[Swift-commit] r7387 - provenancedb
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Sun Dec 8 09:05:25 CST 2013
Author: lgadelha
Date: 2013-12-08 09:05:25 -0600 (Sun, 08 Dec 2013)
New Revision: 7387
Modified:
   provenancedb/prov-init.sql
Log:
Minor fix
Modified: provenancedb/prov-init.sql
--- provenancedb/prov-init.sql	2013-12-08 14:38:58 UTC (rev 7386)
+++ provenancedb/prov-init.sql	2013-12-08 15:05:25 UTC (rev 7387)
@@ -501,19 +501,6 @@
        app_exec_final_state, app_exec_site, output_dataset_id, output_parameter_name, output_dataset_type, output_dataset_value,
        output_dataset_filename, output_dataset_annotation_key, output_dataset_annotation_numeric_value, output_dataset_annotation_text_value
 from   function_call_dataflow_with_dataset_details
-       left outer join
-       script_to_app_exec on (function_call_dataflow_with_dataset_details.function_call_id=script_to_app_exec.function_call_id);
-select script_run_id, swift_version, cog_version, script_run_final_state, script_run_start_time, script_run_duration, script_filename,
-       input_dataset_id, input_dataset_type, input_parameter_name, input_dataset_value, input_dataset_filename,
-       input_dataset_annotation_key, input_dataset_annotation_numeric_value, input_dataset_annotation_text_value,
-       script_to_app_exec.function_call_id, function_call_type, function_call_name, app_fun_call_name, app_fun_call_start_time,
-       app_fun_call_duration, app_fun_call_final_state, app_fun_call_scratch, app_exec_id, app_exec_start_time, app_exec_duration,
-       app_exec_final_state, app_exec_site, output_dataset_id, output_parameter_name, output_dataset_type, output_dataset_value,
-       output_dataset_filename, output_dataset_annotation_key, output_dataset_annotation_numeric_value, output_dataset_annotation_text_value
-from   function_call_dataflow_with_dataset_details
        right outer join
