[Swift-commit] r7444 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Thu Dec 19 14:33:01 CST 2013
Author: davidk
Date: 2013-12-19 14:33:01 -0600 (Thu, 19 Dec 2013)
New Revision: 7444
Added:
   trunk/bin/swiftlog
Removed:
   trunk/bin/swiftdebug
Log:
Rename and some changes for better performance
Deleted: trunk/bin/swiftdebug
--- trunk/bin/swiftdebug	2013-12-18 22:32:17 UTC (rev 7443)
+++ trunk/bin/swiftdebug	2013-12-19 20:33:01 UTC (rev 7444)
@@ -1,210 +0,0 @@
-#!/usr/bin/perl -w
-use strict;
-use warnings;
-use File::Basename;
-use Class::Struct;
-# Task structure
-struct Task          => {
-    app              => '$',
-    arguments        => '$',
-    host             => '$',
-    replicationGroup => '$',
-    stageIn          => '$',
-    stageOut         => '$',
-    startTime        => '$',
-    stopTime         => '$',
-    taskNumber       => '$',
-    thread           => '$',
-    workdir          => '$',
-# Hash for storing all tasks
-my %tasks = ();
-my $taskCounter = 1;
-# Print basic usage info
-sub usage() {
-   &crash("Usage: $0 <logdir>");
-# Print error message and exit
-sub crash() {
-   print STDERR "@_\n";
-   exit(1);
-# Logic for what to do with a log entry
-sub processLogEntry() {
-   (my $date, my $time, my $loglevel, my $class, my $message) = split(/\s+/, $_[0], 5);
-   $time = (split(',', $time))[0];
-   $message = "$time $message";
-   # my @keywords_to_keep= ("VERSION", "ARGUMENTS", "SWIFT_CONFIGURATION", "SITES:", "TC:", "SWIFTSCRIPT:" );
-   my @keywords_to_keep=("xyzzy");
-   my $keyword_regexp = join('|', @keywords_to_keep);
-   if ( $message =~ m/THREAD_ASSOCIATION/ ) {
-      &taskCreated($message);
-      return;
-   elsif ( $message =~ m/JOB_START/ ) {
-      &taskStarted($message);
-      return;
-   elsif ( $message =~ m/JOB_END/ ) {
-      &taskEnded($message);
-      return;
-   elsif ( $message =~ /Staging in files/ ) {
-      &taskStagingIn($message);
-      return;
-   elsif ( $message =~ /FILE_STAGE_OUT_START/ ) {
-      &taskStagingOut($message);
-      return;
-   elsif ( $message =~ m/$keyword_regexp/ ) {
-      print "$message";
-      return;
-# Gather information about a task
-sub taskCreated() {
-   # Input: THREAD_ASSOCIATION jobid=sleep-n5t2pajl thread=R-4 host=westmere replicationGroup=null
-   $_[0] =~ s/jobid=|thread=|host=|replicationGroup=//g;
-   my ( $date, $ignore, $taskid, $thread, $host, $replicationGroup ) = split(/\s+/, $_[0]);
-   my $t = Task->new();
-   $t->taskNumber($taskCounter);
-   $t->thread($thread);
-   $t->host($host);
-   $t->replicationGroup($replicationGroup);
-   $tasks{$taskid} = $t;
-   $taskCounter += 1;
-# Record that a task has started
-sub taskStarted() {
-   # Input: JOB_START jobid=sleep-k5t2pajl tr=sleep arguments=[1] tmpdir=sleep-run002/jobs/k/sleep-k5t2pajl host=westmere
-   $_[0] =~ s/jobid=|tr=|arguments=|tmpdir=|hostdir=//g;
-   my ( $date, $ignore, $taskid, $app, $remainder ) = split(/\s+/, $_[0], 5);
-   my $arguments = &getBracketedText($remainder);
-   my $workdir = (split(/\s+/, $_[0]))[-2];
-   my $t = $tasks{$taskid};
-   $t->app($app);
-   $t->workdir($workdir);
-   $t->arguments($arguments);
-   $t->startTime($date);
-sub taskEnded() {
-   # Input: JOB_END jobid=sleep-k5t2pajl
-   $_[0] =~ s/jobid=//g;
-   my ( $date, $ignore, $taskid ) = split(/\s+/, $_[0]);
-   $t->stopTime($date);
-sub taskStagingIn() {
-   # Input: jobid=cat-nff3bpjl - Staging in files [file://localhost/data.txt, file://localhost/data2.txt]
-   my ( $date, $start, $taskid, $leftover ) = split(/\s+/, $_[0], 4);
-   my $files = getBracketedText($leftover);
-   $t->stageIn($files);
-sub taskStagingOut() {
-   # Input: FILE_STAGE_OUT_START srcname=catsn.0001.out srcdir=catsn-run015/shared/output srchost=westmere destdir=output desthost=localhost provider=file jobid=cat-xpyldpjl
-   $_[0] =~ s/srcname=|srcdir=|srchost=|destdir=|desthost=|provider=|jobid=//g;
-   my ( $date, $junk, $srcname, $srcdir, $srchost, $destdir, $desthost, $provider, $taskid ) = split(/\s+/, $_[0]);
-   if(defined($t->stageOut())) {
-      $t->stageOut($t->stageOut() . "$srcname ");
-   } else {
-      $t->stageOut("$srcname");
-sub getBracketedText() {
-   $_[0] =~ /\[([^\]]*)\]/x;
-   my $result = $1;
-   $result =~ s/,//g;
-   return $result;
-sub printTasks() {
-   foreach my $key (sort { $tasks{$a}->taskNumber <=> $tasks{$b}->taskNumber } keys %tasks) {
-      my $value = $tasks{$key};
-      printf "Task %s\n" .
-             "\tApp name = %s\n" .
-             "\tCommand line arguments = %s\n" .
-             "\tHost = %s\n" .
-             "\tStart time = %s\n" .
-             "\tStop time = %s\n" .
-             "\tWork directory = %s\n" .
-             "\tStaged in files = %s\n" .
-             "\tStaged out files = %s\n",
-             $value->taskNumber,
-             $value->app,
-             $value->arguments,
-             $value->host,
-             $value->startTime,
-             $value->stopTime,
-             $value->workdir,
-             $value->stageIn,
-             $value->stageOut,
-# Return true if input string starts with a date stamp
-sub hasDateStamp() {
-   my $input = $_[0];
-   if ( $input =~ m/^\d{4}-\d{2}-\d{2}/ ) {
-      return 1;
-   return 0;
-# Check usage
-if ( !$ARGV[0] ) {
-   &usage();
-# Verify $run_directory
-my $run_directory = $ARGV[0];
-if ( ! -d "$run_directory" ) {
-   &crash("Directory $run_directory does not exist!");
-# Open Swift log
-my $swift_log_name = "$run_directory/" . basename($run_directory) . ".log";
-open(SWIFTLOG, $swift_log_name) || &crash("Unable to open log file $swift_log_name");
-# Parse Swift log
-my @multiline_entry = ();
-my $previous_line = "";
-# Read log, and send each entry (single or multi-line) to processLogEntry()
-while(my $line = <SWIFTLOG>) {
-   if ( &hasDateStamp($line) ) {
-      if ( &hasDateStamp($previous_line) ) {
-         &processLogEntry($previous_line);
-      $previous_line = $line;
-   } else {
-      $previous_line .= "$line";
-# Print tasks
-&printTasks();
Copied: trunk/bin/swiftlog (from rev 7443, trunk/bin/swiftdebug)
--- trunk/bin/swiftlog	                        (rev 0)
+++ trunk/bin/swiftlog	2013-12-19 20:33:01 UTC (rev 7444)
@@ -0,0 +1,187 @@
+#!/usr/bin/perl -w
+use strict;
+use warnings;
+use File::Basename;
+use Class::Struct;
+# Task structure
+struct Task          => {
+    app              => '$',
+    arguments        => '$',
+    host             => '$',
+    replicationGroup => '$',
+    stageIn          => '$',
+    stageOut         => '$',
+    startTime        => '$',
+    stopTime         => '$',
+    taskNumber       => '$',
+    thread           => '$',
+    workdir          => '$',
+# Hash for storing all tasks
+my %tasks = ();
+my $taskCounter = 1;
+# Print basic usage info
+sub usage() {
+   &crash("Usage: $0 <logdir>");
+# Print error message and exit
+sub crash() {
+   print STDERR "@_\n";
+   exit(1);
+# Get an existing task of a given jobid, or create a new one and return it
+sub getTask() {
+   if(defined($tasks{$_[0]})) {
+      return $tasks{$_[0]};
+   } else {
+      my $t = Task->new();
+      $tasks{$_[0]} = $t;
+      return $t;
+# Record that a task has started
+sub taskStarted() {
+   # 2013-12-17 16:42:13,135+0000 DEBUG swift JOB_START jobid=sleep-k5t2pajl tr=sleep arguments=[1] tmpdir=sleep-run002/jobs/k/sleep-k5t2pajl host=westmere
+   $_[0] =~ s/jobid=|tr=|arguments=|tmpdir=|host=//g;
+   my @entryArray = split(/\s+/, $_[0]);
+   my $date      = $entryArray[1];
+   my $taskid    = $entryArray[5];
+   my $app       = $entryArray[6];
+   my $workdir   = $entryArray[-2];
+   my $host      = $entryArray[-1];
+   my $arguments = &getBracketedText($_[0]);
+   my $t = &getTask($taskid);
+   $t->taskNumber($taskCounter);
+   $t->app($app);
+   $t->workdir($workdir);
+   $t->arguments($arguments);
+   $t->startTime($date);
+   $t->host($host);
+   $tasks{$taskid} = $t;
+   $taskCounter += 1;
+sub taskEnded() {
+   # 2013-12-17 16:42:38,520+0000 DEBUG swift JOB_END jobid=bash-1vngpnjl
+   $_[0] =~ s/jobid=//g;
+   my $taskid = $entryArray[-1];
+   $t->stopTime($date);
+sub taskStagingIn() {
+   # 2013-12-18 17:38:23,372+0000 INFO  swift START jobid=cat-a3mafpjl - Staging in files [file://localhost/data.txt, file://localhost/data2.txt]
+   my $files  = &getBracketedText($_[0]);
+   $t->stageIn($files);
+sub taskStagingOut() {
+   # 2013-12-18 17:38:23,349+0000 DEBUG swift FILE_STAGE_OUT_START srcname=catsn.0008.out srcdir=catsn-run016/shared/output srchost=westmere destdir=output desthost=localhost provider=file jobid=cat-83mafpjl
+   $_[0] =~ s/jobid=|srcname=//g;
+   my $file   = $entryArray[5];
+   if(defined($t->stageOut())) {
+      $t->stageOut($t->stageOut() . "$file ");
+   } else {
+      $t->stageOut("$file");
+sub getBracketedText() {
+   my $result = "";
+   $_[0] =~ /\[([^\]]*)\]/x;
+   if(defined($1)) {
+      $result = $1;
+      $result =~ s/,//g;
+   return $result;
+sub printTasks() {
+   no warnings;
+   foreach my $key (sort { $tasks{$a}->taskNumber <=> $tasks{$b}->taskNumber } keys %tasks) {
+      my $value = $tasks{$key};
+      printf "Task %s\n" .
+             "\tApp name = %s\n" .
+             "\tCommand line arguments = %s\n" .
+             "\tHost = %s\n" .
+             "\tStart time = %s\n" .
+             "\tStop time = %s\n" .
+             "\tWork directory = %s\n" .
+             "\tStaged in files = %s\n" .
+             "\tStaged out files = %s\n\n",
+             $value->taskNumber,
+             $value->app,
+             $value->arguments,
+             $value->host,
+             $value->startTime,
+             $value->stopTime,
+             $value->workdir,
+             $value->stageIn,
+             $value->stageOut,
+# Check usage
+if ( !$ARGV[0] ) {
+   &usage();
+# Verify $run_directory
+my $run_directory = $ARGV[0];
+if ( ! -d "$run_directory" ) {
+   &crash("Directory $run_directory does not exist!");
+# Open Swift log
+my $swift_log_name = "$run_directory/" . basename($run_directory) . ".log";
+open(SWIFTLOG, $swift_log_name) || &crash("Unable to open log file $swift_log_name");
+# Read log, send entries we care about to the right place
+while(my $line = <SWIFTLOG>) {
+   if ( $line =~ m/JOB_START/o ) {
+      &taskStarted($line);
+      next;
+   elsif ( $line =~ m/JOB_END/o ) {
+      &taskEnded($line);
+      next;
+   elsif ( $line =~ m/Staging in files/o ) {
+      &taskStagingIn($line);
+      next;
+   elsif ( $line =~ m/FILE_STAGE_OUT_START/o ) {
+      &taskStagingOut($line);
+      next;
+# Print tasks
+&printTasks();
