[Swift-commit] r6439 - branches/faster/src/org/griphyn/vdl/mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Apr 13 20:15:12 CDT 2013
Author: hategan
Date: 2013-04-13 20:15:12 -0500 (Sat, 13 Apr 2013)
New Revision: 6439
Modified:
   branches/faster/src/org/griphyn/vdl/mapping/AbstractDataNode.java
Log:
fix sync issues with external type
Modified: branches/faster/src/org/griphyn/vdl/mapping/AbstractDataNode.java
--- branches/faster/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-04-14 01:14:39 UTC (rev 6438)
+++ branches/faster/src/org/griphyn/vdl/mapping/AbstractDataNode.java	2013-04-14 01:15:12 UTC (rev 6439)
@@ -233,6 +233,17 @@
         return prefix;
+    public String getFullName() {
+        String name = getDisplayableName();
+        Path p = getPathFromRoot();
+        if (p.isEmpty()) {
+            return name;
+        else {
+            return name + "." + p;
     public String getDeclarationLine() {
         String line = getRoot().getParam(MappingParam.SWIFT_LINE);
         if (line == null || line.length() == 0) {
@@ -398,7 +409,7 @@
-    public Object getValue() {
+    public synchronized Object getValue() {
         checkNoValue();
         checkDataException();
         if (field.getType().isArray()) {
@@ -420,16 +431,20 @@
     public void setValue(Object value) {
-        if (this.closed) {
-            throw new IllegalArgumentException(this.getDisplayableName()
-            		+ " is closed with a value of " + this.value);
+        synchronized(this) {
+            if (this.closed) {
+                throw new IllegalArgumentException(this.getFullName()
+                		+ " is closed with a value of " + this.value);
+            if (this.value != null) {
+                		+ " is already assigned with a value of " + this.value);
+            this.value = value;
+            this.closed = true;
-        if (this.value != null) {
-            		+ " is already assigned with a value of " + this.value);
-        this.value = value;
-        closeShallow();
+        postCloseActions();
     public Collection<Path> getFringePaths() throws HandleOpenException {
@@ -466,7 +481,7 @@
     public void closeShallow() {
             if (this.closed) {
@@ -474,6 +489,10 @@
             this.closed = true;
+    private void postCloseActions() {
         // closed
         notifyListeners();
         if (logger.isDebugEnabled()) {
@@ -687,10 +706,10 @@
             AbstractDataNode parent = getParentNode();
             if (parent != null && parent.getType().isArray()) {
-                throw new IndexOutOfBoundsException("Invalid index [" + field.getId() + "] for " + parent.getDisplayableName());
+                throw new IndexOutOfBoundsException("Invalid index [" + field.getId() + "] for " + parent.getFullName());
             else {
-                throw new RuntimeException(getDisplayableName() + " has no value");
+                throw new RuntimeException(getFullName() + " has no value");
