[Swift-commit] r5978 - SwiftApps/EpiSnp
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Fri Oct 19 12:18:15 CDT 2012
Author: wilde
Date: 2012-10-19 12:18:04 -0500 (Fri, 19 Oct 2012)
New Revision: 5978
Added:
   SwiftApps/EpiSnp/EPISNP1v41.gz
   SwiftApps/EpiSnp/cf
   SwiftApps/EpiSnp/chroms.tgz
   SwiftApps/EpiSnp/episnp.swift
   SwiftApps/EpiSnp/epiwrap.sh
   SwiftApps/EpiSnp/sites.xml
   SwiftApps/EpiSnp/tc
   SwiftApps/EpiSnp/trait.dat
Log:
Initial EpiSnp code
Added: SwiftApps/EpiSnp/EPISNP1v41.gz
(Binary files differ)
Property changes on: SwiftApps/EpiSnp/EPISNP1v41.gz
___________________________________________________________________
Added: svn:executable
Added: svn:mime-type
   + application/octet-stream
Added: SwiftApps/EpiSnp/cf
--- SwiftApps/EpiSnp/cf	                        (rev 0)
+++ SwiftApps/EpiSnp/cf	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,360 @@
+sites.file=${swift.home}/etc/sites.xml
+tc.file=${swift.home}/etc/tc.data
+# The host name of the submit machine is used by GRAM as a callback
+# address to report the status of submitted jobs. In general, Swift
+# can automatically detect the host name of the local machine.
+# However, if the machine host name is improperly configured or if
+# it does not represent a valid DNS entry, certain services (such as
+# GRAM) will not be able to send job status notifications back to
+# the client. The value of this property can be an IP address.
+# Format:
+#    hostname=string
+#hostname=localhost
+# A TCP port range can be specified to restrict the ports on which GRAM
+# callback services are started. This is likely needed if your submit
+# host is behind a firewall, in which case the firewall should be
+# configured to allow incoming connections on ports in the range.
+# Format:
+#     tcp.port.range=start,end
+#tcp.port.range=50000,50100
+# false	- means an error will be immediately reported and cause the
+# 		workflow to abort. At this time remote jobs that are already
+#		running will not be canceled
+# true	- means that Swift will try to do as much work as possible and
+#		report all errors encountered at the end. However, "errors"
+#		here only applies to job execution errors. Certain errors
+#		that are related to the Swift implementation (should such
+#		errors occur) will still be reported eagerly.
+# Default: false
+lazy.errors=false
+# What algorithm to use for caching of remote files. LRU (as in what
+# files to purge) is the only implementation right now. One can set
+# a target size (in bytes) for a host by using the swift:storagesize
+# profile for a host in sites.xml
+# Default: LRU
+caching.algorithm=LRU
+# true       - generate a provenance graph in .dot format (Swift will
+#			 choose a random file name)
+# false      - do not generate a provenance graph
+# <filename> - generate a provenange graph in the give file name
+# Default: false
+pgraph=false
+# graph properties for the provenance graph (.dot specific)
+# Default: splines="compound", rankdir="TB"
+pgraph.graph.options=splines="compound", rankdir="TB"
+# node properties for the provenance graph (.dot specific)
+# Default: color="seagreen", style="filled"
+pgraph.node.options=color="seagreen", style="filled"
+# true	- clustering of small jobs is enabled. Clustering works in the
+#       following way: If a job is clusterable (meaning that it has the
+#       GLOBUS::maxwalltime profile specified in tc.data and its value
+#       is less than the value of the "clustering.min.time" property) it will
+#       be put in a clustering queue. The queue is processed at intervals
+#       specified by the "clustering.queue.delay" property. The processing
+#       of the clustering queue consists of selecting compatible jobs and
+#		grouping them in clusters whose max wall time does not exceed twice
+#       the value of the "clustering.min.time" property. Two or more jobs are
+#       considered compatible if they share the same site and do not have
+#       conflicting profiles (e.g. different values for the same environment
+#       variable).
+# false	- clustering of small jobs is disabled.
+# Default: false
+clustering.enabled=false
+# <seconds>	- the intervals at which the clustering queue is processed
+# Default: 4
+clustering.queue.delay=4
+# <seconds>	- the threshold time for clustering
+# Default: 60
+clustering.min.time=60
+# Kickstart is a useful tool that can be used to gather various information
+# about a remote process. Before it can be used it must be installed on the
+# remote site and the corresponding entry be set in the sites file.
+# This option allows controlling of how Swift uses Kickstart. The following
+# values are possible:
+# false - do not use Kickstart
+# true  - use Kickstart. If a job is scheduled on a site that does not have
+#       Kickstart installed, that job will fail.
+# maybe - Use Kickstart if installed (i.e. the entry is present in the sites
+#       file)
+# Default: maybe
+kickstart.enabled=maybe
+# Indicates when Kickstart records should be fetched from the remote site:
+# true	- always transfer Kickstart records if Kickstart was used (see
+#		kickstart.enabled)
+# false	- only transfer Kickstart records if the job fails
+# Default: false
+kickstart.always.transfer=false
+# Indicates when wrapper logs should be fetched from the remote site:
+# true	- always transfer wrapper logs
+# false	- only transfer wrapper logs if the job fails
+# Default: false
+wrapperlog.always.transfer=false
+#                          Throttling options                             #
+# For the throttling parameters, valid values are either a positive integer
+# or "off" (without the quotes).
+# Limits the number of concurrent submissions for a workflow instance. This
+# throttle only limits the number of concurrent tasks (jobs) that are being
+# sent to sites, not the total number of concurrent jobs that can be run.
+# The submission stage in GRAM is one of the most CPU expensive stages (due
+# mostly to the mutual authentication and delegation). Having too many
+# concurrent submissions can overload either or both the submit host CPU
+# and the remote host/head node causing degraded performance.
+# Default: 4
+throttle.submit=4
+#throttle.submit=off
+# Limits the number of concurrent submissions for any of the sites Swift will
+# try to send jobs to. In other words it guarantees that no more than the
+# value of this throttle jobs sent to any site will be concurrently in a state
+# of being submitted.
+# Default: 2
+throttle.host.submit=2
+#throttle.host.submit=off
+# The Swift scheduler has the ability to limit the number of concurrent jobs
+# allowed on a site based on the performance history of that site. Each site
+# is assigned a score (initially 1), which can increase or decrease based
+# on whether the site yields successful or faulty job runs. The score for a
+# site can take values in the (0.1, 100) interval. The number of allowed jobs
+# is calculated using the following formula:
+# 	2 + score*throttle.score.job.factor
+# This means a site will always be allowed at least two concurrent jobs and
+# at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
+# at least 2 jobs and at most 402.
+# Default: 4
+throttle.score.job.factor=0.2
+#throttle.score.job.factor=off
+# Limits the total number of concurrent file transfers that can happen at any
+# given time. File transfers consume bandwidth. Too many concurrent transfers
+# can cause the network to be overloaded preventing various other signalling
+# traffic from flowing properly.
+# Default: 4
+throttle.transfers=4
+#throttle.transfers=off
+# Limits the total number of concurrent file operations that can happen at any
+# given time. File operations (like transfers) require an exclusive connection
+# to a site. These connections can be expensive to establish. A large number
+# of concurrent file operations may cause Swift to attempt to establish many
+# such expensive connections to various sites. Limiting the number of concurrent
+# file operations causes Swift to use a small number of cached connections and
+# achieve better overall performance.
+# Default: 8
+throttle.file.operations=8
+#throttle.file.operations=off
+# Indicates whether the working directory on the remote site should be
+# left intact even when the workflow completes successfully. This can be
+# used to inspect the site working directory for debugging purposes.
+# Default: false
+sitedir.keep=false
+# number of time a job will be retried if it fails (giving a maximum of
+# 1 + execution.retries attempts at execution)
+execution.retries=2
+# Enables/disables replication. Replication is used to deal with jobs sitting
+# in batch queues for abnormally large amounts of time. If replication is enabled
+# and certain conditions are met, Swift creates and submits replicas of jobs, and
+# allows multiple instances of a job to compete.
+replication.enabled=false
+# If replication is enabled, this value specifies the minimum time, in seconds,
+# a job needs to be queued in a batch queue in order to be considered for
+# replication
+replication.min.queue.time=60
+# The maximum number of replicas that Swift should attempt.
+replication.limit=3
+# WARNING: This option is deprecated. Please use the hostname option.
+# The IP address of the submit machine is used by GRAM as a callback
+# can automatically detect the IP address of the local machine.
+# However, if the machine has more than one network interface, Swift
+# will pick the first one, which may not be the right choice. It is
+# recommended that this property is set properly before attempting to
+# run jobs through GRAM.
+# Format:
+#    ip.address=x.y.z.w
+#ip.address=127.0.0.1
+# Controls how Swift will communicate the result code of running user programs
+# from workers to the submit side. In files mode, a file
+# indicating success or failure will be created on the site shared filesystem.
+# In provider mode, the execution provider job status will
+# be used. Notably, GRAM2 does not return job statuses correctly, and so
+# provider mode will not work with GRAM2. With other
+# providers, it can be used to reduce the amount of filesystem access compared
+# to files mode.
+# status.mode=files
+# Controls how swift will supply parameters to the remote wrapper script.
+# 'args' mode will pass parameters on the command line
+# 'files' mode will pass parameters through an additional input file
+# valid values: args, files
+# Default: files
+# wrapper.parameter.mode=args
+# Determines if Swift remote wrappers will be executed by specifying an
+# absolute path, or a path relative to the job initial working directory
+# valid values: absolute, relative
+# wrapper.invocation.mode=absolute
+# Limits the number of concurrent iterations that each foreach statement
+# can have at one time. This conserves memory for swift programs that
+# have large numbers of iterations (which would otherwise all be executed
+# in parallel).
+# Default: 1024
+foreach.max.threads=16384
+# controls whether the log file will contain provenance information
+# enabling this will increase the size of log files, sometimes
+# significantly.
+provenance.log=false
+# Controls whether file staging is done by swift or by the execution
+# provider. If set to false, the standard swift staging mechanism is
+# used. If set to true, swift does not stage files. Instead, the
+# execution provider is instructed to stage files in and out.
+# Provider staging is experimental.
+# When enabled, and when coasters are used as an execution provider,
+# a staging mechanism can be selected for each site
+# using the swift:stagingMethod site profile in sites.xml. The
+# following is a list of accepted mechanisms:
+# * file:  Staging is done from a filesystem accessible to the
+#          coaster service (typically running on the head node)
+# * proxy: Staging is done from a filesystem accessible to the
+#          client machine that swift is running on, and is proxied
+#          through the coaster service
+# * sfs:   (short for "shared filesystem") Staging is done by
+#          copying files to and from a filesystem accessible
+#          by the compute node (such as an NFS or GPFS mount).
+use.provider.staging=false
+# Changed settings:
+wrapperlog.always.transfer=true
+sitedir.keep=true
+execution.retries=0
+lazy.errors=false
+status.mode=provider
Added: SwiftApps/EpiSnp/chroms.tgz
Property changes on: SwiftApps/EpiSnp/chroms.tgz
Added: SwiftApps/EpiSnp/episnp.swift
--- SwiftApps/EpiSnp/episnp.swift	                        (rev 0)
+++ SwiftApps/EpiSnp/episnp.swift	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,24 @@
+type file;
+app (file fig, file sig, file log) episnp (file wrapper, file exec, file trait, file chroms, int nSingles, int nPairs)
+  sh @wrapper @exec @trait @chroms nSingles nPairs @log @fig @sig;
+file epiwrapper<"epiwrap.sh">;
+file epiexec<"EPISNP1v41.gz">;
+file epitrait <"trait.dat">;
+file epichroms<"chroms.tgz">;
+file logout[]<simple_mapper; location="output", prefix="episnp.",suffix=".out">;
+file figout[]<simple_mapper; location="output", prefix="single_locus_fig.",suffix=".out">;
+file sigout[]<simple_mapper; location="output", prefix="single_locus_sig.",suffix=".out">;
+int nRuns = @toint(@arg("nRuns","1"));
+foreach incr, i in [0:nRuns-1] {
+  (figout[i], sigout[i], logout[i]) = episnp(epiwrapper, epiexec, epitrait, epichroms, 1000+i, 10000+i);
Added: SwiftApps/EpiSnp/epiwrap.sh
--- SwiftApps/EpiSnp/epiwrap.sh	                        (rev 0)
+++ SwiftApps/EpiSnp/epiwrap.sh	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,56 @@
+#! /bin/sh
+# called from swift app cmd: sh @wrapper @exec @trait @chroms nSingles nPairs @epiout @fig @sig;
+exec=$1
+trait=$2
+chroms=$3
+nSingles=$4
+nPairs=$5
+epiout=$6
+figout=$7
+sigout=$8
+echo $0: exec=$exec trait=$trait chroms=$chroms nSingles=$nSingles nPairs=$nPairs figout=$figout sigout=$sigout
+cp $exec episnp.gz
+gunzip episnp
+chmod +x episnp
+tar zxf $chroms
+# FIXME: make # chrNN.dat files below depend on # files in input tarball
+cat >parameter.dat <<END
+0
+1  # number of traits
+6  # starting position of traits in the trait file
+4  1  2  # number of column for gender information and codes for male and female
+9999  # code for missing traits, non-genetic factors and covariables
+1654 # number of individuals
+0  # number of non-genetic factors
+0  # positions of the non-genetic factors
+0  # number of covariables
+0  # positions of covariables in the trait file
+6  # number of chromosomes
+30  # sex chromosome number
+1  # 1: 0=A1A1, 1=A1A2, 2=A2A2 and others=missing used for coding; 2: A1/A1, A1/A2 and A2/A2 used for coding, 0/0 used for missing
+2  # starting position of SNPs in the SNP data file
+1500 chr01.dat
+1200 chr02.dat
+1300 chr03.dat
+1400 chr04.dat
+1500 chr05.dat
+1600 chr06.dat
+trait.dat  # file name of the phenotype data
+$nSingles  # number of most significant results for single SNP tests to be printed in the output file
+$nPairs  # number of most significant results for pairwise tests to be printed in the output file
+END
+./episnp >& episnp.out
+mv episnp.out $epiout
+mv single_locus_fig.out $figout
+mv single_locus_sig.out $sigout
Property changes on: SwiftApps/EpiSnp/epiwrap.sh
Added: SwiftApps/EpiSnp/sites.xml
--- SwiftApps/EpiSnp/sites.xml	                        (rev 0)
+++ SwiftApps/EpiSnp/sites.xml	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,7 @@
+<config>
+  <pool handle="localhost">
+    <execution provider="local"/>
+    <filesystem provider="local"/>
+    <workdirectory >/home/wilde/swiftwork</workdirectory>
+  </pool>
+</config>
Added: SwiftApps/EpiSnp/tc
--- SwiftApps/EpiSnp/tc	                        (rev 0)
+++ SwiftApps/EpiSnp/tc	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,46 @@
+#This is the transformation catalog.
+#It comes pre-configured with a number of simple transformations with
+#paths that are likely to work on a linux box. However, on some systems,
+#the paths to these executables will be different (for example, sometimes
+#some of these programs are found in /usr/bin rather than in /bin)
+#NOTE WELL: fields in this file must be separated by tabs, not spaces; and
+#there must be no trailing whitespace at the end of each line.
+# sitename  transformation  path   INSTALLED  platform  profiles
+localhost 	sh 		/bin/sh	INSTALLED	INTEL32::LINUX	null
+localhost 	echo 		/bin/echo	INSTALLED	INTEL32::LINUX	null
+localhost 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+localhost 	ls 		/bin/ls		INSTALLED	INTEL32::LINUX	null
+localhost 	grep 		/bin/grep	INSTALLED	INTEL32::LINUX	null
+localhost 	sort 		/bin/sort	INSTALLED	INTEL32::LINUX	null
+localhost 	paste 		/bin/paste	INSTALLED	INTEL32::LINUX	null
+localhost 	pwd 		/bin/pwd	INSTALLED	INTEL32::LINUX	null
+ranger 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+abe 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+qb 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+firefly 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+teraport 	cat 		/bin/cat	INSTALLED	INTEL32::LINUX	null
+pbs	cat	/bin/cat	null	null	null
+ssh	cat	/bin/cat	null	null	null
+rssh	scat	/home/wilde/swift/lab/scat	null	null	null
+sico cat /bin/cat null null null
+sico scat /home/wilde/swift/lab/scat null null null
+crush	cat	/bin/cat	null	null	null
+thwomp	cat	/bin/cat	null	null	null
+stomp	cat	/bin/cat	null	null	null
+crank	cat	/bin/cat	null	null	null
+steamroller cat	/bin/cat	null	null	null
+grind	cat	/bin/cat	null	null	null
+churn	cat	/bin/cat	null	null	null
+trounce	cat	/bin/cat	null	null	null
+thrash	cat	/bin/cat	null	null	null
+vanquish cat	/bin/cat	null	null	null
+octagon	cat	/bin/cat	null	null	null
+octopus	cat	/bin/cat	null	null	null
+triumph	cat	/bin/cat	null	null	null
Added: SwiftApps/EpiSnp/trait.dat
--- SwiftApps/EpiSnp/trait.dat	                        (rev 0)
+++ SwiftApps/EpiSnp/trait.dat	2012-10-19 17:18:04 UTC (rev 5978)
@@ -0,0 +1,1655 @@
+Ind_ID	Father	Mather	Sex	V1	V2
+39365164	2514957	251496	2	-0.024249451	-0.008311192
+39365317	2458842	245884	2	-0.024640478	-0.005954723
+41613317	39069784	3906978	2	-0.023986114	0.007279951
+41613948	2605219	260522	2	-0.024424976	-0.007425483
+41616376	2619125	261913	2	-0.024352501	-0.010362572
+41616727	2599307	259931	2	-0.024452038	0.001807755
+42212025	39069784	3906978	2	-0.024628581	-0.003051996
+42213207	2599307	259931	2	-0.024624802	-0.012352243
+42450432	2605219	260522	2	-0.024499769	0.005495207
+42451542	2605219	260522	2	-0.024233538	-0.000559442
+43151963	2617409	261741	2	-0.024759088	-0.02081158
+43151964	34497515	3449752	2	-0.024632632	-0.007996824
+35119306	2394422	239442	2	-0.024014885	-0.009605842
+35096810	2394422	239442	2	-0.02397682	-0.015134982
+35386984	2332434	233243	2	-0.023795731	-0.005213932
+35611311	2332434	233243	2	-0.023518193	-0.007434283
+35895508	2607954	260795	2	-0.024326758	0.000192713
+35909665	2607954	260795	2	-0.024243873	-0.010231569
+37110737	2467939	246794	2	-0.024228158	-0.02267634
+37575919	2470808	247081	2	-0.024473009	-0.015076175
+37578280	2455053	245505	2	-0.024376582	-0.018000156
+37578623	2473557	247356	2	-0.024882702	-0.014212082
+35119307	2394422	239442	2	-0.024043743	-0.010964472
+35386974	2314284	231428	2	-0.024150982	0.005478606
+35611317	2332434	233243	2	-0.023911567	-0.011803293
+35611322	2406276	240628	2	-0.025036246	-0.013471531
+35895515	2607954	260795	2	-0.023727397	-0.012250855
+36185763	2405465	240547	2	-0.024247355	-0.015618297
+37110738	2455053	245505	2	-0.024126405	-0.017026646
+37110739	2467939	246794	2	-0.024069778	-0.025611017
+37575965	2470808	247081	2	-0.024644203	0.001016539
+37576591	2470808	247081	2	-0.024747204	-0.008613882
+37799919	2455053	245505	2	-0.024385097	-0.012735086
+37800348	2455053	245505	2	-0.02430688	-0.022906221
+38110432	2473557	247356	2	-0.023783453	-0.024644736
+38111366	2455053	245505	2	-0.024350111	-0.011380525
+38881855	2514957	251496	2	-0.023924431	-0.011209712
+38882200	2439114	243911	2	-0.024517323	0.041103817
+17489567	2325626	232563	2	-0.024259562	-0.015291021
+17489581	2273408	227341	2	-0.023869636	-0.009449827
+38883130	2439114	243911	2	-0.02563748	0.028095182
+35386979	2314284	231428	2	-0.024442422	-0.003221223
+35386980	2539707	253971	2	-0.023764491	0.002567522
+35620206	2406276	240628	2	-0.024391167	-0.002295695
+35885153	2368204	236820	2	-0.024267205	0.004146435
+36742899	2607954	260795	2	-0.024221113	-0.001477216
+36742900	2406276	240628	2	-0.02423881	-0.013845755
+37110742	2455053	245505	2	-0.024553128	-0.004100016
+37334022	2467939	246794	2	-0.025203233	-0.009441317
+37577276	2473557	247356	2	-0.024455149	-0.023657146
+40329970	2467939	246794	2	-0.02487377	-0.015460641
+38109866	2455053	245505	2	-0.024137743	-0.013280453
+38110308	2470808	247081	2	-0.024740747	-0.013095291
+35386976	2314284	231428	2	-0.024579693	0.007921365
+35386977	2539707	253971	2	-0.023915301	-0.008467072
+35611324	2406276	240628	2	-0.02557557	-0.015669468
+36180489	2406276	240628	2	-0.023918287	-0.013042656
+36180491	2368204	236820	2	-0.024031324	0.003209519
+37110740	2473557	247356	2	-0.024529858	-0.018880574
+37110741	2467939	246794	2	-0.024706971	-0.009741066
+37576809	2473557	247356	2	-0.024537301	-0.015773812
+37577239	2467939	246794	2	-0.024448675	-0.017685566
+38109669	2455053	245505	2	-0.024381287	-0.014825508
+38109846	2470808	247081	2	-0.02423583	-0.013147149
+39366258	2458842	245884	2	-0.024679269	0.001836519
+39725746	2563198	256320	2	-0.024415448	-0.019712114
+41615419	2619125	261913	2	-0.02517064	-0.010118711
+41615420	2619125	261913	2	-0.024256751	-0.009587081
+41617717	2599307	259931	2	-0.024279067	-0.006817618
+41618203	2599307	259931	2	-0.024096418	-0.004621482
+42449199	39069784	3906978	2	-0.024185545	-0.007192261
+42449289	39069784	3906978	2	-0.024040231	-0.002672615
+43025194	34459773	3445977	2	-0.024154337	-0.010508278
+43025266	34459773	3445977	2	-0.024689456	-0.008127019
+43153981	34459773	3445977	2	-0.024492912	-0.008200289
+39365393	2514957	251496	2	-0.0248346	0.000219486
+39365512	2492444	249244	2	-0.024406257	-0.018412647
+41613949	2605219	260522	2	-0.024338224	-0.001356513
+41615048	2599307	259931	2	-0.026154474	0.000331201
+41616842	39069784	3906978	2	-0.023933481	-0.003194319
+41616952	2619125	261913	2	-0.024764798	0.013838641
+42214874	39069784	3906978	2	-0.02459475	0.002544904
+42215828	2599307	259931	2	-0.024551196	0.0032209
+42452825	2617409	261741	2	-0.024752067	-0.010391923
+43024843	2617409	261741	2	-0.024527017	-0.016501353
+43153121	34497515	3449752	2	-0.024985226	-0.003747078
+43153182	34497515	3449752	2	-0.024595359	-0.005399605
+17190923	2262166	226217	2	-0.024373822	-0.008964113
+17255139	2217017	221702	2	-0.023635329	0.000183751
+17489574	2539684	253968	2	-0.023600315	-0.006718188
+17537481	2539684	253968	2	-0.023658817	-0.00527186
+34847412	2394422	239442	2	-0.024527211	-0.007619823
+34847414	2332434	233243	2	-0.023572861	0.00241278
+34873511	2314284	231428	2	-0.024302474	0.006255449
+17257090	2262166	226217	2	-0.024601708	0.009214903
+17257093	2262166	226217	2	-0.02411475	-0.015143818
+17537489	2272247	227225	2	-0.024316927	-0.005441675
+17537491	2273408	227341	2	-0.023500572	-0.019128244
+34847420	2332434	233243	2	-0.023871841	-0.009710517
+34847423	2332434	233243	2	-0.023528569	-0.012567664
+34847428	2394422	239442	2	-0.024350823	-0.015324263
+35119299	2394422	239442	2	-0.024430538	-0.008726177
+35119301	2539707	253971	2	-0.024432214	-0.008745432
+40308819	37208121	3720812	2	-0.024065678	-0.004197257
+40562484	2563198	256320	2	-0.0245255	-0.010579368
+41615788	39069784	3906978	2	-0.024543	0.024602391
+41616027	2619125	261913	2	-0.024674503	-0.006682457
+42211766	2599307	259931	2	-0.024401489	0.000831925
+42353920	2605219	260522	2	-0.024661261	-0.001493987
+42449751	2599307	259931	2	-0.024751063	0.001219697
+43024422	39069784	3906978	2	-0.024727621	-0.009108677
+43025287	34459773	3445977	2	-0.024814782	0.016208688
+43151184	34459773	3445977	2	-0.024530038	-0.005393801
+16549110	2208408	220841	2	-0.023867011	-0.007438052
+16974900	2192431	219243	2	-0.023653057	-0.010411508
+17075945	2215588	221559	2	-0.024429848	0.001156065
+17347225	2325626	232563	2	-0.023913223	-0.014228938
+17396432	2272247	227225	2	-0.024700412	-0.005528223
+17537509	2180406	218041	2	-0.023824344	-0.004965257
+34527800	2314284	231428	2	-0.024139017	0.016480517
+34847429	2539707	253971	2	-0.024369229	-0.007686644
+34847433	2314284	231428	2	-0.024403426	0.008072091
+17091206	2240522	224052	2	-0.024556647	-0.008828509
+17190920	2263240	226324	2	-0.023622531	-0.008773764
+17489582	2330448	233045	2	-0.023851023	-0.008808882
+17489559	2539684	253968	2	-0.023720255	-0.001078642
+34847409	2539707	253971	2	-0.024567603	-0.009976628
+34847411	2539707	253971	2	-0.02417204	0.002993619
+34847437	2539707	253971	2	-0.024441535	-0.000254622
+34847440	2332434	233243	2	-0.023162954	-0.004826229
+38111367	2470808	247081	2	-0.024733318	-0.008394694
+38112183	2514957	251496	2	-0.024493775	-0.003684322
+38883325	2492444	249244	2	-0.02395716	-0.017549448
+38883502	2514957	251496	2	-0.024096464	-0.003816862
+17537487	2180406	218041	2	-0.024162409	-0.008784627
+17537519	2325626	232563	2	-0.02390066	-0.011110892
+38112484	2458842	245884	2	-0.024607352	0.000775768
+38881332	2439114	243911	2	-0.024476227	0.028300992
+38884187	2458842	245884	2	-0.024691466	-0.008797269
+38884431	2514957	251496	2	-0.02445853	-0.007335101
+34552945	2314284	231428	2	-0.024936526	0.010893419
+34847426	2314284	231428	2	-0.024871223	0.005083634
+38881376	2458842	245884	2	-0.024540247	-0.001812165
+38881454	2492444	249244	2	-0.024496985	-0.010531475
+38885220	2514957	251496	2	-0.024114794	0.001049297
+16095085	2127154	212715	2	-0.024669626	0.019561978
+35386972	2394422	239442	2	-0.023962387	-0.009453754
+37110735	2405465	240547	2	-0.024202469	-0.010962572
+44845859	35363892	3536389	2	-0.024380237	-0.018390808
+47130833	36217775	3621778	2	-0.02503369	0.065665272
+41155797	2607393	260739	2	-0.024873244	0.000800419
+47933317	40759517	4075952	2	-0.024927132	-0.0096749
+44589033	35363892	3536389	2	-0.024902547	-0.013630232
+16958110	2263240	226324	2	-0.024281895	-0.011420743
+16908399	2196882	219688	2	-0.024846545	-0.002662587
+16907925	2264218	226422	2	-0.024539431	-0.014826988
+16843191	2228701	222870	2	-0.024401381	-0.007785667
+16840254	2008001	200800	2	-0.024827098	0.011063783
+17102549	2262166	226217	2	-0.024347296	-0.014839184
+2506391	2392029	239203	2	-0.025066676	-0.016502484
+2557984	2035807	203581	2	-0.025508224	-0.009367232
+2531021	2392029	239203	2	-0.024840865	-0.013559862
+2541085	1891008	189101	2	-0.024886188	0.006909199
+16250349	2122623	212262	2	-0.025151013	-0.022100344
+2555431	1775791	177579	2	-0.024630576	-0.004989029
+2598229	1891008	189101	2	-0.024393316	0.004428174
+16481418	2198463	219846	2	-0.024244777	-0.008020134
+16493310	2181081	218108	2	-0.025376523	-0.017559832
+16744305	2035807	203581	2	-0.025368633	-0.02413012
+16749231	1953800	195380	2	-0.024331873	0.014933347
+35596139	2426427	242643	2	-0.024895307	-0.017647595
+16064096	1957142	195714	2	-0.024888812	-0.002874192
+2529447	2035807	203581	2	-0.025091257	-0.019575769
+2552240	2392029	239203	2	-0.025450983	-0.022813032
+2575935	1891008	189101	2	-0.024399148	-0.001111203
+2550855	2149325	214933	2	-0.025139775	-0.010556825
+16382249	2181081	218108	2	-0.025326794	-0.010091105
+16399763	2181081	218108	2	-0.024158556	-0.011454296
+2581587	1891008	189101	2	-0.024766049	-0.002957307
+2612167	2383767	238377	2	-0.024354559	-0.010816686
+35607242	2672344	267234	2	-0.024491039	-0.026435718
+35607245	2672344	267234	2	-0.024594282	-0.023890465
+16136593	1891008	189101	2	-0.024798396	-0.002868755
+2605883	2031596	203160	2	-0.022777489	-0.011732223
+16241066	2392029	239203	2	-0.024758164	-0.025271311
+16306045	2105692	210569	2	-0.024884254	-0.001672695
+2557871	2392029	239203	2	-0.025319843	-0.022057716
+16419694	2181081	218108	2	-0.024563963	-0.011604432
+16425893	2181081	218108	2	-0.02511193	-0.011981961
+2597503	2182729	218273	2	-0.024561801	0.013975786
+2629262	1960469	196047	2	-0.024581371	-0.01354196
+17107586	2127154	212715	2	-0.024701019	0.020346786
+17106121	2196882	219688	2	-0.02490782	-0.010149962
+17051619	2262166	226217	2	-0.024355603	-0.008985915
+17049675	2264218	226422	2	-0.024286148	-0.016086333
+17030126	2210163	221016	2	-0.024245862	-0.009487893
+17029672	2008001	200800	2	-0.02436983	0.018476964
+16997378	2008001	200800	2	-0.025060809	0.019197149
+16995026	2264218	226422	2	-0.024881065	-0.011761695
+16924297	2210163	221016	2	-0.024642434	-0.008565551
+2622109	2008001	200800	2	-0.024581238	0.01141431
+16870662	2196882	219688	2	-0.025040089	-0.016076213
+16862578	2215327	221533	2	-0.024097741	-0.011617617
+37837332	2439114	243911	2	-0.024761999	0.025914107
+37813013	2439114	243911	2	-0.024824561	0.039257442
+37405823	2473557	247356	2	-0.025001316	-0.017291355
+37354774	2672344	267234	2	-0.024806047	-0.012195196
+37790583	2499260	249926	2	-0.024519519	-0.023769117
+37071760	2455053	245505	2	-0.024577124	-0.021138364
+36758554	2409276	240928	2	-0.02514684	-0.026691099
+36758550	2409276	240928	2	-0.025330288	-0.032233168
+37859150	2473557	247356	2	-0.024681569	-0.00360234
+36672909	2672344	267234	2	-0.024114722	-0.018581967
+36368698	2672344	267234	2	-0.024834766	-0.00571622
+37111248	2473557	247356	2	-0.024611944	-0.02019216
+2617082	2262166	226217	2	-0.024554075	-0.016918702
+2597574	2196882	219688	2	-0.024778818	-0.020425364
+34802544	2372328	237233	2	-0.024954963	0.006793579
+34841889	2332137	233214	2	-0.024937266	-0.009386646
+34479488	2383767	238377	2	-0.024391031	-0.004544567
+34539098	2339887	233989	2	-0.024700411	-0.014085975
+37152996	2314284	231428	2	-0.025174016	-0.003060851
+34468932	2314284	231428	2	-0.025046846	-0.00422532
+17507012	2383767	238377	2	-0.024520711	-0.004510592
+17496204	2332137	233214	2	-0.02511889	-0.017852456
+17470864	2368204	236820	2	-0.024109964	0.001031829
+17470490	2300210	230021	2	-0.024046114	0.005757327
+17426970	2539707	253971	2	-0.024810965	-0.010715575
+17426628	2539707	253971	2	-0.024296819	-0.009661134
+17390052	2314284	231428	2	-0.024599958	0.008914625
+17385540	2277541	227754	2	-0.02464781	-0.010873118
+17352542	2314284	231428	2	-0.02499861	0.001155202
+17350348	2347462	234746	2	-0.024665373	-0.020562095
+35599472	2539707	253971	2	-0.024844725	-0.004819372
+25609376	2539707	253971	2	-0.024711411	-0.0101461
+17268600	2264218	226422	2	-0.024322035	-0.012679409
+17234560	2262166	226217	2	-0.024283275	-0.013670659
+17201423	2300210	230021	2	-0.024917233	0.00277225
+16762977	2206073	220607	2	-0.024337199	-0.013839175
+16769541	1891008	189101	2	-0.024653512	0.00715003
+34835770	2372328	237233	2	-0.024279849	-0.0120813
+34835769	2372328	237233	2	-0.02463826	-0.004400761
+16602787	2181081	218108	2	-0.024560198	-0.012376439
+34536871	2314284	231428	2	-0.024953273	0.003793964
+34521701	2380278	238028	2	-0.024662931	-0.002811628
+34515704	2314284	231428	2	-0.025041453	-0.001769786
+17495314	2008001	200800	2	-0.024758729	0.010299025
+17484481	2368204	236820	2	-0.024313584	-0.007383277
+17185681	2008001	200800	2	-0.024724167	0.009785176
+17465427	2332137	233214	2	-0.024436725	-0.002897033
+51071560	40362890	4036289	2	-0.025153462	0.001659316
+47135148	36829865	3682987	2	-0.024934242	-0.005286262
+46227940	36217775	3621778	2	-0.025363638	0.072735838
+46578457	37858056	3785806	2	-0.024680669	-0.010384138
+47368991	38467287	3846729	2	-0.024908488	-6.70E-05
+47577902	38863395	3886340	2	-0.024681471	0.01496301
+41415101	2569678	256968	2	-0.024666864	-0.005601773
+44884431	35363892	3536389	2	-0.024695892	-0.015914054
+16778143	2008001	200800	2	-0.024983996	0.016649696
+16792205	2254563	225456	2	-0.024320586	-0.002655885
+34835764	2314284	231428	2	-0.024730622	-0.001356681
+34486744	2347462	234746	2	-0.025120285	-0.01160065
+34475479	2383767	238377	2	-0.024355544	-0.016332775
+34533282	2383767	238377	2	-0.024486509	-0.010831054
+17547957	2368204	236820	2	-0.024518202	-0.002558953
+17544393	2347462	234746	2	-0.02494455	-0.010737878
+17474245	2539707	253971	2	-0.024655022	-0.013918851
+17474184	2332137	233214	2	-0.024906854	-0.015329585
+17457925	2332137	233214	2	-0.024605944	-0.016666322
+17456333	2314284	231428	2	-0.025047956	-0.000201787
+17426627	2539707	253971	2	-0.024605606	-0.014122183
+17418147	2314284	231428	2	-0.025080037	0.011230921
+17383797	2105692	210569	2	-0.024309093	-0.009117714
+17382156	2314284	231428	2	-0.024875682	0.007011548
+17338911	2339887	233989	2	-0.024535134	-0.006568005
+17338619	2008001	200800	2	-0.025206162	0.019582678
+17291214	2314284	231428	2	-0.025351069	0.000847653
+17287378	2339887	233989	2	-0.025000911	-0.010017532
+17265875	2008001	200800	2	-0.024436761	0.014443603
+17199605	2304615	230462	2	-0.024378272	-0.010594795
+16812204	2206073	220607	2	-0.02472579	-0.021406395
+34486208	2314284	231428	2	-0.024298676	0.002285315
+34484148	2314284	231428	2	-0.025257679	0.016130737
+34474069	2576863	257686	2	-0.024811939	0.004532193
+17536640	2332137	233214	2	-0.024494671	-0.018696632
+17515331	2325339	232534	2	-0.024184844	0.006077534
+17473126	2392029	239203	2	-0.024413357	-0.02711107
+17472410	2314284	231428	2	-0.025143139	0.004850698
+17456054	2314284	231428	2	-0.024991116	0.001086503
+17438892	2332137	233214	2	-0.024959203	-0.012903065
+17436651	2332137	233214	2	-0.024693813	-0.023234881
+17430217	2314284	231428	2	-0.025345838	0.000649575
+17415490	2264218	226422	2	-0.025031697	-0.010226283
+17415470	2339887	233989	2	-0.024852303	-0.013442233
+17371643	2262166	226217	2	-0.024573565	-0.007786641
+17362755	2210163	221016	2	-0.024449885	-0.003236152
+17338306	2347462	234746	2	-0.0246356	-0.017854702
+17332449	2392029	239203	2	-0.024778015	-0.020683605
+17282399	2314284	231428	2	-0.024992936	-0.008215923
+17277578	2539707	253971	2	-0.024516766	0.005525248
+17244912	2314284	231428	2	-0.024795743	0.015568815
+17244620	2539684	253968	2	-0.024204282	-0.017160757
+47237009	36217775	3621778	2	-0.024982791	0.072009126
+46118261	36217775	3621778	2	-0.025015346	0.072744293
+45887480	41484239	4148424	2	-0.024240911	-0.004503796
+47368600	38863395	3886340	2	-0.025129134	0.007691938
+45353555	36217775	3621778	2	-0.025423561	0.065906564
+49810350	40759517	4075952	2	-0.02460126	-0.000966047
+45774425	35363892	3536389	2	-0.024471754	-0.020532809
+46367020	40281973	4028197	2	-0.023653732	-0.012154144
+47368992	38863395	3886340	2	-0.025000664	0.010406628
+47576522	2569678	256968	2	-0.024679726	-0.000614957
+47714616	38789771	3878977	2	-0.024182125	0.002466163
+45134458	34459804	3445980	2	-0.024223824	-0.001709951
+41054049	2612955	261296	2	-0.025392086	0.009476096
+45887271	35811063	3581106	2	-0.025044574	-0.007181121
+47370284	37814409	3781441	2	-0.024891499	0.011159108
+42824171	34459773	3445977	2	-0.024101678	-0.006187985
+44872796	2542232	254223	2	-0.024508726	-0.009241859
+47235738	2569678	256968	2	-0.024263325	-0.001104404
+45887319	35061036	3506104	2	-0.024862021	-0.005101391
+46522098	36217775	3621778	2	-0.025165754	0.067898086
+49811730	41625283	4162528	2	-0.024749865	-0.009674531
+47235484	38863395	3886340	2	-0.025701125	0.003053719
+47235518	44584745	4458475	2	-0.024323081	-0.005044447
+47235783	36217775	3621778	2	-0.025272872	0.069032442
+45770623	34459773	3445977	2	-0.024718897	-0.006479393
+45887414	36194111	3619411	2	-0.024407026	0.002182587
+17189344	2264218	226422	2	-0.024270394	-0.011928642
+17176554	2277541	227754	2	-0.024311921	-0.009437595
+17120772	2264218	226422	2	-0.024570406	-0.014909565
+17116447	2008001	200800	2	-0.024652293	0.015715869
+39971300	37966586	3796659	2	-0.024337922	-0.009889674
+40938377	2612955	261296	2	-0.024773261	-0.003324014
+40583675	2605219	260522	2	-0.025157666	-0.006611958
+46427365	35811063	3581106	2	-0.025138663	-0.026109772
+42625835	39072746	3907275	2	-0.023952437	-0.008824423
+45770622	39862946	3986295	2	-0.023692381	-0.010248407
+41483927	2612756	261276	2	-0.024744992	-0.020570823
+47235593	37814409	3781441	2	-0.025409425	0.026098832
+46701401	43030769	4303077	2	-0.024857205	-0.003052272
+45887787	37405448	3740545	2	-0.024802223	0.024505046
+45888992	41625283	4162528	2	-0.024853987	-0.002564752
+47712661	38467287	3846729	2	-0.024949494	0.017891201
+46507657	41625283	4162528	2	-0.024407436	-0.012299711
+45888062	35811063	3581106	2	-0.025052057	-0.01327929
+42012210	38575577	3857558	2	-0.024185744	0.004404889
+45890175	36217775	3621778	2	-0.025399159	0.064709699
+47290042	42605118	4260512	2	-0.024101743	-0.008463766
+47713768	37569452	3756945	2	-0.024037302	-0.000349599
+42822848	35341188	3534119	2	-0.024746639	-0.010814241
+17157665	2008001	200800	2	-0.024784278	0.01302062
+17137995	2008001	200800	2	-0.024643447	0.018446273
+17111225	2264218	226422	2	-0.024395155	-0.020108283
+17111214	2264218	226422	2	-0.024738556	-0.017271698
+49811969	42606888	4260689	2	-0.024667208	-0.017313219
+43449733	35362980	3536298	2	-0.024687757	-0.013277062
+45887086	2542232	254223	2	-0.02464267	0.009504336
+45774673	37405448	3740545	2	-0.025041007	0.009359032
+43806414	35097275	3509728	2	-0.025107117	-0.020076688
+47932901	36217775	3621778	2	-0.02535676	0.06497563
+46426450	35363834	3536383	2	-0.024737634	0.008626064
+41053350	2607393	260739	2	-0.025015624	-0.004586381
+49813482	40759517	4075952	2	-0.02444498	-0.018496057
+47134604	41225057	4122506	2	-0.024701186	-0.012120181
+45135782	42179395	4217940	2	-0.024881627	-0.001291099
+47581368	38467287	3846729	2	-0.024731719	0.007670567
+45887336	41097513	4109751	2	-0.024411106	0.00493538
+43449451	34497515	3449752	2	-0.024844015	0.02025709
+46506452	41625283	4162528	2	-0.024701882	-0.003801026
+17131742	2298776	229878	2	-0.024729178	0.000480571
+17131509	2264218	226422	2	-0.024745484	-0.014354499
+43775237	35362980	3536298	2	-0.024804716	-0.028739741
+46362012	42023350	4202335	2	-0.024596419	0.001554225
+39428097	37208121	3720812	2	-0.024713825	0.00300529
+46032820	36217775	3621778	2	-0.025361875	0.068386653
+34540205	2332137	233214	2	-0.024437361	-0.016929318
+47715030	40759517	4075952	2	-0.024890834	-0.014761618
+42122170	35341188	3534119	2	-0.024273833	0.007580456
+49811591	40759517	4075952	2	-0.024944471	-0.012511857
+17126775	2304615	230462	2	-0.024455489	-0.011246776
+17124849	2434493	243449	2	-0.024451566	-0.005633388
+46507937	37858056	3785806	2	-0.024744569	-0.009721046
+46367520	35850975	3585098	2	-0.024886529	-0.012701717
+47713562	38582775	3858278	2	-0.024697101	-0.006992001
+45809282	36217775	3621778	2	-0.025410106	0.063079747
+42058577	2622594	262259	2	-0.024368475	-0.013480103
+36116942	2409276	240928	2	-0.024751039	-0.019522426
+44428532	35811063	3581106	2	-0.024630678	-0.017425333
+43481889	2629508	262951	2	-0.024378504	-0.018410871
+41018625	2583512	258351	2	-0.024628606	-0.012090812
+44428298	2622992	262299	2	-0.024799371	-0.012745637
+40725496	37208121	3720812	2	-0.024652908	0.000218885
+47521595	36217775	3621778	2	-0.025053301	0.074469635
+45803570	2601548	260155	2	-0.023421901	-0.001881757
+45486097	35851050	3585105	2	-0.024701127	-0.002480489
+35415305	2347462	234746	2	-0.024278104	-0.013504731
+46166486	34777446	3477745	2	-0.024820718	-0.009475051
+42706413	39580694	3958069	2	-0.024162693	-0.008710295
+42966873	2672344	267234	2	-0.02437288	-0.023339824
+44428333	34498548	3449855	2	-0.024204263	-0.006130338
+43966026	37862762	3786276	2	-0.024359955	-0.00801423
+44428543	41278655	4127866	2	-0.024573605	-0.015144768
+45744184	36217775	3621778	2	-0.025188723	0.07040136
+42005528	2544920	254492	2	-0.024506975	0.012682951
+45100744	35362980	3536298	2	-0.025198857	-0.009619825
+44318427	36723239	3672324	2	-0.024525091	-0.007031764
+47712152	36217775	3621778	2	-0.025254486	0.064438309
+42859936	2601548	260155	2	-0.024793229	-0.000776915
+51923373	40759517	4075952	2	-0.024240382	-0.020387096
+45504883	36217775	3621778	2	-0.024928735	0.074346711
+52063465	36217775	3621778	2	-0.025269877	0.070193927
+40006586	2555938	255594	2	-0.024866943	0.030983838
+39091701	2567054	256705	2	-0.025128222	0.004198443
+48301809	40095989	4009599	2	-0.024673444	0.034172549
+41110946	2607393	260739	2	-0.024424862	0.042211773
+36830101	2452473	245247	2	-0.024119353	-0.0156228
+38697098	2439114	243911	2	-0.024027846	0.031066239
+45557799	2544920	254492	2	-0.024378559	0.014316165
+46228955	36217775	3621778	2	-0.025144524	0.059796531
+45837797	35850975	3585098	2	-0.024893254	-0.016658751
+46010032	37405448	3740545	2	-0.025283807	0.01904888
+47289852	42605118	4260512	2	-0.02444216	-0.010269062
+47369121	37858056	3785806	2	-0.024831301	-0.00643548
+42626402	39121319	3912132	2	-0.024300517	-0.008142658
+42634854	35100672	3510067	2	-0.024234024	-0.010543021
+44470096	34459773	3445977	2	-0.024649057	-0.012482288
+47522762	40759517	4075952	2	-0.024273437	-0.014768816
+47221350	36723239	3672324	2	-0.024695643	-0.001387707
+46115619	36723239	3672324	2	-0.024039928	-0.01208592
+46237198	41625283	4162528	2	-0.024430306	-0.015095416
+38860695	2397271	239727	2	-0.024484448	-0.005895191
+52531904	40095989	4009599	2	-0.024296958	-0.009643069
+45374254	36217775	3621778	2	-0.024976525	0.07329046
+46710821	36217775	3621778	2	-0.025316772	0.065118537
+42403332	34459773	3445977	2	-0.02453927	-0.000881583
+53255930	40759517	4075952	2	-0.024591978	-0.016743616
+47388611	37858056	3785806	2	-0.024738123	-0.008659911
+42205057	2544920	254492	2	-0.02478352	0.00840364
+50458730	40759517	4075952	2	-0.024781674	-0.010496336
+42633211	39558786	3955879	2	-0.024531157	-0.004191646
+39982828	2383767	238377	2	-0.024329043	-0.004334632
+43772331	39558786	3955879	2	-0.024247842	-0.017765432
+47749090	36217775	3621778	2	-0.024889888	0.063784126
+47724061	40095989	4009599	2	-0.024526452	0.005364442
+48354571	2583512	258351	2	-0.025404973	0.028960932
+41615972	39069784	3906978	2	-0.024604631	0.001745798
+46428126	36217775	3621778	2	-0.025412036	0.06592536
+45974226	36217775	3621778	2	-0.024951117	0.071533244
+45676112	42401994	4240199	2	-0.024662951	-0.010792192
+46404001	36217775	3621778	2	-0.025350012	0.067933653
+36754934	2473557	247356	2	-0.024478664	-0.019577604
+45210943	36217775	3621778	2	-0.02519761	0.070776895
+35382361	2558516	255852	2	-0.024153437	-0.0039604
+42096677	2601548	260155	2	-0.024491704	-0.003646305
+46009076	36217775	3621778	2	-0.025349272	0.067296658
+39399532	2415870	241587	2	-0.024740484	-0.007386787
+42628412	2556811	255681	2	-0.024451833	-0.017423172
+46026794	35850975	3585098	2	-0.024810408	-0.016455955
+46875455	36217775	3621778	2	-0.025553236	0.05843269
+44766814	36217775	3621778	2	-0.024488835	0.068412929
+53313851	40759517	4075952	2	-0.024238548	-0.015166168
+47686924	40759517	4075952	2	-0.024610683	-0.009170682
+46166230	36217775	3621778	2	-0.02494053	0.06436205
+46401737	36217775	3621778	2	-0.025139945	0.063226905
+45804579	35811063	3581106	2	-0.024908644	-0.027558919
+44584242	39965991	3996599	2	-0.024510753	-0.003087311
+45530399	35582894	3558289	2	-0.024452241	-0.019704403
+42402658	35546780	3554678	2	-0.024865494	-0.00808415
+42402588	35546780	3554678	2	-0.024243016	-0.007575476
+44587194	2601548	260155	2	-0.024603354	-0.000612322
+39398707	2544920	254492	2	-0.024843829	0.00496223
+42050634	2544920	254492	2	-0.024935685	0.006007583
+45705016	2558161	255816	2	-0.024390138	-0.008860014
+53133273	40095989	4009599	2	-0.023966509	-0.012812131
+48047672	36217775	3621778	2	-0.024864224	0.064773259
+45209630	35811063	3581106	2	-0.024770057	-0.006036484
+42093754	2544920	254492	2	-0.024414985	0.007627666
+52866335	36217775	3621778	2	-0.025603637	0.06489859
+46487366	2607393	260739	2	-0.024798118	0.005838491
+46686811	34497515	3449752	2	-0.024819529	0.010348092
+46257609	35811063	3581106	2	-0.024376715	-0.01293109
+42822763	2538929	253893	2	-0.024112198	-0.016343167
+43834931	35811063	3581106	2	-0.025135306	-0.019273743
+47600054	36217775	3621778	2	-0.025419319	0.064430269
+42024460	2672328	267233	2	-0.023920012	-0.01560113
+51212104	40312016	4031202	2	-0.024975321	-0.000195632
+47543584	36217775	3621778	2	-0.024916076	0.061730698
+47427226	38468729	3846873	2	-0.024903552	-0.000404703
+38976759	2672344	267234	2	-0.024622334	-0.031042109
+42453439	2544920	254492	2	-0.024909474	0.003104723
+40563447	37428027	3742803	2	-0.023786609	-0.007299494
+43265882	34459773	3445977	2	-0.024915762	-0.004694597
+43403754	35811063	3581106	2	-0.024744011	-0.019312287
+46231123	35362980	3536298	2	-0.024668492	-0.016694366
+46167039	36217775	3621778	2	-0.025384907	0.069612479
+47929333	40759517	4075952	2	-0.024424646	-0.008232159
+40743987	2546032	254603	2	-0.024523846	0.00324981
+43295192	35362980	3536298	2	-0.024599675	-0.028409331
+45807844	35811063	3581106	2	-0.024661006	-0.017227044
+44585174	35811063	3581106	2	-0.024459454	-0.020243192
+53060221	36217775	3621778	2	-0.024897544	0.074010768
+45913423	35850975	3585098	2	-0.024384448	-0.022966801
+46452700	38263266	3826327	2	-0.024047503	-0.019010574
+47069312	37858056	3785806	2	-0.02497495	-0.014089802
+51039356	40698711	4069871	2	-0.025024095	-0.007704458
+38886349	2451927	245193	2	-0.024371184	-0.007123113
+44257815	2547377	254738	2	-0.024340978	-0.011625567
+40747160	2513616	251362	2	-0.02416517	-0.015494436
+40793740	36723239	3672324	2	-0.024306089	-0.011157655
+41557426	2569678	256968	2	-0.023444713	-0.006201557
+41735234	2536960	253696	2	-0.024395443	-0.00016132
+42218982	2536960	253696	2	-0.024570298	-0.004797485
+42297041	2612955	261296	2	-0.02435907	-0.010720516
+42434707	35546780	3554678	2	-0.024433442	-0.013654538
+42476806	2576863	257686	2	-0.024144308	0.00772879
+40563668	2567162	256716	2	-0.024512736	0.000288101
+40563745	2513616	251362	2	-0.024552087	-0.013187077
+41240160	2405915	240592	2	-0.024782599	-0.005064864
+41240411	2609471	260947	2	-0.024388488	-0.00247977
+42153586	2595908	259591	2	-0.024792769	-0.00432487
+42218181	2569678	256968	2	-0.024181462	-0.009183191
+42434297	2607393	260739	2	-0.025258236	0.00613092
+44257818	2547377	254738	2	-0.024300848	-0.018874217
+45352765	1	2	2	-0.02434641	-0.008393811
+41022264	2606831	260683	2	-0.024314744	-0.013162064
+41084374	34501842	3450184	2	-0.024517451	-0.017129366
+41736555	34501842	3450184	2	-0.024528767	-0.013513837
+42002420	2502722	250272	2	-0.024014104	-0.005430161
+42297098	2595908	259591	2	-0.024606101	-0.003721771
+42297226	2595908	259591	2	-0.024419622	-0.003957498
+42477102	35546780	3554678	2	-0.024638902	-0.004526286
+42477336	2612955	261296	2	-0.0244787	-0.00574318
+40074642	2416059	241606	2	-0.024302119	-0.007424188
+41135771	34501842	3450184	2	-0.025072082	-0.006163952
+41240088	2595908	259591	2	-0.02528986	-0.003947576
+42079706	2569678	256968	2	-0.023784962	-0.005294962
+42122625	2569678	256968	2	-0.024202879	-0.015628042
+42297227	2590969	259097	2	-0.024705159	0.00493916
+42297598	2569678	256968	2	-0.024298837	-0.017956024
+42583060	2569678	256968	2	-0.024671839	-0.011803287
+53174828	42273854	4227385	2	-0.024291253	-0.008279464
+53192018	42273854	4227385	2	-0.024909544	0.023172504
+52651568	40791350	4079135	2	-0.02421727	0.012078448
+52337639	40095989	4009599	2	-0.024165622	-0.000107542
+42890809	34459773	3445977	2	-0.024111409	-0.010758256
+40428077	2576863	257686	2	-0.024761024	0.00162956
+48336526	40095989	4009599	2	-0.024029898	-0.013614631
+44368083	35811792	3581179	2	-0.024011344	-0.016978421
+45726104	36217775	3621778	2	-0.025091604	0.060366924
+45677641	36828929	3682893	2	-0.024294921	-0.015368538
+45479600	35811063	3581106	2	-0.024362702	-0.019912558
+42001497	34497515	3449752	2	-0.024807446	-0.010571133
+41060116	2672050	267205	2	-0.023960176	-0.013519591
+41260021	39558786	3955879	2	-0.024582835	-0.014876624
+16945934	2008001	200800	2	-0.025100326	0.072212289
+40176935	2544920	254492	2	-0.024730881	-0.001214168
+53135596	41018587	4101859	2	-0.024640635	-0.003016107
+47856531	36217775	3621778	2	-0.025125099	0.066863117
+43186624	35811063	3581106	2	-0.024734666	-0.01723592
+42941499	2578045	257805	2	-0.024256042	-0.0074667
+44974959	36217775	3621778	2	-0.024601129	0.065267322
+43933811	34777446	3477745	2	-0.025008021	0.007536488
+47129447	37543286	3754329	2	-0.023371805	-0.011668677
+47629369	35362980	3536298	2	-0.024517674	-0.016877147
+52578313	40291988	4029199	2	-0.024933285	-0.006718782
+45259820	35850975	3585098	2	-0.024295095	-0.015438017
+47580033	36217775	3621778	2	-0.025222729	0.068554231
+45259824	35362980	3536298	2	-0.025101274	-0.015361935
+52494405	40698679	4069868	2	-0.024791645	0.003828667
+52497872	40698679	4069868	2	-0.024554853	-0.002555491
+46504189	36217775	3621778	2	-0.025089387	0.069658155
+46572136	36217775	3621778	2	-0.025445331	0.070504918
+41003526	2672344	267234	2	-0.024592164	-0.02714528
+48195698	40759517	4075952	2	-0.02486435	-0.013754352
+43586962	35098455	3509846	2	-0.025380701	-0.010641396
+46011429	35811063	3581106	2	-0.025012855	-0.025010352
+46504190	36217775	3621778	2	-0.025068608	0.066821536
+42022868	35100807	3510081	2	-0.024146235	-0.017173365
+46085979	35850975	3585098	2	-0.0248687	-0.023254969
+47238169	36217775	3621778	2	-0.02492282	0.063026894
+52987562	40759517	4075952	2	-0.024395102	-0.02318263
+42149480	34501073	3450107	2	-0.02404587	-0.010230105
+46696895	36642444	3664244	2	-0.024462762	-0.015818145
+38988024	2214368	221437	2	-0.02466996	-0.005877667
+48345350	35811063	3581106	2	-0.02421091	-0.024050901
+49687717	35811063	3581106	2	-0.024515872	-0.015289081
+39804412	37966586	3796659	2	-0.024302429	-0.018645438
+45369030	35811063	3581106	2	-0.024336277	-0.020486477
+44470502	35811063	3581106	2	-0.024236754	-0.015099581
+43768807	40940517	4094052	2	-0.023787687	-0.008861288
+53247780	40291988	4029199	2	-0.024979366	-0.001527735
+48206001	40759517	4075952	2	-0.024714138	-0.01253494
+41615254	39558786	3955879	2	-0.024660431	-0.007896846
+43265878	35060624	3506062	2	-0.023132355	-0.013837109
+45675694	35811063	3581106	2	-0.024802391	-0.011931288
+46010966	36828929	3682893	2	-0.024458244	-0.010207707
+41640440	2607393	260739	2	-0.024558748	0.008817859
+48173938	40759517	4075952	2	-0.024813206	-0.015207451
+42704309	34459773	3445977	2	-0.024843928	-0.002885954
+44797707	37351873	3735187	2	-0.024748874	-0.025699589
+48356739	40660608	4066061	2	-0.024325216	0.003475718
+45619299	35850975	3585098	2	-0.024784297	-0.023610415
+47466869	38863395	3886340	2	-0.025055652	-0.000934058
+47467514	40759517	4075952	2	-0.024662466	-0.001273943
+42359421	34459773	3445977	2	-0.025001071	-0.015829363
+47931267	42606888	4260689	2	-0.024749937	-0.001087533
+47045000	37405448	3740545	2	-0.025023753	0.017358876
+47467576	40759517	4075952	2	-0.024669272	-0.005298445
+43425392	34459773	3445977	2	-0.024769771	-0.002525611
+45642067	35811063	3581106	2	-0.025492112	-0.0072416
+46032446	35850975	3585098	2	-0.025052083	-0.005531978
+41321335	2612955	261296	2	-0.024560053	-0.011033373
+44070869	2569678	256968	2	-0.024401651	-0.012032397
+46702772	42605118	4260512	2	-0.024613433	-0.010555995
+45891729	36217775	3621778	2	-0.024961022	0.06810333
+47368580	38863395	3886340	2	-0.02516433	0.005160018
+47134787	38467287	3846729	2	-0.025046323	0.000984672
+46577960	37858056	3785806	2	-0.024593043	-0.006015308
+47130832	37405448	3740545	2	-0.024822289	0.013552526
+47369856	36217775	3621778	2	-0.025254377	0.07141104
+45006542	35811063	3581106	2	-0.024700138	-0.013384124
+46702636	36217775	3621778	2	-0.024983537	0.066923046
+45844123	37200320	3720032	2	-0.024741506	0.023357849
+46131814	36217775	3621778	2	-0.024821102	0.072618041
+47234749	37858056	3785806	2	-0.024516984	-0.009390768
+47269724	38863395	3886340	2	-0.024958322	0.003247231
+47043455	37858056	3785806	2	-0.024643695	-0.010655116
+47236350	36217775	3621778	2	-0.024864546	0.064318738
+47134229	37858056	3785806	2	-0.024654024	-0.00382492
+47465773	35811063	3581106	2	-0.024871862	-0.014897809
+46577873	35363834	3536383	2	-0.025097703	-0.013564662
+41317488	2579321	257932	2	-0.024667131	-0.012590102
+38078644	2504539	250454	2	-0.024667627	9.66E-05
+45375550	42179395	4217940	2	-0.024978148	0.006736234
+44690482	35363892	3536389	2	-0.024622988	-0.015665307
+46577702	38863395	3886340	2	-0.025481167	0.014312255
+46506621	42605118	4260512	2	-0.025039919	-0.003647358
+47388624	37858056	3785806	2	-0.024499345	-0.00630012
+46508620	37858056	3785806	2	-0.024494453	-0.005248208
+46702572	37858056	3785806	2	-0.024671544	-0.016474245
+47933081	38467287	3846729	2	-0.024917031	-0.008460354
+45890261	35850975	3585098	2	-0.024935469	-0.017899746
+47134938	36217775	3621778	2	-0.025043994	0.064794085
+46479247	36642444	3664244	2	-0.024571899	-0.008166653
+47045398	37072742	3707274	2	-0.024951472	-0.009481418
+46506657	42605118	4260512	2	-0.024997089	0.000112621
+47043454	37858056	3785806	2	-0.024312425	-0.006305519
+46033681	35850975	3585098	2	-0.025040833	0.005125466
+47368833	36217775	3621778	2	-0.025407321	0.070089613
+47931412	40759517	4075952	2	-0.024736034	-0.001339684
+46131824	36217775	3621778	2	-0.025133261	0.06413863
+47711717	37858056	3785806	2	-0.024875095	-0.013566936
+41053665	2607393	260739	2	-0.025348812	-0.001619218
+47130617	37858056	3785806	2	-0.024669206	-0.002277566
+45848029	35850975	3585098	2	-0.02524853	-0.027732204
+45376405	35811063	3581106	2	-0.024622672	-0.013142997
+52469608	40291988	4029199	2	-0.024590493	-0.011838993
+46229561	36217775	3621778	2	-0.024854278	0.070284123
+44814052	35811063	3581106	2	-0.025083908	0.002403048
+47414547	36217775	3621778	2	-0.025453033	0.061573056
+40089900	2672344	267234	2	-0.024318716	-0.016234166
+40380339	2542232	254223	2	-0.025119473	0.00463205
+46455777	36217775	3621778	2	-0.024722196	0.076463357
+41021753	2672344	267234	2	-0.024852421	-0.01805546
+47319537	36217775	3621778	2	-0.025084345	0.071631978
+46145515	36217775	3621778	2	-0.025149313	0.061067766
+47078492	35811063	3581106	2	-0.024417402	-0.01686614
+52982114	40791350	4079135	2	-0.025145596	-0.002813677
+44585487	34459773	3445977	2	-0.024974252	-0.007057826
+47346143	36217775	3621778	2	-0.025313462	0.062635927
+51206135	2578045	257805	2	-0.024065653	-0.00913505
+41111473	2585735	258574	2	-0.023973362	-0.013584178
+44473134	35811063	3581106	2	-0.025094889	-0.012578277
+45415110	35811063	3581106	2	-0.024640067	-0.019322883
+39752705	37966586	3796659	2	-0.024234117	-0.001412947
+39752009	37966586	3796659	2	-0.024485449	-0.002280948
+48255797	36217775	3621778	2	-0.024993323	0.077227555
+45738569	36217775	3621778	2	-0.025299214	0.067042234
+45913780	2578045	257805	2	-0.02453959	-0.011467637
+44162751	2569678	256968	2	-0.024547969	-0.020175538
+46236184	35362980	3536298	2	-0.025152498	-0.016956327
+46874601	40940517	4094052	2	-0.024603438	-0.002751159
+44162581	35362980	3536298	2	-0.024538247	-0.027435921
+44909401	35811063	3581106	2	-0.025102424	-0.015874833
+47929229	36217775	3621778	2	-0.024950139	0.06521351
+46455702	36217775	3621778	2	-0.024613411	0.067597755
+46346394	36217775	3621778	2	-0.024939323	0.073760066
+45647280	36217775	3621778	2	-0.025170014	0.067390766
+52460404	41344848	4134485	2	-0.024490628	-0.001970763
+44585112	34459773	3445977	2	-0.024930085	-0.006256633
+46426525	38263266	3826327	2	-0.024167979	-0.014668651
+41107834	35363654	3536365	2	-0.024466015	-0.013975648
+50706641	42750831	4275083	2	-0.024396723	-0.004908819
+46412788	35850975	3585098	2	-0.024216919	-0.02002324
+47268147	36217775	3621778	2	-0.025097083	0.077042222
+46086318	36642444	3664244	2	-0.024723751	0.018153206
+48237882	40759517	4075952	2	-0.02442198	-0.010183764
+52403836	37858056	3785806	2	-0.024649956	-0.00994333
+47521803	37858056	3785806	2	-0.024829414	-0.012699297
+45481087	36217775	3621778	2	-0.025453867	0.070329745
+52365376	41625283	4162528	2	-0.024157339	-0.018571294
+41235953	2672328	267233	2	-0.024425019	-0.018149959
+43448997	35362980	3536298	2	-0.024535179	-0.023291376
+34809423	2403995	240400	2	-0.024564565	-0.012352005
+46198698	42291321	4229132	2	-0.023985842	-0.009351842
+52002873	2629508	262951	2	-0.024247278	-0.018355335
+42660911	34459773	3445977	2	-0.02448979	-0.011689501
+43804331	34461207	3446121	2	-0.024365321	-0.008419141
+51475049	35100807	3510081	2	-0.02481209	-0.007198213
+47269521	36217775	3621778	2	-0.025206654	0.064019765
+46084502	36217775	3621778	2	-0.025172595	0.06645172
+45330051	35811792	3581179	2	-0.024569557	-0.019098239
+42120072	38864955	3886496	2	-0.023116368	-0.010857486
+41667296	2607393	260739	2	-0.025176659	0.006460822
+41711371	2607393	260739	2	-0.025054331	0.001881581
+41021801	2672344	267234	2	-0.024970849	-0.02113604
+52852820	41344848	4134485	2	-0.025046599	-0.006365873
+39141838	36723239	3672324	2	-0.024673206	-0.003503351
+46424168	2601548	260155	2	-0.024560458	-0.001807669
+45832362	36723239	3672324	2	-0.025733192	-0.010148359
+45476655	38758680	3875868	2	-0.024565176	-0.018822585
+42661163	39558786	3955879	2	-0.024491873	-0.008623054
+44822576	35811792	3581179	2	-0.024278431	-0.010056056
+39581291	36723239	3672324	2	-0.024604755	-0.013968058
+37969844	2672328	267233	2	-0.024589541	-0.019448987
+46422920	2629508	262951	2	-0.024476527	-0.017504374
+46601195	37858056	3785806	2	-0.024779097	-0.002386815
+45765901	35811063	3581106	2	-0.024443535	-0.020384461
+42480147	2628534	262853	2	-0.024624111	-0.003345948
+45607348	36217775	3621778	2	-0.024759385	0.067748575
+47107352	2544920	254492	2	-0.024335453	0.006732497
+53093287	41625283	4162528	2	-0.024647587	-0.00757514
+46230379	36217775	3621778	2	-0.02502875	0.060210608
+41062092	2544920	254492	2	-0.024666164	0.003209031
+43956995	38575577	3857558	2	-0.0243539	-0.005048282
+47046327	35850975	3585098	2	-0.025086321	-0.018955584
+41004166	39069784	3906978	2	-0.024615822	-0.005230387
+45047982	35850975	3585098	2	-0.024501618	-0.017695976
+43427824	34459773	3445977	2	-0.024626184	-0.009623689
+45921672	36217775	3621778	2	-0.025099317	0.062682867
+47196205	35811063	3581106	2	-0.02463548	-0.015212822
+41825354	2578045	257805	2	-0.023943813	-0.015644567
+35920725	2383767	238377	2	-0.024249917	-0.011454506
+42380231	2544920	254492	2	-0.025058759	-0.004918831
+41366291	38111168	3811117	2	-0.024485694	-0.010588825
+50579639	43025747	4302575	2	-0.024692767	-0.009427835
+45175667	35811063	3581106	2	-0.024598455	-0.01849537
+45923126	35362980	3536298	2	-0.02491261	-0.023468605
+41996673	35546780	3554678	2	-0.024611294	-0.007976554
+52622858	41344848	4134485	2	-0.024402794	-0.007899961
+45338498	34823977	3482398	2	-0.024285121	-0.004128646
+42216843	2576863	257686	2	-0.024707971	-0.002588482
+45338873	35850975	3585098	2	-0.024991518	-0.016557081
+47076109	36217775	3621778	2	-0.02522506	0.067777616
+42008767	39558786	3955879	2	-0.024168449	-0.008400273
+45166679	36217775	3621778	2	-0.024822994	0.071085154
+43362793	36723239	3672324	2	-0.023910032	-0.008481974
+42427052	2583512	258351	2	-0.024721909	-0.008460528
+44822590	34459773	3445977	2	-0.024350089	-0.006880263
+45842574	35811063	3581106	2	-0.024349238	-0.017691022
+53314334	41686537	4168654	2	-0.024489822	-0.005909867
+52796688	48128342	4812834	2	-0.024457255	-0.013779228
+44109295	36723239	3672324	2	-0.024378244	-0.013501166
+51971996	40095989	4009599	2	-0.024476731	-0.010714515
+46165014	42605118	4260512	2	-0.024732671	0.013921669
+47321285	36217775	3621778	2	-0.024927669	0.069820566
+45256726	36217775	3621778	2	-0.025183291	0.068146473
+37996977	36578757	3657876	2	-0.023975732	-0.008282207
+47189300	36217775	3621778	2	-0.025169875	0.065763905
+45174232	34501842	3450184	2	-0.024449683	-0.006723371
+45176643	35811063	3581106	2	-0.024227422	-0.016609538
+46454248	35850975	3585098	2	-0.025074418	-0.018638444
+47981123	2629508	262951	2	-0.024648519	-0.020788199
+47188973	36217775	3621778	2	-0.02518046	0.061763983
+43376919	2473557	247356	2	-0.024297878	-0.018942974
+42994803	35735628	3573563	2	-0.024100656	-0.008047694
+42009510	39558786	3955879	2	-0.024322246	-0.002566964
+45447534	36217775	3621778	2	-0.024982196	0.066611972
+44336765	34459773	3445977	2	-0.024496963	-0.007500769
+42046830	2672344	267234	2	-0.024825524	-0.022928056
+46346664	40940517	4094052	2	-0.024056928	-0.007279621
+44730894	35100807	3510081	2	-0.024145134	-0.017638963
+47786570	34499422	3449942	2	-0.024371749	-0.013230447
+41492207	2544920	254492	2	-0.024822905	0.000786473
+46004871	35850975	3585098	2	-0.024959605	-0.004279385
+40673409	2544920	254492	2	-0.024839094	0.009186051
+45529299	38758680	3875868	2	-0.024359333	-0.005034037
+44814050	35811063	3581106	2	-0.025027243	0.001579926
+43526692	2607393	260739	2	-0.024785048	0.016101695
+44187003	35811063	3581106	2	-0.024524033	-0.016798708
+45041488	35811063	3581106	2	-0.024500663	-0.020228197
+42046603	34501842	3450184	2	-0.024549327	-0.014376908
+47110645	36217775	3621778	2	-0.025053863	0.075838264
+44207941	34459773	3445977	2	-0.024890073	-0.003218451
+53172630	42607843	4260784	2	-0.024979505	-0.016145382
+47392536	35811063	3581106	2	-0.025030089	-0.022332019
+46635466	36217775	3621778	2	-0.025040701	0.067586885
+46502970	36217775	3621778	2	-0.025484754	0.065914248
+46499308	36217775	3621778	2	-0.025047692	0.068637434
+46536418	42605118	4260512	2	-0.024912031	-0.016325086
+52511825	36217775	3621778	2	-0.025432038	0.062194772
+52827136	41344848	4134485	2	-0.024827324	-0.008406423
+45719087	36217775	3621778	2	-0.025117005	0.063235144
+42633151	2590050	259005	2	-0.024580621	-0.013477021
+51685339	40362890	4036289	2	-0.025098767	-0.001082706
+47392109	35850975	3585098	2	-0.024834031	-0.019724674
+45953295	36642444	3664244	2	-0.024507442	-0.011023178
+46201994	35850975	3585098	2	-0.025052889	-0.021170772
+38719518	2439114	243911	2	-0.025216048	0.025369688
+45722746	35363654	3536365	2	-0.024627595	-0.023278269
+42319214	34459773	3445977	2	-0.024550653	-0.011523395
+45399000	36217775	3621778	2	-0.02530199	0.069081835
+47707715	36217775	3621778	2	-0.025446501	0.063224795
+40561030	37966586	3796659	2	-0.024314748	-0.014423929
+41637595	2332137	233214	2	-0.023759615	-0.01905353
+42785053	2558166	255817	2	-0.024273613	-0.00895933
+45557386	36642444	3664244	2	-0.024557355	-0.002601407
+50157920	37858056	3785806	2	-0.024743104	-0.005043841
+38761616	2473557	247356	2	-0.024539979	-0.022689732
+42886716	34459773	3445977	2	-0.024871014	-0.013642036
+43589786	40940517	4094052	2	-0.0243298	-0.011207784
+45032834	2578045	257805	2	-0.024451305	-0.008889921
+46294499	35811063	3581106	2	-0.024595392	-0.021901812
+46119921	35811063	3581106	2	-0.024413982	-0.018607445
+45975510	35811063	3581106	2	-0.024617575	-0.015587711
+46118545	42317418	4231742	2	-0.024975518	-0.009808787
+45048942	35850975	3585098	2	-0.024762305	-0.018032106
+46702296	2558557	255856	2	-0.024961705	-0.022306892
+41758115	2513616	251362	2	-0.023925987	-0.012349386
+45214471	35811063	3581106	2	-0.02440218	-0.020261656
+45297929	36217775	3621778	2	-0.025740108	0.068906926
+46292554	36217775	3621778	2	-0.025024071	0.072119179
+36669957	2672344	267234	2	-0.024802547	-0.024817786
+46224130	40291988	4029199	2	-0.024645443	-0.005408873
+45099968	41278355	4127836	2	-0.024628816	0.001216538
+45976595	35811063	3581106	2	-0.024530143	-0.020653
+46318945	37858056	3785806	2	-0.024556089	-0.019604199
+47714401	36217775	3621778	2	-0.024925221	0.064037229
+45257084	36217775	3621778	2	-0.025090943	0.066120393
+45924344	36217775	3621778	2	-0.025590851	0.06337285
+46877398	35850975	3585098	2	-0.024665212	-0.019779023
+41664947	2544920	254492	2	-0.02389772	0.00871584
+40508087	2387453	238745	2	-0.024455589	-0.008056762
+44911936	35811792	3581179	2	-0.024628528	-0.018820421
+46093426	42657363	4265736	2	-0.024543642	-0.012477187
+45305977	39337159	3933716	2	-0.024758695	-0.001104158
+44107811	40940517	4094052	2	-0.024297348	-0.01043929
+52110385	39633813	3963381	2	-0.024615055	-0.002007283
+46478840	2601548	260155	2	-0.024338049	-0.002565122
+47949436	36217775	3621778	2	-0.024967202	0.063695261
+47603609	36217775	3621778	2	-0.025010465	0.065037725
+35349325	38569098	3856910	2	-0.024039901	-0.015782384
+47428628	38789771	3878977	2	-0.024967039	-0.00227378
+43847014	35811063	3581106	2	-0.024215894	-0.017292067
+52916829	36217775	3621778	2	-0.025478612	0.060305922
+37289147	2672344	267234	2	-0.024665308	-0.02401844
+47189341	36217775	3621778	2	-0.024985475	0.073016536
+46226001	36217775	3621778	2	-0.025074215	0.061115418
+47467534	36217775	3621778	2	-0.024926705	0.068456922
+45976537	35811063	3581106	2	-0.024801504	-0.016850083
+40008440	37686110	3768611	2	-0.024479528	-0.019215618
+44882615	36723239	3672324	2	-0.024326197	0.001572397
+43424037	35362980	3536298	2	-0.02453889	-0.016093354
+46200637	36217775	3621778	2	-0.025039294	0.064633762
+41825338	2578045	257805	2	-0.024221401	-0.010970667
+38405554	35097741	3509774	2	-0.02457992	0.002900832
+43097927	40359667	4035967	2	-0.024504751	0.011198814
+46035787	41625283	4162528	2	-0.024672632	-0.018271526
+52708981	40698711	4069871	2	-0.024931375	-0.016048602
+42931333	34459773	3445977	2	-0.024787905	-0.00602354
+44723342	35850975	3585098	2	-0.0244722	-0.018113042
+47890616	38467287	3846729	2	-0.024659367	0.004691201
+47391195	35811063	3581106	2	-0.024982538	-0.022287589
+44500320	35811063	3581106	2	-0.024736591	-0.017134611
+45647274	42605118	4260512	2	-0.024283516	-0.007798094
+45343398	34461207	3446121	2	-0.025249477	-0.014969664
+40333514	2544920	254492	2	-0.024909736	0.009818353
+43590834	41279853	4127985	2	-0.024671648	-0.016348791
+45687830	40940517	4094052	2	-0.024672547	-0.007528336
+46426823	36217775	3621778	2	-0.025136876	0.061987293
+48261654	41625283	4162528	2	-0.024868576	-0.013679835
+46364671	42530679	4253068	2	-0.024419926	-0.004002627
+45887048	2626785	262679	2	-0.024366791	0.000517713
+43450295	34459804	3445980	2	-0.024634915	0.01288331
+47466870	38789771	3878977	2	-0.024746022	0.008761493
+45258259	42179395	4217940	2	-0.024720625	-0.004749374
+46010033	36217775	3621778	2	-0.025017774	0.072573265
+46131813	37112264	3711226	2	-0.024712805	0.010400828
+47368896	36217775	3621778	2	-0.025280311	0.061978247
+47369795	39748848	3974885	2	-0.024159496	0.005960689
+47930862	38467287	3846729	2	-0.025243017	0.008117645
+42045503	2628534	262853	2	-0.024502988	-0.010976749
+47466496	38699787	3869979	2	-0.024776677	-0.013852288
+46367162	42715677	4271568	2	-0.024447933	0.003049857
+46577703	38863395	3886340	2	-0.025141019	0.008633569
+46226380	36217775	3621778	2	-0.025623167	0.073527151
+42625141	2672344	267234	2	-0.024710747	-0.017210921
+35608432	1957142	195714	2	-0.023829899	-0.001757406
+35612828	2407896	240790	2	-0.024354614	-0.008274572
+35622623	2380289	238029	2	-0.024874489	-0.004940172
+35593222	2539707	253971	2	-0.024931095	-0.008040282
+35752392	2403995	240400	2	-0.02483331	-0.013581661
+38656322	2439114	243911	2	-0.025360443	0.015212786
+39076456	36723239	3672324	2	-0.024771506	-0.01160449
+40481595	2544920	254492	2	-0.024700346	0.006523037
+43880923	35851050	3585105	2	-0.024730095	-0.012878504
+43097464	39564382	3956438	2	-0.023155924	-0.015896405
+35840624	2409276	240928	2	-0.024913667	-0.016585689
+36997929	2520705	252071	2	-0.024838482	-0.01297859
+35413556	2405472	240547	2	-0.024182325	-0.023857089
+35415830	2403995	240400	2	-0.024286976	-0.026051796
+2524316	2122623	212262	2	-0.025098768	-0.011924404
+2614655	2080864	208086	2	-0.024140959	-0.000754856
+2612213	2127154	212715	2	-0.024906681	0.001385758
+2545221	2127154	212715	2	-0.024933792	0.014505792
+2550727	2181081	218108	2	-0.024388093	-0.015967734
+2563210	2181081	218108	2	-0.024439678	-0.014760655
+2601559	2181081	218108	2	-0.024591725	-0.017338193
+2574363	2392029	239203	2	-0.024642839	-0.025369351
+2598553	2392029	239203	2	-0.024446119	-0.021956414
+16546741	2215327	221533	2	-0.023797889	-0.003624644
+17079868	2196882	219688	2	-0.024418817	-0.014719704
+17064393	2262166	226217	2	-0.024422625	-0.006359651
+17036204	2272247	227225	2	-0.024562423	-0.012212866
+17030451	2008001	200800	2	-0.024948827	0.013442606
+17008029	2264218	226422	2	-0.025209232	-0.018503154
+17033115	2264218	226422	2	-0.024551048	-0.008597613
+16939987	2264218	226422	2	-0.024946746	-0.022667065
+16900657	2262166	226217	2	-0.023853161	-0.008634389
+16882555	2152450	215245	2	-0.024327829	-0.011703852
+16823201	2008001	200800	2	-0.02456189	0.01587909
+16817122	2182729	218273	2	-0.024670039	0.001747412
+34797479	2372328	237233	2	-0.02475251	-0.010297369
+34808342	2314284	231428	2	-0.025293588	0.001533966
+34877903	2383767	238377	2	-0.024331904	-0.013470991
+35127186	2389144	238914	2	-0.025012776	-0.015107619
+35092159	2314284	231428	2	-0.025009351	-0.004936622
+35075797	2383767	238377	2	-0.024711746	-0.015410151
+35152942	2383767	238377	2	-0.024541544	-0.018487571
+35397043	2409276	240928	2	-0.02491299	-0.025091488
+35398763	2403995	240400	2	-0.024594302	-0.013319443
+35408044	2672344	267234	2	-0.024515416	-0.022599015
+35349797	2672267	267227	2	-0.024511055	0.001214975
+36110962	2672344	267234	2	-0.02473636	-0.024541663
+35583884	2383767	238377	2	-0.024377331	-0.014512826
+35620863	2403995	240400	2	-0.024732134	-0.010831107
+35751327	2672344	267234	2	-0.024932826	-0.020407123
+35751890	34501858	3450186	2	-0.024798823	-0.018301816
+40582088	38044475	3804448	2	-0.024225635	-0.007147738
+39982592	37208121	3720812	2	-0.024702208	0.003867171
+43811817	38758680	3875868	2	-0.024731921	-0.006892409
+42831752	2600280	260028	2	-0.0246492	-0.003052799
+35817802	2332137	233214	2	-0.024723289	-0.013402442
+35900738	34501858	3450186	2	-0.024765393	-0.016279526
+34796297	2383767	238377	2	-0.024852261	-0.016010862
+34795834	2372328	237233	2	-0.024486029	-0.019761175
+34870154	2403995	240400	2	-0.024755606	-0.015893778
+34870790	2332137	233214	2	-0.024806819	-0.014163024
+35088451	2403995	240400	2	-0.024604342	-0.006736917
+35124099	2383767	238377	2	-0.024541121	-0.010836412
+35088295	2383767	238377	2	-0.024583375	-0.013083393
+35146653	2672344	267234	2	-0.024541876	-0.019392764
+35345500	2426427	242643	2	-0.024805877	-0.016988682
+35359649	2409276	240928	2	-0.024641745	-0.008815232
+35348991	34501858	3450186	2	-0.024585349	-0.022037306
+35348566	34501858	3450186	2	-0.024246172	-0.009583113
+35843992	2409276	240928	2	-0.025117779	-0.019920161
+35817812	2426427	242643	2	-0.025061506	-0.014660914
+34863776	2403995	240400	2	-0.023919901	-0.023965605
+34863779	2403995	240400	2	-0.024618416	-0.021258503
+34792295	2383767	238377	2	-0.024050926	0.000331157
+35073010	2369470	236947	2	-0.024392242	-0.013144466
+35134664	2383767	238377	2	-0.024315351	-0.014785884
+35091147	2386953	238695	2	-0.024642339	-0.006869539
+35373633	2409276	240928	2	-0.024659036	-0.02645863
+35359071	2380933	238093	2	-0.024235664	-0.010386664
+35344495	2672344	267234	2	-0.025116719	-0.022806732
+35361276	2405472	240547	2	-0.024772021	-0.012099051
+36095349	2455580	245558	2	-0.024676103	0.017397805
+36105816	2672344	267234	2	-0.024468383	-0.022460426
+34864735	2314284	231428	2	-0.024694493	0.004850121
+34869774	2403995	240400	2	-0.024895881	-0.026331223
+35091032	2383767	238377	2	-0.024774055	-0.022597792
+35118279	2387453	238745	2	-0.024916892	-0.005909385
+35140066	2403995	240400	2	-0.024833946	-0.022397326
+35088220	2403995	240400	2	-0.025185285	-0.012090864
+35342802	2409276	240928	2	-0.025145383	-0.007997432
+35382085	2672344	267234	2	-0.024427994	-0.020879294
+35403458	2672344	267234	2	-0.024743332	-0.023278083
+35349650	2409276	240928	2	-0.025438231	-0.00592315
+38047330	2514957	251496	2	-0.024389758	-0.016083226
+38582091	35100807	3510081	2	-0.024300263	-0.018000537
+38653790	2473557	247356	2	-0.025025366	-0.008509102
+39062461	2568627	256863	2	-0.025002639	-0.003978564
+39320032	2492444	249244	2	-0.024880355	-0.005446558
+39863943	2546032	254603	2	-0.02428244	0.008461722
+40311668	2607393	260739	2	-0.024877028	-0.006273304
+41107470	2672344	267234	2	-0.024313011	-0.019138436
+41647745	2612955	261296	2	-0.024939575	-0.008206849
+39076570	36723239	3672324	2	-0.024384941	0.003148586
+38647616	2439114	243911	2	-0.02504266	0.032503184
+37566793	2470808	247081	2	-0.024134639	-0.008422084
+37566759	2672344	267234	2	-0.024638661	-0.022780589
+37286187	2619125	261913	2	-0.024498012	0.010460669
+37229628	2439114	243911	2	-0.025104111	0.030329884
+36953861	2451927	245193	2	-0.024571047	0.016082759
+36940578	2672344	267234	2	-0.025463272	-0.014740806
+37331711	2441293	244129	2	-0.024297225	-0.003485883
+36718749	2672344	267234	2	-0.025166604	-0.023122366
+36618158	2672344	267234	2	-0.023380036	-0.018323837
+36611327	1891008	189101	2	-0.024935964	0.011563654
+36193286	2458842	245884	2	-0.025128827	0.00022458
+36189838	2441293	244129	2	-0.024402392	-0.003846081
+35613045	2672344	267234	2	-0.024661759	-0.011595512
+35613455	2380289	238029	2	-0.024534128	-0.005013896
+35743417	2672344	267234	2	-0.024932141	-0.021268331
+35745979	2409276	240928	2	-0.025176107	-0.020471468
+38352991	2439114	243911	2	-0.02475593	0.025858354
+41078540	2542232	254223	2	-0.025118526	-0.000200179
+38629756	2364463	236446	2	-0.024154554	-0.010476274
+40039982	2579321	257932	2	-0.024506472	-0.005193626
+43934743	2544920	254492	2	-0.024874021	0.005073399
+46084166	36217775	3621778	2	-0.025422617	0.070187247
+35913017	2672344	267234	2	-0.024946901	-0.025722555
+35826017	2438048	243805	2	-0.025027773	-0.021215921
+35751315	2403995	240400	2	-0.024566588	-0.013118036
+35584795	2387453	238745	2	-0.024995974	-0.012623461
+35750125	2426427	242643	2	-0.024914599	-0.011938374
+35750766	2619125	261913	2	-0.024425137	-0.014304775
+38990609	2542232	254223	2	-0.024788447	-0.004587424
+40039940	2544920	254492	2	-0.024964718	0.030707386
+35886501	2672344	267234	2	-0.025216815	-0.025719984
+35890415	2672344	267234	2	-0.024627198	-0.017807076
+35820232	2426427	242643	2	-0.02492062	-0.014614022
+37063127	2439114	243911	2	-0.025239632	0.024818554
+37798795	2439114	243911	2	-0.02532298	0.029511481
+37794086	2439114	243911	2	-0.024800659	0.02993805
+37322487	2455053	245505	2	-0.024612744	-0.019025596
+37318672	2409276	240928	2	-0.025175838	-0.01720688
+37067520	2455053	245505	2	-0.024793447	-0.008393191
+36954937	2473557	247356	2	-0.02459981	-0.018109789
+38859369	2544920	254492	2	-0.024926336	0.003465051
+36745522	2439845	243985	2	-0.024282805	0.000836816
+36658807	2407896	240790	2	-0.024396443	-0.019980846
+36655802	2672344	267234	2	-0.024200767	-0.020624449
+36352822	2470808	247081	2	-0.024651494	0.007627392
+36223141	2406276	240628	2	-0.024400759	-0.023670418
+37501796	2439114	243911	2	-0.025506414	0.029632786
+38882972	35100807	3510081	2	-0.024787826	-0.02145246
+37196787	2441293	244129	2	-0.024601541	-0.008946472
+37125975	2383767	238377	2	-0.024577741	-0.012279712
+36831558	2672344	267234	2	-0.024717365	-0.026472852
+36829394	2473557	247356	2	-0.024922072	-0.017758884
+36718725	2458842	245884	2	-0.024665232	-0.018516803
+37998787	2492444	249244	2	-0.024904786	-0.019341133
+36610180	2314284	231428	2	-0.024845701	0.006005869
+36605188	2672344	267234	2	-0.024429474	-0.027551754
+36119177	2403995	240400	2	-0.02434816	-0.005092406
+36118445	2439114	243911	2	-0.024972875	0.020555238
+2616806	2206073	220607	2	-0.024155182	-0.018746255
+16813929	2392029	239203	2	-0.024762645	-0.025762016
+37975061	2403995	240400	2	-0.024856736	-0.012302078
+38406329	2373906	237391	2	-0.024438667	-0.009979495
+38791528	35100807	3510081	2	-0.024667052	-0.007160942
+38882691	2526197	252620	2	-0.023771322	-0.008248493
+39648538	2542232	254223	2	-0.024522685	-0.005530458
+39709204	2567054	256705	2	-0.025222967	0.033163135
+40675455	2544920	254492	2	-0.024684008	-0.002045823
+40725455	2546032	254603	2	-0.0244138	0.003775669
+43587669	35100807	3510081	2	-0.024664839	-0.010500874
+38181668	2439114	243911	2	-0.024905811	0.03235516
+38353266	2439114	243911	2	-0.025052587	0.035113042
+38703216	2439114	243911	2	-0.0253306	0.017556175
+38788331	2672344	267234	2	-0.024704381	-0.026270987
+38516458	2607393	260739	2	-0.024864045	0.009938401
+39477807	2672050	267205	2	-0.024043151	-0.01560138
+40357484	2567054	256705	2	-0.025205969	-0.001365744
+41686290	2544920	254492	2	-0.02432046	0.004351983
+42172546	2616356	261636	2	-0.024942166	-0.003987925
+39364478	2542232	254223	2	-0.024824047	-0.004481324
+39575696	2544920	254492	2	-0.02503778	0.003462771
+37971482	2514957	251496	2	-0.023988127	-0.011833139
+38035528	2439114	243911	2	-0.024860711	0.023461984
+38405087	2672328	267233	2	-0.024137114	-0.008498301
+38465388	2672344	267234	2	-0.024959821	-0.026268437
+38917736	2458842	245884	2	-0.024972541	-0.008783617
+38919829	2439114	243911	2	-0.024743513	0.027000157
+39771750	2514957	251496	2	-0.023632241	-0.010491551
+39804534	2672050	267205	2	-0.024454	-0.01823149
+40745037	2607393	260739	2	-0.025017594	0.006763937
+41000148	2607393	260739	2	-0.025075239	0.003783484
+41320525	2569678	256968	2	-0.024076125	-0.00537728
+39076705	36723239	3672324	2	-0.025020564	0.002604115
+17086562	2008001	200800	2	-0.025091655	0.01739733
+17085239	2264218	226422	2	-0.024885909	-0.01413621
+17042292	2008001	200800	2	-0.024779999	0.017281319
+17041497	2264218	226422	2	-0.024430635	-0.014389176
+17016068	2232701	223270	2	-0.02449563	0.001635751
+17010011	2008001	200800	2	-0.024080924	0.021008802
+16970761	2008001	200800	2	-0.025225007	0.008906159
+46007734	36217775	3621778	2	-0.025558838	0.066036923
+45585638	36217775	3621778	2	-0.025256749	0.065603336
+46511217	42605588	4260559	2	-0.024351325	-0.01749394
+51319192	40095989	4009599	2	-0.024219806	-0.010075837
+48317997	36217775	3621778	2	-0.024938915	0.067453185
+40935923	2383767	238377	2	-0.023536305	-0.012340067
+42878633	39558786	3955879	2	-0.024251162	-0.00732523
+43806111	34459773	3445977	2	-0.024590202	-0.008839644
+44798319	34459773	3445977	2	-0.024580906	-0.005797173
+38100999	2369897	236990	2	-0.024230978	-0.014152126
+45161709	35850975	3585098	2	-0.024781943	-0.017735951
+44307337	2560536	256054	2	-0.024356647	0.002834486
+51497186	40759517	4075952	2	-0.024501159	-0.016130716
+37555199	2672344	267234	2	-0.024845929	-0.02104276
+45801834	36217775	3621778	2	-0.025345667	0.066444882
+42453795	40660639	4066064	2	-0.024056182	-0.003901857
+46455927	36217775	3621778	2	-0.025389261	0.063658074
+52988958	40698711	4069871	2	-0.024698211	-0.003241175
+46534771	35850975	3585098	2	-0.024648683	-0.022233105
+46771254	36217775	3621778	2	-0.025368144	0.063710562
+50684603	38575577	3857558	2	-0.024364328	-0.007597529
+47048556	35850975	3585098	2	-0.024951887	-0.023689719
+46287180	35811063	3581106	2	-0.023933633	-0.020394995
+38468434	36361619	3636162	2	-0.02440753	-0.015458909
+53129939	40759517	4075952	2	-0.024200956	-0.010020603
+41688563	2544920	254492	2	-0.024435893	0.010616997
+47166482	36217775	3621778	2	-0.024778148	0.073238603
+46572381	36217775	3621778	2	-0.024901103	0.064337331
+43990955	36723239	3672324	2	-0.024723761	0.009473387
+44909346	36723239	3672324	2	-0.024554694	-0.00626485
+38700895	35582796	3558280	2	-0.024410262	-0.004307203
+50684593	35811063	3581106	2	-0.024176902	-0.01922769
+45484025	35811063	3581106	2	-0.024933328	-0.011787245
+46576675	36217775	3621778	2	-0.025159686	0.069469043
+37356460	2260518	226052	2	-0.02382579	-0.007787178
+41418399	2672328	267233	2	-0.024480253	-0.019296792
+41345876	37966586	3796659	2	-0.023686515	-0.010858824
+40484160	2672344	267234	2	-0.024560551	-0.024239663
+47368778	36217775	3621778	2	-0.025084695	0.064022747
+35624525	2383767	238377	2	-0.024891445	-0.008182089
+46406088	34459773	3445977	2	-0.024387922	-0.010561841
+46989454	36757442	3675744	2	-0.024251624	-0.021845104
+43905812	34459773	3445977	2	-0.024949549	-0.002162465
+45082522	34459773	3445977	2	-0.024509145	-0.005021679
+43377999	2601075	260108	2	-0.024062084	-0.017501495
+46287357	17525648	1752565	2	-0.024169838	-0.01206634
+43879830	41317306	4131731	2	-0.024055197	-0.012583185
+45175938	35850975	3585098	2	-0.02455493	-0.019018497
+46983383	36217775	3621778	2	-0.024804245	0.073097963
+37800697	2458842	245884	2	-0.024976834	-0.005678241
+46316713	35811063	3581106	2	-0.024997692	-0.016956262
+52503374	41344848	4134485	2	-0.024480217	-0.009929479
+40571809	2473557	247356	2	-0.02391333	-0.024536546
+46738517	42605588	4260559	2	-0.024641102	-0.020126371
+46308244	36217775	3621778	2	-0.024711633	0.071146789
+47569115	40759517	4075952	2	-0.024764583	-0.012244462
+47390562	36217775	3621778	2	-0.025032667	0.071345109
+42075205	2607393	260739	2	-0.025313515	0.024395082
+42785344	2607393	260739	2	-0.024931585	0.004581969
+43031412	34459773	3445977	2	-0.024559621	-0.008210989
+43563836	34459773	3445977	2	-0.024721867	-0.008128155
+43909366	35850149	3585015	2	-0.024651982	-0.024197532
+43911013	36349559	3634956	2	-0.024314227	-0.013597752
+44847293	35811063	3581106	2	-0.024558273	-0.020202633
+45134073	36102196	3610220	2	-0.024606381	-0.008308522
+45353970	17525648	1752565	2	-0.024727934	-0.008258998
+45486577	38575577	3857558	2	-0.024387004	-0.001082991
+45645701	17525648	1752565	2	-0.024238744	-0.013500211
+45973720	2591832	259183	2	-0.024201142	-0.001448971
+52379105	38575577	3857558	2	-0.024270899	-0.004465765
+42821636	2569678	256968	2	-0.024470287	-0.003839786
+43195905	34459773	3445977	2	-0.024193637	-0.004741841
+43563863	34459773	3445977	2	-0.024226149	-0.006386705
+43909753	2609850	260985	2	-0.024559842	-0.011433701
+44163890	35098455	3509846	2	-0.024380244	-0.012098271
+44847348	2569678	256968	2	-0.023994904	-0.009582005
+45135583	35811063	3581106	2	-0.024943593	-0.015986777
+45354423	38575577	3857558	2	-0.024809431	-0.005247989
+45486578	2626785	262679	2	-0.024119979	-0.001331562
+45645838	34776691	3477669	2	-0.024758803	-0.011976116
+45973819	2607393	260739	2	-0.024748902	0.008926147
+45974317	38575577	3857558	2	-0.024388438	-0.001806084
+42786444	34776691	3477669	2	-0.024239202	-0.008733337
+43196165	2607393	260739	2	-0.024740699	0.012349533
+43715612	34497091	3449709	2	-0.024326913	-0.011707838
+43909851	35097275	3509728	2	-0.024497704	-0.013758373
+44165174	35097275	3509728	2	-0.024346372	-0.011416812
+44847911	2626785	262679	2	-0.024199639	-0.00078936
+45136072	2576863	257686	2	-0.02426618	0.010029477
+45484508	36102196	3610220	2	-0.024543596	-0.004471251
+45644221	35546779	3554678	2	-0.024371292	-0.01599022
+45645967	35546779	3554678	2	-0.024018088	-0.014918307
+45973820	17525648	1752565	2	-0.024584048	-0.009637459
+45974495	35546779	3554678	2	-0.024665222	-0.016311697
+42787164	2569678	256968	2	-0.024012894	-0.004219647
+43197357	2576863	257686	2	-0.024559616	0.002719576
+43715895	35850149	3585015	2	-0.024961242	-0.02161203
+43910400	35850149	3585015	2	-0.024751197	-0.012366812
+44165197	34776691	3477669	2	-0.02489971	-0.006671988
+44848075	2347464	234746	2	-0.024290958	-0.00994299
+45350448	36115656	3611566	2	-0.024793276	-0.012217906
+45485414	34776808	3477681	2	-0.024320911	-0.018867462
+45644432	34459773	3445977	2	-0.024382639	-0.012828651
+46006998	2591832	259183	2	-0.024977395	-0.009413173
+45974032	17525648	1752565	2	-0.024802971	-0.012068686
+45975154	2569678	256968	2	-0.024788528	0.000294608
+42788313	2629569	262957	2	-0.024361376	-0.00695347
+43561338	2607393	260739	2	-0.024971325	0.009083153
+43715896	2590969	259097	2	-0.024793059	-0.000380408
+43910525	35811063	3581106	2	-0.024430767	-0.021961181
+44845272	35850149	3585015	2	-0.024932617	-0.024537579
+44848163	34776691	3477669	2	-0.024549963	-0.015653866
+45351446	2576863	257686	2	-0.02459042	0.011292742
+45485561	2576863	257686	2	-0.023967405	-1.92E-05
+45644840	35546779	3554678	2	-0.023948752	-0.014531055
+45972544	35811792	3581179	2	-0.024612701	-0.016136363
+45974105	34459773	3445977	2	-0.024667186	-0.011021524
+45975616	17525648	1752565	2	-0.024505883	-0.001649043
+42937640	2629569	262957	2	-0.02461117	-0.012718282
+43562504	35097275	3509728	2	-0.024351123	-0.012912115
+43716076	2590969	259097	2	-0.024858317	0.009035733
+47399063	2547377	254738	2	-0.024044128	-0.008304576
+44845512	2576863	257686	2	-0.024234016	0.008709546
+45133415	2622621	262262	2	-0.024487375	-0.007343463
+45351876	2544920	254492	2	-0.025167366	0.001081037
+45485732	38575577	3857558	2	-0.025633212	-0.007767969
+45644889	35811063	3581106	2	-0.024462043	-0.017072079
+45972589	34776691	3477669	2	-0.024424569	-0.008101097
+45974107	2591832	259183	2	-0.024385677	-0.008744803
+45975868	36102196	3610220	2	-0.025103614	-0.005528746
+42937894	35546780	3554678	2	-0.024386331	-0.011539348
+43563392	35811063	3581106	2	-0.024742202	-0.008712328
+43716309	35097275	3509728	2	-0.024348054	-0.009947525
+43910847	2569678	256968	2	-0.02413891	-0.010820107
+44846216	2569678	256968	2	-0.024248778	-0.002402007
+45133891	35811063	3581106	2	-0.024768108	-0.021644665
+45352766	2547377	254738	2	-0.024549627	-0.007895581
+45485733	38575577	3857558	2	-0.024729724	-0.006279916
+45645626	38575577	3857558	2	-0.024385686	-0.008634072
+45972688	2590969	259097	2	-0.024697718	0.001244042
+45974179	2569678	256968	2	-0.02458028	-0.010150481
+45976361	35811792	3581179	2	-0.024160109	-0.009455522
+43030813	34459773	3445977	2	-0.024333018	-0.007836796
+43563669	2576863	257686	2	-0.024073376	0.00419858
+43909152	35811063	3581106	2	-0.024597586	-0.019437517
+43910848	2547377	254738	2	-0.024311694	-0.009390065
+44846634	2590969	259097	2	-0.024770276	0.006202976
+45134023	2576863	257686	2	-0.024583644	0.004248538
+45353760	2569678	256968	2	-0.023927791	-0.00539762
+45486481	2569678	256968	2	-0.023966231	-0.01154065
+45645627	35342073	3534207	2	-0.024266414	-0.006609483
+45973441	38575577	3857558	2	-0.024977786	-0.003932818
+45974180	2590969	259097	2	-0.024571795	0.007267026
+45976542	2576863	257686	2	-0.023961196	0.006019625
+46086689	35546779	3554678	2	-0.024159437	-0.02158547
+46507125	36115656	3611566	2	-0.024570744	0.000359306
+46509456	2626785	262679	2	-0.024180434	-0.004025961
+47267853	2626785	262679	2	-0.024772058	-0.006699318
+47269832	36217775	3621778	2	-0.025486341	0.060358277
+47272201	36216106	3621611	2	-0.024244937	-0.016741477
+47545028	38863395	3886340	2	-0.025040282	0.014596871
+47813119	38863395	3886340	2	-0.024833108	0.006709134
+47816032	2615694	261569	2	-0.024694601	-0.010362702
+47817718	35811792	3581179	2	-0.024834718	-0.01588785
+48357238	2615694	261569	2	-0.024198073	-0.011915295
+44257829	2547377	254738	2	-0.024105617	-0.008889668
+46086808	35811063	3581106	2	-0.024442257	-0.016091163
+46507170	2576863	257686	2	-0.024477704	0.010562225
+46509667	36217775	3621778	2	-0.02520019	0.066513392
+47267909	35811063	3581106	2	-0.024333141	0.004989573
+47270128	35850975	3585098	2	-0.024824451	-0.016366725
+47272202	35811792	3581179	2	-0.024525587	-0.020849134
+47545156	36618478	3661848	2	-0.024105673	-0.010591931
+47813631	36216106	3621611	2	-0.024293371	-0.018549999
+47816445	35850975	3585098	2	-0.025210266	-0.019916963
+47817943	35850975	3585098	2	-0.02448755	-0.01904164
+48357285	38977991	3897799	2	-0.024923599	-0.003478449
+49291222	7	8	2	-0.024332178	-0.008338825
+46086887	36102196	3610220	2	-0.024576109	-0.009744276
+46507171	36115656	3611566	2	-0.024814531	-0.00785875
+46769307	2569678	256968	2	-0.024240123	-0.007391857
+47267910	37112777	3711278	2	-0.024367659	-0.007656332
+47270826	38863395	3886340	2	-0.02481404	0.010412128
+47544391	2591832	259183	2	-0.02464001	-0.012105633
+47545239	2615694	261569	2	-0.024756858	-0.009677432
+47813634	36216106	3621611	2	-0.024392199	-0.011990106
+47816602	39748848	3974885	2	-0.025775337	-0.006305372
+48203118	35546779	3554678	2	-0.02465861	-0.007135243
+50206678	36217775	3621778	2	-0.025091471	0.064960977
+46169417	17525648	1752565	2	-0.024752502	-0.008991307
+46507295	36102196	3610220	2	-0.02470673	-0.022837517
+46770127	36217775	3621778	2	-0.024666295	-0.013303062
+47267911	37112777	3711278	2	-0.024170389	-0.008392882
+47270827	36618478	3661848	2	-0.024240805	-0.007748374
+47544452	35811063	3581106	2	-0.02446145	-0.011076808
+47545240	36217775	3621778	2	-0.025197513	0.067822225
+47814324	35811063	3581106	2	-0.025089217	-0.006464024
+47816690	2615694	261569	2	-0.024665871	-0.014056839
+48204330	35850975	3585098	2	-0.024735715	-0.022383704
+50207621	38976652	3897665	2	-0.024302161	-0.003158776
+46170935	2626785	262679	2	-0.02439594	-0.01067736
+46508025	2615694	261569	2	-0.02522255	0.000183685
+46770292	37200320	3720032	2	-0.024415069	0.009124553
+47267938	2626785	262679	2	-0.024658457	-0.020936618
+47271104	37200320	3720032	2	-0.024662746	0.021563582
+47544664	36217775	3621778	2	-0.024901941	0.068167246
+47545881	35811063	3581106	2	-0.024828314	-0.023972163
+47814536	36217775	3621778	2	-0.025219826	0.063769337
+47816759	39748848	3974885	2	-0.024331957	-0.004163665
+48204907	38699787	3869979	2	-0.024723755	-0.006621003
+50208955	36217775	3621778	2	-0.024961631	0.068764743
+46170968	36216106	3621611	2	-0.025046344	-0.016717876
+46508026	17525648	1752565	2	-0.02463712	-0.008042374
+46770912	36216106	3621611	2	-0.024319219	-0.009339255
+47267994	2626785	262679	2	-0.024416369	0.003368756
+47272046	35811063	3581106	2	-0.02448878	-0.019706047
+47544701	36217775	3621778	2	-0.024840629	0.071835686
+47546121	36217775	3621778	2	-0.024832766	0.068371854
+47815099	36217775	3621778	2	-0.024771777	0.066388379
+47816846	38977991	3897799	2	-0.024402873	-0.007014203
+48205233	38863395	3886340	2	-0.024641923	0.009503412
+45644839	3	4	2	-0.023963654	-0.005996826
+46506886	34776691	3477669	2	-0.02424505	-0.003286282
+46508842	36216106	3621611	2	-0.024594143	-0.013059302
+46772051	36217775	3621778	2	-0.025166894	0.06824709
+47268155	2615694	261569	2	-0.024670989	-0.013258465
+47272199	35811063	3581106	2	-0.024780569	-0.011350217
+47544856	36217775	3621778	2	-0.025021853	0.070767658
+47546725	2615694	261569	2	-0.024953896	-0.011674541
+47815184	36721591	3672159	2	-0.024719451	-0.019444147
+47817147	38699787	3869979	2	-0.024547965	-0.020252439
+48206456	39748848	3974885	2	-0.024213858	-0.00691892
+47813632	5	6	2	-0.023926263	-0.01306326
+46506932	2626785	262679	2	-0.024401768	-0.008947209
+46509179	2626785	262679	2	-0.024636339	0.000180036
+47180011	2569678	256968	2	-0.024506498	-0.003842493
+47268652	36721591	3672159	2	-0.024910358	-0.006350106
+47272200	2626785	262679	2	-0.02419021	-0.001834627
+47544983	38575577	3857558	2	-0.024571487	-0.003695733
+47546925	35811063	3581106	2	-0.024974054	-0.009218971
+47815851	35850975	3585098	2	-0.024822629	-0.015795581
+47817526	35850975	3585098	2	-0.024575532	-0.017585498
+48357064	34459773	3445977	2	-0.024238832	-0.009334785
+48204601	2547377	254738	2	-0.024606181	-0.011570456
+46741527	35735628	3573563	2	-0.024369014	-0.016652126
+47076354	36757512	3675751	2	-0.023573049	-0.01370135
+46251563	36721591	3672159	2	-0.024729182	0.002279431
+42108901	36217775	3621778	2	-0.024661631	0.065048852
+47705653	36113185	3611319	2	-0.024256697	-0.016107464
+45846529	42179395	4217940	2	-0.02475627	-0.011154256
+40101840	2472236	247224	2	-0.018034868	-0.006231771
+45078452	2538929	253893	2	-0.018376946	-0.006416057
+44362873	39725062	3972506	2	-0.018327567	-0.007120732
+45519322	41404342	4140434	2	-0.018771	-0.005077808
+47076359	35362629	3536263	2	-0.018023534	-0.006029328
+43265633	35341188	3534119	2	-0.023859221	-0.00846133
+47400459	36217775	3621778	2	-0.018390178	-0.005840994
+47182583	37111514	3711151	2	-0.018575511	-0.007114018
+46503341	34459773	3445977	2	-0.018427489	-0.008540619
+46096039	35582894	3558289	2	-0.018709601	-0.007011641
+45243608	39563988	3956399	2	-0.018608627	-0.005949189
+47810128	42179395	4217940	2	-0.023809531	-0.002681982
+52733082	37112264	3711226	2	-0.023777499	0.009562711
+50826490	36217775	3621778	2	-0.025092902	0.067478479
+47400454	37111514	3711151	2	-0.023826274	-0.012674056
+42058651	2473557	247356	2	-0.024638642	-0.016376805
+44362782	2630940	263094	2	-0.024159065	-0.007354627
+42009213	2344386	234439	2	-0.023802995	0.005024719
+40343475	2386148	238615	2	-0.023991088	-0.012585622
+47705643	37111514	3711151	2	-0.024902083	-0.014734399
+40509439	36685599	3668560	2	-0.024354323	0.000392669
+45441444	34459773	3445977	2	-0.025214295	0.005772115
+42052419	2605219	260522	2	-0.02463372	-9.00E-05
+43423921	35341188	3534119	2	-0.024410477	0.002364342
+42528871	2576863	257686	2	-0.024822331	0.009390376
+45720406	35341188	3534119	2	-0.024043963	-0.003813226
+46769590	36217775	3621778	2	-0.025315487	0.068568432
+46481251	35060347	3506035	2	-0.024249694	-0.011732113
+45807597	34824270	3482427	2	-0.023912739	-0.015638213
+45721438	35097275	3509728	2	-0.024729474	-0.010719756
+45706160	2478218	247822	2	-0.024598722	-0.008736254
+43907763	2492444	249244	2	-0.024189988	-0.006665124
+41145800	2394480	239448	2	-0.024292203	-0.003788132
+43714493	35097275	3509728	2	-0.024248983	-0.0181551
+43877446	39562698	3956270	2	-0.024862182	-0.008194429
+46200203	35365265	3536527	2	-0.024160221	-0.015060396
+43426985	2629304	262930	2	-0.024447254	0.003820932
+43908231	2629304	262930	2	-0.024907803	-0.005938166
+46480315	35060347	3506035	2	-0.023819038	0.00222833
+45807145	35060347	3506035	2	-0.025110321	-0.012828203
+43424155	2573651	257365	2	-0.023470661	-0.012596567
+41256010	2511271	251127	2	-0.023753131	-0.003672631
+46115168	2629304	262930	2	-0.024159112	-0.003832895
+42051415	2554988	255499	2	-0.024017415	0.004051793
+38705832	2409276	240928	2	-0.024497656	-0.016274856
+46115310	37321726	3732173	2	-0.024523979	0.00074622
+42051609	2451847	245185	2	-0.024297117	-0.015281511
+46483101	37321726	3732173	2	-0.024546337	-0.009727247
+46114762	35341188	3534119	2	-0.024419346	0.010459033
+45807146	35060347	3506035	2	-0.025520159	-0.013069846
+46479746	34459773	3445977	2	-0.024196814	-0.004539879
+45440666	34459773	3445977	2	-0.024566441	-0.013146129
+45891418	2576974	257697	2	-0.024433246	-0.0066437
+45721734	2478218	247822	2	-0.024627783	-0.019246076
+45855754	2541819	254182	2	-0.024404027	-0.005849473
+47159844	35852003	3585200	2	-0.024326377	-0.009249505
+41151146	2555853	255585	2	-0.024351134	-0.005938042
+38112271	2488933	248893	2	-0.02412721	-0.007736732
+46115809	2629304	262930	2	-0.024183286	-0.002076578
+41784839	2555853	255585	2	-0.023861167	-0.009066433
+42530154	2541819	254182	2	-0.023876832	-0.010227282
+46116069	35852003	3585200	2	-0.023509943	-0.010857242
+41255908	2458092	245809	2	-0.024065179	-0.006099357
+45807439	35060347	3506035	2	-0.024307333	-0.003088055
+43426418	35060347	3506035	2	-0.024014118	-0.012935204
+37283904	2397271	239727	2	-0.024043536	-0.011886026
+41640048	2451927	245193	2	-0.024436274	-0.000609962
+43164648	2314284	231428	2	-0.024832994	0.010250367
+47055030	2492444	249244	2	-0.024166099	-0.015586044
+45807203	2629304	262930	2	-0.024595655	-0.007111731
+41997921	2514957	251496	2	-0.026082768	-0.006105819
+41147264	2386895	238690	2	-0.024074827	-0.01102974
+42832391	34498548	3449855	2	-0.024563138	-0.006013699
+46770105	35061075	3506108	2	-0.024643285	-0.002319532
+41557021	2541819	254182	2	-0.024328344	-0.006348226
+45921675	37321726	3732173	2	-0.02486934	-0.007792697
+43000556	2605219	260522	2	-0.024500691	0.004923123
+42877331	40208333	4020833	2	-0.024463103	0.000566058
+41256214	2554988	255499	2	-0.024838354	0.009594416
+45807598	2478218	247822	2	-0.024287979	-0.011492541
+40677369	2566128	256613	2	-0.024827253	-0.002218535
+42528804	2541819	254182	2	-0.024012337	-0.008722507
+41997951	2409276	240928	2	-0.024784696	-0.017848579
+46573135	36217769	3621777	2	-0.024799876	0.033547009
+46573551	35852003	3585200	2	-0.02412931	-0.010340331
+42051029	2605219	260522	2	-0.024696874	0.003219754
+46483182	35061075	3506108	2	-0.024630438	-0.007552197
+43424841	2629304	262930	2	-0.024221686	-0.007302051
+45706356	38263266	3826327	2	-0.024095415	-0.024336012
+52991255	40291988	4029199	2	-0.024718588	-0.011579344
+44590835	35811792	3581179	2	-0.02465544	-0.01866489
+43295889	2277541	227754	2	-0.024447552	-0.011333325
+37409346	2383767	238377	2	-0.023980049	-0.011416497
+45399366	35583106	3558311	2	-0.024233905	-0.014603597
+44883728	36723239	3672324	2	-0.024567919	-0.002766884
+49286112	40759517	4075952	2	-0.025007717	-0.013991535
+46427061	36217775	3621778	2	-0.02555689	0.067811667
+52713645	41625283	4162528	2	-0.024486902	-0.013352662
+43383147	39562851	3956285	2	-0.023928017	-0.005184965
+46288489	34459773	3445977	2	-0.02447097	-0.006497758
+47740446	36217775	3621778	2	-0.025145464	0.064154944
+42892033	2578045	257805	2	-0.02428879	-0.01867416
+52488397	40516863	4051686	2	-0.024917693	0.042189345
+41197627	2569678	256968	2	-0.024598612	-0.010280591
+47066991	35100807	3510081	2	-0.024272177	0.016106403
+44186185	41317306	4131731	2	-0.024744269	-0.009419793
+45972770	35850975	3585098	2	-0.02480264	-0.017403242
+47289810	42605118	4260512	2	-0.024436858	0.012946617
+41648051	38639275	3863928	2	-0.0244051	-0.015733325
+40335276	2544920	254492	2	-0.024686292	0.008288588
+45495238	36723239	3672324	2	-0.024423795	-0.012277054
+47130683	35850975	3585098	2	-0.024600666	-0.016300206
+46230610	36217775	3621778	2	-0.024535574	0.066488553
+42662694	34459773	3445977	2	-0.024792613	-0.015302075
+46727156	38974321	3897432	2	-0.024616407	-0.009369722
+46021488	35850975	3585098	2	-0.024803772	-0.019653322
+45736307	2672344	267234	2	-0.024782581	-0.022461993
+40486925	38123962	3812396	2	-0.024143633	-0.018351872
+45594858	36757442	3675744	2	-0.024593456	-0.012978581
+45595048	35811063	3581106	2	-0.02432718	-0.017432294
+46034661	36217775	3621778	2	-0.02511763	0.064097835
+53251877	37858056	3785806	2	-0.025138434	0.027555554
+47811764	40659984	4065998	2	-0.02469864	-0.008090251
+43745072	2672891	267289	2	-0.024237979	-0.004851014
+47130766	35850975	3585098	2	-0.024569976	-0.017534151
+42294591	39558786	3955879	2	-0.024002929	-0.008787698
+45284452	35811063	3581106	2	-0.024661889	-0.017204344
+47430045	37405448	3740545	2	-0.024941079	0.012312976
+45284451	36217775	3621778	2	-0.024963582	0.064282764
+47761599	40095989	4009599	2	-0.024641235	-0.014255725
+17268326	2435524	243552	2	-0.023327019	-0.004510063
+45973995	35850975	3585098	2	-0.024606871	-0.017513585
+46535664	36217775	3621778	2	-0.025160521	0.062590629
+45971260	36217775	3621778	2	-0.024785854	0.067470178
+52472575	41344848	4134485	2	-0.024759646	-0.013416455
+42681479	2576863	257686	2	-0.024610756	8.70E-05
+45351109	36217775	3621778	2	-0.024817538	0.068568333
+41452116	39558786	3955879	2	-0.024698456	0.006442273
+46348645	37405448	3740545	2	-0.024615352	0.019044407
+47966810	40759517	4075952	2	-0.024095507	-0.020057575
+45171219	2672344	267234	2	-0.024731416	-0.02020245
+46264239	35850975	3585098	2	-0.024921624	-0.01497161
+46264222	36217775	3621778	2	-0.025035611	0.064443233
+42046354	39558786	3955879	2	-0.024439583	-0.017001696
+45353424	35850975	3585098	2	-0.024529694	-0.016328086
+46057985	36217775	3621778	2	-0.025355901	0.0633698
+41339769	37966586	3796659	2	-0.024027014	-0.009001201
+46027291	35850975	3585098	2	-0.024830543	-0.013955446
+45264517	35811063	3581106	2	-0.024907142	-0.017619265
+40647525	2544920	254492	2	-0.025015421	0.005556237
+37873678	2344386	234439	2	-0.024483566	-0.001905452
+36259950	2415870	241587	2	-0.024855469	-0.014003355
+47524681	36723239	3672324	2	-0.024834085	-0.01351271
+43941730	17525648	1752565	2	-0.025622014	-0.009583557
+43933728	34459773	3445977	2	-0.024791163	-0.01452525
+45372146	38575577	3857558	2	-0.024276294	-0.005466389
+45774251	38575577	3857558	2	-0.023634408	-0.006092469
+46360696	37351873	3735187	2	-0.024796029	-0.015090679
+44470739	2473557	247356	2	-0.024162908	-0.02698106
+52007483	40759517	4075952	2	-0.024667509	-0.003998178
+52507548	36217775	3621778	2	-0.024723714	0.064395942
+47105367	36217775	3621778	2	-0.024951911	0.065930285
+45344079	2544920	254492	2	-0.024850151	0.015995275
+42060312	39558786	3955879	2	-0.024630795	-0.018002812
+45176158	35850975	3585098	2	-0.024731469	-0.014331187
+45775822	35811063	3581106	2	-0.024651907	-0.011757291
+46872911	35811063	3581106	2	-0.024694395	-0.016325198
+45255022	2544920	254492	2	-0.024196278	0.016974863
+43768278	2544920	254492	2	-0.024706244	0.007050287
+43586404	35362980	3536298	2	-0.024984913	-0.015392115
+39142413	2567054	256705	2	-0.024713629	-0.003089873
+45704329	36217775	3621778	2	-0.024982471	0.073874387
+46987005	2601548	260155	2	-0.024832686	-0.00548769
+46284787	36721591	3672159	2	-0.024320017	-0.017225626
+45641831	36721591	3672159	2	-0.024520144	-0.024420149
+45887706	36721591	3672159	2	-0.02464002	-0.025286704
+45242042	36721591	3672159	2	-0.02523195	-0.004001746
+43939887	35546779	3554678	2	-0.024250103	-0.020060766
+42961980	35546779	3554678	2	-0.024993868	-0.009675977
+47191054	36721591	3672159	2	-0.024177888	-0.021101654
+47223556	36721591	3672159	2	-0.024585482	-0.014480393
+46566869	35546779	3554678	2	-0.02439373	-0.020476067
+51287763	36721591	3672159	2	-0.024736187	-0.01823633
+46065914	36721591	3672159	2	-0.024903716	-0.014176427
+45419089	36721591	3672159	2	-0.024922577	-0.015519572
+45390710	36721591	3672159	2	-0.024897844	-0.013792425
+46201677	36721591	3672159	2	-0.024232347	-0.025045162
+45924348	36721591	3672159	2	-0.024814809	-0.018517355
+45048696	36721591	3672159	2	-0.02463093	-0.017621502
+46602959	35546779	3554678	2	-0.024411303	-0.015409742
+48393903	54113188	5411319	2	-0.0219913	-0.004943041
+35611325	2368204	236820	2	-0.025171585	-0.013644793
+45640036	39122554	3912255	2	-0.024450381	-0.019633961
+45390543	41888550	4188855	2	-0.024696214	0.007459591
+43265887	34776808	3477681	2	-0.024897064	0.036850761
+38409396	2506489	250649	2	-0.024377678	-0.008632312
+45270241	36756661	3675666	2	-0.024413329	-0.006487394
+45390550	37315082	3731508	2	-0.024488873	-0.009639577
+40697444	2601075	260108	2	-0.024244624	-0.00393933
+42880081	2612756	261276	2	-0.024531292	-0.019233782
+42726055	2589316	258932	2	-0.025018915	-0.016708169
+45006541	35363892	3536389	2	-0.024712114	-0.010895919
+43073670	35546779	3554678	2	-0.024109654	-0.001615272
+45150989	35363892	3536389	2	-0.024753701	-0.021206834
+42339542	2612756	261276	2	-0.024518612	-0.004319385
+40379581	2607393	260739	2	-0.024939677	-0.010126979
+15775896	1978596	197860	2	-0.024619831	-0.023439915
+2517531	2392029	239203	2	-0.024182887	-0.011236319
+25597020	2262166	226217	2	-0.024439395	-0.013431582
+17268599	2264218	226422	2	-0.02424028	-0.012800217
+17201054	2105692	210569	2	-0.023086777	-0.01088588
+42789099	34776691	3477669	2	-0.0249001	0.062498111
+44073621	38408351	3840835	2	-0.025034401	-0.008076623
+41054226	2612756	261276	2	-0.025058971	0.073179454
+41639591	2576863	257686	2	-0.024393047	-0.009273964
+43264791	34776808	3477681	2	-0.024588353	0.002658587
+45270235	42001029	4200103	2	-0.024909449	-0.013813483
+40573507	37208121	3720812	2	-0.025022259	-0.016655685
+41804308	34497515	3449752	2	-0.02406879	-0.021501468
+45150990	36102196	3610220	2	-0.025004177	0.074511181
+45693413	2617598	261760	2	-0.024027889	-0.011525038
+45006547	35363892	3536389	2	-0.025098537	-0.01872141
+43072716	39577949	3957795	2	-0.024277543	-2.42E-05
+41804759	35341188	3534119	2	-0.024866937	-7.94E-06
+41403418	38972801	3897280	2	-0.024107057	-0.018555228
+46363275	42715628	4271563	2	-0.023683683	0.014208629
+48119701	37961940	3796194	2	-0.024876257	-0.000790822
+47577051	37858056	3785806	2	-0.024823569	-0.013845496
+45459699	36756661	3675666	2	-0.024904757	0.06480035
+38304869	2439114	243911	2	-0.024258135	-0.013549981
+44650800	35811792	3581179	2	-0.02634415	0.053925509
+53025536	41018587	4101859	2	-0.025290069	0.077785782
+43807423	35811660	3581166	2	-0.02476727	0.009390752
+41321083	17525648	1752565	2	-0.025154623	0.012369645
+42726242	34459773	3445977	2	-0.024374979	-0.021057923
+43561203	39577949	3957795	2	-0.024514588	0.005284107
+45887187	37859049	3785905	2	-0.024703732	0.004511225
+45577554	36217775	3621778	2	-0.024863912	0.014822718
+46004470	42831819	4283182	2	-0.024923376	-0.002060998
+41619660	39558786	3955879	2	-0.024584866	-0.006223263
+47034848	2538929	253893	2	-0.025300532	0.019264541
+47432403	41625283	4162528	2	-0.024749951	0.016231033
+45776290	38575577	3857558	2	-0.024039941	-0.010392116
+47370545	35811063	3581106	2	-0.024569439	0.002680496
+47222335	36217775	3621778	2	-0.024721228	-0.004386868
+43028293	34459773	3445977	2	-0.024467387	0.00172024
+47246255	40759517	4075952	2	-0.024413232	-0.021209609
+47335954	36217775	3621778	2	-0.024324357	0.003486549
+47140493	37569452	3756945	2	-0.025218025	0.062656907
+45743395	36217775	3621778	2	-0.025186389	0.069672722
+46236757	36217775	3621778	2	-0.024844392	0.074292592
+46770790	36217775	3621778	2	-0.025129262	0.063633113
+46200520	36642444	3664244	2	-0.024914028	-0.006969076
+45017473	34461207	3446121	2	-0.024421884	-0.002956895
+51215653	35850975	3585098	2	-0.024461991	-0.02368714
+45726467	36217775	3621778	2	-0.025113826	0.062500421
+52471210	42607843	4260784	2	-0.024856326	-0.004190354
+45017162	34461207	3446121	2	-0.024490918	-0.00887188
+47041514	35850975	3585098	2	-0.024946063	-0.018675994
+52500251	40698711	4069871	2	-0.024800457	-0.000441
+46985223	2544920	254492	2	-0.024453481	0.007770489
+50891015	36217775	3621778	2	-0.025068757	0.059398632
+43344728	34461207	3446121	2	-0.024442023	-0.008611893
+46030007	41640147	4164015	2	-0.024139058	-0.006733739
+46575445	38181444	3818144	2	-0.024580927	-0.011398913
+44111699	34497091	3449709	2	-0.0242375	-0.0108162
+40449468	34865161	3486516	2	-0.024501548	-0.018104262
+45970046	35060624	3506062	2	-0.024588317	-0.012496732
+46031565	35850975	3585098	2	-0.024540824	-0.019649145
+43154243	35583106	3558311	2	-0.024831076	-0.009955465
+46453006	36217775	3621778	2	-0.025594148	0.060884762
+47634180	36217775	3621778	2	-0.025310767	0.063715723
+46366161	36217775	3621778	2	-0.024553978	-0.007469876
+52002386	40291988	4029199	2	-0.024405174	-0.004828132
+52427930	40291988	4029199	2	-0.024705018	-0.011478194
+39968325	2590139	259014	2	-0.02456129	0.001680496
+46115142	36217775	3621778	2	-0.024506301	0.078858181
+51451900	36828929	3682893	2	-0.024304106	-0.006023824
+46164434	36721591	3672159	2	-0.024921	-0.014448996
+46570408	36217775	3621778	2	-0.025322554	0.064988768
+44842278	2601548	260155	2	-0.024466711	-0.009540815
+34790786	2238149	223815	2	-0.024521344	-0.008941296
+45437503	2594123	259412	2	-0.024009972	-0.012432829
+37569202	2672528	267253	2	-0.024021786	-0.015860243
+44587463	40940517	4094052	2	-0.024210131	-0.012150762
+44883330	35583106	3558311	2	-0.024543341	0.004887309
+47813045	37858056	3785806	2	-0.024662538	0.004378023
+46466824	37858056	3785806	2	-0.024655033	-0.008878927
+47733101	36217775	3621778	2	-0.024893336	0.068239975
+35583291	2672344	267234	2	-0.024723814	-0.021053805
+42205987	39089125	3908913	2	-0.023926059	-0.014773981
+46989648	43767841	4376784	2	-0.024812366	-0.014254086
+39772723	2517660	251766	2	-0.024817194	-0.008722289
+43098579	2590050	259005	2	-0.024749378	-0.024861963
+42547971	34497515	3449752	2	-0.02471227	-0.016072192
+45045355	34459804	3445980	2	-0.024402055	-0.008150275
+50826407	35363654	3536365	2	-0.024145969	-0.015614387
+41051130	36350161	3635016	2	-0.024124383	-0.013948312
+43265542	34776691	3477669	2	-0.024157407	-0.009789376
+47909127	36217775	3621778	2	-0.024370237	-0.011173287
+43132378	35341188	3534119	2	-0.024428367	-0.002886907
+45046946	34459804	3445980	2	-0.024789094	-0.004497078
+42751768	2590050	259005	2	-0.024545471	-0.006940315
\ No newline at end of file
