[Swift-commit] r7411 - SwiftApps/Blast/v2
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Wed Dec 11 12:26:31 CST 2013
Author: wilde
Date: 2013-12-11 12:26:31 -0600 (Wed, 11 Dec 2013)
New Revision: 7411
Added:
   SwiftApps/Blast/v2/mcs-local.properties
   SwiftApps/Blast/v2/mcs-servers.properties
Removed:
   SwiftApps/Blast/v2/apps
   SwiftApps/Blast/v2/sites.local.xml
Modified:
   SwiftApps/Blast/v2/blast2.swift
   SwiftApps/Blast/v2/fblastall.sh
   SwiftApps/Blast/v2/swift.properties
Log:
Optimizations for speed and adjustments for 0.95 config.
Deleted: SwiftApps/Blast/v2/apps
--- SwiftApps/Blast/v2/apps	2013-12-11 17:26:15 UTC (rev 7410)
+++ SwiftApps/Blast/v2/apps	2013-12-11 18:26:31 UTC (rev 7411)
@@ -1,18 +0,0 @@
-midway bash /bin/bash
-midway mid_bash /bin/bash
-midway loc_bash /bin/bash
-beagle bgl_bash /bin/bash
-local  loc_bash /bin/bash
-local  cat /bin/cat
-localhost bash bash
-midway blastmerge /root/parallelblast_2.0.9/blastmerge
-midway blastall /root/blast-2.2.26/bin/blastall
-localhost fastasplitn /root/parallelblast_2.0.9/fastasplitn
-localhost formatdb /root/blast-2.2.26/bin/formatdb
-localhost blastall /root/blast-2.2.26/bin/blastall
-localhost fblastall /root/blast.svn/v2/fblastall.sh
-localhost blastmerge /root/parallelblast_2.0.9/blastmerge
-persistent-coasters fastasplitn /root/parallelblast_2.0.9/fastasplitn
-persistent-coasters formatdb /root/blast-2.2.26/bin/formatdb
-persistent-coasters blastall /root/blast-2.2.26/bin/blastall
-persistent-coasters blastmerge /root/parallelblast_2.0.9/blastmerge
Modified: SwiftApps/Blast/v2/blast2.swift
--- SwiftApps/Blast/v2/blast2.swift	2013-12-11 17:26:15 UTC (rev 7410)
+++ SwiftApps/Blast/v2/blast2.swift	2013-12-11 18:26:31 UTC (rev 7411)
@@ -3,16 +3,20 @@
 type fasta;
 type query;
-string num_partitions        = arg("n", "10");
-string program_name          = arg("p", "blastp");
-string expectation_value     = arg("e", "0.1");
-string filter_query_sequence = arg("F", "F");
+string num_partitions  = arg("n", "10");
+string blast_type      = arg("p", "blastp");
+string expectation     = arg("e", "0.1");
+string filter_query    = arg("F", "F");
+string database        = arg("d", "nr.sub1");
+string query           = arg("q", "sequence.seq");
-fasta  dbin       <single_file_mapper;file=arg("d", "nr.sub1")>;
-query  query_file <single_file_mapper;file=arg("i", "sequence.seq")>;
+tracef("database=%s\n", database);
-app (file dblist) split_database (fasta d, string n){
-  bash "-c" strcat("SPLITFRAGTEMPLATE=/tmp/db%3.3d /root/parallelblast_2.0.9/fastasplitn ", at d, " ", n, " 2>&1 | grep Opening | sed -e 's/^.* //'") stdout=@dblist;
+query  query_file <single_file_mapper;file=query>;
+app (file dblist) split_database (string d, string n){
+  bash "-c" strcat("SPLITFRAGTEMPLATE=/tmp/db%3.3d fastasplitn ", d, " ", n, " 2>&1 ",
+                   "| grep Opening | sed -e 's/^.* //'") stdout=@dblist;
 app (file o) fblast(fasta d, query i, string p, string e, string f){
@@ -23,14 +27,15 @@
   blastmerge "-t" @o filenames(o_frags);
-file dbparts<"dbparts">;
-dbparts=split_database(dbin, num_partitions);
+file dbparts <"dbparts">;
+dbparts=split_database(database, num_partitions);
 string db[] = readData(dbparts);
+trace(db);
 file out[];
 foreach partname,i in db {
   fasta dbpart<single_file_mapper; file=partname>;
-  out[i]=fblast(dbpart, query_file, program_name, expectation_value, filter_query_sequence);
+  out[i]=fblast(dbpart, query_file, blast_type, expectation, filter_query);
 file merged <single_file_mapper;file=arg("o", "merged.txt")>;
Modified: SwiftApps/Blast/v2/fblastall.sh
--- SwiftApps/Blast/v2/fblastall.sh	2013-12-11 17:26:15 UTC (rev 7410)
+++ SwiftApps/Blast/v2/fblastall.sh	2013-12-11 18:26:31 UTC (rev 7411)
@@ -3,6 +3,9 @@
 BLASTALL=/root/blast-2.2.26/bin/blastall
 FORMAT=/root/blast-2.2.26/bin/formatdb
+BLASTALL=blastall
+FORMAT=formatdb
 $FORMAT -i $1 -n $7
 shift
Added: SwiftApps/Blast/v2/mcs-local.properties
--- SwiftApps/Blast/v2/mcs-local.properties	                        (rev 0)
+++ SwiftApps/Blast/v2/mcs-local.properties	2013-12-11 18:26:31 UTC (rev 7411)
@@ -0,0 +1,34 @@
+site.local {
+   provider=local:local
+   jobsPerNode=1
+   maxWalltime=01:00:00
+   initialScore=10000
+   filesystem=local
+   workdirectory=/home/wilde/swiftwork
+   jobthrottle=0.1999
+site=local
+# app.local.fastasplitn=/root/parallelblast_2.0.9/fastasplitn
+# app.local.formatdb=/root/blast-2.2.26/bin/formatdb
+# app.local.blastall=/root/blast-2.2.26/bin/blastall
+# app.local.fblastall=/root/blast.svn/v2/fblastall.sh
+# app.local.blastmerge=/root/parallelblast_2.0.9/blastmerge
+app.local.fastasplitn=fastasplitn
+app.local.formatdb=formatdb
+app.local.blastall=blastall
+app.local.fblastall=$HOME/swift/demo/blast/svn/v2/fblastall.sh
+app.local.blastmerge=blastmerge
+app.local.bash=bash
+use.provider.staging=true
+use.wrapper.staging=false
+wrapperlog.always.transfer=true
+execution.retries=0
+lazy.errors=false
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+#tcp.port.range=50000,51000
+Dtcp.channel.log.io.performance=true
Added: SwiftApps/Blast/v2/mcs-servers.properties
--- SwiftApps/Blast/v2/mcs-servers.properties	                        (rev 0)
+++ SwiftApps/Blast/v2/mcs-servers.properties	2013-12-11 18:26:31 UTC (rev 7411)
@@ -0,0 +1,44 @@
+site.local {
+   jobsPerNode=1
+#   filesystem=local
+service.mcs {
+   jobsPerNode=4
+   jobThrottle=10
+   work=/home/wilde/swiftwork
+   workers=crush thwomp
+   mode=ssh
+#app.local.fastasplitn=fastasplitn
+#app.local.formatdb=formatdb
+#app.local.blastall=blastall
+site=local,mcs
+app.mcs.fblastall=/home/wilde/swift/demo/blast/svn/v2/fblastall.sh
+lazy.errors=false
+sitedir.keep=true
Deleted: SwiftApps/Blast/v2/sites.local.xml
--- SwiftApps/Blast/v2/sites.local.xml	2013-12-11 17:26:15 UTC (rev 7410)
+++ SwiftApps/Blast/v2/sites.local.xml	2013-12-11 18:26:31 UTC (rev 7411)
@@ -1,11 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
-   <pool handle="localhost">
-      <execution provider="local" />
-      <profile namespace="karajan" key="jobThrottle">0.01</profile>
-      <profile namespace="karajan" key="initialScore">10000</profile>
-      <filesystem provider="local"/>
-      <workdirectory>swift.work</workdirectory>
-      <profile namespace="swift" key="stagingMethod">local</profile>
-   </pool>
-</config>
Modified: SwiftApps/Blast/v2/swift.properties
--- SwiftApps/Blast/v2/swift.properties	2013-12-11 17:26:15 UTC (rev 7410)
+++ SwiftApps/Blast/v2/swift.properties	2013-12-11 18:26:31 UTC (rev 7411)
@@ -1,3 +1,4 @@
 site.local {
    jobsPerNode=1
@@ -3,17 +4,33 @@
    initialScore=10000
-   filesystem=local
-   workdirectory=/scratch/midway/$USER/work
+#   filesystem=local
    jobthrottle=0.1999
-site=local
+service.mcs {
+   jobsPerNode=4
+   jobThrottle=10
+   mode=ssh
-app.local.fastasplitn=/root/parallelblast_2.0.9/fastasplitn
-app.local.formatdb=/root/blast-2.2.26/bin/formatdb
-app.local.blastall=/root/blast-2.2.26/bin/blastall
-app.local.fblastall=/root/blast.svn/v2/fblastall.sh
-app.local.blastmerge=/root/parallelblast_2.0.9/blastmerge
+site=local,mcs
+app.mcs.fblastall=$HOME/swift/demo/blast/svn/v2/fblastall.sh
