[Swift-commit] r6421 - in SwiftTutorials/UofC_2013-04-09: . part06 part07
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Tue Apr 9 09:48:47 CDT 2013
Author: wilde
Date: 2013-04-09 09:48:47 -0500 (Tue, 09 Apr 2013)
New Revision: 6421
Added:
   SwiftTutorials/UofC_2013-04-09/part06/
   SwiftTutorials/UofC_2013-04-09/part06/README
   SwiftTutorials/UofC_2013-04-09/part06/p6.swift
   SwiftTutorials/UofC_2013-04-09/part06/tc
   SwiftTutorials/UofC_2013-04-09/part07/
   SwiftTutorials/UofC_2013-04-09/part07/README
   SwiftTutorials/UofC_2013-04-09/part07/p7.swift
   SwiftTutorials/UofC_2013-04-09/part07/sites.xml
   SwiftTutorials/UofC_2013-04-09/part07/tc
Log:
Added new parts for arg passing and cluster execution.
Added: SwiftTutorials/UofC_2013-04-09/part06/README
--- SwiftTutorials/UofC_2013-04-09/part06/README	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part06/README	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,28 @@
+Swift script - add arguments to the "simulation" program to control number of steps,
+               range of output, and number of output lines,
+Test new versions of the "simulation" program:
+  random.sh                            # original
+  random2.sh [runtime]                 # runtime in seconds; defaults to 1 sec
+  random3.sh [runtime] [range]         # requests random numbers in {0:range-1}
+  random4.sh [runtime] [range] [count] # requests "count" random numbers in {0:range}
+p6.swift changes to random2 for the simulation program and adds an argument.
+Run the program:
+$ swift -tc.file tc p6.swift -steps 3  # each simulation takes 3 seconds
+Next we need to use the parallel cluster for our simulations!
+Try:
+- change to random3.sh and add the extra argument "range"
+- change to random4.sh and add yet another argument "count"
Added: SwiftTutorials/UofC_2013-04-09/part06/p6.swift
--- SwiftTutorials/UofC_2013-04-09/part06/p6.swift	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part06/p6.swift	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,25 @@
+type file;
+app (file o) mysim2 (int timesteps)
+  random2 timesteps stdout=@filename(o);
+app (file o) analyze (file s[])
+  average @filenames(s) stdout=@filename(o);
+file sims[];
+int  nsim = @toInt(@arg("nsim","10"));
+int steps = @toInt(@arg("steps","1"));
+foreach i in [0:nsim-1] {
+  file simout <single_file_mapper; file=@strcat("output/sim_",i,".out")>;
+  simout = mysim2(steps);
+  sims[i] = simout;
+file stats<"output/average.out">;
+stats = analyze(sims);
Added: SwiftTutorials/UofC_2013-04-09/part06/tc
--- SwiftTutorials/UofC_2013-04-09/part06/tc	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part06/tc	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,2 @@
+localhost random2  random2.sh
+localhost average avg.sh
Added: SwiftTutorials/UofC_2013-04-09/part07/README
--- SwiftTutorials/UofC_2013-04-09/part07/README	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part07/README	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,81 @@
+Swift script - execution on the parallel cluster
+Til now we've been running our "simulations" on the local login host.
+Now we'll run them on the parallel cluster.
+The script will be the same as previous, but we change the tool catalog to
+indicate that our "simulation app" (random4.sh) should be run on the
+"westmere" partition of the Midway cluster using the "slurm" scheduler:
+We changed file "tc" from:
+localhost random4  random4.sh
+to:
+westmere  random4  random4.sh
+And we added the "sites.xml" file which specifies two "pools" of resources,
+the "local host" pool (which we've been using till now) and the "westmere" pool.
+To run, we now add the sites.xml file to the swift command line:
+$ swift -tc.file tc -sites.file sites.xml p7.swift -steps=10 -range=1000 -count=6 -nsim=100
+Note that we're now asking for 100 simulations to be run, each of which
+is to run for 10 steps (ie 10 seconds).
+The sites file looks like this:
+<config>
+  <pool handle="localhost">
+    <execution provider="local"/>
+    <filesystem provider="local"/>
+    <workdirectory>/scratch/midway/{env.USER}/swiftwork</workdirectory>
+  </pool>
+  <pool handle="westmere">
+    <execution provider="coaster" jobmanager="local:slurm"/>
+    <!-- Set partition and account here: -->
+    <profile namespace="globus" key="queue">westmere</profile>
+    <profile namespace="globus" key="ppn">12</profile>
+    <!-- <profile namespace="globus" key="project">pi-wilde</profile> -->
+    <!-- Set number of jobs and nodes per job here: -->
+    <profile namespace="globus" key="slots">1</profile>
+    <profile namespace="globus" key="maxnodes">1</profile>
+    <profile namespace="globus" key="nodegranularity">1</profile>
+    <profile namespace="globus" key="jobsPerNode">12</profile> <!-- apps per node! -->
+    <profile namespace="karajan" key="jobThrottle">.11</profile> <!-- eg .11 -> 12 -->
+    <!-- Set estimated app time (maxwalltime) and requested job time (maxtime) here: -->
+    <profile namespace="globus" key="maxWalltime">00:15:00</profile>
+    <profile namespace="globus" key="maxtime">1800</profile>  <!-- in seconds! -->
+    <!-- Set data staging model and work dir here: -->
+    <!-- Typically leave these constant: -->
+    <profile namespace="globus" key="slurm.exclusive">false</profile>
+    <profile namespace="globus" key="highOverAllocation">100</profile>
+    <profile namespace="globus" key="lowOverAllocation">100</profile>
+    <profile namespace="karajan" key="initialScore">10000</profile>
+  </pool>
+</config>
+Try:
+- running more app() calls at once:  change jobsPerNode and jobThrottle
+- requesting more than 1 slurm job at once: change slots
+- requesting nodes in units greater than 1: change maxnodes and nodeGranularity
Added: SwiftTutorials/UofC_2013-04-09/part07/p7.swift
--- SwiftTutorials/UofC_2013-04-09/part07/p7.swift	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part07/p7.swift	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,27 @@
+type file;
+app (file o) mysim4 (int timesteps, int range, int count)
+  random4 timesteps range count stdout=@filename(o);
+file sims[];
+int  nsim  = @toInt(@arg("nsim",  "10"));
+int  steps = @toInt(@arg("steps", "1"));
+int  range = @toInt(@arg("range", "100"));
+int  count = @toInt(@arg("count", "10"));
+  simout = mysim4(steps,range,count);
+  sims[i] = simout;
Added: SwiftTutorials/UofC_2013-04-09/part07/sites.xml
--- SwiftTutorials/UofC_2013-04-09/part07/sites.xml	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part07/sites.xml	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,39 @@
+<config>
+  </pool>
+  </pool>
+</config>
Added: SwiftTutorials/UofC_2013-04-09/part07/tc
--- SwiftTutorials/UofC_2013-04-09/part07/tc	                        (rev 0)
+++ SwiftTutorials/UofC_2013-04-09/part07/tc	2013-04-09 14:48:47 UTC (rev 6421)
@@ -0,0 +1,2 @@
