[Swift-commit] r6491 - in SwiftTutorials/OSG_2013-03-11/MODIS: . test.intrepid
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Tue Apr 30 11:31:51 CDT 2013
Author: davidk
Date: 2013-04-30 11:31:50 -0500 (Tue, 30 Apr 2013)
New Revision: 6491
Added:
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/cf
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/getlanduse.pl
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/intrepid.xml
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/run
   SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/tc
Log:
Modis intrepid test
Added: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/cf
--- SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/cf	                        (rev 0)
+++ SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/cf	2013-04-30 16:31:50 UTC (rev 6491)
@@ -0,0 +1,8 @@
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=false
+status.mode=provider
+use.provider.staging=true
+provider.staging.pin.swiftfiles=false
Added: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/getlanduse.pl
--- SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/getlanduse.pl	                        (rev 0)
+++ SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/getlanduse.pl	2013-04-30 16:31:50 UTC (rev 6491)
@@ -0,0 +1,29 @@
+#!/usr/bin/perl -w
+# Input to this program should be a raw, greyscale RGB file
+# Usage: rgb_histogram.pl myfile.rgb
+my $image_filename = shift;
+open(IMAGEFILE, "$image_filename") || die "Unable to open $image_filename!\n";
+binmode IMAGEFILE;
+my @pixelcount;
+foreach my $count (0..255) { $pixelcount[$count] = 0; }
+# Read values, three bytes at a time
+$/ = \3;
+foreach(<IMAGEFILE>) {
+   $pixelcount[unpack('C', $_)]++;
+close(IMAGEFILE);
+ at sortedcount = sort {$b <=> $a} @pixelcount;
+   if($sortedcount[$count] == 0) { next; }
+   printf("%d %d %02x\n", $sortedcount[$count], $count, $count);
+system("hostname -f 2>&1");
+sleep(1);
Property changes on: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/getlanduse.pl
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/intrepid.xml
--- SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/intrepid.xml	                        (rev 0)
+++ SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/intrepid.xml	2013-04-30 16:31:50 UTC (rev 6491)
@@ -0,0 +1,22 @@
+<config>
+  <pool handle="intrepid">
+    <execution provider="coaster" jobmanager="local:cobalt"/>
+    <filesystem provider="local" />
+   <profile namespace="globus" key="internalHostname">172.17.5.141</profile>
+   <profile namespace="globus"  key="kernelprofile">zeptoos</profile>
+   <profile namespace="globus"  key="alcfbgpnat">true</profile>
+    <profile namespace="globus"  key="project">MTCScienceApps</profile>
+    <profile namespace="globus"  key="queue">prod</profile>
+    <profile namespace="karajan" key="jobthrottle">0</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+    <profile namespace="globus"  key="jobsPerNode">1</profile>
+    <profile namespace="globus"  key="workerLoggingLevel">DEBUG</profile>
+    <profile namespace="globus"  key="workerLoggingDirectory">/intrepid-fs0/users/davidk/scratch/MODIS/test.intrepid</profile>
+    <profile namespace="globus"  key="slots">1</profile>
+    <profile namespace="globus"  key="maxTime">900</profile> <!-- seconds -->
+    <profile namespace="globus"  key="nodeGranularity">512</profile>
+    <profile namespace="globus"  key="maxNodes">512</profile>
+    <workdirectory>/intrepid-fs0/users/davidk/scratch/MODIS/test.intrepid/scratch</workdirectory>
+  </pool>
+</config>
Added: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/run
--- SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/run	                        (rev 0)
+++ SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/run	2013-04-30 16:31:50 UTC (rev 6491)
@@ -0,0 +1,5 @@
+#! /bin/sh
+set -x
+swift -config cf -sites.file intrepid.xml -tc.file tc ../modis.swift -modisdir=input/
Property changes on: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/run
Added: SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/tc
--- SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/tc	                        (rev 0)
+++ SwiftTutorials/OSG_2013-03-11/MODIS/test.intrepid/tc	2013-04-30 16:31:50 UTC (rev 6491)
@@ -0,0 +1 @@
+intrepid perl /usr/bin/perl null null null
