIYRSEWKRPPMYLLITHKGRNC
+KGNYPLAKEDNINYDIDTDEEWEEQFGGEDVENVDDIPDVYEEDDDNDAVASGWLVPDGC
+FQSDELLDDFTIGNSINDHRANMVNLLSLSSQYPSPVVVSFLNHTSVDFGVGISTPNEEY
+VNSILKGYLIHLTQDISWIYNKMDMSRFYLSITPDESNFQPSNISEISNAKKNVLDLQFK
+QDLSYFIHGKWASIKKLVDDFFEINNYKDIKKASVVHFIKENVRKAKLTGDVKFRWYVNE
+NCANLGLDPGKLSELLAQRRAEEKNLSNKVELTKITQNRAYLQSDTGSPSLKSQIQNSGN
+CPNSNGKGKQPESCQCSNGIDPEYYINQKIVSENDENNNINSQCSLKSTDYVLNYISSSQ
+GSERSSINSQVIDKETHTGTVYNKKRKFSTPIRNLPDDHSNYPSFNRKRDADETDGVGSI
+RTNTPESKKSHAYLYNNSLITHFFPPKAKG
+>gnl|md5|64d3c2dec2767031ae5b84096d21bb56
+MDDLYFGLPPPVSKRSNPDTETSSSSGVEAISAIKKSNTWNIFIDSSINRNIVCEMEGQD
+IRCGNKSGNLLDLEYDPISPNTYTIHQNKSESPPAENKISVEKTEIKFEIGQKLLEKMGW
+KQGEGLGKNNQGIKFPIKIYRKKDFIKRY
+>gnl|md5|e89aeb055c686e58f4d9b52c089b5960
+MELDLIKANDQHCYSSEKNKTGIPILTGRNNVDKVVEYFWEHLERNLSFETNSRVYKPLI
+SALFSLSRVASESLATNSPELITEITAAKEILMLSLSDEKALYKLVSEFGTTNISIAPIC
+KIFESKILSLVLEGCDSFESQVTFLKNIIIEKTDSFVNNFIFGIQKMVDLSLSIFVKDRM
+TILTFGYSENVEMVLENAWENFNKHYNLFVVMPSEAKQTNIESEVRKGLYSYQQKKVSEW
+ENGLTKRGINISILSMDTIYNAMNIVDFVLLNIECILENGSAIGICGTAAISCIAKKVFN
+KPVYIVTHSTKFTNLLPFNMNINNILSDITYQNHQLNSSPVTSIVDISESSYISMIFTDI
+GAMTPQNVSLETKQYT
+>gnl|md5|a6ed21eeab42e0d52dcf09857db3b933
+MDLLYLLFLSFLIYVNGIRNFPTLDVKEFRSNGLSHFGRVDVGKIDIIEANSLYESEEVL
+NKLVLATKRQQELKEKEINIKAAIGSNLHKLNAISELLQMLIEKTSIEINGVVTELKSTV
+KESEKTKNMFLVQQNYKVVPTKKLPLAEYSESELDTFSKFSAGGEYHGLDCPLSCSPSSC
+DNKPKEPTHCFKAETLKDGTFASNCVPFTNQKTLTCPKGFIRCALSQPSRGNLYEILKST
+EASPENSIKTVNNNKKRSIAISGRNMHQCLRLLVVSKKTSCNIENIFAAVDESRQLIIPN
+GNSVFPTIKGDVALFEDVQVKKAGKFQLCLLQFYQDPNISGGEGARIMGSDSIGELNVLN
+EDEEIREDLKSSGQKENTEVYEKDETIVDTGIKDEKGLNNQEEEDEKKVMLENDDGNQLD
+DDKKKSHWGVFWYILPIILILFSSGAGFAYYYYLNNKEFVHSKIINLPYLSALFNVPNSI
+THENKEK
+>gnl|md5|290f641e744fda637e4486dda570f47f
+MKNLNSCIDENGKTPHFYYQRSVILEQELKELKLKYIKIQNESNRNKEILQNQIEKLVAV
+NRKQESLLFEFEQYRQICRTGIAIICRFCGSIIENEAVMQHLVDIHLFESIENKSSSLES
+NQIFLMNQLEIEKKFDSIGSKCFELITQDANEVDNIDIDISKPSENNILIKITGFNHDKN
+DILICSTDSLFKLRIQVIYIIIK
+>gnl|md5|c83d5716300195b313fd85a4a2194794
+MCETTFIGRASDGLILTETWDDLSSNRSLQSYKHQAKQILKSIGSDQGVEKCSIDSGNYV
+FHYIVNDGIIYMTLSGKSYPKKLAFSFLDEIKRLFIEELGREFANRDEFKSLIDAIDKPY
+YFIKFDRVIQRCKSEYKDPNSNKSLQKLNDSLIEVCLLLVFNYNAQKN
+>gnl|md5|a1e8977196016fda4ede90a72a196cf1
+MRRNVDDILLRGENLNDVERKANDLKFASLEFSRAAKKLSLHALIQKYAPILALSAIVLI
+IIIWKLIL
+>gnl|md5|bf8316f8fea24bee0e5fa548f609ff36
+MNFIVSPTEQELYSELSSKYPSLHICTQTPQLKGVMTILRDANTSKEDFVFYTDRICRIV
+LEHALNLLPYDFKEIKTPNGIEVKGIAFNTPICGVSLIGSGEAMENALRFVCRGCRIGKV
+LLNNSSENEFDNAISAAYVKLPEDVSERVVIVMSPVLGTGNSLCCLIEVLIKNNVKEKNI
+ICMALLSSKLAIERVFSQFPEIRLVISSIDYNLDENMQVVPGVGNFGDRYFGIKCSK
+>gnl|md5|ffad89f17b9e7009ee21fe14ab5f177d
+MNLINKLYRIYKREKKEDLRISDKEEPLIISKTRMALLELEIKTLAYILSREIKTSFQIS
+NLSEIKWAEITTDDLDRLESILFENVYEIEINPIIKSLISILRGLLDTRNKFFNGKAMPF
+YVKLKNENVQSTFILEESVDFPFRNDRLIKQCENINSSNATPKSYFSSRTPRNLPDFNQK
+VELPIKSRSNHINLISSTPRSTSCQTPKTKNHMRHTNLDYSTPKSEINKKNYYIYSDSNT
+PRRSSKTGICGNSKISNNQQGSIMAAKALLGLSVNIPATEQDIRKAYLKAAMKWHPDKMN
+SSTNEKSHICFTAIQNAMEILLQNMSKNGEV
+>gnl|md5|15ba63b715bd5a666372e344a760b5c5
+MGEETLCFSPINNYNETGILESHTHNYLYFSSEYYKKDENHRTLEVHYSDNLVGCGKKVQ
+KQVKDAYFKLLHSLINGKAVASKGAEILKISLFAYFALKKAESHDFLRTGFPDRILYLMT
+GCNKSCELGNECIPSVSLGPYPVFLVYSIICLKCSLQENSAIKLSLIFSSFVGLSHSISI
+SGEFKGQLTSRELWRISEIYFMGKILILTSKMTNFLKKIEISKTEQKIYLEYFKYIFNRR
+HNINSSIKSSELIDDLFIKFFYIKPSILSNIICRALDSSNQILHFYCIKFLWKFLPLTST
+KDFLEQYSGRLIPNNYLIKSKTLEKLNYIDCFEGYLEKIGQSLVLFNSFEEESKINPPAV
+LVNSLETGLLYSFNNQLGSLLDNTNRFINNNDDFYKNIIFLLRLIALYSEKSEQKYNEVS
+FKKIDIELIHMGFVQLLSEQIYKIPTLLDSLLNLGEQIKFEEFINVLECLLX
+>gnl|md5|72e9800ff9e1476b060c92580e6906cb
+MENWEDKFISTKVKDNDSFDPRIYVEYLNTYSFPKIKKENILDSSKQHDKKTKFNSLLES
+QPIQLMREFFVKLYSESIFQRKYWPVFIGTIPICDLEPSNHYSSSSLDYNQRHSENKSIC
+DSQSFVSNLREMNAPCSVSFWLFPITLTISRKIFNFK
+>gnl|md5|320a4d636324bde19185233ce97814c1
+MTRRYLSLSLKEVLINLCLTITEDSKADGKVRVTINRTKSILKNKEILYFDDQFIFDSVF
+GQLYIILEKVPIYRLRCKKRPWYVIYEGEGGIDAGGIYRDLLSHICLELQSDKLPLFVVC
+PNSYGYGENQFYFVPNPSLGKKFSFNESFKVEKNTNTNLKDINSEKKIKYDNSGGCIKLI
+YDSLYTFIGRLMGISIRTQIPLNLDIPNIIWKLILGENVSLNDLKQIDWYSVKFYLKLKQ
+IECNWKNSDIEDKSRKRLILEEFDSLQLNWSCLNTNGEVVELKLDGEKIPCKNR
+>gnl|md5|8d97366e98ea0adca8d46af24e17de00
+MNSLVQNSPFSSMMNFTFFDQAKKILQSEESNKLEKYKIWKENTSLLYENIMTHILEWPS
+LSVQWMCESSISDVESFYSDEGINETSKYSLLTGTHTSGMDQDYIIILDVLLPNCSIPEN
+CRKFDSHSDYAGFTIPHMEADSNNFSQRILIPHDGEVNRVVSSPMNGNIIASKTVVGDVN
+IYDLNSLVNEKMVKGTVKTENNPSLILCGHELEGWALSWNKIKESYLASGSDDNVICLWD
+IQSKPNNYERKLKPILKFMGHEKSVQDISWNPSNENIMISVGDDGLIMIWDIRESASPCC
+TTKTFKEHCSDNAKINFGFKKSVGYSCIGHCSTNINSLNTIEFNPFQTNIIAVGGSDPVI
+AIFDIRNMSKRLHSLNGHSGQINRLSFLLENESLLASASSDSTVSVSLI
+>gnl|md5|a406c2ad0483ebd169be66f06819efd9
+MEQRPDEVEDGVPELIFTHSGHTSPVIDLSCMTNYLQTTFASISENNYLHIWSPGEAMFL
+SDDEDEELERIKDIQVE
+>gnl|md5|f86770333598a01438a671d71234f754
+MEYTNRKLYGGAITLNIPKEFDDISNVRDIPDHQEVFVDEFSESSIIVEILDPIDFAGCR
+NVAEYYFMDISEFNSSLDTRIIYSEPLSTYSNDLEISKCFGNQKLDKRYPDGIRREELDL
+YLLVLRVVSKKADIVISFNNPTGCAAIKKSLHKNTDNRRHTEKEIREIMDEILRSFIIKD
+YNLFL
+>gnl|md5|cb36a93ebc957cb068ae8ae6766df459
+MDSGEQLENVLSRIQLLPWKEQHDIELLLKVLRKYEVENRVLKPFDKVYIDERNYFVVLF
+CDPVEGGALSESTQVFANGKPLMSLQKVHFLALPPFNAALSPLAQKVSTIRLNRLLQDQR
+EFEREIEVSNSEVENLCGSDQLCRLYIEPYFQKKRKEPIYVGRKVEIDGITFLVWACEPT
+QVGVIDGNTAVYINWDCFGEFKRIHVMPFSDTLPQTYSFDIFQDYLKPFLSRYTFHPFSE
+GESFTYNGVQFKIIATDPAGVKARIGDNTTIYCQGSLTPSIVDLLPVHLLENIIRLPPRS
+RPFSILQALAHLPPSDVDRIFGSADSNNSRGINNEIVNKITQKSYYYGEGNETCSSSDDA
+PLCTVCLSEVNEGDFVVRLDCQHIFHHQCIKEWFKMSVICPLCKVDVRGSNSN
+>gnl|md5|1aeb37bf371ae4a85ff9dea9ef71faad
+MFGVITIDDQINVFPNELNHFSEIHLKDIQNINPRINDPLVILRNRINDKYLNKVVKNAG
+LMIYFVGFDGVDHADIDNDEGGLLFCVTFKMISFRPYVGEVIEGVVIDSDSTGLTVSLGF
+FSDIKIPCNDLREPKSIDSNTKIWSWDYENHKLCYLIDSTIRFKVSSVVFNEQSHDSSVS
+SMVVVGNVQNDGLGMISWWS
+>gnl|md5|123f7fe06b936a16cccc33fea322d1de
+MVNDYGRQAATTIQNCGNQLLGSGRDYLQNSHIIGEGPKPLRALCFVGGIFLSLASLLGI
+FSISQLFLSPGSYLFEAVLFGLGIVVMIVESKDIEKLKPFRDFCLEWAKFLTVPAGKGTL
+YLLSGILAMSIFRINFLELFAGTYMAFLGVICIMVQFGCRNQLQAAGISIDSTGSFSREN
+TNERFNRLA
+>gnl|md5|e0b7b95ca923e55b69cb046a7ab59d4e
+MNSFDLFLTDFGVYPWYELGMNEYRGGRTFEDWIKSKENSQNCFKNFIESIFHNNFSDCD
+ESANIQDKLLKRNEHLKFVRRMRKIEYPESSIESESTRILMIYWSLHSEELLTNDSCGLL
+LDPEDDTNNEAFNSKAEEIQLFEDSFDIIATILKFQDKSGGFGGNFSHMPNLVSTYLAVS
+SIIITGDTEALLKIDRFKMYQFFKKLRDFETGGFKIQLDGEVDVRAFYCVSAVASMLQIV
+TEELFDGIEDYILNCSGFDGGYSGDFGGESHGGYTYCVVSGLCILGKSSIIDIDSLLYWI
+VQRQSGIEGGFQGRTNKLVDSCYSFWFTGLLFCIEEILRIRTSITESYIQSCLCDFQALA
+SYILICCQLSEGGLIDKPKKPRDLYHTCYALSGLSLAQRMNSIYRISNKQSLPPFSECQV
+FDDKYVEKCTSYTPFYSISISEENSINTTDPFLNVRTDKIRKSRLILNRHPLVLTINGCI
+GTEGIGYKEYIENANAI
+>gnl|md5|a847254e286b1e495b4195939ef75eb6
+MYPTDEDIRTYLSWRQADCHINNLYNTCFWSLVSINKLNEREATEKLKFTDSSYKNELLF
+KEFGINYNNISPQFRKGTTIYKARPKEKKSRDEYLLLKNKDILLLDKCKEATIETDHRDY
+TELDKPSNPIWKIDDEMVIINCIYKCHCDIIQDKFWHENDHLLK
+>gnl|md5|dc473c9edf0a2314c88d02bef8a71473
+MNLLNGEKKGGSNDHGSTIEYDKLINNVSNIVSESQYYRKGNMGNPNSFNSELTSSNFNE
+SSESSGKVWSKEKINMKATIGNLMENLSGSIKAREAINQIKMLDTKHKTKGEIAEFLSPN
+KLYKLERKTQYDLTQKEMKHWGATIDRINRQEIISYGEPEKMDIVSTGQLATNYQPLDEF
+EQEFDNILKAMNRDDSKNAEILGHCDISPCNKIKDQSEKSFMKKLKFILFQQQRENKRLK
+KIKSKTWRKNRRKQMQIEEEKLLSLGEVEYPELVKKIRERYEEKRARIRLMRRQTARQKW
+AKMALRFGGNELQKNISDQAQKQHEEKKRIEQIIQNVSKNLDEGSELSDSDNETESNLHF
+IEKARKNINELRNSSNNLFDLKFIQRGIEYNNSLLDLELNQLDQENFQDKILINEPEGHL
+SNNVSDEIIQLSRPSVNEVMETKNQIQGVLNYNQDIIGINFKDNNLNNQLTSNMNDSNCL
+KSKMNEKNLNLTTKNVEKKRKIYLNIEDELERMANIDITENQESAQANSELLKHIFIEGS
+PDHIPNSVDIDNSSEPKSIIRSSNNKSVPGWGNWCSSVSRIMDLNIREEEDSSGKVKKLI
+NSNRSIDKKLKKYCVNQVPYPYTSSDLYESTFRHPIGPEWNTTAIHNKLIQPKIQTRIGA
+VIKPLVYSKHLKNIQISDSFLEKWNLTKKCNRTKARF
+>gnl|md5|dd1c6672187b7ac459533104ed39a499
+MPENCQKNIGKSSKISDLSLKIREAEKDLSISRGIQLKSASTGNHFKPINGFVFDKTSKD
+LKEVSELHILRLKQIETAQRLKETLRRNVDLMTELQKARGAVRSLEKKISLLERGEGINL
+FHSSVKGANSPCSHCPKQQEEINKLKLHIVELNDTFQKRWDETQKELHNAKNSLSDVSSK
+LLESLSNNHQTKISQETEQFRNINGDDMNQFMEDSLHFDDNILENYKGNTNNSNFRRNVS
+EVQSPSTYKLSRPSSSNFSNDLNIHQNINAYPQIYSNINHLQYNEYSRQSETPRASFTNT
+YNRSQLLNNQKSDPNIVIKHSRPQSEHLIKYPVPEINRNTSNSHHSNSSFYQTSNNGVRY
+DPAARIRSLDSVTINPGLNSHANSFPLGLACNVSNRRYDLNPRDSVLNSLSNPMVYPNTY
+SSNILSSHNKVQTPNDSFISSVEMFNSSKMKNSMFHASNNISYDSQSLENNSIIQNQIEC
+EEPTGISNYNSFPINEPNNIKNLVSPSSHSKSIVEPTKDQTVNNYSATPLSDNFNEYPSS
+PVTKSSLNELEIDQSTYGNIRKTLEELKRTQDQRVQQLKDDREKLLRAVLNDLQEMKDFK
+TNLNIIKESQGKNTKTTSKGFFSLEDSSKYDV
+>gnl|md5|1b71d7fbb24ad7dcdac7610321865fda
+MKMIKLFIALILSKIVLNLSSLIGPNQIHLYPSFENSPFITNSWTIGIFVRLKISLWAPL
+FEDVTDQKLFREILTLCINRGIPPPQPPIFIRILEYEHLTGLTGILFEFPKNDRTNRIVN
+RGNILQFLMQCREDKLGGEAHIASNILLRNSPIVQNVSSMQEFKLKKIEEDYSMATTFTI
+TFLMVATTLSVISAYVIYYSVAKNKK
+>gnl|md5|cc91d254d4dfe6ef20aa62f26c0d91b5
+MGSIIVILRKLCLITVIFLVLCASEGDAISPKLQDERIKSISDLTQMDIISLLIVGCFAS
+IAVSAGGGGGIISMPIFLGLMRVPFSQAVTFSSAIILGGVICALVTNLLQYKRAVPEYND
+ATTFLKLAVTENQIHEYSFSFMPVEKAPLIDIQIVLFIAPLLTLGSLCGVFVGRYVSNLV
+SIFVLNALLLYVLKVSISKFNKIRESEKKTIKIPNCEPELLSPTISQTKQLVNGEKIKDN
+LKVILYLYTLSIIRVEKIVMNSINEQSSIIQIASPLHQDKWVKFRNYKLWITFILLCFFS
+VWISILESGILFSKESRIHLLLWLSSVIILLLFPNISLPKRSLNLITSIINSQERLAKIA
+KTFHSNVTNQDYNAIDIVSYIRSKYCNNFSNYILASLEVLSVGLIGGITGASGGILISTI
+FYSSQVDPSSIAANNSTCLIISTLTCFFTYLFEGRVHFDLAILLLVISVICTLIGKNIID
+YYVRKYKLSSIIVGILIILISASLIYMNLRLFVLIINY
+>gnl|md5|caae8e12f996e2138609f65d504ddc45
+MISNDHLKRLASTSAVMSCTLGKATCLGMDKICSPLADNDVTQRKTQIICTIGPSCNNVE
+SLIGLIDKGMSVARLNFSHGDHESHFKTLQNIREAAKARPHSTVGIMLDTKGPEIRTGML
+EGGKPIELKAGQTLKITTDYSMLGNSECISCSYSLLPKSVQIGSTVLIADGSLSTQVLEI
+GDDFIVCKVLNSVTIGERKNMNLPGCKVHLPIIGDKDRHDIVDFALKHNLDFIALSFVQN
+GADVQLCRQIISENTQYSNGIPSSIKIISKIENLEGVINFDSICSESDGIMVARGDLGME
+IPPEKIFVAQKCMISKCNVAGKPVVTATQMLESMIKSNRPTRAEMTDVANAVLDGSDCVM
+LSGETANGAFPFDAVNVMSRVCAQAETCIDYPVLYHAIHSSVPKPVAVPEAIACSAVESA
+HDVNAKLIITITETGNTARLISKYRPSQTIIACTAKPEVARGLKIARGVKTYVLNSIHHS
+EVVISNALALAKEESLIESGDFAIAVHGVKESCPGSCNLMKIVRCP
+>gnl|md5|5654b6bca13fc7dbafd90e3c0492d33a
+MMRNMDLISGNNSLFYYNDQLIWFQKNKLFSFSLVDYQQTEIALGNEEDTLVSVNISMDG
+TVTACSSNKVIYIIKICNFSFQLIGRFVHSKRLNISIFKPDTNEVIIGDKFGDLYLLNAS
+SIHSAIKNGRNLPSFDNDSDSEEILNNDMADCIIPKMGHLSTVTCSIISYDSKLLFTGNK
+CGKIWVSNIKHLENTLSILCGHGDAISSLCEIKIAEESSKLIISSSLDKRIKLWDYLYGT
+EIDSINLEVSNIQF
+>gnl|md5|66eb267db85ffb2d05e5ca453bd794cf
+MTIILVGNKSDLDRREVTTEEGVEFAEQNGLLFIETSAKTSNNVEEAFLKVAEKIYKNIL
+DGIYDLSNEVSI
+>gnl|md5|2fc8f6826fdd43e4f00c42e698f12bf2
+MLENDFPHNELVWWRMTRKQRYLPGRTVTLELENKTVGIEEEHEKLLMKLVKQGSVIIHS
+FDDMKYAVCSSSNVRLYPALSEQEQKSLEKECIRSTKMNYRALLRIKKIVELRKLDQAQF
+ENSETNMSLLEIRMIQFFKDRDSITNISESIEYLEKNTAIELLGAIVNRKTLKTMIGQSP
+QAFFYLDKTIFNEKSKHLSEKEDISVGSIDSKHWQNELNEIIVNRKTICELLSCIPFELL
+SSSHNGKNNIELMAGRIFVNDPEDSLIEEFCEKSIDTIYRGKFIMEYIKLSILYLRILSK
+SIALRVVSANKKKNTRQRSILEYVIVLSLELLFCDPYEAKMLSLTKLKYEETGISNVNNC
+LVSLSIDVDSNNSSEKMPENISKAEKSNVHGLLLNFKTTVPSRDSKENELYYKVDLNRIS
+SQLAISEELQNAYSYYNKKFTLKELENRTKSFHVIKTSCPIMIKLLREWILNANRGEFDH
+IDNIDQLKKIKENLLNVDK
+>gnl|md5|e4826409effef5e6baac2a0780d991d9
+MQKKRENLHKLAILILNSLLILATFFTIFFLNIGYYRWGFSNGSNVKYSVCLNRIYSEGV
+CINTSVIDFENCTEIIEFDNFGSSKTLNSVATNSLTKSIKNTIISIQNASLILTCLIATY
+LAFLSFSTLILLIKEYLHNKRYAHIFSIILMGASVLFIKSGLLYWISMHFSWGKTFRTEN
+NSATIQKIYHSLGSGFYTLIGILSLTFAELIVLIKILPRDHEYSKYSLIS
+>gnl|md5|a415442fd897431e492044df755cd6a7
+METIFCYKCKLKKAEVNTRFLSCIDCFNSYIEGNVRKEIRTGPIERLKELKSSYQSKKPP
+KSELYVALGFGFYSHALLNLLSVIPKTGKRPDYYIKSFINVDTSPLVNRDPSEYYKSLNA
+CIQSIYSHNAYSNGFQIIPKLQIIPFCSSIIRGDTQLDKEKRQAILDEIKFHIDRGTDHI
+KLLIQLIIFKDIKHYLDSIDHSRQKCLVIASTSESLGSESIQYMTLASGVHIKSIYEYLD
+FRFHTEKSSFLFIRPLRNLTSKEVMLYWKFNISKMLNSSIGAELSLNKSPIEYEISKFIL
+SQNEKICNITNIFMKLNENNNETHKYSIYLKENIFCKLCGIIHNKVIENKYCQMCYSLLK
+ILNNLTGKVID
+>gnl|md5|a858f87c29f878ad7ac04b5fa8f53f89
+MGILLLSIYLAANYPIYSAIIFTCLVFTKHFFIVLAPVWFIFLLNSCIQRSEGKFFILIN
+SSFKVLFSILSVSAFAITPIIFYGQLNQFISRLFPISRSFIHFIPASNLYTLYSISDKVL
+AKFNLNFCKIYHLDAEGHYIKSMKCIPPVKPIFCMLICILFIIPVLVRLWHSLSNIKESM
+KSILITSSISLLIAFQFGFHIHEKQILYAIIPLGIYTILFCGNDQQLLAHYTYLSNWSNL
+SVMVLLETYPENIIKYVIIITYYVLELLLLNINLRKYSVHNILFIFGLTTIFFLEFFVQR
+LVFDKLQLVFIYHALSSLICIFPILYYTFYFYYFWVFDSTKNSNRQESN
+>gnl|md5|5a155ebf4e6768a0403c58a127499c22
+MGNLQLLSLDNEEDLSNLFLEFSWLEESGELIKESRISFDFKVFDQERKCYEIYKFFGGL
+DKFSKIDHGKELDNGIEKLDSPALNFEHNIFFNETLSQNSLKYFPSLNGMFFEKNEDNIM
+NKILSVIEIQRNTKNSTFYPNIIFYEQANKSKNYIYFKRVMWESTIKDKLDELPKINLLN
+NVLKNWLEFQSLISIVQLHSLEIFHGNIKTENMLVNHFYTVKITDISPWKPVFIDSSDLR
+FWTIFFEDQNCNARSNVLSCNLSPERFLLEIDTKNIETELKCEIKNKLFSMDIFSLGCVL
+NEIENEESTFTINEILQMSKFEKYCSNVSKVNNDWIREIFLNYNWEKRPDAFGTLLKLLN
+MNKIIQINSLNAYLFSHLEKKKFNFCKSFPLFFYPLSIIMQNKMFSDLRIQVIILNIILP
+IFLELFIIKNIYANNIEPNKKNICFEEIFSNLKIEYTHDWDLNKLKSTFQNKFDNELMKD
+LILSILISDLNHQIFDEKTKLENINSNNYSNIKGFFSIFQLLLNFWDNKKAEFSEDFNLT
+HYINYIIFG
+>gnl|md5|09e95cb230abb03cc7c14032dc34dbff
+MKXXSKELIISAYSNGDIYFIESESLQTEISFSIPLFLGSVIDYSVDNNSNDHLISFATD
+ENIVIIIDLFYLKSMKIWKIDHELRITNIGSSNINDQSSKILLNFNRNGVFALFDPISGE
+IDSNVDFKFRITEIKEKFIHIHRPFLFSSKMVHTDFKSIQKCNCLYCQTQRVRIFGNYLN
+QYLIMSQYHNTTVKKERLINRNIIGPFSTTHNFIGKGQ
+>gnl|md5|ca8acea2d2b0eeaf676c650766429cc5
+MIRNEIMAVGYINSNDELEAAMKNMKSHDSNKRIQGIQLFADVIKTDCSLLSIEYIKKLQ
+IVFECEHNIDVLLQLAKSCTNLGLISLFEEQICRLNINEFDFFSKGCIFNAAKQIIYNAY
+DDFSTRFHTSKRKSNKNSLFTIEKIITLIPILQDIAELDDVYVRLETMKSLKSLINIITF
+LIEENLNNIHKSTKYNELELIFNHSLEIFQKLANSDILSHKILSCHIIPLILEQKRLSEI
+FVDEKNILLAKYSDFCVHPAPILRKHASKVFNAILEQIEFEESIIEILLFPIIRNFCCDE
+QEGVRLIAIENIEAFFLQVFELANSNKEYIKKVIIFFEKLQPFIFILYNDVSWRIRSNVS
+RPIINIYSKLSRLVTFGEAENIDIHRIKEQSIIKSNKVKNENLKIVDNENESQNLDISID
+GDNLSSHPCPKDNSSVNDIDYLNKLAFILTQLLMDLESETRINTLSNVLKTIEEQTIESR
+PTITDDKSPIPYISKILFYNVIIQQINNSNTLLADQNAAVRINLSRITKIIMLVKTNFEI
+DEFMNIELENAFDHLVTKLTHDEDDQVRQSVVLALCSGVSESTDINFLIKKIILPHSSSM
+IQDNFWRVRYCSIILLILSLYKLLSSYYEEDEIWNCKINSNNDENTKDFLNYYEGTIDVL
+IELIIMNVTDKTSIIRQLTSIFSLPLLSSWFGLEWTKNQLWSKNILPMITNEKSYIMRIT
+GLLSANSIISGVCIRSFKELLDVIKHVIQLILIVAPTLDPGNEDYQPYQEHLEVINSQLT
+TNQSDRNELIKNTEFLNSGLAQNNIFSLSSRSNHLTEYLPLINASNLTLSLNPSDKNHNT
+RKKSKSISFDFSEFQLEIISVVLQYSVNDIVPNVRAKAFQTINSIIDRNGLGSFQKSVID
+QVKYSYENDLDSDVRTYCRYILKKTMDEINEDYD
+>gnl|md5|2ee8a9b7ee522d5742d1a367218bb0da
+MASLGLKIENEHINVVSNTTNFIKQIVEDDLKNGKHNKIVTRFPPEPNGFLHLGHAKSIC
+LNYGIAKIYDGRFHLRYDDTNPYSEEQQYIDAIEEDVRWLGVDWGEHKYYASDYFDQLYE
+WAKKLILAGKAYVDHQTVEEIRKNRGDSNTPAVESIYRNRSINENMELFERMKDGKCDEG
+ECVLRAKIDMKHGNPNLRDPILYRILKQSHPHTGDKWVIYPMYDFAHGQSDSIEGITHSI
+CTLEFELHRPLYDWLQSELEITRTRQIEFARLNMTYLVLSKRKLLLLVNEKHVAGWDDPR
+MPTLSAVRRKGYPPQSLWDFCDKIGASKRDQMIHIQLLEDCVKENLHSICQRRFACIQPL
+KVIIINWDECFQKETVEITVKNHPDDNIDMGERVLYLTRNLWIEKSDFWFDENQEIDSQQ
+PPGDFKRLFIGGSVRLKYSYAITCKNAIIDTDTKEVKEVHCIIHSSDNENDSNVNKRKLA
+AIHWLSTSNVTNVEFRLYGRLFTLPEPENQGKDWRQFINNKSLVVIHGFSEKNLLNDEFF
+NSKGEIKMNRYQFERIGYFTRDIVDSKRENDKINLVYNLTVQLGESPDLLIKMLTESGAR
+ENTKDIERRNAYHTNREKIAAERAARKLAKEAKKVQKNNL
+>gnl|md5|1461fd99f96580935051573e595a2504
+MDRSFWTNILFKHTNPENLYENVLVITHSILLDLGFIPVKSIKGEDDEIDNNLDHTSISE
+EFGVPINSRDDGISIELLPSNWRSKSKKNRLFYISKICSKKIDKVIPELIFDLNSSETSV
+QLLVKSNPIGEAMKLEFPFKISEDHSTNESLMFELSSLIRNEIDGFLSKSRIYTNNSKSN
+TKEGHKIPIIKCGPLLETERSFEEYIGNNFRKSVDPLIDSNGVRGSLVGPESIIFKNQPK
+IFGKPKNIPISSIPGGTTIPDNDMFFPPGNNNSNYMFNFRE
+>gnl|md5|22ff883e31c5c2f97f676445c2158ea7
+MRDEINQIMESRQEINEQFNLNYDDQNLQNKLDKIKASLLRPEYKIKAIYPEAVRMLLLF
+IYGHTTSLRGANPYLILTVLHEARRFKVQLLEEELFQMLNSPLNIDIIVQMSSVAESLEM
+EGLIELTVYLLADCAQALFKGPHLALGPDVLLKVLKSERIIMGEIDIFLALKLYLVQRES
+SMGLLSNKRKNSLEFLKNIRFEQMAPHDLLKIRTKELDSLLLDATLNKLLGNEGSGRLVP
+WKENNEFTTNTHLGLYPISLARRTSVSGKYKWAWTIGDYRLVSDMIWQVQVCKTYMGRIR
+IGVCCRGSSEAKNTSQVPKIFYYDFMERCFGSAFQTNDVYNLRSRINYENGKKDQIILKT
+NMVLQVRLNISRYNLILTISDITNPSKIEFETSHTFAHGCSVTNVGITKRPFIETANFVE
+MLDDGDKLKLK
+>gnl|md5|70600d24b83b9abbe6b82d7ff561f1ca
+MHMHEYLHEILNLIKPFYENFLMTLFNKNRNKKEIGHIANNSQYCFVDEMGVEQGPFGSN
+EILTWIRNGFFDGKGDLLFRNLTSSPAERVSLEQILPELLNEAEMNFSRKICPNKTSSIK
+KKQAEPIEVKEITLIDDQIKLLEENDDQHKDLILIVKPSLKATDIQAQMHTTRSNITAIF
+VDQVNAINTKIMGNPLEFKDEKYNLSAPYFENYAEQFFGNEEFKSNDSFAFAPILKINVH
+SSVLATSSPLLKNSMKTLFEEHFRLRERVAAGKCTIEEREQSLINPVLTIESDCPIAFQA
+IIRYMYGHTSEVLSMNKLLLVSMWKESRRFMFKKLEDELLIHLFSTKLDIVDLIEIAAAA
+AILKFPKLVDEIITMIASCASYILQGPYLALSVDAYVKLIKNNYVMMDEIQVFYATQHFI
+QQKEIEVGVWTESFEQSDYKKEIAIYKFVRYDQMSAEELKSIRVKKLDSLILDAALKKLT
+NCEEEGRLKPWLPNSEYNVIYRDGEYPVGLVRSGKLNLNSNGLFQSRWAWTTGDSRLISE
+MTFAFKVLKSFRGKLRLGVCCTGKPVITETQNIRMSKVFYYDFSEKEFVSAFLGSNIFQC
+TSRIRSSVIKRENIKVNNFRFGNSIWKTNKDSKINEMPGTKLRRSTSEDNVQDLYKQTIA
+FESRIEKGQMYHLVVSIHDYSVLLRIESIDCGTYIENYYDHGFLVERLEVSKKPYIETKI
+FIEMLDPGDSLGIPSFLTITRQQKTNRSK
+>gnl|md5|508c5be65b8eddd4774bcf91bb544f90
+MAADIYFYWQELGMKDENLYHAYKLGTKSMENFVAPTTALFPEINFNSLINCIHSVLSDQ
+INDSFSDSFIIDSLLSRETIEQIVGQLTLNSQGLNIWGLHLSGKLDNGNISDNEPTIGII
+KGACICVIQSCFNHSCDPNCHVYTIDDSTIYVTTNRDVMKGEELTISYVDNTLPLAERTS
+LIQNYHFTCTCRLCKKEERSNHTDSGKKKRFE
+>gnl|md5|53fb2c45512c9d356d6f2f791bc057e0
+MKPIIGNGHLEETNLEKNLLNKRLFSNKIKIFGNKPTEKEIIDNLERLFDSFSKNLLTDT
+LIDLNTVLSSAENTANEFDQYPRESDFLNKDSSSNIYHDDNVIPLLENLGVQVFLNRDNC
+DSHRNLWDSLGGYQDVKRQIEEHILLSFKYPDVLDKIVNGTRAQSNSNNRPKLILFEGPP
+GTGKTTSAKIIGNSIQVPLIYVSLENIVSKWYGESETKLAQIFDIAKKFNEGCIIFIDEI
+DTLASSRDKTFSMHEGSKKILSVLLRKLDGFDTLNSKTLLICATNRRRDIDEAFLNRVDT
+TVLFNLPNENERELIFKQYAKHLTFEERMMLAKMSKKLSGRSIRHVCLEAEREWASMILK
+KKEKGEYQRDEIELPTVEIYKEALKKRVS
+>gnl|md5|a995fd746a6f96d262a51cc4e34088c6
+MIKLSAFTSFMLANLGEFGFVLASKGISLGIISRKVYLILVATTVISLLSTPIILRIFSI
+ILKRRNSNIPSNENNYKKFNVKNNEITSIKQKFNFSLGSSFYNANKRRAFNITNIIKNLG
+IFSGNSHSLDSSTKDYKFDIYIRNNYLNSRFQEDRISYSNVFENSRANPNTDFSLNENEL
+EDLSQDVVSNESKFGCKTSSISLEKIDEFTLAHVTNLGNSSSKM
+>gnl|md5|395050e8150f2305438db277701065c0
+MDDLKTIVLRQNEILKKLETALSNAIIRIESIERLYCNKENNSVADNLSLILPKETDYGL
+MKNNSCKSKDLNKEIGNFDFNAVNSAFKLIPIDFLKMDFNNHPINLINNSNDKNSHFIKN
+LNSNKFVVNSNFYHSVINTDFDHQRLEELSENMFDNTSTNITSKLPELETNIKHENQELE
+VFWEDKENYSNASNNNCKLQICICENESKSDDKEFFPKETLNFIANKLDMFNVFYNGNEN
+HILSNCIGKNALNIKSSNKLYIFDEEDNSSMRLDDPLDLEIAENEFYYLKGHIKRSSTRD
+RPRSSGLDNCHLFNCLYPKTREIKNSCDNIDKLGVYSSNQLTPVDNSYLIREIKYHKPYE
+KIVGYVQIPYNAFLSRSFESSGHDKIKNKTPLKEVNYLDSHNVHKKIRSSYEKRNIFSSN
+IYQYNRQIAHIKVNCPIFYQFFCFQRYPILILRPLFSN
+>gnl|md5|703ad883d135223472e56a8b8c158413
+MLLVDRISNLEEKVNEQNEAIKKIALYALEILDENDRLWKHIMKDITMKHNRSSPQNINE
+PIFRFRSKTPPPLKEPNLPEKEQSFKVIRGTEKFNNDVFLSILTKEIGQRKVFTKNGKK
+>gnl|md5|c6b7634e01ea0c46ce55c8515c337723
+METNPEESNQLVNTSAEVIRTYLNKIVTNDNLDTLTPKKVREELEKALGLPLDSLKPKKN
+QINDLIDAIILEIKEKNSTNSPIEQITNNVSNVNYKDEETNANNEEEHNGLNINIPEITK
+QNGKATKRKQISMSIEEFLEKSQTLSLSINGSSEKLAISPRQFSTGSVGWYYGGKVPLPV
+GDDLEVLCQISVNCTVVGSKTWSQNTSKKSKIK
+>gnl|md5|a8eb3baa9e6beee4fe3400a92d6f5246
+MGSLDKLGIIGVLDSAIWSVASHPKDRIIASCGSSIVVWMDTKLKNHKWYQEIEIVNKCS
+MAGNSWVKAYEFGSLEHKRLIRKIAWSPCGGMIISASFDSSISVWEFVSRDIGWACICKI
+LGPESEVKCVDWSPFNNFVAACCRDRAIWFFSLDIGENRKLGTPIEYDCIGVVTAHTNDI
+KKIKWHPTIPMVLLSCSYDNTIIAWAPSSQLLGHDEVKSLEWVKLYTLNGHSSTVWDFTY
+SPNGEFLLSCSDDSSIVLWNSNQGNENKFKNLNSVNFALTDTFKMIFYNTPNTKRLSKYI
+QIDQANSFINNYDKELYSYPIYSIEWCNYINCIIVSSADKSLHLFSVTDSKRLKHICEKP
+NAHNSEINSVSWLNDDKKGEFISAGDDGEIALWRFDFE
+>gnl|md5|76072b43617382892293de53975127cd
+MWINKLISVILQIIIAIKLSVGRITINVHNTKDENGYYFINVFVGNPPQKQTLILDSGSS
+QISFTCITCLNCGSHEYPPFDIMKSITGKNCNRKLLGGEKCKYFHRFNEGSVISGKYFSD
+TLRFEEVQQNSGIIKDHFEIKYDYLGCNELETKKIYRQRATGVFGIGLKSSLDEHANIIN
+SLLTSLESNINIKGSNNLVVSICLLHSGGRIVIEEHDEKITNRNSNFSENKRNHVYWVPI
+IYPSNVYKVSLEGLSIGSGKFSLLEEKTSLFAIIDVGSTYSFFPSNLYNKIINQFSKLCE
+LLNKLNINRCITINQ
+>gnl|md5|1e1dc90ad92ebf54669dd13393eb7ee1
+MTIGIPLKLLYEGLGHIVTIELKSGDLYRGTLTHVEDNMNCMLEHVNATMRDGKPVSLEQ
+CYLRGSQIRFCILPDMLKNAPMFKLAANAKNRASVLGAAGNKKAFAARFISRGTSRGRSG
+RGLAVQNY
+>gnl|md5|3124c693fe0b74f35e1a91690fc9929c
+MSLPSCLFEDRFVINSVDSGKFDRIGRIRGRSVGFDADLILDINNELFPVREKESLYIGL
+SSQVSVNPNDIVWDNSGPQTLMDQYDYVMYGKIYRVEEKQSDRRSLYASFGGLLMSLTAD
+KNLVGDFSLDMRLYCLVRRSEDII
+>gnl|md5|8b08445cb16599c49be283d491cde4b3
+MDSIFYRFQTAFKLLGLEVGASTKEIKSSFRSLAKKVHPDKNRGKHEKSAHESFTKLRDS
+YVLLCNEIERRRFEKEYLSLNDSNTVQQKSRQDSYSNRSLTVNTSKTDGLLKKEKLDRMD
+LELLRRESIHLVNAFKDYFEPKVVKEYKRNKQNLKWALNHARIDKIIDRFSEFEKIVLFK
+LAHII
+>gnl|md5|3203187a2b2200cf8a211e83410bf8d6
+MALQDTASTAGILAELNNRLTSYESTIRELRSKNRDFVNRLRDNQQIRKDLCIKVNSLQN
+DLEKRDKELKAQKEQNKQLKKRVANLNELNSNYQNKIEQLKSVCEKLRNNAKNTELNFSE
+DLNSLNTENTNISSINNINEKRLFKNTNDNNNINCKSTENCSKNASSSSSVLNETTNINL
+QSALQSNQNKSLLVKKGDLKFSVEEINDLNMKYIPVPDDPIDRAIATFTNSRENKILFTR
+VKQGTYVYGRLMVEAKLVTKPGVDKNKPLLRIVSRGKLYTLADFVNTHENEELNNIEDSI
+RNQNSNLVSDGQALVVASPLNKFRTTQVLTPSSPIKITASPLQQNSANSVASATSIQHYM
+QSPLSYTSNRIPIIDPKHNQGVNLQNYMVNYPNNTHEMMLSAQNANSIVTPTYYNNINGM
+HQLSPINHKNASFMQLQSIVPQQQFPYYHHLTESSNLNNQFNQNLSYSKSNIPVLAPPPV
+AEYMPVTTPIIMARQPMNALNYSNNTSGIQQISTQNISQIGTKSNETKPLSVSNKLECNI
+QQEETEVKDLNNSLSLYSISNTNQQQYQSLESTNIQNTNVVHHSNKNETSSTKDIGNYSH
+LEDDLTLNKNNSLTQKSPIKQTSSPIKSVSASTIGEWYRQANIMKRCNSYSCENFSVTSN
+KNA
+>gnl|md5|d9ecb8d4f41e63f24be67974e098d35e
+MLNSYNAFFSESNFLKNNEIVFNEEVDNFKEIPEFSRDIPEKHYSSSHFIQFNGKQILRT
+KSLFYKDHFLSSKTINIPGIKPKGFNSALISSKKIRNILILKSKKESNIKLLQKYEQFTM
+EKNHKFKFNKNTMLILTIFFFINIVSKAFINILIFGFSLININSMSYYNCFHEFLKIILS
+SDDPISVINDIEIRKNRYCLYLFKEIYWKRSKVTIHYLTLIHFLNLLLFFGISNNLHYTV
+GIRVLMNKNLLIITILFPILYNIINFSNFNINKTKYSNLGCNSFDYYYYLNKSNSLPWFK
+LQIFKLLKLKQENLKEFSSFKVNLLLNSFILSIVVSFLYFLFNYKKNENNQQLTIDLITL
+LPIIFFLIQSIHFHITQVSKTNTSHKLNLYSYIRWLKTSMQKAYYFPIYINKSASSTTPK
+TNTSFSSNKRNSILYEDGYELSTPISGDSLKVDPIISISSTKIHLSSNIVLILINPLLFL
+DNSLTFGYGKSPLFPIKQLKTVKINNFDRIAVISNHNLISSYWTINMVLDPKGMYTNDNK
+SLLHTLKLLDIFPNVLDNFDQNVILNMPVREYLEFFNSQVVGGEASVTGDIKITNFERDI
+RSQDLNKLEQHISKAEENLRDTIYIKKLLLFGHFALYSMYYRELILHLDYNMDLNVWISL
+VKQFFDNEESLINNIIIISTEADLPNIIETETRLYNDEK
+>gnl|md5|36d622553e94558e15df04cdee198a8b
+MRSERLNKIIQGHASNSSNNITLYGENCRKLVNQGNLQVMNSQDMKNAGVITNKPITRSM
+TSSVGNVINISNASMGNQKHSSKLTDANSKNSNAAKLGSKAIPGLSYNEKFNGKESPTNK
+ENVVNPNTFAEKQLKTVGAQYTSTLEKVVNVDMDNTDASFFSEYAEAIYQTSRDLESKKE
+PLLFTASQVVSAQPSVGKQILEWKRSGVNLLFGLQITFNVPDEVTVIANSMLDRILGLKH
+FQRASEMTLVSATCFWIALKYEAAYVQGENLKIPPLPALSDVAEKCGLNIAAILFCEGVV
+LDALDWSIEFPKPSDYIKRYCLVFKDQYTGNKATRVESLSIYLSHLAIHEPAMMGVCASK
+LACACLMLAHKIEGVEESWAPAVEYYTGYTRDSLKELTRYMISNLRTIRNTENGENHASP
+SHYQNVRKKWWSSWGSNEWG
+>gnl|md5|6a4b506f684edea67d41cf102f921ace
+MNIVQNMKKNSAGVTLNKSKNFSSHKYSFQGTQNQVDKTAVIKGINSQIQAKTNDQIPKK
+NVSENSNLNDSELNTISCSNNNSESSSLAFNSTFHLPYSFKEVPEPKIRSELMKKKISKL
+ESYLSLCEDLYLGGISKTQSVSEIFQSLIISHNIDHEEQFNAFLKRQSINNGFTKSSTKA
+NSKNSNLQEPITNAENIISPLQLLTHPFRNKEVIDLWGPHEVILFECGVCKYGKEFDKIQ
+RIIKTKTTKEIVDFYYCIWKRTSRYKAWKSNRQLSEYIFS
+>gnl|md5|7e8200639b87197c4a068930609c451e
+MEACLFDVQSLVKTIQSLQLSKANKKNGEGQFLTCMISTQGIKLSNSTLSKDVYCCSWLR
+KNIFKKYLYEASQTNCSRFEICLGTILNCIQVFGLDAKMVILTYDHVSLHLSITDDDGAV
+TDCSLCTYNISEETDEFYYSNFLDCKNVAIFDLDYVTMFPIILRELLKDLCDVGRSESKV
+S
+>gnl|md5|66d5e7c6290dcb7d487a345618d5d8cc
+MNQLNKSHSKGRIKTIIKSAPNELWYSIFDQEITNSIIRHPFVDQFTWIKPNCENVNIEE
+PLMQQIIGPKFYLFEDVFPNSILSIPFIQNSIVNNNGVFISLPNLSIESSCALSIINKRT
+KESNEEKSKLMAIIRTPNTLFKNVLNVDKFMKQPPHMKKTNHFSFHKIELSEKSYWNDKS
+ENMNKISGNFQGSNFNYECLSSIDILNAHAEVHPFFFNPLLNNCKDIIFPNNSKISDIYV
+CVCCNSGDKIPKDLCYCNAIQESKNPPFQPSLKNLSYNAKGSGNNQFYFSLQQQFGSSLF
+TKTDFLCYFENDKLLNIETEARLLKNLKTILCINGSPNVKITPINVKFISERINNKLIDE
+KRCSGKGLSVITGSDPSSKDYLSDMLIFIDLNALVSLILTSTNAKISNTQIFEQIIEYFD
+ILIHQNLFSDNQNLINPFYFWDLRFGQSIVCDNAPKICNILKCVPFKEAPNEVIKIIGLL
+RPTILQRLIWFVASQVAAGAYLWSLFHLKGVESSPISINYKPHFIDENKNSVNDLYLLIF
+RMNEEISILCISVVNFNDANL
+>gnl|md5|b098e50c4dc4b1558ccd6e878341b498
+MSDLDRQIEQLRRCEPIKESEVKLLCMKAREILVEEANVQRIDTPVTICGDIHGQFFDLM
+ELFKVGGELPDTNYLFLGDFVDRGYYSVETFLLLIALKVRYPDRIMLIRGNHETRQITQV
+YGFYDECLRKYGSVNVWRYCTEIFDYLSLASLIEDRILCVHGGLSPSITTIDEIRSLDRK
+QEVPHDGSMCDLLWSDPEEINGWGISPRGAGYIFGSDVVKSFNHCNDIELITRAHQLAMD
+GYKWWFEQNLVTVWSAPNYCYRCGNIATVMELDEQLNYHFKTFEAAPAEQRGIPAKRPAP
+DYFI
+>gnl|md5|0723d2145f0f519449cd2b59336c4e32
+MKKIKFFLTATSSLISAIVTSFLLHPLDVVRTRQQVAAVSNGAVIAHPTLISTINFIIDT
+EGVIGLYKGLNGQLVASGVSWFIFRYFFDFIRYFIEENKCFVFSYVVKSQTYFDPLQISP
+FSNSIATIIASVFSTALVHPLWLVKSRLEIQSVNTKKRGWKQYSAGLHGIAECMYSIYQK
+NGICGLYSGFIPTLMLIPHTLIQLVIYDIFRNQSINYNSKHLYLSNLRFFIFGFISKLLA
+SALTYPLQVIRSRMQMAKIENIQLKTYDINILKLSHKEFVNFARDNYFPGLMTHIPKVSM
+HSGIMFLIYEAMIKLFESILSIN
+>gnl|md5|588ee70ba174013bb790977449151d66
+MEKIPLELLATVSEYLQMVDIFSLLHLNRGFNYLWTSLEYWSIVCRGRRNYLNLLANEFN
+CILEDLKSFSLNKSNQDDLVDSDNNEYFGFNLNNLKASFKQMGCKTKCSDKSILWKIFVK
+RRLRRLDLAHLTSVFQDVKIYKYDKKIIAVFSPLIATISQHFLEIYELRNDNYLGRKYFD
+TTPEKLIDIKTKLITRLNIDLLQGQENVTWNNIEPKIRTTNIVKWAFFDKNTILCVTKDY
+GIYIHEISNFSKRIALKKPLVNKYPSLPKVVIFEISGSLLAIGLEDGVVDIWKLLSSERA
+CSNLKWEKWYLTHHCTIYYEHTYSRKNLIDIFEEIPSPLTWVNISHNCNLLLAIYKGVVN
+EIRIFSINNLDLNNNPALMNKIPLYSDIQMCQIDPKGRFVICVDSNKEIHPKTRFYSLSS
+GKLLLVQNFRIICPLFTSCGHLLIGAYRAHPNIPIEKSQSTMKIIKTSPKHINSEFTSSY
+FISIWSIPSLKEIYSFNCGKSEQIINIRFSKTRNSTSIITTTINKNSSNYIDGSIIKTSS
+NIHFISHDFFTSMKPMKLPHFF
+>gnl|md5|8389e82a9ada5974f69e459d5e3f34a2
+MKTITVAIVLSLVWIYVHFCSRFENKIKDIALLKLRGSVEMGDQLKGGPHYTGMMVGGRH
+VGIEHSLDLGDLSQVYRCLFYSTHPGSCNPSGTVINPCHFCRTEVVYAVASAKCPGDESF
+PPSLAPLYMWVLKPYHIRKRLGHQYLCAVEPNPAAKYASRPSNESPLSSDENSYPLPPEI
+PFSSSNNQNESLSESTLMIIIGSGVLLTLLLCGIGLYMV
+>gnl|md5|4c503414b20f710abb69fd90655697f3
+MKYYLPFGVLLLIIQLYLSRCSESSEDVESEEVLSIQDSSELKNCRQAIRSISGAGCHEF
+TLDPSLLKVISEMSNPGQQYRFIVIDGEQQNYQQADDGDSSSQVNYLSQQVQTPMQMPMP
+VQMSMQMPMQMPMQMPMQIPTQMQIQRTNQGLQFGHGNMVQWVGGPVNFDNMVDCKFYRQ
+NPGFCVPMSIYTPCSRCKARVRTIFRTSYKVRCPGQESFPAQLRPYFAWVPTSHRNPKRE
+KGIFSRWRRQFMCIVMAISDIPKDVSLFWQHSQITFDSAYETPQYVPLLLGPYGDQSTAL
+GYAAGTNFLTTSGLSYQGAQHYIQNQNLERNGHEAS
+>gnl|md5|99c2ffe56d04f583c15d21c1fbd8d363
+MSNLEKLVICGVRSFSPDRREGIAFESPITLIVGQNGSGKTTIIECLKASISGELPPSSK
+SGQYFIHDPKLNGSAEVRAQIRLIFREYQNKKKIQIVRSFQLSHIKTRKADLKSTGDLKP
+QFRVLESVLQTKDEESGQVTSISHKCADINAQVPILFGVSNSIIENVLFCHQEDSNWPLQ
+DMAKVKKKFDELFGSTRYSKALELITKLKGEYNKKIKEKALFNENLKQKIDFLKGIINKK
+NQCLLRKAEINKEMQVLATKLDSHLEMKQELMKNVDMLDKLQSELIFEMTLFDTHVKEIK
+EMENVLLKSNYNQLEDELEINSLLHNEFEEIQNLNSKLENLQNQTNHIKNNLENFKVNSS
+VDEFTQRKNEVLRKIAEIKKLTDLKEILLFLENSLVALNEQLTNYKGLNWESVQKAISTL
+EVNKTEIDSSLVNLKAELNFKIEEKKKLFDSINNKREEQMKLQKDFDKICEKIKEKMHID
+NELNCLKSKIQENTDVNTNEKLFSVNYLNNAYNCTYNLGKINGELTILERIKSSNIFNNT
+HFEYDENTGSFSEMIERRKTEYQFKKIETLNIWKELEQIVGRFWH
+>gnl|md5|7e096aca4eaf9578bfe8cf92ac2aa471
+MFDISNQDISNKTLIQSLLSIREEEANLNTKIVKSNQIIEELNNVIKLMNKRKQLESSKK
+NINILNNNIYSLLGISKLECLTETDFGHNKSFIQELYLKKKNELDVLQIAIEKIRCEISK
+LTGEYKANENWLEKFTCDSKGYSSIEELSEKYLSGVFEQQTMSLCVKDLEKYHKSLQKAL
+MKFHIDKMTEINRTIKELWNITYKGHDIDYIAIRSDAEDNEENFTVEKKSSRTPSGTKSF
+NYRVVMIQNGVELDMKGKI
+>gnl|md5|94d2c146801cbe12149ca5ba8d52e11c
+MNNLSDYAKYILNGELVAIPTETVYGLGGNAYDRSSILKIFKIKGRPINNPLICHVHSFK
+FAEDNVFELSERTRVIYKILTDKFWPGPLTVISKKRRNIVDEVSVSGKVGVRCPNNQLTL
+DLLKLSSVPIAAPSANRSGHISPTSPLHVSKEFDQSYMNEVGIKVWILDGGECCSVGVES
+TVLEYYEDGNFISIFRCGKVTKNQIWETLIDNCRNNEWIKDIKISYFGSNNSSPNRNYLS
+LHDTVAISPGMDIKHYSPTICTKLISFISDTHKCTGIDVDLRNIILIDIGSKLSFLRYYV
+RHYFSLCDDYDFSSACKNLFATLHQAEDFANSLDDLSSVYIFITGFETEDNISLALWDRV
+YRASCGELIYCNLNEIKIQDKYIKRFYKV
+>gnl|md5|596eae36a1b98982c844f88e541b8df5
+MNPFDFPIVIDTGQFQTRIGSSINKLPQIIIDTILFEKIEVKEIKFDKKIFSDKLGINEH
+CIETKSLSSSNNWNPQKKSLLVNDYQDITHPFNYLDGLDWNLLETFWTDIISREMCYDTT
+MCPVLLSEPHNAPFDFQDHSMEFFFESLSVPSFNCISQELLSVDAVQRGLPNIFQKSNSK
+GSVGIIVHFGDSSIRILPIASGYLLSDYIGIINLGGYSITNSLFDNFKTNFKSSSPITHK
+NIDSIKSYGIFDGIITKMAIPYICDEIISVARKCPVDYLRLLLKNIIFIGGSSINSLLST
+YFKNYFKVRFN
+>gnl|md5|4cffb42403ab9fa1dcbeda1560b4b58e
+MINFLYSILFSCILNVRLLFFIFIVVNAANNSDQCINILNSWDLRQGMENKCPNWVVDVC
+WIIYDVKDGEGFNLQRNVFDRMALVVSSLNEIMYKKNENKFAVLILPPFCNIAHWTYNSK
+RRLPWSTFFSIKQNGLPTLEYDIYKRLTGIVNIGAEVVGLNFDWNNKSLQSSTSIEYYNS
+FKISESRHLNSKCFFNNYVRNGNVVYGGRCELVKIRGLICLSFFKLMRFKEVSEEIYKIL
+ESNRKEGKLHNYLIKHTEGILVPWPWELSKYRVLDVISYNNNIRRYANLYMSANTFFEEK
+KPYISVHLRRNDFVFLRNDDIPTFDQVIDRLLQLSKDLKTKRVVISTDSNEYEKNELLDI
+FLKHNLDLHIINIKDHLDDGIISAVSQVILLNGEYFIGTKESRFSFSVIWDCILSVMNDF
+KNDISRNFNKCNEVFCGKANEKSSICREHPDRLPKFNIDVA
+>gnl|md5|fb6bf5ce2b150e16abd930755e1ab34f
+MQKIKTQDDSLSQGGVNTNSALTFEEVNSSIPAFRDDFPVNAGEIKQLRREDLLNEHRRR
+HLESYYKSSAEWSNYEKRQRNDEELEVKSLSSFIHDLILLSPKTKEEYEHVINILRRRHK
+VAPSKAQIIRVYEELVSQKGIELSSDNITMLFQEYSSKNNQPQVGSNLEKALLSKKAVRS
+QSGVIVITILTSPGAFSCKHDCHYCPNEPGQPRSYLSTEPAVLRANQNSFDAIKQFRDRS
+ITLKNNGHIIDKIEVLVLGGTWSGYPKEYQNAFIRDIYYAANTFTNKNNIYDNRDYIDRG
+KLPLSEEVELNQTAECRIIGLTLETRPDYITLDEILQLREFGCTRVQLGIQHTDYWVLKL
+INRGCYMRQIVKSIRLLKDTGYKVDIHLMPDLPNPYDHTSTNEFNLAPDESHILSKRITL
+LKNLQAYIGFDNAQTLGVVNDYLMLSNVLSDPKLQCDQWKLYPCEVVPFSKIEEWYENKA
+YLPYAEIFPDTLCYLLLSCKVGLHPWIRVNRVIRDIPNQSIIAGNSCTNLRQMIHDKMKA
+LDLNCRCLRCREIKDKHISNKQLNQLNANSNGSFNDKEENGNKLKNKKNKKAKKHTKNKE
+NGLNTKDRDIQIVLRIRKYSSFGGAEFFISVESKDELDLYGFIRLRVRFKDEEVVAQNQS
+SSGSKNESDIHSEYNMEEFIEDSEEILEKFPVLKDSALIRELHIYGTVVPHYNNEKEADS
+AVQHRGFGKTLLRAAEYLALIHGFSRIVVISGVGVREYYANNGYFLQDTYMVKNIDASSN
+INSEFDVYFLDYNLETDLFKTLKYIRSLECSNQFKGHNCNNIIPGMAEYKEMTIENYAST
+INVDIYNNALKILPEPENNIQYKNTKDSKVKNLLNNIKYLIFNNFNSRFSWIVGMSIFTS
+SIFGLSYLRSKRMMV
+>gnl|md5|eb62ccd142d2599549587369ee0ea8a4
+MSNKSSERKTFGGYYNSHNNRRKKRDLVVSNCSNTNGSSSTAYNKYYNKANRDDPGALIL
+KLLHNGRNIETASVVPQSSSYIRPQSRTKNCESVEPNFKMQSEEPINVNSENPNATNVNL
+FATPPPNRKGRYSVASSYGTNNPKFVNYSNSGGNKSLQSSSSNPTNFALPMYMRSPNPES
+IPMPCGFPIG
+>gnl|md5|6c10fa5d0df05dfabca2df3e07119c77
+MSLTERVECIAKITDLTQLNYFICGKTHSDIIDFIKLLSESIKGKILVQQHEYEERGKER
+SDIGFNSIINILKLLSKLDSNIDEIPPIKQPMRFGNKAFQTWYDKTNQTCTSYISDILKE
+NSDEYLQEVKSYFVESFGNRSRVDYGTGHELNFILFLMCIHRLGAFQKNDLPDLILVVFY
+RYILLMRRLQSIYLLEPAGSRGVWGLDDYQFLPFLFGSAQLINSNELFPVLTNQILDRSI
+LEIYSAKSLYINSIQHILNMKTNVYFAECSPILYSLTSVPTWEKIYSGMIKMYVAEILNK
+FPVAQHILFGNLIPFK
+>gnl|md5|5d129dc08313293f22c5b94ea6b1e990
+MSDVILSSGIGSQSSSIILDIGTQSIRAGYGGDDLPRSVVPTCIGIPNKEVDLIDSNRLS
+NTIFPLKPWEKRDYIEVLHPLQYNIQEKAIEFNEEYLTKIIQELSLSQKFTNSTSSFLTK
+HNYIFEPLDDRMNGQTLLIPIHSTSNPNNSIKLAEVAFEKLEVASLFTSRRPVLSCFACG
+RTSGIVVDIGASVSNVSCVQDGHCIQGSIQEYPVAGDFLDNEIYKKIHKVNIIPEFGIFK
+NEDKNGPSEYHVPLTNVDESYLNWGVMHVIREIKHSSLFFPNPNSNNDNEFHLPDGNVID
+TTSIRNTIPNLLFKSGNSNQGYPGIVQMVINSITETSNINKEISNITSSIILAGGTTLIN
+GFDAKLHQGIIDQRPSIIFNNSVSFQKSNYKIYSAF
+>gnl|md5|929722f0078c360ad682e5bfcbb29f22
+MYSLTKNRDPIQIEGFCGQLISETEKKSYNGKIEHNFNPYMNNGGSCVAVAGDDFVVIAA
+DTRLSKMYRIASRSVSKTCQLTNKCILACSGMLADINALRKTLLVSF
+>gnl|md5|1e71d68d2b0f915923b23cb64fee0cd4
+MESITNDIFDGLSNEITVKNDNFGDFGVEIGERIEFPLLVIVKHLQYQNGLKHKDFAQYT
+RYCSRKLHRLRSGLKMKCGRSKFQKSYTECSDYTNHKHLLLLILLIERNLSSGADLGCGT
+TKNVNTRLNKVNNRGRLHEIRKLRRGCNLSKLLVEVAKNRCTHRSIVEVQAYQSYILGNY
+YLKCSNWEKGAIELNKSLKLYQQLKLDVSIFEKFNILPHYNISKLSKSECVQAYDDQIME
+MAPLIRLCLYHCKRLDISVHVCDNTVNVLKNNDSFNNSNMKFFYNNKEYNVPISNLEILL
+VELQENYKAVKEYIPSGDTEKILKLPGNVVIELFSETLMSSTTLRNKIHEEMTKASANNE
+TSVINSCQSNEWVAFESYTKEFNSFVSIERDLIFVFQLMEYFNNPEFYTKLTFLNDEHWV
+NISHELQNSTAKKINSSRYPEEGVRICDIVNYTVSEISSSNKATHISDLIDILEIVNNNC
+RSLFLSHCFGQKGKFQEAFVLCDLVKSRLEIKETNFNKIYLDKDGIFQRIITLIKEININ
+VNDMADKSYNIYLSNAATYETIQIKAMDFKNFNETLNDEAISPRVLPIPVKPIMFDIASD
+FILSPDLSNKIKKNGLVNKIFSKATSKFRLFK
+>gnl|md5|cf05a039d505aa8d52deaac52b5da901
+MLFKKIYKCIFSHEIDINEAVPYVVCAVIKEPWSILSLDISFKEKKKNSKITIGLYNILL
+LLLILLVFLLILFSGGITIGQMAPPPIFIGNIYGLPIKTDSLTISADGTFIATLKMPVYN
+KSLLSGRLSIRNINFVPVSTKFVCTPNKSNNNIFSHSILDEDLSNGFIFPLNKKLPTDND
+KILIAKKVTLVTENKDLRQLEHILGRYGEAEAKLGAWLPPGKNEFLMLIKGDVDFEGAKK
+VLNETLGSNCINGVVRSFVVDVQLDFNMRYFLGSISYVQQDIGYVLFPACNK
+>gnl|md5|e5d957b0397f96a4d88ee6782dff4ac3
+MNLSKYGKRKRTEDLGIYTCEKKEIDKFYESQYECNNSGILLVPTQNNEFEQLSNSELFN
+NSELQKVTVDRNIENMQEVCIFDETLSKNLFEEEIVRNSTPTPTIM
+>gnl|md5|0ca405ae65c08faafc5a7488a0cd4b1d
+MEGGVINLKKERSSVRTFIRFCPSKKTIIEDSKECQWVFNTGDHGKSIRASRKSSISRTR
+SCTVTDEIFKEDACNSEIYRKTMLQQHAVDVLDGISTNIIVCGPHKTGKTNLLIGSQRSI
+GIVLQSIYDIFAAIRCYTNGIHINEKGINTETTGNFDRLFVVKASVLEIGEDSSNFKLDN
+VRDLINPENPLQLIKKLGGELGYSIKGEHEHLFENEEKLVASILSAVARKKVLDAIRRER
+VNTRKKKKTPEQIQNTIFGEFGERWVKDDMIGSLLITISVESVDKSELENNISKNEKIAN
+STHVNYGTLRFFEISSCISASPKLKAVIPLFGLLDLAFEIRKYCYTNEKSNRINITNISS
+YIASTIIDSNLTIIGTLSRFPSEKKCCIRPLIAPYDNQTTVQPHSIFDTLQFLEYIGNSM
+KFPIYPQRNCFKKPFVQSKLMEVCRKNLMNGSKKIHSKMIIKSERGIWQSESSGRVTRII
+RLLTFINRSIEGSGILRILLSGNEDDIIRIYCQTLIGSAALDPRGSRLLLLFAPTFLPTT
+PHRPPTCLFLLILPIPPLLRSRPS
+>gnl|md5|942b8e42d74a1ec967ce94f702038b1c
+MKNLDFTIERPKFEDNNFKEISENKAPNKFGNNIKFDEVLLSSSTNERNESSESDIDITN
+IFDSTALERNKDKLDNEDFNVNLCEQFDKSNKSKKKIFISENVGNSNNYLNVDEYVGESN
+NFNDQINKGIGPDSNLFDPVKQYEKLLKKTISLNKLQKSIMESQKNVLQDESLYANSNAN
+SMNDYISKLEGKKPSNPLSLVNKKAIEASQKAIEASKKAIEASKHLYEREVNHSRGKIHD
+HIPASKNFPQIDIYAPSYDSDIEYDKFHNPEDIVFDFKSSNESDEDHKERVLESHYKSNF
+PHNNKSCPCCDQLSKRSKCRCHYADASVNFNGISETSVNTDKSLFLYYEPGAGKNELIKP
+NGRSWDIFVNVPKKFANVTTLGFENGKKLQSDKQEFENPFENDENIEAPDSQIISSYEAF
+SDKDISNITSEFDQNSFQTKINLDSLQREAIENNKLSEKKVNYESNSNMENENQIIKNDI
+LDDLMEIKRQTSNLKHQFILDPKLFRPLYESDNPDKCDRSIKKIDIDQELKSVEKYSCFE
+HNSNIDRLSSSANSNDLNFNSNFNYSDYPNFNLENSSQENSFEGVTPYNSKINQPYINSS
+SNNYSDDKYLEEIEMDLNEQLNNFSKYTNTNLLNTHLSESNTDRSIEILKHQEIPIENVI
+REIGCCHIKYIMPFPKDLKPKIFKGTSNFQFPYLRSLY
+>gnl|md5|65c5b2b072366a6f8d30f3b2afad8168
+MGNKTKRGGDKYEVFGVGGIKVQQILDLKNGEYEVYYKVHKCNLDDYKEINIKLFGQFIK
+TPAFYPVSKVLLDEKTINTNYEIDQNNLLNKTILKFDNLSIDIKPAYTLSMVFKHFNEMK
+KMGNEIDISIPNLVPFPEEKESKTNREIIKRLGILNGSNNFEVNDDMILNDKIRASILVD
+YKNNILKNITNKLIKNEEILNDLSKAIILHCETGKKHDRKLAKDEKKLESELDEITDCQQ
+RMFATYSCLQQGGIDSLPVSFELEDPGKVKSRQTKDRKFYIDTYNLLEKKFEEINLRKEL
+FEKKRDEYTQKLHRTLATRQKSIIKTQRSYNRILDELDKVYSQLSKKQTRRQDLYKNLKS
+DSLKVYEGLENQKVLDFHLKKNTVITMNNERHEVDKLGNYDDNNNNNKRITGRDRKYNNY
+SCLVPTDPESPAFWFAEASYLRDEKEKINQYKKHDDDFNINNLLSDNPQKIKRWDLDEDS
+RWISCPSSVSITFSTMKTPEIQPIKQKGMFKNDLYTENFNKIKNEILSGEKKDPMLPENM
+NDEEINVIIQKDKERKKLFGKMINTKKSNPLEDNTSQWVNEPPSPRKIKSFYNKYLDYYN
+EKLFNVIKEESNNEELKYETDIGHDYIDINLLNKDVKLIPELFWDKDFILNLNAGATQKE
+DFEKIKNVWEDQLKTGREMKKSIEAEKLKLMKLLPKDDFNINHLDVMEYHDENNLVNNIK
+DSNIVKTDWRQINHTFKSDLRDVPWEFLDEISKLGTMPSQELNKEDLQKYIVESLVLNGK
+GLFNIKNQIKESLIQKEKSIRRAQSNKMPHQGLGDDNDGQNPKLGAN
+>gnl|md5|964ea0fdefad642ead35dafb17d161b9
+MCCSNKQNAIRLIKDTHGVHSAIIQDPTKDDLNQINNKSLLSIAMQMTFHQSFESVILFE
+SWRTSNRFDYFISCLFIILMGCFTMFISSINKIYVKEIKKNRVEHENLGIKVICTNVLLT
+ILYYFMHYLLMLIAMTFNWGLFFSVIIGLSIGYGIFELGSITINECSCNSDCD
+>gnl|md5|2e3575bcefd79c3d03e873b779c105e8
+MSRLQHETDGGNERTNKSLQYENFSLESQSIFQRESFDGFRAEVAKSVTSNLQTSYSLLL
+GTSNIKGYSYQLGPSYQSSSKNTLILARVNDEGTVSGRFSRCFGNNIEGRISINSSLSDE
+NKNMSEVSVDYNGEESSYSLKVAYQGIFLLNGLFSQLITNKLQLGGELTWITANNTSIMS
+LGSRYCHGKNIFFNQITRQPDFTSPGRIFANIHSLRSSFYRKLSDRLSLASELEVSIPNF
+ESTLRFGYEYLFKTARIQGMIDTCGKISLQCLDNKGFGISGAIDYLRNDYKFGFMMQFFP
+NEKDDKLDD
+>gnl|md5|a97e559067d2aee71708542405149fef
+MNQLETKCLLEELSFSSLQHFLLSNTRPRIEKLALITGFGNWIPFGWCEFFVKLFETNSK
+HYLQRLFLNHEKVNINSNDFINLLVPFYLPSFVNLEIMFRIIKTKIKTRDEWIDSMKTNS
+KNEFQENQINSLIHPDICNNIFSNLMIVINSSIKITDGLKIRSYTKNKHLDFQTNTQNSF
+LLQSNQLNWEEILKDFDSFSNFMSQINFVTPDLSLPGISQTFRGRQRTENQKPSHEKTNE
+LIHSTSDNVLETIPIFGNMGFDQINQSADTDEFNYEEIPEVYSNKIEKLHDEIESPEQTI
+MRSFQGKIIVIDDSSDAIKYDNSEKNSSDGCERLIEKSTNNELPLTWESVFLDSHDPLLI
+INQLQYHDRIYMGMSPTNYMVLHRSLYEKYSFLRLNYESEYLFRLLWHFSHCCIYHGSLL
+NSSTLNRDFESSIIHPLQCILLIIGILRRSLENPNHSDLKQLNWERDNSDDQYSGFNSSC
+INSSSNKKLNVVERILAISIELLENGVCNQIVNYQMNCKSNYDPFILGSNIQGILDSKNN
+ESLNSILHENESNLESSSNCKKNINSSFEKNYEANINKEETKILNCKNNLSNDSSLSSSR
+ISSLESVIQKVYDCKINKNELSNADRKQPRKVVIYSSTTKSIHKDNFFREETGILKRMVK
+NKQMKETRIVNINQQSKKFNTFSPTLVANQDLDKPQSQNILRSIGLESTNAFCERNHESY
+KDDKLQSKFKVFTSSPLRIFKK
+>gnl|md5|22ae60fa86cdce9e1d2d7f2189c4c5b5
+MKSLFSFDFLGKCNSRCFNILLTGPASSGRTTFLLRHLKGRYVDSATTEDIYSAVIEREN
+CVLNIVDKDIFSQSDNSYNCTLKIKNRNEIDKNGCIVKKKGKDKMQIISKGTINNEDNSN
+IDGILFFIDSSDHGRIPLARRLLMQLLKKANKQTPILIIATRQDIIGALAPGELAAKLKI
+EDIASMFEDQAWDYGIIGVSAYTGLGCNEALDWISEAIWRHQLLCHCIPFNRFCYNLCNS
+GILMLNF
+>gnl|md5|3f7a2623030847a833d1643f73b6f129
+MDGCKHYKSRCGIIAPCCNNEYWCRHCHNESQEDHHEVDRFSIKEVVCRRCNKRQPASNS
+CINSAEYGEISGKKCDVTQFAKYFCSKCNLWDDNGIEKNVFHCDECGICRVGGQESYFHC
+KVCCMCYPLSIKETHKCIENSCRRPCPLCLEDLFYSIKTVSILNCGHTIHEDCLLLLGEA
+KGLTSLRCPICSKSLGDNSQIWNEIDKMIAESPIPEESKELVNIFCNDCNIKCNTYSHPY
+GLKCQVCGGYNTRLED
+>gnl|md5|9967de378f6bdb9dc6cf5e56481e70af
+MPNQQYSLNNAFQNFQRQISSQNQSSSEQISSQSSTYTNQMVNNNISLMKTFVPHTQNGV
+ENDSSISQVIKYLRKNGYIETIDTLLFEMNENDRKLKSNSLDNEMTDSEVENLINFTRKI
+DNIDTQVISDKYSKFRNWILNSLSSVREELISVCFIVFVNICYILYKNSSIERYRNFLNK
+FSDDFSLSKYREAITLLRNSNDLGYLKNAELLKPFFGSKFHIILNRTSISLLNNFLLSHC
+DTLILGIMQEKLIIHAFDHKTNNSDVTLTSRNEELGCLKEVGNFQIGELYSEDSLFIEFN
+SKNSQKTNTYGDISVVAKDISKVLETDMSGKGYSQNNSIINWGLHPENYSGIISKENEMK
+KSKFNRFDDEITEEIKNVEIEFNPINDSNNSFTFKYKKHLYEEVSNRKFVDSTHLPSIIC
+SSLECSNCNEIIDMNISHNHEVGAYCTDDGCIQVFDIENPESKIEPIWIHRNRVQCVRFH
+PWNPEFLLSAGIDSIIKLSIITKDQEPTLYQLVTFSGHSTNSCIWDLSWDDHGISFISGS
+SDRSARLWCTSRTYPIRIFTGHFGDVRSVSIHPNSSITVTGGSDNQIIIWDVRTGKKEGT
+IHNRKVMSGIINQVKFSHNGYLLASSSINNQATHFYSQNQLIVPIWDIRKLCNSNRATKF
+YQLCQFPNDIIDSKKQTFVKSLDFSFGSRVIASATNSGIVSIWDTNVETSFNQTDNPNLV
+NNSAQIYKLKNSSTKSLKFLSRNLLSISSVKL
+>gnl|md5|2643bf8bc7f9223e37d7ba4b815dcdc2
+MKISLSGYKVINLFDLELNRLTIISKNKSFRISIKKLKISVFNWFIFIIFVIYIRLIGYR
+HIDLFFNFFSKFTEKKIASLKLDQVEIYHLKKDGSSVPDAKRSNLINFVSSYFDFELFSV
+RLLSEYKLLGKTFLFGTNIGSIYKKNYSFRKXIILYEGFLSDLMNILMISLLTI
+>gnl|md5|81ea97fdafcb34b824a0191b5ad73c5a
+MVFFAEKLIFNLKFLIREFVCKIEAVQLKVSKNLMDVVVGIAFDSEFSHKKNELYSIKYY
+RGTNSFHYLFDLRQSRAFVNNLMLLSNEDVSVVPYFHINCLSNAKFNIKNIEVPLFYNSE
+YLLDLNNSFFDKIYSSYNEPFYSRYFNDNIFSINCRIDLNVFNLNNISSEIPYSKLCDFS
+AGNATVGLKICFSSKVFKDLILFFGSKVPTCSDIFERAIKIRKNQKIEIPFDLIADFPNM
+MVFKDTNSINIMEFDSAFSQNNSVSIIDIIKNVIENPKAFYLDYNLINSSLCIGFECINY
+RGSCININIFNIISIINISGESLSFSFCNPYNNKLEYECIVENLNQEFIDNVDTKIDSVL
+LINDPMKITHRFYIEFNRVSRAENHCSIKENIIELNETGSQANSKNYRLSLIKDKISFII
+IIWCPLIIVNYSNLDCILKIINAENQEYYFLEGKISKNNSWNSREKRNFSNKNIFSLSNI
+DKKDFIELEIQSGCYISTFSPSRQRENDILIEVEDYKHLLKSNFILSILERHSIKIKVVK
+LMPIWSIRNKSNFNIRITYGKHVNIPIKSNSGYLDNTYLVRNTHFNYDIQEQIKIVFDEF
+VNFFLINLTKHEPYERLINLYRNDRNPNKEWKLIKISFYPIQNGSVTKFNTGIYIELNNF
+NENESSNYFVFENKTSFTYLLTQANGLLDFNSIHVNIHRKENLTQNIRENTLM
+>gnl|md5|d628f062f93d1565219cd20d51979ba6
+MDFNLNLNIYFRNFLHNFVTESQVNLNDAYKPTNNEYILIIDIFPYELCINELFINKKLR
+IVNCKHSINSPKRIAINEFNSIINLSKHLLKNTTYIIVKTLLNKSLNPLIYF
+>gnl|md5|c5f2047c24106185294eb35cd4d933a1
+MVLQRMRATSYLRRTMSDPFSRRRTTLPYIVGIFSQKNDLCKNLMNTGISKNSFKETKIP
+NYTWKSDAIAVLDIFFTKLNILFLFVPFGVLSYYLEWGALATFWFNFIALIPLANLLGIF
+TEELALHTGEVVGGLLNATFGNAVEAILTVQGIRAGLITVVQGTLLGSILSNLLLVLGMS
+FFAGGIFHHVQKFNEKGASFSTSLLMLSCMAISIPTIVAQFDLPQHNILMISRLTAILLS
+FTYVLFLFFQLYTHINLFRDESVASNDKSYPSYMIDNISSVKYPNALSNIEIYNNNIYKN
+YPIISQNFNNYQLYDVCLELPTISWQIGTVLILLCTILISIISECLVDSINGFISEWRFS
+ENFIGVILLPLVGNAAEHITAVSVAIKNKTDLTIGVAIGSSTQIALFVVPFSVIVGWLLG
+KPMTLSFTPVSAIILLLTNLIVIGIVQDGESNWFEGILLIISYCIVAVVYWYI
+>gnl|md5|e3b1e7acbf4eb379682c5f9aa6154b32
+MKNGQLKLADFGSSIHLDDVVCNSQNCGSSCECRFTINRGRREFKYFVGTPQFMAPETIR
+NKPPTKAVDLWSFGCTVFQVICGYPPFNAPSEFLVFCRVFQNGLRFPPDFPEDAKLLVES
+LLKQEPSERATIEEVKKSKFFEDVNFGELISEKEYLNFPPSLKDLCLIQVAKSYEKYKTE
+DLEKLNALDNSGTIVGRLRFEVERKEYEGPRDTWQNEFYDQIFNENISGNTNNCISSSSS
+ESNSE
+>gnl|md5|a1c6f4511015bfb73a37079bfe90ee56
+MTRIKINKLRMIGYWNWLCGDDLCSICSESFELTCPQCLKPGDSCPPAFGECGHSFHLHC
+IHEWLSRARNDSGMCPMCRREFKFQSNANILQSTDK
+>gnl|md5|4f595b7f119710bb8115ea31787baba3
+MRNLDRERELRRRQYLADREKRQLELAERVLKSKELLYASIGKEVNEKKKNELTAEQKIL
+AEAGKMVEERDTDGSLFETYIMPESYDEDLQKRLSIAIIKPQDRLDKRRKFNRSDHDIWE
+SNQARSGDISLVENNRLSTRKVIDQEKNSNSLILSDGSLIDFELLETTSTEVSSEFLSRN
+KIIESQDIELINDVRNSLPVVKFKEQIIKSLEEHPILIVVGETGSGKTTQIPQYLFEAGY
+YKNGIIACTQPRRVAAMSVAARVAKEMGSRLGGLVGYSIRFEDCTSEETVVKYMTDGILL
+REFLSEPDLKNYSCILIDEAHERSLHTDILFGLVKDVSRFRNSDIYLENDIGKNDKIEGC
+ANYNKSPFKLIISSATLEANKFSEYFDNAPIIYIPGRRFPVNIYYTKSPEANFIDGTVVT
+VLQIHFSQIKRSNENMSSKKIIPVGGDILCFLPGQQEIEETQALLESRLVNKDPNSPELI
+ILPIYSSLPSEQQAKIFQTTPYGFRKVVLATNIAETALTVDNIGFVVDCGFCKQNSYNPK
+TGLESLITVPCSQAAANQRSGRAGRVRPGKCFRLYTKLSFITEMEVSNVPEIQRCNLGNA
+VLVIKSLGIDDLLHFDFMDPPPPETLIRALELLYSLGALDDKGELTKVGRTMAELPIDPM
+HGKMVLASQKYNVVNEATTIVSMLSVGNSIFIRPKEKAKQADSIRKAFTVHGGDLLTLLN
+VYNQWQSNDFSGYWCYDNFLQVKSLKKARDIKTQIDSLLSEKLDIQISSNPNELEYIRKA
+ITAGFFLQSARINKGGNYTTIKWRHIVDIHPSSTLFNLKPSAITYTELVLTTKEYMRNLT
+EIKTDWLLEVAPHYYHTDDFNSKGN
+>gnl|md5|8105a63a58491e9f571cbe98176688d3
+MPQETALIYRPLKLSDIFKINKVNLDSFTETYNMNYYGDYLSTWPELCFVCEAPDHSIAG
+YLVSKVEGEGDQWHGHVTALSVSQQYRNSGVATKLMKFLEDISTQLNCHFIDLFVRPSNE
+KAVKFYKQLGYYVHQTIPSYYTDEDGYDMRKLICNKNLE
+>gnl|md5|d38a997805f4b35a58cc73b900afdc88
+MLESIGTDIKHFHMLAKQRQFTNKPQGRKQLFYIPEKQYSTPDLWLTKSNSIYNSYSSNA
+KEIVENTLDYYPNIGREWYIKRWNDIKSIKFQKGN
+>gnl|md5|579902d557d16801fd5ad3f4efae3c02
+MSCVKSKENSNLGDAYGDITRLFSTVTNGTTVEAIKYIVALVGSSKEKMDIEEHLLGYKD
+GNGRNVCHFVCSAKRNDTLKAILKLAPGIVNSLDNSNENPLFLSVRAQDIESVTTLLKSG
+VEITRKNSSGCNVLHYACQVADLNLVKLIISSLKSENPSEIDLFVNTCSDEFGTPLQWAC
+MTNNKELISYLLNNKSNPNKAPLGKLIPSPLMITIGIGNTELTELLLKSGALLAEAMDSE
+GYTPIFAAVEKNDVELLSLIIKYMKLQSCDASNQIVKGNSIYSYAINNRCSEEIMEILKS
+HALDSIKIDNIQQIEQGQSTQTESIESIESSEYSSLNDKKKSPEPDISPEVIIEQDLEDI
+SNYNEVEAERLKAEANSFFKEGQFDKSIEMYSNALSHLMMKKNNLSEGAITLKSSILSNR
+SLSYIKIGDSSKALFDATSCIYINPKWSKGYYRCSQVYHMIGDVANQACYLWDAITNENS
+NSALKQEYLDAFSQIMKKHRQNQ
+>gnl|md5|a6c24a0db9b05299019692d1a716f8fd
+MLNVLDIYDDDSDSIGDALLADMGELLRFRPGVFDGAISISVLQWLCNADRKSHDPYKRL
+LVFFKWLFNSLNRGSRAVFQFYPDSPSQVEMITSAALKSGFGGGLVVDFPNSSKAKKYYL
+CLWAGFYSTIPQTLPQGLTDENDEEMTSASNLGRSGCKLKTKKRGNKREHRVKSREWILE
+KKNLQRLKGFEVRPDSKYTGRKRKSGF
+>gnl|md5|367497b2e6214a504c5ed77f41362b57
+MRYKGTLVSFDEYMNILLNDCEEWIDNTKKGTLGKVFIRCNNVLYISRAEESKETKTDIQ
+KDEEMAE
+>gnl|md5|ef1d42135a1e196927ea1be691168866
+MTDNTDELNESKIFSCEGCGSKTKSKLSCPQCKKLGLKTSFFCSQVCFKENWAIHKLKHQ
+LGGSNKEVAKVSLDLVKKNVILDDPRTWVNCSHISKFIGFNGFTGPLRPYPISIKRKVPS
+HILRPDYADDKEGRPFSELKRKKSSVIVTATAEEIELLRECCKIGREALDIAASMIKPGV
+TTDAIDEAVHNFIISKNSYPSPLNYWGFPKSCCTSVNEIICHGIPDFRPLEEGDIVNVDI
+SVYYKGVHSDLNETFPVGKVDEKSMKLMKVAYQCLEESIKICKPGTMYREIGNLIQSICD
+KQGFSVVKTYCGHGVGALFHCAPNVPHYKNNKAVGTMKTGHVFTIEPMINAGRFEDITWP
+DDWTSATLDGSRSAQFEHTLLITETGVEVLTKRLESSPKLEILSEIE
+>gnl|md5|ed69016b048cb57811d07b837f726525
+MMLGKGMRSPKAEITELTPNSIRFTLSNTDLSMANTLRRIILAEIPTLAIDLVTMIDNTS
+VLHDEFIVHRMGLIPLDSTNIRDFNFKDRCECQERCNKCSVEYLLDVTCEGGATRNVTHY
+DIQPVATSTLVPMPVPKKDDSVDGMNNGILIAKLGPGQRIAMRMTACKGIGKFHAKWIPV
+SVATFTNEADVRINYSLSSNLTLKQRKEIVNCCPKDVFALGGNTSKTEYALNKNSTYSTK
+TKTEELPDLEVVSSKSCIFCNECVNLTKNYGYINPALIRVDTKPDKFHFLVESTGALPVE
+SIVELAFEILQEKLNTLSRGVARSETAQSGLDTNGSGGVNITADERAMDLVLDLS
+>gnl|md5|1c68a819c6945a858a5c0d1ce248e2be
+MEKNEAFSLDDPFDLELNLKRSSMEMGSENHSKEENEAKKACINDEPKKGFGWEICVYNE
+DMGKSQTFHVSEEVGKRFNYFRLLGERSSTLEGNSEVQTTFEIAKIIFQDYGHNNNGIFR
+KLTPDNLEIILITLDYMGFLPMVGSDTKCQEGEEFDVDVFWSMLARKLSCFDWFECESSI
+VSMKIRQKILNLSLKLQNGFKLLLELVQYHQMRDVVISLEGGRIIREIFKNKSEIYGIRI
+INTICESLGAQWSPETSKVEDFLKGVTEENDIFDAISHVWQPTLWYISERKTINKFAQSS
+PHVITGEMSGFPIELELYADQDNEGSATTVNFAMETLPPSPDASITSVTSLGIFAYPKTR
+CTGFFNCFAARAKFYFENTFLGEATFDLSSDGIKAFCPIISGGPNKTGLLVTCRIDEFVK
+KNKDELLKLLMENQAIFRNSETLRILQPSLNNNISLDQITISHLNVDIKIRFFPLRTLTL
+YLLYKRSLEVDTKFVTKFSFSLQQDVAEWLGTYFTCVWIQISKQRDSLFTNRYKSILSLS
+SKSLRGQKGTNADLSVKHSENNTPNPSTRYSSSSSSSSDSLDFLSLIENERHLYGESPHD
+NLLRTGSRTSSAQTSDFIGELTQDSELKDSPFSSCFSDMLSNTCSKIGVNNCYIDPISPG
+ISPFPLITAWFKGVGKPSDSWCIHNILSEILSDDLITRHFTDVLTLIQTCESWVDAESLS
+NIRQQFIHFMNNNKLDSIGALLFDWIRRIPKSQILELKD
+>gnl|md5|87eef6fd9a490d78f23729cf14ec6dc6
+MGHPAGDVSEDDVSSYENDRKLINGKVKDLSIGSRTEEGLLTGGEAASEEGEEPGETETV
+TDNSASGKSDKQGIKGIPRIPRRRSRSPSLEEGQSVEEFSKISGSFSPHNSGTIDSSHKK
+RRKRANSGWDAQSNNSCNSPNLAPVPGNPHGHFSGVSGTLTGNNGVVTNSNSNLGMGPGH
+STIGSGNSIGANSTVSSGTTTGAGPRQSSQISRIYVGSLDYSLNEADLKQVFGSFGPIVN
+IDMPREGNRSKGFCFIEYTSQESAEMALATMNRFVLKGRPIRVGRPTNAASSNGNQSGSG
+GIGGGGSGNVINPNIAVFNNNHITHQNHQIQSETTHGTGIATHSQNRIYIGSVPYSFTTD
+DLRHIFKTFGVILSCQLIPSIEKPGTHRGYGFIEFGTADQAKLAIETMNGFEVGGKQLKV
+NVATALKPQVGGGGGGTQSGVSGATVGQIPMINPIQNVIPSQMPSMGIPHQMVLPSMMQM
+PNVAPPPLPIYQQPPGYPLSNGPAPYQIPSAISGSASGSNIILLTNMVGPDEIDDELKEE
+VKIECSKYGKVYDVRIHVSNNISKPSDRVRIFVVFESPSMAQIAVPALNNRWFGGNQVFC
+SLYNTERYYSSFLDD
+>gnl|md5|95599cadcb7a3d9baedfa4ad4a0b2a18
+MDDLLSSIKLKILSEAQSENLGGSFPENIRKLLGTVEEELRTVRESVLESIDISSINYVK
+SKKELDSLQTETVALRKTIASIETKVEDDLGSSKGVAEMEEIYSIKRDLATLKKASIFFE
+TIAQLHSIFAEFDNYLVEYEFDLAADALSNADQKLNEINFDDSNINQIGSENITGNRAIQ
+QIEEEKDVFEEVKIEYLHRRGRLVSIVELLFRYIFHFERNEIRIRLSLPRSVLMEVSDFS
+LGYDSEKPCSEDGDEVRISLQDVWYSLISLGVVNEHVAYLSKLCIENILDPLVSKSGKLS
+TEKNCGYKLLPFETRSHNECKWEYKVVCNKSGDKNKEFDGVEDCNNQRSVYEHAIPVLIS
+ILKFLSDDCFTGNIQVISLFGKYTWSWISPRLLHGVSSTPTTKDCQILREFEVQARSLQI
+IPAGEDTISNYVNQLETSRYEERKLHALNFAREIIMRDDPSIILVDDSTEIGSLTNLLEQ
+CGVQKSKADKSDGLSNLISLIGEGDLIGNMEIDSFSSIQNENESFLQLQICGVSSCAHSL
+IQKIHQLLDEALLDAQKHCLSSAKQGYFLVRELVMLFILLRPTIHKERLDSDPLFAATFY
+TDCTYLIHHLILIPFTYGSKFPPPIPNIGSFVDLLLTLRKLQETAISSLLTKESESIREL
+LEEKALSMESMKNMSLDQTFIEVETIIVDIVQRLKRVSSMFSSTLPINIYLESFGILVDE
+TIRITLDQVLKLATSDDVQDVSPDDASALVILLNNLASQIQRLFECHIFKINNKDGSASN
+FGVHNSRLIYNDPPSLVGYLKHWDSLTVLRDTLDADIASVVQQKHKIKALFQDYEIRGIL
+NLNPFLSSNVDEVYYIIVSSN
+>gnl|md5|7cf67929c60a7aa575fcf7ecc9d2aeda
+MTVYKSLLNSNALNIFRGYIKGILSDKNGVFSPRSTNICIYKQVADSLSNNIKGLVLHIL
+NEELEKNKEKELASTIDLNLIDLITDNYLYLNAPILPLESLLNNEFERIISSSKDKSNNF
+IIIELPRYFTSNPLFFKNSANKQVEEEDGLDSDNEFCKEVTHFGVFNTTTDDASNKLEES
+IYRVLKRFIERAMMQENFNIHLIMLSPYFKPPQFLLGKGMFEIYLSIEWEASKSNLIQLI
+KDVFKGIEVENGVIEMIIASVSHQDSAFSKLIELCFELKHSLATKYIGRRILKREDIDLN
+CKMKIRNEDAQDFLQKYNSKLLNSYYSSSIDSLIATKISIDNDFVGLNELRKSIKDSINA
+LEQFSERSEVSENEIDIYGYPISWFLWGSSGSGKSTLVRSMVSISPKVKVLLCNVIDLIS
+PFHGITTRNLRRIFKNAINSRPCILVFDDIETLGAFTKKDDISEGEVRSKINKELASTFL
+YLLDSVISINQDGDLGNDLLQLLNINIQERSLEEAIDHFNSKVSRKVPGIMIIMTSRNNM
+GDFSTELLLKVQRHSFLQLPSTKELLESIREKDNDEVSAIAEEIANEIQNLQGERLINVS
+EFKILVQNKLYEKYASREANSKTSEKDP
+>gnl|md5|7dae388443561eb6b2f7e63bd1049d3c
+MPPKKNEQKEVKVLLGRPRGNLKMGLVGLPNVGKSTTFNLLCKQAVPAENFPFCTIEPHE
+ARMNVPDDRFRALCKHFSPKSEVPATLTIFDIAGLVPGAHKGEGLGNAFLSNIQAVDGIY
+HVVRAFESDEIVHTEGEVNPVKDLETISNELRMKDLERVDKLISELNRLTKNGTDRTKKE
+QVAALQILKDVYAHLEAGNWISSKYDWKSSEVELLNEHQFLTAKPVVYLVNLSEKDYIRQ
+KNKFLPKIAEWVKEHIDGVIIPYSAEFETALAELHTEEEKMAYIKEKGASKSMIDKIINT
+GYSALNLLHYFTAGEDEVKCWTIRSGTKAPQAAGIIHTDFERGFICAEVYKFTDLMELGS
+EAAIKAAGKYLQKGKDYVVEDGDIIFFKFNVTNSGKK
+>gnl|md5|e9b149e01964e3b9b209b4bee037b719
+MEYQTRDRLLSAVWPHIESFNTFLSVGLKNIVKNLPKIYVDSGFIQDDCELNAAYSPAEY
+LRIGVTSAKIGKPIFGYSESSGTKLTPQHARNGHISYSAPLWLEFEGYNSSLDTVSKHSI
+YAGTIPIMVKSSNCHLFGLGTKELVEKGEDPNEVGGYFIINGNERVIRYVIQQRCNYPIG
+LKRPRFATFDSFGSEYAVLMRSLRDDGTSTANYLYGTSDHQCIYRVLLNRQEWLIPFWPL
+LMAVGSIYDSNVLRSKILQYCNPKDENLFNTINMLTLEWGLDNSVGVDAEFNSVSFGNKG
+PGDTDILENRYLHQIGRLVWEGVAFHLPPGSLLQEAGRFLIDNYVLVHLEEWNAKLECLI
+LMFIKLIKLQLNEIREESIDSFAYQELLSPGNLYSALFKDAIFSFLQKIRSTYLIEIRSK
+SGEKNKESKNGANLLRDTAYFKSVLSKNISMIPKRLQYFMATGNVKTTQLDLQQLSGWTV
+VADRLNFNRFLSHFRAVHRGQFFTTMKTTDVRKLTGETWGFLCPVHTPDGEPCGLLLHLS
+QDCIPVTQWDSQETLRRLRNYLISHGISCDDGLGSLSSTWGIESSSRDDLYSPDLTKSIP
+VMLDGRVLFHIPREDFMIWENKLRTLKWQTNPSVLPVHAEIACVPPDSGMFSGIYIFTAP
+GRLVRPIMHLETAQVDWIGPLGQPWMNIGVTEEETRKSTKLLEIQKRLIGISDTESEEQL
+KNDLKALKKLIKDNDRVLSSVPVNYTHMELHPSTILSVTASLIPYAHHNQSPRNMYQCQM
+LKQTMGTPCLNYPYRTDNKMYRLLTPQEPTIITKGYSSFGFSEYPTGTNAIVAVMSYSGY
+DMEDAMILNKSSYDRGMFHACVYKTKIISAAPPSATKKSDAESYFFHNIGPDGELVVKEL
+SADGLPNIGQRLTKGSPICRVERTGSGGGPSNATIQTYHDDEVAFVEKINRIASGISIEL
+QQDSLSGGGGDGASSSSGYGEKVSIKLRIVRNPMVGDKFASRHGQKGILSMLWPQENMPF
+SESGMVPDILFNPHGFPSRMTIGMLLESMGGKAACIHGARSLDATPFNINISDDLSRSEE
+NCEDDKAGEKTTVDYFGKALERAGFQYYGCEPLYNGMTGVELPCHIFMGVIYYQRLRHMV
+ADKAQVRATGPIDALTRQPVKGRKRHGGIRFGEMERDSLISYGVSSILVDRLLICSDEHR
+AYVCPKCGLIISSISKRAMAQSISSSKLSNCIPPIAVCRVCKSPCRIITLPYIFRYLSNE
+LAAMNIVIRLHLQQEDVPISN
+>gnl|md5|f1f08cc200ac82ffc669d9db81b922cf
+MNYNDYGCFKPFILSTYKSYFNISLGKALQIWSIICIIFNILIYQITFKNPIGLPFLVYT
+ADKTTFYYYYFTMLSSSILALLTSIFSTRKLAISCLSLTLINLIANIAMLKNMNYIFLDK
+SSFGNRCIFESEFFRDWKKPLLQQCSESYSKICISNEKFHSDHLIRNCGILILEDDLSCS
+NFQKQLISNGIIDKFVNICISPSKYKYQAYLTIFVTYLHYLFILITTPIGFSILRVVYSI
+YCIVSVGGTGWEHLSAEELLLSPQAGLLNENPIIPFRYSLNGKNFLRV
+>gnl|md5|3f8936a20d1c29b81793d00b0ec2e5aa
+MIITLNGQFKVSSATSAVITLEGVGINPNNTAGQIFLKHGSELQLIPRDRVGCSINSNIV
+RNTYGKGNLFYLIF
+>gnl|md5|2af6636b2b13fd411d2cc4f04834a50e
+MDNANGQQNIVSSFPPPPPYFRLFDHEDKVTKIKPPPCIEGPFTCFGSQLSSDISIHPLD
+SDTILYNESNVDLPAELMMLNEMFQMEILKLLENSGKGVVDTSSVKKIIKIYNNMNHILE
+KLRIIQTYYQICDELEAQVNEKNQLLDQMKQHLEEYKSLLDDLSKENSDKMSD
+>gnl|md5|7efb71342e622c24ee0584bbacf99319
+MEIQVQTCTFFIKSKSRNCKFPRYGDSNFCNLHKGIQDQVCDENHEKLVNKIIPCFIDGR
+HFVSINKIRSHIRKCSRVRDIAYELNQPFCMHNNGPPHNLLNIREKLQVTETSHIEEINR
+KAIKNNHSDSKKKLIVSKERLEFVDKLHDFCVREFGKNPHFESRQVDIDNLNLNRHELQA
+ISISKEFTKRLINSENSISCNNSNNNFLFDAENSLIIEYGAGNAILSYWFIKECGKPQNK
+IKSSKFRSVIIDRESRRKQMEKLDESISSIRLRLDIEQFDINSLILVCNSEDISKESIRA
+HMYSSLGNGNVPWIISTLLEQKIWMHDSSGKQIQTIEEVEQLSKEELKYILTTLSNGGGP
+NISR
+>gnl|md5|c54e53b139f40d523d2a284072607f71
+MLNSDRTADFFNFVEKHDSTRSEGRIGNSGQSNRYSNSIQGSQFNLLASEISQEMNSTSL
+KIEELNRIVKQKGLFRDRTNQIHQLTEDIKTSVTELNSRLEVLQQHAQQGFPSSGGYYQS
+NQHYMTMVETLKARMLDITRDFKDTLQKRTEVIQQQDWRRNLYSYSSNSNNLSGFTGSSI
+GDSKTSFSSGTKYSKMSRVPFDIESGEHGMDQGGTEFEFGAAQSMMQHQNQSFSYARSRA
+EAVENVQRMIGELAQIFQKVAGMVTQQEEMIQRIDEDISNTFSNVEHGHAELIKYYNYVK
+SNRGLIIKLFLLLIAFIIFYVIFLT
+>gnl|md5|2e76c417a451b996c18e4e6be970154f
+MSQYNYVVTAFESGSFKGILKVDLFGDGIIRLLAIKTRSMEIYEINKDAVFFDEKLLDDE
+IVDIPALNKVGTVEIYKDIIEIDRFRPKNQDFDDVLIFTREYELILLRAYLLNSDSEKIL
+CMSILDKVSLYRENLRKSQLIKMMVHSEKNRIVILAYEGCLQVVGCEISSKDEENKAVFT
+SPLIIRLSELSITDVCLANTTNERSLLGILYDSGYSKDPRLMKIIELPIDLRKWSYNTNM
+GHVMQQNVFKIAPLYYRSKKQKMVKGFFLFGDGIVEYRSIEEIMPNKTKNSETISSNQKI
+VTSRFNSSAFSGMDIGLSPLSITDILNLDDGSRWLVLDNLGRLFIMLVEYDQDDIDKVVD
+IRLNILNRYSPFSRIVNLGDDLFFLASKLSDSLLLYSKNNNFYIISSLPNIGPIKDLLFT
+NFDRKEETKYEDIPSQISKRDPLPLIAACGFGSGGALKLICNGIGLQNIYISNDSFVGQI
+TRIFSLCSTIGKVIVTGIDHSYCYKIAWSYEKGRDDYKVMDSVDSFNKENPNQPKGKNSS
+PVSHKKFFINFEKCELRGLVKDEETIKVCTFRGNYSYQVTPSGLFPTGETNDHHKKWLLK
+DNLPPIADSGLEYIEKFDFCEKNEVVVICTGTGLLLLYRFDDESVLSLIYFKTKTELFEL
+ISEDLGINHLSEESKDLNNEKNILNNSISNTMDEVCIMGLFSIDNYILIILGTWMNGSKL
+SCIYYNKQETGKIPNFELLLNIETEFREYETMVTSLKVFELERMIETQNKKHTEEFIGLI
+VGTNNGYLQLQYISKDSIRKLMRNGQEKVELKDNCRFNHYNTWKISNSFISEIYETEISE
+SLNRHFFICCEQPKVLFWSYNSGKGKHGLGVWSFFNIHSSWIPFLCQIRIPPSPLLKQEL
+TKKDNYATKTCILYITHEEKAANEIHIDNLANQDPEKLGGIQISRKTSQQPLIKIGLVDT
+LQRYNCRSIPLEFTPEKVCFIKDLNMYAVAGVKERYKGRSTILKPILESEMIENNEKDAI
+KVNELTFIQSVICLISAKDMKIHYCKFLETNTYPTCLEYVTLRASNDENDVRSFLAIGTS
+KVESNIDSNSNSNMGTENFGKITLYSIINKHYSYTLLESAVYETEVAPFVIKEFKMSQLL
+ISIENSLICLELHISKNLADSSSSSSSSSSDIWMNTEMDLELTSIELKRKETYCTHTMIV
+FIKILNEEYILVGDLMRSVGLWEFDRYTGKFHEVCRDNSIAWVVEGIFLSKDMYLISDEN
+RNLRVLMRTLNPENDETYTSLSCIAHLHVGESITTFQQGKFSQAYPETRKCTGGQDCMEE
+SPGKLMFDEQIAFGSSQGGIYLLFSIKDDPKFFSQLVLIEEAIIHALKNSNMDIQLRNKV
+YNLRDSDLKKLFIRNSNSSVFTGVVGVLCGKDYLPLRWELNSTKESYNFEYDCSGTPRGF
+VCGDTIELFLDFPIDLQKLVLKELHSFKSARKLKLPDNVNQLETLIEQLKNMH
+>gnl|md5|85024e9d2a40b93ff06f3bd3517f843d
+MIGLVKENTSNISNNIISDDIYANENSKSHSINSQFQNNEHKRASKNNKAVGDSAFRAIA
+NNFMSLFGYGDTVQSVNETNFSEVPVNQKPNIGRQNVSDIMGVHQIRGGDIVAVGTDVED
+ENPTSGEGQIVNSRLEASNSATLLSSGSKPNPSSKTTSKSNGGAASKLAYEKNGDNSQLQ
+IIAHVSGRPVHAKYSYGKNKFKVAHKIVEQADTMHSGSEKEVAQIPNAPNPNSIIVPSPI
+IQFRQIPVQMVGKQHQIVYNTPLITKRVIPQTNKIVYQPIYTHNQVEMGSNGLAGSLGHG
+IVHKNLYSQEAIVGTNNLILGKELPGLYPVGVGAINALPNTNSYLCNSINNQILGFGTPL
+VGYRSMSHVPNNGFTNIDSNQSSGAELLDVNQETRLQSSNEAAASSVSHPRNGTVGSVGS
+AGSVCQPISSFGLGIPIQVKTLEEDNIKRKENVSSSKQTAQASKQVLRTNNGNFQTLSLT
+TTTSSDTGSVTMSNHVVNAKAIQERPSNTNLDTTKTMVKESSNTQEKIKSENEHDLHKGF
+IPQASPVVNYRSTLDYLVTPMVRYRDIASNLKVKTVPPQLSSDDACKYVTTEITGNNGIM
+SSSNGSNSPRNMNVMGSNEYKETVYTPVAPLFIPNYPVVPGGVGSPGVIEMNNPKINSNI
+NIIPGTVGYTGNSLPKQSQASNTQGSNPINGLVPGSSRGGRIFDGGLNSHIYRRAPVGVP
+QNLGYRLVRTVKNYVGSSKAPIGGSSIHKENYTREENLNYRNQNTRKGYVNKMYQYLADS
+SQFPPLPKEMYVGDIEFLTRPISSEPSAIKVKRFPTNSQDGETNVSQVKGSTPGKGREWD
+SINRGTFCTVYKVRHNECVAAVKCPQKRIHDSDPLMSRYRCYTEWKLLYRCNRHPNILNL
+IGGIRINEYEIWLVTEYIRTGDLFKLIHGNGSRSKAFRESVEYRYKVMYQLADSIRFLHS
+LSPKIVHKDLKSNNILIDENYNIRICDFGDAEELHYNTITCCTAVTWQYAPPEIVGCTDP
+ARPNSNANEKVDVWSMGCIFLEILCKRTPLQHVLDKVDESGKHSTLYNLIHSNKIEGELK
+IPPLPDSLYNLITMCLRPNPDLRASSKEVFDYLVNSEKKILKQLSYINQYKLSSGHSIVN
+NQKNDIKALSQLRAV
+>gnl|md5|9df3a628b85d3b7f2e00a53180615ae7
+MNNLRNISKSGIGYSFCRLLVRKTHNLFGFKFLNIGINQINLARAARFNSTIKDSNTGEN
+NKYVYFGDRIVDKDTKRKLIEQVFSSVSNKYDLMNDLMSLGLHRCWKDIFVENIISPESF
+LRIKREKDEDFSNVTILDVAGGTGDISFRIIDKFRKDNIEVLPNIIVVDSNNEMIEQGQL
+KSIEKGDCSIIWIKDDGEQLSQIPSNSVDVVAISFGIRNFT
+>gnl|md5|143450d2c51d119a4d4a3f57b9ab9ac9
+MNFIFGAILWGLLIFPALFQKCHGNKYRTNLDKYTKIYQYQTSEIELYFPNNDIFENERE
+NSQAKEDIKDLKSTEVSDIRYSFMKLGGKEFLCGFEGHGKNDSLNLSEETNQSWDNMNSK
+IKNYLKKSKISWLIERCFIYTKKKDINNGIHVQVDTFEICVGVSVRHKRQIIDKETSDNI
+LESQFNIVGDYKPTEDTFYENGTIIHYYNPAIENLKGDSGYSASIEFKCSYNKSGISQVT
+EDVNKEFKPVIKVDFLSPSFCDWRVDESKNITSLHKLESLLLPLENRCQNFTDSRFWNYE
+LCNLYAVSQFKKDASTQELRLFNLGIHPNTAQILNITDDLEEYLSKNLISNIVNTIKPGR
+VSLLENITTKIEPRNINELISGKYVHSKYVITVMLLNGTHCPENNQKRSIKLVFECPDNF
+ESISDYFRIVNVIEDSTCNYEMLIISPVICSHPLLMPPPIYKHGKVKCIPKNLIINKLIE
+DESTEHLFESQGTRSESGLVSISQIGNQFEAVNIEYINSIKNGSGTQHFFTLSDSPRIRN
+SNLTSPKFLVGQIVQHLWWNYYGVVVGWDWELNAPKQWADNIYQKYPPESRKKPHYLLLV
+HQKETLFNNSSPIESIPSNLTHSYIPEIALKRVPNLDSDNNFSSKNIIINKYLNTYFSYW
+SEIHQRFIPNTNSTLWRIYPKDFDKLNERDEL
+>gnl|md5|c926df0365d3c88a05d9c2f8035c250a
+MEVNSSNLLVPLHSIGFVTDEVPFALEKLGDEYFIVVATGHYYQVYDLDQLRIKYISQRM
+ENRIENLVTKYEMVYVSMGDKIAGYNRHEKTFEIEHNSRVKGMLVLGELLISWDKETIIV
+SEIDSNRLKCKILVDMDVSEEIVTILHPVTYLNKVLVVTSKGCELWNINTKKMIHRFSSI
+QVVLNASKSMKNKIENNDKQKIITAVTSSHPDIVGIGTQNGMVYTLDIANDMILLSLEHM
+PEQKGVRSVSFCSEKAILISGCENGDIVLWDLENARVLSILDSAHESEVVKVQFVPGVLM
+FITSGKDNALLEFVIDNQNSPPRELRSRRGHLSSIIKTQFYNALPEKSRDLLCISNFKNC
+GYLGKTSTIQQHQNRIFSQNSLKKKFNEKYQFPFSRLPPIIDFSFAESRHFDWPNIVTIH
+QGMHEVFVWSGHNFALTPNLITLENVQRLEKNKQSKSNQSQNFVSHGLTAKRKSLPLAKA
+ISVSGCGNYVVVGYSDGSIHRFNLQSCIHSGQLILPDNSEINQPTMEILSIHISHSTMVL
+CIIRDLDNYYLSTWSIKPIKYLNTKIILSRASVISNIETQEVFISKIFGYLLALGLSDGR
+VILYDFQSQIISREFQCGHHHILDITMSSDNRWIVVSTKNSELFIFDIISSNLLDWVKFK
+SPAICCVFDHSDAFLITSHDQSKGLLSVWANKHALSISVGIEGLSNPPSEPYYIDDPPNR
+VLYFEDSDQALNNDKDSTKESESSDNTNLSNSDLPENGDYDPSLIDRKLMSFSGIPFSTL
+QAILFIDEIKERNKPIEPPKKPESAPFFLPNTSEFSSTIHKPSKESDNEEVISKDLAESK
+DPSSSLKTELQELLEKTSLDDSDSFLSITKLLKSKSPSGVNLLLRQLGPLSGGSFQEIAQ
+MIHYFNISISKRTDSELIQTYLNIFLKIHSTTILENESEFKDFQDIILKLNNLVKSDWDS
+LQDRLQNISCFLKFVTNIQID
+>gnl|md5|448c269cdbbe79c907aa7060a518ef93
+MKDRNFEQLLEVINGNSTHQSNLEKLITNSIPELESNFEILELEKKLIITKFSLGLMEFK
+SDSKTFHQARMSLLALILEKQEIKEILEFNFNGFNPSVHILHSVEIASLEIRLFLESKLV
+ELEDFKFSLDESKDKKQIQDDEEIDLLTSSFRILDSLLTQLNKDENLDFLEFSEKITGVQ
+VVELLDSSKGTAKHCIEFVLDIEGIIRDEYEMDLNKGVLELKGNTNSKTSSLYWIIYYSC
+SISSKWQINEPDQDLDKYIKLLEIASRYLNPLHFASVFPTLIHISVIDWANIPGILETIL
+TSMLSFSTLIKQENKKEGIYSGLYYAALLITSAWWSPGIDTYRIAASKIKDGSRSLEYIS
+RNYLNLDHLDKIQDSKVSLSKLRVEEEQKSGTKMPEFVPLDTNAIPEYSFEDNPGVDRVR
+RISLIIFGLIKEIYQEDINQFQGDQINKILFIRHLDDPNSQNFEKCSAFIQTIICILTLL
+TCRVQNSYIPSELWNIIFKLIIVLTPKSSKGYYYDSPRKITFFISLLRTTAIAFSSGYSD
+QAKQFDKLLEDLKIETTYNIPKLIIRDDCEEFSEQDEESIKFFRNLLDIS
+>gnl|md5|4cc8072575d9c9e51416e170ac193b10
+MQKYINYRIRVTVQDDRVMVGNLMAFDRHMNLVLSDCQEYRRVKKGEEPKELKRSLGLIM
+LRGENIVTFVAEAPPKNQSTKPVEPTFAGNIQTVARGPPLIPPPMMPPGQFPLINPSIGG
+LPIPPPGVPPLPPNIHGNK
+>gnl|md5|9edfd25f6640488fe54cf1c4c1e835e4
+MSLETLSALYPKATKSKNEAERLLEQFELGLDRSIALQQRLSAILNDFCRQVTELKQVLD
+KLKSSKSIDRSQEKIWDRRIDNLVSDSNSLRESISKQLDHIHKSQIEEQKKLSYSSPEKN
+SGVGALIRENAIWQESHIAIDHALEQARSIVFNLKNQNRMLKSVRKKALDMASRLGISHS
+LLSNIERRNLVDQILVYGCILLTSLIFITIYLFIHYVYRK
+>gnl|md5|72c475f44958d61d2d71d062667228b9
+MVIPTVEFSIRVLFINVKGHGIQYGTLGKSSLKSNVGLSTIIQQSLKSLMKGCQIKFPME
+LVNIKEFNYKSSVEKYSPIISKNLASMVMRSDSIVFKNGLFEILSRCDPENSTNLSDLLG
+GFCVVNHTIKNISF
+>gnl|md5|323a5c5d3ae2e1c7e1b36e0d37f05da6
+MILLYATQHGEGNVKVKMRMGNKIWEFTLLCNLNDGSFYVGNSESFDHTNWDWITEFSVS
+MKMSLGLEYLQEKYFSMELYAKSCLKKIQSYLVLSKFWNSHIFLNFETNMKMDTSDLTKG
+DINLSFFDIFEDNFVRYSSNKGSKYKIDSVFGFLREFHVKKENQVDDIEYQNIDKENQSN
+LNISNTSQTTSLKTGYLYVYRFSNGMPIICKDTEYCDIVTSVKSFIRKKGNIFGMKLAKK
+DEIVENNHEKLSVFSGVS
+>gnl|md5|7b8819ef7962700d900b404b31fa4205
+MKSIEEMFYSRSTEDEEQFRSRTMGLVSMETYKRHISDIRRGIKPENVSKKTKIIPESKP
+KKMKYNTLSFEFNQGDDVPDQIPDKEDQSETISNEITLTTIKDSLSGENKSTESLEKHSE
+FDFSTIGKDTSIDTSFLPDKKRELEEAKAREKLKQEEFEKEEKLKQEIIEVVFSYWDGSG
+HRRSVHVPRNTTIGEFLEKCRIKLKSEFKEFSRLSR
+>gnl|md5|a8a28b3067ab1fc856974c2edd114be7
+MENLGKMSNPNQNLGAQHLKVSGENQHIEHDYDEPTIPADCWNESQEDYKVGGYHPVSIG
+EVYNGRYLIVSKLGWGHFSTVWLAIDTLSTPTTYFALKFQKGAQEYRQAAYDEMEILTAT
+KNHASGEEWRESLNRHLESCIENFTRPFSRNFNGVVGFIDYFEVSGPNGQHVCMVFEVLG
+PNILQLISLYDYKGVPIDIVRKIAAHSLIGLDYLHRICGVIHTDIKPENIVVSSSSIPMV
+DFRVINTEEKYDADSSNIKESDDHHIRDGSNSDNNIKDVTTATEITNSTTADSIHNSNTN
+DPSNGNSTQYHGLNAKERRRLKRKNQRKNKQKLGSQATESSNAEEDVIECIPGEAKNTEA
+SEKGKRLSTPPFLKLHLKPMPSDPTHSSYYQINFNSKKLEKSSTEQSKLENFSFNSNMNN
+LNQFPLIKPPYHHHLYEVYHPQQYIANDEQRYTHLLPLTQWNKSYVGGSELLLQENHKFS
+KNSRADSKALRFEVNEEKIMEVSNVIKQISVNPNTFSRNEAEYFIVDLGNACWMNKHFSQ
+DIQTRQYRSPEVIVGAGYDWSADIWSLGCTIFELLTGDLLFTPKATEDFSGDDDHLAQMI
+ELLGEFPKSLIKSGKHSKRFFNKHNKLHKISKLQYWDLKSVLIHKYCINKFEAHNFSLFL
+YSFLALDPRMRPGAQTLLDHPWLRIRGVSSDYLENMLARLERPLTLVDEENISRDLQSLT
+ISENDQGDYKNLSIKQELSEWFNQFKKTLDS
+>gnl|md5|b9d462bbec238a4b2ec387825cd14acc
+MMESILIQGLVGSIIVYMVFSRGKNNLLLFPRLNKFRYIISILLCSSIIAYTIVSKPQTY
+YDIIQVDRWAPRTELVQAIRIAKKKYHPDKNKLDEKSNYTELFYEIQKIETVFSSETKRN
+NYNKYGDFRADGNIEDRNIILCLILGAAFHVYSCLFGLFLSFPSIFRKSRGLFPVYSIAV
+FCAELHMRLSDDPNPLSFLPVIGGLLPFEKIRVLRSLFTCVLIISFVYASNYYRDYDEIL
+NGMLKGNLITNKRIIDLTQSLIVQLQTHGIGSTSTSSGQNKNKKKSNSTSSSSNATPLPP
+KIKVDSDHEQEDPQLEVIQQLSEPLKELASTMNESQKKQLQTVLNIAFTAKGKENKKEGG
+GFLSRIFGSSFFWIILVGYVFQIIKNYLS
+>gnl|md5|6e229c747a5634e3ad38f90e05f61f26
+MKLSEGAYRAKLADMVGNYKDVIKVLTESSDFRDNSLILLLAGSLRNRVTSIRNSLKSIK
+SQEEKLRKEKSLNNEFIQVIEDIKRDFEESILLESEDVIRIIDDNLLMYSEEGARAFCIK
+LKGDLMRYRAEIFKDDEKNQCIKQAVEFYEDALQRERSFLEKYPSDPLYLATILNYTILK
+YDLLGNPEGAMKFANRAIQAAENSRSDSEQFSENTEKLLKILKDNVSQWEQGCSGLLTSA
+FF
+>gnl|md5|d9af817da027deea672a6a53dd45f41a
+MASIQEKLQKFTLGESLKDEFVSICLVRDIHNSKELLEILMKKNHPKLLELTQDQSRQFV
+ILMNARMVGSFPDVSFLKLTSKIFFFFEHYFQIYNLEHILISLSICLLKRKFQSKTKTKA
+FETEVIYNISPSTNVS
+>gnl|md5|4c53e1dae96daebafce0eb719e9e1b56
+MAKLMRQGRVVVLLNGRYAGKKAVVVNTFESGTKDRPFPFVLVAGVEKAPLKVHKRLSKE
+KLKKKSTIKPFLKSINMNHVMPTRYVVSDFDIKPLLQGIDMQEADGKKQALRALHLAFND
+KLINIQSEKGKAPKDLIFLRKPLRF
+>gnl|md5|767d83c054b2091aee057a96f8b7ad64
+MEVVNSAVTIISDPEKCRTWVSQHKSSVKAYISLAIFCVVVFFFLSDGDFSFLLTLSSLT
+SAFSFAMVCLKIEITKSCAGVSLRMMEAYVILIFARLCSIIPFEGYLPYDRSGDWLYQTL
+EASCMIIAGTIVYLCRYRYKETYDPNSDEFNSMYLIIPAFLMALVFHPSLNSWMPADIAW
+TFALYLESVVVLPQLFMFQKERKVVPFTSHFLAMQAVSKVLAFIFWISSYTELNDPSKVL
+KKHVGYWVIIMQIVQLALMGDFVYHYARCITRGVPVQFILMENV
+>gnl|md5|8f918a5cb1a3eeb191b6c9798d7c67cf
+MSICQERAKELAENAKKIASPGKGILAADESTGTIKKRFDQAGIENTEANRAAYRELLFK
+TEGLNQYISGVILYEETLFQSTASGEKMTDLLKKQGILPGIKVDMGLTTLPLTDGETSTT
+GLDGLGARCKKYYDAGARFAKWRAVLTIDQAKGKPSCLSISETAHTLARYAAICQENGLV
+PIVEPEILSDGSHDIEFCAKVTEKVLAEVVKALHLHHVLLEGSLLKPNMVTPGSDCPKRA
+SSQEVAFYTIRTLKRTIPSAMAGVMFLSGGQSEEEASLNLCEMNKIKDCPLFLSFSYGRA
+LQASVLKAWKGDASNVPAAQKALLERAKANSEAQLGVYKGGVGGSAASEGLFVKSYVY
+>gnl|md5|3b2b00222a38c0a1bae85b6bd9b809f7
+MDGITSTTSIKSQFVVGKARWRPGFPSQIAFCCSAIDSAIYVYDLLDPIRPIQRFSRHTD
+VVRDFDWLESDAIMSCGADKKLILSVWEDAAKPNRKIKTSSCLYTPNFHDSIEASQRVVF
+NISHEFFRKTVKKNFEIYNNPVSGETSNSNTELKKQNSDFKSKVRELMDKSDSIFKFCSE
+RNELFKYSLYSVTGFLPDIGLVQFPGDLASILDPRCELERRLHIHELNNRKSDWIRIIHR
+LGVFGLTPSWSSIFSSLGSTKVHNWKVKWGPRIIVHKNKSISELNGMVYISSGRGEDPRS
+FLFNRDSLKKLTLEEKVECIFEFFLEVFGIKILQEQRYMYIIKKKCSLKETIEAISNELN
+LQSNMNNVVICLLIVNNLLPCITPPDSPILKSTILLQLKLTLSLINFLRKLGLFCLSSQL
+IKSSQIKKIRNLGRENISESNFYCGSIIQGNEKDSFFESKSYCERQIKSEKALLDKNFQP
+RTDLHSCLKCNSSKNICVVCSEPVLGLWVGCPCCRHGGHPKHIKEWFLSNSICPSGCGHL
+CLY
+>gnl|md5|c7355fc907e254f627a85cfab46d5dc9
+MSRKYFVGGNFKCNGTKESLKTLIDSFKQVESSNSEVYVFPTSLHISLVKEFFGNDHPGV
+FKIGSQNISCTGNGAFTGEVSCEMLKDMDIDCSLVGHSERRQYYSETDQIVNNKVKKGLE
+NGLKIVLCIGESLSERETGKTNDVIQKQLTEALKDVSDLSNLVIAYEPIWAIGTGVVATP
+EQAQEAHAFIREYVTKMYNSQVSSNLRIIYGGSVTPDNCNELIKCADIDGFLVGGASLKP
+TFAKIIESAQ
+>gnl|md5|184ac5418540791baf69c3e7edda89b0
+MKDSGLEKPLLNGNGFKIFASTESVQKRLIYAIFFCLVFTLIEVVVGILSNSLALISDAS
+HLISDICSYFISLLGIHLSKRKATNTMSFGYNRAEILGALLSILLIWFMTIMLVYEAIQR
+MLYPVNVDGFSMFITAIFGTLSNLFISFVLSVHNHGIGSIGADCTQHNHTHEHMHEHDCK
+QAQTHFQDDSLYCKDQQLVENQEQIGGINTTLLEYHHRSQMRTKDLDHELNNYTNLMNSP
+VIRRVNSGLKECSERQNDYSHLHSNNHYPSKHSSEQESLALKSAYIHVLGDILQNIGVMI
+AGLLILYNPAWTIADPLCTILFSFFVLATTIKILKDSANVLMEGAPIGIDCESIQNDFLK
+LSSVLEVHDLHVWSVSVGVPALSCHIVVASEDNARFTLRYATDLCQKKYGIFHTTIQIDY
+SPNKATCETIHHQKCLVGSNNQNKSEIHQIIHPVDYSA
+>gnl|md5|56ad8fe85ff71e84a2912c157c891726
+MTLSPSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSMITSTSASTILKTQQTLSDLPGVFY
+NDGTRNEQMRTYKWFRPPFGRLTKQQYELVVSRGYNVVMCDVYPNDVSFQGFPQFLAQFC
+TSNASPGSIVCLHIPSNSFRSANIEVLKLMLPELSTKFKCVTLSQLAEQVYREQSSDNL
+>gnl|md5|69569b548cb32f4d119db3fef60d1198
+MGKRRKKKKLSILRLLMTDGNAYQSDLSDDSDIVGKDVFENAAINSLVSGLEDDELGKFS
+REKKIGVILELLIE
+>gnl|md5|7ba212f30aff508c68065de2b3be7e53
+MKSKSKLQVDVEAKAEAEVETETETESETIASDFKVKIKGMKSNRFKFESYINRLSSIEL
+KVGEDKIWNFSSENVEEDKWYSEDNFQDQKMDSSESEVEDYSEIALEQQVKEQLSKTAFG
+DSLKYWEGTVRYSEFVDLVRILKPYRHSLVHIIQHLEFIIKELTHRINECEYPETAEAIS
+FLIGALAKDTRLELFPMLPKIFEALSIRLETPFNEVSITGKGGVGLYNEKVIQSVFSCTS
+TIFFYLSSYILKDLTNYLSIYRKWIYHSSSVIRHFSSESIAYALKKSKEPDIIKSLDIIF
+QFSFNEYNHVSTKTDFLNKWLSEVIVNVVFSINGCISNQGNLVLRYLYRHLGFGLQIEPK
+YLFNQNQSFQEDQEIISSFLTSINDGENVRNYNFKSSCNFDFRKSFTSLNLILKDILNQI
+NDHISDTGNVESLQEILSTLLSIYLEILDSSFPNSSKFHSNSDFNIEYITLHLITCIQMI
+TNTCHYQVNSTNLRSESSAYKKKRFRFNFGIIILHFILANIKNGVFEKFYIEINQSQTEW
+SLLFSQLIVSYMDFVSKITMDGTILHDSSCIHALAYSDFKLSQSNSFIKILSSTVSSLTF
+LASNKGSFNSHPWIWLKSIFEICKDTKQVENRSNLIILVMNSALNILPIFNNKNHYYNEF
+ESFMNIILEYQKFLLEDFLKSNNSNYEPSLKILSNISKFIAQDDSFGTKSLYLNNSDLSI
+LILRNCKYVIANQDLELCNLYIVLELLGYFCLENQYIFSSNLDTSLLQDLKSSLLLIYTK
+LFKLKLDSDLRILDTFETLEYIQVFKLFCLVFSRLDMNQITLIKMTTKIKFWMNLNDLSS
+SSMLKDSISSISTIPLQYDLEIITIVHILFKSRLGKISRFHGLK
+>gnl|md5|b3ec98265907f2e5c31aefed9f6692bf
+MSLLLSVIIDPLVNVKLSLNDSCISNQDNDFEINHSKDLEFLNTLKSISSTILSEIPEVE
+LKGYCKSFFLNTIISHDNINQVSKFWIWTQSHFQEKEKIPEDFGFVYNNQCITLSSYKKD
+QNLQSSFSNKIKISMKHINLYTSQYKIVLRFLSYLDHLLNFMSHTIKDHIHVILIILTNI
+LYLNHNIMKIANNSLEYEKDIQPVSLKLQNDHDLILEEDEEKEDIQRKIAINRVRMTCKQ
+IFISISSILNNYSEFSAYFKYLISPISPLLLSSFENNLKSLSNLHISSIMSFMINLSKEE
+TLLDFYTYLFP
+>gnl|md5|fa4987f61d8a10909c42ed5d1df6d5e0
+MLTRNMKKTNSRQEIITFKELILLKILAFVEINKRSSQDLMNIEKVEDYHKNSRKDEYLS
+IIKIILLLLLSTISKVHSKNENITSFNWNIFNLILNMLRILDINIHIRKDNENDETQDYK
+FCKDKLIDRIGSLIIMNNQELINGDMNSFNSSFLILISDIMSYLLLKTSNLKLRSTISEI
+FLFSELSLSGKGGYFNLILDSMDEYCNNSSRKVNNLQKEELLNFEGFTINSILVKHKDVI
+GLSPEITSNLNILIPLAIYGLNKPSKKKRVLDSSGNIDLQLDILKDLEIILELDTCIKIL
+NKYLRVLYSLISQQLYLIGGNEGVDFSISSLSSRFIKKLVLSWCNSIKTVILDNSEANRN
+DKEKDVMIGYILNILLNLVIPYQEEVIRYSQDLLIKRNILQLLDVIIENFTPLLDQFSVK
+MSISRDLLIEKFHLSLFPIITYTTIEDNEQVRLFEELTHIQKHRRARSLNFFGRFSKFSF
+EKFGKDKMDNVENDIMYLGKYKMQIPVNVYTIKTIGIPLALDALLQKGSGKETYSLSLGD
+NSLRSIEAFALFFDWRFCIDLTGYLIKLLRLFPQRKTYIIKGICSLLNSFDFQINELVTS
+NILDISDLQYKVSSVNDPEQEQEQDQDQDQDQNQDQDQVRAQNPGKNLEEQLNEMQTSIK
+QRLLPLLRSIMVDRSYKIDSKNEQSQIINPELKQKSGVSKSSSQHHGLIRSDIVLIIIRV
+LRCLPSKQFHSELPRLITQLIMALKSKDREIRRSSRSSLKSISKTLGVQYLPWIFTQMSS
+ILTTGYQLPVLIFTVHSILHEISISLHNLNKNESNPILFDDCIPILGKMVIEELNRIADP
+DKRTTSLETIDTPMTGSVDEGKYVRSPQIIRIISKFVSLQGAEKLFEFLEDLLSGKLGNR
+EEASVISDSFSQKYLYWLKNLHFQFCIGFINNENFGQNTKLKFSIYNLAKGVVIDRSMIK
+NYDIRILISSLDKKILNLFQDPLNLIESIKTGTYNPSVLSNTQAPKIDRMERKERYYKIQ
+PGASIGRGIHQVIKRQKGFESKVKSVVLSSSCLYLLNQLLKVVNNVNLPELVSEDGNLQY
+FSINLLLDHLLPLVTINFANESSELASFSCKCLIRVLFIESMESTRNLGILEIDHLGSLI
+SKTALSIMERSGVNSLNTSNGMAELISSSMKLFVALLIRPKSVEWFNGLFFDHSMKKTTL
+FYTNILKQLHITINDNRLRITSLQLLRQIILYGKDQVTVSSDSLGSLYSLVDSVLPLIVQ
+YSGMEPKIVAMGCNIYVDLLLYYPMSEQSQRPRISGSTLGFTRLSYLQKEDQALLTAIIF
+>gnl|md5|45f1f669355ea696e98013bfbabe69f6
+MIGLLPLVINDSSFNWENSIIIGSLKHATRALYQSSTMLKKQDFTEKGFHMYNITNFEWV
+QDIQKFGVYQIIGQTCLFAQRAVERWDKVFNDIGKANILLDCLSDARKSVISSRMERKTK
+LRLDTVRNPEIAFKRKKAMRERIKENKKRKLRVKIENRKLNRV
+>gnl|md5|5e8f1b6324f5b800d6cdfd4da8886c90
+MDPATMNNTRRFRRLYFGNLPINLGLTESSFQQIVWQEMALRGLCLNPNENPILCVWFAQ
+KKGNYGFIEFRTVEETEKALQLDGFACMGSKIKVSRPNDYSQALQSSSSSTAVGGSGTNI
+QSPYNSALNPINNLNSHTTINGAITKDNAFYLGQETALQLLFTLEDTYSLGTRNLDSKVL
+RITNVLDPCQIQDPQESREIKRDFCDGVQYKDSIISSRIITIDDISRLCQELAEKDIQLE
+PADILLEFDSNTNLQLSVSAMSIASYNNKIPKMNLFDEDFYHSHLKG
+>gnl|md5|c3a885d50d2348dd76324fe5a7e15455
+MSSRDYRRRGESSFKGGGFNSSKASRSSSNSSYDRRRYAPAKTNTRQKFKSSSRSMSKSS
+SEYGCRSESMSLSNSRSNSRSCPRAGSRQVQRKSIERGRSKERVKRNYESSPEEFNDGYY
+HCHHYNHQRQDERGFSHSRRSQKLRSVSSSGDRIENRGRAHERSEFKYLRSNVKNHSRIT
+TTHRVGDEDYELNNITTYSHSKSVPGPINSSSSRSRSPSIETNKSENKNDGRNKIRDKVR
+QRDRDFDKEWNRSKSRSVSRSRHSSRSKHISESQNKYKSKSNPRTRSYSCSDEEYISNSN
+TKTSRNRSQYYRNENYYDQGYDNDYAFNKNTEYGNRPSHGYNYDHGNSNYNDYERDSYNH
+GDRNWNNTRYLNRYRDRHENYVNRSFSEERERSRERERRRRRMQAK
+>gnl|md5|644502c758a4780c4fae1d52d7c0a63a
+MNKNNNVCLGRRGRPKKNQPKPSLIDCIEALSEIDNFSFFPIYKKELSNKNFSEIKQIFK
+LKNNFNSWYTLNKSSSIMDFQSDFLNGDTLNSTSTSDNSIKVSFNNDLEEMILNVNSGIK
+TKSDFMPFLFFTNGHVWKMAFSPPSYSINKIFLAIGIHSHESPISQINKRYNDKGIIQIW
+SIPFQNPENEADNSLLPQQVFEIYHNGQFCRFLEWIPQSEKPEKGSAGLLFCVLGDGFAY
+LLSIPLLNNMILNRFNIDDLVVWKYSNPYYTICSASIRIPDVEAEYLRIVGTTVEGILLV
+WTFEAESNSKQNLVLLNPSEQIILVSQNIPLLSASWCPIYSSSLIAVCDYNGKISIVDIR
+RSSNNLIKEFELPNRPITCIIWSRFVNNIYLSHGIGAIVLSVETGDYTQFTIEAYNKKKK
+YSKYEEEQISPILGSRSWTCSSFLHHAIFGFNDGSTIIGPCFEFESKSFQETILIKALVT
+NLNENDPIHINELADDNNVEMNNELSSIECNDPHDVNNNLDNELEAANNLKLFNSMKELI
+TNNYNQRVNRMKQGSINIIWNHENNNLNAVDFLEVQCITSVDLFNYPKLIDQPYVAIAYF
+GGLVAIHKFK
+>gnl|md5|e55b1a0ee87306c334f68cbdad97383e
+MSIENGSIIRLPSEIINRKEFSSSDTQRFSQFWIVNNIINSLFSTNNAHNELMKNCCFKE
+SLFEEIRFQLNVIVNNLELIQLNEKENSKQFQVWKELGSCVSEFIIELMQKWDSKLCELQ
+YHHLNNCEVSFNELASEFNQIGAKVQGMDVIESFIKQEDLWGDEQLFWEVDSVYPLREFQ
+FGVMNEQTLCSTPITIVYLSSLLHPYLNIWSNIRSFFNILINKVFLADLSNIKNAEIQKI
+ELNIFILETLFGNIEKSILIIDEHLLNIWISLLRKCIDTFIKFIPNTPNSLKKFPSNKGS
+DTIEFHDSICILHDILNYYNKYNTCYLYNIGNIFGIQPKNEISILDSILRTIKVDNFLPN
+TSMDLFSDVNLQDQSKAFPINMLFKSSDNNKPQVVQRRYTFQSNIGESFRELNKSLKTYY
+KELFIKENEENKVDFVNPIITQLIKNQINFESYQGIRIINILSCLSDLVILEESSTEQLI
+KTLRLDSKRKFPNIDVDPTEANLSIKLLYNKGIKDDEREIKRKIMSMFLLEFEVSNSKDY
+IKGQLPTFYSLKIRINNTNPNLISNINPSNTQMLICGIPSYLILQFFDKNNMEEYSNIFS
+FLLEVKRCSLFLNQVFQTLIFLNREKQGILLCKQKAKKMANDDFDYIKFCNNNCLIIMKW
+IDSLLYITQKIRFSIQFIVDIYYGYFSMQYPIIWEDFKNHLNSNNSVSFMIKSHKLYLEK
+LHKLTLAPNKRDPNNSEIDQSFQSISISFVILLKLGRRLNILTYKINQLVQFLINVNNVL
+KSKKYVPCMILRRKIQKTVKKIALAFELLYSEFNESKQQFIDSLKIYILSNPNKGMEFLL
+LQLNN
+>gnl|md5|bf3189abbf6097dce0472f792ac54703
+MDLHPHIRALDVVETFWETFNELGNVIILNPIIVKSSFPIRVDMVRDATQKMIQRHQSLR
+VRIISKMTNSEGRKALKRYFIDLCDSAEVVIREEFLSVQENQNLEFENEPVWESMLVKEQ
+NEFFDNENSPLWRIRMMRLGKCGNTYRTCFIGSFHHAIMDGLSRQYFWTELLGLCALSNE
+FPDIAIPKNRPTALPKSVCKYFPSSLKVRLLKPFYSWRATAAHGVCLYRKLVAPFENPCS
+LEISRDLYADFKKSPRTSILPIKISKELLKKLMSKCKERKIQLNGAIEAVSALGLMGLIY
+ELRENRMNRNSGDISELKDDDKSPENQRNRELSTTLNLNCMNNCAPFNIRGSDCFIQGGE
+GNTIIPIRTMVAINCRRWVTKDNPSVRPETSKDVEADLMNVLEVMQNNNNSGTTTTTTLT
+DKNDELAIKNDSTECSNLNSGDENISSLENTEFNEASYANRSRSYKSHSREFFNNLNKIN
+ISLTKLNSQSGEKIGPSWLKKAVSKVMSPKNKKSKQIKTVGLGSYAVLMGLDMKVEKDCM
+SDIDKMWELANNTNKKIHSIVDSKDPSAVTFEWHVISGKLLH
+>gnl|md5|1c255e135073d598983ce457e28086eb
+MQLGDPTIRPSSFLVSNGGLWDSSPLQELIKRINSITTEQEVMVEVESSYSCVAQHNVSL
+IERNLVKI
+>gnl|md5|e2ad0dc07afb315f1ee0dfd9468664b0
+MAVQVRNKKKDKTLWISAEEEVDDSTSNEELEVMNIDDDYDSSDDSEGEDQYEEEGEEDD
+SDEDEDESNTKDWGNKKQDFYDGGSSSTDSEGENWSDVEMQDEEARGIQASRMMRLSKED
+FGMDDIIDQGKLEEDDESAENEAASFGLSINDSETLLESLSNLSNTKQEKESDVLAALGN
+DGLDGIEGLDSELAPILTSIKEKVTEVKERMQVLLNLVKTKEGSGLVTEKGMEYLDSKNT
+LLLMYIGYLCYYMMLKTSPDINIKEHPILLRLVTLRTMMEKLKPIDVKLQPQIDRILELA
+EKSSQVDNFLSSAPRPDRFVFEDEDNDNSDIEENDIFKHDLRDEFDESTNIDSDVEVTEE
+DSDGGKGVYKAPKNLPVEFNDKKLSKTEKMMKELERERQRLLRTDIIRQMRSSIHEGPEE
+VGREETEQLPQLERLQRQIKERINFEEDNMMRLPKTKKDKREEKLYKRLMSQVEGGVNTL
+DDLAQFAERATDMVTDSKKNSLSKYLTNASRLNREITKSNLAQQNSDKSITEKLLKRKKA
+QAELAQKSKYKPEYDSKSADYNDSVDESYAEAEKELFKNNSYLQEVLKLNEEKKMQKQKR
+KQEVDSRNMPNIDDLVDSGSRRASTKEMIKNKGLTRKRKKIEGNARVHNRLKYKKALKRL
+KGTQRSMRDYEGSYSGESTGLKDNVKRSTNLS
+>gnl|md5|d7c7f3c33ffe9ea164ab46be9f53a874
+MIKIYSKLKDENEETSNSLSTFRKKNVSKIGRNLTSNISRFYKTLYEENYLRIISEEIFD
+FQSLKDINGLNLDSFNDFVMSIKSPYIKNIESIPYFDQKHNIGSNERFKIIYWLSLHSNR
+LKFQSCTFHLSCRIFDTFLIETHVQYNNSELAATAAACFLLASNIIETVSDMIVPSIRQF
+CNAAKWLNPDKILKRQLEILTHVNTSFGINYTPSKLLYIYISRIKYHSILSKEFLHLYRN
+GEIIRIFDSSLAICDLLQYTPLPTTKNGQSLISIIPCFILWV
+>gnl|md5|5e63d71065db593cb9085e9d5100b843
+MSSLAYLCNQNNIKNNEHNNIQNDNNNNNNNIINNNTNNNNNINNNNNNNTSDFGIPRKS
+SLNSSFSDQMNTNISLSDNQNFSNIQYSSNSNLDINKLQEIIQKSIPWISNNNINMNINT
+GNDLLNNTNNNNSSNNNTFFTPCNVPNPNRFSNKPKNSNSKVQIQL
+>gnl|md5|9770548e67055ff49f0eb62428f85cc8
+MFPSLEEFNRSWSRLREGGIQDFLPEDKPVLNQICVVCKNKMYFYKESNKDQGNAFLTIS
+PDDTNCHVNSDRNEIILLHSQNDGTRKRIVLDCANMDEFTRWNIALQFGGXINGVTKSCM
+SKYTFDISLFGIVKSNGVEQLENIDTKECKPIYKDFYNITDYQSIEIFKTYESRLKNTPL
+LIIPFKDTEYYFFAKKRQIVFLTRRGKVGEVRIIINLQTLSNFDIINKDLINVDFPLLET
+NSATSLKAEYIVGAKEGLLCVYCTSKNKERLINIKNVINENKYLNKGSNNGNNNNNNNNN
+HLVESVTKKFPECGYIKYTTSEFMCVASRAGRSVVLRRKEDDYDALSVRCKSLTEYEKWE
+RSMSIAGFINSDTTNNAFLPPITY
+>gnl|md5|625b1339a1c6449fbad96106b7fe0ab4
+MDSEFCIEDLIVSIYGTEMLLKQIKERQIRNCLYNWKYKSQLERELSLQKKKYNKYMLDG
+FYALARQTQSICMLFHTMKLIEYKKQRFAMDKLISNFKQSNNRQETIMNKSRSCESTELE
+NESELLSLDENTMLEFQQNLIRYFHGINSLVNIIESKKDKIFYNSFYKVKNFKGNEKQKT
+VISNQKIERNVTKDNLVAPSSPLNKSEVNDKENISSNTLGKQLNNGLTLNREELYFELIP
+EKKQFYTRKQNASFNNGPISNPSLERKTSNISEFAKQKQISRDFTQQSYGNSNHFHKQIG
+NNVVIGNNIIDFTHANPVLFSTIQSPVNSNPVLTIFPPHSPNFNFTNHVNKGKYLQFNNN
+LNYANQLSSGSTPLNTTKYSKDNLPNINNAFSKNQLQHKPELGRNFTIKRYSSNDRKSPR
+SAEITKSILKPCINFTQDSTNLIQNITDSFKSVILN
+>gnl|md5|31d0b50c90f6448b171ee2e7bb8dd91c
+MKQEPVRGDPNQGICISLEKVEDLNDNSEVAFQWKCSCWSTNDEFLLEWNINVPKDLLRF
+IPNGDSLLVSQLGFFKYNDMVYVLVAWNRRYMWVYCHDIKSFTEMHSQGINISVEPKVYN
+LELEDDQDTEDQALLKDQNDHTVSLAIRTGDGEFQFVISTSTLKLHTLRITVSGEIAQVL
+GFSMSSNWWDIAKFNEDIFQSENQNFDSSIFCQEFETESKSHLKSIVGLLKSAWNSSERI
+QRSKPRPAKIPENTEDFDDYSEYTRPSEAPIRTPFDRRKSVKKLRKSTFNEDILIFSFPS
+SYIKWNVSFMCFITAEIPNTLNGKKTKILILFRHDSFGVVELCWTLNFNQIGDFYPSNLI
+AIPCFENNDIRNHENSISTMKIHLEISLGNFHKFALFFIYKSNNSLKLLQLTPTSSLLPE
+TSEATNPLLSWTHKPSFNISLLHEIMNISSFASKNDNNCFNDICNLEQNIQLVSSPQAQD
+IFLYQKSSLQPGITHKCILCTNKHIFIIYITENGHQLICKNILDHSSQSNKIYFTTYSQN
+TLYLLVNYQDIPLKIDLSSPYNNESQEYLNNINNTENEATGESIGNSNFEFNQLILKYRG
+LRNGEISKVGNIFGNSNSESMITNLEMLHKQIISDFKLTKLGCAESSINSIKYTKILSMI
+GQNLNNRILSNNFEALDEEATLLWGKCSFLLDSDYWKDINSIEDWKELSEGTCFDQITSK
+FPSLQSFLIKYLDPIAIISSN
+>gnl|md5|81e28ce69455d144858378fa9f5955bf
+MKVSVTPELKDFFSKYGDKSFKNSDNIDVDTLYKAYSKIVKEYNSINKENGSDEKNVDAI
+PSLQELLLNSKKEIDLDQNQKNATQKNLSIIEILRKRSEERKYQSSIKNLSQAKYSKTSN
+NVPDAFGVHYSRDVLMSMNALIGLILTFIGGFYAPLYMGLEDINSRIFIGIACSILCLIA
+EVGLFMIYDIKRDMREAPKVIKEDPVL
+>gnl|md5|e75e502ad3b4d3be3a4fa11bd8d22253
+MTDHSQIMDSVIATPRASSNGSIFWVTPTQFNPQTGTYQTHYYSDDLVKSGTVSVGTPTW
+KNNSMVPQAIPSSNINSKSVAAPILIPPPQSRNLANFEDPVIRIPEGIKELEYEDDDDQS
+VVDIKQLGQNFDYDSENGDNSNRAKNVVDAVVALGHVLVKDLQKAVPNLKNSGSSIFESC
+LAGSNISGLENELAFSPKNILKDTLRNNTQVKPHLLPNGVTMQELIASGGNIGSSPDKRF
+KKMSSMLSSSTLLSSELFFDQNKFPRMSLITYESSHNNNKAIQLNKEAVKRLNSDFGDSP
+LCFISLIDCPSELFSTLLLNPDLESLSVQKIINKELSDRQQHITNNQNSLVDLYYWYKDE
+EFIYLLLDFKISMIPKLHDILLILANSISSTVVMNNSGIINQESLKKLVPIMDLQKEFES
+RQEKIINKLVNNSKSGGISNNNNNIRSGEFNTPPREVVQELKDDDFKTAQANPLLLLTPR
+YKPTLRSETFNEFNQITEQELDKNNLNHGTPRTLLCTLKTTPRPYLVWLLHDFNFLLYDT
+ANNMILNSIDYFETLMTELGCGYECEDSQITYFENLKLYLRSYYTMKECHTLVSPYTIDN
+SERKIRMDHMKQIACLRQRLLGISKNHAISHKLGQYNSSLTINRYLSIFFKVLNNNETED
+LSELNEIVQRRFCDRILMDVNDYYLSEDKKLMESLPMNETALKGEIKEIRSKCMHLYKEY
+TSTLIDTDIYIDYKIQLQSELQDRENDTIKENLNISVKYCTTYLNEIAKKNISNKLYNGI
+KSNNASFESLNNKNSNINSRKQYSILDLEKDLDDIYLTMLDSLNDKIPREISLNCFLKVA
+NELRHEWYQVNGNGNNMGLNSSSVNSKGVGNDKIGIENCFGSNNGNNRFDDEFMRRMETP
+EMLVNRLNADLEEIDSEYNGYSLMQKKELLEDILLEATKKKDRLSDFYNSNQLYGLDNLI
+TAVQDRLDVVNSERKSIMDNNEIQRQMILKQKHKRWRKFFPCLKKNINYDVNTINNTTNN
+CNNIQMNDMSRSIDESY
+>gnl|md5|92c4a0994a557514858d5827d863b2ab
+MSKLLSFGNCANINGIGGNPSTSMNLNNMRKVLQPNSPGNYNQYKVPLSEYSDKNNAGTY
+YYTSDNSFNNTNKSYVSSPNVYPRYINQHNNIHNISGYQYLNQSNDNFNAPIEYETIPNR
+INTIDESSRIIDSNYQSREKYIPSGTGTGTVIGEAGAPITLGTGAATITTVGAGTGIGTA
+MGAGKLPSSYNNNVISSSRIDLNIAKKTEFGGYANAKSTVSKPNSSNWKEWNSYSKLLPL
+AVVELDVQNECNYLSTLFSSFSNTVKGFISNFEFEKLMEYVNIIEVGYRGTIFSVMDRNQ
+DDYITQVEFLTGMLIFRPYNIKEKNSPNFNRLRLQFIFFYYDSNRDGLLSIDELAKLIEH
+ISIIKVTTNKKNGKPKKKTQISSEKSKKLASQVIRDYLNKEFCSYDDFFQLVNNGILNGT
+VNLLRCRNDIFLQKKNQSSSFSPPNQQIYNKLPYDNSIQNLNYIQQPFSPSSNSIPQSQS
+QFPQISTYNTNIHHPQNFIPKNNSSIYNTPINASTEQFPQLKTIISPNDEYVKTISSKPP
+SPSTLNNSNNQPIFSLSSISKPKTNASLGIQNQNTTETFNYNYNNTNINPSTNSNYNYNY
+INHNNQITPPHNSILSKNNSISSTITRKQEDQFTAHSNSPPNPLLTPDPLSNYRSTYETS
+SPYYNIPSEGRPNFNFSPY
+>gnl|md5|eed183c9db741020ec50e3acea157e2b
+MELPQTFYNGRGIMNNNTSTIMMNNSLNNSTQQKKVSINQNQVGCGLSAGLGMGGIMDVG
+YNQKLFYYQGQYQQQSHHQNYYGYGYNPYYSSGYMSGMGTVHPQYYVVPSPLGVSGINNT
+TQTKTDNTQNIPVTGRKEEAKKEKVTEKNDINECNGSKLTIQPSLLSNRNATTALNTVNF
+AANIENNTSTATITSTATTSPSVATPNITNINSSVISSNKEIPNSSLSSNSTNAVSKAAE
+LNNSLTGRGIGIGTNPVMSYQRYGGLSAVGGREGYSSSYVPAPKVGINVNIQQLGYNGGI
+ASGTKNVGTASSNNNNGFVQNVKNFSYVPPPLTSIYNYNNNNIGEGGGHQHLFQNYHQAK
+NVSSRSGGNVSGTVGGLSARLNFGSMSYVPPIIRR
+>gnl|md5|604a034441a170b90ed31cf1cbc3eb6f
+MFMIIIQDLISKIKCSKDINVLKYQNLIKIIKFVIILKSYQKLDLHLKRRLTKRLGIKLL
+KLLKLLLEFTKEYGYIKDIESNPNNDNIQEEIQNNSFQYVKEDQLMYFNTIIIVLSTSII
+KINQELINEDNNNELSFNSILQEESITNKITIDQLNLALKESYNNRVFKEWKEIIIPLLP
+LILTYYYDSIDEKKSILFIRVVNTNNYPELNTNNHHLSTINVIIVKIIIILKEIWIGMGI
+KNLLLINILRNKELIISYDIGSISNLYYYLLKKVWNFKENSNNISSIELESSEQYSVNLL
+NSISCTNSTTTNTSNDNNKNSGFELEKLKLDFSNEYFEVSDDRFRLNKKEESIRMNNPSF
+FMINMLIYNNRIIPTPKLNLVPNGHYMEGNN
+>gnl|md5|34304b08aa96ef47f9846d56081a7b1e
+MFNMINLKLHTTRFLILVLVILSNIGELLSQDFESENKSSKYDHIADQIYYNRYHSNNAK
+YLVWLLVLVPVFICIPCLIWVWCSDHCLQILKYRSNMKVFKEKKLMNEIILTNLSDSILN
+KELNGSNSSLPSMGVPHSMPPPIPHPPQPQFHPQMGGVMPQPPPIPQPQPSSHPQILSQP
+IIGGPQHNPILPTHIQSSPSYIPNLHIPRPPNMELPQLVQQDHAHHHHHCGFNGH
+>gnl|md5|b640fba68d33221745010dee4698c25b
+METNIDFDQVCHEGSDIVGDFEQNTMEESLDGYKYTEERNFHDINSDKHDQNSSLNNHFK
+QTYEGNSEVIIGNHSIGMEIRTQNEKQDNIEIEKKENNYYTTDNNIINIQQQQLNSKKKA
+SEWRNELLSFPHIFNQVFLSLNRFNDYIDQRWSLLNESHNKLYNLLLELSKTCASINNSV
+PHNIDNIFFIEKSIHNRYISLKSKIINHNQLNYFRVTNIYIPGTELNSENIVRENEFKMR
+LYEELYNKFQTCKNDIEITFERKSEMVTQLDSRINKIVSSIEKFINNNQCLLESHTKPLY
+NIDSSEICEIGIVKRKTGVRGRPPGSGNRGRPPGSTKKAKKDPQT
+>gnl|md5|5fb6c92c40ab2ce97a1ab4ab4ba41e15
+MNVTSTLASPVDQIISDGLNTSNKISSTKISHYSRIPVKIKHYIVSDKDNSKEGEDTDMG
+ENGKGIFNIGKYIDSLYNQSRDSINGNNTIISNIYESEVGN
+>gnl|md5|7f7013a6ddd5870119d8614e55e4ecec
+MLSLEIQRKIPRIYVIFIIFIIFFSNVECLLKKANQTVKFKKGDTNGGYGLNFTPSNYKN
+VIVWLHGLCSSAVEWERFLILVNKKDFLPNTKWIIPTSKYRKITAIYGNECPAWFNITSF
+SPKENIEDINGILESAKRIRNIIKSEIDSGIEQNRIFLIGFSQGSAMALITSMIMRDIAI
+GGVIGSIWLDSND
+>gnl|md5|e202688516fd9ae92145f5a500d18051
+MNEDIWKDGQKQYSCPLCMTSTYYKNDIKMYYGDPCGHKFCSECSTKANNNKKSTSILRG
+SNQICPVCHGFVKYIADFEYGETDFLKFESQARKQVYTILNETRKDFKDTPCYDNYLEKR
+EDLIYKLIYGNDTEKKSTQDFLNQYSKENQVAILDRKTREETLLRNDILEIVQKEGTFYE
+QLNQLSQNATIDHLQIVHPLQNEYPEFFQNFNKNSNNQNNSNNQNIALGSNIPNPIDKNI
+TCKEYLHQNAKKSNVSTYSSIESKQRAGGFTENIVWSLCKNELFFGFYACHHDSNP
+>gnl|md5|9389727b190996db5ac9236092ce6211
+MSVYPSESHHLKEWVFGSLDLLKTKKNDINEKAKENWKDIFRQISNENFEINELLLTSKD
+EETLISYYGRQLIEFCNHKQLPFVSKYNASILYHRFFTNQSVMDYDPRIIIFTSISLALK
+LEEFGLHFTLEKLFGDVPGLNIQEVFRHELTVCNTLKFHLYILNPRNTLEGLRL
+>gnl|md5|f824f3d799391a6de91b3f1ef133c34f
+MNFSRNRKGVKDDSKYTYEPGDLETKVTENGLDVSFKRKVVSDLLICPICEGFFRGATTI
+RECLHTFCKACIIEHIESKGAECPKCGQNIGIYPLQGLVFDRTIQNITDKIFPEFKDKER
+KLYSEFLEKYGDEADIHDEKDLMSLTKPTASQLLNKIKLKPIDSTAYFYNEILLPELEKN
+KTVDSNNQATTILENLSMKIKLESINSEFFQLEKPYLIVPPQITIFHLQNYIMDKSNEKF
+EKIPSIFLKGGQILPRNHSLEFVCRSRRIPLNNLLILE
+>gnl|md5|69b2fd4da92857be5ae5a63e84bab0b6
+MSNFEESEQIFSTSETKIEAGRQQHIILDKKRLITFTLTDICLLLEKVMEQQGDESVITC
+RNIDWNLIASQLDKDPFEIEYFWKVFNPDIHFKPTLGYAVVPVELNLNQETLLLYENVDH
+QTNAIYNYKLQSSVNSKMDSLRNQTTLKPILDFAKVRIQLLNSAFEAKKKFNNLACTPAS
+GAGGESGN
+>gnl|md5|63fff86802813fbd57d1bac22253f0ad
+MESNILCVFTDVDGTLANNENQLSLKNAKTISALMDSHILLVPATGRSKVGFLRMFTEDI
+MDIAKHHGFPGIFFNGAVLIGPNGIDDIMKTWTIPDECMIELCNLLDSIKIEWQPEDEGY
+EEAKLKGETHRGVAYSVYLLNEFVHNVRGSHLRYVEGLSREFSVKVESVVDVIKKNKNQS
+LKFIIGESREKLEEIKDIVHAFLRDKPARVLFSHPLILEILHIDCSKGNAAEHLLKTLNI
+HPENCLAIGDAENDVELLKLSGISVAVANACNMAKGAAQHIVSSNDDDGFSEAIQKFCNI
+QINLD
+>gnl|md5|1898a8eac3f40a59ba465c45f4c2b21f
+MNDNENIENLVGLLKKVERKQRREEFEKYRKASDEIQHELKQYLVKFHQIAKKSEKKALE
+QINSEYKQEERRIEESLEQIKDIEVQFNKINSEYEKGKKNLQSRISKLKEMYSTQLELIQ
+EEERKELRILRKEMKNLLLLSKKEAYQFSKNNIKFGNMKIINLIKRISSDLN
+>gnl|md5|9098a006e0965530ba4f89fe9dadf285
+MIANSMITLYGMDPQIGLTTFNSNMNIDGTSSNSNNTSSYSLYKPYSEATSQAIDNCIRK
+IIHDQYSRVKELLILKKEQVHKLSDLLLNKETVTNQDINECIGPMPSKL
+>gnl|md5|067286880357879dc381d31f790b8fd7
+MVHKVLYREFQEGSPNDISIDDNDNYEEYLKYNVTHITSIQHNYYDILIRLIGVLQVLGL
+LIQTILIWYNLYIGFLSFEFLALLDLSLLSIMYIFISPNVNLLVIFGFLWLVSPILITLT
+ASFSDDTIIALCTIAFLLYLLSHDYTIIYKDLKEIEHQNTDVVALNLSMLGSILLASRLE
+NNIQVYFFLCFSIHILYFSRMVRHNLWNNLPKVYLYVLTPITSITPIWFLYYPLNIVYTI
+ICAVIVSGTILYVYCGLNYKNVIFGPWDVATINE
+>gnl|md5|778627d521d21905786c9ec173a9a14a
+MINNILDLIKQGTEKEKIGNLEEALNIYISALQKWDHICKYQNDERVKKVLLTRMEQLVS
+RAEQIKNLINNNGKGSKTISNPNLASTSTSGLSSSSSSENISKSSQNPSNINDPLKDAIR
+SCILMESPNISWDDIIGLEQAKTSLKEAVILPAKFPELFQGKLKPWKGILLYGPPGTGKT
+FLAKACATEMKGTFLSISSADLTSKWQGESEKLIKALFDVARERAPSIIFIDEIDSLCSS
+RNEQENEATRRIKTEFLVQMDGVNSNSNNNFKPILVLGTTNIPWEIDSGIRRRFERRIYI
+PLPDEESRVLLIKNGLKSINHSLIDDDINYIAKMTHGYSSSDVSILIKDALFEPIRKCSE
+SNWFKKVVIMNNNDEITNNNNAENFKIYWTPCSQPSNIDHYDKELYRKTSLYDIPNNQLL
+PPKLTKSDLIHVLSKTKSSITNLDIDKFTEWTNKFGLSGE
+>gnl|md5|8c2c73755fbf1c7a80521d26c78b0d87
+MASIEVYREAIRTVIEYVSTKYGPEEETVINMILESKGIPGIFRGQSIHPVENMMIGRGH
+GIMLENSMDHDSRIPPIDTNNNNTGLNIISSMIQPAMQQQIQPIIHHPIIQHPISPEIQT
+LIQSPMIAQSLIQQQQQQIHSLTAGTVASSSITINTNTNTNSASVSSPNYLEQPSTTVVT
+TTHNFHTENSGDEKSISSVVAVANTGCNSPSLTSSSYSFSSSSAEPLILSNSNTTTTTTT
+TTTTTTSSFTKNNDNSINSIIITNNNEKDINNSNIMNTHNNMTESTTYNSELSKQLKENS
+NFNIETQVSDEKTNEQININKFDEKENDIEDISEKIRTMLRMATNVNELNQAIKMAYSVG
+LTYEAGLGERKLKKLLC
+>gnl|md5|40157ec6a62ef11fae229d65d934badf
+MKKNTKTIQRMSMIKKAINSIKQYPVPIISHQQFQILEGIGNYLGSQLEKLIKSDRINQL
+KELKDYQEKCIEYRENKINELNLIVDPILTQNPEADNSILETLEQEKLNEKEFNNKIETN
+NHNKNGNQGIPQIYGEKWSIIVIIGILQILKPCKDIDLERIQGLYNFLKEFYEPKMTLKK
+AEKTIKQLIKQDIIQLNKHHFKIEGFPIESEKICYNLTNKGSEISMECIKYNELFEYIFT
+NYKKEQFNNIISQNNIFEIIKLFDFKRKTKVFTDYEIVMIIDYREVNNFNNSLNNDNINN
+CYDDDNNNNNNNFSSKSSGIPKYLLNRLIDQGIRIEFKNLPIGDIIWVARPKLEDNDEIT
+SIDDSFVLPWIIERKTGSDMCSSILDGRYEEQKYRLMRSIGVENVIYLLEDLNSIHENIV
+WSSSSNGPISSGKIAPKQVLRSAQANTQFIAGFHILQSQSIGHTLTLLIGMHQMITRNVS
+NRWRNTEIKQDEIFDRSYIITKIAQDRPSFKDWEINSKKSSNLTVEETFGKQLRSIKGCG
+PEATETLLEIWPTPYKMYEEMSSEITFDDLYSKVLKKCEEIRNMKFGPKKKKHKPSVSRD
+LLFHLYCLFSENIQNGDLNNKHKFEIETEDKRDTQSNDNDSC
+>gnl|md5|a215a92c0b6fe9378c6276b08c7c9664
+MVDGSELAFRLICKKYGCDLGYSPMYHSGLFSKLQGYRETNFQTCEEDDPMIVQFCGNDP
+ETLVKASKFIDDKVKGIDINFGCPQNIAKRGNYGAFLLSNPDLMERIISTLSESDLKCPV
+SCKIRILDHHDLQPTINLIKRLESAGACMIAVHGRTMTSRGVLTGPANWEALKILKSRCS
+IPFIANGGISNYEDIQKCLNYTGADAVMSAEGILENPWLFQGFKTPEAINNKPSQFQIAL
+EYLDYCILYPPPNVGIIRTHLYRIFHTIFSLPGAHIFRDEINNSHQVHEFQLFVQNLENF
+YNSKIVHELRNFSGKIPQIGFWYIRHRHDKLDHNVTRELISIYNYQQQKLPTILQFNECD
+MTDVKVSNNLEIQSDDDISNLFSL
+>gnl|md5|3a9dbefafb32421241d3f1d19db2e58b
+MGINNKGFKIQGNISADNKVKIIDISENKSFNPIKHVRWHMTPQIITEGDDYSLVDPLPL
+FEGFEWYISRETIGHYLSVTIFRGNTINKNRINLIQAKDLHFNGQKKLINHEDDSESLIK
+SNFNSEKDTDLDKYTTEETIIG
+>gnl|md5|d13b567e5d2e9422bc181a8678779a6c
+MDGIAKICYNTKKDEKKERRKKRKLLKVVKDNKNGNTEANSIEYKLRYPYLNRI
+>gnl|md5|69b40f76d8c89cecf913b0cc426dcd89
+MYYLGCNSNRIENYFRSPYTYKFYIDPKSKEEYDSEKAESFKEIANNDLNHLKMLETEFQ
+KVYEIYCQNYTYINGGLEEDICDHGVLLSNVYCYDLEGDSFGTCFVMKHVINPFNFLNDN
+INEKSSTNDLTEIVYFLDIIHNVETVLSHSSGIATYRVGSTYYYGFKDKQKKHSSSGDDE
+NNYNNETILFDGCKTNWVEKKFELSNTKFLKSFLRSNTKSNFNEEVSNENNMQNIAIDRN
+SITIINNQTIYYHISNIGKLIESIDNNVMKQIQHVMIDNLSNISNNLHE
+>gnl|md5|a4b5c38c0ff752b4981e4a2384e51dab
+MMQLVFTSNGNGRSTSILLCDWLFTILDYLDKKKSNSFYEKVCELVRDDISEVDMASVFE
+LLVENLDGIFEILKDAEVKKEIVIRDDVKRSFGELYKESEEFFIPLISMLLHPKFDESRI
+DTCKKIFLEKLMSKGEIPKLRINVLQVYYDIFGQDLELLVNILKYKAQYGCFNNFETMES
+SLDMLEKKITNIDESKSELKRNLYLGMYDIISSESKDNKNYLNKKAYDYLIGFFETFKSK
+DEISQSIRSNSHILDLGVQFLISTILLPEILFFDSLLSMPIYQYIKENYSKEYKVLLELF
+DICYQGTVGDFHDKLQNNNQEYQNFLDKLPILKANESNIVNKLQLLTISTLAKGKSSIKL
+DELEKEFRLSSFDTQDAVVNAISVGLIDGNISENSNTVNINCVTKRQFGKAEWESLDKKL
+NQWMGHLTSLSSILANNSNNNNTNNNVNNNSNNE
+>gnl|md5|f1d26783cdc56a71349df13969d79ebd
+MKTAFQGELNLMNNYYEGPPQQSPRLSVLDAGATGFGLNEIFKVATFATSFDHSLFGITN
+ARAAMATSYFIGLGSFIGFIILIALIRIIYFAAKKRNSRSEYSNPNSQRFVVRSSDDIVS
+NNFGSDEFPAISNRAKV
+>gnl|md5|073e42d2bcb698e758165cda212999ef
+MKKLILYLVLLHIYIVQKYVICSKLTHYSVGGHASTSRVKGRSSSGSSSSSGDFNVPGLN
+GYLCPSYNRDPRGFGCFGMNTAYTVKKNSWQECANQCYWSKYTVFGNCQRSVYNSNNKDC
+YIKSGDNRCVKSPDGMILTNRQSYMIGECATTCTVSTWSSWTTCSGVCGEMRSRTRSVLS
+FPRYDYEYCPHLIEYSNCVVQNKCPENCPQYGVSILGWGCQFESTFSFNKNLFVSYEEDW
+RGCMSTCKQDPFCVAWSYNATLSEGPDSVGFSREYRPCYTHRFASGCQALAPGWVSGNKN
+TINVDCETGTCIHNEWSSWTTCKDPCSNTETMSRNRTVKTVSQNWASTPCRDETQIQLCS
+ENPQSIETCKTCLVGGWSEWSDCSTSCGEGNRVRTREVTKPPLNGDDSTCPELIEKESCN
+KDVECPHVQCELGEWSSWSPCSVTCGCGTTTRNREVKGENCTELSTESKKCNLANCDDNS
+ASCTAVMSVWSEWSVCSEKCDQGVVRRYRDFDFTKIGVFGYNPPGTSEEQNKVREICKDT
+PTLEEEPCTSGVACTPGCKYTEWSTWSSCDCSGTQTRDRVVTFPEGVIDATCQSSKDTRS
+CSKPEGCTETAPDSGDATLAIAIGLPVGILGLCIIAGSLFLIGGRSGDQEEDETSYQYFD
+QPSATLDQDSEYVQEIGPESQNWAS
+>gnl|md5|011811fb018c384d103986864ef93544
+MKTFLRILILLVVSIFSGFVNCCPEYGVYYKGTFCAAANGLEWWGASSWQECRERCRSNL
+FSLIPCKVFAWDSNGGTCTLQNGDRTCKTNNQNVISGNPDVAVTGSCATTCTVSSWSSWS
+STCVPKVYGGITYRTRTIASKPKYPLERCPHLQEVVNCSDRNWGKMGSAELNDENSALNH
+VLNGIINQSALGKDTSATNCPNYDVGILGWGCNLDDDLNYGNLLITSTYSWQDCLNRCKQ
+RSDCTHFNFRYTGTGTSPCYLILGEIGCSFHSIGWISGSRDLAVKYGECDINCVLGDWTH
+WSGCDSALCSDGKAYSKRTRPILTSPRGSGAPCPKTRELKECSNTHTCMANSCVVGQWSH
+WSSCDENCSIVVRRRTVQQIPSPGGTPCPHLVEVNPVDKCEASFSSPLNIANQLSCSVAD
+SFPWGSWSTCSSTCGGGFKIRSRNSSFFKYSAESCNNQQCSVYNVEECKIGNNPNIIYSQ
+FNRLCLITGYSNSEDRLKLLVNYGLNV
+>gnl|md5|4f1c6dc585c696896605dd42d3df4323
+MSVEERKSGCTLKLPIVNEDDDMMDFLEIDDEELVHDVKQAVSPTSSRSLENPDFNGINL
+LLSSTNTTNGVSSIGTSTSSGQFIPYFGQPLLFPNNNQNLLNLVALCISTPPPFTGLPQN
+NPFFSSNGINEQVNFVPFSTAAPLFYFGLPEETLMGGGYTGTGNATKYQQQNQFGKSVVG
+GPSNINFPTNGHIQEIENGVCGGNGGNLMDNEIQYNSAKLRPNVIQNQNSVFPGCPNIFG
+ESGYGNNNNMVYSQQTKLNPNNQLGLINNLNFNGGGSRIGLGLGVGLGSGGIGTGTGQAG
+TGIGTGLSYDTPIEKEYDVNNIKIGVNELNRLSDQGQNHLYYELNQKQFHKNGNSNSRRQ
+NTNMNGVSNSGEQLNSSVSLNSGGNNEKKNRWQLSDPQFKSGYKGVSWNSRMEAWLAFFV
+ENGVRKSKTFSSRKFGFNRAREKAIKYLDARRKGIILTTPPPLSPSKGIYDRIPQQRKME
+SGRDNNYSPGLNDFQTFNNDNINNNCMNINLNSNSGNNMDITCCNSSNNNVPSTTASSIN
+SSSSSSLLETNHTVMCS
+>gnl|md5|b1723c19e36f8def173f3208230e6ed2
+MVSDKNCRVYVGNLPWKAKWHDLKDHMRQAGNVIRADVFEDEVGRSRGCGVVEYSFPEEA
+QRAINELNNTTLLDRLIFVREDREDESSRYGRRSNKWNNRGYGMRTRTHAPRPPLKEENK
+GKQVFVTNLAWKTTQEDLAKAFNEIGPLESCEVFYFEDGRSRGIATIVFTDPNHAQLAVE
+KLNDREIDGREILVRIDQ
+>gnl|md5|b9094a8af3cbe0bc6694ad54baf4f55e
+MEFVSKLKSEGFTIESWHSLALHLYNAEELEKCETILQECIEEYELLDEKLTQSQNQNQH
+SDIYINRLKDSIQTIGMLTMLELNLALGCFETNYRKSESIIRRIEERLKQFMKLFSCNYS
+SSNHFKAIHKYWGFLYLYKSVITNEIDLSQRNTFLDQAEKEFTITLESNTKDTQAISGLA
+NVLYQKMAFSRALRLFSTLLLILGTEKCPNTVRLAMACCNLRLGNLKKSQECCKRAIFIC
+IFGAKTDDDTIHATGDDKEKMETLFIKKEGKEEAQLNRDLLENETFIDSLTQFERQTLSD
+LLLCYSKSTNYKGLSLKNAFEIIAKIFPSHPALVLYASNAEFYLGYTPNSNFEKELYNIS
+KRCSNFYCSLEAHFHIAKRLHLRKDIANAHSHYIIVVDVLKNFYNTDKTLLNLYLSCLLG
+AIKTSCGLQKWDVSTQYIHKAFESLGIKGSVDSLKDYNLPIEYLYEFLIPTISLVIMSIE
+DPAMIPTTISIFSQLTIEERLLNCLHYLFFILDRMDDINSKQCYIIVFLLQKITTCLLFR
+GRRTIRRSDYNYEVITTLISKYTNYSATLKPIPLIVILFSCLKYLIVNCNSLPSPRDSER
+NSSCDNPMLNSTPYLRYKDLVRENFGIYLNNLGVCIMECATSLSPEHCCIGSNEYTMLNE
+SLEIFNQSKEWFKKSILNSNKTVEIVIRFNSAICHELKGFYANANDEYKRLTSEFPWFTS
+AWLRRACLALERNDYQLAAQYCELSLNSKSPDIGTLNSGSNSEPNSNTNSVYSWAPGIGN
+NHESANLLLSHIYFCQKKPDKSFSALSKVIKSKNTYYSNIGKVLLGFALYNKAKYQSQSN
+YSGEMSIYNPTSIQSRLVLSEVLRHESFNYIASNLILIQAAECGLFESSKDMWKYMTDIS
+SALEGAASCMHYVALINLGVLHAVLLAVSTQRNPPPAQHNLTLRSIVDDNNVGGIDGRNE
+VLGSHPHFAEQKRIMKTTVKLFQQALQFDPTEKTIHMSLIKCCFDMNMWEDARKLLEKAT
+LRWPSDLTFKIGLTYCLERLVYSEMGDMERAKHPGRVKYWMMLCEAVGNFYHWLSIIKET
+FQVVDMNFINQIKNNKLNVTSLQKFVPGIVMHNQDNKIVLNTENKDDLRYKLSAIPLEGT
+DLLPNIEYLTKQELIMSRKLYSRFEELLPIVEQVYEKEQRDVEELRIRSEDFRKKQEEER
+RRKEEEEKVASERIKLLSIELGKEAESIAASLPDIQVEKRSKSSKRDRSDDLERVEEDDE
+DDDNDDELASGNESDPYTGSDSQSETRSNLDSSSDVEEKKRQHPSKSLKNKEKKSRKDKK
+KKKKRQEDRIRSRNIGSENSFSNSNEESDVEQIGSKMRDSSSESDTLASKLKKNKKKKSN
+DAKKREEKRLLKLKRLEEQTAALLEEEEKEKKEAQPQENTNHDGLSDNEKELDHEENQGR
+LRLKKRRFLDTEDIDLQLQGEDES
+>gnl|md5|f2c339cf9cdbb0c1d50834ece3dc6912
+MNPGGFLILRCNIQELGKGQNMNPLVQIQASTRTNYTSLLYNINEDSVEIHDLSWYLTSS
+KTVLPDNTTFSRNDTIHFAIGIDTNSFSTVS
+>gnl|md5|bcc2d7623d460527c920a6eb2bbc5b38
+MRKFLMLKTDLNDITTNPTKRNPVPQDYMKSTVSYSNKKELIYYELNQFLDFNSFLLLFF
+SNINITILVCK
+>gnl|md5|3ca587251890778357d397728ce41dd7
+MLDLESEVCMSQYGYKFPVTKSLLPTIYPYLSIQFIAQVENSKVSRFGFVCSDSLSYAVV
+DCNQGTVKIAVLLPSRTGSSEPTLHSINLPTGLKCGNPSAQSWVESRLIFQEKSMNDPLL
+VKGVGPFTSVWTYSTDLNEHTRSFEFPNPCPSREVLFFTSGFKNVQTQMIPRSLFDMKFS
+TPNSNLLLPFETASSYVIYGTQKYNLETFSISMGLPNYPDQKLVYETNSSDILSLENQNK
+TISGKPIFVHISLLPFTEQISLSVNNKAQNINKNSYMIWDKKDIENNEEMDSKTIFKKGA
+PELFTGGIYGLNLTSFDTDSPIYTTYTTGFCAFPGAQLVEPLYEVVDNVYGVDDCNILCQ
+NDPHCWLWSYNIVNRQCSFHMNAVSFEYTSAPDVVSGPRYCQCNYEMPNQLFNLIGKNVK
+ISNNNNNSGGDYNAYFSENTFECDYPTFGFAITNGDPILNTTSPSPQICLKEVLADRGGI
+ASYWTYDPITQRCESAVGGYLRPQKFGPPTTPKDLAKNNHGQNNNAFLLGGEVPRVHNTP
+NNFRKLSLDLFEKLPTINEENKKSMNFENLIPEMMSIPDVGGVSPVYGFKDNKNEKDGDG
+DGDGDGDGDGDGEEETTTSTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTSSTT
+TTTEMEITEEANEDEKNTEQNTEFSNLDDYLKIIEQNNENILDENEINPDEENNEEYKNI
+YDIATLIVSHKSINELTEEEVTEAQSNELNQEERESSIEKVNEITESILNSLNPNQISVI
+DTQIAEGIHRNYSIATLKIPFNSFEEIKQEIYNNYNYGYPIYFLKGLYKENVLDFNINGF
+DDFQIIDLTFLFQNISFCDISKYHATIMVLNIAANIHKLLNCSPHMIQITDFPPTIIEQN
+MYCQKRVLEYTVR
+>gnl|md5|da478a5127f53fefb5852b77596dbefe
+MFGQRSSLIPFDFVFSTINETGTGIINIEGENYQTFIPQVKDSDS
+>gnl|md5|c000387ad9756bb367fcb5c5199997d1
+MEIINRTLDSIFVKCHDIQVENIKYGELVVLIESDDDYSGYSDADINENYGEFDGENEDN
+GEIADESSVEDVLEIVXQAKKKKKEPTIYEIEFGNVSNTSGKCNFDDLIKFLHRL
+>gnl|md5|4fa6d04ca8bb90c3fcc998326ede832f
+MKLNNAFCGFSLYMIFIFLLGDVTGIHINRELQNLSIESEGNIKVGNSAKDSGDDVNDES
+NSIIKGEEEKNNDQGLTTNNTESGNSTTTENTSDNNETVSQNITEADNNNNNNNNDSLKH
+HVYNGTFDLKKTFFLDGIAYNSKF
+>gnl|md5|b87009b21af009d12f0db55752c17a99
+MVQRHRLADWRHLKSRVVFKNWDNTHKKRKVLEDTERNIKELRVKKKNRMVQVNNKGILD
+GVELREGGIKGDPYLERVNKGHTGLGADAGSLKDESKQVLNARRGLVRMIIDIILGKDTT
+KQYKEGSAAYFIDKIQKILRLISLMFSLFILGFIITSRINKGRKDVSSSFPVGSLGRSIK
+FEMMLDTLENEHGKLGGEGSFGERSKVNVKGIGSKDVKGQNTDYDENLEEFNSQVLDDPE
+YWADDNDKDLWDDDIDEYYDMEIVSSEDDENDEELGNNNTNKENSNTIPNESSSQIIQGK
+RNKGLRSKGVEISLPSSLILYGRVTKEDTYINGAYNIIIEEMKDGKKYPKLHHGRAIYKK
+EGKTNGNTTIPTLFIIFDGTHEFWTITSSLDPGLKPLAFLPDHALIPIRHVGPYGAHSNS
+TWVFRNNNGILKDSSVRIVENSSVDFPRIPVHITKATHNWHIKHHRETKGRTNSNKKNVS
+NYNTDLKVFKDPYK
+>gnl|md5|ff3b3f9f64b4981d6922521ba90f1d1a
+MRYYRENSFSMLKVLELRNLYIPLDTFDHLILMFSLSNNNSRYKFQSYEIEGNQLLYNYQ
+KVYATYNLKFEDGSSKNHYYNINKYHSMSIQEESDFMLNSDYTNLGFSHPDDISCKNKND
+YDLLGMKLKDKDNYNRNTKESSKINENGYMNNKLQNKSPFQHDSQVMQPFLDIKRWIINI
+SKTKENNNPENISNVLYSLNTHILILDNQLQEMKYQSITEIHRNLISRTILEYLVDPIKT
+CLSISNSRIVLSFGFDNLIYSGYMLGVLFEYQVTLKELSALSFLIPIDFFCQLKLNRIQV
+LKVSLFKDKNLEPKDLIQLCSWIERYGKNLNYIHIRVTGSSSKWVPKEAEITRLINLWKK
+MCPRTLEGKSQEKIKFECCFTDHIFSKMEKLPKDFEYDTESD
+>gnl|md5|463f444984ffd2ae98d1557d9ec794ec
+MLEIISEIKDLTKDISVLKVKHHELITKITNNQILITISGVHPRKYSAKLEMLFRKNFIR
+NLHEVEEIFHKTSHNGCDSEISNDYLSGLKPDEELRSIKEQLLRRFKDRE
+>gnl|md5|6e0f4c3af3a88654246d1ddb39774c20
+MAPILKHALFTLKAPLYFQLLPARLLITYILFWYSIPFLVFANNYNLGKSQNNQCNDILN
+INCTKITNHTVKKNTNINPTIQQNNLMNFGSYHYENNHQLGKFETDLNVNNDNSTYKVID
+GAPSETLFNLKPKFSEKFEDSSPSKCYILTVSGGGAKGSFSAGLLNGLAFIYRYHGIKLR
+WDVTSGVSIGTLNTIWSQFYHVGQSTHFSTEGASIWSNFTHKNVHDCKKTLSKNAPLFIF
+RAITEGKKLPNYLCSTYPMLIFMRHLLQNRKRFKGPKWNALAYHFKSALSYYFNEEVPRS
+IIPSIIRSSSAFPLVLEPAEISGIGIFGDGAISKTIDLRGAVHRCLQSGKAKTDKDIVID
+LITTSYTNNEFHSIIDPTYSKTMLESLYWFFNFYSFTETYQQYEIVQTIRRYPNVQFRHI
+LSCLDDKDSIVNKMGLLDFVESDVFESLNDGMKSGFYNSTMFKDFWSPVKRDITPHTDWK
+PYGDNNIIIPNQDFKVSNPDTDAFVEFPKLENKPYSLPTIFEFMSSTTKVLDNNNNNNNN
+NNNNLLDHKIQKFILELHQNILSIRFLENVREFIRQRDDELLYYERRI
+>gnl|md5|836086b15c6034eaab8ffef29b96b654
+MGISKGERQLQFVPQRYLRRGIFSSVDLSSSIYSALPESVCVVKIPDAISKEVNSLLSRG
+EKFPFGIQPTPFEDFRIFDIYLLGQDYVGILVDLPCNIEVYKSLDCESMFKSNNLNQMLY
+IYDANCLPKWFITSQGVNISSIYKGPMKSNMMYSDQTFVSFIKYLRESLHWEWPAGLLPA
+SRGVRSRKYRNTELFDIGEVIEAEQELLDRVSMPSQDMVTIDVISAKEMDEQIHLFKHEQ
+KNSPFPIASVFDKKKKATCMGIIGRDDDLRSMISRFKREDSQKKGTKQNTLEFEDIQSDI
+SDVIFRESSDDENNPDNSLEMEPNNIRISEENLSKTTIRENSSNNKLVISNELSLNEDWD
+SHDSSSDD
+>gnl|md5|56427cf98c1b4e3dae2528470d82bc33
+MRKQNSTLPLPRGSRGDSLSMPHSASSTFSKFGSKYIGTGTGKQEGQGLWQDILRSFMNG
+LQGKNAENLHGTLFVLGRANGGKSELISELKKISEKGKEKDIKSVLVSSEVDSSPYIGLD
+FCSMKINQGFFQLEQDDSIEDSDQDELNKDLNTTPKNVTLDVWSVDHCGMSDELVKRLVD
+VFNSQNSRLTGNNTSENSSLNVSSTDVGLAVTNGIGGGSLDDDCRDGLTSMQSPNIMFLI
+VLDSSLPWTLNDDLVIWIQQIQECWAKSLELSNLSPDLQRIMIQEVNHYFETRMEEIVAE
+AEQSSVSRPEPGEKALQDTIDSQGEDTEQRTQKLSEIEASSSNASSSTSSSSNLYPKVNL
+GIPIGVVLSKSDIGQRFSVPTDGATGQPFIPFALSFLMNVGDSYGISFFTTSIQTSGDIH
+QTSGVDLLLSYILHRLFDTPFTDEDGKILKTVNDIVNKNNSILCVLPRTPIDRLCLSPIP
+NVKSDIYEEMVQKSKFSSEISNSSDALELVHGLSTAFDKKIPSLNEFLEQIRPQIPLIEA
+ASPGAAPVLLSLTAASNSEESKSISSDSVSIKGTAGGASSSAISSSAASVSGSSQRLKPS
+KSNLNANSPGASGDPSLKGFFQSLIQRGEKKGSLSHRSNLKPAPSMNLRKEFGSRMESKL
+SSEVKLDEKTQESEVANTNSLEIEKVGSLPNVEENTVNPIEEENETVAVTETATATATVT
+ETATETVTATETATAAATAGNEENNNDKQTE
+>gnl|md5|01c929521974bfd2093f144b863bdfb0
+MKTRDISRFAILLLFGVFLTISEASEGPIEPLGKDDLNGEESIRYNENDNNSIPNFQAAV
+LSDGDIEEGSSQTSTSTDQEGHSEKGDKRKIVINSLLPNTEYCTEELSKLLDFHSIISSS
+CGVDALKKVGGWLHKHRNSLPYWPSINISPPKNRITFYGCDWTICEREVENQIDQKLKKL
+HLPVKQIGNTVQSDARNYDSAKRAIDIQIRNGNMSKCELINSIGIWWCQKALPQLITDKE
+TAYHSIFKEFNIHFDQQSTVSGSTSMSDISNTEDQQTNVTVEEDQELNKEVSDIFTMASS
+NNGKVNKDFYKYPNRLVFLKTALEDPMECYVIQPEKDYEATTNELREILDNERNRLESNL
+AFVLQIGTSIWGSNKAFSPLGKITNSVQRIISTMRIYTEEIRRDLFKLFPPTDSNSETVP
+LPPHEDLVILISEICRIQSITDAISLVIIKLLRRNKISKKASEDAEHLLMNWMFADMNIN
+KSLIPVTRPVVTKKSSPLFVERAKRMKINASRITKFMNNIADKD
+>gnl|md5|6353c8c5c398442a5087523c8218be1c
+MKVRLILAFKLFLGILSFALVSALDLDLNKPDTVNLRISSRQLEQTYNFFTKKLSNSEKE
+NLIKLNSSSEYARSTIPKGAGYDFTVQMAIYTLSESLYINREYFKVNLISDSNKNKDIFE
+IANCLYSTSSSTLKALKLVRQRCFHHSESSQLNIFPKKVVKKLELYCNQFKKIEVRYARL
+SDFIYLLKMILKKSKIHNSNLLELSKLIWGIIKSPSFKKIKFSKDLSAPISSKNPAIKPS
+KKEAATISKISSLLRHIDNTLLEKIKILPFWIFKVSDEFSIILIESQSIANRIWFPLEEQ
+IELNLKKLRKCTSSKRQPCCSHKSKKYKMSRDEKFIQNVRDVANQIRSDIE
+>gnl|md5|08d8afe30849996361ea28830b0277fe
+MPGEHGGTGCSCQHEAVITSGKDLLSEIELDKVMALNELNVGSCRGIFRPYEDRLSEDKV
+CKSQDDDPELIIFVRFSSPCTIHSINIIGGENGKSPNRVNLYINDENLDFSTISDQEPVQ
+SLDLVEDYCGTVDYTLKVSRFKNVNLLAMHFPSSFTNDQSWIYYIRIVGESSGYQRKAVQ
+AVYESKPNVSDHKSNIESLNHFSLM
+>gnl|md5|298f7709116bfbe37aaf62389554f759
+MDLDVEFSDSSTEGEFDTLGKCISTEDISPEIISRNQNQAQTSSCSRSGRVRKMRYSNFS
+NIDNESELSDESLSEFGQTSKMQKTRERSNRNKGGKSRSQSQKSEDLDYVNEEDLYDGDD
+EEFMSEDLNNNVDAKRTTDSDDGDEDFYEEPTQKKRGRKPSKTKVSQTSGVKRTVRSSRK
+AVNYLSFDDSVSSDSLSQDSDEVEVDAEVETEAGMSVSAQQNVRTIDRVISSRQNPEDPN
+ITEYKIKWMGYSHLHNTWESAESLINEGVSGLRRLENFQKKMAEMLQRRKFMTEDEIEQE
+DITFEIQRQLDFDALIPERIVDVYRENDNSGVDQNSAEDRTQLYYFVKWLSCPYDQCTWE
+SYETLEEHKFLSFIDSFYAQMELVSKFDKNCDYEMRSLALTSFEPYLSTPFYMGIKVKDM
+LNQSKDLEKMEIDDPISSNIQEMKIEYHSNNENEHGNSITEDVKMEIKDSQKLGKIKEEV
+ENIEESNDEPFQPRTLRDYQIYGLNWMISRFKKNVNILLADEMGLGKTVQTISVVGHCLY
+MEKIVAPFLVVVPQSTSDNWLREFKKWLPDANVVLYHGNAYARELIRSYELSKIEMKDEV
+DENGNYNENLESKDEVHNYNQKGMQSCARAGTGGNGFFRRCRSRSSKQTRKRYRFDIVIT
+TPSILNSQVDCDFLRQIDWYMMIVDEAHQLKNRDSKRFKELHEFGTMYRLLLSGTPLHNN
+LEELWSLLHFLNPLRFQNYQEFRLRYPDIENPNVIGPDKQRQLEDLQSELQEYVLRRVKK
+DVEKSLPNKVERILRVELSPQQTDMYKSILTRNYDELSKTTGGTKTSLQNICMELKKVCN
+HPFLIHRPELDPSQGITIASIQHQLVYGCGKLCLLDKLLSRLREKGSRVLIFSQMVRMLN
+IISEFLVLRGFRHQRLDGTMGKELRKKAMDHFNSPNSDDFCFLLSTKAGGLGINLTTADT
+VIIYDSDWNPQNDLQAEARAHRIGQKKQVQIYRLVTKDSIEENILERAKTKMVLDTLVVQ
+GLNNISTSSSQTQASSSAAASVLAMASQALYPNGKKPGSGGASFSRDELAKILKFGAQKL
+WSKGTNNVPAQSQSGSDSSCGQCADGQCGETCMHRAVNVDGTQGVENKLKEDESSADLFE
+DDKRFASQIDLDQVLADAEEHVHDTQGLADGLLRSFANIADFRYEAPPLIIDSNTGALVP
+LNEKKKEDNEVDFDSKEFWEKTIPEEERLKLIEKNQQNTIITGPRKSAMRDGSLKYRDDG
+YTYVGGDNSGSEDGRTGRIGDQGLEADENFGTKGKKQSKKKTKEKSVKKSSGSGSSGKSR
+ASSSSGGSKKMEVGLSEQIEDVEMNLGSQKDLDKTPESLGELVPNREEYPLPEHSLQSRE
+DFEALMLEITSFPHKYNQDDELFPSEINIIYRDISNGVKCVKNGKRARRDSRVLHPKRRF
+KLFRSILKFGDPYRRLDDIIIDSRLKGKVEKGTILNESQIIVALCYEKAQKELSSENVVA
+TSKEEGEIKDEDDVQNNKSNNEATSILEGQSTTDSTIMGGGVPLEVGSMEDFAEENDIEN
+NNQVSKTALKKNLLLIGSHRANALELVERIKMLSSLDKLMRECNPGVEKPWKLPTGPLAR
+PDRESVKRDEDNENEDDVDDEDEDLDDEEEKEKSFELSNENNLEEKKIEPTNTENENENE
+KQSSPNGNEFDGNYLKFELPPVLVKSLRTPSWGIPWTLQTDIDILKGIYIYGFSNWTMMS
+MDENLSLSCIKRIKFDKLKQRTLRVMKHLHSVMVIGKTARKKRKFIPSSDQEYNDFNKNE
+NSSSKRGKKVAKKCEDQNKDGTDLSGHLVNDNSNGDNNKGSTKSSKPLVVGGKKGLPEFV
+LECSNMDEKELRRQARTCFNNSNVKPQLLEIKKLFHPSNNMTDSDVVASLKVLLPVVGDE
+INEILKLATNEISRNKVHNCLWSYVAKCTVFQPHDIEKIYLSWKGINPPETNTETVTEVN
+PDPVIEPEPEPKPENEPKLEPEPKPGNEPGSESKSEPEPSCSAPY
+>gnl|md5|a36a166190dab1147fe3ab13b66e7dc9
+MLLPNKNNSEEINNNHISTTPNDNLIIKVSNQLRNLQNLPFESICAGDQTINCGENGKCI
+SLPNVNNQKQFLCVCSDGFTGPSCETGKFIDKLFILSFN
+>gnl|md5|0d3544d8fd115dab87fcbf4c6930b1bf
+MNMMKILIATLGGAILFGCSFSRVEARIQMKAYGSIVSTAYYYSDIFIGLPEPQRQSVIL
+DTGSNLLAFSSTQCQQCGTHLDAYYDPFKSITKREVPCHSYCKVCVNNKKQCAYTIHYLE
+GSSLSGSYFEDFVAIRNEKGINSEPSPYVVGLSTIFGGITHETNLFFTQAASGILGLAYT
+ASSQERAPLFQTWTKRSKYAKDAILSLCFSSEGGMISFGGYNSEYWVLGSNDKSFRSTSE
+ANLFERALGYSFLSSSSNSQSRSNSRGNNLDSKIGWTPLSILNGNYYVQLTKVSVYQTKL
+TLHKDSSSGNTKPIPLVIDSGTTLSYFPEHIFIQILNVINQRIAETENKSTFRSLIEAGS
+KFLEYTGLKSSSSQNELELGIKQISIFPGEVPGAALLRKRVYRRLNNIEDIVNTFNSTVH
+PENFSDEDIESSNNQLNNSNEVSNHFNQTTTSTTTSTINTLFSSQEFDIDSSVSRIMLET
+SKGERCWKLRDPNEMSRFPTITLGFPGLKVEWEPAQYLYKKYRNTYCLGFDSDKSFLVLG
+ASFFINKDVIIDVKNSRASFVKSNCPQIAHARRTSTSEMSQLLKDASSSSPESIMKSEVV
+VFDSNTKHINIENGNSNNNNNNNNSQSLNLSSGTSSKNPPNYRHSADNDTISESHWEPKN
+LTSPSSLSSYLSQSAVQYIGVTNHSVDYYNQSINYENLGNNDMLILYLKQQLHDIDDIAD
+NTGNPQIQKNLQDANNSPSDSKNENQDANSDNKDSSSRYSNSQPTIIHWLIILLTALFSC
+YLFNGVDQKDAKTE
+>gnl|md5|26934a29ad3ebb12468cf2e22a789962
+MNSLSLSHSLGKSYLFERYSRFGMSDSIIQRNFQNPVSVYNELLATELLPTTESDFSAMV
+KLRVGSQSMGVQERRKLGSKKLYGDENEYSRLNSCEVFDPFATVPLRSVSMDPAWLSSTN
+MGMGPISRKIPKGPFKILDAPNLQDDFYLNLVDWSSTNLLAVGLSSSVYLWSASTCKVTN
+LLNLQDQDTVTSVSWTQQGNHLAVGTRQGSVQIWDVVEQKKVRTLNGHRARIGAMDWCGP
+ILATGGRDHTVLLRDVREQEHWCSRWLGHKQEVCGVKWSPNEMQLATGGNDNKLLIWSQG
+YDTPVCQFQEHNAAVKALSWNPHQSGLLASGGGTADRHIRIWNTVTNSCVMAVDTGSQVC
+NIAWSGNVNELVSTHGYSLNQVILWKWPSMQKIATLTGHTYRVLYLAVSPDGQTIVTGAG
+DETLRFWQIFPTGRPKGPKNLAALSVPNAPAMR
+>gnl|md5|dfc46e74fe09b5ca7f31d0caf74b0254
+MSDKRHGSPCSNGNDELNDSSVLTENMDTVATRSKNLPFHETYKSKPTPADKPYRVDGID
+KYKELYEQSIRDPESFWSQMARKELRWLRDFTKVRSSGTCLQDRLAWFLNGKLNVCDNCV
+DRWAEIQPNTTALIWEGDDPSSIRHISYIELFRNVCKMANVLKRFGIKKGDSVGIYMPMI
+PETIYTMLACARIGAVHMVVFAGFAAQNLLERLVNARCKIVVTADQGSRGKKIINLKDVV
+DKALEKIPEIKTCIVFRHLNGPIEFVKGRDFDGETLMRSEKPYCPLEDMDSEDPLFYLYT
+SGSTGTPKGVQHSTAGYLLYAAVTQKYLFNIHPGDIFGCAGDIGWITGHSYLVYAPLCNG
+ITTLIFEGVPTYPDAGRYWEMVERHRITHFYAAPTAIRTLKRLGDDFVKKHDRSSLRVLG
+SVGEPINPSAWRWYHSVVGEERCSIVDTYWQTETGGIVIAPIPGCFDTKPGSATFPFFGI
+EPAILDPDTGKEIDGPGSGVLCIKNSWPGMFRGIFGAHYLHEDLYTKPFPGYYFTGDGVL
+RDQDGYLWITGRIDDTINVSGHRLSSKEIEDALTNHFGIAEAAAIAIDHDVKGNALVCFV
+VLKDSGNRTFDLNNSSPHPFEYELRMCVRTQIGPVATPDHIIIVENIPKTRSGKVVRRLL
+RKIASGCNDYGDISTVANPECIKSIESSWAQYLKR
+>gnl|md5|0eea2f76065970c44aa03d690f3389a0
+MEILSKLLFCAVNILSGKILEWLLILLDVDNETKIKGSVTLRRFLISTWLLNPFPVVIAA
+RGSADIIPSILVLITIYFLMKAKYDSFNNKINIIISAFFFGLSVHFKLYPVIYGFPFIFF
+INPNYLKKDRPLFWYILNLPIKIFTNLNIDQLIFGLVSFSTIVSLISFFYYLYGWEFLYE
+TYLYHAIRKDHRHNFSVFFYLFYLTMYSVKEVLASNFVYKALPYIASIPQMFLVALSGIS
+LVREGECIMAIFCQTVLFVAFNKVCTSQYFLWWFILFPLALRVYLTNNIAQLDESKGIIH
+SASASFTPILISLGVWLITKLSWLYFAYNIEMLGQPYFLSVSF
+>gnl|md5|3c0ba647990c8e1165d9bea9bdb6ffe5
+MQGIEILQNRGYDSCGMSTIDDQGELITTKYSSKESGDSIERLKNDSELLHGNHHIGIAH
+TRWATHGGKTDFNAHPHQDYKKRISIVHNGTIDNYCSLKSELMEKGIKFQSETDTEVIAN
+LIGSYLDDGEDFQNAVQKALSRLQGTWGIAVLHKDYKDLMILARHGSPLLVGVQSGHIYI
+ASETSALANYTNQYVALQDGEIALLSHEGINKLITPSRLLSIDHEKVESSPSPYLHWTLK
+EIYDQPHALARSLNFGGRISPYNNMVKLGGLDQRLDELKNVQNMILLGCGTSFHAALFAQ
+LLMEHISGFNTVSAKDASEIFVTGFPREHAGAIAISQSGETADTVKAINIADKLGIPKIS
+VVNVVGSMLARTTGCGVYLNAGREVAVASTKAFSTQVLVLSLIAAWFAQNRDSVISQRCQ
+ELLEAIHRVPISVGVSLQAKDQCEQIAEMIKDNNSIFVLGKGYGYPVALEGALKIKEISY
+IHSEGYSAGALKHGPFALIDKDSQTPVILVILSDENQSLMMNVAQQVKARGARVICITDD
+ENLCKDIDCEKVLIPSNGPLTALNAVIPLQLIAYYLAIKRGINPDKPRGLAKAVTVF
+>gnl|md5|96f3fc60607dec165f689b67be882311
+MSFFKLWGILLLIASVEAFQNRLFNASRIELLEAEYALDRLGLWKKFADGNHSDCMEFTL
+RIDRMLNAVANVDIGAMEQFIEMDEYSLKYQDICGTKEEHTISSLYENAPGWGGETPLTI
+LARSSLPRSSIMMQVLSSKGLDFVKSQMNGFTPLILAIIHRNFSGVKVLLNLAERQKYAL
+HLNKTEIVNNSLDDKNTKTTNSVLRNVEIINEVDSMGRTALFHAVLMEDDGMVESLLMAG
+AEPNIADFSGVTPLLLATKKNLLVIVKLLLSKGADQIILDPRNRDPLSVAIKNNHPDVIL
+ALLEDQTFQTKYLNFYQSSRYKGQILRPTYHIRRLLDIFTVLQLKEEAIQSLFKIEFLRN
+DTSLCDLRDNEGRTIVNIATFREMYDLLEDILEFYKNASIYRYEGYTSCNPHIIDKSGRG
+PVDYLLTGTASIHNSFYSLDNTIENARKINKYSDTYESIYKNNIEIQDQKGENPSIEFSK
+MPTSSLNFLSDRRKFLLTKLLKLPNPLDLSSYLFELLRKGGNPTVYTIKAMVNWLGGSKD
+LLLHRTSRDGHNALTFALSTGQLTVAREILDILLDSSISNQNTYKSAVKLAISYSASVHS
+SSIIAEVALRKPVIVHEWICERKFNSMIEIEEVKFVLQNLPREFIGFSKHPDLCKPLYTI
+TKQILDPESQIESTEIVAIMLDTNGGLPFLERSDVTMALKTVGTSLSISASFGLNIIPCL
+EWTSTMSYTFTPYFFDVINKLDTNMTKSPQTSQTNKTQTTKDSQDILKCMRQNLSRTENV
+EKDSSSNCLSSYNESPSIKGQNSSNFEENQTFNTNGLIKNSKYSSNERIISPKINNLKNP
+GKIVTKYGLGSTITSILIGHGIMAAKRNQILDLVFSCPLREIDPILKNFQRNVLGITLLI
+LVIWILITSFVIIFSSRSRLDIFGFIPKYSSSEPDRQAFTMAEWKFYKLASVLRFISFLY
+CIVIFISIGRVRHLLFTLFFLFLGLFLKLNQFLLLKENDIVDITSAFIREEMSDNDNTAL
+NKDLEDNDDVNDQSLGMGNPMPAGGNEETRQEGIHLGTIGEEISASHSSATFTDSRNTFQ
+SDIVKREHITAEQYALTTLFIGICSFVIAISSNLQRFLFWNFREFYRFHESYYFTVNHTY
+IAISTEIILILNTWSLTFNILKAPGLMIFILTQRIQVLRYFLLAYPDINQNIFNSLKRNN
+IGFINKEGSPNSSPAMNMHLPVSKGAVFVPPGRFDVVLCQWVRVRYAIMKRMHRRFTVAS
+KPYNALYFGIGFIIFVFLFNKNNIGHNFHLGILNYLLFDEFGFTLLTVFASYSITLIVIV
+WLACTSNQISEFQHWRLFWDAFSFMPPCSAQQVVLQHIKLTQDLDDEDKRVDLWSIPITN
+FVRNVLLLCIVVVWVHISIIGIFHILI
+>gnl|md5|8d4d1738c6a86088f1087b3572401c5f
+MIQEGDGNNGQGFYYEPKDYDSVLIWLHGKGDNANSYLDFIHTAQNYPELKKTKIILPTA
+DIITFKRFGFSDNAWFDMEDLRPYALEDLDDINNSVSRITRLISLEIEKGIDPKKISLGG
+FSQGSAIVFLISMASRKYTLGSCIVVGGWLPLTERGFKEGKESKIATEELTFDVRESVKE
+HVDFIVLHGEADPVVLYQWSLMNKDFVLEFIKPKKFIYKSYPGVVHTITSQMMVDIFNFL
+SKRN
+>gnl|md5|71bcf940a365559cf27d11ef700fed44
+MKKRLLKPVESEEELDEELPHPVGEESSDDFGTKKKLIKNKFGVFSENADPISQKKEKRR
+AGTGVLGTLIDSIREKVTQKMDDSEFESVSEKDEQFKASKVKRSTKKRKKKGTDSIDVSN
+LLCSLDNTSKQKSKNKSNRDLDTMFESFSMPSSDSESNFGSKMDDFENDVIDRKVDKEIH
+DNTSEEDDEFLNLTEIEMALRKCVKNDYNPSLELNEWLPTQCIDARSEVARQMDDDVIIN
+EITEKHEFFYSQWIEQIGYLSSLTKGFTRSIRECFVREGQISSISNIKKSNPELLLDPED
+KILITVQNSDACVILNRLVNIANSQEKLIIEMSKETGISNIDEKDSTIRLKYGIISLKAR
+SKLWWFCRMAEHCGLVGREGNNMIKYYVLDKSRKKTSNSIFSTNADIISSIDPSMELFNK
+NDSESNMDDDNDFTGDECGENHVETEQISEMDSKWLDISSIKVSNKVRPWERRAKKVETK
+SQNVEESIANGSKKELFKFMLKNIGPRPIWTNSGAIGDVNSHNKFNIEIEPPTNLSLREQ
+GQMKIKWLQMKNQAEKLATHHFKIMDPETKDLDHDSLKYWCKLFKVNLLFPPCKSDNIRR
+VGNNDTINSNILLEKNPEIVEIMKDRKNNQYVNNQKISPLSYFENITGTKRNSLPLDVEF
+ISESDGEGMEEIEQGYDHAPEVEEKKGEEKEEEGEEEEEEEDEEEEEEEEEEEEEEEEND
+EKDIKGADDIDQVNGNHYNERENKMVDVNEYHSAEEIFDQEMDEKTESDKEGNIKEREAN
+ESSEEETNLKMRIEAHKRLKAIRKKRMKLKRKMMERYGHLFENEAEESDDDGIKILRRGI
+GGDYSDDDDDDDDIDWDELSGFSDFIDDNNYENGELDGDAIQAHLKHMKEIEEKQYRQLF
+TLEGIKERKNKVYGFAAGQDDGIEGETRLEKKKNELLFNSAFFDDDVISEFWTDEEELDD
+YEEEIDERNLTEMLGLNYEEWQNSLPKKTNSSDESLNEQRKLKYNILKESLIKEASGSIN
+ILKQRLKSIQTKLSIEENISSKEKNQLQTKYIECMEKLKKLLHSIHSACNKCIYENPQFF
+DHIDIYEYIQKREESRNKKKFKAKNTVEDKIKQKCRYQNKYLRENVNPLNKIGKTGSDSE
+DDIINRKRVQKNGKNIVNVKGGRFKISKK
+>gnl|md5|8cdfb7b969adb1eb1f99a44de5dde371
+MISGKLQVFILGFFLIFLGVHSESSLLSEGTASLSKYDLSEHSKDNSADSSISPLFPERT
+MIDGSLNDAPIEKASDSSILESSKSASSKNVPSFVDASKSDQSVLEEKSGLFTENLDEKQ
+EGSASPTFPAPSEYSVSKVSEGSISPLVEKSKSSADYEKLLDEHDEKLQSEYSPKNQEES
+IMLLEDPNYTVEDALALLRKQRKIHESAKGKNRKSSESFASDYESERIESPTLKYDETSR
+SGEKEQSISSAPEDQQYDELTFIPKELSLPRENERERSATIPITSNFEPSKKDTTVEESR
+SSLDKSLKEPEPLTEEESEGIALEKSEEVEDSELYKAPFSEKSRSSKSVEDEMSNLSENS
+VSEKEKTALVPSENTISAGNQVSQEEQSSDEEVKDQVEPQIVTIPSSVSSIDNEGVKESQ
+HSENNEASTSPKLESPIIGTESESEIENETDDSQQPLNEADKSSDPRDSGSEIVPEQEEE
+NLFNRSLLEEKEPSGGADEFSHEEFMERTQSSPQLDNSPLLHAETFRNEDSANQLRGILL
+PLVDMFQVSIGCAAPCPYQRYFIQTDRILKRIAKIEAKTIEMSNIMKKAREVTIKEVSDI
+FKFHNTAAKRRALLFVQKYLKSIKLLHFKVDSAKKIVFLALKVRIILQLLPSKYSRDYSS
+EELERISSQIDLAVNEYNNLRSALGSKTIKYGLLKYLSLNDYDSRIKSIRSILESELSGY
+LSKLPTFQKFVSRHRKLAFTLHDMMNKAGYPVKKRFFMVDRKGLSKEHLKLYKKKVNEDS
+KQAKNRLGKEYQKFKSSQENKWKNFTKKVNSG
+>gnl|md5|ce24eca1257aa23488915b0e5bcb61f6
+MYANMKTPDNNEPHPLSEVDLEDQRIPDEYKDPEFIEKSLEKLAMNITDIYKKVSDDFKI
+PASDIDTIKDSYHEFLETVEIWSAIAGEALIFTGNQIKGFSLSKKNKLSYFYSREEFYVY
+QAIFNYSISLIASLDSFLNLRRNLEEIRELLRKSFSIILPYKPIKDLSERFDNNLREFKN
+NYNHNVRFFCRNITINECLGTMKDDFYRRNEKFTNFIARNGSLKRAVSQILELFDFKVSA
+KDHLSTNGGTRDDVNRYHAIKGYLSNQVPIFSKKFNKKLLKEQLNIDRVHATSAIKALLD
+KRGLSSNTSSCGNVRWESKNKKQKLITKKLKI
+>gnl|md5|6e3f60cc9c1644f492af839bc17a9d06
+MFSCFRSCSESPFCLLFGFKEEKSNNYGTDRSQRALSSKMSEASDVKEKKKKQKQLFNRR
+TADEILTICRSWENYIHPRAKDFWKSSEQVYEILSNIASNIDRSDDPITSGEEQCVRWHG
+ELEAEDGAPVIRILKPGETDECQTYVNRILAFLYADDESFLELQKKPPVAFKNVCEDPIC
+INLTHISLEE
+>gnl|md5|7acb70255ac8cc91b0aeae932e57c11d
+MKFSKYSKVSLGLLAGAFASAISVFSHPVYISEWATEIRNIAANKNLKIEAPEQLEQVLL
+SGINFDSFDASCSALLQKVIKEIGFDSTPLNLESALDICAVINPWNSMECSGITGVTASY
+ARSLQEFVRIRDSSKGDLRAACLVASAIAPGRPFAPLIKGSIKSKCQEVCSGPLSKSISA
+IDPSFCSLSIDLCNSVDFSLYTAFSSFNERELGIAVAVSVLLSEGSAGLRTSFREGCGFV
+HFLKSKGALPTASSEVSESDLFSNISEFYRSKLIESGLLPSTDSNLRSGDTVFLKVLNSQ
+VAKAIISILEAQIPKKQADVRPKRPTIASTHITSSEVSPLSEASDSLSTEVKMQSFTEAG
+QTSTSSVLESWFETIKQSIKKGTKDIDREFDNALNKAIARFDSSSVYFSCVSELKRFSLG
+SHRRITEACRKIDPFSHVKCQKLSHFELMAMVKLREELEKNGKDIVVDLRDLCAVASKMS
+MESFLRTRDEELSSMCIRTLKKSSFKNKYPISERGIKKACIKFDYFRTSSCGNLVSNYPE
+KVNFVLSLANNMFDKRTDKERLQIIRESEFSTPSYADICNSIERIPVETVEECIFELRDS
+LSKFKSIASLLNIEGACIASLEEIPFGRYPPYPPYPGSQFDRYPPSIYPDRLHRPVFPKK
+SVRRFYKDIEFQPQFPSQHWFRTELPDILERRAPFLEQEYSESRKGYYKDQEGKPVYHDG
+YRYRLNGNWYVKLGEMWYIDNSSSLDFVRISPGDPRYSNYPLSFYEKSPSDPKGPLRRKS
+FATYLSPHSSYYYPRTSSYLYTLYGKHPGQGYYPTDAYQPFYSKCDKCHNWIPYGHTHVH
+GPETKKTSLSRFEEKLPSTRDKSSPSGGYLTVTNEYDEDGRLLVKTVEKTALPEANPPQG
+KREVGVQVG
+>gnl|md5|9869c8818eb699332c0dbb0ae935b181
+MMETKMNNLEIENCKSNESKSLECETSKENPPAPMKIVIPKSMIIFVSAATAISMFVLAF
+HVIPTLVVNKYLLFEQKGLPLRTDHRIFSFMKQSINTKPNNFRGNNDSPSNALELEFLKY
+GSSESIQSFSKNRKLSEAILNNTNSSLYTHENNTTYISGSTTLNFNSDINSVPNLGATET
+NSKFNSNYVCHKFVSISKSDSSTIENEFTHNTKCKTHYILARSLPRELNKLDLATINAFN
+HLSEASQSVKMIAEILDNKKKDEGLLILMASKMNYEPDWKSSLERIHTNWEFNTYVSQII
+LTSWTISKSFFPGRHYTPALDFGFMILNIPQDSDDELTSMKIRASLDVVKSFISNLNLII
+DGTLSKLFSGPNYSILTENSLTQDLFTNWTYFDHSFSFLSNYFNKNQSMLLEDYLTSAAL
+DVSRLIEQLPLTIVDSVILARDNLDNLYKRNPTELRYTNPNETQVVIIPPVERKKIAKYN
+YEEKFRRICIYQAHTEQRSILRSTPSRASMAEYARYHGYSYFLFDGSFYDSIPKPVITDW
+SKQGFYMKIFSGLKLLFWNLDKIGDIFGKIINDPETNLMSEKFYSEFLESVMPNYLNVDW
+DARHNARIGSTGKINSKGSSGKEGIQITPSNIKANVCDYIVWFDLDIVITNKFFSIERIL
+DSNTPEYNNKPPEIFRNIYKDVGEVVFFAARDSEWRNRNSFVNSGFFILSRSRASLQTLF
+HTLALDPVKSQEIVLNGRFWPEQSTMAHATLSIFNHSFSSPNQTYPFLDTKIDTVNDIKK
+KFVGSTPVMLTAYLEEIDRYAHSVLASQRFANGFIHMSPDAYGDGPWHPGDLFVHAAGQY
+SPFRDNVLSGLLYSINTVGFTYDEINYFKNYCYNSLDFVYRGLDRLIEELTYEFIEFEKA
+RLSDPTKQLENINNVDLTFHFVKKLMAVKTRPSSKDVLTHPNQTSYEKIHFLRCNYSLSM
+AAKWSIAEAFVLGGISVFGIAIIAFIFKFARFYSIK
+>gnl|md5|b03b450f5d8dfa5b12e879974d5eae18
+MKIFYLTKILFLILITSVFVKSENFRSAQELEENTSNSEEENQNSSKNFVSNTINDYYNH
+VSSAATNEFNEETQKLKNRFKGMIQSAGESIKNFITDKVNLIQ
+>gnl|md5|9fcd083fedb14e0cd6487b1db4634cd1
+MADIIFKSNESIRSLNSKNSNREDFIENDNMIDESALLVDLKQKEESFTEFECKRFSFIS
+KEEKSGKLLLKTCQPCQNLEVSNTTDKTALELPSVYLRDYMYLKLNNGIKVILISDAIDM
+EMGIGIQYPVSLIEGCNDLGGVRLISNVLIRGLKDYFREVALIKSYFLHNSRVSINFSTN
+ENILQILKYFSEVFVNFEISIEKFVEAYKLTIDQFKSRQDAQYTRIVGKLFEIAHPNSYF
+KNSCHTFNDQVLENEYAGYELVQLRKKIINAIRNNFSSNLLSVIITTPNALNCSQLLVSK
+GLSSMRNLNLSIPNTFDNEKYAIPFSTDNLIGKRLTFPSFFPIKQFFFCFFIEESLEANI
+KEIEGALAEMFIHGGNSLLSNLKNRGLVRNMDIKILLAESSPILSFRVEVEDTEKNNPAE
+ILSIIRQVVYTFTESPLLESYVMNYFKIHDVKFSKIFTTSSTNDVIFKLFNIINTSPLEE
+INNMINPKLLLESVETVLSYTTFDHFFLIKSCDFASEERTTKTVENEQI
+>gnl|md5|aa55988d5f35921b39e35655e80b2d10
+MKSTRIKTFIFAIYFFALFFNNIFQIKAAEAPDGNSSDDLSEEHVTHIAETSNPIYALVD
+SLVVNYYERNLFAEFILVELSIYISLLLKLLALVNPEDVEDGYLPLKHFFVSFLLNSTFE
+RRKNMVSKEKIEKLEQSSRGKYVELRDKLSQQMHGNSVKLFDTALTNKDEIQENIDFLLN
+MLLVLFEYGIERFLGSAAITLFSFFDSFSLVLTDFSNIFSSSPRKEISSRFISNKDFVSY
+VDFDFCYNRVESGSLQENVVNSAQEQFTNQIIDSSSPNIEELCKIKEILLTALDLLKTGL
+FIVFIFERSTFYGFLSQIHDKELKIKKELEKINCDGLSEQKYLELKVDARNLFDIGGVHS
+NNLVIECYDECLPKETLTSSMASVYKSLLSAMLVLRNYETTTFGVDFLKLLFEIVLTLFE
+EYTKKCAQQIKKIRSLAEVEVQNLQISTVKEKFKMRKELYKQSLMVQAEIERKENKERKL
+REKKVKEEKERLERERLSEANKNKEKKPRKKKTKPKKVFPIVEDSTTDTSKEDVGEAQTS
+ASSYASQEVSSKAKEQVCRPKLNRKEEKLRKLLKEEQKSLQREEVKKTILEQKCSNISTR
+KRKQGERKIKNENRREKEERERLEEKEREMEREREKRERMKHSNYMYTLLNSISAIEGLF
+AEAEKSRASISGLISFVFQIISEEKVETEEASSEKGISDMFASLSVSETVTPQQQASGLS
+RTGMELGARPKTSVGGPKPRSSSSSSSSSKSSARRRSKSRSRSRRSSRSRARSSRSRARS
+SRSRGRSRSRDKSSEVRALTFDGFEVPDSIFSSTVHEDPNKSSKFLKYFQVVNGLDSQDS
+SVFEQKYLEYEQQLIDLSVITQDSLEDEILNSLELCGNLIQTLHTVVIPLVRGKELMYLQ
+LLERAFVKFFIKFLIFLQQKKDE
+>gnl|md5|c756d9a361c7db75b6019085ee46fdc2
+MKPLAGQSEKPLKSRTPLNSFVFPQASNVQVFNIMSSDSQTLLVNVLPSKSLTERVDIAK
+SVIITSVPENENKNNTSLNVTKT
+>gnl|md5|6991206cc888636cd1bafcdb954058b9
+MRFLILPLTIIAQQLYSNHTIHYKGDSGLDLFIIEDQIIKAGETGFVRTGIKIAAYDDYD
+EPSSYTIVGRSSISKSPLRLAVPGGIFDAGFRGELKIPFDNIKDYDYELKVGQRYVSLTG
+YDGKPVSFSLVDQLDETDRGERGLGSTGLGPVVLGNTGEETRSKSPNQALVNGTRTSLRS
+NCSLIY
+>gnl|md5|83d69683dddd09d0d7660dc35f6fff03
+MTSSEGPAIGIDLGTTYSCVGVWRNDTVDIVPNDQGNRTTPSYVAFTETERLIGDAAKNQ
+VARNPENTVFDAKRLIGRKFDDQAVQSDMTHWPFKVVRGPKDKPIISVNYLGEKKEFHAE
+EISAMVLQKMKEISEAYLGRQIKNAVVTVPAYFNDSQRQATKDAGAIAGLNVMRIINEPT
+AAAIAYGLDKKGTGERNVLIFDLGGGTFDVSLLTIEDGIFEVKATAGDTHLGGEDFDNRL
+VEFCVQDFKRKNRGMDLTSNARALRRLRTQCERAKRTLSSSTQATIELDSLYEGIDYSVA
+ISRARFEELCADYFRATLAPVEKVLKDAGMDKRSVHDVVLVGGSTRIPKVQALIQEFFNG
+KEPCKAINPDEAVAYGAAVQAAILNGEQSSAVQDLLLLDVAPLSLGLETAGGVMTKLIER
+NTTIPAKKTQVFTTYADNQSGVLIQVYEGERAMTKDNHLLGKFHLDGIPPAPRGVPQIEV
+TFDIDANGILNVSAVDKSTGKSSKITITNDKGRLSKDDIERMVNDAEKYKGEDEQNRLKI
+EAKNSLENYLYNMRNTIQEPKVKEKLSQSEIDEAEKKIKDALDWLEHNQTAEKDEFEHQQ
+KEIETHMNPLMMKIYSAEGGMPGGMPGGMPGGMPGGMPGGMPGGMPGGMPGGMPGGMPGG
+MPGGMPGSNGPTVEEVD
+>gnl|md5|05a6678bc2f9ae7929eeb3c85e6a1546
+MRILFILLLFLSIKTNLIHFCLAGNFLDVNNAANGGEHEILYSNFLKEFGNDYNKQVEEI
+SRVELNRFKGQTYLDYTGSGLYQKSQLEEIYTDFINNAYGNAHSRNPSAELTNRKLSEAR
+ELLFSFFNISKDTHTIIFTGGATGGLKLIGEDFPWTKQSKFYYTRVNHNSVLGIREYAVS
+KGAEFRALSFNDIEKILAQREKDYKEKKDGKSENLCLFAFPGKDNFSGEKYPLKWIKQVQ
+KYGLSDDCDWKVILDAAAMVPTEKLDISENSADFVVVSFYKMFGYPTGLGALISKTDQVN
+KFNKLYFGGGTVVMASCDSRWCKMHENPSAKFEDGTVSFLSIVSLKYGLNKLQSIGMDKI
+NKHVSSLTLFTFNLLSQLRHFSGGSVVHFYGRFASPPTGGIINFNLLKPDGTFVHYFKVE
+QMASDSNIHLRTGCFCNPGACQDYLGLTLEEIQITSEVKNSCSDPAAGLAGKPLGSIRIS
+FGYLSTFNDVLAIYDFIKTNFVH
+>gnl|md5|13d8910db1eabd2ada51a6306d9f8d03
+MRELSIISFNVNGLISFTKRRGYTESIFSKLLDNICVNDEVTNANLNVESPDIICLQECK
+MSFGDDLNNSIGCPGNYESYFSLAENNKRYSGVATYSSKKTMVIEAAKGFSWLESNPCQF
+DINQMIQTEKLQEIESNISKIKDKYGISISEIDGEGRCVITDHKQFVLLNLYVPLLRSKA
+EEKEEKEKEEVVLKEIQNQNETQIELSETVDPERFKYRLAFQEYLNLLLHVLKNACKRNV
+ILAGDFNIILEKIDCYDDCGILDNCKLAPCVLKNTKEILETSSFAKAYMHMRRMNIEMIK
+GYCLVDAYRHYYPRTNNKYTCWSQMNQSRIRNQGTRIDLFLVSKGLISESIKCEILDHIY
+GSDHCPILLILKTGEFESLYNNEKRKPPSICSKYLPQCKQRQSTISQFLTLSKIEGQINK
+TIKNHDFKMNNKISLNHPQCKHGIPCVKKKVTKSGVNKGRLYWSCPKSDQQKCNTFSWIE
+ETNSDCKTNHDLKNFVIR
+>gnl|md5|b498c50cd69f77bee95158a64db4cc39
+MSGDKKLYVLFESAAGYLLCIIDNWEEIGQVTESVIEVCADPMRFGQVAQFFAFFPFQTA
+EMALENMKEIQNGNTTEELKTFLIQNLPKKVKKYNLGVGDASLGKTLSDQGYPVVIDKNI
+NELLRGIRIHFTRIVKSFDSSIGDLHKFQVGLGHSFSRNKLQFDPNKQDKSIVQSIALID
+RLDKDINLFSMRCREWYSWHFPELAKIITDTEKFLKVAVLIGDKDKFEDNEETRKKISKI
+VDDPSLEEDIFSSILISMGQDITDNDMNMIKNLAKQLIALYKQRSHLIDYLNNRLYNVAP
+NLQSLLGDTLAARLIAHSGSLVNLAKSPASTIQVLGAEKALFRALKSKGNTPKYGLLFQS
+TYIGKASQKNKGRISRYLANKCSIAARIDNFSTVNNNIFGEKLKQQVEDRLKYLSEGISP
+PKNIDIMREAISENQDILKNTISNQLDSDKKKKKKRKSHESIQNEQDEGDQQEQMRDNDE
+SSEKKKKKKRKSSGKGDDE
+>gnl|md5|18a7a9d60b532c6ee2f0963991bb1fd5
+MSSFFQLLWLSQWSRYITNGNSNPGYPLLFHGDSPLIWIYRLRESFSKNRNHFWLPLLQV
+YGRSIVNVLFLKLIFLFSCSLCSIVFTQTVSNNQSIGALNSCIFLVSAYLIRSVIDAHAR
+LYLARVTMRLESGLTGIIFYRLLSGRGSEKSREQKQNENAVSVDLHEISSKIRLEIEGDE
+DSSSNRNGFKAFKKFLDSSRGRNELEKITYSKSIRYLLADPDVFSMLVGDISAVQLFLNS
+LIDCILLPVNIWITWKLLSKQVGLIAALPGIITFLFFFISSFGFQVLGTIYKAPFMEYRD
+QRLSVCHDILGILRVIRIMGAEDLAFDKIMKSRNIETALNRKRLVRTQFGSFLEYHTQRA
+TQLIVFIIFYLFIGTSLNLPAALASIHILHSLASPLRGIPVTFIEGLISLLRIRTFISSH
+PDNYFEYFSEDDDTSTDCEFTGAIDFSNLKNSVQEEVSKYSNKVMCFKQFCKSSDGISID
+DQYLNNSNNSFIYECHRIIKSHLCNPENSLNTLGKCVIFTGSSGCGKTSVINSILECKDN
+DLCYAYSSQTSWIPQGTVRSAILFGKPWNEELYMLVTGICQLQHDFQSWKDGDLRVIDEG
+GTSLSGGQKTRVALARCLYHQSEAAIFLFDDIFLNLDPNVGSKIFSRLFGHKGFLNSPYS
+RTILSIDLTTLLYFINNQPENSLTNIQIVHLNNHDIFFSGSLIEYQTLINNNSRPNINNS
+LEVNNFVCNNDVENQNISPVCAQGKDCMQENLHESTCNSDLAPNNLNKMNLEFHNKLESK
+LTDNSNDINEELDVIHRISYQISALQSKNISIESFHSITGTTPTSSGTCTSPSTLNNKVS
+LTLTSSKIFYKPVSLPADLVLETEISPGKRNTLEIYWWYFSLVGRTWCIVLLISCILKSV
+FDRYSDTFISYNDSSNNPNFIWIYTFIVLFQGFLCALLFIGEAIGGVKASNIAHNSLIRQ
+ILFSPFWLSDSTPTSYLMNRLSTDMLVMDESPLKKIASVIVPSIDFLIQISILSYAVPYS
+LPIILMVTFMTYKIVCQRYISTYIRAQKVALSVLSPMYGLFSQLINGIVVIHAFNAQRHL
+LNQFLIQIEHLQRIKLLQHIASQWAAIRLQLYTLPLIIFILFIPVESNWRYLALLYSLLI
+SDTTGVITYKFASMERDMCSSERIFSLISNGSKPGTEVNSDNKSFNGSSKTTIENSTKSS
+TNNNREDDFNNRTFYTNNTLIQNPNLNQATTGNSNYTYRRFDSVEIEEINDDLFFVIDYR
+FNSFGKKKIVLENENMSHKLLSGIFKPDSKRTGVKIMDLEVGYSDIMGTSYSVVLDGINI
+NVQPFEKIGIVGRTGSGKSTLILALLGLVKYTKGQILLDETPISMLSIKERRRIIGVLPQ
+IPLLLKGWTIRDFLDPYEELTDGEILLGLDKCLLDPIFINEVKNNLYSNAGSLSGSQLRY
+LSIAKLVIHSRQYRMVLIDEPPPNTNGDQGLQQSISRILVTHFKHCNIFIVAHHAESIKD
+CDNIWILAQQNIVKSIHPKSIPTQNELAQILTSYE
+>gnl|md5|81bca1269d34401b1cc7f08db65228cb
+MKFNKKNIEFAGGNTLWSKLFFTWLSPWMSKFLGPGVNTDDLPRLPANDDIPIWTNYLEK
+AVNQEERISKLKGKSLRIYKPLIKVFWLQCLMVLLLKVFFDVLQTLATLSLRSFVSSLEP
+DSSNKNNFDNNKNNYYMGSVFIILTLLKILVETQYSYWCGRVSLRIQASLISMTFRRVVH
+WKTSAISFEESAIGKSARKSIILRHAESRGIQDSEAVISSNVFNLIVVDTLAVEGFLINA
+IECFIFPFRLIIAYFVLKDSLGSSTTIVGIFTLIVFLVISFTCQIIASTYKAPFMSARDK
+RIDRCHEVLSEVRTLQMMGYQNIATDRVMKCRQVEMKANKIRNTLSLIGNWIGYQMSGIA
+QLVLFLLAVYKGIQYSREHNVPLVIPASVGVTTLKVLFSLLGPCRNLSMYSFATIEALIS
+FNRFQSFLRSRPLDLRHCDSHSITSNNFHDLSPNIKTPTPIEHACMHNSGANSLDDTRNI
+ANSRLITDDRENTSSPDSTRLFSLRYQTLSSISDKEAPEDSIIGHFDHHTNSNIYSRYTT
+SNKGNHLANLKGVTSRDVVVMRNSSYTWNKETRKRNKYNNDTANEHTHLLNRNYEFSTTS
+ASNNSDTRFKLKNINLSLSLGETIIVVGSPGSGKTSLMNAVLDEIVQESGLTYVQPRETK
+SPIAYASQIPWIPNGSIKNIILFGRPLNQLKYDVILDCCQLNQDFKSWQDGDLRIVDEGG
+CSLSGGQRARICLARALYSLPDYLFYNQESSPLSEPIIVSESSSYNNSNLSISSLPSSQD
+SILYLLDDIFVSLDPGVSKTIFKKLFGKNGLLRKVATILSIDHTILSFLMSTSKLLKDFN
+PKILVLDDGSPQFFGTYQSYLSDWRCINLDITNKDNVPHSEEFSNDDDFSYNNNNKYDTT
+TNNNTMYLSMNPSTKCETLRKVMEKEGRVTGMVSKKTYYWYFSKLKWSWTIALLILCYSK
+TMFDKGTDYYMGSYTSRAPLTDVDKSIFEGKKFALIYIILALIQLAVSSMVFIGEAICGI
+KAAIEIHDNLLVDVLNAPLNFFDSNPVGRVLSRFSTDLLMVDNIPIMKIATVLVGAMNVL
+FQCIVVVSAEPSVVFLFPMIGLGIYYAVARYFSRSSRELQRMCLVLYSPLCGVFSEAMSG
+GPIIRAFRAQDHYMLQGTEIIDMVQRAKFMQLCSKEWSSLRTQLLTFPLTAMSSNFFTAL
+ISDFFYSPSDTLLENQTSNMNTRLGSGPGAGIVGIALYYSESIASNIGMTITSYVNMEKE
+MISVERLHQYYEILNKEKIYNLPFSSPCKVEDIEKQEKNIENIRSGVKIIDLEVRYRRPN
+SNPADNPDEIYFPPAINKMNACTGPNEHIGVIGRTGSGKSTFLQAILGLVPITSGRVFLD
+NIPIDQMSNEDRNKLIGILPQVPLILKGWTVRNFLDPYQKFSKDDIWDALNLCGLSSLIR
+SLPGGKMLDAVIVPDNSSGSTYNSNNNNNNISENSSKTEQKSKMTDCINSSHSETPDDER
+YLSDSQLRYLSLARLVLNAKNYRLILVDEPPPDVFQEDTIDYVPIHQLLRQYFPHCTVFV
+VAHHAASLQNCKKVWVLGKGRILFETDLNSNFSQDQMLQLFQTAETECVEFEASKNTEQK
+>gnl|md5|6af5c16e6ad257468e76c790938659ec
+MHQLSTIQPDVVISTPGRLCEHYNQLVISQDQQEIPELFRNIHFIIVDEVDRLLSQPYND
+WLSIVNNIS
+>gnl|md5|77eac1e02d6f13d2cf7bb6a23fcddb53
+MGMKYVAAYLLCVSSGKEQPTASDIKKVLESVGIEYDQSIIDVLISNMSGKLSHEVIASG
+LSKLQSVPTGGVAVSGGAAATSGGAAQDSAPAEKKKEEEEEEEGDLGFSLFD
+>gnl|md5|a0dbe762e968c45fb5c2db6fd34e1a70
+MMKVYNIKDENVDNSFCFLSSEFESYLNSCQSSNSIIIKGCNKLLRKIIHCLCDHYCIIS
+RSISTIGNNNNNNNKRNHEKTMILSLPKSSNIITLPKAKITTLLKINQHYSKKQFNSISN
+WY
+>gnl|md5|d8a5f7365ad7b9dbedb6d7101cc4290f
+MSNKEKKQISNKNTANKKNASKSSKNAKDKVDKETELANKEIDLKNIKNKIKRAELANQL
+KREKKLEKSKRRRENREREKRGEEVVKGIPRTIENTREIDETFVHDPLNDKELHKEMEND
+EFSDYFSRKRSPKLLITTNNRASKHMYNFLKEIVSIIPNCDFYKRNGFNIK
+>gnl|md5|2086d00ae64661dbe4683f2c855526b2
+MNNFTVRVRQFLNNPLLARKQFVVDVIHPSLGGVSKSDLKAKLAKLYKVQDANCIVLFGF
+KTAFGGGRSSGFCVIYNNISALKKFEHRYRQVRMGIAEKVTATGRKGRKETKNRRKKVRG
+TEKAKISGGKK
+>gnl|md5|9f0f81d51ecfcb2a399324648025ec4a
+MKQISFNRKKRQLEFQENQLNPLLEELKIIRRENNSLIKSLIKKIKKDKGIN
+>gnl|md5|18be8735af6fa4c91a3f891e3ea394c3
+MMDDNRKIGLGCCGLGMILIILGVLLFFDKALLTIGNFTFVAGLTLVLGLSKVTRFFLKP
+DKLKGTLFYFGGLFVIMWKSTIIGFILQMFGFVLXFSTVSTKHWFLYKAFSTKFYSRASR
+N
+>gnl|md5|25cb88d5d33aa3fe5c2d7b73dcc80656
+MFCGLIIKPGQKVKLDSTQGEILHLSQACLSEPKDNGRVYVQAIDNGNAYTICSLQKGTI
+EHANLDLFLSTSAEIELSVIGKNEVHISGFYEPEMEEDFDDDDALMGMSDEEEDEEEEEE
+EEEPELENSKIDNKKSLKRKLPSKSDESTEEEIDDEEIDSDEADDLDLDELIQDNDEDDD
+EDGDEDSDEDDEDDEDDEDDLDDLDDDEEEEEEEEEPVKAPSTKNKNKQSSTSQKTKSSD
+SQPPSKKSRLESKSQSKPDQLYEESIIDFLKKNGRTNMAMIGNKIKRPEGVSKKLGSFIA
+ERTDLFKVENNMISLVK
+>gnl|md5|61787d236747f727402fca9a474dbef1
+MCLRQHLRCSSLKVTIFGAGSFGSAISCVVGYNTERTLIFNSEVKLWLYDEQLESGEYLA
+DVINRDHVNVKYLPDFKLPNNVRAVTDLKEACEDCNLMIFVIPSQFIRSVASQIRKLDID
+FSRAVRAVSLTKGFLVENGHPFLISKIIEEELGIDCCVLSGANVASGLAAKEFGEATLAC
+SDYDDAYIWQYLFDTPWFKIDCVPDVICTELFGGLKNIIALLVGMIQGLGCGTNTVAAVM
+RLGVLEMILYGSIFFNIRSSIMTRVFFESCGIADLVTTCLGGRNVRGGKAFTLSNGQKPW
+EEIEAEVTGGQHLAGLVTLKEINETLEVLLIEKSIDVDKHFPLFRSCFKIAYTGTPPRSL
+IDILGRNELRELRFVPSGLLSLIDDSPNHGEVMQRSSSRQVGSLILSKTQSCMQYE
+>gnl|md5|84e6bbeda0f33122619b3dce2b8a2fa6
+MADTSSRVKTSSSSVTAMSSIENRRRKNVTIRKPIILGTYAFMLSIAEQKKRGDNATHSW
+TCFLRSPDNEDISYYVKKVVFSLHPSFLNPNRVVEKCPFEVTECGWGEFDIMAKVYFVDS
+TEKPVEIKHFLRLYPPGTTDVRSVKFPSDNTPSDCVASETYDEFIFYEPTERFYEKLISG
+PIQPMAQHRLQPYFHKTDKSAFEKTLAAAHVSIQNEMASLRAEIAQITLDIQNIRENYYS
+LRPSEVASMFPQQHIADQSPVSESKSSHMMHQQSELSLPPGGPIIQKSEPYGRSSPNQRT
+QNSKFQGLPNSRHDCTVDSQFQPQNIDHINHYDSGNINQASGQQFHQNFQQQQQYHQQHH
+QQHHQVHHNMTDIPPHQIHHGHSSHHQNIYDNPKMVSHLAHNHNSNSNFKPNNSLDGVSI
+DINRQTQFQMTNQIQTNRNPENPHSVINNNQGQYSTHDPNLPPKMEPHSSNPNNANIQ
+>gnl|md5|d51ef0c6f7b212b9397ff43d36356392
+MGCSKTKWKCIHNGECSKEFYYRIHTFVGGLEISVEDVDTNLSSSKVSLYDEETISFPRL
+VIIRPKGLNNLKDINSMKHVSEYRKNMSLDYFIEIYKDLYSEPLNVETSHLYDFTSNCIF
+EILSEKDIPLLTELRSLYGPPEFLNSENNIEGNILGNVLEKDESGILVINPWESSSIGQT
+GRNSSSHGTFAKDDTDPSSHDFDISHGNSKQDLNKNLENSMGSQGLDFSGFSIASIKAFA
+IFGILFVFEEPYLLVSTSRDISSVIYQNGTYKTINRVTKSLAIPLFSNSIENQYFNLDDP
+IPFQNKQDDLKPSNESFFKQPEQMNCEFKVVQNDPNDKSKNDKSKKSMEKMEWINRVSST
+LQKLSPIKGNKESFSLLSDSGANWLSNSLINVSSGILSTVSSAISNSINIQQNNPLLSTN
+SSPTNRQFKDSSLNYIDNQSKTKDPNSPISLEELLVERRNHLERLIEGVTKMISSGGFFY
+SFDMDITHTLQRKFENCWKDHTERVGSLGENGETSSEIKNKAYIISGDSRFIWNRNISLP
+VLISGVDPRWITPLIQGYFCNQAIIISPEGPGYNKIGPDVLSLKMNLINSFTDLDELIPQ
+ANNTNSSVTCEQKCACTDNGIVPCRHKFACKMCYRDYIDSLTRYDIVLMSRRSWERGGTR
+FNARGIDENANVANFVESELQICINNSDHWFAFTQIRGSIPLFWEQTGVNSCAITCFDHD
+YSSFMFDKHHTKLVNLYGEVFYVNLLGSSAHEQALSLGLKKEINYYNLNIESKYSDVRYS
+EDSETGLVCNCVKNHIGSTKDEFCFCSCRAIPIVYTNYDYHQKVKNQGFESALNEYVSIL
+AKEFGDRIGYFHGVFSDSNSKSCSESNSNNNQEPVTFVNFFDLDDFETKEETQKNNVNDV
+ESLKNDRDREFIIKMRQKGVIRTNCLDCLDRTNALQWYIAWTWFVDLILSISTCSFENSN
+LQDKQDNGRNISQEGFVKSLLNSQLSHFGWFKLILNSGEKTQLEENNILEIINSKNLNQI
+LIPRSINSCISSIPRIQTQSKVMNSPLTLSNPIIPSRISKTDFEIRNSPIQTAYREIVQR
+HSFVMKRSTGNNNSSGLLNGLDINRNNSTIDLDDFRSKNLSQSSKNNLSIFEIFRECLLN
+GMGVVTLKDSFSLLWAENGDVISEHYTGAGSVFSGVIKNRKISLSTNFDHAVKSLRRLYH
+NAFEDSSRQQYIDCLLYKHPSNSNLLGRTNDLFKDNLLDKDSKVQNFPQVLNKNSKELNS
+EKLTIWIGSWNLGGQPLNIDLDYWIKKDLPKNTSIVCFCMQEIVELSSVRIVFNQNDKNK
+EATFEMLALRSLGADKYIKLHSISLVGLFCVIFVRRSFHHFVKSVESNSIKLGLMGSTGN
+KGAVMIRMNIERYGSIVLTNVHLVSGEQYKEERNSQLKLILQSPIFNEIPNFKGFLKSGS
+SLQDHDLVILAGDFNFRIQLPKQEVIDLIKDKNFIELLKFDQFLLEKKSDNEILSKLVEK
+EISFFPTYKYIRGEYIYDLTRTPSWCDRVLVLSNNSKLPLITTTDADTKNSEQDNFHEND
+SFNDYNVTITGYKSDERYLVSDHHPVFAVISVQFN
+>gnl|md5|5aed9e32342158ca3c34e400767cf0bd
+MSDSVRNDPKKAIYKIQRSVKDSIEKSCKAYNSKFSPFKLNYHIDSDKNEDKEEAKQEFH
+YNIDDDLSADIVEYIKECVQNSSNINEQKESLNEWILNIVDKNKLK
+>gnl|md5|def6fdbb039475da0b9ae886f16e2500
+MSATGKNGTGSSALIQKLMDAEVDAEEIVCRAKENRILKLKEAQISAEEELKAFREKEEA
+QFESEFKNFSVEDSVDQTLEKSTEEAIEIVKNDFKNNGGAVADLILKKVLSVDLSLPPTV
+THLAKIGKIH
+>gnl|md5|136d987986fb837192418d07dd39e73e
+MKESEKEKTVSSNREFLEINEENNSNRLEDLVLVVDHNKTDKNNIINFKEKDDDSQNKLP
+PWKRKPISLDNDILKRAKNFLSLCETIGNEKVTQSYNEDKHVVMNVHMGVFDVNGKLPED
+SSLSNNDIVDVSNLDFKTLQDNELCQIERDEDDSDDNDESDNYEEDVTGSSFRYDPDSKS
+SLEEQMAIHKMLTQSKSGNGSSKKNKNLVQVISSKDNE
+>gnl|md5|f72b0f26a9fd905a5fdf79a89410e7c2
+MSKFNYILNFSPDTWTPTIESKAGENCLGGIKNFPFAPSMKIDRLGAVCDFSYTSYSRGR
+DAKSSQADNQDFHLVDSRPFPKTKVRYVQRKFQKETAQAYHQKQQQQEKAEMLLRQGKRS
+AKMRQAGTQQYQYSRHRFVSRMRTLTEWSIEPLSSWISVAEIPLSSLPKQFLDVSKSTIE
+DIGWFGTLKSYNKSMDRISPKLPMVLKDFGNMEFLQPTTSDDEILRDALLQPERNIDVAI
+TDQILACLVAAAQSKYSWHILVTNVDGKLIFDKQDGSIIDLITVNETSAEPPLPDNVNKN
+NRPHLLGLEALKSNQNYTQNIQIFGDEGIIRQFEPIPFSEENQDTNIESKCYRYRIFSLP
+PRAGASSSENAQKTVRVAIRTEIDAQIPNAESENSGFIFARALNEYDPKTVKTWNTQLET
+QKGALLATEIRNNACQLTKWATQALLSSCDILKLGYIVRRTPNDRESHQIISVQSYKTKE
+LSAQMGLKEENAWGIVRALVDLLSEQPEGQYVILRTPVKHVLRVYRIPDEESSELPQDEQ
+NHNKE
+>gnl|md5|9587e2f5ad9b4bfecfd348e1eee58bfd
+MGAYKYLEELYKRKQSDILRFLMRVRSWEYRQLPAVMRCSHPTRPDKARRLGYKAKQGYV
+VYRVRVRRGDRKKRVAKGIVYGKPKNQGICKMKSTRNLRAVAEERVGKSICGGLRVLNSY
+FVCQDATYKFYEVILVDPAHPAIRNDARINYICNPVHKHRQQRGLTAAGRKSRGLQVRGG
+RAARLRPSRRAVYRRRQLIQLRRYR
+>gnl|md5|d80c7fa5531f1a9a5ccc837a4479d6a8
+MIDFDSEDELINEETYFEEIYYGVSDRVIGECRAENTNSPIETSINFVKVKEKNIENRVG
+IQPNIMNETINETINETASKWSTRLRANSNSNTSPTFDTNSSSKSSSPRKLSKATRSRLL
+LKERIFSMNPFGVNINGRIETNNRHTDRYNNQISSTENHPITNVIVTQNTHVSKQPFSSL
+FNM
+>gnl|md5|cde487cd8483b9e0b47178da228bdd6c
+MITQSSESTNSTISPFWKSERYSIDYSLSTYLSWLYLNKTQKIFCQGRLLSHDDKSESLS
+LYDFLTQNLNQPVELSRIYKNGSNDGAFALIGKLCSSSKNDEQSTAMTTESEIRENNVER
+PNDISSASSKISKSEKIFEAGILLYYNGRLIRRLEHTFPCTKPKELNEFQLTALINVPHW
+LKPASNKQEFLLERTGIFEEFQDHIRELISVYINIHHDQNKLKAWEAEFNNSSSEDSSLI
+RPNKIPKLEG
+>gnl|md5|28048ccdca1843e2e3e99d26bab5269b
+MKSERLENSSTASIPYFTSLFQSGRLIPKRERLYARFVFITFGIASLFMWNTYLSCYGIL
+NKQLFPGMGFIQYVQTSYMTSVFIGNLTMVFGLTHIFDPHHCTVIFNCVGALQSSIICLS
+VWLLHGTHLGCSLNILIAGFVAFSCAILIPETFTLAAIMPESFCSDVSLGQSFSGAITFT
+LTIILDIFIPHDIQGRKLLVAVMFALSTVISLFAAFLAQSLTKSPWCYSAIAEIRRKSNS
+STLMSVNQYRNDSQLSYEDSLVSVPISLETENSFECRSTHLEVTRQIWPQLYNIFMSFMV
+TLAVFPTICAEWDTFLPEKYSNILMVILVGMFHLGDMLGRHVPKFGFTIPPSLLWILTTS
+RLAFIPLYAAIKNASYDSFLASIWTKIIVQFFLAFTNGLSAYLAFIYGPETVYFRHNKEK
+ASFLLAIYNVAGMTAGSWLMNLLVWVKYF
+>gnl|md5|fe34e74b8777120f3bff024f6b447e90
+MTINNAEEMELMKRRRVGAEYQESSPVEGTEQKQERHVNVQFIDPDGNKVGDEFDINLDE
+TNLRDLNALVNQLLENEEDTPYSFCLNDSNLEVSFSLSETFDKIGGISTEDVLKIVYYPM
+TPFKILPATRCTSSLQGHKDAVLCCSFSPDSNLLATGSGDTTVRLWDLLTETPEMCLKGH
+LNWVLTLAWSPDSTLLASAGMDNAICIWNPSKGDKVFRKLKGHSKAVVSLAWQPLHLMDY
+SAETKVNDGEESATESGSNNLYFPKLISASKDFTLKIWNITTGTIINTLSSHTEMITHVK
+WTGINQEYVVSSSRDTLIKVWNPETGQLLRDLKGHAHWVNTLALNTDYITRSACYYPTGK
+NLKLNFKSLQDKIAAAKQSVDNFKKRCKFERLLSGSDDNTMFLWDPLGENGRKPIHRLTG
+HLKVVNHVAFSPDGRYIASASFDKTIRLWDGHSGKFIAVLRGHVGPVYMVSWSVDSRLIA
+SASSDSTVKVWHVSSKKLKEDLPGHADEVYTIDWSIDGSRLSSGSKDCIVKIWRH
+>gnl|md5|184b3595c27499b1d4d761ca73628795
+MIEEDIQLCNNFFENNAIKLDDHSQSRKNPYSYEYSYLPKNEYNIKMNKIFEKYKEYGKN
+KVDLEKLIYGSSRNLRVGNKDFMCDINSSVLMNELSKEIMSRIISSEIQKRVYLRQKECN
+FCSYNDCQKCYENSIKLKNLENNIKAQNKLYKVILAYLELCGFEQVMINSEFKGQGKKSK
+AEFEYFGKDGRLWSVEKYLSEPFIDRVLKLNGQLSPFLRAKILERIKLTLQAFIKVFELS
+YFNIDRLECNSCEYGLCNDCFYKFREINDKKKQISKYNHLLKVVNLELEKYYIQIRKSKT
+NSRIKGNTKEWILIADNSLRKWVPNKPELVLKCDKASYSEAFTYYNEISLKRKHLKNILN
+HIYNSIMHSNLKFSEYHFSKQAKEWESIWRERVYYDEVFSYINRYLSSCVNKNEELSNSF
+HDYLYKKSEIRSLYKSFQEHSENINCLMEKIKEIHNGGYIVCSKLSSANCCNDLVNPDDI
+YKLLNSEFNAFKLIRKRLNHSIYNEHLNYFDRNKEYSENYHEGEINNRFSRDLNMKNEKL
+RNKKRVREEELDKITVEYQDIIRSPISGMSKYLHENEIKTRSENQSIVQLSPKSEFQCSK
+TEILVLQRITSLLTQNKNRLRLLRSLNSVRCKIEDCYNCKIRNKFHDKLGKELKIFE
+>gnl|md5|6d23f422f04b2528c253b0bbec265e5c
+MFKVTREELGEDIDLLEYLSDSTYDGEETEEYISKRCNTIEEPLTLSDSFSKSFVIFGLP
+CIGSDKYERFLKALRTIINQTLKMMRVEYDENFLLDVPQDEDGGTKGVAILTFSNSFQAE
+TVCQALSKAPFDKQTKFNTVMFDDVKRIIEQDESAPGHFETLYPPPTLFSRDDVRNWLMG
+PRCREQFVIRYQSATEIYSFDSIQRIPELIYDGERAKGGKRVWTDFSVQWSPMGSYLVTF
+HRQGVALWGGDDWDKKIRFEHKDVKFIDFSPNEEYLLTWDGSSPDSRFDKAVKVWHVLSG
+RLLRCFSTPTMTLNNNGTDSGLHFLWSPTGNYLAHCSDKGELFVYESSTMTLVEDPATGN
+KNPLKYPLQFFDWSPEEDNLSIWCPERGDTPGRLTLLSIKNRKELAIKNVFNVREASVHW
+QPKGQYMCLKALVSRKAGKKAKKEYTQLEIFRVKEKNVPVDTVHIEGVTVKCLSWESSNR
+FAIVVVDDVTRSQTLRFYQVNATQTDFVCSYYLTSPVDTIKWSPLGSYFVLGGSGGNLTF
+CQLTNENKFDILQKDEHFMCNWIQWDPTGRYVTTAFQSKLAEGAYKYSTETGFIVWSFQG
+RQLYNSPLETFYQFIWRPHPPSLLSQEKFDEIPRKLKDYSKKFDAEDEAVRSEKRNIVLQ
+KRKVNEDEFNAILQKIQEWKVQQPLYKEWLAAKEVLLNSLQWEEQEEVIEIELETIQEVI
+STEV
+>gnl|md5|bb3e36f1db29f21a82ea528663318b4d
+MGSTLSSGCCSGRESEEAKKLAQEKMNRSEALGDDISRFDLAYDKNDIQEFINLLSSTQP
+IDKLDEPMHPWAADPKTVGALAATQLAILAARDSQPELKDEIRKKGGIQGLLELLKSKEE
+DRIDGAIVALSFLSVNNVECCNVMFDCGVLPYLVKCMSSEIDGLRAASAQTARNIFILGL
+NQRKEFMRLGGITVLVSLLNPPTKNIDKPESWYTPLEAVYHIEDLIIDQNEELLEYTRAI
+RKCGVVEKLQILTKSNNRDVSEAAEILLARVAE
+>gnl|md5|dfa583e5a62315bc685af583ac3ed1a4
+MITHPRIFAATLYEIFYFRVFVLLTRFQNVKTILVSPLLFESKVFTWICSPIYVVSANRE
+QQIKYLMDRDSCTQTLAENMIDSQMSLKTKCELADKVLWNNDSIHDLKIQIKKEFSIL
+>gnl|md5|c3e7e612205be1cb216181cce565e8d9
+MSIKKFRSLLTTLVLILFLFNYEHNEQETTNRVVLDHSFLNLRRSSFRKLLSCFGCCKGK
+CKKKKSKKKGLSLPPPPARSCLKKTGQDSQSPEGDQNVRKKRVTFKLDDQSSSRIKTTAG
+GLPSSSSLSLRVMLGLERPDNTKDEDNEEFETKF
+>gnl|md5|c4678d9ace4ef66f515f9df1c5b27f88
+MGFITNYFHAIFLILIINSAFFTINEVHPSEYKFSILQVKAPRCSKLRSLLCCCSASSRN
+EEDELPNQNEGDGSGIPVLLAYNPISNTDESNSGDTNSNDEEDPKCCSSSSSSSSSKRKK
+ADISKGHPGHPGLYTVLLDFEPEVGTYSGFTNTKTTHPPSKPDPPQFIPNVRATTTTTTE
+KTKTTSNDS
+>gnl|md5|f95a6e89848513b691544dcb6053eb1f
+MQLRNCLLIIFVFSLSFLSFEHRNERDIVSEDKVSLLKLRNGISFGQNLRKMLCCCRGNS
+NNLSTQEVTVFAVDNPTFNNNDESSGNCSNNMESVPNPDPSNIPVPSSDPVVSSTSQQSG
+YSSSSRPIPIPARSGSNKGPSSPSSFPSPCSPSSSTSKLGFLGMCSPSVSSCVRHSSSSS
+SLSSSSSTSSSSYSSSSSSSEDEDEETNKSKESKKKRHRGRKTGKKSRSRSKSRSRSRFR
+SRSKSRSRSPSLVFQFDEELT
+>gnl|md5|48ed6aeb367013a494a1409febcaf4bd
+MKFLYVFLCLICLLNYTTFNQLGRVDEYSKISLIKVKSLNLSSSDFPNGEENHESTGDRQ
+DETDGNGSSSSSSSSNDPEEDEADGSSSFGGAPLSSPRPQRRKLWGRGHKGNSPHPDSEG
+DEADGLGSFGGAPLSSPRPSRRKLWGRGNRGGHSHSDPESDGESTGPFGGLAPRPPSPLK
+TIPRKTKLRKRF
+>gnl|md5|c766af6f2295a5728f427599f5f8ca1c
+MMNACFYLYIIIPLLYLTFNYQSTFSQDFSTDSLAQFSLLKLTASLGNTGSDSDGSGPDD
+DPPNFKPPPPPGKKGNVGSNPDGPPVPLPRTKFPGNKPPKGPGKPPVPTPRLRDLDGSDG
+GKNPDRPLGRRGGMRGRNGGNRQDKSSSSSSNSGSSSSPDGPVSSGGGGKGGVITVRKSP
+GGPPKPPERLSSLSGLLD
+>gnl|md5|8567a889488188cbcf469863f9fd1540
+MNCPKLLMNLCIVIGLLSYFMAYSGHEIEFTNEKYIEFSLLQMNIPSRLPNLLRGCRKLF
+RSTGQKPTTIDFSSFDGTLPRSQSFLPRNTQGLNNHFSGSPPPFPKKPPVGDPYNPERSA
+ALLSRRFRVYNSKQ
+>gnl|md5|4ff69fd6614d2081ddbcf8def51ef2bf
+MNTVKLNFIPLVLCLAFLSNFLRINDQILSLNTHADLSLIKLSSPRKLLRRLCCCCSSSC
+SSDDSCCSSSSNSGSLNIGDPTQPRHVWSVTSNYGGFSQEMQTVPPRTQEGNEHNEQSEE
+SEEKHSCCSSSSCKSKKLSSNNGSSNGGSNGDSNSGGNGGSNGNEDDPQNPYAGYTGRLN
+SAFTTD
+>gnl|md5|00e811a8aeffb9fa73ca22ca1b488642
+MIRMNNNIIINKRIGYSYYMECRCTSNELIRGCLLLKDNKLWIMNILSKIQEIRNNTIYD
+MLLRMREYIRIRKNYEKGINDLEKNLRRIILSRVWIEMINNIERIWILGRLIIIIRNRRE
+ERIKRQVLIRWVNKYNENYRNKCIIEYMRRIYGNTIKIKCYLIWSIKFEIIKKKKRLRER
+YERYLRVYIIEYTIRRMNEYYLYNKWLIWCKKAYDRIEWVHDFRLKSILFINWRRYSKKQ
+RILRDELYILYNKVKIRKKGYILIEWVNRIRILLRMRNDAENYYLNNIIYRRRFKDCFNI
+WRGLSLRLRNQKKKIMDYLENKNKNLKITCFKLWRFFIYYRKTRNSRFEKITNIIRLNHL
+NMMVYRIFYSWKLKMIELRSLKNSIFSFWNSGMGLEMDESGLGVEDDERGGRRGRGVGGR
+GRGRGGMGGEMVRGEMVRGEMVRGEMVRGEMVREEIEEGRGEIKERREMNELISPSTFNS
+PSQYSLEFSVDSLSLKLKEEEDGGGEEDLNNGEKRRKGRVENKDVERKDYGFMSIFSSSG
+NSSLELVSQRLESKRQDDLRGVVKEREIQGQPKNNYGNSSPSSTREYVNRLLSSSSSSLS
+VLSNISEKVSIKESPYTNSNTRRSPNSYSKARRSFSPFLQYSVSSSSSSSLQSLSYSDGD
+LEIDELHSATKLKINRTRKNQNSLDWNSPSLSPQPLPSSLSPPPVTSSSLHPSLSSSPPP
+ISRQSLSLPRQQSNPSSPSLPPPSLPPPPPQYSSYKSSNSSNNDSMIRNRSNLSSRLPLP
+FPIPIQQQPQLQMVNQDMKQLYDSNFTSSSSSSSLSYFSSAFSPFSYSKKITEDPNSLLV
+KLDTDTNQTIKDLPQDPYHISSSSPIFKTIKTDLNNIPNQNLKDGQQIESNLNIKPTHSQ
+NNNIFTSSISSSSSSSFSSQSP
+>gnl|md5|93e2dc6a7678b9a2ea0ae75c8c5cf18d
+METKMDMNGISIMEVKTKPYYGVSLTSKYERFPKLTNSLGSYNNTNNGSGCLEIGGDIQG
+EYIQSRFRISPTIKTLGCLNKSNKENKDSIGMMLSNTITLKPFSCINSLSLGSMISSSNI
+NLPYNNNKNSLKLMLGLMLKGPLFMRSCKDTIDERSQGYEQFNYQGLIHKKENFGSRFKN
+SMVCNNNNSNYDNNNDDLYEGIGGSSTLSPISILTPNYVLSLQTNTNHQNNKLSGFTGGL
+ILNNLVRNYLTLGLMISYNTGNNNGNNXWKYNEDNIHXLKDMDXDHHEK
+>gnl|md5|0e53352a06b73a05292c2ac4c798d608
+MDVMIPMENMTPGFINDLQDGILSNGNQNNDLQNSNEPLMQRNQTSSSGNNPVNNLLNRE
+SDYLQRFPTLTGFNRAGLSGNERIIVQDRDDEEEEDDDENEDNNHDKNIKNNPLYNETSI
+SSDGKKYNDTASPIKTPEIVYYNNTSNLRVLAKKGLLERVEEKVNDVFDGLKKKSNNNDE
+VKDLEKEDDADENNKKNDNKKSNQNGGKMIKQVFSTIEDIVSNTLSK
+>gnl|md5|6319303700b9ff76bde78b8e39447fbc
+MNSEIWNNKRFLLSGFEENDENNLIRKKYIENNGGTVLELNSEIMDDDVDYLICNYSKGY
+RYRHTSIDYQKLRTPFWIWLSVNDEWNYSLEWHPFFRPNGNFKYNILKGFQIYIIGYSKT
+IGGFNNREKSPKYIRKKDDIGILVSFIETQMGARVIFDDENKNENESNDDNNLVKVPLKA
+SVTKLALICNNEEFEGEIIDKVKEKNNIQTIVNLDWLFDCYEEGRIVSYKKYIYNSKREK
+EKREEEKMRINAGLEKENNSIANAKYKMIISHQVYLKHVEIYNIMIKINNIEYMEVGRPS
+REIMKIIQNIDGKNGLNFDENTVMVLVFNDLMEEQDFWYDLVNILEESVVFNIKLASKEK
+KDKILHHFQMMRIINDPEDFINKLIGCEENIIPLISKLGSKVGYSIPSFINELLKSESEF
+LDTVLKFTDFENITGLSGFVEYSNDNPMDIVNLNRSKAIKRFDSFEKEFSTIKFS
+>gnl|md5|2db062de5e2b0a0add8c502d973ee2d9
+MLSLIIFICILKNKSLKEEISRKEKMLDDDCEIIPVNELKELKNSLLKKQVSYFFNINFK
+IYY
+>gnl|md5|b60cd6842f92349be91017984953413b
+MVKRSKEEGNNMEEEGIGLDETQQSKMEDDNMESKSQVRPSRNSRKVVKYTDFDDEDDEL
+DDFESDFDEEMDFIDEGDEDSGDEDDENDLDLEEEEFEKGKKGKKSPPKKKGGESINSKP
+AXSKKQSSKESSVEDELESDDEDKGTKPAKKKKLSAPKNLTKRNVANSGGSAAGDAGEAI
+FNYMKEQNRPYSVQNVVDNLHNIYSKKQVTDEMERLAVEGKFICKEYGKQKVYLIDQSDC
+KELNKDEMEALDKSISVCESELNDLEVRLKQLKQETRNISVPLTIDELEEKIMQENLKVS
+L
+>gnl|md5|e5f388393c39913a68955292dcc96101
+MKEKKRNVNYYLNCALGGALSCGLTHTAIVPIDVAKCRIQVYPDKFRSLVPTLSKIIRYE
+GVKALRLGWAPTLIGYSAQGALKYSLYEYFKDLYSSKIQTTNKESHKGLIWLGASATAEF
+FADIALCPMEMIKIKMQTCSRPDLLPNSFLKSVNNMYKYRSETKFPFGSIKPLWYRQIPY
+TMAKFYFFERINQMFYDKVFTKPKESYSKKSRLGITFLSGYLSGIICAIVSHPADTIISQ
+LGKAAYSGSKRINVLSMTREIGIKNLCTAGLGTRIIMIGTLTGMQWWVYDSFKTIIGLNA
+SGKNKVKS
+>gnl|md5|19abd04fd0b4ddedf6edc5f95d5cc8f7
+MTYNGGAILAMKGKECVAFATDMRLGSNGYRTIGTDFDKVIRPSSKTLMGFSGLATDIHT
+LTNLIKFKTNLYHLREEREIGVKALSHMTASILYSKRFSPYFVEPIVAGLDNNNVPFIAG
+YDLIGCLSVCSEFAISGTADNQLFGICESYYRPDLEPDELMEIVSQCMLSGIDRDAFSGW
+GCKVYLLTPEKLVTKTLKSRMD
+>gnl|md5|471b3428df08d321f2aa28ee5523ae05
+MVREAPNKSDAPQTLTAPNTSTNKAAPAPAPAPAPAPTPAPAPIPAPAPTPAPAPTLGPA
+LSKDSAPINIPIVSVSVNERSGTPNSKEVIQVPSVPREGGNTQSQTPSPPSMPSSQQSPP
+KQSSPQPAPPPQQSSSQQSSSQQSSSQQSPPKQSPPKQSSFQPAPPPQNSSSQPSSSTPS
+SKPSQTQMDSQKPNSQKISPQKVQVGKVGQVSNQVELNGIGSNLDSRRSVENTKFSLIES
+ELDSKFPDIKTAFNKDGLQEVKVALIFITISLIMVIGFSIRKYRKLRKGGEQVRNITNTV
+FPVKIVSLYLYIFLSFPITVLMQFLSCIAPIGYGMFNVIQSTYQSICYIWLWDLFVEYFG
+GSEQIVTAIRRTGPYQVWKVPPFMIPTSTETYFQPKIVIVSYILMIQFLPINIFVSILNV
+IHPSKAFLYNLILIISLTISIYGIMLIYWPSKEALQPYQGGWKFGILVIQSFLIIVIDSI
+IKLAKYENREYNSIVYKLYWKLMLTCGVATICTLAAVAIIDSREIYQIYNLSIPTKDSEN
+IPENKAMLAT
+>gnl|md5|4813d0436de081341a47b80cb09bc13c
+MNALELISIDLFFQLISYLIIAGSCIVKIPQIIKILNSRSTQGISSFSIYVEILSSCIYS
+FSNWRFNVPWLLWADSAFIGIQNAFILILCVVYSQNKKKFPINQIFYITSISLLIAALYQ
+DIIPIQVLRYLSISPLIFVVLSRVPQIVKCYIESSTGQLSFISFFLLTGGSWSRVATVLF
+SESKSNTILLLTNVISALLNTVPLMQIVIFKYCSSISEKNGIEQKRHSKRKVE
+>gnl|md5|d1c9e01ec8fb591860044b00271d7e70
+MEILQLLNINQIHSIIQMIIILPYIFEKLLLIIELDQERIYGIWMVAKEAILVIIHDWIS
+FIRFLKIEFEKIDKNYSNSIKNDLNQIILDNTWPLFIDIIANMIKEEHGFGLKVVSSNIF
+NKNSQRINNYIENYYLYFDILLVNIVMDFIFTLNEFNRKDDIIEDLEILELPYQYYKTII
+SYFDDFINDNNKFKDGFELRNKCYLEEYKSFHTAENTNFGVLNRNGSNNNTTQNNHQTLN
+INYQTLKIYIIEKLFVLYDQLNIKLSTISRMIMKLTIEQDENQLNLVSLKVKDLIICIEE
+LGDILNRMTSNMFKSFSMEDLQSGLRPMPHLKIEEMQSLLVLIEKHYKALRRFEEENMDE
+TNEIQIEILKMRKRCFGSYIENVLPELIECVTCKDQSIRQRLKIILSILSKDISKDYKSL
+LVPY
+>gnl|md5|205a8108608991ff0f3f7a0d4332894d
+MDDIKRNKDPKDLPEFYLVLSNISKRQNFGTLLRSACGFGVSEVLVVGEKKLMTFGNKGT
+LPHLSLTQYENIDQVVDIIKEKEMDLVGIEISDESRPIYPHPFKRSTAFLLGNEGTGLSQ
+KYIKLCDYLIHIPLYGNGTASLNVAIAGSIVFHHFAIWAKFTESSKKGAKYIIQDNNNNN
+NNNNDHHNIDISNVKGKIRHYLFPSELGTFFSF
+>gnl|md5|452be80cd855bf59996f50b8d977e61a
+MEGFHPDWQGYFKPLIALIAPKNLQEHISKSIDSFRPKSCFPCDKYLELKCMTYSELINP
+TPTPSATSPSKTLLKSPYSISNSNCVILGNRTGNYLGGIDILNVNWMNKVRYETPALYIL
+CFDWQKYPINTNNSNSEETEKNKDQEIINELENDALNIIKNITPILKKRQSPPSVLIFVI
+LPSGTPDPQSCVTCFRRNHFPELQAIFVKCGLKHQKQLNIRIERLAEMAYETAQAYYSEN
+ERRWRKSAIKAQTAGITASSDSFIGSLSMKSSSTGLRYSVSNSIQSSLSPRFGRNSFFSA
+VNSSSNSVNNLLKNVSLTNANTLSRSNKNNSFASSTSGNGCQTMTQLQSKVLLIRYCIKS
+AVMNEFCGNFALAVKQYIAAWDNIMNETSIPSYQFVILCNIISLRLYHIHVINGEIQKAM
+IHLKIHCRTLREFGTNHPKFKFLSSLWLSQTLQKLASVLFFHLVNKSFIQDQSIKEDTKL
+CQNNHHKYPDGLEFSLIPLSIGNKNEKIISRISESCRENCAFKFENENLGDILSSIARSI
+QNIVININNNTQCDNVISDELNGKDDSNKIEDRSGITILNNNNNQNNMVLDTLINISKLY
+KTSAEYSHLSKSQLIEFCNEFDTELFSNDQEIGGEILPPLSLGCFEELSSPETFLEYERK
+GLSSTSQHKTTFDQLSKLCSLYIGSDSFDIDQIEDRSIASEVLASCEIVRRNIKSLINSK
+SLFYRSISLFYTSAVIYRHFYPINLFNTISHHNINLNTNTESEIPQKNVAINNNNNNLST
+LNSTPDNKCNQPAPAMHVDNACQSGCMQAGASMADSTAGTNGQNAGELVNVGSGNFITTP
+TIPSKIGAGQVFGQLTDRFFQMISLSFAEYLFEENYINCSLSIFEAIFQSIVPKHVFAEI
+SRLTTIDEQQNKFFGKRKARIWEIVNPQMTNTCFQITNSYFDSNFWLFLKRVCTRILECL
+SIQNLNLEERKNIPKITISNTSSESKLFGNSNIDNSNLYNNSNIKQDGQYIYSVVSSFLA
+VLKPKRTWTQGQNQCKHKNTIPNHCSILILSYLIISNSLERDSETACKIEIEAFYKWIQV
+LYYKVLNNNITSNNEDDHSNNISNSNIIQQQLTPVLTGSKAQVKNILFTHFLHNNYSTIL
+QDQSIPDRIIIMIHHFPTFLNVFINSRMETTLVTNIGILGVIIEKFEVVEFEEVGRLNSQ
+LSLHCRIRRVNYIPQNYEDHHSRKLFYQVYRPSILIFGIFLYLCVSNSNQANDYIKFGIN
+TLKYFNYQKSISNLTGSNIYNFSYVQFCLRNPSLSYFTCIGSWLRHSRTLIYNTPNLQIV
+PGGFLDLSTNSIANPVPIYKVPVDDLQILSKFSQPFNSLPIFHKLVTNNIKFNDQLSSKA
+NNDEIGFNIESIKKLCKVWLLSPFNALDVLLTDSKQRIDTIESIAYNAISNEIRPLQLVL
+RIPKDFSEKFILDISVKVGKLITQDPYFGVSESEFENKNDSIIQREEDIVSKLGILQIPT
+NNKWEIVFSQNTISSVGNNDNNNNAIHYNSYQNNSLTPYSSTIGRFTIDGKLLRRSIVCE
+VKTSFETGIVNTENVNKEVGSLEEFTRMHSLINKGEEKTITYECKSVKSLSDDNIQFVGF
+DPNLANETVVWTLRENTSNYRDYPSTESKFGSESKLVESETELGFISESGPLTGQKPKTT
+ISSGSSTWSLSYSEEKTVSFIDENITPYFKILKNGAKIDEYTTNLFQGVGEEKDKEEERR
+VEKEKEIEEKEIGINQQGEFENDSIFSTLDNSSGVLLFIPMFLSINKGGNYKVSVNVKIL
+NQFQMSNNKDLEAESEEKLIEFSGNLILHDLEHSRPWYVGECITVNSIIPKMDSLHGCVN
+YLDKHGEQLEHRVVPLYDSSNEISQFFLSFEVQTND
+>gnl|md5|018085673834063c410bac97881bedd0
+MKYVALFCLIIQTVAVIFFMRISRIKKSENDELYFNSCAVVMSEILKLLSSLLIVLYSNN
+FNMVEFYNTLRFEVFNSFKTNILVGVPGLLYVVQNNLLFIALSNLSGAVYHVTYQLKILA
+TAILSVIILNKQLSKIRWLSLLLLTIGAVLVQTGKSSESKTLNNSGLVAENTDNFLGLCS
+VLLACFTSGLAGVFVEKLLKDSKTSIWGRNVQLALYGIIFGLIGCLTGKEGLEISQKGFF
+FGFNTLVWFVIILQAIGGIIVAAVLKYADNILKCFGNSFSIIMSCILSWYLGDYSITLNF
+FAGSVLVIWSIFIYGLESAFPCSEYLLKLKLILKRNSRNKIIAKYKNLRESSSEASFDFN
+DQNSGTRNNHLNSLNNQNKSSNILSNSKFKNINNFINKQNQNRDNYGEIDDVIPKGLQMA
+IISSGV
+>gnl|md5|7b29f02163c99387a1a980b28012661f
+MLAKPSQDQSIHGERQHGSDVRSNNLTAVMSIANILKSSLGPQGLDKMLVDEVGEVIVTN
+DGATILSQLEVKHPAGRVLVDLSELQDKEVGDGTTSVVLLAAELLRRGTSLVSNGSHPSN
+VISGYKLALKECVRYISGSLSINETISEECCLNVAKTVLSSKLAGADSEFFGKLVVDSIM
+TVKATDPLTGAVKYPVKSLNILKTHGKGLSESFLVEGYALSHTGRACQGMPTSVKNVKIA
+CIDFPLKQYRMQMGIRVELEDPKELARIRLEEKEVIHKRIEKILATGCNVVLTSGGIDDQ
+CMKYFVSAGCIAVRRVEKVDLRRIAKATGATICLTMAQLEDSEESFDPAYLGECQEVREE
+RIGDTDYMMFLGCKTHRAASIVLRGANEVLLDELERSLNDALCSVSKLLESNGYVAGGGA
+VEAALSIYLEDFARTLGSREQLAIAEFAEALLVIPKTLAINSAKDATDLVARLRAYHASA
+QQGQLNNYATKPTSSELTVKPQDQDKYKFFGLDLINGTVRDNVQAGVLEPTISKLKSLRF
+ATEAAITLLRIDDYIKVKPVENQQGNE
+>gnl|md5|f15caaaf61bd3730bdb36433fa117812
+MSGCSTDSKKSICKTASKSCNSKSSKISVKKETPKSTSLSSSKSRKSSLSKSSIATTKAS
+NSHPIKKEQGTVKPVVKKTISKTSKKGGEILNHKIIKSKGSEAKAISEIVKKGASSSTKK
+VTKSEVAKNKILDNIVKEISTGNKKRKPESNLKEKKISKANSKEKKSASTEKATKPKSKT
+SSSSSKLKKLPASVTSLTARKNSMKVDAKNGGDSSLRTPTRTSRLSYSSTPISSLMAAND
+AESDHGATNGGAIGDLIRTPVHLVSSALRRMTKIFKN
+>gnl|md5|4a496f8e2f50bd469f9a7181962d126a
+MNIELSKPLLKTYTQNQIISDTTSNQSYESPDLSDRNETKVSDFISYSNRNPPNILMENG
+TLNIMHHWDRLSQFFEFCLHDRFHVMLSMGWGSLILFIFLIYILLAIILAIIHFIITFGD
+AANCIGSDKFGNIEYFFFAVETMFSIGYGSPRSPCCLITNYFTPITVISGCILNSVTVGI
+FFTKFSESTSRKWSICFSKELCGIGFKSITPEEVLEVPNQSNLPPVTSYAFTKAAETTCE
+NCPFIISFRLFNISQEPFFSPDLKIFILIHGDNGPYITEISSYKLDVPLEFMETPITVSI
+YSNQPDSPLKNFTINHLRNQGHLIELMILLRFSDNRTSKNLEVRKTWRLNNVFWGYKFSS
+IIKKQVYHGGTMYKVGISDLDNIEPVISGTPFL
+>gnl|md5|5132ab32b56d8a833ba5c688728f8572
+MDALETKKIASVLKAQAEKTPFSLLVSPGDNFPGGIDFKHCFENIYSEKSLQIPLFAAMG
+QADWDNGNANLLLKRNNVTYDSNNDIFPRFSFPNYFYHYVSHYTDTSNVLSRRDGTVLFV
+FIDTFILSSSFPDHKVSEQAFQNLNATLHYGHKHHDFTVVVGNKYLASSYSIDSSLKKVQ
+QLILDTHVELVISGQNRGTYNSTIEGTTFLNCDSYCSFKVDGSKMVPYIIQNGNQVELSP
+INTQLPSPSLSFQGIAGDELPALEMIELTFKKGAKHLSREAFLKIVGTVGLMILATCIGS
+LIINRK
+>gnl|md5|7e67a6ebde1b478b0c0e1a9616016a84
+MKNKNNKKRILVEKEKNYHEKANFEIWKTDGIYRNENDRSFIFGNRKMSNMKKMQIDYYP
+YNEKSKIENEMRGNAVIKTRKERN
+>gnl|md5|960e4d65f539df8c547f8a02dddc64d0
+MNRSNLERDFRELINNKTFNLENEIIELNTNLLKEIKSVKNESSTIFKNFNRSLNDILTK
+EKNQIIYNNNHPEIESQIQLIIKNLTEHERFYLKLRNDLENISEEVKLIDEAQDVLRSLI
+WSMNKRNEELSTFNSENTIENSQLEALQGQRPEIEVYLKKLLGTKLEMQGYNQIDWAQSS
+MGGKVLNPKSNKFCKTNKDNNNSNSIIIKSLRYFQDQLFKFLIRKNHRRTTLKVPIYNSE
+CFEPNQLIKSNQEKTIGNCLLAEVGTNIDIQLSVLINVTSVGIDHILFPLQYDNGETVPR
+KFSVKCIKGSSIEEYEYGHFMYHYPQNNQGLEIFQVNSNSFM
+>gnl|md5|82c97deedaf377faf092ece6b0d13f5c
+MVKYEKSILTIIFNIIIFLYLLSSFNIIRCNGEKMAHFELNSVETISRSLKNTIFVDNLE
+KVNFPLANDGFSPGPKVYILKELLQNRREVKKLYKILRKMLIKFYIEEFGIILTYHMSQI
+EEIKLMGIDTNGYFRLINHQQKPIKKKLPKLSKKMIKKSQFAKTNTLEDFGLMTKDSDAK
+NKQDEHSTFIENEASQIEFLSARPISFLKMKNSNTNIDSFGNKRSLKKLHMINSKVNKQV
+AFCKCKSDHKLHLKLIMIAQSLLFVINNAIDTNSTPWYSMPDFIALLLEDILKITSIMKF
+IGPNFKQFKSIKEYYKYSKKHIKKSQKKHFLKFFSDRRNNYQTNFLLQILGITISFFGNI
+FNSFIEDFRNSHSVSDLATQIEISNANDLKKKNSMIKISKQDIIFISEYIERLPNKNNCI
+IYPMIENISVSAPNQKSIFSLC
+>gnl|md5|df4bed7bc16b333886409bba1adeed85
+MMQSMRRYIVLGLFYFCMGESLSEIPTQYSKNSNIFFQVIPISALLSRSMGTYSFCKSII
+YDSKNTRNLVHVFGAITACILTFFVYILGIYISHESLIDGVRMILSQSLVGGGLEKDFLR
+ICIYLELFVQSILLSECVIRRGKSVYASFASRISPILGSLLMIISLVLRCLHLETKMVPY
+YIPYLEICPYVWGLFIFIHCIAFYIRYDDQGDNSRDEENIVYMNNKVGEQINSKQNYNNR
+VSSESVTIQKKNQ
+>gnl|md5|9ee0985d716539cf4fbc0bcc3439312e
+MDQGGELETQEKGGISSAKELLVENKDDGTINLDTSNLLEENKKLKDRIKELEQKHYVDN
+IQDEGQEERRNQVSILTEQLVHERNENERLHENLNGLQELLVKSKQELLEFQQRVYDSEI
+ISSRSQHESKILEQEKNTLQESLKKYQEEAGIMESRMKELHASKNNIILESTKKISSLEV
+SCRDFEHKITLIQKSRDELEMEYSKTCDELRRVKSELDFCKGHDVGKVI
+>gnl|md5|faec0c148db78752156734ee43167654
+MESKLKDLQNEKENLEKLLAQMQKDEEIQEKKSRKSISASPIGELINLSLSSSEYPERRI
+STRNSIHSSSDNKIDLNDSDEGFKDHSGIDNDEVSKLRVQLEESRKLQNYWKELVQSVEK
+QLETKTRDLDELKIIEENLKGELESRREEAKQMEEESQKELTRLNESISAMTLRISSIDE
+EIAKREAVLRDNLSQVTEENIILKKETDELRRMEQDLRGQYQNIVRMHSLDIERLQNMNK
+QCMELKEELSNLQDKSKKSNDESTNLVMEMQNDIVNLRRQLESYIKKYEIAKTDYQNLRD
+MMNKIKTENQLPSNLENMLDMAMVSSSLIDGVDIIEGNDKVSDERRLSIQSSVNGVLGSS
+GGGSTSSSSSSSSSSSSVTASLLLMRKVQTLTSSVEELDAKLDESKIEIQRLKFERKSLR
+EENEVLQKRLSEELERASEFASKAEANESTLIRLGELVTLRESNDRLRRELIQATERHSN
+LEKQLEQESRQSDPLRCEISKLGAQVESLKSLCEEKSALSKSWEEQYNRVLLNYENMNPN
+EITQMKEEISKLKTQNEELRDSLGIKAQEIEKLQTEKQQEHVSNEELQLTKQQMEQLRKV
+YMSTNQKLKEERNKCTRLENDLKRLSSQVQAQNQNQSQTQSQPQTQTQPQIHMGGMGLNS
+SSSNSQDGSNSNNNGNSTSSGNSSSSLNCKPTAQEIKSISQATENLVDTVLKLAKLSILR
+IESEGGGGGGTGAGGGGTGAGGGTGTGMGTGGGGGSSSLVATSSVNSINPSESVGTEGNS
+GGVTGDNAAFGIFTTSNNTIATFTTTSSSLVDSSTTTTNNNNNNNTVASSNNLPSIVGFS
+GVSGQSSSEIMTTSAMTLQPLHPPPPPPPPPPPPPPPHTLPHLSQSQNSISSQNSMEIQS
+CTSGSGSILCENSSDSLKQQRVQDDLAGISSIPAQKKRPLIGENTEVNETSKNIQENSQN
+NSNTNIQII
+>gnl|md5|ece01a7ca222b112c14b39b2affe1cd3
+MTNKPNVRISESGLEIVKFSKGIQVQARNNRGTRYLNYKLLIRKIRWVSEQESQENWTEA
+QRYDLIFKDILLRDMNRMDAMYNRDINYIRDLLCILSRDIWSLLLSCHQNFGQMNVFHGD
+HFNESIGNVNHNNNNNNNCNGNTSFMFFSSLSNIVNPGIEISVHDKRVIEWLYNLLECCG
+KLAKLRSYIIWNSIAVIKVLKKRRKKVSINRHIKNPLDAYSLLNSHEFYKSITLDYLNKN
+LRNLMLKVFRKDMFSDYCQKCKKKTSEPIKSICNHILCWKCIINVDEIFYLDSNTSKNDF
+NLNPSNNSNSNALQSPSIISKQYDYETGGLLNVSDQTTVSNSVNCCSPYSFKKIKNRPFK
+NCPICHTKWSRNPESLQVENKFVKLCIQHYLNTKSLTGILDIDTVIQSSVSNVGFISSDD
+ETEDEFNMEEESGIQDFDLNSISEHNVNNGSDNNNDGFLDSIYDFNISTSDTDINMGFIN
+NNNNNKSINNNIFGMLSCRPYSSSISTITSSNQSLDDGLSSSGGNLSASTSNSNMNSNPS
+FSSFSASNNSVVEMGGFESSGGGDVGCGGDVGGGSSGVSSGVNVGVGVGGVGIGGGVGSS
+SNNSISGSSGIPSPPPLPVSCNNSYSRSLNSNNLVQKMSHSFLQGQEAEFSRLGFGFDIG
+LGLGPGPGPGPDHDHDHDPDHGSSFNGTIEEGERRAGVGVGEEEEEEEEVIMGGIRGEFR
+ASNMNTRVMKSSSSGMDVSSFSGLGQKSFKNLDKSVMDISSQQRKHNSMQNRLLGGGCIQ
+TRENEFYSGRLGGTFSNGRLNGNNNINHTKNLIGYNNKEGNFLNFDGIRRSGMGMIDVGR
+FQNYQSSSKKTHQNNNHFNGFVSNNNYYNNSYFNSNGNGNGNGNGIGNNGYHGWSHNQYG
+QGQNANRNVNNNHQYLHFAQQSLISNQSCFTGNNTSPFQTSWSSNMNNRRNNNNNTNYMN
+GIQNMSSLYTDHSNSINNFDMINSNYDYSGLHYSGSVSQHNGNNNNKSLLSSSSSSIKSM
+YSQNNGEIHTFPSNLHNNNIIWSNSGGNYRRKSMNNNNNNNNDSSNNKNNNNSNNSNNNN
+TNTNDNNDLQKISSCNWNPFTSDHLIGNGEFLQEYFSNKNNKNHNFSEEIVSSDSKLLDL
+FRGLGV
+>gnl|md5|bfb0ca5a1b5a83be6f5f75c74f86e8f5
+MDENKDKSKTKDKNKEKDMDKGKVVLNQVVPRNLTKIRLKNCIPVESIMELRYNKAEQEG
+IWNNRKGVCIHFGGRFNKKKVNRDEKKFLPNEDITQIIHKNESGVSELKNTENDQNSNRC
+FNFKKHLFNQLQVIGQFNKGFILTKLSIKEEQNYINHKNNERNGKNMIESLHIFIIDQHA
+SDEKARFEKLNSDLSNIQTQKLISPLSISLTPSQEQLVISYKDIFEQNGFRFIFNSNSEI
+GSRIQLTQLPVILGIPLKQIDFLDLLSQINKYKVRVSIIDDSKSKVLDLPTQISSNISVE
+CRQNKRLMEKRTNEELDEKEEEEEKEDSISVSTGDQENTNVTLWCPSGIVPRPRRIWSIL
+ASK
+>gnl|md5|4ce50a1d16ba586f74337f7f6a7dc481
+MNGELNKTQYNTNIKTKNADYFDQMENISGSNVRGRLTYSDLHVKDSFSHVYSNNNITRC
+SSNYREENFDRDSGSNMVILNVYDLDAISGSINRFTRVFELGAFHAGIEIYGVEYCFGST
+SDGSSGITVNLPRRHPIHIYRESVKMGRTNYSRGEIKRIINEMKPLWLGSDYNIFRRNCL
+TFADELCMVLNVGQIPNYVKLLPELLCQAGDGLDKVTKHISTIFDRIASNCSNLAIVESE
+QEEKNDQSTTNSSGMSPKKFPFGIKNPLL
+>gnl|md5|e67a86806141ac66752dbc861e5420c4
+MQIAVDKSITSVTNLCYSRELILNGIGNLFPQEAIEYGSLMNSMECMGGLTTAREHFNVD
+CDQVKILIQEMVLSVNSIQKRLVKRRIAYSERIHYEKKLKKRQQRMNSGKSISLNDNVKL
+DRTQRKCGDALDEFTRIDDDVQQELQQFLTRSHEISLNIISKYNYAVGSFFSFVYSHYDN
+MVNGEIPTNNLMIPDQPQVSITNSNSTPNADLVVSPGKVSGTAMNSATSVSTSSSNQVQS
+TPNLRQTGNTSMGTINSQKMDSSETLTRPASTSTLKKSDSGCFSGVEFASRRNTKSMHQN
+SSSMEINLNKA
+>gnl|md5|dc69c16eeb5b05e6bcf12555df2fa9f1
+MIEIPIKSIVCVEIPGRVENLDNAIFALGGMEGIEESINSKAPMKLLFCREDPYNRPIYS
+DFMKRTGVLLRKLKYANGRIEWRVIGDVSLVHQFIQMADFYFIPPPGFRDKKTIHEEINE
+EIVGTPFIPPAVFSKVTHPVNIKWISTNDNFDKSTNINNIASSIAGDTAGTPSALDVQVE
+SGGNEVEMMDITEEQEEQMKSEGQQYWNVVFKYSDSIVPSMPLKISSSINLDKQALGTLK
+ELFEEQPLWLRPVIESKISPEISTWKRKLLFTQVCYNISDGPWRACLCRLGYDPRKDPES
+RIYQTLDFRDPYLRKVLKEKRIGINVKVEEDLGETILDWQFKVPPKRGSQLYQLSNIEDN
+HIKKILKEAVPLESCTRESGWLKKSVIDQIRELLSLKCEQMRQLENN
+>gnl|md5|73c55d71269c4e83bd808035a3182493
+DFMKRTGVLLRKLKYANGRIEWRVIGDVXXFXXFVFCLFVFVLVVLVFFFFCWF
+>gnl|md5|92a67c2b57c7e23dc109f2b623042bd6
+MSEKKAVIKNADMSDEMQQDAISCAAAAIERHNVEKDIAAYIKKEFDRKYNPTWHCVVGR
+NFGSYVTHETRHFIYFYMGQIAVLLFKSG
+>gnl|md5|868c9f5ff8e4aa4e19c508a45411833f
+MQSYFLSECPEEPIGSIDVITSHNRQEILGQNEGCLLALTCWNKSVKFYDPQIPYGASLN
+DNFKYNPSNEPIERSDELQNTSTSVQNTKYISTGKCLQSLQCEYIYLACKFKNDSTIFFG
+GFNEAVDIINLQDSLYSPRKLVGHLAPVRCLSLLENSSILASGDWNGEVLLTCVNEGSFG
+SRISKISLPGKVFCMDYSYNEEWLLVGDSLKNMNLINLKKLSSGIETTTPTEVVPNFMKY
+QLRNICANKHKDVFATSSIEGRVQITSVERALRGEVNSKESPKDNYAFKCHRTKDNSIMT
+ETIYPVNSVCFHPQFANVLATGGSDASVFLWDTNAKKRLWRNSNFQLVDSDKNLIRVCNE
+SISSLKFHPTLPYLISSCCDTFDQSCRISSETRDQANDGSNSIPVQRSSIIFHSVHGVKP
+LE
+>gnl|md5|4c9e198692f325c26efa66105d970330
+MEEAQELFRKAEKAGKGSTGFFSSLLSVGPDYDEAIQLYSEAGNKFKILKAWMDGCECFS
+RAAELSLKQNDLVTASNYYTECGNIMKRSDLQKAIPYFLKAVELYNKNGRFSQSGKLYKN
+IAESLESDFQYVECCEFYKKAADMFDMDEYSKTAYSSCILKYADNFSLSINDEYSNHSIS
+KTEKAALGNNSLLEAVEIYEKEAKKALSNSLIKYNAKEYLFKAFLIILSLEDNVDAQIKW
+EKYSSIDQSFCTSPQGKLCRSILDIMERRQNSVGEENDDLNKNRFVEEFTSLIEEYNNIY
+PVDDWKVHFLSIIKKNLSRIAMNLIEKAENNEFDLT
+>gnl|md5|5849f88eecfa996e90ed457649eccc1e
+MKAKNVQEELSSLDAFSSVSHNVTPNPGNPLDIDVVFKLRENKKRFTLGSTINKRGKIGF
+EASAFFPNLFGTLSTSKFSIATFGTSSRELSISHFTPNIFSTNIDMVYNLSKSIVDYNKS
+SSYTENSFGGLVRFSGPNNHHNLTVESRIREFPRLVHEQIGERLQDCDTDSSNRFFGQSI
+QTLKNSICYSWNKIKSNHYNEKDEDSSEAGTEKRSNAFYKINSNHTIKQLSVELAGFNGD
+VSFIKTQGFYTWSSKLSRNRYGFNFLKNPSLDFCLGFGALLPNFINNSIFKASMHDKFFL
+GGNCGAHYCLPGFAPRSVGPCTYITRAQGKEEDSKIVENRENVYLGGDSFIVSEARISHP
+LDLSGMGTDVKPDVQAFVGSAIVLDRNDNREKRSVLEKFRQNIRVTTGIGLSVPLGPADL
+SLLFSAPIKYRSTDTLEGFQLGMRMTYAPL
+>gnl|md5|8d6c89fa43b121cc327f4e8f833286a4
+MSVTTASKPQYDAFRDEYSFSEGLSFDSFILVNDPRCKKPPQRIVKEEALSPIQLFLRPF
+MQCCAPRSRSGKKIKINISSYSTTTRTSIASIEIANKFGINENETENVETLSKQSKSIMW
+YILVPYEYGIPIITETQRQFACLLWGIKNEYGLVTTEKSIQKIFEAAKERRETSDIIKEY
+KSNPDLQIMKLHRDGLSVTVDEAFNEILSYYSPKYSILAIISRGRCFAFYSQASEDKTNV
+TYLLFDASSKYETGPRVFGFKDIKSLREHVISEFSHDHETRLKVSEGFRVTVFQGRVMWN
+TEFDMPNTIVKKDFKEKNEAMIRLGRLNDPKFDAKVVYGELQKATTRPTDQDYFFTYQNN
+MMKITK
+>gnl|md5|2c95b23a108cb9b1b88483f81b2f0572
+MSATQGKAEYGKKRVSTIIKALAWIAIVCLVKNASSEGLSGEKRHVSKDYCRAVPLDGFA
+DFAECAPPSNEAEYTIEVVPVVASGIDLRSEVDIVLYGGDDTQTSPIPISSSITGTVRSL
+STKQLDIGAPQQVGIFLKSNTRWKCLKITVVKDYRYWVFSCNGELTPQHRSLTFGVTGNK
+LYTASIMTGKSGEAGTKGGVEISISGEAGQSDKILLKQGFYSSTLRRMLFRAADVGKIKE
+ISLTNTALDDPWYCEYVRIQSEDGESIDFTVRRWIGKPFSQMVTLTNSISGSENSPAQDI
+DCNTRAIDIVPRAPVTTITFKVKCPVNCGSEKFATIYGTGIHAASSSICKSAVFDNILTP
+SGGELVLTIVPSLPKYFGGKGAFSIESSDFFPKPGSEIFSFYTYLSDSIDFIQSEVRVVD
+STGNLASSGRLEVRRNGIWGSVSLKGESTVTNELAATLACKQLGYSFGSILPSCTYVNGG
+NVCTPKGYPISVAGLQCNGNEIDIAQCMFEEPKTTNSMTTVAIQCSSIAPKDTMHGALRI
+VDSTGVPSRTGAGRLQVYMDGWGSVCSDGFNSVSERVACTQMGYSGVKNGGASTKSCKDF
+GGEDVCGSEQEQILMVDVACKGDEEKLVNCQHYSSNNIYCVHEEDVVVSCSGSGDPTGNG
+AYLSEKSPSILPSIPYNKYQFDCNDSPVSIKGAVGTGAIIACPSKCSKASSHIKGSYIYS
+DDTPVCKAAIHAGIITDEVGGEVVITFVSGQKQYFGSFNNGIQSRSIETSASKSKIRGSD
+LASIRSFTISKLSATINRKENDFSQQIVNEELPAISPPVLSWVCPTDYPGFRGGKNDFID
+ATNLPGGDRISSLDDFTISARVLITGGQGTWRTIMAHTECLGISLYIDRDNTIHFDQLCN
+SDTVSTSYAPAINEWLFLTVAYNFNEKRVVMYINGNEVANKVTGFVFNLKTKLIIGRSSD
+SDSEYFLGQISNVNIWDKFFTPSEVKSAMEKSWHQKGISGGGELKGKRHTIDGRQCITSC
+QSEFPVAYKMGGINYATNPSIQIKCDTNLDNARFSSKANKFRVECPAGCSKSRYPVKGHK
+VYSPKSSICQAAMHMGIISDTGGEFVVALYPGLKQYTGAAGKNNIVSTDENTPQTRSFVV
+GAAPKPRQLTCSDTASFIFQLPVGERELVSCPSNCGLESDAKVYGMDIYSPISSICRAAI
+HASKLSSGTAGEIQIEVGPEQFHFEQSNRNGIQSQSTGYYIRSFKIV
+>gnl|md5|47c09518404b07056f4400878f971e68
+MSVGTVSTASTPSKSHRSRSESYQKLKEEKDFATTSFESDTNDGLYRKLIPSLYAYSSLH
+GCIDQLIPTNYKFLESSIGLSPKSLGMLTFAQKFTQGLFTIISGIICDRQISATNKQLEN
+NHKNLISLEEGDRDSEFAQVSYRNVEDENQSGNRIERESEYGEEEYEARSLSSRSEASEK
+SQLLQYSEDINFLRIWPAYFMMVTTIGWGMVMISMIFASSFLQMLTLLCFMGAFLSLMGP
+LTQSVIGTFNNIGRSEHFGNLFLSQNIGRLFCISATANIMGHYFDFTWALLTFSFLSFLF
+SIFLYKSCIEHAFQQKGGKTLHRKILSYTGEHAYIVHISMQIREIFSKLSYGKLKDFIHD
+YSYVISNKSAWLMLVMGIVNGIPRHSLNFTMMWLQYCGLSPLLATTVYSSSWISAILISP
+FVGKASDYIESIYPWIGRQALAQTAILLRIIFMIILLRYIPWGSHYFFYYLVVSILIGFM
+AGWPGVGASRPILCQIVLPHHRATLFAMFSLFETIGSAIFGAPIVGLLAQNYFGYDSSLK
+KEIGEIISSDNLHALQTLQLNANALANSMLIMTVIPWILTIALFGLLRLTYKQDQNGNNQ
+AILS
+>gnl|md5|e94546936b27293896c3bc5c0fd8c673
+MAEQLTEEQIAEFKEAFSLFDKDGDGSITTKELGTVMRSLGQNPTEAELLDMINEVDADG
+NGTIDFPEFLSLMARKMKDTDTEDELIEAFKVFDRDGNGFISAAELRHVMTNLGEKLSDE
+EVDEMIREADVDGDGQIMYEEFTKMMLSK
+>gnl|md5|71c29e54babf1ef503062e03630f6d0f
+MASSSDTVGIPTPFVVDALSEVGKSSSGYVHIRNQQRNGKKSLTTVQGLSAEFDLKRLLK
+AFKKNFSCNGTIIDDPEHGPILQIQGDHRHNVARFLVGENIVNSDEIKIHGA
+>gnl|md5|e81fc6955868d364a3d9b0c19818783d
+MKMELEFVGQSSLSNPAGMNQLNNVNHKNAMMNEDVAGAPIIASILNSATHPTICLFQVL
+FKVLAFLSFIFGPFFFRFFSNNSFILTFFLTSILLSLDFWTVKNVTGRILVGMRWWYEIT
+KDGETVWMFENCNESKNTNTNVSSSTDKSVFWVTTYGWALLWVVIIVFQFLSLKFQWISL
+SVIAITLSFSNLIGYTKCIRSSRNIQKDWITNIAVKTIMSNAQNMV
+>gnl|md5|96b558697dfc622e1775aefec7eba50b
+MLDSETLTQKTKYFNSINCCFNLVVYLCWMFIPDEYLNQINITYYPDRMWGITVPIYMLF
+LPFMTIITYNCISILNVKPTNSFDLIIDESTRYIDLSFLYKFEDLEQIKSICKSTLKIYT
+MVNKNSGEKITEGGRSDHEKKYELYDDPKSAIIRQAFKSEDVTLDLVHLNNEIDSIHNNK
+NIVPVADLPLPLVCEMIYSDKFAGKQ
+>gnl|md5|d2d407e1f085a1202fb53aa9dc76b740
+MRKTNRWEGIILFLILHVLIKFKHVIGEITNVLNFQADIIVPLATGGDLPPDNNYDIYRR
+IWRASQSEIEDLERKSLDFFKEMTDVDIAGLPACSIGNTFNGFGGGILSIIPAFKSQFKV
+VETPERPQLSGLCLLRSMDGVAYIYDQGTQLRVASIYHVRNMDIIGYKLVQSLIPQHEAT
+ESPLPLFDTAFLLNVLEDGYLPCSKFQGSCIKGDRLLYGWYTIRDIYNKGEWGVIHYESS
+GPQNILKEFTPLSFNLNSPVWGKGYSNGFVSRRFVNNDYVQPCHENACPYRMSKMFDTVS
+VSFRNILTFVTA
+>gnl|md5|8bedc753cfe0395bd983df804b753f0e
+MELDFLNGEIETGTTIVALKYKHGLVLAADGRTSTGPIIAFRAARKITQITDKVFMCRSG
+SAADTQIISRYVRRIVQDHELETGEDTKVKSVASVARLISYQNKEHLLADMIIAGMDPNG
+EFKVFRIPLGGTLIEGSYAISGSGSGYIYSMLDSKYHSEMDLDECKSFARDLVSHAMFRD
+SSSGGIIRIIVIDKSGVEEFVVPGEDVPNL
+>gnl|md5|8796964e0665358d2e3816bb6e588395
+MFAMQSSSGISRNKSEESGYDDLLVENPNRIEKELRIETKSKNIEYISASTLDEALLALG
+VDDKQSADMHPEKRQKAAWLAYVDNNLPILKNENPTLKRSQLLQMLQKNWKKSPENPMNE
+NPKLT
+>gnl|md5|9df20aaabf8aba2757c34faa319a1469
+MISKRKREENESKRPSTFSKAENLPLESQELTNYHVVQLQESSKQYKRRINELEAKISEM
+IPIFDKIQDEGKSEEENLSRKFEHIIQQKDDEILSLRNENQRLSMQNVFKRFYSPGNSSS
+NTNSIGISGKTNQSNRQGTTLSELINDCSSEVDRIDITSSDIKSKLIEKEKQISELTNKY
+EAISQENFELRKNLNKCAPYESFEGKISSKKEDDDKFCICVQSIIGEIFELRTQLNSEKL
+KFVTLIENKLLRGIKDFLANQKSCEEHNKVIIQELEDIKYRYNSLKQDLFSLESSKRTLD
+ARDKEQKKKIRELELANSKIESEKMRVGEFIKTVNLKLEKGEKEEVIENLMNEYEELSNA
+FEEKSLECDDLRQKLKEKEKEYDDFKIGIEDIKQTLKEMETIKILYEEKLSLVRRTNKNE
+SGREVPNSDRIQPNQETRISEFLSKHLSFISKLSEDKQVSNYQTQDGNDFNDVYKSLIEQ
+KTITEKHKLDLEFYKSEYCKLKEKLESIENKELNYNTTISILKNRVQYILNRVHKLTNLE
+INFDDTEENINLQIDDYDKEINSLKSENQELLTLMKCSVCCDKVKDTVINRCGHLFCRDC
+IDRNLSSRNRKCPLCHINFDKNDTGRIILY
+>gnl|md5|e26e8365dec751672d3bf8e9099feec9
+MSICIWLSLLVFEGSYLFTEVIGTQTVLFVAIIIVLGLLLISFGIFCGVLGYIGCTISNS
+RCVYFFFIQLNFQLIANVYALIASVIRGYITYSCAYLLCIILICFFLYPSWSLYVHIKIN
+GIPPNAHKHYGLLNDVLSKVEQKNERKSNLEESESLVENGCSSISNGPGMTTSIQINSQI
+FQKKEQNRITMLKKQSTKNSGEIIHKNNSEDNIEKLSHIAVKFSDENDSSGTCSEKPTGQ
+VLNIQTLDSLDSSQQSSSKNSLTQPLISSDVSYKLRNEAKIFLNWSKPTISVNRNIATSP
+NTDCSNGNSGTPPRYSKLQVSNRNNKPKFTRSDVYNGC
+>gnl|md5|404b1ecb01486f8456c907c8f98ad101
+MTQTSYGPNSMNKLIVNHLGKQFITSDLSTIIEELDIQHPAANMVVMACKRQAEEYGDAS
+NTVLIFAGELLRNAAKLLNDNGLHPSDIVAGYEIALERSLSLLNGMVAHRVANFKNVSDL
+SGIVRPLVSTKNIGYSDLITRLTCEAITSIMPDEDKLKEFNIDNVRIVKLLGGSPMQSFT
+INGMMVNREPGGTIRNLEKVSNVMVLGCGLEMTGTEAKGTVVLNNAQELLDFTRGEESLV
+ENLIKDIKQTGKIDAIIAGGPISDIAQHFCNKYDILTLRITSKWELRRICRSIGAVAMVR
+LGVPLPEEIGKASSIRVEEIGSKKVTVINALNTKVSSVILRGATQGILDEMERAIANSVS
+VIKSSTKDNRFVAGAGATFVELSKCLRAYDKSENKCQQNSADVPVPGMEEYAVNMFAEAL
+DVFPRLLAENSGLNSTDLLASLHAVHQQGSQPHKGINVFCGSGTSPIIDCISNNEQGVGL
+IVDHLGTLCSALKLATDSAVTILKIDEIIMAKPAGGPKPRSQNDDMD
+>gnl|md5|13b5dcb4e0bc5d8b92f4528998d21bd4
+MKFPNTLEIKEKISKRVFNAKYKSQDVVLKLFTPDDLDGCAAQIKHVFDEYEGTDCDYLE
+TSLDDRVLYCIKIHYLIQRNLGICMTSEYYCKEMQEWVFETIVDGQRDYLESSLSGENKS
+RTSKDMKNSFIQLIHVFGVRFDQKSQVFTSQDQFIGLIFPKLGQPLMNFTQNQRWVPNPI
+YLSSVFSDELSIAHIFKDVVKSALFLLRELNIVHKDIKIENICTVLDNPESNKIHPIIID
+FGESQILSNNGMLRDAYGTHTMLPPEAFTYSFCSHNDENYMGYSAEKREVWTLGCLLHTL
+VFGYPPYFDIFSKKSPIEFQLKLCDESITIDIPTYSSVLNADISHNLRNLLSSILVKAPN
+NRLCLENILLHPWLQP
+>gnl|md5|9e5e45e9405c4cedf679f57a9cfcb67b
+MINNSQELVQKVDDIVLPECEDRKYRALELKNGLTAFLVSDKETKTSGCCLTVYIGAMYS
+PKNLNGLAHFLEHMLFCGTKKYPNVDEYQKFIASHGGKRQGSTTRSTTTYYFEIKNNAFN
+EALDRFSSFFTEPLFCKDMTEKEVSAIENEFHLKYHSDERVRFHLLGQLSNKSHPLNCFT
+TGNKETLEVKPKKLGINLHSELLKFYSSYYSSNIMSVVLYGKEDLDILEKYTIEYFSKIP
+NHQVNCFDYTKIFMEIPPYTRETSNRKIIKLIPYETDKRLKIYFPLPPLDKYYDSCAPAY
+IANIIGHKGEGGISSILRAKKLATGASFAITNEDPCALAQFGVVLTDEGYNNIGQVLEII
+FNFLVLFKATPVIPELVGEFIGITRAGFTYQPKFSIRDLFSLPAKYLKYKCKFEEILSSG
+FLVKKFSQDDVFSILEYLNNDNFFVLLSSQAIEEEYKKNQENFIVEHYYGTKYSISELDE
+DLLSIINSSSPEKALKLGLILPKPNQFVSTDFSIVNPQKVCVNDYSRIPELLNFDELKAQ
+GNTDSYNIHSHPLNIWFKPDSTFNSPHSLINMRLIAERILEFKENSSFEKLSNFSNKLVF
+QVFGEILNEVMYRSMHELSSDILAASLSYTINFNSRTNVFVLQGFGLSHKLNYLISIMFE
+KLYHGTEVRKYYDEAILIISKDWKNKIIKPNLTSFSLECISESLSPFFFNRQEKLNVLES
+FTFELFCSIRQHFLSNCRLEGLIMGNFSEPNAKCISIQHWKNLINFQNSVKNEVKSSGIR
+VEQFSIVNLEKDIYTLNYIPNSSDKNGCWMLSFFLGEYNLRKQVLCDLILPFVSSEAFAD
+LRTNQQLAYVVRATQIFSSPAIIIGYYLQSSEYTNALTLERLLEFHINKTKVELKSKLNK
+EMFIKLKDSTIQTLSSNPKSIFDEYKTYLHEINERSYLFDIRQRKIDILNNVQYNEFIDF
+YDSIWTSNSVLTEIRSQIDDTKNSGMGSEYKDPSIPEGYLKLESITQISRNKNTPTISLE
+DKLKNL
+>gnl|md5|c0388f50042f3ee8271f0fd13606e5b0
+MTEIKTNLKEIQNEITKPIYDENKYRALVLKNNLRVLLVQDENTDISGASMSVFVGCQQD
+PEELNGLAHFLEHMLFLGSARHPNPSDFDDYMKLNGGSSNAFTDNLSTSYFFEIKNESFE
+HALDLFSAFFICPLFDTKYVDREVNAVNSEHNKNLLSDLWIRYHVISSIARNGHPLRKFG
+TGSIETLKYEPEKKGIDLIAELKNFHNKYYSSNNMFLTLVSNCDLDELENYAIKYFSEIV
+DKNIARIDYFGEFQKERPYLSIMESPEDGALESMVYVIPNKDEKKVSFNFQIPDLRKFRK
+GLPEMHFTNILGHEGPGSLTSALRRNGWCLALSSGLNEMYSANLFEIIITLTEKGAREVL
+SVIEYTLNFVNLVIKNEIDMEVVSDLEKLSQLVFDYRNRPSLDETISNNAFALANLPPLK
+ELLTFGNRVEKMDVDAVKYLKQYFDPKNMFILLSIPENKALIEDERLKDKLIYDRHYNIN
+YLKLEFGPEIKEIISKISLSNASKFGLKMPTKNNYIPENFDLMNTYGGNMQAFPTILEIP
+GNSFSDRVVAYYKPDTNFRTPHGFSQFFFFSSSKVTCELLVLDTLTSLTLSKFVAEEAYN
+ATIANLDYKISGGYNLRNSMNCLSITISGFNDKMHTLLKFLIKSLVELKNDGEKQLYKSF
+FEDALEESRLSVRNSLFNPDILSHLTSYNFREFYSVYTPSKEEILSILSTTTYERLCDHI
+STFFSQCLIKSITVGNLNKEQARELVETVTIKELLSFEQLNSKMEKTIIRNCIDLKKAIE
+SDPEIKSNRIILSKSVINPMDKNGSVIYSIDMGEYNLRNYVLLELLSKYLDSNCYLELRT
+NQQLGYIVHACSYNLKPAIGIYICVQSSDFSNSHVINRIHNLLDDLLVVKLSEKLDEDQF
+NILVDSEIKIYSNKPKNIKEEVAQYLTTITNGESNFDWKDKSIKILENLTYQEFCSFVTD
+LISRPRAIIQSISALDASKKCEDVANDSVPNGFIVIKDFRHFRNTDALFNITI
+>gnl|md5|eaadff1f4da62fe843d95708baa5a214
+MNKYLLIYHFFLQVVILLSINGSSLGKEPDLVDNEECENPEYLFPWGNDYLNSCLSFQCH
+RVREHKSWYRFWEKKPKYVHKNIYGSERVIQCSDCEGFLKKGALFGGMSICTPIEFGGSF
+DIPKGWVSIATASLQLNKEIKNKSSIKLVPDNWRIDGQTKKTTLDLSACSTSDDSEVALS
+ILVTLSNIAEPSRKSSKYRRILGLHDDSINVRIKTLGVDMGNSADGFDDDDLDDDFDDEF
+DSEDVQQSMHQDNGYNEYFLYDMNKLASTQHRVPRDNPSKGKKNKQKVRKEKPFTGAEKL
+PRKWKLSKGHASIYSSSDVLRLDLASDIHPNELVQVILTCNNKYMNCNIQDFVSCFNILC
+RSVTKEELIRRAALMKAKRFISNSIISGQVVPKMAYNGMPFQPGFPPAIPGPFNGQFQYP
+HANNIVNGNFIQRNSTLPIQGVSNVGANYIQNRGKNGVVLVNNGVGKPVEVSNQANVFVG
+NDGVQNVNINTNTKTAGISNISLKQLPANVKTSQSTAASKGIQIIVVPVQSQTNAHCQSQ
+TNMGNVNKAATKSSLKQKKQKTLISQNIISKEKTKIPNQINNSQIPTTPKQSKSRINQIG
+VYGPANHTVVTSYNSNVLNTDIYQTSAEQNLESQPTTVCILAMEPKSESKVNVVSSNTIQ
+PVEKTQFSNVKQDVTVVLNPINTVTKNSKTSKRNTVKQTTKTQAPTLNILLVPNKTVKTK
+NNFKKVSKVSKNEVKHANKTVDIILFNGNLNHKPKKTVDKSNSDYMVLNTNNVLKPPKII
+TGKITYKSPKLIKKSSKSTEPEFNIIDTIVLEKVNHEEPRNKIDKLVPVDTSSLSDENIL
+LSDPGISSQYISSSQKKHSKQSHSPHLKNKAHRKKSIKVKSRKEGTTENVLLDADKHISN
+SDNKASLVKVEKYILRPVNTSESSEDSESFSEYEFGSEEIGYLSDEDFSTLILKKVKDDS
+AKSDKSVKTESNSKVSTHSQKIKNEDDDKVNEEIKIKNIEKSESKVEIENSPLSDSSDYE
+IFSKQKHYNYETRSTMKSILGYSILISVFLFIVFIIMKLLLL
+>gnl|md5|1148bec17a4a956322624f20d8610f81
+MIVDLELYPKQSLRLLLFINEQEKQSKKSTKFLEYCNEEEVKEFQYLGEEDRIIISESFR
+KVVRAEIREYIDLYMEQYQEPLNDKEEALDINEKQYTVYGNFQLFNEQKDTILWDLLTLL
+IYLDSMNPQIWDRRAVLIGELLQRIGLESEYMRFLSSELNLTKLALCHTFKYGEIWSYLE
+YILTEYYERIKENEFKSLNNDEIINYVLKDNFEFICLQIDSYEHNYHAWSLVNWLIYELI
+PTIISTDDSNNPYKYNEIRMIESWVIKLLQRHPSHYGGYHALVNLNESKINSQSKSNKLE
+VCTVIGLVYPKEIIDMLRIIIECFDHHFINCFSVILGFRYANFMLLIDSVDERSHLQIFE
+NEIIWFQKQDLVEKMSKSPKHLEELREHFYSILSEISSYNYNKSIIQKFYDLLDSEIQII
+RQESTLFYNSDCSYKGLV
+>gnl|md5|0792d6a83504394c4259b93bac34736e
+MADTHYPNGSFEEYEGESVYEMDRLNINDEYIDEQGVEHNTSACTTNLGLYNFDSEDDEI
+SREIYKGYGIKNETDGSVTETKRTTNENEKESQLKTPPKRPFLRKGEGKSLVISNSRKAN
+GESISRRSSQIRSNPAAKIVPSSAPSRRFIRSNKSVVPEAGRNSKLDSLLLGIESSNLTT
+ESGLEGFEIFDAEEEFLGIDWRKEQNIVNPKSNRDEKLKGNIIEKDQEKDYDKLIQQKLD
+LLDEKMEYIHETHEEMLKKKTLLARERKLLESQKVTFEKELRAKFEKSRQEIESEKRRLE
+RENNKLTKDKIALSDQVTRLKMTIKAKDAEINRLTKEITMMEKKEKERESMQNKIPIGKK
+ESSSESVEKKRAVNLRANNQKNGEFDRARLAGNTGITTLTTNLQTTTSISSNSSGSFIDR
+DLVIEEQLAAFDFEKELDLLYGILSTCFEFVSEGEDFTTLPGIPEDVGRPWCDIEKPYKV
+QKDDDLRTITFKFPSGLVEIVFYDEQEDSVCPKNTRKLLWTHLGWCILVYPNGDIKAIKP
+DKNITYHYVEKDIVKCVVSTMNLLNYDGETTKLHFSKFFSLGQLQCVDPETRKTYIIHSD
+MSKQILNG
+>gnl|md5|bc79af4fb4db23fc3e9183443d77e8a0
+MNSRMVFYVEQEQLGVEIGPIQRGLVSYIILDPNEEDGSCEFNVYMVCNPTGLLTKLENR
+ESSCDKIAINEIIPSKVTDSSSQPSDQSAYSAVSRFDIYSETNNSDYYENSNKENYPLLN
+DETILYNKLNRLKCINTFSGTCFSLFVRWNLGIDDVLYPNIPKLNPSSIDEGLIFLKIDI
+NQIKDPSLVSIIEGINFLELLINSSSDFKDTTLQNHYSSNPSTDFEKKELQIISFKFIRS
+LSKIWGYSIMEHFDSKQEDNEANTYVVDDKFELKGSSSSRIDADYTDLLWSFLVSIRDEN
+LIFKIVLLLLDELEKSSTQQLYENRFIPQVRNDNTTIFSQLIRIAIEIYKETQYLGRRYE
+NSPENENSDLKEKYSLWESIKKKYFGEIKAFKFILMEIGFESIIADMKMHVRKSEPLIDD
+TSFDWHLNGLYSKSKKFLEEFNLIELHQNNRELLGRLKKLIPVCYISNILKTYNCSWDIS
+KKLIRSTIKYYSDQNIQEAQPTIFLTPIFNKTMITQIVSSNQPNQIEISSHGTKGGCERE
+ILSLNRVNSIELPKLNSELSESIIKFNRLPICIWRTISDFEESSHLQNHYTIQLEKSLV
+>gnl|md5|d62177cb8943903da5a45f4bbb4acaee
+MDSSDNRFFRARRTLCEMLEDRGYIVSSQDKEEDFSTFKERFESHQRLRSRMLMVASHRQ
+DQTKRIICYFADESKKTGVKPIRDIVEKMDEHAIQRAILISQNVLTAHAKVAILDAAPKH
+YIESFLENELLVNITKHELVPKHILLSDDEKLQLLDRYKIKETQLPRIQYADPVARYFGL
+AKGQVVKIIRPSETAGRYVTYRLVV
+>gnl|md5|734e6d18c958d67f2d7c2395104a0cbf
+MSFGDLKSYKEKHLKVVKLVESNTMVNFRILMHNNRGARYRLGVLEIPECFLSKYGDMIR
+HSEIKTASKNPDLIESIQITETGSKSSLVNLENFGIASIATPSFTVPTFGGLPHCILPKI
+ESDQSENYELASLMPEVDYLLIGHGLDLERVKRRELESIKEKNDERTGNRSCIKYGNNAS
+KFDMLEQPPPQLANKDYVNYLMFRQPMIPGVSCWNGSDGILVQTESGRAMVSIDDLFASV
+RYFQPPFLISPAEEAQTGQCGKNVSFRSIQRADEMLLALIEQLKRKSVYTQRKIEEKGKV
+QVDEEGSIKDGGGAFRTIRSERPRTKVLANIQGAQFVNYRAAAALGVWDLCRGTGKGLKN
+VGFSRDKGNADLRVDSSSGPEAISELDEVILGVAIGGLGYSEKSSVRAECIKAVVDHVPD
+DKLRLISLSTGSPIELLQAVYLGMDIIECPYVYRCSLSGVALSFELDEFLKQREIINYSN
+EEKKNVERFLLEFDFSSNECGIDLEKSEGAQVDAGVCFFGGAKYLNLNDRRYSCDSDKLT
+KNSPVSHSRAYIHHLINSGEILGVSLLFMHNYWQYQGLLLSIRRSIIDGILEDFVAWFMY
+TQTDLQIHPIKLPEPALETYTFDGMKGRLQKD
+>gnl|md5|976cbf3b307891f9c6acb0d0be034631
+MYKSHGNKGLSSYFSPSFEEELVSQYQTLSESTASDIGWPVQESCLKADEIGWEDPVKGG
+GLALNEFGSFMGNMNEEPINNSSKDLKSRYVNNFIFDDNPIAVVPCGLLYPIVFIGNIPP
+NVPYEYLKSVILSSFDTRSEEDNCHRMIALNYQPSYKEWRTAYATFKTWSCAQKVIQHLH
+LRRHFKNAPFHRLVACISPIPPPSVLSSSFDSAYDPQEAEQIITEFQETNRRLIMYQPQD
+TEIWLPSYNRIEKNKGFFGTWNCFRRDHKMHQPPARWMQYYRENGLCEYWDSFTGNMQPT
+LSVSQAKDDKHFLPTSITLLRDGPGGANLFIYGIPNDWTEVTLMQLCQRFGHIVGIRLPT
+ANNNGKLNRCFGFISYDNKPSTWAAIRSIAGIKFFGKPLKIQLKAGEDALLPLTLRPIVE
+GSTRNRNFHQEQFEAKSKSAAQQSSSLQINHMPFMNGCNIPRNNGSCVNPPIIPSPASNT
+INSFPNTTQLHCSYVSGIKQARYRPEPGHIRMNQKYESSILLPPNDGSINSPYNGITDFP
+INPITATNTITTTTTAVPNANSTSNKDSHIDHTNNSSLSFSDFFRIQSAPQPSIDSLENS
+HLIAESQNHLPEKSANLQMLLKNILIYDNSNSHRV
+>gnl|md5|e79a452543b1024881c50488d4b7776f
+MLFTEQDLLEPTAIQVQGWPVALSGHDMIGIAETGSGKTLGFLLPAMIHIRAQPLLRYGD
+GPICLVLAPTRELVEQIREQANQFGSIFKLRNTAIYGGVPKRPQQASIRNGVEICIACPG
+RLIDLLEEGYTNLSRVTYLVLDEADRMLDMGFEPQIRKLVSQIRPDRQTLLWSATWPKEV
+QKLARDLCKEIPIHINVGSVDALKASHNIKQYVNVVEESEKKARLKMFLGQVMVESAPKV
+LIFCETKRGADILTKELRLDGWPALCIHGDKKQEERTWVLNEFRTGASPIMIATDVAARG
+LDIKDINFVINFDFPNQIEDYIHRIGRTGRAGATGVSLSFFTPDKYRMASDLIKVLKEAK
+QRIPPELFKLSPQNKRMHPRNTGFRRNNPNSLPLGGSNRAYRDLQR
+>gnl|md5|f12d915fa7acf615fd691d42f6f9a4b8
+MQKAVGAQCRYIIHIPQGATICVQVQKLRTKTNILNNKLTQQSQSLILKLSTKPYIIVGN
+AILPGTEA
+>gnl|md5|3ae68c0d2175f34a71bd87b93bc5e376
+MMESRTPLEQLEIELNKRGEHKEQIEQLKSYLKEKLYFQFLESSLEYISTDGLKVCGNEL
+CEFLVNVVEPLKSNFNPLRYAVFVGEVLSRSPISIQEKVELLKKTMGDEDLYQVKENYKN
+ASLTQEQNIAPKQEIKGDLYFRCLLALEYSKSKDLSVDCEEMLEFLTKKLEFYRGLEAEI
+LALYHRSYASYEKTMGRMSRFYRQTIHYLSYTPLNKIPYKEKPFLVYELIMAAVISEEIY
+NMGELVLHPIVQEFSSIVKGNNSNQMIDELTKKEFAENAWILEILVSLHEGDLNSFMNAI
+TKYQDKVSKTPLSTPDARVCITKKTATLALMDLAFRKNKNERVLTFDEIAKHCRIGANEI
+ELLVMKAINMNLIKGIIDQASQTVEISWVHSRVLDKTRMKLLMDKIDNWVGSTTDIVSQL
+ENIAPELVNS
+>gnl|md5|4d03e288bfae2934294e20a70926f185
+MEKDIEDWEIWKGDIPFWKHSLAGSIAGVMEHSCFFPLDTIKTCLQSGKVDGLTGNRGMI
+AFIRSNGTRALFRGFPAVVFGNVPAHASMFTTYEFSKRLMSKITKKLEKRAESKSSLLHD
+ANTSIFNSVVSPAICGGLSTISHDIIATPLDVIKQRLQVGSYKGMADCIITMFKREGIRS
+FYRSLPITLFMNIPQTGLFVLLNENLKSFFGKNKDDLLKQNTFNFVIAGISGGTAAFITN
+PLDLIKTKLQTQACHVSQKETLRVVYPSVKKAFIDTLRKQGIRGMYSGALARSLLIAPSY
+ALCWGTYETVKNFL
+>gnl|md5|601f7871c0e6600da1fba919aa32fe8a
+MLLGQVCPSQMAGMGLKRSGLLVCKFADSEDLNLTWPGGQTKQNLVNYLDKSIRIHGKFC
+GDDLLEIEVSYLEEDDKVCWRATTLDELVEDCAFNIIRVVKQGNPNKAMITESATKIKGL
+KEGKRSSINQARYMGLMKDQEGFAPKQCRPITKEELKTHNSEKDCWISYQGKVYDITKYL
+EFHPGGKFDQI
+>gnl|md5|37ae51fa5e267e1845f4ecbcf185280b
+MLAWIKLMFSIYIIFYLIFFYIQVVYSLHSNLSKGANGHKYFILNPIQYNDFVLNIIKNS
+EEISSENSFRKSDNLNQIISSQIKNIICKESDLVFSNTETNVSHSTILNLTTSDSKTNGN
+SDYLLLFGADRCILDSSFIDGKFTKINIRFIPNLVNPTKEVYQDKICDCVFKKGNADEGS
+PSEFQVNCNSDSSNDSNKKVLEEHDYLEIGGATALNIADLVNLPTPIIDKNSQVGREVKV
+EVSNKTPLKPIIKPNHIKASKPKVNKFNFSKYFWETNSGFFGEGEEAIKKSNIEYCESHG
+QSKSCEDEERSRIEREFREGCNNKEHQLILETLLIIVNKLVEYLDNK
+>gnl|md5|f23c3b22dde01d564e136b4479f57b23
+MMGQGQNAINGACSRRYEKDSIEINKNKELRRKQNNKRGNFQAHNMTHGKPEYLKEAVDR
+LINHGNIVGNSPDRYLAKERKSQASCSTSDPTSPLAYRNGNDNYFEQYEICDLIELTSEM
+ALSNESRFESLSEYESIPKLSPSTTVMGITDISVTNTSNSNSATPTESEKGSGPKLSLTQ
+GKFRREGLIPACKGSIHSDYIIDSGRIGKGTYGSVKSGTNRLTGCIRAIKTIPLTRVEAL
+DNFMKEINILKNLDHPNIVKLYETYQDKENIYLVMELCSGGELFDRIISQGSFDEIYAAN
+LMKQVLSTICYCHDHGIVHRDLKPENFLFLNKNYNAPLKIIDFGLAARVNNEDTSLNTRA
+GTPYYVAPEVLQGKYDKQCDMWSLGVILYILLCGYPPFHGSNDSIILHKVQKGVYAFKEE
+DWKHVSFLAIDLIRKLLTYNPAERITARDALNHPWITRFADDILFLSPRNYFYSNDGFMK
+TGIASSDYIDSSINNLKALECQQKPRNCSLMGSRRNGYIKGGLRYCRSKRRSISSSSGLN
+LLSNFRAFHKYNRFMKVALTVIAQQMTESQISNLKEAFILLDANCDGTLTPQEIITGLKN
+SGITELPSDLLAILNDIDSDGSGSIDYTEFIAATLDSKQYSKEQVCWAAFKVFDQDGNGK
+ITANELLNVFSYNSEQGSAGINDKALSDVKNMIKEVDVDGDGEIDFQEFLEMFRRSNS
+>gnl|md5|6c43203029e523ac1f1474b6c97ce995
+MPPKGEKKTKEQIAAAAAAGGRAKRKKWSKGKQKDKANHSVLFDKKTADRFHSDVLKSRL
+LTPAVVVNQLKVNASAARAMLRDCESKGIIKPVGEQTHGQMIYTKA
+>gnl|md5|5dc350bb142c385651c8d7cf61c98e4e
+MSCIQILDFLRNYINKWPDFNAKAFNFDNFSLNENSEKIYENLKKRVCGYLYDYLCEDEI
+SEILYNSFKRLANTFITSFELEFTAQPELDITDLFVMFEIIDSEFMISDNTAEYCVLYRN
+AVSGKYEPNLIENESIRNFNSIASLIEHAISKFNSNNIYLLQDINSVSRETLEELVQNRY
+IRMYEIYKRKSEIMVNKIHLNQFGAETVMNIERSWEVILFSKIIGIIKTLFLVNNKMNDS
+EINNGTYEYSSAYEKSILLIAIKFTETLKIIQTYNKENNRCGTILFLQFELYEIIRNQFP
+YNLVGCIDDIEYWNYFQTYMEMFTDIQNLMTLELSYLPKDIEQMIDDAYFNRMQSIMDYM
+FNRIFIIINSIELKYYSSEKQEMNYLSSFCALIANYFNPLLFSKNESNEKYYLLIKASIE
+INIINWAKLSFLCTNHEFNTCDDSIKIETGSIVPKNISKVDFFEGKLINGYYMIFCGLKI
+LYLLLNTTDISFFLPLVRHIFSNLQVVYCLLSKQEYQESLTFDYIDDFKRAKRLLDEIII
+LFSQSLNIEFIRTLSTSESNIDLQRNKTSIDLLNNLIENSCLIV
+>gnl|md5|e04a6349dcf639176d088bce409a18e2
+MKNSGVDYRGRPLFDIPHKMASTTILSKNSADLNLKGFFNLFILILVFTNMGVVLENAMK
+YGCKVSFPKGITDLIQNWPILWCICQLLALVFVSYLLEKYLASLKIFLLNIYDCEPNSNS
+NQANCGFANSSLPKITGGLSLVLIMINMLMMLYIPYKTVKFYSPNPLSSLILLSFSFVWF
+FKTLSFHHVCHDVRRCILNNEDFHEVCGTSPEAEIASKYPTSLSLRYHYWFLMAPTMCFQ
+FWYPRTGGIRWLQVIKHTIELITCIILIKIITEQYVMVTAHYTFTLKEIQSMNIFQFLGH
+MATRIMKLSIPSLYVWLLGFVSLFHHYLNILGEITCFADRAFYLDWWNAGNFGEYWRKWN
+LPVHFFLTRHIFKPLRKKGFSSSFSGLLVFTFSALIHEYLVVVPLDIGWTGWVVLAFVFQ
+VPLSSWTQSSYIQKRETLGNVLFWITFCFCGQPIAVLLYYYLWALSKGQIDQIDLNKIEG
+IPQIPLENISGYIANLTNVTHNIYH
+>gnl|md5|516a86755621b13806623557a3d805ca
+MSSNYRVHDDDESSQNSHDGNNSSSNGIANILLTQDPSDYSEAEEVAVDEVVYEEEIANE
+SEEELGEDLYGDNFMNDYNKNPELDKYDPEMLDDTHYEDDIEAKRRADLALDRMKSEKSQ
+GKQTEIHHKYGISTFNADDGDEGEIEKRRKRREAFREMADEAARGGAIVDINELIQDLPL
+AEQSEWSEHVENIIRRLFKVFLQDFKLSSMYKTISNSDNKLEGRNISFEDLYYIKKIEEM
+VQEEKTSLYVDVKHIFTFCYKLWDYLNLYPTPVIECFNQCAYEVVTSMYHSLYSGKSIMV
+RLIGLDYIDQLRDLRVEWLNQLIRVSGIITRRTDILTKFKSLYMECVKCGCDSLGPYEDN
+PLFESGSLSENNSIMKNIGKCTDCQSKGPFVINREKTIYENYQKLTIQESPGSVPAGRVP
+RSREIIVSGDLVDYACPGEEIIVTGIYRTFRDQKLNIKSGFPILGTQILCNNIEKKHDAL
+RKDDLTDEDYKKIKELSRDPDIKEKIVSSIAPSIYGHNHIKTAIACSLFSGVRKQVEGKH
+HHIRGDINVLIVGDPGLAKSQFLKYVEKSFDRTIYTSGKGASAVGLTASVRRDPISGEWT
+LEGGALVLADEGICLIDEFDKMSDKDRVSIHEAMEQQSISISKAGIVTTLRARCSIIAAA
+NPIFGKYDSSLTFKDNVDLTDPIISRFDVLAVLKDEVHPMKDELLANFVVQSHMNSQEMY
+GSSGLDQDDQEKKFSSGLSDTSQNCDQRFAPIDQKLLCKYIRYARKYCKPQIRSVDKEKI
+ITFYSRIRQEAQQTGGISMTVRHIESIIRLAEAQAKMRLSPVVSNKDVDGAIGMVLESFI
+QSQKYAVAQRLSKIFSRYKALSSGFVDVLENLLLQLFSDKIQKIKLRNWDEEQMNTIVEE
+VDNLTVNLDEFIAIAEKIKLSHNVTLSYLKSSSFLKHYLISETTDSMGNNIKIICKRSYT
+DQDSQSQLSM
+>gnl|md5|13a72c19ee112a285664201efbe33434
+MTRKENINPFIKALNKYPNSVVISLCKIPIVNYSGNLLGRATWNVINILSKFKRVSFLKE
+VLGVYHIKIFMADDNIIITSANLNSEYLLNKQDRYIMITGAKEICDYFEQSLDLISEYSH
+RALSEGEIQKPKKLHFNELKKDLMELSSDTDFHDKIASTIKKKLNNEDTSDDCVLASYFQ
+CSPINIKSEEQIITNISQLCDKKNTDIFLIAPYLNLPKYLISLLKNRERSVNIVSGVPIT
+KCDKMIKKHNKPSLERIRTLVLPKLYTYINYSLINQLRTQGNGIINYFEYKKPNWSFHFK
+GIYFFRNISKSNPCGSNVQNQGQIMATTFGSSNYNYRSTNKDFECSFVLIPNQNKILEKS
+LNNELTNIMNTSVKQCAPKITWRRLLILKVVKIFQEYL
+>gnl|md5|471a8a43f321dfb80b40f4edaf470051
+MEIIDQNWATFGFYFLSVVICTLSTIVFFLWKSDGEVNTKKDIFETINSPSLSEENVIRY
+SRQIALKEVGVSGQVKLKNAKVLVIGAGGLGSPILLYLTGAGIGVIGVVDHDTVSTSNLH
+RQIIHSTDKNHMSKSISAKQSCNSLNPNTRIITYQEALSIDLVKEIFPLYDVIVDATDNC
+RSRYLINDAAVYYKKPVVSGAALKWQGHVTVYNYSNGPCYRCIAPREDNGKVDGTPGGAE
+IFGVLGMMVGVIGCLQSTEVIKVILNDFGKGDNSGIDSPNQLPVLSGKMLFYNSLSNEHM
+GTDLLELEIKITNV
+>gnl|md5|8e8f328dbd59b6bf3d7e046a78ccc83c
+MFFENFDKLHTANNLTKFIYLFGQIPSEIINSELYQVSINSNIELPFLNTFSPRIVKNSP
+RYINSIRLTEIFSIVIKNISKSQKTNIKTVLLFLIDFVKRLYNQHIGELRGKLVNQDHNT
+NDQADFYYSYIVLFKYLNHCLEKYNNYIDEHITMSLKSIGKPESIIPKNVIFAF
+>gnl|md5|afa41de0fbd3d043adf3da2bb4646d00
+MIDLLYDLRKYAVAKHPEFSAAISNAEKGVAQVGVDQGVNEQNGNSKNDEEMSSYYSEIR
+SIGVSLGYINKMIDGIRINKQRALLTTSSSKDEEISENLAKILDETHEKTLELKNNIEYL
+RIQNENLKKKASKKEATEIMIRENLLQTISKRFRETIYEFQSVQSEYKTEMRNKIFRQIK
+IVYPDATQSAIESIAEEEGKITTTQLIKMKLSGSHETIGNAITELQDRYRDIRKLEKSVE
+ELQQLFIELASLINEQGEMLDHIEFSVSTAKDYTEKADIELISARKYQKKTQKKMLWIIL
+CIFILILVVLLPMIIGFTINSS
+>gnl|md5|f29ff1f11ec8bba273e6d7ae496ae15c
+MSSEAVDVKSPRLFACGYPGCHASFKRRSHLERHAQTHTGIKLFKCHECSKAFGRSDHLR
+RHMMLVHSSIEEKASYPCSSCNSVFMSPTSLRRHIKRSHDTPYICEVCGNLFPSATSLQR
+HTLRQHLTAEIPFPNRTEDSNSKQCWYVCRADPMLCSAAFLSYPGLVRHIKSKHWSSSNE
+PQPLILNQNQCIINNDNSQNQCLYALPNEANVGHNENDPLLNNTIGENKDSDIDCSYRCP
+YPDCGRFYSSKSNVRKHIQVSHCNSKPYECHLCPKKYGYRTPYIRHMKNSHPEFQDENII
+NDHCSGITTMDESHSDLTIPGTPHYPPLYVDAIPF
+>gnl|md5|95e1a89ddbd8c34d714e450df0c47a17
+MSFQIVPDQLEEVEEDVNTAIAVAVSTSRNALMEIGINEEEEETPMSQNANIESQLQTQQ
+SYNSETSFPDEVQSFLINLNDSISRRDVDRIRYFNENLHNNLTFKYYMKSRWPNPSVVEN
+LIDSFNNYSELTKLLYIEQYYRHIFAKFPNHVKWIDRVSSWKNYIALFNHLLFRGHSSTE
+SQSSQIPNSLKEYFESNNLSTNFDREDEICLPPEMTHGIIDEFLYQFQDTCRYRTRVAHV
+ISMSEQGQNDGRAAKVDQDVWRCDIIFQIFQSFVDLSEVRMLMSADSSASQQEHLQVLNS
+VESFPIRYQLGYFSILGLLRLHALLGSYYIAIEVSNGIDHQIFRPLLWKVQTAYVSYLYY
+LGFSYMMLQRYIDAIRIFQQSTVSFASNAMNSNNSSHSSPYQHDAIGKFIDRMSWLMLFC
+QLLSYGNSSNFNRMEESLSHQNDRKSSPSFSPLGSDISNWKEMLSKVSPRFISPSVPLIT
+PRDHIVKADQNEPQQRQMQTFSPLMHLYELNSMIRSFTKLYNNLNVDTLASLMHIAKKNG
+NLKSREVIKSRNSGSDSQANEISSTHSTTTDDFEVQEPSSIARSQIIAIKSRSGRQKIWK
+SGDLHSGELVQLNGDVDLLLDLDTIHIIEGKQVDKFFGDIFAKQILKARNLLRHIDSLTS
+KNLDSSSKKEKA
+>gnl|md5|1992468863cf0ec89d56309db0d8e036
+MAGNSEYSRDDDTGLTIIQSLCMNCHKEGETKLLLTSIPQFRDVILMSFECPHCGFKNNE
+IQSGGVLQDKGECIELVVTNVSDLDRQIVKSEFATISILEQELDIPPSTQKGVISTIEGI
+ITKTIQGLSLNQEARIAQDQEVGGKIEKIINNLKGYLEGKGLPFTIKLDDPSGNSFIQNP
+IAPLVDHNMKRKLYDRTKEQLEEMGYYGVQNLKDDESQRISTYQPKKDNSNVTFSKGADI
+PEHLIPHYIDLNKSIEDQGELGSNEDRIKFDVPCPNCGNNGESDVCEIDIPGFRRCLIMA
+FVCNFCGIKTNELKPSGAYGELAKKW
+>gnl|md5|73b14fb2e8802262aa459e35ca29bf95
+MESSQKNGKFVYIYQNQFNYHFYYFRILTVESELDLNRDILKSDTASIEIPEIELEMGMG
+SLGSLFTTVEGMIVKITDSLKDCFTFQGDSATSEQKKGFQRVIEKLENLLEKKEKFTLII
+DDAADHSFIGKRIVNGQFVQDDQQLKTEKYQRTDYQNETLGINDIKVENYSESEN
+>gnl|md5|6208a7e66cb2f5d3b31190bdbbb65ad6
+MVDSTIMDVNTKKRKRKKISQDSQANELTFFENECKKNVESNMKSSFTGNELVIIKGEIS
+SWLNLVSNSSLFPSGIENIMNSMGNKELFRGIIVARRITNLPIRYTNVPGSIIPNLCKNS
+LYSVSERFPCTPLNSEFEKENFERISFDIEKSKENDCELEEALFGVLDNPKNIKEGSEFL
+INKKRKKETKVNVDFLKKNLSIFPGNIGREYLVFQKYDDGIILDGDAVMDATPEILSQHI
+ARRLRGCTVLDACGGVGSNTIAFSQHCKRVISVEISNSRTLICKHNSQIYKLYGDQSWNN
+TESNIRDTNSIDAIRDSGSPTLHFNIAHSIDDSYNLSMYFDPKSNIVFVNGDILDFCDWY
+QNNSHNKYDFKSSSITKQAFNNFENFEWAFASPPWGGYSYNGFKHFNLENNSSLNYKEMI
+IRLSSVANNIALFLPRNTNIPEFSALLSILGFYAIEIEAIRDTRFNYILGIVLYSVRTRS
+KFKLQYLFGQNIDSISHPISKRLISFTEHILRKSKLDGGESVNEQNISKLGIKKISKFGK
+KIERLIKKKGLEPMMAITYLLNYILHRDDYCTNLYLSNCSNNIFPVAGNNQDITQTEGLK
+MKRKYKKYIRKIIKELEHGN
+>gnl|md5|a7daac1c5305bc0940165f653f39ad5f
+MDMDSTMGESQSDSIIRIYVKKRSGKHLAVLNIDKDATVSDLKLQFYEEFHYYPERQWFN
+VGSSNGEVLKEGKLEDYGVENGTTLYFKDLGVQISWRLVFFIEYLGPIIIFPIFYFFPTL
+IYGEPAPPKSISQKLTFALALCHYIKREIETCFVHRFSNATMPIIRLPINCFHYWFIFGA
+SVGYYTFHPKFSPPEFSPLTLYFIAILTCVFESLNFNSHLVLRKLRDRGTKKRGIPYGSG
+FDLVSCANYFWETLSWICFSFIANCATCWLYTLIAFIQMSQWALKKHRNYHKEFANYPKH
+RKAIVPFFL
+>gnl|md5|cf02df122b4ff7f6a76358dac85a0f0e
+MTKTSNVLISKKLTWLLRHGDPAKTGLNMRNDGYVEVNEILEQTGISLEKLHYIVENDPK
+GRFRMIDENGKNLIRANQGHSLSFIEDEKLLARFEIDNNSEFIQRIIIHGTYLDKWKNIK
+INGLSRMSRSHIHFVSATNFKLESIKQGSKISEDMCINQIVREMCNYKCTAGIRPNCEVL
+VFIDVVNCVTNSAEYKFHLSDNGVVLTRGNSQGIIDSTMFLLCIDIKNGEILLNNINNEH
+KITEIVRFIVNSAR
+>gnl|md5|92568a53615fbbb5b439325c5c5bbbd4
+MPFRRSLSSLMIPGNYFDFNTLADAKLNYIIGLINLVIKYISVIRNVFCNTFYLPVFLST
+DSILLDIERSIEESILNITEITITDIGEKSNLDIIEYSTFGNPDCLYPILNICKNNRYLS
+PEIAISYFIECFLRKNRENSAMKIEKIQNIYDCFDPNILKNALNERILNKWQPLIFSGDI
+IFQDKNNNVYNALNNQDKITDLIIQKEVNLIVKIGMPSIVFSLGLLISNIFGGKDLFVSC
+DNDILHSVDCLCEWNSCGDFVPFIGRVKEGNVMNSLSGRRNQSVEDIMPELNPKSGSHPH
+TLQLNNKIQKLLWGCLNFTPCQRLTLAQVEYELRRINDDLAFIYQQRINKFDTKSTRSVR
+WFNKLKANLKKNDKSRSSENNININL
+>gnl|md5|80cd3351a0bf174f65ed0e35466a4616
+MIPFVQKRFDTDHLNKTIVMLMQIMPKSTKISAENTQSITTLELNRTCFAKVTISKPGPE
+DSDINSDEKYSDIKSIEIVTLTEQTKAIVSCLTGIILQSFEFPLKSNENVKLSGILEIVC
+PTFELLLRKCIIEWEKQIDYIINNKFANEQMVLILSEMNTLLHLIVPIYLKYLRHKNING
+NSKNIHKSTFQFLQKTLSNILSVFSDFFLSLSQIFITESNSENFSKDDLKSPARNKINQE
+RKDIIYSIGSSLISSLSIISDVSTYNWTNVSRRRYLPSPHFKICGWISSSQFKFVDLWKR
+IFISERCIIVKELSQIVTLISERSSALNSKDIITRSLKFSSEDNDEYNAFLEDIDDELYN
+DSLENVSLSLNNVD
+>gnl|md5|8f60923dd7db2f0295ada560ba14a51b
+MDLSIRNENSLGNFTSEELTCYETWYKIIQHFSDKYPSSLEPINHHDIPKFGMITARFLK
+TSGIPKDVLHDIWQIVDTENKGILGFSDFGNACRLVSFFQHEKIFPNQHMLSKIPLKLAY
+FNISKFWEEAEKAVKVDEQDINSIINSYFSDTSHISDCLKRFKDLDEKKSGFLDGIAIFN
+KYISSNLVRKELKQIWDFSDLDEDGKLSAAEFIIFNTLVKVSIERNISINSGVSKQSMLI
+VINKIIEMESEYKGTDYRNIPKLRENNLIQFTPVEEKEVEKLKSEIEMLNGEIDDFKQAK
+NILTRYKESDDQQILKLSEKKLMLMSEHKDLIQNLNEKHSEIVKNRDLINYLYQDIKFLK
+ETNNLLSNFDLPKAINVRNGKLGPDTSINKNIPKINTNIGDVVLEKCQNRRYKDWVEFPS
+RGHHV
+>gnl|md5|88ded42a2ff1e812b648c539d7939a34
+MEDEKSVANSDGIMFDASMSAANDGYSQLDGSSIGQSIRTIGSAGKLSRTDLGDTARIRG
+ERYASSCNASSLNESEIVKKHLNSVEIGGEVEFKELFSTFLKSYIAKDGDSIAEYSTSKG
+NNSMIDGGTSTYMTLLKKLLEAQLTIEGGNDNKNGSHSSGYSFDISLRHIEDFNKGLYYT
+IVSAPSDAIVFMDEVIESEIESILGDDFLKEFALPKVRVFDNINICNMREVNPSDIEQLV
+SIRGIVIRCSDIIPEMQKAVFRCTSSYNANGLHTNCDHREYRLLIGGEIDEPTLCPVCNN
+NYSFELMHNLCQFSNKQILKIQELPDTIPPGETPHTILGYVYDEMVDCCRPGDRIEFNGI
+VKVSGVRQMAKRRQLMSVFRTYIDILHVNKNTCNMLYSVVGNSAGEMSEIDNGIQSIDGQ
+NVNSVEKNNLFTKEMIEQFHAMSKDPMLYDKLSRSIAPSIWENDDVKKGLLCQLFGGSRK
+NLLKAASEMVAGLDGQNCSFSDSLEHKQPNNSSLNRSEINILLCGDPSTAKSQLLQYIHK
+ITPRGYYISGKGSSAVGLTAYITKDPETKEIVLESGALVLSDRGICCIDEFDKMDDSSRS
+ILHEAMEQQTVSIAKAGIICSLNARVAILASANPISSRYDPKKSVVENINLPPSLMSRFD
+LIYLILDKQSEESDKRLAEHLCALYTSYSSKEKPANSAIFDKVTLSRYISYCRQNCNPKL
+STDACNKLVQNYISMRRQGSTGGSLQRPKTITATPRQLESLIRISESLARMELSEWVKKS
+HVDEATRLMMSATYSALVDPTTGLIDMEQLTIGFGGRERMIQAKINKILLEILSNSPDGI
+SKDGIFNKIMEQLKTGNSSEFNQFDYRKEFDACLDTLVISGSIKKISGQKYKLS
+>gnl|md5|7c057e854e05edcda89ee537cf423565
+MTKERSSSIIKLENFESAEALIENYRREFEIHRLHETLQSMLIEEDESITNILNAAYSDY
+SLISTDLLPLVDSYLPSIKQFQEKIDSNVNDVTSIVGRYSEEINSKINNHNLLFTKKLEQ
+NLFKMCYDEIKRYREILSITKSQFNKDETSNSFLSIRIIHYCILRLLKIRKSIDAIYQTI
+KKKHTKLDFEFENNKHYNDCFEICNNFSDELKTLVVQASNNILQTNYSKFLETEDFKQNN
+NILLQCIFLLNLKDEFISKVKNYIGTEIISNYNFYDNKDDKLLFSNVINDLENIIQGEKL
+ANFINKIVFSLFNYDDSEFLVFLIDIYIQGVLLFLLEHVESTYSEHIVSPTAPMDLFVHQ
+LNSIISLIEKNEKILINFESKRIPANKLKELKLKILICFRENYFINNYSKKWKFGTYWNL
+IYRNILNRRISIRNEVVEFSKVYVYDNKKYWLKYSIEIIRQIRWILGNSSIHSNTPLPPS
+RYLVPLFMRCLYSSLLLLYDYSSYLLSFTELNNFSEKNSQNNSIWSSKTKPEHICCVLMD
+AISFEEWVNIHFINEMFFHIDQVKSEFGLVELFELSEYENVLDIDQLKSIVKDELINQDY
+LAHINENLFKPLTNTISIYLKNQTIRIFETGLRAVPCLYRLTTTSISSKASDKIDNSERV
+PSSYIENATKPIEVFLIFSLNAIKSVIADLSSNTIQKLRETYYNILFNTFEGIFEEIFDI
+CEKQILSSKHQLASLQKLAQKNIGSAANRIDPNIIASQYMTDVDTWLTKMLKLISNFFEN
+LDQGSEKYVKEYINAIKEAPKYLKLYEILKN
+>gnl|md5|6dedf78737c88dbdf9581402af8ee7ba
+MRIFKDRFKHEYEVLLKKVLYNKFTLIIFGVFTITSIIINEARFLFRESTIDWIFFSIIL
+FLTIVRGIEILVFFAFKKNYHSIFFFDLVAYIFLILSAVLFDSSEHSTCDADILNFDDFQ
+VFSQVKGYGYNFQLNLINSTLQCARFILLFVCNDFFTLFSKLYNKKSIIHTENIYQQNQK
+KDLSKNNLDSDKHLSENKIALSQILGLRFAIVLVLSALLYPLLSSSVWIQINSSAFLSIK
+NLSQLSILRNQYPGDKSWPIAYMLELCNFVYTNSIGDSTKWMKLVAIQSPYTLNNNPTCE
+GCPKSNLEIMTDAMSIISNSEIPSWFVGILTLPTLKEGISLIPIEDYRKIRKQSLRQYVS
+QVCMRSGIDSISNFYSSCPEELKAKITMVFDTTTMLQLGAGLSIGISFVTLILLTTLMIL
+VHCVLEKHIFSSIKRINDTLISIASNPLLALKMSNNAYNELSNENATMGKFSNKMLEETF
+SKLGTLLAVGLGSAGANIIIHNLKDDKVVVKLPGKKVMGIYGFCDIRNFTDATEILGEDV
+MVFVNQVAEITHGVVCKYGGSANKNVGDAFLFVWKPDEKWEGMESLLADMSVMSFVIIIK
+QISSCPKLKRIAMRSEIQERMPNYRVKLGFGLHYGWAIEGAIGSEYKIDASYLSPNVNLS
+SRLESATKHYGVNILLSHNLFEKLSVSMKQFCRKIDCVTLKGSNQPLELYTIDIDPEAQD
+DETNSILHQVDTG
+>gnl|md5|a7df4b1b102ff4664724da77e1cd8973
+MSPQLKNLHDKKISIDFTFQDFFEPDTLIQADRHSSRSKEKLIEEFDNLFSVIPKNDKTS
+FVTGCRDFFIIDKKHSTQKSTSKKKGLNTSFSEIDNLISNEANGKRDDYNLSSNSNVESQ
+TRRNKTNRFGAGKRKKKKIRFNSGTKNSFQENSDLFQNDSPGPNNRILNYEDFSPPNSHK
+ETLASENSSSEQFSPLSEKKLPIIDGYGPFSPRKSKQPPHIMLIVHGIGSNESAINKNRE
+EFVHQLESVKAHWFWEVDIDITVDAVDWKSKLASVQDHMFDRITLPQHRENRMLLNKTIG
+DVMYFMVPRYGDYIIAEVAKQLNQKIKQYKSKISEKPKIVLIGHSLGSVIVYELVSRQQT
+RITKSEIPKLDFVVDHLFLWGSPLPAMLVMMFPEYLRSGLTLPKGLAPIQPNEGFSGGNF
+ILNKCPELKIYNVFHPYDPVAFRLEPLLYPNLVSLPDPVLLPYWRNLSKRTYHQWDKEME
+NARKALYESISGITSSISNAVLGGILGWGGVNEYKSTLEVNLVPRDQKIKQLRDESVISK
+FKTKFSASRKTGAFTGINFLNSSERQLKTHSNSDRRESESVNFSLLKTNEVPGIPIRVDY
+QLQEGTTEHYISSLAFLQSHFNYWKSRDLGFFILWKIIEDFEPVISYDDYRAALEHLKQD
+QTGLENLDSSSEISDDSSYEIESD
+>gnl|md5|cd79a1e415cc8b113d3cba8b2136e0a4
+MKSLPLINYSTIFMFLYSCFTVFNYATCELFIVNSKATNQTNDSWFNLDLLREFLMDENV
+TSSSADVFEGFKKMIKVSPPTPKTKSSSWIPQNIKDVISRINSNSKKEVKHKPILKRKFE
+DLKHYLEYHLYPENPQNNTKPEEKGRNMFSFGFAGKNLNEQNNKKSTIQSSESSSREQAL
+IEQKSEGTTQNPNNMKETSNQNTPSSPTPELPADQCEKNVINMFKDCIERCKSNLKQAQY
+KSGGISPLIVSELNTCIHTCRHSANSSNCKLSANSINLINQEIPVPKPTIRRNQKNQEKS
+RGLLSKYIIDPIVSFITTCLFCLLGIIVVLYYFKEYRFYPRMADYITYKIESYYTEDEKR
+RAIFEGDGFPQQPKVNWKRTIVYFVRLNYLPRVLANNFTWLIPMRDHYQQVTDPSNYVRV
+H
+>gnl|md5|efb1e23836ddf7a47aed527b6c45a134
+MLNIEQNADECAKREGANMVPVLHNVTEECNIKAEEKEIVPEIEEAKPKSNNCLGSDEYL
+EGHIYAAMCTKCAGELQQKLNPTEPYRDPKKVSGKEQISRGLIIESKSFVDANKNIKFSK
+KAEKNEYAGLCSSPEVTTPNGERETSTDSNIKNTESTKVSHGIFDRTCLIQEHALVNRNI
+NDFYELNLGNLGRGSYGSVVKAIDKQSGAQRAVKIILKPKLENINRLKREILIMKRLDHP
+NIIKLFEVFEDTNYLYFVMEICTGGELFDRIIKRGHFSERYAAVIMRQVFSAIAYCHSNE
+FMHRDLKPENLLFSDSSPNSLLKVIDWGFAAKCPKTHKFTSVVGTPYYVAPEVLYGSYSK
+LCDLWSAGVILYILLCGYPPFHGKDNVEILRKVKIGQYSLEHNSWKYVSDSAKDLIKRLL
+MTDPNKRISAQDALNHPWIKSQISSPNTADATYFTNDVCNSLLARFRDFQRQSKLKKLAL
+TCVAYHLNDADIGALQKLFSTLDRNGDGVLTINEIRSALHKIQNVSQLGDDIDNLLMELD
+TDGNGRIDYTEFIAASIDHKLYEQESLCKAAFKVFDLDMDGRISPQELSRVLNITFLQEA
+FEQSTIDSLLKEVDINQDGYIDFNEFMKMMMGDKQEQKLETKVQKIEDEGSGNKKLSKGG
+IISDIFGTNSIFKKLNN
+>gnl|md5|1c2059568ff34edee2760a9fddf910c3
+MDNESQNRNENSPLLREDNQKTPYGINRYILLIIYCVFCGLTTSAIQQSICIRFIMNKLG
+AYEWVCNGIPTEILPTGAKCKAQDNYITTCWTAGIMAPNIILSVLGGGKLFDNLGPKLTG
+FIGQVMFMLGLLIFCISNQNFPLYPLGFILIGLPQGPIFNSVVSVSNLFPNHGNKIISIL
+STMGDVSAFVFYFIYHFHEFSGIRIRNILIFYSIVVCGALAMVALLLIPKNSFEKFQGSD
+SIEEEDSNSELTFNTTCSTEMISLHNQSLINQLKSSFFILLLPYFTLTVFRSDSIKACLD
+SFLQSANNTDIDLIRSQMSIFSTLQCFSFIFSLMNGFIMDKIGVSKGMIFQNSLGIIVSF
+LFLFNASHIVRIVSFFIFFSYASCIYSTAYCYLVECFGFSNINFLMALTTAPVGFIYIVI
+PIMYSKLNPSNFFYFHLFYVISSFIMYVTPINLLMNNPNETQRANLSDGLSSVQVDEAKT
+FN
+>gnl|md5|fed2b6fcd40f46c5ebda1c269dd9f84f
+MKGVCLRSLKFRQILSRSIFQQLNVSFNGRCLFYGALFNLSNRIFFKSITYSSDPYKVLG
+VSRNASDEEIKLKFKELAKKYHPDLNPSEEAKNKMAKIVK
+>gnl|md5|77c7911bd491449b03616378484d47e8
+MKCSGTGYSNLMLCIKCNGSGHIIKEKNVLLRIPRGTKDGTQLKLSSEGNFVSGNYGDLF
+IKVNIKPNTKLKWIKDNIHVDIPISINTCIFGGEIVVPSLIKGTSMRVKVPPKTNPRVPY
+ILKGKGPPIFGKDTFGDYIIHFSTRNSHPDLFKNYKESIGIKDKLLSILSELNKKVSKKA
+SKE
+>gnl|md5|b8a0011c32fee47f4b50325db8e589b7
+MNQINNFPVAQQVYFSTHNALRAGENEIQKFVLYIDELDGTKRILLSIYPFYDCQMVKRL
+VIKYLDLPEGTSIRDIQLFYRGVEIPNSRFMHTFEKQRHPLHYSLRMNKSDFGIRSTGLK
+WSSKIQKLVVEVKLAMQRNVHPKLTLDGTGATYRMYNAKGQVVAMFKPLDEEAFSPNNPR
+GYQGKLGQQGFRSGVLSGEGASREVATAIWDAYYHNFAGVPDTTLLEACHQAFNYDSWNK
+ITLEWGDIFQKDNNKANSEITVDWKLGAFQEFISTTETVGNFNPSVFCIRDVHRIGILDI
+CLFNLDRNDSNILVVANQPNYSIKFNISNSNNPSPAISPYEHPLSTPDGKKTKYKLIPID
+HGLCLPDVLDVAQFDWVWFDWPHSKIPFSRSELRVIKYMDPDADAERLKRKLLIRSECLR
+SMRVSVRWLRLASSMHLNLYQIASFLCREDLEIPSSIELLIQRSLQHCYRAFDATALISS
+NRLGNIHIDLATTSSAPNRARVFNKSPKKGQNTNTVDNFIDDCELSDNSQISDSESEFSS
+DNSTIKSKWWESRKRKQKSSQSQKSDIHSCPNEQLTPSSFQKSCLNGASRSTAYRTQLLL
+GLAPQNATWMLLDRENNIIPIQWGDKHFEHVFFEVLEQEMKHLIIDKHPKWEEYPYFGEE
+VFDEGKNKDISAKEKDYC
+>gnl|md5|2a3ed910ef9ff53a894951b051a43092
+MSSEEGTDNWSAEEAVESVKTLSVSELQSRIRLLDGEIRLMKSESNRLKHELNQMNERIR
+SNTEKIKLNKQLPYLVANIVESLDFSDEQENEGEGMEFDGDKNDKCMVIKTSSRQTVFLP
+VIGLVPENELKPGDLVGVNKDSYLILDKLPPEYDSRVKAMEVDERPMEEYSDIGGLDKQI
+QELVEAIVLPMTHKERFEKIGIKPPKGVLMYGPPGTGKTLLARACAAQTKATFLKLAGPQ
+LVQMFIGDGAKMVRDAFEIAREKAPSIIFIDELDAIGMKRFDSEHSGDREVQRTMLELLN
+QLDGFSSDDRVKVIAATNRPDTLDPALLRSGRLDRKVELPHPNEEARSRILQIHSRKMNV
+DLNDVNFQELSRSTDDFNGAQLKAVCVEAGMTALRRGATILCHEDYVEGIAAVLAKKKSP
+LSYFS
+>gnl|md5|9d7109866edc06960af306fedbc9844c
+MFMIRGKLLSQSLPCFKFTRREFLPLFSVFFQKKAIRNLEYYNLNKRWKSYSKTSKNLSE
+GYISQIMGSVVDVKFEGKLPELLNALEVKGHQNKLVLEVAQHLSDNSVRAIAMDVTEGLS
+RGEKVIDTGSPICVPVGKATLGRMVNVMGNAIDGCGEIDAKVKKPIHRTAPEYMEQVMEP
+SLIVTGIKAIDLLTPFIKGGKIGLFGGAGVGKTVLIMELINNIAKKYGGYSVYTGVGERI
+REGYDLYNEMLANGVNKKSIVGSRVDSKHKRQPIYDFLGSKTALVYGQMNETPGARARVA
+LTGLTMAEYFRDSMMQDVLFFVDNIYRFTQAGSEVSALLGK
+>gnl|md5|a5fdc0df9e411a8a798eec9ff59a1cbc
+MSEVGIFPSIDPLESRSKVLDRNIIGEEHYKVSIEVLSILQKYKQLQSKISTQGSHALSE
+EERLIVSRARKVQKFLTQPFFMSEAFTGKPGVFVNLIDTIKGFNAIVSGEMDNLPETMFY
+MKGSLDSLGKPDSTY
+>gnl|md5|70b3e1e658af60aa9723921d3115508e
+MAQFGKKKIYYLFGCRLIIIMELIELPKRQWYHVSGSSLDIKIPSSHNASTSQAASILQC
+NREYVVHMFSDVPRVIMLDSGINSQEELNNGSKCSSKLSGLGMESFSLSKVSNNIVYIKG
+KELSIVNIQSDTINTLVRGNTHWKSVVFNHLDDRCFVAWNKCSVCLWNRSSYEYHILQEC
+SNSNKSNAPQHSAANLSCCVLINYPDDVKISSCQFIGELIILFTSNGYYDTFSSNLSPGE
+YYRSIMSRQIIDSNSLLLDTAVYPNIRIRDPTINHMNVTATLLSVEKDIYTVRIYNLPID
+SNNNFGEITLLQSINIHIMDDNKNNQFNAHIIGPNWGEYFAIQIFNQLIVCSVGEELPIK
+DLFFFPSRLLETAAFRPPKNVTWLDAGKTKSSENLSKQPIEVFVSNIFGGLESIIIPPVL
+DLSANKAHYSSENISIPSDTFTINLSNQKKTNIDTNDEIADDYYAVLMANASHKTEKSDF
+QYNNTPQNKLPSDRSNLLTSIFSTLNMEEKQSMSNPQSKNTNTSNTNHKDFGLNDKIFEM
+ITDELKKLTFSLSKELNDSVSSAISKYLEPIERDIQSIKSHLSGIEKSVDNYVNINEISK
+IETNVKELFTSTNEKLTSIDTCISRLVGESRSVREKVTKLNKQCDNISSNPIDNFTQVVA
+DSFGTLTSAVTQLQTTVNRLELQISNGIPLKALTPDNSIANKSAQNIALQIDDALKQKHY
+DRAFAIAISADQSTLSQSDKREIPSGECFVLSLAYKFDPCVWLDDPLPISHPVILGISKI
+LSDTLPHLIESLKTSGNFSQINCISDLKLRILWIKETIHCFEPFTDTLTPSDVMQILNEI
+SESMNKCISIINSVSDVSKSMNYIVPACFTDGSIISDITSILRHIRRTTRNITSGMK
+>gnl|md5|da1e6ca848a3625e49ca99dd56753a4d
+MNDKFLQKADRNDSLVEFVRYILSSRSSSFPKLSLPELDRDSELPPFLKVEKLMFERHER
+ENKKIKFLNKCLQIAPIYPEKCNKRVAFRYHNRQPEKCSYFNLSNKKSNLSLNQKANLNG
+NFSSGLICKSITPLRERICLACRKNSLLRHNNQKKNKYTEKNQNSILDYSKVAMHDNKMF
+AMNELFQKLLNTNSAILNSVFEEDKKVLEPFKRTNDSLKINNCISKNVINDNLADGQIKE
+MFQQMSISLNNSEINEESHSRHSMKKYLQLLNTDPISLKNKSLATILSIERLSI
+>gnl|md5|297d4655ec01c244c1b8d49f87676d59
+MSDSDSDTALSKRISKRSSKSCANIKNEELDSDFSDNIPLNSRIKKKAQRPKKTVANTKN
+TKKASKKPTKKAKSASKPPSKPRKRQSIKSENDSEDDDINKDIKKQFRDGQKYITPPNGD
+ATRAFYESLYNENPYSIIALKYCVENGILMGAKHTSAYKRLEHLRESGLLKRSLGGIQNE
+AIECLKRFDSKNGGFP
+>gnl|md5|ea45015c85b4c0f94db45f6ebdb0e4a0
+MKSLLFVCEDSNSINRDSSQRLKPGDRWFFGETEIIDKQNSALNIPLDNHNYRKFELDQI
+ITYDVDELSLIANNLAEQCFLNSSNNLVISTSYSFGNNCPLLLEGSYNGNNTLVGPGLFL
+LLSRNILSTIQDQDESNSISLYCSWTGVLNSGDFTDLFEDLNKENDSFDMENLSPISGEF
+GYTSIFKVESVNSLAAEINNKRKSSNWKEICHYIFTFRIYKDFNEIESGKNNQMGSISLI
+SLGEGIKTRISGQISPWNALEMAMKEFKDPIKSDFCMLQFSRFISHYFEFPDLITIIYRF
+PFYINPMKLSHGKEIKFILSMMLFHQTFLNFISIENNVDSIQKDNYILAPKSILSNSSNI
+DNQNSKYLQDFGYDSPIQIDSYKSSFFFNNELNDAPIPPPNPVSKNEFNLKFQEDSSKYN
+IFLENGFISETSKIEEIYLEGNNGDLEGNISNLPTKKNLKCEYDTLIREIKMLENTILDK
+NEIIIRLEKLIDARDQIIKQNQETIMLLRQDLNTETTKVKELEHKIKMNKGDNFSNHLHN
+KKLPLHLQRARPSTVNNNLVSKNVGCCNDTEIHMVKTQNKDENNVLQYTQDEAVLSPVLT
+GVAKMALEKFLRN
+>gnl|md5|56f2949c4871440b7cfb14d78ac32927
+MSKDEQKKIDSSYDKVIKKPIKLLKYKNSNSKLGIKNNEKNLVQTNKLANNLEYEKNFPE
+SLVNHSALNDDATLLVPNPIVGIDETTGYTKAELSHKEAQRKRVHKQIEFRASLTHRQRV
+SKFNEKLSMLPEHFDIPKVGPG
+>gnl|md5|ad3bf348ad07b6197f54cc3714fd785f
+MDKGEPYGCRSKSVIKPEFKNFLYKPSVQKVNAIGNNVYICNFHGWKGGRNSQKCPECVE
+IEKKIMERLSHTKFKNVAGIDYIEGTNTLEGMRIWLRCNMGHKLIYAMKDISRGCRVCSS
+EKYLSPKYRNNAIKLDIKKEEEYRRKQGELIAEAKQIFEMKSNTNSGNQNIDLEVQECID
+NHPNISYETAYALTYILKFGYEPYKLFQVPNIITSENKVSILKRINTYFRTQARLIHPDK
+SDHPRSADAFHILSNAYNQIKNYLENKV
+>gnl|md5|43cd4f904520a1c4af69ef5ac50b95ca
+MILKKVSYYFIGIMILLLISNSDVNCWKFKSVFKRKNKKSKQIRVLEDQAKKQFDRQIPN
+CEDYGFHGCDPTTPDACSECYSRCGRQCEDFLWLSLEAVNFRMLPRAESQKECKLPSGKK
+SSRILCFTTAGRRHIDPTEQMIETMSISNPEDIEESPAQVNEVENMVPENLPGINAVPMT
+QKMQEESKTSLYDTSAVTFRTSGEKGTLVSSIELERSGGKLPTNFENESNAKIITVCGAI
+LFVSIGALFVVIIYKKRQKRAEDY
+>gnl|md5|517672ccf3a522e47fdd0bb668bd313e
+MHNSNVFYLVNGENHDLINCYYCESCNKLISQEDVKIEVDTYFCPSCLENVPSSEAFSRN
+FRCINCHDCPKCMATISTNKLDLGSETDESNGRIMQHSYNCGFCHFSLNVNLEMDAGNEI
+DEKTLKESNDGNNKLHIHKQNDSLFLQESNYLSLIIDKVKNSAYKHFDTNISSETKQLNN
+PNDEQSELNLSLRILEEKQKTSASLIREKNIWLNSDKMKYLSNIRELLPTCLKKNDLSYR
+QYLNNPDIINSVYLSLRANSNNKTKLCPYMKKLSVQISKRCMACKRLVIKPQLNPLSQPP
+FRVNLSANLFFPNFRIVSIKDNSSGDRSFTKIIKIRTENLMDRQVRIDFLPERDQNEQLS
+IENSKVYSILKIEPKSFTIEPKWDPLLEQQSQQSNSFAHERRSRNRKYLDVFICESENIR
+DKIELELTAFTNFQSPTGNESTVQIKLIGKANIQDENYTTN
+>gnl|md5|a87a38933eaf67300413e8758f708ad1
+MSLYDRAITVFSPDGHLLQVEYAMEAVRKGYGAIGVRGAECVVLAVERKAVAKLQDPRSA
+KKLLLVDDNTCLAFAGLHADARVLVNKIRLECQNFRLNIEDAPPVDYIARFTAQQQQKYT
+HRGGVRPFGVSTLIAGVHNDGSPGLYQTDPSGIALEWKAQAVGQNSKTVQEFLEKNYKHD
+MAKEETINLAISALLEVVESGSRNMEIVVVDKKGCNFLSDEETDMLVSAIESKIAAENEN
+KTRQ
+>gnl|md5|8b1be4bf8e6db3fdf00d3555e616d61d
+MEVEANSNNYYLSVMRRSSRRTSFPTLQGLYVSLFEGEITNDGLDFSISNKNAGKEFNPK
+LIKITFLLSILISTILCLDHGFVACNLENIEKSFGVGYAQSSFIGSMVYMGFLIGCLLTG
+LFLPVLKSKVLLIGSLVCVAISGIYSSKSLTLAEIYASRFFIGFFQAFSIVYLPLWVERF
+SPQSNTTTWLAYQQLFSMIGVFFGYLLGGVLTCFTAEDINIYYMSLSEKISSLFVSWRGP
+FIIQSALIIPIIIVLIFIPGEILDVGDQERLSEVEYSKTTGLLVSGVDLRRSTNDNLLPD
+ESNSNKRNSKLRRSSILIIPSQSIGPNSSKSFEVREICTNPIFMFSTFAVCGVYCFTTCT
+LFWLNQYFVEVIKVDRITSVFSVACIYLSGPTLGVYIGGITGDLINDRHPNGFGFILTLC
+TLLSFIGFIISMAVVRTCSYISFFWGMIIILFFLTSTLPMSIIVIMKSVSSKTRQLASAI
+AQFCFNLVGFLLSPVIIGIIMDVIEYFPFGALKRRYNPIEVGVKIMLYISLPTFFFYSLA
+TFCSYFNCLISPKLTQKKIIIANQSDIPKQLFIK
+>gnl|md5|664182f43eca152d918e704cb4a56b9c
+MNLFENVKKVLGEELFFKIQLSKILVVGAGGIGCELVKDLILSGFCNITIIDMDGIDISN
+LNRQFFFRRKHVGMNKSTVVALEAKKLFNKCNSDNHKVSNIVGIVGNIMDYNTEFFNQFD
+VVLNALDNISARSYVNKICIASNIELIDSGSAGYNGQVHPIIPRVSRCYECYPPPTQKTF
+PVCTIRSVPDKPQHSIAWSKYLFDIVFGVRHDEKEESDNILSDISKKVQIDLDNLKQLEK
+NEASEFIENYIVNMFNFLFYSEITLLANNQEMYISNDKKIPIPISWDDIQRKNYIDRVIN
+SEDDLENSEQKVFSIKENAELFFNSVRKIIINRMNEIGTASLCFDKDNKDAMDFVSAASN
+LRSYNFHIPLQSRWSCQSIAGSIVPAVASTNAIVSGVQIAQLLLMLKSKLSSLTNPEAGN
+SDCSSNNKLLFVNKFVWIRSIPMGRFIICPESLEKCNPKCLICSQVLVKIKIVSFDKWNL
+MEFVKGIICQHLKLSEPSVELNGKCIWDPDLLEDDHFIKYSSQRPLINWKFSDGCIVSIT
+DFSCGEFQCDAIINICDKNIIKSEKNFQTYEKNGEPFTITIESSKTSLNDSCRDYLSSES
+SDDEILSEFQGNLDNSSIRKRSFNASENVENTPKKRR
+>gnl|md5|0e334594b61347c2e9522c3a73bcffdc
+MKKNPENIEYYTDHINKKITNSISNSIRLLLKKFDVELDDPNILDTATEAYINYIELLGK
+ISSSIAIAAGRTQVNIVDIKKSIKSLDIKRYEQVFLDSELESTINKKNNFGTNFLKRTIP
+DICTNGNSLWKDVLNDTNNANKKSLDPELFEYVDSIPKHIPDFLPIFPPRLDYCDKFISS
+QCSNGKDF
+>gnl|md5|78107baf0f75d136975ec64fae66f7cf
+MNLKPLYELNFLFMDKLNYENKLELKETKWKSNIDESDPAFRTVEFGSDPHVFNSETVEI
+FLTGVILTILGKASNDSEKLKLIEEVVESDFSSLSCSTGLIANLENSIKIDNIFCVTFTS
+SLFSLICLKLDGHIIDSQNIKLFCRRPNKYSNLNNEKVLDTFIIPRISQYDNFKENEKCI
+LKNLPTDINEEKIRQHLENIGKLKSLTIIYDPITGIPKGVGSFEFEESSLCKKAIAILHG
+KPIESTKNGIWNIYLGSGTITNYKSNKGQFNQSNFSANSSIIQNSEYLHITEIPTSMTYN
+IFSNPVLGLMMKYSKQVGETPSQIIQLLNIFLPEELVDNEIYNSTLDSVRSEAEVYGTIL
+EIFCPRPKVIEEFHSCSGAGKVFIYFSDITAARRAQYQFNGRVFDNIKTVSATFFPLEKY
+LKHEYSVISYYDEDQKLY
+>gnl|md5|30ed94424b3bcf55a877d9157fd30022
+MILFYTIDLILFITLDIVILQQALKMKSTYYSEMRFTSMSSISHRTRVCFILLCLLANIT
+RTISIIILDLTWPIVSEYRLLLKNETNIEEWSLDLLRTLPSLVYLSSYSVVVLFWAHVYY
+TSILISTPQMVSFFVAINTIIYGLYITGMVVSLFSNILSFASISMFLLAISYISISISML
+YYGIKVVSHLTRRAASGTILRYNVIQRVLFLTIFCPVLLFIRGIISGVQCIYSIIGFPTY
+FKIFDKTPIGDSVIFILTELFPSIVIVVSFWQKISPSTLTVSTRGLGFTSGVFSNIQNTN
+DNYNTHHSFHLIQNINALNNIDELVKKKDREIS
+>gnl|md5|772920d89ed07c2155d7b021bfff51ce
+MRLNKESLDRMVNIITLNRDKYKDLFTELIFNLLVNFDFEASQKILNSFSSVTESDFFLN
+PLQKYIEENARLLIFEIYCRIHKSIDLNVISNELSMTSIEAERWIVNLIRNVHLDGKLDY
+EHNRVEMIDRSNNPSQLVSDKTRNILFRSNLLIQNLSNNPSFNYNNSQKNKQNWRVQSNK
+QSNRSEKKEQM
+>gnl|md5|bc9ee862981b71035a6cde6cdba3579c
+MKQSINSEYGIDEFNRSLDIRLRGTIKKYFEDFHVHEIQKNGDVCCISSLRNKHEIIKEI
+QERKKILSGDNMLINSNATIIPELINNLENLGISQYCINNLLTFISILGEIKKLTNNSSL
+GNRMFKLDNRGNLKSIFELNIKLYGTNTNNISPGNNLLLNNMHEFKDNKDSVNAQKEKRK
+KIHTLIKEFVPFITSRTVENLKNNNILYQDKSFQYKDIFISNEIFSEISKFFKVDEIESE
+CLKSFNRQILCNDCNERQFDIIVLRPSNDYIYSLRNVRQNTFASIEECQGNLEANEITSD
+TEPACKKKRTECAESNLITEKKVDLLLGSNERWDPNIPDYIHFTIYKENRDTADAINMIS
+KCLKRNHKSFGIAGLKDRRGITVQRASAYRVLEDQLIYSTASKNWDRNIRISDFKYENEQ
+INIGDLNGNLFHVIIRDLEILDTNIQKESGNEKLTLKMVDKLIGDIKSSGFINYFGLQRF
+GTSEIPTYKIGISLLKNEWKKAFYLILGFDEEKMISYSAEKRKFYDQIINEDFEEYQKSL
+SNHSYLEKLLLNGFIKEKKKIQSNTKCKAKEDIYRESINLLPKNSYSLYIHSLQSLFFNI
+VASERIKKFGRNPVIGDLVIAPNLNKYSNKNEDSVFSEKNVIVLESQLELAKFTIQDVVL
+TLPGDNVAYPPIMKEKYEELMMEFMGISIQENCMGINGTYRKILVVPDYINYVGLNISEK
+RNDTNKFPDSKVILSDLDILTIHPELKQELGTKEPILSPEVMSYKCDDKDENSQVNTLVF
+SCMLPKSSYVTMALREFLGNSPSEK
+>gnl|md5|14ba27026d4ff56a8bfffd4931366e94
+MSNNVNESFREIQQPPPSYLVSKDLDSIVVEESMEIFDDRIYDSETQKNEDSSKEMLENV
+DFLDRVVDQFYGNERTSSIRKVNDEMDEGNPLLFSNNMTRNTEIMNINKRHKIMDNNDQK
+LGGSREFLDAIQAKTRKYITFEIGRGYKRCLLLQTGELLRLVHSYNKECLLQDTVPGALK
+LRDLRQVVSMGSSQRPSIEVRRNCILVNVPHFRAIILHQKVLLIASGYSRSPLDYPSSGI
+NYNYSSSNNNKSEKKEDFKEQNNCVNKNAFSLNDVQLEVPAPYLSSIDIPNSPSNYQCKN
+DVINEVNFDNSMTVQFDSSKVSSFPKTGIEYTPIEGLSDKQIYSKNCQFIPPGIEEGFPL
+LRKLEHISGIESSTPFEYLVLETILVESCNIINRQVRPIRDSVLFILDSFPGRNRETRRL
+LDAVSELRRRLNAIEELAQGLFKAITEMLGNEEDMQRLEISFYWNRPEAWEYPKNTPYHE
+EVENVLECYAQEVEMMLQQIESIGESLEDALEVLTLELSSLRNSIMKADLGLSIIATIVG
+FCGFFADCFGMNLRNGLEEVGPALFWFITWGLILLCAAGAIVVLTTFRKIDL
+>gnl|md5|95f0604f5f3e0b4532b5a3f2a5b3dcac
+MNTHFSLWPKIEAIIFCKFDEELGPIVLCSSPSDIFGSEKSQLYSIITKYLLPDIHFAGK
+TISFVIGNRWKAIGVPIFIEGSQYLRNSFQFTVCIIVEKKPYNFYQEIYSRHIARTLGSA
+FKLLEEDCGILYYYCTYTENLPDLLKKVTKNSNEISSFPKNILEVIENVRSQLNKRHQVF
+VEFGDASILNFRIRRPPSNIIIYPEDIPFPSENTLISDIKHIGLDFSLIKILPYINGINT
+SFEISRYCSLPIEDVIVCLEHLVLYGLISMIDMISSENKYRFIGGEDKHGLYRKLCNECI
+NEGNVLSFTKKYHKELRKHKIKSIYKFIAAGVVSKKITRLHEIPIIFADTKELSGIEKEL
+LQLCNGNSKLDHIQILLGFNTKSEIIKFISNVFDKSSIYWAYL
+>gnl|md5|4f1c0d793bada5cbdf77627e43c773ea
+MVSFVCGNCQDVLKKNKVDSHCVGKCRDAWEFTCIDCNFTFEGFDYKSHNSCITEKEKYC
+GKLANIKKPVHYPGNSFVDRKKEFQLIIEKILKKNGSMNWKKLVKESIKEYMNNGISDNI
+EDKILKWECLAAIPISYTTNESNMVSFKQSF
+>gnl|md5|24621b1b9cd65e89741b089e18075e04
+MHRRLFSGHQKISILKEKLSGLSKCGYTIVFALDNCEPIIIGASNISYFNSNTAGFSSRQ
+YALYTLVDIMHSSEINLVLILSTSMFDLPDFFEKRVKSRMSQRRILLEELQNTKKHNRVK
+SIINKAAKVLKIDKRLVSEIDQLSIDSYNDSIDSLFSYLADENKESREVIRSWEFLVDFE
+MEDEVLSNLLYKFLLVSPQCNIKEFMKIFSASNKKKLSKNRNEFRLLNQGIKVQECLKLK
+RFESLSIIQHTILVALIKLITLGVTNITFKKIINELHSLKNYISVQSNLSGLRLDHAEES
+YQLSFLMLVKMGIIEPVYNIKTNALYSTLSTTPVKFTQHKLYSDSIQQFNIPTILQYWLK
+NNILK
+>gnl|md5|f1a7efc1710b77523fcfca9cec9e9f5a
+MIIESSQIRTLIIYWVLVIFCLPIMFKLIVNLSSDSKKKKIFTRKIFHLFLIALFFPQIL
+SFNIMPTKESQGTIEFTVISIYLASCIFIYLEVMRKYRYRELTKLINKLLLPFLDNKDNI
+NDLIITHICLLVGISIPIFKEFLLRKDIQDFDIVSATLGIATVGVGDAFSAIFGILFGKM
+SLPGNKDKTLIGMIAFFISTYSYLQLTCFFSSSKYSLSKLYIISFFSSLLEAYSHYIDNA
+TIPMFSLTLYTNIR
+>gnl|md5|4b3d1267c1cca09e95f1d203437f7761
+MEVGVEGCLHIELEYDKSTYHLKDVVIGKVYFSIVRLKIKYMEIDIIRLETCGSGPTAIT
+ETEVLSKFEIMDGAPAKQETIPLRMYLCGCDLTPTYKNLQNKLSVRYFLNLIIVDEEDRR
+YFKRQEITLWRKKLG
+>gnl|md5|3ae27ed39c31f8d38427bd080990c31b
+MPNKYVFRCKKCGSTLFTTDHIIKHGKLNERNEEFNLKDENNLCTSYFISNTSWMEDYTE
+QNGRIICPNRSCDSKLGYYCWFGGKCSCGYWQTPSFQIHKSKVDYLPNSLRRNTIDIAII
+E
+>gnl|md5|19c0153d155189fb7be375565042844e
+MNLYNNPLLEVRIPRVVIITFVFIIWIRRTNQQVINACTIGNNPCTENAECYVETLFIGA
+PKCRCPNGFQGDGLIGGTGCQDIDECAMGIHTCEPKTQRCINTIGSYECECLSGFRKHEQ
+RLNVCVDIDECMELSVCPSSTLCINTEGSFKCECLDRELIFDQGRCRPINKCTDFNGRLN
+DCSQNCVLGSDGRGKCECNPGFKLHEDRKTCVDINECEENNPCDLSISSCINIPGSYICD
+CFKSAGYMTSPINNKICININECEEDPMICGDLNMCCKDLAPPDKYECVFPSINSEVINR
+IDVNNHLKEGMKNVEGEHKNLENNSKYIQNNKISRKWIETNKEYGNNADSIASNNNSGCY
+DSDIEYPGYTIQILHSLTSAFDCQLQCQVDLGCDFFTYDMMNRVCLFKAAKSEPKESPGM
+ISGPKYCNYKKISKNKLFPLDSASSQSSLLRRMSSNNNSNKPNQISDNKCPPGFNFAYDI
+WRKQKNKRTMEVIQKQFGTKQMNSINPVDISEGLQSNTNFMANQINQWYDVFSNVPTTFS
+NTTKQTNKSVPKLESSNINPGFIAGGIPPPPRGTNFPYNEHYKFNQYQDQNSQIPHKHGH
+NTPIYGMKSDNSIT
+>gnl|md5|f2d59767276544d8f085b05e5f00a33a
+MLSSLSDSELSEQLIQVYKSFLQGNDEYSSKIKQMAVENIESGRILIELGDLRNISDELP
+QKIINEPYLYVSPFEEVIKDLVDLEREIDKNSPLKSSQFNARVGFSGWFGRNHLTPRGLT
+ASNINKMVCVEGIISQCSIVKPKLVKSVHISKGHLIGQNDISGGANQAFVEVRGHRDISC
+LIKDRYIQSGVPSEDGQGNKMEVEIGLCRYKDTQKMTLQELPEMIPTGQLPRSIEIIAED
+DLVETIKPGDRVKIVGVYKPISRRENNALTGIFKVVIVANNIQLLNKNVTSPELTPQEIR
+IMKEISNRDDTFEILSRSFASSLCGHEYIKKGLLLGILGGAEHNLENGTHIRGDIHTLLI
+GEPSCGKSQLLRFVMSIAPLAISTTGRGCSGVGLTAAVTHDPDTKERRLEAGATVLADRG
+IVCIDEFDKMSFSDRVAIHEVMEQQRVTIAKAGIQASLNARCSIFAAANPVYGHFDDFME
+LSRQIAFPDSLLSRFDLIFIVKDSRNSQQDRKIAAQVLAQVRYNKNSSINDTRTNKANNN
+FVIQPEYKDSDLNEKNEVNDIWQPPSNKIADKRSQNNSKGSSGDKVLTTSFLRKYIHYCK
+YVRNTPKLTDEAAELVARIFTELRAKCMNQSKGGTTCTTRTLEGIIRLATAHSKLKMRDS
+VIPEDVLIAFELLSYAMFGEVIEKESLLNVVFEKDIENELQQEDNSRNKRREEKKYQRSN
+HPSKTPELNFLEENEHSIIAPPPSSIVTPSREKINRKESAARGHQVALAAANILREESNT
+DHGDCELADFKKKFITSCIAEQFSESGLEAMLEEELLKNIISKSKEKGNNFMITNRDIKE
+VLRILEEENRLMIAGDTIYSIV
+>gnl|md5|3546a7cfe77121320d9d96960af10100
+MSKCNGSGNNSFALKDNKFLYTNDNFGSNINACQESNKYVTSEEKPLLLLLDGINQKFHT
+DKAFSRKRSIESNEYESIINKGLKTKRIHEHEISSIKSSDKKDYSDVTPDTLLGCYANLT
+KLGVRIDDYFLIISKINSNKRSQDKSDNVVSGNGNPERENNNRPKLYWAKHIATGFPVVI
+KVVKKTRIMSSFPGSYSIWKKLCLKLLNLPYHPNVMKIYQVLEDEENFYLVMEGLEGGEL
+FQFLITEQAIPEETCKYIIRQILESVNHLHCLKMLHRDVKPENIMFRYKRREEKPYSPMS
+ASSFSTFEGTDDKLGQEIKSKEESIAHLSLKSSKEYFEVVLVDFDTCELMDSKPHVQMIR
+MKKRLVGTFGYLAPEVLNGGEYSAASDLWSIGIILYILMTGIPPLRIDLMCDYPKALEVL
+KVISDQGGFQFDAPPLPDFPLAQDLCIRLLQWDPKKRIQSCQQALKHPWLVDSFKYNPIG
+PIYKQILCNTDVKEMFKRKDISKHMKEIEDIEELDT
+>gnl|md5|416d16e071959545ecc101bfa64ca2fd
+MNINKNEMSLSPLNSLSAQLDSNTNKENHFDVKNQKPQCISDNTEANIKHEDFEKSNIKK
+KYKKNLIWDGPRWDLAHFDPTMSARERKKLVYYEALFNKLENDVVLRCNEHNNKNVKNPN
+QKRKMRNNTLDSSPKTELSDLKGMKEHKSDIDSGDSSKSDNYSKTNPEKFVNSHNSNQIG
+ILLTPDRNFSRSENIISPILEEPRKCSRSNSNSQTPANERESSSIRRSNDWRVKLLNKRC
+SLQATPYRGATP
+>gnl|md5|ebf832dffe8b9f4b9bd13a9d50cfd303
+MCIGFIDQIGKFPFKVTPFFFFKKNNLGIHNIFYGCKNYRFGGCGSVLDYRYLNRSSKII
+LTSGICENESIKILKEFYEIGNPKAPENKRKRPLKPLN
+>gnl|md5|c7f1f92c6004f78753152e049acfc0f8
+MEVSSIYGPNILNSKFANTDFHAGAKNAERISSKVIRPEQWHPWKSFGKLMDEAILEMGW
+QERYSILRDIVSKYGKRKNGYLTQSEFLNILNDNPITDEQYRTVFYNLMDRNQDGIVSEV
+EFTSGMLSLSPLAKNDPKTSIGQLRLQFIFLYYDTDRNGLLNLNELKRMIIHISSIRSLA
+KKTISMSESKAREYAIHLIAHYDGVFGFNAFYNSVKNNILKGTGWLLRTHLDLVDFINDN
+INAEYNSNNDINKHGSFISNFSSKNCLKSTFDQDSEQAQHMELAGLKLTSAFAEETNMNS
+RLNKLSFEAGKIQNDIKLNSKGILDLFPYNFQNQAFSSLEQRVIEYYMNILTNSENKSDF
+EEKMYINNILNCSEIMDLCDRAVQIIRGEDSLIKIKGNNSVRIFGGIHGQLIDLLYFFEQ
+FSWPHFHRGDILSMKYVFLGDYVDGGKFSLEVISILFSLKIMFPDKIFLLRGNHEDASVN
+LTYGFHFECKQKFGMNGETIWERINDAFEFFSISALIDDQVLCLHSGIGKSIKSVANLSG
+IPKPIHVKSEELINKSDCNNRLAESDRYVFECLWSEMIDQTSFDDSHNFINETDVEHTRD
+AEIFEKNMYCYDSYDVEDFMNTNSIKLIVKTNDYCKRGYGYNANGRVVSLNSATNFCNNF
+CNDAAVLVITRCFDNQLIQYNQIIKYQTIDNSFGWFDQINSGIKAKQL
+>gnl|md5|63b19ea1cebcd415ae7e38961eb90bc7
+MLKLFILFIYSFIYLIEAGSGTLGEAPKQIFNADLASLELLILTNSNEKNIKQKYSIFIS
+NLVSAGHEITVKTYNRYSQEQDLELFLYDEFLYNNIIILDIDNSDVHPSFPISYVPKILN
+FIDRGGNLMIFVDTIDDTNLNIGENKAIIRLAKECAGIEFLPQNTRLFDVTTDGVGKSSK
+IFSNNFIESDAIFSPENFTKKGILYHGVGFSNSIPSNELVIPILTACHTCISVNNDIKSK
+SISLFGNYISSSTGEEIGLIMALQGRNGARATFTSDGKLCSDETIKSNSENSKFCKDIFL
+WSFQQKGLIKIGEISHRKLNDSFETIVENYDEILNYTVEDIVRFSAKFYKFSNDKWENYN
+SEDIQLEFTMLDPYIRTYLKQSEEESRSSTFSSTFKIPEVWGVYKFVINHKRIGYNTISY
+ESITTVRNFRHDQNERFNISAMPYYSAFILTIISFCYFTLLFITKNSI
+>gnl|md5|f3f446c41561115b50ec67823a4d9a4c
+MSVRIITNYGDLKFELFCSQCPKACKNFLALSASGYYKNTIFHKNIKGFIIQGGDPTGTG
+KGGESIYGRYFDDEIYPELKYDRRGILSMASKGASKKPNTNGSQFFITYSSLPQLNGEYV
+IFGRLIDGFETLNALENCPSDKSHKPIDEIIIKDIVIHSNPIADQEILD
+>gnl|md5|981373adaac68393242ab5ffa86dd8b0
+MDQKELDEVAVNQKENEFDELLPYSKIAKILKLVTDKKFTKTSVKLIQSSTTKFIKEISE
+LSEKQSRIRSKKLDKDQTVIIQKEDVISAIQKGGKKFSFVNFSTEFLEDRFWNMEIS
+>gnl|md5|932fd3525ee48f3eab99164eb0e0f7aa
+MSESHEIFMEDISLLPGWILRNLSLMREIDKKSNDLQITLEEKRGKYLKELSKVANPESQ
+NIDKDVNIFKIDEINELQRELKALLKEKIAISDQSVHYIRYDGEILKKHYEQLRESFTEN
+FMNNNDSGSSNSYSGRTSLQGQINFKNPGSNNTINNIANNFNGNELNTCRNSISEAYNSN
+DNCNNESHNGDKNIESHNKPSFAHESISRASKRRRSSTATHIKDTFDQITKKPNAFVGTS
+SSQKSDQNNLSNDNQNQLCSICEGIELINNKFVKCEYCSNNMHITCSWSSNPFLCRKCCK
+KSSVQPSITYDIEYSASLINTPKSDNTKISKGSRKK
+>gnl|md5|371caa1482c20075cab1d93877d4adf0
+MSVVSYSRFLDSAIMGIFTICLSGLTLYLFGEFWGLCQSPPLSKWSIGKIMSTLFPFKRT
+FDVNLTHILLFSIIICLLSLRSDQGTNSSKCGQKQKRND
+>gnl|md5|086814d5d78394ae9d510e812d94e85b
+MNESSTHIQSKKIPQNRISDIQTIFHLFDKDKDGSISGSDLFETFKSIGLDIPPQQIDVL
+LNEIKGRASTGMQQDPAISSSIDCAMFSGFISRQLDSAPLSEQLRETFSLLDINGDGYIT
+PECLAEVCSKLGVSLTDQDARQLMVQSDGQAKADYNKFVKLMQLSKG
+>gnl|md5|78797bed383f6662012f30db090cb8e1
+MLKMDGTEKIIKKNNALLILFLMIFLIIEIGIGIYIKLEMSNARLNYNILLNSILENSRS
+LYLGLNDGILQLYSCEENIEQKIKTEMTKYLNAIPNIAYSFPFSFCLSNFDFRDITSNIY
+YDYLSIDIDFWITNSFSNFSGILKSIENCMNNSLSYALSQESAFLLEPIIVSKKQMWAIH
+QKMRNYSINMTNEEFKFGQNTLICNNSMIHDLEGSPRITGVLINGSEYQAPLFKIDTKSL
+DKDFINFAISGNDINSEETEISLDNIIENAGLVQSSKIKLNGINLIVHESEDNDFPKHLS
+EIKFLNQLFASPQEENIFVNISNPRILDVNDVINYSNGFKSAFNRTIYIPTSSLLSIVEV
+FSEGMKELERNIGNNLVGNIMLIRFFSIIIILISLVFTAIIFIPLILIESEKGKEIFSSY
+GFLIVERYKYFSRKYSRETNSSLGEFYSLFEKLFNVIHKVLEGKKKEKNEITKINETPTL
+TISKNIELNIVYKQLMGIFRFKLCYVWKFSILNSYCLPLINDQQNEFIVIDNINTNMNSI
+LFIFSKLIDGD
+>gnl|md5|2142eb0c8a1a03e5460766bda86ec259
+MAWIKRWITQKYWEDKFEEALNKHFNTKLPIKVKPFSNGSDLFNNFTIQWLNAIYQFDQL
+YSENAYEGKFFVEAFTRIRKNFHAWNDEYKKSKWDI
+>gnl|md5|ebfa713b8df652b45d40e0939cf79186
+MSSMLAKIFLKSRSEFIDIEYRNKSNMLSKLNCCASLKCAITLFNSPLPNVISTFNSLFS
+SECDFSWLSNSWMNYYMNWFVCFCKKSLTLVNNKHLENRNLALGNRSIKSFSQKSLSTRT
+IYVAQFDLNNVPITFSSCQDLYLQIYNVFSFSKPILLITISFLENYMVEYYRKMLEFCLS
+IFSFELREFDWSDEIQTNNMRVNQIRPLSILKNEFANILNEIKQCPLKSLEPFILDLTNE
+FLSLILIEIEDLRNFHISNSNPQIENWLAINIDKITSIYNTEIIPYILLSVSSIYSN
+>gnl|md5|2d08768631e4d0cf89b03d875e485a2e
+MFELEKLLASYSHPILRERIEYFGRFKLDILDSNHLNIESFNLLEQGNETIFDYDGFVYK
+LYLSSASNKEVNKKSNTSENKENDLKIVPLKDIRRESFKHLNLVIEVYNTHIRQLWNDAK
+QLIEHYKSITSNAIEIYESHSLDNCLIIYLPNNAISEVFSDLNNRNATKSAAFEMITSSI
+KSCLYCGSVLNTIRYISFYCSLDNKTILEDIGIQGFSLIYITLLSNKKIYAFYPDSQNKY
+KFAILAIEFLDKLIKSNILTNNFIQELSIAINQSEISIFKNMLDSNTISISYSSSLPKSA
+NEILYNQKSDSSSGEKSFMIFCIPISWLDSTDDYIKLYFAGLITLINNILLQMIPQCKST
+IRCGLRKFVLELTSQECEGC
+>gnl|md5|cf0e7ece99df21b14d86eedd2a62d339
+MGGSDFPIGPKLRIRLKAENSETEIGLKHKKRKKYVSFNNGGIEAASEDSKVSLLIECNP
+PSLRRVEFAEVLNIKLNQNIDNKEDTVDLMSDESVENEDTLDYLDNLEMEAKRIIEKNGL
+KNKFDAHISKQTVENKDFKNNTLNLSDNDLPNVGNVECDEEIKTSNVIQETRNQITTNNR
+VSSPIYSNLSQINNQSSLPPQPIQIAPNVVQQPLKTFANSLLLSKEKFSTRSFTPLDPNL
+NSRLLLKVQLPESINQLYSLEGITHEDIKQNPKTDESDETNETDKKIPIVIPTCSEWFDM
+DSVHPIELEMLSPIFNNEIIDLRIDEKQDYRAEMSGNGNSNFLEERVFSLNDEKINEYKL
+IRNKIIEIYRETPRQYLTVTECRRRIIYTGDVSFLLKLHAYLEFWGLINFQADIKTLPPK
+LRKLRDYRLNDIDVNHSNNKSTLNISRINDEAINNPFINSMLVNCVSCGKPCIYSYYILR
+AGVVCGVSVAVLDRCVWCIRCYSEGRYPPILNSGHFIKVDAPVVSSVTNPEEISRMGALG
+IASWTKEEVQKLIEGIEYYGDDWDAISYHLGNVKTPQECVAYFIQLPIEEPFMRNINPSK
+NTKPSFPFMDVSNPLMTQIALIASTINPVVAASAAKSALDRILEIEGYKEISKDASLMPD
+KDAHLRNEAAGSRNANANFNSKDSQYLPQYIPKVSSAKWPSSALLGEEGIQQVCSKALEN
+AALRAKELAEWERNEVKNIMPYLIDNTINRLELKLRQFRHLQSMIDEERNLLEVRLEKIK
+KEDNEIKSKLSSAKGQVMSKQTLRL
+>gnl|md5|ce405c907ae24a24b51ed4ba1f58e20e
+MSLISKKEPLSISSKFKFVQQNCRIFLLKDYNINRNTSVFSHDKMIFDWRNVGLIELIYF
+DSDEFIKCPICLDSDLLVPKISNCGHIYCWPCIIKLMNIILENDEYAKKFKCPICFSNVL
+LNELVSLRYQIVKKVQIGSEINLCLLYRNVSSPLIHFEFNMKNLDGKVLLEKNEKGAQFQ
+RIGLISDQNEILLHDLQMLRMRKLENERSGSDEEIGYIEECISIIENIFKLKGVTPRCER
+FSNDAFDMLLSHYGETELLEELEYRFINSSANYSNQCNMKDIFYFYQLFDGQLVYLEPFY
+VKVLQTEFGSIENLPKALLNVSVTSIKEFIINHQNIRKYKFLSHIPMGSKVYIVGINVLP
+YISTKTKEIFNAELEKRVNKRKTIKDMNYINLLYDEINHSSTGYEMINLNHANSCSNIEK
+SNQNSARATDLDFPTLEKYSNLKGKDKIGNAAFNKGNSQKFLHYKSNKDFYSPLRTFRNA
+I
+>gnl|md5|fdb4eb146ed2b01d4d112c7e5010aec7
+MMNTNGLRQNSLVQGKKENLSDILGSINGNKVCADCGAKTPRWASINLGILICIDCSGVH
+RHLGVHISKVKSISLDKWNSDWIKRCMKIGNYISNKYYEHKLPSGFQRPSWSSQQHSIVE
+QWIRDKYEFKLYTPDNMIPPSLQIDSMETTVPNEKTVLKNSEDFNKPQKCNNMVSSNLLE
+IELESKESSSKVEKNIDLKSNQLGSETANSSLKNKHNLENQAERALDRVSSFENSEVIKI
+KTVKEAIEKMYENSVESPPSLNNFNKVLNTSIGSIEKSTSSEKIRKIGFDLSDKLSKNEF
+KSEENKSHCIVENSKKPCPFSSIDAFSIIKESFSR
+>gnl|md5|a3f1043a60406f1e2bf8993983845851
+MRFFIATEPHIFSPLNPIQFKISRYFLEVMKAIILSGGYGSRLRPLTLTKPKSIVELCNI
+PIIEFQIAQFASIGITEIIVALNYKANELIPTLKIIEDRYAVKVHLSIEEKPLGTAGPIK
+LAQDFLKEDEPFFVCNSDIICNFPLREMLDLYHKKNSDSECNGVILIKQVSDPSKFGVVL
+HDENTLIVEKFIEKPKDFVGDFINAGIYILSKRILDLIKPNQQVSIEKDIFPIMASSNTL
+YCNKFFTNNENIWADIGNPKDFLLGSKLFMEFLKSNSITGHLCNDKHGSKTELLSKLLNE
+NKLELSFKTPELRIIGNVVIHPTSSIGEDCSIGPNVVIGKNCKIGDGVRLKDCVIFDNTN
+INSYSVISGSIIGCYCNIGKWTRVDGLSVFGDDVNIQDELFINSSTILPNKSVTTSINTP
+NTICL
+>gnl|md5|50ee6bb3acf634b94ac37bc407a1f6d2
+MILLYVLSFLFSTFVSFSCASSKVILDPLQHDVQILTAPNFESLLSKYRKNGVTSVFFYN
+GDDKVAVSELLGWYNDAARELKGMAKVAAINCKEFKQFCSKIGNSGKIIIYPVLPIPTFE
+FNGEKSVRNLKNQLLRYIPRDNVSVIGVPNQESSKVIKIEDFLTRHISVPKVLVFSEKEI
+PPTIIHSLANEFNKKLLFGFIPNCKKNDISIGITKKFQISSFPTIMVYKTASKAPEFYKG
+EIKFLPLFEFLNVYAETFVMGGGFSDNESQDSGSKPWLLQRIPELTGLSYNDVCGKHKNL
+CFIYLKNGEISLEEQSMLEELQDLFTPHIAGRGTNFKWMWMDISMEDEFMKLFNDDGNKI
+TLPSAVVLGTSKRLKFTVLPRNIEGELQSANKDTIKDFLDKVIGGDARFTNIKGQKLPKF
+IERVQNKNTKLEKSRDEL
+>gnl|md5|c9bb30845a44f3e4fb1b95592e6e64e7
+MNYFYLEEPNINLIYCTIVSNIKKSNLSVCKIEQIIPLETLKCPILMVLHIWKAYVYFNY
+QENNTELEKSKTFLLYSIVGYIFEEYITDERGLKNDCLERLLTFSIISILWILSANYCNL
+FKWVGIDQIIEKTEYFFKKIENSDYIFICKAIKNFIATN
+>gnl|md5|61d7eb3b8ab643410983084c9a378ddf
+MFKELGEAYEVLSDKEKRNIYNQYGSEGLQAGFGGPTSDQGGMGGGIFIDPNEIFARFFA
+SDRAGSFGDEEGSSFFFSGPSGMFRQVHMSSTHNGRSSTRHAPRSHEVPLLVTLEELYLG
+KRKKIKVTRKRFIEHKVRNEENIVEVEIKPGWKDGTKLTYSGEGDQESPGTSPGDLVLII
+QTKTHPRFTRDDCHLIMKVTIPLVRALTGFTCPVTTLDNRNLQIPIKEIVNPKTRKIVPN
+EGMPIKNQPGQKGDLILEFDICFPKSLTPEQKKLIKEALD
+>gnl|md5|42fb3ea0dcfa741ec0d504475c5819b8
+MEWDTCASHIIIRQTCGDIYKLETFFSGSETQFKLGEPLTYNKEVLINPYFVAANEKVIE
+TLRNRIISKSD
+>gnl|md5|6a060781321ea187ee3f71d2138467de
+MSLDEFNKLRYETNLDSKVVISAREVVEIGFLASKVIMEIYKNIDAELRINYKDKDNSPV
+TTADLNANEIICAKLSSKWPQIPIISEESETDTWENRQKYK
+>gnl|md5|019164eaac7471f452fab04a2c18f3c4
+MRKSIIRTKNQLERIYNERALLAQNASDFVVKLFYTFQDDKHLYQVMEYLPGGDLMSYLI
+KYDKFSEEDTRFYMAQLVHAVDLVHQLGFVHRDVKPDNIVLDSKGHLKLLDFGLCKFSPL
+IEGDKNSEYQTENHLRCVNLNTKSHKDSNKASEISFNENNENKRINKELYRGSNLLEEKN
+CQNEDLNISLKHLDRKTIHSTVGTPQYMAPEIFLRQGYTHLVDWWSVGILMYECLYGGVP
+FNDDTHNPIKVAIKVMQWEKLLLLPHPCRKISPEALDLLKNLLCHPSKRFDGEQIKKHPF
+FNGKFINFG
+>gnl|md5|6e78a3b5ceecb71bf6113da160b04b36
+MIEIDWDKLRQCPAPFNKQINENIYKGNVTAGELIDESPNNTRYGVQGSSLVDINFLDYT
+YRNKDRNNDPISIGEAIKMCR
+>gnl|md5|36ac0d6bea7149b15858414e20735c19
+MKLILIVLFLSISNTIVHGFPPFLREGKDIVSAGICRNLCKGGQVFTPFLPPKEPDCSSS
+ISCKKCDYNSIIKNDPSTVCSYTFSNEFVDSDFDTQLTLFHGKSQLIIPHNSTLSRLSKE
+SNVLNTNKGEKSHGLFTVAVQWKKMKGIDVSQCSNGIAEIEWSLFNIGVYRNWDIIAMIE
+TKPEATFPFCFENVEFPLDPTRSSKIGSKMPTNLKRLGYSIANGRPSAIRITKTIAVNQK
+EMKINPEKALEILLKKYVSFKIGINGASVKNIFSETFHESRKDLSKDDNRTEGGSDSNTN
+ELSHSDFNSSFSGNNSENSSKPPEKKNIKLEILKEKLLDKLRGRGFTDPLILDSMMSLGF
+YSCFRIICTKKKSGISKRKYRLQERIPLTLESARDIHSKALSQFSDLISPFYTVPLPIHN
+SEYWVNGDYKPHIIYNQSPLQNKNKISPTKVESKRKKSFKNNIEKGINSDFDSDFSSSDS
+DLLAIIALTNSETLQNGASVNEILETDSILDLERNN
+>gnl|md5|879a865b7555edba10a72b45ef922f29
+MTKTAEFYKNKGNELYKQKKFDEALVQYDLAIEIDPNDISFLTNKGAVYLEMGEYQKCLE
+VCMQALDKRFEVKADFTKVAKAYNRMASCYIKMNELQKAKEMYEKSLLEDNNRHTRTSLK
+ELERLIEKAEKEAYINPELAEKHRIEGNDLFKQKNYPAAKKEYDEAIKRNPSDSRLYSNR
+AACYMQLLEYPSALIDVQKALDLDPKFTKAWSRKGNIHYFLKEYHKALHAYQEGLKCDPD
+NKECNEGLKNTMAKIQQVSSSDQIDEEQVAHALADPEIQSLLSDPQFRLVLEQLKQNPAT
+LTQVIQDPTIANGIQKLMAAGILRMG
+>gnl|md5|9b123345086b37c8c4912f6cf920866a
+MHFESSDGKIKEQITFLLNNENTNFDSSKAELIKNLIFSWKIFSEHMDIENAEQFTNRFI
+SLIGEHVFSQYYTINGKIKRFYTHYENPFIVYLHVLYLKFSLGNFSGPISCTNLLNILFG
+DYNTEFSRILYRIHIFEIQNMLLLISSYYLNINWGYIYKLIPGISNFNCSNDAYYTRNIK
+NRGDDSAIGFIGSNLPRYNIHLSSFLVLRDCIYIVFSLIYYSKSRELDDFIIDNYCGLLK
+DMTYQKTLLLTGPKISNTNNGLTGSFKLKERSCITSAIPLLYVLIQFISNSNETETVVNE
+IMSRITNEHIIDSGQYLKDNKFCSGNNSRIGISSPQFVISLKPSYKFPDYNKCIDILLKG
+GEFLSVYPTPNFLNLLIKRIRGNYTFDVGIGDFSKKNMNESRLSALLEEFFPKVMLKLSK
+DLTHLIIEEISNETRTRARGLSTISVETYKGKGIRSIFKRRPKKKKIPIENIIATSIGYS
+SRPESIPLPSPGMNLPCFCCIQSELDGTSLFYRTLNIHTNKRCFKLLSVKIQDLCVKQWH
+AIIRQFMDLKFHQVQASNPISKNLIKITKSKKYNKIANCLLNSCKIIDKWYEEVLPKWGT
+HWNCNSIPVSIHNLSLSRNQNINKNRNESEYTKLYFGKYLKNISQTLQPDSFNFWFFGSH
+WLNQNTSMHIFVNRPRLTVLKSFQNLKGYSMENICPSENGNSVSNWINFLQYKLHSSYPL
+YTFPIIDRGVRFGAPNSQLLSDLWSVGIPNDIRNKIWKIVLGNDLKVSNELFDILNLQSK
+LNIDKNDDSSTNSVIFRYALEIQYIFYNKKKNSNIGKKLSPYIERKVEVLNSSASFYYPY
+FFSQKCGFAREFDYSTFKYEEADISLPLINTDEYFIDINNVYISRRMIKTDSLENELFIN
+RSNFEQIQSSDDINFIDSLNSESMLALDFSSLEALKLNKFIQYHEVSNTHSNSFFQENMD
+LLKKNDTGNPSSITIIKGLLDTIGALISHIPNIGFQPCLINYLSVFLMYMDPPSAFKCIL
+NLINSFDFLFISSDITSNSFEGIDKCSIGLLSEPSTGSLLLNSQYHQFLYNDNIWILFSH
+IFQSFVYSKLPQLYQHLLYTIGINFESVVTPWFRHIFMDTLSLPVVLIIWDNFLLLGLPL
+LFQAGLSLLKLCEPQLLKCENILDTLNLLLNNCDYNSFVIKADSFTNTLREMQKVCDVTE
+ITSITSQYKLIEQKRWILRNQQSVRNYLLSQGYYCTSTPNTPKGR
+>gnl|md5|4ebdf0fc344ff9e234b932cec9ffcec8
+MESSLEYIGCLSGHSDWVTSIAAPPDNSDIVVSASRDKSVLVWNLSDANKDQHSIGSAKT
+RLTGHNQAVNDVAVSSDGSYVVSGSCDKTLRLFDVNAGKSVRNFVGHTSDVFSVALSPDN
+RQIISGSRDHTIKVWNAMGVCMYTLLDGQHNDWVSCVRFSPSTSQPLFVSCGWDKIVKVW
+SHEFKPTCNLVGHSSVLYTVTIAPDGSLCASGGKDGVVMLWDVSEGKHLYSLDANHSINA
+LCFSPCNYWLCAATDKCIRIWELEHKLPVAEFAPPAPIKNGLPWCVSLTWSNDGKTLFAG
+STDSNIYVYKVKN
+>gnl|md5|0d3e92e37e2c6c092f83941c85cd46b4
+MEAVKGERGIVQIKGCFYSLTPGGIIMQNIVMPLMTKSLGVFIRENRALRKQNSSHRISP
+ELVKNLSFQIVNGLSALHSSGYTHRDFKPDNILLMDTDDSERKFPTINICDLGRL
+>gnl|md5|3a0a09d91375affc575a3862ee4af8a8
+MFDYSKRIEHLMTNFEQISRINDENKLVKNILIKEISGIEGNIEMLKLEFYRISSRLSDS
+LKEKDYLEYELNKLKNKYKSTNDELNEIRNNLSARNEEYNEFKKLNECMRKEVEDLELAI
+TLEENAISEKRKELKNLEMVSIGKETERRKLDKLASQTISELKRKIKVREIIEDKVSVPS
+SSIPVKIRHVNNKESKNSNYKDFKDQNKILINERGKLCSSLQNIKIKRIMAQHII
+>gnl|md5|242a490fa560105951bc00649f375b86
+MSDITVLVTGASGFIGSHLVEYLLSKGYYVLALDNFFSGDVINIGQCRDNPRLEIIRHDI
+IDSIKLEVKEIYHLACPASPIHYQKDPIYTLKTCFIGTMNILGLAKRTNSKVVFASTSEI
+YGDPLVHPQNESYYGNVNTVGTRSCYDEGKRIAETLCMEYYRSHGVDVRIARIFNTYGPK
+MLFNDGRVVSNFILSSLLNQELPIYGDGTQTRSFCYVTDMVYGLYKLMKLDREKILDNMP
+INLGNPNEISILELGEVIRELINPNLKISHRKFPMDDPKKRQPDISRAIGILNWKPTVDI
+KTGIKETIKDFKIRLENNKPVEVLHQKEAKPILNS
+>gnl|md5|21f3c6901a3feedc1a29ae6671936f28
+MGGCKSKVDKHIENREIPQAPELRVEKRPLVELQDKITYEGEWLGDNKHGYGIQKWPDGA
+VFEGNFVNGTANGYGVFIHTDGDKYEGEWQNDRAHGHGTYTHSDGSKYVGEWKNDKKHGK
+AIESWVDGSNFEGSYAYGLKQGFGKFSWHDGSKYIGNFDANQINGFGIYHWNDGRVYTGY
+WLKNHMFGYGKFDWTDHRCYEGQYINDKKDGDGKFTWPDGRAYIGQWKNGKQHGIGIFYN
+IKKEGKVGEWRDGSRLRWIKSSLENGELVGEGLSLREEYSKQREELLKANDLYENYRKLP
+KNDLELQQMRILQKFDEYLLTLSDSEKGLESNKQAASDILVDSNNIVTQLKNNDSALENK
+DQEMENADGGNEQLNTDSLQIEETKNEQENCGSENVVEYTADLSLVEESSDKEEKPISAP
+LIQEDTQINTELVDQVQVDSNKDRGMTGGNSALDLLNYSENKGEILENSGADSSNSKLDS
+LEVKPCNNEDIQISEQEIKGVSVENIGSELKANSLTEKELEDIAENKGLEDSK
+>gnl|md5|5835562ec8d06d8f948bda9949851bb1
+MSFHIKQKSLSFELWEYFYNDGDERLISSDCFQQSTENKYSRLVFALVSLLNGKDIKQNY
+LKDFHLEKSTTELYEICKYDTFSTKSSDDKCIFNLFSKLKQHVGDLNTCFVGINEFESLI
+NFSEINEKYIVYLIFWVVVKFFESIKIVESDREFNQIVTCYLNLAYNIDHLIWDLIVSDY
+ILSLRKKGIIDVNSITIELNDEVESLFFLLVSPYSICPTLCSLFLLLKSKVIRSRFKYIN
+ENSFIDSVINQIVKLIANTLKEISPDMAELSFTITVCRVISNISYDFNNELIQQLYILRD
+YQKCMIPGLKRINPVFVDRFILYSFISIEQFWIEISKDEGFFSSIISHIPPLELSTSVIS
+LMNPYKEFSKYIVILIVLFSLNNQLSNTGNASKHTIEIMKKLVENPKEPVEILLKYFLFP
+DYTRDSSAKSNLYIFFRLLSNNICNSSVSLGIVKSIYAWIKYTIFHYLKHFFTIIWNHSL
+N
+>gnl|md5|4546dbf2c5f2c471eab55e648a8bd0ae
+MLYFHEVIKHKNPIINHFQSVDFDIFCFIWNKYVNYSKTESQLTSRQISIFFSNIFCRNT
+NIAQQIVEQGFQYKSLNNCIDFNVYLERTRSFIDRICYITPQILCEHTILPKIANKLDKL
+LNTRSLIELWGKYNVTDSKVFCLDFKIENQIIQCVSLLSWLSNIIISPSKSAHYSSESSS
+NEKSAFLPVAERSVVRVLCITQDIINSQLDSRIYHNLIINFNILLKHSVHFIISVANSFP
+QLNKALKDTLSALKQFMSGHSLSNSSIHHTINTIDEIL
+>gnl|md5|d9cdc299f85ee3906eb05bda47e982c9
+MRKKKSSSHLNNENSIVENIERLPSLGKVPEHEGAILMSSEISKSMKRSSSQITDELAIS
+SLLSNAKFTLSVIKIGGNTKTKYEKNTHGFIVVHILSCKADSLIYSLDNKYEFVMSNGSY
+VHIPPNHFFSFKNLSNESAKISFVVLPKKIREVGNEPAFHHPIVD
+>gnl|md5|ca202d2e4597ff6ab953def31ebfdee4
+MFIETSAKNGYNIKSLFKKLASTLPNLDYIQEGKNEANSSSSLENNNANKIVDLQSGEEN
+GRFNYKKCSC
+>gnl|md5|41b1f3759ea642201967cbb104cda2b3
+MDRNGWSEYLKKQRLQDLKSLAKQLGIYIKSNTKKSDCIDIILNNSPDTPLSSNNLDFIL
+KEKISNDQHNFPSETSILSNISESTNLNIIKINEYFHTASDAICDSSCSMCQKNLSDIIV
+NCDACYRPFHSRCVGFDIKRAEFNNNHMMVFMESISKKDGKKFKANLINFICPFCRFFVI
+DPYNKIIKPLFFTTFYSYTAIHNIHPKYGNINFNNSSHLPHFTSKYSFSPNLFLNNGLES
+NDPDAFNIMVYCLRLDRMDLNHEFPRVLFIKANGKVIQNIESPSYDHIRRDCPLYLKDYL
+VNNQLMTKQNVNITFSTLNALLKDSENSELLPIPTAPYIIGLFLTKTISCDNILDTILSE
+GTLSIEISKAHFKNILENKIQSSIYNQLYDDSSDEIICLNKDQYLNTLCPLTMDTIELPG
+RGIFCHHINCFDIKAFIQINSTIKAFNTRWKCPLCYQIIRPSMLKLDSFVKMIIRSPTIP
+RENNKILINSEIFDRIKQNEDMPGEMFLKTSNSIKYEFPKANSLNSPINEHLTIIKEKSS
+QNSDLSLPNNIKDCFDVQNEVIDISDDDDENEMIDDHFIVNDDELNSLFSNSNYIDINNG
+NANYSEQSKETVLQNYSEDSILLDNKKKRKVSEGQFLSQSSGRLENTSNGDKTSISLRL
+>gnl|md5|c6ab40f4805565d552f95a0117e3234c
+MCDRVDRHVLRKYELVKKLGKGAYGIVWKSIDRRTGEVVAVKKIFDAFQNSTDAQRTFRE
+IMILTELSGHENIVNLLNVLRADNDRDVYLVFDYMETDLHAVIRANILEPVHKQYVVYQL
+IKVIKYLHSGGLLHRDMKPSNILLNAECHVKVADFGLSRSFVNIRRVTNNIPLSINENTE
+NFDDDQPILTDYVATRWYRAPEILLGSTKYTKGIDMWSLGCILGEILCGKPIFPGSSTMN
+QLERIIGVIDFPSNEDVESIQSPFAKTMIESLKEKVEIRQSNKRDIFSKWKNLLLKINPK
+ADCNEEALDLLDKLLQFNPNKRISANDALKHPFVSIFHNPNEEPNCDHIITIPINDNVKH
+SIDDYRNLVYSEISRRKRELISNKHQNVQNPNTAVSNPRVNRVSGAVEFATPESNPNNIT
+SNKSNEPIYSKFQSELQSNKRSSINKNPPADNSKKGGILGNFFSQVYNTFISGSATNKTT
+SFGNSQTISNYSNGKVDEKHIQQMRSATSYYSNSINNSNPIKKGGGFIGNNLSSTNDNTA
+KTANSSTKNSKYITTGAVIKNANSTFSVSTNCGGNSHVYYPRAYMYNNIKHNLPDYSLIP
+NSELSNSLSGKNTSNLKYSNNPELSNQFKLNCHGSNQTSIINLQMQQNRSNTSKITYYNE
+PNIEPNSKLNDMVGRKSTSSGVGVNTLHHPPPFYTSQQNKNVNKNYLYKY
+>gnl|md5|99b03b7fde814a0d5702b64777fb234b
+MIKNFSMYQVLEKSKRFLNNLIIDSSMLKIFCELSVHSSNKIINENIYILKLRSLSILEE
+VINLAFSVNINVIGCLKTKIINDIKPYLTKFCEFIISKFEIDANSKETAYMVSLLTIIKT
+TLLYDEKHELINYLNTEFWVWLLDVFIRRRENSHISVQCKTIFELGIRFGSYSTLENLFN
+KVKLVDKVSKFIYDGTDLDGNLIEEREFVNKKTGKRIRRVFGSIYNLFIVLEQIYNNFLK
+IIVPYNPYIYEVIKNVIFSQLNNYSKIDDEAMEMLGLLIKNEFEINYLSQDSEKIEFESP
+IDMDPQKISLLANLSCNTKFHELAKSYQSQNKTNYIQNSFSKAEDLSSKLTKNIENSTLT
+PNSIKKKTNSEDPSISNEINTSNNQSPSKILRSYFSGSIVDLFNCDENCECPKWSFCNVL
+NKLKIEKNCSTGIPNFPVLPLEESKKIRETRKRQIKLCSSAQKND
+>gnl|md5|294387118bd46160c9a0285e5d747084
+MFKGNVIDFNRYSILIDERLKIKSKERMRPNDLFSDPYYQKSDFEKNCIDTISENTSKNM
+LKNIWNLSQEKANTNPSETSSNCNKFYNYENYLGIKRSGCKNATFEKKSESKMEEFIKNT
+SARKQKLFREFSTGIVLGDEGDSREKMFSYVSNILSNQNNKEKDDNENFKLAYPFYSNIF
+NIENRTDKSELSKRFLLERRITNNSDIGDECAAMILSPGTLKYYSFDRETRTYNAIKDLS
+NNNISDEYNLDNVTPKFTPLQKNLSSKLHGSDFYNNAAIRSSETMFTVRFRLKNISSQIN
+EKIIKNTAANCGAFAYQIMFEFDPIKWCSKGIATGMLRYSGDSLNAFKRELIELFKIEVE
+ILNGIQESSE
+>gnl|md5|0b9b586a0ba11d820b7bc424f3a2097b
+MSICLRGIQNALETKLGELDTLKSHDWNLEIDAFLDEEEKGTAKEGGAIMSEHKWEIEIQ
+SLKNDICCLFDSFEKEVDLLNNDGMNTDRYSSLLQNLKHDYNNICKYIDSRRKRVNLFSK
+SNTPSGNKYQKLYIDKSTESFERSQFYREKNIIKDSVLNLNSMIDQALNTTQSLSGQNHT
+LKLIFDKTRTMRKKSISNIQSVVNSIINLKKRQNFVVSVLFILLVVIIIYIKK
+>gnl|md5|dd378cc024597a5fa3077e483936a80f
+MINSLFQLLFGILLMILDVPGSPRWSARGRTLIRKEARFLTHLTGKSLCLLFLSCLTSTT
+LWPQRRGAGVLALLAFLTSVAVAGVAIIGLLISLQKSVRLERVRKNIITTKTSTVADVYR
+RYAIADPVYGMQFEEFSRMAADYTNGRQQFGVTDLSIIYNALDENQKSGINEREFSEWVN
+GSTVYL
+>gnl|md5|6bf180ed3e04ca69e950b121822ab32d
+MYGNKDKEIGVFQEKIEHSGEIVDATLAEFNVKYQTLFFIATLVLSIAGFFSAIYSLFGL
+RITNFVNSCLQLIVGVLLLLLDIPGQPRWSAKFRSDIRRQARILSKLTGKSLSLLFLSCL
+CSTTLRANNRGPMIISMFSKTKSKSPGLFLLTFLVCLLTSSVAVLGLLISFEKGIRLNRI
+KKSVISSYTSVGACNTIEIYRSYALSDPLFGMLGDEFNRLISDRTDNNYQFSQDELSIIF
+NALDDNQKGSINEREFVEFFSSRFTLV
+>gnl|md5|8c3ae0659904d65e7f4bc78b6c0382e5
+MKLLGVNSFALRQFVEGYRGSYIPRMSPYEFLRNVNNYIIENNPTLVDGYADFCKHIFIP
+NFTEAKQSIVKITNENEKYIKTGYISRRDEEIPVLSRWFPKDSPPASQLIKSKYLDIILY
+SKEQCEKESSIMNCCLQDILDDKEKNPDWYIISIKAQNESFEVPMEPITILRNTLIEEGG
+SGVPLKREKYLESVEFWKEHAIVFS
+>gnl|md5|37a355b96e86fafa9e5c3e9c47f25167
+MGNILHYLIGQRNYHYYDEIALDCGVNMFSIQKNVEQTKILKYKSLSMKISEAESLYNKL
+MDMRYHTEQIIDKYNSLTRLFEGIHCKICYLDFAQRWVYQQDCNKFYKYCIELEARIAEQ
+DDSIKRKYLEYCDFVQLYSIKSGKIKYLNKYPGLKTCLLLNRKCPKCYESKKISHSQAKV
+SINN
+>gnl|md5|4edab3c933626b5099bfdfd49a9662cf
+MEEDDKINLFGVYEELFHLLRDGKDEVIKGSMELLLDQSEMESLSEFLSNNPNYFRSILL
+LIGNDISSISECALKILINLSQKSEIGEELCRNWSAIEYSMDNLREQIKSNSTVPYHLSL
+NLMLISNLTRYSKGREKFFDKSRQSKSFYLTYLLECLSNSRDKKEREMIINILNNCTYCS
+QGRVFLFDSNLGIELLNKVSELMLATSRKDDLIMTKSLMSIITHVCLDKNLHTIISKKDC
+NVIPSLCCLVYPNESHRNLRYRKSSNILSELQNKTIFFDSKREGTNSNNISFNEFENRNP
+KKKCGGDDEEFTDSAAEDKVSEFIKKNAIGPVNKNISQDVFDCILVLISTINGRTFLREL
+GAYEVLRVWHLYESKDEIISGIEDIIHLLVYSEDELLQQDNSSIDA
+>gnl|md5|dd79a07f8409b360e708351d517ffba5
+MYRNQYDTDVVTWSPQGRVFQIEYAMEAVKQGTAVVGARNNEIVVLACIKRSTSKLAGYQ
+KKLYKIDNHIGVAVSGITADAKVICNYLRSECLNYSFTYDSPMPLNTLVNKLVLKSQVNT
+QEYGRRPFGVGLLLAGFDESGPHLFETCPSGNCFEYYSIAIGSRSQASKTYLEKHFKEFA
+NCSKDQLILHTLRALRSSLSSEQEMNQENVDVAILGRNDVYNELLEEEKIKYLQIINQEQ
+PPTIEQIDESQETSSMQID
+>gnl|md5|5ae2083ceff86df05d11cf89ebf42cbe
+MSIERSFDYKTSSLSSWNLQEYIATLSSTNACLLFEDISCVTELFSSLSEIQQNIVSRLM
+ILGSGYGNYIGEQAMNIWILTTKRNELEYAIRRLRSLKIIKVNVLDSNSQKSSSDSISVQ
+YQLNPIFQKTLSKFLYEGDIFNGFEIPKRKSEIKISYESLTKFVRKQWSNILNIIVQLSG
+SQNIPKNSANTFYKFKLISPDTIKVLDNIHLISCDIGKYNKKNSPNSKGLRIQIYSSLSR
+ESSEQLFDGFDQEDRFGSQNDQNALDIYNEIKYDMAGSNSNSEEEYLPTNNLKIKPKKRV
+INSKHTLAKNQVDKIFEQKLAPKAFCWLLCDSCNQLLMLLNGFIKLVELESTIENGEYKF
+SQITSENILNPPIPNVISLILRISSSKIGQPISIHKKTNNNILMRFILFAYDLGLLYIDE
+SIIESSLYSLKNRFENLRDLNIELLYTTPFSLL
+>gnl|md5|bfff9c7c4939b21518dcf494af428a70
+MGKIELGTIRCGDNLVVMPNRAKAKIQSICLGEEMDEYAWSGPGENVRIKLLNIDEDSLS
+KGFVLCSQSDLCPVVKKFKAQLLFVELLEQRPLITSGYECIIHCNTSCEEVCIEELLEGV
+ELSTKKKKNRPAFVKSQYMLTCNMSLTNPLCIEEFVKCPQLGRFTLRDEGKTIAVGKVLE
+ILDSV
+>gnl|md5|eef4f05c3e8a548f3c1a9e4108e175a5
+MQNNLPVQNSFAKLGALSLLKQSIQGEDSETNKSKGITAISSLVRHNKTLEDSFISDNGI
+PLIALWLHSENVGVRERALSLLRHLLIQGVVNSEYIIGNNNSKIIDTILTLSRNNSISNR
+EYQNIQYGETISETLLELINAFNPKLSSSSKDKIRKEVNKRMTFLIDYCKLHPDDDISPE
+YSILIQCEKLLV
+>gnl|md5|df4bbf152d798694f6da22f5f4c7e28d
+MSFKVESNLVCSSTLKSYNKSYIKKTRRGKIRKVSNEIYVRNEILCGLNFCTLCYGKYSG
+ISNQKVRNIIFPNFDIFNKYSDFILEDESLNHVVIPYSILDYLSETDRTVINKLRNKLRS
+QNELPIFKEIELTNENNLFDYNVNQYIRFPDTQFTETCLNHSISRFNFEDCAGNSIIKVA
+IWFINHLSKSNANIRFYILTENEEWIKKFTSNLPFDSKCFIVNPYEYINFVSNEYVNSGD
+KLPFKTSLVNDNSHRIPAARGIH
+>gnl|md5|d002fa05685924b5d1e1ec5ba6b56564
+MISRNRGEIEVTNKNRKMTVNIIGHLNLNRSIDGDLVVFKLDETLNCDEKNLKSQIKSEL
+ELDQIEDLEHTEIAGIGSILLGDDDYDENSALNIQNISIQSIESEDNNSLTFSENNNFSG
+RVIGVLSRNWGEYCGSLVPMNSNDDRFNICNNTSTRQHRIFVPIDPKIPKIIIHTKLSST
+IENQRLVVVIDEWDCSSFYPTGHIVGVLGKAGDLETETSVILRIRDINSSEFSPSVLKCL
+PNHDRNDDWKPNEIDFRDRVDLRKKLVFSVDPPGCKDIDDALSIELINPNDDNSQENWYL
+VSVHIADVTHFVKPNTPIDDEASRRSNTCYLVNKRIDMLPEELTTNICSLVSNKDRLSFT
+CNWEINENAEIRNVYFNKTIINSKYSFTYLQAQNIIDDKCNNSEIAISLRRLMKISQVLR
+KNRISRGAIELSSSEVKVDFEESRNLYQDLNHNDLGKEQISSVILNIKNVYAYNYLNTNS
+MVEEFMLLANVSVARQIVSKFPNCCLLRRHPEPKYDQLEKLKHVLSKVGISNFTYENSLS
+LSNSLKNILDSEIIKKNPIIGKLVRILTTRTMNQALYFTTCKSVEGTFHYGLAEEIYTHF
+TSPIRRYADIIVHRLLSASIGLEPLCEVMSDKDYVSS
+>gnl|md5|9f2eb5488223c895fd07d318b3c06278
+MKSFIGIQFIAYLFLFFYCLNVARCDNKINNLLELRQSILQHEKELENLHGATSNLVGEA
+ADVLNFSKKRPIFSELNNFSAPGAPTTTIKMTLKFPNTAPVNINQGKLREEIRNTATGNG
+DAVPSINPIPLVVIRPDALTNLLSSLSATVHQRKKIECKFIKNLIFILIIFSEKNYST
+>gnl|md5|89882a7538ab6905d3e3ee4db3f77edf
+MRTHGGMNVICDKYRFTCIFIHAMCFCMQPFFLFQEVQGILFKLNIGFLFLSIILFELFI
+FLDKMHKHYRLFFGLIFLFMGCGYIGSIRVNLLGNRALYSTFLEQQATLEEMVKELSSNT
+ALGKTRFGDPITDKNNQSGGSAPTVVRHGRDTITLSIGYGPLSGLGELPFFGNTGPKVPI
+IITSPQPILDIESLSASYQKEANTPGSAAYVDEQALAQAVTNPKVNSDQVAVSLKSTLQN
+AAYFAADAELYK
+>gnl|md5|0127d3e42ee9efac6d263bee3a55fa33
+MTQNIKTKKTTKVSKKEAKKNKPKRAMTAFMYFASSRRAEITAANPSLRSQVAEVAKILG
+EEWRGMSESDKAPFQKQADADKKRYEREKAQMAGQ
+>gnl|md5|7c06cbcec31e1e36ffc271337ca232d8
+MFLNGEMNRSQRNAIRRLRSLAVILEDTHIDKERSIPLISKAITSQKHIRRRDSTERNIA
+TRLDSFKLSMGGKPHLHSADLFENFSPVQLERQKWVPTLPYSLSSNCIKIKEIEIPDLIQ
+KDENKLKELLPNTFGRPCIEITRDESKNSENSDHALRVGIVLSGGPAPGGHNVICGVYDF
+IKNHHPDSQLFGFLGGLDGLFKSTYKVISDELMDRFRNQGGFDMLWSGRGRINGEQDLER
+VEKVCEQLQLHGLIVIGGDGSNSNAALIADYMAKKNKNFCIVGVPKTIDGDLKNPAIEVS
+FGFDTAARTYAECVGNLCSDICTSQNVYHFVRVMGRSASHLALEVALQTRPNIVFIAEEV
+EQEGITLFEIVKNIVDLMEERSKMGKMYGIILIPEGLIEFIPEMKILIQELNEILDKLKY
+EGSECDQEASPDDFDKKICSCLSESSAKIWEYLPENIREQLLLDREATGQIQVAKIATER
+LLILLVEAELHRRHGTSFYYDFEHGQTKETISDQVEISNKSNGSILMPFGFTMMHHYLGY
+EGRCAMPSNFDSNYCYALGHCAGALVYKGMNGYLAVIRGLEGNPLSWQACGISITRIMEV
+KKSRQDGQCYAAVTRQLVDLNGPLFKLLKQVRDIWKFQDLYRATGPLQFEGPCSETIPYI
+VRTPELQDLLCGEDASVTDTDINIVQANNGGGKRGVFNRIQGTLSSLQLYRTTYRPPLPL
+LLTHLKARCKPTTQYNLSDPLIKRQITTCYPHLCNSNHFYCQEAQLDISSEEPNVGLRIG
+VLLMSRQAPGIANVVWGLYHRLKMVRGRCLGFYGVKGFLQGKHITLTEKDVDLLPNQGGS
+ELIGRTYTECLVSKENLEKARKVCESLHLDGLVLCGSAFGMTQGAILAEYFLQNNCNTKV
+VGVPATASNNLANDLVEACVGFDSSTKLYASLIGNVLTDAASMPKYWHFIRLMGRQPSNE
+VLECALQTHPNVVIIAEEYGAADKTLVHIVEDVADVICKRAEFGKNFGTVLIPDALLSHL
+PDMKILISEINELRRFAEEHSEMKLFISEMMSLGHSDHPTLSDHTNSQEKSSRVDVADNK
+SSAANQEHSPADSFDGSKYSSKMTPWSLALFKSLPRFIRREILSLDVDSAFSAIETEALL
+VLMIKKELKKRKQDNRYNGNFQPFTHFFGYQGRSAMPSQFDAKLGYALGHFASIVVESGL
+TGHLCSIRGLCGDVSDWRMTAIPFNCLMKIVPSNDETHPELPSNIPTIPSSEVDLKGKAY
+RWLKIVQEHWAMQDRFCNPGPIQFDGAAANFYFRTLHEQQSEYYEMLKHVQNYAELVRET
+CTFGVNESFLKTAFVTLNGLLNLRYRDGSLLSSLPDIGPIILQMKSHSGMLNNPTGQGEA
+IEPIVGELSNKAPSNLHTSKYISQSNLHMAQSICPGVEEGPWNKTK
+>gnl|md5|908a9ac14751bef5b1bde4b93adecca9
+MFIYNEVEILQSLKQNTDNIYTIKTTLSAWIQQIFFLSTFWQSKKVWSFSSQSNDKTIKI
+NHDIQNEIEAQHQQESNNFAKEIILNEGTNKTNKMNEKGINQVIQQKKKQFKKFFELPPK
+LEYIPYHLFFLIVLFSIVSILWIINIANYQLHTETGEVIWKILDSPFRARSFYTFDPTLD
+FFPYMFKDCSKKDENLNFLYDKDQLSNIPGELLYGLYQSYRLTNITSLSHLNSWIQKIFI
+PLIKTKNTQTSEKKNFLMDLGHPTLYSTVNPMLLFKQHFSPVKCNSNPISSGLYLSTISR
+SKSSLSIKDISNFNPLSVNNVPTSLSVPNTQIQKIRNIFARILKLVNFNHGIFSRELTTS
+AEKSSHMESTLSSSGVDRIFFLYAGKESEISEQFNKSLHGNDEGNLFWVIRSYSLSTGSD
+VNVDLITSLDSFASNEDFNIPFDGLFDYSMDTLEIYFPIIIPNQNSVSLIKLKFELLRTG
+KIEIEYSFDFVKHEWIKQTINQNGIYIDSKNQEISEDVDGNENESENQVKDSDSNSGIWV
+FSFVLIGIQCFIFLIFLILVIYNFYRKRLLRKRLMNQINYKMDISESESESEIQKKKKIR
+KLGIRKIVRKIGRKEIENEQTTIKKQKLETFGNVHLNEKKNVLEFRKKKFAHKKQNKDIK
+EEITDSKQIVEEELYDEDILILYKLSNFNILIIVIMLIAFFVLFFSSIAYYILIISTKIS
+ININSIDIEGGFNSIASSHGDPLPWEIEISNLNDINSKLNMIGSSSGFYNDNVFSFSNLF
+ETINNIQEISGYFEMFEIIGVFLIITYLSIIFIYSSLLVDRHRRTKILKMRRYMEKTGKK
+LTGNSFESLSVFTFMDTTSQRGFSWNDANYALFPIFCVVASIILIFSLTGYSILGYQEAT
+YFSYYYSVISSLLMIFNYNSVKQVMMTSITPDISIRFKSNIITFIWKPLYYLLTFFTFNF
+ILKALIPASIIFYMRSVASKNLQISQDTLLSKLNNVAVTRPSIPVFTNDCISLRMKFFIK
+ALYKKLGKFKKFDMNLMKGNTIEEQNETEVNLTEGNPDWIFAKLIPELFNEIIHYKLNIA
+ELVNKDQQGIQEIRDYLGNISLQLLLIQEHLVKIEFLRCKLSMIRQELMKIEDVKKDISR
+GNRESQHYIDRLLQRLMSINDEIEHLDESNRVLGQEKETVKQKTSSVAANYTLQKEKEKF
+STNFLFEYGNSYAKTLFK
+>gnl|md5|7c0d2f0f662f1a66c5fcff7bba2f6db1
+MYSTNMGLLLQWDDSLLVSISLNCDGTILKCFKPKINGIYEGVISSSADPDYFKNNILFY
+LNRGNHTYNLGNTINYENSSFINGAHLYNYSNYSKSNLNVMIFGTIMFTINKYFSVFAYN
+IDNHQIIWRNDSLRQKDHLKLYKKKLFVLRKILPELVIVDQSSILRIEILSGKTISIESY
+IESSKLIVSTPPFTSNEQNINPLLILLDKHNKTLKFVGLDNKTVNIKDKSYFYFTNESNI
+IKCYKMISGYDSEVHWQYVFDLDETISVYSTPECSYCKSFPVIVDEKYNIINRFDYPYLL
+GVITSKKKVLLFNQINGNLIYSSFLPQMFEPPFTLEIFQNIILITSFHSNHKVPVILILE
+LFQFIKEETSTGINMLDKFIFLVSNKKNVKESKIYSEKHVHVQETTFLYNYELPIDYSLL
+SRTSESLASKIILFGNERSNVLECIPERLFTTLRPNKSKKKNLIHNSNLPFYQSILSERI
+KFSTKFNSKKIFSFPHETYESKSKLLSVGFNSLEVFEIYPNTSFDLLPYDFNYYNIINTV
+FLILTITAISIYFSKRNQLKKWI
+>gnl|md5|f3404a53df990203959cd899eac5fd83
+MVRIEPDRKWFGNTRVITQNKLETFREEISNAFLDPFSVVLKRSKLPTSLLNNNSRPEKF
+TCEKINLLNVEPYNRTFGQGHERRKKPKIIFQFDNLSELASNIEQSHNNYNQEQPNSFES
+NDFYLEKTERKGEFEGFDLLNDDSVLRKGTSRRIWQELYKVIDSSDIIIHVLDSRDPEGT
+RCKYLEEYISKEYQNKHILFVLNKVDLIPKWVASKWISFYGSIRPTIAFHSSITNSFGKR
+TLFHVLRQYASLLSDKKHVSVGFIGYPNVGKSSIINTLRGSKVCSVAPIAGETKIWQYIH
+LTHRIYLIDCPGIVPPENASSYNVVLRGAIRPEKLSDPCIYIKQLLNIVKERHIKEKYNL
+KSTDNWKNPDEFLTLVGKRLGKVLRGGEIDLITTAKIILNDWIVGKIPYFIPPPQSSSEF
+AIQESTDKNLIKAQDIERINVCKEFEYNNENMNFIDEKPLKQKAICSKQLNKWDDVVCQF
+D
+>gnl|md5|8fa10a6d99c488788cac155e2009ce68
+MRSCTYIYIYIYVYFFFFFFACALQRFVILLALLEIYSRHMGSEQSKTNCSKEINTEVEN
+NKSKIKSNISIGLKSSVKKNSSIRKTSSSELDECSDNESFSLIVKHKTQNSNMKKGFINS
+TSNSKNGNNDLDWDTIIHIIDTDVIEGMVIIEDSNE
+>gnl|md5|97018cd9b6f2c8932e44c685fdae45a0
+MNIFSRPNWFVYDICGILCMILTELLLLYSALILNFFFIKKFLDSGERILFIFNLILCNS
+IYIICSFCHLSCTTTDPGVMPNNGDKGEILLPIELQTQTVSIRSCAKCNNLKPPRTHHCS
+VCKRCIFKMDHHCPWINNCVGINNQKHFLLFLAYVFLFCAYSLILICIRFYKCISYSLPN
+PSDINDSYLDFQLLSSTTELLNFNQKANETPYYDCTITPISFILGFSVIIEGLIFGIFCI
+AMFVDQVICIINNTTGIEHLKQEYLYSKKKSAYSLFIQVFGSKFSWRWFLPTMTRPPFTT
+SNFDISKFLDFEFGDLIIDPETGFDCDQSKQDIQSYDSSILFKRMKSNRISCCFICEGID
+SSNMSIPNVSEDFSIFENEVRKGGTSNPSFKEILMDDLHR
+>gnl|md5|ee4d11f1bc0e8152602c8ec3fe1fa724
+MGKAGKGTGSRGKHHGKTHFLCRRCGQRSYMVQKKRCASCGYPSAKMRSYNWGQKAKRRR
+TTGTGRMRHLKTMARRFKNGFREGTVARPLNMAAHK
+>gnl|md5|6abee13b5ef4c171c40af02e87d03681
+MAESFGISQEFLEKDIVTFISSSKLSCTIDRVKQVIICSRNDKKINQYNELVQKGDLLLN
+RLQRLTRIIQV
+>gnl|md5|b2cb894ae4514b10135ab5dc12cda924
+MNKTISSDNLKDAVRKWHAKRKKDSNNQANSENTGSEPEGIFGTKKHDVRHISAWSHNNF
+AESNQLSHFTNEQKRPRSTVIENNIKYIFDGPLSFDTIMALKKKKSNVIFSNNEKMLNNP
+NIEQNDSKSAINQCYTHQTNNSQVMDNFKDEIDIIYSKSISAAQNFFKSSSISEVINLLE
+YILNFLSFSTQELISRYNKKAYFDRHEKSLGICINFILNKSNLTDEQFDEISLEYLAKYP
+KVFESLKTLTKINGLDDVVPSEISNHLQKLNSQIDKIYNLLLNR
+>gnl|md5|ef58768a8cf0dccbd83d5348c9750b95
+MDNGFPISLLLVNYKEFVSIFLDIPNWERLKSNSIGRYIENRVNIIQKQILLNGETSYWK
+FEQSLCILLRLSTCLNPYSDIRESISNSWQSIINSLNETWSIGSRRDEDPKKLLTEYNST
+LFYTKIKDIHPDLLFSITLGGSCISIREAIKIFTSENSENNQHCLPCGRFISPEYLVPGT
+PGFFPNNKFYLDENETFWKDVFNTFHGRIPSVFRIVYILPEYAKALLKSYKINMEDQNFG
+ALPLHYRHFIGILCSSLYDNDYMIKLEMQMYVFNNGPIEWLENPSDSLPVKFFALFEFLK
+CITFEPAYISNELMNHLIGEVSDTQVWTITELCHILCIVTTIQSISQLSCSFGITSMDHW
+ELGPDPLEGPNCDGNTCYKPNPATMKDCFEYRKVISSNFFHENSNPDSLTTSYYKEILSE
+YIDVEKEEKNYTHRIKNNHSTSNTNKNMSMPKLSFLKLPIFSLNKIYNLRLFSQINSFID
+LKWILDSTISAKLKRKQINEGKDYFNLDRTSLFSDSQIRSNEYLREYTQINTKNFNDNEK
+NLESEYHSKQKYEGEISTLIRIKDLLNHFPPQGDILGISKDEIPLFRSNSDKHKADRVLL
+SSVMNSKPKLQFNSLSGRFKHISNFIGAESPNLVLNKLESNKKFSFKDNEKTFEFRKNKK
+ELKNGCLTNKNAHFMSMLNSFSIQMLEYEFYSETAWSVLSIYSGECSKCIKDELDILLYN
+CNKNITTICDIYKVPTTNPIRSSIWSYVFKLCGIVKFEMTELVHNSFLPLELKVLLKKTI
+RSPQRILRSDFERCRIVFSYTELIYYLIVVCKAKQAVTIICSIQSLSNILKGAQ
+>gnl|md5|9902930a711b7773edaabc5aa7760789
+MEGIQIPEIYINSDMILSFDEEACNWNETSSNLSNSPKILNTSIQNTSNKLNVNVNVNVN
+GNVNYSHSNSKCSFSTNNISEEVNASECNPKFLEIHRGNTNHKKISESISFSQEETPKSI
+IIDCLLKDQNQFKTENQYVESSQNLNLFSYLENNLTEKVNSDKFKSINKENNMARRRRDD
+PKLCWRCHKRDATPHMRSCEPCRVADRQRWSRRRNLSKIISGKNVNNNNSEHSVNHFNNQ
+LKDDSSISLCSDNQKIDTFNGGYIQNSTQLKCDNQYISGTNEHYRAFNTGISNANSSAQV
+TGFSVGYPFKTDQWREQQQSISFRENRNIHPCAEISQNLSYITISYFPSSFSGLTTLPVS
+AKFASDGSMNGLETLPSVVLSFIVDKCNEQLLQRQLGRQNHQNLVSSNTPCNSQVESGLG
+NILMSNVEANKNINGTGGIGSFHNFHCANIHSNTLDSRFYC
+>gnl|md5|b4a40825998eb5a1b1c81a7b627f4581
+MVRSILFALPPIPVGLHRELASGPVIQSSVAEFAFKKKIEPVGEAFFYRYEGKYSSKINF
+LKEEIKIENSIPINNIYSQEECQKKSKKISGNKLAKGVLSLARLKELVEEKETLYKKLGL
+DENVCVKEIKQAYRKLVLSYHPDKNKENSSDARSEEFLKIQEAYEILSDKNLRHAYDSAL
+PFDDSIPSVYVSENNDFYEFKNFFSPIFRRNSRWSIVKPVPEIGNIDDNIEVIENFYEFW
+RGFQSNRDFSIHEEHELNHAECREEKRWMERQNFKIRSKYIRNEISRINRLVDLAYKNDP
+RIKQHFENLNKRKEEEKRKKIEQKKIEEEEKRLMDEQQKKKAIELKSAIKSLRISIRNKM
+KNISDVNIFFDKFQKEDFSVCLKTIEDFNWINIFLKNIHLTEVVQIHSIEKINLKQWEEW
+LLKLDHFQLEHLDNFLNKWIEVFGENCSDDYLKKLYLIFTIKILHINNFDANKSLQPTKK
+TNESNMSNLSNDCVTVNTENLSSDWTVSEMSLLAKALQKYPGGYKNRWDMISEYLKNTKT
+KEQILTKVKELSESEKLAKLSNEVKEESAFDTFIQSNKGVLKKFDNIPDVRDYSGTSIIN
+NSAKNDVTHQKKEIDLWTRDQQCSLERALKQYPSSLPLNERWELISSCIPGKDSSQCLAR
+YKLIRERLLKKQK
+>gnl|md5|58e79750fd230c29df9e6328b4f5c5d9
+MIFLTPILPILSCFCLHYLWKYFEKEFGIITSLLSISILIITFYGAYIYFKKSLYIEIDF
+GKFANKKEDFTEFNSNLMLSVFERYNRERENCLNGGLVAVKQGEDDPSEIKNKKFVSQSE
+THSSEMKDTDILFHDSKLSFFGLSMNSPNTSKKLYQHNNCYNSSHKICSPSLLADTFIQA
+ADIARNYQSEHYRGIHNNSQLQHSNILIGSNTNTLAKAAETKNSNSRLFRSVGYSFHSNI
+EFARSRFEDYISSLQFRITNKRVRNSLPGRLLSSVSNSESGIKKNAISKHRQSSIPSILI
+ESIDDKSTKAKANSSTPTRKIYNSFLSPLPTSKPSPILLFTDNKN
+>gnl|md5|58990ea1eea1ca9f4cd8f17be52b4114
+MYDSSNQNISCKGKLALSGGHLSTLSTKNSAPSPSYIIGPSKQSATISGWNRLNSSLGSQ
+ITNLASFIHRRAGRISRSPSPVRGNINLKEIRSSRLELSTERSLEELSKQTLNSFLSIEK
+RNGNSNLGLSFGSISKEINSAKQIGESAICNEKSIYEENRELKKQISELKEIIICKEGEN
+QMLKLKLELFHKEMIKFSGISLQGRESLPPLKVKARNNKHANKELDEDSFKLYICGDYSN
+DDNEVFSRKKCIWRPCEELAKNNLTEMGISFACVKGKRINKSMVNQDDFCIVKLANNTLI
+IGVFDGHGRYGHKVTAIVRQKIIKGIQSIFLGMPFKFEDNSQISDITYNHNLGSLQELNQ
+KRIIISILKIFEGIQGYLEREGSFGTSGTSVTFAIIDFERLIMVQLGSSGGIIVDSNTGD
+TIYSTPRHDLSNIVEKERIIGNGATINENNRFSLNRIEEKKPQLFSITRSLGDSDGRVVG
+ISNKPEIWEMKIEKGSSMKVILATDGFLKFSDEASIDYNKLCIQKELDSAIKKCQGFWLN
+STNNTSVDDITVISCNISN
+>gnl|md5|89719bd9664769176cf3fa12f056d8f7
+MKGDSEVSTNPNSKILAELAPEIKNYLHFPDEANLYPNQLMCRRIIVNDENGFEKSKYSV
+FDDLLIGDLNFLLRIIDAKYNACTILKRIRLSEIVENYKVFEDKEVNEESNLLDILHLFP
+KNYTSENKAINIHDSVLMDRYSFGRTMSDIMLILQCLPTRKANSELCTLFDSEINPPISI
+KDYFTRLSEYFLCSPSLFVLMFIYIKRIIDNNPSYIFDTKSAHRLMLATLVISVKLYDDK
+FLPNTHYAHVGGVSETELSRLEVDALLLIDFRLKVTIEEFVKFSYSLRFLGEVIKKYGIA
+LRDSNVI
+>gnl|md5|573810159cd2768f4aca9fc69023439f
+MVKFGTYIIENNDNGPQLIRREKSGPLIVLKVGTSTLTNSRTGKLSVSNIGALVETVCDL
+MDKGCRVVLVSSGAVGAGLLHMNIREKPNKLHLKHAIAAIGQPLLMRVYEDFFSMRGAKV
+AQLLMTRSDFVNKDRFIDFKNTLLDLIHWNVVPIINENDSVTTIDLHFGDNDTLAAYCAI
+AISADWLILATDVDALFTKNPRLHRDAVPILKVNNIDSIIHMENDVSDENCGTNFGTGGM
+RTKIFAARIAAAAGISTFLVNGSHPNRLLQLVDSIDFKMNKAHNNNAISSYYSPTSEAND
+LEKVSLCESLDMNSSSIESLADTKTCFEHSYSSIVGNFIEETPESTQVDNGIITCALEEL
+YQGEYIGTIFARQALTQAMKNHKRWIMSLPISGKIFLDKGAIKSVTVDSKSLFSVGIVNV
+KGKFETGDVVSIICDGDK
+>gnl|md5|277da4705ff514b2c2d6df56c106d400
+MDFLNFPKFLFGNIYERIYECCVVNELKQEKKVQQQKKLKFNNLNILFYNQKDFQANKYS
+LRGCMTSRNNYNFQKSEEFFTCRKLYNESKLAACEYTIPIEKTHRQSIEDYNSNCWLSQK
+KKSGFKINIIPSNKTQITPINVQKVVKNENESEKKNSKSQINGAKYIIPILNLNFTEKRN
+SELMTYREHFSASNNKQISPILSNFKDKTLEGGRKLQNEWINVNMLLLSAYHDRTIQSTK
+AKIEMLTFYAIEICFKKIDSKLHIIEEGSFGRVYKGRYNNCDVAVKVPNLDTMKSDPFGV
+TERILREWKLLAKINHPNIIGFKGGIILPNKHIWLITEFIQGCDLHSLKYKFKYEIPREK
+AIKMIKQLIKALDFLHTPTKEKGIIIHRDIKPENIIIDNNNWNIYLCDFGDAEEFGSGNK
+RRLSGATWLYSPIELLNADPIGNHISIQSVSQYNEKWDIWSLGCVLQEFFGNSNPFEYIV
+DVADNSNQIYSKLVKAVRENKYIPNIPTNIHPQIRKVIEMCLQPDPRLRPSAKVILKIID
+NVF
+>gnl|md5|f14920dffa8eb9c932e1ea726a0a9d78
+MVRNVRSKYVVGFTIHAGKGFITPNQSPINPLVVVKCCGREYRSKIKYNKLIATQWDESH
+SWNDIFLTDSEWDMSFITFEVQSANSFWKNDVIGQCSIQLKTLKQRKNHFLKRHFNITEL
+NDTFPKGLLYLTVYACGPNDTPPTSDILELMNAEEDKFQNNQVDFLNQIVGAHEMKKEFS
+TLEREKQMYNLYVTIYRVEDLLFKKGLRDPFITVEFSGCSMQSSIARGVLDHNFNECFRF
+PVVVPIVEDIIILKLWDNSTKPPAIITQGKFSFARVRSTTIPVRWYNFYGNSALNIELGN
+KYSNDIFFTENVSSQSDIYLGRILISLKTELLRNKDQLMPAQVIAAQPLDELFTQPCNII
+ADVYSIKGIFGRNACVEVSVGPNKQRTEFVSREVEGQNYDDCKNNMVNKSKKQQSMDNFV
+YGSTQGRVPNIEIESQSKEEFTWDIIISVYTHTNSNVNKVDAQGILSSSELAHGSKRVAY
+CRLKITDIPHYIENKPLPPIWIPLKQTRDGWIDMIDNKERSYNNRFEPLSETENEKNIET
+NNIQEIDLYSIGSSAILISISKQFASSVKRTKRHTIKCIDYELRCYLYACRNLNETGKDR
+TNPYIVVSCNGVYTTSSVKVNTNNPTFLECLFLRVKIESDPLTSFPTVAPITISVFSRHS
+WGKRFIGLCTCIYDRINGRNKNNEPISTLEPFWIKLKGGARLNNHVGDILLCIDIIKLCD
+SKMVPPQPLFPELKRVQMIVTTTLLQDLFMMTEEDVKYNIKSKLSQDEDLSLLNQGIIGS
+KIEKYRILKEMNGNFFLENHERGNVYSTEIKNPIIEFTVSAFGRVDATTEGSENVDDKLL
+KNSEGRTKSSSSIPTYRQIVQWKSITSAGAKEFFNKSWKTLRGYNFEFFKTISLDIFLPL
+SPLFDPRLTIRIFEGLVDESKLVGEFVISLVSFLPWIPDVDSAHEWISSKHDFSNNIDIA
+KITNVLSKGSKKKNLIKHSGLASIALADMEEDKEKKMNSTAHPFPAVSQQEEMEELKKKS
+LMNQGLNQAGVPITLIKSYTVSNVYYPRISQNMFTINLHIPFHFIIVAEGKTTDKRNNLK
+IMISNSGMDTGGVITTSTSGKTVSLRPSIDSTMEEFLSDILIPIIPVRKKGFDGKMKTFG
+YLRGYILLALPGVLDEINSKKSNENIINDNIDEDEIISQEIKQAVENNKISRCYSHEMIR
+YIININSLYKRIKGDNVYPNPVRVRLYILSALALVVPIDYSENIYQESLEKKTLFEKIKD
+KLSIINMFEQNIRIKSFYISIVYGSKEENFRSTAKGTLNPLFYVCQEYNVNFPVESRFEI
+RVWGIQEKVYPYLACKILGLLNQEKKEDVENTDLNGNSNNDLVINEINNEVCQELGPEYD
+VFIGSTAMDLTDRWHSKEWRQMMREDHIPIEYRPLYRDCTSNVNYGLLQMWVEIMSSNKA
+AVTKRYELSEPVPTEVEVRVIIWAGRDIKTANNLDYGDYLFKSTLDCKQYPEFRPDFGNN
+NPRVQQTDVHYNCRTGEPVFNWRLVYPHLVTPISGCLLQISIYHYSSFGNHEFIGEVNLD
+LRKYIMNVANSLEAIDEDVELPLVNSQSVDSSFDAGFVQVTIQIIPQSEANSKKVGMGRD
+IPNRFPKLVTPSVGRNWEDFLQLKERQDALRPIWLKIRIVYIIFAILLFFIIGAVYPALF
+YQSIYS
+>gnl|md5|2a557786f9d51420c8eb5a2e90870a5a
+MSDRFSLFSLSKISISDLLMLKEKKCENKIENAKFITKSSNLEDIFTEDFKQKMERNKIC
+LSVKAQGDVLTHFPLFLNKPFTSNENNKSLSGTIDTKKENLHLNQTNNSAISKKRSKINK
+IIETNIGDHLIYEMKINKNRFARKELTSTKLIWNSIQENIKSIISSTE
+>gnl|md5|c08cd83f6d0f7c2baaaaa79996a8a9de
+MFNPISQNNRILIDHCNIPCNFIFRSDSNAEDIEGFAGAGVFQSVPLFDPISKYVKYLSQ
+PIIKDQDYRNEALRQLATIAFYVQDEFDEIPQDIEGCIIEDCQGSSIKSFSIAIVQSRPQ
+V
+>gnl|md5|5b55a599afd81bf669efbeef0315ebfb
+MLDRTIRGKKSWRNLSNFCSSAEYNEISEDSTEIDMPEINKVDDYIFEQEVEIKIKLIDS
+MPFDRFVCVFKTLDENGHVCWHKEGDKDIEIVISFQEKKNDRWKGIWSDIVFDIINAEVE
+WGSITLMHRYNLMDQIIKKWSDEFINGTYKFISNSNVILWHEFETNNKRESTDRNLIAIN
+SVNIRDAILCGEEFWAWIMIWMRLNSLGVLDWQRNYNTAPRLLAQSAETASLTLISKWLE
+MPQYRYQIRLIAQSIIRGGSRGQEVRDRILHIMHKNRIPEDHGTFYEQWHQKLHNNTTPD
+DVGICRSIIGYLRNNGNEEIFSKILHEEGLSWEKIRSYDRPITSKPYIPPFLDVNTLASD
+FEQYLEVLVDVHEASNLQRSFHYSREYLDEKSQNICASVIFGENKRFDNTKDLNVLHGRL
+MHVNKAREEILNLIYNLYGGKQSDTDTRNFRAIKEIMYLDLGLENLQCMFIQTICTINNN
+YDNIIHLIDEMNSFIWILFGHDPCNKELEAIFFDWKEFKILNKSTKNYILILKSLVDRLQ
+LFIGSMMDNIFSIWDPKVTFFGRSIGLSKDDPIIKNFMDEILRSTLYSTISLQIKRINKY
+LLNKTDPNELSDWQFISYHPSWRDDQIFTGIFKKLNKITELTEDPYKKIISCSNISGEED
+IPMNVIGIILTNPENSPDLLSHLSVRARNMNVLLVVSQNPQISEFINSIEENEIINLKIR
+SDLRLEISKNNEILDKNELIATKSLNQVKVKHKSRFFEFKNKIKGLNKWVLLPCEMDNNN
+VGQKALNLVKLRRLFTSKSIELPFFVPSCVSLPFGTLNKLLNSSTFEKITSQLNILEEQC
+KLENPEAFEILKNVCNIIEYEVEPCNQLIEELINAMKILVQLDLENINVDTIKEINKERI
+QKHSNSMKLIWEKIIKVWMSVYQPISFLNMKKIGLPLSNVYMSIAIQRLMNAKYAFVLHS
+KNPIQNKNINLTEYEEMYGELVMD
+>gnl|md5|e44253d5f6b286b716f8eb6a1b0fd57e
+MEDESPVGSPILILDKSDPVFNSESEDENVSYSVIDVERRERVVETFSWSPQGRGAEAEC
+RISIEEFRIRIKNLCQDYFLDFKTQDFINGLKCISCPSLHNLVIVITIRMALDYSLSVQQ
+QVSALLTILKDSHLITQQQIEDGLEKLIQSIDDICLDAPYSPERLECLIDCAIVDGIIPS
+NFRCRYPEAFLNKLIELRRISENNPKEIFNASEIEGLNLHLKTLRTFKSFILENEEDFFS
+SGFNITEVEKIISDAHLAAYKTAFWNGIDWTASSFAEKSSSETNSVPSTLCFNHEFVKNI
+VISSMSRNNLQRELVSNGLNLLSPSIINSVDISLGFMRILGNLDDLSLDVLNACDLTTKF
+IARCIVDELLPPSFITVNSILHMGGPGGTQALNMSEQFLRNKPRNLLRHQTQNIWLQSED
+VKEDILIKMEVTKALDKYSISLDKRECIKTLHSLPLTQTNKKYLVKYIILHFIEKVSLGS
+DDQFKNNFVEFCDREMRAGISLLEYLLSQGFLDEDTIMEGFHIYLDTTRDFASVDQQTQE
+VFSVFVSKAIERALLPYNWKTN
+>gnl|md5|b18c082ee840b25e6e1461e7f66e10f3
+MSDFSWPKSDVRKYENEIYSILQSFEKAQEWADLSNCLQRLNRCISKEFCDIPGVPLKET
+ISKRLAQCLNPSLPSGVHTKALETYGGIFGKIGKNELSSDLALYGSGLFPFFVHSSTQVK
+PIFLDLIDQYFLPLGPGLLPCLSGLIVGLLPGLEDSKSECYDRIMKTFQSISSRNCVGEK
+NFMCTLWLVILRTTQVRYPALEVILARFSTIYTSNKIISMKKIQSLIPCSILFLKALESC
+IDDENILVKRYLLDFLISHVPINQRTSLKLYYSHIEEILPHKSKVNLLRKALKLFLIREW
+SLTRRLIQWIMNDKYFSPEKKNEYKMDDEIVQTLIAAIIEELIFSFSLLDNYFSVSENSS
+SFAKYQSIRISKNPNSLQQTNNLANQTTILQPIKMINALFEEFVQCVNFIAPKILIPIFM
+YSRELTIKVPELKDSIIKECRSLINSTNLNPNIFLNTINSTFLNLLKKKTEKVIIDPNES
+LVTSPTPLLLKEIILFYVDNFLLNQEAEDNSLESFFMDLFIILIKIMVEFKAEEKEMIIF
+TELCIFSLNNLRAFKEINNNDTLESSIETLKQFIGFISTFLYENVFTEDKITLRNLLYEA
+LTKLFNIKIFNEILLSQMDMSSLSPFEKFPIPSWLYKLFSRLIEVDFTEYSLLKLENYHI
+EDFFKCLKIIIDLLFNSNLFSKEEFIPSCWAECTLKIVKMLWGFLDPELFRFHEPTTNLL
+IDLENWAQVNFSRISNQINIHSQASVIRGSSILNQLFISQLSVLDIDLRIKNIKKLSIFM
+KYSVNSIYNIPPEVTFLILEGLDSNSIQLKSSCSIWIIQAMETPKLILDHLLGDLSGFEF
+VLLTNKRLQYKDGLDFARIIYSLERLVALISMENINIIQVFFDTKIDKLSISFNIFQYEI
+LNYFEAFAFICLALFIADIPNSSDLRVNCTAINSLNFILNKICNNYVVSKKFNYEDKLMT
+ILYNIINLVLEALQESITTRKYPLQAPTIQLLNTILLIQRQYKSISNKLEPSYLISANTK
+LFTILISGIQQTPNLSNNQIEINKNDYYIFSTNYSSISSCSSLIKPYLDLSLSIFEDLDQ
+ETLIQNAKSIILCLCMELVVSISNKNYSAILQYLDSILKVLLNVIGILPTSNTLSESKPN
+NFQNNSGFIYSLFSSQKSYPNKNCNIELNSLVNTPQLLNNPPETISSVTKISKSLILKNT
+ILILFSALIESVNFVHEIRLTKETANLDMVCSQILRYVDSIAFIIAWNASDAFVFSGIAC
+WSHVNNQIIKTKSRNSLNQENTNNDLRNISIISIFQLNSIKELIGPATIFSVVGDFLSYF
+WLNSSVVGTPNSTKFNHNNETQDTKVPSYVLFFSKITIDKGWIYCYKLWKETMVYHFLYT
+VLVTSSFSNGQDEFLNLWEIISTLLNLFLQNVKQPKSILWFATILSTLDSSMSSSKDVPS
+SFFLDKRLLCIFEDKKMIKNLNNLIYMVLFLLQENFSSKVSGAVLPQQFDKFPPLPPNIE
+AILQSIEFDFSHESQLPREISNIQGNSPKSIVSDDPSLLFSYYSLGFLIMYNTEVAFHAS
+NKRLFLRNIWGSCIVKSLDWMFQPLLKRNNNVANMIHKYFLLLHIDTFPFRIFPDYPSGI
+RKPVIEALNSPNFFCIDRRTFRCWTNIISKLVSYDSTSLSAVGRVNILETYVSLQSMGIF
+STKAAELQNRCNHIKRLAFLIFCCPENTFQLQLSLILEKLVENLKLAPEYLIDSDSNITL
+HFVYLAEQVILCLRVLLLKVHYQSLMPLWPIVLAELIKIFRLKNHKRLKISAMKFVDLAS
+LLDIPEFHLYQWIFVIDFFNTKDTTETDDQKYNENIPSPESILFSPFCNISDANEDADKL
+VLGIDMKALDHSFNTEIPKFPLIYQRNKTESNDNFVEMALQLNNNCLLNSIKGSKIDYEK
+LLKSIENDFLDFPDNLLDWSYSCDLYSLYNMILNQKSILKHNCNKFSKI
+>gnl|md5|61488f1d04b39e9309da34e80abe616c
+MESLWWLKIFEKFVKEKMSISIPSDNILNGELIKFSSFNKIGHFEVISQLNNQYFSCFCR
+RCHKIINTKLIPNNSRYEIISRMIVSALNRFRSLFRCSETKKLNEEDIQFIINRILIANC
+EINNALREVPVSY
+>gnl|md5|60ad38054bcbda5a2c703b91747cb099
+MNTESSSFEWLDVISRQGSKLSRTSFNTARTDLSIYYECNELEEYIEDEIELPSDKSEEY
+FDFKKSVTTKFTEVFPRSKTRSTYISDAYHGFSNNYDKNKEHERIRSKTTPYKNNISDII
+SSALFRDVFLIENSEDVFIDNSNLVSKKFNTKIKIIKEGNNFQSINSQDSFVNYLNDNTP
+STHFTESQVKENLIKSSEDTDESHEKKQDSFQKSCNLENNQLFESFEVKLNSKRSIFETR
+QSYNATNRNLFNSNPQLIESKSRTTDSKTNIEKNKDFNSKLYIDLXTFFVEGRTDIXRKV
+SQSDCILXT
+>gnl|md5|3d8a367fca00fffef9b9803e69bc61da
+MGIYLLFGSADDRFNDNFMLLAPALVIFGIFYDKNIYLNKKNSLWKRFICLFIICWSVIA
+STRSIIHFIQIKNSWAFFIYLIFFTSIFLICKIIFYLTIIKINKNKIRPLEISATSLLNV
+SKIGIPIGVLVHTWRMNKLLPRREYKLFLFDLARCGRVSALKVIISSFISFGIIFPLQII
+TIPNISFFEYALYSIFPSILFSHDYITIGFISATIIIILNKSGDYKVSEKDSI
+>gnl|md5|6092856d261663c953818c8129978deb
+MQKYEEKSPLIRTNKSSFSIFSFFNSLLFKPSLSYSERSIHLSGRTLPSKFVPNVVCNQK
+YSFITFIPKVLFDQFSNFFNFFYLIVALLQLIPELRTGPLFTYIAPLLLVLSITIGKEAI
+DDFKRYKRDKEFNNKKYRKITRNGIQEIRSSDIKVGDLIEINTNDRIPADILFLRTNDPT
+GTVFVRTDQLDGETDWKVKRALGITQHLETLDDIFSLEIIANIEGPKKDIYVFNGTIQYY
+EQNITSSFNPDDSGSSVNSQISVGHLSATNLEKNISEYGADTATQPVVEPLMLDNTIWAN
+SVLTCGKIYGLVIYTGIESRSLMNTCTKSLRTKVGLLDSQVNTLSKILFLLLIITSFVLV
+FCKGFDTLWYVSFARFMLLLSSIIPISLRVNLEMAKIVFSSQINSDKNMKSVTVRSSIPE
+ELGRIDYLLTDKTGTLTQNYMIVQTLHIGHAIFHQENFSEIVDALQYVQKGRVNIEKEER
+IIIDTMDNISTFPIISSNPTIWNNSNNTLHLQNFMLGIALCHNIFPRSSIDANLSNENRN
+NSAEDILDNNNLGSDECMVDLNQKHIVYQSSSPDEIALINFAASLGLRLVSRSNENMDLD
+LEKLYLGDHLRNSMESGLYKNEKNFPVRLSFKILACFPFCSSSKRMGILLEFKGRYIYFC
+KGAESVMIELLRQKGSGWLMEECTNLARLGLRTLVFSYKIISKEEYEIFNSVYSFPCTSL
+LQRDKNLNSSRKILESNMELLGLTGVEDKLQIDVPLTLEAFRYAGIKIWLLTGDKLETAL
+CIAISAGLKPKYLNFYILESKYLKHNVNFTEKLLQVEELKYQLQRYINESANSNVLVVEG
+SILSLCIKYCPFLLIHAASLSPAVVWCRCSPSQKKDLVLLLKEYHLKYLKLCESNALVSL
+DDLDSLSNKDLTYDQNNGESGKNIDNSKICSVKRRINEAKSGYNRKNNKNLNMFSFDELN
+SKSFGINNFPKLAEYEGNIDEWDNDSDPMSNYSKQNTLSFVQTESKRIYNLANVSVNART
+CRICAVGDGGNDVGMIQAADIGIGIVGKEGQQAANAADISIHEFADLRPLFLWHGRHAYQ
+NSAKLAHFVIHRGLIIAFMQCVFSALFYFIPVALFQGWLAVGYATYYTMAPVFSLVFDVD
+VNRSTALLYPELYRHLKAGRVMSTKTFFCWVWKSLYQGTVIMLGAFVLFKDNILMNLVAI
+TFTSLILSEILNVVTEIHYWNEVIISSCIISILIYFASFFLLESHFDLQFIFTFIFWGKI
+CVLTSISWGPILLYKLIKKTIHPPRYYKLMQH
+>gnl|md5|ab5fa1d467a82d717aa75293e816a6fd
+MYMEEGFLNIYNKECRFCFGVETDHSPLITPCECKGTQAYIHLNCLYRWQRLQINRPWSS
+RFCSVCLHPYSIPRNTHFVFFQGSRIKLFYCGIFSTYIKLIFAVFAIANLQVFSDLSPHL
+GNLSFFSILGFIFSFFLYYNSRKRIFINNLQADSS
+>gnl|md5|f4ae57594bf67da8252852176d0c5094
+MNSNNTFTICSELNIEISSSDAKTLKIIKKNCNDKEVEDYVVVVPPYMFEYESFCKLRWR
+DRTLRDLFLNEFRTRPIEEYLRLIDQRRLSVNDTPANSLDYIVRNGDKIKHRSLFIELPV
+ATDKVKILYDSSTLLAVFKPCGIPCHPQGRFNKLSLTKLIQSEYLSKLNTNSTYIHPINR
+LDRVTSGLVLLSKDSSTTKNLSSKVQFAHKYYLAMINESASNFISHVSQSSIEGVSIREL
+SLDESHGITSHVIKCEIGLKTLKDREGESLITRIDSSENSKYSLTYFFPLISCLDINEGK
+KQKINETDKYSILLCKPITGRTHQIRAHLKYIGFPIVRDILYSDKVLPGIKLNTSSFKFT
+DSNLSASCIYNIKDLEVEELLKFPLQKKYFGGGGSMSLDSSDGLAHVEYFVEPPIGICLH
+SLLYILPPSVPTENYLIFKCKVLPDWIANNTNLNIAKVLEDWPYWNKSILSELKHNKLGL
+L
+>gnl|md5|1e54fdf1d8c1284b7ba753a15e842ae7
+MLGRLTIEIFLSIIILFISCSTQLELDIMKEIGTNNKDFFQKEISPVAISRIIAIKDQLR
+VFSGSNTDTSIREGNFISTIMANNLKEYIGLDHKVMSGSNRGAFVIYDTNDYPFACNCNS
+AQYQNWKNASEDQNIKVECTNTINTGIFNSNDIDYCDPTNIAASQSV
+>gnl|md5|be259ad08ff4198a53212bdc4e1b6818
+MFKKINIFLKNENFIFNGSIIGYQEILFIILITTILVYFGIISVLYDAEILQNVIDETTE
+IHNRESINNINSLNNISAQRLVCKFISSFNKIVYDVNELSSAQKFNERLLKLLSESFPSN
+SIDISYQFLFLIYRKILVSKTKCLVISHLQDFSEVMFHRLKIPKHTLVLCYSEIIKLDDS
+ILSKEEKNLFIHEKERLQIIINSERDIVLQNIKLNILRVAKKIKFAIEVVIFLS
+>gnl|md5|5f672308843b3b70586f9cd624c5cefc
+MSENEYNEKDNQNNGKELGTKTEQKTQLLLEESGVLNLDKPLNEIESIDNKQNNKKKKKK
+KKKKGKENLYEDKDDTYDPDLPTYSIPIQDNTHLRKVCNWPAIEFSKQTSPPTVPINKIY
+SRHEFPEGEIIEYNGSNSYRISSEELKDKEKLHILDYASLRRAAEVHRQVRKYMQSIIRP
+EMKLIDMCNILESKVKDLVAAEGLKCGWGFPTGCSLNHCAAHYTPNPHDFTKLTQDDICK
+LDFGVQVNGMIIDCAFTVAFNDVFDPLIQSTLDATNTGLKVAGIDVMFSEIGSAIEEVIK
+SYEFEYKSKVYNIKPIKNLNGHSILPYHIHGGKSVPIIATNDDTRMEENEIYAIETFATT
+GRGYVTEGPDCSHYMKYYDNPFLNENSTRLNSAKILLGGINTHFGTLAFCRRWLDQLGFN
+KHALALKSLVDSEIIRPYPPLNDIPGSFSSQMEHTILLRPSCKEVVSRGDDF
+>gnl|md5|cbf68fa71fe644b22db65353401809d9
+MTYLFIYDHLMDPFEFKQCFPNVEFRFFGIGRLDNFKINWIAKGLPFYCRTRPTLMPSLN
+TATYGVIIEINSYEKKMIREYTKYLPNNLLIETNVVIVKLNFENFGKNSQKNILFSNSGI
+RESKNQSSFDLKVMTFFTESSNMIFDSTFTDFLLEKQDDFSNYTYLIELSKSSKKISPAL
+PSENYINLITKVAKFYKLPEVYIEENLNLSSKQRLSFFESIVRKIALKYIYLITKFQIQG
+IGVGIIDLLWELDPQDPLVFADYGKINKGIVFLIATFIIMLLSPILCFIAFFWK
+>gnl|md5|149e0611990729c5174251dd8e0cfc82
+MLINNGEGQISIEDPTHRVKIVISSKTLFGKGIYCFNHFVIARGKMNKITQSFHVDLMFH
+PPIQNIDKNVANEILSNLFSSINYTLLKSEDREKNIKNQSLNKTKFFRTTKYLEDLKIKV
+QVSRNDYWVIFSDIVLTSMRVIENLRKVFSGYEKMIKDSNINIGFILLGNFINIDFDKNG
+ENWTEEKICVENEHNFSNVNERGRSTSLFTFNSNSRENHFKNSQNNFNITRKGFERFKNV
+LKEFPVLLSNCNFFIISGPNDIGPDLLPKPPLSNYYASYLSKVFPDSKIHFLSNPSVIDD
+SDIKMFCSRYSLTKELKEKTLFSYCGTKDVGFTTQWNIEPETLENIIPQTVLGQQHLTPT
+SSNVMPNLDYFLFLLPTPKILIIGDSSPSYSVKSMNQTWIVNPGSFNNTCSWVQYNVLTD
+SIDHVWL
+>gnl|md5|54d84c30cc1e2df5189fd1ac4c62f3d3
+MSSDILLSDYQNAKNNTVIETSPVDILTNHLVTKVEFEQVEGQREIRGNKNQSTGFPFLR
+NANLGGKFNYNKMGFQSALSGKSVLNAKCIILERVMLKNQYSDFEYPFFNITAGKLANEF
+GIENGIKPSKDLIRSIFAKRICLNDNGMIILSSGAIHTPLLLYKSGIGPLESLQNMNIMP
+LLEVPNLGTNIVDRLLFAIPFFFKSDVFTNPFVNPIMSSFSKTSGNCGYSCSTINIESLG
+GGRTVEGTLYATRLIFPPRLRNNIVTDFVIEIFKKCAENYPLSGGVPICLILQYPLECLR
+RSAAVFYFTSEPKSRGGINVKNDGKFELDGNYLSEEEDRENVIIGLSSVIKMLRSGRFQN
+IAEQGGYSSCPMTVLNGIIGVLASARTERLFINKPLSPDFMDELENVYNIILNYKNSIFP
+DECNGVSDPRDCLERKNIIFEKIATFPPILPDLSNKDEILRLAYNIGTSIWHWSGSVPLG
+ELVENESFLLSGTRNLGIVDASLLKILPRINPVYTIMSLGRYAGTSIINLRKKNQENNER
+IYS
+>gnl|md5|37477b0001eeeaa04f24d8aa96ec3cf8
+MNIMHRSNVLLYNIECVLEEDKFLEYAFGTNYSEMLVTFDKSIINIIAYKKILHSLESVK
+LQISSNKELKDDYLGRIEILKLKLEDKLNVELLGNENQSQNIKNLSSHLKPKKNIYEYLE
+SNSTKFAEHSLESPPTSKNNLKPENIDNGLDIKVINEQFKDELVELAEEMKCSAFRFQEL
+LRSEKKVSFSP
+>gnl|md5|bc137496c9f11b895d6473ee27b56a1c
+MQINYLIFSVFSALLLGLNSPVYAITTESNECVANTKSKSENRFRRFLDGLNKVELKLPR
+ISRKNVISEYTVEDLVSKLREVEKTRSNTKNPFKKIRCLIQESNIKKKINSLLKEKNEEE
+KFEKFEEEFPMDYSPKVLSEEGSISPYIPVVVEDYKDVEVASGTPIRNDEEMQDEIKYLT
+SEDADQSVSGELDDLADPITSETGNENEGTEDSVTEDFEKKVLEDNLEDYQTKDMDGESQ
+SNENEQQTDLDLQENADKEEKGNIQNKGRLRNIFKRKKLTASEKLERLMSLKKNIESRIS
+SSKSKLLRRILGMKLKRVNNKISKITDAAVDTVTESGEIDIE
+>gnl|md5|f3e11319b5b6b79cca5ef813766ec640
+MIVEEDNEFLEDGLYDRNSLNASRKVTEKSEVDVMNINSNRSSLNTNSGSNTNRSKQSKR
+NKRRSYRK
+>gnl|md5|e137977364d4c33ab0460a474bc9a3e3
+MNSIKLLVESFISSGDICVISKSYCPYCIKAINSLKSAGYSPLVMQIDGRVDTKEIQDYC
+RELTGSGTVPRVFVKGRFIGGCDDTLKLLEDGSLSSFVETI
+>gnl|md5|01d2463ec1498e72eb149430ab6defb8
+MRKIDCNFILILWILLLTQLIPECTSSSLNSKSEDLREVNEIDIVQEGSNVVVPTHLIRE
+YGYYILNDNGFSSNSLICEFEDENLQLKYMNFASTLAKVTSKLLLNIKLTNSNQYNIYNQ
+IFSRILHLESEDSGFHYFLGLKNMYEQLKYIKDKEFIFSEKGLESEIKGSIESLSKAIDS
+LSEKNDQKKSEFCVSLYLFRFKGLRQIMIVIRGLLSLIQTEEISEINTHLDPQFKKVFDL
+ITQNIEHLGMYKSTLLEINIKLEETLLGCLDAIRNLNIPLFGENSQDNQLLDIISKSSXC
+LL
+>gnl|md5|7da19c4cbb538fa06d6f8187c07787e7
+MVLGFPINKNGKLTKIRMVGKYSGFGGETPVSFAIVDDKQFQQDSSSLNKIQKGLFQSAI
+SNYVSIYKNLAPLDSSHRQNREFVWIVNEKSHILYMLLLRSKIGKASLALKELGLIYPVA
+DNAQNEFQISFANVFFNSISRRKSLNNLFYDVIKNKLIILNSSDNMRSYYDIGFSELESD
+TQLFSNISISQTSILDIPVYESDISQATESYLSDSLPLFCSSRRNYYDNSILLNINENFS
+YSELLSYRLLINVINPKILLKIRNLPSQYALRKIFNFGKELLLDFEKLRISYNLPIMNIN
+DNIGISTIRENMKLFLKGMIQYTTYSQLERFSLHISPDLFRYKLTIPTTNNKSIVKTKDE
+VFQLNGITYFIVRYSEETIISGLSTLVEEVLNGRTNIVFLMQGLDLKLLRPGDLPSDSSP
+QIHLMKRVPIEFIPSERMVRIYASSYDTENLKLVYGIMSLYQGFDLSIVTDNEEYYYFNL
+LCWDSNNGTSKHCSYIQVFRYLKSNIFEKLKLYQNSLNNNISLSLIAEEGEILSLDFIGL
+SVISRFAGAVLFKADKYYELFYKSEQYWDLCSFVQEFYKFSTDLPIKAINYDPKIKDIIF
+KPDFSECPIPEIANLNIYANLPHFIKHNNNPQESGFVFTLYNSIRYQTLSILINYFLSGE
+KIFIKHEGIEDVSAPESILEILGYFDIRILKDSLISLFLNEISLKRTEVESAKIVSNQIR
+SIIPNSMVVGINIRNERIF
+>gnl|md5|2bf2ddd9b552c27228180e7aec7d9701
+MLKLDLGRKNIVFLYIILEIVRLAYCSIQQNPDLNQDGLNFDTEILSEADKLIELLESAI
+PNVAHNCADGLELSPFMDIQSGDTLNKENFSSPQAEFKQLTKPEKYAEPIDKRKEIDYGA
+LFNCKYKYPERTYSKMYLGHLKTLKESGKMHRRATVFQDLHPSDKLSYLQKNPPITGSIF
+ADEPRTILRRKKPNLFAEVTKKVEIGKGEPRKSEKSFFDMIDGQKSKLRKMHSQDQYLRR
+FISSYDQVLKELKAKLKSIKDKDSGLREKRLQAISEKLSGYKRLVDDGKSILDDLERSQV
+QLLNTPLLSQRAVKSRVFEQGTRIENLYSWYEVVVPPKPQYCSTMKLSLNRVGEKGPASQ
+SESKTDLETSHPDKFNSHLSVLSRGPKTRPSEIKQNKFRCKVETAGAERSNSDSKENGSG
+SGMLGGPIQHSTEGMDTYRATYVEVDDSSDEGDTNNPIDPPNANSSVSNILKLLRLDIDL
+KTSEEAGNRNQNNTGDRYLAKYISRWKGRVSGTKKSSLGNKARDSESKMAGGSSGHSKRG
+AALHLACADDSSDLGDRNDQNIPKNIFTSKAYVLKLLRLDIDPETSEEAVNRNQSNTSDK
+YSSKCTSIWRGKVGGTKKSSLGGSGSSGSEIFGGSIQNGAEGADTFRATYVEIDDSSDED
+YSNN
+>gnl|md5|144b35bc791086737c22bf88b565cee9
+MSKRVSLYIFIFFVLFDIFATSQYEISPNATVSRAEVLSFENSEISLKELASRLKTFLSV
+EQIIYLVQEIIPENLKLVAKSSEYDYFDVSESELKETYEGIIYQNLTKVPIYQLVHIPEL
+LSNATHLRKIRNAIHSPRPIRPRKQIKGRNPSNIPGASPYFVYERVIEIYNSDSDIQTDK
+>gnl|md5|10fe9d99f497a838eda8da66f462b5c6
+MLKKTTGNRKEDKLESVYSKPPFSYNSNIVLRHLPKINEKQYSNTWSLFQKDDTCSHLKH
+FVLNRMVLFVAYVLEFWRKSRNSEKIPFKSITEICIGFSGDYLNFRPKASDFKLFTEDWL
+FQKDEQTLYSNTLDLLWNNFLIFENSAFPKNSEETESDYLQRIYNNALVPEPLFVHDWKN
+IELPIRIDIAEFTKLLLHVQKSVEIFSTLDDITLNHVTLVRAFLESFFEETYQFPIIISE
+KDILLLLERRELEKKPLDELFFEIMSSKSDWSWIKHETSSHAILMLLEYLKTVKKSVEES
+IKRTPTKSDIYSAPRAVLAHGKWLIKAPYPVFYPSTPLQKRALHGLPKFLINKARYIQAY
+FINAFDRVLQFDLSLHLADIVYSLTNCAGDDKKLVELLRERISIQNGQDFVNDNVVREIY
+NSCMSFSFYKYLLKGALSEEQAFAAPRVFYKPKFGWRFFPPNVPDFSRLLVLSKAFKVES
+ENNVFDRDSHKLLDETNSNEIVVRPYTWTTLKGIYEQKKLEIWQLNRAISMCAYFNHWIS
+YKFSTKNSRDLQVSNCINAIYRLRSTNKSQSQSEISQIFLRYLGVPFIKENDFNEMLSAF
+TSFECVGKPNSMSTRQWLMNLYRIPQIQENNKNSLSEEFESLRFHIPPVFGEQKTIFEHG
+QPQITSINADTPEIYIPMDLDSDSLNNLRELFEKFTYRYLSRAGIMVETELEALNFSMVD
+VFKIARDRKLSFSEALQQHVSDIGGNVQRNIFKKLSAAFFRFILLKFASSNEEPFVQILR
+RISISRVITDGGKLPFDIPLGIVSGRLDLELPYNSHSFGEVNFARLVVAYMNEYLIELFD
+LRNKILSDGTVEKNVLKEFPGFVKENCVAKSMDIIRKGGIDLQNALDQSCSSELSWMSMK
+VLRMLVSGLMTYCKLNFRGFPIEKNGRSILDFSRENLNSPIVLFDKYFKTWTMQNARKNT
+REGEDFGSKFSTLESIGIVDQMTGTIISSNFNFCSEMNTSQINRLLIKLQYYKHCISENA
+ISNIEVDRLLDLNIWCLALRQKVPDMKKTYSNMLFTYFGISGAVKESFEILEDSFEFLEE
+SLLGKNSLVSIGQWAQDFYSSHSKPFSQFNSLVKSDRLFCPRVITEDELQQLQIIQKDNI
+FNRVEAFQGFSEIFLREKYGIIFESRPIIVALLVDGFSIIKPSNSNISLIRSMIPIASEE
+IVNSLIGAFNSFEANLLKGGLTSLEDLYKNPICERSQGNWHFYIELETINRADVLINSKL
+IFSELEINRFQNIVAFLNTALNYKYSEKMLGSYISFKDIATLFKAEIDLSSFGHIINYFH
+RTLQDDLSFSPWLTVKALKGIFQAFISWERIEIFKVSPTYSKNFGLVVSSADMAKYNNSP
+VGLINGKWHWYTWCKRPDFNLIHREVLGDEVVHVLTPQERSLYGIPRIKHKFEIATLFIQ
+YFLQDVLNILIPFKPDVTMKIFKGETNLSPDSVEFLKKIWEHYKNSFIYKGSLPKHDLFH
+NPIINVVNKQRFFPTAAIPRFDNFDTTLIPPSLTEIENFYPGIVIGSKFEINRLITICAF
+INLSFEIFIDDSTEKDDIITPIGLYDILKDKMNILIIEKQDEITGLFRQWQFYSGTQEKA
+LHLKNTLLNYNNFEKSMLDKGWDFSKLYQKPIVFAVQNGYKMNFNLKSYIPKVKNRV
+>gnl|md5|6df00ade25e62a76d4c89b18dcb3a07d
+MLHKQIKNFISIILFYIDIFQSFSYVNLTENQHISCFMQVGVHRKFVNPYRNKITVGPYG
+QEKTCKIACCSKKFYCATKQSSCSETKHSGMLNCNCANNLSSCSGCKGSSCTYSNSSNHS
+CPKNCNSSCFELHSSAFISCKNLSPNDLCLTFPRFKKNHSKKNCKCCTQFELSEDELVKI
+KNEAGVFGKFNESSEITTESESSEIADDIEINVNKTSNSTEAKFSYDVSANLFIIFNLTI
+ALDLSSNYG
+>gnl|md5|8699972bedd65a1de830acb3d09b690d
+MDNMGFFLMPSFFKMKIRRLKCLQFILLLLSFVSFKIFMFGMANANIDMNGPPDRVYYYP
+IGFNLASLFIGPGVGNFLSIDSQVTNFVSPCQFMHPITIQFIGSYPKSGMTPIKNIICDS
+VSLQKSLQKFQLGVDTVKVVKACTDIAQVLMESETTYTIFNGANNITIWLEGSKLVNIVK
+EFNEQLPDNIPQIMDRDVKYQFDPTIFGEDVMDKVGISTYLFKATSFPFKISVDYSEVVP
+GTNSHGTNIPVIEFSANITLSYEFSKQSSGLSSFWTPPTGFGGFFPMLVPNDKFSNGVLY
+TTYTEPGKHAGFVAWGNINIPITSPFVRIVPPSRIPGSEIVCTSNYDFYYPTNEEPDGSV
+KNYPRDLESLFNKDSSKIFRNTVAVQSYWNKIPFGANWYEQGFPVGSPNSQWIETGNYYG
+GCYFNGTFPLVPSSTNSGFANTICSTQSASISDVYKTAFYPPPLEFLQYGVSNMQTMITS
+ILQYGVQSSSDSSSIFDFNSNVEFLGAYPSFHIFGATPGLQLTSPSPRLNVPFVQYSGRD
+LKAGDPFFNFNFQYMQDRFGHCSEPNGCWICSNPRVIPWKTEIIDQMNFTEFCASNLTVI
+PNSRMIALKFYYGNFEEDIPAQIASGFQSCLKSVPDRWIPVGLNTTEFTFKAGEYHTNTM
+FIYNTLSNDTCCSPMNTYYYFQHYYTIVTDIYQPIQLTQITPYTDPYAGGILPGIFMSRN
+FSYQFYMDVYPDNTWTENSQLKLRSWLMCPEIENIDLIVMPESLLLGDVLISGGKVGGSV
+KIPPFVLSKFYGSPTYCILRAFIFVNDIVEKNNIELLKAVSLNEYEKLNPRVYRSDEGMH
+EYAQWIFVNNGFLAKSSNILEPHPGKTSISDALYTPVNVTHHYNFTITPFLFSAVALNKP
+VFSPDSQIFEMVLSGQHNRFGLRLPPTHSKWYVFTRTADKWDQGCFVECEGDMSRSPYAE
+WCLPKFVENNPFNYNLCNYTVVTTSPDISESQIEDAIAVVTNPISYLSYVDTMSLVNAIF
+SLPATFELVWGKYFQLIYETAIDSHNISFNQDYPFAQPTTLAVINRILSKHYYRERLDIK
+TSLPFNSIQRIYTLVECFLVNGLDNLVLNSTDLIGATNPLPELSPENLKILLSIYQGVAS
+RKSYTHGAQDTYSIITEKTGNIVFSSTFNQVDMNKGVKVGGISFPKIDMKSIKPEDILFH
+NGVYYRVNKKLYENNLAIEGFNFCAKSFNTITVIRTGGYLSNYLVTKSLENIEEFPLAFT
+SFVLCTLEYEIWNLENNVELSFFAEYKEELDYSEVKCTAMKQDQSELSDELCTTERVKHF
+TNQTIEFKCGCSAITYYGLKGKPIPYIPTLSDKDLKPLFSKSRPNILQPYMLISNPKLST
+YCNDFLPIIIQLKNIPDFVPDESLSLNFKCVIPNSAYSSLEFCTKFENELQYMDYSFSRL
+GQNINLTYYVKPDIIQRTALPIKQSFWRPLNQQDELPQINGVAGVTVLLNITLELSKLGL
+GNNLPDLFGYSTFDIITSIETSTKEQASEIGELSTTYIPSKLINFPGAFTKSKVPVSSII
+EHVIPYSIPYNSLENCPSFLNNYFSSNYLKSIEFEMSEGLGISKDSCFNPELLSSIGSCR
+ISITNEEYIKGGSFDCIKSTSRKNLEMNILEQPISMINVTKLSTKNSFASSKDKVIFHNE
+TIQPSINAYFSSIVSKNHPKITIETGTSKTIDQIVSQSGYCDSIKTGCSSCRASRSYQAD
+FQFQNQEIRYYCSATSDENQVEDLTTGLLAACRTDGSYWGQACSFQQSNATLSGNATYTE
+LTLIPQESLTHMVIAVGIKSKIIDAIECKNFYLSMVNKELPLQIIPHKIPSIISKASESL
+LLAKIKFIGGNEWDNVQGLKFLSFAYFENTGYVQLKTTPSVYNLKDQAIQNDLIAVSIKL
+NITETDVNPRDGRLSVILLVIKQNSNEIINENKLNIIVKRSNIHNLASSGDYVSYVWDDL
+LFQHDFSLIKIKGTTENKGPREIIPINFKISNLAGMSNWKYSILATLSENGLDNEQNNKF
+KSNALLLSFLTSNIPQYLRLPTNYESWKIHLIIHNQDNELLCGIDCSEINNDAIDKHLRN
+MFCVKSSSSKCNYFIFQKSKKIFEVGQVFLKEDELKEEYSNLLEYFLNYQKIGTLNDRLM
+IASILSAKLDFLTIDQIEKFQEKLIEIDPNNKDTTGGNSVMILYIFWRLFEFSYRNFDKA
+LPSHSFDPERLFRIALKAECGYFEGFKNLIVDILDFLVELRLLSNIEADTNLFGAFSVNQ
+WAMNNDFGSQIEIKGKMTKLSIQSSIFSDLDLHSGAAIGNELVIPTLDLSNEKLENIDIS
+LIKNIYFKLHHENVDYQEFWGRNLFINCHDPRYGLTIIKPPLYDYLFELANKIQQDKSFN
+GVFQKVYDVFISKCGYEYRLYGIENKISFIVSPEYTPSVVLGKRLSYQCTYKGKDGSWYQ
+NGCETKLKQGKIVCSCNSIGEYGLITTYQSSLTEVVVKLSHNPGSIQEVNINGIIYKVNN
+GKFYYNNQVFDIISNEIITIYPDRVTVGKRQFPLENYFNYDVVTQLTLRQEGVLGTISLR
+SKEYNVDIEGSSIVHDGFNQGNYSQNSTIIII
+>gnl|md5|b6579534cb945da296262e7487544065
+MESYSSSLSKFLPWIKTKRSDQILKLDKKLINMSFSDTFEMVNFYLDRFKSEFNLISKNL
+DILISIIREDIDEYCYDYTELVINEIKGLIFSTPIFDRNDLLEILREFFSMNSDAYLGST
+SYTNYDFACKKPVEETKYCSNNESSVASALYSTGLSRNNYSKSLLCNLWFRSIKIIQEIQ
+NYNFQKELLIVLKTISKRQQFIFWWYITSNNAHYNFEFVSKLFTERRRIGTLQCYLTCME
+IEFKSAFINNGLKT
+>gnl|md5|246023caa614d60655f53cee0fccb1bb
+MNTLYTSKFIFFGVFTVLCSWFPFTSLLAAPGVCSRSFEGLIKQTNGGINLILVCTVILI
+GLYLFFSGIGLINLSGCLLRLGMPSDYPNAVMRAFMYSQFRSDSNYSKSEIREANVHLTV
+NSIYSSSNVNRSVESKQNIDGYYNTHILTLDGEFKKRLKRAMQTAKARLILAIVSVMVVI
+CVSYASFAVFEGSQIFLEPNSIILNHNGIDLLGPESEFGNTCLLLIITAISIIILNMNTC
+GSFILCIVSCIHFFGLLLFFTLYFINFSNEAGLSFISFESESIQFDWDVHIWGFVGGILE
+MGAFVISAVSFHIILPGAFKLFPDYEVKSSRIWGITISLILFIFFCGISIILGTVPSFPI
+LPYGLEPSSEGIGLAWRILESKISSNSFFSIKLLKRVFLLGNFITWILFVSIVMKCIDNI
+IRSISNQVECNFESFSPNKNSLSKRYFLRSAKQQIYGNETNNTRGTCEYLSNDKIEANKV
+FFWTIVKNLKALVNRNRILDFARYFASSASAIGIIFFVHHKLISEPYLIPIFRSLSASIF
+SIIVLILPCAIFWFVFYSEMVPQSSSNYQILNLIFLGRVSSRIDRNYEKHRDKLSIYNDN
+CNFSFNPLTFGFFSITFPILLGCTILVYEISKFASLCLGLRFNS
+>gnl|md5|8c8943845de2d8782f0ab227945c1b5b
+MYEYTNICSQREVRLSIFPEKYPEKRKISEEIQTENIELQTDWSTKCCCTSRVKFSDTDI
+QEDATIEGEGNSGGQIIDEIANAISNYRRDSVLNTISEFEKKLLTIGMAEELSPENSDTE
+GSEYGELNMRRHSELAFKPLVLSAVENRRATAPDNMKRKIIDQLKIQINEDNTEELRSNQ
+IPPNN
+>gnl|md5|443dde9a789d83b0994bb32af6326b85
+MNSNQVVKAKQLVGVVTYSKNNRKEELYSSCDGIIKEVLSQGFHDFEATFFVIYCDLKNP
+VLSTYFGYSIVPITEKNTVFGKFEDSPAKKEINIKKNKFNDRNTRLISNKEHKKLYSEQS
+TNHKYNSSLEYQNRQSMHCVGKFQLDSICMNEGDSASSDNSENPSNVKRVEFLYKKCVPN
+KSKPADSSLTVKLKAYRKSLEALKQSVANITDFSRVGNIKLEDEKQLDFDKQKNLVSKMS
+TLSIKYRIWISLALTIIILTLIALLRISRYSFTHST
+>gnl|md5|e37de3eef2956380cb06f96d97b519ea
+MIFITTAKKDIRTFPKALYLEFVSDKFGNLIVLIPGVLFLFQNNLLYISLKRLPAALYQV
+IYQLKILTTTYFSVLILKRKLSLTRWFACFLLIFGVIMIPKKSKHSSTERTSGLSEFIIG
+LFAAFTSSFTSGLGAVVLEKVLKDTDERIHTGNGEFQTTVWGRNVILALVGIIGGVPLAY
+FSSKDQIAQYGVFQGFSPFVLLVICLNAGTGFVVVAVLKYADGILKCFCNALSIVLITLI
+SWLFLGDTKMTPRFAFAATIVVCAVTIYSLDKVVPRKFYSTELFSSKLSSNNTNTFDSTE
+KTEQFKGLEKDPEKSLLIQRDTKT
+>gnl|md5|5feecff30f859031e046ac03a689b30b
+MKVEQNVITTEATRLLECEAFKERKMFEIYYSNGLYYLAIFKGRYNIQMRFLTLILMSVQ
+CICVVLCMKLSVTYPASDGKQYLTPVAVVMVEILKLLTSLFMIFQISGGNSIKEFIYALK
+CEFLHDVRGNLLVVVPGILFLFQNNLTYIAIENLPASIYQVTAQLKVLTTALFSVVLLKR
+RLSTTRWFACFLLFVGVLLVQKTNIRNKGNINSFQLMIGFLASVTCSITSGLGSVIIEKV
+VKDPDDSKIVSSDIENSTKLDNLIDERPNDRVQYKSSVWGRNVILSLIGIFGGTPIAWIT
+CKEKIIRDGVFQGFSWLTILVIFLNAYGGFIVVGVLKYSDSIMKCFFNALTIIIITILSW
+AFMGDNTPSIKFFIASTIVIIAISVYTFNKVFPDSFYAKFLRLVEFKNRNTESH
+>gnl|md5|3adbcfee6572765f59b7769c0bd8983f
+MDNIFEWLLYLQKCGFFIISTVLLFHLMLAIFYQIRTKHVNKGKTGLFQIVGLKKSFFGE
+FLRQIEIFFLIFYPFAFHVSVVAVMFYKSYTQTFESSFNWHEAVKIYARSLLTVIFCIVF
+LKLLKAKYGSFEQIFLVPADLSDCKFISISFPGSCRFSKNNIWCKLFGNYYIHILEKFPV
+TKLCRIIKRSEPINFFGTETDRYFEYRREKYWWYENEFTWSREILSRKAAESFPVENTNF
+LKERDQVIESFGNHDKDKILEFVGTNSLGSYPLSLWKLIFSEFTSVLNIIRIMTLLDALF
+YSFIVWPLCWSIITFYTISWSIIKSRRNYIETEKVLTQHDWDIYRYLTGPYKPHSYSNAG
+SSFVFSKELFPGTVIFIDKAMRIPADLLLLNGNVVVDESCLTGEATPQCKTGGIQIVPSE
+FSLDCDVLSNSRHLYAGSQVLEVSSTGITLAMVTRTGSATLHGTFTSGHSNGNDEHGFTE
+GLPPLLTSNSRRDFTSESISSLGRHCDLYKSIKRNWNFTPEPLWILCFMYGTFIALTDSY
+TLSFEIGSIFFIVSTIIYIIPFWSTSSMSLYFNNAIKYLNSEHILTTNPKKLNQLLLVDT
+ICFDKTGTLTVPTFSINNVHIYPIRNNTRDHLMQLAMASCNNLIFEKAGPLQLTRKNSFS
+CPSGSKLEQCLYNYSGFCGYKVFTFSSERLFIIPLCNRKTFLERVIELESHLILDYGASF
+DIQQLDNVYPKNSLEYISAVCDAVEITKRYPFDETLRSQSVAIKKYSIESELSSNLYCIH
+SISMLFMKGAAEKIVELTTNYDDCNDGTSFRDWSNDILENQVAGSYILGYCYKVVNDQAN
+SSNNTPSFKHLSSSFIPLGLAQLHSPIRPEAKLVLKLLKNGNFRCPIITGDNINSAIVVA
+QELGMIFNSFASCYIDLENNLVWEIENSKKKVKFSLKNKNKIRTLSGIIPQQIIQDKFQI
+ALSSDAFKLFIKILNLETYAGYKRKAPDELNELTIFSKIIYNTAIFARFTPELKSMAVEL
+LERLGMTVLMVGDGPNDIIALQKANSGLLLTETIKCNGLVAPFISEIFPYGLHSVCRLVI
+ESRGVVFAFVSMYQHIVLLGIFFVTCKTFLLWQSQAMIPAMAWLFIDIFCTLLPLLLFSF
+SRPKEYKIENLNTIINYPSHDITSSHYPETCNSDCVNTRIKNLNTYAIDVNSDKYMLLVD
+NESPSALINKQIYNIKSHIGFHTFYTAGFLSLLISFTRFFCYFLQTSSLRSPKAWNRTLF
+QVQFDYSGLPLAH
+>gnl|md5|5d44cb14e9103569be048ff30176adc2
+MEDYSREYSEVLLQLKELQDSEAFLEPVNWKKLGLDDYPDIVKNPMDLKTIGKKIKANFY
+TKAEQFWADIDLIWYNCQLYNHESSEVYQQSIRMQDAANNLRDMLFPSISKKIHKRKYEY
+DSHTESEDEDSSNILKKTLLCQRMSRLPPELLALVVRHIYSQDQQIIQHSGEHKFSIDID
+FMNNQLFSTTSALTKRLLRLQLS
+>gnl|md5|d31027763e8532c1d8bf937f4238dee1
+MVAVVSSDSHKERQSNRPRFITPVSAAEKSIPVVPAPDEKTYKETTEAIRQVLNEWNIKI
+RGLTKMINDRSVGREAFDRKKSEFQAKLDEYQKCIENLEEERKLCMAKINEKSKEGREMK
+ANLQSLKKSVGYKSEEEIEAKIKEIEYQLVTSTLSLKDEKKLLSQISQLKQSRPIVGRFA
+HMDASASSFEENSIIPLRAKISSIIEDLNKFRKQKKEVFDKLRALTADRQKALEPLRSLY
+DERSAMQSKVEEQHTKLRQLREEYDREMKLFMEYQSKLRALRSERVKEEKILRDLYRQRD
+DLRLALEQEDDPPISTEMQLVQQSLSYIQKLMESHGVIDKTSQSTKDKATLSDESKNLSA
+SAIKGRDKDESVLLPKNQRNEEYLIPPKGKKNKRRQNSSSNNSSSTHKSLVVDFATISTF
+EKVDLDVPMTTDDLPKAYSLLLEKHLKLKSEFDEKFANREKRKEEILKKLGDIELKITEA
+GGILEDAVSSPKIEE
+>gnl|md5|9a6b34528b31ae374fb82bdb4c44807e
+MVKMSSRESDFKVYSRRNRSGIWRLLLIRLSETNKEIMVIVQTTNVERIGVKNKIVDLLI
+EEFIDKSFEMDLMGYKIKSLYLHQSDSIVDTFDIGKLDLLHGSPQISFKIRNTELFIGPL
+SFFQTNTKGCETLYNEIRKVIEIKLLENLKKNENLKKKKLIILDICCGVGAIGLTLLDIF
+RDLGRNFGDVELIGIDCSREAINSAKKNAENIGIENAKYYTGTAESILPNFLENLPSNNL
+VIAIVDPPRSGLHSSVIKSLRKMAKIEYLIYVSCNVESLVKNCIELCSAYDPHTDQQEYF
+PVFFPECAVPVDMFPFTKHVETILYLKRYVNNSNSSALSKSKTDNISNNPLLAR
+>gnl|md5|1fe309f72bcd2137ef3a5180d32f7c39
+MSNVLTCKALKILCGEDIRYFELAEVAYLARMKKLYVCLGRHSIYLLKRNLRKVITGGKL
+KYSQIEGIYEDISKDTRFLILLDNERDERWVDDKLIINCLNRHVLCNFLEMAWKADHAFR
+TGKYYDFPRFGINLNEIRNGLNISKSKNSSINKIKSIAIWGMNSREKNIKGRYETYKFTG
+ILDEKTLLAIQKQLNLLEEGYTTTIFPFAKIEEFQDYKKYIFDGYFFFAKQGFENKATQS
+HNSQTGSYVSYNGVEININVHPQIFLNQKKPNTNDTQTRENKGAETKGYSNIGSNLYNVA
+QEYVRFLSNMSTDKTYSVYLNGQYNKKMNLSDDISTWSCWEIFIKTSRMSIVCIIMRRCY
+IPPTLDSYQDISVTYTCSYKDMKYFNLTDRDLLRECRLSADSISPISQHHTLYTEFIQSQ
+LDTLLFDEFSYSWISTNIKLHPAFKVGARSFLKSILKMLDKANILADSELIEEIDLLEKS
+GSSRYDQENETKVEVFEDPMACIHEMLSQISGVDKFSRSIIERQKLHFFELRLARYLSYC
+VDGGLLGAKFIIEDLVSSVGMANRNVDSKIRQVLDYLLHVRSKDMSTDYCQLKLVNLLQN
+PRFVRDYCFVPSVMARFVNSGYCARLIPAGKETLYIEFLMNLLTLPIKSNFGQRSQLRIS
+ILQQVLHATGDSKKRDYYIQMVPLLVEIFSGNELDGDNTGSKYAGAALLNLCFSNDILKS
+ELVKAGISSAIVKKLQKRDDLQLTKICLSLVVNISKDPSHRQTLIAEGILPIIADSLHEI
+LEDFRPYNQDLVLQNKIHGQFSIYSKQNSDWDVLPIILGVIGQLSNENDIKHMFISNWCV
+LDYILYLFHNLEVYVGSNNDMICKIIFCIKQLCNSSWIVQLRVGKHCIPTLIEIISTPVN
+KKERREASTIKFIQYYSYWVPFHTISENRDSSIFLSGINGDVIFHSLLLLETLSYYHPNC
+LEMISFGIENALDLCLESYCIDTIVIKLNYLKDVVKKVSLRI
+>gnl|md5|89702ec58a0295b0720c88ebdfac05be
+MTATGKRNAEADQRRRSVLVSVDKVLDPTSEKKDASGKSGRRTAHSSKKINSNSAKSTQT
+DSSNIGSSCGIEISSGQSPNKLGHTSLAPNNAQHRKKKPDKSNCGEIRSNFNSIQNLASN
+LPSLSTSCSPTSVSAVTPTQKLLSTSASDCTKISKVSVNNNNKNRNSVIIENTTNPVNIG
+SNSLNDSNQQSKGSFSQGIAQNNAISEGQQYGQVHIPLISPMPHQFWYNHLVPQCNFGHI
+VPPPPDYFPDSKISLNTPKEDLILPGNISPHPQQSVNSTGIIGNNLGACAPAIFNYQIPY
+FQPYSLRSYEISTLNVINYLIPNKEFRLKVSSVVNDLRNWLEQSKIPLLVFPYGSTSTGF
+ADQFSDVDIALIPKKDSFDKAKYGDAPISDIFTKPPGLILQELLGLLQSDSLDALDTLSK
+NKSTDSFDCMSSLNNENKLKGKGAVSLDQSAEVRKLRNPFTCIQDITSAHIPIIRMLHIH
+TDIVLDISIALPSTNNQEEVKDGQTSGSLCKIQKANSLPIIQSRLGILTWYARMDPRVVH
+VVVLTKVWTRFRGLRNTLNGFPGGYAWTICVIYFFQKIGILPVIDANEFFIKSHNASKII
+FKDILEDLNSDHIQSRCKSSENNLALTSIKGNYKKGKGDIYLQNGIEKIEGIPEESYLDG
+NFPSLVSELDQEETVNYKDDIEDVTNVSYDTETASGSAGVAEQASSSDSSFDSEPDKGSI
+EKDGVGYKMLYLDVVKGGKFQYKSDLDEVKGGRAAKLSVKNRYSISKDVNSEKTLLNVKN
+LNLDKPPEEHETFGESSRSSIGSTACTYSLSPGILSSDNICINCSDSKYSCACSESNMAS
+VASVGYSIDTGYKNGTKQSESNANKEYGNCFLADIKGYNTHSNGKVTNDKEKSEECGSNS
+VRDIFDIDELFSDPPTLINNVKIFEESKFLKFSQSHTLFYRFLKFIETHLWTTVIDISSP
+DIINTTIPGICCDIRNPFPGPPACRPIFDENNKKHLRNEIQRAIQIIQSPFGDYSSICGG
+YLNISAECSKGPFTGTSGIGSGILGVGLGLPLSPSNVNAAKQRVSSNQYFGPFEAPPLHI
+IGYNPVISGYDQNNSNAIFPAQVPVANLYTDSPPHLILPSVSTPLHIPPPPPPPPPKIKQ
+SSSILGVIRGNSFESIKHANST
+>gnl|md5|fb9d9de5efde9d71d7b6e9e27f1d812e
+MQSKIVYNTDSMAQIEDFSEKRKERTLKCFIKKLIIENFKSYNGRHIIGPFSEGLTCIVG
+PNGSGKSNLMDALSFALGLSSNDMRSTNLKDLIYRPEQEGGPVDISQSNNTVGLSQKGSQ
+SNLSNNAEVSLVFTLQFENNQEIIFSRRILSSGASRYLIDKNVVSQETYINKLADYNILV
+KARNFLVFQGDVEDVAQRAPKELTKLFEQISGSDELIEEYDRLSNEQSLNQIVSHNSFNR
+RKLLEAERRELQKQIEEVNEYERLEEQKANNRLELVLFQLYCNENMGGKYFDERQAIDNE
+ITLICQNIESEKQKIRDSESKLAKDNLEWNKQYNDLEKLEQDESSKKNEIIKYENSIKRN
+KLELKKLQKQMENMLTYKQKNKKLIEEYEAKTQSINNELSNLKTQESSEFIDAISFDLQE
+YIECKKKADIASSKLREQSLQIEREIANKLGLIEILEKENEEIQIQLTTSRSLLDSISAK
+INEQEEKLGHSKETELELNSQIFELESNFNGFTDKIAKLSEQRYTFNERIKDIDARKGEV
+QKEIESRKLIEDMKNYINTGMIIGKEENIVFGRLSDMCHSNNKQYNSVIDSALGKYSEYI
+VVSTWETAKSCICWLKQHRKQPMNFLPLNSIKLDKRGNSTVMEANLRAICNNNKSMRSLA
+KDNLHSSDERILPVLEFCLFGVIFTQSLEDAKKIFYTEAPRLGIIPKVMTFDGEKILKNG
+NISADSSRNQMNNKGFAKEYANLLSKIETLNEEICRLEEAESDGQRRLYRLKENLKRLKI
+DKNAIELKIEIYKKNKNEKSTGISLLENQFKEREEEILKHRSEYESLCIKLENLRNEIHD
+SDQRHFKQLSKKLNIEDIASLEQESRKKHEEQLQKRKKLSSRLNIIIEEYDSIKKRDNTL
+KEKFKEKEVNLARIENLIIEECKQIEKLNEEVSQIEFKQTNLKNSIKSITSFKKEIQKEL
+EAKKKALLELQGLCTSKELERSSKNEELEALNGELIILLKNIVFENIKIPLISGEYDDIR
+KYWEFFETSGKNKSENHLEYLEPPMIQIDYSALTEGQKNSSKSLRQIESEVSRLKKNISD
+ISHKLESLNPNMKSKGKLKEIDAQLEALLEDQRDIRKKSMEIDKSYKSLRKRRTESFMKC
+FEAVKEAVGDFYSRLTCDDSNIGGQAFLDLDDTNLEEPFSCGVIFHAMPPSKRFRDIQQL
+SGGEKTMAALALLFAMQSYHPSPFFVLDEVDAALDPRNVQSIAKFLKKASFQSIVISLKD
+RLFSQADTLIGVYKNREMQTSSTMTLDLRRYSQPATVILNVQKENLGYNSAFSRSIEYDS
+HEGSSLTGANFFEKEFDQDIGKGQNISVD
+>gnl|md5|46fdbc27c709a374b2b7eb35b380e2d8
+MAANGNDLELITSILSKNPLIHRPDIVFGKLSDGLDYCIFNSESQRNSFHLNLVLNTGSI
+HEEEFEKGFANFVQQLILTELNKELLRIRTEHLTNITSSTDFHCTIFNIYNEVENTKLND
+SELRATFFDVLEIFLLTIYKFREKLSSSSDIFSDRIEEIKNKTFDIIEKSDKSVANYIEK
+QIFLQFHRDTLLPKRWPIGEKSSIENITVTGLLKFINKWYLPNNMCLFIVGDIPASNELL
+ANHLSSFVSGIKSLNLEKRASGINLYETSSSHNIFSVKERIGHKTINNALNIIEKYTGSD
+FQREVVIQHPSIDQVSISIGVKLEICPLVDEGEIFMNAVDTIISNAIHTKLLNSLSQLAC
+DEELTSISWDFYNSSRENCGWNTFSIVSDEKNWRAVFRLGIQQIVSICNTKMSMEEFEEI
+VLITISDYKKSAEEELGDDPKLVLDGLIDDWLCGSIPLSKKQEYQLFCKVVDRINPEIIQ
+CRCKALFSHIIYYFDENDHYNKESSFTGCIFVSKPLHNSFQNSEIDPENSINTSNNICKA
+PESESEFIKSLLEEYKACVYKDLELSVESAKSYSNEVFFEKNSYKIERMSESFEFGIWDA
+LKASTYITIDKIFDSIRTNFNSLVGDLVNSDESIEHLNGKYSIKELDSLAERIKFNSNNF
+QNDSYEQGSHSLPNDICDLGL
+>gnl|md5|b50d5148f630ad7bccfbc5b2c24178f3
+MPAKHDDICSLYPYTSIIWKELSRISAQLSQESLIDETNCNNEEIKFNIMADLIRLLSKP
+RLFLEESMNNFMIETMDLFGNDGIFLTSIVLENLENLILEIDQLLCNNNNKQIFQNKENI
+TKEECINLIGIIFSYVDISNSNSFPDEHELEYNEAIKNTSQNDTNIYKFESNDFQNKIDF
+LVEEPKVVTTKTELFEKVFISPLSIPASVSKELESQLISTEKLNKKLRSAFKGLKMFNFV
+QSKVFSSIYLSNRNVLVAAPTGSGKTNIALLAILRSISDFVGINTLDSDSVSDYYKEPDP
+IKFKIVFIAPMKSLVSEITRKYSVALQELRIRVVEVTSDAAVPKEVIDRNHIIVTVPEKL
+DIMTRTYTFDDNTGQVNLFNSLQCVILDEIHMLGDERGPSVEAIVSRILYNVEISQRPIR
+LVGLSATLPNWEDFATFLNVNKNDAFFFSQALRPTPLEKTIIGVNEKRVDIEKKREIRKR
+NDKTSNQDSSLNKEKQREERQKDKISEQINSKEDISNISDLYNSIAFKIVLDCLEKNEQA
+LVFVHSRNETLSTALYFKRMLNIHSIKSSFNRGTSCSDNNNQEFDGSIKNLIKKKTIGNY
+FSTDEMNKVNKKEFGGNYLLKALRDCDNSSIKDLFDFGLGIHHAGLISSQRKLSEALFSQ
+GLIRVLITTATLAWGVNLPARHVIIKGTNVYDSKKGNFKDLGILDILQIFGRAGRPQFER
+LGSAYMITSSDKVQSYVKKLTFQAPIESQLSNESNLCNLLNAEIARGSILNAKDASRWLK
+YTFLVTRVKKSPIVYGFKAEEIINDPNLAQFCYNNISKCLDLLYQSKLIRYNIINDEVSP
+THYGKLASKYYIDFNTANIFRKLILEDERNSESDSCLSDFNILEIVGKAKEFSSMAPREE
+EIEELENIVCNRQVASIIKKSLDVTNVSSKVALLLIAYSLRIEITTPTLVMDSIYISQNG
+TRILRFIFELIQLSTFGVSERAQRVLEWSKMLEMRIFYTQSVLRHFVYFSSLDKTLNPNE
+TFASERSNRNTKFKGPLKISSIKKLEDYASWEMIKDLAISELKDIVYSDAEKISEYIKYI
+PKIDFKEAFVSPVTLKIVKLGIKLYPNWKWSQRWHGIREKFYLWVTNPNDGAILYTNQVQ
+VTQKSVNSTVSITDLIPIPDEDPPFFLNIRIISDKWVNLDFEIDFNLRPALDNFTQSSYI
+QKEFLQTNSESNPISLNSIPDITELLNIPPIPIKSLKYPEIIDYYNNKKIFFLNPVQSQL
+FHILFYSDENIFLGAPTGSGKTMVAEIAIFRALFADLDSKISISKLKTESKKKSKIVYIA
+PLKSLANERFNDWKFLFSNTLGLNVVLITGSSQTSLLELEKASIIISTPEKWESFTRRWW
+AKSRSFVQDVKLIIFDEIHLIGQEPRGSVVETLVCKTRFISHFIEKYNVNKKIRSLSLST
+SLSNAKELSSWLEVGASGYYNFPPEIRPVPCTVYISGFQEKNYCPRMATMNRPIYNKILT
+HSPKKPVIIFVASRRQTRITAMSLSHMCYCEGQPNRFINTERKDSFGLSLAGSIRMAKDK
+SLKQTLESGIGIHHAGLSESDRNLVENLFLNGIIQIVVATSTLAWGVNFPAHFAIIKGTE
+YFDAKLGQYIDYPITDVLQMVGRSGRPQYDSHSVACIMTLESKKSFYKRFLYDSLPLESC
+FGVSPLIEIFNAEVSSLSIKSIPDAICFLSSSFFFKRVVINPAFYDPNVFQVEIAQAEGQ
+TSLLDVPRVRLIVYILEKLINDTLRALIGLKCIRISFCRKDDHSTSSKYNLTSNSYFQNN
+LKDSGELYELEPEVDGLKPGKSGYSENQNCTWSKLFPNINKVTEIFSNNSPPISIFPTLL
+GQISSFFYIKCSTISKLNKFLNYKVLKNHFVSWVEILSLISQAQEFETYPVRHNEDKICT
+KMLKYLPFGKLPFEPMTSPHQKVFILLQANIFSIPVTVVDFINDINSILDQVPRILHAFI
+QLNKLGNYLSPSAFSS
+>gnl|md5|d3b553d3e9eb42a462a1bb59bf38dff4
+MIIVGLIGLDNVVAEYAFRFIVERFRFKGIRLVDCERNCNFDNAANKLKSTTKLESHFKT
+FGEEYGEKVIRQICFCGSDSEESYDDCIKFRAKKAFMISTTDLNSSYVISKITKENEFDI
+FSNAFFVSLAIDLPLISKLSLLETNYENANFEEVEKSIETLKNSPGKLKELASILVQDFE
+EKKRGICRLVRRSDYYISYFIDFSDLEKKLINLGLSKIDSRPNWDEYFMKIAKLASQRSN
+CVSRKVGSVIVKEKKIISTGYNGTPKNMKNCFEGGCTRCANPNRVEGKSLETCSCMHAET
+NALLFAGIDKCIGATIYVTLMPCISCTKNIIQCEIERVVFTTEYAIPDEISTIKLLRDSN
+VKVDRLVEKQSCL
+>gnl|md5|227050e721118544f4008cea5ac710fd
+MPPKNQSKQERGQQRALEKQKQKIIEDKTFGLKNKNKSKSVQKYIKSVTSQINNSKGGQV
+NQELKAAQAKEEKKKQAQQQALLAALFKGTENIKKVSAEDARKVDPSTIKAEQKIDLYID
+QRDQKQNSGSKKAPLSQEPTSFSTEIICKHFLSAVEKKQYGWFWVCPEGGDNCKYRHCLP
+VGYVIKEQESDDGGDIEGEEETLEERIERQRLELPGPGTPVTFETFMEWKKKKEKEEEEK
+SKADAAKQGKQMSGRDLFVYDPSLFVDDEDAAGGDTYEIDEDAFLSDDDIPEMNAYSEMI
+EEEENQVESIENDHKDKDKNSPEVKINHSIFQNEIDLPEE
+>gnl|md5|d3ace4a3ef90bf87c40b84cee80ec026
+MNKKRKYFPVGKSNNSRSGIPDLRILNKGILMSITVNNKSIAAYRDISRILLSNSECNEQ
+ESPNYLNDDLTIEESIELETKKFKKDDSRFKLIDNISRCLVLIQFNDSNDKPSALVEKLM
+KSVYEHRTQEKRGKNESDSGCLLSSRYVSRLVPLDIICSAKLDEIRKNMKALILSSFNNA
+FCSESEFGKETSCASWACYYNSRYSGSDIKRQEIYDLVSELIWGPEDGPKYQEYKKLYPV
+DLGNPSKSILVEITRSFCGISIVCNYHKYCKFNLNKISSN
+>gnl|md5|4d6fd2de5b079345f54f863a8ebe3f88
+MIAEKKANNSRHLLEFLFRSEDELQNNEKKETLNSLNTKVHSAMIFNMEIFRNERRKELD
+QLLKFSNEEFIESSALRTAKNDSKVEYTCDIRFGSTELWRIQRNLQKFENVTENNRIKTN
+RKRGLISSTDKKIIFDREKYEQQMSELKANPERSEFLRTSHVPSDNDKNLLINQYIKNQR
+KKFISESIYIRPDIYHINQENKKYNEKLDRAYHEYTSEIKQNLERGTAL
+>gnl|md5|40f23bef4cd4d013388545a72f6be9c0
+MFRNFSFKKSLFSSCYSTLEHNRFFGIDFRNYLHILQKNKIYGLYKFSTIDAKQINNFDA
+YSRYSWFPETHDSILLKFNHLRTTFLLEHISNKSASLNGPLSGKKILDIGSGAGIFSERL
+SELGGDVLGVDASCKSIDIAYKNALCNSTSFKEISKLNNENELKNFMNSMPKPRSLRYFK
+GGIEHIQKSEIFDIIIASEVIEHVNNPGIFVKLISKFQYLRFTISVILLGNLLKKDGIVL
+FTTLNRTVLCYIYSIIFGEKIFEMIPKVSSIDYFESIHEHRGHIAGESLLNRMNWMVLQE
+KMAYIK
+>gnl|md5|4927e5ca9aca345ecfe17e2b26f303be
+MNSESISDAADLIIHSLSLSDHLKELIKNNLNYDDDLCQKIISFSKVLIDGVINLPNSNT
+NLEENELSDKTINLIQNLVIIHFSDLIINQLPLNSVNHTESLCKERDHILNCLESEHAVI
+EKFLNRILIDSEKSLREPSLNMFQILLDILFLDINNSQIKFVEDSFNNTQHTINRECEEY
+LKTKLLFKLIIKSVIKNDPEPLITNLNEIISEINSELSKPQKIEFEESETCVNAFSIKKF
+IDSLLKLSFGYGWNLLHIFSYLEHIETLQLLLEHFSFEEQINIVNRKSLSGFVPISISIL
+KDNLLMTELFLTCGSDVQAQDNRRNTLIHFAVNADIQEILIKRRILLNIKNSSGQLANVI
+QAKSQILKFDLDKFDHNELSDAEYKETQAQQSNTNSLSNYEPDHSETLKEISFCCQTFDS
+QEDENKVMLSAWISGNEPVSSCRDDFCVFSTPEFESRDSDVVEHSVWNMLGFASSRNISS
+IYKGKNGDHAAMEQNLDRLDEMGLTSAERKKGIWSDIVINYTARGLEKSCFPPPLDCPIN
+LFRQILVLTSERFALFQYSPLKLLQAAPIVDFEEIIVPKNSNVLLLLKVDGWDDILLEVS
+RRSEFLDEFTTSYRTLTTPSEILLSQATAETSINKSTETKPEKLNSFWLGFMSNKNTSSS
+TSDQKQDVLSPERASAFQNLISVYGENPPIVAEPDNLIGLFNSENQYSLVLAIINKSSFM
+LLPHRETSLLVSIPTYHFGFLGICINPPLALENPLSQKKKQMSDLIASSENESSESRLWQ
+ERFFILRSDGALIWCHHPNDTVYCETIPIRFVRQIRVFNLATSKENEFIPCFALDFTKNS
+VPSSLILHSDSSEMRDKWVEKIHNVRTVLSESSES
+>gnl|md5|b330659a768163fa794c6949f1b3e99c
+MKNNLFLIIILIGSVFTSIIKCSKKEIVAAKSSTRKISDELNDLLASKAYFFVDPNYFWS
+LNATTQVETKAPLSESEFLVVNAPSIGIEELIFIKNRKKDGEIFYSHESNSFLTYTL
+>gnl|md5|1483e0e907698e8651de6b674cecdd3d
+MLTIFRFPPTSSIAISAISKISELPKENIPTRSLQPNDEIQLNSKVSERSHFEEQAKAEK
+TPNNAIIKLLEDKKNEIKKNIENLANQLRRHIRQVEYIDSRICELRGEKIDLQSSRLISS
+LRLDSEHYQTSLSRVSTAINTGINTPNCELASSNEAEVRSNILSYKMEGDWLIVPEFKEI
+VSRTVNSS
+>gnl|md5|70df3265d0c10beb028ebd9a90b7e8ea
+MVENKDEIGNSIVFNQPWIPIMRISFKDNNEKYNESSIVRGVITINGQAAACGTDKGEIY
+VHSLETGKRILSHEKVGIKNYELGNGGLNDIKTDQSGNLLAACFSPGAISIYDLRAGIKK
+SGSLLGLTVMNLENAHEGACTCISVPNELLYQPIFSGGYDGYIRSWDLRKKGFFSQVLSH
+EAPVASLEQSNDKRVLSSASFDGKIRIWKSSDLKLLKTLSGPQGSNYSLHSIFSFNDEHL
+LCTGDSSSCIWKFGQEKTEKLNISWENSKKLQKDYSNNIYDNNHLPMLTGFSVIWRDQVF
+VPRINPATAPAGDASVYCLHTAKYLYSLTPISPSNAIITSISKHPDLNNNLIMTTSSLPE
+PSIVLWRLNEINS
+>gnl|md5|a3908d65c78c0dd63e7344e8b2749f76
+MEDQKYKIYRHKELPLNICHFTTLPSTQIWAYENIDFLINTEKLSPNVWTVITADNMTSG
+IGSYDHKTRTTRTWYTLDGKNLNATYLTLRRREISEEPEKNISDLSLYTLGIALSVCKIL
+GEFGIKEPKIKWVNDIYVNGKKIGGILSKQLEKRYVFEQVEYEPIVIGIGLNVLHDKCNL
+PENVESPATSVKIESELDSSLIGINDILESLHLEVIKSVTNINSSRHKGFQDNTLAEVNK
+RLLYKGKVVKIIDYEKEGNEIEMGVLQGIDKNGFAIIKLPEISGGELKISHGRIKFDG
+>gnl|md5|a9777c61db051d2df2a5f7fbd51e7468
+MRKFLTCIIEHKSIESISLHEKYTKISEKCARSGYKASESTKTQSLNCIYCYKEILQSLK
+EKYDDMKSIFQTDEDESFGNIYIIVIYLEKFLRTKISVITQYITSTNWFMAYSASREFCG
+TLVIIFDLWTRVTRDFFWPYTTVASGNYLSRFPIELGKLIISNIANNNINN
+>gnl|md5|f21f48485a33c032af16577a47103681
+MYKFNNLLGVPYNGGDILFFSDSSNLVSNVDNRICVHDIKFNRTHVLGCEARSNISKMCL
+SPDESILICVDEDNYGSIVNFSKGLILNRMQFPGSVGFICYSHNGNYIAAAIDSGIYIWH
+APCISKGWQLILKRKHIIHNSKVNSLDWSRCGRFLLTASNDMTVRLISIEKIDHFDTVAF
+IAHKNPVVGSYFTKNMQFIFSVSSEGVIIFWKPSSKKESRGKKVFTPQKILPRQIKKSRA
+NTKLALDTDSDIEPEFYDGIRSKYWIEALRAYVNQSKGAIITGCTFNYEKNLVAISTSNG
+VFTLYGISVGLDSDSLDPSNVLINSIHTFSLSNSPLTSLKFGAKGEWLAVGAAKTGQLII
+WEWQSESYILKQQGHSFGIQSSSFSPVGLTQGKWNGKASHDDYLGIGSRTIIATGGVDGK
+VKLWDISSGYNFATFSDHIAPVSKVIFNPQGNVILSASLDGSIRAYDIMRYRNFRTLTAE
+EDTGVQFTCVAVDRAGDLVVAGSQGEECKIYVWSFQTGKLVDKLSGHTSNIVDIAFCPSL
+SSPGILASASWDGTVRIWDLYARVGKGATGETLVHSSSVLSIAFDPRGNNMLATSSLSGS
+ITFWDINKGTVEGSIDGLRDIHSGRSSSSAFSANNSKGGGGRLGAKTNQNINRNQHFSSI
+CYNSNGRFLLASSRNSARVCLYDTLTFTLVSTVQLTNSRFFSGIRMELNSNLNSNKKKKR
+IPDSENPDEIWSSSNRLIEKEKIIREHNSLPGTIVGEFSSPSRQSHFSVYEVAFSQNSSH
+WIASTSHGAFLFCIDTLGNSYSGSSTHLNMLDTFKKQIMTKEVNVSNIDHFLKEGDFLRG
+LILALAMNNFNILAKAYIQIPITSIDYIVQNIVSFFLPNMLNFLRIVTSPNNKQFFRLER
+HLIWVESIIRVHGNTFLNVNKTLSESLNNSKTIFENNAENKNSEESEKLKQNKLAILSTN
+LSDCDTRSIFLAILMNISQIYSFSRQIYDSNCSILHYISSKLTSK
+>gnl|md5|67cc5f9eabeff04668ff5262fe62a495
+MMMYSGHISSKLENDKLSYSCYQGREKLEYNESWFNKIKNRSEVGVSYQSQLEILFWIAF
+CLLLMVGYKYLSDGSFSAILTLSSAFQCFAFLLLASKVNTQCSLSGISLRSQILYSIALI
+SKLSSTLFFNGYLPVDRSGDWVYQVADVVSLAISLLLIYWGNTKLKYQYKFDKDSVNIVI
+PIVFSAILAAIIHPDLNSYFPADFAWTFSLYLETTAMLPQLVMMTKIGGEVETLTSHYLA
+SLATSKILSFVFWLFSYRELAPEHGKNVPGWTVMASFAIQIILFTDFLYAYIKSVRLGKA
+LIIPTSIV
+>gnl|md5|fe2de74e43c2328b3ff10ee6ac56755f
+MDDYDSQSTVEDVSEWAEHIEDVIEELQRNYRIIQTEMSCLVEKLQVVNRPRNYISKRVV
+FPKRNHNARIGNENLKNSRNCCNNCQGNSTYKSSKIEALEGLAENILGIANEQYINNMVE
+KSVSNLERTLVDKLDKNCAHHHLELQRNITDLKVQQSIMESTVRDIALQIQEIALELKDL
+KTSIGNRVVGDTMLTMSQKNQKDDENLDSNLNSNTLSSSDSSSCSCLCSCTEKSSNNGSC
+SCYERNQNGKLEGSKMLIYEILRDVFVEDENLVGIGNNLDELELENLCLIRQLFKDFVRI
+ITQGRIETLEKGIGEIRNKNAKDEKNTEKRLEDINLLIKDELMNRSAESDMIAKLENRIQ
+GVKNEVDSIQDSFISIKNDELFNKEQIERLEKELNNRSELIQSAIKELNDEYFSLRKKQE
+EESGFLFGDELSKTITDKISSIKDLVSYISDDLFKNEEKLQRQIKRNSKIIEELKSGCVE
+FEKYSDENFIEIANSLKNFRMQTITILSSMYEVINENITDRVNVSNFQQKLQENFNESSE
+EFKGMIDIRPHIFSMQSNQCPAKSQNTGFKNFNVEKNSNSTSQKIPPNAYHINN
+>gnl|md5|22f6b0ef73660c9eae77a99a3d2b6c05
+MWHPNVSGHNEGLETISTMNPLAKVGPTEKKQKGKVRSGPTNSSNQRRAGTRFSNNPNLQ
+TQSHVPTQPSPVSGVAVGPMPIPVSASNSLGIGNINSPSLNSIGVPGNIVVAPPINQPSQ
+GQTVSYRNTKKIPIDRSKFHPSISNLAGAIIGVSGSNQKWMEQESGAQVQILGTTGNDPE
+GLHILVRYNEPRELEIVEAIIEEIGRATFEGGGGFISHILPNRKPVSPTLTGLQGNMIVS
+AALQDHTSGIEKQIMGSGVAMGGMPSLPPNYSSSQPLYNNMSSNIGMGFIPRGNIVAPIQ
+IEWPKTPPASPVEFEWLLHLVLHSALSQLGPMVSHGVPMIHIPMLYDSFTSFRFEHDATS
+FFQSCIIQNGLLGLIQALPHIFIEGPHTIIDSSNIPKLSPIFKVNLSSGVTPLLLPAQSV
+TVSFADFKLAAEAFWKMGALPPTFSGFGPQVPQNINGTSGPSGLAVTGSTGTISDHVYNT
+SSVVSPNQSARQHQGKDSSGSSIGENVLAGGTNKIKKDQGANSIINTNSNQPTKGSSLIS
+DDDDTFGIDNSSSKNGVITNGTSSVALSSHSSTTTTSSGVTSIVNVGKDNIPQTSLMIVL
+QGVHFLLRRWISKRLAPHYIPKSSLDFLPLDILESEFSQFYEIPLNIEILGWTNLLHFVE
+AFPDVWTVENVGPDEFTLIPLPYPDFSMIAKTRGITKLNNEKHYDSKPDSNAFTLSAQGS
+SLANIHKSGGSLDNIQKIVKQTQDFVAEAIASGYPANSLEINSINEIINGVTMGIYSLDN
+NTSSSLYELVTKVTNLLPKYSSNSASSTSTNFPNKPISGSISKSRFDNAYKGTNGIGSMN
+GLAKGTKSGGFQHQPHSLQPPTAYPSTHISLANEKSILGGSGNHHSLTVPQVGASRFNSM
+NNAKNEIRYDIGAAQPMSTHNQHNIHLHAPHQTNAQVLNSNLSTGRSVNGGQSKRVFSNQ
+CAGASKGPKQLVGQDQRPYPLYDQQGSNPSTEFVNLQHNPNHMNPTQNTFGMQEASESNI
+HNFYHHSMDGNSHFSTYNGGGISSIGNSMAASCHYDYHSFGVQSTNSAFVQPSQNHSMNG
+AHFSKSVGIPSDQTIGNNGNNNGNNIMLSLPNHASVVSNRSGWDRKNKSKNN
+>gnl|md5|ba1538e41fac4cdd47c9713f253b67e1
+MYIDASQRLGCWNFILPKLISEDFVICTDKENPNIKTIEKNLTPCIESLLELNPIVIGEA
+VREKQVNLKSETNSDFLPSYLEDEDVSICQALQFFVKGRKSSELIQDEIILKNTTFSGLV
+DILDAPGVLEITQKTIKLSLIHVLVELAFQTLVILEDHVRVEETGNSIESYSSKMINSQT
+NWLALFKHSSNNERRKLLTANLEEILQLDPNSNSESMVWDSSNLYFTWLLATRIILSLTT
+YFPRILREIWLRNSNNKTQAILQKLVINYFSPIIIPIELNHIPLIIEKMSNPDRKITFDH
+NVSSRAIKMSYSERGFTATLSFTFSQHHPLVIPKVNIPSVVGVSKKQNSNWLISVIKAVR
+YKNVTHAILTWINNLSLYLDGVEDCLICYSIVHPQYRSLPRKRCHTCNNIFHSECIYKWF
+RTSNKTTCPLCISLMH
+>gnl|md5|b58ed1b29ba91f96bb100775f85215d9
+MSDENTNSVNESVSEQYKIKGNESFKSGKYNEAIEYYTLAIKTSQASNETQNKNLHIYYS
+NRALCHIRLENFGSAIEDSGESIKCCPSFSKAYYRRGIAYFNLLKYSLARKDFMMVLNLT
+QNDRDAQSKIQICTKLIKQEKFMDAISTDRSKLIHETIDFNAPGFAVSNDYSGPHYKPLV
+DHSKFAQSGNETNLKSREFVIPKVPDASLIRESFVTELIDFLKNPENRLHRKYAYMIVYD
+LIQVLKEVASKPLVRINIGKQEHITVCGDIHGQFFDLLNIFDINGLPSVNNGYLFNGDFV
+DRGSFSVEVILVLFTLKIMYPYHVHLARGNHETKNLNKLYGFEGEVLAKYDSGLYDLISE
+AFCFLPLAHVINDKVFVVHGGLCSEDNVKLSDIEQLYSRCEPADSGFMSSLLWSDPQQKE
+GRSPSPRGVGCNFGPDVTLNFLKTNNLDYIIRSHEVKQEGYSVDHDGKCITVFSAPNYCD
+SMGNKGAFIKIHEYDLKPNFVQFYAVPHPPVPAMKYANSMLSYGM
+>gnl|md5|c9c7433fcafe40de8a60633ba6b7e91b
+MAKATALELLESLYNELMKKAEEGAYSGEVLEQYACSVLANLHASKDPFGIYHQELASQD
+DRKKRQNNPLSHVIRRLTEEIFAITTTCSYPILLTPRLYIVCVSLLSELSLGKLSPLFLE
+TFDGYADKFEKDFKPLMLEVFIRKAPWQILVKNLNYLIGNVRSGVAGAMCDSKIKIEFQE
+LSSITSPEMSNLGLLNFLPLFFTNFESLKKGILEGRYSFNFNSSKGKIKANSKRTSSLVD
+FNAIIEKTKIVESFIPKKSEKTTPTEIINQALDNFALTRVSIAALTSIFNKFGIESGRKE
+LKEFNLDISFIINAFEAVIATLLSGTEMFSLNMCESNDKVFESKHKENPQAVSQQIFELD
+GSISNDIFTLENKTNIYFPFHFLHIQIVSGLRNLIISMSNFKDSNKVIKNSSSLNDLIIA
+YIMRMLNQIERILELQGLNSTKQDHENSTFSSSRINRFLELIPSETIFLIQEMSNYYYPC
+RSIFKKKLLDIHVSQLKNTEQMVSSFFMTSFTQVISIEVGNDLDCDLLMESWDRIFRDVV
+FPNLLDSYTIDLFITMICNPNTLNSLSRINIESFLDKYLGVITRILAYHPDLSAKPILVF
+IMNCVKNLKIQMPNYEWLANWMKIILSAICMPLITLFPQKVNCDVNDLKAVISPIKPNNR
+ILNSLSILVYPKIYADNRKKGKPDLMHIISDLSTNLLLVSIYNSNYTGNKRLHTMTALNV
+CIKLLDLLINDLIDSLESHKKQIGSDYLPSDESIISIEKKNIAKLISGIFKVFPYLFHQG
+ANYSQEIYEKIVKLITFIITRFNELLFSDEVFEVVLNLLKLDFHSNLVIISPICWAIGEV
+FISKIDNNSLEEHETKIFKLINSLKSLIESCCTNCNQANNELNKKNCNSGTDTDSNTGLM
+DEALSEFSDSSYSSFISDSSLEIDNVASEDGLEDDTIDSFVYSSGGATGEGGKIAFIDHF
+TNNEHYNNKIYRTMSEILNEDDLKDVYKYLDNIYLVEAIISTLCKIGLSCKQSKSNIITL
+LEICLRKFQIRGFEKDNFEDENLIFQEDQLLQYSRFILSKKISLCIKSLNHSSVFSSALN
+KPTGPPSTLFCNKSLSSILF
+>gnl|md5|67152b08489eadbc51c60b79649fd05b
+MRHNNVIPNVHYHKNYKRWIKTWYNQPGRKQSRRIARQKAVAEAGFRPVGMLRPIVHPPT
+QRYNMKTRLGRGFTLEELSACGINKKAAMSIGIAVDHRRTDLSEETFQINVDRLKKYING
+IVLQPRKGKKTKKGFAGIPNDSAREEFKALKNVSHEKAFPIKAQALAVKVSISLLTL
+>gnl|md5|7ec43ceede7ec87fcd5f96075958d123
+MTMESRMVQTFGRKKNAVAVALCKEGKGLVHFNGKPLDLIQPEQLKVKAFEPILLLGKQI
+FSGVDIRIRVSGGGYTSQVFAIRQALAKAIVAYTQKFVDEATKQEIRDILVSYDRSLVIA
+DPRRCEPKKFGGPGARARIQKSYR
+>gnl|md5|bda4bedd85ac92651e2aa0eb79c4655b
+MTVSLVSCNLPAQELAFTNFAYVSSSTYTTLKNLSNTQNGTGQPRILVKNLILNIEIDER
+VAHGELALNRLHRQFARIESRERIEVELAVGFGTTGSEAAKSIAGTLLLEAELFVGSSQQ
+LLLDGERIIPGILQSIRNQVVTQGQKVSYFYKEENLLLLLTVKDILSLDSLLSNGNKKEH
+SDSKNSHFLIIDSTNMELTGSKTGTVRFQNDHRSAPTLFRHHFSFKDIGIGGLDDEFSVI
+FRRAFASRVIPPKLLKELGIQHVKGLILHGPPGTGKTLIARQIAKVLKAREPKIVNGPEI
+LNKYVGQSEENIRNLFKEAEDEYRQKGDFSALHIIILDELDAICKSRGAGSSGSTGVGDS
+VVNQLLSKIDGVNSINNILLIGMTNRLDLLDEALLRPGRFEVQIEIGLPDSEGRLEILEI
+HTKQMRESSRLANDVDLSALAQESANFSGAELEGLVRSATSFAFQRHIDMGDMTKPMDAE
+NIKVCRSDFESALEEVQPAFGTDEDELQSLVPRGIIKLGSESQRNLELLKRLSEQIKADE
+NLSTLAVLLYGDKGTGKSALAAHIAITGGFPFTKLQSPLQFVGMSESARSQELRKTFSDA
+YKSDLSCIILDDIERLMDFTAIGPRFSNIVLQTIMILIKNRAPKGRKLLILATTSEYEFV
+HTSGLADIFNLSIRVPSVESQDVPGILDYYQNGLFTPDTLTKISDSLRFPVPIKKLLFAL
+ELVQHKFKNSSTISHQGLFKLTS
+>gnl|md5|4285e3690affa43e0ed59f805843d664
+MTIFEVKLSSVTTLQDLLGENEYVKDNYKNCDILVLDYEGKEKLGFLNRDILLTDYRLIF
+LKDAEYSTQNSKIPSKFSCGDYINISSIIVNAVSSCEKAEDNPYLYIQLGDPEFNEDSDE
+DLESSNRFSEINIRCSDQNTIYTLFNSISETAAYMEQLENLSDSKSDDELTTDQE
+>gnl|md5|55ddf616f44720cc4a46572eb9681168
+MKIETEISLFFSFLILLCEYSFSLGNIQNKFERFRTFNTNHDLLESHQNPSSKIQRTSED
+IKYGINPLFEKPELDDRYSKYKKIYDRKNQNEKIKRKDQLRNQVEELLEDMDYVKQKQRY
+LEPEIPDKYFSFRGAEEHSIDDLD
+>gnl|md5|356b9c445ebda4059a914fe4451fc4fd
+MIHKLISYAYPDILIERIRHLETQNILNEAPKTAKLSSLKIKNGNEISVTFKNVPKDEKS
+DKYHQTQELPIEELPMTPIEKDIPELPELDIQENLDLSQGPSTQQSLETKVLKSEDDVLN
+DDEILEPNKAIENPLSKNYDFNVGDEYEKLKSDYFKNIRAGKIAIYNSDDEPPRQSNRKE
+HQFVLSDEGIDNDGQERAVEAEKIDINNSDGSYLGADINHCNYKVNFKQITLPVSNFTNE
+IERNNIKDILTLNVTFSELEPCNLETLISEVNKIAKSMGKNYSLVRMEHNASERELLALS
+KDNEKHHLLDLEITRGDEFNAFLILEKTQESDYSKNDIDKHDVEIISDLTEKQISIADCQ
+IYMTIFVDSASLRDNINQSFSKKPLNKNRSLGKGGKKHLKPINICTQSYVPIKKVLEKIK
+IILKVDSNLNEIFICGDKIVDTCSSLPVSLIKSETCVLRFDS
+>gnl|md5|d356c3d15035f7bcca85a25b46970e06
+MLCSKTEALKQEKPDIFSLAYNDDICSTAKNLKSLDDMESELVVSSCVMLVEYPLTHKQK
+RNLKFEVGFLPAPLSLISSASTLGNYEFKGNGPCALTLSMYFIKTCGRACNVNRPIVAGV
+SSIPVSCMSQCSQYSKDFCMVGCKRYGCSVEYYDCMNLLCGTSP
+>gnl|md5|14a182ff50b4a7912c94aa949180e034
+MLHFDFLLIFFLLPFLGRTMDPDLNFKNLNGSKKGLVKEEPPFATSVEMNENNETIVSKL
+SHQNHSLV
+>gnl|md5|c6eb867e85d8c12f701da0d9b7b9243c
+MRYNGLTARSTNSTLQELDGIKLKDSESIVDNQRALQISGWMNSFGLPAISSTTILSQSR
+FTEGSFMHSSGGRNCSPLLTLIFVRVCNSICNANNDSSSGRSSIPIFCLRDCQPFAKFAC
+LRGCRTFGCQVDIYTCMELMCQ
+>gnl|md5|f84546da4483e01d00a96272fc529269
+MRNKSEFMAFNSECNQILKKSDSDDVNSWKNHENFEYCKEMNFTDRKLQIKSGFGSHIRL
+PQSTSSLRGPQDTPQGNIFKYQTQKICLSVLSLHYIKVCEKLCDAESALTVEEEVFPRSC
+FPICVDFANHVCIRGCSFFGCNIPFDACSYQMCNFKLT
+>gnl|md5|1370d6129463b483ffdee2e5d15d7e02
+MSNQINLPGGLPGLSVPQPPGSMPSGVGSSTNSDAIIVDILCEFADFFVDLASNVAARTG
+KMWKPRILLQQKSKRSIRAPEDPNKPKRPHTAYTLWCEHIRQKVRENDPNRALQMKDLAE
+MWNSLPEQEKGPWERKAQEFKQKYLAEMAAYRASGPTSVGGGPSPSAQQQMQPFSSTSMT
+GW
+>gnl|md5|8be3240841a93394f3350939b57ddb86
+MIKYKAIGKYLILLCYALNIFLSLVFCQELTSILNPEGGGGFSCNYTNAEYTCGGYSVTP
+WSSWGTCSGCNGVITRQRSISGSVSQGGPSTTEGVKCLNNQSCEPCSYTQWSSWSACSDT
+CESGTKYRTRRVSSNVDCGVSEDELKLIETVSCNNDPCKCDETIRGENGLYYRGCQKYSR
+SGQKCLNWLSLKFDAFDYLATLENSGIADHSFCRNPISNNTLVPTIWCYVSASPLIPQLC
+DPVPTDCVVSEWEQWSSCSSTCEEGKITRTRTIIQESLHGGVECPVDLEQVQDCSVDVIC
+PVDCVLGSWSHWSSCSVECGKGNSTRSRSILTRPRGTGAVCQEYLQTKSCEGEGCMSFWE
+KNKYSIIGFAVLGVVLIISIIYILIPSNNSV
+>gnl|md5|3dd7a5b602d4200984dea775817add39
+MKNLVKVILGLLFGLVSVHSLSLRAGSQELAIAEDVSDLFDGREVRKIEVRSPVSGILSK
+VNIRQTGYHSSGTAFVVTADSSQYYKSTINTGGKNVSVKRVIDAGRNVYIQIFRDSYVTL
+YTNKAVGDSVSQYDLLAILFVVKTRQGEAPLVKKLPRSVPTMPIPNPTASSTTVDLDTVN
+SSLDSSSGQISESVAAEEAGIDKEQKLDLTGESSPTVEAERVTGEVKADETSNEVVAQQT
+SEEIAEKADSTLDNLASIPEKSELDTDVSDEETNKDNDFSELSEFASDSEESKGASSSRN
+SESEPEPVSVASSENESQMTKPDQGIEPTAEELSTEIRALAENQNAETPSLDQGETIETQ
+TSIVEVSEVSQAPEDVIETKPITEEISAEENSQKVDVPKAEQDLKDESSVEPPIESPQLN
+LQLNLQLNLQLNLQLNLQLNLQLSLQLLHLQLRLPRKSKKRSFYKASHLNQLLVS
+>gnl|md5|512301da78157cdf14ad31e98fb7cda0
+MIFAISIMNWPYTIYLNNVAKERALTKFKVGLKKENESEKIVNFFKENKTLSMSFLFIAT
+MMFSLHILLSFSVKGILVPVILCYISLPLFVKFVAKANLNEKNDSKITSFLAYLPLYLSS
+AYIGLKLDDSVNNTFSSNYNPNNILLYGMRLAGDERALRLCISLLFYNFYYLSGFLDLLF
+QVDTEIERNIYLNNLAPLKIIILIALNALSFPGNKSLVSYIWAYPYYTGGVTTCIFIIGT
+WVWLELFRITGTQLFKNVKISENLHRHFSRSGIVIYITHSVWLEFVTRYFLIYYISPDSS
+YSLYDGKSISLFGFVFPGFGMMSSWILLNISGIILSVITYISIINFRIPRLFFGISN
+>gnl|md5|cef907822dfb8ab1edaeacf45916a4eb
+MNYLILFTLLSQLIAAVYSFDCTSTSALDAYLTNRGGSLNSAKCVSVVLLDAYSPSILSS
+TSCDALVVDSRSADSTGLLNSARVTCPVTTSHIPAVFDLNANLSRRTQLGSIYCVQSSVS
+ESVLYTSILDRASADQVSNILLPVISPASTNFESRVNNAAFQVRSWIMTAFGNNNMKCPF
+NIIIPAPDFFSYDIILHGFSKAFTRDQAAYNKSIQSGTTPAPTPAPTPAPTPIPIPAPTP
+VPLPRTQLLSDFNQYDGIACPTMKNFFTLLSEANDPYINKYTAVTTQISLAFSDFTIGIH
+SCDAFIMESGTYKFEELMREMGLPYSPVTQESGVTVRSTNYRQSPAIWYSSLKKVMYLDF
+YNAIHEVGTYESLMDLIKAAYLQIFEFADKHRLSELLVLPFGLWDSRHSYSIQIITAAVE
+GLAAALNEFLLYNSQMHITILTETREKFEVLVDQIKPYFNVMNVRTSEELLGTDTTTPMP
+PTIPMRPPPRPSRPPPPVPQRPIGSLRPVAPQQPSIRPSTQGTYYFDSDEECMSGTPVSE
+FIQSMYNGRIPQPTTSNHFSLILSNSNPGVVGCGCLVVDVSEKAQLELAVKLGISAKECA
+SVGSSEIKVLGVRALNAYTIEPWMTNVSRVYCLNSTKFIYNSRVKAVEVLYKKILASAKY
+RCTTVLSPLIATSMITSESRNKEYILQAVKSMDEFFSTSPHRDSIHLTFYERNSEIFFLA
+LDLFATYYLEYASSGGIGATLTSINRNWLSLSGIIGGNMIPQFRAPATTPRKSKNLLSSV
+KREISRRIVRTTTTTTPRPTRIPPPRPPLPKFTGNKDASRPAPSDSIFTSSHYSAIQEFT
+RLHSKPDVNGLYSMNYWVQQLTTFTSTSLTELSKRFYLTNTNISDLVNCKVLAIDALSPG
+IHNILSLTGNSYPSLLGGVTVVANRRYGDSTVPLTKTLSRLYMVDVDNRSASSAFEEVIS
+KAVANSEKQVVLEIFSLKEMYQVSRYRAEQHILQAIKALINRMKHYTSSSLKVVIVEEDS
+MLASIILEVLISVFSGRTRI
+>gnl|md5|17b74a6fc6aded04dce14d22b0578570
+MRRRKEYKVRELNSFEIEQKREDLKANIEESRPKSSLLRIVLDYIGLILYYFINNVKLIF
+HYILNPRLNTLKELYPHHTAGKYEPRSKFGYRFFLVCNRVQNIGFGFEYRGVYYFSNAHF
+NANTDKLKIDGKEIRLYQQGFTMLCSKKEHNMKKPRDDEDLYLLNPYMPTIKGKCIYKNP
+FFYSFFPINSICREFTGLPITNSKGELVSIYDNFRKVNSLVYNIIGDVNLWKEEQSNRCI
+DYKVESVQTDREDIQVFRVISEFEDGCGNFENNEIVGYFFKYNSINYISGAFVDEFGNLN
+LPIAQKDNDEAENTLKYSNLYRDLWVSVPNSMHNLSLPDQDEYAFVLNITRYNQKEIKGK
+IKIDNNQQFWAEFVGVPNREFLGLPILNRNGQLIGVYSDFNIENSFGRLKYSVYLGGINT
+FKNFLLRISLRNQNTIQTLETDFDIEILEQVVSLCSIGAENNDESCSKLV
+>gnl|md5|ec2cbbf7d16f830663d2bcbc40b2332e
+MMIINKKISIFLLLIIIVIFSFNMDNLLLEAAYNSNKSNNNNNKSVNKDEIVKMSKEKKN
+NGEKIEIKVRNAGLIIDDNNSNSNNKLLTPQKDELLRQYYNEYSFPDYMYIIVLGNLKNS
+VKIKNNPGEFIINNYKLGKNRNFSNSTVTNNINDINNNNNNNGKSNWKSIVSTSTTTIST
+REDINKDEDISNGNSISSLTISKVDNIPFISIESNEKNSGIVKNIKENIPFKHILLPFTT
+TTTTVTTTTTTTTTTTTTTTTTITTTKPNTTTTTTNTNTTNTTTTATTTATTTASNSATS
+TVSVINSTVKSLDNKIDENWSLDKGYEKEQEMKISSFNTNNKEDLNYADNNNSNSNEEIN
+NKEKFNGILTDLFSKNLNRSQNNIRKQYTTTTTNNPESLLLLSRLTTKAPPKFLISSIKA
+SSNSTLEISKLDNSTSTITTFIGSNNNNKPSKLILNTSTTTTTTIAVTTTESSKILASNS
+TIKVELPSSGRISDILSVDNLETTNNALNPIKTTDGNISSISTQSKYYTSTTTSTKNSNI
+KRTITSSPKAKDEETRTSTSTDKISKTNTTTPSITTTNSLNSTTIVDENHKISDNVDLLT
+NVEDVLIETRGPFIIVNEEGEENKTNSKSKGLLLNNSNHGEKKVEYEITDGLNNEQSLDI
+YNENDKNSNNKQMLNNNNNSTDISIFNGSNNNRNTGNKSDSLINSRTSSNKSIMNNAFIT
+TTTTAKTTTTTSTTKPTTTTTTTTTTKLVTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTKQTTTTTTTTTTTKTTTTTVNSTTTSTTTNPTTTTTTNTSTTTTTTTTTTTTKPTT
+TTTTTTTTTKPNTTTTTTTTATTTTTTTTTTTTTTTAKPTTTTTTSTIKPTTTATTTTTT
+TTTTTTTTTTTTTTKPATTTTTSTTATTTKSTTTTTTTTTTTKPNTTTTTSTIKPTTTTT
+TTTTTTTTTTKPTTTTTVYTTSISYTTSTRNAPTFFNTTTKPITTSTANPTKTILNSTST
+STVVTSYGNKDKSTISSTVTAVDKSSTSTSTSTAFTTTINTTTTPTAKSTTTTATTTSTT
+TTTTTTKPTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTSTTTTTTTTTTTT
+TKPTTTTTTNTSTTTTTTTTITTKPNTTTTTSTIKPTTTSTTTTKKPNTTTTKSNTTTAK
+TTNTSTNITYTSNIDDLSNTLKMNSIPNNDIEFDGMSNGNDSQLFASKEDKLLLKLPILI
+TTTTSTMTTTTRKSFTPKTSTSIPINNNNNNNNNTIKLPTNKGREKEENTDSDIGKHNHI
+QTITLALLESSFCEERKDNYKQITMALKEHISNILGIHIQDIVIDEIYAENSNKLFSGYE
+KCNLPNGKLKGIIFDLSIIKNILIDYPTYNDIERITLIENEFNNKYGKIILWKRNIDNIN
+NEHNPFCQASLKTTNNIKFMCINNPIYCIHNNEYKCYTNPMGIDCFCYNDQSIYNHIQNN
+QYNITYPMTNECKTIISCTNDITLPIIPRCSTSPYSIGCPCNLNPYSKLCGCYINPFNPG
+CHCTYNPNSNDCKCLLNPEECKHENGLDIIDYEIIDRGPFDLKHGLRRFYKKHFRKSNSL
+PIFSNYHILQSLLIIFLNMMILYTSA
+>gnl|md5|c7120abc53c542389140264cfc4d8800
+MNIGDVIHFDDNLDDSINFKLDIPFNLKKVFLNESDTENNTKLNISIISNHYYDIFVSFP
+PIFEASSHLHIFRSFPEDYYYHSNSNSNNKSKNTNLVISSNEFINYLKTLESNISCNQDS
+SSLLLLFPSILFITIQKHKNSSSINNDISNNEKCSLSSSIQVNIQYYKKENTIDVINQPI
+ENEFSTCINCKRKIPSDNLDLHSLQCEKMYKRCNQCDLILKKSDFEKHTHCNKCIKFGLS
+LDQIQIHDKLYHQFTQCKLCNQDNIKPIQLKIHQTQECPKRIILCRYCNNFVQAGTDGHY
+VDYKDKYYYNLTSHESYCGSRTTNCNICNKIVLIKELKSHIDLVHAK
+>gnl|md5|bc8abe3d4cadb7c82975482f9ea8809d
+MELLREQSLCREFIKGIDRVICMIREIYNEKNESNDKLHMKKKIENLKIEKEYLKDILIK
+QMSTYCVLKSLHNENKANMGNNFIIDSNENKNSIQMNNLDLEEDVVSYFDVFPQKYSISN
+LENTDQIPFNNKFMKERIEL
+>gnl|md5|548df2032662fbfe0d9f0b362d6816ba
+MELKEETNIVTLLAVKKAYNYFVPSLNNVEEMQPSKNEIESDSESEAGFEKRQEETNTKE
+PGCVNSDLRKKANDRKRLSFVRFLKLDKVGPHCDCDKDNQGKCVRMQNWLEVSKSNELGL
+TTIYRELINIVEYIVRMEGSDIIEIDLTENGVINKIFSNRVMNSIYMDVCRTYPSISYFK
+FEGKSYLSKILLIYSLMDIDVGYVQGMNFLVGCILWHSNSEEQAFELLVSLMFNYGMREM
+FVSGLPGLRVKCLILNQLMEKELHIIWDHIIRQGGTIDMLATDWFLTLFSYSIPLNIIGK
+FWDDFFQQGWVPLYKLILYRLQRIESNILYSNDIADIMNAIKYSTPTTKNGIFGNVFLNI
+KDELGKSNVIRFFNNFNTLFSNNTNNNNINHKSNDFGFPDSDLINDSGDYNVVNHGNLTN
+DPNIISLPHVWSELITESQFEIDLDVDYIQEMELKYSSNPSDDCIEFFKDDNHKIRDSIP
+INSTDLNMQSFEYFLDNDEVKEKEEQDEEKPALNSTIADSQYDDLKCIDPPNSCENRLNP
+EQNQPSQSLEVGFTKKTDVNNQIITRYKEYYDGIMTSIFEQSDHSSIPESSVDITSTNNT
+CNSSSCNKDNKEVGITKSQTPSKSIYEIKDKLKSSLERLLNITETLLIKSINKDHLKELS
+IKCKEIQKNKFGPWSYQQ
+>gnl|md5|448d121ba192fbefa708d3b560fae640
+MIKPEGTNSEFVLCQSPHHMQISAPDLGTKDGIVTQYLIKQLSSQMGANSFFSKGPNYRV
+FTILEADVLSLKAQAGLRRTMEKYSNNSRLILHCEQLSSIIPPLRSRCLCIRVPLPSPEE
+VLQVLRFISNSENLQVPNNYLEQIVTESECNLRRAILILETAHTQSFSNPPSALKLPWQK
+VCIDIATSVSFLQKPPRFEYL
+>gnl|md5|cbc8522bf78a1b9ed3afe54e5fd44f39
+MLWIDKYQPRYLRDLKCNKELNSLLEKITSNSNGNIPHLLFYGPSGGGKKVRISSVLHEI
+FGDSVDKVSSEKLELTIFPLLLFELRVELRRKVKQ
+>gnl|md5|26e31b2e6fc323d1b3d08f4e62cfa97b
+MTINEEMNGSEKRMTTTRVIRRNSPYLRAPRMYSISDLALACPLHCPELSISDFDIGRKL
+GSGQFGSVYLARERRTKYIVGLKVLRKKNLVKSGMEVQVRREIEIQAHLKHENILQLYAW
+FEDKSRIWLVIEIAPGGELYEKLCTDGPLKEYQAARYMKMMIEAIQCCHRKHVIHRDIKP
+ENILIGVDGQLKLADFGWSSHINNNKSRRRTFCGTYDYLPPEITRKQEYGPEVDIWSLGV
+LCYELVKGEPPFPSNQGHNVQYYLIQNKQPEYSPHWSPILVGFIHSALQKLPQNRITIAD
+MLKHPFITKYTSGETLTQEISLTENPNKNLNVESYSNNDENVCKNSKINQQS
+>gnl|md5|8a859cdf53d0089203b92d6d15e88da6
+MPELYELPSYSALKEYANKQKCIHLRDLLKNEVRNSCLTVNFGEIFMDFTRQNLDEEGFE
+LLIKLAAESNLMEKIKLQLKGGIINSTEKRAVLHTALRSKSNIPITLSSGQNVLNDVNEV
+NRRIFKFANAIRKGELLGSTGKILKDVICIGIGGSYLGPEFVYEALRTTQEGFEASMGRR
+LRFLANVDPIDIRRATEGLHPETTLVVIVSKTFTTAETILNAKTIKEWLHKALKSETAVS
+KHLAAVSTNIKATSDFGIPVDHVFGFWDWVGGRFSVCSAVGLVPLSIHFGANLMQEFLDG
+CWDMDQHYETAPVSKNLPVLLGLLSVYNSTFMDKSCVAVLPYCQALCKFPAHVQQLLMES
+NGKSSSIDGNMLHDKIKTGAIFFGEPGTNAQHSFYQLLHQGRNTTNCEFIGFAKSQCDSQ
+ILGDPISNHDELMCNFFAQPDALAIGKTQRELNLEDCLENLIPHKLFQGNRSSISLLLPI
+CNAYYIGQLLALYEHRTAVEGFILNINSFDQYGVELGKVLAKDIRNIISLKKTNSSPEIV
+QNKEDKIPGPTRRLIDLYLRVSKNLTN
+>gnl|md5|9d9db1f18804546fb355fbe0ffb92dc1
+MESILSGIEHDKSLNNNFEDQNRETLLSDFPSVEDYPGKKKSYEAEEDSFVKFDTRMMKH
+FSIEDITFNNTIRNFDNDKAKYHRIIKSGIKFAEYSLELSKRQKKNTFISTGIKKHRILK
+LNQERSIASASIIATVTILKSLLYKEFPTNIRWTYYSFYPLILSSYLQAYNNLKTENNSK
+GFFSKAMYIRKSQALSRLNKSLLRITRHINNLEIDGKYNYSVKPKHFWKLIEPTVVSPAH
+GLITTDLIKKPKSLSGEYLKDVMSILKSNKYKLAIAQNKAREDFYYYINHDLEIIKD
+>gnl|md5|bc97244f60d0b70ab098bffbe4d8a4fd
+MVHEYIGSKITIISRNDKRYEGVLHSIDVDKSTITLKDVRYFENGPNGAPGPASSTVFEM
+IVFRGSDITDLAVCQPAAATNNNGLPNDPAILSVNGGSGTNSAQSQGQSHVADTSSVNQQ
+KPLEASPSNSRRSPKMSYSNAVSGGKPSSTNQGSSSISNGRKDHSRNRQRGGGYSGKSYK
+GSGGSSHYNNGGGSQRSFIVGELKPRINQALKAELDTEFDFSEQNKKFEKTLNEGLASAQ
+TEQGVKLEGTISDTGNKSGAMNTGLGISGNSNASNDTTDDDPSKKLTVGGYNKVSGFFDS
+ISCETLDPERSKKPQGSSDPQAKALREKQKQIDKETFGTSAVKPRTGSYNRGSHHRRGGG
+SHRGGYHGNNRFNKREA
+>gnl|md5|bad34e38d72d1cfeef0832bc7880398c
+MLCVLFVLRLVLLIVIPVIAGKDYYKILGVPRNANENQIKRAYRKLSLKYHPDKNPGSKE
+KFMEVANAYEVLVNPETRRKYDAFGEEGLKSEGFGGGGDGGFDFGGFGGFGGFGGFGDFG
+GFKFSAGGNTFHFGGGGPFGFGGGGGGRRQGGNSRSHFESQGSSYNNLYSDSKHVTELST
+MSAGEIKDKIKSREWIMIVNFYRPGCGPCKQLVQAYGNLAKLMSQYDVEFGAVNCDTHFQ
+LCQSYNIEKYPHLSMFIKGKNSQIVFNPSPGSKNPYSESNIGKWITEKMPDHSMRLNSYN
+QAIQWLRLGKHIPKAVLFTNKDSSSLLLKKIAKDFQNRLNLAIVSINNDWLKKIFFASPH
+MEASKPANPPYILSVDEITESGNKVGGKASESSSITASGEWISLNTISHDVITLTLSRIV
+GSFRARKQHDINEALKSKVQELTFELVTSKGFCSETDSRFCVILIMEKNDFRMDKRFEDL
+SFKYRNDPINFFWISAFRNGKNSHFLDTFKCHSEFSPSSKTCIAIYRAKRRKFQTFDNLE
+QLPKFIDGLLDGSHSLSSNIPRSTPIPVPAESEPTASYQNDEEDHEYSDSEDSDYGQESS
+RDEL
+>gnl|md5|80a8f4bf5d137ec8eb75924a3f3052a3
+MEVANAYEVLVNPETRRKYDAFGEEGLKSEGFGGGGDGGFDFGGFGGFGGFGGFGDFGGI
+EIIARGKLIHFGISSAREMVI
+>gnl|md5|09cfc8ba4afae08846ea69ad7d942b87
+MDNKTQQFFKSIKEKDPLNNKCIDCGAPHPQWASVSHGCLMCLTCSGVHRGLGVHISFIR
+SITMDSWTPKQMKAMELGGNTRLTEIFSEYGLNGCDIKKKYNSQIAAYYRGMLKDLCEGN
+TPGPKPSKSIGCLEYVPESNNKNNNVSSNNGFSPMRTGTSFSSSNSFGNNPSDDKYANLF
+DRNIGSKGFGGILDSLSSFSMKVISNTKSYAESTINHLNERGILESAIDSVKAGGTYIEE
+AGRAVVEKVQDEKFWSNTATTMQNSAQWVNNTIQSGISGVNEAIQTAIDPSNFNDPLNNI
+FGDDINEAETDKSGQIDPQKSSDSINSNSYNSSNSNFTRTIGRKPSPPSESLATNMNSNS
+KASPSNKAPQSVISSSNSNVNIVQSDVKNINLWESDLGDDWEPKDFKKGNTKKA
+>gnl|md5|0a168b7345c082212247234ff01bcb56
+MSYILKDNDQISQKIAQFEILCLSILLLNIYMQSNWTGPPFKIDDGVSKDWKPEKKEVDY
+NKNELSGLITESLDNDKEFGNNYHKECTRCLEIDGEYLYQRCNSAPFLTWSIFLIEFLSN
+RSTDNKDEFNSESNILKLSKYIVIGDEIPKLSFINFWKQRFYRIWQRSLEGGIKFAATPY
+LESTILEKYSNWLKNEWNIIPDDFPINDRFKDNLLRSFRFDEELSNNQALFSNKLDKNVS
+SIFLLDLSLSLSTFSRANPCAILLKQISLMNGFKYSFTGALGQKRMNQRESTAQLVVEVY
+RSSDNLENEIDRNMMKSEEPIKDSINNETEEKILDRQYPENVLLKSVDPNIDIYENVKLD
+DDKNSHLTGSLAIIEQCVLLIHCVAIYETSPTNDVIAYEQLNALTNRILKFDITKIKDED
+LRKKIHNWLCFSTALWYRCYAEHHRGRTADRACLQLQSLVDQFNDAEPGPEERLRLVFSV
+NYPNIWEAKKELGIRMMRIGSVLSAYNMFVEMCMWEDAVDCLIVADRKTEAIELVKEQLK
+VRETPRLYCSLGDLTQDLSFYEKSWEISRHRFARAQRSLGNAYFKKSQFELALDAYTKAS
+LVNSTNVNCWFSLGCVALRLEKWEIAQQAFSRVVSLDPQQGEAWANLAAALSKKELWDEA
+QSAINEGLKHSRDNWMMWDSSLKIAIKREDLNRIIECLSGIMKLASYKERFPMWSLPNII
+NLLKSEKYAHEINNSDRPYSLINKSLNLLNQISQYSSKPVVYYVLSEIQILKNDFSGAYS
+SKMKELRGSMEVIFNEKISSDDKEKYLQDIPNIYSDIKEIIYKCNDSDKPNEERVDEVNM
+IITTIIKRLKVTKPVWSSTLEQKLSSSLS
+>gnl|md5|4a47ff72e7ff2841d7524761a93ecd54
+MEQIQVTPYLDQKPGTSGLRKKTRVFMEGTYLANFIESYFQSFSPEDFEGATLLVAGDGR
+FFLPEAIQIISEIAAAHKVKRIWTGVNGLCSTPAGSAIIREREGGIAVGGILLTASHNPG
+GIDEDFGVKFNGKNGGPAQDSVTNAIFEITKNLTSYKKISLPKIDLSKIGAQELIPNQFT
+VEVIDTSEDWLKLMKKIFDFQKIQNLLNRKDFKMAFDSMHGVAGPYARKLFVDEFGLPES
+SLLHLEPKPDFGGLHPDPNLTYAKDLVELMKVKSPEKVDKNTPDFGAAGDGDCDRNMILG
+KGFFVTPSDSVAIITSYAKEAIPYFSKGLAGVSRSMPTSTSLNNVAEKLGIPCYEVPTGW
+KYFGNLMDAKMIDICGEESFGTGSNHIREKDGLWAVLAWLSILAHKNPDPTKPLVSVEDI
+TREFWKTYGRNYYTRFDYESVETEKADQFFKHLNSLMEDHQKLREIIKPYGIDIKLTDNF
+TYNDPVDKSVAKNQGLRFIFQDNSRVVFRLSGTGSVGATIRIYIEKTVSDQTKVNNTSNE
+ILGDLIEIVEKKIKLQESTGRDRPTVIT
+>gnl|md5|072b2c20eab4e45fe633ab201cc0ffcf
+MNNMKFLFYFGFLVYVIGSSVNANDLALPLKKNKECEHCILKGDKNIKTQVKGAYLVVER
+ETTLSKTPDTQIKPFNDVPQPPKVGTDDAEGDQANVKELSPTVGEVPNVVPEPRYIPTVK
+IYDSQIEDLSFPEDIDSETQSEESEDENEDELILTRLQLGGQVEVVSKRDSEGKIEIQNI
+GNLDLSCTRIEEETKPKSKSKLRGNKSSNSMVVSGSDSPQSTRFLTYDLLMLQNVGEEPT
+DGDSATSQPSSEDTESEQNGSNGRVIRKLASGLECDKCELCTEDKKCFYHNGKNTDKSSE
+VLDSDLLSSTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTIPPSMSDEEKSPFVSD
+DISNDEVPAQDDSSKTPSTETNKDIDMNILLDNMNALVKIVKEGKEESAKAQLELRKDRE
+LLTKVILDLRDSKDLTQLYIQLAKLEMEISLVKQNIGQLKRDLEKAKSSSNFLTQYENKN
+NTELELMKEKAMSSKVYSPKLARAISRLEKKKTTTHAIQKDVSKRIESLSQAISTEESRI
+SELLEQKKKTENIINKISSEERLSFDEVDNKQ
+>gnl|md5|259ff611a83017e3df1dcf271d9eaee8
+MNIIKVEEYLREKYGILSIIEEKKKDILDELEKKGGKIRKNVVGNKSGMIKDEWKKDLDK
+FVLDCDLREYFVGESIKFRDGKIVTDLNNLLVMVVKSYDCIRPKRSSIGDFDNDNDDLDS
+DLKDEIWDDLMEYDNNHSDNFGNKKQEKVELDEEKGKKGKGFSSKIKLKKRMLYFTLTTG
+KMKLPSSEQSSTQKNDTVIINALEYERLNCMNNEDNMVLYPGTKLLLSLQQGGLSKIQVQ
+NSILLLNNNNVKYLGGNVESLVESWKLNNILSGSGSKGFSGSKNLTKKPPKFIPFVNKES
+ERKQLNEQVKDAQQSYQQNKEIQSKLKSVPCLALSSTGNTNTVESENDSKNLENSVKAYN
+EFIEEIQKYKKQNLISLEKFNLSSKKATTTSKISASSKNDKNKLHDDRDPGAPLRGRLLR
+STEKIDSDAREFLKSRHDNSSNITLFDHLFSKLEIKDALSTGENSGGVGVVTQEGEGGRA
+GGGMEKGEHSCRGGHSSRGGHSGRGGHSGRGGHSSRGGHSGGRGGNSGREGNSGRGHSSR
+GHSSRGGGHSTRGGGKKGRGNGKSNHENSTKH
+>gnl|md5|09d1e624d1dda89dac021b8be91b9e50
+MPISVLIEFILDENVEYEEELGLESNMVGISNFSKLVYYMMIYDLEWTWKYILSTKNGVF
+LLNLIGLLNHPSIFHLLKLIIGILFCQDQDHELFIRGTEIKLDDILRRLCQNFRLDNELG
+DGRNLLSRRKNRDRPKLIKSTCEFLVDLFEGFLDLTQVFDHFNFEKINSEFTPLSMDTKL
+SRIMKYFREREKINIKLNIWNNNRYRGDKISLSDDLTYELLLSLSRSVQNLGLIFTNISS
+LNQQDLYLYSGLASGLMLVINTVVKLERGKEHAEKRLEEGNSNKKKDEKEKKGLFGVKPT
+KWMNDLGARILNLGNQVLNSESRKGILMSPIKICRGIDNKQVPNIISSRLKMINFEIIKI
+MQGCVWEIAIELSIKKEESSEVGRISNSSTYRGYLVSLIIEILDYIETLIDFEDIEFLRS
+LIEETTNRGGQNDQDSKRQIRGSSIVWGLLDAIIFQGRISNTVLEEKAFQIFKNCFDHCR
+REKKPTLGCTEKVNYSRSNKFTLDNITCTRKYFVLGYLKSSLFLSNIVKHKRETWIDDRI
+LRRTITRVGRMSSPNLLRLDEISPITANIENTYDSNIKIGVSRIMTNRVQRSFSGTGDSV
+VSNHQRVSEYLYSEIKSMQRDQPWIANYF
+>gnl|md5|909ec26c89514eb18a94a2facce5c3d2
+MGRFKSRFHISLRRKWTLFCWFFSILIREISSDLPPNCIHGDVVGTWRIHVGTYKPCPSD
+QKFEDPTCGFPSPDRDFAHSMLTPTERGLMNNNFKLSFTFDVKFEGSELKVISTQNLDGV
+DTGKFNDFEKVGTTGNWTVILDQAFTFWTKSYRYTAFFKYINEHEDINASYCYCHTTLLG
+WWDSYPESVISNQDNKEENKILSLEERSKYHNYPWLVMSEDLKLRRGCWYGMRIFDGDGK
+MTDRTEWTLKLPRWRSSPLGLPPDHPVNAQNPTIAEYLNEVSAKYSEFDSKNKLWSRSNK
+FEIGDIQNLDTLPKVRKALKISPHFVQRKKSNDEYITEISSVREEEQISGSKNNTDEPIW
+MRIRSFDWTNLQHVYGRLGKKVGLVPEVFNQGDCGDCFAVTAATIITSRLWIKYSNEPDI
+LRKIYASSIQMSECNVYNQGCGGGLITLAFKFAQEVGVRTQDCIDDYAKNLGLKEIYPTP
+VYTPDEVGIADDGHSFLQTKKGKKFESKKSKIKEIKQQGEDSQEYGQEHKQEHKQGHEQE
+HDQEHEQEHEQEHEQEHEQEHDQEYEQEQGQEHDQEYQDDYKDMEEHLEGSDSAEHISNV
+HDYYDDSDDENSSDNEELGDLSGAKHNIPKRFNVIQQLCWDLGGHMGAANTQCRKEIPIT
+KNIPKSCSKIIKVKEYSYVNNVYGKTTARDIMESLWNEGPVAVSLEPTLEFSLYNSGIFK
+GFYDPITRQYPWSSIPWHKVDHAMVITGWGWETYGNERIPYWIVQNSWGKRWGEKGFCRI
+IRGVNELSIEHAAVRASVKIYDSDRKYKAADLQKVHDDSVFQYL
+>gnl|md5|4fca7675fd00d6e880a9a0f522361184
+MKPISIQILSSFLLWLVSTSFLINLARSSLIGIDIGNDNSKVASIRPGRGIEIVLNSHSQ
+RKTATAVSFSTSSPSIVRLFGEDALGSMVRNPIRTLLHIPSFLGMCGNDIDVTKPTELKS
+ETTLPNGLRKDLFPYVIEHNKIQNGTFIRIDGHGMVPEELNGHYLDFLRRMVEGSSIKDN
+QNKKGGSSLNLNPGPVFGSETVGAVIAIPPTFSQRQRKSLVDSAEIAGLNLFGLVNSLGA
+AAVHQSTDLRNNENSTFLYYDMGAKHTSSCIVDFQPVNATHMGRTIQTHKINVLGCSTNY
+NSGGYLADQAIADLVIERIRAAPGKSPLAGVPLDNSRVLQKIAKQSVRTKLLLSTLKQAD
+FFVESLYKDVDISQSISREEFDRSIQEKILSKALEPINESLRVANKTMKEITDVEILGGG
+IRVPGVRALLDQYFGSFGKNVSQRLNGDEAMAFGAAFVAANQSATFRTRNIFYNEYSSNN
+YSLRFDDQEIPVINSTSHYHGTHHIELKSSEDFIATLSENGRPISRFNISGIPEFISKAQ
+EGGAIEDSILNVTLQIKVDTFGILSLESAYGWKMVNQTIRVPVTVPVNSTKVEEGNSASG
+SNSTGNSTQSGSVSNGDKKSSTKTIYEEKVITRSQPFMLKFLEEPLDCPLPLTKEIKQSI
+SHHINELNKLDAKHRQLMYSKNSLEALIYDNRNKLYDDIYQKVTLEEEREEITKLLSETE
+DWLYEIGDEITLELVEEKIRKVSNKTDIVHVKAEEFKYRSELITNVDKKLNYTIQTFEAI
+QFTHTWVQNSTFAEVKSMLDEFQAWYNDTKSKQSELKPTDSPVLLRFETLKKLDKVVSNV
+QRVRNIPKPRPKIKSKPKKQDNETQSSSNSTSSQFNFTTPSNNDTIDSEFIPPMDNNSST
+SSESSEASSNNSSVPSSEQNRDQSEL
+>gnl|md5|4838d1484215095008889c91ae6c0669
+MKEKTPGEAKRGDIETKSHSGLVSSFHADAPTFQPRSGFVVGMGSGAGTGTGTGTGASGA
+SGSGGEMGSGLTASAQPFIPSAIRHNTSNTIDHEHGGFQISSASYSNSQLGAQPASGSKQ
+NLVFNGSGSILGGANQDSGGFGGMDLLGNTSVSDGAIGVISGLPGSEYEGLLLGGTTSGQ
+KSSSSLQEESQTSLGGGGIHGIQYGSGASSGPGNSGVSSFQSHGMNGIDSSNYYGDSGSH
+TVGQNQSVAAGSGPGAVSGGIGLGLGVGVGGSGPSAGITQHHHPHPNVLDLSEYCRRVRG
+WNLPFLRTIPQMNAITQIRHELQLQNISLLLTQNDIISANQGHGNNSGEGSGNGAGGAGN
+GSGGIGQHYVPPIVQRIFYGLCLLDDSNVASTTRFCGYQTYAYKAINVEDYSAYCLRRID
+GFPLSEFEAVRPLLERWQKLAQHPCIVSYRQSFASLDFSQGSLIAVYDYIPNASTMESVH
+FKEPIGEPLLWNYIIQIVLALVHIHSSQLAARVIDPTKLLISYRGRLRLNCVGILDLTRV
+DESKTILDYQKQDLVALGYIILALCCGSLTIINDLNHAVEQIFLKSSLYSNDLKKLVLIL
+LSKPALNKNNLDVFILANMLAARMIPQIEHSLKLTDALENEFRKEIDNGRLFRLLTKINT
+IADRTQLNAIHKWNETGDRYICKLFREYLFQQTDSQGRPVVDMGHILDSLAKVDVGTSET
+ITLMSSDGSSILLVSFADIKHSIEKSFCEIIAATTTSSNFHDL
+>gnl|md5|7370673a54b6d5c7ee41e877ed7bc118
+MGNQLVKLRADRAQDAQDVREWAFATFPGLETNLEAIFAYHCTDGVGLLDYETIEKISRH
+LIMNFGYTDLLLRFTTPNGTLDNRHVSNGLAILDVDIRKPVTLDTFKNFVVCWLDRLIEA
+QDKDVENLNSALNNEQEKQKARILHAVAQWRERFKTIDDFHVFCDDVRDAKKVELDEVVA
+DVYDMQERLNEQQLRLLQRQKEVEEVYANVQAEEAAIQEALSNAPTATQIISEEIAKTFK
+NNIQGDVTQIAYSSELTPFGAPVSAGASTSFKRNIPKARKSTKVLGMC
+>gnl|md5|b40cdc150bf29fcee596540ef3333eec
+MCTEAEEISLKFNNLVTEFQLAKKELEMLQTSYLNKSLEEGIKLVEKSIQKLSQESKGIT
+KELRCYAEITSTPEIITIYIKNIRKEIFKLQNTIERELNNHIQTY
+>gnl|md5|c4ebec11e24790ad4266bf3dfabd3ba8
+MRKIFYILLLNLWFAYSFVFGNDLDSKKNYVVEVEEDGIKSEEENNKEAELEQVKNISLN
+DIQKESNFELLNNEKLYLELVKKETDQLIESSLSEIGSLKMSLDLTNKTHIQDLESDFNE
+KYLAYKDEVGPILKKSALNKKGWFSNIDIKVQEKLKDLFLQDDETSNKKILKNTPLNYVN
+GIDVNKWYSLLDSINIFAISMLSSGFSNKKQKQKFHKKELQELVEKINKILSLISTITSS
+SSCRQIAWGLVIIEGQNISILNGISRKLIKRSQNSISLLKSKNESIIKEHNAIVSKKIEL
+DLNLKGLLDVIIKARSDELNSIITVEDISQDIQA
+>gnl|md5|324cc9457175adf5e2ee3de93a286402
+MKILLIELPSLSLSSKEIDLTELVIARDVLEISALVSVRKKDLFGFERDFLNLQRYYIDY
+ESVSFQNFPNYYHLFLFNFSYRYLQNPKTKILSKVCTYYIFSVVIKSVIFTLLWKLFLRM
+TKKTSLFLFQKNLNCIFLMVIIVKSCKCKAHYQLQTIKSSLKS
+>gnl|md5|9ecb5cefc7d326709e8ad59bf21ba31c
+MSRDQMTYREYYDMPRSVPYGIPEGYRNDYYHMRMRRDFEGGYPPDYGYNMDGRHYPEDY
+YSYPGQRFEHHGGTMEGIRESKFSNGSDKWDRSNGERRNIGNDLIQNLHVETHRRDPGII
+SRENDIRKQIRLEEGPGGPPQQSVPSSQVGKLSMQEVESGVRISKGHKDGSGGLSVFHTT
+GKDSIWTKIDILNKKKLCYDCQKEKWRDKITPLCKECYKSLSNSSGGNSSKKECTYCRIE
+FLQHRILKKAFKVFNKEICMDCCKNLCKYNTIPVRCHFCDCWSAWNSHLLCDRCSSSREQ
+FGEPLPCDMCRKSCAFDRGEEARKKLDGRLFCFLCTFKYKKLKHEEVKKTNSEYKRAEKT
+LTKVDLPEIESKNEQNDDKNCFPNLSSTSDSNSKENVDWKIIAQERTILYEKAKQHLAEL
+QAKELSNKIETGSLITQLKESNSNLEKKNKLLEDKILRLNAELNDWQLKLNNICDEKNKQ
+LKLIKDEKRQAIQEMEGLLEKLKSENRELMEQLNSSSNL
+>gnl|md5|feef879aebf1eecf79a277d7bec49c94
+MYLEKENLHLLNGSFFRVNFKAISQGELKNILKACGLKSSTNTSSNQQIALLEGIRRYLL
+TEDLSELTDLSNPNNKSIESKRYTFDYKNIINEDTISLELILKSLRRSPLTLEKIMMSNS
+VSVSEIAECCSSYLNTPKSVFSNKIILDKIQLVLASLKIKNIVS
+>gnl|md5|0a3b52fd12de0d4115860b5e1f5c6577
+MIKNKGAMILNCFSKFSRKFQNMIDGQASYQTGLMKLSGGARLNYVFHNWFGNTLFSFDP
+LDGLSDTEIRTAIKNSTGTKSSLFVSEGAFEVLARIQIKKLLRPSLTCVEQVYDELKRLV
+EQCSLPELNRYSNLKNNMISVVNHVLEECLGPTNRAVIDLINMELAYINTNHPDFIGGAS
+ALTSIFEKEKAFLTEGLTRNNSNDRSNKQVQDSIIQDSDSVPMTPSGKSRIILNDFFNDQ
+HESRKSQYISTEYNETENISTYQNYKIIETHQISSISKPIKNIDEKSPVFPTNRSTTSSI
+DIFSPVQKIQGHNPAKIVHAGIFGANLPENEKNYSGRFGGKMGLPLVPETIETSGDPSER
+EKIESDVIKFFIVSYFNIVRKNVADSVPKAIMYFMVNAAKEAIQRELVAKLYREEIFDDL
+LQEEKGIVEKRQQCHRNINKLSNITKQLETLISNFNL
+>gnl|md5|52b7b2ff81c33e6558f112b56317b064
+MDSLIPIINELHDILTILKEGSGGSNVSNELNLDLPEIAVVGSQSVGKTSLLEYIIGKFP
+TNYIKLIVILMITIFVVD
+>gnl|md5|e3a9c2240f183d04832674bb80851d30
+MGLALSRIWNRLFGKKEMRILMVGLDAAGKTTILYKLKLGEVVTTIPTIGFNVETVEYKN
+ISFTVWDVGGQDKIRPLWRHYYTNTDGIIFVVDSNDRERINDSRDELMRMLGEDELRDAT
+LLVLANKQDLPNAMSVTEVTEKLQLSSLRHRSWFIQSTCATAGDGLYEGLDWLARNLEKA
+AS
+>gnl|md5|e11dcd2224f040893224e042893c35b2
+MKAFGKISNSNTEKDVLFDKFINNSRKYPGHIIRYSHNGSPLWISDKNIPSETPQKCPLC
+NSNRVFEFQIQPEAIVLGNLPNKVEFGVIAIFTCSKNCRIDYYAPEYVLIQNNPY
+>gnl|md5|6628cc4160ea3d12bf1b22d24d9250bd
+MNDVLLGYLEKPRTPLVLDSRYFPSKFGGKPAWLNPQNLPQYRDLQCNSCGTRMRFLLQV
+YAPQDDREDLFHRSIFLFICTNCTCSVQAFRCQLPRMNDYYDYNPAPTSFLFEDVNPEET
+ILELKELKFNNICNTCGLPLSTESKCQQSNTHDKCNAIDSGASKVILDEFSLDIEICSTD
+EEDEDDDQEEAQDDNFENDPDEEMTPITGENDLGLEELPDQLDNINNKPYNMLEREQRIN
+CEKKHFESVNKQNIDPKSSEYKLFKNYKEKFSENIGKFYDLSNQHSNNTLLSL
+>gnl|md5|8760116791d94f0d32f2db6f68038ed9
+MDSTAEVYSLPQLQDRIKRDPGAYLSDFELQLQHFYSTLDVFRLNPQNIPKEIFQLMIFI
+AQTCPYYYKYGVCNKFIEKLLDELKNNSSLMTSDMRVSMATSLILLSNQKIIDIVYLLPL
+WFDLMRLPDKILRSKLLKHIVSSIVNANIKKTGKKTSAKNRSKSILKSKQIGTSFSISET
+TFSYFAETGNDNTPDQALKQLKSYNISIGYDLKKFNSTVMSFLRERIADPKDVLRSMAII
+IDVYRQHVWNDAQAVNIIAKCCVGSTSPKVASTAARFLLGRNCSMEELENDIEDEDEKRE
+LAAEAAKAMKSALLGISSNSKKKKMEKAKQAMKKLEKQKKNKTENNSLIKSNQCIDLIHC
+PQEFAEELFHRVASHTDPFEVRMTLIGLISRLNERHRRISYQYYSYLGRYLSPNNKNVTN
+VLAFLAQACHELIPPQELSSTIKLLMDNFVNECCRPEVIVVGLNTIREICQRVPLVMDKD
+KLLDLANFRKMNNKGVSIAAKSLVNLYREIMPSMLHRSLMSKDAAMNMKDENQDENSFAY
+GYKKIDQTISGADLLIKYNNRKNKSKKDTEPESCQSVKDHDYQVDEDSDHDHDEDYIDDI
+DLEEIDELSQVDMEELASSNEDDFEDPDESDIGSDIEDSTSIKVSKSSENIMDSNNIVFD
+KILDQDDFKLIKKLKTRVEAAKAVGASKGPKNEQLDFSTASSDEGFGSGISEEDNTSDSE
+SENDSDSNDSTDYDISRDIRDEITRNMGRKKLSKQQRVQSIMKGRQDRETFKERRIRGKF
+LLILMVQLFCFFCACGSVIYKEFREEFKANGLYFFLSFSSSKQLSG
+>gnl|md5|b9b42086160dbe98e256b5e3efad3bbf
+MKILFFIIQIYTNIVIVVYIGILKLLSTFKRIKKIHQGFINPRFLVKVLEWISNACCYNI
+YSYKKQLPNKYQWNLLIKCAVYDSIITCLNSRYKSLGIDDFFKSYRIKYQQYSSILNKKF
+NIYPRSSFSIIKEHCLDLPKLYRIKKKG
+>gnl|md5|c095f03ed9116ba1e6f59446a3c1872e
+MSVLKGALAVLMKQEVLTLGEYLEQKRKIRVFKEEGLYNDSLGELRRLLEKTLILEDPFM
+PKALKEGFLGLRELTFNSLDNSLDINGDRRKLFGINIEKLLEWSSILGQNYFSSPRNQSS
+MSSGKRSRNNEYNETLPPSFITDQIKNIIPDSEKDSPTYQVQDFELLLRKHFPRIRIFHS
+GSYSGLRTSFDTIKHKKYSFCNSTSYKFQNLHAWNTLLSKIGPIEILFLFVCCIIFRILG
+DHSEILIQQAGRMLTNDFLEELARLYETGPKKTNSFVSSSSLTPILTIEEKEEVKPLDET
+PRQVNKRSGGIIKDSRLSKIYKIDIPYRSTFLYCDHFSKRGGLPCLSVLRLLPPNLLGAR
+TLLRFIIQTDHIFKDHNRQSLIGLLGSYEMTKFSRVKCKLASAMMEEFQNLLLNIRNTSP
+VDFLGQICPIEPIRDSDLQNFNKLPIPCFETSSTRVVNFLRLYLIKVLPKNILGTFKNFK
+TFINKKIPIIVNLHIRETFKIQHAMNGIEVSNWVNRILEEKSYQFIKESKNLINSNQRSK
+KVPNNKTRSSIKKSLISLGKTYLARNMYFLIVYLVFPILRRHFYATEIEGSNKVRYFRHP
+VWIKIVRQADKWYLESILKGIQSKDYIMNLSSIQEISKLIDKNSEFSENIPKIRWIPKSK
+GLRPLINLSKVGSGQILQQNLERDHTCEEKKKIGFCDCNSVWTGGDLPTSWINNNYYYNY
+YNSNGNNGTVGNNHNYGHINNIGGKNFTSFSSQNCQIMTPPGRLGVGLGFGNYNIGIGIN
+SGSSVPTTPINKVMRRPSSNRIIDIRRPSTNNMLFYPSKILRSFLLRMTGKNHLGASLVQ
+FGDIYKIIKNWWIKNRRDKQQFQMNEDFYQNQGKKMSHVKIYIIKADLVNCFENINKSKI
+FEFLDVISLPNEISLLSLYSRALSKTTIIPPFDNMNRDSYQDELGRSCIITSKGKLNMVP
+IFEKDHDEDHKVVKSKIKRIIGPDLDELLWNLKNSCLSNKDLSILGQKKAEIFTFLNSRR
+VINWKLVKEIIKIHLNTSFFRLRTCSKSLRLIKSKQLGNSIKFGKRFLSLFKQDFGIPQG
+SSISYILCCLYYNFLDLNPEIQNLLGQSFFSSSCISLSFLNPIKQEKAQVLDPTKKDLFS
+QHDLETGLSRYPEFKENEINIYNTSTSKKRRLEISEYNINAKSVLLQPSEEFDNNINNQN
+CQIRVNLKNYDQESPSQSNKQESLLLRWVDDFLFLTSDLESAKKFLKLLYIQKLWGSNVS
+KDKINSNFPWIDHNNEIIIFEEDDVLLSSPSSSCSSSCSSSSSSSSSSSSSFPPSTECLS
+SPVEERTNTSKGEKDCQNEKEMINKAKIALKQFHKQVSWTGMKFSSEYNYLNCMVSPWKN
+LEFICVMDTVTLTTKHQFTSNYSNFHRFKSMTISENLQKSNYMWSVLGIKLIRYFDFRIK
+NGLLYDCKINSLFTVSFKYNSTNKQPIN
+>gnl|md5|29cd3988357e4dda3b689ee8b6b030da
+MGNSVPSSSSSVSSETVNTNRNGAENMSSPIGIKNFGNTCYMNAGLQFISAMGIFTEENF
+GGMKLNKSSSEEVCRSLISILIQLGKPSRITDAISPYQLFKQLRQQNSDLFNQHQQDAHE
+FIMYILEIIHDGTIKPCNTPKLSNEDLEKLSKKSTRPGNVFWNNHMMRNNSILNNTICGQ
+FRSRITCENCGNNSDTFDPFWDITLALPEVSDDYEKISIGSCFRKFFEQQNLFHENDEPN
+YNCSHCKSVVNATRCINISQFPNVLLVTLKRFNNNGEKCNGIVSFKTAGIILKSLTEIGH
+FKLVAVLQHNGSTLFQGHYISYVFKKEFNGWFKFDDDIVTLVDDILEEDIQAYCLLYVLE
+SKSALNSNSEQAYSVGIRNQRN
+>gnl|md5|3e0fa7eab60ec73d927a813b9a514120
+MVDEGSNSSLSPSSNSEITKISNEYHDHGSGKKRRTFSRGRFRKPGRHGSHKPDVTGLSA
+PGVPGGSEPASVISELGAGNSKGSKSEPKNNRNLGGRKDFSKYRNKKVDPKKGSSNAKEG
+VGSEFSKNGRGNFVMTKPKYSWRNEFSRLSKLYGANVIAEELVCDEDENNKPTEERKNNE
+VDDSFRKTSIKLSCKYQPSDPDFPFSKLSEYNMQDSKTESSSPEKFSILIHITIPSGYPK
+ENIDQVVFDTPEYQYVSSKFNEAFQECISKSSLTLNPIYEALKAFDRNFSELVLNGLPSI
+ESINEFILLNWTPGEQKLLEEAICYYKYTKDVNKKWIEIANHVGNGKTVKQCIDRYKYCR
+SLVVNKESEKKTRMGEESDAQYAANESKVEDGLLYSEKDGFDKTPVGELSRLNLMNYENL
+LINGLEIFSIDLILIAILRLQIYCSRCNEVNDYKPISIPSNHDLTLNNQDEARELTFLDN
+LVLGNSQNCKKCGLKHSIHFSPLICHSNDIKIGKIEFSECSLRDILPSDILVSCSNCSNF
+LKIREFFVGKQYSVSCRNCFKELKIKADGLIVGNEIFNVDKSTDFLLAELNNMKKFKKKI
+NKDSKLPTAVGTPLPSNGTCSHYKKSNRWNRFPCCNKAYPCHECHDKDNPDHKFEWAKQM
+ICGFCSREQGFSENCKYCRANLTGKSGNASGRFWEGGKGCRNPLTLSNRDSRKRKLISRQ
+LKKT
+>gnl|md5|7299956ca57c24f1d048a8cc8745446a
+MHAKLKSSQIWLFTLLIVVIVCEIRCKVNFLDFFENFVQELRKDILITDRCTTKKEEELK
+CYWIILESELIHLLKAAKSVSNGIFGFNGRTKNIIFLRKLIDLINKNTKSKIREKFIAYQ
+SYPYLNSTIISNYDIKWYNQYELEDIERIVNQLSKINLGDYGIMKFGNENSKFENNSKNL
+TIKLVILSIFYKQYSIDQLAYRKIAENTDTVNNYIQHLSKSVRTEIKLIDEDIENLMKNL
+EVSMGNKKKSLSRKIEFILENIQSKLTSYIEKINNSFDNIRKKLYSRILEYYLLVIVLAK
+LFFIFSRKILSMILLLNHILIYILDNFEDYTFMLISLQFGFEMVFAFIQEILH
+>gnl|md5|40276c89438fd51678b5cabff13d4474
+MKFIKCSKGQKRVLLMIILLLISYYIYIGGFTYSKSNNSRYVGRYIQAYSKCLHGYFRIH
+WLEIPKLAFKLTNLLPFVKRGSIQKLFDWGNLTRLNNEDLLSTKQNKSCKYLIMLLNPWD
+LPIDCISEEFLEEKFNGSSSKSSTFIMEHNLNDNPWRKELYRSISERTSNTNFFEDHITL
+AMLVEDLENELSSLIIGEGFLKETGEDYLNRLLDISLDLEFSDGECKRTVNIKRLWEFGR
+LYNELNKNSESSKAGESKYYREFLAFVYYRCIYGAEGSNISKNLEKNTNTEHLFIKLGIR
+DKTDLNKGSFFDVVACYQLIPIIGIEDNELVSLGNLCGWEFEKKNFYSQNDIDQEKIHLI
+RQHIVQIDEIYSKLDIIRLNNKYNQNLTKENEMEDFQTSYFNQIILLLKKTTRQIMIQYT
+FVSEEIGNFINSSRKFDQSFEAKSPKSPSVYPIIPTTDLKNNISNHYNKQISDSINWKQL
+ISSIVDNTQNILVREHINTMLINFLFDAIINMLNPWISLFYQASFIINSYLSIISFLLVI
+VAILVCFNTIPCFRNEKDEKKSQSIWSKVLRIYKANVIVILLNAILILGGLIRYLYLPNE
+IELLNTNIAIIKAVNKVFNIVLCPCVVNIITSFSTVFSIFQWQLIWMSRKLSFSSLINL
+>gnl|md5|1549a7e4f74fb609849ae5c9dc43d5af
+MESSKYKLLETGFWNEMPSKMKIESPKSQEISGVKQTSVETMHPIIGQDQWTNGMECLIS
+SEGKDGNSIDSKDLDDSERLVVGGVIEQNKNEIIGGLGLESSVISMNNGFGGGNNDPLKS
+SDDLSIGLSPKRSKCMLNDDLELETAIATNGNGVAGGSCSAVGKSSLKWNGGGTGSNNGG
+IVTPCSGQDNSHIVTPPPPMNHSYRQLGSMNASTISTTPTRSIHHSAGVDVDLDLDVEID
+EEEIVDDEVDLNNQDEPNVGLSGSSRANSDVGGGSGNGGSGSGGSLFSGTQNGIFFIKKN
+NGGSGVNSHHHHHHNQGGSGGQTKPSGGLGVTQTSDQYKSGYKGVSWNKRMQSWLAFWTE
+GQRRRSKTFNSKIYGFDVARSEAIAFLKAKQSELQSIGQLPSKKSMQYIRSNMDELSSLK
+SMNGMYLSNMISGRNLNSIGRPKFGGILKSQKGDMLCDYDDGHEGASLSGIGAVIGNNET
+NEGLILDNLSGTNIVNNASSGNNSNCNNGGNNSGNKVGSNVGNNGNGGVSNSISNGNGGS
+NFIGINSIKMGGGSNLGGDITNLGNMGHIHPLIGNNDLMSSLENKALINHKSLFSSYGGG
+LGGGDSGMVSGNNLVEKLGLSRVGVNGGVGTGGGYVGMIYDDTMNGGGMSGLGIIGGGTN
+AAAAAVAAVAAASTGSSSSSSSSPLTVSGSTPGSSIVTSTSNSNSVSNIGPSTSTGTGTS
+SISTSNSNSNSNSSSNSNSSTIPILGGGNGGSAHNYYSLPDFKSMNPTSSINFYNSMTGG
+VGGGHGIGMGMGNRIIPGISPGVIHPKSTVGGGGSNVGNVVQMETYDDASGLNKIAQGLF
+VGGSSVSGSSNPVGVLGGGHTSSAVTGVGGFAQGAAGGGQGIMNLTGGSLMGNVLMMSGN
+GTNGGGASGNCGGGGIGGGLEASNSVSSSTTATSLLQMALNTINDNSIKINNYLNNGVQQ
+QQQQQQKQQQQQQQQQQQQQQQQQQQQQQQQINGNGQLPGVRFEDSKLKSAGMDETKQMV
+LNSTSSNHVNNLNGYSGVELNSGGASKGGGSTIIHSSGTKQIFDEHGKTVSMGGIASLSS
+SSSSSTSSPASNSVLPGTSGIPTPSTVASLLPSLTSPLSTSQHQNLQQKKQQIHQNNHQQ
+SSAMVSSISPTSQSSQLVSQTPSSSSSSSSSTTANNNTSKSIMEGDNNNGGISDNTIGNE
+GWSDVFQYNKLVSNSMNYTISSLNGGGICGNNDKGIGGSITTSEINNTLGNSNLLNAVSI
+FDSKMGGEKAEK
+>gnl|md5|847de0206388c394f4060bd3399b0c87
+MIRIRLVALFIHSLVLLCIICYIITEFKNDNDHKNKLIKQINQQVLLEKEDAKLIQNEDS
+NPNIFFESEQIFEKNDENIFQIFNNLPEIIKSFQDHQKNNFSKLCQNYWKKGVKSLISKY
+KTSSIINSSNHSKSLILGPSFQIEEMIKYLSYTTINDDITMIKLRFKYIFDPINRKILEF
+EPIISCIPDQRIPKVSKLKQLKIRDINHTIKYIFKAIQKISIEENENNNENNSLKYNNHI
+RYLDLLIHYDDCPIIWKSMPFHIYKNDTLHIEKCILNSKFSKQMQFLLSNTTEIHHVFLK
+PQQQFNSKCNSLSTLISYNNDNSNNNSNMNICEDSTVNVTNQSSNFSFYSSSISKSYFLS
+FNYYRYQNQNNNYQSIIQNDDQNYHQNNGTIFSSLINNHLTTYTICEIINNFVKQIISIL
+SRYHIPEIMCYGRIKCYIPCFFQNNNSIFTSIFDKLKKRDMFKLFNHLHCICQFNPKNSP
+NSSGLILSISSNSNSWDFASIPYVNHLDNNELIARSFISNEYLNNNKDLWNLKNNTLFFI
+GRYTDTSRLDLSCNIYNEIYHNNFHNGNISNHVFISDSNKISCENRANLLEKLTLCDSKF
+ICRKESISFIDWINRLISSKFSLDLSGVGPWSNRLRMLMLTGKLNIIFISSIIFTFKLSL
+KFLSGTMIFQNIRSYYSHQFYDLLFKKNRLFFKFNNISDILLNVS
+>gnl|md5|2e5d566831855a36ee810089415358f2
+MNESLHVREKMEVNKEEDEKKKVINEPIMKVNESQEDSVNKNKKKLEYKKLQNKLKKQRN
+KENRKKRKSEQVGNQYKDLLKTDEKRLANNISNREEEEEEEEEDIVFKIQENDELKKMFG
+ESCKLLIGLDHENILEEKEKYTDENIEDDENSENNGNSENDENNESKKSVITFRDGNEGI
+NMKLLMEEEEEEREEIEKRRKREFLKEMKNRNNGVIGKMTVKELKEKTNHPELVEIWDTT
+AGDPEFLVYLKSCLGSVRIPHHWNSKRRYLQGKKGLERPPYKLPHFIEETKIAEIRALLL
+EEESKMTMKQKQRRKIRPKLNRMDIDYQVLHDAFFIYSTKPHLTQFGDLYYEGKEFEFKF
+KNIRPGKLSQRLKDALGMQPNWPPPWLVRMQKYGPPPSYPYLRVPGVNSQIPNGCEFGFR
+PGEWGKPPLDDHGKPIWGLLPPIEDDDSNNSKNTNNLYSSTFDYWGEVEYDQFDDIEKSD
+DNQQVEVKEKQNHSTNILTKNTSVNITNEISNISRTNNTGNYSQLVENHTEENNNTSIFV
+TSNPFLFTQNQTIIRDNHKIGNDSQADQSQKQPLYTILERNEIKMDNNSIFPSSYTYNYK
+>gnl|md5|525ce2b3717ed74b788fedd1f19edbf4
+MFLRIPLFILAFIGIFNSNSSFIKSPYKNYEFKYVQYFESFSFLKIKASAPTSNFCKNCG
+SRTFRVGCLCSSIGNHRERPGPSNLLEDSCSARRDSNSRKDSKSRKDSKSRRDSKSRTTS
+RSRSGSRSRSGSRSRSQSPKDSKEQITSTTTQHPLSKIKDPAVKLRLKSEKTVEIQNFKS
+VIADIKASIDDLLSILILECPLLFTLQFSALSVEELKEELIEVLTSFAGLKFLRQTHVPF
+LITKEELDKLQGKNNLTIERLEEMLELCLTTSHRIIDNLASIFDKKAKIKELKQEIQILM
+NLN
+>gnl|md5|0bcd2463b7ebbbc34730e80a2c378c75
+MMKLLLLVFFIIYQFFFNSFFSNRVCLFETFKLIEEKRNSQFIGISILKLQANAPSPNRN
+KICNCDSSSDSDSADFTCNIHRHSHLSSPNTSETGRDSSRDNSRNNSRSSSNSSYRSRSN
+NLGESRAASNDKNNRRESSLNAAHHSLGIVGFHFRNYSPKPSNFEERGRSRTRNRRTTTR
+GSSSRDKGTSKNKTSRNTSRSASRNRSGSRNATRFRSKSRNVSRSTSRNRDRSTSRNRDR
+STSRNVSRSTSRNRGRSKNVSRNRTRSRTRSRTGGRARSRGRSRGRSRSYNKNSNSTSGG
+ESPSTSAYSHEENQQEEQAPSESLLSHLELSEEQKLSSIEARISIIRSYKESCLDIKSSN
+QHLFSAFVRDCRLFLSESFSNLLDSELSELLLELWSDLANSKSSNNEIIPEILSITEVLS
+RNVIAGLSLEELEEKRKHCKQIVTMLLNNAETYIESKLKIGQLRKEIKYLSK
+>gnl|md5|2538741e9f6945be0178b9953d0051f3
+MFVDSTKTRNRNSCSRDILNGGGVVPLDDDNVFWMKIEDEYFGKIDDRMKDILKFHIHSS
+EYILNIINDNFLSHYQEKEQSNFVKTSMTLMEGLKGWNRVPREINGEGFGLFENNGELQN
+ILDGYIQDPLKEEQNKLLDFEDKDKEICDEKRIKSISLTLSIPPLTKPTDFPRELIHCRS
+LRDILYNLVKIQCAYKYTRLNNSRNLYSILDIKESLDIQDNSLNGTCNYICLFPDIISGP
+SVEWRNNLSELDKEKLIFKDENYYNYNDTSDEWIFNINNRIENMKLRRSLLDTNHLLPYN
+YYKSELKEEKDENMILNDNMSKQEGNNKIKSILGTGEGLKENNYEYFRMDPKDLVPVVDL
+EDNLYEESISTVSKIKRAKSFGDFFQENIHISPNKRLDEYNLEIMDDLENLNKLSEKNKS
+GYLNLSSIMDSNKRIDFQIGNTLNNSYYILQDICQNSLNEYNNNGEFDQRYLNREKDKEL
+SEVSISLIKRLRYISSLKLGIFREILFRVENERQPNPNYWYRKEYELK
+>gnl|md5|7d524ee94a244a26a5dee6e623dd237f
+MFGNIFTLPNIVRQTFLADLRDDTRTVIFLTRLLSRSNTINGIQGLKNQDEIIPLSGDGC
+LSIQKINSDHNNSKSGDDNHPPISEENLIVLNGFAKFHLYMPELVYVQSIDTVLSRLATP
+WSGDIIFWQKVMAENAFASFGISDLSHINSYKYLDNSRIIIASIFGIMEILLNRMG
+>gnl|md5|5b76ce5469845441e767ea062f196556
+MKGNNAIIDSRNPLFSIKIEFNQQTQSSSSSTTTTIATSSSSSPSSSSSSSSSSSSSSSS
+SSSSSATTSDHDISYINKWEDLIQILVYEVVSRFVYGIGIPKQKIINFSKTQRRRNAAFN
+IQKNLQSSFGFVEGMGIPPSVSRTGTSKGMSTFTTTTAVKTTIGTTGVTVSSSTSTANAN
+ANTNANVTVSANAKTSNTSSAGKTSKMGITSSSETESFTETNITKVINVETDVITTKGAV
+ELSLEGTNEMVISDDIGVLETSNNNSIQNTCPACDKIYKRDWQQVCLDWIYCDLCNNWYH
+WYCLGLHKDNIPSENEPFHCLYCLERKHKGKRGRKRKNLRMDDFNNNYSVNNGKGMTTST
+VLATGSDNIIDITQEDGHFNIQEANVFSLSSSSSSSSSSSSSSSSSSNQGDVMTQSAITM
+VAKEAEVSGNLNQGDQQAVKLGSLSSTSSSSSSSSSSSSSSFSQSSQSSSYSSLSSLLSQ
+DLSQFSSNSYNSSPIRKWVKKKRVNYSMKNSSKSNNNNNNNTNNNKGGDQKVALKKKNSN
+NSKKNKKKKNKRSF
+>gnl|md5|c0322ce1ee5e8ea42ebff51fef777cbf
+MASSNPSLSSTTGSESILGNSNTLSGGSSLFGTSSSSLASTNLTSGVTTSLTSLSTSPSL
+ANANTNSNLFGNFSTSASTSSSLFGATTTPASTSTTPATTVPATTTTSSLFGTSSATAPS
+TSTNNFSTSPTLSSSTSSSAITGGLLGNTNLSTSTTTSLFGSSSKPENNNTSLSLLGGTT
+LSSSSTTPNLSISNSSTSPSPSPSPSLETTISHQHERVEDVIKSWESRLAKQVKLFNKAS
+SDVLEVDKAIITYTTKLYSIRADQQEIRMRQENMDNRIDQIAQQQNSLSNTLKIIEESFS
+KKLEGSSSINSFSNNNNNNNNSNNNNNNNNSNNINNSNTNNMPRIGTTGGSFSGSHDKPN
+QNMRISAARANALSSELQDIESQVETLMSQLNNLHERIYPSPLNEIVKILNMHQLTLQSI
+ESEAQRLKEKITIAEDCLVRR
+>gnl|md5|5f3863b08922fac80dc23006d3aeb740
+MKDDQSYNEEEQKQKLLTTYNNLSDSVISVAPMLDVTNSHFRMLCRIISKKTELWTEMVV
+DDTIIHCYNDENRRKILQDVHFKKNDIENPLVLQLGGNNPQKMEKAIEIAYKYGFQNFNL
+NVGCPSCKVASKGSFGASLFKNPLRVAKIVDQCNKKLIDLGLVNKRISVKTRIGVDQYDT
+YQHLYNFISLVSGCNINNQNKKDYSCIFPQSDDHSDQNILESIDYTENKFIGANVFIIHA
+RKAWLNGINPSKNRTIPKLKYYWVYMLTLDFPNLTFILNGGVTSIQECISILTGDWYIQW
+YLNNYKDDIKDNEIEINNCTKIKKIRTDHLKDDHHIETLSSNSYFTLTQEYQNLYQIIQS
+GKWINKIKGVMIGREVMNNPFILSKVDSMIYGISYNQVSNNNNNNNNNNNSNSNGSNTNS
+NNTNGNNSSIHLTRRIVLERYVEYLSKFKPRNIKDQGQFTIGELNMYLKPVFGIFHGFSG
+TKFWRRTLSEFIQKSLKKEDDILNINSPADILIQSMNLFSKDYSNLLDSIV
+>gnl|md5|138f9676ca38290eee9a842b096e0731
+MIQLILARTVSSLCNCVTYFSGSTRSTGPNFHYRGFNKTRNDQTEYEIDSLLMEDDLVDE
+LAATPLSAEEIAAKLSNSNTKQNPSNLLGVRDANIEGGSIGARGADIWMGGGGSSMGIGG
+RMERNENKISNDWWSDGEEDEEDEEVEVNGGFSSNNRHNFAVNGDRGVGTGGIGSNQLNE
+KVINTTFFNSNPTLIGNSVEKNIEEDLYFDENMADISFQVNDSNNNQLQNDNWDKEFFDN
+YKGEESFDFVPIKENLDDFSIGNTDLRLNQVNNEIVFGDQNDPIEYKDFNNNNNNMLSPI
+IENKDFGDFTSGNSPNNNYIINNRNDIDTRNNEYYESEIGITTLKNNGNYFDQENDQISF
+SETYNYQINNQVNHIDNQQNNIEQVNNIFDDFSNYNSPEKDDSDITGKFVYSNNNNHEIS
+SSQNQFDFDDFIDTSKNLNDDSIINIGQESEKIPVHNSETVPESISVPISETVSTTLSAP
+KQVLPVHGKNVIDDFDDIFNSSSTSNDNFNTNIRNNYYGDDYNNNNNSITDVFDFEEKSL
+QANNNNYSASTYEDDEFGIFDFVSAKSPPANDPFKSDFLSSDRDSNKNNQQTSILL
+>gnl|md5|38a1797c3e7053d93b52915e16cf0bfd
+MVIRNGTWGMLDFSLKKMNLKLIIYLSNIFEYRNNQKSENILKRFFECIKLILKKEATRI
+VKIKFKIRDICIWSILYERIKRTTTTTSDNDKITSTVDMYFTKTCSSLDYVCLSPLKNLF
+SEYSSSMLPEYITIDRKNKNPGQNSIDDELFPSWEYGLSLPLPVPFNHPDLLLNSKPKIF
+PVFGKRPIEEEDFDNEKKHKRCFKSAGKEIYIIPIITLKSNEMNLGTSSSIMGSPISIEI
+TISPTFLSVIPLIFRQFIDISYMYDKFKTIHLDDALIGLNRKRSSNQSFKFNQDQNTLKS
+QSMFFEAQKTNSQDSKHVDTVTSLLKSLKNIPITSIEIRSKFNTMVVIFPEFNDMEMSNN
+VSSRYFESYSKKINSRIKEDSNFLLNYNEEEIEKEARERQIRKSECTNKNTGTENDDYYI
+SVFSNTYHPAIAFSHNLNFLFILETEKEGKDEKVLDHESLKISLEISQLRVQLPFVKNIG
+GNYIMDEIDKFNSSKDYFKMMSSEDNVQGRDPILDVFIPSLNSCFVLSRNIQNEVNTEIH
+GSDTFGILFGMVNIPIVFAIDGAGIPVMDDTFILRNYALRKNGGENNMNILVEDMEKVHQ
+EEGMMELRGGDLNGEEDPCFTNCMMNRPELLGIIINAIGDHYLQIQANLNNFRFIFSLAT
+FSVSAPYIQRINSWWNDIWLIRMRYPRCEGSTMRYFFVDTRSDGINISSYGLTSKGTKFD
+YIIEDKVEEEDEEEDEDDDDEEEGKENDRRKNNNKYHEKEQNEDETKSLDHGKGFKWKCI
+KGTNEVYSVNSFDYINFEITNPLFFPLDESIPIVLALPVTACLDDIVRPWNSLEFEIKDG
+SVIQFDERLKSFNMEILIEERRIGFSKSKSIVTGSPSLRLNKGNDSYIMKPQSVVKLDPF
+LICHCSNKSNLSRINSNISDSNLVQNEFAEFNSDEENQALMDFRFSVKMNEETLGIGEDS
+HRQLNHGGEGSFEYFTLAHSNKISKSQKKVGGFLNGWNSFKHRLSSNSSLALIPKDDHFH
+SDHQFEMVDNDDNYMKTVTRRHSASLDNLVSSSRRSFSLFRRRFSNEVGNTHNHHHLNLS
+PINENDHHQINSKRSDLRSGKDNINNDNNNTNNNNNNNVNNNNNFNSSVEEERIFKFQLS
+LNNLEIWFHRDNKKENMSVISKKNLDLEGGGLFPIPKKRYS
+>gnl|md5|8df6fc5f974d2f1b26bd952ccc7f99d5
+MLIDDHLGSNPFAIEIICDTFNISSINDSKILSREELQGKKSNLLQFLWIRFYGFRVIFR
+KFNDLLLTSVPKNVVTKLVDIEGDTTTALGGDDDETGHASSNTNDSSSSNSNNNGFFSKI
+TKNLLPIFFSSNKTERQKINFMSNFLCNLNRQDSSQFELFRELSEISVGSKEFSQSELPK
+HTQNGNSKFIKLPEDPSSSIQMTKDQGIELHILFKRWDIRALNASNIMFETIFKDEEQYS
+KYISSREWKASKLIFLPSSDKHLERPPSVDDYPDENFELNCTEDIISVLYNFINYFNQWS
+SFLKASQYIYNNRKTHKDLERYLSSIISYNKGSKMNGGPSNIPKHLLAEIETEISIRDVI
+ALNMSANEFLKEGFLSKGGGFWGALNRNSKVDPDILHNFIEERVLGNSAKNRDHDHDGKK
+GIRDQKFWIPEPKQVDSMKFSTFNKWFSSEGKLQVTIPKARISIIMSDLSSISSKIIPVP
+DWMRPLLFTKSPNEALVGKISGLILEFDMNMLSDKISFYHRQTLINILRFETFENEFGLI
+CGLFKKSGATGIEKNNLFNHSLMKIPSHAIKIFPITFLPSIKILEIGLSDKRVLSKRNQV
+KDHAFQDLIDTFTNQSFVEIENMNKLRLVDLEYNEIITNDCQQNKEKMKEKIGLSINIHQ
+LFACTVFNDNKRQENTVIPGFCPNFNYHIIHDEYLPHFNLNSLEISGFNLYDLKSIWKIG
+NLVPYVTSNINSIISRSQKEEEILLVRSLMEMINISSKENMIYSIKLNKLKVSSRFPNTT
+NSNSRYSIRHLSLNKHNHDTLNTYKCLGCKINPNFRKKSNALNNNFELTTFKVNDNTDFK
+ENNNKVVIEDIEKKVTRIISEILTSPEDFLQSLKTYRVMESSQSIFRGVTGLTLNSSFGN
+LASYDYEEEEINQISESLLYNEILRYLLQNEYFVEENVSFTGIQIWISTLSFQIWTSTKN
+LSLEMEGLILSMLANNIQVVNHNDHETLMLKIQQTMKNEPNNKKELRNIIRKEKEQALEF
+FNLKNISFYSFENQMDLNLSKISMNIFPAIMTLINGYELLIFPKKSTLIDLKRTFENIKS
+FNQK
+>gnl|md5|47eaeb8f6038904a7fe69145355e0b9f
+MFIFSSQPFNMRCKKHLALQNSYNNSPQTVCQKLVIVDGIFIILETILCRINCKILDIIE
+NDKFLDSDTQCGVGASSFFDLLSQNTEYKEQKIWISSLFKLMNGILQLSLLDLCGSFLES
+RRLIFISQTVMCIEWYQELYKNSSSSMIKSDEILRIYMSYLLDSGGIRIHELRKTASNCL
+SRILLSYPKLFEKNLLLIIQLINENLNNSCTCFEEKTVLNSVLIAATNALGDFNKISESC
+EMTSKAAFSMISRDSFHFSNQEELLEFLFKDLIESVKMSKEPIESNWKNLILLKNSLTXL
+SSIFGNVKLPEDFLTLKNGGFLKEENSHFILRHPLENVSRQIFETICLINLTFLQICDSH
+LHTNITNNKSQLEELNIISLFNAISDQEWMHRSGIKNQSDNKIIKLSQITSYKMIFYNSL
+FQIRRITFSIKDILIRLLVFTFTLGTYKDIFNDQSNKMILNPGQYFDEVNVNLLIKTLID
+PIRSLPIHILNFIIKNGLTIILSPQSLPRFQDGHPTDIFLEEVFSNRFVPIVLDRLKSEW
+QNLMISQAFILSSSISELKNLDLENISSSIIPFQDPFKVLLNLNFDNNEFQNNVIQDNSL
+YNVIYNSHYNDLSETCLTILKIINRFILSTNRQWQTNFKSKTGSKLINYPNKIKSLSNNN
+EDFQMDSSFSGCQYNQYYDDHEFQDSILMDCEDSGNHSSQKNKVQPKHVVLSQVFLLNQN
+LMRSCLEILIEFLSFPDPNILETSLHIIQRYLQLYINFTNQGIHSKYSHIHIFLIKNLLI
+QLFKVGPRALPFDPLNLSPSKNDNIKIVTPLNSYIKLDHPKLL
+>gnl|md5|329a40bc1eb9228d5a9e513c1d608ec4
+MAIMSCFSPKDDLKMVISGVDDYLKQLDLRLKETNHGNGGRGFNIPTLRDSQSYRRSVYN
+SNGDLVLSINTKDKYVRIFDTESLSPKLKFGYFHMFSSQYEEGYKRKSPTRSYPVVHTFT
+ESNVNRNEVIHSNTRIEREIEGEIDSRSSSQITQIEETSVEGDNIRIHQTSINEEENELD
+NEKKDYSLLSVRGHPIYADVGGFLISESTGNSKLALLKFGKILNNELK
+>gnl|md5|258ec1435f664e869c59f0de98d81869
+MLCSNSIIFNMFATSINLQDSAFDNDQSYSCWCEYPKSLLGCTWYYNPNRSNLKDIRNFN
+SGIFSSLQNSSLSSDNLPLSIGPKANLELILNIIQNPQGLEKQINRRYITLNKEETCMAD
+LIYLIKANLDGVISDGFKDEHCYNIFILKGIGWRKLSNYENEENEDSSEIFLQEKEMGKK
+VYGESLTKNEKILSKLKSYSGDLLGSLSKNFFFVNGEKIKAEIKQIGTEEIYEDLKEQFK
+IHKEFIIPISWSSDGLRLSKISFLPIKVEEEHDFVLKSNIDNTNESVENQFMIQRSFSGI
+SNMSTMPSFSSFSSLEGHMLNSNVRFSKCRIITLYRELNRFKDNKEYSGDISVENPESKD
+NFCLKSLIKNTNEIYKDLIVGKFYGDISSRFLSFDSQPIQNTLYFDSIPNSENNRLDDSF
+KEDLIIKNQYKFTLLQSSQDTRQFEFHSDRSDLILIGTSLGKVKLIDRYNDVILAEQGKF
+I
+>gnl|md5|80fb1aa4f88566ca844b6cfa7fe23ad3
+MEGVKYSRGGKVHIGEERCRGGRGGGYVGMFVDGKGNGRGGGTYRGNRFSRGNKTKSGSI
+YRDQNTRLDFTRKLQSSTETTVGPDGLEKSSASADCSNKVIIDTSDLLAISFRISPEKKC
+DEKIGVIPNGISSTEASEYCKSQGSSQNPSPLGGCQEKFNTSSNFYGDSKHFSNYKHYKK
+NHFQSAYRGRRKMFNKTQGEKALEMKREPEKQDLTSPTPSPMEPAQIQEVESINTKKDGP
+KLPTSDKKIPDREDILESPSKMPDKNSKCTETLIKDQDNNINSDSQMIRDVINWMKERQG
+EAIHWLKENGKYPQEEYVQNSVRKPRKFSQDGGFRGKKQSWNDSERNIEEKNQRFPAKYK
+GQKKDTLSFSYSPKTLVNPTNQDKSSNSTSECLELSQCRETSKQFGANIPNKDLGQKLDL
+RAKQKFEYNRRFSREKAGNFRFQNKTKENEPYRSTGTRNDSKDGEKSTNSNSNFNTPTKY
+RNHYHKKQSVQKDL
+>gnl|md5|0975b237f0705261fa6a1fe2c4f2c18f
+METELGLSKEENGRTGVRGELFLNFEEVGRIQKFLMENSGSFGFELSPEPVVDSSKKNSK
+KKSISGGAKVNPSGIVIGEKRKSRSSRPSYSRELKALLEDGMSILESRHDNKGGNSQSSV
+GQRGNVEDSQKRLPDWAKRFHRILKVISQQEAFSPFVSAVNIKNFDLYIKGDALFSREGV
+EEETFDGIPSSENKKKEIDRLFLNAGQFFKYIERCSPIKPISLNCIISKLENNEYLSAAH
+VFSDIYSVWICGFRSVEPGKALWTKAVDASLNLNLKLLNEPLQDDFLLTFPGGIPKGSTK
+NAKSIIDGSSALEPPKKIQNTGKNIGSLLFDDSGKDPNYHTLGKNKKSASNNQSSQNSSS
+SKSAKTPKKHSQASSSSYGAKGITEPERHEFQSLLSQLSQNDHVELFNSFFSTAHWKEVN
+SGEVELDDQQTPPNVFREMIKWCKLKLNIPILEGTSKKDSSSNKNTCKRARQQKAPSGLH
+SSQKKKSHLSAKQFFSSGRAFSSPSSSSASEDEDDISLSGNLQISQQWASTSSSGESDTE
+PELTSFYPHFNSK
+>gnl|md5|be5658ad3bc1d246173e5b57e3679838
+MKDNVRERLILRLGITKNDGERRVHASGHDRSMTHSSKKAYGDSTDEIQEHDDFLFRLLD
+LSQNDSSRLKYLEKLSYLKIWVPSAHRPPKHQTAIIFDWDDTLLCTTFLNYQITKRNRIS
+GSSNSQQAVNDSAQGKLEKDIIACQGECSDNFLSTFPQDVQIIMNQIQKCVVELLVKAMD
+MGNVFLITNASEGWVDYSAKMYMPEVVDVLSRLTVISARSKYEHKYPGAYHKWKFNAFLE
+IQKKLDSETITNLISIGDSIIEMEAVHILGREFSESLVKTIKMKESPTPDELFKQLSLIN
+TKFEDICLNARNLKIVLEKRSL
+>gnl|md5|f4b12efd1c563fb430df715fa7a81463
+MEVEGKYLSVNTEHQRSINTVFSKNIELLRLAIKRSEDQGMLVIVASGNYESDRNNDIVP
+TFPSSFK
+>gnl|md5|84ae5ab88adc44b71664856238db7805
+MNSEEYTDWYSLENLDNTRLNFDELKEESGWFNIEIDKHDGSDIAGFGASESLIWSLSIH
+FRSITLQDPATVIFKAPNWYKIIKSTNEISPSKCPKTSPPYPCRRSTTNFSDHEIEITSR
+IVCSWKDIFDRLNCEPLKIEAYKVSTFGDQELHSMGYVNLKHILIQTEKTNPTVSGNYIF
+GSNTFRIWPTRILLYPVSKSQVPNDHKNTSNELDSLSDFELEPNSGESKNKNSENSVTEE
+EKSVPIGLIEVDIVLQDCKKQPISDGSSPGIRQKSLNTKTDQNSSLFSRPRSVSRSRSRP
+RSGSATNESPINERTRNNLRNKTKTPPDKRVSFSPQRTSRNAKYEPGNDEEFISPEDLEF
+LKIGNMYDKLDSNIRSPGVISDFSSKIGYFTVGDVDFSNKLIETIIKEIDNDELYEQGLE
+NSDDYTSKVNFEIWKRSEKERFVQHLHNLEEEFRKLTLIRQETIMKDFIGDISRKSNKLA
+RLENLVSNKILKLKNKENSIDNINDENNRKMKLFQFEQTKLLESQKNEFKMKLELEKKKT
+QIAEFEKNKWFKKYSEEEEINEKLHKEIQSLKTGRKSDLYFKNELLRKDELIQSFEDQIL
+QLKESVQILRASRDHYKTQFEHLAAAVHLFPEKETHPTSNKSNNVYTHNIESLVQSGLYN
+EDDQFIQLLKSNNNIHSSFSNEDANNTSIPE
+>gnl|md5|63b54d8a446158528c75526d19c18276
+MELPIHEHSYNPPEEYLFDEDEISKLEKEGELENTFIPSKFDCLRRVPAYDKLITERFER
+CLDLYLCPRAMKMRMNVDPESILPPPIDTSDLKPYPTSIRIRYDFDQIIDSKNIQMSASS
+DGFWLAVGVGNLLIVFEISTSRIAFKLDISKLAQQVNIYDEPSSSDETQESNTNSITTLA
+FHPNLPILACGVEEYLFILVLKLPSICFAEDSEASTDIEEKETLDSDEIIKNSKNKEKDP
+IKDYQHSLELFEDLHTYNKESSKLELLSWNSINLDPDSELNKELSSAVVIKHQSTIRHLS
+WHNKGGYLAAVSPRAISPSQRVVIHSINRCSSITAFKKLSGLVKSVQFHSSNPWLIVATQ
+TCIRIVDLTSSKTGNKKLGNQNTGKALVKKLIGIEDPTTISLDSSGKHIFVGQSNGRIAW
+FDLDLGNTPYKLLRYSESAIKKVQFHQGKSMVFSASKNGTINIFHCRMPTDLMSDPVFVP
+LKVIKGELSFISSAIWHPRQPWIFTAGINKDGKPSLVLWG
+>gnl|md5|8faa5ee0ead6cc8c5b4acf8abdb2748b
+MNLDFDTNNGTLQNSSSRILPSNWIRVLISQRVLNIYKQRELQDKTNLIFGLYNKPNINL
+IETKLNNPDLLAEFLVKKCLSNQWKTGIDFMYSKYGQYDLMIALQTLIESCELLKFTDYQ
+QTFRVYQNLAGLFSLQLYFASSYSRVKNIDLNSNLDNYKTIQNCSSNGIINQEMKKSVYD
+RLSCIVKKEELNQLFGDLCETIKSNNNDMVGKGTLTQEYRYRFETEKIRLLNLDLVELFE
+VVSDPQICYNPAMIMVILNGYESIYGPIVHSVWPRILFIQSIIIGRFKFLDDYKHEFGAL
+NEEILISMIRLYNNSLNEDNDDNLEKINGMTFYDFIKSNDDGNNNNIFESSEETLRVEFD
+TQDLGFYHGYSDLDLDQDQEEDQE
+>gnl|md5|50f42ac2217930643b2cef02bb15f408
+MEIDEFGTEPSLERVSVAASTNSSEISGRCLAASLKLQELREHGIKLVNRVEVPHINVLK
+LTFRILTQCYRMLSRGLIPGEKLLGELFGMMDDLIIRRGFDLFKYGENEQKENEKLLDSE
+TRMFLVLKDYFGHSKKVFRDKIKKTGNIMENIPRNKTSLLTGELTRVFSEINSLRINPLK
+FAGSFEIESNFLARWNKYTHQEKQFLIGLKDIDTEANLRKYLALPADVSYRASLNEKLNR
+LSKIQNRVRNMVKERGMYYQVTEKSILQSKEFNENLDSNPVSAQILTQNLEDPNIQSSSN
+TKQNLNMSQNPVIDTCPEKSLQDEKLKILQESILEGISSTGIFIPSITIDPKDRGYSMLE
+RICHRFSEFWSSKSPIIHQYRFQMIIDGIPTEREKMIREKKRKKALLGRLAVNATKQVVS
+IQSQKQINLERKERERLRLLRENDLEAYLELVKETKNRRLQELINQTDRFLLDIGLRVQD
+QKMVGSESGFVQNSNLEGDQRETGDLIGISNANIDESSEFINIPKTTSVASYYTMAHSVS
+ESISDKPMKLLKGGSLLPYQIIGVEWMLSLYNNKLHGILADEMGLGKTVQTIALLTYLYE
+HKDNQGPHLVVVPLSTLPNWQKEFEIWSPELKILCFKGSRYERRSLIYEMRQTKFNVCLT
+TFDFIIRESGALQSMQWKHIIVDEGHRLKNSKSKFHVVLADFKSENRLLLTGTPLQNSIT
+ELWSLLNFLLPQVFHSVEDFQVWFSKPFSDLPSNEASLELSEEERLFVISRLHSILRPFL
+LRRVKSDVLQDLPEKKEYIVRMELTPWQKIVYDQIKQKAVHSMDLFSGKIXYRSVSNTIC
+SLER
+>gnl|md5|6c91a8e31f32592bf3f8267bf53da5ef
+MYLHNKESNVEKIRINFKDELGVVATNIFKRAFVSILKKHDKFHNGIVTAEKFCNSIKET
+DECLRKEDNIWGVIVDSEDKCNVSSPIITSIMSLVQITEDKYVNCKPLYLDVERIVSTVL
+VKNPYNESTIMVSQIQRTSLEKDHVKYSVRCPKMFLEDLYPPALESANKYSNKNRQNSIF
+EINRKDFSEENDTEKQEEKLPQLRALPPDKLDDFRKLYAMWNRCMLSDEDFIIHMKKDIG
+IEQIPREFLLQVANKGPSRTLSFRDAICSLFINDVDSLRKYRPDFLVPQPSRIPIESIYN
+PVTHENTIDKSTQRILECCKKGYGKIFNSIDSLNDDMLNDFKSFGRRHKQNSSESAILKK
+SIEINNQLSNKNEIQVSSSDISSTISSNHSEKPKFDFVINDIDSDEERAKIRGKQLSNYH
+RLTVTMPNTLQTQLKRCAAGETSGNAIRQYLKYYGIPISVSMDTLLRRSDEDGSVSFTSL
+MKEVYHSIKNMQSSL
+>gnl|md5|4f9b64d4caec4733d7af6854809dad6d
+MADQQDVEMAQSDHQNVPDTINELVLKEEKNISEKSKIKEYCKSILEKDLDHSINCDIID
+QSEVSEFRSQVNKMKMWPSFDHIFKAARRDNKWYLRSQPLRAVNKILFEEQKLINISKVR
+NLVIICFFSY
+>gnl|md5|a9d216a900dc4c58ad2342d64c7a50f6
+MKSISLLASVFAFLALFSTSVESVRAKASIVPITFYSTKELDSNHLIRTVLVYSGLAFTE
+TRFKKDSESQAKLFKEIIKSGFLQPSIPMISDTAKNVQYISTDEAVLSYIILSYNKELFS
+KNLLLHTISIQLSSIARSYIQKTTRILDSSKTLTCSKLLTNENIYQTLKVLNETFTSTEH
+KFLMGNKVSFNDLIAYNLILFIENVSSGCVISNFKGLRELAFNVSSIPQIFKFESSSYFM
+SLLVPGTHAFAKRINFAHSSAMFLSLAS
+>gnl|md5|6684cf8fbbffa8cc2c60e4e2d2c7d42e
+MFRNRKVLTFFLYIFYLLFGSGILGQIQKDMTEFSYNILKICKDHRRLKQEQQKLIITWI
+DEIFESKSVAFNLRYNLKKCKKSVSNMLDGKATMKDKIVKFFFERRLKNYQEQCRKLATA
+SDPLSFKKEELEELRKFTEETSSEPNSGLRLNDFYSSKFENEADSILGNSFNLGESFKSV
+LAAAQNQTSQSDEESEIVKYILPYSSYDEYLDENEIPLIEETEKFILKHDSLLLLVPKVL
+PMHMNYVKMPLPQIEPQPREIRIDYSTNAPESQIVAIDELYKEGSEASIKSRDSVIEDEI
+VDEKLDIFDSSESSSGMLSESEFIDIESINIKDSIIGGKYKEKKRFKSVSVLNEPNSTNN
+EHISFNDKGQEAGKSESTNRAQSDKDEEVESSVGSNLSETDEETSRYENSKSEESGSSGT
+DRYYETEDSTDNSQNTDDLQDQSTSESQDDSSEQSESSGEHF
+>gnl|md5|57033e0bf8f7e0c9838294c1ce311c94
+MIVWQQLRDVLLLTGMSLKYPTWSGEQLTNIISRIIPKKMLNIIIENGRNSLQTNTDKNK
+KCNQGLSELYYTFIESSKTIFDLLTVSQLIQESLSKYINTIKNLKVDKQLSFMISKEAVD
+IGFENHQLSSEEEDFLEVITTYSTCGEYGFDEDDGYASVVESEYNEFSSTNKASDLNGRE
+SKLIDSLGLFVNLSDVKRPLIDDYTSSKVNNGIGFSNRTNIENSNTTIMTSTTTTATTTN
+TKNESIINGKFIHSDTDINDYDDRKTSFEFNISNSVQQIGENVINLGISRKNLQDLVSET
+LIRNSSSSSSVYIEKEILIGVCRAIDDCIYHSNSILEHCNKNKVVKGKNSSRQTLMWLFI
+SIIIMLLIIFVGEYNNSVIEFIERSTITTGNQSFGSEKISIRSLNSKDKFEIYDADNSYS
+ENNVNLINASDCILSKDKNQSGVNSDICNVIGDITVIXKCFTNINISHRN
+>gnl|md5|e737751c16a37feca198f832723f7881
+MIQVVGISIVDRSNQPLFFRTLENESLDSLHFAVYSALDIIERKASGDAMEGSLDPYLGY
+LGPAISLSYEYEIYGFLSFSHVKIIVVLQDHPENEIELRNFFHNVYKAYVDSICNPFLLR
+TIETPKLIGKIDRLISNAREVNIHIDKSQS
+>gnl|md5|cb93caa7823738199230f7e91c4f68c8
+MEILNEVDMSVVTTTASNSEFVDYSASNNAKTSRGEDNDLSNYLESNKENLILDETNIND
+SDNLLFEKDFLSDNNRESFSEYNGSDTEMEGCEELVMMVPDLDSTLKFKHDTERFFMTLS
+IAEAELDLAKSASRTSKLAMGDDFDISSRGGTNCLKEIRNYVEELLDTVNDVRDSNFGIQ
+RIVEECNEILQQSVSQSNLSQIDTMDMNTITDQNLVSIERLKLLCEAVSEENSRLKKEID
+ILNNENEFLIHRVDHEEESSLQEEKRPYNYFRNNPIMRLFFFIFILAMFSPANISNGLQK
+AQVFEQQSGFSEIASEFLDRDYKFSKINTLQLLEKSLKGLKFEDTSSQGHPDTISICSIL
+SELDVLEKCFTRIRLS
+>gnl|md5|aff9eb2e584b8cfa93f00554687ca3b6
+MNSDNENKNKTSIKTRIEEESDESLTNLEYNSENNNTNFMMPFQNNILKLIDHLSINIGK
+ISFEGLKNVIKGKYVINPIISTEKETTLVDQNTVNDGFEGDSSTSSNGTAEPKPELSKYH
+DVTVLPTEVFIPESAKSFEPAHARGALGVMPMPMELPPQPPVSHPEDNSQISTIIINEVN
+NHGGDIPETETASEQGFGGRDDKYGPNNKYHHHHHHHHPSYNHHKHHHQHRPHHPPFNGD
+NSSSSSTSTSSTSTSTSTSTSTTSTSTSTSTSTTTTTTTTTTTTTNEEVNAVKNIGQKRN
+LRRLKKVVLEDEEDEDDDYLDEIEQEREESKEGNQVTEVKLQMTMPIITLIASETKYCGN
+GVEYLNELSLKFRETIGKLFDLSYEEVFIVKMTSTNKSFVDCNDKNAVQKDKSGVKFTFV
+>gnl|md5|dcabde3ea94afac8fff7db570db608e0
+MTKGFLVYLLFAIFLVINQVIDGVKSELSQTEKEFSEFDINHDGYIDAQEIRIIRTSVTL
+QELHQFFWEIDLDNSGTISFHEYSNFVTNNSHAHHNNESNNQHS
+>gnl|md5|fd36b1c59b586ca79756781e80803722
+MEQNKENMNNYKHNWTLPLKDFTSSKKKENFKSNDSNLSIGNNHIAFSTQTCSSSLPKSL
+NSPISYIPITKSPTSFTNTSYISSSPSSSSSSSSSSSSSSSVSFSTPSSSTQLFSPKISL
+ISSYITQEEEVLEAGIYDKDNLGRNGFSLRSITGDRESIIYDEDYESYLESTIKEPFLEP
+QRRE
+>gnl|md5|b64f8cad35847f25679744ffaf2b3ef3
+MSAEIYKEFAMLREKNFRPSINTLQEWLSITWNTTYNNGLKETKVSQIPSNSLQLFSFIL
+NDIISSLVENALRISFLQNSNINLENSKIPMQDSNNLLQNCNDLINEVNKHKESIFGCTN
+VDFNIQKVDFNQIIDTFSKSQDEIPKLNYIHYILAIIQRINEIDFKLLEYSEQSNPNNSL
+PSKINADLIIEKLYTLYSKLTGQIIRGQQNSFGGSTTGTGGKRKRDSFELSSDFAKCANS
+DHFHGAEENDYTGNEEDDMFEAIVESATSEFSINNAFPSVSLYL
+>gnl|md5|b018c7e0d9b3b2888029818da5a1de13
+MADLSKFQGLNSSQIHEELLKCPKSSWPKIISELPTGIKSELIAILSNKKANPTQNNNSV
+SEDPKENTPKKSKTEIVNDDSQISSSSPIKGQNQNETPIVHPRRISLEIETNKETTIESE
+KGNQDEICLSSQSLYSNKIFQELMVSTFSPINSVISRTMYIAGDIRPFLKNKDCQEKSVR
+LVQSYLNIWISLFWNSLINKSKKKKVSNKLTNSMIKKHFSEYYKQEVSKFDYDTLINKSA
+HRHVGMNSNTENGMIQGTDPDITGISSVVKER
+>gnl|md5|56a5dbafcec82fada41272fe7eba7875
+MSKAPDIISKTSSLFSDAFNHHIFTENSKKWLEEFIHNCVINNKKIIHSINHLLIRIFNT
+KDIQNNLSDLFKDVILNESTQDYISLAFWNVIRKSVIFPKNWFNGIKSTENPLKKLVNSK
+ENSEK
+>gnl|md5|3530221168f3e79fa31070f892808ab6
+MESISEELIKLLSREDLEDAIRRLNLEVSELRDEVKFWRCRAEASSKEQGKVLIRSSISE
+EMLNELNNLAGKMDILKIADDGINKENKEDSDSISNRKSIPKPFSVATGVPGVPATATTT
+TDAPAPTPAPSSSSALGAPSDSNSLPETENVSRTAINSKLKSMILKKAPPKMMSRADFVK
+KSELKSSGAGIRGNGNSEVSAQSQISNAIKKGSSRISLQWGCLAEEYPKFDVSVEENLFK
+DYFSEFEEKLSVLINNEESKEESKLELSSTSVFSKDFQTEELQIPNEKLFEWFIKKESIN
+SKKVTMINNQTPSKIEQLVLDQGKPLNIGDRSINKEKSLANKKDQKQTETTGSESRACIF
+GSKTSRMLQITINYFKKKLPKNQQKNLDFFKKSILQCTLDKEGVNLLLETVPDPSENAAK
+YEVWKECVTNVEKYLENNSRETLFEEEEFVYFLSRIPNLSKRLECMILRSSFEQLYLESL
+KWIEEKIRGLELILNHQRLPLLFKAVVDSRNILNSKLGKENQQEPDKVKFIPLSSLKKLQ
+SLKSPNIQGKTLLNFISSIVGEIFTTEEISIIKKSSEKNITMVYTMVTDLIFSWLELRDG
+SENLVFSTENHSIKEGITEYSDEFHNIMKLFYSEKYSQMIKLCSSFRRMLKLYVASCYYF
+GDISTFLPIGAKSIQRKHDLFETLFEFINKYNVALKQEAAKEGDQISPKSVENTPRENSK
+KLFTSTNTSARRLSHINDMKNILNPEVNSKPREFSSKNININGKPKTNIQQLFAKSIVRE
+LNLKPLFNKNNENRIDRHVSFSDGKSETFGNNSNSIAADLTNDSDKITEKDAISGTSKAK
+VETSNSILLENIEETVALSLEPFYGNNQETSNKSSAIQASEQGHLGKRFSILELSKEAKE
+ILSRNSDNNFNMNLSSSFDDDVSLDDDDNETIALSSPSYTRILDISSMLDSKIAQDEESC
+NIISTKLEKDNTRKKVVIMAEEYESPVRNNTKFNRRQSIRRMCQIATYLDNSGYNDEIEE
+ANDDLNNTLSKYKSPMVPRKGSNHSYHISSSPFSSGTENSQEVNLEYDQEFENDNSKTCV
+LSDILEISNPLDDLKKPNVNKENNTIIHSSNHLNQLQNINTNSKGSSEYSPQKITFTRKS
+GRFGGTLSPPYN
+>gnl|md5|7b1d7055673a1f3d62198e968c6e6e13
+MPQRALVTHISHQDLDTVQRGTEEWNLLEHYLQVCCRSSRSLIQQIWHVNIGSISTSFDR
+RTQDKLVLYCWVDTNELDQNNSIQDVSRRGFKIPSSGMKFTSGNIRLPGVPQASHNGGTS
+VNGGDLQQANNTRSNNMFESDYTPATRRLFEFFLCKVGVGCSVVKNDESEADGDRFPIPP
+EYDTVFLRNKQINPPSMINSKVAMDSELKANEFNLSSALALSAGVLPQHTFKHEYIIYDS
+FQVVPEYLIQFEYDSSSPELFAVPWCDECQDSPAILWCQADTARLCDSCDERTHRHNKLV
+TRHIRIPINQMPRNSGNCPVHTMDSLEEFCTLCHVPMCRLCRPSHTHADEKTPSMIMPIS
+RAYRAQLERHNKPHPCLNSRKMELLEKLESQQLIFNDVRANMFEVEQRIYSILESSITQL
+QIATESKMNKILCEQLILNQLLQQVEWSEGFLQYLQSILPPADFLFAWLKHCHYREEVFQ
+LCDILTSNEQFFPDSRLVGRVDILSESALKHNKHHKHAKSDLFT
+>gnl|md5|a15d0e33624102358f4b8de67efb48ab
+MKCLERKRLWYQVFQKYLVFVQVIFSSHIIYFSWIIFKKILWTIFYSSYSNCTYIFSLNT
+LFTSVSMLPDELGYVVQGFVSLARIQTFLFSRIYDYPILKDREFVSNQNNNICCGIINKG
+KNMINQEDINIIEKQVIEETFQKVALWYINATFARQIYDDPVYRYLHQLGYLRSCGGMDL
+VYNPPYNQKNKQENCILNFHQINSNEEKKXLVXXXXFPXXASFXXXSSFXXPXXXXXLXX
+FXPXRXPAARGGPSF
+>gnl|md5|dc4fc05629495f947c8646e50185b78c
+MLKFPRIIHTNIFPNFLSKILKIEDYQSITNIIWIVKSSLPISDQIHNYPNSSIIPTYFS
+CISINNLQKSYLAFDDFHGLVLV
+>gnl|md5|5ef451b00701f1310de938e4ed364dba
+MRKTKQSNQNQNIPENQYIPINNYKVIKILGKGAYGTVYQAIKKDNQNDTEMALNINENS
+CQNSQDKYKIKTKTKTTKNYYNNKKYYAIKAFDKDLSKKGIHPSILREIGILKELSNHHY
+FNQLFIQLEDVILENDRIFAIYEYGGISLLTFIEEKCSHYNYKNNQTYFSSNIKPTIWY
+>gnl|md5|2ff859f916507bb47f3087114f6f704b
+MFKLALRNIKMNNNNMNNNDNINNGNNGNNSNNNNDLYEELENYKSKVSIFGLDQDEMKS
+DIEESSNSNSNNNNGIEVINSKNNKESTELNDSQMLMIVPSEFSFGSNHCNRKSDLSLSS
+SSIGKKLNDDHLVNNYHQYNNSVENNNTSNNNEITNDLKGNMFKLGYDKIVSTISSALIS
+NNTSTSSTCTSNSNSTTTTTTTSGSLSGTVSRIGSPMIIKGNEMNYSQMTKNNPIILQFP
+MVRSSSQSPGGALSRSNSLRYSSSSGGNNNNNNNIGGYYYQYNMGEKVYKINDNNNNNIG
+KEENSYQKRYSSLPRHNIRTIPPPFFPRN
+>gnl|md5|9d8cd5d85f02942d92df709dee8997e7
+MRIVSLTIPNPALRNEEEIKTISLPIKSKSNGMQIIDTWPYAFPRYKYDIDDQLEISIYY
+KLKNSSNKTNSDEIHLHSVIYFPCILLDEIDKKGKKQWILGLDKFQDNNTNKLLMNDISI
+ENSLKQIKIMEEKAKRSFKISKIYLIFYSCNKTVLNIEEQLTSNYNTQSNYNNNNACDLL
+LTENHYEDYKKFDENSISKYVKEDINLDKSKSSFGIRPEDSISKISAKTTNSNTISRTNL
+IKQNLTENNDNLSDAIEMINKYRRNKSKGLSYHININQNYKTNILNDFDHHKEQVNNNTI
+TKIQNIDTASIISKTISTNTQKYLEKKKLQERLLTLQYYFSLWRQESRKERNFKESKKNV
+KIMSGLINLLLLFEKNQRFKKMTFITSLKINRFFKEMKKKEFNLEQITNEKNFLARTA
+>gnl|md5|cbf094bd4195b81a475aede7d3f423b7
+MKMKVTLLFGLLGLFSAVKGEMQQIRKYNYGKDLCEFDMNSVLKRIPSLTDLSTGDIVQT
+HLSNEEFEISSNGVSFFILSLFNKIF
+>gnl|md5|e2cec92651f90b65d367912c3779d6e5
+MVAEKQQERHTNDKKRKFRRPFQRSPTNGAQKSSIGKEKDKIHNRYVSTNANTGGGLHDN
+HVNGNISRNSKDVSESSHEIVSNHNGNKEHMSNNESRLNSNKHVNNVGSSNKNFSINNGG
+VKDQYYSTHRDNSDKGQHSNVTNNNSTYITGNDDNSKPSHAKNNKPEKIQPNHHQQQNHQ
+QQRQQQHHQQHHQQQHHQQQNHQQQNHQQQNHQQQNHQQQNHQQQNHQQQNHQQQHHQQQ
+HHQQQHHQQQQHQQQHQQQHHQQQHHQQQHQGQNTTQHPKQVSQRQIPSNFQQKHQTYSS
+SSHNSHHEGRYNQDRRGRGYGYSGNRQHNHGGSSGGGYDLNRKQPPPSNSGGGAGGTLHN
+SQSKLNQHNKSQQHFQNGPSNNTAVENTTSISSEVEATSTSSKPANTTVISSTTNTSNIT
+NVTPPTTTTKDEGGKHYSSQNNNGISTSRKDFHATPNRRGGDSHYYGYGRQHGAREHSNY
+HQHKDSIGKGGPHGGHQKDNNDASLKESRTISHKNFSNGKPGSGATTTTAVIGSESEHNL
+TTNVEQRQKNQPISQQQPQAQSQKPSHSQQSNNSDFIAEHKDVTKDDYPSTQKANTDHNL
+RSNIPSNSHNQYSHNHNFSNNGSWKNQNGGDHTYGRHGRYSGPKNVGKNTSACNGGPNQN
+FVHPKHSTEGSGGHMYGQNAVGGTTSEDLKKKKNKKRFNKNLRNINNQSGGTNGGQMSTG
+HQVGGHPKERPKYVTGDQQKTHNGDVFSSASPNENESKNISNKAQSGVTQHPSNIEMSLE
+KGKSVDSRKKLSTASNESENTGSAKVTTGSNSMSNKLSCKGSEYLDGNNKSADFNININI
+NESSIVAEKNDLKTNRDIEGREKLESSIPASENNEGSSNNTGGSGNGNNMTPTSSSSSSN
+SNSNSNSTSSSSSSSSSSSSSTSGVVGPWRRSLHGGQTVDSLETVRRAVKSLLNKITVEK
+FTVIAEKLAVCIDEIKNVDELEELVKQVLDKAITEPDFSEMYADLCQILKWRSPVLVNKD
+GKSTIAFSKALLARCEQEFKNMPRNMTPTDEEREKYDSEELAILYRKRKLHVLGIIRLIG
+ELFIRKMFPMRSLNELVFDLVMIQENPDEYAVECLCQLIMTTGYYLDSNEKSQMIVDQWF
+GRLRELQNTSISTRLNCLIQDVFDLRKHKWVKKVHKQKAKALADILKDIDVEDVLGGAAI
+AAQYGSVVVVGERSNLVGNSAYYNYMTSQEELYISKQKSLQKQ
+>gnl|md5|4ac69fc1f0c7af220eff51ebc0b675da
+MHSSRNSGDIPDMAKNSVLLHSEPIDDNSRKVLGPSKNKFTDITIKEYCKDIKKMGFQAT
+NIGRAIDEINKMLSWRLSDENIEPDEIEPYNDLEYRKNVKCTIWLSFTSNMISSGLREIF
+VYLAKNKLIDVIVTSAGGIEEDFIKVLGSTFLGEFNLKGSELRNKGWNRIGNLLVPNQNY
+VDFEEWIQPLFDEMLEMQNKDSINWTPSKMIHFLGEKLIMMNLSIIGATKIIYQFSVQEL
+LMDH
+>gnl|md5|dff5201e823c703c9e40c524c7924b06
+MEQFLQKIGVGMLKRKVINKGSYTLKVEISNEKLLLIKIEPFFGPTQILNWDLSGEIFIE
+KNPEVGIWRNRVEFIEFKHEKTNNQLVTAICMTRESENLPGKVIETRWTQPGDKNTKIKF
+IRYR
+>gnl|md5|8749f71e679a579dd2f1ad4578131195
+MCDCFTFLRQKEDYSEFRTYDFGEHFEISITSVESPGDGQISLDGTSTLYDEIMFCYSQL
+LENDDYNLYVPIEGNPNCKFFIHLILILQAY
+>gnl|md5|95ce21d9cabc89787e8ffddabda9893e
+MEAAKKAMEAKKKALQDKKAKEKPASKSSLVLDIKPSSLDVDLDAVAKMIRALKIEGVEF
+SEGEKKVPVAFGLFKLQMGATIIDDLVNTQDIVDSIETLGMTDEQKKKFSEKDDACGDDD
+EEEEEYGLVQSCEIVSFNKL
+>gnl|md5|4f7814a98f9a6d123ed267cfdf095c4d
+MRSTEQVKLIGKLASSEHTSTAEKRSRILSHAPHWXKYELAGALPVGSSVXLMALHNQSL
+LVRSQLLSSDKQLRQLVLNCLGITPDLEPAQYILTMIYELVRDDAGQYHGFVETTKGIPI
+FEKFMQFLERPKVDSYLSDKLLFFLSGLISHSNDGAYTKENITELIDHLFKTPENRRSLS
+GASQDDSSSSSIASSSNVNRMESSYSTLNGGYCSVIGALDVLGNLVKVDSYRMLVLSHPN
+VVEFISSNLSSSSPTSHIYKACVIVWLLSFNEETVPILVSRDLIRQIANTIIDCRSEKVV
+RVTLNLLKNVMNNDAAIESIIDLGLLQYLTILEYEKWLDPEIYEEIRQGQIMIDQKLKQF
+SNFDRYCIELEKKKFKWSFLHTEKFWLENVMNFESDEFAAIKKLAHLLKTSDDPVTLAVA
+CFDIGEFARLYPMGKQILGKLNVKEVLMTLMTSPNREISKEALLSIQKLMLNKWNRANIG
+SNSGSNTTTTVKS
+>gnl|md5|8c7d392fca958413edcfe8c084abb430
+MLNYTVGSDNLENGMICYYGEDEVIGGYPKRKFEEDTEEGFEKGNRKKRYILGQNVGKWT
+DEEHNRFVLALKKFGRNWTLVQQEVKTRTLVQIRSHAQKYFLKKVRGIAPSTLTMDSKLI
+STASDGIVPTWLLQDDSNFANKTSISASSNINPNNTMVNNNGVSNSGKSSNNIGGMNLYI
+YNESSNPDLSIIDEPINLVNVCNNNNLETSNNNGNNNNNNNNNNNNNNNNNHNDNSCIND
+NINNNITGNCTSMDNSNLVITGGMIGGMNILGNPILESGLSPDVRYNNYMGNSLLVDDQR
+DQCIYHDYRTGLIDLKTDVTPRLDYSPQGGGGLISKQIVNDCIFDDPYSDKRVSVDSTSL
+VSTAVSSPASISPEKNYIPASSMGLDMLLMPPTVEMEQNDSNHQNSFKKGSNVYSNNKTC
+NTNNNNPRCNTPNITSNGNTNNNNTLREDNLGIIPESLSYGLNYNFEDNENIINPSISLS
+NCDVPWPLTGGDQFLHFNESDNAISSSPSASSSISYLDLDSSSEAKHYSTRVSASPNKQQ
+YDMGNTFSDFVYCGDSLGIDLLNVYTNLRDSSSPIIDNADVTEFI
+>gnl|md5|31a118c04a83d7620c9dfa89a3f90e38
+MKSLKLVLTTFLVLTLSLLAGFVFGTNENPNFLRLVSDKKMYDEWLKTMTVSEEIILERF
+GSLLEIIDLDKNGLLEKDELMKWIKFVSERSSLKEVEAEFRILDKNKDGKLSNEEFINHF
+VSGKDESSNKEITELNNFYRELFKEVDTDKDGYLTVGEYYYLTNYYSLSKELFVKINSFL
+SQNDKNGDGIIDIEEIKQIQKDNAEVIKNDSGKLVVFGVDMSGEKELSVKKIIFLLRSQE
+IQDAITDAYNQLIDVYNTRKDAKPEDSKSSSIPIDFVRSNYVIYIQSILTDYGDVFKYPH
+DIFVGVDNKDYDLSKEKCTELFGENEKFAEKSDEENEFDTDEFDADDNNPNDDVEISDDM
+IQKLISLMGNSGLGDMDDKGGSMFDVFASKAEGAEGGDLAGMEEILKMLQSLIGSKMGEN
+DHIPDENETLIPDHEDNQEFPSLEARDEL
+>gnl|md5|0c639e1f0abd746e39fa874b50bddebb
+MHNTLSYSKKLTSGSGANVYHDDRINRLSQRLNSIHNGLDLDRSTKHYDKLAEMEASMKK
+FEDDMNRKYDEGMKKVNELKSTLMSLKSENREIYSSYCMDHETKANSIENQNYLNPKSDI
+LQAERRLNELLQSEIFSRKSMEQRLIE
+>gnl|md5|626272754e8c53f0d83d7fdb2b485636
+MKFKQRILLIFVYLFVILQIYIKFEFAGANSVGKLGYYDYNDSNASDKKRGKFRKDPSIE
+LNFMKYFLNVNKEMELIKKQNNTSINTPFMDFLHVPLSQRTIPKSEEVCSSIQLMSFWKL
+YNDVFDLVESEFNNILDLELVQKKASEELYENSLILTQSDEIKQDISEELKKIKNETSST
+NIINEHRNLMEDHVKPQRNATKTNKKPNKFKDSYINKKKQTKNYKNKKIKTFEFGLHKYF
+NLN
+>gnl|md5|9663f00bcff63320f009b8894009ed62
+MFRQLRQNPSAGRMGKRFTSLEGSNTLILQKDDASNLDDTPNNSKNKKSQGNLNSSLQIM
+TDLNKIPIRFPWILEELPIAQSFKNQFLLFNENSSLNKSESKEENVKKTFYQKAKGLSNS
+TLRQENIVKAIVSNRGIAMVRNITNVPAD
+>gnl|md5|61f5565255f6d1ffd04bb06baf8821f6
+MEKHGYIPIHVNLNISKNCNSKKKLYWTKRGPIKFCIVCGENIQINSDFFDRLQVPIQIS
+HIELKNENSISNSGSGSSSSSNSIPNSCLISNYKEYNNIIPLFNFPLITQLKILLTKNYK
+SNEIEKNILELYQKFTDITVNNINNYLYNYIHSFGNSLLPFIDTYQNIPLISIGLISLSS
+SKLRYILHCILKDIEENPKIKIMIVFKFMATN
+>gnl|md5|1247273ecb742705312e1df3d53ba84f
+MISTWLVIFFIHLIFSTTFITTFVLLILINARIRQYALIWMTWCLWLLGSFLFSFGRVML
+GLYHIFRISINIILFIWSSLLLRLSLWIRSFHTARDELYYKLEQSNSYDEWFNIGTKLDE
+ICGGYEWRSIEETDDYQWIYLKEYIIRLKEARKNNNLKKLVFLLRWCCDRNFASISKQAL
+YNKAFSGTKILIDEFEDEIENVLKFLTMCSKSPELSIELENALSDRNTYKLSSDQDSRSN
+SIERLISFSKQSSIYSSSSLFNKEIEENSMNFSMEDGDESFDFDDIERLLEEEKENSNSD
+SIKEETKNLYLTSNEQELSSTGRINNKSSTGRISLKNRDLMNTSISSLSEFRMENMSKNV
+SIQTCEKCLANNEENKVNKDELNSGINKECHCREYDNDLQVIDSGFNISKDVSDRWNSDW
+GYYYENKVRKNYINQFSFETGTGSVLTFSKSEGSLASNSLIHYLELLGHSTGKTALCLSG
+GGALAMYHLGVVKVLLEQDIMPKIINGTSGGSIVAAILATKSNEEILNEYIKPTVSNMHG
+HRWFPPLLDQIRHFLVKGYMIDPKEFIKTCQTYFKNYTFYEAYKLTGRIVTITVSPTYVT
+PEFTEPLVLNCITTPDILLWSAVSASCALPGLMPVAELFAKENHTNKIIRYFPPGMKWMD
+GSISQDIPHKELSTLFNVRQFIVSQVNPHHVPFVSVNPINTSIIHPERTFLHNVLNWLTL
+DIKYRYTKLAKLKLIPKLFGKDVSNFWMLQEIEGHVTITPRVSLFDWYRCINHPSYDDML
+HFITEGERRTWPHVMRIKHMNFLEKTIKDTIRNIKYGSRRK
+>gnl|md5|f8fa8ecf5478e3a085f88462aacb14af
+MPHLSLNSGDNVNVEKDGEGNFSSQLKIIANLLENNAIINWLPESWRAYCLFIGENMMNK
+SSKFKYWILVAIILIGQVPQWIILLFPSFIVNLIGCMIFGYIYPLIMSLRTSSNIGISYY
+SLNTKMGEKLQTWIIYLIIFNVLNEIFSMSSIPYVWNNCLDTFQNHIYYLIILLLQLTSS
+IIPILTKQVKFKKK
+>gnl|md5|ed18fea6bb682c56fc1ec76ae84fcbb8
+MGELNNDIGIICVVYTENGVFSNGRLSEILKSKLEFEYLKANSKEQLDNNEDDLLNILHN
+KLMNYVKVYKINTLEDLNIFLQRVIPGICLNHKIDAIFIDSITNLYRSKVSFSENSSAST
+SLIQFSNVFKRISVDQDSWLIVTNQTTTELNEFHIPGSNIFGNKQKPSLGLIWSNSINWR
+IFLSKSRSPSLEKDLNISYRELRVELSSEIPKIK
+>gnl|md5|62ac206383b814f817dbd4fdf018b704
+MNFGGNNKPFGGFGMDDLNESGGFMIDGNDSSMQNGNERKQSVGNEQKLAPLKVGMILRS
+YSNFVTLSRFQLFDKDINLFKLVGFVRNVEHDDYPQRLRFYLDDGSGLILIDWLVDNTGT
+KYKQDLVNSIHEGCFVKIFGELTLMVSEPSVRAFVVRPLVCTDEISLHDIDVASYIVRSM
+YGNTYDSGKVQLSDSNVIINKQGSMNYGGAGDSVKDSNQSIVSSMFNLSGQFGSNSNNNT
+NNKNEGNFNNYGSNNNFGNEQNISMNKPPIRVVSAIAPKSNQFSSGAGVQSNPLKLREII
+SSVLDQASNEGNPEMTIDGIFDSLLTRDVHATHDDIRNQLKNLVGEAKVYQTNPHTWRAT
+GY
+>gnl|md5|94a2981b6fa015eb1831502e61c1e1fd
+MTDLDEYLSTSLRAQENFEEEKVIKIITSHGVNTSNMNLLLRKEKMLDGKVINLPIPRRP
+MILVGPNCKTKKAPNMEYLDNLEKEAFLTWRKSIADEEELTGLFVTPFEKNLEFWRQLWR
+TIERSHVVVEIIDSRDPLFFRNVDLERYINEIDPLKKVVLLFNKADFLTLELRKQWIQYF
+KDNAPNLKVYFFSALNEINKREHLESYIPEDFNLKNINDTDVLSTHQLMYKLYELASEVF
+QASKQRYLDQKEYNSEETNETTISSIQNDDTENGQNSNSSDEELDSGKKDDDDDEEEEDD
+FEDEESDENEEFKEDEDFEENENIPNSILKNKSKAKTDSEIFNHVKLDPLNPGELTIGMV
+GFPNVGKSSIVNALFGSQKSSISRTPGKTKHLQTLRLKPPHLNDKEEDQDFITLCDCPGL
+VMPSFTSTKEHLLINGVTPIDHFRGNFLDTIQLIGERITVQLYKTYFDGIDYQVPRIFNS
+TQFLNKLCETRHLFQQGKGAIPDWSKAGRMILRDYWSGKLLYCHTPPSNTKNIIGSDPIK
+LTESLDKVSIHDNDEDSDDDIAMLKSSVLNNDIINPSDKEKKKTKRQIRMENKKLIKGRT
+VCYS
+>gnl|md5|868aa710a055d58c273ab9292a377c96
+MEDSLKLQILDIYAKLIIVVSPFGAIFFILMGILMLRSTLIIEGIPVGSENYSDSTLASL
+IAGASFLVILILALIYRSYRAKSAAKKVANAQGNQENGYNYITGNNEGVVISSSA
+>gnl|md5|a1e4c23e82e46285182deb6bfe611b1a
+MDESSIHLPVINTWNKQMEKVKLFIKQNSNIDFDDIERKFLILQKEMTDEIKGMLFANYK
+NIDFAQQKVSPSNFFLLK
+>gnl|md5|620d9a8d1fc6b365046ca318c7a1e1f1
+MNRLITENRLLLNQLKEIGKELLLKSEQIQEKNAMIDKYQKEIRKLELEQTVNKIQENMD
+KDQNLELVSKLENQVFALNQKLNIIRDTVNN
+>gnl|md5|2dc570a51d25621e6e1f4b970e5edc52
+MINGLYGLINTGTSILKGGRNPEIGLDEIHKNRIKNEIEQLKLNQCKLEKCRDNLTFENN
+RYHTQYCHFHVNNVTMYDKESRKNYVLIDISIMIEDVDTFLNNEIPVQIILYKDFPFSPP
+DITFPSTFCFPSLSDGRSFTAEILHEWSPSINLLTTVDSIIKFLKSYSTHIAVVGPSDMF
+IGSYRNPISFNYQCYNSLVYPILGTKIIFEDDVFKHIFENNSIKEQNVISQRGRNLVSSF
+IPIPLNTRGLRRETMNWRIEKPCINIDFVFNNTNVMLFDSTMLILEVCQKTKQNGIFQTN
+NPSKTSSSSDEIISDSTLQGNVAYWLYMPAISHIIDCNGKLIFGNQGTLPEYISNKLSKH
+EYSECLVIVLGYDFLFEKSPILFYQNEELIQTPKDSTRPIIIELKFHTTKANHESSCCHS
+FATNLREKVAKLDSNFPKNCHNPKWNSYFEFDCLSNLNKKYQQAITGNHIYLSSEIIQRW
+VVICSKLIEQSSLLSETDDKYIQESSSLVKQMQDILVSPVVKHILNSNTSKPSKVSSIDE
+DLQNDTFYKYLEEYSPENPSKHELSQQESQKAETPHQQDIQENQILHPIHEIQPIQNNPN
+FMKITHIDGISPTQEILHIEGTTHTQEIPLSHEILTIQETSPIQEIPPIQETSLIQEIPP
+IQETSPIQETPPINEPFHTHPQLINLDTSSETENDNHLDESTNNYGETSKSCDQNMQIIQ
+PSNYSSSLQSDHPTSTDPNQTYVNQNYISLYESSSDEFSVREFD
+>gnl|md5|3938764ab389b526e0b9c317018f1a40
+MPNPVVYFDISIGQTPAGRITMELFADKVPITAENFRALCTGEKGMGQSGKPLCYTGSFF
+HRIIPQFMIQGGDFTRGDGTGGESIYGSKFRDENFVYTHDAPFLLSMANAGPNTNGSQFF
+ITTVPCPWLDGKHVVFGKVLEGMEVVKSIEKCGSQNGKPTKSVCITASGVLS
+>gnl|md5|f1a0643a34b359473138ff3eda5d14c2
+MSLLSIQKPQGVLELGISEIENSTRKLVENETRKFEAYIDILRDQMMGMGELEHENEILQ
+GEVARITEQLSLRELDMESKEKKIFELEKSARDFQQMNQDYEKELSELTEEKNNLKTQLN
+EMNAQIEKLLNEKITSEKVVQGNDEKQIASKSKSKKRTQEEHADENNSTNKVSKEAPTLK
+KSRLRRPQNEDSSESKKSISKDTESIIQEEKLEKEENPLKNVLGKTNLGRLRAPLLRNRV
+VKAAEAANPEVENAPELKTLEKEKSGSGKSSKSSSIESKKSGKKTSKVAKIAKIPHYDEN
+ILNSMKVIELKDVCSKLQLEISQRARKSDLIQSILSFQGE
+>gnl|md5|90e6ad39203c7879d5bff4208b69cade
+MSDFTREPFPGRVFEDLGGAFSMGCIGGFITSFFKGMKYSSTKKEMFSSGMLFARKAAPS
+LGTSFAIWGGTFSCFDCFFAKLRGKEDHWNAIFSGTATGGLLAIRGGLKTSLKSAMVGGI
+LLTIIESVSIGINRKTIQTPRQQFKEYQRFVQMSEERDKKSKI
+>gnl|md5|01fef37b9ffa082e368326467a888e31
+MAEVPVSEDISASQQPPSSSYSLPPQFSNEPDVRTMASIKATLSKKAEELVKAGQPYVMT
+SLGPIPLPDNVRNQIPEKFVAAPVLEEREVIVARREVQERIIEVPQIQYEHKFVEVPQKV
+VVEKIIPIPKDVVREVEIPRYTATVEEKVIEVPQGVKFVEVPVEVPIAYPPRIVPVPKPY
+IVERTVELSRPVIEERLLEVPQKVYRQVPYYKDVEVPFVVPRYVEKLVEIPFHPGMMYDE
+NMLNQSIPPIPPQSQPPFMMGGPGSAPTSAPLLSMPPPMYGTNDPEDVASDGLPSHPAIP
+PYHMLPQPQPGVIPQMIPLANSYAAFPLPQGVGMSPHMLNSGNTAHIPGKTPVPFNPPQQ
+PPQNLLNGVNINQIQFPPNQRQQFPYQFPPQQ
+>gnl|md5|c7ca65f413aa7b400279fda3cf499520
+MSQKIDLNQGERTESKCPETLNEFSNMYKHKKMPCKSALNFGENIINMGAPSFIPEYPTA
+YYSNPEVMNQGINSLVDTKQLYDYSSPVGDLEKTIEHYKMSHEVGWNASNSFTPTNSGSL
+ELFQFERRDSPVAVDALKNYPSFERMNSGFLGFGRKPSNSIFSIGQKLERLSSNEIINNI
+NTLPEIENGIENGIENGIENGDIPLVDLEQYTQLSYFEKYINFNIDQIK
+>gnl|md5|c78770f90ccf72b580f4aedd4dc5de34
+MEISQRKHFEVDKHEKVRKEAHNGPSLSKKKIGFLSPKSFKTKSGLPLKPIFLSFFLFIV
+GLFFFYIGMALFLSKKYSDSTPSLLLGILCIIPGSYYSFSILQILRGVSGYSFEQLDIS
+>gnl|md5|322ccf0dd7d0ad380d49ba2756344fdf
+MSDQNIPMPQYASMVAPPSVVLPQSDAAAPSTSILNCCSAPQSTDNGADPALSVNSTPQI
+GKVRFASTGTTIVTRNGVISFEEFLKKGAPVDQMLIPPFPQVSGIPMFEDGTPDIATIHS
+TCNVVNLSQTNQTNTIPHSDIGTETSLPQPEDSAR
+>gnl|md5|f2e22f94d935104da067bed34c945c8d
+MNQELIEIHEIKELLDLDLHDSQLFSEIQEEDESVIEDLAGMSDHYEESGAEDISNIIQN
+LEEIMKDELIGSNLVSDDTEILADLLNETGEANMELDDNNFFIQNKVDSFENQVGNSLQS
+LGIDERLVKYYSEKGLKNLYDWQYECITQPGVLQGRNLVYSAPTSGGKTLVSELLMYKRV
+LEGGRAALVVFPFVSLVSEKRDSYYKAGGEVCGLRISEFHYGSKSPLFEEFDIGVATIEK
+ANALISYYIQHGILFKRLGIIVVDELHLLGDEQRGYILEVMLTKVRLLSKLQGEGRTIQI
+VGMSATLPNLRDIGLWLDAVVYQSNFRPVPLREHIIIKGKAYIKPGKDQNKSTLRSSVQD
+TLSKVMSWDFHQVNSKFNSTDFDIDQIGSSRWKYPIVDMSELLVIGWEALKKGESVLVFC
+PSKYSVESTALFFANCIKGQFCEGIDIENCSNSQQIMQSLRSVERQRYMLAEEIRQNSSL
+SKRSIQNNNTLIDCIIKGIGFHHSGLSHIERRIVEKGYKNGILSLLTATSTLAAGVNLPS
+KRVIFRGINIGKSFLTCVDYKQMSGRAGRAGQKGAFGESFILVNETLSQPGREVSEEVEN
+ALGLITADMKPLMSSFFTNTNGITRLILEILAVLFEFDQNISVNNREKIPDKGSYTGSIL
+DLLTESTLMSYQIKLYNDLSHEYLKNIDALERALNYLLEKKMIMNREKKTNPISIGGYTL
+NCCCTQLGKAIVSSGLSPSTGLELYDELRRNMESTFLGDLTYMSYLVTPFPPNEISNGSK
+PTSTSTQPFFRLDWKVLYDNIKEMPILERHSLIRLGFDLEQISWASQLCEDNLPPKLKEP
+EFLRRHQRLFASQIMKSILNGLSTEIILSKFKFISVRDLQQLHTGVLSMCISCISFCQNM
+NWSNMQIVFQSYLRQLQTITLLEEYSGTLTKDQNLEKSVKKLISGVKGLSFLSALELRST
+LSVKTPNQFLMIPKKILTQSINNRVYSGGIKTMQFVNHFVNKVFIDMQNSKRIPFYNRSL
+GFSNISPDLIFQTIHTIPDLEKDENLNILNFSEKQLNEIENSCILEALSEWDSFSQQSKA
+DDNNHISYISQEIPELTRCDMNNLDLENDEILDMLQDDIQDNIDLEERLLLWSTPLQQSQ
+DWESQGNWKLNNK
+>gnl|md5|7642a1ea55a4f4aad71addac03a5f7ca
+MRWKWVVSSVATLLTLIISVVNIMHQYLNLCKPKLQLCICRILTMIPVYAIISYISYLFV
+DYAAPLNIVRDCYEGYVMFSFLQLLIFYMGGDQVILSVLESNKIKAEIWPHHHFNHSLSM
+VGLASTAGSIESNEEEISVNIMDICPDYFCEKDNLDEVSIDSGLRGDEPANHHLKIARFY
+SFIKLGVLQFVTLKPISALISLFLESIGLYGSGSFSFKRGYLYITALNSISVSLSVYSLF
+LLYISISEQLAPIRPVLKFFCIKLIIFMSFWQSIILSVLSHFGIYPDEPNYTIKLHNWLL
+TIEMTVCAIIYGIAFTIKKDFKNYVESRQGYSQDDYNTDNLQDCEKTGHKDLFAGKDSGP
+MRNANFPPQASTDKPNLTLKISHSPSSISKNIKLYIYRFTCIVNPKDIIQDIVSAFRFLK
+QINKSPNPEIKLGNSGATF
+>gnl|md5|672fe69e487c5df7282562dec0eebeff
+MQKRKKKWKLAFCNAQECVNALDYMLENSLETLLNKQEKLRIAEGLSEREKELNIKQNEL
+NSALNEVEEGLRKTIELTLLEMKELSEECRHLEREFTKKASNIPNIIENLNDTKFDSEYL
+GKKVTVEDIQKLQNKRKQLLEDLEQLRKDEETLNKEIQNLEIKWNAYRKRTQRLETEISL
+KKTETNHQAIQVDAHINRRLSTCNSIRSDKDNDPNIMEVDAIQEQMGTRRKRRDSVVKWI
+GRLSMNSSSEEKTNQLSDHELVTTNVKEGTKIDNSDNNNIEDRDEEVQGELQVLNLLSLV
+KIEQPESDETLTSKAGPPSSTLKLKVDPSPLLSQFLDPNFVYCSDLEPINVDKENSRKSN
+QGLFSKGALDFSLKVRNQCDGSKSLEEISLCSQNQDATEKSLNNEDIALFNIFVGELQRN
+ENIPVSSIGKLLCSTLK
+>gnl|md5|ce8fc0188fcdbca11bfee927fcdc06f8
+MKFDSSIRSPIEARRELNESIIKKKKSLNITQPNENKDNFELKSKSDIQANSSGIVKASS
+KISDFTKICGPKSLNDNSSTENQILKAKTLDTLKKDTLLNAKGGIPLKVVEKSSTSLLGK
+SPILKKSSILLKKDTLTKDFFTKDTPIKEVIKKMISKDLTGTQSKDLPDLDGKAKSSISK
+ASEIKKSPPAKKMNDIPNTEDLDQNKELTKTFSKNFPKAVTTKSDILAKSNFSKKVLPKQ
+LGNAKPMIIAKKKSDENPISKVIPMSLPNTLEKDDYNLLIYNSDKYWSSRLYDLYRRMKG
+ESSQRDIFTKRYLKKERRRLSTQSGIEKRRIKTYTRLRIINEAKSKGRRHTLISIKPGSI
+KRYGIPALMNYSYRYTNKALSSDTEQNYLVRKLSPNYTDSSHIEYILEDTNTYVFGIHRH
+HELLSIARNTFNEDFRFCRMSKLYKYALRTKMSDLEQFVEEVMGEMIINGDLNQDSRENV
+LENNIMRLRYLINTDKEEKQSLSGCKNKSDEANQLWDKLVTRFDLNNELNTSNKILSTNN
+FWKETSKFIYDEEIDLFKKVYYLSDLRELGSIDIDESVLESIFKSIRVSYNSQDFKFPFI
+FSKEIRSSKNVGYHRKDFISYVGKLSPWTKIALIQKIKKKNKSI
+>gnl|md5|3f901d3ce328bef09c23011df81b44d7
+MGRRNRLLEGARQLHIREIKIKNEKTIRKNQRIKQKGEFLKDVLKINRIELITRGEKALR
+EILKKEVVKQEIM
+>gnl|md5|aba213b79697f43999b4fdede197abdd
+MEKLKLVVPIRRQENSAFKHIHNYDPEKVEKIKVKDDVNRLSCVKELANIGNDLNDLVKK
+IKIRRYIGLIYQITILKIHLSRLLGKVRNKKKVRILNFHMVQRHSHKKTDIHFGSAQNQN
+SPPKSPNRMDLKMLPRKPNNQYFHEGGV
+>gnl|md5|23b6fc8802a2b2b499e76595c428ea2e
+MSWCDPSHTIISLEFAYGYLKFIILYFLSLVLWGLYRHYLHLKVEAEIPSSTSEKEALIG
+FRDSIIGISLKYIYSVLILLSQIFLCIVVWNVVCATSFEVQPYWTTRAKTYIIFYMSGLS
+MCLILYFLEPFFETFFYLRETLDKCAYVKSKKRHGFTQTLRSTLNKALQREASSVQLESN
+DLILPLLKVQKRADKTRFVCHNQVTYTFLESESGFVCCDQSNLNELVGKEGLLNNGLSSE
+EISRLSNIIGKNTIDLEIPGIFQAFAKELLHPINILRLGSLWQGIFLRFYIWAILWAIMI
+IFTTFKTLKVIISNQENIKKALENYIGRPISVLRNGKKVRIPSHDLVPGDLIFLSQDLTA
+PCDIYVVSGCVVVNESFITGESNPILKVQIDRNSFSNITSTQPGNKSSSMTNYELKNRTC
+STLDSINLDKLEINSKDECNPISHDSKVLHEDKIIQKPIFMGTKIISSFSYGDYSKIAIG
+IAFRTGIYSSYGQLLYKTVHSFSNISQYSVSNVKYIRNLKALWIIMLSSAFAAILYQNHL
+LGWSTGSFFFAVGTFIQLLPLWAPSCIQFSLNKSVERLVNLFSLSSTFPMDIPLAGKLKV
+LCLDKTGTLTTNKMVFIGAANAIKNNSFGYPNNIAHLLENSNPNINLELQKNKESKSVQY
+IDHNRNSLNIYVHYELVWETSTVSYEEEDPLINKSTGILVNPISSEPKFLPPIISSDSFS
+PDDLIYIGLCCCHNIVPQITNNGTILIGNDIDKALFTSTNAKIKICNERKFISLTGANNE
+DSGSVDNIYEYPIEVLRINEFDWNNPCMSVVVHHRIFDRYYIFCKGSFDVLTKFSPNKEE
+ILTEKHKYLNTSNSLETEDEQELVDAFEVLNSSGEMDSDLLNKYNHSRSNNVQKPLNHMN
+EHNIVDGYSKLGYYVMAMSYREIKDKVLIDALLNKPRSNVSRNTLESDLTIISYLLLQND
+LRPKTREFIDSIKMSGIRPVILTGDSAFTALSVARKAGIISNKNPVAIADTIIDITGKET
+IVWYDAIAGNNMVISPNKIYESTEYNSLVVTSRALMLLRSKKYFRPSNFEMGNMMGPLSN
+FSFLKTYCRLEKFSSEELSSHSLFDLVFDRIKIFARSNPEHKRIVISEFKKRNIVTGMIG
+DGVNDLPAFKMADVSISVHENSYYFNNFINNNNSIQEESIQNHDNFSINTENSPMTLAFS
+SFSIEADNIMRVLDLIREGRAAMVTTISLFMFLSSQGVFYSFYKNVLFAIAQANLPVMIY
+VFIDVFLVFPSIWLMILCKPKKYINSYRPTGALLGKRTIISFLSLLGTCFSFYYIVMTRL
+LNSPWMIPSLNHNAEIPVERWFQRQDNFEASVTSIWMGLQLSSLSLIFSFGGKFRERVTK
+NKRLVLWVICCHIFLLYLCISSPNALTCLFRVNCTDQIDRFWEFQIFGFNILKITGGKFQ
+GAGSHNVFPLAWKVEFIFWNYFSILSMSLIYWWISSNSNLKKV
+>gnl|md5|4299e469b972ebf6f330d6ec6fb8a01f
+MKESKGSEDLRAKYGKGFDIIRKMGFKGGGLGVDGSGISEPIQVKIRPANLGIVVERDNS
+SNKSDKFENKSTEVKNIEEKNKKQKTSINELAEVINQDPEAKIYQIFPKKTFLNDIMESV
+SLQREACEQNRKVLQDYFNEKQLEIEYQSNSLDNLKEKKTIMENLSITTKQIQRIFLKLH
+YDLEKIMEDEIVNLFEEQGDVSSVENEDFQDQMDSLEKVVQEFSESFNRVLDSCGDASSR
+EVSKSYLPYCSIVRDILKVSLQKLYKKEKNMELDPDFGISAWIAIKALFVNLETSRREKE
+YDSKLCFEQLLLDTVGKYLEIYFICSWDPIKENEYGISLLSIWVHLIPLEFIKTNLMQTI
+WNKQIHQLQLNKIDSNSEGISESSKYKWLFRWLPYYYKFGMGYQISKVISKHIDDALEEW
+EPPEEWPLSLLTIWKPILETEKDYEAEDFETIGFFDHETYRSNLIKQEFDNIILSKIFPK
+>gnl|md5|aefa29892620671a915f904586703417
+MKLNIANPTTGLQKCIEIDDEKLLLPFFERRIGSELDCSFLGEEFKGYILKITGGNDKQG
+FPMMQGVLTSNRVRLLFRKGMKCYRPRRTGEMKRKSVRGCIVSHDLSVLSLVVVERGEQD
+IPGLTDGEKPRRLGPKRASKIRKLFNLSPSDDVRKFVVRRKIEGKEKTKAPKIQRLVTKE
+RLQRKKKYRRTLKERSEASANAKKEYQKLLETLKENKTNTK
+>gnl|md5|fc386f96e29ae99ff8b98592b748f078
+MHIKKVNPWFAVILCISLLNGISIWDRIQLNLDRGDNTGASISYLQLEIQNQNGAEHIFS
+PLRIKNNQLSSLDQQFSSQVKPKAYTTSKGLKTLLVSDNTMLESAFSFGIGCGYYQDPDN
+LAGLAHLMEHVVFLGSQENPNPVGWDEFLLKKGGAANAYTSADTTIFYVLSPPRELESVM
+SYFTKMLVNPVIDERSSVSEIDAVNQEHEKNIPNKVRAMIELAMYLAPEECPARKFGTGN
+KETLYINSKKNNINLKDALKEYHTSCYTSDNASIVIMGPQSNEELVKIADKIDELFTNSG
+KATKGISKITNTVTSHSDSRTFKNQHSLAPDILSIFESSGNRKSNIGISSTGRITSKQTE
+SKNKETNQDSIKSKSPNTEIEVVKMPRGSSSPPFVIIYWDSVSDSLSILKENAEWQMLKL
+IQYFFEDQSQNSIATELQKRKLATALEYFDNTSTQYSVYGLLFTATDDSDQTTSEIAKLT
+SAYMESLIEQINSKDDKWIQSFYKNYTNMANIKYEYDEERDTAGIASQAAESLLIFPDEP
+EMALSAFVKPVSMSKDSELSNAQITALKEFVKHLEPSKMKIIKLSDSLNSSSEHNFRFEP
+YKTEYSISKISLENSENTSKTIETLRSTNKIGELLTCVPGDLSIISFSEDKCPGYKSFEK
+EIQERKIGNELQPCPILEEEGLSIFWKGPIHTVPTINLTLVQRLPNKDVSNNVRVSLIAN
+LHAQLQSSKMDYILSSFKLCGLEADISYSRGRFVINVQSYSSNFEDVIEKLSNYLVNGSR
+LPTKTEFETALTNLKSEILNLSDLMAYDVATDVAQSVYLSNYYSRLQLRESLQKTDITFD
+EYIEKIKGIFSVGYFDALIVGNIGYEKSIKLVSRMVGSLVNKKIPYSNAIHDGILNVSGD
+IHIKANNPISSDKNNAVVAHFLTPPVDLIDVSIYSSIGEILNSPFYDTLRTEWQDGYVAF
+ATTKYETPIISLIGAVQSAEKLSETLVCHMFSALKKVSKDVEEDLKEISKSEFEDKIRWF
+GLSKYSSQKLDSFTKYIEHFGKLIVSHELCFEKNKLIENATQVFVSEPNIYIEKLNKLIK
+PSSSRRLVIVELIGNKSPDNKEDELKLVSIANGDIPPTNEECKEILNSEIGKATMMDAIS
+FKLGSSGSSNGKLRASRNNTSKEENSYVVYDSDIQCNISEENASFASGKDSKEVKTMLNV
+FGKRMSSMKFSSESKINGNKENSIGNKQNSNSTTKNKRSSCDHSKL
+>gnl|md5|12882478637197d8a04ada0aae0c5930
+MKSNIQLHYCYFLLSEAKKKASYIGYSVNPCRRLRQHNGEIKKGAKKTKSGVPWNLGICV
+GGFPDRVAALRFEWAWQHPNICKVTRENIESWKIVKTKKTSENKRILNKRQWSIQQRVSI
+LLCMTTLEPWKNMNLTVFVFKDELENTIKEVIEGIKKIKISPNFTSPNILNKDYLLMFLY
+FGEDSFYEKGIKFLRCDYETFKEFQKPSFDCDSDSNIEDNSNVFNPEEIISHE
+>gnl|md5|d5c314c85a1cfbbaf8413c3975f48775
+MSSLKDSVVSFQKKDGKMEELESFAKQKSQNVSKVIETKDSNSPQAGAIIRFKSKETIYC
+SCEFLDLESLYETERDQAESSKITKEVKLISNSNSHLDEYLDTCSKSLISRNSSLSSIES
+ITFMDNNEYKSQTNQINTVRNENNVKVCSENEIFNDKLVREFSESGEFTEYHTRSGFLSS
+LSRRLWDLEETLSFTNLDSISGIKTFLLGKIGHGNIGSKLNTSDHVFLGPKLDDGHVFFA
+NSRGGYESQRSESDTSEESVRYPSFCLEVNEKEI
+>gnl|md5|fbbeaf04be93bd5bd39632ba8e34ab4a
+MYENHNFQKDYKIVFGSTSESRRMVFSKANIKLSEFVSADIDERVITDDDPNKLVIKLSE
+AKMDAVLEKLPYKNGEDKVIVICADTIALKDGEVRNKAKDSDERLRYVKSYSESYADCIT
+GVTVYNYFTGRRLSNVTVSRVHYKKMPDDAIQQIVENSEIIKYSCGALAIDCPFMGKFVD
+GIQGDVDNVMGISVCNTVELMEKSIALGVVN
+>gnl|md5|42c076f3d9bbb2a122f78f63e7e1b4a4
+MSSFFHDYLSGSDDDCTAFEDSSVCKEGANEFKSSIVVNSGQLQSEKSDNFVACYEGSLQ
+KKDQITPETCIEPNLIKQISSKIGVKKKEKRKKKNKYLNEFYEISSIENVKTLDLDDLKK
+SNQEVGFPDNLSREKKLDGDKELRQSCNQKRKHQVSITFIFKYFPNSIF
+>gnl|md5|0be1ac8d58871d9e2b022ace90700f35
+MKFTLVTILFLIFMKKAKIVMADLTFMYDLVVIGGGSGGMAAAKEAAKYGKKVALFDFVK
+PSTQGTKWGLGGTCVNVGCVPKKLMHYSALISSSIHHDAQMFGHKTSSSFEWGKLVETLR
+NHIRMLNFSYRTGLRVGNVEYINALAKLIDPHSVEYEDNGQKKTITSRYILLATGGRPSI
+PETVPGAIQYSITSDDIFFLSKSPGKTLVIGASYIGLETAGFLNELGFDTTVAMRSIPLR
+GFDRQCSEKIVEYMKATGTKFLVGVVPINIEKVNENIKVSFSDGSVEEFETVLYATGRNP
+DVKGLNLNAVGVEVSDSGKIIAPKDATSVPSIFAVGDIVEGRPELTPVAVKAGILLARRL
+FAGSNEFIDYDFVPTTVFTPIEYGHVGLSSEAAIAKYGEDDIEEYLSEFSTLEIAAAHRE
+KPEHLRENEMDFALPLNCLAKLVVVKSQGEKVVGFHFVGPNAGEITQGFSLAVKLGATKK
+DFDDMIGIHPTDAEVFGILEVTKRSGESFVSSGGCGGGKCG
+>gnl|md5|1d6f411bc0a9825f445bf643027ee3d1
+MMKYPDGDYMTTINTVGERSKLVSEVSMNVANPNISGRMGEKQTRVVQIDNSRVTSVGME
+PEMKSDLDCNGGYTSANCTNIVKGKNQEDREVTQNKPLERIGPNNTDFRNSKSTSTTASS
+HSGSSLSHPHNKWSIPSRYQVRHLIGTGSYGHVCEAYDSKENRLVAIKKIHRVFEDLVDC
+KRILREIAILSRLNHDHIVKILDICVPEDTEHFDEIYLVLEIADSDFKKLFRTPVYLSEL
+HVKTLLYNLLVGLKYIHSAGIYHRDLKPANCLVNQDCGVKICDFGLARTVKRPTDTINYN
+SVASNNNNNNNNSVVNRRSIMTGTSIKSDNSQENGGFQQGGRFLKRQLTGHVVTRWYRAP
+ELILLQENYTEAIDMWSVGCIFAELLNMLKENVAYYSDRSPLFPGSSCFPLSPDNKQQTE
+DYRFKIRGNRDQLNMIFNVLGSPLDEDIEVLEKEDAKRYIRIFSKRTGIDLQTRFPGASS
+QSIDLLKKMLVFNPNKRITVDEALSHSLFKNIRNEMLEIISHEKVTLPFDDWSSMTEREL
+RYFFLKEIQRFSPDLVIPDSIKMDID
+>gnl|md5|1ee2afe0c103c388750840c4f50d6415
+MREGKHDQDLNFTNSREQNRDKHGIMEQGREIQREIELEREYFRGTERNSDEVKIARNRR
+NDLNKEKESKVSVKKVGVFLRQLANVQPDIVDFVATRFGILGGIIYERPWYFILGSVLLT
+LICSIGFIPGIPKWVDSAEHLYSLPYSLARDHGELHNQLFSNTKSRSQLIVVTSQTPGEN
+VFTWEFLEIVSQVNKLIRGEALDAVGGRRVGVKVGPGSSGDKNLDGEHTKDETLKSSKRE
+EYFSDITEDKHYDNNEVDPFKLSHETFLTYNNICTMTPFGTCSVQNVIEAGALEMKAVLG
+DEDPELYMLDGLVFNLRKQGFLPDYILGKMKAKPCVRTLPTELISKILSPDKYSSSSKGP
+GFSDAKIECIVGAEAFLMVYDIFDDGTPENLSRNLLWEQSLVSILKDNRDWGRARISFSA
+FRSRDDELKASTSENSDILLVGLTFTLLFFYVGVANFSFDLYKMKTYSGLAGLFAALLGL
+ASGMGLMSIFGVSFVPTVLVTPFLIMGAAVNYLFVIVNAYSTGYTIPSTKERCRLALQDS
+VIGITITMCTGLVSFSIGAVGEPYLSIRNFCLFSAASIIFTYLYVFLFMFPILCLDAKRE
+ASRRVHFFGLPKLTSNDIKATRDVDLGRSIPVDNINSFAVVSYNLSRALKEYNIELYPFG
+EHNKEESNQGFFDIDDDSDTKLDLSNIQDNKMDFHLERERRIAVNSKMGFFTKLRKRILH
+VPILAKYQYSDRKTASESTIPSFNQLRHEMRLSDFDLVSRDLDPNILETVKNNNQIIQRK
+DDSNNIKALQNISIEKLDKEYDLNHVDDLLQILLAEPSGNVGRTTRRLMLHYIGPVMATP
+IVKIIVIIIWLGFLGVSIYGFTKMESGLDLRDLSPPSSYLQAFDQDFTKYFNKYDVPTDV
+YFPEKLEWWKRAVQDRIFDFVERLERLESTQRVIDPLYNLMKNPELAAALRSGNKKLFQE
+TLYYELYNNPESNYKQFSFDFVWKERELITYRIKLLAKGMPTSQQKADWMTSIRRLCNDE
+ERREKIPFKVVAYNYMMLFYESDLSILTECFSNMLSCGIAIELITLMLIPELMSGLFVII
+LMACIDIGLFGFMYYWNVKLNMVSMINLLLSMGFAVDYSTLMTHTFSHCYGKTRNHRMIE
+SLGLMGAPVCHGAMSTFLGIVVLSGSSSYIFTVFFKMMVMVVGFGIFHGAVVLPILLSLV
+GRMPSHSSNILYQVIEWIQNGHSYSINSISKGNLPMIKAPPESSIELDDKMLSADLRLEK
+NVISNNTVDFLKVLKDTKLQY
+>gnl|md5|a06cd1ef68c7be20ec2a1d4794d7c7b4
+MQYKEKSFSSRESIKVENDVPSISLNSAEIDVIDSLPILNRHGFGPLTIVATSLNNKFQK
+RVYSGTFEIPIYGRDSHLVFYEIESKNFILISIEKHFVGDLIGNSGTVFIESGSDVFCLN
+ELELRKSNGDIISTECPWGAQIFLESEIINFKFSPESIRRFKPQEPPADWNPITSTIFPS
+NRNYVELIKLLKSNISKSSEAAFSNIQEDGTPTALLFIIDNKYMSLFLPENFSYSYEKRS
+CTVFRSDGSYYDVQKGIFRTDSGLKIITNAPWGKKLTFDESLVRISNNINKELNSFVIPS
+IGSWYLWEIXSEKKSQRSISKKIKNVYHRL
+>gnl|md5|e8278bff4b0ec4d43e59b57a99e1e6f1
+MVYLFVLAIVLLYTNTNYIINNRISTQSSLLTIQLSSSSSRHSSINLSGLTLEQKYRNCL
+DDLQTLKESLAATIEEYNICNADEGELESSYNKKSNVCKLLEEDYRKYCKSHNFKPPALD
+KDSCRTLLERIKECLEQKRKLGENLNKKIRECRELKKKIDERTEMYDKVDKRCSKIEQQL
+FNERSYTRIHVVEQEDVMDKPTSRLSSADASLLLEIVKQTEIKFQLCIEQLAELSERLAD
+KTNQMYETSEQITTALGGAISKKVVLGKKKSKSTEIRSLENTLELLKEQKMGALKLQLSK
+ENECRNLQTKLSQALERLQIAESQSTTSESRTGSRGCFGRFTSFVSRTCRRFTSRLTSRF
+TNRFTRNSNRRRRRESRF
+>gnl|md5|16a469edf94efd61df5dc9ca8f3fdba4
+MKLKFIFLFIIALIISYLFCDIYAAEAPEENSPNNSNNPLIEYSQDVDVTEAILILVTNR
+FEANFTSEILLKVVCIYILNMLRFIAIINPELSSSLFKLLDLVFATLHNYSIEDKKTLYI
+TQTKVGQLTYLCSKASELSIFSEINGKDSNYAQMIDELYSISSKIISVLSRLLNLLKLLA
+VVEVSEYIRHLLHSLIELGEDTLTEFKKAIEAYGSIPKEILNKKIEFSKDISKSIFLSLN
+FDDKPANMRKLMSENKIKFSARNEEYKKYLSTGNSNLKPEDLEEAKIVYENIFDSGGLSV
+EQIFYFETLILQAASILFIIVANTYKFYEERVSPIQEKINSFLNTVYSQITLRGTELDLS
+EQTCLEIKQKIRELLNIELLTSNDILASSHTKTKSSKEIVDVLKKMYLQLIKTLALLHKE
+KEKMASCKYLTFLLNELLKLFQLFGNSVKNLIKDFEETKSEWEVKSISDLKKSRKETLSY
+LRSSLTKYAELSKEQTKKREERVKKLKEKNKKEEEKKKQKEKEEEQRLLQEKKLRQEELK
+KKKKEKPKKTKTFPEATLQEAITIEQKQEVTETSIKAPSKVKKKSEKKEEALNKLRLKAE
+ISEKSEKIRGVIKSERKSNVSERTRKMNERKEKQKACKERERREREEEERRRRDAHYQVK
+VLESEVKVSVSMLKEHFSSVTNKQNEELQLLIGTVFGIMGEDEATGGDEDFNLTDQEEEL
+SQPSQPLQPSQPLQPPQPSQPSQPSQPSQPSQPSQPLQPLQPSQHSQDTQLRPRARRRAD
+ESLQDAPTRPTIELFGQDPVFASSRDVGKDLTLFGLSHTLSGLSLDDMKDTSEDQASELT
+SSYDLISTSESKSGQKSKSRSRSKSRTRSRSRTRTRSRSRARSRSRTRSRSRTRSSSRTK
+SRSRSRSSSRSRSGHGSEPWLGGTLQNQENTMEEVISKMYVSSTHEEFQLSSSSEHSRFS
+KMFSNTDSVDPLSSQAMLIFNVKMPNFKHITESSTEEEIKKALDVCGSEISRLNSEVSPS
+VSGQDFLSVKFVQKSFISTFIRLLLLLKSKSNSTS
+>gnl|md5|f069fab89caf2a7f1d2abef107a4f17a
+MRLRIKVYLIFLVSIFTTKICSSLTIKEIEAIGNNDHSRTHSSFTTDSELISSDEESNLT
+DEQTMLKSYSSSKDQSLYSNSQIIEYDDVLGNLGIIAIITNKRQTCRIISGNFNKRNETK
+NTLYLLFDTTNKNFVSIFVPRLIDFTLKGKQGLVTLIYNEEIFLLNKLLLINSNGEISTT
+NHPWKLVIEVNSDYNKLQSLPYDLRNKNYIKLPPDNWDANDDSVYPKNIKSIKPLSILTK
+NMNQIKELRIPHFSVGVTPTALFLKLNTGEYMSIIVPNNTVFFVDIDDCSIHSKDGHYYN
+ICGGYAVYCNRWLFTNRPWKSRIIIQSNFEELLVITKSKLQVLENVEQLSNNSKITENFR
+NNIKNNKCGKCFCSRN
+>gnl|md5|dbb8468e21278cc45acc2adc5b7524b9
+MEKIIKSDYDSLLEIDLYSEDEVDGDLTITDNIFMYDQICYLKNCLVVLLLIWHFMHAII
+FGGDISPSITRFKIGDNGIFALVLNILVPCIFFVQGWLKALEIHKQTSFIKRLHIEFIIP
+IFIYVLFYLVSILFKNDTNLENLTNEEFANLLSESEYFNPGFLSTFLLLFLINLVLDPTA
+LVIVPHFYINNSLISYKVNNSPIARTYKSGNVSNEMDRKYFSVLKNFSFYKLIYCLLMVL
+LYDSLLDFLNNMEPKNLIYKSKISNIFSVLILLIMCKIFKNSPRIFYYVCFIGSFINLII
+CSSFGSYINCHFSMSLISSFHFLLNVFFTGTLISCMNLEIFKKWKFSIFFTLCSVLCHFT
+SADYSRAIISPLIFPSIFSIKSRFITVSQIFSSIFAILSISIQLFKCFSSKSKTKSLRTI
+NSTILLCSSLMLCISSIKLFFE
+>gnl|md5|11e4b5ff7a78470fa395cb0e7f3bd79b
+MVSQISSPLSNTTVCSIWKIERLIGGGSFGDIYLAVNTETNEEVAIKAESTMSRHPQLIY
+ETKVLKLLQGGVGIANVYHCELDREVNHQIMAMELLGPSLEDLFNLCHRRFTMKTILMIA
+DQMLQRVEYIHSKNFIHRDIKPDNFLIGRGRGSRNIYVIDFGLAKRFRDPKTLQHIPYRE
+NKNLTGTARYASINAHLGIEQSRRDDLEAIGYVLMYFCRNGTLPWQGIRANNKEEKYKKI
+MEKKMGTSVETLCKSYPPEFATYLHYCRVLRFEDRPDYTYLRKLFRDLMQREGYVDDGDF
+DWTKLDSNGSKKVETSSMQTNNCVKTTGKSLIPQIQPNVSLDKSVFDQKKQSKSNKRYIH
+SSSSRKANNSGAPANSNIIQRECSPVEQKSNMENKGDKNPNETANSNICNNLTSANSGKR
+ISDIGDQAQDHSMSLSPNPTLTRGKSKAKNKDIHEYRNTKYQDTPSKKHNMKAHNTQKPS
+RLKRGFCSCTKVV
+>gnl|md5|8686ea38c92d46f0ab6242190e1e9002
+MSLFATVSFALSFGKFRNIDLLQSGFYRLRSRLYFLNDGVAYNAIPRNIIYSKQQKLDLK
+WEGILEDGSVLSRPFQINYVDDVADLNETIIFTSDVKLHVPSTKPFSSFFSDSSQTDSNE
+IFRSTFANSQVSIAPFFLEVDLFYSENLEQILPPDSGSMSEESNSEDSEHYQPSDEKFSS
+LCYNVYRINNVANGIVEYLPIIFDEFHFCNTSCLILSQITRIFASFDSHYSENKTQYIPR
+FSSTKPLPVIPSFLLSTSKNEENSELSDKDLSKNCNRTFKCDENKNSHSINVRSKVQVGS
+FTIRGMLIQKMAQTFVKSSKKSTEEDNDKTSDDLKLNENLEVSTKETNELLNLANNKELN
+DIQDTSEICDDVKGNAEKNQNTNQNAIIGIDEVFPSIVTRDPMFIESSKFRLELISSLTN
+IYLQLAANMHYITKKCCSSQRAKLMGSFLVIPSLELPGGSKLNVEPLINLSESNYEENGA
+SIPFCVVREKIDQIDEHKISRISSEIQLKEANEFKHSLTIASDGSSIGILPEQRLSDSAL
+CLVKLPTTIWALTPLNWQLNYIRGITPPIFRRSPTSHIVTSDPLISHEPILPFQNVIEAP
+FGIAQYSRKINLELEKISFQIFETWNRLVSILPFVLHKLEQTCKMEHIRKTMFLWNETIF
+FENLSINELYSPSLKPEPSTKFPEFLGNRSFPITPPVVLSVNSSPPYNNLPNNGELNKKN
+SGFFSIFPILTGGVGLSSQNSTAFVLKPIDYYSRVADLLRNDIVFKSIPTPNAIEEVCLP
+PLHEIASNSDNQSNTKNDIFDENMLNNISTEHLKSSKYNEWLPILFIQRYTKPSTLINCY
+KHPISPISTNSEINNLIVDHSKAIINNGVGTITHCGQLCRLGINNDPAINARNIVNRKIE
+QESNKTFSSRCFDYDQNVEKETNHDNETPKIPMIKTETPFLESSKELTKDLHIMIFVHGL
+QGSAFDMRNVRNIISLYYPDVLCLLSTCNEDYTDGPIEEMGKRLSDEVIAAVSPFSKSLK
+KLSFVGHSLGGIIIRAALPHLHMFSSQFYLYWSLSTPHLGCISNNSKLINAGVWIMKKWS
+SSQCISQLALSDAPNYEETFIYKLATEQSELFSKFKHIVFCSSHQDMYAPYDSARAEYSP
+DGPSVYKVMVESLLKNVDPSRIVKVDVDFHLPQKNLDTFIGRAAHIQVIENQFFVKILVS
+RFPEWFIV
+>gnl|md5|5af79b5e365d4656dcbf0451e93eb0cc
+MLSKEEILDEIILERLNSAISRVSRCMSCKLNKSKYFDIVENILICKRRLKKSQKFKVVG
+AHKITSKEIDLLEKNIDQLSFKTNKRAGFSFKNFFSKYFGSKKHSYSSILKEKERMETSR
+LESENYSDFEWNLFSKEQNFSRRNTFDFCSIYEDEKLVSLPFASNKKYASVDCDGRYVFT
+NENLNYNFRPLDEDLNCRYKNIGYESSGGLSVNCNDKTYEYNEDHYITQDHLNTNNKPNV
+TSKNPFDLF
+>gnl|md5|a85623df6a5351f7fadb3aa432febb1a
+MKALDGQILKGGVVSFSNESKGKSEKLLPLKIVQNKYNKHKKNEPKRKLLTPFKNESISD
+FCKRVDSDSRQYLMEKDRETLRMQKSMKNKKKREKRSLKNLEKSQAKNTNLNEISELESN
+FSLNNTNRPSFGDVIDSPPLISSKIKDKLEKSKKETKTCSDLSEYVNQVRKAYSEIKMKR
+INESNKLFQNKKKNPERVLNDFGNGWVGIGKFRRQEE
+>gnl|md5|1f8b6fad5efd45e826dbfb82e24bed57
+MESRIKDISLAEFGLQDMEIAKTDMMGLVELQRKYRDSKPLKGARITGSLHLTIETSVLV
+ETLYELGAEIRWCSCNIYSTQDHAAAALVKKNIATVFAWKNETIEDYWVCLNDAMTWRNP
+SDKDKICGPNLIVDDGGDATLILHEGVKAEIEYEKYNKIPEYLETELDENGRQLSMDLKC
+MYKVLKMELLKNPFRWRGMLKDLYGVSEETTTGVLRLKIMESEGKLLLPAINVNDSVTKS
+KFDNTYGCRQSLLHGLFNGCIQMLAGKKIVVLGYGEVGKGCAQGLSGVGARVIVTEIDPI
+CALQASMEGYQVSVLEDVVSEADIFITATGNKDVITVEHMRKMKENAYIANIGHFDDEID
+VYGLENYPGIKVIEVKQNVHKFTFPDTQKSVILLCKGRLVNLGCATGHPPLVMSMSFTNQ
+VLAQMDLWKNRELVDRSKNTRFFVKKLSKELDEYVARLHLDVLGIKVTKLTETQAKYINV
+SINGPYKSEDYRY
+>gnl|md5|574edf8cc715d5df2e0a169156590b39
+MGINKLLPFLIISLLSISEVYSEQNDEYIAKSQVDEDYLIEDFDTEDEDSRYLFSLNNIQ
+NDIWSDRFVNGFSSIELENNNSGVIHLLNNNSNIKLGSDEYVITSSNMPNYDSLIVFVED
+ISQALSSNKENREIKNQNLLIVTNDTENEILIKSNRLSNGFVCMGILNGTEIWSREFCEI
+VQGFKIDEISCNCKGSFIYSFAESRDQNRALQMQYSKFNFPEFGSGGNIQAHHVNDAYLS
+RVSRNDDPNSNHGDKVPFPPLHGSIGGRSGNVNMQKKETKKSPTNNEITFEQNELMQYYH
+SGSTNKYIINNQDGSHTYDKSKLNELNHQNSINKETSQINSDLIENNSIHKNPWNVNNYN
+ELIKKSSSISNNNNNNNNNNNKLHTDFSTPKVDSITINMEIKNISFDSLNNLLYKQSFIS
+KFINSLSKALNLIPNKFRIVNIWNEENPSLRRGNSGSIGITINIITSSPDEIITKVKNLK
+NQICEFSKIFDFYLISISKNIGLKSVSNEIITDKTKEKKEREINSDIESPRTLPIIFTMN
+LRTRKPYINQKEAFTLLEDELSKSMKIPKSSIDIPEFTYKQLNDPLTNESYLMIHTEIWV
+HPEKQIREEYTSLLTNIYSNIIHNKRSSFSSIFLCSKHEIKEIPHIRAHPIEDEQTSNQV
+NNSPEFSGEKIGISKETEPIDEGRISKIGRFYLINQNRQENQSNPHSKKAESIENIQNEY
+NQDTNESNQINPVIYLFKE
+>gnl|md5|d493a8f93ea048edb6681b9628a697a4
+MVAWKKTILFQYIYVTILLGISLIFVCAEEVQNVSEFSQALPNTELNFGYNQGQALVESS
+IRFPTIRSFFSWFGSFNSLYVKYQHTFEEIATSIPPKEDLESQITLMTAYSFLLQCLKTM
+GELNSIYETSIVETDSDMLSDDSLSSVSNLLKECLIPLKDLLLKSFIALQDQAFDLGKTY
+SPALLKSSELIMESYETCWSIFTTILGYITMFQQSMNILLRNRSENQEKLKFLENKQEKS
+SLEQLQSNIYSRRLVDISREEKLISLILSLFEGDFSVSINILELESLITTENKRSIFELE
+ESIKNLEKSIKCDVNSEENSNMLLVKTLKEELNSRTNDLIRQTSGSPMYLQKYDQELTEI
+FMKLNLEGSQSDSTNEQNKAVDETKVKVEEADPKEVQ
+>gnl|md5|1ebc76c5d72e93f80087e0bafe3e48cd
+MGMLFSGGLDSTVLLYLLLEWLFSNLEHLGSNIFKRFFSNNQFSEIQFSQDNLFFIIELI
+NTSFAPCEAPDRLTGLASYYEILELFENYLRKYRNVSIRLICVDNSGDVLTKEEKNILKC
+IAPCKTHLDFNIGGALFFALGGKGTLVDKESFNEEWWQEIISENEDSSIWNGIFEKKAPF
+SEATIESTKNNESTEHPKDSNFQRKCPYCSFREHSKCQNKCCKSCCRKIQQNLIKPIGES
+FPACRIHKMKAADFSKIPSTQRFIDPKNYYLSELNIDGVLFPQEKEYVKGLIVVLDNKLL
+YRSKSKFLIIGSGADEFLGGYGRHITAKKHNGLQGIRKEMLFDINRLWIRNLGRDCRLAL
+FNNRTLFAVFLQPIVIDSIGKLSFENICGSRFEVTKPLLRFIANKLGVQFSSKFKKRAVQ
+FGTRSSRQTNLKHFDSNRKATADATYVPVNI
+>gnl|md5|bafe98c75f1323c37f7274f53c0dcb9c
+MEAHSIISNEISEEIQDLKNKLLEWTSGINGMLELGVEKLNDQVSRDINMIKDSSIRIDG
+LEKRIKDTRELSEIKKVVEIEKEEFKKCFNTNTIALSEKLKRLEKQLQEDRQRFEQEKLV
+YEADLKVAKQQSLEREKSCRIYSENLGLNIGKVNGNNRFTFTCIDENFPEREFFFDLFYN
+EKAQLYEGIGCNPQVSDFKPNIELLNSKSITFRQFICKMRKSFKQLIK
+>gnl|md5|c00617629a13e6397d14f7f2dec1eb7b
+MGILERIADIEAEMARTQKNKKTEYHLGRLKAQLAKLKTELIEAGSGGKGKGEGFDVAKQ
+GDARVILIGFPSVGKSTLMHELTGTETAVAAYEFTTLTCVPGIMKYNEAKIQLLDLPGII
+EGAATGRGRGRQVIAVAHSADLVLMVIDSTKDDSQRRKLEYELEAIGIRLNKKPPQIVVK
+PKKIGGVTFNSTVPLTHLDNKMVVSILNEYKIYNADVLIKEDCTVDEFIDCIEGNRRYVP
+CLYVHNKIDNLNLSEIDELARQPNSVVISSQKRWNLDTLVEQIWGKLGLVRLYTKKKGEF
+PDFSEPLIMTPQRGVINVETAVKLIHKDLINEFKHALVWGTSVKHNPQCVGLSHKLQDED
+VIQLVKTR
+>gnl|md5|346d5ecefff09f29ba912d61af771220
+MTKSKDSPEFLEIKKLLTDFVQTLSSDTIDIHIMALRGIILSIGIIFPHVVNLIEETLIN
+DIVNCLFGIFNKDKIILNNDEGANNILNEPITSFNELIFSSKYDVECRRNSIWSLGVICY
+CIIGTEISSKNMILDLCHNTLVQGCFDYSTDKRGDVGSWIRELSMETIACLYYNNVFIDD
+SKYEKILPAFVFNIFNYSDKLRVKAILLLWKILYLHFTNSDSIEDNSIEYTNINMYWIYY
+RIFHGIPFELFEICQIKEMKETKLENLCKKNSLKYRLFESCQLILYDVLKDYALVHSKNY
+IDELKTFFGTKSNPFNLGCYYFDMLDSIEKVPHSLYPYLDFETNFYLSFK
+>gnl|md5|43ab4153f31f1c90f76f1c6f587caac8
+MVLFQWQSEYEYLLHRICDLLDQCKQMGFLHISTDYRNVFTSNSTFQNYILIGSSSMKEF
+MKEMIEKMTPFYTPGILSYLAACCVDDINLSHLFSLLRLHNIMEYYPKSVSEHKQRATIL
+TAIFGELYAIKNDFEEGKLKLNDFKRGHVNNSENEQSIELLKMTINQLGGLILDSGRDRA
+TFIKEAFCAPSFAPPKSDIFSINNDELLNNHLQTQVMVNRVSNVNKGDPLLVSALLCGSS
+LSIWQRIHLLYDPDRNQAKDSIVYAVIYAAPLMDRMRQLVFTSLLQSFCRPQWCNNLLPQ
+LSDKMRRFNNQNTEIIQLIVRGFLLSGVTIWSYESPQQIYDISTSCALTAREKDALLKIF
+RLVDEKALAQESLEESSIAPSFESVIRELSRQFYTNSNWDIDDTGFVKSLNERQSYNKLG
+NSIEGALKLAETDYEFMHRPLNIVSDRVKFYQAMQHFQANLNDPLASFESKSDALIQLSS
+FEDIEANLFNVN
+>gnl|md5|4e8cb185abb4683679ea2f749e87326f
+MYAKEDFGNANISQFIRLNNRLRANGFLSIPFLPDLTSPARSLILNRNQVEEDNNEGTNY
+LRYANPGVRLSEKLVQTSMIPQNLNDVTTPQNLSQIGETERQNDKFEITPGIRKYTDSEY
+SGLNTDDLRTVGSILHGICADRDNSFENEQNVNSITEIAREHSVSGRNKMDFPFDMPSNY
+SSKYGMKPDGDFRLGSSIELSFTTEQPESLSMAAKPESIETNQRLIVDGNKLISTIHNLL
+YELESRGEHTVETINSERSQKNGLMEKLNLLRRKYEALEKENESLRMINRVLTEEEQSNR
+KNRVQGRETPQCSTISKLEREKQQLLVENSRLKQDILKLQEDDDKSRDKADQFLRSVKSN
+LDSERDSNRASTFNHTGTSSNISGTTLTTLEKKKILQSHYLYSIIVGFEKSISYWKLQAN
+GQNNLDSKNGQDSFEGNETNLGNSNDTISEKSFFEFCQENNISTSELMKRDKNLWTRGLY
+MLQNTDRSELESIVRWSCRLLNISNFRNIPIQIGQLLAKKSTSATPKITHIFESASSKKI
+SSQNNSQEVISIELHDRFYNHFKTLFDVLDDQDVIQA
+>gnl|md5|a243b4b3043ec91b9def042a3e7272a1
+MDFEDIPFEEIIRKEKIAESFEKRKSAESEKKNANGSYKSCKESEKNDEIDQKLKKYGRI
+TSKNSPMEVSSRRQTLPEKLENERNYIRNKHEGSKKGNDPRFNDSCGKLNTDLFHKSYDF
+LDDMRQKEFNQIKNTLDLYKIMTKSKELGTWNKVKKSSKFKNSDVNHLTQDQIDNLKLKY
+QKLVSEKDHRKNLYLKQQTISQHRKQEQAKIESGKKPFFLKQKDINISIQHDKYKNLNKK
+QISMLEQKINRKNVSKFKPLTSLRKI
+>gnl|md5|6e99237b42180671b047eb87f893ad76
+MTLSKNSIEYQSYQRYQRVYEDIYRKFDTYREESMASSYYFNKELDMSTNISGNDGQNYL
+KPSTKEYNMGVSTEDLMKRNEDNLRISANLAQETQHIGLYSLNTLTVQRDNLTRSKYGLN
+NIDYNIMESRKLASTLYKQKVIERLMLYFIIFVLLLANIYVFFRRIFGRK
+>gnl|md5|a5af96d0b8c3900baee5a97d0d4c5ef0
+MLSASEYFVSYEEEFLSVIQGIERLVLKCVNIEDGGRGEKFTQDEISILERRFQDAKKCL
+DQLKDEVS
+>gnl|md5|a4d01e88dce51bd71277e311923e1dda
+MTTTTTGNPTTTTTKAPNATTTSTTGHPTTSSTTGNPTTTTTKAPNVTTTSTTGYPTTTS
+TTGYPTATSTTVHPTTTSTTGYPTTTSTTGHPTTTSTTGYPTTTSTTGYPTTTTTTTVPD
+ITTTTTEYPNTTTTTSEPPKYAVSLVMDLSKVPNIDQMKEINLSANVIYRNLVESGINTE
+ILSVPINEPNKTQGHTSFISTLQGSDNNMRVDRLLSMVAQQDSERVLNVIAQQNGTDSHS
+NQRGYHNKVLLKRRKIVYITAGFNGCTSVKTCPGIVSLKKDIDIYFISLSKDANMYREIE
+YISSEPVLLHSIMMNKSDLSNEASHISKWIRDEYRFNNPMFLIPKKVKKNFKNEVCSKCS
+KNAECYVHSIFETTHDLSKFECVCSEGYTGDGFTCHDIDECKVGNYCGKSQCCINTLGGF
+ECKDSKDGKC
+>gnl|md5|c92097d0d5003acea393fcbd0860a4e0
+MFGVLNKKFVLSIGLLLINLTIIFASDINEQDTWVSPENQHDYKYNAILTDEGTSNLNRK
+VAESQSHKYKHNHHQSHHNYRYYNTYYNTYTPKYIDTTDDERSYTNSHFNYIPKENHHYH
+YNHHQKNVYQMGWNGH
+>gnl|md5|2d9c02965361dfb737ba4c280750e944
+MRGRWKGGKGGHGGSSSGGSNTKVSEICRHFVQQGNCKFGQNCNYSHILRQVAQIQKAHF
+GGIRCAISSPLPTGELELFTGGCDGQLKRWIIRPADKDVMTTEPERGSNHRRRNYQNKFQ
+NDVSGATQLSVKMDSAINCSAEVCSCLIYGDVLFCGLINGTIRAFHKPTGNFTDLVGHNQ
+EIHQLLIIDNILVSACWGGKIVFWKFDQASGTFIISAQIQAKEHIKCLKYFPYKGNSAGA
+MGQPQCQIQDASPHLWVCGGGIVQIVDLITLQVVREIIFDGGPIMSVLEYENHLVLCSLQ
+GVIRVISPTGEETFRKSLGSPALCMDGTVTADAKHILMMGQNNGHLRCITLPLFDSVLEF
+HTPDTRSEIRLVSNLGGSPGIILTAQWDGALNFYQWCLPKSS
+>gnl|md5|27ebe61e88c0ae1ee86e63689c4a2e36
+MISMEIQFRDIIQKSNLPKPVSRNLLSTNTGEKKLYRISVEIERDWFQIYNVDMEVTXSF
+QESETESIQVFTDEVELVQLDGMESRIILKPEINQKLIKLPSFSSECIIQTPIMFDMSPM
+KTSTEVNFSLNLIASIKGQEKEVCTRHNFVFQVGPQVDLKNIQPVPNLDHYSLPFYYFEL
+LFEATCKRVLVEKIITMLPKDLESSDLFGIMAPVELKPRTIENFQDLGDLYSIREYTLSH
+PLIIESNSRPLKLIWIVPKTELQKMFTPQILISTISLPKEERTKLSISGPFQIPMETLYN
+FISLGKSTHSTDNLLETSLDGLSLDHVEHPSYSKVDSEFPLVIYLNYTFQKEETFSYCLN
+YFGDEDSEDKGCWWFIGARNGYIEAKPGSKIKLEFRVVPLTNGLLKLPSINFGCSNSHPY
+SYPYFTLSDNSRKFYLGKQVVI
+>gnl|md5|28f9bac3e82a43ffea9c7a1be4f83d4f
+MSNLSTSTVTQGAQTYNQGTGTQTQTSPNTQTTTSKKTMYPKPQLQQSSISGYEQVSSGV
+SSPYNGSVGSIPVVLQPPSTSVSPSNYYAVPPAQYILDTSIYSSATPYVAVPATVLSPTV
+MTSSPQMSAAYASYGFVPSQNLGYTTVGVSPTNTSRPSKYSPGCC
+>gnl|md5|5fd988efa52d2b56bcf331b860c83602
+MALERDIFEDLGSSSASMLVVSVGSLKLYSKILKLLPGTFKIALCVGLRHEPIKDVSCVT
+KRRVFATLSRYHNGSDAEADQIEHRIQHNFEIPIPFCLDNKATTVRLAIFLVMNDRSLVP
+VCRSMIRLSSTRDPTTAMKWFPLVKYNGFTGVGSVDNTAEFEVIGEPGKEKLVKRHLVVG
+SIQILTRRVLQERIGRPDLHDALCFSTLCDEKKSRKSLAEQYDDSSSEYNFSEKDLSCNE
+LDEEKDNLFNGKYTSKIKGCYLESSIESLEDKIPFPFIQFKDILSKYPTLQNIFHLMPLY
+NQKINKRILMLQKRNKNAKVVLIGNDFSSNYRSGISMPIKVPSSIENIMSSSLDWNTWFC
+KSVDIAIMQSVEAYSKSTIFPSTNKYKAGKCNMNKKSSYNFVGNKISTYHFEYFMKSLES
+NMDVLLVNTIFGAAATEFSRDIIDDVIFRGKNQVRKFTPYKNLFVIWDYMIKRSYQELGM
+DYDIKLNNEEKMDDSTLENKVGEEVVEVLNISDISDSETHNIKIQETNFCKLENDFEEFS
+EIVAFDENIPKVVEDSSSEVNQDQENETIPLYNSLKRKVVDSIERSQIIPLSEDHPFSSL
+RLFENDRVFIHHKTIGRGLLGILVLGDSQTSAEDASKIYTREISAHMAINEAILRTKVKK
+AIRIYNSISKGKIPPRQFIPNSKAVIGYDGYIDPNLNKKLSDFEIAMILLKGIDKFVKCS
+SEILHPSVNLTTVSPSLITCVDYSGFRIVVRPLPPLPFTICDWPLPIQSNERGEISNIEK
+CLNISNILHPTKLISEIKHLPILLETSIGIFKYYNFHHTYNIFPRDPWVSDVKGERVNWG
+NSSTDEYYHNYDTFSKNKLLSRNKCCTIRPLFIKQAGAVQDMLKYQDTDEKLRRFHYTPD
+DLHELFRKEIEPSGFCLVCASDVQQRSYGFFNINKEAMLFKPVPMNLISKFTETTTNYLI
+KINDGTHCSLCGKSMRVKTHTNSNNHMELISYIGDKIPYPTLGHYDDGAAIKMNRVKLMT
+SYMQSSNDYFSEWSFTEGDVFRRDQIFWERRPGLYCLPRSCIKGGGNLLGTGLDTIKYLL
+SQAKLLLNAFDDNTRFSSASDFNREEKLKIVKGVDVLTNQRDKAQ
+>gnl|md5|c7e8b9f7e5a4559eeb372770a6d66d88
+MIIISAKNMKKESSQWNLRNIIRLLFQTKERMVYLFMNACNGNQYHKRLFRLFLLASYLK
+RGDKLVNLKDWEPILSLNRNSKDVDKSRLGCSYNEKNASGLLFSVIYEANSWLYETEEPI
+>gnl|md5|d27aea974b4e1d6e4c092ec303e505e6
+MGRTKSSSKFNEMDFCMSGMMVINSLNNTTGELSENINQSYGTMDEGFGNLRQFEFDNGE
+NNKQISSLSINIDETKSKSNPRYLVSHIKESVEITAIENFFIDLIKEAEDDIKFIWKSMK
+EQIRLFKTVKKDELDEISRINSRIQYEQRISRLSKIRINEILNDSGSSEIKYLDLDLERS
+NLVKNINESFELSSISDESFSISFPIYKASLIATDNESKNLLSKLMVYNSKKATFDDEFE
+QIGNDSSIIYNSLLKKNTGIYDKTLIQSDSEERKMIDGVKLNSENAFFTESSEFDNVEDY
+TKSYPLSYRSKALDILISLIYYTTDYRDYFSNWKDNQKT
+>gnl|md5|60646b6d775c9dfcc2c9ce7db21ff48e
+MESISTAKDTHDTEILHFNNQSNSFQDLDHDHKIDTKNINTGTDNVKIDSREELIPSLDF
+NDLSMIERVSKEGVNTSFNMKSNVDENEIIEWKVLKKALRKEIVLKGNQMFEKYGGLDQF
+DYLPYNCKLHSNLENSHLDEVSPRHKNIEYSCPDCGKSILENFLMDILEAFDCHTDFPPT
+IQRICELLLFPDCYNNTKSFLYALDKVCLARISFSSFKN
+>gnl|md5|f68df66276d115bc6e1d197ef7c7e33a
+MSVPICGGRTPGRRYGHTMVYSKPNLIVFGGNDGQRTLNDVWFMNVEESPFVWTQVLFDR
+DERVPFPRVYHSAALCTEGPAAGMTVVHGGRASDSRCLRDTWGLRQHRDGRWDWIEAPCR
+KGGPPAQRFQHVVLFVGSKMLALGGRGDDVSKVLPSMLYDTENCEWRDLPGIERFRHSAW
+AIKSTLFSFAGFDHKTQTHPTVDLLSMDCSAEPNFYNEKERSIRRKSLVGVPYNTIGVQP
+KDQLVVGTGGDPNKTTRSDLTNEDLGSSTTNEQNTVQEYNSPKSNDIPFTDVERAIARAN
+IQLQSDSKRYIPKMEYKTTAGLIGLTPAVTKVSSRVHITVDSMNNDFSTLVQKVSIDQLG
+EEGRKIDKVAAKHALADSPWMLTPSSMGVPGTGLIEKCLKLFLHPTITPVELSARFNHMA
+AFSLTWPEVIQLCEMAFSIVKQEDMVLKLRTPVKVYGDIHGQYYDLMRLFHNYKAPISEE
+LEDIFEAKGDIDSTDYLFLGDYVDRGSHSLETICLLFALKIRYPRQIHLIRGNHEDPVVN
+SLYGFKDECRRRLREDTDDPDSCWNWFNRVFEYLPVGAIIEDRILCIHGGIGGSIHKVEQ
+IKEIQRPLRPSQTPQTEYEQRILDLLWSDPTDNDSLEGIVPNDTRDPDGCGFIVKFGPDR
+VIQFLCENNLDLIIRAHECVQDGFERFAGGKLITLFSATDYCGKHQNAGALLFIKRDLTV
+VPKILLPSASKDPRMILNNSNYWDQNILSERPPTPPRSATYFDKINSEFIDIAS
+>gnl|md5|40657f5f4c3d16a0760dcba9d5c0ab97
+MQSTKDGEESKNNIEVETSESKLSRDSSVFGLSNQTPKPPIKRDSFVGTSYLPIQNHYKL
+GEKVGEGSWGAVYIVEERCSGILRAAKKIPKQFSGEIFRFRQEMQLLSILDHPNIAKLFE
+SFEDYNSIYLIMELCTGGELFDRLSHVGRFSERVTAHLIKQMLSAISYCHSKGIVHRDLK
+PENFLFLHSKSNINCKHCLFEQKSSQLFQDEEAALSKYLKQDRFRICRSLPSSMNNQQLQ
+SLIYNINDNTINPSNNNAICDITSNHLFSASNSEICKKNRDKEVGERHESYDQETNNGEL
+SHTDIPIPNSEPFGIPNFIANMYLKKGSISNSISNSNSSSIKYPIPSHQDKECECNCNCF
+ELNSPLKLIDFGLAKRITRTGTLRTRVGTLYYIAPEILLGKGYDDKCDIWSIGVMAHILL
+CGVPPFAGNTDTEIIEKVRRGSVSFSESIWSQVSTQAKDFLLQLLNKNPSERISAFQALQ
+HPWLRSWDTPNIPLCGIGMINKIVVWPWHQQRMRVTKSRASSGISSLKIKSSISSPSLYS
+NRERINDILSEEDLNNLSGSGDNTPVVTSSPETGGFFKTQIVNVPPRLDSSSGQGSVAGS
+MIGFLESHGLSTGSQIRNVNRNSMLKRSCSTPLLYSMNNAYPNTDANPSLVSIPNSSIYN
+PGLVQIADQQIATPRTKATINALLNQEDSILSPPGDTRFHFGCHCGNPIVLNHFCQGNVS
+INSIDHGSCDGSKSYSGISIPNSISSSSSSSSTFTTSYSISRSSLSFSNLLTNNNLKQGN
+IDEYLENSDENANVQRISVINNVTIPNIVSKVCDKEQLFHCVIYNKTCNAYKPLLKLISS
+WERFCNYTLLKRVILVSIALRIGENCEFNQLRDQFNRFDVAADGVVSLAELQCVLCFIFH
+VERISSSNYKNKQCHPKQTSNDNFQSVSSRSSPLPPLANSPNHQPSFEDYIDNASEIEED
+HFDEIYDEGFRSSAIESPEKGAFNHSNQIGNRKSMSIDDYLKSLSNQSTFNKDQLLKFLC
+SFNIDDIIKLNELCNRIEGIFGIIDQDQSGSWEYSEFIAASMEPEMYLNNTSALKTVFRN
+FDKDSDGKVSVQDILASFGWEDDIILCSETISPQQYEQYLKLGNSQSYDQQRDERFLGVD
+QSNSVQYCAHIHWTEIFLNECCKPGKNYLDFCDFYDFLRN
+>gnl|md5|a157e05b49511452ada85f89962e61ea
+MGTKLVSNIKNFIISGRNQNGIKGLVKGSYPNGYRNFGPDLDRMMLPLNKKYVDESKLVD
+SINEEIIVLEVVVQVEEERIIITSQY
+>gnl|md5|f1bbd31426d59a382613d41d2fae4f36
+MVSISGGNDEIPRSILYYETPQYCYSLLRCLHRVLCCCPRIVGISRLVSTLINLIDVILP
+LYDLNGTLCSRSKNFDGQLSTIGNNRGGMTGGDIGKCALLMRNVAFQVVFDIMCILSDTS
+QVFYVIRVLVKVRDWCGSCLLDLIRRCQRLASQNSETGNLNKRTLSTYNSQLKSNNIGGV
+NGLTTAVNQKYDKLDLRTRVGATGLLQTSNKKISELGNVNNTSEGSKLVQNSSLVGGTSG
+SVASYNSGIDLSSYLNIGGLREFDLEIVNPSFWSASKILEIAGINRKWITGQIGNSGNNY
+ISMNFTGVGVGGGGIINGLNDNNSSNMSISSGISSGLSSDIIVSSKTTQVIFNRSENMGS
+NNSGSSGLGGALRTDVIGGSTKSIPSTNTNIITATTNATANATATTSATNAATVVTSSTT
+ASSPSAIAIGVGNISSSGSSNYGSISSPKAVALPSSNYCYDYSSEDEENEDYDFDDIDTS
+SDEDKSIVNFKGSERRRGSGRYKFGGGYAEEDRRRGEEEDDDSDNSSGEDGDDDYWEADQ
+KLLELIRLRPTSSIINAQPPTAGILRRTVSSDVSISKGTFSKIGSISSLWTKHNSSPPKA
+LSSMKRVCFAEVAQIY
+>gnl|md5|988ede57467adf00fbb5a51ec237eb22
+MFANQDDFWTSDEEEEEEEEVEEEEVEEEEVEGEEVEGEEVEGEEDKDEEKNDQNNDLDM
+VEEKVSRISLKEGKEREENGEEEERKKKKGLIRKKWSIEDERDVSDFREIIGYEPFKKED
+LDDSEDLENVVLKYPYELDDFQKRAVINIHNGDHVLVAAHTSAGKTAVAEYAIELANKNG
+RKAIYTSPIKALSSQKYREFLNRFREYPAHSSFTQRNRIGIITGDVSINPDAQCVIMTTE
+ILRTMLYRNDPCIEQIQTVIFDEVHYINDLERGVVWEEVLILLDPKVQLVLLSATIPNYI
+EFANWIGRIKQNTVYCIRTLHRPVPLKHYLYIYEKCFQIMDENNKFNINGYKEMLDFIKT
+SKSKKSISSLKSKVSKLSSSISKANSSQEIQSQEDPNQEDPSQEDQSQEDQSQEDQSQEA
+KVEDNNIAMLRISTINKQISSSAGAKGGSGGILSSAETKFKTEVYRLQVFLKLLEKNDQL
+PVILFGFSRRKVEQLATNLPNLNFLYNHNEKSNVITFIKESTSKLNELDQKIPQLLQCKE
+LALRGIGIHHSGMLPIIKEMTEILFTRGLIKVLFATETISMGINCPARSIVFTSIKKYDG
+RKNRILLSSEYTQMSGRAGRRGIDTFGNVFIFNSSHETIPECIDIVKMMLNTYLPVQSKF
+RLTYQMILQLSCRHSLKIEDMMTKSFKEMFRSINLPIFHRNLNRKLKRHQIILSKLHSIL
+ESYNSNLVISNYNQRNTNQNINQKDEFQFESDSESLLNIINGLISTIETSNLISGQLFQK
+LCNSSINKNILSQKILNPGRLILFNSFYLTGKSLPMFANILEYNPTSTLSSIIVYSQEFI
+DFQLSSNNYLSKNIMDGNNNNNNNNKGIGDSNNDIQFYDVXEESIXNYQNFNKNXQISVV
+QNLIDXDRSKKNNNQRNSSSSYSSKNSTTINLIHYSTFNSQKLLISTSLYNDTNIIEINP
+LFKNINNYYIFQNVPLELFMFIFDFNASATNNQTNLLKSINFKDISILHNIAILLKNSVQ
+DFLSNQNSMNNMNGNCNNSLKNNNLGNSGINPNIAPKPKNKNNKKGMKVNLFEFISHQEQ
+QNQQLNTNRGNITEYSSSSSSSNIPENWPKLLPISKTLKSIEIEYYELLQRYNDLFPEFV
+NNHIFKNCYSFIIEENNNHNDNNDNNTMIQLVVELNKLDHEISIYKHFINDESLDDYPEM
+KLKIQLLIEKGFLNENLTITTKGRIASELLTSDELTLIEILLNGMLHKLNNIHEITAILS
+CFVFPEKMESLSNSNTNTNNNNNNSILGIDRPSLPSVELLNAHDELINIHTDYEKTHYKH
+QINLDTEHFWSLCNDKFMLIAYKWSNKESLKEIMEFVHNSEMNLHEGTIVRTILRLDELV
+RKLIIAAKMMGDKILEEKLCLIHENIARDIIFMTSLYFNSN
+>gnl|md5|3ea5350b704435973c91f39a079e5eef
+MLLLKNQDNNNNNNNNLKKKMIELILIKKFKDFYILIMKNYGIKMNHINNNMIEYYYENL
+NDRFQYNNNNNNIIDENCSILNEEKNEKMIINNNILLKKNKQNERIYRIGNIHPNLRGLS
+SMIINNINDNNINKNLILLKKNSDNNYNINDENNNNNYYYNYNKIQVLMIINDMIQILLL
+NINHFNNNNNNNNNMLLLLKLVDNILIRIILLTIENIIDINNEDDDYNEDYDDNNNNMNN
+MNNSNNNNNNNNYYYYKNKIKIGGNNYNEYNGINLNIELIGEVIIEIMLYFGKYYQNDEE
+IKEEIDLMINRIKEIDEIELINSDLLSLLILKMSQKYKIFNNEQLDNNNNNNNNNNNNKI
+IKYNRIELIMFKNEIKQLLNDRMRDNEEIINNEKNKNENKEEYEEIQIEEIQVEEEKVND
+DYDPISNAMMIWEY
+>gnl|md5|5dbdeaf9e6310770acc5d84cf79e54d5
+MKELNLSLVASKIRKLKNESENRRKLSKEVLISMKDVVLLNFLSDYMNEIEENSGTYSNR
+KSLLSVKLVNKFLNAANKRLEISEFRMKKEDPRFLMNELRLEIEECLTITSNFIFQVSKC
+NYYRGLLSREFPNIFEVMINIASSNLLGIQLRCQILEAILELMKNQSNDKISQSISLRKC
+LSEEDDEKALSKLWKSLFQHKNMYLTQLFDQDKMFDISSSIKQEKYNGNSSXTINHLNT
+>gnl|md5|d7f02391c14c285d010b8cd19510eaa8
+MTEGTSNSSTCNASKIADFFVTEFYSRLKKDPSTLYELYHDSGYLAWVGNRSEVMDGSFN
+PQSAIRAETKEKIRSAINLLDLSNCTTYVEVLECSKSINNSFCITAKGRMYIGGGESVGK
+SFVQNFLLTEIRPRWYFIRNDCLIFIDSELPLKQSVQNTAKIANNDSGVAKNSGKKSHDS
+GFETNKSQKEQNHSSKVQCNDEHNKEVNKHATGPKEDDDNKNQSVVTVGAHANTDSNAES
+QKKVSSSTAANTSNTSSNHASTSAPTTSNNAAANTSSASSPSPLDPVNYTDSLNAKNNAN
+INRSNPHKYEVTSYAGKLMGGALKNGNKVKGYAIHVPTEDKNKTASQNGSTKKTSTQKDP
+KSLKEAKNKRKIFVHSLPTNISDDQIREAVLNQLKVHGGGYVIDIERARVSGRHWGIIEL
+DSEFSCKTLLNNGLYLGGTEISIEKWKQINQPQAQNFSQNSSKFNNKNSNRQAGNNYHHN
+SSSNSKN
+>gnl|md5|56fd8110d5cfad52ebf9acdc06d3b2c3
+MYATQDQSQLPDVPDFIKNEVKKNAFKKQGGDSLGGHSFTRAASSLNHYFIVAKLKNKGQ
+LYAWGVNTNNVLGLGIENGEFNFPMKVNFFSALEVFQVSCGYSHTAVLVKGISEASGRVY
+TMGLGDRGRLGYTRGHTEFGNEHDKNDLNESWYTPIPCIVNFPFNAKISRISCGANHSLA
+LSDSGLVFAWGIGQYGCLGTGELNDVYSPVKIEAGPTDKKVLHIAAGARHSLCCNEDGQV
+FAWGSNSNGRLGTGGSYGMKTVPTQIKSLSQYHITLVAAGESHSGCIDSFGYIYTWGNGG
+SGKLGHGTQSDCNIPRRIEGISSLPFVQLTLGAFNSMALSQSGEVYIWGAKQHEIISLPT
+KIDAFDSHICHINSGPYISFAMDVRHNIYLWNNRLLVNSKKSEALNANEEQLYKRMNSKN
+PVLLPFFQSKAFVDDCIFYMGFNLVDYKGNKVSYEPKSEGGLFSVNRIYKSNGSSEIGSL
+VGSQIPSWSVRQIACGTSHTLLLVYGGTIFAWGDNKYGQLGIDTRRRKSQDGDKNESFLN
+EPTEIKFSEPIRRVACGSWHSLCCDIKGNCFSWGRGDRGQLGTGAIRNLYEPAGIVTLKN
+VIEVAGGELYSACIVACITTGNKDLDTINSGDLWIWGDGDLGKLGLGDHVLKSCIAAPRH
+LNLGTPIIKVALGSSHTLALTASGELITWGAGYYGRLGTNSTKSHSNPIKIRFPIKGVQI
+VDIAVGSYHSMAVSSLGDLWVWGKAENVLSEKDVLTPYIFAKLESPSGIPRIYSIHAFGD
+VSYAITQSGVLWIWGPENSETENIQGLETSIKIKSHTGRAEMIVLPGNAIGVSGSTTHHV
+CLLASGEVVSWGDPSRGKLGQQDIRNKKYIEDPTLVIQKWNDAKNMLDSVGKGDSSAGLA
+TDKKKNYTKDEGVTTIEELEAFMGELTSKSVHFSKKAKSFEYVQSLLHKEDPRTRKDSIS
+LLEEDLVVLFSSHIEYFRKMKEEEERLRYLIFLAEVQMRRLINMIQSANSNSFIFIEDNY
+YRNIYGDYFNSFILKYMSMIEYIFTILRTQPLYIINLMLECSFGEEFISILNCLYGLFPP
+QLEYVEVFETKNFHGLNDSLIMLEIIGEILCKRELQEAFSTNDVFWPGKSKFLYYLSSVV
+LRGPDLRSLVQNLLDIYTPTSLVSVIAKFPKEVLLVLDSSCLAQYLGISPNDESLPKHYL
+NMVKFAEVALLVGISENINKNIKFPRILERLLYKACKLVNLMEIPSFNPLLDYKQQKDQA
+IQQPLIRLLLYGIILPILEQCNAYCTYFYFPLITDMRIMSSIQLLAHSIKIFLAGYLNQT
+SSSQGFLWINSLISFSSSITIKISEMVNEQKDLTDLSLTYLSYNSQYSLHSDNYHVVLNL
+VDIMVMINSIQKYKNFLRLNLMDPVINSVEYFSRRDKLSIPFFPLEFINLVKNVNLLPNS
+DGGGVFVSIRISPRWIINNDVRQSRISNYLRVSNISSNIEIENSNRRANRKFYDLDEQNY
+DEIRDEENTCLPPLDTSMMFCPLTKIGMSQSLLPRFEANVRKSNGISEFGLFIRYFEIPD
+KRRAIEKGLLILPIITARTMFELLETVDEYIEQFKRKENDKRQYEQLSFMLEFRKVVEEL
+MLNYQDSITPLLIWITNEIMNRIKHRAYLEHLLEIEEKLRDKRKWYKDQLNEWEDAIEKS
+VINMTLWGYKDTELINLLNIYYKNNINTTMKQMENVLYNTMISGYYAGEDDLTMIKNGNY
+ITTDIIKKSITLPFLCFPLSIFIMNNVIKIKSDEKIFNLFESQRKTMMNFFRRTAQMNNW
+TIFITFTPTLGLDCIITTSRSGYKIQSSFEQRIICKFYITPDQVKKAKFSNFLYTRLYSN
+GLVEVNLPSFVSYVYSQI
+>gnl|md5|9e9b832cc9c833c6a4ea84b4903499e6
+MSGETPEKSESSISNTKKITNLLKEMSLGSFMNTAANAIKPHKFWNTQPVVQNDDSSTEY
+SFGPIEIEPDSFRKEIYKLPDGFSWFDCNLWDIESQDFEDTYQLLKDHYVEDDDSQFRFN
+YSKEFLRWALCVPGQKKNWLVGVRVNETKKMVGFISAIPIKVRIHNCIMNTSVVNFLCVH
+KKLRSKRLAPVLIKEITRRIRCEKIFQSIYTCGKNITKPFTIGTYWHRIINVKKLLETGF
+IGIPRNMTMSSLIKYHRIPADKRIEGFRPSVDSDAEQICKLFENYFMKYKDISNETMNNK
+INYDEINHSKELGKQAYMKLDKIEDLQDKIIIHQCFNVEDVKHYFTNIDKVIVTYVRENK
+NKEITDLFSFFIIESTVINNERFPTINIAYSYFNIANTCSLKELFNEMIITAKNNNCDAF
+NTLDLMQNLQVIQDNKFIIGTGKLRYYVFNWKIPQISPSNVGIILF
+>gnl|md5|42713904f719dba2f02b3cdf66ff548a
+MKIEDSVIVVTGGMSGLGKAVVEELLKENPRKVCLMDAVLKEGELEEEAINKCEKYCVDV
+TDYNCIKSAAKSIIDKYSKIDAVVHCAGITHCPTPIVQKDDNGKIMENNEDIPEIWGKVV
+NVNVIGTLNVIHCLSPFLAMNQGNSHGFEKGVFILVSSSTARDGPAQNQGYIASKGAINS
+LTLPLARELGPLGIRVVTIGPGVFDTPMSKHAMSEKTSYTLLKSIPLGRFGVPNEFAETV
+VNVGLKSEYISGEIIYLDGAWRPPFITSGSVRRLSIQKSSSNDE
+>gnl|md5|b5585ba7f8e55964c2bd9a08955c2b85
+MFKSIKKKRDEFLFKWNRRRYSYRMGWYYSMLSIVSGLIILVSFILFFLLKMNSCTGRKC
+GIFRTFSCSPTSVSLLSSAFISLGSIYSIKSAFSYMLSRLLYSFANYRTTDFMALGKFAS
+ILGALVKHIPFLIALCTICNGIICITGVIYILIGLCSHSYSSATQIIVDNCRLYFSNCEN
+PTVNSIFDCNDPSQLISSPFLQLRCLPGSSEICRYSQELKSGSNPCTKDMLKSYLMSTGD
+SEIIEELEKLTGRTLSISMPDQVDKENSKKIIERKLGSTYISTLQGVSNRELLNLYLLPS
+SPSDQSELISSYGFSDLYAAARVWIAAACYTYVSTTILFFFVKYFSPQDSCFSFVRSPNE
+FFLLKILNIFTPWQ
+>gnl|md5|66ea68555353859184f75e173196e0b5
+MKAKNKHFYGVYPKSFLLLYEKRDESNCLQSFKVIYILLYFIYCQGVNIFSIFRRKNSFG
+LLTKEKHES
+>gnl|md5|319da35a5e2c81e936bfa3ce9fd2765d
+MNNFFFKILYICKLSFSLFFKKKKKTSIPPLPHSFEIFTYKASGPYACNFPPKFRRGIWR
+ISDKDMKIALFDNSWSW
+>gnl|md5|81b5e89d04cbdf4dc81a77ce6d2fb5d3
+MTNYAYNNATVASKKGVIYEVWQNNINEAFQMISEIMDDFPYVAIDTEFPGVVVRPTNNY
+YEYYYQTVRFNVDLLKVIQIGLSFRNKYGQAPTNICSTFQFNFKFDMECDIYSQESIQFL
+RHSGIEFDKHLNSGIDFLCFGEYMYGSGLVLNPKVKWISFHGCYDFAYLVKILSSQPLPE
+TETNFIELVKALFPTLYDLKFILKQLSSLSHLSSLQKLSEHLKIQRIGIAHQAGSDALVT
+CCTFFKLFKLHLNSQVDDNLFNGQIYGFGLPTPTIVK
+>gnl|md5|d354584756b85842a63b94b8aac3048d
+MDLLKSTIYGNIDQEFVIDNTLDACCFQFETAQSTLSMGFEDDIYLRDSIQTFQDDPDHI
+EHTDHNFNLDLDENSSFDQRKQKELKELTFELATDPSPNSEFLVRVTETLNSILQNEFKA
+LDFQTSPLVKHNGE
+>gnl|md5|918da30cf9e9d6e2734dec9fb6fa41e9
+MSNKKTSTIICGFKKKNLEAIKTCLETHLNRENILDNAVIQECFNKDVLGFSLDSVSNLQ
+ELKEVWYSLFGKDPNTNRKELMHAISLSAGMSEVLNLSIYTQYGNEMNLGIFQSNEEKKL
+NEEESMNVLVDTSKLILEFLENGCEKDIYIKPIFKAERTTLILRDLENDVIENEIFDLLS
+KCPHFHTGETSSENKTNEYSLDAVKKLVVNFRKEIHGTWFITLKTEDLTTKVALWLRDQK
+LRDNNSSLLRVGIKSEHPIASLLSVLSMNKGIQSIHNRMSNLQLSGTEMGIGIPPILSTL
+NAPLSNLPPNVSSSELINVSAGNGPNNAVLDGPSSNRRTALGNVSSKMGYMVNIPGSSNS
+GLIQTHPQINRPNQENDQSTKDTGNEPQIGMDNLNSQNPEHLTAPLPVMYPYHRGIGRAI
+GVPNHTTPLNVYGPIPGAPNGGIIAPIIVVPGATIPGGVATSPLSSPTPEVGSPNASKTG
+DTEATKSPKNNRKRRGSKSSYISDSDTKSLSPNISNRRNSPDATNNVKTASEIENCGALP
+VADGMNSVIRGIPQGATTMIHGITPFYYGISGLSEVQPVNLQYLGGGPHLGPHPHIFIHG
+NPQFHYHHQIEIGAPGAAVQGDSGDMESSPPNTISNSETNKDNIQYIKPQMPPMFPAGYY
+HNVHYIGDESLGAIGNHGFSADSFAINNIGGSGIVVPGNLNAQARSFWVRNPSNSTGNQK
+FKANGRKNNNSSGNRTGNKSGHSPSNPKKNNNQKSSFVNGTNPEGTYSEPKVGSKIASIS
+KSPVNDAITKHDEIDQYENAEMCSTNSSKQYPSNEREEIECSPSEEAHIGDNSSITKNTA
+NTCSSYANDDNQNQISKKLPNESSTLPIDEPQDKQQTFNKTFKPFLNSAGKSRGHRNSKN
+SSNGGGNSEGKGNLEYSEYRSNLANDKSKVPDGTKGNNGPNNQAAETGSNYHQRRRASRQ
+INTGGGGGFGGRENEKFTHGKYNGYENNHFRLKRTTENEQSHFNFNNHGKKSDGYSNNNH
+FHGNKSTNHKGKGNAAKSNYQESKEIGLDHFPSLSDAMATKK
+>gnl|md5|84bec541e579890d242f62a921402d41
+MVTVVVSPLIALIEDQINSLRKWGVKSNGLSSTIIQKSDPSQSINKALEELYIDLEKKVP
+TNSIIYVTPESFGTEKVLGCLYKLYLNGNLYCFAIDEAHCISEWGHDFRTAYRRLNQIKN
+IFSDIPVLACTATASPKVQKDIKTVLNLIDPYISVNSFNRPNIHYTAYNIDDNDYLVDLS
+LEEIVLNGVLYMQEYFKRIDNQESAVGIVYVNSRKSSEHISQYLSNKGVPSKAYHAGLSL
+KIRTQIQNEWLENKIQVLVGTIAFGMGVHKPNVRFVIHSSIPDSIDSYYQQSGRAGRDSK
+FSKAMLFFSKRDITCLKCIKRKSLQYLFMKSKQKAQQAYEKFQDNLQSVIEFAQCNNSEY
+QETDECYEMDYDPENRIENSNNRKRSSIDHYPGSIQNSKPQDPNQYQIRINKYGQCRRSY
+LLGYFGEKFNREKSSSNYLSCCDVCDSKSKQQDKNNSFMSYVSSKVHLKKSSNLLNKDYN
+INSYKNQFSKQEEFNFEFNQIQDPDPDCNQSNKVGSSGFSSVFKSAKSFLDSNQKASKSS
+FQSALKMNNLLKSKGMSYLERLQTLEEQEMKSEEKSNTQNSKFNIIRNSLKKKRNWV
+>gnl|md5|f0903371077aff4f290a8c2b3c156326
+MQKINTPNYDKIISDELEHQNLTFLDLKELNDKFLEKPVFELENEEINLKIREILKNKNI
+AKPIILLIVVNRLIKIGNKTIFLKPGKCIEENVFIPELELLAFLLKEGNIIRDCCEYANF
+SNLQNISNSFTIEVLNSIIKIPTLAINSILTLKPSLKNNMNFRILDKYIPLELHDSNYYE
+NIWICTLYILNDIRLIDKATYNVLQVIFSRLFLRGYKEILCRIMVGWSNNIDKSLFEDCK
+LLNNGELCLNRVFDNILKINKTDDNLIKSFIKQLFKEIESVRVQTNQGILLLKLKDRNFE
+EELRVEDIRNDDFFLFLKSIVDFCVIEEDLKNKGFLKNELFQIKKQNFSIKTYLLFLDIC
+VLNVIKNDEFSKYFLPEQSFDYLEMIRSEKLVALEESNKLKIYLNFLKELTQCLTKQWNS
+YQDSKAYSLTLSTVIIRSVSILIYLNLSNLSNLKKVLLEFYMDITEGIQFRLKNIDPIIR
+SSAMYLGEFYFNLLYELFPSTNEADSGYLMSENPKFDELKLFNPEIKNHLSCIYNSTKFF
+AINTFSYESEIQIRNATESIKDMSLSKEKKEFNEDQEKKIIDEDDEFWNKAPSIKANSKN
+EGIIQSKASKSLLYTTGIEQKKQEPKRKLVNKSFDLINLYTDEKKSKEIQDRSEKLLNVL
+KELAENIEKDDSNYDHLILPLIDKLISLKEKDQKILVLIIFSKLIQYKTDKVSVEMINYS
+CNMNNGIPMDFRILVLNSLASACQNMANTQSNTQSTIRPNKKTIINLFDKYSLIWSSHIV
+KYIMELITHSENQECFEKIPNIFFISSLELFNQIIVNTSSNNANIGQIAHSGLEFITSID
+LTNNHLFKDIAIRKSIYMLAFNIILKIKYSSYFLALNQILRQVVTWISKAEISETDPNSI
+RIIQETKSFIS
+>gnl|md5|6ab4adcebabd67eac6979e37035cf2e0
+MLGKTQDDASFHKKISFQKEESLGIPYSKENPIKRQKNQSFFSFAHSYIQFTWVTKWIYL
+GSRRPLPAKDLPDLPETDSTNYWSNLFENFIEQERLKNLSSFDRNVLVIRALWKCLYGQF
+IMLIILKVSWEACLYLNNSVIRGFIQYKEMESSAEVSGVSSEKSQALGVGLWNGLLLVLF
+YIVHVYISTQFNFWESRVILKIQTCLKTSIFKRLIESKSCAKNLLQNGKEIVDSKIKEDK
+LNIAEDLHLDIDPSLSNQNSKSQNNLNEIGQNTNRSFYDKKKGSEDRYTISTNVFNLLMV
+DVEDIEDFIMALIQFILLPCRIFVASLLMYRNIGESAIPGVVLMISMIVFMIILDIISAL
+LKGPLLYWRDKRLAKLHEVLNKIRTIKILGWAPFAEEIVLRDRRNEVSYLYRIISFSALS
+YLFFKLAISGSVVAIMVYYTKGMLSRAGNLSSYPNGFDLKASNIIPLIHVINYVAGILRT
+VPNSLNMLIEGWISLKRFSHHLGYSHFPSDENKVLENHRSLGDAIVCKSNISSEGRVEKQ
+QKQEETPLISKILTFDGGNMLEVNEVINKKNQDKLPSQVFHSYTNQKMDYTFDESILVYL
+QDLEYIPESDDENFKKTKNNFTLIIPKMIIKKNSCHLIVGNSGSGKSTLLYGILGEVYSK
+RGLRFIRSQNSTIGFCSEDPWIPIGTIRSVILFERPWNEKRYNRVLEACLLIEDIMQWQE
+RDLRVLDDGGHILSGGQRSRLTLARALYGFLSDQEEYNSFDEDSIEENSYYSVYCSNDRS
+SNRFDTQLFLFDDTFVSLDPNVGRRIFYNLFNRESGLLTGGNYSAVIVINTTVLLCFLDE
+KLSQEEINEKFGVEINIWNIKSEPGRPNYNILEHSKYEILKNSSVEKDHSFNNSESNSRT
+VSGYIDVGPGQVTKEKFELRKRNLSAEKEAKSNSNLSSSIVTDFEHQNSTIKARGTASSY
+SSSDFYNEDIICIQSETGHRVIPLSLYGWYLSKVGIVFFISVCLLIMTSIILDSGQDFLL
+VEWTGFTSDGRDLKTGTEFYDSNSSSLNTLESHMNYMYGLIIIFIFGILTHLLVQVTQIY
+ASLRAAKKIHNEMLSKLLTTSQEFFDRNTIGQIINRFCLDMVSIDRKTMFRICNFVSIFL
+EILIRGGFIIFVFPWLLLMIPPICLFAWFWLFQYYRHASRELFRSNLSAHTPVCNIYTQA
+LMGGSIIRAFRCGHVFLNRNINYIDNLQKIRFMRSASAQWISVRMQLLLLPFTAGITLAP
+ILLKYLNLSTAFFASFTIIKMTAGLWGLALVFVMSYALLINDFFNMFTTVEKSMCAVERV
+SVLLNDLEDSKKKEFNEEVHELKYKEYMVSNRNSPQNNFQGLYIYELRVEYGNQSLGIEL
+KNEYVKYGECIGIIGRTGSGKTTFLNSLLGLTPIQSSLLFLDGKWLFNKDMRKNKNDYIG
+VLPQNSIGFDGWTIRKFLDPFDEIHDDQVIWDGIYACGLETTLRSISNLNPLDAVLGNTS
+GGISKRRGSKDKNEHKFTQKHLRQLALARLVIHRLKYKIILVDEPPEELSSDLQKQNGSD
+NYVSMNSSSTRKLGSNILENQYLSVEEIVSKFMKHCVVFIVAHNYKSLKSCNRIWVLSGG
+VKVNECEFSQVNNQQMLADFLLTNTKNQ
+>gnl|md5|f6436cf3751aae2c753599b3d8cef1ef
+MENIGLEAVAGKIKNGKNDGVEFLFLTKAVEGCLISQEIISELLDFDIFCIDWQEYNKDP
+KYTVGNFDKVNSINFVIQEPLIQVLREILVTLEATLDANLDLKIRIYLPYSSELHVEYAR
+NIGLLQEEICTINKKVQLKRFDFISIINEVMKEFEGINISIETVNWISIFYCIANLICNN
+SCSSVYATCIENRSLPIPLLEEDIERVYNSVVNERKNQHLNNFIMPDLFSKENVKKDMAL
+LNLVNLPSSLRKAYSMHILQLMSFLQQVTGTNFVESESCSIKFLSMGQTSNLISKAMQES
+YLEMVNTSSKTQIKPSNTKDDITILIMDRTLDCISPIYSPILNINLSEDETFSRFDDGII
+EFLDEFILSSTQNQAIGNISTGDSLEKDDPELNCKELEEDRESYLNKKVEDSNNSDEGYI
+HEITNPVYLSIMLDPEKLQKDLVISQNYPILSYRFISALEDLKDLILSREKSFSESLKKD
+IINRLDSIMNIHPIYGQNSWMFLLLSLNQSHYTRKFWTEVCDVCNNYDLKSNKRKVMVLI
+IVYRYLVIIQNDIASNSNDINMKSPSTQTSSSSLTPVIFQDQIEKEEDIIGKIVSILLII
+REKLLPDSITNISKKLEDLSLNPSLYNTYDLKLELSALLQILHYFLIPMFPLDLVSFNSI
+FVRNLRKKFTNNSFENISVNDQTELQSYSLECIRKIISLAISCSSYEGPDCKFTSFNLKQ
+VLDCFHPEGGFSSFGDLEKLGRKLNNIRNARSKIKYKFFRNFQLSPFLPENSKKQEFQIL
+SLVSQVILYIIQTIFIEESKTSKEWLKVDLKMKSISSNYDESSLQSLRNKLKETKKTLVI
+NIIGNISMFEINEIEKLSNKFRDYVNIIILTDHISSAASITNSLITDHHNL
+>gnl|md5|6f1a24e63af9505628f30162ebf8bbc9
+MRRAVSRVAGFVSKWATTFIGKYLENVSEDSFELGLNSGKLQLRNVKIKEGFLEQLRLPI
+KVKYGCIETINISIPYSNILRPGSSSPLVVEIDDVNLYASFIDHNEFNSEKIESLVISER
+LRLIEHWNIHFMAELAEDEYFSVKGSSNKGGSKPFLSRIVSVLIQDVRLKFRRIHIKLGD
+STNKELNCGLVLDSLEVRSIPNLSQVLVDQDLVIPKLVGSGINEDTNISGNNSASGEVNS
+ELGPDQIHGYEEHLGLVKEIFCSRSECSDEKLFEPFFQKKDSSEFSYRILDLDGLSIYTA
+KEAADGETNLKETPKELDQVVHPFCCKLLLRQRKDLFNASKMPIYTIYGVLEEIYVTVSE
+QIITYCGGILNQIQAFNKQIELGKTMLERKFLYRPNVPVIGNAKLWWRYAIGCIIRDRRA
+DISSISGSHRFSRSSYNSSLYIRLQEDFTEAKISMYCRDYTVEFHKYFEEKMTFDSIGPY
+FDGGLFNELLLDFSRQFSEYYILRVPFSRFVSLHTSLVHQWVGKRLEIHSFRRTSHSDSQ
+AAGGGSGSWIQWLFKFHRISSVPLNSADDVFFDAQESEDEQNKQEEYENFNGSVELDEAF
+LAQQTMEDLQFFDCLSDHSLEDGDKNTSESKQNLGSFDKSQSENPLYMESSPTVKQFGAI
+SSETPFMAFRVLLRETKLEVVLRDEFALETGGSKIDGQEGLRMIKRSALMGSLRSFGLEF
+IQSDSRISLLSVLQEFNLDYSDPDGERFQIIYEDESLVQDEKMWFTFYYLNKKSSICDVQ
+GSSRRRSSLSMSSDFSMDRSISKRLETSFPESSKTTIKINVEKCYAIFYSNVVSALVNAI
+NKYNKSIGKSRGEGIKHKSKTRIDNHMACTESGSTDISEKRDINSQEDGFLQNSGLVDVD
+IQIETPILVFCHKVDPRLGGAIYNVISFGKISISNNDSEILRGYELEESSLDISSPQSRF
+ENNSFDLQSFINKGVGGGIQVSPYYRYVLSEKSTYWFKCIQSLCYYAKIEEIYLSIYSDF
+QSGTTGIEKDEQKIRVRIQDTSNIHRRESGKSEKRSPKLPKGVDMVNSYRLFSIDYIDIK
+LNLLSYKRYNMLDETWMKYIKLFGVLTQLDPFSQDLFEERSFMNLVLSTNSVCLDSKPTG
+GGSIGEIQLGDVLKNIYSSIQINSITSNFDPQVYQSIYLNMIQWMDDSCLSEYFNLGRKL
+TREKEFKMFKLGLNIQLFWFLRLNSLKFDFVSDNNSWMNVGTRDIQVLNFIHDHYRLVNF
+SISQLSMDYFLRIKEVEREGGYLKSKDEAQECKGIKRIPLFSLSNTFSFVRFPTSQYHFI
+EEELSLEKARDEKVKWLNRSRSGYSQSNQVQVRTEIGSIIIYLRPLILQELLCLFKRSTS
+PYISTEQEIKSKKDQDLGSEIGLKTSDKWTKYLIDANVCNSELVAFQRDTEFFKLIFENT
+VSICDHDTRRDVIVRVIRMKGYNMVNGRKDLCFFKMDSSVESSMMEVKMISHQRAQDIED
+LIHGRLSKMISSSEMLVEAENITLVLFLDAFLHNIYYFSYLIDNIQSFVYYLEEDNVKDS
+EVVKSSKSSSLILPSQEKVGGEIEGSSDVCVPLRSMNFRNSKLIIPSVSVDDADPDKVSS
+VEMFIELFNFNNKSLIRQVSDPSMIYLYIFRMMNVRMRQVWGLYLEEENYEITEGRSSIP
+FGIIPDLNFHLRRYTCSEGMNNSFDMNCFIESKQKEAELNLYPETLSLLIKAFSENLMNY
+DPFVKQLTNLSSGTISDPEFMISLKEEKLQDDQFIIGTKKKRYVPQLIQHRFIGRRAALR
+FQESIQGGESSSIIPTGRFEDQDIQPSNSISVSFPLIRINLIKDWDWKNKQLTGFDGNVL
+QIEGKETKEGSIQTVSIVRIKGINLFMSKFPQNQSFTFNLLLSSLNFNDEQNPSFLISIP
+DSFHYSDVNSNFGTGYCIQDQSQDQDHKQEKGDRESNKGLKKTNFEDQHYFTVYTKEAYF
+ENYLESYFNALKPIVEEDQNLQENQNPRRERDLEQPIEVQYYSFKEDSDDIRDNKKTNTS
+CSSWRIRIESPVINTDCDIQSLFGIYDWYSDYSRVFCLPNSDIIEQEKSRKDENNSRFLV
+DLMEVNLSLKKFNCILASNTGLRTKVNLIGTYDLGYLSKKEKNQDGIQGENDLERLCESN
+LNISISSSKLGYHMVDFGSFVIWDGLEYQIIHNIISKGMEAVLKTNRSLKLIFQPITLQI
+HYPHVLDLYDVLLSMQKSLSKRSQLSRNSDLYRSLTNGISERFTSSQEFLGIGSPKAKEE
+LSINVIIQNSRLILLNSIEDFSGIPLFMIFVQSNSLILSSRSYLIDHPISITNSGDFSLW
+IMNPRHGYFEPIIEGCNFNLALDKLVQNDGFSPRNKSCSSKVTKRLNFHLLSALNLNISP
+WTIRTILRHYGAWNSRGCLLSSSVKPFRPILVINQSGYDIQLIGYPNFDTFQNSKNNNFI
+DLGSTCNIIKDGTEVVLDQINYCFQPSNIQIFQIHIGRARIKEYCKNEDQINFERLFSTE
+KVINLDNTGRFAIFIRNLKDTKMGYENKNLQNGINSNCLLFESPYLFYQVEHRNIKDQLG
+VEKILRILSPLELSNEISMDLQVFFTDGLFSSRVLPNSKIPIPFNLETSNYLCYNKVSKD
+LKEDNNRTNPVKYNEYYKLKINNFLRDIIKENENLNKYRITEKREKRRIYFVQKGECAGV
+GFYITIEGIMSTFGQGKYQFYKYILKFKPFLTLISTLPLDLEYRFFAFTSGKEGNNKINV
+ITTQINDQDFSSNSGILEYMKPKALYLPCSLFDENPQVKLEIGVKSRKDSKTDNNNHFEN
+NSQNFTVIWSCLIDLGNEIKLGIWKTQNTLNDLNGGDDNEIYLQRLGEIVPGKNKISMFS
+VYNLEKNPKGGYPLTWVVHSKYWFNSVGSELNLSNIILSDFTPPPDSVSNLMKTSNTWLK
+SNQNLFGQYGDLIKHSIIPLVKREGSIHIEGAFDKIKSRKIVFMALINGKQHIFDFTKPH
+IKTKKGGIYNLGILQDKLGMVGYNFFYRDISLELQLNGNIARVLIGHLILFPQKMVVNNS
+KITIEMQSHSNFILNPSTSIPVIPYFPDTIRLNYKNLSDRVKSGTVSSYHIGNDQTRRSR
+VISIKSGSIIYPNFVLNKNKSWKILLKKPSGDKFQVKTEVNDNFESLEERPDELSYLKIR
+SILDENLGFEMVLITIKKTFNQEFYTRNVSSVFIFNCSNKDLHISQRNDDSKNSTYIPSS
+SIIKQVFRSKSISEFVWEDYFRPRDIFIHNDLNITNSNSANNIISGYNVNKKAKYISIDN
+YSNKRRQEKNHLFEVYDFGSNEKKDWIIYKVSKISSKGNNYILGLFSYEDFMDWHSKKGL
+TRRALSLLQPSRPTSISSPSFKSGNSYGSPVSVVSSSLTKFSSFNRGYSSSEQYIFDIFC
+SQVLVSVIWENPSRNTPQELFLVVLDNLHSKYCFFTHLNAPQDFQISIGNIQIDLQYKDT
+LYPVLFQRLPSSSSRTLNTLEEKFLASNKTDFASFSFSSNQNNFLESSSQHQYSNSSLLS
+NSERSVLPMLVIASNFCWDCIKSSKGKVSDSSGEVDLEEDVKELEVNLNRRSSRILISQN
+LSENYFSEVSEYLKSLNIPNIGLPSELLISQGFLRNQKNSNGDSLQLINVNKLLIRLLGI
+NICFDTHFIYILTMFIDQIKEISRSIGNNVKKGRSGTNISIYDYDKNTNLDGESRSPKCD
+DLGLGDGDYELSKNNDNEYIGGNINFGYGIEEEQEEENEEEDDDEYQFIDKKDIIKQFPL
+KQSFFDKVFIKNFKIYPMVIHLTFNLNLLKSSINSDSLSSSSSSLSSSSSSSSSSSSLSS
+SSSSSSSSSFQNPTNNYEISNINNRQRNGSIIGNLNFGKVLEQFAHTFGLVFSSLIRSIT
+TIEDAPLWMNQFESRDSESCSNLIQKIRKHYEHELYSQLYVIATSLGSVGNPVNSFTNIG
+AGIGDLFYEPIYAVTSGRNDSNNNNNGANVVTGVKKGIESFMNHSVFGTFQAISKMAGTA
+SQIAGALTMDEKYMEERRRFVHGQQPKDLMDGISIGAHAFGKSVTDGLSSLVGEVLDGAT
+TGNPNSLAIGITKGLVAAVVKPITGVLDFTQKTAQGIQKASTVDRVGNTNRTRLPRVFYS
+KSQVLAPFSKEHAFLHDIVTCIGGPDHIVNQRISSSRDDIGNSIQLGQLFNGVLYMTICG
+DGSKIAVVTNDSLLVLQMNSGILCSESESENVSVEHSIQLHNIQYVIMGSLSKSNSRKIN
+VCRSVFNNDEDFKSVILNRNSIKGHGYALNIDDIYPMPCNKKEEAGLKETLFNDKMMSEI
+VIQMQRQSECISPSPRTRSSQRLRPSIPKSSSSSSSSSSNKREFPDYFQVREAETPSMII
+ITHPSTPLPHYRWIECSNRSNLEKLKNVICSLI
+>gnl|md5|0fceb3820c3e791010e28c88ada2cd82
+MKLIGLSAQPTYHPLARSSSGSFESDSTESGRVNEERNDTLEEMIYKQSSDSIEDILVPI
+TKPIFSDYASIGRNSGVEEVYSSNVSTISSKGVVFPNTTASSDNAFTKNNSTNSSKHTST
+STTTNTTTTTTTTTTTTTTTTTTTTTTTTTTTTATETTTTKKNTTTTKNTTTTLRPRFYT
+TGKSLYTPKTENVRTSAYVKKNSNSLTGNNIVKRDSGIIDMNSDKEAENSLLGFGAGEYV
+NSESDDPQETQELSYLNEAGQVKMEKSIEGHFDVIERTVNKKLIIGVVIGILLILLILMF
+CCVFFLRRRSDDTESAQNVDNSNKEIIRNKLNSLQLASIKPILARKGSKIVHMSQKSISY
+DSNIAPPEKKSIVSVEDTTFSPEYMNSGEGGEAEKTIPYYVAQSQANTLQLHSGRNINLG
+YDTRPQTQKQAVLKSPKYHDFFYSEPSR
+>gnl|md5|7c1fd073c91c07deddfa432cd5f0b909
+MCLLLPSEKEFSYRFSPGLEKWQMTSVVEELRKDFDESKIPYIIKNRNTNDYYIHNPNKS
+ETEDKSLIRLSYISPKNQKDKPTEAIWKEKIAVFDFCSPGQSGDLETKHNIENGTLLKDF
+RIAINLEHKENPIEVANTVTGPIENSCVLERRRERETVEVSNFVLDSTHVVQIESRRGFR
+QCETYELELELKPSHFIPLLKSYIEDTNNGKLKVIGTHPFIKLLTNFVNLVFGITLFLNN
+KKPNEQIESSIQNSSGNENQIMDLTSCTQSNEIVQAFKKYVSPITPILGDYLYRAVASEK
+QKLNRPQDIICKDDIDISLGIKPLPPDTKEI
+>gnl|md5|2e2c7cfc18d6d6c31a54ffe88a99407b
+MGNFLASTKITTDLASKSVYSYTLTTLEGNLFPMESLKGKVVMVTNVASKCGYTKSYYKQ
+MVRIYSVFAPLGLEIIGLPSREFMGQEFEDPKEIRKFADSHNVKFPLMEICKVNGPDALE
+FVQKLKRETPELYDEKSNTLSAIKWNFSRFLIDKNGKVVAFRGTRTEPNELIPKIAELLG
+VSDYQNLFKNYDKLHPEVRL
+>gnl|md5|ea4130a9e08f800048fcba768631dcb5
+MEAANDSFKYSSKAFATMTAGCIGSGVVFLTYGMKMAGLAVGISTLIICAIVSIVTHSIY
+VVGSLQLGAVDLSTLLMRVSAYKSIRSFLARRDAKKENKEDVEKLQKGQKMILTASEVEE
+MKRNMKFHFKSISIICFLSMAYAVPVYFILLRSFTQDLVTHAVFSFPQAKFLEYLKDEYF
+LSALYFLLVLPFATKSKVSELDFLGWFSVASFFTLATVIVVRSVVFPYSGPMPPVTGEVH
+IWPAHGPLSAFKMFTFATYAFLCHCMVVPAVLNVSTCTYKRCIKVISASFTFLLVFSLAL
+TISAYTTFGEATRDNITLNFSPCDIFMGFSRILSCISLCVIIPLFTVSICNFIVNDIGLI
+NYMSELAVEDVFQVIFDGNDDDDKKESRALKLTYVPSNPNIVLDELVNLLAKNKARAIES
+DGQEDYSTEATLKSMKNKEKFNIWRFLLSTAILLVSIFLSHVAKSCTQYVELFCGYIDAF
+TASIYPLFVYSIIWGRKKSFFTNFFVVLSCYISAIGPILSSIVTTYELITGVQT
+>gnl|md5|099eb90cf7dbb0bb80504e34842fd5a9
+MRNIRFIPQLGIFVLGLIIICFGVSECYHEEKSLESSQVFQKDPQFKLEQSGSYREDPER
+MRNLDEFIKYLVNDVLFPLEGIVKGYCLFRSVSDEAKEDLGLYNKESIAVATILLSGKWK
+NPINFILRCRESLRVVSNGMKVSSFEHSSESWSSITSARRKMKASRIKICFKARICSRMM
+KKEEGTDNLRRFLIDRTQYGLIYPDQGSEMAVWNTVREFKDILSAGILKGSIKNHIRVII
+MFNYMNKILSQIGKQPVTLFVCIALINSMVRERSLSEWLSFSRSKTSSRNRLNEPGIDPV
+TNLRYDTRLNIKENISNFQIRTCNHVIWTSEVLLSERQVQVIGVNSNQIYTLRKRISWMC
+NKMFTM
+>gnl|md5|8bb598e185775fc2a6652780ecc3d337
+MGHSKNKKSNSSSGSEAGKESERFISFLPNSVATVLAICSFIAASISSVYFNNGVFKKQI
+KFPVFVSCAQQLVGMIIMSIFGLIRMAISKSSESGNGKDGVEVQANGSSVSSWKKVMYAI
+PVAFFFSFNISFNNICLTHGKVSTYAMAKSTTLMWSLCLQFLILGIKVKLTSLISCAIII
+SGVLIGAFDPKSLVLVSLIYGCISSFSQSCYNITLKWVLPKIGNDSAGLLKYVQMWSILF
+FFIPMFGTGEVIPAFTTSGCFDFNDLNRMIYLWGLITTSALLAIGVNQSTYVVIGLTTPA
+TFNVCGLVKQALQTIGGIFYLGESLPTQTIIAVCLTFCGSASYTAFNHFGSKPSMSPSEL
+KVVEEKYKEVARQSVGTASDVFENAQDDILKRSGSKTKNVITPFTSKNPEAIPLKDDIEE
+GLPTGNNNENRN
+>gnl|md5|6437237ab39447cef1974693c0a03603
+MGKSWKQFKYGLLALAYILTIVKCQRKIPEYFNDGPFPSLSIPTSSFGNSTTFVADILDG
+ALSPFSYLKLAGISACGKLQTGTPLPSVCYIDFELKCNNPSEGGLKIRGKPVVTHHGVID
+VTGGSFELNNGKSKAGGWGYGIFPYLGESSYFELTLVPVLNKKGEYVFEIYGVGYEKAHL
+TSESIGINCPFSIGEVIFKNVHWARTYIVGVNWIRNQLPFPNVIPKTKNKLVEMDAPFTP
+GSSWRLGGMFLSSLHVPVNPSIPIGNTDMRVILSCPKNNNNFLISLNSTGDVTVSQLYTN
+YTNMQLFDQFKPNNEIFTGKYPHVMYNGLIVELVIARSLYAESGVIYLNDLAIPKFFECR
+DNTIRVSVKHDTWAPLYTSNFTSNCHEYGSSFTGVNLFSIPTFLSPGQCQNSCIQTSDCE
+FWTYNNKDNICNGYSSEKYSFKRDSSTYSMITGSVSCPCYSHNVNLVTPLLDGNDKVKVT
+NSAVSSPAECQALVLENNGLGSYFVYNKEKKECYKQGVVKSNTVPIIDTNSVVGPSICYE
+YIYSNGVTRFSDKLQLIKSIKISTNSTDHHGEFCRSLCSMEEKCQIFELNNSYECILYSI
+NDKRGLRPLFDIIENSWPTSGVILMGISTPLVVSYSTRNRENILHAEVGSLSLDLTRSSD
+ALNSSLTMKQLSILLAILLLLIL
+>gnl|md5|1e3d7e5e78227bf5e7536be21221f5e0
+MTLFANKIKELCYKEPHGSFLCEIKTQIGLPPLKIYGKGSNMISTSISVMNPPKELGQGN
+LLVLMIATPSRSSIKWEKLEPQSLLFLSVLMGPKWERELKRYTQLSIKYFPYSGEYIRLT
+PPVFKIETKESIIQETSDLLDSSISASISRSPSTKMSKASVLPGVWHEHLGNISIQKLVD
+FSKFVPDNSNLLINIVWTLASAFNSLWVGGVELCQIDLKSIYVYLGSQNQQSLNMGKILD
+EFLEFGPNEENVHSLTNFVLHTLSPPLIRFSELGRSRVHSVTESSIEASQSKINECNDQL
+EVMNIFKNILSSTDLSGRIKGQNLETICREISEIDPTKLDCSSLAWARENSRIPNDLDKW
+PITDIPIVSPTLKQQEVEIPTSVNPNEEFSNLESKYSEQSRSLLESVPPIPVYIPPSNPS
+IPPPIHQSVHQPTPPSIPASEPSAKEVVTEESQKKEFSPESPPSEESEVEGTSTNEIFDQ
+ASVDQGDSSVFVTNPILPPPPPTSTIVKPYKPEDLNEFTLVKVPKGQLMNLHIYPRITGN
+LSEQRKFEIKELLTALKGVAEELISKFTSWSASISRKHSSIVPDVNFKPSFIFVPPTPNN
+RADSPRILEKEFYIHESVFLFAREELQRIELPMQQIRNEDLVEVKMSRASLAFINNNKQV
+PPSITIPQAPSFPDIRPNISPISQAPSSIGGVNDNEISRLVSNIEKEPSKYKESIENTQR
+SSELSNSLEKKSDISLSSGSLGQGSESSQKEMSSESVIKENSEANVSESQRSISTKPNSE
+SENIQGLSNGHEHGYSTDSSITKGEQNNSNSLAQENSPNLDSNSQAEMSSLKSESSLDFG
+SNTDLSSSDSRSVSGSNSGE
+>gnl|md5|6e962510487c16f65fb970f540e80942
+MMEKPFTCENQTKSGFSSTTLLLFYVVSAPMVGAPYLLPSAVKELLMNNDAYYWLDPDFK
+LTTMNSLCSLGTSSLLLSGVLGAYFVDLFNNRNTAILSAAFHIMGWIFCFFLDKTWFYFP
+YIGICLWGISTQLLTLTKTSISVFYDSKKHLVVAMVGGSVGMSFAYMQIMVNLVRYISSK
+GIDFHYLGVNPTQFIIIINCFFSILWMIGFYFIIPKHPFVTPTVDYCTRVSISRSQIMNS
+LTEFDHEERLSLINSQMIVEVNRCKEDIPYQWTLTFKEQLISIPTILFTIIYSLMWFVRL
+YFTVNMKSILLDQTSGDLQYSESIINIFGLLLGTTFIAAILVGIFVDLMGIYLFLVLFVA
+SSLLILVLFANFIPYCFLSHLFGIVICVFCYSYFIGCSFSLFTSAFGYTHLNSIQGISST
+IAGFFTLVYNLWDSFIHRNYKDNFFFPTIIAIIINSFILILSIFILLYTKRWNSHNSTYF
+FSINKKTSLIK
+>gnl|md5|63ab9d2fb6fd8264509dcd9193bd9eeb
+MASSETDKRRASGRRGSLESGRGDSLGKNSNESNPGVFREMFGTKENPTVIPFKSIIKNP
+KIYFPIIALTATLTAGHIQNPDATRELFFKSGGFSFAPEMLESGEAFFTINNVMSVANGA
+VFIGHMIAGSIIDRFGLLPCALIGHILSIFGYTLMFLLHFSSYAYYFAGICFGISVSCTF
+ASRSRFMQMFPKVKNTVGMLLTIGMDFSLLFPLLQDKLSELVGGTKTVMTGMVIIQTIIL
+IHHAFIFPYGKLPDRMEYKNSNNSRNLEDETTDLIQKDETEEIEQDGIQGYRELSCIRKI
+FSLPFIAFFIYMLFFALSRIHYQLFFRSTCLMNISDQVSAKKAADYGNVVYSLASYLSLA
+WGYIVDYNGLIITMQYQIALLIGAYFCAGFKSVSNIIPQILSNVFAGLYTCFANSLTYSF
+VAGVFGYESFGVVQGLASLSAFASLMSINYWQNFLENVLQRDYNLANKLIMYAAIVILVI
+LFILRMIYVRKNK
+>gnl|md5|5bd14aebcc90a86ed60e96fb91c52004
+MNFVKEFGLVLLLLQLILWITLIQELSIVKAADSRSGNKSGLRKRSGLTPQGTSKVSSDS
+SKKESNSAGEEGINSVEELRGINPMKAHSIGRVVEICNGQNVLKGESKKKFFFLKCESDK
+NQKVVSVPQINQITKKAVEGSSEKTVLVNWKLNLEGANSALVYAILFVTSTLQYSVMENC
+LVLPRNQVLKGDPKNPDLAQKLYDCSVGSKVQPITSFHILAKIDTYFNLRPARLYNELER
+AMRISQLSYSYKANSKTPEVRVSLHPKYYVINDKNGNEVFNEMLFIEKLDAIPYIKVIVV
+LKDENLLHDLLIGKEFQEQKAQVGRWYRRMLRGIWLPFYTAAMFMLQNGNKVHCDLHTRN
+IMISIDPNFGSDKWKTINTMLELAAVTPTSMKIIDIGNTISMNSHEIQYENDPCRKYERR
+PYEDIGLLDFRILDPLTAPAKPPTFLPEEEKIFSEDVKPDDINNIRSLIKYYNMKLSKLK
+AAIRSVHQWESCRVKRVNKKTRRLHQEIDKYPCRFIDQKQALLEACKILKRYTAEQFMGV
+PSCNFSSRRK
+>gnl|md5|5baa37580d0ec709b821d30374c35143
+MFELKSLFLFLALALLRNAAGDEFSDYSIFQIPESSTELSGGSLGMLNFDQKQSLEDTTF
+DTQSQVLPDHFQDPNEPSTIGNMISENNYSVERKEIIGSSDNKYKESPYSETSMSSRRGK
+RSQNIFSINKILSKYSKEELALLNEYLISFSMLLKRRFRKFIFKKYSPSRIRSQFAKMYV
+DKFGGSKSKALLKLREFEKILSLKHSAARRLFHSQFNLLISTLNSAEVLIYLAEKWRYQP
+TYISEPLLVVTKSSYNKLMNLCKKKSRKIKIVLVSASSELIPKKFRKSDLNDSFQELSKF
+SKTIHSFQESLSSGGADSKLALGTTQCNWDSSRKKKAKFTKSSLKCFFKPKKHSFFHIHY
+YDITNTAKFKYLMQVLLRYKPDPYSQNAYPLIIIPVLIGIPQIDKNGSILGLNSITEVTK
+KKRKYGKSFNHKNKKKSNKKKRTKLGK
+>gnl|md5|8b12633c04d154c59a7c30f0a458e7c7
+MIKSKYWYWTLTLVLLIIQVVLGQNEKFSRLVASYATGIDEIFYPFIPQLFLMMGREQVI
+SSLFNSFDVVIEKYPGTANLWMFESIKGEINEIKNSMKENILNLGDKYNIKFTGDNKFKS
+FQDFQKDLLIYFKEFGLERAFKIHNEIEEIRKKLMDYKTLNNVKILEKVEYRWNFLINIL
+DFVDKNEGNKNGELRRKINQSITNHFIMMETPKKTEFDVKNFDSDFSNEFWDGHLSNYKL
+LALFHEYSIQQINLLYKQKLIWLRIHLTVGIIDSEGFLNKVHKSASNTMVHSISLTSLQY
+LYQIKDRIDFFLLNESYLDQLLDIYDNLSTAMNRWMGQTLVLDDLQYLYTHLKIECLDIR
+KTLINFFDRIKQYGETDLIVLDKKSKRSKKLGKKNSGFLTRLPIEWDISTKLENDLLSLI
+KEIEIWKGKNYPKVKKSGDILIFRDMITSRVNMELEEEIKKNDSLYEDHTEFNLYLERIE
+QRYMTFVRKSIVFLDELKSTSNDCQTLYFSASQAGTLIYEIVASEILKTSNRSGRINMNS
+SKQLKSLIKDLEFVKESIDTVKKTEEDSDATNILGESISDEDFIYVPGTVGSFKKSQTTS
+GYLIFRISVIVGLLIVAIILYIYKDKILVKKFDNSEESEIYERYCSRVSLDEIEFNSSQN
+GENKMVMKKNKYYKVDNKSGNIILKQQK
+>gnl|md5|2042f28bd940ff03b68ed4180a5ea5b0
+MDVIEAGDVVEKPSPDVFRSSRQFLDSEVKLIEEIKHNFLDTVGYMEFRKFSRKHQGVFR
+DVARAWTLILLVLCGFFSNLLFFSSCPNLGDIAAHGLFYKGYNLIILCVEIGMIVTTSFW
+LLMTQFQTGVVYSFRLSILYTAITFLLFILRTTISDSENSTILQKCDYILSNGELIVYNI
+IPLIYITLQFLISFVSFFYSKLRPIIAVYYFKHPWFLKSWKFVNIEPVELKLLSFGKRFD
+GSRNISPRNTSSKYCEKSESEDKTSSEGMKGYSSDTKMFWDTESDNQNIRLASGYFIEIK
+RFSVRKLLKKLNPIRLDLLLTFRTRKDRGRRPNSLKNQGCSINSWYLGEINEEGRPHGFG
+RWREDDYYGEILVGFWKNGHPVGPFKTRECRSGSGFICLKLGFCRTEANLTPNLYGYADI
+ECSVSGQFFRGFPLCHIYPAPSIGMNRSGSIFARIGAKGKAALDDTTQKGKKMVGAVFNS
+SWFKKIRKKDKDKKTTLEKKEGILDSKKVVRLNLDNIEGNSDKMESNELNSLSFDIPSGN
+EQNLKEVEPKLSSGMCKSEMNLSLQKKGVHMIRKVRQKLRRNQNRQDKERDLSLLWVFQN
+LSPHIPMFTIHPKNEVTILVDAERGLYIAGYFPVSEVLRYTKQTGARLALNNQDPESLLS
+ENNLKSTILGPNDAISGLIPFSSSFSSSSIIKASQHPLNRPQDNRYLESVEVRVVDRYCN
+DSVFSKDVLDENQDNTIYYPELEVKNWIHSDGLHAAEALIFIHGYNNTIMDALRQVGQMI
+AFGNFPSYIKPMVFSWPSGNSFLEYFKARKSAESPHTHNSLYQLILGLKNRGIRHIHIMT
+HSMGTRLFIQSFPKLLSENLLERCEQHDHRSSIDPGNYLGLRHSETQFGDEINPIINEKV
+QIVSMTFLNPDYYLDDFINKAFPMLRQYCNLITMYGDSQDGALKWSEIIQGRRALGCNVF
+GLHYGAIGSFSKRMKSQINDLDQYRASDVELTGSLKKTVSTSNMAVYGDEINFSSNQKIG
+ATGSKLDTENHPNSENRASQESKPRNDSALSLIYPSKVLINSFNASQSPRQGSPRASSSG
+ILDTSSPYANRHTPEQRFNYLDMDVIDQSFIEQNVGTMRHNNWNLNREVIEDLRELVVSR
+KRAYQRSTRLDKREGNVWVYRIAPSCVTSIFD
+>gnl|md5|d1429b76809c6873ed538192150be79b
+MKALFLAFLIIFIEGWGGGKLVRVESLKTSPKRYQEKERIPSRLSPPREEPPVFERYLYS
+YPKDYGHYFFNRISDSNYWDRINGENKQIPIEGWQWDNTSNNWLWGPLRNQDGTPLLPLS
+PELEAPRAYVGPTRIYGPIQVDDLPIPRVLDIICKPYESLIGIRAWFPNPESKGRKDLRG
+IQFLCSSPLDTRVKGGSKHSTWSRIMGNVGPNLKKYTVLTRPEDPFVKIRVFVETLNPVK
+HQSQRELVIPTYQGPRLVYIDNQEEALEKGPIYLIRRITLRTKNNHLSFLGKAGGNLPSV
+VESAPEGYELSGFRILISGYPRSKWRGADFSTLAYRNSISLGFLFSKTEDILSRPQVIYG
+RRGYDFQDIKCDGKITGLQGFFMGNRGLVGIKVECDRVWQEVILGITEGTDYKALVGSMI
+SAVTLHLSPEKFIQSLVVFSTTGRQQKLGDDWVTPTIRSSKSEGGGRGKILQGIFAELDK
+TGAISGIGFHWKKPPKPGQAGDREDYGNLEVSESPLEGGDTGSLGNSSKKEIVPRSSFYG
+RVAKDCPILETKCPTGVPLTGLRLIMRKGETQPKPFKMYLVSLAIQCGDEFFKPIGNPNL
+IEAGKKRTYDILIHEEDPVVDFRVYLGDLGLPHLFDLRFKHDVLSSYELYGFRVAMMIRS
+ERIGAIAPLYRVATPIDLPPITAKDISIRLFGAVRPESDPDVVVLETSCPPGIPITAVRM
+WFVRKIEGNNIFSRLVGLRIRCGSKWRKTKLGSSMGDRFEAEVESGDFFSRSFVENQSEK
+PFYVSGIMLVTLENRKSSFGETGTEIMKKLASGDVESEIYGFIGQETPEGLVSIGFLERK
+ANYDDYPTFNDIEVAPYQVSASDIQGESEDSLNEEKLIESGIVNFRPGEEWFGRRGLGGS
+HAEETFCAPGSRLTGLLVHTSTKIPHSIIGLTLICDGKPLNPVGSTLGDIARYEIPMNEP
+IEKVEVVLNKEDRSLSRLKLFNRNHMKKKMGKLHDRFLSGFDVEIRKGMITALSAIYTNF
+GDSGPPPKVRTVLGSNQVGPGSAPITDRNTPWGHANANGDVSTGDEYSCEEGTKLTQITM
+AYKRNSVEQKQELIGLRITCNDEDYEQVGMWDVSDNNYILVEETFGLREKEFIIAIGGTR
+IDKTHSIGKLYFETNLLRQFGEWQHYYVEAKTRGDGLYGFELLFEKTGDYTTPIAMLLPL
+FRPTSMDTRSEDLEEKKYKSPFELPKGVAESSEEANEQEMRGMLSSPTIVTDWIGLDVGS
+LEMDGIWCKTSRLKLDGRMTWEDWRNSRMTGLRVYNDGDHIKGIALQCGNSWLEEANLGL
+VGPKFHFDEISDCLESDADYIENIEVAIDSRGIPAGFKVFSHVKRQKKVLINNNSMVTWQ
+SNVPDSGNHYASGIHVEYDPDTNIIFRVRIVYRPISIAEDPEENVGFIF
+>gnl|md5|5e38e7c526dcda7e75263a2e2a210ada
+MEQNSIVPYHNGRNYPEYGQLTNYYPNNTNNNGNDSKSAPYEIPGCPVFSVFIATVVGIL
+WLFFALTLPAYHYARVVFPIDNYIDLNFGLWTVHVSSNCDSFVSFDANKKMCRFIVSRMD
+NLSISDATNFICSLEAGTLQLLNLGCNKFHLLRIGSSVIMTMFILSIILLFFAAIFLLTF
+WFCYRTRRVRQSIFMLHFISALTCVLGIVGYLLVGGLTIQPFRDSSMFGIGSSMFARLFF
+VDISRTFDLSTGFAFAAFGMIWIVLLPLWSVCALPSDICVDAIEVIEDTTYEEEELKKLL
+GYSGLFGQNYGNGQSAVNNSYYQNNQNQNYYNHQYPQYYQGQQNHNPYGQQYPYYNQQYR
+GY
+>gnl|md5|7626e78403ff56c2e68423533f43c16e
+MTEKVEKKENKKVEEEKDKKEDEKKEKDEKGKDEKDEKEKEGEKKENKDKQKEKIEIPKI
+EIKDSNSSTGNFTANTTIPANIGNLVNGGIPLDKNTRKNSEFLQIKDSQEKVTNQTKDTP
+SLNNNTEEYFKESNFITNITQNSTQFDSFNNTILSNITNDSNNSTIIKNNQHEIEEQSNQ
+DQMKIDSVNNTGIITKNLHKKRHHILIDDHYNNQKLESINTTKQEQISFDLDNYLIMYNI
+TSSEDGTQRYILILNEDEIILVNKLLDDIAPHISHNTNTNKLPLFMEATLDGINKAINVN
+NKKTTTIQTSIKKYFNNQKGLIGENKIVNKKKSNDFVGTISKFKIPIELFPLNKNQIIID
+IDLVQSNISLFAYIKLETASNNPNEILRLSTTLAVSSLGVEDTANTVNIQVKDENKVNVL
+PTLFTLKKENLENIDDNNNNNNSTMSPNYQISKHPIQKSFWKSILKTH
+>gnl|md5|7baef63d8bb21f51de956f26332ef91e
+MEEKIDRKDFFSVELENGQVEPESSPIYRNPNYSKGELSNLQGLNANNLWELFVNAVNKY
+KNKKCLGTRKLNRDGTYGEYIFKSYEESKEEALNIGINILKMDLCPIRKYEDNEYQKEIS
+MMGILSRNREEWYLTEHACNAFGICLAPLYDTLGEDNLKFILVQTQLKSLCISNDSLEKI
+ISIIERSIIDSTRDSILIKNLICFDHPTTEINQRAKNLDINLILFKNLQEKVSKKDKEIY
+KPKKIKPDDMCSIHFTSGTTGYPKGAILTHRCFLACVKSSYEHLFSENEIKLDNEDAHLS
+YLPMAHIFERLIVMNAYYLGIPIGIFSGSVTRLMSDSQELKPTILVCVPQVLTRIIQTVN
+DKISQSNFLVRTVFHKALKQKESIIKTKGDPTHWLWDRIIFSNTRQILGGKLKAIISGAA
+PLGLEVNHKIQAIFCCKLIEGFGMSECIGTLGTRYSYAHLGTVGGPFSDVEVKLTSVLEM
+GYDSTKEPRRGLLKIRGNSVCKGYFRDIINSKELIDSNGWLDTGDIAERQQDGSFKIIDR
+KKSLFKLSQGEYISPERIEGIYLSSSSLIQHVYVYGQSTDRFLVALIFPNEQALRKWSED
+KGMNTLSLSLEELCESHELFDELNDSFHKAELSSNLFGFERIHKFKVIPEVLSTSNGLLT
+PTMKIVRNKVNSKYKEVLNTLRSQI
+>gnl|md5|9ae7c2a481079fb77ad649e44fc00d3d
+MVVIPIIPFKGINIDERIEMEFRKSGTSHLNLLTNDLIENDLSPIRGVNSIHIPGILNDA
+LNQVPLNANATELSRAIRKKISEISPGRFPESQCNYDLINTKAIYLTFLSSCKFFNDIIT
+LFNNLPESHPSYADIHYLLSNIDSWGFDESHNTKMCSIVNDRINSYMELCDKTSKAGKLR
+ESNKNNKSLITKRICSIEWKNRFFFGFALREHYGPIPLNALSSSLLPRRRTIILNIEADH
+IFNSVPLSMYENRFFYCTIKTNLFSSTFETIRKITIATRSTLKYVGNISSNNLNEIDRSD
+LRNVLEVARNSTKVFQSHLSNLFEKLDNGGSTNNKLHYKIYKEYTNCILID
+>gnl|md5|738d2cf29e0da16c3f42d8ac1e47926f
+MKASSLLCVLFAFLFRAINIFAQNNDAKSSEKSTCEIYRDVKLMSANNTRYSYTSSSSKK
+SGPAPFRLAILAMLVSDFVTDNFAEIGTGFQEFDVIKFYEEILKHGGTRGLNNYKDCCFN
+SCFSGLIPYDSDHHLANSDSISDKIGRTTLCEALCDHTMHFLKSMDYFFLSSSELFELKI
+TEKESNHFLEKDRNFLKGQSQAKKQQKSSLIRENEEKDDMAKVQSFSSVNKFLLDIQDRE
+QNQSESSDSNSIGSNHHYQLHNHHEEDPNNIKDASVMNFIEDKDFETEEMININSRLLML
+WDVDKTLWDSYNFIQKGVIYGRAGKFNPYTMSLLFMIKERQQHDPRILDQYIITYGRGTL
+MKLQSPFLKSLCYSCWDLMRVYDRYFAEKYDSIQTQDFKRVFEAKEHNTISFNGEEFKFR
+NCPGTLKNLLFWKGKDMELIRDHIVSADESLRKEYYYGNISNNLTDLEIEYNFRYPFKTR
+SEIKIDEIGTGLVDDTVSPLKLTCIEEHLF
+>gnl|md5|7447b87ebe036377893150630d930bc9
+MGKKLLSGLIVPFLVLFTAVEGTPDYSGIFDPTSLLSKEKISDALVDSWDEPIDISKANV
+STIFGDLLNSKTFSDYNSLFPLSPYNSVSNEYLIRCISAEGIVYSPDICPNLDCEQYPMS
+TDFKYYDKSSSSNIRLSLSKENVALGSAIYTFDTSTIPSITLINKFVVILRTEDPKVNSK
+ISVRLVSIIKKVEDGKETVPILRGSSFHSIEQNIIPGKTFYSIDIVGLFSYLPNEFELSR
+ISIMVLPSSPSTQVVLSMDVFAIARFYMAVDTIPIYEFGGIGEKAIQQSKYIQVRTSSVF
+GRSIIDYNDKLKARFNDYCPKTFGGQCLVQITSLQSTNAIGIFGFQLQLAGVVFAIKSAK
+IYIPISVFKSAEQVVTDIQISLLKPTFSITNLNYEKFRESFEKPINSISVPLSLESGIKT
+LIVDITRLFQKSPTLAVENVLISLSLPENYVGAIFTLNKAKITYQFDPSETFQSMDHLNT
+QVFSNPNIASIETSFFDSNGGAVSYDSSLGFEDITQANKTSISGNSAFVSQFSIPFITTE
+SLQEMNITIVERLHASSENIDTSDSDSDSDSNSTSDSNSSSNSNSSSNSSENGDQYENDL
+TETHKTLDYTLSIVKALNTSTLTSSNDLTAISSKDFKLKLGGTTRVDVLDLVKKAINESK
+LNLGLITFYGFPKSKDSSKDINLALPFMEIKWNPGSSLSNGVISGGSFETKLKNLKLGEL
+TKTNWSSTSTVATAKLNSVALAAFDFSKVPCLNTITSAKAKIEFSKFTANGEFEVFLMDK
+FDWNSSFTVEGQSFFDNPTQKYTTDKSIPPTLLAVPFVVDRESSFEMDVSITNVIGSGGA
+SLLKNPHLGVIAFSTNSDDSEMMVKSVEIDLKCSFNDGVYYNTAIV
+>gnl|md5|0df0b8954d70a34debf426187f1a4052
+MKNIIRYLFVFIAIFALNSHSTLAENNEEILKELDFCKYPEMYPGIHLHFGYWDGFRGRG
+NLIRLVFELSQLPYIGHAFGGYNPEGAFDFTNWFGKHKSLISQIDPSSTPNLPFLVDCSN
+TSKTKFMTETLDLMIYLARKFNPKLLGEGLAIPENQIMSASITANNLFSGWVQHLMGKEG
+SIEAVLNSPDFFTDGDITGGPVITIFQVEEFVKSQVQQYDGPLTFGSDATIPDIFIYEFA
+NLINTLFPGIINEYPSIRGLVDAFNEIPLVTRFIHSERSVIYPPLTSELLPFQYSMAFNP
+RRSFSSEIPRLGQYLVFYGHSESTSAASICLSHKIFSISSSNVDSEEFNEMYGLLQFPQI
+VDIATRVIGRNALVRTWYRVFRKLGSTKNRMKKSCVAILTSGKYHQVSISTEQAQEICSS
+FINCYTSRSTAWNATKTLIDASKRFNFFGGSTSVFNSERYFKKYITAPLLFAKAIRFYYT
+SKVMLKSGSFSKKSIVEILNETQKQGAVSTFGFTVNKELAIQICTDYCANKLPRKSLYSF
+KSSYSMQALCETSFMSYYPNESSELAIEKASTLVSLLDQISN
+>gnl|md5|17addeb38761d058df3e97653c7e7470
+MDRLEFLYKNINEKQKWGHPKSAGLWSKLTLGWLDKYIQNASTGISHNPSEFPKILESDS
+TVLWANKLEKEIMKMNSNLNKCDDFNVNVFRAVFNVLRGTLFRILFGKILCEILGMFIAD
+RLKLSLKMVEDFSKLDKNQDDYYNSRRNGISIAILIGFLQVLFVILTTQVGYYICRLTVR
+IQGSVTHLLYRSVLSRGINRIEVIPDIKDSQREDTTSIYNSILIDTNIVVKVVVSLVDVL
+IIPFRMILVITMLTRTMGDSVLSRPAMFCIIFISLLITILEICLAFFKWTYLVRRDERMN
+LMDYTIHNLSSIKILGLESLFYWKINKSRINELKSRKSFIIFQSISSVLYSTANLITQYT
+LFKTALICSVLYSLEIPPSKIVTSYYVIDMFSQRLADLPLLISTIVEGNNSKIRMESVIR
+HVIARNLEIQESINRDAEFHNSVKELQNNGSFESNINFNSNSIVDDGSVGEDFTSSSFNI
+NINEESGIQKARSVSDNTIVLIKNVELINELFEDRININLFQVERSCLTVIEDHSSERLE
+MFVQAILGYNDYGCQVGPKISNCTDSIFYIRRISCLPIFWCSHDPWIPSGTIRSIILCGS
+PMVKSLYKLALFSCDLNADIFSWKEKDLRFVDGKQGLSGGQIARIGLARAVYKYLYHSQF
+DSEFDHLFILDNCFRSIDVPVAVNIMLRLFTGEEAVLQYANTILIISPILKEILFSKSVG
+TFSCSIREYKFGNDGITKGFTIFKNNINDMNVSKYFGASNNNSSLTSIESQQSDDEEILR
+KKKSSSIQCSLNVSESEQYPLNYDYPYPSKTILLGNKLSSKSDCISESDLIKAIQSKEVL
+PLLEDINEIGSVSNKTYGSYLSSVNKITLLLIFIGVLITVFGGILSQFGLTYFLDLICKT
+NNQGKDLDIIKGNAPMSVIPYGPSRNIDLRKHVSRFVLDKFKGPLEYILGVQMNINGQLS
+LNTNQLIGSFGLMLFIIIMGTFLTYVLEAVACIQACKFFHNNLLYKILINSSIPTLMKIS
+AGQVLNKFSTDVILIDWNTMRSFGRVTWGFVSLVMNICLLIALAPWTLPIFLIMMGLILF
+KIFLPMISASRNLQRINLIAFSPICSIMSSTLEGSRTIFLLKNSEYFEKTALNILEFMQR
+IRFLQHTSLIWCNTRIQFFILPISIINSIFPYITPFALSSAENKMPNSIILFYLKLLSQP
+ITIAWGISKCLSLAENATCLMADYVQLEKEMCSIERINDLMNFITQKDKERNYIHHEEDK
+IEKNMLLRLKNNSTRKSLFLNKDSDHTNFKKTYHNIFVSLLSANDMSNHRNPVLSISNVF
+INYEIPDKGNLCTSSILRDISLKAFNGEVVGLIGRTGSGKSSIFSSILKISPVISGTISL
+LGQPINSIPRHILRNKIGVIPQKMCILPNCTVRDVIDPFNQYSDNEVHSVLKICGIYKYV
+INTLNGINSQISLQNSHINIHEEDQSKQKSLPLCLRSSRNSSKPPIFVISEIYLRYLYAC
+RIILYSKNYNLILIDEPIIFQDELSKNSSMNEQTIQIIDIISTYCSHSAVITISHDISII
+KKCKRIYHLSDGILKEISFVKTHSLS
+>gnl|md5|2e8f588123f419ab28b9c59cf00a17a5
+MNYFVILGKFILFLTILELFIDVILAEEKNEPIKVNNESETGLKNKLWNFLYERSLQDTS
+LVKFLPPKVPKDFVCNEENKSEFFKSCFRTIRFLLKEQWKRHESQKKYNNPKLIPGMIKI
+GEDLKFSPPNSDIEKQETYENLKNFCIKSVNNYFEVKKNREDFINRCKALSVNPPNIKNI
+KRSSLPIDVRCRGENMLAKMEELDYKRREANENEKEYLEKIIRGEIVPEEGRVPLQEVLK
+RFDYGKDHVEASQLVENPSFYKQWMNQDLEASEKLSALEKLKENPGFGSLFGITKDQENI
+DYGDPDLYEKNDADKDSMSFKFQYSNYAIPGTNKRIKKKDSLEIQNDDNPELKSLKTPPY
+YSGSHENIANSTEIKKVSTSPEFEVPETKNYTNSKFKDKSQFQIDKNSPPPPPPPPPPPP
+PPPPPPPLPPSQHLLPPPPPLPLSGDSKVSDMQKEDPTLSFEAVTSVPKYGKPFLRKGPI
+RPPSSPPPLSPTSPHPTPQPPPPPPLPSTSFPQPPPPPPPLPIPLSESSKVSDIQKGGPI
+FSFEGETSVPKYEKPSIRKGTVSPPPPPPLPLSEDAKVSDIQKENSQYVLDYTKLQEEKE
+DPLKKLSYIQDEQVLKGELFSENNKLGPIELFERKDRKNRQDLLINGPTKYYGRHKMNIY
+EDEYLEYGNKGINHHGMLKPKYDMNLRSKVKNPDRLVPLNEVYTLPEIFSSNKKTDNSKV
+NDEIVPRGYDRHGLMEIPSKERIKKEFAHRLTNRKIYTNLQGDVKLNPLNVDLPSNNKVY
+YVNVGGIRKIIPDYNLNPVYKFDPKKSNEEYYQNDANNQQVLKDFLKIIQEKKRKRKVNT
+HARTKLKDESDRQRVSTAYKIHMNPKRGINTKPTREFAPLSDINNFSAIEVNKDAKKRIS
+FSDIIKESSENNNKGNQPKNGELNQRIYVPGKVEADDLLEDRPHESISENLGEQKVVRFQ
+LPDTNNKPKKKYVSPPPQISYAGTEEDEDDDYDEND
+>gnl|md5|cdba34621a8f2dac95076ab5c3797809
+MAVKCPNSVIPKLKQLLLSSLNSIFPFSVSPNKSKSIPLNIAMLSISSFNSPIGSPKFIG
+TMNHLLSSIVFNGQFSMLKGISSFGPLIRLHVFKLYLILITKFFLIFKFLLGVPLST
+>gnl|md5|7076a68ff5db8b2f6f0945c85ab1a953
+MLKMSPRKERDHQKSMMKVLKKITSMGIWILLQTIQKSKKKSKIIKAFKKIPIISPTISF
+LYSRLSNRGKKKRKAKKYIKTIRKLEIQFRRKAYGHFQEKEYQQGNELSQDDDQFMYLLS
+Y
+>gnl|md5|69c678073cbb6df2e925ebb8df5272ef
+MIITKWVYNVFLILFFQAFLVVLASTEFESFKLGRVEPQKLKIISKTTTLNDYGSLGVYS
+FKNSKDEVVMKSILFPNYAVLFDEGRRQFCSGKYSADSHTYNAGDQIPFFLNYWTDKYTY
+RYWVLESDQGVICMLPYTLETNFTKVITGVDSDFQFELAPTYEPNNTNSIIQQTPLFDHS
+QSCTLSLFQGCFSSEFVLSLPDSSFTSGLELIVRGFSEFRTYKGIFSELVFHDKTASNAK
+ILHILINPDMIGIHLVGTGDQIWGELKHQVEIGNMKFNYDFRIIIKEKWIYITSPQGQTL
+VSSKLPDNFSNVGKIVSPQRSVSDPTFIQVLLASNTEISKDFIQSEAFCLLSMSPFTSQV
+KNILGFSQEVLFTENYHLDISLDIQSFDSIQEEDLLLGISFDEILIDPANLEIQRTSHLT
+DPKVRIGLFKGYISLEEMQSRTIITGSYQANINSKVTIQIQPISSENKLRILYKIDQSNW
+FRLTEVSGELNKLFNKIKFEKNSKHSEILSYTIKGENDASSLATTYTDSTPFISPTSDNL
+CKLMPLSYCNSQDVSFVLEDLTQVEGKDQTMEEETSKVESLMSINNVTIQIPNFPTSNND
+LMYKWRLLSNDIPVYEISVFQTSISITNLISYETITGPPMSIISQYSENLGISIIFQTTK
+IFIVDSGTNNIIASISKSKNLNINKIQTSYEKKISVNYYSSYSFTPGPKTTSTESSILNV
+LFECQFFNQCNYGNYVCQGSSARQLCKDPEIMKLWYSGPLISTDTSLSLGVFPNSLSVFT
+IGSQNENLFLINVFERYISLSDPFSGRSCYNELPNNIVLNQNSYVKFGVIVSNGKRVDLV
+YFSGNDTPNLLCSISIQGRFISDFYFFESNGQGLSSTIGDITMNTELDDLSGQITTISPP
+AESNSNSLVPFKPSNQLDLELSSELKANMGVHFDVNLDPDSDSALVIGVSILNRYQDIDT
+HLYISGGSYPSVILSSNIPGVGTLTNYSSIPDECTSVRNSLFNGGNVQFTIGVDIETFVK
+YNLGVKEEIKIPYLYVVLCDQSLAKVPMGGLNINKLLISNRSIISTSTTLVNGFYANRST
+SRIRDLSAVPLENDDSISGYKEGCEINQDLGVTSYCLSSSLNIEGDSGLNENYELTVYLT
+IQDFPQFKYRNSTYFNGISYQVGGMSSFVVLFNETHLGVLNLIEEREIWNLYGGDALMPV
+SSWISISVNRISGFIYFTLNDQIFASFPDYPSQHISIQEISLLQPGSWSVFQGVKQDSVY
+ESNRYPFIYHGFIECSFGDECQPTKEQTCFGNSFSGLCPYPNPDEIVWLFNAFPEIPTEV
+NNGTFGSSFELPELVHAYKLNDGFFDIFAFYFFKDYAAIQYLLDGTVCRNSYNVQNSGST
+SLDSVPSNFQWGFYLGDGTINLVTDLGGNGIKKICSLNIPENIDLRLNVVYPVGHFLGII
+EANKKNKNDLTITDVPPEQDTGNNPCMLEMFKKCKINDQVQLFPDETYFKSNYIFELSFV
+YDESREYNIVFKGQTNGLLSLYPVSKKQTDLIKLSILGKSLQLSNSNSDISMADILIENA
+ESGVTTFSLFVYLSSKGDTFNLVSSLDLETENTNSRLRNLVEGYKGVSVSLNGKISEISI
+DKVNESNPTVYLNNWIIEADSLKPSSKHLTCKLEEVDPGSWCVGLNATYNQVDSDSKLIW
+LNFTLSKDLQGDPNTFEYLDSYILKKENDKDLIELKFGSKELQIKDLINDETSLSYYTNK
+TILKSGEIFKLGIGVLEESPDKIYFCDEYSNVLLRIPFPSSEISGSNFIINSKKEIFSSF
+MVDSKPLSINETLIDGYNSCSFESNCGLETLTCTGQILEYPCPRSTPGLNWMISSKLVDT
+GISSGEWGNEFAINNILSSFIILGDLQIKFLVHFFRNRVVLLDPSHGLSCSGPYISNQAV
+TEGDSVDWTIGLDSNHMVFLGLFDSNSKKHFTVCGFKNFGEDIPFVAVIPVGSKPGLNIF
+KQFGRGFPTGGYESTSNSKDNNGFYHPNLDTSTQEYTPLIPYGQNAPFLPVGVPVTDDQG
+LVVPPGFYFNKTTSQYEPLGSAEDSNSLRPPVPFQLVQGIEECELEIYSFCNSTKVAMES
+SMTNLDKKDWTLFAMVSTGIPTYTQDPSPNFNFQFKFKDKQDQIKFSIDISNSSIVISGS
+DSSQIAEAVSPQCGPYCSTYPKGYFTFWLQKKFSENKFVVGVNYNNLLLVEFGSDNRDFT
+KIDTGGDPGATLSPSKTYVLWNLLDISNPPKQSATTTTTKTP
+>gnl|md5|c47345642d66de02fc2c5574771f3d5c
+MTKIYHFKDNNQDEILILGFNMTHLTLIDNQSSKEYSSYYTNQTTSFPTKSFSIGIGWSR
+LGLFVLNEYGDGLIQLKSDKKYEFVKIEQAQVLETLTIYEWSNKFVYPREMLFLGYSICS
+AYNDCTDDNSLSCSAQAFGDLCNRRKTNISWDIEFKVTETYVNNGTWGNEFELPGLVNIY
+FVSNDHQNILSIYFFQSYLALRDLENQNICSGPYPESMNISQDDKINWSLNIGHSGEIYL
+NIESWKGSNKGTKFTICMIGGGSNGKNKYIQDVKYIHPLGYSPSFNKYTQINSLLIPNGG
+YESTSDPTNNNGGFYYPDKDENTGEIKPEDKYGESYPFFPPGIKPAPIDGDENNTPPNYH
+YNTTTGQFEKNEDHPNPDEINPFQPNHIVDGISECDLYLFSTCNATSAKIMPEDTTFNED
+WTLFVILSTGVPVYGDNSNNIAFNYKYNFVKSDSTSSDDLVLSLSFTNNTVTFKNEKTNA
+ESVVGSPQCGPYCSTYPKGYFAFWLTYNSVTNKYIISVENNTKKLVEIEADITSDSVFNK
+IIPVIDTNRVGVEVSKTFNIWQLTNIKEXPADTTTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTTTAITNSK
+>gnl|md5|d3220ddb6c171f34f4c37ca67030bb9f
+MNLYLNILDDNVTGKNYTVCYIKNLNQFGGGFKYLSPLGYKPNYSRFIQEISPKFQDGGY
+ESTSKPDNGYYFPEKDVNTGQYNPDDKYGENSYPFFPPGVQPAPIDGDENNTPPGYHYNT
+TTGQFEKNEDHPNPDEINPFQPNHIVDGISECDLYLFSTCNATSTKFMPDGTIFKQGWTL
+FVMINTGVPDYDPNNVNNNYNYRYEFISSTNSNTGGGTLSDKLILSLEYNNETVTFRNEI
+TGEEDVVGSPQCGPYCSTYPKGYFAFWLTYDSKYNYFIISVNSNNDYLTSISADNTDMIF
+NKIIPKGNNVNNSYNIWYLNSQNRLPVSIATTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTTTTTTTTTTTTSTTTTTTTTSTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTTTTTTTTTTTTTTTTTTNPPWDQIIQDNCELEPNNQPCRGFNSTIPSIVNQGNLFW
+IDSNIAYYSPKNYNIRKLYFTENNNPISNDGYYWMGYNFMKDNDPVFTLLFNETYLTIKD
+WKGKQEYYSPYTNEKLAYNNMNFTIGIGLSRLGLYLMNSKLQSLIQIQPQYDYSFNHVKQ
+LLYDNQVITNYLLQDGFLYPNTLLYEGYEKCSLYNNCLSNKLECNSQVLTGICSTLSPGL
+NLEFETEIKSTNLNNGTWGEIFKQSDLLNTYIISSNNEDQYIIYIYSNRIAIQDLNNYIS
+CSGPYPNGNLIHIGSKLIWKIGFDSYYSIYLNVYDQINHEYYSICQLKPVIHHITSLDLI
+NAVITNNNNNNNNNNNNNNKNNTSNTFGIDSIDYIYTRGYNPSNTKFIQYINNFPRGGYK
+SSSSSNSNPNLVTSYYYPYFDKSINEFNPLYNYGKNYAFYPPGIKPAPIIGNYHTTPPNY
+HYNTTTGQFEKNEDHPNPDEINPFQPNHIVDGISECDLYLFSTCNATSAKIMPEDTIFKQ
+DWTLFVIISTGIPEYEDNSNNIDLYNYKYYFINYDKDTGNEEIILXLLLRNETVTLKNHI
+TNIEKTVGSPQWGPYCSTYPKGYFAFWLTYDEDNDLYEISINSNTEILLKLPSFKPKIQ
+>gnl|md5|3676b5761dc5fb2c7d6c62723efe2ba5
+MLYLNIKQKDQSIFSVCVIPFGDHLEPIRYIYPKGYAPSTSNFTQILNSIPKGGFEPTSN
+NSKLGFYRPIFNSTSGLYNNDQYISLKNDDGSIGKPFLPVGIHPVPYFGTSENTPPGYHY
+NSTTSQFEKNEDHPNPDEINPFQPTHIIDGISECDLFMFDTCNATSAQIMPEETTFKQGW
+TLFTLISTGIPIRDPNNINNNDIHHQQEPNIRFDFINVEIGGNNQQTLVLSLELFNDTVI
+LRNEKTGDSSIAGSPQCGPYCSTYPKGYFAFWVTYDPEIHVYIXFC
+>gnl|md5|d63d611e5b76688dca0b7d5a5b7ae87d
+MSYDSLNEEISISIDRNRQILLKLRNAQAVSSFDRIQPCCSNSVMNSFSLWQLSNVAHIP
+QIEATTTTTTTSPPWQDSVHNECLLVENIHCKGFNATLKDPPVFHHENILWMNFKLPTQN
+CNSPFNLNENFWYGYFFTNKDKAVLSILFNETLISLYDWKNQQEFYSPYTDGSLVYQGQN
+LTIGVGWSRLGFFLLNKDSESLINIKSMTDFSFDKISNHGESLNPSIFLLKSGFLYPNEV
+LVHGYRECSFFENCVSNSLSCNSQVLSQICSNPTAGMSWEIETEIMNTQVNNGTWGKRFK
+SQDIMNVFALSPNGKLVSFVNPNSNGNLEDPGFIYILKDRLVLQNHLGSVCSGPLPGAKE
+VNFGDKIKLSIGIDSMSMLYLNVFNEDDNEYNTVCTIGKIENGWRFKYIFPIGHSPSVSS
+FVQIKLGFPDGGFKPTSTEPDSLYNPPFDKTTGTYHPELKYFNSYLYFPSSIVPAPIDGN
+EANTPPGYFYNRTSSLFEKEQVSQNPEINPYAPEYIKKGVDICDLSLFSVCNSTGVDLKP
+DNTFFNSDWTLMVMMSTGNPETQEILGENNLKRQNYRYEFFNSNTNSLILSITYSDSLVS
+LTNEQNGITVYSSSPQCGPFCSTYTNGFFTFWVTYSKIKSSYTITVNRNKEKLLFLNGID
+ESFNQIRGKSLSSKTSYTLWQFINVSRDPVGISTTTTTTTTTTTTTTTSTSTPGLDNTSS
+STTTLPPDLSGGCKLSIGTACTGGFGYFDKTNDSTWKEGVYVTIRFKFPKVVKKRFTYYL
+DSSLRTLSSQTVFSLTLINKDLNVGSILFEPNKLKAVLNETSITTQYSNGRIYSEGDDIE
+ITLLRINGLFYIMDSNGLAMIEYPSLLLSEDEIKSKLNFTFTDIYPSIPTRLIFSVQNYQ
+GYPFVLLNGYLHSTLTNYCGVDQTTIVNQAAKGVCNYPKKGMEWDIYTKTVNTKLNSGYY
+GDLYDNEELISAYNINNGTHNTLGFLFYRKFVVLINLITHEQCSGIHPDSEILKFGMDHD
+WSIGYNGNSIFLNEGKLSKNFNKFTICTLPLSREMLPFKYLIPVGESPYSKMRVTQFGRG
+FPENGYPITEKNNEVPINGVFMVQILITNFDYFVQKQIADERFKEFKELFISSIKSSYGP
+KNKHVGIVSLTPRNVQVNKVGDTAPYKQVKGDILVTFYMHSQVGQKLADFSFEVSIKVIF
+NPTSLFGQIFEWSQLNFLTSGASPPIEKVINNTSCMGIYKKKTELETIVNKYGYYSDLVT
+EYLPESVVGYFSFNHIIPNVPTFDDHQRFVLSFKKRLGELLEIDYKSIGVIAVADTPIEN
+GVLGYGVLSFYINSNSLELSTALIEQLSIRLSNPNNVFTKNMDWKQIEVGYCNKPKFYMY
+QHDRRDGRRFNHYSLDNINLNDENDPFYISSDNENIDNQNEYEDIDNSEEISQGLDEFIN
+SFSHHNN
+>gnl|md5|259ca534d38096b84e7260fde8c6918c
+MDLKLEFLNKTENRTTGCSAQCIFGKIILLIASIILLLGLLVWIFQEKLLFFPNINGKRD
+LASNFPGYRHPNENKMNSEDVVLTTDDNVKLYCWFIIHKKFDRYSHEQSSAMHISSNLSE
+PHHLEQVKKDSPRKKILDKIRKAPKYMKFHFPEFSDRYEQQEKAPTIVFFHGNAGNIGHR
+LPRFLEFYNLIGVNIFAVSYRGYGDSEGTPSEEGFYLDAKASLEYVLSRTDVVDKNMIFL
+YGHSIGGAVAIDLASKYDVTGVILENTFTNIKSVAFRVYPIFKYFGFFFKFIQRLKFDSV
+SKISRVKSPILFVVGNEDEIIPPTHSVELYMKAGSPKSLNKIYLVSGGSHNDTWIKGGME
+FYLMLLQFIYNAIDYNKLELEVSSNNLINKNQEETLFSIQEILKTKESSPISKLRKKTN
+>gnl|md5|412e915247f407a882d5cf7d8f3573a4
+MIGNNDVLGILGTKPLNNLIKDNLFLENEQFNESLNDYWKSFLWEFQFSRLYFKLARGDC
+RIIFSNSWLPYVNHSKVLLFRLFCLVFFCTIILYDIFTEIKIWRIENLARYYTTNWCSIA
+TIGYFLVLSIVSIQAQNLVSSSIDDNIYGKNIAEIEDIIGKASYLNWTCWYAWMIQSFLL
+PTGLIVNIGYWMVSHPNTSVTLILAIAKHAIASILVFWDCYSTYQPFFLLHGLYLYAYII
+GILLAIGAINLFPNSFLSLLPISINDLYTFFNFNDENHIKIAPSLLIFIFTLFYPLLLLF
+LWFLFREKNLLVDPLPNNNLISSSESKCEIMKAETSEKVALISNEEQLEKV
+>gnl|md5|894b721151b6d4993507220dbb53b05c
+MNKRKERSEGVEVSCHEQLMGGNFDIYGFGDKRRNLNEYYNGRQLLGFIGDICEKENSVL
+APTASLGTENEITEAGVGSETVLGTRSVSGPEVEGRRLQDLESAEEQQSYGQLVKKYESL
+QNSHTTLQKVVKSLLDKLSQLNELCSQKDRELSEYKVQLKKLVDANETLNMYIQSSHSSI
+MSNSMINKFGSDIY
+>gnl|md5|c4e09049b88bf295fef14c7831486d3e
+MKSFKPESMPVNSSSESKNVGLYKDHLKKSRVKLLPISNTCYTIIREKTEDFFPGECDEN
+ADNHNSNGQIQNNMNKNTLENQMLDSNMIRDVISSL
+>gnl|md5|8f1fa2d0a813521f1b1ba9b31ea87529
+MKEDTTELSHVEDEIEMEGEEAITNKSAIADPIFGGKLLERCLKLVKKVQEYEKEERKEK
+GSKKVRYIRRGVHEVTKSIRKGQTGLVLIACDIHPVDIIAHIPILCEEKNIYYGYLGSKK
+TLGTICKSKRPASVLMISFNSESSVQDKPFYSIYSKVISNIKKVHPYI
+>gnl|md5|69b37b610b116071bd2d8083894633b0
+MCGDYQDYLRLRKWVKRVSTPLLLNDAIVIPMHCNQTSHWWLIVICHPHKIFNLMNSSSP
+RNNSTTKIENSNRGWIICMDSLGGKNISQNEKKKAIINILKFLDIERQNNDSYFNLLEAG
+NIPTMVYDSVNTKAHNTNTSVTHDKLSETFRSLSNWEIIYNPRSLPFQENNFDCGIYIIE
+YAHLLFHYGTTIFNSMINTSSSSDVSHTTHLDQNKFSRNWFQNRRIVYTKVLEFMSNNES
+WNEDNFLRNKLVEIFDDSIEASNHNEKPSQENISSLQARRRFVMSSLNKSYFNK
+>gnl|md5|d29909b5880b82830fa9677b938e57d1
+MAFEGATKRNKPNLVPGNYVCSRINYVDLESGEIELTCITPEEKKTWSNNENYLGVLKNS
+NYKNTNIIEDYSKSDRSSLPGESQSCIKDGMTVTVPQSVAQILLADQSYVLEALSKYFAY
+EICVGQNGIIWFSASNIKEMLLIMSALKVIPNCTKPQVSLNNFLLAGLNDLYLP
+>gnl|md5|973980a20a0598f1f58269a0281605bc
+MQIVRFQVYSLLVLINHSNLYLNDHLRKTSNLLNSIVYNNSSESSLDMSFVLKLSEYNDL
+ENYSTSIILKKINLSLFILPVSLLSLLESEEDAKSAFEAIQNSNAFGCIQNESFSSLFDI
+WNELEKKYLNKNGESEE
+>gnl|md5|b535e193a59d2cf6358f7365e3cc98d5
+MKKSNFENERGHSIYDIFTDQEKVTYFGNDNLNSKTICGSLKDAGLDLKVMRDVENFLGN
+SGGIDELKQSGYSSSNPKLTGIATSVIRMDKVKEEKKPQDDQDLKKLSHKVFKNEGFFDI
+AREIKLRKLSYSHFIPLHQLWKQYIKGLIESNSVHSGANGAMRTRGGIKLSQLSQNLSQA
+DLHGSMISVISSRNKSCVNIQGIVVKETKETFVIISADDKVRTILKGQSIFGIVISNNYL
+VTIYGSQLCYHPYERIKHKFRHRDSLNITP
+>gnl|md5|663102ecc382c3ca58867911de6ad551
+MFKLNNINNNNNNNNNNNIKPQNVLRNQFTMRYSFNNDQLYSYSGGGNRGQRVPRNEMSG
+TVGYNNGVGFVNHQNYLEQVIKYQQVQLQQQQQQLLFTQQQYEYSLQLQYQYQLQQQLNQ
+NRFNIQRNSHIQNQSKIMNGPVTTLPDPQTFGKAENMYSEICYSNDQGELEVLEPYEILI
+IPKRDNTVTIRDVSHVDLSNNKSSRYQEMEVEVEIKKGDKDIELETVRDELLSEKKINMN
+SDTNEEIEVNVYETRNFEEEKYSESSFDQKFNDFGYEPINNRSIEVDLKECYNCEIQDEQ
+ILESESELEEVSLNGNQGEIEIEEDSVLVIKYKNNVGTDILNLMEQNIDNCVIDGNSYYY
+ENFVRSLSFGDYSPYESQVEPNLLGFGDNCFYIVNNGPFSQSNHTSKLVEVLEDEKNEQE
+EKDGKDHFQEANKKEETEENIQTKEVQDVKSEVGSPKNSRESLEELSEKIQRFNLLLEKI
+NKMEQMNISFKEAFLSEKWNLNSNLNSGTRGLEGIKGKMEENQLEDDKSVSECSALGTVK
+DIYDSNPHIIYKNIEDRSFENSSEKLADVEGELEQGEEHVQRYIQAINDYFAREGLLGVC
+ESRLNTHRWERNYENAMSSLNSQFKDSFYNSDAFSESDPESAVNSIAVSEVNSDFIETKE
+NEVMDGVTNEHCEDILDIPDKFVDEYNNDLIKDEHNQEDKLPKQDSLQLETEEIKTQEQN
+LIKNSRLSSPKDSRTQLFPLNPIHTENKMAASSSISRTVLVSKTKNEDLSNSTKNHQKVK
+IPTINIPNSNDIPKKISSSNILKKPQNDLKIRGKTLSHANPTQKNANLAGSEFNKEIIDK
+DDEILARLSQCRVINSKTIKLATNNNNNNNLEGNTGYKIYEKSQSNASFRPRLNTCSVPF
+SNSNNSSSTNNNFNQHTNKRACEKMTRGPASNNWFGGKPTNNQNRPQAPVQVRKEPNLGF
+KSLISSGIKVNVAELMKPRIIRK
+>gnl|md5|1fa2d2bf76c8723eef6b569d015a203d
+MKLSFFLSLLVLFISYYQVNSQDAYHPFRSTALELADSKNQSSCNENCIQEKNDRSLQES
+SENSNSGTSQGSNNSVGNIIQENINNLYKELADHSQEQAKNTWDSLSTGAKAGIIIAIVV
+VAIIIIAGIIHCLCICKLCCCC
+>gnl|md5|bc6fda202488695c118cfe1503916dee
+MNKNSGLQIKQLISLSEEELTVKIDELKKELASLRVIQSTGTAPNKLSRINVVRKGIARI
+LTILSQRNIKSLREKHAGSKFMPLDLRKKLTRAKRRALTPQQAKKMTVKASKKALNFPKR
+KFAIIA
+>gnl|md5|6287ef24906aa634580ecde5eaa09960
+MARIPECIKEFSQEQYNQYESLLEYERLLDESILQQRYSLSDVWLTLMDDKSIRCYKKKL
+RVHIFNTYESQKPTDAELESFSFDNDWTRKVPPSWTLKILGSIIQGDAYQPRFTSIFSKI
+IIQLSETETIIWDKKTSPTPECDGLEIHRIGDEERDIDILFFLDYRTPHYSLSPQLEEFM
+GTSLANLPSIVKRIWQYVEMKGLQNSKASHDSIMIDEYLGKLLSVDTEHVLLKDVPDLLK
+QHLLPPKPIKIRHRLALKGDWIDNESTYDFTIDLTENVPGDITLGNPNMSTRIQESGEFS
+TINKALEELYHKNQSILSKIYSSCNKINFYQGFANDPVDFIHSLLTTKHFQLYGNNSINN
+ILSDPNAIYEYQIADKYAEYYRQPWVPRAIEKYLSCKNKNFEERVNKTVASVSACEKIRR
+RSGFGQDQRIQSHPNQQ
+>gnl|md5|5e693d44f40588b82bac5c4b581c5d32
+MFDFINKYVGEVANASASENTERTLSETGSTPPPEESSDEESDVISHTMDWGFLDYVEHL
+LMLSRSDEGEDLEITKTKVIQDSWSSIDNRALSLHKALLIKVSLKLFIHLLLFTIKYSSI
+FI
+>gnl|md5|547f625fa433fc9669e5cf8b577338cf
+MGLALTKIWRNLFGKKDMRILMVGLDAAGKTTILYKLKLGEVVTTIPTIGFNVETVEYKN
+ISFTVWDVGGQDKIRPLWRHYYSNTDGLIFVIDSNDRERINDAKDELARMLGEDELRDAV
+LLVFANKQDLPNAMSATDITEKLQLSGIRNRNWFIQSTCATSGDGLYEGLDWLSRTLASR
+SNN
+>gnl|md5|9f5d8f62a822fd4e2a1900ba3671fe71
+MKKRNVLIGVTGSVAAIKIHEFIKKLKEKVISNNIEIEIKVVATDSAKNFLNGLALDLLV
+DCQDEFGNWKSMGDDIPHISLRQWADLYIILPLSANTLAKLSNGLCDNVLVS
+>gnl|md5|c33a489af8de7dfefc677725da25e015
+MVNINSPRKDLSVLAQCMNPVEEEMQEEQVFHPDSVILPPVSAVPFDYYPYSPRYKYPEV
+TCSYPFVSSPPYVVHYMSNLGVPSFFQQLDISIDQRRNVFQRNSGRNRGLQFEKGEENFG
+KYWSETQPSRPLGCMG
+>gnl|md5|173b3ecf746f816313a3e1863a28f40d
+MGKLSRDRRDIYYRRAKQEGFRARSAYKLIQIDEKYNIFDKVTRAVDLCAAPGSWSQVLS
+TKLLNNSEYNEGQPKETDKIASNNEEAPLIVAVDLQEMAPIYGVNIIKGDITSRLTVSRI
+LEYFQGKKADLVLCDGSPDVTGLHDIDEYIQNQLLISSLSITSKIMRKGGTFVAKIFRGE
+NISRIYQQMFCYFELVDCCKPESSRNSSLEAFIVCRYFKFDDQDSTNVNFEIPDPLTVPF
+ISCGDLSEYDPDKTYETEYTSSLEPIQPPINAPYH
+>gnl|md5|b15c5c92ae6a6a07a19cba7410d761e4
+MEERNIEENNEDDDLFGEDIAFSKESVNRRLGKVQKRNRLTKKVCINKESQQNETREKIS
+SNDNNHIEEDSDYEEFKPAARKKISRKEDTVLTIEKTQKKVGTKNEQVPQVITIEDEERE
+KSVIKLNVKVYKRKESDIIVIKTLVVALYRNDLVKKLVIYISKNLNPKPEKYLEDIKVYF
+DGDCVNMEMEIKEIGIEDEEQLEVKVPFECNWIK
+>gnl|md5|e2fa1c8011f288b842a220fc62d3df37
+MTGSELRTPVSGCQWLGYNRVHIRESRTYKVSPKKKVELMRYEYNSTSGCELENYSRQII
+GYGDWDVNKYTRGNQTLVDVRINWRKVIIRSRMNHVNILDDLNKINWLYKSLSPVYFYDL
+NLLNTCIEHLTIVPDYDISAIDSKTIKIDGETIKISNEKLNIDHIPDSKVEEALLRMVTG
+YSGNVISDMVKREFSIEKDWEEFFKHKSPRMRKICQWKDIKEFCLMPPSEIIHKHSCKLP
+SVDHLISSDLETLKVALYPYNSTLPDTDLIEFSKYKTC
+>gnl|md5|1b0f1c9a980a4ed8e0f886a8eb4b7b92
+MGNTAVGHTGTRLKAPVDAVVNTTNKKAPVSEKPTQPQIPNKTSDVKKGGTMGGERGSVT
+TGMFVQSGSGTFAERYNIVCMLGKGSFGEVLKCKDRITQQEYAVKVINKASAKNKDTSTI
+LREVELLKKLDHPNIMKLFEILEDSSSFYIVGELYTGGELFDEIIKRKRFSEHDAARIIK
+QVFSGITYMHKHNIVHRDLKPENILLESKEKDCDIKIIDFGLSTCFQQNTKMKDRIGTAY
+YIAPEVLRGTYDEKCDVWSAGVILYILLSGTPPFYGKNEYDILKRVETGKYAFDLPQWRT
+ISDDAKDLIRKMLTFHPSLRITATQCLEHPWIQKYSSETPTISDLPSLESAMTNIRQFQA
+EKKLAQAALLYMASKLTTLDETKQLTEIFRKLDTNNDGMLDRDELVRGYHEFMRLKGVDS
+NSLIQNEGSTIEDQIDSLMPLLDMDGSGSIEYSEFIASAIDRTILLSRERMERAFKMFDK
+DGSGKISTKELFKLFSQADSSIQMEELESIIGQVDNNKDGEVDFNEFVEMLQNFVKNE
+>gnl|md5|cbdb6d9049d669da6a7beec04d9aa575
+MHSSSPQAMNMDSNCLPNYLPFPIFVQIIQARKKKLPSLNSPHSKKGPISSHKNSKRFPF
+KPHNISIQAPSFIHQLIPLYNFNNSQRRTFGGKISFIDIKN
+>gnl|md5|0566faa897960897c5563aebd6856461
+MASNWEDSLNPYSLLGVKRNASERDIRLAFLRLVRKFHPDKNISELNQEKETQIANNGEQ
+GDHNSRITVKYHALYDAYCILKDPERRKEYDLSAFNESLSNYNSMIWHKSVDLEELEYMN
+EDGKEVFAYFCRCGGLIFLEKKHIEEGYNLFSCDGCSSKIMITF
+>gnl|md5|151304476c9b0ffbed9b559334cb4e14
+MVSIEMNESRESSSKEISNMIIEINHIKESLVDYWIELTLTQAKSMNNNLESNSDADTVL
+NQALTKQE
+>gnl|md5|7c83aaf0f3fd6b095aceff16ef302115
+MENIPLLKSVENKDPSLNWNIDVSAELEKYLSAIELLDEDMNYSQSIEANGYGYNNENIT
+SNNGSYMQMFNFVEAALIIQNSTSLYSKKIEHLHSLVFDAFHLLSTGKSQLNDGKIGNDE
+HTNSSNQLANKNNIAEKNTAFLMSNMVSVPINLLQPGRNINLQFEQFGNNNLNDDISAKY
+SSYSSYIGVSTLGNSISLPQYRIDTSSNTLFLDEADLGHFTSNDSVVEHEYLGDMFAENG
+MDYDSFQKEHQDHELRQNDEVYDDDMVMNEDNGPVGAELDDIEIESQDYIENFDNKENEL
+LDNMDEKGKKDVKSSAGGRRDKNKEDYWVFMDEHMKLGKDKPLKPGRTYKIPSRNYTISL
+ESLSQKEDILDFIDIYSLSSYFMGLTKIEGEKYKLGSQKLPFFSDLKPPKLSVEKLLTFD
+DPDYEYLRLLEPELNKSASSWKKYHSKVFFGSMDKKRRELLNSGSGNDNEQETSEFNDLG
+MGEISEYDFEQTQDVLSDPELPLDPIEDHIQDDENLMEGTQNQEEQIISDSNLVDIIDFE
+QNLSELHTRINTWTGYVEPLLQAQNSRPEFNIHEEGKMIIERMKKFNIMEQPIRFEEVTN
+GFSKWQVCRSFLATLMLSNNREIDILQENQNTIEEEVDFFSIKLLDEDEKNQALNTNVNN
+TEKASVVNLDFPKKKKTKKDFEEESNELGNKLDKGQRTSRKRGNKT
+>gnl|md5|3525600509b839b1d9065ed6932710c8
+MSWNPLIIHCKYAKFLFQFLIFFIDNVCNLVLCGKRSQLEDNADYKIDFFRNTGKYPSTG
+YLESNGLYGTPLILKSQDSTLWIILFGVCLAAFIFGIGIFMIANFGGNLKHSEDKLAELE
+SNEYFYDPLESPEEEIKHLNKLQGKFVSTLNYTNPNNYNHCHHPQFSQFGNYYNSNQQYY
+SSSSLR
+>gnl|md5|494520f9be0205b900e07e58535e5435
+MSSTYSTFVSSIGAIETGVMGTLAGGPSYFIPFAIFGYYKTRADVNAATNRMMEIADSSR
+NPRKNFTRSTKMRNTQEFSGQQNSYFWILTILAVALGVIAISLLSCLVGITPDDDYRESK
+KRRRKLMENPKITPEEFAVTMANYTPNEYKYREWNRI
+>gnl|md5|507195b3bd7f0a871f781dbfa2babb8a
+MILITWGNPSSAIDHWGHIGGFVSGTCLGIICNFKSDLKPKWYKAAFGVSIALISSTLIG
+PIIRIWAFELAPCVVFPEKLMNP
+>gnl|md5|c14e54726d74648c73cd84a3f4cb4567
+MSNIHRLSDLPPQRDSRSQSGRSFNNNDPGLSLRFVDLFFPGITWKHSIIWISLVQFIVY
+IATCIVGSYALSPFV
+>gnl|md5|bb197f3a2b6fde842195cb737d6b6fc5
+MFLNVLKLTPLGGGPAPLLKNQIVRQCYSLMFLNIFIAIWSISSILYSKFTNANFGSEIS
+TYFFIVFLIGSVNSIFFSKLGSLRYCSDSEWSNRLILILIINLVQYGAILWGCWISYKVF
+MSRYLAGTKMYYYFIFSRWMYNTLFGMTAFFSFSVIYTSFIYSKLLVSLTHQRVL
+>gnl|md5|c69c842b8d0d1ec387776e0cec437e99
+MNDEVEKLRRQAEIRKRKLLERSSDRLKLIYPNYEESENNVSLESITDVRYGESSKSKPI
+SECKSSISETNSRKISTNGTFSDFSQEEIGDQRKKQDSRSGLKLVSYIEYWNQKEFEKFR
+KVGSCILGIFLFMIHNFVPDSCLYQFFSAKIRINSISGIVSFIVYQFLVSQVYLYSYFSI
+FLNYSGSNDSENKKWYKSIFGCNNTQKVDYLVIMNNIIQFAIATKNFISEWFLLVTFYSF
+FSFIHIYFLAN
+>gnl|md5|b18acffa1f6efd4bacc92cb068060e81
+MNNGKLNTMKANYFVPEYNVRVVRPMIYCREKDLANFALKAQLPIITENCPACFSQPKER
+RHMKQLLSQEESHNPTIYSSIMNALYPLISINRTNTTVKEEEFISNDDALKTMSKLDEDI
+SGELLLTSCSR
+>gnl|md5|8de843efe3863bc627f2ee0583bab40d
+MSEELKFNGQDAPNEEIHEKKDEGQVGMTFSEREANMNQTAECEEYLEDEEYYEEDEDEL
+NASLDPELLLEEGRKLRKEKKFDEAIVKLYWAMTNRMNLLNITEESGIDPRLSEYYLIYA
+DVLLEKEENSTNFFSKRNEQDAMSSFSSSSSSSSSSSSSSSSSSSSSSDPTFIESTVMNM
+ANNSVAEATDEEVAWENFEAAKLAYIKLIYLKKRGDYDTYCQGIIPEYLTNLFSSNELND
+GKFEELLREVCSCDSEERSRIPDKDITDLSYVFIRLGDILQLAEKYYEASIEYKNSLFIL
+ETFKLPEDTTESSLICLAQSTLFSGKIKDSKYLFERALNLVRNHFEGKNGMTAPTDPQQI
+EAYKLTLEDLQLTLDDINRKLAVNQEDQKPATAIPKLEEIKKENSFNKAQLPENEPVKVI
+NTVDINGSTCENTVDNKKKRRIDLSKV
+>gnl|md5|9ad67f5d2899c5a467d816efe8245991
+MKNKVFRNVFTEFTVDEYEEFLLSNGRYDILAILLAYNSSYLRSLEILENMVNSSDKSSL
+EAYSSNNSNFINIYLIIFQVLLHLCNSEITPIHIQANLLKRYSRFILDKFDICPIDRLFT
+LKPVDKFPLTIDEILGLFNLLPTIASNRLTKSYLETIIATQGDNIELKHKINLIEIYIND
+ISANIETGINNLIGDGSSYINLFNDNFRPSKLAIMLEDLEDFDTEILVKHISFNSHFKYK
+VHDNIIIEYIIILFRSNRHDQALNYIINVLENIELAEIYTLAQIYHNKYAIQSDNMNLKV
+NAIEKSEFEISFQNYQQNNLIKDSKQVYRKLKFFTEFKLWKIFKDEYSNISSPIQQNNTG
+DLEMNSWLEILDISHNELSLISEEYNKVKDINEQSSYMKLINKLTSLNRDRNLQNIYSYG
+SMDSNGEIMVLVKILIESWRSCIQDKSIEKAEKLQNSTINILNKYSFHPDISIGNILQVI
+PEEWPLLKMINFLKNSLVSSIHNQTSKSISTNLSAISFLRLYEKWSNTRSNHVTITQDMI
+CHVCSLKLGNKPCALYPNGSCVHTHCLSNEYYSFNSY
+>gnl|md5|fe49caa006448f9a45ad294659f6987e
+MSGVNSLGRKVWDKEFYSKSKEERDRIRSLENAEHEKKLEKKEEISEEGAKKMREIYLDI
+SKNVGLSKSHTSGDDIRKNISGYWCEVCNLGFNDSHSWIRHLNSQSHNQKMGTSLYVEKK
+SLESVKRRLSELIHDYDHGLGIFSKHNKNESKNGVYRQGIKGGNKVKDKDRVSEEENMSE
+DETKNQMLQYNFPSSFS
+>gnl|md5|c9c922a3ed62e867b12a563db93de2d9
+MKSNNYQEFESLPNSLLFEKKSKSQVLRQNDLIANVVRDNLDNRDKLFNNEHDVNNFDDL
+PFVIPSKRIIIEWPLYLLKNLKALDFENNDFSKYELENIEICKIVSNNVREKGAQEWEEV
+QKCEKESIQEHEKELIQEHEEKLTQEYNKELIQEREEEPAQEYEKELIQEHEEKLTQEYN
+KVPVQEHEKELIQEREEEPAQEYNKEPVQEHEKELIQEREEKLTQEQKKELTQEYNKELF
+QEHELEQTQNQSQKQNQNQRQNQNQNQSQKQQLTIQKQQLNIQKPQLNVQKHQLEQTKFP
+TNLRLKYMQIYIMGGYAKKHFYNKEQNSYNIRVEIKKNQEIQAIKVINILEKDDMHFFHH
+GNNILSSFQNNNFEYHRKFISSQIQANKRMFRLNSHQYKLQIFKFLNLKIPIKCDDQIYL
+YLGNCQSKHEFNDVQQDHQIHRRNAILPITKQNLLKLTKDGGFQTLLELHDHFNTFQTNI
+TQQNSTHSFLSRNFNHPDTFIGYILLSIQKA
+>gnl|md5|5ea2f69f6910c6d601a8f61eda5fdc93
+MSLRHKLSEHNNGFRFLLDSSADDYFQKLKTKLEYLGHVGIEYRIQNKVPKSIRTILDYG
+IKPWFLFSVSSVNSIRLIHKIFPNYDKIPLIRLDRLPLKNKNKAMSFLSSVYNELKIIMN
+NNYRVIDQFYLVAEKMIKMESSSKFGEKSANEDVCSEFEESVNDFFENKKISNIELLKAL
+ITISSLNGEIQLSQLESIMTENSITDNVESSGSRNNFYNINEDWLGWGGSVSGHGILNSL
+PGIVFSALQLSEIFESRDLLNYFFLVALISPFVVVSDSTTSDINTISNYLKNNISPRPLI
+LGISGITGNVPVLSSCDISVSVSLSNDISDKDKRMNDDYDSRSEKDKNNDKVRLYRLGKI
+FKVWRLIKKNNKSIKISDASNNYLLNNFKEEDNSLTISSSRNLDNSTEKDSYFTSETLSE
+KVENSKLKKKSTISVHNYTIQDIFKNSDDNFVINPVTDVSVRKFHQIIPLLSRAGRLTYY
+RISLAIFNNIFKLFLLIIPNLLFQFYCEWSGTLLQLLDIVSLYIIFWTVLLPVFYGIYGI
+DVPKYLLDLPYLYNSSRSGYYSHWINYFGVFMESFVLGIISFYLSVIMCSNSPYKNGISP
+DISILSASLTMYCIMGTLFSFLIKIKSFSTSMLVAILFKLCSILLITLLFSIKKYDSDFT
+FRLYALYAQHSYIFFLSIPLFISYVVLYNLIFKIIIHHILPDPATCVKDWWLIHISQSSR
+VLKSPIILKMKNSFKKMKPACFVSSIFSLIKISFWYEWIMIKIHLQLGNDHQDEYMNPIL
+FESLKIPTLTNLIVSQYQKYFIWKLKKKKNMRQISNKGGDDQSNSINNLTSVEKKEINEC
+HHHMIELNLQPQIIVSSSSINIDNNQLPLRDLHSETMDNEINIQNQMRNVSAGSLSYKRL
+MKFFRPIEMNYFGDNRVSGQDWSFEDWKRRVIFHANIVWSPKQIYMQSVAPITKKWRAKG
+MRSLQFAQSLRKFSSRELEEYNIFLLDYALFLADNRVGLMGIQNNDSNYSRALRKSAFSN
+NIDMISNERSTAQNTRYGKNVEGFSNTVTSVSPITNNSSYVNSRTQEPSTVDLNINLTGS
+SSNYGRISTFSEDVKALLNPFKLTFKVNQLELEYQIERQIEAYEHRNALRAVLCVISGIF
+LTLGPFSVNVSNTGYSWVGILSIIFCLAIFMNFVLSYTYGKNKLSVKSQLPLLVMISVSS
+ILTSSHGFALAVIFPIISFIIFRLGFIPGVYVTIIGFLSVVIGQFIWNMPSSYWMRYLPI
+LLGINTFCGFLGYRSELLYRAQFLLETHTNDLRQRQRQILDTMLPSFIVERLLIDQKNNP
+RFSSESVEDRGTVSILFCDIYDFHSIVAVLQPKKLISLLDCFFLTLDCLIDSYNCTKIET
+VFETYLVASCLDPYDEASANFENFKSKKSNKSSYRQKPRKVTVNKSLKDIINLLRFALQI
+HKIGSSFFYEIPNTKNMDLSQIDTDNQMIGVSPLASLSCSSKDRKGNKNNSFIFTGQEMA
+LKQLKLKIGIHSGRVISGVVGTNKPQYALFGDTVNTASRMKSSCETGKIQVSSMTHDLVK
+DISILKWKEKRSFVKGKGMMDTFTLESVSGSAYPNYTHIRKQEIRGKGVGAIQIGNYYVK
+NTSDFDILALDDILLKYLAKSNDDKKVSQKDSNSVSYSKQLTKEQKRTSSLFKSSIQLPQ
+PPLLPPLSTSIRNEDERKESHFSQEFPPETFKPVQELGKGIDDYREEAEYDKEDNTEDTP
+LQDGLLKGIGRQDSFSLNENIGGDIELHLKSQDSSSIGFFKKKELNSTLVPSEHETVAKS
+NRKRMKTRFRKSTEHSFMSISRNSSDYHQKIERINSDQFAYSVRKDSNYQKSNIIDRRRK
+EKISDLMSLTLGFKDNEIEQKYLITYYSDLTTLKTIEESLVIVIVTLVLQTLIYTILPCG
+QNYEDGIPGFRILWTVRIIYISSVFLSWLVLFSTYTNYQIQSSTEISGSVIPGVSESGLI
+RGGGVGEEARQLSGDKWKGQLSLENTKHVGGPILFLNAVLAGGASMLMLTILWQFTMVDN
+SISLWCDEEILELLLLATVHHNAGLLFKYIVLFDLLIMFLILTIFSVGINVNLEGIVVYC
+VALLVNIIAAYSRERTGRAIFYGTLVAGNCEKKAEELLVAMLPRKVLVDFQEDKLKLAYI
+HKNVTFLFSDICGFTQWAMTVEAESVVYMLSSLYAQFDDSLSKFGLFKLFTIGDAYVAMS
+EPEIDPYEQKSSNVSSQKIKKKNKDNQANISFGTVGGGVGSLGMNFGLGINYLNSVNSYL
+SHNSSLRSSSPSILSNPISSKQSSSSSGSNNSYNTKDRQIYNLNISQMEGYTPAEGARRS
+IAMAHDMLEKIAFVREKLSLPELSMRIGLHYGGCIGGIVGSSRLRYEVWGHDVIIGNRME
+SCGTPGNITISGQLHEVLSKNFNHLFKFSYVGKVSVRKQQIDMYKTRIRKNVQLKINKVS
+NSENMSNLIRRNIIYNNEKHMEN
+>gnl|md5|254ebe9bad85d1fb73216b9ac6c0535b
+MDKKEIAIGNLLLLVQRETNTNWNRLYLHPEYLFDGYLLAPLTSPDKFNIIFLEIQTGFL
+FIPLIFSSSVATIIDFPNDSVIFFLLEKARRPKSDYLVILSSFFFHTC
+>gnl|md5|a0cf6f7139a4683370cc632e77f9147c
+MNMLLPDIKKGKWSEEENKMLILAVNRFGPGNWSLIKNFVIGRTDADCSKQWEKLDPASS
+FQYDIIRATQKHMLPLSYKWIGLSRSNHKLLNTIQSQNQGFNKNDFTQPKLSGSDFFVKP
+AQNILSIAQYVLSTYNNNFNSQNDASDYSISQLIQQLEQNRTNNQLVDPDIA
+>gnl|md5|0bb2e0c5672ed8aa97d75829787766fd
+MAFNIFVEYLYILVIFKVNYVISIRNNKSSSNKNPTSILNKLGEYSVDLKFIELQKKVDL
+CSSSLSKTNNELISARLRIAGKQSNSQEIDNNKSEEEIIDELTKKIQEINQECNSFVDLL
+LLKRIYRFSQISLDENINTEIQVKEKINNVIRNLVITENNAPFIRSLINKAKCNNFSINE
+HCKLLTSKLLYYMAITPKEIIENFENVQLVDTELAQNSTIQKINNENQV
+>gnl|md5|53387827f8525eb20172fb634b1f44c1
+MLSQLEDMSPEQMFEKFESRDESWLLQLTTNELELLLDKLKFLLDLQLNRHNELLSRLQI
+ELSESQETVNELKVSEEFTNNLLKYILMLLTQIIEKKLFKFEISLKQLKDSNRFTELELI
+QRELSFLQEIKDFIKNLFFVYYCKSPLVMNSSLCSFLTSVYSDTEAKFLSKIENLYEVYD
+KYENEWEDVNDESVKLMNKKKKKKSNLKKKKFKSKAKRINFKKTKLKSRKKVKYQRKFNI
+N
+>gnl|md5|7cf16f91c2ba1be1832605c2bf75d1a9
+MGFSFIYDMRFFLIKFFPILLFSTRINNGLFIRNYEETLIDFSLSQLSAGLESSDGSLRS
+MSSFLSLESFGSCFSEFQSQSSFYTAPDYDSNNSIDRAPCVFECLYSKREVLTLLRRRNY
+KELKSIRTIVLEEVMEEIIQKIKSMILNYEEQVSRKESLLAIYNLCKRLNKKAIKKTEKE
+IKLLKFELKCYLTHFDLYLYILFKHLFKRKIKEFKSTTKDLQSSRHTNRVNSLQREIAFN
+NELLSLLGAAFLYYLCNNEILENLHLCTFMSKQHLKITKYNEKIISLHKKAIDSIGVSTV
+PDSGSVSGSESESKLETIPEESSDSYEPF
+>gnl|md5|c2337242fa25887e02bd44c1c7c75a25
+MKRSKFNLLYIILKFFVLFIFFVYLKTRHDLVKYDHTLAQNNFKRSHSSKLKQFYQILSI
+SFINNGPNNVNGEGAKDISDNKSGTCSTSGNPSPKNEFDSESGKQSKAHSMKMCRSSSCP
+SLGHISSSRSNSSSSHDSNSEMKSRSKSESCLKSKTSSSSKTRSRSKTRSRSKARSRSES
+RSRSGSRSRSIRVMKKRSKSDSSINPKPSISKPAPLNLEDRIGSSGPLSSKEELGAYCIE
+LSFEEIFKILQSKDTSQLNDVSSFSLSTALDELIFMNSSLANKLIDLEKTIEHEKSKLNP
+EDKNYERRLSTLKDFTLTESSGIVKQSEQLFKLVQLLFHILYSRKIQAFESTTDAILNQN
+SDPKVITNRRIVFSSELISNLNVLYNMLHCNQKSLSSLLFCRFLQDFIENNKRVNAALTK
+YMMSLEESNGGVEGFSKVNKGRKSRTRMKKKRNRTKISLKDPERENQEKKIRKLNSKFRK
+LFTSSNIGLESIE
+>gnl|md5|db265f491566a092ff00c741bc4e2aa3
+MSSLLNRMIKEYRAASYSLFKLNRDNIQAIQRDLSFYQGLVSYLTDMSGILSYNYNYMKE
+TAFCAFITISIAEYNSRYSSLIETLPGTKEYQMFEDIDHEEDIKEKKSDKSVGKKGKHGT
+KKK
+>gnl|md5|bed2341f82fc5c2fa91168d463fa6a28
+MDEDLKSTTPSLIRTLSKNLNNQLLGRTNSETSINSNSNNGNELESSSNISRNSSFNLKN
+LSPECIEKHHEIIKFSYRHKKSLNILLQSFPQLILPPNGSLVPLLRLAPMVVNFENKRCY
+FRYRLKQLRKESGSYRSGDNHQLRLVVRRNRVFMDSFQQISTKSPDQLKQKLHITFHNEE
+GLDAGGVTREWYNILAREMFNPDYALFRREGSKSEFNHPNPLSYINADHLHFFKFIGRII
+GKCIYDGQHLDAWFTRSFYKNMLGQPITPSDAESIDPELYKNLNVMLEHPIEDLGLELNF
+TTTIDEFGRSKQVELKPNGANIPVNDENKYEYVCLLCEYKTVKLIEKQLSFFLSGFHELI
+PARLIAIFDDKELELLISGSPTIDLDDLMENTDYHNYDRKSQQIIWFWECLKEFDQNRLA
+TFVQFVTGTSRVPIGGFKNLMGMRGPQRFSIHKSFGENRLPSAHTCFNQLDLPDYSSKEQ
+LKAKLLQAITEGKEGFALV
+>gnl|md5|18383690e49bd031fe9ca7f62bb08981
+MHEFPAFACNEYKKHEMGQICCYIAEIIDVFYRVCIDDKQNNTFYIFLIDLSYKTGIFEK
+IMSLFHFSMSTYWMVLGKIIGKHNTENVNKMLPPLNPSSRLKYSSEFLGQLSEYILPKLS
+SVHNLNGLLYLATKSMHNNILLLEHFSSWKRYLNSTLTTHLHKSKFHLNNCRPIISNTNS
+AELNIFDSSLDSFFRMEFNSVELTESILLMIITNIQLWWKEVLTNYYLDMAHNNWLIFYP
+IRCLSSTFKIMLHIFDIQSDSFNSFVAKNFDQSNDKTVKQNSISDADARSSSSTSNDNLQ
+LSSNLNIDSSVQNHDASLTSQDENTVNSILERLNMMGFDSRVSEHAIFCFGNNIEVIVEY
+LTGVTERNENKTMISEEAGNYMYSFRRIGKVLSEQFELGKLITYKTLSKEDKKSEILRIY
+STLPSELYYLSKNVYYSSPIVCDIMLKFSPLLKKINMLEKVLFHIYTSMKMLLERNQSVF
+SAESSNHRYQFIKEELSFLQDERLNNDKFPIIFNSFYTSLNNSTPLIDSNSNFNKLNYQE
+IYSNLDTYSKKCAPTKKIHLSLIPDLSLLSILLYKKTDLKSFWISIDSNYIKLTSTQNKN
+SSKSKNKSNISNSNTEQVPEQSFHPINSLLSFVNIFTQGHYIFDSKHDGFTFKNMEKYIR
+DNLGEGNGQSTGQNNQNGNNINSNSNSNNMKSSQRPSSLVWIPANKETESKEYNDKGIKL
+ASRCPIWFEYFCLILWRLLPIFEQSIPVSESSNTPFLVSQKNQKDIIFTMLDILTHFPGI
+NGSTSMAVLGVITILTRKFNNSLLLLSYTPFYMIEMHKNKDKTQNIACMCMGNTLGGGLG
+VLYRLPKTAYFDGILQVLSLITIQVLEDFTILTQLIENKLDELFSKQLSTQIQSGEIYGE
+NLQVVNNTENNTENQENENPNSCKYFSFYPRSFTLNYKKDLKLLEKKEIEYPFIVLSLNS
+VIGELFPYIQRCPEIFYQVLNYFCVLHSIKTGNESSSNSKTNSEDHCSDSNYKAKSEPAE
+NDDVLMNDENKIKDDSAFTRIKYTTFNDLMENQEIYSKYNIPVNENLLLQWKPLNYRNSE
+ATQEEQNKYLELKEKLKYVQGDSALRPSSTCMFILMSIFDHMVLFGEILNKSKFGKKRGI
+NSCLRGRKDDEIFSLSLDSLTYIMIRIALTYPVNINRISKVPILSICNENNARLWQEKKR
+EFYSYRYRNSSNLKLGVSCFCLNLQKSLSTIDSENKKELKAALEQEFSGISTVIPNIHSL
+TNNIIKFKPYSFEFLLNQLFVTQSLKINFLPFIFRNIASYIVMNSINCMTSMPTCTCKKC
+KQAGSPSSGTEENSPLKMAGWQLNLDWQTYNLKCMPNLSTIKKSNIKDVHFMEMDHFIYF
+LHILIGWNKFVLKKFMVYTVNSLRNLLASLDKFKGNSNRHNWRSEYVNSYFLLNILQYLI
+VLLQVYPSISDPGLLRKASIYNILSKLYVKLPYSDLSNIILFCMKNLIYSRSVMMPNSEC
+LAAIKEGSLDSKVKKVRNSIGVGNGNDQLEDDQLEVDLDQFGFQFNSSDEDFDDDLDDSL
+EDDFSEEFDLTSLDGLDGEDIDDNDEDDDDNDVEDMDDDVEDDVEDDDENDDLFLDETMI
+NDGVIDIEGEDDDLSNDDIVGDDDLTSDVDDVDDDDDDDDDDDDDDDDDDDDDDDDDDEG
+DDEDGMNFDESDMDSGMSSEDSDVDELRRTPRIRDEYEFNYIYQMNNQTNINGLEDVPMN
+TSSEEVEEDGGENINEILMRDAERNGQNRIILNNLRSSAFRRNTSTGGGSSSSRRRSGRG
+YNRSIRDDLDNDLNFDDDEDNDLDIDDLDDEIFGEEYNSEEDNEDINILQGINNIVTNTN
+ITPTLLISDGVNNTVVQGTENSNVTGSANTNSNSDNNINNNNSSSIEQSSELEQALPEQR
+NEREATEESEARIENSNNGAGYSTLRTPPHPLRREELISNTTIRNSNQLNEVNENILGNE
+VSPAPLRRRIASQGNNYLDDMMMVLLREDDDDFEIDNLQFLEDLSSLGGVAGSAGLSLGG
+EGGRDDLQVQFLGTQGVGTGLLNNLIPNTNNTVYNESLNSSFYLDSTEAHWPPMPLNQRN
+IFINSRNIPLSFLILNSLTFVPNTSNLNPPSNNDLILQWMSYGGYLTNPVLSHYNIGNVR
+NSDSSGNSSGGSNNFNSFSINNSTNNNSQPAFGWHFHNDISLPTEHPFLTRNIIIDNNMG
+INSSGNSNNHGSGSGNNNSNSHTNNLSWYSNGPLYDSQRSLIGEIHSSSLRNNSELSILM
+DAIRNADNLTNNDDVITSMQNNSNNGNGITNTCTEGGATSTNANLGGSSSLRGSNLNVST
+LIRNIGDINRNNNLDRLLTDENNSTVSLIPLVLVSQATSFLRDAVSSKIPIETNNINLFT
+TNIEQDEESDNHTFDLQERGDVICDNQLDDNTENMDSIQGGEESAQHQDQEQSDDDNEDD
+EEDDDDDDNDDDGVDDEDDEEVDEESDENMEDEGLLDSQVTSGSLNQINQNVIEDLQGTQ
+VSFNQEIQEVQNESADHITNFEVDDNQTNQANTSINQNIEGLENMNYQDVPVCALLRVLE
+ERIGLSRNRILEIVGVDTGVFYELPEDIQSDVLVLQLTDGDTTRRLLDNMTLSDSGSRTR
+ESDFSSSLTIPSSIMDMLPSSLRDIIRLRGSANGGNSIEDSGQTLNGDSTIAGVQGGADG
+NASANNANESNQGEDLENIQFISSLDPVLRQEVLLTATEEFLRTLPAEIADEARALQQRM
+FPSYSSAATRERGNHSNTGNSSHLGGAGNTSGSTGGNNSRRNNRIPSLTLDGDDQYISTS
+EGANNSSGGGSSNNQNSSSAQLLSLSNNLYDLLPLISNSRNGGITTIRFNVNSSGNGLGI
+RSLLSAASALSETRRGANSTPSGNSSGNPSGDHDIIGADENTTDLLGSRIESSATGMNNS
+TGGGSNANVINLSNTSGIASGGGSVNNTNNRRGAYQIRSIIGNQHGNISFDGGLNISASI
+PFLSSLGGNVGARSSGAVGSTGSSYDILYELLNEISQTSTPTSNWNITNEADGPALENSM
+YPLMNLTSTSSSSSAFNRRHNNQTSLIQHLQGNTISGSAGRSASSSSFSIQNILPMLRTE
+YNQMLNNGVGGSSSGLQNISSIITFGTGGSSSVLNTVSGSSSNINISSSTNSVRNSTYNN
+SSYVRIIPMLSNRNIHSLPGRTSSNSLNTTLQITGRSVSTRRAGNIISSTSNSNRRRRRG
+RSGTGGNDGEGDGGSGNEENFTDNHVINSENNDINQRENDPNQELSSSSADPDLENNDTP
+TLEGSLGNIISFRDPLYGFPDKQFILLYLQEVLINIKNNNIMDQNLLQLSIIPEVLYSST
+FTRQNISKPLLYSYLFNMLGSFGPNQWMALDTLFAIISIGRTHLEVTPMRLLTRYLGNNS
+NSINGSNQQIQTFKSVNNYSINYKESSINGYFSNLIPYELLFTSLMSHCDVNPINMMYYS
+LLQILEVIGDFITHFPVIVMYLLDEWDPILRLDKFIKKNNLGINSTDYNVNHRRSISSGI
+MENTVFMDIKDEGTQKDGIKKEDDICDDALVFDDNNKIKPKNVSLLSPVQSNKSKSEEKR
+RIGSSIPLSSSVELSRKRKRRFTKEGFELNSNDSSNNNNIEGGLTTLMDISTPNCTIKIQ
+DTVELTPYNPRSSINSNVFPENEDSAFEENLVLDANENLSEEDENMTILYGNSANCILDT
+CNDVTSGRGGSNTGSIVRREGGISGNDDFAQTQSQNHMQTQTLSQSKIFDQNMNHIHSKI
+QHHNHSQNKHQPIGCNHSMNGTVLNRIGNKRSAILQLNRLKRKLFNTKFPTEMIGHSNFT
+PLLLLFEILNSPIVQNSPQHIQKLLVIKKKIFSLNFDEIPKVQMELFAISNDLIHSESLK
+PNIKEDLKVLNEYNEKDQA
+>gnl|md5|1c2dd803336e43de89b76c221f40a078
+MVSTSNEHELITKEFLETQKKFEQINERRRILVAQESENQMVSKELELLESDAVIYKLVG
+SVMVKQSLDDAKSTVSKRLEYITGEIESVNKSFESLQSKLVEKSNQVSYNYHLFITFF
+>gnl|md5|79d653656fe03849ea1421e3f0490047
+MKEVAELHLSALIIITLLLSFGSALFSGLTLGMMTQDLLHLKITSSSKNNKNAAFYAKRL
+LPLRTNGNFLLVTLLFGNVTVNTGLSILISELTSGWLAFTVSTILIMIFGEIIPQAICSR
+YGLYIGGFFSPFIRLIQIILFPLLKPISVILDKAVGKTNEKIYTREELNTLLEHHSKKDI
+ISVYELGLIKRVIFSNFTLSDIMIQIDEFHIYYIDSQLETNQIEDFIKKGISKLYIIDNN
+STYSELFNDDSQQCLTYTKKNDIIYLDIPNTNDHQSNYIEYSNSPITSETYDSDCSICND
+CPHSKSGIILGYIDLDQLSKQNKIFQNKNNSNRISTIVNTKSFIRLTNIVISNKMMDLIK
+NKDTLSILTSISNIKDKILCIQGSTSISTLFNVLCQYNLSQNDIIIIYSTIGNGYKMRYD
+GVITLTTLYEYMFSSEKYVVNELKEDICSNLLLKHQHPNISSYF
+>gnl|md5|0b7774b83e27c2f96a11249c837af179
+MRTVYTVNTRNKFAALSLSDDEDDQQIITKQEPVKSTAGNKENPSSLIYPKNEVTPNAPA
+SALDTTSKMSRGARKGNTVHRGGRGGYTSSHGRVFDRRDASGKAHRVSKQNDSAGIEDEV
+IDKEKKYNNNNSSDVASNNQLDENVGDSEESQNKVDETKEKESQMISYEEYMKKMAPKRL
+EVPKTEIVKGNTTAKDFEKEGLQRYVRDDGSNTITNKNNKNKANKNNTKSDKGVFNYFEL
+VEKYTTRNSYNRRGNDDRRNRGNQRPNNSLQARREAPDVSDTRAFPVLGQ
+>gnl|md5|9dd7769d3a9a4659df4d4ed46986fb7c
+MESSSGGGSSVGEVVTPEVQSKITSKLQEIFGDDDVSVLTDYICHMVNHNQPKEHIINEL
+KEFLSDEASQFGTWVFQLVESSKNDYSTNNNIPNINHDNGLGKNNSSPNDTHKSSTQSNQ
+NKDSLDFAISNAIKNKSGSGRSKLFQPASSHKNNHSLINHESSSGPMVGNNRLPRVNYRN
+APYTRSNNFNQSGAPYNSSNQAANSSTGPSSTHGKIKIRCKNWPNCDKGDHCFYIHPSEA
+CKSWPLCPYGPGCFFIHPTVPCRYGLACYNSLCNYSHPNGWDPNHVEAPVFKYGGYKNSS
+LIINNNKQSQTIGNANSNSAESNNDNATNPISMNLNQENTDMPSYDSNCNGKTGHFNLES
+EKNNSFGHN
+>gnl|md5|6702d6358d77380e22e366c6725fc95d
+MKEDSNHGLLLDVPFTSPICTINSIDNRILVGTWDGYFYQICLNKKDDVVTVQIEPSYPI
+RYISALKDSNCEVDPHTGAQKSYELILGGTYRTKVRMKNRINSPITPLEELEISSDSHYQ
+IIETRSSLEPFDSHTKGIEFGNKYHKAPLFLFSSTINSYFGFNSEKGEIEILIGNFNLPD
+REFVILDYDFLNNHLLIVERSPERLDYYALCSLQILELPNSQNYLQEEVDSSNITNLAEI
+PPKYILNFPIKNPLFITSNIKSDLTLSSSAEYNNFKDSAHVYKYLYSTMFSISDFKKRPL
+NIFKSMYNLCDAKFWGFNSFIFLVSNHTIIAIDVFFSKDNEFVTNTNTKCKFCIKSPDRN
+ITSISTTNYNYLVALTEKNRIFLSNRNGEIVYSISNITPNKSNFRWVWPAHVFVTHTGTI
+IFSTTKGLYYIHCDLLDKRKTQFTKNQSFIIDLPNN
+>gnl|md5|269e8bd07f17c8061080d9f4e0cebb3c
+MTLFTRFVEPGRLCRIQYGPDTGKMCFIIDVINMNRILIDGPSTNVARQSIPLKRLALTD
+FKAKIPRGARTGTVKKILEKDNTIESFNKTTYGQKW
+>gnl|md5|dbcadc6a9b00047fb334d2902ab2fe1f
+MGNLIERENRGVQYPVREQITRRLSNTEYIFSEALNRNDPRISLNNEKQEKKLISVSKSK
+AIQNQCHINGLSIRYIPSLKRMRFEYDCIQDSILNIYNSNSLEENLINTEKPIFSHIVPK
+SLNKEFQCDLKSDLKQNFVLEIKPKSSSTNNTETIQLTFCEQIPKKENNTLESQIKIKRQ
+CVLYNGKAFEIQNIFGLSNKSSKASKNDEDSEKCVICLTNNRETILLPCRHACLCKICSN
+TLFKNTRDCPICRNSVLGVVNIEDSK
+>gnl|md5|cfa7e4f473a1a859273a0fb56ccf24ed
+MKNIMRSRPSSSSSLGVNGIGGLGGGSGSNLGGNGIGNSYMGSVSKRTELTEQQKMEIKE
+AFELFDGDSIGYIDIKEVKVAMRALGFDPKKEELKKILSNVELNNGMVSYNDFYDLVETK
+ILQRDPKEEIIKAFKLFDDDETGKITFKNLKRVAKELGENISDEEIQEMIDEADRDGDGE
+INQEEFIRIMRKTNLF
+>gnl|md5|7e01eea45578ed88f4dfd48867accb9a
+MELNSDKNFSITGIRKKTRKAVRPEIGESNIGIGCTSISRPSLMGMEKQRQEESNLSSLF
+LKRTSVLKTEKKSEPRDENKVEALRQNLGSMGLENRNREINDGKSSILKKSFKEDMIEKT
+VVVATEDTDAQIELNSTTNCPFLVGSGSEASYERSSEVKTVLRKSRYDYEQIYDEDSVSL
+KDLVSNLNGESMGVFGTSHDIEELSKWFSKMVGKFETFGLNIQSKLERLEQDLEENTKDL
+KGYSGDSEQVGINNTTNREEDENNLRNEPMSISERYSELIRLKNKLLEELSNVENEIMLE
+EMRIKKEESERRIRIEEYKSTRQVYKDELSSLTVIICWIEECLQNFVYPIQRKQSEYKME
+ISREGDLLKLIQEEISKIEKQEKVVLEKLREIQEIKRYKGEEKELLEEQIRLSQASKSDK
+IKNANFKEASMISQTIQVLQQEVLELEDSYSSVLHQEKEFMEKIERIRKSRQDEINRMDA
+CKHEILLNRKQRRQQLKLKVEQLKECKFSFDSEIFSENTSFVLNSLSEKFYSQINSVLSF
+EIDLINKHDLEDGKERDNVQIQPQQKQAESTEHSSQLENKQPDAITGSESELKSEHVLEE
+KSPPSLNYEDVTVEYKHSEIQSEKEISSFLDNNYNTNDNNSSFDDRSGFDDKDCESQALS
+CELVCPNNAHIAGKADSDICHETEIVSSSSSKKESGGENTNLDDPTQNSLSF
+>gnl|md5|e9b644c7998c5fc0cb11f79cb5b9c7c4
+MSDSVNARESNVYMAKLAEQAERYDEMAKYMKDVVEARQESEELTVEERNLLSVAYKNAV
+GSRRSSWRIISSVEQKEHSRNAEDASKMCGKYRSKVEAELTDICNDILTMLDKHLIPTAT
+SPDSKVFYFKMKGDYHRYISEFSTGDSKQSSAEDALRAYKDATVVAKDLEPTHPIRLGLA
+LNFSVFHYEILNEPRAAIDMAKEAFEMAIEQLDKLSEDCYKDSTLIMQLLRDNLTLWTAD
+LGASGEAEGAPEAS
+>gnl|md5|49b4f29eb26fb31503f3e039daddbc21
+MPPAGKADPSEVKYLYIRQLGGEVGATSVLAPKLGPLGMSPKKVGDDIAKGTAAWKGMKV
+CVKLTVQNRQAKIDVVPTATCLLIKELKEPIRDRKKVKNIKHSGNLSMNQVISVARAMKF
+KSRAKAFSGTVKEILGTCNAIGCTVDGQKPVDLQKMIDAGEIEVPTA
+>gnl|md5|a460ccdf3e4914e38ff742315c269ac3
+MTEISESQTELLQAFCEITTCDITTGRTILESTNWDLENAISLYYEQQNANVYEGNNFNI
+TEQVNANNITVNQYGNLNEQQETNVDQANEGKHLNTLKLKKCFKVFLSVCGTSLSAIFGF
+FKTLFCVPNLNNRAQDNVSIRNFNRSVISQIEQVQIEEARRIREEQDLEYMRSLNLDSMK
+QEKALEKKRTKDLIRERREKLKAEFQQDRDIEQESLSRVCVKNSAGKKFQRNFHKDDSVY
+EIFKWIDSLALDENNLISDKFSLRLPHSKSVEIDDSYADEEITISEIGFYPNTLLLINNF
+DEDSDD
+>gnl|md5|a74e2b2989778e834878435fb19e894c
+MVGDGFDELSPGSSQTSNEDVFNMDEEMEYSGAVKDYSMNTTSSRVVEKEDSGILSNEMV
+DLVLDYISYKAGEGSNVTGIEKVDSTIQNCRNSGFKKSIILSYLVSSGYLDLNEGVENGE
+PIEDSLSYIQSMLHQKSKYIPENIEEITLAVSSATKLFILELMAKINKQLNDSGSNKRVI
+ATKHVYDAYITQEKLIPDL
+>gnl|md5|2125f1b780b812bcf0d2b1844d78e5ce
+MDLLVTGQDEKIKPFDMLIPFVNESGQIKFVTRRRLRQLVKSGLSKGFSEGVPPFTQEAM
+VEGAAEPKENNEEKNNEGKTSEEKNDEKKPEEEKSSESSAAEKGKEAANSAKSLLQEAET
+VLTGGSLFEPSEKKEDDNKKEEKDDEKPEEGESSSEKKDSSESEETSESSGSETSKSSKS
+DDVDSAMGAQDSASVHASEEEEEEE
+>gnl|md5|15bbe5f7c3a9f96e6d97bba1bdf75341
+MMFDSNDGGRMVGSMENSQMHMDANATVYGEMDGLSYRVERPKYMNCCVCGVATEINPSR
+MCINCIRSEVDITEGISRQAIISFCRQCERFQKPPWVSCQLESRELLALCLKKIKGLNTV
+RLVDASFIWTEPHSRRLKVKCTIQKEVMNGAIIQQSIVVEFFMQAQQCDDCRRSFTPHTW
+NTVVQVRQRVEHKRTFLYLEQLILKHGAHEKVSNIVEKPDGLDFQFQQKSHAQKLVDFIT
+HYFASKVKNSRQLISQDLSSNTHNNKFTFSVELCPICKDDVVFIPKNLCISLLGGISSLL
+LCKKITNRISLIDPFTGREADLTKEKYWQYSGSNGSSFIPLLSRSSLVDFYVLNVERINT
+TGKHSAIGSDHNQGRNNKVCIAEVEVCRESDLGIPDSSVIVTTHLGAYLNSGDWVSGYDF
+RTLNNFGVVEDISEFVQWRERNHDVILVKKVFRKNQNNLDSSIQRPWVLQRLPKEQLAFD
+NANSKSSFNQDLEQFKAELEEDSEMRRDVNLYWDPRIQESSREIYQKARRPRHLVKKDKL
+SKNQSQGQFESDDMIMDDEGYQHDHDDEFSQQVDISELLDGLSINDLQ
+>gnl|md5|c13e50efe35ebc62250a3d61a0bda4be
+MLDDDTVGTYIKEDGVIIHLVPYARNQRNEGSAQPASESRSRASGTGGNAANIHNLFATT
+SGIPGLNTSIGGFPGAMMFGAIRLDGETGLPLEAEDLMQRVLRTFGDAVNGNGIDQNLMN
+ISSGTGDNRNLGSVTFDSFAVGQPTTIPGFSGLISSTERNNQESLSSNTDANRTTTSTST
+GAIANNSANSSATVTGTEGGRSSNINGANMNHSGSNTDSRLNNNSAQAQGNFRGGNGEGI
+RGDPMNSNPIGRIGTIVSRIFQAFNQPVEGIQEGATRSEGRVSQAGTGTGTGLETGARAD
+VGSGANQTGTSDRTSGNTTSQDIRGRVISSPASGLSWTQIASSGALNTGRTGVLPIGRPG
+LAVATIPISNFSIPITIRATSSTGIPSINLSQSLNTAASVAAPAQGESASVRAPTDTGST
+PSSNTNVSEAYRTSSNNFFRNISNVLEESANQLRTVAAGIREMSGLEGPDRTEQNREGSS
+SSSSLPPIPSSVSSRSISGENLALSGQTSDYIQHHSHRLYISNEVVHRFLPWDSLNELMD
+ILERDCGWRRPRITIPPPVDSIDASPLAIFISVYLQAMSIVQSNLMQIQAWQERFARLDI
+PRLCYTVHLLALISHISAHIGSLLAWLFQNMAQHVEQDGLIEGLQWNRSSNEIENPIDVV
+ERRQDTSEETKGMDVDEETPFELVGEDILNNANLKQDNQDIKDNTGNVAKMFERNSSSFG
+FNSVNTNSSSNMGYDQNNEEIINKLPDEIKEKWERWTGNPQNFSRNVFASFSTRPFSDTY
+QQGDVFSSSSSFGFSQPSNENGNTSGSRINSHPSSQELLRMIIHQTEANLNISSSSNSRN
+YTNIQAEYRSMLIRDLINIARNDSDFLNNRSRFPYLQRIISLLYE
+>gnl|md5|ac907324283e5b7a64d71d3ec6d8963a
+MADYGTTEYWEERYKKDSNPYDWYQRWENMREIIKEYLKFDDKILVVGNGTSRLPEEIYD
+DGYQSIEAMDISTVAVEIMHERFASRNIPCQVGNVLDMYQYSDDGYDVVIDKGTFDSILC
+GENSHINIDTMMRELVRVLNYDKGRYICISYGQPNYRLNYLKSMKEWEVTTIPIKKPAND
+QIYKLKNYNDEDSNSQENVNITTSTRPDLYHYIYICTVVNKNVPEIGNSLNLNDDENGDI
+KTDNDVELNADNIQDPNNFEQDLGETQEDERNEFQVPDENKVLENSI
+>gnl|md5|2bf1b850da068e46401f918a133adfc8
+MLINNENVRAEEENGRRPTRNETIVYKIVNYMSSLIGGINDNVGRNNPCIGILSPMSPVM
+ITDHVKTVGNTMVLPSPEPIIQMIPNQNLRNNMFFNVYSNDKKYVHKFGPKVTPYTNLNN
+GLLAINEKGDQIVTGSISLMSSPTDMCLNSSRNKLINPSSYFSRLRNPISECGGLVKSPI
+NSCFSGQINKANESSITEILVSPELAQTLQQIISIISHQIEIDDSENSININNIKGSVKI
+NRFQRINKKSTIGGLNYALMSYSASIIQKHFRNFDNNRMVRYINPVTRSKFSKNQIMNAI
+HIIQRYWRIYIYRNQIMRELLIKNVMTARNAASCKIASIWKGYKTRKFMDSIIKDVYIKW
+IWNDSDSANNNCSSEINNTQNYEYSKYEVKLRGSFTCKPWQEHLKLNWDNQENCFLINIC
+LTKGAHYLQFIINDEIKACGSMEIVVLPIIGVSNKINIVGEAYKSSRKFILLSYQLTHFL
+LFFIFIFQ
+>gnl|md5|43bac37ae8c4204c747ab179905fa5bd
+MFSRLYNRNVDSNNQNSGKSNRIRITLKDRINSREAAKFPITESRSFINHGERDDYSVVR
+RSNTIGRIIQNGSQQIFYPINPNNNFTRQQMRGCYNSNIVQNSHSNFQQNGSIDSALSSR
+RSNEFNTIQSLRSTSDLASKISSNVVLAEDQEPRIARNKVKSITSSIPLNLIEKDSAERL
+KSSINSQINEIEDSENERLNSNRNRYGLSLDLYSLTEDSARKIKPELSVELECSINETNE
+NNEVLVRSISLQKEKLPNLEIFPLETVNSSNSKSNNRENCELRRFIDNNEITGLISKLNK
+SAFYFVRFNLLLHLAAIVIQCYFRRYLCKKYLYFRKYGPIKLLNTSAMQIQACWRSFLTR
+FGASLCEGTPSNNGSHKCINEYNWSTLHEKNFTEIVKKRNQNAKCIQNFWRNIYLKNINI
+EREILTNSIFSARALAKETIEKFLLGYLVRKNADSRYKLVPIKWSWSVQEISEIFILQKI
+RNRWSEPKKMWFNQEENVYRYNLFLSNGIHQVVFKVYYKNKECKGDQDYTILCNSSLETT
+PSDEFQFVNNISVYNSNYTVSAFKYMRDRISYINFSTINYLDNLNPDIMQNIEQDLGYIA
+LSPSYKQRLDIEYSETEYENSPYKEFDRIKNDVINTPSTNLDYSPGTQHFIH
+>gnl|md5|4acf912f9807e144d79df88b0c9aad38
+MENSTINHPFKKKLNRVLELKLGENEELINGLISLDTVDDISEGIPKHLVTELLNTKGQN
+KCRSMQLLIYRYHLMVAESCLDSLKPFIDDLRAMNNEIRSFEKEFNENVTTQLTNWNKFT
+FPLLEEFSMIQDQIQLVENKKNMCNTMLSHLSTNFVGDIKNLKSSMDESRGNLLLSLVAI
+YNKCMASEINSKKLIEILSSDSLDSQNTSESVLSKLKSDREYSSMIPQILINLKALILDL
+ELKRNQLATEITSFLVDLVISKSPDEFNDQFEESQNDEDETEGIEKGTEEKVCIFGSQSF
+QESVEILELHHKEQCYSLLTCVVETRSKYLEYRFNHIIGHGISIGDNNYSSNLLDYLESI
+FEWIRVCGVSIESEFLIKAFGYQICEDCEFEEKHLDFNQSDTSEPESLDSMAKNILNNIT
+HTLCIPFSGAIRDILRQFHPPQTSRPDSTHHFGNLTSLKIGITIGIKIAHLINNYVEALI
+PMFKILPKRFSSKPKQARLAFPLLIQRFKDLREEAIAQYYVYAGIVKENISSRISEIITT
+DFSISILVMEWSSLLKDILSTIQNGVLAISNDNIPKIEDINSTLTSMLDTFINPMFNAIC
+SVATSDKTPLASIIRINNVNYCLSVLTTFQKMKVLLEKQIEIANQIINDEVSKLTDFLKE
+EFCDKYRFGELLKELEAKKEGLTTPQVFEESANSNTDPKPKPNSNYNSSESDPGQDPLLI
+LSQVIIDQFFESILRFGAIPFANADRIQDKQIRNNILKNLFAHISRQYELIFDQITLIWP
+QKSSFLRHDPQQIKLIFSSLTV
+>gnl|md5|b04cb7e784f507b877616fb4b963550d
+MSNYKQTELKRNKGDSRDVSLLSASSLHEGQSNMQMWRRRWEPCLPHILRSPLSIKEVSA
+FEGMGEMERSDVSTYFPLTSGNSLVKFEAISDGSSSWKKFPARRIGVVLSGGQASGGHNV
+IAGLMSYIKLCNQSSQLFGFLGGPEGVYSERYRELTEDDINGILNQGGFNIICSGRHKIE
+TEEQMRASLEICEKLKLHGLVVIGGDDSNTNAAVLAEYFKRNSSSTVVVGCPKTIDGDLK
+NEVIETSFGYDTAVKTYSEQIGSIMDAIKTEGYGYYFVRLMGRSASHITLECGLQTRANM
+ILIGEEIKEENRSLMSIVDEIVEMILKRDSLGKKHGIVLLPEGLIEFIPEFETLIKELNL
+ILLKTNDRKQIVDSLSQEMKTLFLELPSDVQNQLLLERDPHGNVQVAKIATEELLVHMAK
+EKLEKVKKDYILDNVKTHYFGYEGRCALPSNFDASYCFALGHTAAALIDNQRSGYMAVVR
+KLSLTPEQWEPAGCPLTYMMNIELRKGKSVPVIKKYLVDLKGQSYLAYCQVRSEWKLNDY
+YKNPGPIQFDGPNSGITNYMISPPRVEDLLRMEDRYENKMNHKLLGSEGSQNRTKDDIKI
+PKILLSTASKFNDDLIISSSCRDLDAYIITKCLPHQTGRHNSKVLQLREEEYSSEFTEIR
+ESSHSKSSVGNSLACESLGLILSCLSTPGTQNVICGLVNGLPSLKQLIVFKSLSDFLEGK
+ALKVDLTSEGSLTFFENSLNSGGCIFPNGVEIKMNASEKKNSNTTLKANDNQEFTNSSCV
+LSCKGLVSNDFLSQLLSFFNMRAIAIVGNNEAATFGASLSEQLICMSLNGMKSEIPVVFV
+PVCLENSISHQMIETCIGFDSVTKSISTLVGNLLTDSASATKYWYFMKMIGDKTSNVALE
+VGIQTHPNLVVIPERYADRKLSVYGSEMAGVTLDDIITEICDIICLRSNQGNNFGGLLVS
+EGLFDQVYPTREYRKIFSRFSTQNLCNASNSGGCEILGSESLSRYEKKVVEDFKLIFSDI
+DARLIENLINSRKICDVRTEIILSALVQKELKFRRSKNKIKNGMNPVCFSFTDQVRACIP
+SDFDSTLGLMYGMLASKIINSNLVGGYVTGIKGVLSQADSWNMYAIPISSLMTLNIEGDK
+IKDSRNNSNLSFESKKLLTESTLGNAGHQLEFICKLNSVNSRNNPSFKLLMNHIEKWEVD
+NTYANPGPIQYFNLFKNLFNRTLFESEYVYTRNLKEMDQILLEIKTLCQLGVEKDILNST
+VQHLKAIQNSISIMSSCNHRKSKPEQIECIQKTNSIANYISNLKCKSHNNETNLEMIVNN
+IINQETCN
+>gnl|md5|510baa4c1e6c18d0bcd1d8a353778ce3
+MNTSSNEVKTDQGEKNVSISEPVRQTICISDVNQLSEKERIELRRQKFGACGPSTEAEKR
+LARSKRLGAASEDDKRKLRQERFGMISEADKIKNRRERFGTMSRVNDPDHEKKIQVRKLR
+FGLK
+>gnl|md5|30f9f8eaa326abd92e6c0213589493c3
+MRRNKEVNNKHYCQVCKIWIENHPNNIRSHQEGGRHNYNLRKLLKSENYRELQKKKDEEE
+VRKEFMKLQGVEQTSNREKKRIKLIDKEVRSGSSTTFGDNVFTTNYTFDNSKNIFEKKDH
+NESHDKTNEMGIIGKWEEVKESESAFLGNIALEQQDHAQIPNPFKPIEGCVQIKKNSLSQ
+KVYSCISDIEGSFEEQQFNEKSTSDCQKVKNEKIKIVFKSRKIPR
+>gnl|md5|78cfd1479d01eec917ef68f9da92e94d
+MSTQIWIEKYRPKILDEMVGNEEVLTRLKVLAKHGNMPNLLLSGPPGTGKTTSIHCLASE
+MLGSKYGRAVLELNASDDRGIDVVRDKIKSFAREKIDLPEGRHKIVILDEVDSMTDSAQQ
+ALRRLMEVYSESTRFALACNQSTKIIEPIQSRCAIIRYSKLTDAQIRKRLFEIIKMENIP
+YVDSGIDTLVFTADGDMRIVINNLQATYHGFSMVSRDNVLKVSDIPSPEKIKSILDSCVK
+CNWRLAHSIVEELFIGGYSPLDIVITMRNVLKKYQLPERAILEYLKEVGRCHFVMLDGCA
+TPLQLDKLLGQLCMISARCGLNSNKTN
+>gnl|md5|e851f0404518c05ce4adfd770fcb2211
+MLNIPELKETLSWDDIYSLFESSLRISSNLDPKLLVNAILCECRKVINCRDCNLFIYDSI
+NNVFYHGFDTSKYIISDSLLKKVLITKKYEILDDSGDSDNYQLENNHDIKTRRFSNNAIY
+IPIYNTEKESPIAVLEILDKFKFDKDGIEVKDSFTQIDIIKLRCMSRVFSISVMNCEKYR
+EVRNTKEKADNLLNLVQSLRPDLGLQSNLFTLCIHAQEIIESEHCIALIGIPERQQIISL
+ISDTGNELLFNYEIGDIIHRIIETRHSLIIQNTGDDNKPRFENRLVECSCSSIRIVIGSS
+SVSTSNDDQFIRLLQKVYGGEKPIYNALVFPIYAERDNWSCVPTPSQRISSISSLSSAFS
+SFEIGHDYDDLVSVSPRNNSILNSSIISSSIVAPGSPKSDRVGRSSLVAQTHTNTRSSSL
+SPSNQFAQSNNTQAISLIVLINRLGVFKEKSKFTENDVRLLEPFGRIVAPNIGTLFQTSL
+FSYLQTIYNTDRNISFNKYQDKMPQDPPSFAFPHSNWKNRHSDVIFEEDEDGAKDLEK
+>gnl|md5|0d19b91f31a702a3875cfce9fddea4d4
+MEALKRLIDKRSERMAVVEKISASTESELILPERVNFYFAALRILHQLKRKTPEPMKGMQ
+IQETISLICSLDQVISLYGALVTSPKSTIEDYEEKVESNMRTIISSINRLGFRDILQKEV
+QYSNKENLDLHRAQRIIPGIFLGGSTIANDLKKLKDLGITHIVCCLQGACKFPNEFLYLN
+IPIYDTPFEDISKYFSSSFDFIHNALSQSTVERPNNVYIHCAAGISRAPTICAAFLMREL
+GISSLQALNLIKLSRPYVAPNPGFLNQLYNYQLFLTSAKVCQKRQQVSNSNQTQIQVQGV
+PYQTNLKRNVGRIK
+>gnl|md5|bd8009f5edb44e55be196b8b603635a8
+MFRDEVRTFSSGRRFACQMKSFLKNRRCISGCATAFLAGGLSAWLYLDSREKPESYFFNK
+LKSSYKVGCASQETSNKLFHQKILNQNLSLKTEKPNYVELIGEQGPIKSMVLGSEGTSAM
+ISISAIQVNANNPIEDRLLIQRMRLNLPGGENKDFVISAVIDGHGGWQVAEYVQNNFIRI
+FQKELSQYMSSLVREGSANESNQISQINKTDIIAGLFYSLKKTYYILDEELKSKLEVAYN
+LGFSKLASVGACTTVSIITEDAILTANSGDCLSVYCNENGIWLPLNEQLSAMNPQEQKRL
+EEIHKHEKDNLIQCKQILHEKFLMGLYTIPKYRGCYVKGILQPSRAIGDFRLKSMDFNYN
+WEKDLSTEKLLPTFSYVLKDKESEQSKKEQHREKEDLNEDEFPYSYDLINGNNSINMRRD
+SYRYFVKNPLSFPYVKSEPMLHLFFYNSLNNNLSSTDNTSVEKISPNEYSLTPVHTNSSL
+KVEYITPEYKHLPISEYSNSNEFIRDFTLSKIRNAYSYIQNPMNSSKKSFLVLGTDGVWD
+FLTPKDVTNVILNSKSVEDGVRRILKKVLNNAGINSIEKLKSLPKKRKVFDDTSIVLAEI
+TPNKHDNN
+>gnl|md5|3e79475532714606432a0c9bbbf5cc31
+MKITPKMFICEVPEKILEDGDCCWIHGFVVDVEIDQDGELDMITLDDGTSNIRVSIKDKL
+NDANCDNFHEDTVKTYRGLIEELVQKGRLISTVCQLNKGVFKVLHVSDSINGNGDSKNEW
+INNSIRSRGSQEDDSS
+>gnl|md5|e7dd5b024828dbfa3206ffc5e0f26826
+METMSREYEQLKNSILELANGISNISENKNLPILLNILMDGIGAYNSMISRQSNFSDSML
+EMSFWSIELMDTIYATNGGMTTLLDYTLEKIQDQFPSILNTFDEINYLDKFSTRYKISEI
+YRGLVRINFGLDQRIKSLEEMINKRQKYRNKSKAWELYNREEVLLKINNLKELSDFLKYE
+FISLIKDILFFSKYLGIDDEHNSAINSSHETDTDSIKGSYDDLISEIETVCEIFQNGQVH
+KTREIMDRIISNLDVEEFEEILGAFNLLNWLKGRVSICLGRNLENNIEEISVIRSNKQQE
+SSSSDLDKDDERLLNHQETRYYDED
+>gnl|md5|1943e453219e000b490abaa1119799de
+MEVHSSTVGCQTECTSTFEDTQGLEKNYSMVRVIGEGTYGIVWEGLRKDTGEVVALKKIR
+FDSDEILDEVGLPSTAIREIVLLRELKHPNIVALLEVSCTGMQIWLIFEYCETDLRRYLR
+LNRKKGLSINQVKSLLRQLLSGLAFCHGKRILHRDLKPQNLLLSDSGNTLKIADFGLART
+FTPPLKPNTHEVVTLWYRAPELLLGQRCYNCSVDLWSVGCIMVEMISGKPIFPGDSEIDT
+LFYIFRLLGTANESNWPGVTQLPCYKSVFPQWKVNPKLNLHALLPNLDQAGVDLLFRLLQ
+YCPKKRITALEALQHPWLNTNTQNMNVEMTI
+>gnl|md5|4147fc05c5dd14ebfe04a449fe93007a
+MLTFIGKDTSKFIQKANKKLPNNLNQIFNYQNSQKSLGESCCNSIENISLVSNTCDSSPF
+STCCNSESPDGSSTITSEKAHKDLDQVLTCTSKKYCSSEVQVSLISYSPTSINSDSNHLD
+SKNTNSISSILALFTYNILLVFIVLVF
+>gnl|md5|93762b83c2ea83211ce0794ba2e114ab
+MKLNFDFQGVFKSINLKENLHFNNCVSAYNNIKSYAANAFKSCEDDISLFLEGKPFVLSN
+INYNELSNKLIKVRKNIENGLKGGKGGFGATIKSQKRKVNVRELSVDLCKDLKTGKRIKD
+LNKSGNNVESKVEGGSRTKSSSSTNSGSISRNSKVLENSCSIVNSENELLTQYQSHVLNL
+ENKWKNITKSVDFGMNNLNQKVNG
+>gnl|md5|aec636bbfdbcd4e1cd624464ef3411e9
+MLYLKFILNILIFFAGQILSEPLPFSSDEVTVVPFPPFIPVAGGYVPEPQNNETTIDYVQ
+KSRNDYFGSELSQIVNSPNFHLVTIQNGEQNKQVWAFVLGNEKKVFAYRTENISITDPLH
+LGSNWNVISNSESNVWPVKMRFVYPSCHNMVKDKDEEGVDCGGPCKPCNMFNSCRIGLDD
+LRAHKILKYSTCIGELKHGEFCSLTCPVGYRMKDLTKMKSEIYSQCYDGRLNQLIFGNMQ
+APMTGESYYSREYRGFRNMLESEVSHLDQEFNELCESPFDICVNIFL
+>gnl|md5|120085b4912ef7a3223c651e1b5ad0d0
+MQGWNYGTNYNGIWVSVGESTDIFNGDIRGIYIKPYSNLVLLYNMYKLQWEIYERLGDVS
+YEKLKQVMRQDGKIKDRVLNEENTYLKENNKGWVLRAMNPHPNPSPPKGKWLTTPKSNFE
+EENILQIKYYHIDVYCDSSVTTLSGGDVHLSPIKMVRAINEDPVVCSSEKPVTSFSLNLD
+FSNLAFKPRNSYIYRYDGRFSGNGCKYMEVKGTTIEATECSGFFRKEELTQGETIWKKIA
+SNSRIVLFYWTGIKWICTRNDSSNTILGYIDNEEQEEGYWLNKIDSSAGAYIKTRTTLKC
+FKNHPQESGAEHACNRALLKGWPIGMEALNGNWDLNRYEVYIEGNKNGDELSRSKKEIKY
+YEHRRSDGCKLYLYFDDNVGYTVITNNHPKSRPELENKKDKKNKYIAIYKDELQGTPILK
+GQDSHHVQWLYYPIDEDNMANLSSPRALSSTYIYTKCRDNEEHHSKRQNSQGRDFDEEDM
+NNSINFSNEGENKNNSQLQNTSTKKQNRVSLGGRKLVKAKSISKVSQCSEYKIMGFNKPL
+ESLNGIWKRDESYPKQGETSSAESILELYKCTNSNDKDIYIYYSEAPLNKTGWFLDYDLN
+PLNGFIALGTNSTSDGLTSSWRLWSLTEKKWNNLDLSLECQDQTNNSNVNNKKTIFTTTD
+SKVLVNGFEVLESESPKELSIIPFEDVEDHIKAAPIREMPIPFFTASLPLIGQLAANAFP
+MIKGISSLAPKKPKPTNEDSLGSPVTASAILPNLDIFSTAEQLRQNITKSRQNERPSIYY
+DPSLLPRNSINGNNIPSVMPYDQFGPPVNMYNPRNDIPNYNYLPGQHNMFYSPIGPGNIH
+NNNMFDPSLGPSNNYFYNPYNNNNFNGIQQQQNTGNEMRDISYLNNQQQQQQQLLQQQQE
+LQKEQLEQQQQLQSQQQQQQQKLQKQQLEQFYHPTQNSQQINEIPTLAGEHEGVNGQLLY
+YVNGNFSQGDNHLEIPVSTSTTTTTTTTTTTTTSTTTTTTTTTTTTTTTTTTTTTTTTTT
+TTTTTIATTEIGNSNRDNMIPGISEEGRKECPEDKEWAVEHGKLLTESGSITNKYKVIIV
+SILYQEDLKLNYLQGVYSFNGIFNGRPSYRHFVNGVRNESNNLPELKTSTLDVSLFYDKR
+LRSWIFGDLENIGYNTEESIYIRSSQSDCLVPWDSTITWKNASNSASLPLIISVRAGESI
+NY
+>gnl|md5|79f2808241eae35ee65e18886c12c6ce
+MEHTDNMKLDNLTIPNQKIQSTNNEDRDLSAEINIGIINTINMNTDIANIGDMSQHFIRE
+YSVLSESPNLAENIAMIIEDSQSFFSASSSLYINEDNDENPYVEDFHHNLIIDNPCCDHN
+VFQSFGVLPIAMESFKNSGKKSKSCLKSSNYCKNSNIVNEENNKSNLINTYNSKTSNNVI
+LNNFIEENGIINNKELSNQTKSLKDDNDKNKNNKNNINDNSSYVISNDILRDYDQIVPKR
+SNLSLSSPIIDINPPVSALNTSSSRISSMENTKLNDSFSYIGKSHESQKISKKSKIKSKI
+FRVINKIKNRTSIIENE
+>gnl|md5|cf57d7e7147638bcd8e4277b62f7a406
+MISNEGLITVYYFIPSDGDKENNPNTFKVKGTHSTLTTKQIKDSFPLPGIYYFRFKVRVG
+NTYAWMDPLNDDDIVPLYDDAIIAKVLRINWDYKNKFTQRLNNKQDAYSISSGVIPSPNS
+LNQAFYQSQPPSQASQPHHPSSPPPPPPPPPPPPPPPPVLRHSVTASATIPSSSNSNNID
+LIDLNCEHSKWNSNSGYI
+>gnl|md5|30dd247eaf55af8bdf592cc6adeefcdf
+MSEWDDMVKEWLIDTGSVCAGGLCSIDGAFYAASADQGDAWKTLVREDHEENVIQSDGVS
+EAAELINDQTTLCQAISEGKAPNGVWVGGNKYKIIRVEKDFQQNDAIVNVTFCNKPQGGC
+FLVDTQNGTVVVAVYDESKDQSSGNCKKVALQLAEYLVSQGY
+>gnl|md5|292ed6f60825d297e0775d0a22cd4519
+MEIIDSYDVYSKNSWYDIYDRFPDYKIYGPTCIGTDIRVHNTSNIYGASEHSTEVNLPEY
+SSSYRFYNLDVFTYKNDKPDALYGSIPLVLSVHNDENEKNSFISGILWLNPSDTFMDIKR
+KFNKIDTWWVSETGIMDFILMVSDNFDSFYYNYHMLTGFPTLTPRFGLGKHQSRWFNCKD
+SDVLELSSTFEENKIPLDSIWLDIEHLNKRKCFTWNIENFKNVPEMLGELDIKGRNLIVI
+ADPHISIDDNYHVYNKLQNQPYLSNNILEDDEKVIPITITKTEPISNPWIKIRNHQEWED
+FVGVCWPGKVKYPDFLNPKVREIYSSFYTNKHYPIMNYSNIGFWIDMNEPSVFSSSELTL
+PKHSFHYNDIEHRQVHNLYGYYHLKSTFNGLLTCAAQRIIFLDNISNTNEIVSSFHGSHS
+AIDKALANENKRLNDRLKQDKSVLNLISSGRKILNQDNLLELGNVIKNIQRPFILTRSFY
+IGSHCYGFTWTGDNKADYDSFSSVISMNVSNSVCGLSYTGSDVGGFYGHPCKCLFINWHK
+LSIWMPFYRVHSHIDSPKREPWEFGGETLKYIRKLVVTRYELLSFWYTISSLYSFQGKPM
+LKPLNWLLFEFKNHDLIGKNESILKICECQSFLLGDT
+>gnl|md5|e0deb6338e4693476372dcb8938d5070
+MQKSPPMTPSSIFSSVSSSSFYSSMTSQSDNVTSITSLAESSIIFNSKHIYEIYSLHKSI
+QVYNPTTNQVSRINTNYDAIRNNWIYRNDIYLETISVFGIIHKPKIILLNINNIISESNI
+NPTNKVIKKLDFTLVNLENINESETNKLELYNVEINVAKLVNLINNNWKISIYV
+>gnl|md5|a19389ad2a749676197a669e820145a5
+MESSLGNLCKLHGQMCQKSREKSYEIFRNCDSGVLISTDLTARGIDIPDIEWIIQFDAPQ
+DPSYYIHRIGRTARAGKLGKSIIMLQPHEGAFIEYIEKKTMRKILGYNHLEGEKNNTGII
+YDGNYNSIEDPFYKKSNNLKLCYCTKLNEDIIKKDEFLNNSCNINRVGLCTIRKFMYSDF
+EFYEKAKKAFVSYIRAYKEYQLPFIFPFKSLSIGEIAASFALLRIPRVKEILGKSNISGK
+FITGSKNIHPDDFNPNPKPPSNIETSKDQRDNFENTKKRKESKNIQVNL
+>gnl|md5|0da4742e32ef53bd45cae4c4dc459884
+MKDRKRTPKNKGNEEISYRGFEALRPSISEGSLDFIQNHLGFRFMSPVQEVTIPELLTHK
+DVAVEACTGSGKTMSYLVPVVEILLKSQIQSRGISNFNMGSLILTPTRELSTQVFEILER
+YLDIINQYREKGGSGNVLKCLICIGGGNINKTFDYIKQVAEEEASEDNSKYYILVGTPGR
+IFHLFENLKDGFDWNIKSSLEILILDEADRLLDMGFENHINMILHSMPKQRRTGLFSATL
+NSQVQNLIKTGLRNPKYIKVSISCNNLEKQNTNEKQETSTSIEDAECDISVPIGLTCFYV
+ELNPLLKIEFLIRFLLNMKRELESGKQIKCINFS
+>gnl|md5|8bfb69397c9f10949ffb6a112f1fe616
+MNSVKDKCNNMPKQNHNESKISIIPNTAPYKFMRGLMCFLTVSLSMLYLIFSCSFAIKYR
+PLVFDNILTETIKGTIKGSNGEYIQWIATIPTGLVSRTVAIICVVMFLIFGVYTMLFSFY
+TACKKYKFIQPWHFMLLSAMSCVGGLISIFLSNKFAVVEEFTHKKDCLLQSVVSNDCSVA
+IGNDEIYAYDICKAVESFCLDENASMSRYYTKAIIVAVVSFIVSVLSFAYGIVLLKLKMK
+YSKKLALINEKNAISEKTKLDLEMSNSSSICQYDKDNSGINCQNNQTGTGYSTADNTNVV
+NSTKTNVYYPNMSNDSCKAIQPYQNEMRSIPMGIVVTTTTSKQCHIAAHRNANSQVNTSN
+MGNIIGNSAISCVNSIHHSCHSGNLNHNRNAHLGLSLKQQYHHHHHHHHHGPNHGNRQHH
+NQFL
+>gnl|md5|f0ad0a0c06ca4826154b5a2d4ca24e0b
+MSSSDSLNCENVNNIEEFDVERSIHSTKSPSELDDDRNEDITGTIEAPNLNIELNSSLNK
+HNDETSSNSTTLEKLSKKKRFKYKIVSKFMSLISHRRSGKGFSKNHSRRRSQSINYNLTL
+PTNSSSTSTSRHFSFLRKLSKKNRFKNDKTNSKNLTNIESSIEKFEKSISKSSIKLNFNS
+LNNICIAEDVDIQVMEGLETACNFNKKISTEGNFKNFFEIIPTNPKLDEKLHVKDEDKSF
+DISSKNRQITNPNMICNDNSNININSEININTINTLLKKRVSILSKPGKFEEYLKLKFEE
+LEETRKILGNFLRRYEKNRNFLENRNIDPSNLNQKQLNNQRLRMYARLANKLSEVSFECL
+LSKPNELMCQLVYNKDGVRVWKKEHKSGRVLLRTEFIVPVAPLDYVEYSTDSNNRRVYDN
+NTVDLKVVENIAPGLDVMYVATKRIATVYPRDIVNIRYLHGYNIKNGFKFMSWNDLSASE
+KINQDEMMCCSCSCSTEHPDAPERPGYVRMDLSIGSYMAIPIKTPFGIWSNVSMFNEASP
+KGWIPSSVTKMIAAKMVPGSVESIVSSMLTYYKFPFKNKLNRPFSGFCYRALSTIYVDQK
+KLELNCNTLQDPIINSKGVSNGTMNFISGSKNSKSNSKISFLLNRPLIMSIQDFIATYKS
+NSFQEFIEQFNSVQIINKYIISASSSILSSCNSDLLSSSTDASRNISLEVDQSKSIEYND
+ADVKQVEHSSKISMCNLSLDKLPNITEKNGNKAFLNQIISSNGALQDFCYDSSFERPSSF
+EFFEVPHNINKKQDQSKAISQSCSNNIFVCCNQIKTNRKRVLKLLMNSCKMYQDFGASYL
+TDFSDIAIISRLLSLD
+>gnl|md5|4205451ecff2fc9d2964348b1abc3e44
+MSFELCVNWPRDLNKAKELILKAYSFGYLGIAFNNTLNLVEKCNKLRSSPNKNSVSGNIL
+SILAKEGHVCPIQYIQLEKEELRGLRKRSLIVKSNSGPLVPKNAYLPLSLSCHNFEINKQ
+FGKEDDTSLDFFQLRRLSIVFDNPDCVPYINALSRGPCNESSDSWSKAIFSSVPNQPYDL
+VSVRPTTQNALNSAISSVECDIISIDISSAPRLPFIIKRPQINLAISRGIFFELDISQCI
+LNKGNSRRNFFSNLNTLTRHVPHKNIIITCNPSFPLDIKTPMDLSNICHVLLSLDFDRKV
+KVNSFDFINNNAIKALAKGTNRRSFASVILINKKEEHPDQEMDIL
+>gnl|md5|acda9de025d0dbd36e621f045fc41df8
+MTVFVLYVQADFEGIEELIFPENYTWCFDIEQSAGSLTKERITVDPNESIEMENSRGIVN
+FAMKWESDKRQSTITCIKLNNISRMKVTSEDEGKLVPVAAFDCRGINLTKWNPSFGYNVI
+SNSGKKFENINLEELEWCDFDENSNESVGIYNLNSEFRVHKI
+>gnl|md5|ded5c81455095a3882e6120b1490a36c
+MLYHLLFYHLPQPLEVWVTPRYSRIGELMANMENSANEFDSEKGSHNYYMEHNQKKMLNK
+TISRRNERCPAEDYCTENETFLNVDEYEANNFGSTNLIRVKQGVFHRAIATWNLRITFFS
+LSLAIFFAFSALIFPFGLNLRRVIFNDIGTSSGTLYYFANALLSISPSNLFAFFTFIHAL
+LISIYVFIYRRPVISRLSRILKMSCSAIMVIIILIRSISTFILSHYYMNKFRSGRLFNDN
+YPNLNSFLADFNIKMRANHSFYIRMALASSSQYLFLFVTMVFISSYSLDIHQLHLSSINA
+FKSTEESESYSLIKRGGDFVSNNDEKDGILY
+>gnl|md5|002a6c9e41cea03234a4deeeac484a17
+MSSDHLSKQDADNLDLTKLTPITPEVISRQATINLGTIGHVAHGKSTVVRAVSGVQTVRF
+KDEKERNITIKLGYANAKIYKCTNPNCPPPQCYRSYGSNKEDEPMCEVPSCNHKMQLLRH
+VSFVDCPGHDILMSTMLNGAAVMDAALLLVAGNETCPQPQTSEHLAAVEIMKLKHIIILQ
+NKVELIKEAQAQEQYKQIKDFVAGTSAQDAPIIPISAVLKFNIDVLCEYICTQIPIPIRD
+FTSSPRMIIIRSFDVNKPGEDAQNMRGGVAGGSIIKGVLKIGDEIEVRPGIYNKDADGEF
+TCRPIRSKIVSLFAEHNDLKYAVSGGLIGVGTKIDPTLTRANRLSGQVLGHPGFLPEIYD
+SINITLYRMRRLLGVRAHDGSKAQAKVSKLREGELLMVNIGSTTTGGRVTKIRDDLATFQ
+LSSPVCCSVGDKLAISRRVDKHWRLIGFGDIISGDTVRIINDY
+>gnl|md5|df811159c33525b2b2a670e911885a10
+MKYIYVISSLISYIIVINAFALRKKEGLDLGLKKNLIQSRNSYNFECDVAIECMNILRRY
+YFFVAIVYEIISTSNCVPRSSDIKFRIYLSKNLSELNYYRNYFAEHIMDKGRSASLFEVI
+HEFPKRKALFLNVCSQIKFIDAKELYLIEQRVISNYLKILMELKIYISADISNFSGSPFL
+INQGREVIKIINMAIEIILITQHKIQELEKSSNKPTSIYKLSKVPQKLLVTKIYKSNLIV
+RISHIVKLRKSIRADKSDLLTILEDLERNNEMPPKY
+>gnl|md5|e364810931475200b05436f0580267a5
+MVNTMNQILLKHISVFLLLIAFFDQLVEFNDLTATFKDISFVRLSAVYNGNFHEQIEVLE
+IGIENPPQLDLSEMVYTEEVDIISHSMAESLIDRFKIPDCKLNILYKAVNTLLHSMFLFE
+RQKCILQLLKTKYEKRKCDLLPRIISISLSCRRIKKQIKKLERSLEKLTEQIEQLERYIL
+NCFLSAIKMLWKEGREQSFEIDEEAAKECDYKELYSIWQENQLLKKSKTLLKSFTT
+>gnl|md5|9714d4ba48f629215ebe85aa012f5f03
+MSNKCKCIFSTADQIENLINEFEEKITEKTAFIRSCTRYLTIDTNGTVNNSVVRAPSENI
+DEGLKEIMQVSQLLTGTF
+>gnl|md5|b70cfee36c36e4dbe0578b0a795ce7e5
+MYLNLAFFLCLPLISIYEFGSSDFYFKLSLIELKAVGGFGAGQAESSTEGSVERSNQEEN
+SDQSSEESSTSQNEKETGGASPILNSKSESAFLSQGNSYYKKKLGESILSFNSRNELVEF
+VLFESNKRDLGLSFSDCLKVSQVYLTSKFTPNTSENEIVVDIKELLSLLRKYIRTNGSCL
+ESFCVKNQPKTSITSTESTLNIDEENDSDADSSVKTNQSTSSDASSGKLYDGSSGHSQLQ
+LTTSSNSASPTSIEFLEMQPKNDLKFELVKQDQSTPTSNEFVQPEENLRTPTPDLNLPVS
+EPENVPTNEENLNTVFEEMGTEIQVNQDEVVPNLDLNARNAIPITEVELELDFVDPWKSL
+ISMILYDPVRRSSLKFDETHCDKMAKVTGRIIAFITKYTCKLRLILKNYRRKKCNERNKV
+TSVLVGCYKLKKQLEKNIKYYSKLRYDLVDSVVGVTQCSLAKNNFISQRNKTFFHLSDGN
+SFIRCTLKEYYLLFDFVIFLFYIINAYKSAVEKLDKFISSSCTTICPTRCGKRPQICNCL
+EESYNNIFADKINMESYRHNLNNRMILCKNYLISNYLFSSSIPESAEYVSTSGYRYKIEN
+FEYIQTVQFPITYPSSLEKYTILKSSLFNLLLNPINNQEQPPNPAPAAKEVPNRSRNLEK
+RPKHRLKSKFPIRRNKGKNTNINHNTQTHPDPTSNPQNNWL
+>gnl|md5|a0c038e6793e6dc7319def2aa3eca5a0
+MNIFSLIGIHLLVFFGISANNIRLSFKEFSLLSLKENNDVDIYRKNAMIQVQECSPESMN
+LLLGIDQVLKFEATSYSCYVKNLTNAFESCKRRCAISRNIGKCRGIENRLAAAKEKYNEL
+LEQQTRWGKLLSYCIKCRALTEYMLIKSRGGIAKKSRITSRNSGDDPAYTPKNLFDSYLT
+RDLSSFELLYLSRMDTYLQSQKKLCKTKSRALCSCAKKTLKDLKNNKNVLQSIVIKQDSF
+QRRWFTFNEKNILGSGDTIDSIKEECEHVLEKDAEIQNGINGNLNAGFTKEELEPVTSVL
+>gnl|md5|9550812638f98bfdbc9b770f204f432c
+MSIANSSKCAFFHYMCAYLFILTVISFLCWDGFTEILEMNQVSLFQVGMPQYQSFSEAKP
+LFSGKGSKEYKDFLAEFGVLDGLEIEKERSNKALKKLLLELKQTFIKYYSLKGLVLSFKK
+KPSSVENQDLVENNNRMLQEANTELSKLLLEIFSCIVLKKASKYKNYTVSNNHFDCTIYS
+YVYYSSMKELSKRIIILLEETLSSFSKSKFSCQQFNVNVKQSPCYYLFFSVKAIKASMTT
+ETSYYCQYKRIKKNCEPYACLSLRKALSFR
+>gnl|md5|1595b5639839fcba0b1c6af03d6972eb
+MLKSSSIINFLLVLLFTVSFTSNNFVKNFILEVSFLNAASLETGSESEPVALPPQDTQMP
+QFGVLQGRGPIVLSDFMANNGVGLDLSVKKKCSKRELQKLLKLLENTMLTLFEIYGKSVS
+SEKSINEQTHSSSLEIGRLNDLKAKTISLNGKLEQLLAEIFSCVLRMSAKRYSGKSIRTN
+KKGCTLVSVTYFSALKSASEAILSVLKKVLRELSKLYNKCLTSVHIDPNLCRCYGFSLSS
+AQDSFSAQKQISKDSASEKMKCKCYVRNRITTRLLGGIRARTSGETVFEDENEVNTYF
+>gnl|md5|b50471c3570aba3cd34f14c328a22e1b
+MMHFLKIYIYSILYLIYLIQPRILVSRLVKNNYIFELSFIKAEKRQNFPVQMRIKESQDQ
+APGAPTVESVEVQLKSNVADLSPSKPEHMPASQFLAVFGLDDQMFVKGTCSSEVKDVFIK
+KTKKIVTFYFLYRGEYKRDYDTSGNRGKDMTVNTRNHSEFVKLMTRSGEVIMFMSRYMSL
+LMNCIMYLLSHYYRKVSISYNEEGCTTYNIFFHLVMMEMIECILMILRYSRRQLIKLIAK
+LAEGSYTDSESRIKAIDLALAMISETSDIEKEKFNKHKENFELCKEYIKHASSAKGSKYK
+GSKFDTSISGSSSSLKYSLKKLLGKKPKSNEKGEKKKDDGDGDGDGDDDKDEEPFWKLVL
+DSFNIDAMYDDDVFF
+>gnl|md5|18405cede4228ef9d490725beb0e6fff
+MLFLWLLTIFFVFIGGINENKGILNHNIKLISFLHAEGGKDLESSSSSYLTKETSTTNSD
+DGELSQPNSWFVTKLESNAESYLESIGISPDLTSKESCTESQLKNLLKELKKSLKKLILT
+NEQVKHYNDNNSSGKYSTVGFQEYLTEKKQEISMHKQNIESLLEQIFKCLILLRLDKYSR
+RIFKDNSVNCNAQTYTFFAVLKTTSKQLLSILKKLLHKFNKEYKNSTKNITATFDHSTLS
+ASIQTLKILITKQEYTIRKIKHKKKKCKMYMEISSRDISTLL
+>gnl|md5|d601628a76d097635947af2737c4ce63
+MASFKYIFTVGFVLISIYLNAFNGAIRNEKIKSIEFSFLNAQGPSYSLREPPSPFKTTIG
+SVLFAGKPEGVSLEEFLSRFGYNGRKEDLQPACTKEQIKALLRELKRMFGDYYLLLGKNI
+YFRKLSYTATQNSVEQLDITKYLSSTRPLFTKAESILISLLERLFKCILSRKIKKYSKSS
+DYEVFSLPYSKSMKAISKSLLKLLKGVESSLKEEYPKCLKTSTGASLVECKALGESLAVC
+KEHAQHQKEVKDGRYKEEKALRGILKSPHSDNSRRLPSEPKHVQLKNVSVDV
+>gnl|md5|989ba60f4c1d37cba674c05dcbad346a
+MKLKLLSLIHLFLFFVLFSEFKYDEINYYQITPFNSFVKLKISSNLNGKPKDTGESKSPQ
+RTNRGPSYTLRNTSSSQNPQSNAQKAVSPTRKVFSWPPTETTRKKTTKPSSPKSLSESYS
+WPPRERTKPSIGQGRVSSAGPQHLDTEDLFTAVKVQVTEEDSDEETGPVTAKLVVLSDSD
+TDSDSSDSGTSTSKSSSSDSDSDTSVPGTPVTKRSVIIQSEEQLSPELAEKVQKMKEASE
+RIVRKKLLAGDVETLMKSSRFTKRMLLISIPLLIQLLEAIFKFLTSENTTMLSPEVFSQI
+QFQSQSSASSSSLFLVNLETANESINSLKLNLKEQFQEKYKVECNLQFLKTQIQTFLKVF
+LEHAEREEEMRIISNPRKGKVENRIQKIESFYKQLWSRLQGIKKEMIPFLDCYLTYLDII
+STKNIEPTKKEKCSWNELMVLNFFLTSFKGFAMLFRESLTGFEQDIEKFEKLKEKPQDGL
+SDSEKKMVKALKPTMRKIEQLRFDSAIASIISSVLLTIMGKCLNHLKSEY
+>gnl|md5|9d16718111dc8c86a900fd9ca532fe8d
+MRLKVATLIAIISLINPLNVLYHVVDIRQISKYGDNKLDTNFSLLEIFKKKSRRNKKQTI
+SIEESDSTSDSEIESKNQDSVDKEKKKKRNKLRKRLRRIPNFFRNLFRRNKNKAKANGKH
+KRNRRHKAEKSASIEEEFADQANKRVRQPETDLEPEVGLGSDSKSGPGSGSGSGPRSGPG
+SGPGSEPGSEPGSGPRSGSVPGPGSEPKAEEGIRPSQGELSIQNKHENIQNLDISKLFSE
+ANNRRKKNQSFVNELKNKLKPQQGSHDQIKNLISEGNPEGQKIILEMNYKEFYKYLNQEI
+IINTGGITPIVKLDELVLLINFDQMLLNLESKSGNSEQIIKSLFRTENENYKIKVNSLFN
+VYKQDYGRECTFEWMNDLVTMYYNAFMEFKHVEEDYQRLLDPRKSTPSERAQNLSKTYYS
+MKEAKSNIRKILMKYLNCFMITFFSINIDAINVGENQEKCTIQDLTTLSYYQNIFLALKN
+LFNLVFKEKEAEISEFNTMLISGIESLSEEKQHKYRIFSRLSEKLFPLYKDADLYEKLIR
+IIDVKLSSCLTYIVNNQESIEENYSKF
+>gnl|md5|2be1b5beed702f91045f7047625c17b9
+MEEIVTLLGLSTSINPADVKMAENSLNMKEGMPGFIETLLMIVTKTDIELHIRQVSCIYM
+KNLVKRKWDIDWEHGGMNKHDRDIIKGNIVNVYMSTPKMIQSQIGEMLLYISIRDFPVYW
+NDLLVSIVKFLPDEQTDLLSNNGMFLGSDLNALVSKLQQYESTLSMIKLILDKYRYAESS
+NKVLLELKEILKVVCEPMYRMFVYSSQCLFRRLPVIQDNTSRQLVMNICLLSCQLFYILH
+CCDIPEFFEDRIGPFMESFQAILELDTTPGLVDSEDQLIICLNIKSQIFENLRIYSDRYQ
+EPFDIYARKSLSTVAILLTKMVSQNNNTVDTNPELSSSISSLIDEGLRLIGSLAATQWSD
+NAFMDSGVLDHLVEKILIPCTFLDINDLNIIEETPKDFVYKYLWDINDVCDSTSKRSAAL
+ECIKNLGKFYYTKLSELLSNLIISLLNGISDDVHGSSSIFDWEEFNEKSGNYCKYQITKS
+DVTREASVFLFICLSVRSFSKIGGVAHLEHGIDIVGFYDNYIKSFTSSPLMRCCALKYLI
+VFKSHFNNASSLDILQQSYNWLSTQTSSIEEMMILLAFERILTQKTASSTGNPSIQGGGI
+GANTSICTPNDNSNSGGALLKVQQGMGSQETVFKLSPTDTYNLCFQMIGNILHPMLKKAF
+QGGDKRTYLTESEFIPRCMMRLLTYLGKLGSELVNTLAPTIAECTKLAVENPKNPSFNHY
+LFELLGVCIRNSSDCEKLDNFVLPILIGILEKNLTDFIPYSLQLLALRLDTLASQNELYD
+KLFIHLIDAKIWHGPASAVPGIVRLCSSFFKRHSLFEATISSHVKQVFERFQFCLSHRRF
+QSTLSFEFLRDIVRFLPFQWYSQYLTALANLLLTKSQEWNRIGDHQTIIQVVGAFSIIVI
+KKPYGEMQETSLLNVLDTLQNGLSFIFFSKVVFPNLLKATLSPPLRYTIFIALLKLVSEL
+TFERSKRNDFVLEAFKSVYLLFNAIKLSDDPNFQRRNSISTDLSGVSDDSAQNNYLAVLP
+DSNLDSQNPIQDEFEINYHKLLIASCHSSNNPYPSHKEILQILTSGPSSTSIGANSAHAC
+NFIDCIRNSEQLNLMKITFQPYLNEISNHFVGDQNIQSFINSLK
+>gnl|md5|74d4e22477c7b10f3acf679522afa4a2
+MDNTSLLRAEGGFVPPERNSKLYMMLLILISSWANSCITMIWPLLVVGDYLRLPFQAIMF
+LIEGLLCFFLGMTSDLKSKKTSLKYSLKIMLGSVLAVLLIVVTNLFIETKFLKLDILRYS
+GRSGGFYVFNSETLNDNILIFDETTNIMNNIHREEADLAPGSSEMNFGNKVELDENNSNL
+QLKPDSVSVLVFTLILFAICCILQSSSNSMYYNLNILIVDSSIDDYNTRYSNSYIDYAGW
+SEICFYNIGSYLSLLISRLTFISILELLTQKNLKFSNRTIEIDYIHIYCFNLLVLLIMIP
+FGYYLVEHKLKLNFTNNSIYQINYQNIKQYSTSIQEFMGDKSNLFWFLVIPYWIIYFIQS
+GNNFHKWIVIDQTAFNIEWWELYSFIYEAIISLILSIFLAYMSNKFSPVILQVYCFAILS
+MVSFGLTLCTYMLHEIPVKTFTDFISAFTLCHGIFHISCVVPSINALYFSIKFTPSEIKS
+MVLAIIHTILLSAPILDQIINNYSFKLINISEKFLLITAINLIGIIYTGLFMAKQSIEES
+SFRTSLELLPVYNYHENKTIK
+>gnl|md5|41f663666a52375f62931541b1a33d30
+MEVRVGGKYRLGRKIGSGSFGDIYLGTNVTNSEEVAIKLESVKSRHPQLLYESKLYKILA
+GGIGVPTVHWYGIEGDYNVMILDLLGPSLEDLFTICNRKFSLKTVLMLADQMLNRIEFVH
+SKNFIHRDIKPDNFLIGRGKKLNVVYIIDFGLAKKYRDPKSQAHIPYREGKNLTGTARYA
+SINTHLGIEQSRRDDLEALGYVLMYFNRGTLPWQGLKATSKKDKYDKIMERKIATPIETL
+CKHHPFEFITFLNYCRALRFEDRPDYAYLRRLFKDLFFREGYQYDFIFDWSFLQPEKDRR
+RTGNSVGVGVGVPVGAAVANAGANGPIPTNGMGVGVTQGNIPAGQSTNVVATGTGTTTGA
+ILPPNASLPNQAGPSQCMMPGGPSSPAGIPVAGGATQVTYTQTNANCVAGEGGQDVYHES
+QQDEQWGGVVK
+>gnl|md5|755350035ab899e23566126aa66ce86d
+MDYQEQENQTGVRFNWNIWPSTKLEATRVEIPLGCLFTPLKESSKLQLVEYEPIRCRASG
+CILNPYCPVDFRSKVWTCPFSLQRNPFPPHYAEHISETVLPAELMYPSVEYILPGIPANN
+VSPPVFIFVIDTCLIEAELTELRDSIQQAVSLMPSDALVGLITYGTVCCVHELGFTECPK
+SYVFRGTKDVTSQQLQLQLGLTSRGDTRNQMAEGSSRRFLLPVSECEYSLMNILDDLQPD
+SWPIPADTRPQRCTGVALAVATGLMEACCVQQSGRIMLFVGGVCTVGPGTIVSLPLAESI
+RHHLDLQKNSNSARHVQKALKFYSSLAQRAVQNGHAVDILACSLDQVGLHEMRVLCDRSG
+GHMVMSDSFSMNIFRDSFKKMFEPDASGYIKQAFNGRVEILCSKDVKINGAIGACTSTGK
+KGAHVGDTMIGESNTCEWAFGAMDKNTTVAFYFEVVAQGVNQIPPGKQSFIQFQTLYNHP
+SGRKRLRVTTVSYRYSEPNILDLAPGFDQESAAVLMARLAVSKTESEDGLDVLRWLDRKL
+IRLVSRFADYQKDDPNSFHLSSEFSIYPQFMYHLRRSHFLQTFNASPDETAYYRTVLLRE
+NVMNSLVMIQPALLQYSFDEGPPQPVLLDVQSLKPNVILLLDSFFHIVVWYGEMIHQWKE
+QGYHENPEYENFKNLLLAPAEDAKSILQDRFPVPKFVLCHAGGSQARFLLAKVNPSATHN
+TLSGATFDSVSDGSIVITDDVSLKVFMEHLIKLAVQS
+>gnl|md5|24af48c63e74b24984d7346873b0e113
+MKIPRISKRGSNQLLLSFFSGLFLLNYVFSTNTTKIACNACIYRPVVSNLNTHFYGSKSN
+IVDFEFQIPCTFYSPMITVSVPKSYKINQLKLLPSSNIGKFEDYETSCLKENESYLEHKV
+EKGIVEKSSSIDTKNSLFAFDNIVNEQIPSCDLGKDAENELLQVFTSLGFQTWQVVSQNS
+SKCLEVPKYETKGTESLKMMGNLANGSYVLRFDLQNPIKEEFTGNWNLSITSTKNNFPTT
+PFCLTYIDQTSVSRTLGPMLGPLNVKNATFNSYYTGSQKGEFSFIINSLKWNGSNRINQQ
+ISEIGELEPIRIRLTFPACENQNDCYSINSKNSETFCQIYGHKYECYLERKKPELVLSIG
+LSEAIDNNNLNSIFPLKVEIKDLAIPFRSEANYKLKIEVLIPSAPISKPEFLSLNVSTVE
+AITKKNQCIGQWIKFLIKDQTVSNLMNNNNSLSYSSVSIGTYKLPKTRDIDIQIRYRVSN
+SETYPILLRIGKMNDKIQGSYNIRVKPLVEGAQFVKKELDQRIGYSNVLLNALIYDKSRL
+QEELSIEFETKTDSILLRNVDSDNPLECILLVEGPKSKRNSKYQENIFEAQKKEWEVEIF
+SIGDEIVQDEEENVQVITKKVLLGEILDPRETEVSEIGGPFVFVDTKEKYSMVVYFFLIG
+HQYNRMMTISMLIPKSITEYINTDLNVRVIPPESYDVSKTFSGGRVKITKYTKERILAIT
+LESNEGFREGWWGISIDITRPVVINSMDLTEYVEFNISSSVSTMDSPYLTSLLFLSVHEN
+FKGPYKTPVANKLQYVKGENYIFQVISVQQSHISFHPFPMLKDQIVELETNSPNYLVTKL
+MYMEKFRFLYIISEPSLDGKDIDIVTREIGNLGSSSCQIILVLGNGYFKGSKCDKVVKYS
+RLDKEKNNNKSSGSKDKDFALVKRLLSKFLSSKDKFIMSLITLVIEEDDIETYDNEIYSA
+DETTPNERVNYNFIIKKKSKVNTWKLRLDPSPTYFESYYQFRKALISTHYYNLYTVPSSI
+QALKVCPPEVPILSQEKTSSQPLVLKYKFFSEIISSYNYSVTPNIPGTCIKQRLITSNSI
+DRKIPGVLTISLVLLLILI
+>gnl|md5|1949714b36128f7436a81db6bbc1fac1
+MKSRPNGSSTLSNILQQYSDSVSQGEGVGYIGIEWKGPFPLHNSIIQHVKRVQLLIGKTP
+SLVYGVIPNIKYGYVGLENMLYIFPIEETIQKVLRRESSIGSSTERRSTDRMRSAPSIFE
+QGFDGKPASDESILTIVFPFSIKNMTGTFPRVGIFTSDVEYLLCVITEKSVHLLALKFDN
+FDLAGDCSQAYDNDRTVPRGAGLIKVPIMNIRGKDIGMLQCSLPGSHNSKFHSLQGTLDG
+RFFFLEENSSSIHELVYQSSEGWITPYCYIHSHQIYSSFTKELFLKYTFLRFMPRSFSIK
+KISLAPCGFMSILDTSQNIYLAAYLNDINSKEVLSNIIPWGRMVNSLGYWASNLDINSFF
+LPTDWDNYVSSEFQNSEKLFSKTENLNLENFSLGLFNKNDSKRFSSPSSLKVVAMLRKKD
+IFDIFSKIPGNPLFKKNEESFSMYSIRAEYQNQFDINDLQLFFTSDYNLSLSLFTNNGTR
+LQFQCSKRTNEVMPSIQNVINGFRFEPESLFESPKKKIQTETAFNQSKLSSSSYSSNDLT
+FGFWLTYVLPASSSSNENSNISNSYYRNGLTIITRNAASYSFQNVNASTDFSKTSNKNIC
+QVELRLFSSLPADIGITSSSNFRNRTLNSQNSPTLSLRYNGNFSSASQCSKGEPIIIEFD
+EQVKAIHEFTPYSENNNNNSLNNLEDFHTLACKRSRASPNVFLEYGGNPLGNNNRQHDLL
+GWVKDRCIVFVGETRYFFLVLKWNGLQQIVGASGLFMQLIQSPLSSSTNSSQFRRLVHPE
+DSFLTDDHLSLTSPWVEALSGAIAFDLKSVLELPPFYKYENKMQLQLTTQILEFCLSKLQ
+GLLNILSRSQNIIGNEVFDQSSLPCIPPTMSRPFNQILSEELNKNYDTHLKDSTTFLLKS
+VAYITNFLLQLFRFLTLFDSSPPELKDFTFKTFVKHDQNLLTEMPILYLIVSNTGVSQIK
+KFVESFSVNILEAISYQDHSIIEISFVTQIKLIYKKIGWLINSKSSKIMKRLALVADLSI
+EVGDCPSNNHLKESSMIERISSRNLPPIGGFSLPPFKYWEYFQADPSQNEYFREIFSSLL
+LKPFNKTEETTLLLLDCISHFDHLLTEQLKLKQNFIGSDSQEEFNTQNYNIYFLHIEQII
+KAWSDSLCDAFIESFDCNASLSEISINSMKSLILLSFSQPLKTLFSSCFNKKVLESCVAR
+LLRDLFPVMMSRFIATFARTDKRNSCCCQILLEDMIEISRYDSLQRTRCSEKSLLGIIAF
+SISKSFKSLNSNQHLKEYNWNDFSSFLYGLAAESNYSPYYFILSTIYLLDDFQETHSGYI
+KCINMLSELSLNKNVLCGSYCKNVRTRIETLRFIKEICIVGVGKGLISVDMNVSQLLPRL
+LTESYFDRNQFQMDYSLEYAISNLEGIISLCSNLQIPLLDYIEKLAYNQGQTFNQLIQIL
+STQIFPYSELNSLIKSNSYIEPFLIVSTLLESSVSIKQEDNNIEDLCSQISDYLLQSLIP
+PKDHVIYFHFSDRDYGSQLPILSKFFGLNGPDNLSESINRLLEFIQTPLLNISGSSLLGS
+LSVTPKTYLCVGLSNQEIFEKYDLFQQIYSITAIFEFTNYYISALSQNITDPCNLSQLPT
+SISIQLWNKSWSVPYDLLFDVYISLLDSSLASNSSSDPFMLIFNRIKALESPIFKFEPIL
+NHHDFFILHLRKCVIGILDNWIKNRKLFPLNKNHISMANNFLISTLAYIQNAYSADQSQK
+LTST
+>gnl|md5|4e0a7f9bb1912f3ba21d8df881b04391
+MISLINEGDTSLPQWNNMMGLNSDSDESENGWVHWYCGLREHYFFIVIPNEYTRDAFNLY
+GLRQYFPKNYDSLIELILSSNIPDEDDLADPALQDLHREAGELYGLIHARYITTPRGLQI
+MKHKYDKGCFGKCPRVLCNGYKVLPVGITNELRSRRVRVYCPNCQEAYDPRNVNLIDIDG
+AFFGTSFPHIFLQVYPEYISTSCPEPYYPKIFGFRVSDKLSIIERKGINGEYGKRAQVEM
+FKARPSSVQHIEKPQLLNIGTGKLPNLMVDGSNVNSSSNQDNLNSRNSEYNSTASSKTIK
+SSNTSNANVLAYHPEDINMNQMPYNLNSASRSCSYSRQ
+>gnl|md5|3348a0c69fd184f4e8627e461bcb56ec
+MMLLISYIIFIYTWLMLFEKVDGSFLTGNNIAAAITTKQGTKSNTGSILGNANSMDTILM
+TAKILSTADTIQKSIQNENKDQRVKASGAEVGQENFTALKGQNSTREDLIGSGIQYCNID
+KDGLCCLMPNYCSKEATCKSDIVGQQTYIDYLNALPRCQCLPGYIGDGRTKGTGCQNVNE
+CLTGEARCEQLCTDYSPGYACSCNMGYRLNTKDMRSCIDIDECKEGSHSCSHICVNTRGS
+FVCECPKGYTLDKNQQDCIDINECQENSGLGPCEFGCKNLPGGFECQCPSGYKLDKKTQK
+CIDIDECKEEKNLCTGFGEVCFNKKGGFECKCGTGFQYDENENACKDINECVLNTHDCKK
+DSVCVNEDGGFSCKCLEKGFEFNKEKRACEDIDECSNGDSKCDQLCFNTIGGYRCGCYKG
+FRLNLTGPEENRLDVKSRVCIDIDECLESPELTGCSHGCINKRGGFQCTCPKGFQLGMDG
+KVCEDIDECRMPENPCENNRQFPCCLNTLGGFTCVEQIMSGDLFKRHECPKADGDSIKRE
+PRTGNVNNSSGKFKWFRSNTDTVNRLKTK
+>gnl|md5|ff890ff4b07c8eb033e71567e4158328
+MERDIRFCPECNNILCPKENIERRKLLYACRNCEYFSYADPTNAEENVVNCITYQYEGKE
+DILVARGLHQDPTLGRTLEWNCRGCGHNVAVFFQLPERVCSEAMTLVFVCVSCGEWVKEG
+KETDDEMDYSEDHTNIFNRPYFNIDNISFEPKKEETEENNYQQIKEG
+>gnl|md5|74c27d2aced87b5e4db9dfc6ba816152
+MRNLIKDIELYPTIADNHLRFIESNIKGEAGLKEVEQLYEGALSVCGLHPAEGPVIWSQY
+RRFLSHQNEENLSLRVSKVRDLFYRQMSLPLSGLPDLLDEYRIWEEELPAENRESFDVAK
+EHYLRGQQEWSLRKPLEMRVQTDNVSNLQELFDAWMLYINFEKDRMLSIDYSSNAVPPQE
+SHSGCNNCNSSIKYRFDTKDSVIMAYRRALDDLGSIRIDLWLELANFISTTTNCPHLLST
+VYASSLQHFSTNPKLWMFYLSAKAESIKDITSHFCQLHHFYGPGCKARSSATWYPQNYQI
+LKIKSLKEMLEIALENYISELYRFQEIFSKSKQDALELYFVVTNSLIDINKSLKSQLDTA
+KTSNITYEQTHLEGINILELEELIFKKLEKLYLKGEELLLGSNVGLVEGDANGRGEKFDI
+LEESAALFYSRWFDFELLRSANLKEVIISILEKFLDKEEEQVMNLLPIIISVIKGRLTAQ
+DQIEIGPVLIERFSGCSEKIKAKVLSEWESTESFVKYKDSNKRQRLDAFEGDPNILYSPN
+IGKISLGVSSSSSEGVPTQEVSQCILPLPIIHQGPMINGSSRTSSSRSISKNNDIEGDFV
+CLSEIRLRRDKRRSRRNFTESDYDTSSECSSESNSISALLGSSGTNGGRQFLRNFTPPGT
+PSYSIQKVPGVIAHQNHNLKSPRSPTITSGLQQTALHSDQPGSNSFTPKGSHLIRSPGMV
+PQDLEARTQCTWDGREAIEPSIAPPIPPIPTISSISSVSSNSSHSSLGARQIERSISQFV
+SLGEQQISISERTVDDQNMPPPTYTPKKNKLDRSNEKGGIQRESSITSVSMAVSACEDSD
+LNSSPKESLKTAKDLPSDSYQEDTLFIRFPQDQDMDEERLRGILLDHFLIQISQIRIVRD
+PKGKPKGFAYVDIEPEKIDEIMKNSEELKRLEEIGIQVKASNPPKSQAPRKSLSSRGNSK
+YKRQTRRKQAQGQQDSSTTILIKNIDKSLDEKQVISHFQDSLGLKVKNISISRDQSGASR
+GFAFMDFFESGDALAAHMLNESKLGSSSITVSSSTRPLTFPKSTNSDVDLTDSLNARFVP
+RTKSKQKLPPGRIGMKGRETKVNTSTFHEDLELGNQQETVNKTTSLTNDDFRKLFL
+>gnl|md5|18797930448eb3b5d7422582a2aa9508
+MSGLKEAEQSKDKMRNSVDLLCILEQNKVNDHGTSSRVGAFLNRASRVASSPIVHWIIIF
+LCILHMAIFLAIFMNKTQNSALNRFCQEIYFPIGIIISIYCIYDSLVILVYICKLLRAKY
+GVSGKLKDETIIMRNSVELFLNLVIGMISITGLSTNIVGFGKILGYAANWKRLSVFLRKQ
+VGQNKRFYTNEEYCLDLVYITDRVIAMGLPAINIEAIYRNPIEEVSTFFMTKYPRSHMII
+NLCNEREHYSLSYFHSIVSCPFPDHQVPTLGSLFIICFLVLNYLVSDRKNVVAIHCKGGK
+GRTGIVVVAWLLYSRLCSSLEEALEYYSNRRTDLSLPGCVKTIKNPSQIRFVHYFSFLLK
+HTFPESVIKRGSNFFWEDLQRGFRSGYYWNICNSELRRVNQKCEKRHWKISELLRDHCIY
+LPQCLIHPINVFPVSIVVNNKEREISDIFEWKICLHSEYNRDAEYLYSGLTTNFDWNPRH
+AGTHLSQSLYSKGEGYQFFLLESDSNKQALSYFGQDQSQLIYSARSKIEQLVSSLKTKPF
+SPDIVTRTAQDRPKPWIEREFVIKIFGYESPQRHLQKHSLSPKSMHQRSDVDSETTEMSC
+LLYDPIESLKPTEEEEENAHMLRSISLIDFSNPERKKEFSNHVITAVNSPYKDIVEFPIK
+KINEWGSSRRSFSNSSVALAHFWLHPALIHTSSHSNLWTFFLEWDTSSKTWLIRDCFLSI
+SLKRKKEIDVRSSNFENVCIDVTFQYK
+>gnl|md5|9ac9abed778ed6fbcfeb07649eaead94
+MTGNNPYGGYDLVIREFDPSDSDGVRRVCFKHFRSLTFPSVFFYLSQHLADMIALLVIGK
+VFMDFKQLISMLVLFCVYLTGRSIWEVETYIRNCCTDLRNVHELYMISPGYHFWVAELVK
+RRNSIRKRRSMVLGSGGGSNSRAEGLEQNDNASKGIECEDTPSNRMEGGESILVGCVGLA
+PYRDDPKIGRLVRLVVGVESRRMRIGTRLLAQMENFAKDYGYKEIHLYTNNLSTSPIKFI
+SQHGYQLVQVISRGLMRGDLLLWRKSFEKSSSDNSYLNNEKNSIGERVILD
+>gnl|md5|40c5db32efea5b2d118f028d7c994736
+MNSSYNSYYKLNHGFIKEKHSDMSSIDKKLRGMLEKLRMERRQKFLKFQRTEDKEYFKPK
+GKSEKVHSKFIKDWKLSRVWSKELIEYTWLSKLSEGYKSIQENPQDWLLLPICTGSRSML
+IQGNGYCELRNQDGWRIFTVKNVPFAHTGLTIIDGIYNQDQNTFYCNDLIVWNNLNICIS
+TTECRLHFLSSRIEESGVTNRIAESMDVSMVLDSSLKFIPNIRIQLGKYFPLSKDSLLHI
+YGVNDRTHGSLSDFDCLVFVRKDSVYDVEQDYEDAYPECKEYCTVSQKNWFIWRDKQNRS
+FKDCRDEEMDNTTFKLNINEKNELYTKDKVLIGKVRCSGTLYRKSISR
+>gnl|md5|04dda2bb8130758f911319b3d2764a2d
+MRNEQSSHHKLFLVSSILRDRVFSSIYWKGECFALDSETILDKAVLLDYIGTTYGGDRKA
+TPFLCLLVKLLQIRPSTEIVLEYINNPRFKYLTALGIVYLRLTESSIVIHKSIEHLYQDY
+RRIRIRNLDGSFDIIHLDELVEICLCEKKFLDLDFPYIHKRAVLVKQGYLKFPRKSMLEY
+VPSNSGDSSPISKTEDESNVKRRKSFSRSPSVSSIEGNNTQNLGKEKARKTFIYSSKNEL
+SLSVEQWNVYRKKLGLKPLQE
+>gnl|md5|411285fd5ee9ca8f15aa057cd028d513
+MMASRKQEEVLVIYIKSVIQLICSLCVIIIIFNKDWISGQNTISESFVVGFLDELCIRSS
+VLPLSRQSWKESDAGKSFNFNESEKSPFQVGKSNSDIIKNKLGENLDSKIVNSSILRNKK
+LSHRHKLKLDVEEVNNIFQQRLLGENGNITSLKGNEGKLNNGESKKSGLYFSSFDQVQYC
+ISHKSNKLVKDWYIHPNYLSYLVLLIVIVSVIFSLNLIKMKNKWSSYELLIPILDFLVFS
+ISLLNLAQILHVLTPLLTYLQKHNFMAFFSTNFFMLSGSIGGFFIVFSLSIGIIHYRYEA
+FTNLKRFEDQIENIQSFSSFIHLISNSN
+>gnl|md5|dd504f7e164ed6877d7ded3c553b9883
+MKVYKCIFTGDEVMSDSYKQTSPFGKAEFDDIAFEVQSKRVQKSAEDFGIAHNTEEGEAE
+VVDADVETVNDIIDAFKLESTPFTKKEYMTYIKAYLARIKETMEKSNPDRVETFMKNAQT
+FVKYLLERFDDLEFYLGPSLDCEGIIIYGYYEDGDLAPRFIYFKDALNEERY
+>gnl|md5|7977c56b801b0ccc6d1b5dcf468947ae
+MEGEGLGMANTTDLACPMSLEEEVKMHENNNPEEAMVKGQVVGKENGTITVETDLMEKLK
+SQHIVEEESNKSVGKTLEEAVCTENSNNSNSNVESTLKGEKQDENKENIEMKDVTSPENK
+DKSKHLSKIDFSVFEEGFYRRYKSFFHDRQADEIDLTQDKATISKKINEHFSNFEINPVD
+VIRTFLVLRKNSEHSHGHFVMSPAQSPEPNIHPSSEGNTRGRRCTNKDMGGVSNDTNNAE
+TNANGVNYKGEYKSENSSIVDNHTEIGVSTRNSRKGRVSNRGRR
+>gnl|md5|e45ddb1b67c49a34b4d35f846eda6cf7
+MRSITIEELSEIDDDNIRQLAEIIIKRNFNEPSESRYINEILNSTGEQLNQKAQNLSQSI
+KEKNKKLQEMTDELQFMNISLQQLNSPKALKKMTLKELKQHCSSLRSIMTSYLDSFNQ
+>gnl|md5|05f672f2cc175db5a71dd28d313da39c
+MTSCSEKIKASESGTKVSAASHEPLAKDEVSQAQIKSIDQAKSSLLELDPEIVENSTNQT
+ENGSGSVVITPTGVSKTSSIDDITTCTTSSDISTPIELSLTAKRPRAETSFSDKLDSDTL
+EPTIKVQSLDPSIGIVSKSEAEIRSSFIQDHGPASTVVSSPTPCNSIVFKCIDASESGVD
+INNRTESNSTEVIPTSEASKSTTASASPLNQSQSCKDELNSGICMGAKQPALLSSKQLFD
+ELVQLAAVSPTTGASGIALLNPQQLASLDNGVLQQSLQNFGLLMGTGLGMPSLGATGNTT
+PIKVQSPSISASQLMVGSMGPSSAEDLQQSTSASTTASASTATSSTASPLTSPINLSSAS
+ATHGSAGQIPGMVTQNQFISQLMANPLFQPQAIASQSSQNLNRMVSAAFGAGSPQTTPAS
+STFGWPSGGSTTPQGFCPTGTQPGMSNFAALLAAANSQLHSHNTFPVTFPTPVNRSISNG
+SNPILMPMQSATPSDGSAFEGAQTSTTASTASSSEASTYPSTIGQQNDPLLRLGAGLPHN
+SSGTPCIPPFWHANPALLASAASLIGSGDISQTMALLNVNPLGLQPFVQAQTPQQANTHN
+SNSEEEGANRAQQNCLSLLASLQQPSFDFSSLSTSSPATLAALASAATAATNAQLSSAAQ
+TQPDAENHASKPVAKASGGGRASHGSGSRALNASSSVTAAAAALDHLDVDWDSVGLREAE
+LAAMEICKTASTLFDTTDGTTPVPSSPAAVGEAVLTAAQLTISARAMLKFVKGLTPTQLG
+INWHACTQRFCVTYTTRDEQNPRSWTLGAYSNGKLHYKYFGPRSWTVMGLKEALRKAFKA
+RTSLLLGQGIIEEPEDTGLSKEELTYHARQLLQQLRDSLGVKKGNVHKGLYISWHPKTRR
+FVVALKSCESGKTIYKYFSPKERSIKGIKTALLDAHQMVVAACQ
+>gnl|md5|bcf0e6afccc6e8ff626a82985502058f
+MTPTNPKDSDATESHETQCVQESKKDQEVPKQEIPQEDDTSVAEEDDDDSSEYESLIDSF
+RFERGLSLFLEIPKETIKYIYSDKLEKHIQLPSIVSFRDLCMEAFGEENVVEKRESDTGR
+RKWDNILKEKSFTQDSKENDDIGEEENKDIEEKENEESERTYEDITSFLDTIKSNSKQDS
+QNVNENVLRKRVHEMSTRLSKQGLLCDPREYYFNPMTMTGASGANRSREDYYDVFDDFID
+DSELVDDLGLSLDELYSRNADRGNHTADHGDDNVTTTSIQTSELINADYSNPNVFFCDDD
+PQNDFIDLYYESELGDEYGEISDGDGYSDGEQDDLDMKSGGSDVLHEKKSQTLRDILNNP
+VIKLLVQLRTDCWVYYSPKNAQQNKEQNIEQNSQGSLNAQTSSTPMIDFSIGVPSSQATV
+DLTTPTAKTSKEAVSGTYYFPQRTPRVVSDWFRTLNQKIKEIIEAYNHCKGYYNEKGNIK
+YEKNHQDPEIMNNIGVLSSNIEKDPILLRIPLLFSDIYSNPADVAPFDSKLIRLIWEGLN
+ICVPINNKKKQFNLSQNSSDSSSIIQLLTRFESFRTKWARLILNHNQEALYQFDLNAFEA
+ITNYPPIKNKSPEYVQRVLSSINEYNLQINSSGSKDKEEKFDSKVGEPTEGGSTPVLAID
+TSNLDEISIEGIKLENLEVSQTQNDTSSEINFERSDSFTNTYLMSTMEHSDSQDSPKGDI
+FDKTRTEKAGDSNSQGIKAVNCDLVFDFGISLLEYIHGINRLRIVYKDMISSNVMTKSVQ
+KEQENIPVNGSRGLELMIKGHILKRFSSVNFEGQKIKDIPHRFFLNQVKLLQIKYSYKNL
+TSISARRTKAEPESKTAKKRQRKDTIKVGSEHSPNKDFNGVENPVKPKKPRKSNSSSSGE
+KQIGCVNMAHDSLPREEESSILSNEELLNSNLPATTEKLKQKPRKSKKAVKIEGNSPAVP
+PNELTECLQSCPLETPKLDFHEQNIQASSFGVPPIQSCNQLTYQGIVTRELCDPEKMISH
+TAQEDLPVYNSE
+>gnl|md5|acc53ba534086aa09c491751235af737
+MERNKLINQFSITDVYHGLGIPISMVYSRNLLGGAGLCVGDSEGYISLYSTEDKFIERFT
+EPGIVIRKDERIFSRKLHSGTVTDTKFQNVGFYSEKVERYIYSSSTDSFLVKFDMEHEKE
+SCKLRAHKEWVKRFAISAESSSLIATVGNDGSLRIYDDRSIHSNCFYLGQGNVGRSRTAS
+NKLIPGQISIGPSIQAPEGGENLNESYYESIEKIRLAPKFELNRIHEHGVRKSIGREKMI
+GDKSISVSGVAFLSEKNYLATGGCTDGHIKVWDIRKASCGIAERACAFKFSPQKDEDAQR
+GITWMEADELYNKLALQTRKGTIYIYSVSGILSFSKDLSAIAIDSNKVFYEKENVGLLDA
+SQRPSISSNGEWLITASNSGSRFYLFNTSMDLESSIHYYTHENLEESSIPIFQCFAWERG
+KFSMGGTQTFPPKDGNVNFRVDKCVGREYRLNFSVGTKLKKLSFYNNKDFQLDNINSVMP
+NFSGVSAGDATNSRTTVGKNEEGDLKPRWVSGETLSYSNSFDGDMDVANQLSLSSSLSVP
+FPKPSRSSKANSVDLTLKSMDEKNEEKNEESQELKGIREERKTGFLTIGGIGFSEKDSQT
+LSEGGAFGRPTPTPESVEKTPFRRSIPFMGSSQDSVGYPAPQRGQSSYMVQSQESLLTPI
+SPQKNTADCKGALEMEHESGNTSSNRSHDFNSRRIIHIPLSQSNEEVLASPGIDGAESFE
+ADYTIYSEPIPHASVSTPGSPDISSDTMLQDDKCEEGNKGFKQRRLDSWVRVRKNTEGGS
+TANCSTAELSPVS
+>gnl|md5|d2b518964e31b6e705c9a75a9d142b2d
+MGELDVNLLLNYLEANFGVNTASSTGIDLNTFTTLVKKLNLGWSSGQIRHAMIFLSGERS
+LSSMYVSSLSHQKKSENKNRNKYLLSVKVNDFINKLITIEGGIPNNIATSHFKGVVSSNS
+YDRSSILSNTNKHPRNDQNSSVISNSIYPQDDHIRNVDDIPIEEYEYSNSELEEEIVERI
+>gnl|md5|1f398f912278297d1fc584c3effb0789
+MSLFSRKKFRLLSLLVILSLVFLLELTEIEGKDVAISLRRGTNFGVDESSQDFQQKKSES
+IASHHYVTDKVKNRYSSTAIYFILSGILVIITILSTYIIRECVVDRIRRKNDSFLQTVMD
+TVFRQAACIFVSLAISYCMLTSRLIDHIRNFCENIMADYSNQSIINNLATQLDKAIVNNS
+KVWTAENLGREFNNILAIVILSFAWYCLFVLYFTGCVKFLEKWIRYADETDVGVLIKSIF
+NLQNLFSLKLKKYSDSNFGKEEIQKNKLYLSKSKDKFFGENEAVQHNNVPITILNENESI
+SSYKRSSGLSIDNRTDQTHEGSGKSNYEARRTSIGNNSDNITEESFEDPLDSSNSGGSSE
+EGSENEGIRSDTDVEEELGLSQLNESIELDINKSLPFKGKQHRESSILKRKKNDVEVENL
+TWKEKLKLKLENFWTKFWLWPNQLFLTYTKAHFISLRYDFMDEVAAYDSYGSSFSTNHSG
+DSGYSEDGLSTSWLISLTDPTTSLVAGVYFTEYLRAKLLIMAVTLIRIPITTLTFILGLN
+VLGWFLIYDYYQNLILFNNVKHYFSEPMICIYISVLLLCFSLTIWLRAWLIKRQLQPRNI
+LEYLKMKYSLDVGMPLQEIEYDKIMPRYKISSAKIISNSEYSQISSQSNQSLDQEREAMQ
+NKSCFGRLSKYLKLKLCGTNSPSLHDDLFLFKRNGPAILLRWFQASYFLQLILISIVIHL
+SYLQKRLWYEEFPLATFTIWVIFGIQHLCLPFIIYPILLCTSVGQMADKIVLEQVLNIQK
+TQNIQRLSQISEALRFYSFLHLFNSGSEENKELQRRKFSIVAKTAPWELQIRCRNTMNFL
+INNAPIRTRVSYSIFLIYKFNSDF
+>gnl|md5|7e9031e3045ee7c0dff68b42e1271876
+MGMFLTKPSTTKHSDQGGDFDKYGVRFGVSGMQGWRVSMEDAHIALPRLDKHPELSLFGV
+FDGHGGSVISEWVSRHIESIFEQELDTVLKELSSNEINLSPEKSKLPNRVVAISEALQRT
+YIKLDEQMASPTSRPEQRAIYDKKKTNSDTNPPKTFLQELLGGIDGQRRVLRMVEQNGNR
+CLQIVSYNGDEESNSSENGNVDGDKAEEVDEIKESSAKNEDSSYGRQPAENIPSTDLDEN
+QNYSDEITPFESDIKRDDATYDDPNTGFIDDDGLAEDDGYLEDISDSGACGPEHCGTTAV
+VAVILPDETGDTPYLIVANAGDSRAVLSRSGQAIALSHDHKPELPLENERILKAHGTVEN
+GRVDGNLNMSRTLGDLQYKSDSSLTPEEQKITAFPDVRIIPLTNEDEFIVLACDGIWDVV
+DNQLCVDIVRRKILKQIEALESGNDSKKRESNMNGQNDREFGSIESKEQLSISTKLDGSS
+PIPALTSIQLSKICEEICDECLAPNPVESEGIGCDNMTFMIVQLGPNIRKKSSDCMVSTQ
+IGSAVAKRLNAAASAIETQISQAQQGNKTDSNPGNFSDDDGTLRNEQSSRMETQARKAPD
+AVLNAPLPSVSWIPKKEFNVTLYGHGVDDGRFDNIPEGRL
+>gnl|md5|1ad36541912a8ab1f7ff25564e8b4faa
+MPFPNKKIELGDKLSESIRSFSTITDTEIIIGICRKNIPGWKEINESYIEVKQIFSGLTN
+QLFVVSIVNESMSLSLKHPRILFRIYGKHVGKFYDSKVELDVFRYLSNINIAPNIIADFP
+EGRIEEFIDGEPLTTKQLQLTHICVEVAKNMGSLHIINSKRADFPSRFDKEPILFKRIYL
+WREEAKIQVSKNNFQIDKELYSKILEEIDQLEELIMGGEKFSMERALELKLHSPAFSLVF
+AHNDLQENNLLQTQNNIRMIDYEYSAINFAGADIANYFCEYIYDYCSDKQPYFKFKYEDY
+PCEELRKLFISVYLSQTLQEQVMPSQQIVHIMTKAVEVFTLISHITWGLWSIARTPGYQP
+NSVEFDFTEYANTRFTHYLQKKKELIDQGILPLNSWLFNL
+>gnl|md5|3c27e1b82cc60952a99d183176cf59b2
+MSTLSKRKLYITSGDYEDFILEKKIKREIDYSKICIELNEAENELFKLLIEYTKSSNLKT
+IVRVAGGWVRDKILRFIYLNSAKNKDSCVDNDEEQASTFKKDIDIALDNISGKDFAIGFN
+RWLQSHHNYPAHNVGIINRDPDKSKHLETATLAWNEISIDFVGLRSETYTLESRIPIITL
+GTAEEDAFRRDFTINSMFYNLNERKIEDLTCKGIEDLYNGIIRTPLDPMKTFIDDPLRAL
+RAFRFTSRLHFRVDEELLSACKDKSIHDALQTKISRERVGTEVHEMISNKYTGNPAIGLR
+LIINSNLVDSVFKFPDNEVIYSFINDSEYHCFSNFGDWYSPGPYLVELTHRIIEILTSKN
+LSGCLNNSFDYKKLDIIRKLLYIDHESNWGVSTYFSFLLPLSHHYYKNEKNKEIPLVKYI
+ISNSLKLSNKIANSVMQLFDSLLKIIHRVVKLDSLNELANSTLAENSNRDKLKVDVYSKD
+FLKSIGDSFFPEIWNFYCNYFKCCLEKWSLTNIHASSEYKRDQQSCKFFQRRG
+>gnl|md5|b5316721fa4ac64a5be81700bb9a1155
+MGNYSKYLSIVKEKDMVDEEKVIASFVHEKDPSVDTKNITRQKVPGFPYAEIWDNVFSED
+ECKEMIASLEKSGEFSFWNPGHSSKKSYRNVDTIEGNMYALSKFIWERIKNIFNYHEFEI
+NENDSYSEEDNIGKWKSIGIYEKMFFGRYSDGGHFGPHTDCSVCIDTNTRTLWTVLVYLN
+TIPEEGGGATSFVDESQKTQKRFIDESGRERTNPNNVITRVQPRAGRIVTFFIADMHEGE
+PLCAGYTKYILRTDILYRRVNPILTSEADQRAYILWLKGKDLTYRGKMDEANKIFKQVSE
+ISPELATKFNCLC
+>gnl|md5|b92479acb6d31bdfbed37a6bb93ca0ee
+MVGLSGEFREFPLGDVLTGSTLSNLVESMENALAVALSTEDPNNRFGSPPASTQVVEQLP
+RETVTKDNIVRIKMCGPCVVCQDEYSIGDEVMGLSRDEEVCHHIFHANCLLPWLNQHNSC
+PVCRFELPTDDEFYESRRRSSAQNISSTLESTNQAGTQVGARNGIQDHLDSATVSNNNIQ
+STNSESQEPLIEAELGSSQINSQERDQDHARNEGNSNNATSSNFRTINFSNPIGEVTTLT
+SQLPVITSTISTDRNFPHNL
+>gnl|md5|010000ae7dff48414726d9039930864c
+MNFEDKVDAKKVEHIKVLPEGEFQNSAQSSNGFENVDPKSEPLSEIETKNEEGGIKRRFQ
+PNQFLKFSNLVLVPGKPRKWKRVQRRFGRSEGAWLYRWEYIPESIDNLFMENLELMARGV
+VGPRRTGRTTRAVSFHMRENPVGPNHLNMYELEGNYEQS
+>gnl|md5|ead5997881122c42fe0774d507d2c573
+MMISPLSWILTLLLVSYGFMLMVCHWLLFDSIQCIITLLIGVGIFISTVVFVIICRFLFF
+PVSTLRRIKMQINVFRRRLARKKAFKERNIQEFEMQRIIIDENEDKQELSERKEIPWKSE
+SKVLISDNNTFLNTEDILGVNEMRTSKETLGSKSSCSEYTRKHKANGELIYADPSVSILA
+DATSLVSSGINQHEETTEDDTNASGFTSKPRKNKKIKSSEISGHGSRFFSFIGNYSSFGE
+NRLNFDEEGTIFSKKLNTIRSRVILMYDKYFLRGLTAFFSKDFVQISLFLINIIWALLWA
+LDSNYLTRESINDPWKVKKGAETLLLFEEAFLWIADISFLYKILGEISLLSRGINGIITL
+KYLITSATFIPLLEMLTTSPILLVMKYSIGSGSVTTLFMLGFLRYFRVLNPIPILTIILS
+WSSEVMRICIVIIWTIACVVLGFSGAMMIIESPKPNFTTLFDYFYFTIITISTVGYGDYT
+PSNFVSRLICIILIIFTIIYVPNQISKLVQLAQTPPETMGVCNIGVYDESIFERDHIHTT
+LVLVIGSPSVKHLSYLLMELNQLNANIDYIKQFNGKSGKIIRYQPIVMLLTNSDPRDYST
+LVKNSQQALHTQLFVKKIKNIESLKVDIESIKGFIYAIYFWSDAINAKVYSPINAFHEDG
+VNFQENNLTEFLNCNSEQYGSTKLFATDRVLDLERNTMMIWYAVRKFLDLKEYEFLYRSK
+ETGILYNSSSSILGKKNRRNSDSKTDNYPDPLRINSVIVFNGENADFKLDNALRDDHFYD
+LYGIQDINTARRNVVTNNPNLQAPKTPEEISSYLFYLSKVSGSDHQINMNRIANMVRDQL
+SSELNEKYNSTIKNSKYAIHEQKSSYTPVYIAEIRSRLLAKTALCPGFSTLLTNLFNTIK
+IEDLELGESLHNSINGIINECGGNKFNQEFESLVSENIRRQSRALSEDTDQLEFDGTNIF
+DADFSELEKGTLNRMATIDETLLYSSLDTVSQSGILTRDYIRGTHCELMEIPLPNYLIGM
+QFLQIVSYIFENHSMICIGIAVNVCEETGINKGNKNQFEDYNANGELNIELDESVNENGC
+EDDEHYNFIITSEDEEDQNSNNRNSEKKELDSPSKSFIINEKDSEKSNYKKLKLFPNKLK
+LARIDENVSNKFKYKSSIRSNSEKKEPSKVFGICKKKRILNPSDFIAGRRWRYGDMVIEE
+NTEIDLLIISNSRRKAFSLIHERENLDIKTEKYKEPIVPRAKQTLNYIRLCLQGKTKLIN
+NKLIIPSWRVETPVTPRIRKMDTSSGKSDQLRGQPPSPIHRELKYSKVSKIEKIDILCPS
+KIQGYIHGTTFILLVCEWPECLEEFLNGIVLNRSIPVGWDSFRHINKNFKTSVPTSTQSL
+ILSTIIVFLSNDHNEKYLQRSIVPPSCVGVYIKGNSSNDEDLIRSGLFYAHSIVVCSSNS
+INSDSKVITTCWRIHSLINMKIQAEIVLLKSKSSKFSKNVCPLYKSHKKELESTERNGFG
+SKIKDLRLFDAKWNMWQWKVTANLAQITKKWLFEGGHLPPCFFPAIIADIRFEESLPLLD
+STSWISLNEWDFSTCPTVISGRVLTTDMIIPIIYRNVKINPLLATSDSMKPLLGYNEKYN
+FFNSPLTYDNQIINLDCPSSGIKRFYTAVSKIMPETEYFPDYTEWGSLELISIPEQFHGS
+CFSTVFKEMLRISGIITVGVVRTIGNNVDVPEVVIKQITADENNIQENYSRSKNSYNTYL
+NRVAPKFSINNRVLLLSPHPKHIISKNDLIYVVTPISKIF
+>gnl|md5|97c54ab2fbb70ece5cabb6b63837e670
+MPPAETRKLDDIAKMIVCKTHIGTKNVEDKMLSYVYKRTHEGIFLINLAKTWEKIQIAAR
+IIATIDNLADVVVVSQRPYGSRPALKFAQHTGAHAMVGRFTPGTLTNQITQKFMEPRLLI
+VTDPRVDSQAVIESSYANIPVIALCDTDSPLQYVDVAIPCNNKGKESIALMYYLLAREVN
+FLRGKTDKWDVMVDVFFWRDPEEYENSAIGADMELNDGMGVDIEGAAVDSAAAANEWGGV
+SGNWGGSAADEWRNAP
+>gnl|md5|ec7c7fe28db1c8ce3534a4839fdc8c5c
+MIIYLSPKDYHRFHSPTNIEIKSVRHISGECFPVFKGIASKLNNLFSINERVVIKSEWEH
+GKMYIVAVAAHGVSDIKLFCVPNLKTNQRGSNLNYLRKGKTGQFIEYSDFKNCKNQGKYL
+KGDELGLFNLGSTIVLIFQAPENFKFDVDRGIKLKLGQIIGKVLDSQSS
+>gnl|md5|d71711674037738116c7a0910d3c15b4
+MLVLFETPAGYGLFRVTNSKLLSMDTDEIAEYFQNPDKVQKSVSLEAFLRFKDTKSALVE
+ATALVESKLSKGLSKFIKKNIPNPASESLAVADKVLGGLIKQKYEIDVVYNPKMQEVMRG
+IRNQLTDLLTGLTEKDMKTMALSLSHSLGRFKLKFSPEKIDTMIIQAVALLDDLDRELNN
+YAMRLKEWYGWHFPELGKIISDRDVYANCIKVIGFRHCTRDANLQSPPCNIPSEMEAEIK
+QAAEISMGTEITEEDLKNIIELCDRVLELSEYRESLSTYLKTRMSTIAPNLTYMVGELIG
+ARLISHAGSLMNLAKHPSSTVQILGAEKALFRALKTKKSTPKYGLIYHAAVVGQSAPKLK
+GKISRILAAKLSLCIRVDALNDQNEPTVAIENKQYVERRLEELSNQLTSGRLSSTGGNKK
+PSTPSYSPVKSKALGSYDSSMDIVGSKRKPSGDSQEGSPDKRSKH
+>gnl|md5|149f8367e40dee4d3114b9c6494eb3b0
+MYSQKGDEFEVEKNKLINIQIKKKLGERNDSNDQKESIIPFGIPVWVQNRDDDIEVVKRG
+FLRDANLGENVMVEFSSINSKSIFAIKSYPKHKIGLIIDNPIKSPDLSLLDVCTPHGISH
+MLGERCAAGFCYTFSGNLLIFILPRVEKIPRLMKAYSSLEIQRFWTEMKTKFEPHIFSLA
+RRALVSWAENHQDQTIIIMGAQNTGKCFNMHMLIRFLAKNLSLYKYIKSSYAISEKIASI
+VHITRSFIQTPGEGNNGDNKFYHYGQSYCGQVWRIFVASDGCLMGSHLHLWSFNTSPVSY
+WSRTGPFFSIFYQLAHGLILDNNNPLIKSLKLSNDETMLYLTQVSPDMNTNYIDQLRGFK
+MTVGSLNSLGLNDTQKIDFFKVVFAIVVIDSYVSILCNSTVNEINDSKIVFFPLLARLLG
+IEIEDLRTNIVTCYEFVQLQVTLYCRLLDWVIFTCNENLRPAVTNLLGLESFTIIHGPGF
+IKEGFSFSNAMQNYCEEKLKKNYIHEIFDSEKKILESEGLNMIKLNYSDIDSITDLFEDP
+EKGFMNLLKITSKRQRRVEEFISEIQKDPTESSLLHKPTPCDEFGRIDLDPSKSIYSKFV
+RSFTGNELLKANDEFITKGESKFQEEPYNELLKRKKQICKDYHDSNSEKIRKYRKIRTKR
+GNRADSMGNDLFSGVVNDFEVDYGANSLHSSVLVEDEQAGELPDYLPPEVTINHSFGNCN
+YSIIAMAEEDNLNQVPEKVDELFRKSNNKIIRACWTTILETDEKYMQERNIYKGTAQKKK
+ARLSIDEDPEIIKFENFWKKTEDFMDLTWIRLSAIPGSPSMSQIALKASKMVDSMLRRGK
+LFFSVCASSYQLGKKTEEEVSETKITNDLEMYDISSQVLFQQYGFTVKIPLRVFLLKFSE
+IYIPRIHKKGILERLKSQQNLRDSIRTLLHGLEVPEVEYLIGTQNLFLRNKMVLVLERRR
+EEYLKKALPASIILQNAWRTLKPRLFISKLRLMSVRIQSLIRMRFVCILWRKILPYRQFI
+CGLALLIHLAIPWVKTSTIFDKLEELAQQREDERKFFRNSAATSIQAWWRGEMVRRRLTL
+YRYNEFREFSIQVIQSAWRTLKAQALLVEKLAFTKTPNFKAVKIQAVFRGWLVRKKFCKL
+FMLKRCILALKRKSLIRLGIAKHIEYRGTLRRSHVFREQIRAHREVVNKAIIIQRVFRMA
+LCRRQYVKLRFSAQVVQCRAYTCLEVYRYFKAIKSITLLQQWWRVTSTLKKHIDSGNSLI
+KTLSKFKIQKKIPKDPVKKSIEMNNLISRELKQFNMMRYPLLSMQGLFQPLAKIVESNTV
+FLNPVELSIVKDVGDYYPSTWGRGFVTLCRRLCGAIFETAPTKQFPPLKILQFSVGQRHT
+LVLIAERILAGQGDDNIEIDSFDNEDLSNHKFSKSGNSGALLGQTSGKLLNFEYRNHVYS
+WGVNDQGQLGVPVMDLVSSNIREPVRFIDSEYRYTKNEKTGKTVRYLIRQIDYTRRIRWV
+GCGSDHSMAITADGKLFTWGENIFGQCGHGHNYSYIPSPKMIEPLKEEQVYMASAGARHC
+GVVTQNGAVFMWGAGTHVCLEDYRFKTLYGHLAEYDTVSSNANFYEPFRVELPSFDNSSS
+TNKNDDKKNGKFGTDEYNNKNEGNKNGGVRQILCGNGFNIICTQNLFIWGRNDKGQLGMS
+KKGHLLVPTLLPLPTTDLLKLDYSEELKKEVRRRSLLTLISGNKITISSISAGPDFVCAT
+VEDGFNIMYLWGNFTVHEQTGGSNSSHSAMKNFGISKINLKSQNSSTISNKAIQCPTIVR
+HSIWEKKILTQVACTVNSIAVITDDSELYGFELVSLKKTEAGKSEKISLSTDELDTGHKL
+DNWGGIISAKKKQKNVMDKKKTLLPEFCKDLDILRIPEKYKGNLNDLFYFEPSLYQYRCV
+PNTKKAGLLTEEVISSISSTMSILWVKHRRKTYISQIKGKSDTNNSKIDTDNMDENEKLV
+EIDRENVSTDSQMKMDEGNILQKVKERRNIVMNRNMILHRIQPKSYIPSYLFHDPQRVLG
+NGCNDSVFVELLRRIKNKNKKSIAESDEHILDLNEAEKPN
+>gnl|md5|d415c8def2106e4d0bce2e55877b96f8
+MNVRLNFLLYTAVLVFVCLTSSCQSYESFDPRSPNGGVTLNGYIQKPGIFYFLNEELRWR
+DRDFPFYNMLMSTVATTFINLINQIEKNEEGLMLYYSREVARLAKKGEVINSIYKSFLTV
+KGSKHELKIYEEQFKPLCKSYRIEIAKSPIISIVSHSTSRLNAYDYLIPFIPSEVLDPVM
+KKFSVEVTKFLWPQSFAEMSNVFITMIEKLEKLCKKINFNLLESCNEYMQQSRSYLIDLI
+KNHEKFLKYSKTKNANYLEFSNILRKLRGEILSFKPYQIVLRKLDPVKADALGVPMFSGF
+NHSILDETMKEYYEILRDRRLKNR
+>gnl|md5|46fb4837e225b99a04fdca5793263f4f
+MHERTDLFFPASTNVDLTISRCKKKLASLRRYIKSVSYLRSQTNTGHSRDKYDFNIKNNM
+RQLQLNKNEKCMDLRRNDEKKCNYKYYGQNEKKYNAEMNACSGIDSESSISYNSSFVNKL
+IERYYSTSKSKLPDLNNVEKIISFKTTSNLSTPQLRINNERKDESQINQNIPKNNMELNN
+IESNYGSYCNPKFDSDYKNNNRKENFEKQESPHATLLKQYDLETREIVDNLDKKIRNLER
+RLKKDKRKIKLHNKNEFQEPIYERLERSNSIESKLLSISVMPPNGISCFESSFLPYYCTQ
+QEIKILEDLISIKGEIYGSSQTSIKIVGIGKIFCCHARTRFIDSIKRLYQGSINFIKLKL
+LIYIEEPEILLANTCGPQTFENKYDMNFYEFEELYETKKISRFLICLVITDRPMECFKKR
+CYTISNAKQVLPIYIININSISS
+>gnl|md5|c8440c07bc17b1c1aeba343345b77a70
+MHSSKLKSIYLIIYGIVSTLFWATTLYFTINEIIGIKSTYEQLGKHMIALRISQSLAVLD
+IINSSLGIVKSQFLPTIIQVSSRLHIVWIVFYLSPENSRQISTVFSNIMIITWSLSELIR
+YPYYVILQCSFNFPSIRMPLFLKWLRYSAFAVLYPIGIFSEVIICSNFISDIYNNSSSSD
+PVYQRLLHFPTKMPNALNFEVNLACLYIVILCIYIPGSIFMYSYMIRQRKKSLINLWKLE
+GDNTKVE
+>gnl|md5|a18427c7c338835f611ac92e12cafbfd
+MTLCAGKCTYETGGRCIVSLSEPLLKYRSVKELKETILHELIHAYLFLTSNDRDRNFHGK
+EFCFHMNRINRMSGLNINIYHNFHDELNYYRRYIWRCDGVCRNHPPYYGYVRRSINRKPG
+PADSWWNFHKKTCGGCFVKEAKTLPQINNLESLDTKPNGQTSSPNMHQDDILEIIEVSD
+>gnl|md5|b9de698e8ed000fbd052a6a79eee62d6
+MSRLSQSLHDRHITIFSPEGKLYQIEYTFRAVKNSNITAIAIKGKDTVCIVCEKKVPNQQ
+GQQDKLLDPAYVTSLYKVRKHIGAVMLGLAPDCRSLISK
+>gnl|md5|d4606388f376a34d0cadae4b35ee3c82
+MRLLGASGMFISIDDEDGPSLYKIDPAGYFASYRACAVGTKEREGNNALEKIIKNEPLNS
+YEEVISASIDCLKTLLGVDFKAEDIEVGVVTKDMPEFRLLSVEEIDNYLTSIAERD
+>gnl|md5|c74a7f81041ad0d39890717f66db08a3
+MISPELLDLFDNHKVLGQSILPGAAFVDFMATVALNYTKSQFTLGVIGGMPDWIQLKGIF
+FRNPFILSSAKQYKYLNRQFDSQDCSDEDNSSRSSDFNIIMSKGNNCQISIESSLKMDEE
+TVVYATCDEVEYLSNIEAQTKSLCIISEWPSSELISNSKKVSQI
+>gnl|md5|7e2fba14313d6ede6b7fc28552f8e266
+MDGAIASQTMEMMESVYAPKVYGAWNLHECCEKFELNKNLKHFVMFSSVASLLGNFGQTN
+YSAANSCLDSLVEYRRNKGMCGTSIQWGPWIEQGMAMNIKQHLEKVGMHGISNEMGIRVI
+NDVILYQSTDVDKNSLGKYPVITCQSFNWNVYMRQLYYNSKYPSFFKDVVASMSTGEVKN
+IGMDFRGMSKEEVYSYVKDSVHNIVEQIIGIQSSTLDLDTPFSELGMDSLSAIELRNALI
+SRFGIKISSTALFDYPTLRSIIQHLTDSLYVSETRDAFSDLGMSISEREYSVAIIGVSCR
+LPGRVKSFNDLYEIVLLKSKDCITEIPLDRWPFDLYYDPDPDNRSKSYVNQGAFITDIDL
+FDNTFFGLSSTEATNVDPQQKYMLEVAYEAMYNSGITKRSLTSIKKTAKTSDDPVLMGVF
+IGCCNTDWHFLQAKFGFENFTSYTGSGGASSLVSNRVSYSFGFRGPSQTIDTACSSSLVA
+MDAALKSLKEGSCHTALVGGVNLMLSPHLFVAFCRARMLSPDCRCKTFDASANGYVRGEG
+CGAILLTKRSEIGGKKIRPIAYVLGSATNHNGRSASLTAPNGPSQTEVIQNALRNARLTP
+NDIDYLESHGTGTPLGDPIEFGALKTVFGNKKDIKRSQPLILGALKTNIGHLEGAAGVSG
+LLKLILVLKNRIAPKILHFQKLNPHIDTENFDVEFPTELKPIISNKSKLVGGVSSFGFGG
+CNSHVILESASASELNTESNQNKNYPYLIFAYTGQGCQYINMCKELYDTEEVFRNEMDKC
+NELLYPILGRSLISTIYCEKTMESEKLINHTSISQPAIFSIEYSLTKLWESKGIVPSAVM
+GHSLGEFAAAVTSGILCLKDAITLVARRAEIMASLPQNDGIMVACRVSEDQVLDSINKLN
+LKDSAAVAAINGPKSVTISGSRSSVMEVLNNLGMEDRYKQLDVSHAFHSPLVSSAEEKFE
+KVIENIQFFEPKLTFFSSVTGNIESKLLIENKYWAQHIIHSVRYYDALETAISTDEENIA
+IIEIGPKSVLTSMGKQAVGGIQLVQNSNENISNNELTWIPTIDNSKSNTIDFNDALKAAQ
+EYIKYISESVCVHKWNHSRFHWADLTSVHPLLGKFYSSISDENYLAYSTDMLKSKVFKNI
+VEDHVIFDTNIIPAAALIEASACAAFKLQRSEKFPSKYVEMDSMDIEKPLVSNQDETTSE
+MEVFVAKSGAIQIRKKCISEAFEYEEEFYGPQIIANDTVFSNSRIYHHASISNSRILSKD
+EVDKQCFPNLVDYLEKYSAKDTIEVPIDNIYEMMNEIGLQYQKNYQCLKTVKVKIDNSND
+EKKIKSPGNNQINEVFCYVKRPISDFDLTELRIHPGMLDSVFQASSVLFASDELLEGKNA
+TKNKRGHVAMAPIGFTKCFYGRIQHNSDVWGLVKLNRFEKKGNIAFIDVTLWDSKTNILA
+AHFQDLILKGFSNAASLLSQEVRIPNQFLWRTYNKKIVDRTHCIENNSTFEQENKEDQDK
+EFKSEDSDHDNQIQKILIFGIPTVIKELICSKIDNKYKKISTTFICLEEDLTIDLIDQKI
+QEENWSAMFYLGGLMDNLSSKQVMGDILKISQVISTISVSITTAPFVCLTSFNDCKENGN
+IPRHSGIKGFVKTARVELENVIGKSINISHIECNSSLVNDPETLMRTISYIASIYEGKIE
+EEITLERDLTISESGIYAPRLESINFPVFGAIKLTMSSRGAIGNLKFKPQGQSERVNPPA
+NTVEIRVRSIGLNFRDVLNVMGLYPGDPGPPGGDCSGTVVAVGEGVKHIKVGDNVFGIAP
+GCLKTYVTTDSNLLCKIPNGFTFEQAAALPVVATTVEYSLRDIANIKKGDIVLVHAVTGG
+VGLMVVQYCKAIGAKVYGTAGSESKVEYALSNGVERVSSSRNADKFKEDMKDLEGKVDIV
+INSLIEDFIPNSLNLLKKGGCFVELGKRGIWTEEEMKEKRPDIKYKCVAVDVMMEEDPAW
+FGGMLKRIKNLVEEGIIESLPLKVFDMRGSDENGIDAFRYMQRAQHIGKVIIKIPTPFKY
+LELDMENHKLNNVGSEKEDRYNSEYGIHVITGGLGGIGRIIIKWMLEEGVRKIAILSRSA
+NNDSLRDIPEIKDYLNTDIIQIECIKCDVSILSQVENAFREILVKFGETNQIHGIFHAAG
+ILMDGAIASQTMEMMESVYAPKVYGAWNLHECCEKFELNKNLKHFVMFSSVASLLGNFGQ
+TNYSAANSCLDSLVEYRRNKGMCGTSIQWGPWIEQGMAANLKQHLEKVGMYGISNELGIR
+VLNDILCFVSKSSPVIGCQSLKWDTFMRRYNTIPTFLSEVDYSSQGRSQGRVDISKLSDE
+ELVVVIAQVAQQCASSPTLPSPDTVLLDLGLDSLGAVEFRNSVLEMTGVKLPQTLVFENP
+TIYAISMYVRDQNSGNSTKSDSKKHSQASNEQGKITIEQWLLSSLKQSERYILYAEAFEK
+KYQTISNLITETDIISALEELGVENNQDYDLLYVSWNELISSEEENSKKQNDSNNKKLEQ
+ELIFDPIADVEEIRNSMKLNLDGILTTTDPSEFKTALLTGVTGFVGRILLVKLIEEFKNM
+QIVCLVRASSPEKGLERIINVCEEAEVWNPTYASRIIVECGNFEEEYLGLSEERYYELCK
+EIDVVYHIGGDVNLLSNYKRLRKANTLSLVGIINFCTTIKLKHLHFSSTLGQFPAFFAVF
+TREFENAVVKETEGPSTREMSRVFPPTRQGYPWSKWAAEQILETAHQQGLPLSIYRLPNT
+YIASDTGYTNKTDYATALLIASILEGMFPIGSSTAPLTPVNTICEIIISASKKKERKHWR
+YNLLDTRILGKKHVEAWASQLGLGNYKGVAIDEFFSAIKSRGPESPIFKFVPLMQYWRHY
+WFDNTERTQPFPVDTSNVSEDMPEISWPPLETTFQNSFLYCAKRGYFPSNSSSISFTPIK
+CYSDALNEIKAELSLRNVNFNQNKYDFICRKMQKNADSIYDSLKKVSLNFCAKYSYYILL
+KQSIVNQYILQESLNDSILEKFKMMDCYFITGTSFEEILELRRIIRKLLNNYNELKFVDI
+TCPYLPTKNSRRLILEQLKIATSILPLKRFEAMDLDEILTDDSILLEMFMFAPFTLPLIY
+GKECFEEYKNKITGCSEVMEAYSSFKNYIIQTLIKNNYNTEYPIIFSSPFHLPFVKEILQ
+IFENSKVIVVDNKPDNSTIQGKLSMVKSLKSKYTNLDVSEEENSEIYLLDILEEMKHRFA
+INEPSIDKNRLIYLKDFGEIHNEKISVQLQDFCFTSIDSRF
+>gnl|md5|1205d9ade90e8661cbd9b6f1de81fad2
+MKVNILYSVTGELISVEIHEETTVEVLKSLIEIELNLDSFKNYELSIEGKILQNDGFVLS
+DIVNEGSIFVLSEKTNKNTFENSNFSLNDQENLIQLLSKELFTKIKEDQSLKSVYYSKSS
+KYRDSIDKDDIKSFTELIKNDYFSGNLNSIPSSSNSSSNLYNLDPLSPEYQRLIEEQVRK
+QNVEENLILAQDHLPESFTQVHMLYINAEVNGISIKAFVDSGAQTTIMSKKCAEKCNLVR
+LIDYRFSGIAQGVGTSKIVGKIHVAQMKIGNSFFPFSITVLEESHVDFLFGLDLLKRYQC
+CIDLHQNALIIGDEKVQFLSESEINSEISRIDPNNEYDQCFEQGKKLQLLSLGFSESQVI
+NALRATNGNTELAASLLFSNETFE
+>gnl|md5|86d1a618394f1f5e6f14383c087eef8e
+MTSVGSGYDSSVSTFSPDGRVFQVEYANKAVDNSGTTIAMIYNSGIVFAVDKYVASKMMV
+AGTNRRVFAIDNQIGCCVAGFVTDSNKIISIARSESLNYQKIYGNSIPIRVLAERIAMYM
+HNFTLYGSVRPFGCSILLGGLDQDRGVELYCIHPSGSCYKYCAMAVGKGRQFARTDLEKL
+IEKNLSEEDALYEAARVIIQSREEGASKNLELEMAFIGPGSDFQFSIIPEKQINLLNERV
+EKYIDDLASAE
+>gnl|md5|332b7a1fd0535dbeb4f77c8779dd979d
+MPIREVNVNRQTISIKGRIIQKSSLQILKSGLRFFHLDIIDKDNDVIRVKFWRQKAEEYH
+NILQHGSVYILKCTGNDVVVSNTKFNDTSNPYEINFSDRCFVRKVENDDDSIGKAPKYVF
+STVKDIREIPVPSIVDLIGIVRHFSPSTKVISRKNNDEVSRRTISVVDKTGFLINITLWG
+ELAEVSDEKFLGNPVVALKSIQIREYQGRQGSTLNGRSNMEFSIDDGKMEELRDWYDSIG
+SSIKFESISNISSNESPNNFRVNDKLYSGRTLKDIRNRMEDNEFSSTQSFQVIARISKIG
+SINVNQQVSGDKGGSLTYDACPICKKKVLFSTSYCEKCDESVVPETKFLFPVTIEDHTCS
+LTVQCFHEIGSTFIKELSASACKEMEQNNDKKLNFILNLQCMWRHYNLKIQLKAEEYNNQ
+KKTRAIIQSAEPIDLNQISYLMLESISQSILGKTNKRYLFEDNVNTNKRISVG
+>gnl|md5|ef34dadf9a6f9f677302d47ef727479f
+MSISKRIQKETMNLANDPSPGINAEPDEDNYRYFKIMMMGPEGTPYEGGSYKLELFLPEH
+YPMEPPKVRFLTKIYHPNIDKLGRICLDILKDKWSPALQIRTVLLSIQALLSSPEPNDPL
+DTVVADHFKNNILDAESTAREWNRLYAKGS
+>gnl|md5|8dd7c7ac8e57a54b454129d25f1124af
+MEKLSSWLHERTKRRRDMRKKIKNLWNEEVSLNGEQDKDISSVENIIGYFKDKRRPSFER
+DLSLSEDTASMSPNSDVGCDNEEKIEDDHLFGPSPSDIKQTAINQNLNYGAALLYGEGEA
+MAQFVQAGKRIPRRGEVGLTGEQIESFEKVGYVMSGSMHKRMTAVRIRKENQVYTAEERR
+NIALQNEKQRMLKESQLLGELRELIKREEKKL
+>gnl|md5|809bf51b633a17c63b5ddad8245f8e6d
+MLSAIQGYHSAAKSRMEQDLVSKVQRHPGIPSSHLSLDLLMNMDDKIEVSDILGTEKPID
+PLGKKTISDTLESIFNINS
+>gnl|md5|1c326e33f7061f3187e63cb7a4a7d089
+MSELEALSNQSTERGVVQENSTEKMDATENLNEISVDNNAAIELLNVNLQDMFANSFIGA
+NVVNATRMQETIGESWPFDQYQATGLLPVDYAYWLTPYNTSIGPTAFVMMQATATFPDGT
+QMDAQQARARRRRHVFGVCC
+>gnl|md5|0ff8e6e2dcb91b7c6e23503dd19cee7f
+MGDYIPIEIEPKRRALYSEILSNNRYLYSNSGNENETIKNLEFRIFNGETSLFITTGNKL
+KTVSPIKINEENSSKLTSFNSKNLITATTLRKDGRLCGISMENNECIALDTETMTVVRRF
+EKSSEQLSSIAFSCDKSKIISGTLTGKVSILEVSSGEIVFTAPAHNDMIRCILPLENKLF
+SYPNHDSSIINTLNIYFATCSYDFNIKIWCFSELKQAENYAASNASPNKYQLKVMKTLKH
+NFPVECIDIINENKLISCGGTCIKIWDLEKTEFECIHSIANFARTITTISSNENIFAVGC
+LDHNVCIYDSKTFEFIRSFNYNKGIVKVATSNCSSYIAIALEDGSWSIRKKVSSEIKETT
+RDVANEDINNLRKGYRTGTIRYYKRGRAVSANAMDIEIKNCKKRQTKLDRLLRSYSYKKA
+LEIALKMSWPHFISLLKLLSSRGALHLIARENEYEKTIKLLKYISKNMGKCGPYQFILIS
+ELIEHILHESNIVRLLNQNKSVENKNEIFECIKKISQKVSLETKQHVLLKEFKIAVEIII
+QNCKKCLVN
+>gnl|md5|bfc72a5caa3d3292eadb6fce9233ac49
+MEFTKLVSKPSFKLDLDKINYKFEAGNKNSNSCKANGNRGKHSLECGNSCGTIYLEDDDS
+QILEQLKRIEEENIRLREINEQLSRSLCISTRSISINNNNNSFQIDDFSRQSSFLSSQAL
+TTRSISMNPQIVKNLKMTVSDIIGDRSEIALRVMLLEDEYFLGLEPILDRQSARVVLSKT
+PSYWSIKKIPHFWEGFSNIMSSVIKKGFLNTISYWSFLRAPPSPKKNVKKWEGITIKYKG
+PLKEFRGYSLAGNDDGLFVYLESEEDAYDNIFYCNFRKKKEKCTEDFRDCTNDLRTNVLN
+LLHANTRSFICIEPNIKSKGGNIMIKLSESKKNKLMFEEISASELLARQLLISAEQISQD
+FDLTNRNIHQMTSFPSFRNYEQNFQKTSSNRYSPEESFRSRTVELCSSVETQNKDKRGSL
+ADELSNELLTQRNQLLSNFFGETNHSKYTLSDSIGFKEEIPHNNSSKIIDTNLGENSKIC
+SPRIRASNVINDQLSGLEYHEVPLTRRLNVVYIPSTTAVLVHDLVDSEEELNNNIDSGKI
+SDVEQEYFKVE
+>gnl|md5|c29acd00cef1ecbaee82b890937ee01e
+MYWDKYDEIPLRWISFFLFKWRLELDESFIGGPLLDDFFEKIGSIFYLLLLKRYETTFCD
+IDTTEVDINLFIDRLPKVLILIGNSGSGKRYFARELLSSFSKICYFENSKSFNPVTFNIL
+IDEYFIDTRTADCFDKKIYYLNNKLTSISKVGVRLRDSLCSGSFSPPAILVCFRSANPNK
+YYTGPNSNYYGDVSKQIVILNLISKFIRIWDDKNIPIVSFFISDIDPDDYGASNKILQSK
+TLDIKYIFKYGYGEFFEIDFRNSSLQIDKISLLRFLIYKRYDINEISLNYLMEKISSIHS
+KYIRALSNEELKFIVNEIDLARISDILNEELHDIPYTVSCGRFIAIVLNGVIPDFFNVFL
+HYFNFVIRRLNKSVSNSNCAICDLSCDRESGSCKNGLIQMIGFGEAIHKVKNLLLPCISY
+PEISNFQLPIVFNEASGIIVFGARG
+>gnl|md5|5e2a02507e73a280c655923af052715c
+MSGLASSPSIGKTILFEKNNDWGLNFDLGELEIYENQDLKTRLKELISPFENTFSSVSTL
+EYLHPFTLKFRSEILEKKFEKKFRKRTEIGIFWIGLLTLFLIILDILLEVYNQKVNEVSN
+SSVTAYFIICGVVAICSLFLIISFFVNFLNKHLEVIFTSTTIITTILNITAGNLLLDVSL
+SPNNNYDPAVQNSRSLIVITICSILHFMLPISFMSILIYSITSISFYIILVPSMLMPIPN
+ETQYVSTTIYLFVFCSVCILAKRVNVSSSRRDFFNINLVKAEMQILENSMNQTPKSTMIE
+GTLANINKVQLFLRYLNTSCTKGINRKMLHDAMVDLTSAQVTLCRSDDIYAVDPVAIFLP
+QSLQSNVPQTPRQSKVRIIGSGDVTPKENCSPTASQKIKQELGISYDVRIPISPNSPKSM
+GQFLSPKSHENKSSYISVDSISARRNTESRATVTSIPGPSRRRLSMMIATAGENSSTLID
+PSVEKVREYITAEFTKSSASRREVLYASKVFDGPTANPSNTNEKIKTTSQNLDTNHIVES
+MISRQGPLDEPVVGGDIEDNYRHLLKNKRKIAHFATHLASKLISIKDPSGTISLLSQSYF
+NETNPHNFTLPELPKGVSTELYSDLDRALQLMDNQYSSNWDLDMWRLNELTKGNCLSVAG
+LYMLHLIASEEKNQEAGFDSSNLPRGITTAYSSSITAPSKLIGNISKFNIFFRELNIRYL
+NNKYHNELHGTNVCHLAICLSRATGLWSHLDTVERLASVIASLGHDVGHIGRTSNFLVNS
+RHMLAINYNDRSVLEMFHASLTFRIIYYYGGGAADFLQSWDAELHKEFRRIVIELILETD
+MHRHFECVSRFRVRRQAVDWDPYGDAQDRLMLARTCLKAADIGHGALKWNQHYKWCRSVV
+EEFFLQGDEEKALSLPISPICDRESTDVPKSQVGFLNFVCLPLFQELCYVDVEGDVRRCI
+DRILENINNWEDIAEAGIQWDSEDALTFVSDEKADLQ
+>gnl|md5|50eef3cbee550c2504d1f568688a6d3b
+MNHIFLIVFTIILSTKNFSILVFIIPIILFIIFIMDSSAFRKFLIWTIFLVILLNFCFYK
+KKRNYYTCILSKMAMKARYFLIDIANILHSKHLIYSLGFDISKAKNSASIWNSVLGNEIF
+CRNKQYFSAEINNFCNKLSLDGFDQVSKQYKIIKSIPILQWISWVEIKIEKNMCNYNGKN
+FYEIFTENLFHLFRDDRCLKSTMLKHLLIGLLSPLILALSLTFL
+>gnl|md5|616a5328f50674614e5015408dcd4ae7
+MNILILEVTKNVMKRTTKVNAINKGHKFVYLGSDKLEQSNKELPILSNKCTTKSIIGAVI
+EIKHAIRIIPISRILLSFDICANIPTENDINIRIIGTK
+>gnl|md5|fdca4e71e94d7132b390f957c7d70d26
+MAKGTFQSFGFSPKLLESIKIIGYSLPTPIQRKCFPSILAGRDVVAMARTGSGKTAGFVL
+PMIERLGCSHSQIVGIRGVVLSPTRELALQTYRVVRKLACKTNLVVCALTGGSSLDRQFE
+SLSGNPDIVVATPGRLFHHIIEAGLSLIAVKIIILDEADRLFEMGLASQIEKILESIPKN
+RQCVLVSATMPTALASFSKVMLNEPEVIQIDSDYILSETLKLTFLFVREDEKLASLLYLL
+RNTIPSHERAIIFCATKHHVDYIVKILESNNIIVSYIYGNMDQEARTMHLSTFRKNKSRA
+LVVTDIAARGVDIPMIKYVINFDFPLSPKLFVHRTGRTARAGQHGRAFSLITSRDLPYTI
+DLCLFLGLKMTTLTSKQTTDSSNDSLNTEKRVEASIRDDDIHEEGISFIKPASLNDFHVE
+SRLILASFPDLTLEIESIERVLTENSEIERCRRSMESAYLLYLKTRTPSSKESLKRSREL
+LEKCGGASKILMSIHPDLNIDTNETNLNIVTLQNLGVISDPLLDHLKLFRPTENKTHNKY
+GCLNQVTGKMVLKSSIKMKKIKDMGNVVKSILSEDKFAIGTSISESQNGISDEISSNNNI
+SQTFVNKKRKPKKPCNRVKESEHFFIPYKNSEEEVSRSTGLQLESSSFDINPDEEGEMKR
+QKCVRKWNSKRKRYELIDISKQNSIKKFNESGIKVKGELKCTGQYKKWKANTNLKIQNVG
+EIEDIELNKTIRSNRFKDKYNTSDINSSFDYSNVHDKHKGIIEAISKGIKLTHKQKRIAK
+RIGIIKEKIVNESKSLKNEIRTPQQILKKRANDVKQRMKNEIDNRRKQLAKKNKEFAEKN
+FKKVIQKGRPNRSKVVLVKSVGSIELFR
+>gnl|md5|9aef09c9e0751a73de9595f1c6192d89
+MQNKDGGFGKRYKDESHAGYTFCAVSSIAIIKEITKNNSIDLLFNFNRLNRWLLKRIIAS
+ESHENTKYQSYCFNGRIGKKCDVCYSWWVFASLKIVKNIIINRNMDCSSIINSKILKILI
+NGILCHQNNIYGGFQKSPFNADNKDHSDPLHTFLSISALSLIFNSDSEKSSLEFYEPTEP
+FEVFEPLIKIDPISVISEKYLNKTI
+>gnl|md5|222d8dcab403148d433874fef23f898f
+MLGGGGFGSNQNQQSSGGLFGTSSSFGVGIGQQGVSQSINTVQPASTGLFNSSTSLFGGN
+ASPGLFGSTGSSNSGFGNTGQSSVFGQSSNGLFGQSMSTFGGNQQISSTQPTMFGSSS
+>gnl|md5|9c43f7b287701f87e676a6b9a4c2d47d
+MNYLSMAINKLFLLLNRPEKKLTSFGSWAIITGASDGIGKAMAKELFEEDLNLILIGRNR
+EKLQNVVNEVSFKYASKMLILALVAILEKTRFKSRSKILFNGFY
+>gnl|md5|9fbfd163568e08e00e8c5ccd2798c8ef
+MSKQEGLENVDDFCISESISNSEVVTKYYTAAEIVNSTLQYVITLCLDGADISEICRKSD
+SMIEEKSSSVYNKKEGGRKLDKGIAFPTCISVNEICGNFSPLPAESLKLKNGDLIKIDLG
+AHIDGFISICSHSIVIGAERISGKQADVLKAANTAMEVAIRTVKPGNTNTYVTSILNKTV
+KEFNCNMVQGVLSHQLKRHVIDGNRVIISKETLDEKVDEFTFEENEVYGLDILVSSGEGV
+TRESDYRSTVFKRAIETNYNLKSPIPRQFLSEVNKRFPTLPFSLNMISDEKVARLGVSEC
+IRHNLLYSYPVITERQGEYVASFKCTLLLLPNGSKRISGLQFTQENICDSEFKVTDEEIN
+SILSTPLSVKKKKKNKPIVSS
+>gnl|md5|b56103cdc6b1dea59668f4840eb3136d
+MITSLVPHLCVDLLEAELPEESTSYSLLERPTSSNIDRIIDDLELDSNINSENIVMDLLS
+REFFDSLFNLMEEFEQNSDLIGLHKIFQVLRRIIVFYSSFNEVFEILLSDDYYLKFFKAC
+EYDETLENYKIKFSHKKFLENVKFHSVVPLPEVRTIHLNYRLMYLRDVVMPRHLDEQSLQ
+RIATIINNNFSSIISMIVTTSDIWKYLKENIQKNFLVAKFIHAVLTVLKQNPMLSIYERH
+QIFINLKVNNILCEFCGYLNENCIGARQMLELSTSNDDHKNFSNTNDLSFINYSNIRPID
+LAVEIYSMVCEINPGLLRHAIHESTSQYFKAHKETNIYGSNVNDILYADDGLQNSPKESI
+KETENLSDKSNVFHSLWGTLCEIFINSRSESIQMQICAIFKRILDPKTMDVPERDDSLSL
+FYDMGILDRLIDSLLNDSLIFTEFNPLYSARVLFCDILATCVQEHNYRIKYKILQNQLPR
+KLLRIATRPFHKIFSISVIKFLRTCLGTRDDFYYRLFTKHDIFKYIFLIMGQLKVPRNRG
+EGSILESVVIEMLDFICRNNIQLILKYLLENYIVVICNLNLKASRGSKCRVFSRMLESFK
+LISKSTQSLNNCKRNGSNILSSNTHSGLTS
+>gnl|md5|b8e9bef8277d12027b731d0c38502cb4
+MAFSELESIKNISIPEHKAYCFNAWPLEYRRVKLYEVNPENGNWIDCGTGFLKLNKDNNK
+FNILVSLI
+>gnl|md5|7d0052e5852fd3b4e9abf6f1cb838e98
+MESNDPKLFVSTFTDYIERQMDIIRQRKFTDLKLHSIKNIIFLSQFKQTTFILTQTPSFI
+KSSNTNQGTKVSSGLIQQQNSLLGCIISPNPIDKDFKTNVNPTIMKYFSGLLSKTHSYIN
+QSKMLIKQDLSLVYEHSTLVIKNMLKASTECRRMVIKWMGIICTSNEDKSKIYNSIPDLS
+MFGNMQNSREIQHNLRSLIMRTSGLSTSGFSINYLHIVLRLLQPVKIEKVSELDCFFHIY
+GRFDQFNDICNEVHNLLGDLVNDATLGEKDQVEIALNLAKKKLSDLNQINLKYQDFIKFP
+TQIFWISCKSIKCFMQPVLLEYESILNDLNEYRSGLTSGHKYKNDHHLEQLSCEALSFEC
+AIFHQNTISAFWHFLSLFIQFIFRTIYSFDENGVENCDRNTLLASKQGRITVALKSTAPS
+SKPSPQFSSLPSCLIEDVLSVTELLLRIKGNDEILIGFDFDSYISFVIFIINYGNYFRNP
+HIRCQRGVIGIHYLLQIPQFRHRIEASDFTAEYILPALISLFNDVQKSPYYDRFSLRLPI
+IMLFESLLKVDLHRERLHKFIKQRDESFTKFIHLLVSDLNYLLEEGLSMLAEIKKRESKR
+NQVPNAISINNNEFSNSNNESRSSNHEEIESTIEEMPIERLEHACKGYMQLSHASASLLQ
+KITEYYTFEILDSPLILPQIVTCLNCTLDRLVGPKCLELKVSNFDAYNFNPRQLLANVCM
+TYVTLAFNSKVEYKPMEKDFSKILILEIINEQRYFKIHTFVKAHHIARREGLMNKSKSDC
+FNQLIKYLQKELEENEVGQSMTNIDETDIPEEFLDPIMQDIMQDPVLLPTSSKIMDRKVI
+ERILISDGVDPFNRLPLTKDELIPQTCLKDRIKLFLENKNDS
+>gnl|md5|3dfc639fb47b57a226a6077ceda67cc2
+MSVNKNILFPCMKKAECNIFCPNEVLRENINSYGSIEIMDKISIFHIPSPQNNQKPKKIF
+VTRKECCKLLDISIDEYLFINQNLCGLKPIIKCTGKIIIKMSVTSVIIACKDVWILNPEN
+SKTLEIIERLLECTGYNISVDNNTPSTKVSFADGISKEFISPLVENYNYNSGLEFTRNNF
+EETEHVLSSSILSTFTDINTLDNSHEYKRQESIECSISSATQEKNIDIYNYRFIPTINKD
+YYSHSFAAVCIEIGLEVLNKELIESINCTKNEVLKSCNILIKSSKWYKYPWRFTFSDFTN
+KKMISKSVNVSFFL
+>gnl|md5|e82659c6b24f2b450b72a1dd254e44c1
+MSLQIMDQDFQHILRIMNTNVDGRQKIMYALTAIKGIGRRFSNIVCKKADVNLSKRAGQL
+SQEEINRIVAIVANPLQFNIPSYMLNRQKDVKDGKYKHITSNNLEASLREDLERLKKIRS
+HRGLRHHWGVRVRGQHTKTTGRGSRAAAAAKKR
+>gnl|md5|f0bb48be92708285ba39a225672568fb
+MDQELRLSNGTNTHHIELSIYLGSISVTISDDNQINCRFFSLTVDIEPSFNLENSLQEIN
+TQTQNIFDYNDSEIDDCEKTQFRTSWYEITDAPLHAAYGIFSSEINGIIKECNINQDICL
+NLKLPIWVSSMAKQFYNAYNQIGFENFLLTVLQLRITIWATKNSTIESAEIFEVGEAIIK
+VSEDHILSKNSFYFIHRIPEHDAFAIKEYSGNDKECTIGILKCFFNSRPVIIKNINHNLI
+DICKNNAKPCDFSKKNFELIQKLRISQENILMQLHDIVPLKWEYLDDNNVIRGPYNSIVM
+MSWIVKGYFGENSKLRLFDFGQECIIESTTPRCLQKFQPLSNYLSLIKSDVSRIFRCSSN
+DLINSGLIVKEPNNENMNLHTVEMINESSAREENVRFIQKSQESKRIEIENAVNMLKTQF
+SHIEKEFQNKFRRKVQNKSVDNNFSSEATNISKDEFIKFATKNVFRQKNNALFKKWCAEY
+GPELVLEACAIRIQTAFRKYIKRRYFNVK
+>gnl|md5|3e1607e267a0f68fa33fa4d07c262b9b
+MNTIRPNYGFINSSFPKTCIQSVFRTSRGICKVNFKHYIKLYRINNPTGFWLLFIPTFGS
+LTLASNSLLPKANITALFALGSVASRSAGCVINDLVDRQFDSKVVCHAFFIHYHLLSG
+>gnl|md5|ce2c6003c1997f3949230f3db2308e1f
+MTPANNVPVVDNWEDLLNSDNEDSFNNSEFQTNSNNITSTSISNKCFNDYEEQRRCQELV
+EEMDGNVMDDLFDGFVSQRKSTSKLPGNNSTHAISNLSNQQDAFSNLNLNSYGKVETTAF
+KIAECIKPALAKSPAWLRFIDICLNEIFQKIDLKDLKTLKKKVDLQLSVREKEEREKSQQ
+KKKPNDFGTLSKNFREELDIFDGIDSLDESDDY
+>gnl|md5|97e88181eed221e4318d9725159801bd
+MRQDLICRKIAHLKVDAEASIRNSSSKIERILNDGLPIFSDEVGSFSSNAEKFYISTSNR
+EMENTTIAVKNYLNNAKWDLVNKYYINVLKNLDSLTNIIFCIQKNYFDNIQYINISQSYN
+MGSSIDNITTRSLRINEASKGELLISLYRRLYILRPFIEKINNEILRIPDHIITHKCALS
+TLNELLPIWKISINSQAKNESQCLYNRENKLSSVICLQLPLENIFFKQGSFVSRPMAQID
+NNSLFNDVLVTLFFSKNKFNPYGGKYNLRASLKLPEFTSYLINNNYQLYVKTKPSGSESK
+NITSSTLPQVDFPSCIKSALAKQIHSTLHRVHWALIDRLIFHTIVQQVVNAQKDSPEAIY
+INELSSERVIFSINEASPSISFSHDNSGLEVKNISVSYKPISVENCFLSNDELNALKLLR
+ESFLEIWRNSIKLNTDNLLENQMCVIKLSKYSNKLLERWIHKLAKKCINISATSL
+>gnl|md5|1af7e6368b954eca90a2be0b532020d7
+MKSFFRKSLNPIHNTKSEASQQIKSSLVAINYLSINIDLSSIIFSSGYTPSRLDILNKGF
+LLLYYTDPYTATMAAWFFEIQGIPAATISGWSLIRICGPITLDEVTEIISFKPFAITFFN
+YKVKYSWIAVHGIHTKQLLLKYIRNQNWNIVEALHNRNFQDVVEVLEIFNNEEVPNCYNK
+LEYMFVSLLEKKSYNIENPDQYRLHQKLVLLSRCSRLTNEIYLNGVYMRNTHESFQSPIK
+RDLLLAIRKYLYSIPIFTEACISKSSLKSLKTEEWCLGLDEKPIYRRENGCFNDCIETNN
+NYKAQSNHSVSRNKLLERMLRVILIELITHFRAKYNNSKYPNITEVSELWKIRFGIEVDI
+IQLFKMAGLYEEIKNIVEATKEIKITRD
+>gnl|md5|e7969008cba918e88ae0ea6428c8715c
+MFFDKRILALLMNPFRRNIKRNSFNINTFNRKCFDLFRNKDSFRFNYTIFSISISFAFLA
+KYYFQNIRKQLNMKAISSDEIEILSSKSKNMIVLNLIKGMEINKSNFIKELIKQIKSKEL
+NRLNIQIYYTENTCSESTPNVTLFKGYGSRISNIDLNFKNNNNIEQIKSFFGPKSEKIIN
+GNSSTIKNISYDTFESDVINKSDENNPLLLMYYDDYCLMCFLIRPLINSLAARLRNTKNI
+QFGRYNIGRNDLHEFSPPVKATPSFVLFRGSQEPERLDEYKPKDIIKKIIEIKCKVENND
+CGKNELAELSTLEQKVLIRFHLFIVLSIWNLYLKELQGKLINTPKSQFCELNFMHLEELL
+SISCLFLQDQNVSSKNSKSFDEINFEKISYDKIAENINFQEIFLENIKKDMKRSDTIEEN
+INHLLNEIEGCCNDYITMKKLIKK
+>gnl|md5|5a0922bad777db34a064b76637fdd57f
+MSRELLIPRERFEVTSEQKFTNYAAGENFDNIKSEDWVIISGFPRHLISLIRPKLEYEIG
+PIDHWINGYVKEGHDIYFVSFRNNKILQKSLQFNETMVFGNLILICPCFDNISTEISKIE
+EVAIPKEEYYNHSNIKIQIC
+>gnl|md5|3c21d30d6cf0a8d99cb2b016560fc6ea
+MASNIFQTRSWNDHLNNQNILKGKFSSSERDIINNSVRDYIKSQQWNWDEGLDNLFSTRG
+GKKDRHWPIIGESLPNRSLQSIYYCAKRMLMRGKKGKWTKEEEQELIKLVNEHGKKWSMF
+VEFIGRSAASIRDKWRDLHTKIVENDSNDSGYILNLNSQIEKPLKSKMPFVIDVFVLYCI
+ERYTGKFLPFKGISWKTIIESLCSPNFPTEFIYFWKKCCRKINEKLGINLQPIDGTDLSN
+FYGKISQGQIRLRYVSSLYPKLKYVQDEQALSLISNTFSQAVNYLYETRYNYSHIDEIKY
+NDWPKLLSAHIPLTTLWSRIRLALTRITKKNMHISDRISILYERLKNKQLQCQVLGSIDS
+TESKFLFEDDEYYTNGNMDGCPYFHVDTKRLRKTVVKLLKAQSKREKKSKNAARLQKEYS
+SLQQVFQSGNYIT
+>gnl|md5|a91c5485d8e0c9de6c0f9c1197d18689
+MNKVFRSDNLIETSSQNSSKHSFSLQLSDYFRLLIDRSIEIRNWRRGEKYCTVLQLIKPL
+EICDTLRWCECLFNLADYSAVIRISQNMLIENVNGYCPDKIKIFIFRSKSEFFMGKYSNS
+IETSNLILETIKHGLNMEPDVKKKLLLKQLRVRVLLIKARIFALNNMFDQCDKIYTGILL
+EDDPMNIVSLEMVFFSHKFTLNEKIEIFKKWKHFIPKSYYWILIIVWYRIMHDYSRMIDC
+YNGDFKEDLISFSLDSKISLNQLLMNIPVYSKKMVFLKDKIFSLTNLSNNNSLKTQIFDV
+SSHLDCETHIIMQMISAIYDSGYILTVSNILDEKIPSSPLSIFTMGCYYYKQLAYSKSAH
+LFRKVIEIEPGFYEAHLLLAHSLSLNNNSKQAIIVYSHIQDQWRGSCYGTLYKGVEYLKS
+NNYDMASLNLRSSLTQFPDNPIVLNEFGVLQFYQKKFYESEETFRKALHKLHINKSNYLK
+YVLEINMSCSIIWSILYCEEIVCKPRVVEAISILERCNKINNSANKVYLISFLLAVAYQI
+SGEKNKASLKYLECVSLGIFHPITLKSLHTICS
+>gnl|md5|57041f816beb10598d00f6011b9e3220
+MNAYLNAYFSEKSTNGFLFENNIATAPCLSGSTEPKTVKTGTTIVGVACNDCVVLGADTR
+ATNGPIVADKDCEKIHRLSDNIFAAGAGTAADLDHVTSLIEGNLELQKLQMNRKPRVAHA
+VSMLSDHLYKYQGYVGAHLIVAGSDSTGNFVFQVSANGCIMQLPFTSMGSGSLCARSILE
+ARYRDGLTESECVELVSDAIRAGIYNDLYSGSNVNILIIKNNYVKHFRHFDTKASERIYR
+QPKPISFPVGTTPIIAEKTEDLSSFVVEVSEVQIDENMD
+>gnl|md5|b25117f139f8cba01f78f75dd65435c3
+MARTKQTARKSTGGKAPRKQLASKGARKSAPVTGGVKKPRRYRPGTVALREIRRFQRSTE
+LLIRKLPFQRLVREIAQDFKTDLRFQSQAVMALQEAAEAYLVGLFEDTNLCAIHAHRVTI
+MPKDIQLARRIRGER
+>gnl|md5|3ece12fca46252c5d2970aa28b23414a
+MSLDVPINSTEPTKEGRFLSVLDQECIDIKLLQDLLWSGVPRGSPPELRRDAWQIMLGYL
+PPRKDRKNSYKLKKINEYRLLLKEHIEHDNYSEQEKKILRQIRVDLPRTSIEYESLKNQI
+ILDLMERVLFLWAIRNPASGYVQGINDLLPPFLVVFLLPLSPVGDIELLDINKISSERMF
+EIEVEIYWCLTRMLDTLQENYVTEQPGIHKLIVHLQDIIKRTNKPLFQHLKEQGVDFLQF
+SFRWMNCLLTREFPTKCVVRLWDTYIAENTLNKTNKPLRSSSITSLDQIPTGNNVISHFN
+AFHVYVCAAFLLHWEKELRNMEFSEIMLFLQNSPTKNWTERDIDSLLAQAFVLQSLFHFS
+PRHLIDYSN
Added: SwiftApps/Blast/v2/run2.sh
--- SwiftApps/Blast/v2/run2.sh	                        (rev 0)
+++ SwiftApps/Blast/v2/run2.sh	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1 @@
+swift -sites.file sites.local.xml -config cf -tc.file apps blast2.swift
Property changes on: SwiftApps/Blast/v2/run2.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/Blast/v2/sequence.seq
--- SwiftApps/Blast/v2/sequence.seq	                        (rev 0)
+++ SwiftApps/Blast/v2/sequence.seq	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,106 @@
+>gnl|md5|e0785fc0b8720a5c4d78be370ef19af0
+MEVLESGEQGVLQWDRKLSELSEPGDGEALMYHTHFSELLDEFSQNVLGQLLNDPFLSEK
+SVSMEVEPSPTSPAPLIQAEHSYSLCEEPRAQSPFTHITSDSFNDDEVESEKWYLSTDFP
+STSIKTEPITDEPPPGLVPSVTLTITAISTPLEKEEPPLEMNTGVDSSCQTIIPKIKLEP
+HEVDQFLNFSPKEAPVDHLHLPPTPPSSHGSDSEGSLSPNPRLHPFSLPQTHSPSRAAPR
+APSALSSSPLLTAPHKLQGSGPLVLTEEEKRTLIAEGYPIPTKLPLSKSEEKALKKIRRK
+IKNKISAQESRRKKKEYMDSLEKKVESCSTENLELRKKVEVLENTNRTLLQQLQKLQTLV
+MGKVSRTCKLAGTQTGTCLMVVVLCFAVAFGSFFQGYGPYPSATKMALPSQHSLQEPYTA
+SVVRSRNLLIYEEHSPPEESSSPGSAGELGGWDRGSSLLRVSGLESRPDVDLPHFIISNE
+TSLEKSVLLELQQHLVSAKLEGNETLKVVELDRRVNTTF
+>gnl|md5|f67549f249c59ecd0b48ff02ca209442
+MAEETRQSKLAIAKEKLKEYWQRNSLGVPAGVKRNRKTSGSSPETATSGGCHSPEDSATG
+IHGEGPTSSATLKDLESPCQELAVVLDSRSIKISQLNNTIKSLVIMANILVFVFPKCIVI
+DLNRNVDTEISKMSMG
+>gnl|md5|cd0de5548a14c880425dc87f8486310c
+MNSGAMRIHSKGHFQGGIQVKNEKNRPSLKSLKTDNRPEKSKCKPLWGKVFYLDLPSVTI
+SEKLQKDIKDLGGRVEEFLSKDISYLISNKKEAKFAQTLGRISPVPSPESAYTAETTSPH
+PSHDGSSFKSPDTVCLSRGKLLVEKAIKDHDFIPSNSILSNALSWGVKILHIDDIRYYIE
+QKKKELYLLKKSSTSVRDGGKRVGSGAQKTRTGRLKKPFVKVEDMSQLYRPFYLQLTNMP
+FINYSIQKPCSPFDVDKPSSMQKQTQVKLRIQTDGDKYGGTSIQLQLKEKKKKGYCECCL
+QKYEDLETHLLSEQHRNFAQSNQYQVVDDIVSKLVFDFVEYEKDTPKKKRIKYSVGSLSP
+VSASVLKKTEQKEKVELQHISQKDCQEDDTTVKEQNFLYKETQETEKKLLFISEPIPHPS
+NELRGLNEKMSNKCSMLSTAEDDIRQNFTQLPLHKNKQECILDISEHTLSENDLEELRVD
+HYKCNIQASVHVSDFSTDNSGSQPKQKSDTVLFPAKDLKEKDLHSIFTHDSGLITINSSQ
+EHLTVQAKAPFHTPPEEPNECDFKNMDSLPSGKIHRKVKILLGQNRKENLEPNAEFDKRT
+EFITQEENRICSSPVQSLPDLFQTSEEKSEFLGFTSYTEKSGICNVLDIWEEENSDNLLT
+AFFSSPSTSTFTGF
+>gnl|md5|c243d77c83c27dff598d70af18d8ed42
+MGAEQIRLEDRAQCAARQVLGGAGDGEGGVVHQRVDAPQGQRGFGAARHAVLAAQFQVQR
+VEALGAAGLDILGLAAGGDDAPAARPHVPRRVQPDARGTAGDQNGLHARLLAAGVLRQGR
+ALRKPRISGWTGAACGPIHRNMSDDPNVPDPTPPDPSQDQTTSEPLSRAIGERYLTYALS
+TIMNRALPDARDGLKPVHRRILFAMRELRLSPTGAFRKSAKISGDVMGNYHPHGDAAIYD
+AMARLAQPFAMRYPLVDGQGNFGNIDGDNPAASRYTEARLTAAAEALMEGLAENAVDFRP
+NYDGTLEEPIVLPAAFPNLLCNGASGIAVGMATNVPPHNLHEVIDACLHLIKAPDARDDT
+LVSIVPGPDFPTGGVLVESRETIAEAYRTGRGSLRLRARWSVEDLGRGQWQIVVTEIPYQ
+VQKSKLIERLAEVIQLKKVPILADVRDESAEDIRIVLEPRTRAVDAEQLMAALFRVSDLE
+VRFGLNMNVLIDGRVPKVCSLKEVLRAFLDHRREVLVRRSNHRLDKIAARLEVLEGYMIA
+FLNLDRVIEIIRHEDDPKAVMIAEFKLSDVQVEAILNMRLRALRRLEEIELRAEHENLTR
+EREGLAAMLADEGAQWARIAEELRETRAKFGKSASGGQRRTEIGEAGEVAEIDMDAMIER
+EPITVILSKMGWIRAMKGHQPLDAEVKFKDGDGPFMALHAETTDKLMVFAANGRFYTLPA
+NNLPGGRGMGEPLRLMIDLPNDAAVIDMFPWRDGERYLVASKAGDGFVVAGADILAQTRA
+GKQVLNGEAALCRRVTGDHVAVVGQNRKLLVFPLSELPEMARGKGVRLQKYKDGGLSDAV
+CITLAEGLRWQETGGRTRSEPDLTEWLGKRAGAGYMAPRGFPRDNRFN
+>gnl|md5|ccc28dbc1a3ca81c8dd929af669b1173
+MDRAERIGFWVSGFAHAGLLGAALVGGALFRPQPLEAVRMAEVATMSEAEFQSLAAAAAG
+RGPVSDVAATTPAQPRPPADENRLGEVEAVSPPAPDAQAAELSTPSDRPEARPDLSDFQT
+PNRPVAVATDAPRPAEPENTVELAAL
+>gnl|md5|9d3da0729b348bbcaba8c65c444b6fee
+MAGPAHGRAHRGAALMLEVAFRHRFPGLSLEVAFQAPGGVTALFGPSGCGKSTAINAIAG
+LLRPDQGRIALDGRVLFDGATNLSPQARRIGCVFQDARLFPHMTVAANLRYPSRWRRGAA
+RDFDRITEMLALGPLLHRRPGTLSGGERQRVAIGRALLSDPALLVMDEPLAALDEARKAE
+IMPWLERLRDQIRLPILYVSHSVPEVLRLATTVVLMRQGRVTHSGALADILADPELAPQL
+GAREAGALIRATVEAREADGLTRVATAGGPMLLPELDLAPGRVLRLRILAHEVILAREAP
+RGLSALNALPVAVTRIEGGLVQLALGHGAQHERMLAQVTPRSVKALELQPGTACHAIVKS
+VSVLPS
+>gnl|md5|4276fd81078276b607fce4cf16581984
+MPRRRSSCCPRSLAGRPVPRNTRQPSRGSTLPGSPRRWKSPRPHGRSISEGLARPGKGRT
+FIGRPSPSLNIWPGIAGIMPPLAVGSWVAAVEQTYAADAGMRRDEAIRSATPGAAFPIFA
+AQAHGLASCPMVGFDAERLAREFALAADEIPVLLVAVGHAAEGNRPQKPRLPVAQILTTL
+QQPEVDMPKPSDILLTALAPAVWGSTYIVATELLPGAPPLSVAAIRALPTGLILLLLVRQ
+LPKGDWLWRSFVLGALNFTVFWALLFVAAYRLPGGIAATVGAVQPLIVVFAASAVLGTRI
+RVLSVLAAVMGMAGVALLVLQDGAVPDMPGIAAALGGAFSMAFGTVLTRKWRPPVSALVL
+TAWQLTAGGLLLLPLALLLDPPMPPLDAANAAGMGYLVLFTALTYILWFRGVARLEPAAV
+SSLGFLSPLTAILLGWAILGQALSASQMIGAAVVVASIWLSQRATPSRQVHAR
+>gnl|md5|6803c5e1ab1272ec69688700d3c02e0e
+MKVYLANQPVDFRKGPDSQLSLVRDAGSDPFSFELEILAAHVLGEILKGPRVFADETGLP
+TLAPGTGTVNKAWLWAYARDDSTFGGSGPPMVPYRFEDSRSGECVHRHLGGYGGILQVDG
+YAAYNQLVRKDGGNAGPSLAECWAHSRRRFYELHTAGTVRSPPPRSSGWPISGSSNPRFV
+AKTPTFAPPRGRPSPPPPSPDCSPSGNRPCRASRANRSWPRPSAMPSPGATSSSDS
+>gnl|md5|c63587eb43399c568f1164527fc27358
+PFWATPFALAACTPEAPPPPEPETVSVDPCGAARYSHLIGQTSPTISVPEGQMYRIARED
+RPMTMEMIQDRLTFIVDSRGKLLSVSCS
+>gnl|md5|3f0af0be21624a9da7db4d62141deca1
+MSRHRGAKRCRRYGLLGIISLLSPAYLLSVERWPFHSGPPDHYGRLSSLLDLSVLQSGWL
+LPLHSTSDFRPL
+>gnl|md5|bfd0bd685d4ee94a015cd061816ab82d
+RHIRRDALEASVLNGLKKHLMEPELFREFCAEFTREVNRLRMERGADLEVARRELDKIGR
+QISQIIEAITDGMYHPSMKEKMTKLEARKAEATEKLANADEPPPLLHPNMAALYAQRITE
+LSENLQHEDSRAQAAEILRSLVDQVTLLPEEGELAIVLRGDLGAILRFAAGKKDPDFLSE
+AEALDNLLGQMAVSRKPGRTKAKTSALNATEVSQLSLVAGVGFEPTTFRL
+>gnl|md5|458f535dc6b3a85dbf0b50bf0ffae312
+MMMPTARSMTLPRAMNSLNSLNMGLPFPACCACSGRGCHITLTPCNMRQDMTGNDMTALS
+EFPITRRWPPRRPDVIQLYTLNTPNGIKTSVMLEECGLDYDAHRISIGDPEDQFTPEFLS
+LNPNNKIPAMIDPNGPDGKPMGLFETGAMLVYLGDKTGKFLPASGAARYHTIQWLMWQMG
+GVGPMFGQVGYFHRYKGSEIEDARPRTRYYNEARRLLGVLDRQLEGRDWITGEYSIADMA
+VGPWLRTVRVNYEAEKETGMDGFANVQAYLDRFLARPAVQRGIEVGAE
+>gnl|md5|f53520edd5c9ba7e5bed2fd08cb44ad7
+MPSWRRNWAAATRIRPAVRFWPRSGWTDAAGPMRPDPRPAACAAAPAGAEPRHRCTEEPA
+LTESRKINPWLKAALEFGPLILFFLVFMRFRDQTVSLAGRDYSGFILATLAFVPVLALST
+LALWRLTGRLSPMQVATLVLVVVFGGLSVWLNDPKFFKMKPTIIYLIFAALLGTSLALRR
+NWLELVMSEALPMNAEGWRILTLRMALLFLGLAAANEAVWRLMSETAWVNFKTFGLPAIM
+VAFFIANSRLFERHAQPRDGE
+>gnl|md5|68631421ddc36a3fd81617d12227b1dd
+MILHRPDDDSTARRLEIELRNGPALEAKLVDKIGGAWVELNARHERLVRQEVGARLDAER
+DRKAEVILDLLYEEAAEGRLYTSTQFASNFENRAGLGSQHTIQDRLNVLATKGFIKYQRN
+GALYGLPLVRSRFGYMCVEGMRFGRVEQVDPETGEITGQGLAVLPSHYRCASSGAALEVE
+NPSVWVWPEVVDV
+>gnl|md5|04b3fad17b0d40e02b489a48c451ecc3
+MPVACCRPCGAADGGADLGRSGGEGWLHLFPVLLGAGQARTHEALRRQGRIARRTAGTPR
+PWFIVIITAGLLARRSLPLPAFPMPCGTSGVIRRRLAAYSCGGSAGLAPKGAPASLFAFG
+SDRPERTVMPTYRDDEAISVKMLYWPATLCPREEVSPLTTTGAEDLKQADTVLYMQFFRL
+R
+>gnl|md5|0fab0da718e659ed5fb9c7a5f6a3d18e
+MAEHLPFLAHCSPAPRGLARAWGFGRRPGSNDRGNDTLTHNVLRFASGLWRGQPGRVILY
+TIHYKAFTMTASTTMTIRVSPETKQKLERIAGETRRSKSFLAAEAVSAYVERELEIIDGI
+RRGMADAAAGRVVSHEDAMAEIHAVIDAAEATRAGKA
Added: SwiftApps/Blast/v2/sites.local.xml
--- SwiftApps/Blast/v2/sites.local.xml	                        (rev 0)
+++ SwiftApps/Blast/v2/sites.local.xml	2013-12-11 04:50:42 UTC (rev 7401)
@@ -0,0 +1,11 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+   <pool handle="localhost">
+      <execution provider="local" />
+      <profile namespace="karajan" key="jobThrottle">0.01</profile>
+      <profile namespace="karajan" key="initialScore">10000</profile>
+      <filesystem provider="local"/>
+      <workdirectory>swift.work</workdirectory>
+      <profile namespace="swift" key="stagingMethod">local</profile>
+   </pool>
+</config>
