[Swift-commit] r7351 - in SwiftTutorials/swift-midway-tutorial: . app bin doc doc/figs doc/images doc/images/icons part01 part02 part03 part04 part05 part06
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Dec 2 09:19:14 CST 2013
Author: davidk
Date: 2013-12-02 09:19:14 -0600 (Mon, 02 Dec 2013)
New Revision: 7351
Added:
   SwiftTutorials/swift-midway-tutorial/README
   SwiftTutorials/swift-midway-tutorial/app/
   SwiftTutorials/swift-midway-tutorial/app/simulate
   SwiftTutorials/swift-midway-tutorial/app/stats
   SwiftTutorials/swift-midway-tutorial/bin/
   SwiftTutorials/swift-midway-tutorial/bin/cleanup
   SwiftTutorials/swift-midway-tutorial/bin/hosts
   SwiftTutorials/swift-midway-tutorial/bin/package_tutorial.sh
   SwiftTutorials/swift-midway-tutorial/bin/plot.sh
   SwiftTutorials/swift-midway-tutorial/doc/
   SwiftTutorials/swift-midway-tutorial/doc/README
   SwiftTutorials/swift-midway-tutorial/doc/TODO
   SwiftTutorials/swift-midway-tutorial/doc/activeplot.png
   SwiftTutorials/swift-midway-tutorial/doc/asciidoc.css
   SwiftTutorials/swift-midway-tutorial/doc/build_docs.sh
   SwiftTutorials/swift-midway-tutorial/doc/cumulativeplot.png
   SwiftTutorials/swift-midway-tutorial/doc/figs/
   SwiftTutorials/swift-midway-tutorial/doc/figs/modis.dia
   SwiftTutorials/swift-midway-tutorial/doc/figs/modis.png
   SwiftTutorials/swift-midway-tutorial/doc/images/
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/caution.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/example.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/home.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/important.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/next.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/note.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/prev.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/tip.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/up.png
   SwiftTutorials/swift-midway-tutorial/doc/images/icons/warning.png
   SwiftTutorials/swift-midway-tutorial/doc/part01.png
   SwiftTutorials/swift-midway-tutorial/doc/part02.png
   SwiftTutorials/swift-midway-tutorial/doc/part03.png
   SwiftTutorials/swift-midway-tutorial/doc/part04.png
   SwiftTutorials/swift-midway-tutorial/doc/part05.png
   SwiftTutorials/swift-midway-tutorial/doc/part06.png
   SwiftTutorials/swift-midway-tutorial/doc/push.sh
   SwiftTutorials/swift-midway-tutorial/part01/
   SwiftTutorials/swift-midway-tutorial/part01/p1.swift
   SwiftTutorials/swift-midway-tutorial/part01/swift.properties
   SwiftTutorials/swift-midway-tutorial/part02/
   SwiftTutorials/swift-midway-tutorial/part02/p2.swift
   SwiftTutorials/swift-midway-tutorial/part02/swift.properties
   SwiftTutorials/swift-midway-tutorial/part03/
   SwiftTutorials/swift-midway-tutorial/part03/p3.swift
   SwiftTutorials/swift-midway-tutorial/part03/swift.properties
   SwiftTutorials/swift-midway-tutorial/part04/
   SwiftTutorials/swift-midway-tutorial/part04/p4.swift
   SwiftTutorials/swift-midway-tutorial/part04/swift.properties
   SwiftTutorials/swift-midway-tutorial/part05/
   SwiftTutorials/swift-midway-tutorial/part05/p5.swift
   SwiftTutorials/swift-midway-tutorial/part05/swift.properties
   SwiftTutorials/swift-midway-tutorial/part06/
   SwiftTutorials/swift-midway-tutorial/part06/p6.swift
   SwiftTutorials/swift-midway-tutorial/part06/swift.properties
   SwiftTutorials/swift-midway-tutorial/setup.sh
Log:
Midway tutorial
Added: SwiftTutorials/swift-midway-tutorial/README
--- SwiftTutorials/swift-midway-tutorial/README	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/README	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+link doc/README
\ No newline at end of file
Property changes on: SwiftTutorials/swift-midway-tutorial/README
___________________________________________________________________
Added: svn:special
Added: SwiftTutorials/swift-midway-tutorial/app/simulate
--- SwiftTutorials/swift-midway-tutorial/app/simulate	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/app/simulate	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,135 @@
+#! /bin/bash
+printparams()
+  printf "\nSimulation parameters:\n\n"
+  echo bias=$bias
+  echo biasfile=$biasfile
+  echo initseed=$initseed
+  echo log=$log
+  echo paramfile=$paramfile
+  echo range=$range
+  echo scale=$scale
+  echo seedfile=$seedfile
+  echo timesteps=$timesteps
+  echo output width=$width
+log() {
+  printf "\nCalled as: $0: $cmdargs\n\n"
+  printf "Start time: "; /bin/date
+  printf "Running as user: "; /usr/bin/id
+  printf "Running on node: "; /bin/hostname
+  printf "Node IP address: "; /bin/hostname -I
+  printparams
+  printf "\nEnvironment:\n\n"
+  printenv | sort
+addsims() {
+  while read f1 ; do
+    read -u 3 f2
+    if [ _$f1 = _ ]; then f1=$lastf1; fi
+    if [ _$f2 = _ ]; then f2=$lastf2; fi
+    printf "%${width}d\n" $(($f1+$f2))
+    lastf1=$f1
+    lastf2=$f2
+  done <$1 3<$2
+# set defaults
+bias=0
+biasfile=none
+initseed=none
+log=yes
+paramfile=none
+range=100
+scale=1
+seedfile=none
+timesteps=0
+nvalues=1
+width=8
+cmdargs="$*"
+usage()
+  echo $0: usage:
+  cat <<END
+    -b|--bias       offset bias: add this integer to all results
+    -B|--biasfile   file of integer biases to add to results
+    -l|--log        generate a log in stderr if not null
+    -n|--nvalues    print this many values per simulation
+    -r|--range      range (limit) of generated results
+    -s|--seed       use this integer [0..32767] as a seed
+    -S|--seedfile   use this file (containing integer seeds [0..32767]) one per line
+    -t|--timesteps  number of simulated "timesteps" in seconds (determines runtime)
+    -x|--scale      scale the results by this integer
+    -h|-?|?|--help  print this help
+END
+# FIXME: NOT YET IMPLEMENTED:
+#    -p|--paramfile  take these parameters (in form param=value) from this file
+#    -p|--paramfile) paramfile=$2 ;;
+while [ $# -gt 0 ]; do
+  case $1 in
+    -b|--bias)      bias=$2      ;;
+    -B|--biasfile)  biasfile=$2  ;;
+    -l|--log)       log=$2       ;;
+    -n|--nvalues)   nvalues=$2   ;;
+    -s|--seed)      initseed=$2  ;;
+    -S|--seedfile)  seedfile=$2  ;;
+    -t|--timesteps) timesteps=$2 ;;
+    -r|--range)     range=$2     ;;
+    -w|--width)     width=$2     ;;
+    -x|--scale)     scale=$2     ;;
+    -h|-?|--help|*) usage; exit  ;;
+  esac
+  shift 2
+done
+# process initial seed
+if [ $initseed != none ]; then
+  RANDOM=$initseed
+fi
+# process file of seeds
+if [ $seedfile != none ]; then
+  seed=0
+  while read $seedfile s; do
+    seed=$(($seed+$s))
+  done <$seedfile
+  RANDOM=$seed
+fi
+# run for some number of "timesteps"
+sleep $timesteps
+# emit N (nvalues) "simulation results" scaled and biased by argument values
+simout=$(mktemp simout.XXXX)
+for ((i=0;i<nvalues;i++)); do
+  # value=$(( (($RANDOM)*(2**16))+$RANDOM ))
+  value=$(( (($RANDOM)*(2**48)) + (($RANDOM)*(2**32)) + (($RANDOM)*(2**16)) + $RANDOM ))
+  printf "%${width}d\n" $(( ($value%range)*scale+bias))
+done  >$simout
+# process file of biases
+if [ $biasfile != none ]; then
+  addsims $simout $biasfile
+else
+  cat $simout
+fi
+rm $simout
+# log environmental data
+if [ $log != off ]; then
+  log 1>&2
+fi
Property changes on: SwiftTutorials/swift-midway-tutorial/app/simulate
Added: svn:executable
Added: SwiftTutorials/swift-midway-tutorial/app/stats
--- SwiftTutorials/swift-midway-tutorial/app/stats	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/app/stats	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,19 @@
+#! /bin/sh
+log() {
+  printenv | sort
+awk '
+{ sum += $1}
+END { printf("%d\n",sum/NR) }
+log 1>&2
Property changes on: SwiftTutorials/swift-midway-tutorial/app/stats
Added: SwiftTutorials/swift-midway-tutorial/bin/cleanup
--- SwiftTutorials/swift-midway-tutorial/bin/cleanup	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/bin/cleanup	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,2 @@
+rm -rf *.log *.rlog *.d p?-*-*-* *.kml *.swiftx *.out output outdir logs hi.* _concurrent .swift/tmp
Property changes on: SwiftTutorials/swift-midway-tutorial/bin/cleanup
Added: SwiftTutorials/swift-midway-tutorial/bin/hosts
--- SwiftTutorials/swift-midway-tutorial/bin/hosts	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/bin/hosts	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+for h in $(cat hosts.txt); do ssh $h hostname -f; done
Property changes on: SwiftTutorials/swift-midway-tutorial/bin/hosts
Added: SwiftTutorials/swift-midway-tutorial/bin/package_tutorial.sh
--- SwiftTutorials/swift-midway-tutorial/bin/package_tutorial.sh	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/bin/package_tutorial.sh	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,15 @@
+#! /bin/sh
+BIN=$(cd $(dirname $0); pwd)
+BASE=$(cd $BIN/..; pwd)
+LOC=$(cd $BASE/..; pwd)
+echo executing $0 from BIN=$BIN
+echo making tutorial package of BASE=$BASE
+echo placing tutorial package in LOC=$LOC
+  cd $LOC
+  tar zcf swift-cray-tutorial.tgz  --exclude-vcs swift-cray-tutorial
+  scp swift-cray-tutorial.tgz p01532 at raven.cray.com:
Property changes on: SwiftTutorials/swift-midway-tutorial/bin/package_tutorial.sh
Added: SwiftTutorials/swift-midway-tutorial/bin/plot.sh
--- SwiftTutorials/swift-midway-tutorial/bin/plot.sh	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/bin/plot.sh	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,68 @@
+#!/bin/bash
+#usage: ./plotswiftlogs.ketan <swift-logfile.log>
+SWIFTLOGFILE=$1
+#TMPDIR=`mktemp -d plotlog.XXX`
+grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
+SWIFTOUTFILE=swiftoutfile.out
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#extract active runs in a file
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >active.txt)
+#extract successful completions in a file
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+if [ $activelines -ne 0 ]
+then
+  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+fi
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+if [ $cumulines -ne 0 ]
+then
+    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+fi
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+cat << EOF1 > plotit.gp
+set terminal png enhanced
+set nokey
+set output "cumulativeplot.png"
+set xlabel "Time in sec"
+set ylabel "number of completed apps"
+set title "Cumulative Apps Completed"
+plot "plot_cumulative.txt" using 1:2 with lines
+set output "activeplot.png"
+set ylabel "number of active apps"
+set title "Active Apps"
+plot "plot_active.txt" using 1:2 with line
+EOF1
+gnuplot plotit.gp 2>/dev/null
+rm swiftoutfile.out plotit.gp active.txt cumulative.txt activetics.txt plot_active.txt plot_cumulative.txt cumultics.txt
Property changes on: SwiftTutorials/swift-midway-tutorial/bin/plot.sh
Added: SwiftTutorials/swift-midway-tutorial/doc/README
--- SwiftTutorials/swift-midway-tutorial/doc/README	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/doc/README	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,938 @@
+Swift Tutorial for RCC Midway Cluster
+This is the asciidoc input file.
+Its content is viewable as a plain-text README file.
+This tutorial is viewable at:
+http://swiftlang.org/tutorials/osdc/tutorial.html
+Tutorial Outline:
+Introductory example, running apps locally on login node:
+  p1 - Run an application under Swift
+  p2 - Parallel loops with foreach
+  p3 - Merging/reducing the results of a parallel foreach loop
+Compute-node exercises, running apps via qsub and aprun:
+  p4 - Running apps on OSDC compute nodes
+  p5 - Running on multiple pools of compute nodes
+  p6 - Running a more complex workflow pattern
+Introduction: Why Parallel Scripting?
+Swift is a simple scripting language for executing many instances of
+ordinary application programs on distributed parallel resources.
+Swift scripts run many copies of ordinary programs concurrently, using
+statements like this:
+foreach protein in proteinList {
+  runBLAST(protein);
+Swift acts like a structured "shell" language. It runs programs
+concurrently as soon as their inputs are available, reducing the need
+for complex parallel programming.  Swift expresses your workflow in a
+portable fashion: The same script runs on multicore computers,
+clusters, clouds, grids, and supercomputers.
+In this tutorial, you'll be able to first try a few Swift examples
+(parts 1-3) on an OSDC login host, to get a sense of the
+language. Then in parts 4-6 you'll run similar workflows on OSDC
+compute nodes, and see how more complex workflows can be expressed
+with Swift scripts.
+Swift tutorial setup
+To begin, start a few virtual machines running the Ubuntu image.
+Once the instances have started, run the following commands to
+install the tutorial scripts on an OSDC login host:
+$ cd $HOME
+$ wget http://swiftlang.org/tutorials/osdc/swift-osdc-tutorial.tar.gz
+$ tar xvfz swift-osdc-tutorial.tgz
+$ cd swift-osdc-tutorial
+$ source setup.sh   # You must run this with "source" !
+Verify your environment
+To verify that Swift (and the Java environment it requires) are working, do:
+$ java -version   # verify that you have Java (ideally Oracle JAVA 1.6 or later)
+$ swift -version  # verify that you have Swift 0.94.1
+NOTE: If you re-login or open new ssh sessions, you must re-run `source setup.sh` in each ssh shell/window.
+To check out the tutorial scripts from SVN
+If you later want to get the most recent version of this tutorial from
+the Swift Subversion repository, do:
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/swift-osdc-tutorial OSDC-Swift
+This will create a directory called "OSDC-Swift" which contains all of the
+files used in this tutorial.
+Simple "science applications" for the workflow tutorial
+This tutorial is based on two intentionally trivial example programs,
+`simulation.sh` and `stats.sh`, (implemented as bash shell scripts)
+that serve as easy-to-understand proxies for real science
+applications. These "programs" behave as follows.
+simulate.sh
+The simulation.sh script serves as a trivial proxy for any more
+complex scientific simulation application. It generates and prints a
+set of one or more random integers in the range [0-2^62) as controlled
+by its command line arguments, which are:
+$ ./app/simulate.sh --help
+./app/simulate.sh: usage:
+    -b|--bias       offset bias: add this integer to all results [0]
+    -B|--biasfile   file of integer biases to add to results [none]
+    -l|--log        generate a log in stderr if not null [y]
+    -n|--nvalues    print this many values per simulation [1]
+    -r|--range      range (limit) of generated results [100]
+    -s|--seed       use this integer [0..32767] as a seed [none]
+    -S|--seedfile   use this file (containing integer seeds [0..32767]) one per line [none]
+    -t|--timesteps  number of simulated "timesteps" in seconds (determines runtime) [1]
+    -x|--scale      scale the results by this integer [1]
+All of thess arguments are optional, with default values indicated above as `[n]`.
+.simulation.sh arguments
+[width="80%",cols="^2,10",options="header"]
+|Argument|Short|Description
+|1    |runtime: sets run time of simulation.sh in seconds
+|2    |range: limits generated values to the range [0,range-1]
+|3    |biasfile: add the integer contained in this file to each value generated
+|4    |scale: multiplies each generated value by this integer
+|5    |count: number of values to generate in the simulation
+With no arguments, simulate.sh prints 1 number in the range of
+1-100. Otherwise it generates n numbers of the form (R*scale)+bias
+where R is a random integer. By default it logs information about its
+execution environment to stderr.  Here's some examples of its usage:
+$ simulate.sh 2>log
+       5
+$ head -4 log
+Called as: /home/wilde/swift/tut/CIC_2013-08-09/app/simulate.sh:
+Start time: Thu Aug 22 12:40:24 CDT 2013
+Running on node: login01.osgconnect.net
+$ simulate.sh -n 4 -r 1000000 2>log
+  239454
+  386702
+   13849
+  873526
+$ simulate.sh -n 3 -r 1000000 -x 100 2>log
+ 6643700
+62182300
+ 5230600
+$ simulate.sh -n 2 -r 1000 -x 1000 2>log
+  565000
+  636000
+$ time simulate.sh -n 2 -r 1000 -x 1000 -t 3 2>log
+  336000
+  320000
+real    0m3.012s
+user    0m0.005s
+sys     0m0.006s
+stats.sh
+The stats.sh script serves as a trivial model of an "analysis"
+program. It reads N files each containing M integers and simply prints
+the\ average of all those numbers to stdout. Similarly to simulate.sh
+it logs environmental information to the stderr.
+$ ls f*
+f1  f2  f3  f4
+$ cat f*
+25
+60
+40
+75
+$ stats.sh f* 2>log
+50
+Basic of the Swift language with local execution
+A Summary of Swift in a nutshell
+* Swift scripts are text files ending in `.swift` The `swift` command
+runs on any host, and executes these scripts. `swift` is a Java
+application, which you can install almost anywhere.  On Linux, just
+unpack the distribution `tar` file and add its `bin/` directory to
+your `PATH`.
+* Swift scripts run ordinary applications, just like shell scripts
+do. Swift makes it easy to run these applications on parallel and
+remote computers (from laptops to supercomputers). If you can `ssh` to
+the system, Swift can likely run applications there.
+* The details of where to run applications and how to get files back
+and forth are described in configuration files separate from your
+program. Swift speaks ssh, PBS, Condor, SLURM, LSF, SGE, Cobalt, and
+Globus to run applications, and scp, http, ftp, and GridFTP to move
+data.
+* The Swift language has 5 main data types: `boolean`, `int`,
+`string`, `float`, and `file`. Collections of these are dynamic,
+sparse arrays of arbitrary dimension and structures of scalars and/or
+arrays defined by the `type` declaration.
+* Swift file variables are "mapped" to external files. Swift sends
+files to and from remote systems for you automatically.
+* Swift variables are "single assignment": once you set them you can't
+change them (in a given block of code).  This makes Swift a natural,
+"parallel data flow" language. This programming model keeps your
+workflow scripts simple and easy to write and understand.
+* Swift lets you define functions to "wrap" application programs, and
+to cleanly structure more complex scripts. Swift `app` functions take
+files and parameters as inputs and return files as outputs.
+* A compact set of built-in functions for string and file
+manipulation, type conversions, high level IO, etc. is provided.
+Swift's equivalent of `printf()` is `tracef()`, with limited and
+slightly different format codes.
+* Swift's `foreach {}` statement is the main parallel workhorse of the
+language, and executes all iterations of the loop concurrently. The
+actual number of parallel tasks executed is based on available
+resources and settable "throttles".
+* In fact, Swift conceptually executes *all* the statements,
+expressions and function calls in your program in parallel, based on
+data flow. These are similarly throttled based on available resources
+and settings.
+* Swift also has `if` and `switch` statements for conditional
+execution. These are seldom needed in simple workflows but they enable
+very dynamic workflow patterns to be specified.
+We'll see many of these points in action in the examples below. Lets
+get started!
+Part 1: Run a single application under Swift
+The first swift script, p1.swift, runs simulate.sh to generate a
+single random number. It writes the number to a file.
+image::part01.png["p1 workflow",align="center"]
+.p1.swift
+sys::[cat ../part01/p1.swift]
+To run this script, run the following command:
+$ cd part01
+$ swift p1.swift
+Swift 0.94.1 RC2 swift-r6895 cog-r3765
+RunID: 20130827-1413-oa6fdib2
+Progress:  time: Tue, 27 Aug 2013 14:13:33 -0500
+Final status: Tue, 27 Aug 2013 14:13:33 -0500  Finished successfully:1
+$ cat sim.out
+      84
+$ swift p1.swift
+$ cat sim.out
+      36
+To cleanup the directory and remove all outputs (including the log
+files and directories that Swift generates), run the cleanup script
+which is located in the tutorial PATH:
+$ cleanup
+NOTE: You'll also find two Swift configuration files in each `partNN`
+directory of this tutorial.  These specify the environment-specific
+details of where to find application programs (file `apps`) and where
+to run them (file `sites.xml`).  These files will be explained in more
+detail in parts 4-6, and can be ignored for now.
+It defines
+things like the work directory, the scheduler to use, and how to
+control parallelism. The sites.xml file below will tell Swift to run
+on the local machine only, and run just 1 task at a time.
+.sites.xml
+sys::[cat ../part01/sites.xml]
+ In this case, it
+indicates that the app "simulate" (the first token in the command line
+declaration of the function `simulation`, at line NNN) is located in the file
+simulate.sh and (since the path `simulate.sh` is specified with no
+directory components) Swift expects that the `simulate.sh` executable
+will be available in your $PATH.
+.apps
+sys::[cat ../part01/apps]
+Part 2: Running an ensemble of many apps in parallel with a "foreach" loop
+The `p2.swift` script introduces the `foreach` parallel iteration
+construct to run many concurrent simulations.
+image::part02.png[align="center"]
+.p2.swift
+sys::[cat ../part02/p2.swift]
+The script also shows an
+example of naming the output files of an ensemble run. In this case, the output files will be named
+`output/sim_N.out`.
+To run the script and view the output:
+$ cd ../part02
+$ swift p2.swift
+$ ls output
+sim_0.out  sim_1.out  sim_2.out  sim_3.out  sim_4.out  sim_5.out  sim_6.out  sim_7.out  sim_8.out  sim_9.out
+$ more output/*
+output/sim_0.out
+      44
+output/sim_1.out
+      55
+output/sim_9.out
+      82
+Part 3: Analyzing results of a parallel ensemble
+After all the parallel simulations in an ensemble run have completed,
+its typically necessary to gather and analyze their results with some
+kind of post-processing analysis program or script.  p3.swift
+introduces such a postprocessing step. In this case, the files created
+by all of the parallel runs of `simulation.sh` will be averaged by by
+the trivial "analysis application" `stats.sh`:
+image::part03.png[align="center"]
+.p3.swift
+sys::[cat ../part03/p3.swift]
+To run:
+$ cd part03
+$ swift p3.swift
+Note that in `p3.swift` we expose more of the capabilities of the
+`simulate.sh` application to the `simulation()` app function:
+app (file o) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@filename(o);
+`p3.swift` also shows how to fetch application-specific values from
+the `swift` command line in a Swift script using `@arg()` which
+accepts a keyword-style argument and its default value:
+int nsim   = @toInt(@arg("nsim","10"));
+int steps  = @toInt(@arg("steps","1"));
+int range  = @toInt(@arg("range","100"));
+int values = @toInt(@arg("values","5"));
+Now we can specify that more runs should be performed and that each should run for more timesteps, and produce more that one value each, within a specified range, using command line arguments placed after the Swift script name in the form `-parameterName=value`:
+$ swift p3.swift -nsim=3 -steps=10 -values=4 -range=1000000
+RunID: 20130827-1439-s3vvo809
+Progress:  time: Tue, 27 Aug 2013 14:39:42 -0500
+Progress:  time: Tue, 27 Aug 2013 14:39:53 -0500  Active:2  Stage out:1
+Final status: Tue, 27 Aug 2013 14:39:53 -0500  Finished successfully:4
+$ ls output/
+average.out  sim_0.out  sim_1.out  sim_2.out
+$ more output/*
+output/average.out
+651368
+output/sim_0.out
+  735700
+  886206
+  997391
+  982970
+output/sim_1.out
+  260071
+  264195
+  869198
+  933537
+output/sim_2.out
+  201806
+  213540
+  527576
+  944233
+Now try running (`-nsim=`) 100 simulations of (`-steps=`) 1 second each:
+$ swift p3.swift -nsim=100 -steps=1
+RunID: 20130827-1444-rq809ts6
+Progress:  time: Tue, 27 Aug 2013 14:44:55 -0500
+Progress:  time: Tue, 27 Aug 2013 14:44:56 -0500  Selecting site:79  Active:20  Stage out:1
+Progress:  time: Tue, 27 Aug 2013 14:44:58 -0500  Selecting site:58  Active:20  Stage out:1  Finished successfully:21
+Progress:  time: Tue, 27 Aug 2013 14:44:59 -0500  Selecting site:37  Active:20  Stage out:1  Finished successfully:42
+Progress:  time: Tue, 27 Aug 2013 14:45:00 -0500  Selecting site:16  Active:20  Stage out:1  Finished successfully:63
+Progress:  time: Tue, 27 Aug 2013 14:45:02 -0500  Active:15  Stage out:1  Finished successfully:84
+Progress:  time: Tue, 27 Aug 2013 14:45:03 -0500  Finished successfully:101
+Final status: Tue, 27 Aug 2013 14:45:03 -0500  Finished successfully:101
+We can see from Swift's "progress" status that the tutorial's default
+`sites.xml` parameters for local execution allow Swift to run up to 20
+application invocations concurrently on the login node. We'll look at
+this in more detail in the next sections where we execute applications
+on the site's compute nodes.
+Running applications on OSDC compute nodes with Swift
+Part 4: Running a parallel ensemble on OSDC compute nodes
+`p4.swift` will run our mock "simulation"
+applications on OSDC compute nodes.  The script is similar to as
+`p3.swift`, but specifies that each simulation app invocation should
+additionally return the log file which the application writes to
+`stderr`.
+FIXME: need to revise this figure: drop prog:
+, making the parallel portion of the script behave like this:
+image::part04.png[align="center"]
+.p4.swift
+sys::[cat ../part04/p4.swift]
+Now when you run `swift p4.swift` you'll see that two types output
+files will placed in the `output/` directory: `sim_N.out` and
+`sim_N.log`.  The log files provide data on the runtime environment of
+each app invocation. For example:
+FIXME: The output below needs to get recaptured for OSDC nodes
+$ cat output/sim_0.log
+Called as: /home/users/p01532/swift-osdc-tutorial/app/simulate.sh: --timesteps 1 --range 100 --nvalues 5
+Start time: Tue Aug 27 12:17:43 CDT 2013
+Running on node: nid00018
+Running as user: uid=61532(p01532) gid=61532 groups=61532
+Simulation parameters:
+bias=0
+biasfile=none
+initseed=none
+log=yes
+paramfile=none
+range=100
+scale=1
+seedfile=none
+timesteps=1
+output width=8
+Environment:
+ALPS_APP_DEPTH=32
+ASSEMBLER_X86_64=/opt/cray/cce/8.2.0.173/cray-binutils/x86_64-unknown-linux-gnu/bin/as
+ASYNCPE_DIR=/opt/cray/xt-asyncpe/5.23.02
+ASYNCPE_VERSION=5.23.02
+To tell Swift to run the apps on compute nodes, we specify in the
+`apps` file that the apps should be executed on the `osdc` site
+(instead of the `localhost` site).  We can specify the location of
+each app in the third field of the `apps` file, with either an
+absolute pathname or the name of an executable to be located in
+`PATH`). Here we use the latter form:
+$ cat apps
+raven simulate simulate.sh
+raven stats    stats.sh
+You can experiment, for example, with an alternate version of stats.sh by specfying that app's location explicitly:
+$ cat apps
+raven stats    /home/users/p01532/bin/my-alt-stats.sh
+We can see that when we run many apps requesting a larger set of nodes (6), we are indeed running on the compute nodes:
+$ swift p4.swift -nsim=1000 -steps=1
+RunID: 20130827-1638-t23ax37a
+Progress:  time: Tue, 27 Aug 2013 16:38:11 -0500
+Progress:  time: Tue, 27 Aug 2013 16:38:12 -0500  Initializing:966
+Progress:  time: Tue, 27 Aug 2013 16:38:13 -0500  Selecting site:499  Submitting:500  Submitted:1
+Progress:  time: Tue, 27 Aug 2013 16:38:14 -0500  Selecting site:499  Stage in:1  Submitted:500
+Progress:  time: Tue, 27 Aug 2013 16:38:16 -0500  Selecting site:499  Submitted:405  Active:95  Stage out:1
+Progress:  time: Tue, 27 Aug 2013 16:38:17 -0500  Selecting site:430  Submitted:434  Active:66  Stage out:1  Finished successfully:69
+Progress:  time: Tue, 27 Aug 2013 16:38:18 -0500  Selecting site:388  Submitted:405  Active:95  Stage out:1  Finished successfully:111
+Progress:  time: Tue, 27 Aug 2013 16:38:30 -0500  Stage in:1  Submitted:93  Active:94  Finished successfully:812
+Progress:  time: Tue, 27 Aug 2013 16:38:31 -0500  Submitted:55  Active:95  Stage out:1  Finished successfully:849
+Progress:  time: Tue, 27 Aug 2013 16:38:32 -0500  Active:78  Stage out:1  Finished successfully:921
+Progress:  time: Tue, 27 Aug 2013 16:38:34 -0500  Active:70  Stage out:1  Finished successfully:929
+Progress:  time: Tue, 27 Aug 2013 16:38:37 -0500  Stage in:1  Finished successfully:1000
+Progress:  time: Tue, 27 Aug 2013 16:38:38 -0500  Stage out:1  Finished successfully:1000
+Final status: Tue, 27 Aug 2013 16:38:38 -0500  Finished successfully:1001
+$ grep "on node:" output/*log | head
+output/sim_0.log:Running on node: nid00063
+output/sim_100.log:Running on node: nid00060
+output/sim_101.log:Running on node: nid00061
+output/sim_102.log:Running on node: nid00032
+output/sim_103.log:Running on node: nid00060
+output/sim_104.log:Running on node: nid00061
+output/sim_105.log:Running on node: nid00032
+output/sim_106.log:Running on node: nid00060
+output/sim_107.log:Running on node: nid00061
+output/sim_108.log:Running on node: nid00062
+$ grep "on node:" output/*log | awk '{print $4}' | sort | uniq -c
+    158 nid00032
+    156 nid00033
+    171 nid00060
+    178 nid00061
+    166 nid00062
+    171 nid00063
+$ hostname
+raven
+$ hostname -f
+nid00008
+Swift's `sites.xml` configuration file allows many parameters to
+specify how jobs should be run on a given cluster.
+FIXME: Translate this concept from Cray to OSDC:
+Consider for example that Raven has several queues, each with
+limitiations on the size of jobs that can be run in them.  All Raven
+queues will only run 2 jobs per user at one. The Raven queue "small"
+will only allow up to 4 nodes per job and 1 hours of walltime per job.
+The following site.xml parameters will allow us to match this:
+  <profile namespace="globus" key="queue">small</profile>
+  <profile namespace="globus" key="slots">2</profile>
+  <profile namespace="globus" key="maxNodes">4</profile>
+  <profile namespace="globus" key="nodeGranularity">4</profile>
+To run large jobs, we can specify:
+  <profile namespace="globus" key="maxNodes">8</profile>
+  <profile namespace="globus" key="nodeGranularity">8</profile>
+  <profile namespace="karajan" key="jobThrottle">50.0</profile>
+  <profile namespace="globus" key="maxTime">21600</profile>
+  <profile namespace="globus" key="lowOverAllocation">10000</profile>
+  <profile namespace="globus" key="highOverAllocation">10000</profile>
+This will enable 512 Swift apps (2 x 8 x 32) to run concurrently
+within 2 8-node jobs on Raven's 32-core nodes.  It results in the
+following two PBS jobs submitted by Swift to "provision" compute nodes
+to run thousands of apps, 512 at a time:
+$ qstat -u $USER
+Job ID          Username Queue    Jobname    SessID NDS TSK Memory Time  S Time
+288637.sdb      p01532   medium   B0827-2703    --    8 256    --  05:59 Q   --
+288638.sdb      p01532   medium   B0827-2703    --    8 256    --  05:59 Q   --
+The following section is a summary of the important `sites.xml`
+attributes for running apps on Cray systems. Many of these attributes
+can be set the same for all Swift users of a given system; only a few
+of the attributes need be overridden by users. We explain these
+attributes in detail here to show the degree of control afforded by
+Swift over application execution.  Most users will use templates for a
+given Cray system, only changing a few parameters to meet any unique
+needs of their application workflows.
+.sites.xml
+sys::[egrep -v '<.xml|<config|</config' ../part04/sites.xml | cat -n ]
+The additional attributes in the `sites.xml` file (described here
+without their XML formatting) specify that Swift should run
+applications on Raven in the following manner:
+`execution provider coaster, jobmanager local:pbs` specifies that
+Swift should run apps using its "coaster" provider, which submits
+"pilot jobs" using qsub. These pilot jobs hold on to compute nodes and
+allow Swift to run many app invocations within a single job. This
+mechanism is described in
+http://www.swift-lang.org/papers/UCC-coasters.pdf[this paper from UCC-2011].
+`profile` tags specify additional attributes for the execution
+provider. (A "provider" is like a driver which knows how to handle
+site-specific aspects of app execution). The attributes are grouped
+into various "namespaces", but we can ignore this for now).
+The `env` key `PATHPREFIX` specifies that our tutorial `app` directory
+(`../app`) will be placed at the front of PATH to locate the app on
+the compute node.
+`queue small` specifies that pilot (coaster) jobs to run apps will be
+submitted to Raven's `small` queue.
+`providerAttributes pbs.aprun;pbs.mpp;depth=32` specifies some
+Cray-specific attributes: that jobs should use Cray-specific PBS "mpp"
+resource attributes (eg `mppwidth` and `mppnppn`) and an mppdepth of
+32 (because we will be running one coaster process per node, and
+Raven's XE6 dual IL-16 nodes have a depth of 32 processing elements
+(PEs).
+`jobsPerNode 32` tells Swift that each coaster should run up to 32
+concurrent apps. This can be reduced to place fewer apps per node, eg
+if each app needs more memory (or, rarely, greater than 32, e.g. if the apps are
+IO-bound or for benchmark experiments, etc).
+`slots 2` specifies that Swift will run up to 2 concurrent PBS jobs,
+and `maxNodes 1` specifies that each of these jobs will request only 1
+compute node.
+`maxWallTime 00:01:00` specifies that Swift should allow each app to
+run for up to one minute of walltime within the larger pilot job. In
+this example Swift will dynamically determine the total PBS walltime
+needed for the pilot job, but this can be specified manually using
+attributes `maxtime` along with `highOverAllocation` and
+`lowOverAllocation`.
+`jobThrottle 3.20` specifies that Swift should allow up to 320 apps to
+run on the `raven` site at once.  This is typically set to a number
+greater than or equal to the number of slots x compute nodes x apps
+per node (`jobsPerNode` attribute).
+`initialscore 10000` is specified to override Swift's automatic
+throttling, and forces an actual throttle value of approximately
+(specifically 1 over) `jobThrottle` * 100 to be used.
+The last two attributes specify where and how Swift should perform
+data management.  `workdirectory /lus/scratch/{env.USER}/swiftwork`
+specifies where the Swift "application execution sanbox directory"
+used for each app will be located. In some situations this can be a
+directory local to the compute node (eg, for Cray systems, `/dev/shm`
+or `/tmp`, if those are writable by user jobs and the nodes have
+sufficient space in these RAM-based filesystems).
+Finally, `stagingMethod sfs` specifies that Swift will copy data to
+and from the shared file system to the application sandbox
+directories.
+Performing larger Swift runs
+To test with larger runs, there are two changes that are required. The first is a
+change to the command line arguments. The example below will run 1000 simulations
+with each simulation taking 5 seconds.
+$ swift p6.swift -steps=5 -nsim=1000
+FIXME: Adjust from Cray to OSDC concepts: (perhaps show how to add more nodes dynamically)
+The other change required is to the sites.xml to control how many nodes you request.
+Change the "maxnodes" values to control the number of nodes to request.
+<profile namespace="globus" key="maxNodes">2</profile>
+Plotting run activity
+The tutorial `bin` directory in your `PATH` provides a script
+`plot.sh` to plot the progress of a Swift script.  It generates two
+image files: `activeplot.png`, which shows the number of active jobs
+over time, and `cumulativeplot.png`, which shows the total number of
+app calls completed as the Swift script progresses.
+After each swift run, a log file will be created called
+partNN-<YYYYmmdd>-<hhmm>-<random>.log.  Once you have identified the
+log file name, run the command `./plot.sh` <logfile>` (where logfile
+is the most recent Swift run log) to generate the plots for that
+specific run. For example:
+$ ls -lt *.log | head
+-rw-r--r-- 1 p01532 61532 2237693 Aug 26 12:45 p4-20130826-1244-kmos0d87.log
+-rw-r--r-- 1 p01532 61532    1008 Aug 26 12:44 swift.log
+-rw-r--r-- 1 p01532 61532 5345345 Aug 26 12:44 p4-20130826-1243-10u2qdbd.log
+-rw-r--r-- 1 p01532 61532  357687 Aug 26 12:00 p4-20130826-1159-j01p4lu0.log
+$ plot.sh p4-20130826-1244-kmos0d87.log
+This yields plots like:
+image::activeplot.png[width=700,align=center]
+image::cumulativeplot.png[width=700,align=center]
+NOTE: Because systems like Raven are often firewalled, you may need to
+use scp to pull these image files back to a system on which you can
+view them with a browser or preview tool.
+Part 5: Controlling the compute-node pools where applications run
+This section is under development.
+Part 6: Specifying more complex workflow patterns
+p6.swift expands the workflow pattern of p4.swift to add additional
+stages to the workflow. Here, we generate a dynamic seed value that
+will be used by all of the simulations, and for each simulation, we
+run an pre-processing application to generate a unique "bias
+file". This pattern is shown below, followed by the Swift script.
+image::part06.png[align="center"]
+.p6.swift
+sys::[cat ../part06/p6.swift]
+Note that the workflow is based on data flow dependencies: each simulation depends on the seed value, calculated in this statement:
+seedfile = genseed(1);
+and on the bias file, computed and then consumed in these two dependent statements:
+  biasfile = genbias(1000, 20, simulate_script);
+  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values, simulate_script, seedfile);
+To run:
+$ cd ../part06
+$ swift p6.swift
+The default parameters result in the following execution log:
+$ swift p6.swift
+RunID: 20130827-1917-jvs4gqm5
+Progress:  time: Tue, 27 Aug 2013 19:17:56 -0500
+*** Script parameters: nsim=10 range=100 num values=10
+Progress:  time: Tue, 27 Aug 2013 19:17:57 -0500  Stage in:1  Submitted:10
+Generated seed=382537
+Progress:  time: Tue, 27 Aug 2013 19:17:59 -0500  Active:9  Stage out:1  Finished successfully:11
+Final status: Tue, 27 Aug 2013 19:18:00 -0500  Finished successfully:22
+which produces the following output:
+$ ls -lrt output
+total 264
+-rw-r--r-- 1 p01532 61532     9 Aug 27 19:17 seed.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_9.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_8.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_7.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_6.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_5.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_4.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_3.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_2.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_1.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_0.dat
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_9.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_9.log
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_8.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_7.out
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_6.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_6.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_5.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_5.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_4.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_4.log
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_1.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_8.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_7.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_3.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_3.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_2.out
+-rw-r--r-- 1 p01532 61532 14898 Aug 27 19:18 sim_2.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_1.out
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_0.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_0.log
+-rw-r--r-- 1 p01532 61532     9 Aug 27 19:18 average.out
+-rw-r--r-- 1 p01532 61532 14675 Aug 27 19:18 average.log
+Each sim_N.out file is the sum of its bias file plus newly "simulated" random output scaled by 1,000,000:
+$ cat output/bias_0.dat
+     302
+     489
+      81
+     582
+     664
+     290
+     839
+     258
+     506
+     310
+     293
+     508
+      88
+     261
+     453
+     187
+      26
+     198
+     402
+     555
+$ cat output/sim_0.out
+64000302
+38000489
+32000081
+12000582
+46000664
+36000290
+35000839
+22000258
+49000506
+75000310
+We produce 20 values in each bias file. Simulations of less than that
+number of values ignore the unneeded number, while simualtions of more
+than 20 will use the last bias number for all remoaining values past
+20.  As an exercise, adjust the code to produce the same number of
+bias values as is needed for each simulation.  As a further exercise,
+modify the script to generate a unique seed value for each simulation,
+which is a common practice in ensemble computations.
Added: SwiftTutorials/swift-midway-tutorial/doc/TODO
--- SwiftTutorials/swift-midway-tutorial/doc/TODO	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/doc/TODO	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,137 @@
+PLAN
+basics
+cloud
+uc3
+multisystems
+(modis)
+get hosts.txt for cloud dynamically
+Show variety of UC3 activity and what ran where
+get hostname and app_resources into provider staging (hostname into all _swiftwrap)
+Show gridftp and go connect to process the modis dataset
+Show SwiftR for R users, SwiftPy for Enthought PY?
+fetching apps vs sending apps vs parrot/cvmfs/oasis etc ????
+Demo script-aps, bin apps, building apps, caching apps. etc.
+Do a Swift BLAST workflow  -- with viz !!!  (spice it up with help from Dina)
+OSG page from Mats: "Is your job HTC-ready"
+Use new Trunk config in tutorial?
+Add viz and status display; add node probing to tutorial.
+Debug failure with pinfiles
+What "exercises to suggest?"
+- run stats app locally
+- installed vs transferred apps
+- transferred programs vs transferred scripts
+- summarize things about the env from the .log files, ala stats.
+Y-style dag: 2 sims and average
+Show how to find temp files at runtime...
+Show how to find hung processes at runtime...  (or get other trace data...)
+make your owb versions of the programs; verify that you can substitute them
+Add a layer to isolate shell version v installed version
+Show how to handle a paramfile
+Test if OSGCOnnect works and account string (PorjectName) works OK for both!
+SHow how to handle long lists of files (eg writeData and other swift.properties)
+Expand arith to arb prec using bc
+ISSUES
+error in pin files? debug and turn back on
+PATH issues for various providers
+bin dir?
+setup.csh and .csh testing
+IMPROVEMENTS
+1. Cleanup.sh mentioned in the tutorial
+[fixed]
+2. cd ../part02
+[fixed]
+3. support for zsh, csh
+[pending]
+4. What results are created and where did the outputs go ?
+and pointers to what the log files mean
+[pending]
+5. Part4,
+- cd ../part04 is missing. Cleanup the README
+[fixed]
+6. Part5
+- cd ../part05 is missing. Cleanup
+[fixed]
+7. Part7
+-Change from running on Tukey analysis cluster compute nodes
+[fixed]
+8. Part6
+command line args for nsim and steps, tell user the different behavior
+that can be expected with different arg options
+[pending]
+9. Draw workflow for the modis demos
+[pending]
+10. Link to more technical swift-lang references
+[pending]
+11. Links to detailed language constructs, when explaining
+apps, link to the section on apps in the userguide.
+[pending]
+From Yadu:
+I've committed all the changes that I made on Friday and you can get them
+from -> https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/CIC_2013-08-09
+I'm trying to make this tutorial easily work on several sites so that, we
+do not have to tweak things for every single tutorial. Once this is done,
+I can also add it to the test-battery as well. I think this has value
+considering that we spend atleast 1-2 days for every demo.
+Now, the major pending item is the Modis demo, specifically the issue of
+bringing data to any site and scripts. Slight tweaks to allow for sending
+the scripts as args to apps would also be needed.
+So the major changes are:
+1. Source the setup.sh script with the target site name
+eg. source setups.sh <cloud|uc3|midway|beagle>
+2. No separate cloud folder
+3. [pending] fix modis data and scripts
+4. [pending] support for zsh and other shells?
Added: SwiftTutorials/swift-midway-tutorial/doc/activeplot.png
(Binary files differ)
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/activeplot.png
Added: svn:mime-type
   + application/octet-stream
Added: SwiftTutorials/swift-midway-tutorial/doc/asciidoc.css
--- SwiftTutorials/swift-midway-tutorial/doc/asciidoc.css	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/doc/asciidoc.css	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,26 @@
+a:link { color:navy; }
+a:visited { color:navy; }
+.monospaced, code, pre {
+  font-family: "Courier New", Courier, monospace;
+  font-size: medium; /* inherit; */
+  color: black;
+  padding: 0;
+  margin: 0;
+  background: #f8f8f8;
+  border: 1px solid #dddddd;
+  border-left: 5px solid #f0f0f0;
+  margin-right: 10%;
+div.listingblock > div.content {
+  padding: 0.5em;
+  background: none;
+  border: none;
+  border-left: none;
+  margin-right: none;
Added: SwiftTutorials/swift-midway-tutorial/doc/build_docs.sh
--- SwiftTutorials/swift-midway-tutorial/doc/build_docs.sh	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/doc/build_docs.sh	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,4 @@
+#!/bin/bash -e
+asciidoc -a icons -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o swift-cray-tutorial.html README
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/build_docs.sh
Added: SwiftTutorials/swift-midway-tutorial/doc/cumulativeplot.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/cumulativeplot.png
Added: SwiftTutorials/swift-midway-tutorial/doc/figs/modis.dia
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/figs/modis.dia
Added: SwiftTutorials/swift-midway-tutorial/doc/figs/modis.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/figs/modis.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/caution.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/caution.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/example.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/example.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/home.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/home.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/important.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/important.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/next.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/next.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/note.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/note.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/prev.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/prev.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/tip.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/tip.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/up.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/up.png
Added: SwiftTutorials/swift-midway-tutorial/doc/images/icons/warning.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/images/icons/warning.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part01.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part01.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part02.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part02.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part03.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part03.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part04.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part04.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part05.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part05.png
Added: SwiftTutorials/swift-midway-tutorial/doc/part06.png
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/part06.png
Added: SwiftTutorials/swift-midway-tutorial/doc/push.sh
--- SwiftTutorials/swift-midway-tutorial/doc/push.sh	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/doc/push.sh	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,5 @@
+#! /bin/sh
+# scp -r swift-cray-tutorial.html images *png login.ci.uchicago.edu:/ci/www/projects/swift/tutorials/cray
+tar zcf - --exclude-vcs *html *png images | ssh login.ci.uchicago.edu "cd /ci/www/projects/swift/tutorials/cray; tar zxf -"
Property changes on: SwiftTutorials/swift-midway-tutorial/doc/push.sh
Added: SwiftTutorials/swift-midway-tutorial/part01/p1.swift
--- SwiftTutorials/swift-midway-tutorial/part01/p1.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part01/p1.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,9 @@
+type file;
+app (file o) simulation ()
+  simulate stdout=filename(o);
+file f <"sim.out">;
+f = simulation();
Added: SwiftTutorials/swift-midway-tutorial/part01/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part01/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part01/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=local
Added: SwiftTutorials/swift-midway-tutorial/part02/p2.swift
--- SwiftTutorials/swift-midway-tutorial/part02/p2.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part02/p2.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,11 @@
+type file;
+  simulate stdout=@filename(o);
+foreach i in [0:9] {
+  file f <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  f = simulation();
Added: SwiftTutorials/swift-midway-tutorial/part02/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part02/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part02/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=local
Added: SwiftTutorials/swift-midway-tutorial/part03/p3.swift
--- SwiftTutorials/swift-midway-tutorial/part03/p3.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part03/p3.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,27 @@
+type file;
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=filename(o);
+app (file o) analyze (file s[])
+  stats filenames(s) stdout=filename(o);
+int nsim   = toInt(arg("nsim","10"));
+int steps  = toInt(arg("steps","1"));
+int range  = toInt(arg("range","100"));
+int values = toInt(arg("values","5"));
+file sims[];
+foreach i in [0:nsim-1] {
+  file simout <single_file_mapper; file=strcat("output/sim_",i,".out")>;
+  simout = simulation(steps,range,values);
+  sims[i] = simout;
+file stats<"output/average.out">;
+stats = analyze(sims);
Added: SwiftTutorials/swift-midway-tutorial/part03/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part03/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part03/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=local
Added: SwiftTutorials/swift-midway-tutorial/part04/p4.swift
--- SwiftTutorials/swift-midway-tutorial/part04/p4.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part04/p4.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,29 @@
+type file;
+app (file out, file log) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@out stderr=@log;
+app (file out, file log) analyze (file s[])
+  stats filenames(s) stdout=@out stderr=@log;
+int nsim   = toInt(arg("nsim",   "10"));
+int steps  = toInt(arg("steps",  "1"));
+int range  = toInt(arg("range",  "100"));
+int values = toInt(arg("values", "5"));
+file sims[];
+  file simlog <single_file_mapper; file=strcat("output/sim_",i,".log")>;
+  (simout,simlog) = simulation(steps,range,values);
+  sims[i] = simout;
+file stats_out<"output/average.out">;
+file stats_log<"output/average.log">;
+(stats_out, stats_log) = analyze(sims);
Added: SwiftTutorials/swift-midway-tutorial/part04/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part04/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part04/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=sandyb
Added: SwiftTutorials/swift-midway-tutorial/part05/p5.swift
--- SwiftTutorials/swift-midway-tutorial/part05/p5.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part05/p5.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,29 @@
+type file;
+file sims[];
+  sims[i] = simout;
Added: SwiftTutorials/swift-midway-tutorial/part05/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part05/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part05/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=sandyb
Added: SwiftTutorials/swift-midway-tutorial/part06/p6.swift
--- SwiftTutorials/swift-midway-tutorial/part06/p6.swift	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part06/p6.swift	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,53 @@
+type file;
+# app() functions for application programs to be called:
+app (file out) genseed (int nseeds)
+  simulate "-r" 2000000 "-n" nseeds stdout=@out;
+app (file out) genbias (int bias_range, int nvalues)
+  simulate "-r" bias_range "-n" nvalues stdout=@out;
+app (file out, file log) simulation (int timesteps, int sim_range, file bias_file,
+                                     int scale, int sim_count, file seed_file)
+  simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
+           "-n" sim_count "-S" @seed_file stdout=@out stderr=@log;
+# Command line arguments
+int   nsim = toInt(arg("nsim",   "10"));  # number of simulation programs to run
+int  steps = toInt(arg("steps",  "1"));   # number of timesteps (seconds) per simulation
+int  range = toInt(arg("range",  "100")); # range of the generated random numbers
+int values = toInt(arg("values", "10"));  # number of values generated per simulation
+# Main script and data
+file seedfile <"output/seed.dat">;        # Dynamically generated bias for simulation ensemble
+tracef("\n*** Script parameters: nsim=%i range=%i num values=%i\n\n", nsim, range, values);
+file sims[];                      # Array of files to hold each simulation output
+  file biasfile <single_file_mapper; file=strcat("output/bias_",i,".dat")>;
+  biasfile = genbias(1000, 20);
+  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values, seedfile);
+  sims[i] = simout;
+(stats_out,stats_log) = analyze(sims);
Added: SwiftTutorials/swift-midway-tutorial/part06/swift.properties
--- SwiftTutorials/swift-midway-tutorial/part06/swift.properties	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/part06/swift.properties	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1 @@
+site=sandyb
Added: SwiftTutorials/swift-midway-tutorial/setup.sh
--- SwiftTutorials/swift-midway-tutorial/setup.sh	                        (rev 0)
+++ SwiftTutorials/swift-midway-tutorial/setup.sh	2013-12-02 15:19:14 UTC (rev 7351)
@@ -0,0 +1,7 @@
+# Load modules
+module load swift-conf
+echo Swift version is $(swift -version)
+# Add applications to $PATH
+TUTDIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+PATH=$TUTDIR/bin:$TUTDIR/app:$PATH
